[Mapbender-commits] r3116 - branches/noframes/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 3 10:48:14 EDT 2008
Author: christoph
Date: 2008-10-03 10:48:14 -0400 (Fri, 03 Oct 2008)
New Revision: 3116
   branches/noframes/http/javascripts/map_obj.js
   branches/noframes/http/javascripts/mod_dragMapSize.php
bug fix in convertClickToReal
Modified: branches/noframes/http/javascripts/map_obj.js
--- branches/noframes/http/javascripts/map_obj.js	2008-10-03 14:28:39 UTC (rev 3115)
+++ branches/noframes/http/javascripts/map_obj.js	2008-10-03 14:48:14 UTC (rev 3116)
@@ -154,7 +154,6 @@
 	var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
 	this.calculateExtent(wmsExtent);
-	console.log("ext: %s, %s", this.frameName, this.extent);
 	this.mapURL = [];
 	if(this.frameName){
@@ -377,8 +376,8 @@
 		else{
 			roundy =  performUnknownCalculation(deltaY);
-		var posX = parseFloat(minX + (aPoint.x / width) * xtentx);
-		var posY = parseFloat(maxY - (aPoint.y / height) * xtenty);
+		var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
+		var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
 		posX = Math.round(posX * roundx) / roundx;
 		posY = Math.round(posY * roundy) / roundy;
 		return new Point(posX, posY);
Modified: branches/noframes/http/javascripts/mod_dragMapSize.php
--- branches/noframes/http/javascripts/mod_dragMapSize.php	2008-10-03 14:28:39 UTC (rev 3115)
+++ branches/noframes/http/javascripts/mod_dragMapSize.php	2008-10-03 14:48:14 UTC (rev 3116)
@@ -90,8 +90,9 @@
 		mb_arrangeElement('', "dragMapSize", dif_x, dif_y);
 		return;
-	var pos =  makeClickPos2RealWorldPos(mod_dragMapSize_target, (parseFloat(mb_mapObj[ind].width) + parseFloat(dif_x)), (parseFloat(mb_mapObj[ind].height) + parseFloat(dif_y)));
+	var newX = (parseFloat(mb_mapObj[ind].width) + parseFloat(dif_x));
+	var newY = (parseFloat(mb_mapObj[ind].height) + parseFloat(dif_y));
+	var pos =  makeClickPos2RealWorldPos(mod_dragMapSize_target, newX, newY);
 	mb_mapObj[ind].width = parseFloat(mb_mapObj[ind].width) + parseFloat(dif_x);
 	mb_mapObj[ind].height = parseFloat(mb_mapObj[ind].height) + parseFloat(dif_y);
More information about the Mapbender_commits mailing list
