[Mapbender-commits] r3131 - branches/print_dev
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 6 07:41:28 EDT 2008
Author: verenadiewald
Date: 2008-10-06 07:41:28 -0400 (Mon, 06 Oct 2008)
New Revision: 3131
   branches/print_dev/Changes.txt
   branches/print_dev/Install.txt
Modified: branches/print_dev/Changes.txt
--- branches/print_dev/Changes.txt	2008-10-06 11:40:58 UTC (rev 3130)
+++ branches/print_dev/Changes.txt	2008-10-06 11:41:28 UTC (rev 3131)
@@ -1,419 +1,590 @@
-The following Link gives a review on the changes in Mapbender you can get in the WIKI
-http://www.mapbender.org/index.php/Version_History
-Changelog 2.4.2
-  english
-    bug fixes: see http://trac.osgeo.org/mapbender/report/9
-    new features
-    * set WMS opacity in treeGDE2
-    * Bulgarian translation of the introduction to Mapbender
-    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
-    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
-    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
-    * poi (not included in a GUI yet)
-    * JavaScript compression; Mapbender will load faster
-    * dynamic overview - integration in the rc1 an testing gui2
-    * treeGDE2 replaces treeGDE
-    * different configurations of treeGDE2
-    * first draft of an API documentation for JavaScript classes
-    * print temporary objects (lines and polygons) which where drawn with the measure element
-  deutsch
-    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
-    neue Features
-    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
-    * Bulgarische Übersetzung der Mapbender-Einführung
-    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
-    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
-    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
-    * poi (noch in keiner GUI enthalten)
-    * JavaScript Kompression; Mapbender lädt schneller
-    * Dynamisches Overview
-    * TreeGDE2 ersetzt die alte Baumstruktur
-    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
-    * vorläufige API Dokumentation für JavaScript Klassen
-    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
-Changelog 2.4.1
-english
-new features
-bug fixes
-    * 1658777 Export GUI SQL unsorted
-    * 1634035 Wfs geometry name not sorted by position
-    * 1647206 sort order of modules in gui element list
-    * 1635839 JS error: document.form1.newGuiName has no properties
-    * 1589764 wms loading problems when abstract contain linebreak
-    * 1653348 mod_filteredGroup_filteredGui.php
-    * 1653160 Metadata: Undefined variable: wms_id
-    * 3 Online resource incorrect in monitoring module
-    * 11 wrong sort order in edit_gui_wms
-database changes
-see latest database changes.
-deutsch
-Changelog Mapbender 2.4.1 rc1
-english
-    * changes in database architecture: For update have a look in the wiki at dbchanges or Database_Changes_2.4.1. The update sqls you find in the download package in the folder mapbender/resources/db/update/
-    * WFS_gazetteer possibility to handle several wfs_confs and choose from a select-box - thanx to User:Verena Diewald
-    * new treeGDE - thanx to User:Melchior Moos
-    * new element setPOI2Scale mod_setPoi2Scale to open a GUI at a special coordinate and scale - have a look Mod_setPoi2Scale
-    * extended ResizeMapsize functionality - Modul can act automatically or by button click. 3 element vars are added.
-    * new administration functionality OrphanWMS to find information about orphaned WMS and to fix them.
-    * new functionality meetingPoint to generate meeting points and export them as text or via email. The url can be displayed by highlightPOI
-    * pdf-Print now with Din-A2 support
-    * new element highlightPOI (mod_highlightPOI.php) to open a gui and set poi points with text
-    * metadata handling
-    * new admin guis
-    * wfs bug fix for digitize modul
-    * featureinfo tunnel closes empty result windows automatically
-deutsch
-    * Änderungen in der Datenbankarchitektur: Angaben im Wiki unter dbchanges oder Database_Changes_2.4.1. Die update-sqls befinden sich im Download-Paket im Verzeicnis mapbender/resources/db/update/
-    * WFS_gazetteer Auswahlmöglichkeit zwischen mehreren WFS-Konfigurationenüber eine Auswahlliste - thanx to User:Verena Diewald
-    * treeGDE - neue Baumstruktur - thanx to User:Melchior Moos
-    * Neues Modul add_vendorspecific.
-    * Neues Element setPOI2Scale um eine GUI an einen Punkt in einem bestimmten Maßstab zu öffnen Mod_setPoi2Scale.
-    * Erweiterung des Moduls resizeMapsize. Kartenfenster kann sich automatisch an die Browsergröße anpasssen oder über einen Button. 3 Element vars wurden hinzugefügt.
-    * Neues Administrationselement OrphanWMS, dass informationen über verwaiste WMS liefert und diese löschen kann.
-    * Neues Element meetingPoint um Treffpunkte zu generieren und diese als Text oder via E-Mail zu exportieren. Die URL kann durch highlightPOI angezeigt werden.
-    * pdf-Print nun auch mit Din-A2 Unterstützung (Dank an Frank Härtel und Horst Becker).
-    * Neues Element highlightPOI (mod_highlightPOI.php) ermöglicht es beim Öffnen einer GUI ein oder mehrere Punkte mit Beschriftung zu setzen.
-    * Metadaten handling.
-    * Featureinfotunnel schließt leere Fenster ohne Ergebnis gleich wieder.
-english
-    * bugs in loadWMC are fixed
-    * new module resizeMapsize to resize the Mapsize depending on the size of the browser window
-    * new module monitorCapabilities: periodically checks all WMS and gathers data in the new table mb_monitor (see Database_Changes_2.4)
-    * new module initWMC: starts the client with a wmc.
-    * wms_extent - WMS representing the EXTENTs of the WMS loaded in Mapbender
-deutsch
-    * Bugs im Modul loadWMC wurden behoben.
-    * Neues Modul resizeMapsize das Modul paßt die Kartengröße in Abhängigkeit von der Größe des Browserfensters dynamisch an.
-    * Neues Modul monitorCapabilities: periodisch werden alle WMSe kontrolliert und alle Daten in der neuen Tabelle mn_monitor erfaßt (siehe auch Database_Changes_2.4).
-    * Neues Modul initWMC: startet den Client mit einem WMS.
-    * wms_extent - WMS, der die Ausdehnungen (Extent) der in Mapbender geladenen WMSe anzeigt.
-Changelog 2.4 rc2
-english
-    * mapbender changed to Subversion (svn), big effort is done in code cleaning
-    * owsproxy is implemented
-    * treeGDE improved, now there is the possibility to handle the layers of a wms with one click (all layer on / all layer off). new element var switchwms
-    * bugs in legend solved
-    * changes in database architecture: new table wfs_featuretype_namespace, new column wms_owsproxy in table wms, new column wms_upload_url in table wms. For update have a look at dbchanges or Database Changes 2.4
-    * perpared statements for PHP > 5.1.x, PostgreSQL > 7.4
-    * new gui_digitize in the installation package. Read more about Digitizing
-    * new gui2 in the installation package with new buttons (button_blue), new tree-style (tree_blue) and more color.
-    * default md5-encryption for the passwords in MySQL and PostgreSQL. Mapbender is doing the md5-encryption.
-    * extended mapbender_setup.php with more information (Thanks to Marko Samson)
-    * new element deleteWFS in GUI admin1
-    * printPDF: highquality print and matching for the overview image
-    * new help: every element in the gui refers to a page in the Mapbender wiki. The link is saved in the table gui_element column e_url and can be changed individual.
-deutsch
-    * Mapbender wechselt zum Subversion (svn) mit dem damit verbundenen Code cleaning
-    * owsproxy
-    * treeGDE wurde verbessert, es gibt nun die Möglichkeit alle Layer eines WMS durch einen Klick an- bzw. auszustellen.
-    * Bugs in der Legende behoben
-    * Veränderungen in der Datenbankarchitektur: neue Tabelle wfs_featuretype_namespace, neue Spalte wms_owsproxy in Tabelle wms, neue Spalte wms_upload_url in Tabelle wms. Um eine bestehende Datenbank zu aktualisieren, gibt es unter dbchanges weitere Informationen. Database Changes 2.4
-    * Es besteht die Möglichkeit Perpared Statements ab PHP > 5.1.x, PostgreSQL > 7.4 einzusetzen
-    * Neue gui_digitize im Installationsumfang. Mehr unter Digitizing
-    * Neue gui2 im Installationsumfang mit neuen Buttons (button_blue), neuem Style für die Baumstruktur (tree_blue) und mehr Farbe
-    * Standardmäßige md5-Verschlüsselung des Passworts in MySQL und PostgreSQL. Mapbender verschlüsselt nun das Passwort, nicht die Datenbank.
-    * mapbender_setup.php liefert nun mehr Informationen und weist auf Fehler hin (Danke an Marko Samson)
-    * Neues Element deleteWFS in der GUI admin1
-    * printPDF: für den Overview ist nun auch der hochqualitative Druck und das Matching möglich
-    * Hilfebutton: jedes Element der GUI ist direkt mit der Hilfeseite im Mapbender Wiki verlinkt (Eintrag in der Tabelle gui_element Spalte e_url). Dieser Link kann an die jeweilige Umgebung angepaßt werden.
-Changelog 2.2.3
-english
-    * print: now with overview window with position rectangle and scalebar
-    * gui_de and gui1_de are no longer part of the standard installation of mapbender, as it is too much work to handle 4 guis. If you want a german gui, you have to change the tool tip texts. In the next versions we want to handle the language differences with element vars.
-    * WMC handling: includes DisplayWMC, loadWMC, saveWMC and listWMC.
-    * element logout: now with element_var logout_location to define the webside to show after logout
-    * the overview window of the pdf-print is now displayed in highquality, if you use highquality = true in your print-configuration
-    * there has been some rework done at the AddWMS functions. Now the mod_addWMSgeneralFunctions.js offers the functions mod_addWMS_load and mod_addWMS_refresh to the elements addWMSfromfilteredList and addWMSfromList IMPORTANT: JS has to be added as modul in the element-definition
-    * element tabs (mod_tab.php) now with element_var open_tab to decide which tab should be opened at the beginning
-    * print : there where errors in the generation of the legend especially with grouped layers
-    * legend : new element_var checkbox_on_off to decide wether you want to show or hide the on/off checkbox - there where errors in the generation of the legend especially with grouped layers
-    * legend: new element var : stickylegend to decide wether the legend should stick at the mapframe1
-    * connection to GEOS function for mysql users: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - database parameters where added to the mapbender.conf to enable Mapbender user with mysql-Administration to transform and change the projection
-    * encoding of Mapbender: now UTF-8 or ISO-8859-1 can be choosed as the encoding for the database (have a look in the mapbender.conf CHARSET)
-    * fixed: WFS configuration caused errors with postgresql database
-    * copyright now works with element var for the copyright text: define the JavaScript Variable mod_copyright_text with a text you want as value
-    * fixed: there was an error in class_log, now the printed maprequests should be logged
-    * database changes
-deutsch
-    * print: nun mit Übersichtsfenster mit Positionsrechteck und Maßstabsleiste (beide Funktionalitäten können in der Konfigurationsdatei des Drucks an- oder ausgestellt werden)
-    * Die Oberflächen gui1_de und gui_de werden nicht mehr weitergeführt, da es zu viel Aufwand darstellt 4 Oberflächen weiterzuführen. Wenn eine deutsche Oberfläche gebraucht wird können die ToolTipTexte auf deutsch angelegt werden. Die Mehrsprachigkeit der einzelnen Elemente soll zukünftig über die Element vars gelöst werden.
-    * WMC-Nutzung: beinhaltet anzeigen (DisplayWMC), laden (loadWMC), speichern (saveWMC) eines WMCs und auflisten aller WMCs (listWMC).
-    * Element logout: verfügt nun über den element_var logout_location, um zu definieren welche Webseite nach dem Logout angezeigt werden soll.
-    * Das Übersichtsfenster des PDF-Drucks wird nun auch hochqualitativ angezeigt bei hochqualitativem Druck.
-    * Die AddWMS Funktionalität wurde überarbeitet. Eine neue Datei mod_addWMSgeneralFunctions.js stellt nun die Funktionen mod_addWMS_load und mod_addWMS_refresh zur Verfügung. Wichtig für die Elemente addWMSfromfilteredList and addWMSfromList das JavaScript mod_addWMSgeneralFunctions.js muß in der Elementdefinition unter Modul angegeben werden.
-    * Element tabs (mod_tab.php) wurde um die element_var open_tab erweitert, um beim Start des Clients einen tab voreingestellt zu öffnen.
-    * print: Fehler in der Legende bei gruppierten Ebenen beseitigt.
-    * legend: Neue element_var: checkbox_on_off zur Steuerung der on/off checkbox.
-    * legend: Neue element_var: stickylegend zur Steuerung des Anzeigefesters der Legende (Positionierung / sticky-Frame).
-    * Bereitstellung der GEOS Funktionen für Mapbender mit mysql-Administrationsdatenbank: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - Zusätzliche Datenbankparameter für eine PostgresDB neben der mysql-Administrationsdatenbank, zur Transformation von Projektionssystemen und Berechnung von Flächen.
-    * Encoding (Zeichensatz) in Mapbender: es besteht nun die Auswahl zwischen UTF-8 oder ISO-8859-1 als Zeichensatz (die Angabe erfolgt in der mapbender.conf CHARSET)
-    * wfs configuration: WFS Konfiguration erzeugte Fehler mit der PostgreSQL-Datenbank.
-    * copyright: Neue element_var mod_copyright_text, Angabe zum Copyright-Text über die Administrationsoberfläche.
-    * fixed: Fehler in class_log behoben.
-    * Datenbankänderungen
-Changelog 2.2.2
-english
-    * Unfortunately there was a bug left in the PostgreSQL database-module. In the edit gui-menu no templates from other guis were shown so that it was impossible to modify guis.
-To fix this, minor changes in the PostgreSQL database-structure were necessary. If you are updating, please do not use an already existing V. 2.2.1-database and create the database with the SQL-dumps attached to this version instead.
-deutsch
-    * Leider war noch ein Fehler im PostgreSQL Datenbank-Modul übersehen worden. Da im Menü Oberflächenelemente editieren die bestehenden GUIs und deren Elemente nicht angezeigt wurden, um sie als Templates zu verwenden, ließen sich die GUIs nicht nach den eigenen Bedürfnissen anpassen.
-Um diesen Fehler zu beheben wurden kleinere Änderungen in der PostgreSQL Datenbank-Struktur vorgenommen. Bitte verwenden Sie daher keine bereits existierende V. 2.2.1-Datenbank falls Sie updaten, sondern benutzen Sie bitte die SQL-Dumps, die dieser Version beigefügt sind.
-Changelog 2.2.1
-english
-We have been a bit quick with the release 2.2 and didn't put the focus on documentation and debugging. But with the help of the users of Mapbender we fixed the bugs and now there is the next Mapbender version for download.
-    * There where some bugs when you run Mapbender with PostgreSQL. Hope they are fixed. Have a look at the Installation to find out about how to configure Mapbender (configuration files have been consolidated into ./conf/mapbender.conf)
-    * the name of two columns had to be changed:
-          o mb_log.session changes to mb_log.mb_session (session is a reserved name in postgresql)
-          o gui_element.e_closeTag changed to gui_element.e_closetag (all table- and columnnames are handled in lower case)
-    * Sequences in PostgreSQL: if you use postgresql you have to set sequences for the serial columns so that the next value for the serial is fixed. user mapbender/resources/db/pgsql_serial_set_sequences.sql to set the sequences
-    * changeEPSG and calculating areas at the moment is only possible for user with PostgreSQL/PostGIS database
-deutsch
-Vielleicht waren wir etwas voreilig mit dem Mapbender Release 2.2 und haben den Fokus nicht auf die Dokumentation und das Debuggig gesetzt. Aber mit Hilfe der User sind viele Fehler aufgezeigt worden und konnten gelöst werden. Hier nun der neue Mapbender 2.2.1. Derzeit gibt es noch keine Dokumentation und auch kein Skript für den automatisierten Update einer bestehenden Mapbender Installation. Die vormals eingesetzen Skripte mapbender_setup.php und validate_db.php können derzeit nicht mehr verwendet werden und wurden aus dem Paket entfernt. Die Skripte müssen erst wieder auf den neuen Release angepaßt werden, damit sie wieder zum Einsatz kommen können.
-    * es lagen einige Bugs bei der Verwendung von PostgreSQL als Administrationsdatenbank vor. Diese sind hoffentlich alle beseitigt. In der Installationsanleitung unter
-mapbender.conf findet sich alles wichtige zur Installation (Alles ist nun einfacher. Es muß nur noch die Datei mapbender.conf angepaßt werden)
-    * der Name zweier Spalten hat sich geändert:
-          o mb_log.session geändert in mb_log.mb_session (session reserviertes Wort in PostgreSQL)
-          o gui_element.e_closeTag geändert in gui_element.e_closetag (alle Tabellen- und Spaltennamen in Kleinbuchstaben)
-    * Sequences in PostgreSQL: bei der Verwendung von PostgreSQL müssen die Sequenzen der Autowerte nach dem Laden der Daten explizit gesetzt werden. Dazu steht die Datei mapbender/resources/db/pgsql_serial_set_sequences.sql zur Verfügung
-    * changeEPSG und Flächenberechnung steht derzeit nur Benutzern mit einer PostgreSQL-Datenbank zur Verfügung
-Changelog 2.2.0
-[edit]
-english
-Here you find a list with the changes in Mapbender 2.2.0:
-    * The configuration files have been consolidated into one single mapbender.conf
-    * Now Mapbender 2.2.0 is able to work with MySQL- or PostgreSQL-database. Configure the settings in the mapbender.conf.
-    * You can edit the single elements of a GUI with the Mapbender-Administration (table element_vars/ css-files/ var).
-    * WFS
-    * Proxy
-    * PrintPDF. This module enables you to configure the PrintPDF containing an overview, legend, northarrow and your logo.
-    * Click on a Layer refers to the WMS METADATAURL - new column layer_metadataurl.
-    * The legend is displayed by the LEGENDURL.
-    * New Wiki: To edit the new wiki you have to ask for an account at mailto:info at mapbender.org.
-    * ToggleModule to define a function to be active when the gui is opened
-Here you already find a list with the changes in Mapbender 2.2:
-    * Mapbender for MySQL or PostgreSQL
-    * click on a Layer refers to the WMS METADATAURLD - new column layer_metadataurl
-    * the legend is displayed by the LEGENDURL
-deutsch
-Hier die Änderungen, die mit der Version 2.2 erfolgt sind:
-    * Nun ist es möglich Mapbender mit einer MySQL- oder PostgreSQL-Datenbank zu installieren. Konfigurieren Sie die Einstellungen in der Datei mapbender.conf.
-    * Sie können die einzelnen Elemente einer GUI mit der Mapbender-Administration editieren (Tabelle element_vars/ css-files/ var).
-    * WFS
-    * Proxy
-    * PrintPDF. Dieses Modul erlaubt es dem Benutzer den PrintPDF zu konfigurieren und beinhaltet Overview, Legende, Nordpfeil und ein Logo.
-    * Neue Buttons (button_oo) sind in der GUI 'gui' verfügbar.
-    * Ein Klick auf einen Layer referenziert die WMS METADATAURL - neue Spalte layer_metadataurl.
-    * Die Legende wird durch die LEGENDURL dargestellt.
-    * Neues Wiki: Um im neuen Wiki editieren zu können, müssen Sie einen Account beantragen bei CCGIS.
-    * ToggleModule - definiert ein Element, das beim Start der GUI aktiviert sein soll
-Hier aber schonmal die Änderungen, die uns mit der Version 2.2 erwarten:
-    * Mapbender für MySQL oder PostgreSQL
-    * Anpassung der einzelnen Elemente einer GUI über die Mapbender-Administration (element_vars)
-    * Metadataurl
-    * Legendurl
-Changelog 2.1.0
-english
-    * communication by email mail.conf
-    * new button myGUIlist in the administration-guis to go back to the list of myGUIs
-    * New table mb_log
-    * New column in table wms wms_getCapabilities_doc
-    * ChangeEpsg_dynamic
-    * Edit gui shows the images of a gui as little pictures (better orientation)
-    * sql to update the mapbender standard guis Update Mapbender
-    * mapbender/http/tools/validate_db.php - php to update the database and add new columns and tables if necessary
-    * New column layer_dataurl in table layer
-    * New columns legendurl and legendurlformat in table layer_style
-    * New table wms_srs
-    * Security update in Edit GUI Elements
-deutsch
-    * Kommunikation über email mail.conf
-    * Neuer Button myGUIlist für die Administrations-GUIs, um in die Liste von meinenGUIs zurück zu kommen.
-    * Neue Tabelle mb_log
-    * Neue Spalte in der Tabelle wms wms_getCapabilities_doc
-    * Die Rubrik 'Oberflächenelemente editieren' zeigt nun kleine Bilder der Oberfläche zur besseren Orientierung.
-    * SQL zur Aktualisierung Ihrer GUIs: siehe Update Mapbender
-    * mapbender/http/tools/validate_db.php - PHP, um die Datenbank zu aktualisieren und wenn nötig neue Spalten und Tabellen hinzuzufügen.
-    * Neue Spalte layer_dataurl in der Tabelle layer hinzugefügt.
-    * Neue Spalten 'legendurl' und 'legendurlformat' in der Tabelle layer_style hinzugefügt.
-    * Neue Tabelle wms_srs
-Changelog 2.1.0 rc1
-english
-    * Print with Mapbender Version 2.1.0 pdf-print is used as standard. You have the possibility to choose A4 or A3 and landscape or portrait. The printframe can be styled to your own design by editing a configuration file.
-    * GUIOwner a new parameter <owner> has been added to the user management. This allows a distinction between reading/using a GUI and being allowed to change it ( edit GUI elements). This feature is necessary as a preliminary step to open Mapbender as a portal with anonymous access which is needed to implement Wikimaps functionality. Additionally this enables setting up a hierarchical administration.
-    * Overview The overview map should be addressed with the module Overview, (<Overview0>, <Overview1>, <Overview2>, ... are deprecated). The module can be parameterized with the field "wms". It contains the index of the WMS which should be displayed in the overview map. (starting at 0).
-    * showCoords_div On button click the coordinate of the mouseposition will be displayed below the target (e.g. mapframe1)
-    * Detailed metadatainformation for a GUI. Also information about the last requests as a link.
-    * Additional default GUIs are added to the Mapbender database.
-    * After installing Mapbender a set of worldwide WMS are already contained in several GUIs.
-    * Copy a GUI copyGUI / rename a GUI RenameGUI.
-    * AddWMS Add a new web map service dynamically by entering the URL to an OGC WMS Capabilities document. Current extent, layers and settings are not affected.
-    * Add WMS from list Dynamically add WMS from a list of all OGC WMS contained in the Mapbender database to the current GUI.
-    * Add WMS from filtered list Dynamically add WMS from a list (filtered by group or gui) to a GUI.
-    * setBackground Define several WMS to be displayed in the background.
-    * setBackground_all You can define one or more WMS to be displayed in the background.
-    * DeleteGUI Delete a selected GUI.
-    * DeleteWMS Delete a selected WMS.
-    * Edit GUI Elements - added: GUI description editable.
-    * Edit GUI WMS - added: show WMS ID.
-    * showCoords_div - shows the coordinate below the target (i.e. mapframe1).
-    * setScaleHint - set scale hints for mapframes.
-    * tabs_vertical - handle iframes with vertical tabs.
-    * WMS_preferences - edit service settings of the loaded WMS, change order, remove wms, change settings.
-deutsch
-    * Print Ab der Mapbender Version 2.1.0 erfolgt der Standardausdruck von Mapbender als PDF. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat. Der Kartenspiegel kann dabei über eine Konfigurationsdatei an das eigene Design angepaßt werden. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat.
-    * GUIOwner Der neue Parameter <owner> (Besitzer) wurde der Benutzerverwaltung hinzugefügt. Dies erlaubt eine Unterscheidung zwischen lesen/benutzen einer GUI und der Berechtigung die GUI zu ändern ( edit GUI elements). Dieses Feature ist notwendig als Vorbereitung Mapbender als Portal mit anonymem Zugang einzusetzen, was wiederum notwendig ist, um Wikimap-Funktionalität zu implementieren. Zusätzlich ermöglicht diese Einstellung den Aufbau einer hierarchischen Verwaltung.
-    * Overview Die Übersichtskarte sollte mit dem Modul Overview adressiert werden (<Overview0>, <Overview1>, <Overview2>, ... wurden eingestellt). Das Modul kann mit dem Feld "wms" parametriert werden. Es beinhaltet den Index des WMS, der nicht in der Übersichtskarte angezeigt werden sollte (beginnend bei 0).
-    * showCoords_div Bei Aktivierung dieses Buttons werden die Koordinaten der Mausposition unter dem Ziel (target = z.B. mapframe1) angezeigt.
-    * Detaillierte Metadatainformationen für eine GUI. Ebenso Information über die letzte Anfrage als Link.
-    * Zusätzliche Standard-GUIs wurden der Mapbender Datenbank hinzugefügt.
-    * Nach der Installation von Mapbender ist bereits ein Set von weltweiten WMSen in verschiedenen GUIs enthalten.
-    * Kopieren einer GUI copyGUI / Umbenennen einer GUI RenameGUI.
-    * AddWMS Dynamisches Hinzufügen eines neuen Web Map Services durch die Eingabe der URL in ein OGC WMS Capabilities Dokument. Der aktuelle Ausschnitt, Layer und Einstellungen sind davon nicht betroffen.
-    * Add WMS from list Dynamisches Hinzufügen eines WMS von einer Liste von allen OGC WMS, die in der Mapbender Datenbank enthalten sind für die aktuelle GUI.
-    * Add WMS from filtered list Dynamisches Hinzufügen eines WMS von einer Liste (gefiltert für eine Gruppe oder GUI) für eine GUI .
-    * setBackground Definiert einige WMS, die im Hintergrund angezeigt werden.
-    * setBackground_all Definieren Sie hier einen oder mehrere WMS, die im Hintergrund angezeigt werden.
-    * DeleteGUI Löschen einer ausgewählten GUI.
-    * DeleteWMS Löschen eines ausgewählten WMS.
-    * Oberflächenelemente editieren (Edit GUI Elements) - Hinzugefügt: GUI Beschreibung editierbar.
-    * WMS GUI Einstellungen (Edit GUI WMS/ WMS GUI settings) - Hinzugefügt: Anzeige der WMS ID.
-    * showCoords_div - Anzeige der Koordinaten unter dem Ziel (target, z.B. mapframe1).
-    * setScaleHint - Setzen eines Maßstabes für Kartenframes.
-    * tabs_vertical - Handhaben von Iframes mit vertikal Karteireitern.
-    * WMS_preferences - Bearbeiten der Einstellungen eines Dienstes eines geladenen WMS, Änderung der Reihenfolge, Entfernen eines WMS, Änderung der Einstellungen.
\ No newline at end of file
+The following Link gives a review on the changes in Mapbender you can get in the WIKI
+http://www.mapbender.org/index.php/Version_History
+Also have a look in the trac for detailed informations:
+http://trac.osgeo.org/mapbender/report/6
+Changelog 2.5
+#264  	ISO dump contains UTF characters  	closed  	09/29/08
+#298 	remove content in gui_treegde 	closed 	09/29/08
+#288 	gazetteerWFS wfs_conf rights are not handled properly 	closed 	09/29/08
+#282 	DB - Create schema: wrong column name wms_mb_get_capabilities_doc in table wms 	closed 	09/29/08
+#301 	WFS Gazetteer: Sort wfs conf selectbox in order of wfsConfIdString 	closed 	09/26/08
+#31 	move mb_wfs_tolerance to conf file 	closed 	09/25/08
+#300 	PrintPDF: Error if overview image is false 	closed 	09/25/08
+#87 	enable owsproxy to handle wms layer legends 	closed 	09/25/08
+#269 	printPDF: owsproxy and wms - test wether all is working 	closed 	09/25/08
+#299 	MeetingPoint: Insert of Umlaute or Zeilenumbruch is not possible 	closed 	09/24/08
+#297 	featureInfo1 does not work anymore 	closed 	09/18/08
+#286 	SetSpatialRequest 	closed 	09/17/08
+#294 	mod_changePassword.php 	closed 	09/15/08
+#293 	New modul: ShowGuiName 	closed 	09/10/08
+#222 	WFS digitizing failed when using GeoServer 1.6.2 due to missing links in xsi:schemaLocation 	closed 	09/01/08
+#284 	wfsGazetteer - no search result if a geometry field is empty 	closed 	08/29/08
+#285 	PrintPDF: Error in Print using dynamicOverview 	closed 	08/28/08
+#283 	FeatureInfo: Popup divs should not be shown if featureInfo is empty 	closed 	08/28/08
+#280 	prepared statement error occurred at WFS Configuration 	closed 	08/25/08
+#281 	WFS conf: after saving the new configuration the featureType table disappears 	closed 	08/25/08
+#258 	MySQL test for version 2.5 	closed 	08/15/08
+#276 	PrintPDF: Last Measure-Item gets lost if its not a closed Polygon 	closed 	08/15/08
+#277 	WFS update does not cascade changes to wfs_conf 	closed 	08/15/08
+#273 	update GUI SQL doesn't delete element vars? 	closed 	08/15/08
+#268 	Bug in module Meeting Point MB 2.5 rc5: missing target 	closed 	08/15/08
+#179 	treeConfGDE - admin 	closed 	08/15/08
+#261 	WFS and MySQL doesn't work 	closed 	08/12/08
+#265 	print pdf with locale set to de_DE: encoding problems 	closed 	08/12/08
+#183 	printPDF, no link for downloading, no maps 	closed 	08/11/08
+#263 	Error when highlighting digitized objects 	closed 	08/11/08
+#259 	mod_tabs does'nt display characters from element_var 'tab_prefix' 	closed 	08/11/08
+#260 	Setting language with initial request parameter mb_lang fails 	closed 	08/11/08
+#266 	login.php - white screen after 3 times failed login 	closed 	08/06/08
+#121 	Login fails with https protocol 	closed 	08/05/08
+#262 	setlocale with param LC_ALL converts corrupts numerics 	closed 	08/04/08
+#230 	Mapbender /db/update/update_postgresql_db.sql 	closed 	07/28/08
+#154 	i18n and MySQL: a db function has to be written 	closed 	07/25/08
+#205 	selecting print-format changes mapscale 	closed 	07/23/08
+#151 	edit WFS Configuration: set the dialog in alphabetical order 	closed 	07/21/08
+#237 	FeatureInfo: popup title does not appear and the popup-window can´t be moved (IE7) 	closed 	07/21/08
+#256 	setSpatialRequest: 4326 is static epsg code 	closed 	07/21/08
+#226 	Digitize: spatial request show data from layers without selected FeatureInfo 	closed 	07/21/08
+#223 	logging in mb25 	closed 	07/21/08
+#255 	wfs conf: field f_show_detail missing in module wfs configuration 	closed 	07/21/08
+#234 	Adding new WMS does not work 	closed 	07/21/08
+#213 	wms gui settings: changes are not accepted 	closed 	07/21/08
+#238 	Cannot change password in mod_editUser 	closed 	07/21/08
+#210 	"Umlauts" broken, when loading a WMS 	closed 	07/16/08
+#250 	Gui element Module AddWMS needs mod_addWMSgeneralFunctions.js as Module param 	closed 	07/11/08
+#214 	module tabs does not show tabs 	closed 	07/11/08
+#180 	WFS Configuration 	closed 	07/11/08
+#254 	Gettext broken 	closed 	07/08/08
+#198 	jquery in main frame instead of separate ajax module 	closed 	07/08/08
+#233 	test if gettext .po compilation is necessary on new installation 	closed 	07/08/08
+#249 	Measure: No measure lines drawn after upsizing mapframe width and height 	closed 	07/01/08
+#248 	AddWMSfromList + AddWMSfromFilteredList don't use OWSPROXY when loading WMS 	closed 	06/30/08
+#241 	Query WMS does not work if no layers are selected as "info_default" 	closed 	06/17/08
+#240 	"the_geom" hard wired in class_gml2.php 	closed 	06/10/08
+#239 	JSON encoding faulty (using PEAR library) 	closed 	06/09/08
+#235 	popup.js - error: every popup gets ID 150 	closed 	06/05/08
+#212 	capabilities-upload does not work 	closed 	06/04/08
+#204 	added same wms twice into a gui 	closed 	05/19/08
+#221 	setSpatialRequest did not form correct getFeature-Request, in some cases & was missing 	closed 	05/16/08
+#218 	PEAR JSON not functional, native JSON works 	closed 	05/07/08
+#217 	Application w/ digitizing module won't load in IE 	closed 	05/07/08
+#157 	transfer dbchanges wiki site to update SQL in SVN 	closed 	05/01/08
+#130 	monitoring checks if a reachable WMS returns images or error msgs 	closed 	05/01/08
+#216 	WMS Metadata metadataurl included, minscale, maxscale presentation changed 	closed 	05/01/08
+#215 	gazetteerMetadata does not work as script mod_gazetteerMetadata_search.php moved to /php 	closed 	05/01/08
+#201 	load WMC fails / WMC does not contain layer data 	closed 	04/18/08
+#161 	Remove GUI element "geometry" from all GUIs 	closed 	04/15/08
+#192 	geoportal.con must be removed 	closed 	04/15/08
+#185 	WMC 	closed 	04/15/08
+#206 	Resize mapframe1 before loading WMS maps 	closed 	04/08/08
+#197 	LOAD myWMS doesn't copy gui_layer_wfs_featuretype and gui_layer_style 	closed 	04/07/08
+#181 	personally uploaded WMS services do not appear in list "Add to GUI" 	closed 	03/19/08
+#194 	a fisheye style menubar 	closed 	03/14/08
+#141 	move mb_feature_count from map.js to conf file 	closed 	03/06/08
+#170 	move LOG_LEVEL_LIST to system.php 	closed 	03/06/08
+#155 	hard wired version number (php file) 	closed 	03/06/08
+#184 	Module measure (gui1) 	closed 	03/06/08
+#1 	    Initialize GUI with WMC error 	closed 	03/06/08
+#188 	New Button to export the Mapimage to png, jpeg or geotiff 	closed 	03/06/08
+#122 	SLD creation from scratch 	closed 	03/06/08
+#182 	Delete GUI 	closed 	03/06/08
+#91 	wfs_conf: delete WZ-Graphics-checkbox 	closed 	03/06/08
+#44 	SLD Integration 	closed 	03/06/08
+#173 	Digitize GUI broken on wheregroup/mapbender_dev 	closed 	02/18/08
+#126 	overview incorrect after load WMC 	closed 	02/02/08
+#128 	store ScaleHints in WMC 	closed 	02/02/08
+#10 	MySql Error (near: version=''1.'' encoding=) 	closed 	02/02/08
+#8 	    prepared statements w/ MB 2.4, PGIS 8.1.x and php5.2.x 	closed 	02/02/08
+#71 	mod_help for modules in tabs 	closed 	01/28/08
+#86 	Mapbender - logging the MapRequests from the guis in the table mb_log 	closed 	01/28/08
+#163 	WFS transaction: describefeaturetype-request is missing in xsi:schemaLocation 	closed 	01/24/08
+#169 	IE: WFS conf select box in WFS gazetteer defect 	closed 	01/24/08
+#132 	treegde2: wms opacity is lowered to 0 (fully transparent) 	closed 	01/21/08
+#55 	reloadTree() opens and closes the wms folder 	closed 	01/21/08
+#89 	Add admin_services_* to default interfaces for self created portal users 	closed 	01/18/08
+#164 	New module 'reload' 	closed 	01/17/08
+#152 	remove Ajax module from all GUIs 	closed 	01/17/08
+#158 	include and require with dirname when using relative paths 	closed 	01/15/08
+#96 	Add WFS Update 	closed 	01/14/08
+#97 	Support for Sublayers (grouped layers) 	closed 	01/14/08
+#160 	Encoding error for ISO docsuments in UTF8 database 	closed 	01/14/08
+#159 	By WFS-T Insert (Digitizing) GeoServer version >= 1.5.4 needs only used namespaces 	closed 	01/14/08
+#113 	Integrate jquery in Mainframe / json as a jquery plugin 	closed 	01/11/08
+#134 	the same javascript may be loaded twice in map.php 	closed 	12/21/07
+#142 	Mapbender setup to check error logging 	closed 	11/23/07
+#135 	internationalisation: tabs module 	closed 	11/08/07
+#103 	faulty regular expression 	closed 	10/05/07
+#98 	Popup windows as div-layer 	closed 	09/26/07
+#39 	reverse order of wms in treegde2 	closed 	09/26/07
+#100 	error in table name of insert statements for translations 	closed 	09/19/07
+Changelog 2.4.5
+#191  	missing column layer_md_topic_category in dump for 2.4.5  	closed  	04/15/08
+#202 	problem w/ z-Index in map layers 	closed 	03/19/08
+#200 	featureInfo is checked after load WMC 	closed 	03/19/08
+#195 	Remote Command Execution in Mapbender 	closed 	03/13/08
+#196 	SQL-Injections in Mapbender 	closed 	03/13/08
+#193 	remove element filteredWms_layer_topic from admin guis 	closed 	03/08/08
+#190 	bug in wz_jsGraphics 	closed 	03/06/08
+#189 	logging set to "off" by default 	closed 	03/06/08
+#168 	new database-field 'e_title' not in 'update_postgresql_db.sql' 	closed 	03/06/08
+#129 	mixed up wfs_conf_ids 	closed 	02/18/08
+#165 	mb_execloadwmcSubFunctions not found 	closed 	02/18/08
+#162 	WMS upload fails 	closed 	02/18/08
+#176 	WFS-T write failed 	closed 	02/18/08
+#177 	Update WMS has to display only the WMS that the user owns 	closed 	02/14/08
+#119 	wfs selection in IE 6.0, IE 7 not working using multiple wfs id's 	closed 	02/02/08
+Changelog 2.4.4
+#137  	measure dont work with more then 20 wms  	closed  	04/17/08
+#148 	Save WMC doesn't work 	closed 	12/21/07
+#150 	Zoom to feature: Buffer is NaN 	closed 	12/21/07
+#145 	Spatial request: coords is not defined 	closed 	12/21/07
+#149 	incorrect wfs_describefeaturetype 	closed 	12/21/07
+#147 	dependentDiv element_vars to define the position 	closed 	12/18/07
+#116 	Buffer from WFS conf not used in WFS gazetteer 	closed 	11/30/07
+#123 	Parsing WMS Capabilities Doc with duplicate SRS entries fails 	closed 	11/30/07
+#124 	group rights after copying a gui 	closed 	11/30/07
+#115 	Saving digitized geometries: Integer field always mandatory? 	closed 	11/30/07
+#139 	geom2wfst.php: error message with "new line" command corrupts JS 	closed 	11/30/07
+#77 	mod_digitize : namespace xmlns:xmlns makes no sense in wfs:transaction 	closed 	11/30/07
+#92 	wfs digitize namespace Problems 	closed 	11/30/07
+#140 	in log file, it is not clear whether the entry is an error, a warning, or a notice 	closed 	11/30/07
+Changelog 2.4.3
+#133  	weird behaviour when using left and right key  	closed  	10/31/07
+#108 	Invalid constant declaration in saveWKT 	closed 	10/02/07
+#102 	new jQuery version available 	closed 	09/21/07
+#53 	WMS - wms_format..data_format column not long enough 	closed 	09/21/07
+#80 	Headers in wfs_conf are not displayed 	closed 	09/21/07
+#95 	load a WMC from a file 	closed 	09/20/07
+#66 	layer transparency in IE 	closed 	09/20/07
+#79 	gui_digitize will not load properly 	closed 	09/20/07
+#94 	opaque map images shown incorrectly in IE, worked in older versions 	closed 	09/20/07
+#78 	createImagefromText in wfs/wms conf failed 	closed 	09/20/07
+#99 	Zoombox is hidden behind wms map images 	closed 	09/20/07
+Changelog 2.4.2
+  english
+    bug fixes: see http://trac.osgeo.org/mapbender/report/9
+    new features
+    * set WMS opacity in treeGDE2
+    * Bulgarian translation of the introduction to Mapbender
+    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
+    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
+    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
+    * poi (not included in a GUI yet)
+    * JavaScript compression; Mapbender will load faster
+    * dynamic overview - integration in the rc1 an testing gui2
+    * treeGDE2 replaces treeGDE
+    * different configurations of treeGDE2
+    * first draft of an API documentation for JavaScript classes
+    * print temporary objects (lines and polygons) which where drawn with the measure element
+  deutsch
+    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
+    neue Features
+    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
+    * Bulgarische Übersetzung der Mapbender-Einführung
+    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
+    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
+    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
+    * poi (noch in keiner GUI enthalten)
+    * JavaScript Kompression; Mapbender lädt schneller
+    * Dynamisches Overview
+    * TreeGDE2 ersetzt die alte Baumstruktur
+    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
+    * vorläufige API Dokumentation für JavaScript Klassen
+    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
+Changelog 2.4.1
+english
+new features
+bug fixes
+    * 1658777 Export GUI SQL unsorted
+    * 1634035 Wfs geometry name not sorted by position
+    * 1647206 sort order of modules in gui element list
+    * 1635839 JS error: document.form1.newGuiName has no properties
+    * 1589764 wms loading problems when abstract contain linebreak
+    * 1653348 mod_filteredGroup_filteredGui.php
+    * 1653160 Metadata: Undefined variable: wms_id
+    * 3 Online resource incorrect in monitoring module
+    * 11 wrong sort order in edit_gui_wms
+database changes
+see latest database changes.
+deutsch
+Changelog Mapbender 2.4.1 rc1
+english
+    * changes in database architecture: For update have a look in the wiki at dbchanges or Database_Changes_2.4.1. The update sqls you find in the download package in the folder mapbender/resources/db/update/
+    * WFS_gazetteer possibility to handle several wfs_confs and choose from a select-box - thanx to User:Verena Diewald
+    * new treeGDE - thanx to User:Melchior Moos
+    * new element setPOI2Scale mod_setPoi2Scale to open a GUI at a special coordinate and scale - have a look Mod_setPoi2Scale
+    * extended ResizeMapsize functionality - Modul can act automatically or by button click. 3 element vars are added.
+    * new administration functionality OrphanWMS to find information about orphaned WMS and to fix them.
+    * new functionality meetingPoint to generate meeting points and export them as text or via email. The url can be displayed by highlightPOI
+    * pdf-Print now with Din-A2 support
+    * new element highlightPOI (mod_highlightPOI.php) to open a gui and set poi points with text
+    * metadata handling
+    * new admin guis
+    * wfs bug fix for digitize modul
+    * featureinfo tunnel closes empty result windows automatically
+deutsch
+    * Änderungen in der Datenbankarchitektur: Angaben im Wiki unter dbchanges oder Database_Changes_2.4.1. Die update-sqls befinden sich im Download-Paket im Verzeicnis mapbender/resources/db/update/
+    * WFS_gazetteer Auswahlmöglichkeit zwischen mehreren WFS-Konfigurationenüber eine Auswahlliste - thanx to User:Verena Diewald
+    * treeGDE - neue Baumstruktur - thanx to User:Melchior Moos
+    * Neues Modul add_vendorspecific.
+    * Neues Element setPOI2Scale um eine GUI an einen Punkt in einem bestimmten Maßstab zu öffnen Mod_setPoi2Scale.
+    * Erweiterung des Moduls resizeMapsize. Kartenfenster kann sich automatisch an die Browsergröße anpasssen oder über einen Button. 3 Element vars wurden hinzugefügt.
+    * Neues Administrationselement OrphanWMS, dass informationen über verwaiste WMS liefert und diese löschen kann.
+    * Neues Element meetingPoint um Treffpunkte zu generieren und diese als Text oder via E-Mail zu exportieren. Die URL kann durch highlightPOI angezeigt werden.
+    * pdf-Print nun auch mit Din-A2 Unterstützung (Dank an Frank Härtel und Horst Becker).
+    * Neues Element highlightPOI (mod_highlightPOI.php) ermöglicht es beim Öffnen einer GUI ein oder mehrere Punkte mit Beschriftung zu setzen.
+    * Metadaten handling.
+    * Featureinfotunnel schließt leere Fenster ohne Ergebnis gleich wieder.
+english
+    * bugs in loadWMC are fixed
+    * new module resizeMapsize to resize the Mapsize depending on the size of the browser window
+    * new module monitorCapabilities: periodically checks all WMS and gathers data in the new table mb_monitor (see Database_Changes_2.4)
+    * new module initWMC: starts the client with a wmc.
+    * wms_extent - WMS representing the EXTENTs of the WMS loaded in Mapbender
+deutsch
+    * Bugs im Modul loadWMC wurden behoben.
+    * Neues Modul resizeMapsize das Modul paßt die Kartengröße in Abhängigkeit von der Größe des Browserfensters dynamisch an.
+    * Neues Modul monitorCapabilities: periodisch werden alle WMSe kontrolliert und alle Daten in der neuen Tabelle mn_monitor erfaßt (siehe auch Database_Changes_2.4).
+    * Neues Modul initWMC: startet den Client mit einem WMS.
+    * wms_extent - WMS, der die Ausdehnungen (Extent) der in Mapbender geladenen WMSe anzeigt.
+Changelog 2.4 rc2
+english
+    * mapbender changed to Subversion (svn), big effort is done in code cleaning
+    * owsproxy is implemented
+    * treeGDE improved, now there is the possibility to handle the layers of a wms with one click (all layer on / all layer off). new element var switchwms
+    * bugs in legend solved
+    * changes in database architecture: new table wfs_featuretype_namespace, new column wms_owsproxy in table wms, new column wms_upload_url in table wms. For update have a look at dbchanges or Database Changes 2.4
+    * perpared statements for PHP > 5.1.x, PostgreSQL > 7.4
+    * new gui_digitize in the installation package. Read more about Digitizing
+    * new gui2 in the installation package with new buttons (button_blue), new tree-style (tree_blue) and more color.
+    * default md5-encryption for the passwords in MySQL and PostgreSQL. Mapbender is doing the md5-encryption.
+    * extended mapbender_setup.php with more information (Thanks to Marko Samson)
+    * new element deleteWFS in GUI admin1
+    * printPDF: highquality print and matching for the overview image
+    * new help: every element in the gui refers to a page in the Mapbender wiki. The link is saved in the table gui_element column e_url and can be changed individual.
+deutsch
+    * Mapbender wechselt zum Subversion (svn) mit dem damit verbundenen Code cleaning
+    * owsproxy
+    * treeGDE wurde verbessert, es gibt nun die Möglichkeit alle Layer eines WMS durch einen Klick an- bzw. auszustellen.
+    * Bugs in der Legende behoben
+    * Veränderungen in der Datenbankarchitektur: neue Tabelle wfs_featuretype_namespace, neue Spalte wms_owsproxy in Tabelle wms, neue Spalte wms_upload_url in Tabelle wms. Um eine bestehende Datenbank zu aktualisieren, gibt es unter dbchanges weitere Informationen. Database Changes 2.4
+    * Es besteht die Möglichkeit Perpared Statements ab PHP > 5.1.x, PostgreSQL > 7.4 einzusetzen
+    * Neue gui_digitize im Installationsumfang. Mehr unter Digitizing
+    * Neue gui2 im Installationsumfang mit neuen Buttons (button_blue), neuem Style für die Baumstruktur (tree_blue) und mehr Farbe
+    * Standardmäßige md5-Verschlüsselung des Passworts in MySQL und PostgreSQL. Mapbender verschlüsselt nun das Passwort, nicht die Datenbank.
+    * mapbender_setup.php liefert nun mehr Informationen und weist auf Fehler hin (Danke an Marko Samson)
+    * Neues Element deleteWFS in der GUI admin1
+    * printPDF: für den Overview ist nun auch der hochqualitative Druck und das Matching möglich
+    * Hilfebutton: jedes Element der GUI ist direkt mit der Hilfeseite im Mapbender Wiki verlinkt (Eintrag in der Tabelle gui_element Spalte e_url). Dieser Link kann an die jeweilige Umgebung angepaßt werden.
+Changelog 2.2.3
+english
+    * print: now with overview window with position rectangle and scalebar
+    * gui_de and gui1_de are no longer part of the standard installation of mapbender, as it is too much work to handle 4 guis. If you want a german gui, you have to change the tool tip texts. In the next versions we want to handle the language differences with element vars.
+    * WMC handling: includes DisplayWMC, loadWMC, saveWMC and listWMC.
+    * element logout: now with element_var logout_location to define the webside to show after logout
+    * the overview window of the pdf-print is now displayed in highquality, if you use highquality = true in your print-configuration
+    * there has been some rework done at the AddWMS functions. Now the mod_addWMSgeneralFunctions.js offers the functions mod_addWMS_load and mod_addWMS_refresh to the elements addWMSfromfilteredList and addWMSfromList IMPORTANT: JS has to be added as modul in the element-definition
+    * element tabs (mod_tab.php) now with element_var open_tab to decide which tab should be opened at the beginning
+    * print : there where errors in the generation of the legend especially with grouped layers
+    * legend : new element_var checkbox_on_off to decide wether you want to show or hide the on/off checkbox - there where errors in the generation of the legend especially with grouped layers
+    * legend: new element var : stickylegend to decide wether the legend should stick at the mapframe1
+    * connection to GEOS function for mysql users: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - database parameters where added to the mapbender.conf to enable Mapbender user with mysql-Administration to transform and change the projection
+    * encoding of Mapbender: now UTF-8 or ISO-8859-1 can be choosed as the encoding for the database (have a look in the mapbender.conf CHARSET)
+    * fixed: WFS configuration caused errors with postgresql database
+    * copyright now works with element var for the copyright text: define the JavaScript Variable mod_copyright_text with a text you want as value
+    * fixed: there was an error in class_log, now the printed maprequests should be logged
+    * database changes
+deutsch
+    * print: nun mit Übersichtsfenster mit Positionsrechteck und Maßstabsleiste (beide Funktionalitäten können in der Konfigurationsdatei des Drucks an- oder ausgestellt werden)
+    * Die Oberflächen gui1_de und gui_de werden nicht mehr weitergeführt, da es zu viel Aufwand darstellt 4 Oberflächen weiterzuführen. Wenn eine deutsche Oberfläche gebraucht wird können die ToolTipTexte auf deutsch angelegt werden. Die Mehrsprachigkeit der einzelnen Elemente soll zukünftig über die Element vars gelöst werden.
+    * WMC-Nutzung: beinhaltet anzeigen (DisplayWMC), laden (loadWMC), speichern (saveWMC) eines WMCs und auflisten aller WMCs (listWMC).
+    * Element logout: verfügt nun über den element_var logout_location, um zu definieren welche Webseite nach dem Logout angezeigt werden soll.
+    * Das Übersichtsfenster des PDF-Drucks wird nun auch hochqualitativ angezeigt bei hochqualitativem Druck.
+    * Die AddWMS Funktionalität wurde überarbeitet. Eine neue Datei mod_addWMSgeneralFunctions.js stellt nun die Funktionen mod_addWMS_load und mod_addWMS_refresh zur Verfügung. Wichtig für die Elemente addWMSfromfilteredList and addWMSfromList das JavaScript mod_addWMSgeneralFunctions.js muß in der Elementdefinition unter Modul angegeben werden.
+    * Element tabs (mod_tab.php) wurde um die element_var open_tab erweitert, um beim Start des Clients einen tab voreingestellt zu öffnen.
+    * print: Fehler in der Legende bei gruppierten Ebenen beseitigt.
+    * legend: Neue element_var: checkbox_on_off zur Steuerung der on/off checkbox.
+    * legend: Neue element_var: stickylegend zur Steuerung des Anzeigefesters der Legende (Positionierung / sticky-Frame).
+    * Bereitstellung der GEOS Funktionen für Mapbender mit mysql-Administrationsdatenbank: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - Zusätzliche Datenbankparameter für eine PostgresDB neben der mysql-Administrationsdatenbank, zur Transformation von Projektionssystemen und Berechnung von Flächen.
+    * Encoding (Zeichensatz) in Mapbender: es besteht nun die Auswahl zwischen UTF-8 oder ISO-8859-1 als Zeichensatz (die Angabe erfolgt in der mapbender.conf CHARSET)
+    * wfs configuration: WFS Konfiguration erzeugte Fehler mit der PostgreSQL-Datenbank.
+    * copyright: Neue element_var mod_copyright_text, Angabe zum Copyright-Text über die Administrationsoberfläche.
+    * fixed: Fehler in class_log behoben.
+    * Datenbankänderungen
+Changelog 2.2.2
+english
+    * Unfortunately there was a bug left in the PostgreSQL database-module. In the edit gui-menu no templates from other guis were shown so that it was impossible to modify guis.
+To fix this, minor changes in the PostgreSQL database-structure were necessary. If you are updating, please do not use an already existing V. 2.2.1-database and create the database with the SQL-dumps attached to this version instead.
+deutsch
+    * Leider war noch ein Fehler im PostgreSQL Datenbank-Modul übersehen worden. Da im Menü Oberflächenelemente editieren die bestehenden GUIs und deren Elemente nicht angezeigt wurden, um sie als Templates zu verwenden, ließen sich die GUIs nicht nach den eigenen Bedürfnissen anpassen.
+Um diesen Fehler zu beheben wurden kleinere Änderungen in der PostgreSQL Datenbank-Struktur vorgenommen. Bitte verwenden Sie daher keine bereits existierende V. 2.2.1-Datenbank falls Sie updaten, sondern benutzen Sie bitte die SQL-Dumps, die dieser Version beigefügt sind.
+Changelog 2.2.1
+english
+We have been a bit quick with the release 2.2 and didn't put the focus on documentation and debugging. But with the help of the users of Mapbender we fixed the bugs and now there is the next Mapbender version for download.
+    * There where some bugs when you run Mapbender with PostgreSQL. Hope they are fixed. Have a look at the Installation to find out about how to configure Mapbender (configuration files have been consolidated into ./conf/mapbender.conf)
+    * the name of two columns had to be changed:
+          o mb_log.session changes to mb_log.mb_session (session is a reserved name in postgresql)
+          o gui_element.e_closeTag changed to gui_element.e_closetag (all table- and columnnames are handled in lower case)
+    * Sequences in PostgreSQL: if you use postgresql you have to set sequences for the serial columns so that the next value for the serial is fixed. user mapbender/resources/db/pgsql_serial_set_sequences.sql to set the sequences
+    * changeEPSG and calculating areas at the moment is only possible for user with PostgreSQL/PostGIS database
+deutsch
+Vielleicht waren wir etwas voreilig mit dem Mapbender Release 2.2 und haben den Fokus nicht auf die Dokumentation und das Debuggig gesetzt. Aber mit Hilfe der User sind viele Fehler aufgezeigt worden und konnten gelöst werden. Hier nun der neue Mapbender 2.2.1. Derzeit gibt es noch keine Dokumentation und auch kein Skript für den automatisierten Update einer bestehenden Mapbender Installation. Die vormals eingesetzen Skripte mapbender_setup.php und validate_db.php können derzeit nicht mehr verwendet werden und wurden aus dem Paket entfernt. Die Skripte müssen erst wieder auf den neuen Release angepaßt werden, damit sie wieder zum Einsatz kommen können.
+    * es lagen einige Bugs bei der Verwendung von PostgreSQL als Administrationsdatenbank vor. Diese sind hoffentlich alle beseitigt. In der Installationsanleitung unter
+mapbender.conf findet sich alles wichtige zur Installation (Alles ist nun einfacher. Es muß nur noch die Datei mapbender.conf angepaßt werden)
+    * der Name zweier Spalten hat sich geändert:
+          o mb_log.session geändert in mb_log.mb_session (session reserviertes Wort in PostgreSQL)
+          o gui_element.e_closeTag geändert in gui_element.e_closetag (alle Tabellen- und Spaltennamen in Kleinbuchstaben)
+    * Sequences in PostgreSQL: bei der Verwendung von PostgreSQL müssen die Sequenzen der Autowerte nach dem Laden der Daten explizit gesetzt werden. Dazu steht die Datei mapbender/resources/db/pgsql_serial_set_sequences.sql zur Verfügung
+    * changeEPSG und Flächenberechnung steht derzeit nur Benutzern mit einer PostgreSQL-Datenbank zur Verfügung
+Changelog 2.2.0
+[edit]
+english
+Here you find a list with the changes in Mapbender 2.2.0:
+    * The configuration files have been consolidated into one single mapbender.conf
+    * Now Mapbender 2.2.0 is able to work with MySQL- or PostgreSQL-database. Configure the settings in the mapbender.conf.
+    * You can edit the single elements of a GUI with the Mapbender-Administration (table element_vars/ css-files/ var).
+    * WFS
+    * Proxy
+    * PrintPDF. This module enables you to configure the PrintPDF containing an overview, legend, northarrow and your logo.
+    * Click on a Layer refers to the WMS METADATAURL - new column layer_metadataurl.
+    * The legend is displayed by the LEGENDURL.
+    * New Wiki: To edit the new wiki you have to ask for an account at mailto:info at mapbender.org.
+    * ToggleModule to define a function to be active when the gui is opened
+Here you already find a list with the changes in Mapbender 2.2:
+    * Mapbender for MySQL or PostgreSQL
+    * click on a Layer refers to the WMS METADATAURLD - new column layer_metadataurl
+    * the legend is displayed by the LEGENDURL
+deutsch
+Hier die Änderungen, die mit der Version 2.2 erfolgt sind:
+    * Nun ist es möglich Mapbender mit einer MySQL- oder PostgreSQL-Datenbank zu installieren. Konfigurieren Sie die Einstellungen in der Datei mapbender.conf.
+    * Sie können die einzelnen Elemente einer GUI mit der Mapbender-Administration editieren (Tabelle element_vars/ css-files/ var).
+    * WFS
+    * Proxy
+    * PrintPDF. Dieses Modul erlaubt es dem Benutzer den PrintPDF zu konfigurieren und beinhaltet Overview, Legende, Nordpfeil und ein Logo.
+    * Neue Buttons (button_oo) sind in der GUI 'gui' verfügbar.
+    * Ein Klick auf einen Layer referenziert die WMS METADATAURL - neue Spalte layer_metadataurl.
+    * Die Legende wird durch die LEGENDURL dargestellt.
+    * Neues Wiki: Um im neuen Wiki editieren zu können, müssen Sie einen Account beantragen bei CCGIS.
+    * ToggleModule - definiert ein Element, das beim Start der GUI aktiviert sein soll
+Hier aber schonmal die Änderungen, die uns mit der Version 2.2 erwarten:
+    * Mapbender für MySQL oder PostgreSQL
+    * Anpassung der einzelnen Elemente einer GUI über die Mapbender-Administration (element_vars)
+    * Metadataurl
+    * Legendurl
+Changelog 2.1.0
+english
+    * communication by email mail.conf
+    * new button myGUIlist in the administration-guis to go back to the list of myGUIs
+    * New table mb_log
+    * New column in table wms wms_getCapabilities_doc
+    * ChangeEpsg_dynamic
+    * Edit gui shows the images of a gui as little pictures (better orientation)
+    * sql to update the mapbender standard guis Update Mapbender
+    * mapbender/http/tools/validate_db.php - php to update the database and add new columns and tables if necessary
+    * New column layer_dataurl in table layer
+    * New columns legendurl and legendurlformat in table layer_style
+    * New table wms_srs
+    * Security update in Edit GUI Elements
+deutsch
+    * Kommunikation über email mail.conf
+    * Neuer Button myGUIlist für die Administrations-GUIs, um in die Liste von meinenGUIs zurück zu kommen.
+    * Neue Tabelle mb_log
+    * Neue Spalte in der Tabelle wms wms_getCapabilities_doc
+    * Die Rubrik 'Oberflächenelemente editieren' zeigt nun kleine Bilder der Oberfläche zur besseren Orientierung.
+    * SQL zur Aktualisierung Ihrer GUIs: siehe Update Mapbender
+    * mapbender/http/tools/validate_db.php - PHP, um die Datenbank zu aktualisieren und wenn nötig neue Spalten und Tabellen hinzuzufügen.
+    * Neue Spalte layer_dataurl in der Tabelle layer hinzugefügt.
+    * Neue Spalten 'legendurl' und 'legendurlformat' in der Tabelle layer_style hinzugefügt.
+    * Neue Tabelle wms_srs
+Changelog 2.1.0 rc1
+english
+    * Print with Mapbender Version 2.1.0 pdf-print is used as standard. You have the possibility to choose A4 or A3 and landscape or portrait. The printframe can be styled to your own design by editing a configuration file.
+    * GUIOwner a new parameter <owner> has been added to the user management. This allows a distinction between reading/using a GUI and being allowed to change it ( edit GUI elements). This feature is necessary as a preliminary step to open Mapbender as a portal with anonymous access which is needed to implement Wikimaps functionality. Additionally this enables setting up a hierarchical administration.
+    * Overview The overview map should be addressed with the module Overview, (<Overview0>, <Overview1>, <Overview2>, ... are deprecated). The module can be parameterized with the field "wms". It contains the index of the WMS which should be displayed in the overview map. (starting at 0).
+    * showCoords_div On button click the coordinate of the mouseposition will be displayed below the target (e.g. mapframe1)
+    * Detailed metadatainformation for a GUI. Also information about the last requests as a link.
+    * Additional default GUIs are added to the Mapbender database.
+    * After installing Mapbender a set of worldwide WMS are already contained in several GUIs.
+    * Copy a GUI copyGUI / rename a GUI RenameGUI.
+    * AddWMS Add a new web map service dynamically by entering the URL to an OGC WMS Capabilities document. Current extent, layers and settings are not affected.
+    * Add WMS from list Dynamically add WMS from a list of all OGC WMS contained in the Mapbender database to the current GUI.
+    * Add WMS from filtered list Dynamically add WMS from a list (filtered by group or gui) to a GUI.
+    * setBackground Define several WMS to be displayed in the background.
+    * setBackground_all You can define one or more WMS to be displayed in the background.
+    * DeleteGUI Delete a selected GUI.
+    * DeleteWMS Delete a selected WMS.
+    * Edit GUI Elements - added: GUI description editable.
+    * Edit GUI WMS - added: show WMS ID.
+    * showCoords_div - shows the coordinate below the target (i.e. mapframe1).
+    * setScaleHint - set scale hints for mapframes.
+    * tabs_vertical - handle iframes with vertical tabs.
+    * WMS_preferences - edit service settings of the loaded WMS, change order, remove wms, change settings.
+deutsch
+    * Print Ab der Mapbender Version 2.1.0 erfolgt der Standardausdruck von Mapbender als PDF. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat. Der Kartenspiegel kann dabei über eine Konfigurationsdatei an das eigene Design angepaßt werden. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat.
+    * GUIOwner Der neue Parameter <owner> (Besitzer) wurde der Benutzerverwaltung hinzugefügt. Dies erlaubt eine Unterscheidung zwischen lesen/benutzen einer GUI und der Berechtigung die GUI zu ändern ( edit GUI elements). Dieses Feature ist notwendig als Vorbereitung Mapbender als Portal mit anonymem Zugang einzusetzen, was wiederum notwendig ist, um Wikimap-Funktionalität zu implementieren. Zusätzlich ermöglicht diese Einstellung den Aufbau einer hierarchischen Verwaltung.
+    * Overview Die Übersichtskarte sollte mit dem Modul Overview adressiert werden (<Overview0>, <Overview1>, <Overview2>, ... wurden eingestellt). Das Modul kann mit dem Feld "wms" parametriert werden. Es beinhaltet den Index des WMS, der nicht in der Übersichtskarte angezeigt werden sollte (beginnend bei 0).
+    * showCoords_div Bei Aktivierung dieses Buttons werden die Koordinaten der Mausposition unter dem Ziel (target = z.B. mapframe1) angezeigt.
+    * Detaillierte Metadatainformationen für eine GUI. Ebenso Information über die letzte Anfrage als Link.
+    * Zusätzliche Standard-GUIs wurden der Mapbender Datenbank hinzugefügt.
+    * Nach der Installation von Mapbender ist bereits ein Set von weltweiten WMSen in verschiedenen GUIs enthalten.
+    * Kopieren einer GUI copyGUI / Umbenennen einer GUI RenameGUI.
+    * AddWMS Dynamisches Hinzufügen eines neuen Web Map Services durch die Eingabe der URL in ein OGC WMS Capabilities Dokument. Der aktuelle Ausschnitt, Layer und Einstellungen sind davon nicht betroffen.
+    * Add WMS from list Dynamisches Hinzufügen eines WMS von einer Liste von allen OGC WMS, die in der Mapbender Datenbank enthalten sind für die aktuelle GUI.
+    * Add WMS from filtered list Dynamisches Hinzufügen eines WMS von einer Liste (gefiltert für eine Gruppe oder GUI) für eine GUI .
+    * setBackground Definiert einige WMS, die im Hintergrund angezeigt werden.
+    * setBackground_all Definieren Sie hier einen oder mehrere WMS, die im Hintergrund angezeigt werden.
+    * DeleteGUI Löschen einer ausgewählten GUI.
+    * DeleteWMS Löschen eines ausgewählten WMS.
+    * Oberflächenelemente editieren (Edit GUI Elements) - Hinzugefügt: GUI Beschreibung editierbar.
+    * WMS GUI Einstellungen (Edit GUI WMS/ WMS GUI settings) - Hinzugefügt: Anzeige der WMS ID.
+    * showCoords_div - Anzeige der Koordinaten unter dem Ziel (target, z.B. mapframe1).
+    * setScaleHint - Setzen eines Maßstabes für Kartenframes.
+    * tabs_vertical - Handhaben von Iframes mit vertikal Karteireitern.
+    * WMS_preferences - Bearbeiten der Einstellungen eines Dienstes eines geladenen WMS, Änderung der Reihenfolge, Entfernen eines WMS, Änderung der Einstellungen.
Modified: branches/print_dev/Install.txt
--- branches/print_dev/Install.txt	2008-10-06 11:40:58 UTC (rev 3130)
+++ branches/print_dev/Install.txt	2008-10-06 11:41:28 UTC (rev 3131)
@@ -2,15 +2,170 @@
 http://www.mapbender.org/index.php/Installation
+To update a running Mapbender Installation have a look at: http://www.mapbender.org/Update_Mapbender
 Every Mapbender User is invited to let the Mapbender Wiki grow.
 If you want an account to edit any of these Wiki pages please write an email to info at mapbender.org and request for an ID and password.
 You need a valid email address to be able to edit this Wiki.
+-- Prerequisite
+To be able to install and operate your own copy of Mapbender you need:
+    * Webserver (Apache, MS IIS)
+    * an installation of PHP (scripting language, version > 5.1.x)
+    * Database (PostgreSQL >7.3 or MySQL > 4k)
+The following instructions only describe the configuration process for these packages, please follow the installation instructions for your operating system individually as the paths to files will vary on your systems.
--- 1. Database:
+-- 1. Download of the package
+Download the newest Mapbender OSGeo installation package.
+For further details see Download Mapbender.
+Extracting the package
+Mapbender consists of multiple PHP-files in different directories which can be downloaded in one ZIP-file. To extract the ZIP-file you will need archiving software like unzip (commandline) or FileZip (Windows).
+Directories
+After downloading and unpacking Mapbender you find the following directories:
+    * conf - directory for the configuration file mapbender.conf
+    * core
+    * documents
+    * http - directory for the application. Within this directory the modules are sorted by type in subdirectories. Some modules are pure JavaScript applications, even though they have .php as suffix.
+    * lib
+    * license - license information files
+    * log - logfiles will be saved here
+    * owsproxy
+    * resource - directory for the SQL-Dump to build up the Mapbender database or update the database; also contains translation files
+-- 2. Internationalisation
+* Set USE_I18N to true in mapbender.conf.
+* Compile the .po files into .mo files via msgfmt, see http://www.mapbender.org/gettext.
+-- 3. Apache virtual directory
+After installation create a virtual directory. Edit /etc/apache/httpd.conf (path varies, for apache2 /etc/apache2/sites-available/default):
+       Alias /mapbender /path/to/mapbender2/http/
+       <Directory /path/to/mapbender2/http>
+          Options MultiViews
+          DirectoryIndex index.php
+          Order allow,deny
+          Allow from all
+       </Directory>
+For example using Ubuntu edit: /etc/apache2/sites-available/default
+      Alias /mapbender /var/www/apache2-default/mapbender_2.4.3/http/
+       <Directory /var/www/apache2-default/mapbender_2.4.3/http>
+          Order allow,deny
+          Allow from all
+       </Directory>
+You must reload (or stop and restart) the Apache program after making changes to the configuration file to make them take effect. If you want to enable directory browsing, e.g. for debugging purposes add Indexes to the Options line.
+-- 4. Apache output compression
+For optimal performance, enable output compression of your web server. Here's an instruction for Apache (see http://httpd.apache.org/docs/2.0/mod/mod_deflate.html for more details). Just append the content in bold to your Directory settings
+           Options Indexes MultiViews FollowSymLinks
+           AllowOverride None
+           Order deny,allow
+           Deny from all
+           Allow from 127.0.0.0/255.0.0.0 ::1/128
+           # Insert filter
+           SetOutputFilter DEFLATE
+           # Netscape 4.x has some problems...
+           BrowserMatch ^Mozilla/4 gzip-only-text/html
+           # Netscape 4.06-4.08 have some more problems
+           BrowserMatch ^Mozilla/4\.0[678] no-gzip
+           # MSIE masquerades as Netscape, but it is fine
+           # BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
+           # NOTE: Due to a bug in mod_setenvif up to Apache 2.0.48
+           # the above regex won't work. You can use the following
+           # workaround to get the desired effect:
+           BrowserMatch \bMSI[E] !no-gzip !gzip-only-text/html
+           # Don't compress images
+           SetEnvIfNoCase Request_URI \
+           \.(?:gif|jpe?g|png)$ no-gzip dont-vary
+           # Make sure proxies don't deliver the wrong content
+           Header append Vary User-Agent env=!dont-vary
+       </Directory>
+Make sure you have loaded the required modules (for example, Ubuntu and Apache2)
+* a2enmod deflate
+* a2enmod headers
+For Windows and Apache2, you have to activate the modules at httpd.conf.
+* LoadModule deflate_module modules/mod_deflate.so
+* LoadModule headers_module modules/mod_headers.so
+Mapbender will load almost twice as fast!
+-- 5. PHP Configuration
+You might have to make some adjustments to the file php.ini. Changes in the php.ini also become operative only after restarting the Apache web server !
+1. During the test and installation phase of Mapbender it can be helpful to display error messages. To see error messages displayed configure the file php.ini as follows:
+error_reporting  =  E_ALL & ~E_NOTICE
+display_errors = On
+2. After testing and installing, error messages should not be displayed anymore, turn this setting off again:
+display_errors = Off
+3. Check the following details in php.ini allow_url_fopen parameter:
+extension_dir = (path to extensions-directory)
+allow_url_fopen = On
+4. Mapbender manages access authorization in SESSIONS. Check the following details:
+session.save_handler = files
+session.save_path = (Path to SESSIONS-Directory). (Check authorisation!)
+5. Further details of session management should be customized according to server load (see 'garbage collection' in php.ini)
+6. With regard to other modules the extension gd2 should be included in the installation and configuration process.
+extension=php_gd2.dll        (Windows)
+extension=gd.so              (Linux)
+On a Debian-System you find this lib in /usr/lib/libgd.so. If it is not installed zou can do that using the command (or use Synaptic Packet Manager or similar):
+# apt.get install lbgd2-dev
+7. For some Mapbender modules access to a PostgreSQL database is required. If these modules should be used, you have to check the availability of the required extension in the php.ini file:
+extension=php_pgsql.dll      (Windows)
+extension=pgsql.so           (Linux)
+8. from Mapbender 2.5 on we need gettext and mbstring
+extension=php_gettext.dll     (Windows)
+extension=php_mbstring.dll    (Windows)
+Furthermore check, whether the database information in ./conf/mapbender.conf is correct.
+-- 6. Database:
 -- MySQL --
@@ -78,20 +233,63 @@
--- 2. mapbender configuration
+-- 7. mapbender configuration
-configure the file mapbender.conf
+The Mapbender Configuration File is found in the directory "conf".
+Here you find the file mapbender.conf-dist. Rename the file to mapbender.conf.
+You won't loose your configuration at the next update of Mapbender.
 -- check the database connection
 http://localhost/tools/mapbender_setup.php
--- 3. print configuration
+-- 8. print configuration
 to use the pdfprint configure the files:
 mapbender\http\print\printPDF.conf (if you use the print in an iframe)
 mapbender\http\print\printPDF_b.conf (if you use the print with a button - b for button)
+In Linux : change the permission of tmp folder to 777
+$ chmod -R 777 log
+-- 9. Change the Permission of log Folder
+In Linux : change the permission of log folder to 777 so that php script can write logs in it.
+$ chmod -R 777 log
+-- 10. Checking the Setup
+The script moved to tools directory:
+http://localhost/mapbender/tools/mapbender_setup.php
+mapbender_setup.php tests the data connections. If you use PostgreSQL it checks if PostGIS and MD5 are available.
+Further more you have to check the settings in pg_hba.conf (e.g. you have to set ident sameUser to trust).
+After the installation - first Login
+For login you can use the user account with username root and the inital password root. Make sure to change this password asap in order to secure your Mapbender installation.
+-- 11. OWSPROXY
+Create an ALIAS for owsproxy:
+Alias /owsproxy/ "/data/mapbender/owsproxy/"
+ <Directory /data/mapbender/owsproxy/>
+    Order Deny,Allow
+    Allow from all
+ </Directory>
+URL to owsproxy (no terminating slash)
+ define("OWSPROXY", "http://<ip or name>/owsproxy");
+Apache configuration:
+ RedirectMatch ^.*owsproxy.([^i][\w\d]+)\/([\w\d]+)\/?$ http://<name or ip>/owsproxy/http/index.php?sid=$1\&wms=$2\&
+Replace <name or ip> with the owsproxy URL.
More information about the Mapbender_commits mailing list
