[Mapbender-commits] r3156 - branches/beck_dev/http/gazetteer_rostock
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 21 07:29:25 EDT 2008
Author: beck
Date: 2008-10-21 07:29:25 -0400 (Tue, 21 Oct 2008)
New Revision: 3156
   branches/beck_dev/http/gazetteer_rostock/mod_WFSStreetGaz_client.js
Modified: branches/beck_dev/http/gazetteer_rostock/mod_WFSStreetGaz_client.js
--- branches/beck_dev/http/gazetteer_rostock/mod_WFSStreetGaz_client.js	2008-10-17 17:12:44 UTC (rev 3155)
+++ branches/beck_dev/http/gazetteer_rostock/mod_WFSStreetGaz_client.js	2008-10-21 11:29:25 UTC (rev 3156)
@@ -386,13 +386,13 @@
 //	$("#td_h").empty();
 	$("<img>").attr({"id":"wheelImg","src":"../img/indicator_wheel.gif"}).appendTo("#td_h");
-	$("<span>").attr({"id":"searchDiv"}).appendTo("#td_h").html(" Suche...");
+	$("<span>").attr({"id":"searchDiv"}).appendTo("#td_h").html("Suche ...");
 	var parameters = {command:"getSearchResults", "url":requestUrl, "filter":filter};
 	parent.mb_ajax_post("../gazetteer_rostock/mod_WFSStreetGaz_server.php", parameters, function (jsCode, status) {
-$("#wheelImg").remove();
-$("#searchDiv").remove();
+		$("#wheelImg").remove();
+		$("#searchDiv").remove();
 		var geoObj = eval('(' + jsCode + ')');
    		if (jsCode) {
 			if (typeof(geoObj) == 'object') {
@@ -404,7 +404,7 @@
 				$("#hnrUl").css('margin', '0');
 				$("#hnrUl").css('padding', '0');
 				for (var i=0; i < geomArray2.count(); i++) {
-					if(searchAbbr==shortName2[0]){
+					if(searchAbbr==shortName2[0]){
 						(function () {
 							var geomStr = searchAbbr + i;
 							var geomIndex = i;
@@ -452,7 +452,7 @@
 									"type":"ort",
 									"zoomTo":"1.0",
 									"offsetParam":offsetParamOrt
More information about the Mapbender_commits mailing list
