[Mapbender-commits] r2924 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org
Thu Sep 11 10:33:48 EDT 2008
Author: nimix
Date: 2008-09-11 10:33:48 -0400 (Thu, 11 Sep 2008)
New Revision: 2924
branches/nimix_dev/http/javascripts/tooltip_wms.php
Modified: branches/nimix_dev/http/javascripts/tooltip_wms.php
--- branches/nimix_dev/http/javascripts/tooltip_wms.php 2008-09-10 14:50:28 UTC (rev 2923)
+++ branches/nimix_dev/http/javascripts/tooltip_wms.php 2008-09-11 14:33:48 UTC (rev 2924)
@@ -36,17 +36,26 @@
//tolerance when we ask wfs
var mb_wfs_tolerance = 8;
+//initialize Element Vars
//destination frame for the request (creates Popup if empty)
-var destFrameName = "";
-var tooltipTime = 1000;
-var no_result_text = ["Kein Ergebnis.",'<body onLoad="javascript:window.close()">'];
+if(typeof(tooltip_destinationFrame)==='undefined')
+ var tooltip_destinationFrame = "";
+if(typeof(tooltip_timeDelay)==='undefined')
+ var tooltip_timeDelay = 1000;
+if(typeof(tooltip_styles)==='undefined')
+ var tooltip_styles = "";
+try{
+ var no_result_text = eval(tooltip_noResultArray);
+}catch(e){
+ var no_result_text = ["Kein Ergebnis.",'<body onLoad="javascript:window.close()">'];
var mouseMoves=0;
var tooltipWin=null;
var point;
var tooltipWfsRequestCount = 0;
var numberOfFinishedWfsRequests = 0;
-var TooltipMsg = {'title':"Informationen"};
+var TooltipMsg = {'title':"<?php echo _mb("Informations");?>"};
//buttonWfs_toDigitize_on ="0";
@@ -55,13 +64,20 @@
mod_tooltip_run();
mb_getMousePos(event,tooltipTarget);
}).mouseout(function(){mouseMoves=0;});
+ var styleObj = new StyleTag();
+ styleObj.addClass("dlist_even", tooltip_wfsStyleEven);
+ styleObj.addClass("glist_even", tooltip_wfsStyleEven);
+ styleObj.addClass("dlist_uneven", tooltip_wfsStyleUneven);
+ styleObj.addClass("glist_uneven", tooltip_wfsStyleUneven);
+ alert(tooltip_wfsStyleUneven);
eventInit.register(mod_tooltipInit);
function mod_tooltip_run(){
mouseMoves++;
- setTimeout("if(mouseMoves=="+mouseMoves+")fireRequests();",tooltipTime);
+ setTimeout("if(mouseMoves=="+mouseMoves+")fireRequests();",tooltip_timeDelay);
function fireRequests(){
@@ -96,9 +112,13 @@
function checkFeatureInfoResults(js_code,status){
//check if there are results
+ if(js_code == "")
+ return;
for(var k=0;k < no_result_text.length;k++){
- if(js_code.indexOf(no_result_text[k])!==-1)
+ if(js_code.indexOf(no_result_text[k])!==-1){
return;
//output code
@@ -123,11 +143,11 @@
function displayResultDoc(html){
//test if we have a fixed destination and create popup otherwise
- if(destFrameName=="")
+ if(tooltip_destinationFrame=="")
return showBalloonFrame(html);
//put the frame there
- $("#"+destFrameName).each(function(){
+ $("#"+tooltip_destinationFrame).each(function(){
var oDoc = this.contentWindow || this.contentDocument;
if (oDoc.document) {
oDoc = oDoc.document;
@@ -219,11 +239,13 @@
function createWfsResultHtml(_geomArray){
var geometryIndex = 0;
wfsConf = get_complete_wfs_conf();
- var html = "<table style='background-color:#EEEEEE;'>\n";
+ var html = '<html><head><style type="text/css">';
+ html += tooltip_styles;
+ html += "</style></head><body><table>\n";
if(_geomArray.count()>1){
for (var i = 0 ; i < _geomArray.count(); i ++) {
if (_geomArray.get(i).get(-1).isComplete()) {
- html += "\t<tr>\n\t\t<td style = 'color:blue;font-size:12px;cursor:pointer;'\n";
+ html += "\t<tr class='glist_"+(i%2?"uneven":"even")+"'>\n\t\t<td \n";
// html += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
// html += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
// html += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+"));' ";
@@ -239,7 +261,7 @@
for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
if(currentWfsConf.element[i].f_show_detail==1){
if( _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
- html +="<tr><td>\n";
+ html +="<tr class='dlist_"+(i%2?"uneven":"even")+"'><td>\n";
html += currentWfsConf.element[i].f_label;
html +="</td>\n";
html += "<td>\n";
@@ -252,10 +274,7 @@
else{
var newLink = setUrl;
-/* if(openLinkFromSearch=='1'){
- window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
-*/ html += newLink;
+ html += newLink;
else{
html += elementVal;
@@ -265,7 +284,7 @@
- html += "</table>\n";
+ html += "</table></body>\n";
return html;
More information about the Mapbender_commits
