[Mapbender-commits] r2941 - in branches/nimix_dev: http/extensions http/javascripts log
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Sep 16 07:54:20 EDT 2008
Author: nimix
Date: 2008-09-16 07:54:19 -0400 (Tue, 16 Sep 2008)
New Revision: 2941
Added:
   branches/nimix_dev/log/.dropbox
Removed:
   branches/nimix_dev/http/javascripts/tooltip.php
   branches/nimix_dev/http/javascripts/tooltip24.php
   branches/nimix_dev/http/javascripts/tooltip_wms.php
   branches/nimix_dev/http/extensions/ext_featureInfoTunnel.php
   branches/nimix_dev/http/javascripts/mod_tooltip.php
transcode featureInfo result in FITunnel to UTF-8
Modified: branches/nimix_dev/http/extensions/ext_featureInfoTunnel.php
--- branches/nimix_dev/http/extensions/ext_featureInfoTunnel.php	2008-09-16 09:49:04 UTC (rev 2940)
+++ branches/nimix_dev/http/extensions/ext_featureInfoTunnel.php	2008-09-16 11:54:19 UTC (rev 2941)
@@ -33,7 +33,16 @@
 		echo "";
 	else {
-		echo $x->file;
+		echo toUTF8($x->file);
+function toUTF8($str){
+	if(preg_match('/<meta.*charset=([^"\s]*).*>/',$str, $charset)){
+		$ret = mb_convert_encoding($str, "UTF-8", $charset[1]);
+		$meta = str_replace($charset[1], "UTF-8", $charset[0]);
+		return str_replace($charset[0], $meta, $ret);
+	return $str;
\ No newline at end of file
Modified: branches/nimix_dev/http/javascripts/mod_tooltip.php
--- branches/nimix_dev/http/javascripts/mod_tooltip.php	2008-09-16 09:49:04 UTC (rev 2940)
+++ branches/nimix_dev/http/javascripts/mod_tooltip.php	2008-09-16 11:54:19 UTC (rev 2941)
@@ -88,7 +88,7 @@
 	tooltipWmsRequestCount = urls.length;
 	numberOfFinishedWmsRequests	= 0;
 	for(var j=0;j < urls.length;j++){
-		mb_ajax_post("../extensions/ext_featureInfoTunnel.php?url="+escape(urls[j]), null,
+		mb_ajax_post("../extensions/ext_featureInfoTunnel.php?url="+encodeURIComponent(urls[j]), null,
 			checkFeatureInfoResults);
Deleted: branches/nimix_dev/http/javascripts/tooltip.php
--- branches/nimix_dev/http/javascripts/tooltip.php	2008-09-16 09:49:04 UTC (rev 2940)
+++ branches/nimix_dev/http/javascripts/tooltip.php	2008-09-16 11:54:19 UTC (rev 2941)
@@ -1,282 +0,0 @@
-<?php
-# $Id: mod_toggleModule.php 2238 2008-03-13 14:24:56Z christoph $
-# http://www.mapbender.org/index.php/mod_toggleModule.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-$wfs_conf_filename = "wfs_default.conf";
-include '../include/dyn_php.php';
-$fname = dirname(__FILE__) . "/../../conf/" . $wfs_conf_filename;
-if (file_exists($fname)) {
-	include($fname);
-else {
-	$e = new mb_exception("tooltip.php: Configuration file " . $wfs_conf_filename . " not found.");
-echo "var tooltipTarget ='".$e_target[0]."';";
-include '../include/dyn_js.php';
-var mb_wfs_tolerance = 20;
-var tooltipTime = 500;
-var mouseMoves=0;
-var tooltipWin=null;
-var point, tt_rpt;
-var numberOfFinishedAjaxCalls = 0;
-buttonWfs_toDigitize_on ="0";
-eventInit.register(function(){
-	$(window.frames["mapframe1"].document).mousemove(function(event){
-		eventMouseMove.trigger(event);
-	}).mouseout(function(){mouseMoves=0;});
-eventAfterMapRequest.register(function(){
-	if(!tooltipWin||!tooltipWin.isVisible())
-		return;
-	point = realToMap("mapframe1",tt_rpt);
-	x=point.x+parseInt(document.getElementById("mapframe1").style.left);
-	y=point.y+parseInt(document.getElementById("mapframe1").style.top);
-	tooltipWin.set({left:x,top:y});
-eventMouseMove.register(function(event){
-	mb_getMousePos(event,"mapframe1");
-//	if(tooltipWin&&tooltipWin.isVisible()&&(Math.abs(clickX-point.x)>15||Math.abs(clickY-point.y)>15))
-//		tooltipWin.destroy();
-	mouseMoves++;
-	setTimeout("if(mouseMoves=="+mouseMoves+")requestWfs();",tooltipTime);
-function showWMSBalloon(){
-	x=clickX+parseInt(document.getElementById("mapframe1").style.left);
-	y=clickY+parseInt(document.getElementById("mapframe1").style.top);
-	if(tooltipWin&&tooltipWin.isVisible())
-		tooltipWin.destroy();
-	var ind = getMapObjIndexByName("mapframe1");
-	req = mb_mapObj[ind].getFeatureInfoRequests({x:clickX,y:clickY});
-	if(req)
-		tooltipWin = new mb_popup({url:req[0],title:"Feature Info",width:270,height:200,balloon:true,left:x,top:y});
-	tooltipWin.show();
-function showWFSBalloon(geom){
-	tt_rpt = mapToReal("mapframe1", point);
-	tooltipWin = new mb_popup({title:searchPopupTitle,html:createListOfGeometries(),width:270,height:150,balloon:true,left:x,top:y});
-function requestWfs(){
-	point = new Point(clickX, clickY);
-	var db_wfs_conf_id = [];
-	js_wfs_conf_id = [];
-	_geomArray = new GeometryArray();
-	wfs_config = window.frames["wfs_conf"].get_wfs_conf();
-	for (var i=0; i<mb_mapObj[ind].wms.length; i++){
-		for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-			var o = mb_mapObj[ind].wms[i].objLayer[ii];
-			if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1'){
-				if(o.checkScale(mb_mapObj[ind]))
-					db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
-	for(var i=0; i<db_wfs_conf_id.length; i++){
-		for(var ii=0; ii<wfs_config.length; ii++){
-			if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i])  js_wfs_conf_id[js_wfs_conf_id.length] = ii;
-	numberOfAjaxCalls_ =  js_wfs_conf_id.length;
-	var buffer = mb_wfs_tolerance/2;
-	var mapPosXAddPix = clickX + buffer;
-	var mapPosYAddPix = clickY + buffer;
-	var mapPosXRemovePix = clickX - buffer;
-	var mapPosYRemovePix = clickY - buffer;
-	var realWorld1 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
-	var realWorld2 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
-	var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
-	var realWorld4 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
-	for(var i=0; i<js_wfs_conf_id.length; i++){
-		var url = wfs_config[js_wfs_conf_id[i]]['wfs_getfeature'];
-		param = "service=wfs&request=getFeature&version=1.0.0&typename="+ wfs_config[js_wfs_conf_id[i]]['featuretype_name']+"&filter=";
-		var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>";
-		filter += "<Intersects><ogc:PropertyName>";
-		for(var j=0; j<wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
-			if(wfs_config[js_wfs_conf_id[i]]['element'][j]['f_geom'] == 1){
-				filter += wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
-		filter += "</ogc:PropertyName><gml:Polygon srsName='4326'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
-		filter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
-		filter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
-		filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter>";
-		url += param;
-		mb_get_geom_(url, filter, i, wfs_config[js_wfs_conf_id[i]]['featuretype_name'], js_wfs_conf_id[i], db_wfs_conf_id[i]);
-	return true;
-function mb_get_geom_(url, filter, index, typename, js_wfs_conf_id, db_wfs_conf_id) {
-	mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,{'url':url,'filter':filter,'typename':typename,'js_wfs_conf_id':js_wfs_conf_id, 'db_wfs_conf_id':db_wfs_conf_id},function(js_code,status){
-		if (js_code) {
-			eval(js_code);
-		if (typeof(geom) == "undefined") {
-			var geom = new GeometryArray();
-		checkIfAllAjaxCallsFinished_(geom);
-function checkIfAllAjaxCallsFinished_ (geom) {
-	numberOfFinishedAjaxCalls++;
-	if (typeof(geom) == 'object'){
-		_geomArray.union(geom);
-	if (numberOfFinishedAjaxCalls == numberOfAjaxCalls_) {
-		numberOfFinishedAjaxCalls = 0;
-		if(_geomArray.count()>0)
-			showWFSBalloon(_geomArray);
-function createListOfGeometries(){
-	if(_geomArray.count()>1){
-		var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
-		if (_geomArray.count() > 0) {
-			if(buttonWfs_toDigitize_on==1){
-				listOfGeom += "<tr><td style='color:black;font-size:12px;'>edit all</td>\n";
-				listOfGeom += "<td><img title='edit all' src='"+buttonWfs_toDigitize_src+"'  style='cursor:pointer' onclick='appendGeometryArrayToDigitize(_geomArray);'></img>";
-				listOfGeom += "</td>\n</tr>\n";
-				listOfGeom += "<tr>\n<td>&nbsp;</td>\n</tr>\n";
-			for (var i = 0 ; i < _geomArray.count(); i ++) {
-				if (_geomArray.get(i).get(-1).isComplete()) {
-					listOfGeom += "\t<tr>\n\t\t<td style = 'color:blue;font-size:12px;cursor:pointer;'\n";
-					listOfGeom += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
-					listOfGeom += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
-					listOfGeom += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+"));' ";
-					var geomName = getListTitle(_geomArray.get(i));
-					//if (_geomArray.get(i).geomType == geomType.polygon) {geomName += "(polygon)";}
-					//else if (_geomArray.get(i).geomType == geomType.line) {geomName += "(line)";}
-					//else if (_geomArray.get(i).geomType == geomType.point) {geomName += "(point)";}
-					listOfGeom += ">" + geomName +"</td>";
-						listOfGeom += "<td><img title='edit geometry object' src='"+buttonWfs_toDigitize_src+"'  style='cursor:pointer' onclick='appendGeometryToDigitize("+i+");'></img></td>";
-					listOfGeom += "\t\t</tr>\n";
-		listOfGeom += "</table>\n";
-		return listOfGeom;
-	else{
-		geometryIndex = 0;
-		wfsConf = get_complete_wfs_conf();
-		var wfsConfIndex = _geomArray.get(0).wfs_conf;
-		var currentWfsConf = wfsConf[wfsConfIndex];
-		var resultHtml = "";
-		resultHtml += "<table style='background-color:#EEEEEE;'>\n";
-		for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
-		    if(currentWfsConf.element[i].f_show_detail==1){
-		    	if( _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
-					//console.log(currentWfsConf.element[i].element_name+"---"+currentWfsConf.element[i].f_respos);
-					resultHtml +="<tr><td>\n";
-					resultHtml += currentWfsConf.element[i].f_label;
-					resultHtml +="</td>\n";
-					resultHtml += "<td>\n";
-					var elementVal = _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name);
-					if(currentWfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
-						var setUrl = currentWfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+elementVal+"' target='_blank'");
-						if(setUrl.match(/><\/a>/)){
-							var newLink	=	setUrl.replace(/><\/a>/, ">"+elementVal+"</a>");
-						else{
-							var newLink = setUrl;
-						if(openLinkFromSearch=='1'){
-							window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
-						resultHtml +=  newLink;
-					else{
-						resultHtml += elementVal;
-					resultHtml += "</td></tr>\n";
-		resultHtml += "</table>\n";
-		return resultHtml;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
-	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function Numsort (a, b) {
-  return a - b;
-function getListTitle (geom) {
-	wfsConfId = geom.wfs_conf;
-	wfsConf = window.frames["wfs_conf"].get_wfs_conf();
-	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
-		var resultArray = [];
-		var resultName = "";
-		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
-			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1 && geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) !=false) {
-				var pos = wfsConf[wfsConfId]['element'][i]['f_respos'];
-				if (typeof(resultArray[pos]) != "undefined") {
-					resultArray[pos] += " " + geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
-				else {
-					resultArray[pos] = geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
-				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
-		resultArray.sort(Numsort);
-		var resultName = resultArray.join(" ");
-		if (resultName == "") {
-			resultName = wfsConf[wfsConfId]['g_label'];
-		return resultName;
-	else {
-		return msgObj.digitizeDefaultGeometryName;
Deleted: branches/nimix_dev/http/javascripts/tooltip24.php
--- branches/nimix_dev/http/javascripts/tooltip24.php	2008-09-16 09:49:04 UTC (rev 2940)
+++ branches/nimix_dev/http/javascripts/tooltip24.php	2008-09-16 11:54:19 UTC (rev 2941)
@@ -1,278 +0,0 @@
-<?php
-	include($fname);
-else {
-var mouseMoves=0;
-var point;
-function mod_tooltipInit(){
-		mod_tooltip_run();
-mb_registerInitFunctions("mod_tooltipInit();");
-function mod_tooltip_run(){
-	mouseMoves++;
-	if(req)
-		str_LayerStyles=mb_checkScale("mapframe1",ind,i);
-		arr_layers = str_LayerStyles[0].split(",");
-				for(iii=0;iii<arr_layers.length;iii++){
-					if(o.layer_name == arr_layers[iii]){
-						break;
-		url += param;
-	return true;
-		if (js_code) {
-			eval(js_code);
-	else{
-						else{
-					else{
-  return a - b;
-				else {
-	else {
Deleted: branches/nimix_dev/http/javascripts/tooltip_wms.php
--- branches/nimix_dev/http/javascripts/tooltip_wms.php	2008-09-16 09:49:04 UTC (rev 2940)
+++ branches/nimix_dev/http/javascripts/tooltip_wms.php	2008-09-16 11:54:19 UTC (rev 2941)
@@ -1,346 +0,0 @@
-<?php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-	include($fname);
-else {
-//tolerance when we ask wfs
-var mb_wfs_tolerance = 8;
-//initialize Element Vars
-//destination frame for the request (creates Popup if empty)
-if(typeof(tooltip_destinationFrame)==='undefined')
-	var tooltip_destinationFrame = "";
-if(typeof(tooltip_timeDelay)==='undefined')
-	var tooltip_timeDelay = 1000;
-if(typeof(tooltip_styles)==='undefined')
-	var tooltip_styles = "";
-if(typeof(tooltip_styles_detail)==='undefined')
-	var tooltip_styles_detail = "";
-try{
-	var no_result_text = eval(tooltip_noResultArray);
-}catch(e){
-	var no_result_text = ["Kein Ergebnis.",'<body onLoad="javascript:window.close()">'];
-var mouseMoves=0;
-var point;
-var tooltipWfsRequestCount = 0;
-var tooltipWmsRequestCount = 0;
-var numberOfFinishedWfsRequests = 0;
-var numberOfFinishedWmsRequests = 0;
-var TooltipMsg = {'title':"<?php echo _mb("Informations");?>"};
-//buttonWfs_toDigitize_on ="0";
-	$(window.frames[tooltipTarget].document).mousemove(function(event){
-		mb_getMousePos(event,tooltipTarget);
-eventInit.register(mod_tooltipInit);
-	mouseMoves++;
-	setTimeout("if(mouseMoves=="+mouseMoves+")fireRequests();",tooltip_timeDelay);
-function fireRequests(){
-	var ind = getMapObjIndexByName(tooltipTarget);
-	point = new Point(clickX,clickY);
-	var point_geom = new Geometry(geomType.point);
-	point_geom.addPoint(mapToReal(tooltipTarget,point));
-	//FeatureInfo requests
-	urls = mb_mapObj[ind].getFeatureInfoRequests(point);
-	tooltipWmsRequestCount = urls.length;
-	numberOfFinishedWmsRequests	= 0;
-	for(var j=0;j < urls.length;j++){
-			checkFeatureInfoResults);
-	//WFS requests
-	requests = getWfsRequests(tooltipTarget, point_geom, true);
-	tooltipWfsRequestCount = requests.length;
-	numberOfFinishedWfsRequests = 0;
-	resultGeomArray = new GeometryArray();
-	for(var j=0;j< requests.length;j++){
-		mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,requests[j],function(js_code,status){
-			if (js_code) {
-				eval(js_code);
-			checkWfsResultsFinished(geom);
-function checkFeatureInfoResults(js_code,status){
-	numberOfFinishedWmsRequests++;
-	//check if there are results
-	if(js_code == "")
-		return;
-	for(var k=0;k < no_result_text.length;k++){
-		if(js_code.indexOf(no_result_text[k])!==-1){
-			return;
-	//output code
-	displayResultDoc(js_code);
-function checkWfsResultsFinished(g){
-	//check if all wfs requests arrived
-	numberOfFinishedWfsRequests++;
-	if (typeof(g) == 'object'){
-		resultGeomArray.union(g);
-	if (numberOfFinishedWfsRequests == tooltipWfsRequestCount) {
-		if(resultGeomArray.count()>0){
-			//generate and output result
-			if(resultGeomArray.count()>1)
-				var html = createSimpleWfsResultHtml(resultGeomArray);
-			else
-				var html = createDetailedWfsResultHtml(resultGeomArray);
-			displayResultDoc(html);
-function isFirstResult(){
-	return (numberOfFinishedWfsRequests+numberOfFinishedWmsRequests) == 1;
-function isLastResult(){
-	return (numberOfFinishedWfsRequests == tooltipWfsRequestCount && numberOfFinishedWmsRequests == tooltipWmsRequestCount);
-function displayResultDoc(html){
-	//test if we have a fixed destination and create popup otherwise
-	if(tooltip_destinationFrame=="")
-		return showBalloonFrame(html);
-	//put the frame there
-	$("#"+tooltip_destinationFrame).each(function(){
-	    var oDoc = this.contentWindow || this.contentDocument;
-	    if (oDoc.document) {
-	        oDoc = oDoc.document;
-		if(isFirstResult())
-	  		oDoc.open();
-		oDoc.write(html);
-		if(isLastResult())
-			oDoc.close();
-function showBalloonFrame(html){
-	if(isFirstResult()){
-		//claculate Position
-		x=clickX+parseInt(document.getElementById(tooltipTarget).style.left);
-		y=clickY+parseInt(document.getElementById(tooltipTarget).style.top);
-		//hide old Popup
-		//create Popup and append document
-		tooltipWin = new mb_popup({html:'<iframe id="tooltipWin" name="tooltipWin" src="about:blank"/>',title:TooltipMsg.title,width:270,height:200,balloon:true,left:x,top:y});
-		//open document
-		tooltipWin.open();
-	tooltipWin.write(html);
-	if(isLastResult()){
-		tooltipWin.close();
-	//finally display popup
-function getWfsRequests(target, geom, checkscale, filteroption){
-	//get all configurations
-	wfs_config = get_complete_wfs_conf();
-	var ind = getMapObjIndexByName(target);
-	var js_wfs_conf_id = [];
-	//search configurations that are selected (and in scale)
-	for (var i=0; i < mb_mapObj[ind].wms.length; i++){
-		for(var ii=0; ii < mb_mapObj[ind].wms[i].objLayer.length; ii++){
-			if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1' && o.gui_layer_visible == '1'){
-				if(!checkscale || o.checkScale(mb_mapObj[ind]))
-	for(var i=0; i < db_wfs_conf_id.length; i++){
-		for(var ii=0; ii < wfs_config.length; ii++){
-			if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i]){
-				js_wfs_conf_id[js_wfs_conf_id.length] = ii;
-				break;
-	//build requests
-	var requests = [];
-	for(var i=0;i < js_wfs_conf_id.length; i++){
-		//build url
-		url += mb_getConjunctionCharacter(wfs_config[js_wfs_conf_id[i]]['wfs_getfeature']);
-		url += "service=wfs&request=getFeature&version=1.0.0";
-		url += "&typename="+ wfs_config[js_wfs_conf_id[i]]['featuretype_name'];
-		url += "&filter=";
-		//search for geometry column
-		var geometryCol;
-		for(var j=0; j < wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
-				geometryCol = wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
-		//get filter
-		var filter = new WfsFilter();
-		filter.addSpatial(geom, geometryCol, filteroption, wfs_config[js_wfs_conf_id[i]]['featuretype_srs'], target);
-		requests.push({'url':url,'filter':filter.toString(), 'typename':wfs_config[js_wfs_conf_id[i]]['featuretype_name'],'js_wfs_conf_id':js_wfs_conf_id[i], 'db_wfs_conf_id':db_wfs_conf_id[i]});
-	return requests;
-function createSimpleWfsResultHtml(_geomArray){
-	var geometryIndex = 0;
-	var html = '<html><head><style type="text/css">';
-	html += tooltip_styles;
-	html += "</style></head><body><table>\n";
-			html += "\t<tr class='list_"+(i%2?"uneven":"even")+"'>\n\t\t<td \n";
-//			html += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
-//			html += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
-//			html += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+"));' ";
-			var geomName = getWfsListEntry(_geomArray.get(i));
-			html += ">" + geomName +"</td>";
-			html += "\t\t</tr>\n";
-	html += "</table></body>\n";
-	return html;
-function createDetailedWfsResultHtml(_geomArray){
-	var cnt = 0;
-	html += tooltip_styles_detail;
-	var wfsConfIndex = _geomArray.get(geometryIndex).wfs_conf;
-				html +="<tr class='list_"+(cnt%2?"uneven":"even")+"'><td>\n";
-				html += currentWfsConf.element[i].f_label;
-				html +="</td>\n";
-				html += "<td>\n";
-					else{
-					html +=  newLink;
-				else{
-					html += elementVal;
-				html += "</td></tr>\n";
-				cnt++;
-	return html;
-function getWfsListEntry (geom) {
-	if (typeof(wfsConfId) == "number" && wfsConfId >=0 && wfsConfId < wfsConf.length) {
-				else {
-	else {
-		return false;
Added: branches/nimix_dev/log/.dropbox
--- branches/nimix_dev/log/.dropbox	                        (rev 0)
+++ branches/nimix_dev/log/.dropbox	2008-09-16 11:54:19 UTC (rev 2941)
@@ -0,0 +1,2 @@
+(dp0
More information about the Mapbender_commits mailing list
