[Mapbender-commits] r3851 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Apr 3 05:25:22 EDT 2009
Author: christoph
Date: 2009-04-03 05:25:22 -0400 (Fri, 03 Apr 2009)
New Revision: 3851
   trunk/mapbender/resources/db/update/update_2.7.sql
wrong SQL
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql	2009-04-03 09:02:12 UTC (rev 3850)
+++ trunk/mapbender/resources/db/update/update_2.7.sql	2009-04-03 09:25:22 UTC (rev 3851)
@@ -1,4 +1,4 @@
 -- remove event handlers, are now in the script
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'navFrame';
\ No newline at end of file
+UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
More information about the Mapbender_commits mailing list
