[Mapbender-commits] r3868 - branches/pseudoSlippy/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Apr 10 02:41:52 EDT 2009
Author: christoph
Date: 2009-04-10 02:41:51 -0400 (Fri, 10 Apr 2009)
New Revision: 3868
Added:
   branches/pseudoSlippy/http/javascripts/map_obj.js_
Modified: branches/pseudoSlippy/http/javascripts/map_obj.js
--- branches/pseudoSlippy/http/javascripts/map_obj.js	2009-04-08 09:27:11 UTC (rev 3867)
+++ branches/pseudoSlippy/http/javascripts/map_obj.js	2009-04-10 06:41:51 UTC (rev 3868)
@@ -7,11 +7,50 @@
 function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+	this.extent = null;
+	 * get the extent of the mapObj
+	 * @member mb_mapObj_const
+	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+	 * @type string
+	this.getExtent = function(){
+		return this.extent;
+	 * get the extent as minx, maxx, miny, maxy
+	 * @return extent and additional informations of the mapObj
+	 * @type Object
+	this.getExtentInfos = function(){
+		var ext = null;
+		var c = this.getExtent()
+		if (c !== null) {
+			c = c.split(",");
+			ext = new Extent(c[0], c[1], c[2], c[3]);
+		return ext;
 	 * set the extent of the wms
 	this.setExtent = function(minx, miny, maxx, maxy){
+		var ext = this.getExtentInfos();
+		if (ext !== null) {
+			// old extent
+			this.oldExtent = new Extent(ext.minx, ext.miny, ext.maxx, ext.maxy);
+			// pixel coordinates of new extent in old extent
+			var oldpixll = this.convertRealToPixel(new Point(parseFloat(minx), parseFloat(miny)));
+			var oldpixur = this.convertRealToPixel(new Point(parseFloat(maxx), parseFloat(maxy)));
+			this.oldExtentPix = new Extent(oldpixll.x, oldpixll.y, oldpixur.x, oldpixur.y);
 		this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
@@ -222,31 +261,8 @@
 	domElement.style.width = this.width;
 	domElement.style.height = this.height;
-	 * get the extent of the mapObj
-	 * @member mb_mapObj_const
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
-	 * @type string
-	this.getExtent = function(){
-		return this.extent;
-	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
-	 * @type Object
-	this.getExtentInfos = function(){
-		var c = this.getExtent().split(",");
-		var ext = new Extent(c[0], c[1], c[2], c[3]);
-		return ext;
 	 * Sets the list of layers, styles and querylayers for a specified WMS
 	this.restateLayers = function(wms_id){
@@ -290,9 +306,6 @@
 	 * @param {Object} direction
 	this.pan = function (direction) {
-		var extent = this.getExtentInfos();
-		this.oldExtent = extent;
 		var arrayBBox = this.extent.split(",");
 		var minx = parseFloat(arrayBBox[0]);
 		var miny = parseFloat(arrayBBox[1]);
@@ -302,8 +315,6 @@
 		var xtenty =  maxy - miny;
 		var factor = 0.4;
-//		var oldPoint = this.convertRealToPixel(new Point(minx, miny));
 		switch (direction) {
 			case "NW" :
 				minx -= (xtentx * factor);
@@ -346,11 +357,7 @@
 				maxx -= (xtentx * factor);
 				break;
-//		var newPoint = this.convertRealToPixel(new Point(minx, miny));
-//		var diff = oldPoint.minus(newPoint);
-//		this.arrangeElements(diff.y, diff.x);
-		this.extent = minx + "," + miny + "," + maxx + "," + maxy;
+		this.setExtent(minx, miny, maxx, maxy);
 		this.setMapRequest();
@@ -734,12 +741,179 @@
 	this.setMapRequest = function(){
-		if (this.oldExtent) {
-			this.arrangeElements();
+		if (typeof(this.requestArray) === "undefined") {
+			this.requestArray = [];
+		if (typeof(this.requestCount) === "undefined") {
+			this.requestCount = 0;
+		else {
+			this.requestCount ++;
+		var currentRequest = {};
+		currentRequest.nr = this.requestCount;
+		currentRequest.requestId = this.elementName + "_request_" + currentRequest.nr;
+		currentRequest.styleString = "position:absolute;";
-		firstMapReady = false;
+		// this is the first request
+		if (this.requestCount === 0) {
+			// no animation for the first request
+			currentRequest.styleString += "top:0px;left:0px;";
+		else {
+			var previousRequest = {};
+			previousRequest.nr = this.requestCount - 1;
+			previousRequest.requestId = this.elementName + "_request_" + previousRequest.nr;
+			if (this.requestCount >= 2) {
+				var previousButOneRequest = {};
+				previousButOneRequest.nr = this.requestCount - 2;
+				previousButOneRequest.requestId = this.elementName + "_request_" + previousButOneRequest.nr;
+			// this is the start position for the animation
+			currentRequest.styleString += "top:"+this.oldExtentPix.maxy+"px;left:"+this.oldExtentPix.minx+"px;";
+		currentRequest.styleString += "z-index:" + ii + ";";
+		// add new request div to DOM
+		$currentRequestDiv = $("<div id='" + currentRequest.requestId + "' style=\"" + currentRequest.styleString + "\"></div>");
+		$('#' + this.elementName+"_maps").append($currentRequestDiv);
+		for (var ii = 0; ii < this.wms.length; ii++) {
+			var currentWms = this.wms[ii];
+			if (!(currentWms.gui_wms_visible > 0)) {
+				continue;
+			//disable Layer which are out of scale
+			var validLayers = that.checkScale(ii);
+			var layerNames = validLayers.toString();
+			var newMapURL = null;
+			if (that.layers[ii] !== "" && layerNames !== ''){
+				// get map URL
+				newMapURL = that.getMapUrl(ii);
+			// container for the image, has opacity
+			var myDivId = this.elementName + "_div_" + ii + "_" + this.requestCount;
+			var currentOpacity = currentWms.gui_wms_mapopacity;
+			var opacityString = "";
+			if (currentOpacity != 1) {
+				opacityString += "opacity:" + currentOpacity + "; ";
+				opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
+				opacityString += "-moz-opacity:" + currentOpacity + " ; ";
+				opacityString += "-khtml-opacity:" + currentOpacity;
+			var newMapRequest = "<div id='"+myDivId+"' style=\""+opacityString+"\"></div>";
+			var $div = $(newMapRequest);
+			$currentRequestDiv.append($div);
+			// actual image
+			var myMapId = this.elementName + "_map_" + ii + "_" + this.requestCount;
+			var imageString = "";
+			if (newMapURL) {
+				if (that.requestCount >= 2) {
+					$("#" + previousButOneRequest.requestId).remove();
+				var width, height;
+					// no animation for first map request
+					width = this.width;
+					height = this.height;
+				else {
+					// animation default settings for zoom
+					width = this.oldExtentPix.maxx - this.oldExtentPix.minx;
+					height = this.oldExtentPix.miny - this.oldExtentPix.maxy;
+				imageString = "<img id='"+myMapId+"' name='mapimage' ";
+				imageString += "width='"+width+"' ";
+				imageString += "height='"+height+"' ";
+				imageString += "style='visibility:hidden' ";
+				imageString += "border='0' />";
+				$(imageString).attr('src', newMapURL).appendTo($div).load(function () {
+					this.style.visibility = "visible";
+			that.mapURL[ii]= newMapURL;
+			currentWms.mapURL = newMapURL;
+			if (mb_log && currentWms.mapURL) {
+				var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
+//			myMapId.push(myMapId);
+		// animate divs and imgs
+		// no animation necessary if first request.
+		if (this.requestCount > 0) {
+			// animate previous request div and images
+			var oldLL = new Point(this.oldExtent.minx, this.oldExtent.miny);
+			var oldUR = new Point(this.oldExtent.maxx, this.oldExtent.maxy);
+			var oldLLPix = this.convertRealToPixel(oldLL);
+			var oldURPix = this.convertRealToPixel(oldUR);
+			var left = oldLLPix.x;
+			var top = oldURPix.y;
+			var width = oldURPix.x - oldLLPix.x;
+			var height = oldLLPix.y - oldURPix.y;
+			console.log(previousRequest.requestId);
+			var mapDiv = $("#" + previousRequest.requestId);
+			mapDiv.animate({
+				left: left + "px",
+				top: top + "px"
+				duration: "slow"
+			var mapImg = $("#" + previousRequest.requestId + " div img");
+			mapImg.animate({
+				width: width + "px",
+				height: height + "px"
+				duration: "slow"
+			// animate current request div and images
+			var currentMapDiv = $("#" + currentRequest.requestId);
+			currentMapDiv.animate({
+				left: "0px",
+				top: "0px"
+				duration: "slow"
+			var currentMapImg = $("#" + currentRequest.requestId + " div img");
+			currentMapImg.animate({
+				width: this.width + "px",
+				height: this.height + "px"
+				duration: "slow"
 		var ret = eventBeforeMapRequest.trigger({
 				map: this
 			}, "AND"
@@ -753,31 +927,13 @@
 		var newMapRequest = "";
-		// once the first map is ready, the old ones will be deleted
-		removeOldMaps = function () {
-			for (var ii = 0; ii < that.wms.length; ii++) {
-				var myDivId = that.elementName + "_div_" + ii;
-				var $div = $('#' + myDivId);
-				if (!firstMapRequest) {
-					while ($div.children().size() > 1) {
-						$div.children().eq(0).remove();
 				continue;
-			myMapId.push(this.elementName + "_map_" + ii);
-			newMapRequest += getLayerHtmlCode(ii);
-//		writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
 		eventAfterMapRequest.trigger({
@@ -788,112 +944,13 @@
 	var that = this;
-	var firstMapReady = false;
-	var firstMapRequest = true;
-	var removeOldMaps = function () {
-		// is written in setMapRequest
-		return null;
 	this.arrangeElements = function () {
-		var oldLL = new Point(this.oldExtent.minx, this.oldExtent.miny);
-		var oldUR = new Point(this.oldExtent.maxx, this.oldExtent.maxy);
-		var oldLLPix = this.convertRealToPixel(oldLL);
-		var oldURPix = this.convertRealToPixel(oldUR);
-		var left = oldLLPix.x;
-		var top = oldURPix.y;
-		var width = oldURPix.x - oldLLPix.x;
-		var height = oldLLPix.y - oldURPix.y;
-		var mapDiv = $("#" + this.elementName + "_maps div");
-		mapDiv.animate({
-			left: left + "px",
-			top: top + "px"
-			duration: "slow"
-		var mapImg = $("#" + this.elementName + "_maps div img");
-		mapImg.animate({
-			width: width + "px",
-			height: height + "px"
-			duration: "slow"
 	var getLayerHtmlCode = function (ii) {
 		var currentWms = that.wms[ii];
-		var myMapId = that.elementName + "_map_" + ii;
-		//disable Layer which are out of scale
-		var validLayers = that.checkScale(ii);
-		var layerNames = validLayers.toString();
-		var newMapURL = false;
-		var opacityString = "";
-		if (that.layers[ii] !== "" && layerNames !== ''){
-			// get map URL
-			newMapURL = that.getMapUrl(ii);
-			var currentOpacity = currentWms.gui_wms_mapopacity;
-			if (currentOpacity != 1) {
-				opacityString += "opacity:" + currentOpacity + "; ";
-				opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
-				opacityString += "-moz-opacity:" + currentOpacity + " ; ";
-				opacityString += "-khtml-opacity:" + currentOpacity;
-		var imageString = "";
-		if (newMapURL) {
-			imageString = "<img id='"+myMapId+"' name='mapimage' ";
-			imageString += "width='"+that.width+"' ";
-			imageString += "height='"+that.height+"' ";
-			imageString += "border='0' />";
-		var newMapRequest = "<div id='"+myDivId+"' ";
-		newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
-		newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
-		newMapRequest += "</div>";
-		if ($('#' + myDivId).size() === 0) {
-			$('#' + that.elementName+"_maps").append($(newMapRequest));
-		$(imageString).attr('src', newMapURL).load(function () {
-			$div.css({
-					left: "0px", top: "0px"
-				}).append( $(this) );
-			if (!firstMapReady) {
-				mb_arrangeElement(that.frameName, that.elementName+"_maps", 0, 0);
-				for(var i=0; i<mb_PanSubElements.length; i++){
-					mb_arrangeElement(that.frameName, mb_PanSubElements[i], 0, 0);
-				firstMapReady = true;
-				removeOldMaps();
-				firstMapRequest = false;
-		that.mapURL[ii]= newMapURL;
-		currentWms.mapURL = newMapURL;
-		if (mb_log && currentWms.mapURL) {
-			var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
 		return newMapRequest;
Added: branches/pseudoSlippy/http/javascripts/map_obj.js_
--- branches/pseudoSlippy/http/javascripts/map_obj.js_	                        (rev 0)
+++ branches/pseudoSlippy/http/javascripts/map_obj.js_	2009-04-10 06:41:51 UTC (rev 3868)
@@ -0,0 +1,1042 @@
+* $Id: map_obj.js 2517 2008-06-19 16:40:00Z christoph $
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+var mb_mapObj = [];
+function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+	 * set the extent of the wms
+	this.setExtent = function(minx, miny, maxx, maxy){
+		this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
+	 * get the width of the mapObj
+	 * @return width of the mapObj
+	 * @type integer
+	this.getWidth = function(){
+		return parseInt(this.width, 10);
+	 * set the width of the mapObj
+	 * @param {integer} widht the width of the mapObj
+	this.setWidth = function(width){
+		this.width = parseInt(width, 10);
+		//apply new width
+		if(this.frameName){
+			document.getElementById(this.frameName).style.width = this.width;
+		var domElement = this.getDomElement();
+		domElement.style.width = this.width;
+	 * get the height of the mapObj
+	 * @type integer
+	this.getHeight = function(){
+		return parseInt(this.height, 10);
+	this.getDomElement = function(){
+			return window.frames[this.frameName].document.getElementById(this.elementName);
+		return document.getElementById(this.elementName);
+	 * set the height of the mapObj
+	 * @param {integer} height the height of the mapObj
+	this.setHeight = function(height){
+		this.height = parseInt(height, 10);
+		//apply new height
+			document.getElementById(this.frameName).style.height = this.height;
+		domElement.style.height = this.height;
+	this.getMousePosition = function (e) {
+		var clickX, clickY;
+		if ($.browser.msie) {
+			if (window.event) {
+				clickX = window.event.clientX;
+				clickY = window.event.clientY;
+			else {
+				clickX = e.clientX;
+				clickY = e.clientY;
+		else{
+			clickX = e.pageX;
+			clickY = e.pageY;
+		var currentPos = null;
+		if (this.type == "DIV") {
+			var mapDomElement = this.getDomElement();
+			currentPos = new Point(
+				clickX - parseInt(mapDomElement.style.left),
+				clickY - parseInt(mapDomElement.style.top)
+			// if the mouse position is not on top of the map, return null
+			if (currentPos.x < 0 || currentPos.x > this.width ||
+				currentPos.y < 0 || currentPos.y > this.height) {
+				return null;
+		else {
+				clickX,
+				clickY
+		return currentPos;
+	 * converts the extent of the mapobject so that the maximum	extent will be displayed
+	this.calculateExtent = function(ext){
+		var relation_px_x = this.getWidth() / this.getHeight();
+		var relation_px_y = this.getHeight() / this.getWidth();
+		var relation_bbox_x = ext.extentx / ext.extenty;
+		if (relation_bbox_x <= relation_px_x) {
+			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+		if (relation_bbox_x > relation_px_x) {
+			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+		this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
+		return ext;
+	this.width = width;
+	this.height = height;
+	this.frameName = frameName;
+	this.type = (frameName !== "") ? "IFRAME" : "DIV";
+	this.elementName = elementName;
+	this.layers = [];
+	this.styles = [];
+	this.querylayers = [];
+	this.geom = "";
+	this.gml = "";
+	this.wms = [];
+	// Add pointers to WMS objects which are in this map.
+	// If wms_index is set (=map is overview), only this
+	// WMS is being pointed to.
+	var index = 0;
+	for (var i = 0; i < wms.length; i++) {
+		var isValidWms = (wms_index === null) || (wms_index == i);
+		if (isValidWms) {
+			this.wms[index] = wms[i];
+			this.wms[index].mapURL = false;
+			index++;
+	// set list of visible layers, active querylayers
+	// and styles for each WMS in this map
+	var cnt_layers;
+	var cnt_querylayers;
+	var styles;
+	var layers;
+	var querylayers = "";
+	for (i = 0; i < this.wms.length; i++) {
+		cnt_layers = 0;
+		cnt_querylayers = 0;
+		styles = "";
+		layers = "";
+		querylayers = "";
+		for (var ii = 0; ii < this.wms[i].objLayer.length; ii++) {
+			// layer is visible and not root layer
+			if (this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii > 0) {
+				if (cnt_layers > 0) {
+					layers += ",";
+					styles += ",";
+				layers += wms[i].objLayer[ii].layer_name;
+				styles += "";
+				cnt_layers++;
+			// layer is queryable and not root layer
+			if (this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii > 0) {
+				if (cnt_querylayers > 0) {
+					querylayers += ",";
+				querylayers += wms[i].objLayer[ii].layer_name;
+				cnt_querylayers++;
+		this.layers[i] = layers;
+		this.styles[i] = styles;
+		this.querylayers[i] = querylayers;
+	this.epsg = wms[0].gui_wms_epsg;
+	var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+	for (var i = 0; i < wms[0].gui_epsg.length; i++) {
+		if (this.epsg == wms[0].gui_epsg[i]) {
+			bbox_minx = parseFloat(wms[0].gui_minx[i]);
+			bbox_miny = parseFloat(wms[0].gui_miny[i]);
+			bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+			bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+	var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
+	this.oldExtent = null;
+	this.calculateExtent(wmsExtent);
+	this.mapURL = [];
+	 * @type string
+	 * @type Object
+		var c = this.getExtent().split(",");
+		var ext = new Extent(c[0], c[1], c[2], c[3]);
+		return ext;
+	 * Sets the list of layers, styles and querylayers for a specified WMS
+	this.restateLayers = function(wms_id){
+		for (var i = 0; i < this.wms.length; i++) {
+			if (this.wms[i].wms_id == wms_id) {
+				var currentWms = this.wms[i];
+				var cnt_layers = 0;
+				var cnt_querylayers = 0;
+				var layers = "";
+				var styles = "";
+				for (var ii = 0; ii < currentWms.objLayer.length; ii++) {
+					var currentLayer = currentWms.objLayer[ii];
+					if (currentLayer.gui_layer_visible == 1 && !currentLayer.has_childs) {
+							layers += ",";
+							styles += ",";
+						layers += currentLayer.layer_name;
+						styles += "";
+						cnt_layers++;
+					if (currentLayer.gui_layer_querylayer == 1 && !currentLayer.has_childs) {
+						querylayers += currentLayer.layer_name;
+//		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+	 * @param {Object} direction
+	this.pan = function (direction) {
+		var extent = this.getExtentInfos();
+		this.oldExtent = extent;
+		var arrayBBox = this.extent.split(",");
+		var minx = parseFloat(arrayBBox[0]);
+		var miny = parseFloat(arrayBBox[1]);
+		var maxx = parseFloat(arrayBBox[2]);
+		var maxy = parseFloat(arrayBBox[3]);
+		var xtentx = maxx - minx;
+		var xtenty =  maxy - miny;
+		var factor = 0.4;
+//		var oldPoint = this.convertRealToPixel(new Point(minx, miny));
+		switch (direction) {
+			case "NW" :
+				minx -= (xtentx * factor);
+				maxx -= (xtentx * factor);
+				miny += (xtenty * factor);
+				maxy += (xtenty * factor);
+				break;
+			case "N" :
+				break;
+			case "NE" :
+				minx += (xtentx * factor);
+				maxx += (xtentx * factor);
+				break;
+			case "E" :
+				break;
+			case "SE" :
+				miny -= (xtenty * factor);
+				maxy -= (xtenty * factor);
+				break;
+			case "S" :
+				break;
+			case "SW" :
+				break;
+			case "W" :
+				break;
+//		var newPoint = this.convertRealToPixel(new Point(minx, miny));
+//		var diff = oldPoint.minus(newPoint);
+//		this.arrangeElements(diff.y, diff.x);
+		this.extent = minx + "," + miny + "," + maxx + "," + maxy;
+		this.setMapRequest();
+	this.zoomFull = function () {
+		for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
+			if (this.epsg == this.wms[0].gui_epsg[i]) {
+				var bbox_minx = parseFloat(this.wms[0].gui_minx[i]);
+				var bbox_miny = parseFloat(this.wms[0].gui_miny[i]);
+				var bbox_maxx = parseFloat(this.wms[0].gui_maxx[i]);
+				var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
+				var newExtent = this.calculateExtent(wmsExtent);
+				this.repaint(new Point(newExtent.minx, newExtent.miny), new Point(newExtent.maxx, newExtent.maxy));
+	 * zoom the map with a zoomfactor and optional to x,y coords
+	 * @param {boolean} in_ in = true, out = false
+	 * @param {float} factor the zoomfactor 1 equals 100%
+	 * @param {float} x center to x-position
+	 * @param {float} y center to y-position
+	this.zoom = function(in_, factor, x, y){
+		var factor = parseFloat(factor);
+		if (!in_) {
+			factor = 1 / factor;
+		var distx = extent.maxx - extent.minx;
+		var disty = extent.maxy - extent.miny;
+		if (x && y) {
+			var centerx = parseFloat(x);
+			var centery = parseFloat(y);
+		else {
+			// the image is already moved if x and y are given
+			var centerx = extent.minx + distx / 2;
+			var centery = extent.miny + disty / 2;
+		var new_distx = distx / factor;
+		var new_disty = disty / factor;
+		var minx = centerx - new_distx / 2;
+		var miny = centery - new_disty / 2;
+		var maxx = centerx + new_distx / 2;
+		var maxy = centery + new_disty / 2;
+	var performUnknownCalculation = function (value) {
+		return Math.pow(10,(
+			Math.round(
+				Math.log(value)/
+				Math.log(10)
+	this.convertPixelToReal = function (aPoint) {
+		var minX = parseFloat(arrayBBox[0]);
+		var minY = parseFloat(arrayBBox[1]);
+		var maxX = parseFloat(arrayBBox[2]);
+		var maxY = parseFloat(arrayBBox[3]);
+		var xtentx = maxX - minX;
+		var xtenty = maxY - minY;
+		var deltaX = xtentx/this.width;
+		var deltaY = xtenty/this.height;
+		var roundx, roundy;
+		if(deltaX > 0){
+			roundx = 1/performUnknownCalculation(deltaX);
+		else{
+			roundx = performUnknownCalculation(deltaX);
+		if(deltaY > 0){
+			roundy = 1/performUnknownCalculation(deltaY);
+		else{
+			roundy =  performUnknownCalculation(deltaY);
+		var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
+		var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
+		posX = Math.round(posX * roundx) / roundx;
+		posY = Math.round(posY * roundy) / roundy;
+		return new Point(posX, posY);
+	 * Convert real world coordinates to pixel coordinates
+	this.convertRealToPixel = function (aPoint) {
+		return new Point(
+			Math.round((aPoint.x - minX) * this.width /(maxX - minX)),
+			Math.round((maxY - aPoint.y) * this.height/(maxY - minY))
+	 * get the srs of the mapObj
+	 * @return srs as epsg:number
+	 * @type string
+	this.getSRS = function(){
+		return this.epsg;
+	 * get all mapRequests
+	 * @return array of mapRequests of this map object
+	 * @type string[]
+	this.getMapRequests = function(){
+		var allRequests = [];
+		//loop through all wms to get the mapRequests
+			var currentRequest = this.wms[i].getMapRequest(this);
+			if (currentRequest) {
+				allRequests.push(currentRequest);
+		if (allRequests.length > 0) {
+			return allRequests;
+		return false;
+	 * Return the map URL of the WMS at index i
+	 * @param {Object} currentWmsIndex
+	this.getMapUrl = function(ii){
+		var validLayers = currentWms.getLayers(this);
+		if(validLayers.length === 0) {
+			return false;
+		var layerNames = validLayers.join(",");
+		url = currentWms.wms_getmap;
+		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
+		if (currentWms.wms_version == "1.0.0") {
+			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
+		else {
+			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
+		url += "LAYERS=" + layerNames + "&";
+		url += "STYLES=";
+		var layer = layerNames.split(",");
+		for (var j = 0; j < layer.length; j++) {
+			if (j > 0) {
+				url += ",";
+			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
+				url += currentWms.getCurrentStyleByLayerName(layer[j]);
+		url += "&";
+		url += "SRS=" + this.epsg + "&";
+		url += "BBOX=" + this.extent + "&";
+		url += "WIDTH=" + this.width + "&";
+		url += "HEIGHT=" + this.height + "&";
+		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
+		url += "BGCOLOR=0xffffff&";
+		if (currentWms.gui_wms_mapformat.search(/gif/i) > -1 ||
+		currentWms.gui_wms_mapformat.search(/png/i) > -1) {
+			url += "TRANSPARENT=TRUE&";
+		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+		// add vendor-specific
+		for (var v = 0; v < mb_vendorSpecific.length; v++) {
+			var vendorSpecificString = eval(mb_vendorSpecific[v]);
+			// if eval doesn't evaluate a function, the result is undefined.
+			// Sometimes it is necessary not to evaluate a function, for
+			// example if you want to change a variable from the current
+			// scope (see mod_addSLD.php)
+			if (typeof(vendorSpecificString) != "undefined") {
+				url += vendorSpecificString + "&";
+		// add Filter
+		if (currentWms.wms_filter !== "") {
+			url += "&SLD=" + currentWms.wms_filter + "?id=" + mb_styleID + "&";
+		// add sld
+		if (currentWms.gui_wms_sldurl !== "") {
+			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
+		return url;
+	 * get all featureInfoRequests
+	 * @param float x the x-value of the click position in pixel
+	 * @param float y the y-value of the click position in pixel
+	 * @return array of all featureInfoRequests of this map object
+	 * @type string[]
+	this.getFeatureInfoRequests = function(clickPoint){
+		//loop through all wms to get the FeatureInfoRequests
+			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+		return false;
+	 * calculation of the mapscale
+	 * @return scale
+	 * @type integer
+	this.getScale = function(){
+		var scale;
+		var bbox = this.extent.split(",");
+		var xtenty;
+		if (this.epsg == "EPSG:4326") {
+			var pxLenx = (parseFloat(bbox[2]) - parseFloat(bbox[0])) / this.width;
+			var pxLeny = (parseFloat(bbox[3]) - parseFloat(bbox[1])) / this.height;
+			var lat_from = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2) * Math.PI) / 180;
+			var lat_to = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2 + pxLeny) * Math.PI) / 180;
+			var lon_from = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2) * Math.PI) / 180;
+			var lon_to = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2 + pxLeny) * Math.PI) / 180;
+			var dist = 6371229 * Math.acos(Math.sin(lat_from) * Math.sin(lat_to) + Math.cos(lat_from) * Math.cos(lat_to) * Math.cos(lon_from - lon_to));
+			scale = (dist / Math.SQRT2) * (mb_resolution * 100);
+		else {
+			xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
+			scale = (xtenty / this.height) * (mb_resolution * 100);
+		return parseInt(Math.round(scale));
+	this.checkScale = function(wmsIndex){
+		var thisLayer = this.layers[wmsIndex].split(",");
+		var thisScale = this.getScale();
+		var str_layer = "";
+		var cnt_layer = 0;
+		for (var i = 0; i < this.wms[wmsIndex].objLayer.length; i++) {
+			var currentLayer = this.wms[wmsIndex].objLayer[i];
+			var myLayername = currentLayer.layer_name;
+			var myMinscale = currentLayer.gui_layer_minscale;
+			var myMaxscale = currentLayer.gui_layer_maxscale;
+			for (var ii = 0; ii < thisLayer.length; ii++) {
+				if (thisLayer[ii] == myLayername && !currentLayer.has_childs) {
+					if (myMinscale !== 0 && thisScale < myMinscale) {
+						continue;
+					if (myMaxscale !== 0 && thisScale > myMaxscale) {
+						continue;
+					if (cnt_layer > 0) {
+						str_layer += ",";
+					str_layer += thisLayer[ii];
+					cnt_layer++;
+		var str_layerstyles = [];
+		str_layerstyles[0] = str_layer;
+		return str_layerstyles;
+	this.repaintScale = function(x, y, scale){
+		if (x === null && y === null) {
+			x = parseFloat(arrayBBox[0]) +
+			((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
+			2);
+			y = parseFloat(arrayBBox[1]) +
+			((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1])) /
+			2);
+		var minx = parseFloat(x) - (this.width / (mb_resolution * 100 * 2) * scale);
+		var miny = parseFloat(y) - (this.height / (mb_resolution * 100 * 2) * scale);
+		var maxx = parseFloat(x) + (this.width / (mb_resolution * 100 * 2) * scale);
+		var maxy = parseFloat(y) + (this.height / (mb_resolution * 100 * 2) * scale);
+		this.repaint(new Point(minx, miny), new Point(maxx, maxy));
+	this.repaint = function(min, max){
+		this.extent = min.x + "," + min.y + "," + max.x + "," + max.y;
+	this.setSingleMapRequest = function (wms_id) {
+		eventBeforeMapRequest.trigger({map:this});
+		var ts = mb_timestamp();
+		for (var ii = 0; ii < this.wms.length; ii++){
+			if (currentWms.wms_id != wms_id) {
+				continue;
+			var newMapRequest = getLayerHtmlCode(ii);
+			if (mb_log) {
+				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+			var myDivId = this.elementName + "_div_" + ii;
+			writeTag(this.frameName, myDivId, newMapRequest);
+			var myMapId = this.elementName + "_map_" + ii;
+			eventAfterMapRequest.trigger({"map":this, "myMapId":myMapId});
+			return true;
+		return false;
+	this.mb_setFutureObj = function(mod_back_cnt){
+		var cnt = this.mb_MapFutureObj.length;
+		this.mb_MapFutureObj[cnt] = {};
+		this.mb_MapFutureObj[cnt].reqCnt = mod_back_cnt;
+		this.mb_MapFutureObj[cnt].width = this.width;
+		this.mb_MapFutureObj[cnt].height = this.height;
+		this.mb_MapFutureObj[cnt].epsg = this.epsg;
+		this.mb_MapFutureObj[cnt].extent = this.extent;
+		this.mb_MapFutureObj[cnt].layers = [];
+		for(var i=0; i<this.layers.length;i++){
+			this.mb_MapFutureObj[cnt].layers[i] = this.layers[i];
+		this.mb_MapFutureObj[cnt].styles = [];
+		for(var i=0; i < this.styles.length;i++){
+			this.mb_MapFutureObj[cnt].styles[i] = this.styles[i];
+		this.mb_MapFutureObj[cnt].querylayers = [];
+		for(var i=0; i < this.querylayers.length; i++) {
+			this.mb_MapFutureObj[cnt].querylayers[i] = this.querylayers[i];
+	this.setMapRequest = function(){
+		if (this.oldExtent) {
+			this.arrangeElements();
+		firstMapReady = false;
+		var ret = eventBeforeMapRequest.trigger({
+				map: this
+			}, "AND"
+		if (ret === false) {
+			return true;
+		var myMapId = [];
+		var newMapRequest = "";
+		// once the first map is ready, the old ones will be deleted
+		removeOldMaps = function () {
+			for (var ii = 0; ii < that.wms.length; ii++) {
+				var myDivId = that.elementName + "_div_" + ii;
+				var $div = $('#' + myDivId);
+				if (!firstMapRequest) {
+					while ($div.children().size() > 1) {
+						$div.children().eq(0).remove();
+				continue;
+			myMapId.push(this.elementName + "_map_" + ii);
+			newMapRequest += getLayerHtmlCode(ii);
+//		writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
+			"map": this,
+			"myMapId": myMapId.join(",")
+	var that = this;
+//	var firstMapReady = false;
+//	var firstMapRequest = true;
+//	var removeOldMaps = function () {
+		// is written in setMapRequest
+//		return null;
+	this.arrangeElements = function () {
+		var mapDiv = $("#" + this.elementName + "_maps div");
+		mapDiv.animate({
+			top: top + "px"
+			duration: "slow"
+		var mapImg = $("#" + this.elementName + "_maps div img");
+		mapImg.animate({
+			duration: "slow"
+	var getLayerHtmlCode = function (ii) {
+		var currentWms = that.wms[ii];
+		if (!currentWms.activeImg) {
+			currentWms.activeImg = [];
+		if (typeof(currentWms.requestCount) === "undefined") {
+			currentWms.requestCount = 0;
+		else {
+			currentWms.requestCount ++;
+		var myDivId = that.elementName + "_div_" + ii + "_" + currentWms.requestCount;
+		var myMapId = that.elementName + "_map_" + ii + "_" + currentWms.requestCount;
+		var newMapURL = false;
+			// get map URL
+		if (newMapURL) {
+			imageString += "width='"+that.width+"' ";
+			imageString += "height='"+that.height+"' ";
+		var newMapRequest = "<div id='"+myDivId+"' ";
+		newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
+		newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
+		newMapRequest += "</div>";
+		$('#' + that.elementName+"_maps").append($(newMapRequest));
+		currentWms.activeImg.push(currentWms.requestCount);
+		$(imageString).attr('src', newMapURL).load(function () {
+			var currentRequestNr = currentWms.requestCount;
+			$div.css({
+				left: "0px", top: "0px"
+			}).append( $(this) );
+			var oldDivId = that.elementName + "_div_" + ii + "_" + (currentRequestNr - 1);
+			$("#" + oldDivId).remove();
+			if (!firstMapReady) {
+				mb_arrangeElement(that.frameName, that.elementName+"_maps", 0, 0);
+				for(var i=0; i<mb_PanSubElements.length; i++){
+					mb_arrangeElement(that.frameName, mb_PanSubElements[i], 0, 0);
+				firstMapReady = true;
+				removeOldMaps();
+				firstMapRequest = false;
+		return newMapRequest;
+	this.getWmsIdByTitle = function (title) {
+		for (var i=0; i < this.wms.length; i++) {
+			if (this.wms[i].wms_title == title) {
+				return this.wms[i].wms_id;
+		return null;
+	this.getWmsIndexById = function (wms_id) {
+		for (var i=0; i< this.wms.length; i++){
+			if(this.wms[i].wms_id == wms_id){
+				return i;
+		return null;
+	this.removeWms = function (wmsIndex) {
+		var wms_ID = null;
+		var i;
+		var new_wmsarray = [];
+		var new_layerarray = [];
+		var new_querylayerarray = [];
+		var new_stylesarray = [];
+		var new_mapURLarray = [];
+			if (i != wmsIndex) {
+				new_wmsarray.push(this.wms[i]);
+				new_layerarray.push(this.layers[i]);
+				new_querylayerarray.push(this.querylayers[i]);
+				new_stylesarray.push(this.styles[i]);
+				new_mapURLarray.push(this.mapURL[i]);
+			else {
+				wms_ID = this.wms[i].wms_id;
+		this.wms = new_wmsarray;
+		this.layers = new_layerarray;
+		this.querylayers = new_querylayerarray;
+		this.styles = new_stylesarray;
+		this.mapURL = new_mapURLarray;
+		var another_new_wmsarray = [];
+		for	(i = 0; i < window.wms.length; i++) {
+			if (window.wms[i].wms_id != wms_ID) {
+				another_new_wmsarray.push(window.wms[i]);
+		window.wms = another_new_wmsarray;
+	 * move a wms or layer
+	 * @param int wms_id id of wms to move
+	 * @param int layer_id id of layer to move
+	 * @return true of successful
+	 * @type boolean
+	this.move = function(wms_id, layer_id, moveUp){
+		var i,j;
+		for(i=0;i<this.wms.length;i++){
+			if (wms_id == this.wms[i].wms_id) {
+				break;
+		//check if only one wms is affected?
+		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
+			return this.wms[i].moveLayer(layer_id, moveUp);
+		//else swap wms
+		j = i + (moveUp?-1:1);
+		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
+			return false;
+		upper = this.wms[i];
+		this.wms[i] = this.wms[j];
+		this.wms[j] = upper;
+		var upperLayers = this.layers[i];
+		var upperStyles = this.styles[i];
+		var upperQuerylayers = this.querylayers[i];
+		this.layers[i] = this.layers[j];
+		this.styles[i] = this.styles[j];
+		this.querylayers[i] = this.querylayers[j];
+		this.layers[j] = upperLayers;
+		this.styles[j] = upperStyles;
+		this.querylayers[j] = upperQuerylayers;
+		return true;
+	this.getMousePos = function(e){
+		if(ie){
+				clickX = window.frames[fName].event.clientX;
+				clickY = window.frames[fName].event.clientY;
+			else{
+				clickX = event.clientX;
+				clickY = event.clientY;
+		else{
+			clickX = e.pageX;
+			clickY = e.pageY;
+		//remove divtag offset
+		clickX -= parseInt(this.getDomElement().style.left);
+		clickY -= parseInt(this.getDomElement().style.top);
+		return new Point(clickX, clickY);
+	eventAfterMapObjectConstruction.trigger();
More information about the Mapbender_commits mailing list
