[Mapbender-commits] r3877 - in branches/2.6/http: classes php
svn_mapbender at osgeo.org
Wed Apr 15 07:42:00 EDT 2009
Author: christoph
Date: 2009-04-15 07:42:00 -0400 (Wed, 15 Apr 2009)
New Revision: 3877
branches/2.6/http/classes/class_wmc.php
branches/2.6/http/php/mod_loadwmc_server.php
http://trac.osgeo.org/mapbender/ticket/441
Modified: branches/2.6/http/classes/class_wmc.php
--- branches/2.6/http/classes/class_wmc.php 2009-04-15 11:41:45 UTC (rev 3876)
+++ branches/2.6/http/classes/class_wmc.php 2009-04-15 11:42:00 UTC (rev 3877)
@@ -216,7 +216,7 @@
$result = array();
if ($this->userId && $this->xml && $this->wmc_title) {
$sql = "INSERT INTO mb_user_wmc VALUES ($1, $2, $3, $4, $5)";
- $v = array($this->wmc_id, $this->userId, $this->xml, $this->wmc_title, time());
+ $v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), time());
$t = array("s", "i", "s", "s", "s");
$res = db_prep_query($sql, $v, $t);
Modified: branches/2.6/http/php/mod_loadwmc_server.php
--- branches/2.6/http/php/mod_loadwmc_server.php 2009-04-15 11:41:45 UTC (rev 3876)
+++ branches/2.6/http/php/mod_loadwmc_server.php 2009-04-15 11:42:00 UTC (rev 3877)
@@ -3,6 +3,7 @@
require_once(dirname(__FILE__) . "/../classes/class_user.php");
require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
* encodes and delivers the data
@@ -57,7 +58,7 @@
while($row = db_fetch_array($res)){
$currentResult = array();
$currentResult["id"] = $row["wmc_id"];
- $currentResult["title"] = $row["wmc_title"];
+ $currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
array_push($wmcArray, $currentResult);
@@ -174,4 +175,4 @@
sendOutput($resultObj);
\ No newline at end of file
More information about the Mapbender_commits
