[Mapbender-commits] r3891 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 16 11:23:18 EDT 2009
Author: christoph
Date: 2009-04-16 11:23:18 -0400 (Thu, 16 Apr 2009)
New Revision: 3891
   trunk/mapbender/http/classes/class_gml_2_factory.php
   trunk/mapbender/http/classes/class_gml_3_factory.php
   trunk/mapbender/http/classes/class_gml_factory.php
   trunk/mapbender/http/classes/class_gml_line.php
   trunk/mapbender/http/classes/class_gml_multiline.php
   trunk/mapbender/http/classes/class_gml_multipolygon.php
   trunk/mapbender/http/classes/class_gml_point.php
   trunk/mapbender/http/classes/class_gml_polygon.php
bugfix: GML parser: GML3 includes GML2, so there may be mixed syntax
Modified: trunk/mapbender/http/classes/class_gml_2_factory.php
--- trunk/mapbender/http/classes/class_gml_2_factory.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_2_factory.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -48,16 +48,21 @@
 		return $nodeName;
-	private function parsePoint ($domNode, $gmlPoint) {
+	public static function parsePoint ($domNode) {
+		$gmlPoint = new GmlPoint();
 		$currentSibling = $domNode->firstChild;
 		while ($currentSibling) {
 			list($x, $y, $z) = explode(",", $currentSibling->nodeValue);
 			$gmlPoint->setPoint($x, $y);
 			$currentSibling = $currentSibling->nextSibling;
+		return $gmlPoint;
-	private function parseLine ($domNode, $gmlLine) {
+	public static function parseLine ($domNode) {
+		$gmlLine = new GmlLine();
@@ -67,9 +72,12 @@
+		return $gmlLine;
-	private function parsePolygon ($domNode, $gmlPolygon) {
+	public static function parsePolygon ($domNode) {
+		$gmlPolygon = new GmlPolygon();
 		$simpleXMLNode = simplexml_import_dom($domNode);
 		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
@@ -106,9 +114,12 @@
 				$ringCount++;
+		return $gmlPolygon;
-	private function parseMultiLine ($domNode, $gmlMultiLine) {
+	public static function parseMultiLine ($domNode) {
+		$gmlMultiLine = new GmlMultiLine();
@@ -133,10 +144,12 @@
 			$cnt++;
+		return $gmlMultiLine;
-	private function parseMultiPolygon ($domNode, $gmlMultiPolygon) {
-//		echo $domNode->nodeName."<br>";
+	public static function parseMultiPolygon ($domNode) {
+		$gmlMultiPolygon = new GmlMultiPolygon();
@@ -181,8 +194,8 @@
 			$cnt++;
-//			new mb_exception("create multipolygon " . serialize($gmlMultiPolygon->innerRingArray));
+		return $gmlMultiPolygon;
@@ -260,29 +273,24 @@
 				$geomType = $geomNode->nodeName;
 				switch ($geomType) {
 					case "gml:Polygon" :
-						$feature->geometry = new GMLPolygon();
+						$feature->geometry = self::parsePolygon($geomNode);
 						$feature->geometry->srs = $srs;
-						$this->parsePolygon($geomNode, $feature->geometry);
 						break;
 					case "gml:LineString" :
-						$feature->geometry = new GMLLine();
+						$feature->geometry = self::parseLine($geomNode);
-						$this->parseLine($geomNode, $feature->geometry);
 						break;
 					case "gml:Point" :
-						$feature->geometry = new GMLPoint();
+						$feature->geometry = self::parsePoint($geomNode);
-						$this->parsePoint($geomNode, $feature->geometry);
 						break;
 					case "gml:MultiLineString" :
-						$feature->geometry = new GMLMultiLine();
+						$feature->geometry = self::parseMultiLine($geomNode);
-						$this->parseMultiLine($geomNode, $feature->geometry);
 						break;
 					case "gml:MultiPolygon" :
-						$feature->geometry = new GMLMultiPolygon();
+						$feature->geometry = self::parseMultiPolygon($geomNode);
-						$this->parseMultiPolygon($geomNode, $feature->geometry);
 						break;
 					default:
 						$feature->properties[$columnName] = $value;
Modified: trunk/mapbender/http/classes/class_gml_3_factory.php
--- trunk/mapbender/http/classes/class_gml_3_factory.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_3_factory.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -53,7 +53,7 @@
 		return parent::createFromXml($xml, $wfsConf, $gml3);
-	protected function getDimensionFromNode ($domNode) {
+	public static function getDimensionFromNode ($domNode) {
 		if (!$domNode->hasAttribute("srsDimension")) {
 			return 2;
@@ -70,20 +70,24 @@
 		return $nodeName;
 			$coordArray = explode(" ", $currentSibling->nodeValue);
 			$gmlPoint->setPoint($coordArray[0], $coordArray[1]);
+		return $gmlPoint;
-			$dim = $this->getDimensionFromNode($currentSibling);
+			$dim = self::getDimensionFromNode($currentSibling);
 			$coordArray = explode(' ', trim($currentSibling->nodeValue));
 			for ($i = 0; $i < count($coordArray); $i += $dim) {
 				$x = $coordArray[$i];
@@ -92,9 +96,12 @@
+		return $gmlLine;
@@ -105,7 +112,7 @@
 		foreach ($allCoords as $Coords) {
 			$coordsDom = dom_import_simplexml($Coords);
-			$dim = $this->getDimensionFromNode($coordsDom);
+			$dim = self::getDimensionFromNode($coordsDom);
 			$coordArray = explode(' ', trim($coordsDom->nodeValue));
@@ -123,7 +130,7 @@
 				foreach ($coordinates as $coordinate) {
 					$coordsDom = dom_import_simplexml($coordinate);
@@ -134,9 +141,12 @@
 				$ringCount++;
@@ -150,7 +160,7 @@
@@ -159,9 +169,12 @@
 			$cnt++;
@@ -177,7 +190,7 @@
@@ -197,7 +210,7 @@
@@ -212,7 +225,8 @@
 			$cnt++;
@@ -293,29 +307,39 @@
 					case "gml:Polygon" :// untested!
+						if ($feature->geometry->isEmpty()) {
+							$feature->geometry = Gml_2_Factory::parsePolygon($geomNode);
 						break;
 					case "gml:LineString" :// untested!
+							$feature->geometry = Gml_2_Factory::parseLine($geomNode);
 						break;
 					case "gml:Point" :
+							$feature->geometry = Gml_2_Factory::parsePoint($geomNode);
 						break;
 					case "gml:MultiCurve" :
+							$feature->geometry = Gml_2_Factory::parseMultiLine($geomNode);
 						break;
 					case "gml:MultiSurface" :
+							$feature->geometry = Gml_2_Factory::parseMultiPolygon($geomNode);
 						break;
 					default:
Modified: trunk/mapbender/http/classes/class_gml_factory.php
--- trunk/mapbender/http/classes/class_gml_factory.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_factory.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -44,8 +44,6 @@
 		$jsonObj = $json->decode($geoJson);
 		// check if valid feature collection
-		new mb_exception("Is Array? " . is_array($jsonObj->features));
-		new mb_exception("Type? " . strtoupper($jsonObj->type));
 		if (strtoupper($jsonObj->type) != "FEATURECOLLECTION" || !is_array($jsonObj->features)) {
 			$e = new mb_exception("Not a valid GeoJSON Feature Collection.");
 			return null;
Modified: trunk/mapbender/http/classes/class_gml_line.php
--- trunk/mapbender/http/classes/class_gml_line.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_line.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -64,6 +64,10 @@
 		return $str;
+	public function isEmpty () {
+		return !(count($this->pointArray) > 0);
 	public function toGeoJSON () {
 		$numberOfPoints = count($this->pointArray);
 		$str = "";
Modified: trunk/mapbender/http/classes/class_gml_multiline.php
--- trunk/mapbender/http/classes/class_gml_multiline.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_multiline.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -65,6 +65,10 @@
+		return !(count($this->lineArray) > 0);
 		$numberlineArray = count($this->lineArray);
 		$str = "";
Modified: trunk/mapbender/http/classes/class_gml_multipolygon.php
--- trunk/mapbender/http/classes/class_gml_multipolygon.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_multipolygon.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -125,6 +125,10 @@
 		return $str;
+		return !(count($this->polygonArray) > 0);
 		$numberPolygonArray = count($this->polygonArray);
Modified: trunk/mapbender/http/classes/class_gml_point.php
--- trunk/mapbender/http/classes/class_gml_point.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_point.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -48,6 +48,10 @@
 		return $str;
+		return ($this->point ? false : true);
 		$str = "";
 		if ($this->point) {
Modified: trunk/mapbender/http/classes/class_gml_polygon.php
--- trunk/mapbender/http/classes/class_gml_polygon.php	2009-04-16 14:24:49 UTC (rev 3890)
+++ trunk/mapbender/http/classes/class_gml_polygon.php	2009-04-16 15:23:18 UTC (rev 3891)
@@ -99,6 +99,10 @@
 		return $str;
 		$str = "";
More information about the Mapbender_commits mailing list
