[Mapbender-commits] r4471 - in branches/print_dev/http: classes css
javascripts php print
svn_mapbender at osgeo.org
Tue Aug 4 07:51:01 EDT 2009
Author: mschulz
Date: 2009-08-04 07:51:01 -0400 (Tue, 04 Aug 2009)
New Revision: 4471
Added:
branches/print_dev/http/print/mod_printPDF_div.js
branches/print_dev/http/print/printbox.js
Removed:
branches/print_dev/http/classes/class_monitor.php
branches/print_dev/http/javascripts/mod_digitize_tab_category.php
branches/print_dev/http/javascripts/mod_loadwmc_list.php
branches/print_dev/http/javascripts/mod_log.php
branches/print_dev/http/javascripts/mod_reload.php
branches/print_dev/http/javascripts/mod_resize_mapsize.php
branches/print_dev/http/javascripts/mod_sandclock.php
branches/print_dev/http/javascripts/mod_sandclock2.php
branches/print_dev/http/javascripts/mod_scalebar.php
branches/print_dev/http/javascripts/mod_zoomFull.php
branches/print_dev/http/php/mod_map1.php
branches/print_dev/http/php/mod_mapOV.php
branches/print_dev/http/css/print_div.css
branches/print_dev/http/javascripts/map.php
branches/print_dev/http/print/mod_printPDF_div.php
branches/print_dev/http/print/print_functions.php
branches/print_dev/http/print/testConfigTemplate.json
printPDF as MB module and printbox first integration (no rotation yet ...)
Deleted: branches/print_dev/http/classes/class_monitor.php
--- branches/print_dev/http/classes/class_monitor.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/classes/class_monitor.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,495 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-require_once(dirname(__FILE__)."/../classes/class_bbox.php");
-require_once(dirname(__FILE__)."/../extensions/DifferenceEngine.php");
-define("MONITOR_DEFAULT_SCALE", 500000);
-define("MONITOR_IMG_WIDTH", 20);
-define("MONITOR_IMG_HEIGHT", 20);
-define("MB_RESOLUTION", 28.35);
-class Monitor {
- * 1 = reachable and in sync with db
- * 0 = reachable and out of sync with db
- * -1 = unreachable
- * -2 = monitoring in progress
- var $result = -1;
- * 1 = the get map request DEFINITELY returns a valid map image
- * 0 = the WMS doesn't support XML error format. Who knows if the image is really a map?
- * -1 = the get map request doesn't return an image
- var $returnsImage;
- var $comment = "";
- var $updated = "0";
- var $supportsXMLException = false;
- var $timestamp;
- var $capabilitiesURL;
- var $mapURL;
- var $remoteXML;
- var $localXML;
- var $capabilitiesDiff;
- function __construct($wmsId, $uploadId, $autoUpdate) {
- $this->wmsId = $wmsId;
- $this->uploadId = $uploadId;
- $this->autoUpdate = $autoUpdate;
- $this->capabilitiesURL = $this->getUploadURL($this->wmsId, $this->uploadId);
- set_time_limit(TIME_LIMIT);
- $this->timestamp = time();
- if ($this->capabilitiesURL) {
- $remoteWms = new wms();
- $remoteWms->createObjFromXML($this->capabilitiesURL);
- $this->remoteXML = $remoteWms->wms_getcapabilities_doc;
- $this->localXML = $this->getCapabilitiesDocByWMS($this->wmsId);
- // service unreachable
- if (!$this->remoteXML) {
- $this->result = -1;
- $this->comment = "Connection failed.";
- * service available;
- * no local copy of capabilities file,
- * so it has to be updated anyway
- elseif (!$this->localXML) {
- $this->result = 0;
- * check if local copy is different
- * to remote capabilties document
- else {
- * compare to local capabilities document
- // capabilities files match
- if ($this->localXML == $this->remoteXML) {
- $this->result = 1;
- $this->comment = "WMS is stable.";
- // capabilities files don't match
- else {
- $localXMLArray = explode("\n", htmlentities($this->localXML));
- $remoteXMLArray = explode("\n", htmlentities($this->remoteXML));
- $this->capabilitiesDiff = $this->outputDiffHtml($localXMLArray,$remoteXMLArray);
- * if the WMS is available,
- * 1) get a map image
- * 2) update the local backup of the capabilities doc if necessary
- if ($this->result != -1) {
- $this->mapURL = $this->getMapRequest($this->wmsId);
- if ($this->isImage($this->mapURL)) {
- $this->returnsImage = 1;
- else {
- $this->returnsImage = -1;
- * if the local backup of the capabilities document
- * is deprecated, update the local backup
- if ($this->result == 0) {
- $mywms = new wms();
- * if the capabilities document is valid,
- * update it OR mark it as "not up to date"
- if ($mywms->createObjFromXML($this->capabilitiesURL)) {
- if ($this->autoUpdate) {
- $mywms->updateObjInDB($this->wmsId);
- $this->updated = "1";
- $this->comment = "WMS has been updated.";
- else {
- $this->comment = "WMS is not up to date.";
- // capabilities document is invalid
- else {
- $this->comment = "Invalid getCapabilities request/document or service exception.";
- else {
- $this->comment = "Invalid upload URL.";
- $e = new mb_notice("class_monitor: constructor: result = " . $this->result);
- $e = new mb_notice("class_monitor: constructor: comment = " . $this->comment);
- $e = new mb_notice("class_monitor: constructor: returnsImage = " . $this->returnsImage);
- public function __toString() {
- $str = "";
- $str .= "wmsid: " . $this->wmsId . "\nupload_id: " . $this->uploadId . "\n";
- $str .= "autoupdate: " . $this->autoUpdate . "\n";
- $str .= "result: " . $this->result . "\ncomment: " . $this->comment . "\n";
- $str .= "timestamp: " . $this->timestamp . " (".date("F j, Y, G:i:s", $this->timestamp).")\n";
- $str .= "getCapabilities URL: " . $this->capabilitiesURL . "\nupdated: " . $this->updated . "\n\n";
- $str .= "getMap URL: " . $this->mapURL . "\nis image: " . $this->returnsImage . "\n\n";
- $str .= "-------------------------------------------------------------------\n";
- $str .= "remote XML:\n\n" . $this->remoteXML . "\n\n";
- $str .= "local XML:\n\n" . $this->localXML . "\n\n";
- $str .= "diff:\n\n" . $this->capabilitiesDiff . "\n\n";
- return (string) $str;
- * Update database
- function updateInDB() {
- $sql = "UPDATE mb_monitor SET updated = $1, status = $2, image = $3, status_comment = $4, upload_url = $5, timestamp_end = $6, map_url = $7, timestamp_begin = $8, caps_diff = $9 WHERE upload_id = $10 AND fkey_wms_id = $11";
- $v = array($this->updated, $this->result, $this->returnsImage, $this->comment, $this->capabilitiesURL, time(), $this->mapURL, $this->timestamp, $this->capabilitiesDiff, $this->uploadId, $this->wmsId);
- $t = array('s', 'i', 'i', 's', 's', 's', 's', 's', 's', 's', 'i');
- $res = db_prep_query($sql,$v,$t);
- * Checks if the mapUrl returns an image or an exception
- private function isImage($url) {
- $headers = get_headers($url, 1);
- $e = new mb_notice("class_monitor: isImage: map URL is " . $url);
- $e = new mb_notice("class_monitor: isImage: Content-Type is " . $headers["Content-Type"]);
- if (preg_match("/xml/", $headers["Content-Type"])) {
- return false;
- return true;
- * Returns the upload url of some WMS
- private function getUploadURL($wmsId, $upload_id) {
- $e = new mb_notice("class_monitor: getUploadURL: wms = " . $wmsId);
- $e = new mb_notice("class_monitor: getUploadURL: upload_id = " . $upload_id);
- $sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
- $v = array($wmsId, $upload_id);
- $t = array('i', 'i');
- $someArray = db_fetch_array($res);
- $e = new mb_notice("class_monitor: getUploadURL: url = " . $someArray["upload_url"]);
- return $someArray["upload_url"];
- * Returns the character that needs to be appended to
- * a given online resource, in order to append other GET
- * parameters.
- * Possible characters: "?", "&", ""
- private function mb_getConjunctionCharacter($onlineresource){
- // index of character ? in online resource
- $indexOfChar = mb_strpos($onlineresource,"?");
- if($indexOfChar) {
- // no conjunction character needed
- if($indexOfChar == mb_strlen($onlineresource)-1){
- return "";
- else if (mb_substr($onlineresource, mb_strlen($onlineresource)-1) == "&") {
- return "";
- else{
- return "&";
- return "?";
- * retrieves all information necessary to build a map request,
- * concatenates them and returns a valid get map request
- private function getMapRequest($wmsId) {
- // get map (wms_getmap)
- // version (wms_version)
- $sql = "SELECT wms_getmap, wms_version FROM wms WHERE wms_id = $1";
- $res = db_prep_query($sql, array($wmsId), array('i'));
- $row = db_fetch_array($res);
- $getmap = $row["wms_getmap"];
- $version = $row["wms_version"];
- //map format
- $sql = "SELECT * FROM wms_format WHERE data_type = 'map' AND fkey_wms_id = $1";
- $mapFormat = "";
- while ($row = db_fetch_array($res)) {
- $mapFormat = urlencode($row["data_format"]);
- if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat) || preg_match("/jp.{1}g/", $mapFormat)) {
- break;
- // layers (all layers)
- $sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> '' AND layer_pos > 0";
- $layerArray = array();
- array_push($layerArray, urlencode($row["layer_name"]));
- $layerList = implode(",", $layerArray);
- // srs (layer_epsg: epsg)
- // bbox (layer_epsg: minx, miny, maxx, maxy)
- $sql = "SELECT epsg, minx, miny, maxx, maxy ";
- $sql .= "FROM layer_epsg, (SELECT fkey_wms_id, layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_parent = '' AND layer_pos = 0) AS l ";
- $sql .= "WHERE l.layer_id = layer_epsg.fkey_layer_id AND l.fkey_wms_id = $1";
- $bboxArray = array();
- array_push($bboxArray, new Mapbender_bbox($row["minx"], $row["miny"], $row["maxx"], $row["maxy"], $row["epsg"]));
- // get a bbox in a preferably non WGS84 epsg to use the scalehints
- for ($i=0; $i < count($bboxArray); $i++) {
- $bbox = $bboxArray[$i];
- if ($bboxArray[$i]->epsg != "EPSG:4326") {
- break;
- * transform to 31466 if is 4326
- * TODO: extend to other EPSG apart from 31466
- if ($bbox->epsg == "EPSG:4326") {
- $bbox->transform("EPSG:31466");
- * get map and check if result is image
- // check if this WMS supports exception type XML
- $sql = "SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
- $v = array($wmsId);
- $t = array('i');
- $exceptionFormat = $row["data_format"];
- // set the exception type to xml (if possible)
- if (preg_match('/xml/', $exceptionFormat)) {
- $this->supportsXMLException = true;
- break;
- // correct bbox according to scale
- $scale = $this->getScaleForWMS($wmsId);
- $bbox = $this->getBBoxInScale($bbox, $scale);
- return $this->concatenateMapRequest($getmap, $version, $mapFormat, $layerList, $bbox, MONITOR_IMG_WIDTH, MONITOR_IMG_HEIGHT, $exceptionFormat);
- * updates a given BBox according to a given scale
- * @param bbox
- * @param scale
- private function getBBoxInScale($bbox, $scale) {
- $e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox);
- $e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
- $e = new mb_notice("class_monitor: getMapRequest: scale = " . $scale);
- if ($scale) {
- $center = $bbox->min->plus($bbox->max)->times(0.5);
- $e = new mb_notice("class_monitor: getMapRequest: center = " . $center);
- * TODO: this formula should have documentation
- $offset = MONITOR_IMG_WIDTH / (MB_RESOLUTION * 100 * 2) * $scale;
- $offsetPoint = new Mapbender_point($offset, $offset, $bbox->epsg);
- $min = $center->minus($offsetPoint);
- $max = $center->plus($offsetPoint);
- $bbox->min = $min;
- $bbox->max = $max;
- $e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox);
- $e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
- return $bbox;
- * Returns an online resource representing a get map request
- private function concatenateMapRequest( $getmap, $wmsVersion, $mapFormat, $layerList,
- $bbox, $width, $height, $exceptionFormat) {
- * getMap URL
- $mapRequest = $getmap;
- $mapRequest .= $this->mb_getConjunctionCharacter($getmap);
- * WMS version
- if ($wmsVersion == "1.0.0") {
- $mapRequest .= "WMTVER=" . $wmsVersion . "&REQUEST=map&";
- else {
- $mapRequest .= "VERSION=" . $wmsVersion . "&REQUEST=GetMap&SERVICE=WMS&";
- * Layer list
- $mapRequest .= "LAYERS=" . $layerList . "&";
- * Format
- $mapRequest .= "FORMAT=" . $mapFormat . "&";
- * SRS and BBox
- $mapRequest .= "SRS=" . $bbox->epsg . "&";
- $mapRequest .= "BBOX=" . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y . "&";
- * Width and height
- $mapRequest .= "WIDTH=" . $width . "&";
- $mapRequest .= "HEIGHT=" . $height . "&";
- * BGColor
- $mapRequest .= "BGCOLOR=0xffffff&";
- * Transparency
- if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat)) {
- $mapRequest .= "TRANSPARENT=TRUE&";
- * Exception format
- $mapRequest .= "EXCEPTIONS=" . $exceptionFormat . "&";
-// return urlencode($mapRequest);
- return $mapRequest;
- * Checks if the given WMS has ScaleHints. If yes, a scale is selected and returned.
- private function getScaleForWMS($wmsId) {
- // get the scalehints
- $sql = "SELECT layer_minscale, layer_maxscale FROM layer WHERE fkey_wms_id = $1 AND layer_pos = 0 AND layer_parent = '' AND layer_minscale <> layer_maxscale LIMIT 1";
- $t = array('i');
- $scaleHintArray = db_fetch_array($res);
- * determine the scalehint
- // if a scalehint exists
- if ($scaleHintArray) {
- // if upper boundary
- if ($scaleHintArray["layer_minscale"] < $scaleHintArray["layer_maxscale"]) {
- // TODO: find a better algorithm with a less obscure scale
- $scaleHint = round($scaleHintArray["layer_maxscale"] - $scaleHintArray["layer_minscale"]) / 2;
- // if lower boundary
- else {
- if ($scaleHintArray["layer_minscale"] < MONITOR_DEFAULT_SCALE) {
- $scaleHint = MONITOR_DEFAULT_SCALE;
- else {
- $scaleHint = $scaleHintArray["layer_minscale"] + 1000;
- // otherwise, use a default value
- else {
- return $scaleHint;
- * Returns the local backup of the given WMS' capabilities document
- private function getCapabilitiesDocByWMS($wmsId) {
- $sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
- $t = array('i');
- return $someArray["wms_getcapabilities_doc"];
- * creates a html diff of the xml documents
- private function outputDiffHtml($localXMLArray,$remoteXMLArray) {
- $diffObj = new Diff($localXMLArray,$remoteXMLArray);
- $dft = new TableDiffFormatter();
- return $dft->format($diffObj);
Modified: branches/print_dev/http/css/print_div.css
--- branches/print_dev/http/css/print_div.css 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/css/print_div.css 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,6 +1,6 @@
@CHARSET "ISO-8859-1";
-#printPDF label,input,select,textarea {
+#printPDF label, #printPDF input, #printPDF select, #printPDF textarea {
display: block;
width: 120px;
float: left;
Modified: branches/print_dev/http/javascripts/map.php
--- branches/print_dev/http/javascripts/map.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/map.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -31,22 +31,22 @@
$gui_changed=0;
$new_wmc=0;
-if (!$_REQUEST["layer_preview"] && isset($_SESSION["mb_user_gui"]) && $_SESSION["mb_user_gui"] != $_REQUEST["gui_id"]) {
+if (!$_REQUEST["layer_preview"] && Mapbender::session()->get("mb_user_gui") && Mapbender::session()->get("mb_user_gui") != $_REQUEST["gui_id"]) {
$gui_changed=1;
-if (!isset($_SESSION['mb_wmc']) || ($gui_changed==1) || ($_REQUEST['layer_preview'] && $_REQUEST['portal_services'])) {
+if (!Mapbender::session()->get('mb_wmc') || ($gui_changed==1) || ($_REQUEST['layer_preview'] && $_REQUEST['portal_services'])) {
$new_wmc=1;
if (isset($_REQUEST['layer_preview']) && $_REQUEST['layer_preview'] != 0) {
- $_SESSION['layer_preview'] = $_REQUEST['portal_services'];
+ Mapbender::session()->set('layer_preview',$_REQUEST['portal_services');
else {
- $_SESSION['layer_preview'] = 0;
+ Mapbender::session()->set('layer_preview',0);
-$_SESSION["mb_user_gui"] = $gui_id;
+Mapbender::session()->set("mb_user_gui", $gui_id);
ob_start();
header('Content-type: application/x-javascript');
@@ -55,15 +55,14 @@
echo "var mb_nr = '".session_id()."';";
echo "var mb_session_name = '".session_name()."';";
-echo "var mb_myLogin = '".$_SESSION["mb_login"]."';";
-echo "var mb_styleID = '".md5($_SESSION["mb_user_name"])."';";
-echo "var mb_myBBOX = '".$_SESSION["mb_myBBOX"]."';";
-echo "Mapbender.locale = '" . $_SESSION["mb_locale"] . "';";
-echo "Mapbender.languageId = '" . $_SESSION["mb_lang"] . "';";
+echo "var mb_myLogin = '".Mapbender::session()->get("mb_login")."';";
+echo "var mb_styleID = '".md5(Mapbender::session()->get("mb_user_name"))."';";
+echo "var mb_myBBOX = '".Mapbender::session()->get("mb_myBBOX")."';";
+echo "Mapbender.locale = '" . Mapbender::session()->get("mb_locale") . "';";
+echo "Mapbender.languageId = '" . Mapbender::session()->get("mb_lang") . "';";
echo "Mapbender.versionNumber = '" . MB_VERSION_NUMBER . "';";
echo "Mapbender.versionAppendix = '" . MB_VERSION_APPENDIX . "';";
echo "Mapbender.releaseDate = new Date(".date("Y",MB_RELEASE_DATE).",".date("n",MB_RELEASE_DATE).",".date("j",MB_RELEASE_DATE).");";
-echo "Mapbender.zoomMousewheel = " . ZOOM_MOUSEWHEEL . ";";
echo "var owsproxy = '".OWSPROXY."';";
echo "var global_mb_log_js = '".LOG_JS."';";
echo "var global_mb_log_level = '".LOG_LEVEL."';";
@@ -76,9 +75,8 @@
// Load external JavaScript libraries
$extPath = dirname(__FILE__) . "/../extensions/";
-$extFileArray = array( "jquery-1.2.6.min.js",
+$extFileArray = array( "jquery-1.3.2.min.js",
"jqjson.js",
- "jquery.mousewheel.min.js",
"jquery.form.js");
for ($i = 0; $i < count($extFileArray); $i++) {
@@ -94,8 +92,10 @@
+// this replaces the old init function
$(function () {
- new Mb_notice("new jquery init function");
+ initModules();
// creates the map objects (mapframe1, overview...)
eventInitMap.trigger();
@@ -105,6 +105,7 @@
eventInit.trigger();
eventAfterInit.trigger();
<?php
@@ -118,7 +119,10 @@
"list.js",
"point.js",
"style.js",
- "button.js");
+ "button.js",
+ "extent.js",
+ "backwards_compatibility_to_2.6.js"
for ($i = 0; $i < count($libFileArray); $i++) {
$currentFile = $libPath . $libFileArray[$i];
@@ -164,10 +168,10 @@
$modulesNotRelyingOnGlobalsArray = explode(",", MODULES_NOT_RELYING_ON_GLOBALS);
-Mapbender.Modules = {};
+Mapbender.modules = {};
Mapbender.addModule = function (name, obj) {
- if (name && !Mapbender.Modules[name]) {
- Mapbender.Modules[name] = obj;
+ if (name && !Mapbender.modules[name]) {
+ Mapbender.modules[name] = obj;
return true;
return false;
@@ -181,69 +185,89 @@
$mb_v = array($gui_id);
$mb_t = array("s");
$mb_res = db_prep_query($mb_sql, $mb_v, $mb_t);
-while($row_js = db_fetch_array($mb_res)){
- if($row_js["e_js_file"] != ""){
- $jsArray = explode(",", $row_js["e_js_file"]);
- for ($i = 0; $i < count($jsArray); $i++) {
- $e_id = isset($row_js["e_id"]) ? $row_js["e_id"] : "";
- $e_src = $row_js["e_src"];
- $e_require = $row_js["e_requires"];
- $e_target = explode(",",$row_js["e_target"]);
- $e_width = intval($row_js["e_width"]);
- $e_height = intval($row_js["e_height"]);
- $e_top = intval($row_js["e_top"]);
- $e_left = intval($row_js["e_left"]);
- $currentFile = trim($jsArray[$i]);
- if (!file_exists($currentFile)) {
- $e = new mb_exception("Javascript not found: " . $currentFile);
- echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
- die;
- if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
- ob_start();
- echo "var options = {" .
- "id:'$e_id'," .
- "target:" . ($e_target[0] != "" ? $json->encode($e_target) : "[]") . "," .
- "top:$e_top," .
- "left:$e_left," .
- "width:$e_width," .
- "height:$e_height," .
- "src:'$e_src'" .
+while ($row_js = db_fetch_array($mb_res)) {
+ // Create element properties
+ $e_id = isset($row_js["e_id"]) ?
+ str_replace(" ", "", $row_js["e_id"]) : "";
+ $e_src = $row_js["e_src"];
+ $e_require = $row_js["e_requires"];
+ $e_target = explode(",",$row_js["e_target"]);
+ $e_width = intval($row_js["e_width"]);
+ $e_height = intval($row_js["e_height"]);
+ $e_top = intval($row_js["e_top"]);
+ $e_left = intval($row_js["e_left"]);
- include "../include/dyn_js_object.php";
- echo <<<JS
-$.fn.$e_id = function (options) {
- return this.each(function () {
+ $elementAttributes = "{" .
+ "id:'$e_id'," .
+ "target:" . ($e_target[0] != "" ? $json->encode($e_target) : "[]") . "," .
+ "url:'$e_url'," .
+ "top:$e_top," .
+ "left:$e_left," .
+ "width:$e_width," .
+ "height:$e_height," .
+ "src:'$e_src'" .
-JS;
+ echo "Mapbender.modules." . $e_id . " = " . $elementAttributes . ";\n";
+ // Include JavaScript files
+ $jsFileString = $row_js["e_js_file"];
+ if ($jsFileString){
+ if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
+ // Create the jQuery plugin in output buffer
+ ob_start();
+ echo "var options = " . $elementAttributes . ";";
+ // extend the options variable by JS element vars
+ include "../include/dyn_js_object.php";
+ echo "$.fn.$e_id = function (options) {" .
+ "return this.each(function () {";
+ $jsArray = explode(",", $jsFileString);
+ for ($i = 0; $i < count($jsArray); $i++) {
+ $currentFile = trim($jsArray[$i]);
+ if (!file_exists($currentFile)) {
+ $e = new mb_exception("Javascript not found: " . $currentFile);
+ echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
+ continue;
+ $e = new mb_notice("LOADING JS : " . $currentFile);
require($currentFile);
- echo <<<JS
-JS;
- echo "$('#$e_id').$e_id(options);";
- $executeJsPluginsArray[] = ob_get_contents();
- ob_end_clean();
- echo "Mapbender.Modules.$e_id = {};\n";
- else {
- echo "Mapbender.Modules." . $e_id . " = {\n";
- echo "id:'".$row_js["e_id"]."',";
- echo "url:'".$row_js["e_url"]."',";
- echo "top:'".$row_js["e_top"]."',";
- echo "left:'".$row_js["e_left"]."',";
- echo "width:'".$row_js["e_width"]."',";
- echo "height:'".$row_js["e_height"]."'";
- echo "};\n";
+ echo "});};";
+ echo "$('#$e_id').$e_id(options);";
+ $executeJsPluginsArray[] = ob_get_contents();
+ ob_end_clean();
+ else {
+ continue;
+echo "function initModules () {";
echo implode("\n", $executeJsPluginsArray);
+echo "}\n";
\ No newline at end of file
Deleted: branches/print_dev/http/javascripts/mod_digitize_tab_category.php
--- branches/print_dev/http/javascripts/mod_digitize_tab_category.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_digitize_tab_category.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,2206 +0,0 @@
-<?php
-# $Id: mod_digitize_tab.php 3939 2009-05-12 19:43:45Z marc $
-# http://www.mapbender.org/index.php/mod_digitize_tab.php
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-$e_target = $_GET["e_target"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Digitize</title>
-<?php
-$digitize_conf_filename = "digitize_default.conf";
-include '../include/dyn_css.php';
-<script language='JavaScript'>
-// Returns a form with the elements of a selected WFS grouped in tabs
-// (if the original WFS is the selected WFS, the values are set too)
-var initialTab = false;
-function buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex) {
- var featureTypeMismatch = false;
- if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
- var str = "";
- var hasGeometryColumn = false;
- var featureTypeArray = wfsConf[wfsConfIndex];
- var memberElements;
- var fid = false;
- if (!featureTypeMismatch) {
- memberElements = d.get(memberIndex).e;
- fid = memberElements.getElementValueByName('fid');
- if (typeof(featureTypeArray["element"]) !== "undefined") {
- featureTypeElementArray = featureTypeArray["element"];
- elementCategories.sort();
- str += "<form id='"+featureTypeElementFormId+"'>\n\t\n";
- initialTab = elementCategories[0];
- for(var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
- str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
- // 2. add rows to form
- for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
- var featureTypeElement = featureTypeElementArray[i];
- var elementName = featureTypeElement['element_name'];
- var elementType = featureTypeElement['element_type'];
- var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
- var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
- var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
- if(featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
- continue;
- str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
- str += '<table>';
- var elementLabelExists = (featureTypeElement['f_label'] != "");
- var elementLabel = "";
- if (elementLabelExists) {
- elementLabel = featureTypeElement['f_label'];
- var elementLabelStyle = featureTypeElement['f_label_id'];
- if (!isGeomColumn) {
- if (isEditable) {
- str += "\t\t<tr>\n";
- if(elementLabelExists) {
- str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
- str += "\t\t\t<td>\n";
- else {
- str += '<td colspan="2">';
- var elementValue = "";
- for (var j = 0 ; j < memberElements.count() ; j ++) {
- if (memberElements.getName(j) == featureTypeElement['element_name']) {
- elementValue = memberElements.getValue(j);
- var formElementHtml = featureTypeElement['f_form_element_html'];
- if (!formElementHtml) {
- mandatoryHint = '';
- var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
- str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
- str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
- str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
- else {
- while (formElementHtml.match(/\\/)) {
- formElementHtml = formElementHtml.replace(/\\/, "");
- var patternString = "<select";
- pattern = new RegExp(patternString);
- if (pattern.test(formElementHtml)) {
- formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
- var patternString = "hasdatepicker";
- formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
- var patternString = "<textarea";
- formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
- str += formElementHtml;
- if(featureTypeElement.f_helptext.length > 0) {
- str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
- str += '<div id="helptext' +i+ '" class="helptext">';
- str += '<p>';
- str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
- str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
- str += '</p>';
- str += '</div>';
- str += "\t\t\t</td>\n\t\t</tr>\n";
- else {
- hasGeometryColumn = true;
- str += '</table>';
- str += '</div>';
- // 3. add buttons "save", "update", "delete"
- str += "<table>";
- var isTransactional = (featureTypeArray['wfs_transaction']);
- if (isTransactional) {
- var options = ["save", "update", "delete", "abort"];
- for (var i = 0 ; i < options.length ; i++) {
- var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
- onClickText += "if (result.isCorrect) {";
- onClickText += "window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
-// onClickText += "window.close();";
- onClickText += "}";
- onClickText += "else {";
- onClickText += "alert(result.errorMessage);this.disabled=false;"
- if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
- str += "\t\t\t<td><input type='button' name='saveButton' value='"+buttonLabelSaveGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\" /></td>\n";
- if (!featureTypeMismatch && fid) {
- if (options[i] == "update" && hasGeometryColumn) {
- str += "\t\t\t<td><input type='button' name='updateButton' value='"+buttonLabelUpdateGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\"/></td>\n";
- if (options[i] == "delete"){
- var deleteOnClickText = "var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');";
- deleteOnClickText += "if (deltrans){";
- deleteOnClickText += onClickText + "}";
- str += "\t\t\t<td><input type='button' name='deleteButton' value='"+buttonLabelDeleteGeometry[selectedLanguage]+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
- if (options[i] == "abort") {
- str += "\t\t\t<td><input type='button' name='abortButton' value='"+buttonLabelAbort[selectedLanguage]+"' onclick=\"window.close();\" /></td>\n";
- str += "\t\t</tr>\n";
- str += "\t</table>\n";
- str += "<input type='hidden' id='fid' value='"+fid+"'>";
-// str += "<input type='text' name='mb_wfs_conf'>";
- str += "</form>\n";
- return str;
-// Buttons
-function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
- buttonDig_id.push(id);
- buttonDig_on.push(isOn);
- buttonDig_src.push(src);
- buttonDig_title_off.push(titleOff);
- buttonDig_title_on.push(titleOn);
- buttonDig_x.push(x);
- buttonDig_y.push(y);
-function htmlspecialchars(p_string) {
- p_string = p_string.replace(/&/g, '&');
- p_string = p_string.replace(/</g, '<');
- p_string = p_string.replace(/>/g, '>');
- p_string = p_string.replace(/"/g, '"');
- // p_string = p_string.replace(/'/g, ''');
- return p_string;
-//default definition of image directory for digitize buttons, might
-//be overwritten with digitize conf data
-var buttonDig_imgdir = "../img/button_digitize/";
-var buttonDig_id = [];
-var buttonDig_on = [];
-var buttonDig_src = [];
-var buttonDig_title_off = [];
-var buttonDig_title_on = [];
-var buttonDig_x = [];
-var buttonDig_y = [];
-var mapWindow;
-var mapDomElement;
-var mapType = "";
-parent.eventInit.register(function () {
- var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
- mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
- mapType = mapDomElement.tagName.toUpperCase();
- if (mapType == "DIV") {
- mapWindow = parent.window;
- else if (mapType == "IFRAME") {
- mapWindow = mapDomElement.window;
- else {
- new parent.Mb_warning("Could not set CSS for map in digitizing module.");
-<?php
-echo "var mod_digitize_target = '".$e_target."';";
-$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
-if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
- include($digitizeConfFilenameAndPath);
-var wfsWindow;
-var wfsConf = [];
-var d;
-var mod_digitize_width;
-var mod_digitize_height;
-var mod_digitizeEvent = false;
-var nonTransactionalHighlight;
-var button_point = "Point";
-var button_line = "Line";
-var button_polygon = "Polygon";
-var button_move = "dragBasePoint";
-var button_insert = "setBasePoint";
-var button_delete = "delBasePoint";
-var button_clear = "clear";
-var button_split = "digitizeSplit";
-var button_merge = "digitizeMerge";
-var button_difference = "digitizeDifference";
-var digitizeDivTag;
-var GeometryArray;
-var MultiGeometry = parent.MultiGeometry;
-var Geometry;
-var Point;
-var geomType;
-var msgObj;
-var featureTypeElementFormId = "featureTypeElementForm";
-try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
-try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
-try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
-function toggleTabs(tabId) {
- if(!initialTab) {
- return;
- var tabHeaders = wfsWindow.document.getElementsByTagName('a');
- var tabs = wfsWindow.document.getElementsByTagName('div');
- for(var i = 0; i < tabHeaders.length; i++) {
- if(tabHeaders[i].id.indexOf('tabheader') != -1) {
- tabHeaders[i].className = 'tabheader';
- for(var i = 0; i < tabs.length; i++) {
- if(tabs[i].className === 'tabcontent') {
- tabs[i].style.visibility = 'hidden';
- tabs[i].style.display = 'none';
- wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
- wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
- wfsWindow.document.getElementById('tab_' + tabId).style.display = 'block';
- return false;
-function showHelptext(helptextId) {
- hideHelptext();
- wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
- wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'block';
- return false;
-function hideHelptext(helptextId) {
- if(helptextId) {
- wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
- wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'none';
- var helptext = wfsWindow.document.getElementsByTagName('div');
- for(var i = 0; i < helptext.length; i++) {
- if(helptext[i].className === 'helptext') {
- helptext[i].style.visibility = 'hidden';
- helptext[i].style.display = 'none';
- return false;
-function getMousePosition(e) {
- parent.mb_getMousePos(e, mod_digitize_target);
- var currentPos = null;
- currentPos = new parent.Point(
- parent.clickX - parseInt(mapDomElement.style.left),
- parent.clickY - parseInt(mapDomElement.style.top)
- else {
- parent.clickX,
- parent.clickY
- return currentPos;
-function initializeDigitize () {
- d = new parent.GeometryArray();
- GeometryArray = parent.GeometryArray;
- Geometry = parent.Geometry;
- Point = parent.Point;
- geomType = parent.geomType;
- * Append geometries from KML when KML has been loaded
-function appendGeometryArrayFromKML () {
- try {
- parent.kmlHasLoaded.register(function(properties){
- d.importGeoJSON(properties);
-// d = parent.geoJsonToGeometryArray(properties);
- executeDigitizeSubFunctions();
- catch (e) {
- var exc = new parent.Mb_warning(e);
-// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
-function appendGeometryArray(obj) {
- executeDigitizePreFunctions();
- for (i=0; i<obj.count(); i++) {
- d.addCopy(obj.get(i));
-function mod_digitize_go(e){
- // ie workaround
- if (e == undefined) {
- e = mapWindow.event;
- if (e) {
- // track mouse position
- var currentPos = getMousePosition(e);
- s.check(currentPos);
- else {
-// s.clean();
- var el = mapDomElement;
- el.onmousedown = mod_digitize_start;
-function mod_digitize_timeout(){
- el.onmousedown = null;
- el.onmouseup = null;
- el.onmousemove = null;
-function mod_digitize_start(e){
- // check if a proper geometry is selected
- if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
- if (mod_digitizeEvent != false) {
- alert(msgObj.errorMessageNoGeometrySelected);
- return false;
- var realWorldPos;
- if (s.isSnapped()) {
- realWorldPos = s.getSnappedPoint();
- s.clean();
- else {
- realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
- if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
- // close the polygon
- d.close();
- parent.mb_disableThisButton(button_polygon);
- return true;
- else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
- // close the line
- d.close();
- parent.mb_disableThisButton(button_line);
- return true;
- else {
- // set the calculated real world position as point of the geometry
- d.getGeometry(-1,-1).addPoint(realWorldPos);
- d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
- if(d.get(-1).geomType == parent.geomType.point){
- d.close();
- parent.mb_disableThisButton(button_point);
- return true;
- // add first point of polygon to snapping list (if three points have been inserted).
- else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
- s.add(d.getPoint(-1, -1, 0));
- // add last point of line to snapping list (if at least two points have been inserted).
- else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
- if (mod_digitizeEvent != button_move) {
- s.store(d);
- s.add(d.getPoint(-1, -1, -1));
- return true;
-// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
-var basepointObject = false;
-var basepointMemberIndex = null;
-var basepointGeometryIndex = null;
-var basepointRingIndex = null;
-var basepointPointIndex = null;
-var basepointDragActive = false;
-function handleBasepoint(obj,memberIndex, geometryIndex, ringIndex, pointIndex){
- if (!(
- mod_digitizeEvent == button_move ||
- mod_digitizeEvent == button_insert ||
- mod_digitizeEvent == button_delete)
- return false;
- basepointObject = obj;
- basepointMemberIndex = memberIndex;
- basepointGeometryIndex = geometryIndex;
- if (pointIndex == undefined) {
- pointIndex = ringIndex;
- basepointRingIndex = undefined;
- else {
- basepointRingIndex = ringIndex;
- basepointPointIndex = pointIndex;
- if(mod_digitizeEvent == button_move){
- mod_digitize_timeout();
- basepointObject.style.cursor = 'move';
- basepointObject.onmousedown = parent.frames[mod_digitize_elName].selectBasepoint;
- if(mod_digitizeEvent == button_delete){
- basepointObject.style.cursor = 'crosshair';
- basepointObject.onmousedown = parent.frames[mod_digitize_elName].deleteBasepoint;
-function convertLinepointToBasepoint(obj, memberIndex, geomIndex, ringIndex, pointIndex){
- if(!(mod_digitizeEvent == button_insert)){ return false; }
- if(mod_digitizeEvent == button_insert){
- obj.style.cursor = 'crosshair';
- obj.onclick = insertBasepoint;
- basepointGeometryIndex = geomIndex;
-function insertBasepoint(e){
- var i = basepointMemberIndex;
- var j = basepointGeometryIndex;
- var k = basepointRingIndex;
- var l = basepointPointIndex;
- var ind = parent.getMapObjIndexByName(mod_digitize_target);
- var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(currentPos.x, currentPos.y));
- if (k == undefined) {
- d.getGeometry(i,j).addPointAtIndex(p, l);
- else {
- d.getGeometry(i,j).innerRings.get(k).addPointAtIndex(p, l);
-function deleteBasepoint(){
- if (k != undefined) {
- d.delAllPointsLike(d.getPoint(i, j, k, l));
- else {
- d.delAllPointsLike(d.getPoint(i, j, l));
-function selectBasepoint(e){
- if(!basepointDragActive && mod_digitizeEvent == button_move){
- basepointDragActive = true;
- s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
- // replace basepoint by transparent blob
- basepointObject.style.width = mod_digitize_width;
- basepointObject.style.height = mod_digitize_height;
- basepointObject.style.left = 0;
- basepointObject.style.top = 0;
- if (parent.ie) {
- // ie cannot handle backgroundColor = 'transparent'
- basepointObject.style.background = "url(../img/transparent.gif)";
- else{
- basepointObject.style.backgroundColor = 'transparent';
- basepointObject.onmouseup = releaseBasepoint;
- basepointObject.onmousemove = dragBasepoint;
-function dragBasepoint(e){
- if(basepointDragActive){
- var res = s.check(currentPos);
-function updateAllPointsOfNonTransactionalLike(oldP, newP){
- for (var i = 0; i < d.count(); i++) {
- if (isTransactional(d.get(i))) {
- d.get(i).updateAllPointsLike(oldP, newP);
-function releaseBasepoint(e){
- basepointDragActive = false;
- var basepointDragEnd = currentPos;
- basepointObject.onmousedown = null;
- var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(basepointDragEnd.x, basepointDragEnd.y));
- var oldPoint;
- oldPoint = parent.cloneObject(d.getPoint(i,j,l));
- else {
- oldPoint = parent.cloneObject(d.getPoint(i,j,k,l));
- var snappedPoint = parent.cloneObject(s.getSnappedPoint());
- if (!nonTransactionalEditable) {
- updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
- else {
- d.updateAllPointsLike(oldPoint, snappedPoint);
- s.clean();
- else {
- updateAllPointsOfNonTransactionalLike(oldPoint, p);
- else {
- d.updateAllPointsLike(oldPoint, p);
- basepointMemberIndex = null;
- basepointGeometryIndex = null;
- basepointPointIndex = null;
-// --- basepoint handling (end) -----------------------------------------------------------------------------------------
-// --- registered functions (begin) ---------------------------------------------------------------------------------------
-function registerDigitizePreFunctions(stringFunction){
- mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
-function registerDigitizeSubFunctions(stringFunction){
- mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
-function executeDigitizeSubFunctions(){
- for(var i=0; i<mod_digitizeSubFunctions.length; i++){
- eval(mod_digitizeSubFunctions[i]);
-function executeDigitizePreFunctions(){
- for(var i=0; i<mod_digitizePreFunctions.length; i++){
- eval(mod_digitizePreFunctions[i]);
-function registerFunctions(){
- mod_digitizePreFunctions = [];
- mod_digitizeSubFunctions = [];
- registerDigitizePreFunctions("updateExtent()");
- registerDigitizePreFunctions("drawDashedLine()");
- registerDigitizeSubFunctions("updateListOfGeometries()");
- registerDigitizeSubFunctions("drawDashedLine()");
- parent.eventInit.register(function () {
- initializeDigitize();
- setStyleForTargetFrame();
- checkDigitizeTag();
- initialiseSnapping();
-// appendGeometryArrayFromKML();
- initialiseHighlight();
- initialiseMeasure();
- getMessages();
- parent.eventLocalize.register(function() {
- getMessages();
- parent.eventAfterMapRequest.register(function () {
- updateExtent();
- parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
-function checkDigitizeTag(){
- var digitizeTagName = "digitizeDiv";
- var digitizeTagStyle;
- digitizeTagStyle = {"z-index":digitizeTransactionalZIndex, "font-size":"10px"};
- digitizeDivTag = new parent.DivTag(digitizeTagName, "", digitizeTagStyle, mapDomElement);
- else {
- digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
- digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
- parent.mb_registerPanSubElement(digitizeTagName);
- parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
-function setStyleForTargetFrame(){
- var cssLink = mapWindow.document.createElement("link");
- var cssHead = mapWindow.document.getElementsByTagName("head")[0];
- cssLink.setAttribute("href", cssUrl);
- cssLink.setAttribute("type", "text/css");
- cssLink.setAttribute("rel", "stylesheet");
- cssHead.appendChild(cssLink);
-function initialiseSnapping(){
- s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
-function initialiseHighlight(){
- nonTransactionalHighlight = new parent.Highlight([mod_digitize_target], "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
-function initialiseMeasure(){
- measureDivTag = new parent.DivTag(measureTagName, "", measureTagStyle);
- else {
- measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
- parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
-// --- registered functions (end) -----------------------------------------------------------------------------------------
-function updateMeasureTag () {
- if (d.count() > 0 ) {
- if (d.get(-1).count() > 0) {
- if (d.getGeometry(-1, -1).count() > 0) {
- if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
- var measureString = "";
- measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
- measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
- measureDivTag.write(measureString);
- return true;
- measureDivTag.clean();
-// --- button handling (begin) --------------------------------------------------------------------------------------------
-function displayButtons(){
- for (var i = 0 ; i < buttonDig_id.length ; i ++) {
- if (parseInt(buttonDig_on[i])==1) {
- var divTag = document.createElement("div");
- divTag.setAttribute("id", "div_" + buttonDig_id[i]);
-// FIREFOX
- document.getElementById("digButtons").appendChild(divTag);
-//IE WORKAROUND, WORKS ALSO FOR FIREFOX
- var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
- parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
-function updateButtons() {
- var currentButton = document.getElementById(buttonDig_id[i]);
- var currentStatus = buttonDig_id[i].status;
- var currentTitle = "";
- switch (buttonDig_id[i]) {
- case "Point":
- if (currentStatus == 1) {
- currentTitle = msgObj.buttonLabelPointOn;
- else {
- currentTitle = msgObj.buttonLabelPointOff;
- break;
- case "Line":
- currentTitle = msgObj.buttonLabelLineOn;
- else {
- currentTitle = msgObj.buttonLabelLineOff;
- break;
- case "Polygon":
- currentTitle = msgObj.buttonLabelPolygonOn;
- else {
- currentTitle = msgObj.buttonLabelPolygonOff;
- break;
- case "dragBasePoint":
- currentTitle = msgObj.buttonLabelMoveBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelMoveBasepointOff;
- break;
- case "setBasePoint":
- currentTitle = msgObj.buttonLabelInsertBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelInsertBasepointOff;
- break;
- case "delBasePoint":
- currentTitle = msgObj.buttonLabelDeleteBasepointOn;
- else {
- currentTitle = msgObj.buttonLabelDeleteBasepointOff;
- break;
- case "clear":
- currentTitle = msgObj.buttonLabelClearListOn;
- else {
- currentTitle = msgObj.buttonLabelClearListOff;
- break;
- case "digitizeSplit":
- currentTitle = msgObj.buttonLabelSplitOn;
- else {
- currentTitle = msgObj.buttonLabelSplitOff;
- break;
- case "digitizeMerge":
- currentTitle = msgObj.buttonLabelMergeOn;
- else {
- currentTitle = msgObj.buttonLabelMergeOff;
- break;
- case "digitizeDifference":
- currentTitle = msgObj.buttonLabelDifferenceOn;
- else {
- currentTitle = msgObj.buttonLabelDifferenceOff;
- break;
- currentButton.title = currentTitle;
-function initDigButton(ind, pos){
- parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
- parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
- parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
- parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
- parent.mb_button[ind].title_on = buttonDig_title_on[pos];
- parent.mb_button[ind].title_off = buttonDig_title_off[pos];
- parent.mb_button[ind].status = 0;
- parent.mb_button[ind].elName = buttonDig_id[pos];
- parent.mb_button[ind].fName = "";
- parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
- parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
-function digitizeEnable(obj) {
- if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
- mod_digitizeEvent = obj.id;
- else if (obj.id == button_point || obj.id == button_line ||
- obj.id == button_polygon || obj.id == button_clear ||
- obj.id == button_split || obj.id == button_merge ||
- obj.id == button_difference){
- el.onmousemove = mod_digitize_go;
- if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
- s.store(d);
- obj.title = obj.title_on;
- if (obj.id == button_point) {
- if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
- if (d.get(-1).geomType != parent.geomType.point) {
- d.close();
- else {
- if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
- d.addMember(parent.geomType.point);
- d.get(-1).addGeometry();
- else {
-// delete existing line or polygon
- d.del(-1);
- else if (obj.id == button_polygon) {
- if (d.get(-1).geomType != parent.geomType.polygon) {
- d.close();
- else {
- // new geometry
- d.addMember(parent.geomType.polygon);
- else {
-// continue a line as a polygon
- var geometryTemplate = parent.cloneObject(d.get(-1));
- d.del(-1);
- for (var i = 0; i < geometryTemplate.count(); i++) {
- for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
- d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
- else if (obj.id == button_line) {
- if (d.get(-1).geomType != parent.geomType.line) {
- d.close();
- else {
- d.addMember(parent.geomType.line);
- else {
-// continue a polygon as a line
- d.del(-1);
- else if (obj.id == button_clear) {
- var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
- if (clear) {
- parent.mb_disableThisButton(button_clear);
- else if (obj.id == button_merge) {
- var applicable = (d.count() > 1);
- var polygonTextArray = [];
- if (d.get(i).geomType != parent.geomType.polygon) {
- applicable = false;
- polygonTextArray = [];
- break;
- polygonTextArray.push(d.get(i).toText());
- if (!applicable) {
- alert(msgObj.messageErrorMergeNotApplicable);
- parent.mb_disableThisButton(button_merge);
- return false;
- parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
- var response = eval('(' + json + ')');
- var polygon = response.polygon;
- d.importGeometryFromText(polygon, parent.mb_mapObj[mapIndex].epsg);
- // remove the original polygons
- var len = d.count();
- for (var i = 0; i < len-1; i++) {
- d.del(0);
- else if (obj.id == button_split) {
- var applicable = (d.count() == 2) &&
- (d.get(0).geomType == parent.geomType.polygon) &&
- (d.get(1).geomType == parent.geomType.line);
- alert(msgObj.messageErrorSplitNotApplicable);
- parent.mb_disableThisButton(button_split);
- return false;
- var polygonText = d.get(0).toText();
- var lineText = d.get(1).toText();
- parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
- var polygonArray = response.polygons;
- var wfsConfId = d.get(0).wfs_conf;
- for (var i in polygonArray) {
- d.importGeometryFromText(polygonArray[i], parent.mb_mapObj[mapIndex].epsg);
- d.get(-1).wfs_conf = wfsConfId;
- // remove the original polygon and the temporary line
- d.del(0);
- d.del(0);
- else if (obj.id == button_difference) {
- (d.get(1).geomType == parent.geomType.polygon);
- alert(msgObj.messageErrorDifferenceNotApplicable);
- parent.mb_disableThisButton(button_difference);
- return false;
- var polygon1Text = d.get(0).toText();
- var polygon2Text = d.get(1).toText();
- parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
- var wfsProperties = d.get(0).e;
- d.get(-1).e = wfsProperties;
- // remove the original and the temporary polygon
- d.del(0);
- d.del(0);
-function digitizeDisable(obj) {
- if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
- obj.title = obj.title_off;
- if (d.get(-1).get(-1).count() == 0) {
- d.delGeometry(-1,-1);
- mod_digitizeEvent = false;
-// --- button handling (end) ----------------------------------------------------------------------------------------------
-// --- display (begin) -----------------------------------------------------------------------------------------
-function updateExtent() {
- var anInd = parent.getMapObjIndexByName(mod_digitize_target);
- var change = false;
- if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
- mod_digitize_width = parent.mb_mapObj[anInd].width;
- change = true;
- if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
- mod_digitize_height = parent.mb_mapObj[anInd].height;
- change = true;
- if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
- mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
- change = true;
-// if (change) {
-// drawDashedLine();
-function drawDashedLine(){
- nonTransactionalHighlight.clean();
- var smP = "";
- smP += "<div class='t_img'>";
- smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
- smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
- var smPArray = [];
- smPArray[smPArray.length] = "<div class='t_img'>"
- + "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
- + "<div class='t_img'>"
- + "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
- var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
- var width = mapObj.width;
- var height = mapObj.height;
- var arrayBBox = mapObj.extent.split(",")
- var minX = parseFloat(arrayBBox[0]);
- var minY = parseFloat(arrayBBox[1]);
- var maxX = parseFloat(arrayBBox[2]);
- var maxY = parseFloat(arrayBBox[3]);
- var cx = width/(maxX - minX);
- var cy = height/(maxY - minY);
- var isMoveOrInsertOrDelete = mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete;
- var minDist = 6;
- for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
- var currentGeomArray = d.get(i);
- if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
- nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
- else {
- for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
- var currentGeometry = d.getGeometry(i,j);
- var isPolygon = currentGeomArray.geomType == parent.geomType.polygon;
- var isLine = currentGeomArray.geomType == parent.geomType.line;
- var isComplete = currentGeometry.isComplete();
- var lastPaintedPoint = false;
- for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
- var currentPoint = currentGeometry.get(k);
- var currentPointMap = new Point(Math.round((currentPoint.x - minX)*cx), Math.round((maxY - currentPoint.y)*cy));
-// var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
-// if (!isTooCloseToPrevious) {
- var currentPointIsVisible = currentPointMap.x > 0 && currentPointMap.x < width && currentPointMap.y > 0 && currentPointMap.y < height;
- if (currentPointIsVisible) {
- if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint-1 && isLine))) {
- smPArray[smPArray.length] = "<div class='bp' style='top:"+
- (currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+
- digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
- else {
- smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
- if(k==0 && isPolygon && !isComplete){
- smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
- if(isMoveOrInsertOrDelete) {
- smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
- smPArray[smPArray.length] = "></div>";
- lastPaintedPoint = currentPointMap;
- if (k > 0) {
- points = parent.calculateVisibleDash(currentPointMap, previousPointMap, width, height);
- if (points != false) {
- smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
- var previousPointMap = currentPointMap;
- if (isPolygon && currentGeometry.innerRings.count() > 0) {
- // draw inner rings
- for (var l = 0, lenRings = currentGeometry.innerRings.count(); l < lenRings; l++) {
- var currentRing = currentGeometry.innerRings.get(l);
- for (var m = 0, lenPoint = currentRing.count(); m < lenPoint; m++) {
- var currentPoint = currentRing.get(m);
- var currentPointMap = new Point(Math.round((currentPoint.x - minX) * cx), Math.round((maxY - currentPoint.y) * cy));
- // var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
- // if (!isTooCloseToPrevious) {
- if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint - 1 && isLine))) {
- smPArray[smPArray.length] = "<div class='bp' style='top:" +
- (currentPointMap.y - 2) +
- "px;left:" +
- (currentPointMap.x - 2) +
- "px;z-index:" +
- digitizeTransactionalZIndex +
- ";background-color:" +
- linepointColor +
- else {
- smPArray[smPArray.length] = "<div class='bp' style='top:" + (currentPointMap.y - 2) + "px;left:" + (currentPointMap.x - 2) + "px;z-index:" + digitizeTransactionalZIndex + ";'";
- if (m == 0 && isPolygon && !isComplete) {
- smPArray[smPArray.length] = " title='" + msgObj.closePolygon_title + "' ";
- if (isMoveOrInsertOrDelete) {
- smPArray[smPArray.length] = " onmouseover='parent.window.frames[\"" + mod_digitize_elName + "\"].handleBasepoint(this," + i + "," + j + "," + l + "," + m + ")' ;";
- if (m > 0) {
- smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, l, m);
- digitizeDivTag.write(smPArray.join(""));
-function evaluateDashes(start, end, memberIndex, geomIndex, ringIndex, pointIndex){
- ringIndex = undefined;
- var strArray = [];
- var delta = new parent.Point(end.x - start.x, end.y - start.y);
- var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
- var vecLength = start.dist(end);
- var n = Math.round(vecLength/dotDistance);
- if (n > 0) {
- var step = delta.dividedBy(n);
- for(var i=1; i < n; i++){
- var x = Math.round(start.x + i * step.x) - 2;
- var y = Math.round(start.y + i * step.y) - 2;
- if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
- if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
- strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
- else {
- strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
- if(mod_digitizeEvent == button_insert) {
- strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+ringIndex+","+pointIndex+")'";
- strArray[strArray.length] = "></div>";
- return strArray.join("");
-function isTransactional(geom) {
-// alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
- if (typeof(geom.wfs_conf) == 'number') {
- if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
- var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
- if (isTransactionalGeom) {
- return true;
- else{
- return false;
- else if (typeof(geom.wfs_conf) == 'undefined') {
- return true;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
- return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function getName (geom) {
- wfsConfId = geom.wfs_conf;
- wfsConf = parent.get_complete_wfs_conf();
- if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
- var resultName = "";
- for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
- if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
- resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
- if (resultName == "") {
- resultName = wfsConf[wfsConfId]['g_label'];
- return resultName;
- else if (geom.e.getElementValueByName("name")) {
- return geom.e.getElementValueByName("name");
- else {
- return msgObj.digitizeDefaultGeometryName;
-function updateListOfGeometries(){
- var listOfGeom = "<ul>";
- if (d.count() > 0) {
- for (var i = 0 ; i < d.count(); i ++) {
- if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
- // for the geometries from a kml, there is another save dialogue
- if (d.get(i).isFromKml()) {
- // if the kml is in the db (id = id in database)
- if (d.get(i).e.getElementValueByName("Mapbender:id")) {
- // button: geometry information, update kml
- listOfGeom += "<li>";
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>";
- else {
- // button: geometry information, save, update, delete
- if (wfsExistsForGeom(d.get(i), wfsConf)) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>";
- // button: remove this geometry
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>";
- // button clone this geometry
- if (addCloneGeometryButton === true) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_clone_src+"' title='"+msgObj.buttonDig_clone_title+"' onclick='d.addCopy(d.get("+i+"));d.get(-1).e.delElement(\"fid\");executeDigitizeSubFunctions();'>";
- // button: remove geometry from database
- if (d.get(i).e.getElementValueByName('fid')) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
- var geomName = getName(d.get(i));
- var currentGeomType;
- if (d.get(i).geomType == parent.geomType.polygon) {
- currentGeomType = msgObj.messageDescriptionPolygon;
- else if (d.get(i).geomType == parent.geomType.line) {
- currentGeomType = msgObj.messageDescriptionLine;
- else if (d.get(i).geomType == parent.geomType.point) {
- currentGeomType = msgObj.messageDescriptionPoint;
- var multi = "";
- if (d.get(i).count() > 1) {
- multi = "multi";
- listOfGeom += ">" + htmlspecialchars(geomName) +" (" + multi + currentGeomType + ")</div>";
- // multigeometries
- listOfGeom += "<ul>";
- for (var j = 0; j < d.get(i).count(); j++) {
- var currentGeom = d.get(i).get(j);
- if (d.get(i).count() > 1 || (d.get(i).geomType == geomType.polygon &&
- d.get(i).get(j).innerRings &&
- d.get(i).get(j).innerRings.count() > 0)) {
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").del(" + j + ");executeDigitizeSubFunctions();'>";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
- listOfGeom += ">" + currentGeomType + "#" + (j+1) +"</div></li>";
- if (d.get(i).geomType == geomType.polygon &&
- d.get(i).get(j).innerRings.count() > 0) {
- for (var k = 0; k < d.get(i).get(j).innerRings.count(); k++) {
- var currentRing = d.get(i).get(j).innerRings.get(k);
- listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").get(" + j + ").innerRings.del(" + k + ");executeDigitizeSubFunctions();'>";
- listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
- listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\")' ";
- listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
- listOfGeom += ">inner ring #" + (k+1) +"</div></li>";
- listOfGeom += "</ul>";
- listOfGeom += "</li>";
- parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
-// --- display (end) -----------------------------------------------------------------------------------------
-// --- wfs window (begin) -----------------------------------------------------------------------------------------
-// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
-function formCorrect(doc, formId) {
- var isCorrect = true;
- var errorMessage = "";
- var result;
- var form = doc.getElementById(formId);
- result = mandatoryFieldsNotEmpty(doc, form);
- isCorrect = isCorrect && result.isCorrect;
- errorMessage += result.errorMessage;
- //select box is now checked within function mandatoryFieldsNotEmpty
- //result = validBoxEntrySelected(form);
- //isCorrect = isCorrect && result.isCorrect;
- //errorMessage += result.errorMessage;
- result = dataTypeIsCorrect(doc, form);
- return {"isCorrect":isCorrect, "errorMessage":errorMessage};
-function validBoxEntrySelected(form){
- for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
- if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
- if (parseInt(form.childNodes[i].selectedIndex) == 0) {
- return {"isCorrect":false, "errorMessage":errorMessage};
- else if (form.childNodes[i].hasChildNodes()) {
- isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
- if (!isCorrect) {
- errorMessage = msgObj.messageSelectAnOption + "\n";
-function mandatoryFieldsNotEmpty(doc, node){
- nodeArray = doc.getElementsByName("mandatory");
- for (var i = 0; i < nodeArray.length && isCorrect; i++) {
- if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
- var nodeId = nodeArray[i].id.substr(10);
- if (nodeArray[i].value == "true") {
- if (doc.getElementById(nodeId).value == "") {
- isCorrect = false;
- errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
- if (nodeArray[i].nodeName.toUpperCase() == "SELECT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
-function isInteger(str) {
- if (str.match(/^\d*$/)) {
- return true;
- return false;
-function isFloat(str) {
- if (isInteger(str)) {
- return true;
- if (str.match(/^\d+\.\d+$/)) {
- return true;
- return false;
-function replaceCommaByDecimalPoint(str) {
- var patternString = ",";
- var pattern = new RegExp(patternString);
- while (str.match(pattern)) {
- str = str.replace(pattern, ".");
- return str;
-function dataTypeIsCorrect(doc, node){
- nodeArray = doc.getElementsByName("datatype");
- for (var i = 0; i < nodeArray.length ; i++) {
- if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
- var nodeId = nodeArray[i].id.substr(9);
- var nodeValue = doc.getElementById(nodeId).value;
- if (nodeArray[i].value == "int") {
- if (!isInteger(nodeValue)) {
- errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
- else if (nodeArray[i].value == "double") {
- nodeValue = replaceCommaByDecimalPoint(nodeValue);
- if (!isFloat(nodeValue)) {
- errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
- else {
- doc.getElementById(nodeId).value = nodeValue;
-// --- wfs window form check (end) -----------------------------------------------------------------------------------------
-function getAvailableWfsForGeom(geom, wfsConf) {
- var wfsConfIndices = [];
- for (var attr in wfsConf) {
- var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
- if (!isTrans) {
- continue;
- if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
- if (parseInt(geom.wfs_conf) == parseInt(attr)) {
- wfsConfIndices.push(attr);
- else {
- for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
- var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
- if (isGeomColumn) {
- var isMultiPolygon = (
- geom.geomType == parent.geomType.polygon &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiSurfacePropertyType'
- var isPolygon = (
- geom.count() == 1 &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'SurfacePropertyType'
- var isMultiLine = (
- geom.geomType == parent.geomType.line &&
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiCurvePropertyType'
- var isLine = (
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType' ||
- wfsConf[attr]['element'][elementIndex]['element_type'] == 'CurvePropertyType'
- var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
-// alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
- if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
- return wfsConfIndices;
-function wfsExistsForGeom(geom, wfsConf) {
- wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
-// alert(wfsConfIndices.join(","));
- if (wfsConfIndices.length > 0) {
- return true;
- return false;
-function showWfsKml (geometryIndex) {
- wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
- wfsKmlWindow.document.open("text/html");
- wfsKmlWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
- wfsKmlWindow.document.close();
- str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
- var properties = d.get(geometryIndex).e;
- var propertyCount = properties.count();
- for (var i = 0; i < propertyCount; i++) {
- var key = properties.getName(i);
- var value = properties.getValue(i);
- var expr = /Mapbender:/;
- if (!key.match(expr)) {
- str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
- str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
- var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
- var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
- deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
- str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
-// delete button not yet implemented
-// str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
- str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
- wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
-// this method opens a new window and displays the attributes in wfs_conf
-function showWfs(geometryIndex) {
- wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
- wfsWindow.document.open("text/html");
- var str = "";
- var strStyle = "";
- var defaultIndex = -1;
- str += "<form id='wfs'>\n";
- // 1. add select box
- var onChangeText = "document.getElementById('elementForm').innerHTML = ";
- onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
- onChangeText += "window.opener.setWfsWindowStyle(this.value);";
- str += "\t<select name='wfs' size='" + wfsConf.length + "'";
- str += " onChange=\""+ onChangeText +"\"";
- str += ">\n\t\t";
- var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
- var selected = false;
- for (var i = 0; i < wfsConfIndices.length ; i++) {
- str += "<option value='" + wfsConfIndices[i] + "'";
- if (!selected) {
- str += " selected";
- selected = true;
- defaultIndex = parseInt(wfsConfIndices[i]);
- str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
- str += "</option>\n\t\t";
- str += "</select>\n\t\t</form>\n\t";
- str += "<div id='elementForm'>\n</div>";
- if (defaultIndex != -1) {
- var htmlStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
- htmlStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
- htmlStr += '<style type="text/css">'
- htmlStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
- htmlStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
- htmlStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
- htmlStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
- htmlStr += 'div.helptext p { margin: 0 ; }';
- htmlStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
- htmlStr += 'a img { vertical-align: middle;border: 0; }';
- htmlStr += '</style>';
- htmlStr += '</head><body></body></html>';
-// wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
- wfsWindow.document.write(htmlStr);
- wfsWindow.document.write(str);
- wfsWindow.document.close();
- wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
- else {
- wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
-function setWfsWindowStyle(wfsConfIndex) {
- wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
-// returns a form with the elements of a selected wfs
-// (if the original wfs is the selected wfs, the values are set too)
-function buildElementForm(wfsConfIndex, memberIndex){
- var str = "";
- var fid = false;
- str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
- // Check if there are categories given and
- // build the form in tabs if necessary
- var elementCategories = ['abc','def','123'];
- for(var i = 0; i < featureTypeElementArray.length; i++){
- var categoryName = featureTypeElementArray[i].f_category_name;
- var categoryNameIsUnique = true;
- if(categoryName.length === 0) { continue; }
- for(var j = 0; j < elementCategories.length; j++) {
- if(elementCategories[j] == categoryName) {
- categoryNameIsUnique = false;
- if(categoryNameIsUnique) {
- elementCategories.push(categoryName);
- if(elementCategories.length > 0) {
- return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
- for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
- if (isEditable) {
- if (!formElementHtml || !formElementHtml.match(/<select/)) {
- str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
- str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
- str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
- else {
- // preselect the correct entry of the box
- var patternString = "option value( )*=( )*'"+elementValue+"'";
- var patternStringForReplace = "option value = '"+elementValue+"'";
- formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
- formElementHtml = formElementHtml.replace(/</g,'<');
- formElementHtml = formElementHtml.replace(/>/g,'>');
- formElementHtml = formElementHtml.replace(/'/g,'\'');
- str += '<p>';
- str += '</p>';
- str += '</div>';
- else {
- str += "</table><table>";
- var options = ["insert", "update", "delete", "abort"];
- if (options[i] == "insert" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
- str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
- str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
- var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
- str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
- str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
- return str;
-function dbGeom(type,m) {
- if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
- d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
- d.get(m).e = new parent.Wfs_element();
- else {
- var myconf = wfsConf[d.get(m).wfs_conf];
- var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
- var proceed = true;
- if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
- proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
- if (proceed) {
- var fid = false;
- myform = wfsWindow.document.getElementById(featureTypeElementFormId);
- for (var i=0; i<myform.length; i++){
- if (myform.elements[i].id == "fid") {
- fid = myform.elements[i].value;
- if (fid == "false") {
- fid = false;
- else {
- d.get(m).e.setElement('fid', fid);
- else if (myform.elements[i].type == 'text' ){
- if (myform.elements[i].id) {
- var elementId = String(myform.elements[i].id).replace(/mb_digitize_form_/, "");
- d.get(m).e.setElement(elementId, myform.elements[i].value);
- else {
- errorMessage = msgObj.messageErrorFormEvaluation;
- // selectbox
- else if (typeof(myform.elements[i].selectedIndex) == 'number') {
- d.get(m).e.setElement(elementId, myform.elements[i].options[myform.elements[i].selectedIndex].value);
- else {
- else {
- fid = d.get(m).e.getElementValueByName('fid');
-// str = parent.get_wfs_str(myconf, d, m, type, fid);
- var geoJson = d.featureToString(m);
- "../extensions/geom2wfst.php",
- 'geoJson' : geoJson,
- 'method' : type,
- 'wfs_conf_id' : wfsConf[d.get(m).wfs_conf]['wfs_conf_id']
- function(json,status){
- var result = eval('('+json+')');
- var success = result.success;
- var fid = result.fid;
- wfsSubWrite(m, type, status, success, fid);
-function wfsSubWrite(m, type, status, success, fid) {
- if (status == "success" && success) {
- if (type == 'insert' && fid) {
- d.get(m).e.setElement("fid", fid);
- if (type == 'delete') {
- parent.mb_disableThisButton(mod_digitizeEvent);
- d.del(m);
- var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
- else {
- var wfsWriteMessage = msgObj.messageErrorWfsWrite;
- parent.mb_execWfsWriteSubFunctions();
- wfsWindow.alert(wfsWriteMessage);
- window.setTimeout("wfsWindow.close()",0);
- else {
- alert(wfsWriteMessage);
-function getMultiGeometryIdsByPlacemarkId (placemarkId) {
- var multiGeometryIdArray = [];
- var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
- if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
- multiGeometryIdArray.push(i);
- return multiGeometryIdArray;
-function updateKmlInDb (geometryIndex, command) {
- var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
- var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
- if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
- // update properties from form
- myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
- for (var i=0; i < myform.length; i++){
- if (myform.elements[i].type == 'text' ){
- var key = myform.elements[i].name;
- var value = myform.elements[i].value;
- // update all geometries with the same placemark id
- for (var j = 0; j < multiGeometryIdArray.length; j++) {
- var currentProperties = d.get(j).e;
- currentProperties.setElement(key, value);
- var kmlId = properties.getElementValueByName("Mapbender:id");
- parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
- if (obj === "1") {
- wfsKmlWindow.alert("KML updated.");
- var link = wfsKmlWindow.document.createElement("a");
- link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
- link.target = "_blank";
- link.innerHTML = "KML";
- wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
- wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
- else {
- wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
-function getMessages() {
- parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
- msgObj = obj;
- applyMessages();
-function applyMessages() {
- updateMeasureTag();
- updateListOfGeometries();
- updateButtons();
- </script>
- </head>
- <body onload="registerFunctions();displayButtons();">
- <div id='digButtons'></div>
- <div id='listOfGeometries' class='digitizeGeometryList'></div>
- </body>
-</html>
\ No newline at end of file
Deleted: branches/print_dev/http/javascripts/mod_loadwmc_list.php
--- branches/print_dev/http/javascripts/mod_loadwmc_list.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_loadwmc_list.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,3 +0,0 @@
-<?php
- echo "fisch";
Deleted: branches/print_dev/http/javascripts/mod_log.php
--- branches/print_dev/http/javascripts/mod_log.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_log.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,13 +0,0 @@
-<?php
-require(dirname(__FILE__)."/../php/mb_validatePermission.php");
-mb_registerInitFunctions("mb_log_init()");
-function mb_log_init(){
- mb_log = "mb_log_set";
-try{if(logtype){}}catch(e){logtype="";}
-function mb_log_set(req, time_client){
- var url = "../php/mod_log.php?<?php echo $urlParameters;?>&req=" + escape(req) + "&time_client=" + time_client;
- mb_ajax_post(url, {req:req, time:time_client});
- return true;
Deleted: branches/print_dev/http/javascripts/mod_reload.php
--- branches/print_dev/http/javascripts/mod_reload.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_reload.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,66 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/reload
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * Package: Reload
- * Description:
- * A button that reloads the whole window.
- * SQL:
- * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
- * > e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>', 'reload',
- * > 2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
- * > 60,24,24,1,'','','','mod_reload.php','','mapframe1','',
- * > 'http://www.mapbender.org/index.php/Reload');
- * Maintainer:
- * http://www.mapbender.org/User:Vera_Schulze
-var Reload = function (domElement) {
- var that = this;
- domElement.src = options.src;
- if (!options.src) {
- new Mb_exception(options.id + " requires a src.");
- else {
- $(domElement).mouseover(function () {
- domElement.src = options.src.replace(/_off/,"_over");
- }).mouseout(function () {
- }).click(function () {
- that.reload();
- * Method: reload
- * Reloads the window.
- this.reload = function () {
- location.reload();
-var reload = new Reload(this);
Deleted: branches/print_dev/http/javascripts/mod_resize_mapsize.php
--- branches/print_dev/http/javascripts/mod_resize_mapsize.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_resize_mapsize.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,123 +0,0 @@
-<?php
-# $Id:mod_resize_mapsize.php 1964 2008-01-15 08:11:29Z christoph $
-# http://www.mapbender.org/index.php/ResizeMapsize
-# Created on 12.07.2006/07:32:08
-# Projekt: mapbender
-# File: mod_resize_mapsize.php
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-include(dirname(__FILE__) . "/../include/dyn_js.php");
-$sqltarget = "SELECT e_target FROM gui_element WHERE e_id = 'resizeMapsize' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sqltarget, $v, $t);
-while($row = db_fetch_array($res)){
- $e_target = $row["e_target"];
-$sql = "SELECT e_left, e_top FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = $1";
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
- $e_left = $row["e_left"];
- $e_top = $row["e_top"];
-$sqllegend = "SELECT e_width FROM gui_element WHERE e_id = 'legend' AND fkey_gui_id = $1";
-$t = array('s');
-$res = db_prep_query($sqllegend, $v, $t);
- $leg_e_width = $row["e_width"];
-try{
- if (resize_option){}
-catch(e){
- resize_option = "auto";
-try{
- if (adjust_width){}
-catch(e){
- adjust_width = "-45";
-try{
- if (adjust_height){}
-catch(e){
- adjust_height = "-35";
-var map_frame = "<?php echo $e_target ?>";
-var map_frame_left = "<?php echo $e_left ?>";
-var map_frame_top = "<?php echo $e_top ?>";
-var legend_width = "<?php echo $leg_e_width ?>";
-function frameWidth(){
- if (window.innerWidth) return window.innerWidth;
- else if (document.body && document.body.offsetWidth) return document.body.offsetWidth;
- else return 0;
-function frameHeight(){
- if (window.innerHeight)return window.innerHeight;
- else if (document.body && document.body.offsetHeight) return document.body.offsetHeight;
- else return 0;
-function adjustDimension(){
- var ind = getMapObjIndexByName("<?php echo $e_target; ?>");
- var mapheight = frameHeight() - <?php echo $e_top ?> + parseInt(adjust_height);
- var mapwidth = frameWidth() - map_frame_left - legend_width + parseInt(adjust_width) ;
- var coords = mb_mapObj[ind].extent.split(",");
- midcoordx=parseFloat((parseFloat(coords[2])-parseFloat(coords[0]))/2)+parseFloat(coords[0]);
- midcoordy=parseFloat((parseFloat(coords[3])-parseFloat(coords[1]))/2)+parseFloat(coords[1]);
- mb_mapObj[ind].setWidth(mapwidth);
- mb_mapObj[ind].setHeight(mapheight);
- mb_mapObj[ind].repaintScale(midcoordx,midcoordy,mb_mapObj[ind].getScale());
-function rebuild() {
- if (width_temp != frameWidth() || height_temp != frameHeight()) window.setTimeout('adjustDimension()', 500);
-function control(){
- adjustDimension();
- if (!window.width_temp && window.innerWidth) {
- window.onresize = rebuild;
- width_temp = frameWidth();
- height_temp = frameHeight();
- if (!window.width_temp && document.body && document.body.offsetWidth) {
-if (resize_option == 'auto'){
- eventInit.register(function() {
- control();
Deleted: branches/print_dev/http/javascripts/mod_sandclock.php
--- branches/print_dev/http/javascripts/mod_sandclock.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_sandclock.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,151 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_sandclock.php
- * Package: Sandclock
- * Description:
- * Displays an arbitrary sandclock image on a map
- * SQL:
- * > e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
- * > e_mb_mod, e_target, e_requires) VALUES ('<gui_id>', 'sandclock', '0002',
- * > '1', 'displays a sand clock while waiting for requests', 'div', '',
- * > '', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
- * > 'mapframe1', '');
- * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES ('<gui_id>', 'sandclock',
- * > 'mod_sandclock_image', '../img/sandclock.gif',
- * > 'define a sandclock-image', 'var');
- * Maintainer:
- * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * mod_sandclock_img - *[optional]* the filename and path to the sandclock image
-var Sandclock = function (options) {
- var that = this;
- // check if target is set correctly
- if (!options.target) {
- new Mb_Exception(this.id + "requires a target.");
- return;
- if (!Mapbender.Modules[options.target]) {
- new Mb_exception("Target " + options.target + " not found by " + this.id)
- var map = Mapbender.Modules[options.target];
- // element vars
- if (!options.mod_sandclock_image) {
- options.mod_sandclock_image = "../img/sandclock.gif";
- var mod_sandclock_img = new Image();
- mod_sandclock_img.src = options.mod_sandclock_image;
- // constructor
- eventAfterMapRequest.register(function (obj) {
- that.show(obj.myMapId);
- var isInitialised = false;
- var aktiv;
- * Method: show
- * Displays the sandclock
- this.show = function (mapId) {
- if (!isInitialised) {
- var temp = "<img src='"+mod_sandclock_img.src+"'>";
- var map_el = map.getDomElement();
- if(!map_el.ownerDocument.getElementById(map.elementName+"_sandclock")){
- //create Box Elements
- el_top = map_el.ownerDocument.createElement("div");
- el_top.style.position = "absolute";
- el_top.style.top = "0px";
- el_top.style.left = "0px";
- el_top.style.overflow = "hidden";
- el_top.style.zIndex = "10";
- el_top.style.visibility = "visible";
- el_top.style.cursor = "crosshair";
- el_top.id = map.elementName+"_sandclock";
- map_el.appendChild(el_top);
- writeTag(map.frameName, map.elementName+"_sandclock", temp);
- mb_arrangeElement("", options.target+"_sandclock", (map.width/2 - 16), (map.height/2 - 16));
- isInitialised = true;
- // if mapId is not given, the sandclock has to be turned off manually
- // by calling hide(). Usually this is done in a callback
- // function.
- if (typeof mapId !== "undefined") {
- aktiv = setTimeout(function () {
- that.show(mapId);
- },10);
- var mapIdArray = mapId.split(",");
- var complete = true;
- var mapId;
- for (var i = 0; i < mapIdArray.length && complete; i++) {
- mapId = mapIdArray[i];
- var myDoc = map.getDomElement().ownerDocument;
- if(myDoc.getElementById(mapId) &&
- !myDoc.getElementById(mapId).complete) {
- complete = false;
- if (complete) {
- clearTimeout(aktiv);
- that.hide(map);
- * Method: hide
- * Hides the sandclock
- this.hide = function () {
- writeTag(map.frameName, map.elementName+"_sandclock", "");
-var sandclock = new Sandclock(options);
Deleted: branches/print_dev/http/javascripts/mod_sandclock2.php
--- branches/print_dev/http/javascripts/mod_sandclock2.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_sandclock2.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,72 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_sandclock2.php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "var mod_sandclock_target = '".$e_target[0]."';";
-var mod_sandclock_maxWait = 1000 * 60;
-var mod_sandclock_minWait = 1000 * 0;
-var mod_sandclock_count;
-var mod_sandclock_img = new Image();
-mod_sandclock_img.src = "../img/sandclock.gif";
-mb_registerSubFunctions("mod_sandclock(true,myMapId)");
-function mod_sandclock(start){
- var ind = getMapObjIndexByName(mod_sandclock_target);
- if(start){
- mod_sandclock_count = mod_sandclock_maxWait;
- writeTag(mod_sandclock_target, "sandclock", temp);
- mb_arrangeElement(mod_sandclock_target, "sandclock", (mb_mapObj[ind].width/2 - 16), (mb_mapObj[ind].height/2 - 16));
- var dim = mod_sandclock_getWSize();
- document.getElementById("sandclock2").style.width = dim[0];
- document.getElementById("sandclock2").style.height = dim[1];
- // check images:
- aktiv = setTimeout("mod_sandclock(false)",100);
- mod_sandclock_count -= 1000;
- var allMaps = window.frames[mod_sandclock_target].document.getElementsByName("mapimage");
- var cnt = 1;
- for(var i=0; i<allMaps.length; i++){
- if(allMaps[i].complete == true){
- cnt++;
- if((mod_sandclock_count <= 0 || cnt >= allMaps.length) && mod_sandclock_count < (mod_sandclock_maxWait - mod_sandclock_minWait)){
- writeTag(mod_sandclock_target, "sandclock", "");
- document.getElementById("sandclock2").style.width = 1;
- document.getElementById("sandclock2").style.height = 1;
-function mod_sandclock_getWSize(){
- if(ie){
- var dim = new Array(window.document.body.offsetWidth, window.document.body.offsetHeight);
- else{
- var dim = new Array(window.innerWidth, window.innerHeight);
- return dim;
Deleted: branches/print_dev/http/javascripts/mod_scalebar.php
--- branches/print_dev/http/javascripts/mod_scalebar.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_scalebar.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,105 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_scalebar.php
-echo "var mod_scalebar_target = '".$e_target[0]."';";
-var mod_scalebar_left = 5;
-var mod_scalebar_bottom = 17;
-var mod_scalebar_color1 = "white";
-var mod_scalebar_color2 = "black";
-var mod_scalebar_font = "Arial, Helvetica, sans-serif";
-var mod_scalebar_fontsize = "9px";
-eventAfterMapRequest.register(function () {
- mod_scalebar();
-function mod_scalebar(){
- var scale = mb_getScale(mod_scalebar_target);
- var ind = getMapObjIndexByName(mod_scalebar_target);
- if(scale < 10){
- var unit = '10 cm';
- var factor = 10/scale;
- var img_width = Math.round(factor * mb_resolution);
- if(scale >= 10 && scale < 100){
- var unit = '1 m';
- var factor = 100/scale;
- if(scale < 1000 && scale >= 100){
- var unit = '10 m';
- var factor = 1000/scale;
- if(scale < 10000 && scale >= 1000){
- var unit = '100 m';
- var factor = 10000/scale;
- if(scale < 100000 && scale >= 10000){
- var unit = '1 km';
- var factor = 100000/scale;
- if(scale < 1000000 && scale >= 100000){
- var unit = '10 km';
- var factor = 1000000/scale;
- if(scale < 10000000 && scale >= 1000000){
- var unit = '100 km';
- var factor = 10000000/scale;
- if(scale < 100000000 && scale >= 10000000){
- var unit = '1000 km';
- var factor = 100000000/scale;
- if(scale >= 100000000){
- var scalebarTag = "<img src='../img/scalebar_bw.gif' width='"+ img_width +"' height='6'> ";
- scalebarTag += "<div style='position:absolute;left:"+(img_width + 4)+"px;top:5px;color:"+mod_scalebar_color1+";font-family:"+mod_scalebar_font+";font-size:"+mod_scalebar_fontsize+";'><nobr>"+ unit+"</nobr></div>";
- scalebarTag += "<div style='position:absolute;left:"+(img_width + 2)+"px;top:7px;color:"+mod_scalebar_color1+";font-family:"+mod_scalebar_font+";font-size:"+mod_scalebar_fontsize+";'><nobr>"+ unit+"</nobr></div>";
- scalebarTag += "<div style='position:absolute;left:"+(img_width + 2)+"px;top:5px;color:"+mod_scalebar_color1+";font-family:"+mod_scalebar_font+";font-size:"+mod_scalebar_fontsize+";'><nobr>"+ unit+"</nobr></div>";
- scalebarTag += "<div style='position:absolute;left:"+(img_width + 3)+"px;top:6px;color:"+mod_scalebar_color2+";font-family:"+mod_scalebar_font+";font-size:"+mod_scalebar_fontsize+";'>"+ unit+"</div>";
- var map_el = mb_mapObj[ind].getDomElement();
- if(!map_el.ownerDocument.getElementById(mb_mapObj[ind].elementName+"_scalebar")){
- el_top.style.width = "200px";
- el_top.id = mb_mapObj[ind].elementName+"_scalebar";
- mb_arrangeElement("", mod_scalebar_target+"_scalebar", mod_scalebar_left, (mb_mapObj[ind].height - mod_scalebar_bottom));
- writeTag(mb_mapObj[ind].frameName, mb_mapObj[ind].elementName+"_scalebar", scalebarTag);
Deleted: branches/print_dev/http/javascripts/mod_zoomFull.php
--- branches/print_dev/http/javascripts/mod_zoomFull.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/javascripts/mod_zoomFull.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,21 +0,0 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomFull.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-$(this).click(function () {
- return;
- return;
- Mapbender.Modules[options.target].zoomFull();
-}).mouseover(function () {
- if (options.src) {
- this.src = options.src.replace(/_off/, "_over");
-}).mouseout(function () {
- this.src = options.src;
Deleted: branches/print_dev/http/php/mod_map1.php
--- branches/print_dev/http/php/mod_map1.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/php/mod_map1.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,150 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>mod_map1</title>
-<?php
-$sql = "SELECT e_width, e_height FROM gui_element WHERE e_id = 'mapframe1' AND fkey_gui_id = $1";
-$v = array($_SESSION["mb_user_gui"]);
-$t = array("s");
-$cnt = 0;
- $e_width = $row["e_width"];
- $e_height = $row["e_height"];
- $cnt++;
-session_write_close();
-if($cnt > 1){ echo "alert('mapframe1: ID not unique!');";}
-echo '<script type="text/javascript">';
-echo "\n";
-echo "var mod_map1_width = '".$e_width."';\n";
-echo "var mod_map1_height = '".$e_height."';\n";
-echo "</script>\n";
-<script type='text/javascript' src='../extensions/jquery-1.2.6.min.js'></script>
-<script type='text/javascript' src='../extensions/jquery.mousewheel.min.js'></script>
-<script type='text/javascript' src='../extensions/jqjson.js'></script>
-<script type="text/javascript">
-var mapTimeout;
-var sum_delta = 0;
-var lastTimestamp;
-var lastScrollPositionX;
-var lastScrollPositionY;
-function init () {
- parent.eventInitMap.register(function init_mod_map1(){
- parent.mb_registerMapObj('mapframe1', 'mapframe1', null,mod_map1_width, mod_map1_height);
- if (!parent.$.browser.msie) {
- parent.$(document, window.frames['mapframe1']).mousewheel(function (event, delta) {
- if (sum_delta == 0) {
- mapTimeout = setTimeout(function () {
- lastScrollPositionX=event.pageX;
- lastScrollPositionY=event.pageY;
- mousewheelZoom();
- 100);
- sum_delta = sum_delta + (delta);
- var currentTime = new Date();
- lastTimestamp = currentTime.getTime();
- return false;
-function mousewheelZoom () {
- if (currentTime.getTime() - lastTimestamp > 200) {
- var ind = parent.getMapObjIndexByName('mapframe1');
- var pos = parent.makeClickPos2RealWorldPos("mapframe1", lastScrollPositionX, lastScrollPositionY);
- if (sum_delta > 0) {
- parent.zoom("mapframe1", true, Math.pow(parent.Mapbender.zoomMousewheel, sum_delta), pos[0],pos[1]);
- else {
- parent.zoom("mapframe1", false, Math.pow(parent.Mapbender.zoomMousewheel, -sum_delta), pos[0], pos[1]);
- var newPosX = parent.parent.mb_mapObj[ind].width - lastScrollPositionX;
- var newPosY = parent.parent.mb_mapObj[ind].height - lastScrollPositionY;
- var posAfterZoom = parent.makeClickPos2RealWorldPos("mapframe1", newPosX, newPosY);
- parent.zoom('mapframe1', false, 1.0, posAfterZoom[0], posAfterZoom[1]);
- sum_delta = 0;
- clearTimeout(mapTimeout);
- else {
- mousewheelZoom(sum_delta);
- 100);
-</script>
-</head>
-<body leftmargin='0' topmargin='0' onload="init()" bgcolor='#ffffff'>
-<div id='mapframe1' name='mapframe1' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;'>
-<div id='markResult' name='maps' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26'> </div>
-<div id='mapframe1_maps' name='maps' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;'> </div>
-<div id='highlight' style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif"/></div>
-<div id='l_right' name='l_right' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:10;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
-<div id='l_bottom' name='l_bottom' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
-<div id='l_left' name='l_left' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
-<div id='l_top' name='l_top' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
-<div id="sandclock" style="position:absolute; top:0px; left:0px; z-index:14;"></div>
-<div id="scalebar" style="position:absolute; top:0px; left:0px; z-index:15;"></div>
-<div id="measuring" style="position:absolute; top:0px; left:0px; z-index:16; font-size:10px"></div>
-<div id="measure_display" style="position:absolute; top:0px; left:0px; z-index:17;"></div>
-<div id="copyright" style="position:absolute; top:0px; left:0px; z-index:18;"></div>
-<div id="measure_sub" style="position:absolute; top:0px; left:0px; z-index:19;"></div>
-<div id='permanent' style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:13;visibility:hidden"><img src="../img/redball.gif"/></div>
-<div id="digitize_sub" style="position:absolute; top:0px; left:0px; z-index:24;"></div>
-<div id="digitize_display" style="position:absolute; top:0px; left:0px; z-index:25;"></div>
-<div id='um_title' name='um_title' style="font-family: Arial, Helvetica, sans-serif; DISPLAY:none; OVERFLOW:visible; POSITION:absolute; DISPLAY:none; BACKGROUND:#BEC1C4;border:1px solid black; z-index:98;"></div>
-<div id='um_draw' name='um_draw' style="LEFT:0px;OVERFLOW:visible;POSITION:absolute;TOP:0px;z-index:99;"></div>
-<img id='um_img' name='um_img' style ='position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; border:0;z-index:100' src='../img/transparent.gif' useMap='#um'>
-<map name='um' id='um'></map>
-</div>
-</body>
-</html>
Deleted: branches/print_dev/http/php/mod_mapOV.php
--- branches/print_dev/http/php/mod_mapOV.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/php/mod_mapOV.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,149 +0,0 @@
-<?php
-# $Id$
-if(isset($_REQUEST["wms"])){
- $rank = $_REQUEST["wms"];
-else{
- $rank = 0;
-<html>
-<head>
-<?php
-<title>mod_mapOV0.php</title>
-<?php
-include '../include/dyn_css.php';
-<?php
-$gui_id = $_SESSION["mb_user_gui"];
-$sql = "SELECT e_width,e_height, e_target FROM gui_element WHERE e_id = 'overview' AND fkey_gui_id = $1";
-$t = array("s");
-$cnt = 0;
-echo "<script type='text/javascript'>";
- echo "var mod_overview_width = " . $row["e_width"].";";
- echo "var mod_overview_height = " . $row["e_height"].";";
- echo "var mod_overview_target = '" . $row["e_target"]."';";
- $cnt++;
-echo "var mod_overview_rank = ".$rank.";";
-if($cnt > 1){ echo "alert('overview: ID not unique!');";}
-echo "</script>";
-function init () {
- parent.eventInitMap.register(function init_mod_mapOV(){
- parent.mb_registerMapObj('overview', 'overview', mod_overview_rank, mod_overview_width, mod_overview_height);
- document.onmouseover = mod_ov_setHandler;
- document.onmousedown = parent.mod_box_start;
- document.onmouseup = mod_ov_getExtent;
- document.onmousemove = parent.mod_box_run;
- var ind = parent.getMapObjIndexByName('overview');
- var ov_extent = parent.mb_mapObj[ind].getExtentInfos();
- parent.mb_mapObj[ind].isOverview = true;
-function mod_ov_setHandler(e){
- parent.mb_isBF = "overview";
- parent.mb_zF = mod_overview_target;
-function mod_ov_getExtent(e){
- mod_ov_setValidClipping(parent.mod_box_stop(e));
-parent.mb_registerSubFunctions("window.frames['overview'].mod_ov_showMapExtent()");
-function mod_ov_showMapExtent(){
- for(var i=0; i<parent.mb_mapObj.length; i++){
- if(parent.mb_mapObj[i].frameName == mod_overview_target){
- var arrayBBox = parent.mb_mapObj[i].extent.split(",");
- var ind = parent.getMapObjIndexByName(mod_overview_target);
- var pointMin = parent.mb_mapObj[ind].convertRealToPixel(new parent.Point(minX, maxY));
- var pointMax = parent.mb_mapObj[ind].convertRealToPixel(new parent.Point(maxX, minY));
- var px1 = pointMin.x;
- var py1 = pointMin.y;
- var px2 = pointMax.x;
- var py2 = pointMax.y;
- while((px2 - px1) < 8){
- px1 -= 1;
- px2 += 1;
- while((py2 - py1) < 8){
- py1 -= 1;
- py2 += 1;
- if(px1 < 0){px1 = 1;}
- if(px1 > mod_overview_width){px1 = mod_overview_width-1;}
- if(py1 < 0){py1 = 1;}
- if(py1 > mod_overview_height){py1 = mod_overview_height-1;}
- if(px2 > mod_overview_width){px2 = mod_overview_width-1;}
- if(px2 < 0){px2 = 1;}
- if(py2 > mod_overview_height){py2 = mod_overview_height-1;}
- if(py2 < 0){py2 = 1;}
- parent.mb_drawBox(px1,py1,px2,py2);
-function mod_ov_setValidClipping(coords){
- if(coords.length > 2){
- parent.mb_calculateExtent(parent.mb_zF,coords[0],coords[1],coords[2],coords[3]);
- parent.setMapRequest(parent.mb_zF);
- else{
- parent.zoom(parent.mb_zF,true,1.0,coords[0], coords[1]);
-</script>
-</head>
-<div id='overview' name='overview' style =' position:absolute;left:0px;top:0px;width:0px;height:0px;' >
-<div id='overview_maps' name='maps' style =' position:absolute;left:0px;top:0px;width:0px;height:0px;' ></div>
-<div id='l_top' name='l_top' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:red;cursor: crosshair;"></div>
-<div id='l_right' name='l_right' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:red;cursor: crosshair;"></div>
-<div id='l_bottom' name='l_bottom' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:red;cursor: crosshair;"></div>
-<div id='l_left' name='l_left' style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:14;visibility:hidden;background-color:red;cursor: crosshair;"></div>
-<div id='highlight' style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif" width="14" height="14" /></div>
-</div>
-</body>
-</html>
Added: branches/print_dev/http/print/mod_printPDF_div.js
--- branches/print_dev/http/print/mod_printPDF_div.js (rev 0)
+++ branches/print_dev/http/print/mod_printPDF_div.js 2009-08-04 11:51:01 UTC (rev 4471)
@@ -0,0 +1,271 @@
+var myTarget = options.target;
+var myId = options.id;
+/* the array of json print config files */
+if (!options.mbPrintConfigFilenames)
+ mbPrintConfigFilenames = new Array("testConfigTemplate.json");
+else
+ mbPrintConfigFilenames = options.mbPrintConfigFilenames;
+if (!options.mbPrintConfigTitles)
+ mbPrintConfigTitles = new Array("Default");
+else
+ mbPrintConfigTitles = options.mbPrintConfigTitles
+if (!options.mbPrintConfigPath)
+ mbPrintConfigPath = "../print/";
+else
+ mbPrintConfigPath = options.mbPrintConfigPath;
+/* ------------- printbox addition ------------- */
+var printBox;
+var PrintPDF = function (options) {
+var that = this;
+eventInit.register(function () {
+ mod_printPDF_init();
+this.createPrintBox = function () {
+ size = "A4";
+ //document.form1.size.value = size;
+ format = "portrait";
+ var w, h;
+ //validate();
+ var map = Mapbender.modules[myTarget];
+ var map_el = map.getDomElement();
+ var jqForm = $("#"+myId+"_form");
+ printBox = createBox({
+ target : myTarget,
+ width : w/mb_resolution,
+ height : h/mb_resolution,
+ scale : Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
+ afterChangeAngle : function (obj) {
+ if (typeof(obj) == "object") {
+ if (typeof(obj.angle) == "number") {
+ jqForm[0].angle.value = obj.angle;
+ if (obj.coordinates) {
+ jqForm[0].coordinates.value = String(obj.coordinates);
+ afterChangeSize : function (obj) {
+ if (obj.scale) {
+ jqForm[0].scale.value = obj.scale;
+ eventAfterMapRequest.register(function () {
+ if (typeof(printBox) !== "undefined") {
+ printBox.repaint();
+var destroyPrintBox = function () {
+ if (printBox) {
+ printBox.destroy();
+/* ------------- printbox addition -------------*/
+var mod_printPDF_init = function () {
+ /* first we'd need to build the configuration selection */
+ buildConfigSelector();
+ /* second we'd need to read the json configuration */
+ that.loadConfig(mbPrintConfigFilenames[0]);
+this.loadConfig = function (configFilename) {
+ $.get(mbPrintConfigPath + configFilename, function(json, status){
+ var obj = eval('(' + json + ')');
+ buildForm(obj);
+ hookForm();
+var hookForm = function () {
+ var options = {
+ url: '../print/printFactory.php',
+ type: 'post',
+ dataType: 'json',
+ beforeSubmit: validate,
+ success: showResult
+ $("#"+myId+"_form").ajaxForm(options);
+ * Change status of the working elements. These should begin with "$myId_working"
+ * @param {String} newStatus either "hide or "show"
+var showHideWorking = function (newStatus) {
+ if (newStatus=="hide")
+ $("[id^='"+myId+"_working']").hide();
+ else
+ $("[id^='"+myId+"_working']").show();
+ * update form values helper function
+var updateFormField = function (formData, key, value) {
+ for(var j=0; j < formData.length; j++){
+ if (formData[j].name == key) {
+ formData[j].value = value;
+ break;
+ * Validates and updates form data values.
+ * Adds the elements before the submit button.
+ * @see jquery.forms#beforeSubmitHandler
+var validate = function (formData, jqForm, options) {
+ showHideWorking("show");
+ var ind = getMapObjIndexByName(myTarget);
+ var f = jqForm[0];
+ f.map_url.value = '';
+ f.overview_url.value = '';
+ for(var i=0; i < mb_mapObj[ind].wms.length; i++){
+ if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if(mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
+ if(f.map_url.value != ""){
+ f.map_url.value += '___';
+ f.map_url.value += mb_mapObj[ind].wms[i].mapURL;
+ updateFormField(formData, "map_url", f.map_url.value);
+ //overview_url
+ var ind_overview = getMapObjIndexByName('overview');
+ if(mb_mapObj[ind_overview].mapURL != false ){
+ f.overview_url.value = mb_mapObj[ind_overview].mapURL;
+ updateFormField(formData, "overview_url", f.overview_url.value);
+ updateFormField(formData, "map_scale", mb_getScale(myTarget));
+ // write the measured coordinates
+ if (typeof(mod_measure_RX) !== "undefined") {
+ var tmp_x = '';
+ var tmp_y = '';
+ for(i = 0; i < mod_measure_RX.length; i++) {
+ if(tmp_x != '') {
+ tmp_x += ','
+ tmp_x += mod_measure_RX[i];
+ for(i = 0; i < mod_measure_RY.length; i++) {
+ if(tmp_y != '') {
+ tmp_y += ','
+ tmp_y += mod_measure_RY[i];
+ updateFormField(formData, "measured_x_values", tmp_x);
+ updateFormField(formData, "measured_y_values", tmp_y);
+ if (f.map_url.value!="") {
+ //return true;
+ } else {
+ showHideWorking("hide");
+ return false;
+var showResult = function (res, text) {
+ if (text == 'success') {
+ window.location = stripslashes(res.outputFileName);
+ else {
+ /* something went wrong */
+ $("#"+myId+"_result").html(text);
+ * Generates form elements as specified in the config controls object.
+ * @param {Object} json the config object in json
+var buildForm = function (json) {
+ $(".print_option_dyn").remove();
+ var str = "";
+ for (var item in json.controls) {
+ var element = json.controls[item];
+ var element_id = myId + "_" + element.id;
+ if (element.type != "hidden") {
+ str += '<div class="print_option_dyn">\n';
+ str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
+ } else {
+ str += '<div class="print_option_dyn" style="display:none;">\n';
+ switch (element.type) {
+ case "text":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
+ break;
+ case "hidden":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
+ break;
+ case "textarea":
+ str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
+ break;
+ case "select":
+ str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
+ for (var option_index in element.options) {
+ option = element.options[option_index];
+ str += '<option value="'+option.value+'">'+option.label+'</option>\n';
+ str += '</select><br>\n';
+ break;
+ str += '</div>\n';
+ if (str) $("#"+myId+"_formsubmit").before(str);
+ * Generates the configuration select element from the gui element vars
+ * mbPrintConfigFilenames and mbPrintConfigTitles
+var buildConfigSelector = function () {
+ var str = "";
+ str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
+ str += '<select id="printPDF_template" name="printPDF_template" size="1" onchange="Mapbender.modules[\''+myId+'\'].loadConfig(mbPrintConfigFilenames[this.selectedIndex]);">\n';
+ for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
+ str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
+ str += '</select><a href="#" onclick="Mapbender.modules[\''+myId+'\'].createPrintBox();return false;">o</a><br />\n';
+ if (str) $("#printPDF_selector").append(str);
+var stripslashes = function ( str ) {
+ return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
+$.extend(Mapbender.modules[options.id], new PrintPDF(options));
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/print/mod_printPDF_div.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -53,6 +53,60 @@
+var printBox;
+function createPrintBox () {
+ size = "A4";
+ var w, h;
+ //validate();
+ if (obj.scale) {
+function destroyPrintBox () {
+ if (printBox) {
function mod_printPDF_init() {
@@ -132,12 +186,13 @@
//overview_url
- updateFormField(formData, "overview_url", mb_mapObj[ind_overview].mapURL);
- if (mod_measure_RX != undefined && mod_measure_RY != undefined) {
var tmp_x = '';
var tmp_y = '';
@@ -158,7 +213,7 @@
- return true;
+ //return true;
} else {
return false;
@@ -198,7 +253,7 @@
break;
case "hidden":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'"><br>\n';
break;
case "textarea":
@@ -228,7 +283,7 @@
- str += '</select><br />\n';
+ str += '</select><a href="#" onclick="createPrintBox();return false;">o</a><br />\n';
Modified: branches/print_dev/http/print/print_functions.php
--- branches/print_dev/http/print/print_functions.php 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/print/print_functions.php 2009-08-04 11:51:01 UTC (rev 4471)
@@ -1,381 +1,377 @@
-<?php
- * $Id$
- * converts the coordinates created via the JavaScript
- * functions in 'mod_measure.php' into an array which
- * then holds both X- ans Y-values for each point in
- * the formats 'realworld coordinate' and 'pdf_coordinate'
- * @param string commaseperated X-values of the points (realworld coordinate)
- * @param string commaseperated Y-values of the points (realworld coordinate)
- * @return array Array looking like 0 => array(
- * 'real_x' => 1234567,
- * 'real_y' => 7654321,
- * 'pdf_x' => 451.12,
- * 'pdf_y' => 254.7
- * @see transformForPDF
- * @author M. Jansen <jansen at terrestris.de>, 2006-05-26
-function makeCoordPairs($x_values, $y_values) {
- $arr_x = explode(",", $x_values);
- $arr_y = explode(",", $y_values);
- $x_elems = count($arr_x);
- $y_elems = count($arr_y);
- $the_return_arr = array();
- if ($x_elems == $y_elems) {
- for ($i = 0; $i < $x_elems; $i ++) {
- $the_return_arr[$i] = array(
- "real_x" => $arr_x[$i],
- "real_y" => $arr_y[$i],
- "pdf_x" => transformForPDF($arr_x[$i], "x"),
- "pdf_y" => transformForPDF($arr_y[$i], "y")
- return $the_return_arr;
-} // end of function makeCoordPairs
- * Transforms given realworld-coordinate according to its type (X or Y)
- * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
- * $map_height, $map_width, $coord to be defined in a global scope.
- * @param float the realworld coordinate
- * @param string type of coordinate either 'X' or 'Y'
- * @see makeCoordPairs [needs this function]
- * @return float the pdf-coordinate
-function transformForPDF ($theRealCoord, $theType) {
- global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
- global $yAxisOrientation;
- $thePDFvalue = "";
- switch (mb_strtolower($theType)) {
- case 'x':
- // calculate pdf x-pos:
- $real_shown_width = $coord[2] - $coord[0];
- $ratio_to_display = $map_width / $real_shown_width;
- $target_width = $theRealCoord - $coord[0];
- $thePDFvalue = $mapOffset_left + ($target_width * $ratio_to_display);
- break;
- case 'y':
- // calculate pdf y-pos:
- $real_shown_height = $coord[3] - $coord[1];
- $ratio_to_display = $map_height / $real_shown_height;
- $target_height = $theRealCoord - $coord[1];
- if (isset($yAxisOrientation) && $yAxisOrientation==1)
- $thePDFvalue = $map_height + $mapOffset_bottom - ($target_height * $ratio_to_display);
- else
- $thePDFvalue = $mapOffset_bottom + ($target_height * $ratio_to_display);
- break;
- default:
- // a non valid parameter was given
- $thePDFvalue = $theRealCoord;
- break;
- return $thePDFvalue;
-} // end of function transformForPDF
- * extracts PDF-relevant information from a full coordinates array
- * and returns a transformed array
- * @param array the Array containing all infos about single coordinates
- * created via makeCoordPairs()
- * @return array the array containing PDF-Values for a polygon
-function makePolyFromCoord($theFullCoordinatesArray) {
- $theRetArr = array();
- foreach($theFullCoordinatesArray as $singlePoint) {
- $theRetArr[] = $singlePoint['pdf_x'];
- $theRetArr[] = $singlePoint['pdf_y'];
- return $theRetArr;
-} // end of function makePolyFromCoord
- * converts an array of coordinates (created e.g. by makeCoordPairs()) into
- * an array thats needed to draw lines via line(x0, y0, x1, y1)
- * @return array the array containing PDF-Values for single lines
-function makeStrokePointPairs($thePointArray) {
- $cnt = count($thePointArray);
- $theRetArray = array();
- for($i = 0; $i < $cnt; $i++) {
- if($i != $cnt - 1) {
- $theRetArray[] = array(
- $thePointArray[$i]['pdf_x'],
- $thePointArray[$i]['pdf_y'],
- $thePointArray[$i+1]['pdf_x'],
- $thePointArray[$i+1]['pdf_y'],
- } else {
- $thePointArray[0]['pdf_x'],
- $thePointArray[0]['pdf_y'],
- return $theRetArray;
-} // end of function makeStrokePointPairs
- * test whether the coordinates in an array form a closed polygon
- * meaning that first an last point of polygon are equal
- * @return bool is it closed (TRUE || FALSE)
-function isClosedPolygon($coord_arr) {
- $nr_of = count($coord_arr);
- if ($coord_arr[0]['pdf_x'] == $coord_arr[$nr_of-1]['pdf_x']
- && $coord_arr[0]['pdf_y'] == $coord_arr[$nr_of-1]['pdf_y']
- && $nr_of != 1) {
- return TRUE;
- } else {
- return FALSE;
-} // end of function isClosedPolygon
- * Adds the measured item to the PDF output.
- * @param object reference (!) to the current ezPDF-Object
- * @param string commaseperated X-Values of polygon / line
- * @param string commaseperated Y-Values of polygon / line
- * @param array configuration settings.
- * @return void nothing
- * @see isClosedPolygon
- * @see makeStrokePointPairs
- * @see makePolyFromCoord
-function addMeasuredItem($thePDF, $x_value_str, $y_value_str, $theConfArray = array()) {
- // get global variable:
- global $legendFilenameUserPolygon;
- // create legend image:
- $legend_width = 17;
- $leg_img = imagecreate($legend_width, $legend_width);
- // save previous state:
- $thePDF->saveState();
- // save colors for legend:
- if(!defined("MAP_HAS_USER_POLYGON")) {
- define("MAP_HAS_USER_POLYGON", "test");
- // get the arrays
- $theFullArr = makeCoordPairs($x_value_str, $y_value_str);
- $thePolyArr = makePolyFromCoord($theFullArr);
- if (isClosedPolygon($theFullArr)) {
- $isClosed = TRUE;
- else {
- $isClosed = FALSE;
- $nr_of_points = count($theFullArr);
- // is fill option set?
- // wenn der erste und letzte punkt nicht �bereinstimmen,
- // so muss in jedem Falle dofill auf 0 gesetzt werden
- if($theConfArray['do_fill'] != '' && $isClosed) {
- $doFill = 1;
- // which color to use for filling?
- if (is_array($theConfArray['fill_color'])
- && $theConfArray['fill_color']['r'] != ''
- && $theConfArray['fill_color']['g'] != ''
- && $theConfArray['fill_color']['b'] != '') {
- $thePDF->setColor($theConfArray['fill_color']['r'], $theConfArray['fill_color']['g'], $theConfArray['fill_color']['b']);
- $legend_image_fill = $theConfArray['fill_color']['r'] . "," . $theConfArray['fill_color']['g'] . "," . $theConfArray['fill_color']['b'];
- // color to legend file
- $bg_color = imagecolorallocate($leg_img, round($theConfArray['fill_color']['r'] * 255), round($theConfArray['fill_color']['g'] * 255), round($theConfArray['fill_color']['b'] * 255));
- } else {
- $thePDF->setColor(0, 0, 0);
- $bg_color = imagecolorallocate($leg_img, 0, 0, 0);
- } else {
- $doFill = 0;
- $bg_color = imagecolorallocate($leg_img, -1, -1, -1);
- // Do we need to stroke (outline)?
- if($theConfArray['do_stroke'] != '') {
- if (is_array($theConfArray['stroke_color'])
- && $theConfArray['stroke_color']['r'] != ''
- && $theConfArray['stroke_color']['g'] != ''
- && $theConfArray['stroke_color']['b'] != '') {
- $thePDF->setStrokeColor($theConfArray['stroke_color']['r'], $theConfArray['stroke_color']['g'], $theConfArray['stroke_color']['b']);
- $thePDF->setLineStyle($theConfArray['line_style']['width'], $theConfArray['line_style']['cap'], $theConfArray['line_style']['join'], $theConfArray['line_style']['dash']);
- $theStrokePointPairs = makeStrokePointPairs($theFullArr);
- for($i = 0; $i < count($theStrokePointPairs); $i++) {
- $line = $theStrokePointPairs[$i];
- if ($i != count($theStrokePointPairs) - 1
- || $isClosed) {
- $thePDF->line($line[0], $line[1], $line[2], $line[3]);
- $stroke_color_legend_image = imagecolorallocate($leg_img, round($theConfArray['stroke_color']['r'] * 255), round($theConfArray['stroke_color']['g'] * 255), round($theConfArray['stroke_color']['b'] * 255));
- if (is_array($theConfArray['line_style']['dash'])
- && $theConfArray['line_style']['dash'][1] != ""
- && $theConfArray['line_style']['dash'][1] != 0) {
- imagedashedline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
- imagedashedline($leg_img, $legend_width-1, 1, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
- imagedashedline($leg_img, 0, 0, 0, $legend_width-1, $stroke_color_legend_image);
- imagedashedline($leg_img, 0, $legend_width-1, $legend_width-1,$legend_width-1, $stroke_color_legend_image);
- } else {
- imageline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
- imageline($leg_img, $legend_width-1, 0, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
- imageline($leg_img, $legend_width-1, $legend_width-1, 0, $legend_width-1, $stroke_color_legend_image);
- imageline($leg_img, 0, $legend_width-1, 0, 0, $stroke_color_legend_image);
- $thePDF->polygon($thePolyArr, $nr_of_points, $doFill);
- // eventually create the file:
- imagepng($leg_img, $legendFilenameUserPolygon);
- $thePDF->restoreState();
-} // end of function addMeasuredItem
- * Konvertiert einen Text in ein array aus einzelnen Zeilen. Parameter wie Zeichen pro
- * zeile etc. k�nnen in der Funktion ge�ndert werden.
-function convert2lines($the_text) {
- $words = explode(' ', $the_text);
- $maxlines = 6;
- $available_chars_per_line = 35;
- $total_number_of_lines = 0;
- $chars_current_line = 0;
- $the_return_array = array();
- foreach($words as $word) {
- // trimme wort auf maximal erlaubte zeichenzahl
- $word_fit = mb_substr($word, 0, $available_chars_per_line);
- $chars = preg_split('//', $word_fit, -1, PREG_SPLIT_NO_EMPTY);
- if(count($chars) + $chars_current_line + 1 < $available_chars_per_line && $total_number_of_lines < $maxlines) {
- $chars_current_line += count($chars) + 1;
- $the_return_array[$total_number_of_lines] .= " " . $word_fit;
- } elseif($total_number_of_lines < $maxlines) {
- $chars_current_line = count($chars) + 1;
- $the_return_array[$total_number_of_lines + 1] = " " . $word_fit;
- $total_number_of_lines++;
- return $the_return_array;
-} // end of function convert2lines
- * Adds two white polygons to hide any user elements outside the mapframe:
- * First all A-Areas are filled, then all B-Areas. This is a rather grumpy
- * way out of having user edited stuff flying outside the mapframe.
- * @example <pre>
- * BBBBBBBBBBBBBBBBBBBBBBBBBBBBAAA
- * BBB AAA
- * BBB AAA
- * BBB Mapframe AAA
- * BBB AAA
- * BBB AAA
- * BBB AAA
- * AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- * </pre>
- * @param reference (!, pass over with '&') to the pdf-file
-function hideElementsOutsideMapframe($pdf) {
- // get globals
- global $mapOffset_left, $map_width, $mapOffset_bottom, $map_height;
- $pdf->saveState();
- $pdf->setColor(1, 1, 1);
- // The AAA-Part
- $allOutside = array(
- 0 , 0, // 1st coord-pair
- $pdf->ez['pageWidth'] , 0, // 2nd coord-pair
- $pdf->ez['pageWidth'] , $pdf->ez['pageHeight'], // ...
- $mapOffset_left + $map_width , $pdf->ez['pageHeight'],
- $mapOffset_left + $map_width , $mapOffset_bottom,
- 0 , $mapOffset_bottom,
- 0 , 0
- // draw polygon
- $pdf->polygon($allOutside, 7, 1);
- // The BBB-part
- 0 , $mapOffset_bottom, // 1st coord-pair
- $mapOffset_left , $mapOffset_bottom, // 2nd coord-pair
- $mapOffset_left , $mapOffset_bottom + $map_height, // ...
- $mapOffset_left + $map_width , $mapOffset_bottom + $map_height,
- 0 , $pdf->ez['pageHeight'],
- // draw polygon
- $pdf->restoreState();
+<?php
+ * $Id$
+ * converts the coordinates created via the JavaScript
+ * functions in 'mod_measure.php' into an array which
+ * then holds both X- ans Y-values for each point in
+ * the formats 'realworld coordinate' and 'pdf_coordinate'
+ * @param string commaseperated X-values of the points (realworld coordinate)
+ * @param string commaseperated Y-values of the points (realworld coordinate)
+ * @return array Array looking like 0 => array(
+ * 'real_x' => 1234567,
+ * 'real_y' => 7654321,
+ * 'pdf_x' => 451.12,
+ * 'pdf_y' => 254.7
+ * @see transformForPDF
+ * @author M. Jansen <jansen at terrestris.de>, 2006-05-26
+function makeCoordPairs($x_values, $y_values) {
+ $arr_x = explode(",", $x_values);
+ $arr_y = explode(",", $y_values);
+ $x_elems = count($arr_x);
+ $y_elems = count($arr_y);
+ $the_return_arr = array();
+ if ($x_elems == $y_elems) {
+ for ($i = 0; $i < $x_elems; $i ++) {
+ $the_return_arr[$i] = array(
+ "real_x" => $arr_x[$i],
+ "real_y" => $arr_y[$i],
+ "pdf_x" => transformForPDF($arr_x[$i], "x"),
+ "pdf_y" => transformForPDF($arr_y[$i], "y")
+ return $the_return_arr;
+} // end of function makeCoordPairs
+ * Transforms given realworld-coordinate according to its type (X or Y)
+ * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
+ * $map_height, $map_width, $coord to be defined in a global scope.
+ * @param float the realworld coordinate
+ * @param string type of coordinate either 'X' or 'Y'
+ * @see makeCoordPairs [needs this function]
+ * @return float the pdf-coordinate
+function transformForPDF ($theRealCoord, $theType) {
+ global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
+ $thePDFvalue = "";
+ switch (mb_strtolower($theType)) {
+ case 'x':
+ // calculate pdf x-pos:
+ $real_shown_width = $coord[2] - $coord[0];
+ $ratio_to_display = $map_width / $real_shown_width;
+ $target_width = $theRealCoord - $coord[0];
+ $thePDFvalue = $mapOffset_left + ($target_width * $ratio_to_display);
+ break;
+ case 'y':
+ // calculate pdf y-pos:
+ $real_shown_height = $coord[3] - $coord[1];
+ $ratio_to_display = $map_height / $real_shown_height;
+ $target_height = $theRealCoord - $coord[1];
+ $thePDFvalue = $mapOffset_bottom + ($target_height * $ratio_to_display);
+ break;
+ default:
+ // a non valid parameter was given
+ $thePDFvalue = $theRealCoord;
+ break;
+ return $thePDFvalue;
+} // end of function transformForPDF
+ * extracts PDF-relevant information from a full coordinates array
+ * and returns a transformed array
+ * @param array the Array containing all infos about single coordinates
+ * created via makeCoordPairs()
+ * @return array the array containing PDF-Values for a polygon
+function makePolyFromCoord($theFullCoordinatesArray) {
+ $theRetArr = array();
+ foreach($theFullCoordinatesArray as $singlePoint) {
+ $theRetArr[] = $singlePoint['pdf_x'];
+ $theRetArr[] = $singlePoint['pdf_y'];
+ return $theRetArr;
+} // end of function makePolyFromCoord
+ * converts an array of coordinates (created e.g. by makeCoordPairs()) into
+ * an array thats needed to draw lines via line(x0, y0, x1, y1)
+ * @return array the array containing PDF-Values for single lines
+function makeStrokePointPairs($thePointArray) {
+ $cnt = count($thePointArray);
+ $theRetArray = array();
+ for($i = 0; $i < $cnt; $i++) {
+ if($i != $cnt - 1) {
+ $theRetArray[] = array(
+ $thePointArray[$i]['pdf_x'],
+ $thePointArray[$i]['pdf_y'],
+ $thePointArray[$i+1]['pdf_x'],
+ $thePointArray[$i+1]['pdf_y'],
+ } else {
+ $thePointArray[0]['pdf_x'],
+ $thePointArray[0]['pdf_y'],
+ return $theRetArray;
+} // end of function makeStrokePointPairs
+ * test whether the coordinates in an array form a closed polygon
+ * meaning that first an last point of polygon are equal
+ * @return bool is it closed (TRUE || FALSE)
+function isClosedPolygon($coord_arr) {
+ $nr_of = count($coord_arr);
+ if ($coord_arr[0]['pdf_x'] == $coord_arr[$nr_of-1]['pdf_x']
+ && $coord_arr[0]['pdf_y'] == $coord_arr[$nr_of-1]['pdf_y']
+ && $nr_of != 1) {
+ return TRUE;
+ } else {
+ return FALSE;
+} // end of function isClosedPolygon
+ * Adds the measured item to the PDF output.
+ * @param object reference (!) to the current ezPDF-Object
+ * @param string commaseperated X-Values of polygon / line
+ * @param string commaseperated Y-Values of polygon / line
+ * @param array configuration settings.
+ * @return void nothing
+ * @see isClosedPolygon
+ * @see makeStrokePointPairs
+ * @see makePolyFromCoord
+function addMeasuredItem($thePDF, $x_value_str, $y_value_str, $theConfArray = array()) {
+ // get global variable:
+ global $legendFilenameUserPolygon;
+ // create legend image:
+ $legend_width = 17;
+ $leg_img = imagecreate($legend_width, $legend_width);
+ // save previous state:
+ $thePDF->saveState();
+ // save colors for legend:
+ if(!defined("MAP_HAS_USER_POLYGON")) {
+ define("MAP_HAS_USER_POLYGON", "test");
+ // get the arrays
+ $theFullArr = makeCoordPairs($x_value_str, $y_value_str);
+ $thePolyArr = makePolyFromCoord($theFullArr);
+ if (isClosedPolygon($theFullArr)) {
+ $isClosed = TRUE;
+ else {
+ $isClosed = FALSE;
+ $nr_of_points = count($theFullArr);
+ // is fill option set?
+ // wenn der erste und letzte punkt nicht �bereinstimmen,
+ // so muss in jedem Falle dofill auf 0 gesetzt werden
+ if($theConfArray['do_fill'] != '' && $isClosed) {
+ $doFill = 1;
+ // which color to use for filling?
+ if (is_array($theConfArray['fill_color'])
+ && $theConfArray['fill_color']['r'] != ''
+ && $theConfArray['fill_color']['g'] != ''
+ && $theConfArray['fill_color']['b'] != '') {
+ $thePDF->setColor($theConfArray['fill_color']['r'], $theConfArray['fill_color']['g'], $theConfArray['fill_color']['b']);
+ $legend_image_fill = $theConfArray['fill_color']['r'] . "," . $theConfArray['fill_color']['g'] . "," . $theConfArray['fill_color']['b'];
+ // color to legend file
+ $bg_color = imagecolorallocate($leg_img, round($theConfArray['fill_color']['r'] * 255), round($theConfArray['fill_color']['g'] * 255), round($theConfArray['fill_color']['b'] * 255));
+ } else {
+ $thePDF->setColor(0, 0, 0);
+ $bg_color = imagecolorallocate($leg_img, 0, 0, 0);
+ } else {
+ $doFill = 0;
+ $bg_color = imagecolorallocate($leg_img, -1, -1, -1);
+ // Do we need to stroke (outline)?
+ if($theConfArray['do_stroke'] != '') {
+ if (is_array($theConfArray['stroke_color'])
+ && $theConfArray['stroke_color']['r'] != ''
+ && $theConfArray['stroke_color']['g'] != ''
+ && $theConfArray['stroke_color']['b'] != '') {
+ $thePDF->setStrokeColor($theConfArray['stroke_color']['r'], $theConfArray['stroke_color']['g'], $theConfArray['stroke_color']['b']);
+ $thePDF->setLineStyle($theConfArray['line_style']['width'], $theConfArray['line_style']['cap'], $theConfArray['line_style']['join'], $theConfArray['line_style']['dash']);
+ $theStrokePointPairs = makeStrokePointPairs($theFullArr);
+ for($i = 0; $i < count($theStrokePointPairs); $i++) {
+ $line = $theStrokePointPairs[$i];
+ if ($i != count($theStrokePointPairs) - 1
+ || $isClosed) {
+ $thePDF->line($line[0], $line[1], $line[2], $line[3]);
+ $stroke_color_legend_image = imagecolorallocate($leg_img, round($theConfArray['stroke_color']['r'] * 255), round($theConfArray['stroke_color']['g'] * 255), round($theConfArray['stroke_color']['b'] * 255));
+ if (is_array($theConfArray['line_style']['dash'])
+ && $theConfArray['line_style']['dash'][1] != ""
+ && $theConfArray['line_style']['dash'][1] != 0) {
+ imagedashedline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
+ imagedashedline($leg_img, $legend_width-1, 1, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
+ imagedashedline($leg_img, 0, 0, 0, $legend_width-1, $stroke_color_legend_image);
+ imagedashedline($leg_img, 0, $legend_width-1, $legend_width-1,$legend_width-1, $stroke_color_legend_image);
+ } else {
+ imageline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
+ imageline($leg_img, $legend_width-1, 0, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
+ imageline($leg_img, $legend_width-1, $legend_width-1, 0, $legend_width-1, $stroke_color_legend_image);
+ imageline($leg_img, 0, $legend_width-1, 0, 0, $stroke_color_legend_image);
+ $thePDF->polygon($thePolyArr, $nr_of_points, $doFill);
+ // eventually create the file:
+ imagepng($leg_img, $legendFilenameUserPolygon);
+ $thePDF->restoreState();
+} // end of function addMeasuredItem
+ * Konvertiert einen Text in ein array aus einzelnen Zeilen. Parameter wie Zeichen pro
+ * zeile etc. k�nnen in der Funktion ge�ndert werden.
+function convert2lines($the_text) {
+ $words = explode(' ', $the_text);
+ $maxlines = 6;
+ $available_chars_per_line = 35;
+ $total_number_of_lines = 0;
+ $chars_current_line = 0;
+ $the_return_array = array();
+ foreach($words as $word) {
+ // trimme wort auf maximal erlaubte zeichenzahl
+ $word_fit = mb_substr($word, 0, $available_chars_per_line);
+ $chars = preg_split('//', $word_fit, -1, PREG_SPLIT_NO_EMPTY);
+ if(count($chars) + $chars_current_line + 1 < $available_chars_per_line && $total_number_of_lines < $maxlines) {
+ $chars_current_line += count($chars) + 1;
+ $the_return_array[$total_number_of_lines] .= " " . $word_fit;
+ } elseif($total_number_of_lines < $maxlines) {
+ $chars_current_line = count($chars) + 1;
+ $the_return_array[$total_number_of_lines + 1] = " " . $word_fit;
+ $total_number_of_lines++;
+ return $the_return_array;
+} // end of function convert2lines
+ * Adds two white polygons to hide any user elements outside the mapframe:
+ * First all A-Areas are filled, then all B-Areas. This is a rather grumpy
+ * way out of having user edited stuff flying outside the mapframe.
+ * @example <pre>
+ * BBBBBBBBBBBBBBBBBBBBBBBBBBBBAAA
+ * BBB AAA
+ * BBB AAA
+ * BBB Mapframe AAA
+ * BBB AAA
+ * BBB AAA
+ * BBB AAA
+ * AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ * </pre>
+ * @param reference (!, pass over with '&') to the pdf-file
+function hideElementsOutsideMapframe($pdf) {
+ // get globals
+ global $mapOffset_left, $map_width, $mapOffset_bottom, $map_height;
+ $pdf->saveState();
+ $pdf->setColor(1, 1, 1);
+ // The AAA-Part
+ $allOutside = array(
+ 0 , 0, // 1st coord-pair
+ $pdf->ez['pageWidth'] , 0, // 2nd coord-pair
+ $pdf->ez['pageWidth'] , $pdf->ez['pageHeight'], // ...
+ $mapOffset_left + $map_width , $pdf->ez['pageHeight'],
+ $mapOffset_left + $map_width , $mapOffset_bottom,
+ 0 , $mapOffset_bottom,
+ 0 , 0
+ // draw polygon
+ $pdf->polygon($allOutside, 7, 1);
+ // The BBB-part
+ 0 , $mapOffset_bottom, // 1st coord-pair
+ $mapOffset_left , $mapOffset_bottom, // 2nd coord-pair
+ $mapOffset_left , $mapOffset_bottom + $map_height, // ...
+ $mapOffset_left + $map_width , $mapOffset_bottom + $map_height,
+ 0 , $pdf->ez['pageHeight'],
+ // draw polygon
+ $pdf->restoreState();
Added: branches/print_dev/http/print/printbox.js
--- branches/print_dev/http/print/printbox.js (rev 0)
+++ branches/print_dev/http/print/printbox.js 2009-08-04 11:51:01 UTC (rev 4471)
@@ -0,0 +1,707 @@
+function createBox (options) {
+ myPrintBox = new PrintBox(options);
+ myPrintBox.paintPoints();
+ myPrintBox.paintBox();
+ return myPrintBox;
+function PrintBox (options) {
+ if (!options) {
+ options = {};
+ var target = options.target || "mapframe1";
+ //var mapObj = getMapObjByName(target);
+ var map = Mapbender.modules[target];
+ // Default is portrait, A4, unit seems to be cm
+ var printWidth = options.printWidth || 21;
+ var printHeight = options.printHeight || 29.7;
+ // initialised in setScale()
+ var boxWidth, boxHeight;
+ var scale = options.scale || 100000;
+ // behaviour
+ var afterChangeAngle = options.afterChangeAngle || function (obj) {};
+ var afterChangeSize = options.afterChangeSize || function (obj) {};
+ // styles
+ var opacity = options.boxOpacity || 0.6;
+ var boxColour = options.boxColour || "#9999FF";
+ var frameColour = options.frameColour || "#000000";
+ var pointColour = options.pointColour || "#DD0000";
+ var circleColour = options.circleColour || "#DD0000";
+ var circleWidth = options.circleWidth || 4;
+ // attributes
+ this.id = "printbox";
+ var angle = 0;
+ var totalAngle = 0;
+ // the four points of the box as pixel coordinates (incl rotation),
+ // with (0,0) as center. This is important for angle calculations.
+ var pointArray = [];
+ // The pointArray is moved by the center vector.
+ // default: place box in the center of the map
+ var center = options.center || new Point(map.width/2,map.height/2);
+ // the center in real world coordinates
+ var centerMap = null;
+ // the four points of the box as pixel coordinates (NO ROTATION)
+ var startPointPixArray = [];
+ // the four points of the box as real world coordinates (NO ROTATION)
+ var startPointMapArray = [];
+ var that = this;
+ // if the box is smaller than this, the circle will not be drawn
+ var MIN_BOX_WIDTH_OR_HEIGHT = 10;
+ // if the box is larger than this, the box will not be filled
+ var MAX_BOX_WIDTH_OR_HEIGHT = 800;
+ this.toString = function () {
+ var str = "";
+ str += "Center: " + getCenter() + "\n";
+ str += "Radius: " + radius + "\n";
+ str += "StartRadius: " + startRadius + "\n";
+ str += "Pixelpos: " + String(pointArray) + "\n";
+ str += "StartPixelpos: " + String(startPointPixArray) + "\n";
+ str += "Mappos: " + String(startPointMapArray) + "\n";
+ return str;
+ var initBehaviour = function () {
+ initMoveBehaviour();
+ initResizeBehaviour();
+ initRotateBehaviour();
+ var initRotateBehaviour = function () {
+ $circleCanvas.css("z-index", "110").mousedown(function (e) {
+ circleCanvas.clear();
+ var newCenter = getCenter();
+ var mouseMoveStart = map.getMousePos(e);
+ var vectorA = pointArray[0].minus(newCenter);
+ var currentPos = map.getMousePos(e);
+ var vectorCurrent = currentPos.minus(newCenter);
+ angle = Math.ceil(getAngle(vectorA, vectorCurrent));
+ $(document).mousemove(function (e) {
+ var currentAngle = Math.ceil(getAngle(vectorA, vectorCurrent));
+ var diffAngle = currentAngle - angle;
+ if (Math.abs(diffAngle) >= 1) {
+ angle = currentAngle;
+ totalAngle = ((totalAngle + diffAngle) +360 )% 360;
+ that.rotate(totalAngle);
+ return false;
+ }).mouseup(function (e) {
+ angle = 0;
+ $(document).unbind("mousemove");
+ $(document).unbind("mouseup");
+ afterChangeAngle({
+ angle: totalAngle,
+ coordinates: that.getStartCoordinates()
+ that.paintBox();
+ return false;
+ return false;
+ }).css("cursor", "move");
+ var initMoveBehaviour = function () {
+ $boxCanvas.mousedown(function (e) {
+ var containerStart = new Point(
+ parseInt($container.css("left"), 10),
+ parseInt($container.css("top"), 10)
+ var diff;
+ diff = (map.getMousePos(e)).minus(mouseMoveStart);
+ $container.css({
+ "top": (containerStart.y + diff.y) + "px",
+ "left": (containerStart.x + diff.x) + "px"
+ return false;
+ recalculateMapPositions();
+ that.paintBox();
+ return false;
+ return false;
+ var initResizeBehaviour = function () {
+ $pointCanvas.css("z-index", "120").mousedown(function (e) {
+ var vectorA = getCenter();
+ resizeRatio = 1;
+ mouseMoveStart = map.getMousePos(e);
+ var newRadius = vectorA.dist(map.getMousePos(e));
+ var resizeRatio = newRadius / radius;
+ if (resizeRatio < 0.98 || resizeRatio > 1.02) {
+ for (var i = 0; i < pointArray.length; i++) {
+ pointArray[i].x *= resizeRatio;
+ pointArray[i].y *= resizeRatio;
+ startPointPixArray[i].x *= resizeRatio;
+ startPointPixArray[i].y *= resizeRatio;
+ radius *= resizeRatio;
+ that.paintPoints();
+ return false;
+ $(document).mouseup(function (e) {
+ recalculatePixPositions();
+ afterChangeSize({
+ scale: that.getScale(),
+ that.paintBox();
+ return false;
+ return false;
+ var setCenter = function (inputCenter) {
+ center = inputCenter.minus(
+ new Point(
+ var getCenter = function () {
+ var c = center.plus(
+ new Point(
+ return c;
+ * Calculates the angle (-180 < angle <= 180) between two vectors.
+ * @param {Point} a
+ * @param {Point} b
+ var getAngle = function (a, b) {
+ var undirectedAngle = 180 * Math.acos(
+ (a.x * b.x + a.y * b.y)
+ Math.sqrt(
+ a.x * a.x
+ a.y * a.y
+ Math.sqrt(
+ b.x * b.x
+ b.y * b.y
+ ) / Math.PI;
+ if ((a.x*b.y - a.y*b.x) > 0) {
+ return -1 * undirectedAngle;
+ return undirectedAngle;
+ * To be replaced by the map objects native getMousePosition
+ * @param {Event} e
+ var getMousePos = function (e) {
+ if ($.msie) {
+ return new Point(event.clientX, event.clientY);
+ return new Point(e.pageX, e.pageY);
+ var recalculateMapPositions = function () {
+ startPointMapArray[i] = convertPixelToMap(startPointPixArray[i].plus(getCenter()));
+ centerMap = convertPixelToMap(getCenter());
+ var recalculatePixPositions = function () {
+ setCenter(convertMapToPixel(centerMap));
+ for (var i = 0; i < startPointMapArray.length; i++) {
+ pointArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
+ startPointPixArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
+ radius = pointArray[0].dist(new Point(0,0));
+ startRadius = radius;
+ boxWidth = pointArray[2].x - pointArray[0].x;
+ boxHeight = pointArray[0].y - pointArray[2].y;
+ var initPoints = function () {
+ var w = parseInt((boxWidth/2), 10);
+ var h = parseInt((boxHeight/2), 10);
+ pointArray[0] = new Point(-w, h);
+ pointArray[1] = new Point( w, h);
+ pointArray[2] = new Point( w, -h);
+ pointArray[3] = new Point(-w, -h);
+ startPointPixArray[0] = (new Point(-w, h));
+ startPointPixArray[1] = (new Point( w, h));
+ startPointPixArray[2] = (new Point( w, -h));
+ startPointPixArray[3] = (new Point(-w, -h));
+ scale = that.getScale();
+ var switchBoxDimensions = function () {
+ setBoxDimensions(boxHeight, boxWidth);
+ afterChangeSize({
+ this.setPortrait = function () {
+ this.setAngle(0);
+ if (boxWidth > boxHeight) {
+ switchBoxDimensions();
+ this.setLandscape = function () {
+ this.setAngle(0);
+ if (boxWidth < boxHeight) {
+ this.setPrintWidthAndHeight = function (width, height) {
+ var currentScale = this.getScale();
+ printWidth = width;
+ printHeight = height;
+ this.setScale(currentScale);
+ var convertMapToPixel = function (aPoint) {
+ var pArray = makeRealWorld2mapPos(map.elementName, aPoint.x, aPoint.y);
+ return new Point(pArray[0], pArray[1]);
+ var convertPixelToMap = function (aPoint) {
+ var pArray = makeClickPos2RealWorldPos(map.elementName, aPoint.x, aPoint.y);
+ * Sets the box width and box height (calculated in setScale)
+ * @param {Integer} inputWidth
+ * @param {Integer} inputHeight
+ var setBoxDimensions = function (inputWidth, inputHeight) {
+ boxWidth = inputWidth;
+ boxHeight = inputHeight;
+ initPoints();
+ afterChangeSize({
+ that.paintBox();
+ * Returns an array of two points, the lower left and upper right of the initial box
+ this.getStartCoordinates = function () {
+ var a = startPointMapArray[0];
+ var b = startPointMapArray[2];
+ if (!a || !b) {
+ return null;
+ var returnString = a.x + "," + a.y + "," + b.x + "," + b.y;
+ return returnString;
+ * Returns the current scale of the print box
+ this.getScale = function () {
+ var coords = this.getStartCoordinates();
+ var coordsArray = coords.split(",");
+ var ext = mapObj.getExtentInfos();
+ var extMinX = ext.minx;
+ var extMaxX = ext.maxx;
+ var x = (ext.minx + ext.maxx)/2;
+ var y = (ext.miny + ext.maxy)/2;
+ var scale1 = (x - coordsArray[0]) * (mb_resolution * 100 *2) / mapObj.width;
+ var scale2 = (coordsArray[2] - x) * (mb_resolution * 100 *2) / mapObj.width;
+ scale = Math.round(scale1/2 + scale2/2);
+ return scale;
+ xtentx = coordsArray[2] - coordsArray[0];
+ scale = parseInt(Math.ceil(xtentx / (printWidth / 100)), 10);
+ return scale;
+ * Repaints the Box with the current scale. Can be called from outside,
+ * for example after zoom in.
+ this.repaint = function () {
+ this.rotate(totalAngle);
+ this.paintBox();
+ * Sets the current scale, and repaints the box
+ * @param {Integer} inputScale
+ this.setScale = function (inputScale) {
+ if (typeof(inputScale) == "number") {
+ var arrayBBox = mapObj.extent.split(",");
+ x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+ y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+ var minx = parseFloat(x) - (mapObj.width / (mb_resolution * 100 *2) * inputScale);
+ var miny = parseFloat(y) - (mapObj.height / (mb_resolution * 100 *2) * inputScale);
+ var maxx = parseFloat(x) + (mapObj.width / (mb_resolution * 100 *2) * inputScale);
+ var maxy = parseFloat(y) + (mapObj.height / (mb_resolution * 100 *2) * inputScale);
+ var newMinPos = makeRealWorld2mapPos(mapObj.frameName, minx, miny);
+ var newMaxPos = makeRealWorld2mapPos(mapObj.frameName, maxx, maxy);
+ var newBoxWidth = newMaxPos[0] - newMinPos[0];
+ var newBoxHeight = newBoxWidth * (printHeight / printWidth);
+ var mapWidthInM = printWidth / 100;
+ var realWidthInM = inputScale * mapWidthInM;
+ var mapHeightInM = printHeight / 100;
+ var realHeightInM = inputScale * mapHeightInM;
+ if (coords !== null) {
+ var oldMin = new Point(parseFloat(coordsArray[0]), parseFloat(coordsArray[1]));
+ var oldMax = new Point(parseFloat(coordsArray[2]), parseFloat(coordsArray[3]));
+ centerMap = (oldMin.times(0.5)).plus(oldMax.times(0.5));
+ else {
+ var newMin = new Point(centerMap.x - 0.5 * realWidthInM, centerMap.y - 0.5 * realHeightInM);
+ var newMax = new Point(centerMap.x + 0.5 * realWidthInM, centerMap.y + 0.5 * realHeightInM);
+ startPointMapArray[0] = new Point(newMin.x, newMin.y);
+ startPointMapArray[1] = new Point(newMax.x, newMin.y);
+ startPointMapArray[2] = new Point(newMax.x, newMax.y);
+ startPointMapArray[3] = new Point(newMin.x, newMax.y);
+ this.getStartCoordinates();
+ var newMinPos = convertMapToPixel(newMin);
+ var newMaxPos = convertMapToPixel(newMax);
+ boxWidth = newMaxPos.x - newMinPos.x;
+ boxHeight = newMinPos.y - newMaxPos.y;
+ var w = parseInt(0.5 * boxWidth, 10);
+ var h = parseInt(0.5 * boxHeight, 10);
+ afterChangeSize({
+ that.paintBox();
+ return true;
+ return false;
+ * Sets the angle of the box to a specific angle.
+ * @param {Integer} angle
+ this.setAngle = function (angle) {
+ if (typeof(angle) == "number" && angle >= -360) {
+ totalAngle = (360 + angle) % 360;
+ this.paintBox();
+ return true;
+ return false;
+ // VIEW
+ * Rotates the box by a given degree (0 <= degree < 360),
+ * and paints the corner points.
+ * @param {Integer} degree
+ this.rotate = function (degree) {
+ var rotationAngle = (Math.PI * parseFloat(degree))/180;
+ var resizeRatio = radius / startRadius;
+ var p = (convertMapToPixel(startPointMapArray[i])).minus(getCenter());
+ var newx = p.x * Math.cos(rotationAngle) + p.y * Math.sin(rotationAngle);
+ var newy = p.x * -Math.sin(rotationAngle) + p.y * Math.cos(rotationAngle);
+ pointArray[i] = (new Point(newx, newy)).times(resizeRatio);
+ angle: degree,
+ coordinates: this.getStartCoordinates()
+ this.paintPoints();
+ * Paints the four corner points of the print box.
+ this.paintPoints = function () {
+ switchActiveCanvas();
+ var c = center;
+ activeCanvas.fillEllipse(
+ pointArray[i].x + c.x - 4,
+ pointArray[i].y + c.y - 4,
+ 8,
+ 8
+ activeCanvas.paint();
+ passiveCanvas.clear();
+ var boxTooBig = function () {
+ if (boxWidth > MAX_BOX_WIDTH_OR_HEIGHT || boxHeight > MAX_BOX_WIDTH_OR_HEIGHT) {
+ return true;
+ return false;
+ var boxTooSmall = function () {
+ if (boxWidth < MIN_BOX_WIDTH_OR_HEIGHT || boxHeight < MIN_BOX_WIDTH_OR_HEIGHT) {
+ return true;
+ return false;
+ * Paints the box itself. Plus the circle.
+ this.paintBox = function () {
+ var r = Math.round(0.75 * radius);
+ var c = center;
+ if (!boxTooSmall() && !boxTooBig()) {
+ circleCanvas.drawEllipse(c.x-r, c.y-r, 2*r, 2*r);
+ else {
+ new Mb_warning("The print box is too small or too big. The rotate circle is not shown.");
+ circleCanvas.paint();
+ boxCanvas.clear();
+ if (!boxTooBig()) {
+ boxCanvas.fillPolygon([
+ pointArray[0].x + c.x,
+ pointArray[1].x + c.x,
+ pointArray[2].x + c.x,
+ pointArray[3].x + c.x
+ pointArray[0].y + c.y,
+ pointArray[1].y + c.y,
+ pointArray[2].y + c.y,
+ pointArray[3].y + c.y
+ else {
+ new Mb_warning("The print box is too big. The box is not filled.");
+ // frame
+ boxCanvas.setColor(frameColour);
+ var indexA = i % 4;
+ var a = pointArray[indexA].plus(center);
+ var indexB = (i + 1) % 4;
+ var b = pointArray[indexB].plus(center);
+ boxCanvas.drawLine(a.x, a.y, b.x, b.y);
+ boxCanvas.setColor(boxColour);
+ boxCanvas.paint();
+ * Clears all canvases, to be performed onunload.
+ this.destroy = function () {
+ activeCanvas.clear();
+ var switchActiveCanvas = function () {
+ if (canvasNr == 1) {
+ canvasNr = 2;
+ activeCanvas = jg[2];
+ passiveCanvas = jg[1];
+ else {
+ canvasNr = 1;
+ activeCanvas = jg[1];
+ passiveCanvas = jg[2];
+ var $container = $("<div id='" + this.id + "' style='position:relative;top:0px;left:0px;" +
+ "'></div>");
+ var $superContainer = $("<div id='container_" + this.id + "' style='position:absolute;z-index:1000;'></div>");
+ $superContainer.append($container);
+ //$("#"+map.elementName).append($superContainer);
+ $(map_el).append($superContainer);
+ var canvasName = [
+ this.id + "_canvas_box",
+ this.id + "_canvas_points1",
+ this.id + "_canvas_points2",
+ this.id + "_canvas_circle"
+ var jg = [];
+ var canvasNr = 1;
+ for (var i = 0; i < canvasName.length; i++) {
+ $container.append(
+ $("<div id='" + canvasName[i] + "'></div>")
+ jg[i] = new jsGraphics(canvasName[i]);
+ $circleCanvas = $("#" + canvasName[3]);
+ $pointCanvas = $("#" + canvasName[1] + ", #" + canvasName[2]);
+ $boxCanvas = $("#" + canvasName[0]);
+ $boxCanvas.css({
+ "opacity" : opacity,
+ "filter" : "alpha(opacity=" + (opacity * 100) + ")"
+ var boxCanvas = jg[0];
+ var activeCanvas = jg[1];
+ activeCanvas.setColor(pointColour);
+ var passiveCanvas = jg[2];
+ passiveCanvas.setColor(pointColour);
+ var circleCanvas = jg[3];
+ circleCanvas.setColor(circleColour);
+ circleCanvas.setStroke(circleWidth);
+ var mouseMoveStart = [];
+ var radius = 0;
+ var startRadius = 0;
+ // "constructor" functions
+ initBehaviour();
+ this.setScale(scale);
+ mb_registerPanSubElement($superContainer.get(0).id);
\ No newline at end of file
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json 2009-08-04 11:47:46 UTC (rev 4470)
+++ branches/print_dev/http/print/testConfigTemplate.json 2009-08-04 11:51:01 UTC (rev 4471)
@@ -44,11 +44,19 @@
- "id" : "rotation",
+ "id" : "angle",
"type" : "hidden",
"pageElementsLink" : {
"nordpfeil" : "rotation"
+ "id" : "coordinates",
+ "type" : "hidden"
+ "id" : "scale",
+ "type" : "hidden"
"pages" : [
More information about the Mapbender_commits
