[Mapbender-commits] r4483 - branches/print_dev/http/print
svn_mapbender at osgeo.org
Wed Aug 5 04:57:58 EDT 2009
Author: mschulz
Date: 2009-08-05 04:57:58 -0400 (Wed, 05 Aug 2009)
New Revision: 4483
branches/print_dev/http/print/mod_printPDF_div.js
added NaturalDocs documentation
Modified: branches/print_dev/http/print/mod_printPDF_div.js
--- branches/print_dev/http/print/mod_printPDF_div.js 2009-08-05 08:48:21 UTC (rev 4482)
+++ branches/print_dev/http/print/mod_printPDF_div.js 2009-08-05 08:57:58 UTC (rev 4483)
@@ -75,266 +75,322 @@
/* ------------- printbox addition ------------- */
-var printBox;
var PrintPDF = function (options) {
-var that = this;
-var actualConfig;
+ var that = this;
+ * Property: actualConfig
+ * object, holds the actual configuration after loading the json file
+ var actualConfig;
-eventInit.register(function () {
- mod_printPDF_init();
-this.createPrintBox = function () {
- size = "A4";
- //document.form1.size.value = size;
- format = "portrait";
- var w, h;
- //validate();
- var map = Mapbender.modules[myTarget];
- var map_el = map.getDomElement();
- var jqForm = $("#"+myId+"_form");
- printBox = createBox({
- target : myTarget,
- printWidth : getPDFMapSize("width")/10,
- printHeight : getPDFMapSize("height")/10,
- scale : Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
- afterChangeAngle : function (obj) {
- if (typeof(obj) == "object") {
- if (typeof(obj.angle) == "number") {
- jqForm[0].angle.value = obj.angle;
+ * constructor
+ eventInit.register(function () {
+ mod_printPDF_init();
+ * Property: printBox
+ * the movable printframe
+ var printBox;
+ * Method: createPrintBox
+ * creates a printBox in the current view, calculates the scale
+ * (tbd. if not set from the config) so that the printbox fits in the mapframe.
+ * Width and height are taken from the configuration.
+ this.createPrintBox = function () {
+ size = "A4";
+ //document.form1.size.value = size;
+ format = "portrait";
+ var w, h;
+ //validate();
+ var map = Mapbender.modules[myTarget];
+ var map_el = map.getDomElement();
+ var jqForm = $("#"+myId+"_form");
+ printBox = createBox({
+ target : myTarget,
+ printWidth : getPDFMapSize("width")/10,
+ printHeight : getPDFMapSize("height")/10,
+ scale : Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
+ afterChangeAngle : function (obj) {
+ if (typeof(obj) == "object") {
+ if (typeof(obj.angle) == "number") {
+ jqForm[0].angle.value = obj.angle;
+ if (obj.coordinates) {
+ jqForm[0].coordinates.value = String(obj.coordinates);
- if (obj.coordinates) {
- jqForm[0].coordinates.value = String(obj.coordinates);
+ afterChangeSize : function (obj) {
+ if (obj.scale) {
+ jqForm[0].scale.value = obj.scale;
- afterChangeSize : function (obj) {
- if (obj.scale) {
- jqForm[0].scale.value = obj.scale;
+ eventAfterMapRequest.register(function () {
+ if (typeof(printBox) !== "undefined") {
+ printBox.repaint();
+ * Method: getPDFMapSize
+ * checks the actual config for the size w/h values.
+ * Parameters:
+ * key - string, the key which value to retrieve (currently width or height)
+ var getPDFMapSize = function (key) {
+ for (var page in actualConfig.pages) {
+ for (var pageElement in actualConfig.pages[page].elements) {
+ if (actualConfig.pages[page].elements[pageElement].type == "map") {
+ return actualConfig.pages[page].elements[pageElement][key];
+ break;
+ * Method: destroyPrintBox
+ * removes an existing printBox.
+ var destroyPrintBox = function () {
+ if (printBox) {
+ printBox.destroy();
- eventAfterMapRequest.register(function () {
- if (typeof(printBox) !== "undefined") {
- printBox.repaint();
+ * Method: mod_printPDF_init
+ * initializes the print modules, generates template chooser and loads first configuration.
+ var mod_printPDF_init = function () {
+ /* first we'd need to build the configuration selection */
+ buildConfigSelector();
+ /* second we'd need to read the json configuration */
+ that.loadConfig(mbPrintConfigFilenames[0]);
-var getPDFMapSize = function (key) {
- for (var page in actualConfig.pages) {
- for (var pageElement in actualConfig.pages[page].elements) {
- if (actualConfig.pages[page].elements[pageElement].type == "map") {
- return actualConfig.pages[page].elements[pageElement][key];
+ * Method: loadConfig
+ * GETs the config, build corresponding form, remove an existing printBox
+ this.loadConfig = function (configFilename) {
+ $.get(mbPrintConfigPath + configFilename, function(json, status){
+ actualConfig = eval('(' + json + ')');
+ buildForm();
+ hookForm();
+ destroyPrintBox();
+ * Method: hookForm
+ * utility method to connect the form plugin to the print form.
+ var hookForm = function () {
+ var options = {
+ url: '../print/printFactory.php',
+ type: 'post',
+ dataType: 'json',
+ beforeSubmit: validate,
+ success: showResult
+ $("#"+myId+"_form").ajaxForm(options);
+ * Change status of the working elements. These should begin with "$myId_working"
+ * @param {String} newStatus either "hide or "show"
+ var showHideWorking = function (newStatus) {
+ if (newStatus=="hide")
+ $("[id^='"+myId+"_working']").hide();
+ else
+ $("[id^='"+myId+"_working']").show();
+ * update form values helper function
+ var updateFormField = function (formData, key, value) {
+ for(var j=0; j < formData.length; j++){
+ if (formData[j].name == key) {
+ formData[j].value = value;
break;
+ * Validates and updates form data values.
+ * Adds the elements before the submit button.
+ * @see jquery.forms#beforeSubmitHandler
+ var validate = function (formData, jqForm, options) {
+ showHideWorking("show");
+ // map urls
+ var ind = getMapObjIndexByName(myTarget);
+ var f = jqForm[0];
+ f.map_url.value = '';
+ f.overview_url.value = '';
+ for(var i=0; i < mb_mapObj[ind].wms.length; i++){
+ if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if(mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
+ if(f.map_url.value != ""){
+ f.map_url.value += '___';
+ f.map_url.value += mb_mapObj[ind].wms[i].mapURL;
-var destroyPrintBox = function () {
- if (printBox) {
- printBox.destroy();
-/* ------------- printbox addition -------------*/
-var mod_printPDF_init = function () {
- /* first we'd need to build the configuration selection */
- buildConfigSelector();
- /* second we'd need to read the json configuration */
- that.loadConfig(mbPrintConfigFilenames[0]);
-this.loadConfig = function (configFilename) {
- $.get(mbPrintConfigPath + configFilename, function(json, status){
- actualConfig = eval('(' + json + ')');
- buildForm();
- hookForm();
- destroyPrintBox();
-var hookForm = function () {
- var options = {
- url: '../print/printFactory.php',
- type: 'post',
- dataType: 'json',
- beforeSubmit: validate,
- success: showResult
+ updateFormField(formData, "map_url", f.map_url.value);
+ //overview_url
+ var ind_overview = getMapObjIndexByName('overview');
+ if(mb_mapObj[ind_overview].mapURL != false ){
+ f.overview_url.value = mb_mapObj[ind_overview].mapURL;
+ updateFormField(formData, "overview_url", f.overview_url.value);
+ updateFormField(formData, "map_scale", mb_getScale(myTarget));
+ // write the measured coordinates
+ if (typeof(mod_measure_RX) !== "undefined") {
+ var tmp_x = '';
+ var tmp_y = '';
+ for(i = 0; i < mod_measure_RX.length; i++) {
+ if(tmp_x != '') {
+ tmp_x += ','
+ tmp_x += mod_measure_RX[i];
+ for(i = 0; i < mod_measure_RY.length; i++) {
+ if(tmp_y != '') {
+ tmp_y += ','
+ tmp_y += mod_measure_RY[i];
+ updateFormField(formData, "measured_x_values", tmp_x);
+ updateFormField(formData, "measured_y_values", tmp_y);
+ if (f.map_url.value!="") {
+ //return true;
+ } else {
+ showHideWorking("hide");
+ return false;
- $("#"+myId+"_form").ajaxForm(options);
- * Change status of the working elements. These should begin with "$myId_working"
- * @param {String} newStatus either "hide or "show"
-var showHideWorking = function (newStatus) {
- if (newStatus=="hide")
- $("[id^='"+myId+"_working']").hide();
- else
- $("[id^='"+myId+"_working']").show();
- * update form values helper function
-var updateFormField = function (formData, key, value) {
- for(var j=0; j < formData.length; j++){
- if (formData[j].name == key) {
- formData[j].value = value;
- break;
+ * Method: showResult
+ * load the generated PDF from the returned URL as an attachment,
+ * that triggers a download popup or is displayed in PDF plugin.
+ var showResult = function (res, text) {
+ if (text == 'success') {
+ window.location = stripslashes(res.outputFileName);
- * Validates and updates form data values.
- * Adds the elements before the submit button.
- * @see jquery.forms#beforeSubmitHandler
-var validate = function (formData, jqForm, options) {
- showHideWorking("show");
- var ind = getMapObjIndexByName(myTarget);
- var f = jqForm[0];
- f.map_url.value = '';
- f.overview_url.value = '';
- for(var i=0; i < mb_mapObj[ind].wms.length; i++){
- if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if(mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
- if(f.map_url.value != ""){
- f.map_url.value += '___';
- f.map_url.value += mb_mapObj[ind].wms[i].mapURL;
+ else {
+ /* something went wrong */
+ $("#"+myId+"_result").html(text);
- updateFormField(formData, "map_url", f.map_url.value);
- //overview_url
- var ind_overview = getMapObjIndexByName('overview');
- if(mb_mapObj[ind_overview].mapURL != false ){
- f.overview_url.value = mb_mapObj[ind_overview].mapURL;
- updateFormField(formData, "overview_url", f.overview_url.value);
- updateFormField(formData, "map_scale", mb_getScale(myTarget));
- // write the measured coordinates
- if (typeof(mod_measure_RX) !== "undefined") {
- var tmp_x = '';
- var tmp_y = '';
- for(i = 0; i < mod_measure_RX.length; i++) {
- if(tmp_x != '') {
- tmp_x += ','
+ * Generates form elements as specified in the config controls object.
+ * @param {Object} json the config object in json
+ var buildForm = function () {
+ $(".print_option_dyn").remove();
+ var str = "";
+ for (var item in actualConfig.controls) {
+ var element = actualConfig.controls[item];
+ var element_id = myId + "_" + element.id;
+ if (element.type != "hidden") {
+ str += '<div class="print_option_dyn">\n';
+ str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
+ } else {
+ str += '<div class="print_option_dyn" style="display:none;">\n';
- tmp_x += mod_measure_RX[i];
- for(i = 0; i < mod_measure_RY.length; i++) {
- if(tmp_y != '') {
- tmp_y += ','
+ switch (element.type) {
+ case "text":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
+ break;
+ case "hidden":
+ str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
+ break;
+ case "textarea":
+ str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
+ break;
+ case "select":
+ str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
+ for (var option_index in element.options) {
+ option = element.options[option_index];
+ str += '<option value="'+option.value+'">'+option.label+'</option>\n';
+ str += '</select><br>\n';
+ break;
- tmp_y += mod_measure_RY[i];
+ str += '</div>\n';
- updateFormField(formData, "measured_x_values", tmp_x);
- updateFormField(formData, "measured_y_values", tmp_y);
+ if (str) $("#"+myId+"_formsubmit").before(str);
+ * Generates the configuration select element from the gui element vars
+ * mbPrintConfigFilenames and mbPrintConfigTitles
+ var buildConfigSelector = function () {
+ var str = "";
+ str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
+ str += '<select id="printPDF_template" name="printPDF_template" size="1" onchange="Mapbender.modules[\''+myId+'\'].loadConfig(mbPrintConfigFilenames[this.selectedIndex]);">\n';
+ for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
+ str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
+ str += '</select><img src="../print/img/shape_handles.png" onclick="Mapbender.modules[\''+myId+'\'].createPrintBox();" title="Use printbox">\n';
+ if (str) $("#printPDF_selector").append(str);
- if (f.map_url.value!="") {
- //return true;
- } else {
- showHideWorking("hide");
- return false;
+ var stripslashes = function ( str ) {
+ return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
-var showResult = function (res, text) {
- if (text == 'success') {
- window.location = stripslashes(res.outputFileName);
- else {
- /* something went wrong */
- $("#"+myId+"_result").html(text);
- * Generates form elements as specified in the config controls object.
- * @param {Object} json the config object in json
-var buildForm = function () {
- $(".print_option_dyn").remove();
- var str = "";
- for (var item in actualConfig.controls) {
- var element = actualConfig.controls[item];
- var element_id = myId + "_" + element.id;
- if (element.type != "hidden") {
- str += '<div class="print_option_dyn">\n';
- str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
- } else {
- str += '<div class="print_option_dyn" style="display:none;">\n';
- switch (element.type) {
- case "text":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
- break;
- case "hidden":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
- break;
- case "textarea":
- str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
- break;
- case "select":
- str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
- for (var option_index in element.options) {
- option = element.options[option_index];
- str += '<option value="'+option.value+'">'+option.label+'</option>\n';
- str += '</select><br>\n';
- break;
- str += '</div>\n';
- if (str) $("#"+myId+"_formsubmit").before(str);
- * Generates the configuration select element from the gui element vars
- * mbPrintConfigFilenames and mbPrintConfigTitles
-var buildConfigSelector = function () {
- var str = "";
- str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
- str += '<select id="printPDF_template" name="printPDF_template" size="1" onchange="Mapbender.modules[\''+myId+'\'].loadConfig(mbPrintConfigFilenames[this.selectedIndex]);">\n';
- for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
- str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
- str += '</select><img src="../print/img/shape_handles.png" onclick="Mapbender.modules[\''+myId+'\'].createPrintBox();" title="Use printbox">\n';
- if (str) $("#printPDF_selector").append(str);
-var stripslashes = function ( str ) {
- return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
$.extend(Mapbender.modules[options.id], new PrintPDF(options));
\ No newline at end of file
More information about the Mapbender_commits
