[Mapbender-commits] r4489 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Aug 5 09:55:04 EDT 2009
Author: christoph
Date: 2009-08-05 09:55:03 -0400 (Wed, 05 Aug 2009)
New Revision: 4489
Added:
trunk/mapbender/http/php/mod_monitorCapabilities_read.php
trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php
trunk/mapbender/http/php/mod_monitorCapabilities_read_single_diff.php
Added: trunk/mapbender/http/php/mod_monitorCapabilities_read.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_read.php (rev 0)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_read.php 2009-08-05 13:55:03 UTC (rev 4489)
@@ -0,0 +1,308 @@
+<?php
+# $Id: mod_monitorCapabilities_read.php 1283 2007-10-25 15:20:25Z baudson $
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+</head>
+<body>
+<?php
+$admin = new administration();
+$user = new User();
+// update selected wms
+$checkboxes = intval($_POST['cbs']);
+for ($i=0; $i < $checkboxes; $i++) {
+ echo $i;
+ if (!isset($_POST['cb'.$i]) ||
+ !isset($_POST['upl_id'.$i])
+ continue;
+ $upd_wmsid = intval($_POST['cb'.$i]);
+ $upload_id = intval($_POST['upl_id'.$i]);
+ if ($upd_wmsid) {
+ // get upload URL
+ $sql = "SELECT wms_upload_url, wms_owner FROM wms WHERE wms_id = $1";
+ $v = array($upd_wmsid);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+ $row = db_fetch_array($res);
+ $uploadUrl = $row["wms_upload_url"];
+ $wmsOwner = $row["wms_owner"];
+ if ($wmsOwner !== $user->id) {
+ echo "<br>Skipped: " . $upd_wmsid . "<br>";
+ continue;
+ // update WMS from upload URL
+ $mywms = new wms();
+ $mywms->createObjFromXML($uploadUrl);
+ $mywms->optimizeWMS();
+ echo "<br />";
+ $mywms->updateObjInDB($upd_wmsid);
+ echo "<br>Updated: " . $upd_wmsid . "<br>";
+ // start new monitoring for this WMS
+ $now = time();
+ $sql = "UPDATE mb_monitor SET status = '-2', status_comment = 'Monitoring is still in progress...', " .
+ "timestamp_begin = $1, timestamp_end = $2 WHERE upload_id = $3 AND fkey_wms_id = $4";
+ $v = array($now, $now, $upload_id, $upd_wmsid);
+ $t = array('s', 's', 's', 'i');
+ $res = db_prep_query($sql,$v,$t);
+ $currentFilename = "wms_monitor_report_" . $upload_id . "_" .
+ $upd_wmsid . "_" . $wmsOwner . ".xml";
+ $exec = PHP_PATH . "php5 ../../tools/mod_monitorCapabilities_write.php " .
+ $currentFilename. " 0";
+ echo exec($exec);
+ echo "<br>Please note: The updated services need to be monitored again in order to update the database.<br><br>";
+$sql = "SELECT DISTINCT mb_monitor.fkey_wms_id FROM mb_monitor, wms " .
+ "WHERE mb_monitor.fkey_wms_id = wms.wms_id AND wms.wms_owner = $1";
+$res = db_prep_query($sql, array($_SESSION["mb_user_id"]), array("i"));
+$wms = array();
+while($row = db_fetch_array($res)){
+ $wms[] = $row["fkey_wms_id"];
+$wms_id = array();
+$status = array();
+$upload_id = array();
+$avg_response_time = array();
+$comment = array();
+$timestamp_begin = array();
+$timestamp_end = array();
+$upload_url = array();
+$updated = array();
+$mapurl = array();
+$image = array();
+for ($i = 0; $i < count($wms); $i++) {
+ $wms_id[$wms[$i]] = $wms[$i];
+ // get upload id
+ $sql = "SELECT MAX(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1";
+ $v = array($wms[$i]);
+ $t = array('i');
+ $upload_id[$wms[$i]] = db_result($res,0,0);
+ $sql = "SELECT AVG(timestamp_begin), AVG(timestamp_end) FROM mb_monitor " .
+ "WHERE fkey_wms_id = $1 AND NOT status = '-1' AND NOT status = '-2'";
+ $t = array('i');
+ if (db_result($res,0,1) == 0 && db_result($res,0,0) == 0) {
+ $avg_response_time[$wms[$i]] = NULL;
+ else {
+ $avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
+ $sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, " .
+ "upload_url, updated, image, map_url, caps_diff FROM mb_monitor, wms " .
+ "WHERE upload_id = $1 AND fkey_wms_id = $2 AND wms_owner = $3 ORDER BY status, " .
+ "status_comment, timestamp_end, fkey_wms_id";
+ $v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]], $user->id);
+ $t = array('s', 'i', 'i');
+ $status[$wms[$i]] = intval(db_result($res,0,"status"));
+ $comment[$wms[$i]] = db_result($res,0,"status_comment");
+ $timestamp_begin[$wms[$i]] = db_result($res,0,"timestamp_begin");
+ $timestamp_end[$wms[$i]] = db_result($res,0,"timestamp_end");
+ $upload_url[$wms[$i]] = db_result($res,0,"upload_url");
+ $updated[$wms[$i]] = db_result($res,0,"updated");
+ $mapurl[$wms[$i]] = db_result($res,0,"map_url");
+ $image[$wms[$i]] = db_result($res,0,"image");
+ $caps_diff[$wms[$i]] = db_result($res,0,"caps_diff");
+ if ($status[$wms[$i]] == -2 &&
+ intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT))
+ $comment[$wms[$i]] = "Monitoring process timed out.";
+ $new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+ $new_v = array((intval($upload_id[$wms[$i]])+intval(TIME_LIMIT)), $wms_id[$wms[$i]], $upload_id[$wms[$i]]);
+ $new_t = array('s', 'i', 's');
+ $new_res = db_prep_query($new_sql,$new_v,$new_t);
+ $sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-2'";
+ $t = array('i');
+ $total[$wms[$i]] = db_result($res, 0, 0);
+ $sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND status = '-1'";
+ $t = array('i');
+ $fail = db_result($res, 0, 0);
+ $percentage[$wms[$i]] = 100 - round(100*floatval($fail)/floatval($total[$wms[$i]]), 1);
+$newArray = $status;
+if ($_GET['sortby']) {
+ if ($_GET['sortby'] == "wms") {
+ $newArray = $wms_id;
+ asort($newArray);
+ elseif ($_GET['sortby'] == "status") {
+ $newArray = $status;
+ asort($newArray);
+ elseif ($_GET['sortby'] == "avgresp") {
+ $newArray = $avg_response_time;
+ asort($newArray);
+ elseif ($_GET['sortby'] == "avail") {
+ $newArray = $percentage;
+ arsort($newArray);
+ elseif ($_GET['sortby'] == "last") {
+ $newArray = $upload_id;
+ elseif ($_GET['image'] == "last") {
+ $newArray = $image;
+$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
+$str .= "<form name = 'form1' method='post' action='".$PHP_SELF."?sortby=".$_GET['sortby']."'>\n\t";
+$str .= "\n\t<input type=submit value='update selected WMS'>\n";
+$str .= "\n\t<input type=button onclick=\"self.location.href='".$PHP_SELF."?sortby=".$_GET['sortby']."'\" value='refresh'>\n<br/><br/>\n ";
+$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+$str .= "<tr bgcolor='#dddddd'><th></th><th align='left'><a href='".$PHP_SELF."?sortby=wms'>wms</a></th>";
+$str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=image'>image</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th><th>Diff</th></tr>";
+$cnt = 0;
+foreach ($newArray as $k => $value) {
+ $img = "stop.bmp";
+ if ($status[$k]==0) $img = "wait.bmp";
+ elseif ($status[$k]==1) $img = "go.bmp";
+ if ($updated[$k] == "0" && $status[$k] == 0) $fill = "checked"; else $fill = "disabled";
+ if (fmod($cnt, 2) == 1) {
+ $str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
+ else {
+ $str .= "\n\t\t<tr bgcolor='#f0f0f0'>";
+ $str .= "\n\t\t\t<td><input name='cb".$cnt."' value='" . $wms_id[$k] . "' type=checkbox ".$fill." /><input type=hidden name='upl_id".$cnt."' value='".$upload_id[$k]."'></td>";
+ $str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
+ $str .= "\n\t\t\t<td valign='top'><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+ $str .= "\n\t\t\t<td valign='top'>" . $comment[$k] . "<br><div style='font-size:12'>".date("F j, Y, G:i:s", $upload_id[$k])."</div></td>";
+ $str .= "\n\t\t\t<td valign='top'>";
+ $str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr><td height=20 width=20 align=center valign=middle bgcolor='";
+ if ($image[$k] == -1) {
+ $str .= "red";
+ elseif ($image[$k] == 0) {
+ $str .= "yellow";
+ elseif ($image[$k] == 1) {
+ $str .= "green";
+ if ($image[$k] != -1) {
+ $str .= "'><a href='".$mapurl[$k]."'>o</a></td></tr></table></td>";
+ else {
+ $str .= "'><a href='".$mapurl[$k]."'>x</a></td></tr></table></td>";
+ $str .= "\n\t\t\t<td valign='top' align = 'left'>";
+ if ($avg_response_time[$k] == NULL) {
+ $str .= "n/a";
+ else {
+ $str .= $avg_response_time[$k] . " s";
+ $str .= "</td>";
+ $str .= "\n\t\t\t<td valign='top'><b>" . $percentage[$k] . " %</b> <span style='font-size:12'>(" . $total[$k] . " cycles)</span><br>";
+ $str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr>";
+ $val = $percentage[$k];
+ for ($i=0; $i<10; $i++) {
+ if ($val>=10) {
+ $str .= "<td height=10 width='10' bgcolor='red'></td>";
+ $val-=10;
+ elseif($val>0){
+ $str .= "<td height=10 width='" . round($val) . "' bgcolor='red'></td>";
+ if (round($val) < 10) {
+ $str .= "<td height=10 width='" . (9-round($val)) . "' bgcolor='white'></td>";
+ $val=-1;
+ else {
+ $str .= "<td height=10 width='10' bgcolor='white'></td>";
+ $str .= "</tr></table></td>";
+# $str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
+ $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td>";
+ $str .= "\n\t\t\t<td>";
+ if ($caps_diff[$k] != "")
+ $str .= "<a href='mod_monitorCapabilities_read_single_diff.php?wmsid=".$wms_id[$k]."&upload_id=".$upload_id[$k]."' target=_blank>view</a>";
+ $str .= "</td></tr>";
+ $cnt++;
+$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
+echo $str;
+</body></html>
Added: trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php (rev 0)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php 2009-08-05 13:55:03 UTC (rev 4489)
@@ -0,0 +1,102 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single.php 76 2006-08-15 12:25:34Z heuser $
+#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+session_start();
+import_request_variables("PG");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+<html>
+<head>
+<?php
+</head>
+<body>
+<?php
+if ($_GET['wmsid']) {
+ $wms_id = intval($_GET['wmsid']);
+else {
+ echo "Invalid WMS ID.";
+ die;
+$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
+$v = array($wms_id);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while ($row = db_fetch_array($res)) {
+ $upload_id[$cnt] = db_result($res,$cnt,"upload_id");
+ $status[$cnt] = intval(db_result($res,$cnt,"status"));
+ $comment[$cnt] = db_result($res,$cnt,"status_comment");
+ $timestamp_begin = db_result($res,$cnt,"timestamp_begin");
+ $timestamp_end = db_result($res,$cnt,"timestamp_end");
+ $upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+ if ($status[$cnt] == '0' || $status[$cnt] == '1') {
+ $response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
+ else {
+ $response_time[$cnt] = "n/a";
+ $cnt++;
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
+for ($k=0; $k<count($upload_id); $k++) {
+ if (fmod($k, 2) == 1) {
+ else {
+ $str .= "\n\t\t\t<td>".date("F j, Y, G:i:s", $upload_id[$k])."</td>";
+ $str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+ $str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
+ $str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
+$str .= "\n\t</table>\n\t";
+echo $str;
+</body></html>
\ No newline at end of file
Added: trunk/mapbender/http/php/mod_monitorCapabilities_read_single_diff.php
--- trunk/mapbender/http/php/mod_monitorCapabilities_read_single_diff.php (rev 0)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_read_single_diff.php 2009-08-05 13:55:03 UTC (rev 4489)
@@ -0,0 +1,85 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single_diff.php 3342 2008-12-16 12:31:26Z mschulz $
+<html>
+<head>
+<title>Mapbender - monitor diff results</title>
+<?php
+<style type="text/css">
+* {font-family: Arial, "Courier New", monospace; font-size: small;}
+.diff-context {background: #eee;}
+.diff-deletedline {background: #eaa;}
+.diff-addedline {background: #aea;}
+.diff-blockheader {background: #ccc;}
+</style>
+</head>
+<body>
+<?php
+else {
+ die;
+if ($_GET['upload_id']) {
+ $upload_id = intval($_GET['upload_id']);
+else {
+ echo "Invalid upload ID.";
+ die;
+$sql = "SELECT caps_diff FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND upload_id = $2";
+$v = array($wms_id,$upload_id);
+$t = array('i','i');
+ $caps_diff = db_result($res,0,"caps_diff");
+$str .= "<table cellpadding=3 cellspacing=0 border=0>";
+$str .= "<tr><td align='center' colspan='2'>Local</td><td align='center' colspan='2'>Remote</td></tr>";
+$str .= $caps_diff;
+echo $str;
+</body></html>
More information about the Mapbender_commits
