[Mapbender-commits] r4502 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org
Fri Aug 7 08:42:56 EDT 2009
Author: christoph
Date: 2009-08-07 08:42:53 -0400 (Fri, 07 Aug 2009)
New Revision: 4502
Added:
trunk/mapbender/http/javascripts/mod_changeEPSG.js
Removed:
trunk/mapbender/http/javascripts/mod_changeEPSG.php
trunk/mapbender/http/php/mod_changeEPSG_server.php
Added: trunk/mapbender/http/javascripts/mod_changeEPSG.js
--- trunk/mapbender/http/javascripts/mod_changeEPSG.js (rev 0)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.js 2009-08-07 12:42:53 UTC (rev 4502)
@@ -0,0 +1,142 @@
+ * Package: changeEPSG
+ * Description:
+ * Select a spatial reference system EPSG code. All maps are transformed to
+ * that system.
+ * Files:
+ * - http/javascripts/mod_changeEPSG.js
+ * - http/php/mod_changeEPSG_server.php
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>','changeEPSG',
+ * > 2,1,'change EPSG, Postgres required, overview is targed for full extent',
+ * > 'Change Projection','select','','',432,25,107,24,1,'',
+ * > '<option value="">...</option>
+ * > <option value="EPSG:4326">EPSG:4326</option>
+ * > <option value="EPSG:31466">EPSG:31466</option>
+ * > <option value="EPSG:31467">EPSG:31467</option>
+ * > <option value="EPSG:31468">EPSG:31468</option>
+ * > <option value="EPSG:31469">EPSG:31469</option>','select',
+ * > 'mod_changeEPSG.js','','overview','','');
+ * Help:
+ * http://www.mapbender.org/ChangeEpsg
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var that = this;
+var exists = false;
+eventAfterMapRequest.register(function () {
+ mod_changeEPSG_setBox();
+function mod_changeEPSG_setBox(){
+ $("#"+options.id+" option").each(function () {
+ if (this.value == mb_mapObj[0].epsg) {
+ isEPSG = true;
+ $(this).attr("selected", "selected");
+$(this).change(function () {
+ var srsArray = [];
+ for (var i = 0; i < mb_mapObj.length; i++) {
+ var currentSrs = {
+ "frameName" : mb_mapObj[i].elementName,
+ "epsg" : mb_mapObj[i].epsg,
+ "extent" : mb_mapObj[i].extent.toString(),
+ "width" : mb_mapObj[i].width,
+ "height" : mb_mapObj[i].height
+ srsArray.push(currentSrs);
+ var srsValue = $("#"+options.id).get(0).value;
+ if (srsValue === "") {
+ return;
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_changeEPSG_server.php",
+ method: "changeEpsg",
+ parameters: {
+ srs: srsArray,
+ newSrs: srsValue
+ callback: function (obj, success, message) {
+ if (!success) {
+ alert(message);
+ new Mapbender.Exception(message);
+ return;
+ var newExtent = obj;
+ for (var i = 0; i < newExtent.length; i++) {
+ // use the previous extent of the overview
+ if(newExtent[i].frameName == options.target){
+ var map = Mapbender.modules[options.target];
+ var goback = false;
+ for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
+ if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+ exists = ii;
+ goback = true;
+ if (goback) {
+ map.setSrs({
+ srs: newExtent[i].newSrs,
+ extent: map.mb_MapHistoryObj[exists].extent
+ else{
+ map.setSrs({
+ extent: new Mapbender.Extent(
+ parseFloat(newExtent[i].minx),
+ parseFloat(newExtent[i].miny),
+ parseFloat(newExtent[i].maxx),
+ parseFloat(newExtent[i].maxy)
+ else {
+ var map = Mapbender.modules[newExtent[i].frameName];
+ map.setSrs({
+ displayWarning: true
+ map.setMapRequest();
+ req.send();
\ No newline at end of file
Deleted: trunk/mapbender/http/javascripts/mod_changeEPSG.php
--- trunk/mapbender/http/javascripts/mod_changeEPSG.php 2009-08-06 13:45:17 UTC (rev 4501)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.php 2009-08-07 12:42:53 UTC (rev 4502)
@@ -1,107 +0,0 @@
-<?php
-# $Id:mod_changeEPSG.php 3397 2009-01-02 15:24:40Z christoph $
-# http://www.mapbender.org/index.php/mod_changeEPSG.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-var that = this;
-var exists = false;
-eventAfterMapRequest.register(function () {
- mod_changeEPSG_setBox();
-function mod_changeEPSG_setBox(){
- $("#"+options.id+" option").each(function () {
- if (this.value == mb_mapObj[0].epsg) {
- isEPSG = true;
- $(this).attr("selected", "selected");
-$(this).change(function () {
- var srsArray = [];
- for (var i = 0; i < mb_mapObj.length; i++) {
- var currentSrs = {
- "frameName" : mb_mapObj[i].elementName,
- "epsg" : mb_mapObj[i].epsg,
- "extent" : mb_mapObj[i].extent.toString(),
- "width" : mb_mapObj[i].width,
- "height" : mb_mapObj[i].height
- srsArray.push(currentSrs);
- var req = new Mapbender.Ajax.Request({
- url: "../php/mod_changeEPSG_server.php",
- method: "changeEpsg",
- parameters: {
- srs: srsArray,
- newSrs: $("#"+options.id).get(0).value
- callback: function (obj, success, message) {
- if (!success) {
- new Mapbender.Exception(message);
- return;
- var newExtent = obj;
- for (var i = 0; i < newExtent.length; i++) {
- if(newExtent[i].frameName == options.target){
- var map = Mapbender.modules[options.target];
- for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
- if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
- exists = ii;
- var goback = true;
- if (goback) {
- map.epsg = newExtent[i].newSrs;
- map.extent = map.mb_MapHistoryObj[exists].extent;
- map.setMapRequest();
- else{
- map.extent = new Mapbender.Extent(
- parseFloat(newExtent[i].minx),
- parseFloat(newExtent[i].miny),
- parseFloat(newExtent[i].maxx),
- parseFloat(newExtent[i].maxy)
- else {
- var map = Mapbender.modules[newExtent[i].frameName];
- req.send();
Modified: trunk/mapbender/http/php/mod_changeEPSG_server.php
--- trunk/mapbender/http/php/mod_changeEPSG_server.php 2009-08-06 13:45:17 UTC (rev 4501)
+++ trunk/mapbender/http/php/mod_changeEPSG_server.php 2009-08-07 12:42:53 UTC (rev 4502)
@@ -21,10 +21,16 @@
$epsgObj = array();
-$ajaxResponse = new AjaxResponse($_REQUEST);
+$ajaxResponse = new AjaxResponse($_POST);
switch ($ajaxResponse->getMethod()) {
case "changeEpsg" :
+ if (!Mapbender::postgisAvailable()) {
+ $ajaxResponse->setSuccess(false);
+ $ajaxResponse->setMessage(_mb("PostGIS is not available. Please contact the administrator."));
+ $ajaxResponse->send();
$epsgArray = $ajaxResponse->getParameter("srs");
$newSrs = $ajaxResponse->getParameter("newSrs");
More information about the Mapbender_commits
