[Mapbender-commits] r4508 - branches/mifan_dev/mapbender/http/php
svn_mapbender at osgeo.org
Sat Aug 8 02:45:35 EDT 2009
Author: mifan
Date: 2009-08-08 02:45:35 -0400 (Sat, 08 Aug 2009)
New Revision: 4508
branches/mifan_dev/mapbender/http/php/mod_searchCatQueryBuilder_server.php
Modified: branches/mifan_dev/mapbender/http/php/mod_searchCatQueryBuilder_server.php
--- branches/mifan_dev/mapbender/http/php/mod_searchCatQueryBuilder_server.php 2009-08-08 06:44:59 UTC (rev 4507)
+++ branches/mifan_dev/mapbender/http/php/mod_searchCatQueryBuilder_server.php 2009-08-08 06:45:35 UTC (rev 4508)
@@ -23,13 +23,33 @@
require_once(dirname(__FILE__)."/../classes/class_administration.php");
require_once(dirname(__FILE__)."/../classes/class_json.php");
+ * get guis for user
+ * get catalogs for gui
+ * get get/post url for catalog
+ * construct query on url via get/xml
+ * make queries sequentially
+ * parse responses
+ * show responses with cat-name in results
+function get_guis_for_user($user){
+function get_catalogs_for_gui($gui_array,$getrecords_type){
$userId = $_SESSION["mb_user_id"];
$command = $_GET["command"];
$guiId = $_GET["guiId"];
$simplesearch = $_REQUEST['search'];
-$getrecords_type = $_REQUEST[''];
-$getrecords_query = $_REQUEST[''];
+$getrecords_type = $_REQUEST['getrecordsmedia'];
+$getrecords_query = $_REQUEST['getrecordsquery'];
$admin = new administration();
$guiIdArray = $admin->getGuisByPermission($userId, false);
@@ -40,8 +60,20 @@
array_push($resultObj['cats'],array("id"=>'id',"title"=>'test'));
-if ($command == "getrecordssimpleee") {
+if ($command == "getrecordssimple") {
$resultObj["cats"] = array();
+ switch(mb_strtolower($getrecords_type)){
+ case 'get':
+ break;
+ case 'post':
+ break;
+ case 'soap':
+ break;
+ default:
$xml_req = build_getrecords_xml();
$url = urlencode('http://gdi-de.sdisuite.de/soapServices/CSWStartup');
@@ -84,7 +116,12 @@
+function build_simple_query_get()
function getrecords_post ($url, $postData) {
$connection = new connector();
$connection->set("httpType", "post");
More information about the Mapbender_commits
