[Mapbender-commits] r4515 -
branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Aug 13 16:08:36 EDT 2009
Author: mifan
Date: 2009-08-13 16:08:36 -0400 (Thu, 13 Aug 2009)
New Revision: 4515
Added:
branches/mifan_dev/mapbender/http/classes/class_cswrecord.php
class to hold csw records
Added: branches/mifan_dev/mapbender/http/classes/class_cswrecord.php
--- branches/mifan_dev/mapbender/http/classes/class_cswrecord.php (rev 0)
+++ branches/mifan_dev/mapbender/http/classes/class_cswrecord.php 2009-08-13 20:08:36 UTC (rev 4515)
@@ -0,0 +1,281 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_cat_record
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_user.php");
+require_once(dirname(__FILE__)."/class_administration.php");
+ * CSW main class to hold catalog object
+ * @author nazgul
+class cswrecord{
+ var $getrecords_status;
+ var $elementSet;
+ var $numberOfRecordsMatched;
+ //Store GetRecords response XML for future caching needs
+ var $getRecordsDoc;
+ //Array of cswSummaryRecord Objects
+ var $SummaryRecordsArray = array();
+ //Constructor
+ function cswrecord(){
+ // Public Methods
+ * Create cswrecord object from GetRecords XML response
+ * @return unknown_type
+ * @param $url URL of getrecords
+ * @param $xml Post, SOAP XML
+ * @todo handle XML for POST,SOAP
+ public function createCSWRecordFromXML($url,$xml=null)
+ //create connector
+ $data=null;
+ //@todo handle post,soap
+ if($xml != null){
+ $connection = new connector();
+ $connection->set("httpType", "post");
+ $connection->set("httpContentType", "xml");
+ $connection->set("httpPostData", $xml);
+ $data = $connection->load($url);
+ else{
+ $x = new connector($url);
+ $data = $x->file;
+ if(!$data){
+ $this->getrecords_status=false;
+ $e = new mb_exception("CAT getrecords returned no result: " . $url . "\n" . $postData);
+ return false;
+ else {
+ $this->getrecords_status=true;
+ //arrays to hold xml struct values and index
+ $value_array = null;
+ $index_array = null;
+ //operational vars
+ $op_type=null; //get-capabilities, getrecords ...
+ $op_sub_type=null; //get,post,....
+ $op_constraint=false;
+ //Store XML response
+ //@todo cache this
+ $this->getRecordsDoc = $data;
+ $parser = xml_parser_create("");
+ xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+ xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+ xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+ xml_parse_into_struct($parser,$data,$value_array,$index_array);
+ //echo "values:".print_r($value_array);
+ //echo "index:".print_r($vindex_array);
+ $code = xml_get_error_code($parser);
+ if ($code) {
+ $line = xml_get_current_line_number($parser);
+ $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
+ xml_parser_free($parser);
+ foreach($value_array as $element){
+ //Version 2.0.2
+ //@todo: handle other profiles
+ if((mb_strtoupper($element[tag]) == "CSW:SEARCHRESULTS" OR mb_strtoupper($element[tag]) == "SEARCHRESULTS") && $element[type] == "open"){
+ $this->elementSet = $element[attributes][elementSet];
+ $this->numberOfRecordsMatched = $element[attributes][numberOfRecordsMatched];
+ if((mb_strtoupper($element[tag]) == "CSW:SUMMARYRECORD" OR mb_strtoupper($element[tag]) == "SUMMARYRECORD") && $element[type] == "open"){
+ //Create SummaryRecords Object
+ $summaryObj = new cswSummaryRecord();
+ //SummaryRecord elements
+ //ID
+ if((mb_strtoupper($element[tag]) == "DC:IDENTIFIER" OR mb_strtoupper($element[tag]) == "IDENTIFIER")){
+ $summaryObj->identifier = $element[value];
+ //Title
+ if((mb_strtoupper($element[tag]) == "DC:TITLE" OR mb_strtoupper($element[tag]) == "TITLE")){
+ $summaryObj->title = $element[value];
+ //@todo handle multiple subject elements
+ //Subject
+ if((mb_strtoupper($element[tag]) == "DC:SUBJECT" OR mb_strtoupper($element[tag]) == "SUBJECT")){
+ $summaryObj->subject = $element[value];
+ //Abstract
+ if((mb_strtoupper($element[tag]) == "DC:ABSTRACT" OR mb_strtoupper($element[tag]) == "ABSTRACT")){
+ $summaryObj->abstract = $element[value];
+ //Modified
+ if((mb_strtoupper($element[tag]) == "DC:MODIFIED" OR mb_strtoupper($element[tag]) == "MODIFIED")){
+ $summaryObj->modified = $element[value];
+ //Type
+ if((mb_strtoupper($element[tag]) == "DC:TYPE" OR mb_strtoupper($element[tag]) == "TYPE")){
+ $summaryObj->type = $element[value];
+ //Format
+ if((mb_strtoupper($element[tag]) == "DC:FORMAT" OR mb_strtoupper($element[tag]) == "FORMAT")){
+ $summaryObj->format = $element[value];
+ if((mb_strtoupper($element[tag]) == "CSW:SUMMARYRECORD" OR mb_strtoupper($element[tag]) == "SUMMARYRECORD") && $element[type] == "close"){
+ //{ush SummaryRecords Object to Array
+ array_push($this->SummaryRecordsArray,$summaryObj);
+ //Success/Failure
+ if($this->numberOfRecordsMatched==0){
+ $e = new mb_exception("There are no records that match your criteria");
+ return false;
+ else{
+ $this->getrecords_status = true;
+ $e = new mb_notice("GetRecords Results Returned");
+ return true;
+ * Function to handle whitespace and carriage returns
+ * Inspired by WMS code
+ * @param $string
+ function stripEndlineAndCarriageReturn($string) {
+ return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
+ * cswSummaryRecord to hold SummaryRecord Objects
+ * GetRecord(1)-SummaryRecord(n)
+ * @author nazgul
+class cswSummaryRecord{
+ //Vars
+ var $identifier;
+ var $title;
+ var $subject;
+ var $abstract;
+ var $modified;
+ var $type;
+ var $format;
+ //Constructor
+ function cswSummaryRecord(){
+ //Getters
+ public function getIdentifier(){
+ return $this->identifier;
+ public function getTitle(){
+ return $this->title;
+ public function getSubject(){
+ return $this->subject;
+ public function getAbstract(){
+ return $this->abstract;
+ public function getModified(){
+ return $this->modified;
+ public function getType(){
+ return $this->type;
+ public function getFormat(){
+ return $this->format;
+ //Setters
+ public function setIdentifier($identifier){
+ return $this->identifier = $identifier;
+ public function setTitle($title){
+ return $this->title = $title;
+ public function setSubject($subject){
+ return $this->subject = $subject;
+ public function setAbstract($abstract){
+ return $this->abstract = $abstract;
+ public function setModified($modified){
+ return $this->modified = $modified;
+ public function setType($type){
+ return $this->type = $type;
+ public function setFormat($format){
+ return $this->format = $format;
\ No newline at end of file
More information about the Mapbender_commits
