[Mapbender-commits] r4541 - in trunk/mapbender/http: css img php
svn_mapbender at osgeo.org
Fri Aug 28 08:31:50 EDT 2009
Author: christoph
Date: 2009-08-28 08:31:50 -0400 (Fri, 28 Aug 2009)
New Revision: 4541
Added:
trunk/mapbender/http/css/customTree.css
trunk/mapbender/http/img/closed_folder.png
trunk/mapbender/http/img/expanded_folder.png
trunk/mapbender/http/img/treeview-default-line.gif
trunk/mapbender/http/img/treeview-default.gif
trunk/mapbender/http/php/mod_customTree.php
trunk/mapbender/http/php/mod_customTree_server.php
added CSS
did some bug fixing
http://trac.osgeo.org/mapbender/ticket/389
Added: trunk/mapbender/http/css/customTree.css
--- trunk/mapbender/http/css/customTree.css (rev 0)
+++ trunk/mapbender/http/css/customTree.css 2009-08-28 12:31:50 UTC (rev 4541)
@@ -0,0 +1,81 @@
+.custom-tree-treeview, .custom-tree-treeview ul {
+ list-style-image:none;
+ list-style-position:outside;
+ list-style-type:none;
+ margin:0;
+ padding:0;
+.custom-tree-treeview ul {
+ background-color:transparent;
+ margin-top:1px;
+.custom-tree-treeview .custom-tree-hitarea {
+ background:transparent url(../img/treeview-default.gif) no-repeat scroll -64px -25px;
+ cursor:pointer;
+ float:left;
+ height:16px;
+ margin-left:-16px;
+ width:16px;
+* html .custom-tree-hitarea {
+ display:inline;
+ float:none;
+.custom-tree-filetree li {
+ padding:3px 0 2px 16px;
+.custom-tree-treeview a.selected {
+ background-color:#EEEEEE;
+.custom-tree-treeview li {
+ background:transparent url(../img/treeview-default-line.gif) no-repeat scroll 0 0;
+.custom-tree-treeview li.custom-tree-collapsable, .custom-tree-treeview li.custom-tree-expandable {
+ background-position:0 -176px;
+.custom-tree-treeview .custom-tree-expandable-hitarea {
+ background-position:-80px -3px;
+.custom-tree-treeview li.custom-tree-last {
+ background-position:0 -1766px;
+.custom-tree-treeview li.custom-tree-lastCollapsable, .custom-tree-treeview li.custom-tree-lastExpandable {
+ background-image:url(../img/treeview-default.gif);
+.custom-tree-treeview li.custom-tree-lastCollapsable {
+ background-position:0 -111px;
+.custom-tree-treeview li.custom-tree-lastExpandable {
+ background-position:-32px -67px;
+.custom-tree-treeview div.custom-tree-lastCollapsable-hitarea, .custom-tree-treeview div.custom-tree-lastExpandable-hitarea {
+ background-position:0 50%;
+.custom-tree-filetree span.custom-tree-folder, .custom-tree-filetree {
+ display:block;
+.custom-tree-filetree span.custom-tree-folder {
+ background:transparent url(../img//expanded_folder.png) no-repeat scroll 0 0;
+.custom-tree-filetree li.custom-tree-expandable span.custom-tree-folder {
+ background:transparent url(../img/closed_folder.png) no-repeat scroll 0 0;
+span.custom-tree-folder {
+ padding: 3px 0 3px 18px;
+ margin: -3px 0 0 0;
+span.custom-tree-file img {
+ vertical-align: bottom;
+ margin: 0 2px 0 0;
\ No newline at end of file
Added: trunk/mapbender/http/img/closed_folder.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/closed_folder.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/mapbender/http/img/expanded_folder.png
Property changes on: trunk/mapbender/http/img/expanded_folder.png
Added: trunk/mapbender/http/img/treeview-default-line.gif
Property changes on: trunk/mapbender/http/img/treeview-default-line.gif
Added: trunk/mapbender/http/img/treeview-default.gif
Property changes on: trunk/mapbender/http/img/treeview-default.gif
Modified: trunk/mapbender/http/php/mod_customTree.php
--- trunk/mapbender/http/php/mod_customTree.php 2009-08-28 12:27:20 UTC (rev 4540)
+++ trunk/mapbender/http/php/mod_customTree.php 2009-08-28 12:31:50 UTC (rev 4541)
@@ -7,16 +7,11 @@
<head>
<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>" />
<title>Untitled Document</title>
+ <link rel="stylesheet" type="text/css" href="../css/customTree.css">
<style type="text/css">
.ui-selecting {
color:red;
- .treeNode {
- color:green;
- .treeLeaf {
- color:blue;
.ui-selected {
border-width:thin;
border-style:solid;
@@ -47,7 +42,7 @@
require_once(dirname(__FILE__) . "/../extensions/jquery.contextmenu.r2.js");
require_once(dirname(__FILE__) . "/../extensions/jqjson.js");
require_once(dirname(__FILE__) . "/../javascripts/popup.js");
- require_once(dirname(__FILE__) . "/../../lib/event.js");
+ require_once(dirname(__FILE__) . "/../javascripts/core.php");
require_once(dirname(__FILE__) . "/../../lib/customTreeModel.js");
require_once(dirname(__FILE__) . "/../../lib/customTreeController.js");
require_once(dirname(__FILE__) . "/../../lib/buttonNew.js");
@@ -57,23 +52,7 @@
var applicationId;
- var findAllWmsInTree = function (aTree) {
- return findAllWmsInNode(aTree.root).sort();
- findAllWmsInNode = function (aNode) {
- if (!aNode.isFolder) {
- return [aNode.wmsId];
- var wmsIdArray = [];
- for (var i = 0; i < aNode.childNodeList.count(); i++) {
- var child = aNode.childNodeList.get(i);
- var newArray = findAllWmsInNode(child);
- wmsIdArray = wmsIdArray.concat(newArray);
- return wmsIdArray;
var saveTreeOnUnloadOrChange = function (myTree) {
if (myTree.hasChanged) {
var saveChanges = confirm("You have changed the tree. All changes will be lost. Save changes?");
@@ -86,89 +65,18 @@
- var addMissingWmsToCustomTree = function (aTree, anApplicationId) {
- // get available WMS ...
- var queryObj = {
- command:"getWmsByApplication",
- parameters: {
- "applicationId": anApplicationId
- $.post("../php/mod_customTree_server.php", {
- queryObj:$.toJSON(queryObj)
- }, function (json, status) {
- var replyObj = eval('(' + json + ')');
- var root = aTree.root;
- var wmsIdArray = findAllWmsInTree(aTree);
- for (var index in replyObj.data.wmsArray) {
- var found = false;
- for (var j = 0; j < wmsIdArray.length; j++) {
- if (wmsIdArray[j] == index) {
- found = true;
- break;
- if (!found) {
- var wmsNode = new CustomTreeNode();
- wmsNode.name = replyObj.data.wmsArray[index];
- wmsNode.wmsId = index;
- myTree.root.append(wmsNode);
- myTree.hasChanged = false;
- displayMyTree = new customTreeController(myTree, {
- contextMenu: true,
- droppable: true,
- id: "myTree"
- var getCustomTreeByApplication = function (applicationName) {
- // load a previously saved
- // customized tree from the database
- var queryObj = {
- command:"getCustomTreeByApplication",
- parameters: {
- "applicationId":applicationName
- myTree = new CustomTree();
- var root = myTree.root;
- root.name = "(" + applicationId + ")";
- var nodeArray = replyObj.data.nodeArray;
- myTree.importNestedSets(nodeArray);
- addMissingWmsToCustomTree(myTree, applicationId);
- droppable: true,
- id: "myTree"
var selectApplication = function (applicationName) {
applicationId = applicationName;
- getCustomTreeByApplication(applicationId);
+ myTree = new CustomTree({
+ loadFromApplication: applicationName,
+ draggable: true,
+ droppable: true,
+ id: "myTree",
+ contextMenu: true
var getApplications = function () {
@@ -253,11 +161,13 @@
queryObj: $.toJSON(queryObj)
}, function(json, status){
+ draggable: true,
+ droppable: true,
+ id: "myTree",
+ contextMenu: true
@@ -288,7 +198,7 @@
// dialogue: save changes on unload
$(window).unload(function () {
- saveTreeOnUnloadOrChange(myTree);
+// saveTreeOnUnloadOrChange(myTree);
@@ -315,4 +225,4 @@
<div id='myTree'></div>
<div id='wmsTree'></div>
</body>
-</html>
+</html>
Modified: trunk/mapbender/http/php/mod_customTree_server.php
--- trunk/mapbender/http/php/mod_customTree_server.php 2009-08-28 12:27:20 UTC (rev 4540)
+++ trunk/mapbender/http/php/mod_customTree_server.php 2009-08-28 12:31:50 UTC (rev 4541)
@@ -14,7 +14,6 @@
echo $output;
$json = new Mapbender_JSON();
$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
$resultObj = array();
@@ -49,8 +48,8 @@
$allowedApplicationArray = $user->getApplicationsByPermission(0);
// get all of the users applications that contain treeGDE
- $sql = "SELECT fkey_gui_id FROM gui_element WHERE " .
- "e_id = 'treeGDE' AND fkey_gui_id IN (";
+ $sql = "SELECT DISTINCT fkey_gui_id FROM gui_element WHERE " .
+ "fkey_gui_id IN (";
$v = array();
$t = array();
@@ -130,8 +129,8 @@
$currentNode = array(
- "left" => $row["lft"],
- "right" => $row["rgt"],
+ "left" => intval($row["lft"]),
+ "right" => intval($row["rgt"]),
"name" => $row["my_layer_title"],
"wms" => $wmsArray
@@ -155,6 +154,7 @@
$t = array("s");
$res = db_prep_query($sql, $v, $t);
+ $rowArray = array();
for ($i = 0; $i < count($elementArray); $i++) {
$currentElement = $elementArray[$i];
@@ -170,8 +170,9 @@
$t = array("s", "i", "i", "s", "s");
+ $rowArray[]= $v;
- $data = array("sql" => $sql, "data" => $v);
+ $data = array("sql" => $sql, "data" => $rowArray);
$resultObj["data"] = $data;
$resultObj["success"] = "Elements have been updated in the database.";
break;
@@ -183,4 +184,4 @@
sendOutput($resultObj);
More information about the Mapbender_commits
