[Mapbender-commits] r4548 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Aug 28 08:39:10 EDT 2009
Author: christoph
Date: 2009-08-28 08:39:09 -0400 (Fri, 28 Aug 2009)
New Revision: 4548
trunk/mapbender/http/javascripts/map_obj.js
minor bug fixes and modifictaions
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2009-08-28 12:36:44 UTC (rev 4547)
+++ trunk/mapbender/http/javascripts/map_obj.js 2009-08-28 12:39:09 UTC (rev 4548)
@@ -196,7 +196,7 @@
this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
return ext;
var ignoredWms = [];
var undoIgnoreWms = function () {
@@ -204,12 +204,15 @@
var ignoreWms = function (wms) {
- ignoredWms.push(wms.wms_id);
+ ignoredWms.push({
+ id: wms.wms_id,
+ title: wms.wms_title
var isIgnoredWms = function (wms) {
for (var j = 0; j < ignoredWms.length; j++) {
- if (ignoredWms[j] === wms.wms_id) {
+ if (ignoredWms[j].id === wms.wms_id) {
return true;
@@ -235,7 +238,7 @@
for (var i = 0; i < this.wms.length; i++) {
var found = false;
for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
- if (options.srs === this.wms[i].gui_epsg[j]) {
+ if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
found = true;
break;
@@ -248,8 +251,12 @@
// ...and optionally display a message
if (options.displayWarning && ignoredWms.length > 0) {
- var msg = "The following WMS do not support the current SRS: " +
- ignoredWms.join(",");
+ var msg = "The following WMS do not support the current SRS: <br><br>";
+ for (var key in ignoredWms) {
+ msg += "<b>" + ignoredWms[key].title + "</b><br>";
try {
Mapbender.modules.dialogManager.openDialog({
content: msg,
@@ -258,7 +265,7 @@
catch (e) {
- new Mb_warning(e.message + " " + msg);
+ new Mb_warning(e.message + ". " + msg);
@@ -672,6 +679,9 @@
if(validLayers.length === 0) {
return false;
+ for (var i = 0; i < validLayers.length; i++) {
+ validLayers[i] = encodeURIComponent(validLayers[i]);
var layerNames = validLayers.join(",");
url = currentWms.wms_getmap;
@@ -869,11 +879,12 @@
var currentWms = this.wms[ii];
try {
- if (!this.requestMapIfSrsNotSupported && isIgnoredWms(currentWms)) {
+ if (this.skipWmsIfSrsNotSupported && isIgnoredWms(currentWms)) {
continue;
catch (e) {
+ new Mb_warning(e.message);
if (currentWms.wms_id != wms_id) {
@@ -885,8 +896,14 @@
var tmp = eval(Mapbender.log + "('" +
newMapURL + "','" + ts + "')");
- var myDivId = this.elementName + "_div_" + ii;
- writeTag(this.frameName, myDivId, newMapRequest);
+ var myDivId = this.elementName + "_div_" + ii;
+ var $wmsDiv = $("#" + myDivId);
+ if ($wmsDiv.size() > 0) {
+ $wmsDiv.remove();
+ var $newDiv = $(newMapRequest);
+ $("#" + this.elementName + "_maps").append($newDiv);
var myMapId = this.elementName + "_map_" + ii;
eventAfterMapRequest.trigger({
map: this,
@@ -948,6 +965,7 @@
catch (e) {
if (!(currentWms.gui_wms_visible > 0)) {
continue;
@@ -1042,6 +1060,15 @@
return null;
+ this.getWmsById = function (wms_id) {
+ for (var i=0; i< this.wms.length; i++){
+ if(this.wms[i].wms_id == wms_id){
+ return this.wms[i];
+ return null;
this.removeWms = function (wmsIndex) {
var wms_ID = null;
var i;
More information about the Mapbender_commits
