[Mapbender-commits] r4555 - trunk/mapbender/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 28 08:49:13 EDT 2009
Author: christoph
Date: 2009-08-28 08:49:13 -0400 (Fri, 28 Aug 2009)
New Revision: 4555
   trunk/mapbender/http/html/mod_treefolderPlain.php
workaround: handle type confusion
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php	2009-08-28 12:48:22 UTC (rev 4554)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php	2009-08-28 12:49:13 UTC (rev 4555)
@@ -242,7 +242,7 @@
 				for(var iii=1; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
 					if(! mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
 						path = arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id+"|"+ mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
-						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible=='1', false);
+						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible==='1'||mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible===1, false);
 						if(ficheckbox == 'true')
 							checkNode(path, 1,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
@@ -323,7 +323,7 @@
 		if(state[wms]!=-1){
 			for(var i=1;i< mb_mapObj[ind].wms[wms].objLayer.length;i++){
-				if( mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
+				if(mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible===1||mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==="1"){
 					state[wms]=1;
 					if(showstatus=='true')
 						setNodeImage(img);
@@ -370,7 +370,7 @@
 	var ind =  getMapObjIndexByName(mapObj);
 	for(var i=0; i< mb_mapObj[ind].wms.length; i++){
 		if( mb_mapObj[ind].wms[i].wms_id == wms_id){
-			 mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+			mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
 			break;
@@ -494,7 +494,7 @@
 	var visibleWMS=0;
 	for(var i=0;i< mb_mapObj[j].wms.length;i++)
-		if( mb_mapObj[j].wms[i].gui_wms_visible=='1'|| mb_mapObj[j].wms[i].gui_wms_visible==1)
+		if( mb_mapObj[j].wms[i].gui_wms_visible==='1'|| mb_mapObj[j].wms[i].gui_wms_visible===1)
 			visibleWMS++;
 	if(visibleWMS<=1){
 		alert ("<?php echo _mb('Last WMS can not be removed.');?>");
@@ -572,7 +572,7 @@
 		for(var i=0; i< mb_mapObj.length; i++){
 			if( mb_mapObj[i].elementName == mod_treeGDE_map){
 				for(var ii=0; ii< mb_mapObj[i].wms.length; ii++){
-					if( mb_mapObj[i].wms[ii].gui_wms_visible == '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+					if( mb_mapObj[i].wms[ii].gui_wms_visible === '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible === 1){
 						for(var iii=0; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
 							var temp =  mb_mapObj[i].wms[ii].objLayer[iii];
 							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
@@ -640,8 +640,9 @@
 									controls.push('<input type="checkbox"  title="' + msgObj.tooltipLayerVisible + '" ');
 									if(temp.layer_name=="")
 										controls.push('style="display:none;" ');
-									if(temp.gui_layer_visible=='1')
+									if(temp.gui_layer_visible==='1' ||temp.gui_layer_visible===1){
 										controls.push('checked ');
 									if(temp.gui_layer_selectable!='1')
 										controls.push('disabled ');
 									controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
@@ -679,7 +680,7 @@
More information about the Mapbender_commits mailing list
