[Mapbender-commits] r4559 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 28 09:09:24 EDT 2009
Author: christoph
Date: 2009-08-28 09:09:24 -0400 (Fri, 28 Aug 2009)
New Revision: 4559
Added:
   trunk/mapbender/http/javascripts/mod_addWMSfromTree.js
http://trac.osgeo.org/mapbender/ticket/517
Added: trunk/mapbender/http/javascripts/mod_addWMSfromTree.js
--- trunk/mapbender/http/javascripts/mod_addWMSfromTree.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_addWMSfromTree.js	2009-08-28 13:09:24 UTC (rev 4559)
@@ -0,0 +1,246 @@
+ * Package: AddWmsFromTree
+ * Description:
+ * Add a WMS from a container. The WMS are displayed in a customized tree
+ * (if one exists)
+ * Files:
+ *  - http/javascripts/mod_addWMSfromTree.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>',
+ * > 'addWMSfromTree',2,1,'Add a WMS from a container. The WMS are displayed in a customized tree (if one exists)',
+ * > 'Add WMS from tree','div','','',1,1,1,1,5,'overflow:scroll','','div',
+ * > '../javascripts/mod_addWMSfromTree.js',
+ * > '../extensions/jquery-ui-1.7.2.custom.min.js,../../lib/customTreeModel.js,../../lib/customTreeController.js',
+ * > 'mapframe1','mapframe1','');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<app_id>', 'addWMSfromTree',
+ * > 'addwms_showWMS', '<max_number_of_layers>', '0 : do not make layer visible; n > 0 : make visible if #layers < n' ,'var');
+ * > 'applicationName', '<container_name>', 'Use the custom tree of this container' ,'var');
+ * > var_value, context, var_type) VALUES ('<app_id>', 'body',
+ * > 'custom_tree_css', '../css/customTree.css', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/AddWmsFromTree
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * addwms_showWMS		- Integer. 	0 : do not make layer visible;
+ *						- 			n > 0 : make visible if #layers < n
+ * applicationName		- String. Use the custom tree of this container
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+(function () {
+	var addwms_showWMS = typeof options.addwms_showWMS !== "undefined" ?
+		options.addwms_showWMS : 0;
+	var applicationName = options.applicationName;
+	if (typeof applicationName === "undefined") {
+		new Mb_exception("No applicationName given in " + options.id);
+	else {
+		var loadWmsAndZoomCallback = function (opt) {
+			if (typeof opt === "object" && opt.success) {
+				var wmsId = parseInt(opt.wmsId, 10);
+				var map = getMapObjByName(options.target[0]);
+				var wms = map.getWmsById(wmsId);
+				if (wms === null) {
+					opt.msg = "Ein unbekannter Fehler ist aufgetreten.";
+				else {
+					// activate
+					if (typeof opt.visible === "number" && opt.visible === 1) {
+						if (typeof addwms_showWMS === "number"
+							&& addwms_showWMS < wms.objLayer.length) {
+							if (addwms_showWMS > 0) {
+								try {
+									var msg = "Der hinzugeladene Kartendienst " +
+										"verfügt über mehr als " + addwms_showWMS +
+										" Ebenen. Die Ebenen des Dienstes werden " +
+										"<b>nicht</b> aktiviert.";
+									Mapbender.modules.dialogManager.openDialog({
+										content: msg,
+										modal: false,
+										effectShow: 'puff'
+								catch (e) {
+									new Mb_warning(e.message + ". " + msg);
+							handleSelectedWms(map.elementName, wmsId, "visible", 0);
+						else {
+							mb_restateLayers(map.elementName, wmsId);
+					// zoom to bbox
+					var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+					for (var i = 0; i < wms.gui_epsg.length; i++) {
+						if (map.epsg == wms.gui_epsg[i]) {
+							bbox_minx = parseFloat(wms.gui_minx[i]);
+							bbox_miny = parseFloat(wms.gui_miny[i]);
+							bbox_maxx = parseFloat(wms.gui_maxx[i]);
+							bbox_maxy = parseFloat(wms.gui_maxy[i]);
+							if (bbox_minx === null || bbox_miny === null || bbox_maxx === null || bbox_maxy === null) {
+								continue;
+							map.calculateExtent(new Extent(
+								bbox_minx,
+								bbox_miny,
+								bbox_maxx,
+								bbox_maxy
+							map.setMapRequest();
+							break;
+			loadWmsCallback(opt);
+		var loadWmsCallback = function (opt) {
+			var msg = typeof opt.msg === "string" ? opt.msg : "";
+			if (typeof opt !== "object" || !opt.success) {
+				msg = "Ein unbekannter Fehler ist aufgetreten. ";
+			else {
+				if (wms !== null) {
+					msg = "Der folgende Dienst wurde zu 'Aktive Dienste' " +
+						"hinzugefügt:<br><br>";
+					msg += "<b>" + wms.wms_title + "</b><br><br>";
+				else {
+			try {
+					content: msg,
+					modal: false,
+			catch (e) {
+		var additionalBehaviour = [
+				openTag: "img",
+				attr: {
+					src: "../img/tree_info.png",
+					title: "Metadaten anzeigen"
+				css: {
+					cursor: "pointer"
+				behaviour: {
+					click: function (opt) {
+						var metadataPopup = new mb_popup({
+							title : "Metadata",
+							url : "../php/mod_layerMetadata.php?wmsid=" +
+								opt.treeNode.wmsId,
+							width : 450,
+							height : 600,
+							left : 400,
+							top : 100
+						metadataPopup.show();
+				openTag: "img",
+				attr: {
+					src: "../img/tree_zoom.png",
+					title: "WMS zu aktiven Diensten hinzufügen und auf Ausschnitt zoomen"
+				css: {
+					cursor: "pointer"
+				behaviour: {
+						mod_addWMSById_ajax(opt.appId, opt.treeNode.wmsId, {
+							zoomToExtent: 1,
+							visible: 1,
+							callback: loadWmsAndZoomCallback
+				openTag: "img",
+				closeTag: "",
+				attr: {
+					src: "../img/tree_add_wms.png",
+					title: "WMS zu aktiven Diensten hinzufügen"
+				css: {
+					cursor: "pointer"
+				behaviour: {
+					click: function (param) {
+						mod_addWMSById_ajax(param.appId, param.treeNode.wmsId, {
+							callback: function (opt) {
+									handleSelectedWms(map.elementName, wmsId, "querylayer", 0);
+		var myTree = new CustomTree({
+			loadFromApplication: applicationName,
+			id: options.id,
+			draggable: false,
+			droppable: false,
+			skipRootNode: true,
+			leafBehaviour: additionalBehaviour
More information about the Mapbender_commits mailing list
