[Mapbender-commits] r4561 - in trunk/mapbender/documents/api_js:
Data files/http/javascripts search
svn_mapbender at osgeo.org
Fri Aug 28 09:20:38 EDT 2009
Author: christoph
Date: 2009-08-28 09:20:38 -0400 (Fri, 28 Aug 2009)
New Revision: 4561
trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
trunk/mapbender/documents/api_js/Data/IndexInfo.nd
trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
trunk/mapbender/documents/api_js/search/ClassesO.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd 2009-08-28 13:20:07 UTC (rev 4560)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd 2009-08-28 13:20:38 UTC (rev 4561)
@@ -1,3 +1,3 @@
( repaint >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php doubleclickZoom F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js
-changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php Ajax */home/cbaudson/workspace/trunk/lib/ajax.js mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js Notice //home/cbaudson/workspace/trunk/lib/exception.js Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js Request */home/cbaudson/workspace/trunk/lib/ajax.js Extent ,/home/cbaudson/workspace/trunk/lib/extent.js Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js Warning //home/cbaudson/workspace/trunk/lib/exception.js Event +/home/cbaudson/workspace/trunk/lib/event.js AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
-ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js Notification */home/cbaudson/workspace/trunk/lib/ajax.js Exception //home/cbaudson/workspace/trunk/lib/exception.js zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js ZoomIn1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
\ No newline at end of file
+changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js Ajax */home/cbaudson/workspace/trunk/lib/ajax.js Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js Notice //home/cbaudson/workspace/trunk/lib/exception.js Request */home/cbaudson/workspace/trunk/lib/ajax.js Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js Extent ,/home/cbaudson/workspace/trunk/lib/extent.js Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js Warning //home/cbaudson/workspace/trunk/lib/exception.js Event +/home/cbaudson/workspace/trunk/lib/event.js AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js
+ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js Notification */home/cbaudson/workspace/trunk/lib/ajax.js overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js Exception //home/cbaudson/workspace/trunk/lib/exception.js ZoomIn1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd 2009-08-28 13:20:07 UTC (rev 4560)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd 2009-08-28 13:20:38 UTC (rev 4561)
@@ -1 +1 @@
-( General Database Index Function File Database Table Class Database Trigger Property
+( Database Index General Function Database Table File Class Database Trigger Property
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Property changes on: trunk/mapbender/documents/api_js/search/ClassesO.html
+ text/html
More information about the Mapbender_commits
