[Mapbender-commits] r4567 - trunk/mapbender/documents/api_js/Data
    svn_mapbender at osgeo.org
    Fri Aug 28 09:37:32 EDT 2009
Author: christoph
Date: 2009-08-28 09:37:32 -0400 (Fri, 28 Aug 2009)
New Revision: 4567
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/FileInfo.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 13:36:31 UTC (rev 4566)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 13:37:32 UTC (rev 4567)
@@ -1,3 +1,3 @@
 (    repaint    >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php  doubleclickZoom    F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js
-changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
-ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js  overviewToggle    E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
\ No newline at end of file
+changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js
+ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  overviewToggle    E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd	2009-08-28 13:36:31 UTC (rev 4566)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd	2009-08-28 13:37:32 UTC (rev 4567)
@@ -304,7 +304,7 @@
 /home/cbaudson/workspace/trunk/tools/char_code.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/char_code.php
 /home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js	1246458995	1	doubleclickZoom
 /home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js	1246283980	0	/home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js
-/home/cbaudson/workspace/trunk/core/system.php	1251465834	0	/home/cbaudson/workspace/trunk/core/system.php
+/home/cbaudson/workspace/trunk/core/system.php	1251466592	0	/home/cbaudson/workspace/trunk/core/system.php
 /home/cbaudson/workspace/trunk/http/classes/class_log.php	1246636499	0	/home/cbaudson/workspace/trunk/http/classes/class_log.php
 /home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js	1246636241	1	ResizeMapsize
 /home/cbaudson/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js	1246283823	0	/home/cbaudson/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 13:36:31 UTC (rev 4566)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 13:37:32 UTC (rev 4567)
@@ -1 +1 @@
-(    General            Database Index                            Function                     File                           Database Table                            Class                 Database Trigger                            Property
+(    Database Index                            General            Function                     Database Table                            File                           Class                 Database Trigger                            Property
More information about the Mapbender_commits
