[Mapbender-commits] r4581 - in trunk/mapbender/http: extensions extensions/proj4js extensions/proj4js/build extensions/proj4js/demo extensions/proj4js/demo/maps extensions/proj4js/docs extensions/proj4js/docs/NaturalDocs extensions/proj4js/docs/NaturalDocs/Data extensions/proj4js/docs/NaturalDocs/files extensions/proj4js/docs/NaturalDocs/index extensions/proj4js/docs/NaturalDocs/javascript extensions/proj4js/docs/NaturalDocs/styles extensions/proj4js/lib extensions/proj4js/lib/defs extensions/proj4js/lib/projCode extensions/proj4js/test extensions/proj4js/tools extensions/proj4js/tools/catalogues javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 31 09:30:39 EDT 2009
Author: topi
Date: 2009-08-31 09:30:38 -0400 (Mon, 31 Aug 2009)
New Revision: 4581
Added:
   trunk/mapbender/http/extensions/proj4js/
   trunk/mapbender/http/extensions/proj4js/build/
   trunk/mapbender/http/extensions/proj4js/build/README.txt
   trunk/mapbender/http/extensions/proj4js/build/build.py
   trunk/mapbender/http/extensions/proj4js/build/build.xml
   trunk/mapbender/http/extensions/proj4js/build/buildUncompressed.py
   trunk/mapbender/http/extensions/proj4js/build/library.cfg
   trunk/mapbender/http/extensions/proj4js/build/license.txt
   trunk/mapbender/http/extensions/proj4js/demo/
   trunk/mapbender/http/extensions/proj4js/demo/ProjPane.js
   trunk/mapbender/http/extensions/proj4js/demo/base.css
   trunk/mapbender/http/extensions/proj4js/demo/index.html
   trunk/mapbender/http/extensions/proj4js/demo/maps/
   trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG27563.js
   trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG42304.js
   trunk/mapbender/http/extensions/proj4js/docs/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ClassHierarchy.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ConfigFileInfo.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/FileInfo.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousMenuState.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousSettings.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/SymbolTable.nd
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Languages.txt
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Menu.txt
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Topics.txt
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-combined-js.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-js.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Classes.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Functions.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/General.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Properties.html
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/javascript/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/javascript/main.js
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/styles/
   trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/styles/main.css
   trunk/mapbender/http/extensions/proj4js/index.html
   trunk/mapbender/http/extensions/proj4js/lib/
   trunk/mapbender/http/extensions/proj4js/lib/defs/
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102757.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102758.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG21781.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26591.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26912.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27200.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27563.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG41001.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4139.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4181.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG42304.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4272.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4302.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.js
   trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.txt
   trunk/mapbender/http/extensions/proj4js/lib/defs/GOOGLE.js
   trunk/mapbender/http/extensions/proj4js/lib/proj4js-combined.js
   trunk/mapbender/http/extensions/proj4js/lib/proj4js-compressed.js
   trunk/mapbender/http/extensions/proj4js/lib/proj4js.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/
   trunk/mapbender/http/extensions/proj4js/lib/projCode/aea.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/aeqd.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/eqc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/eqdc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/equi.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/gauss.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/geocent.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/gstmerc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/laea.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/lcc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/merc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/mill.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/moll.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/nzmg.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/omerc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/ortho.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/poly.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/sinu.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/somerc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/stere.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/sterea.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/tmerc.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/utm.js
   trunk/mapbender/http/extensions/proj4js/lib/projCode/vandg.js
   trunk/mapbender/http/extensions/proj4js/test/
   trunk/mapbender/http/extensions/proj4js/test/base.css
   trunk/mapbender/http/extensions/proj4js/test/index.html
   trunk/mapbender/http/extensions/proj4js/test/runtests.js
   trunk/mapbender/http/extensions/proj4js/test/testdata.js
   trunk/mapbender/http/extensions/proj4js/tools/
   trunk/mapbender/http/extensions/proj4js/tools/README.txt
   trunk/mapbender/http/extensions/proj4js/tools/catalogues/
   trunk/mapbender/http/extensions/proj4js/tools/catalogues/CRS
   trunk/mapbender/http/extensions/proj4js/tools/catalogues/EPSG
   trunk/mapbender/http/extensions/proj4js/tools/catalogues/IGNF
   trunk/mapbender/http/extensions/proj4js/tools/jsmin.c
   trunk/mapbender/http/extensions/proj4js/tools/jsmin.py
   trunk/mapbender/http/extensions/proj4js/tools/mergejs.py
   trunk/mapbender/http/extensions/proj4js/tools/mkpjcat.py
   trunk/mapbender/http/extensions/proj4js/tools/pjjs.py
   trunk/mapbender/http/extensions/proj4js/tools/toposort.py
   trunk/mapbender/http/javascripts/mod_coordsLookup.js
http://trac.osgeo.org/mapbender/ticket/524
Added: trunk/mapbender/http/extensions/proj4js/build/README.txt
--- trunk/mapbender/http/extensions/proj4js/build/README.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/README.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,13 @@
+## HowTo: Build & deploy "Shrunk" Single File Library version of proj4js ##
+ * Build:
+     cd build
+     ./build.py
+     cd ..
+ * Upload the result to the server: e.g.
+  scp build/proj4js.js openlayers at openlayers.org:openlayers.org/htdocs/code/
Added: trunk/mapbender/http/extensions/proj4js/build/build.py
--- trunk/mapbender/http/extensions/proj4js/build/build.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/build.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,32 @@
+#!/usr/bin/env python
+import sys
+sys.path.append("../tools")
+import jsmin, mergejs
+sourceDirectory = "../lib"
+configFilename = "library.cfg"
+outputFilename = "../lib/proj4js-compressed.js"
+if len(sys.argv) > 1:
+    configFilename = sys.argv[1]
+    extension = configFilename[-4:]
+    if extension  != ".cfg":
+        configFilename = sys.argv[1] + ".cfg"
+if len(sys.argv) > 2:
+    outputFilename = sys.argv[2]
+print "Merging libraries."
+merged = mergejs.run(sourceDirectory, None, configFilename)
+print "Compressing."
+minimized = jsmin.jsmin(merged)
+print "Adding license file."
+minimized = file("license.txt").read() + minimized
+print "Writing to %s." % outputFilename
+file(outputFilename, "w").write(minimized)
+print "Done."
Added: trunk/mapbender/http/extensions/proj4js/build/build.xml
--- trunk/mapbender/http/extensions/proj4js/build/build.xml	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/build.xml	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,159 @@
+<?xml version="1.0" encoding="UTF-8"?>
+Filename        :   build.xml
+Project         :   proj4js
+Document Type   :   XML
+Purpose         :   build file for ant tool
+Author     Date            Description
+M.Adair    17-Dec-2001     initial version copied from mapbuilder
+$Id: build.xml 2955 2007-07-09 12:12:27Z steven $
+<!-- A "project" describes a set of targets that may be requested
+     when Ant is executed.  The "default" attribute defines the
+     target which is executed if no specific target is requested,
+     and the "basedir" attribute defines the current working directory
+     from which Ant executes the requested task.  This is normally
+     set to the current working directory.
+  <project basedir=".." default="dist" name="proj4js">
+<!-- ===================== Property Definitions =========================== -->
+  Each of the following properties are used in the build script.
+  Values for these properties are set by the first place they are
+  defined, from the following list:
+  * Definitions on the "ant" command line (ant -Dfoo=bar compile).
+  * Definitions from a "build.properties" file in the top level
+    source directory of this application.
+  * Definitions from a "build.properties" file in the developer's
+    home directory.
+  * Default definitions in this build.xml file.
+  You will note below that property values can be composed based on the
+  contents of previously defined properties.  This is a powerful technique
+  that helps you minimize the number of changes required when your development
+  environment is modified.  Note that property composition is allowed within
+  "build.properties" files as well as in the "build.xml" script.
+  <property file="build.properties"/>
+  <property file="${user.home}/build.properties"/>
+  <property file="default.properties"/>
+<!-- ==================== File and Directory Names ======================== -->
+  These properties generally define file and directory names (or paths) that
+  affect where the build process stores its outputs.
+  app.name             Base name of this application, used to
+                       construct filenames and directories.
+                       Defaults to "myapp".
+  app.path             Context path to which this application should be
+                       deployed (defaults to "/" plus the value of the
+                       "app.name" property).
+  app.version          Version number of this iteration of the application.
+  build.home           The directory into which the "prepare" and
+                       "compile" targets will generate their output.
+                       Defaults to "build".
+  dist.home            The name of the base directory in which
+                       distribution files are created.
+                       Defaults to "dist".
+  <property environment="env"/>
+  <property name="app.name" value="proj4js"/>
+  <property name="app.path" value="/${app.name}"/>
+  <property name="app.version" value="1.0.0-RC1"/>
+  <property name="build.home" value="${basedir}/tempBuild"/>
+  <property name="dist.home" value="${basedir}/dist"/>
+  <property name="docs.home" value="${build.home}/docs"/>
+<!-- ==================== Prepare Target ================================== -->
+  The "prepare" target is used to create the "build" destination directory,
+  and copy the static contents of your web application to it.  If you need
+  to copy static files from external dependencies, you can customize the
+  contents of this task.
+  Normally, this task is executed indirectly when needed.
+  <target name="prepare">
+    <!-- Create build directories as needed -->
+    <mkdir dir="${build.home}"/>
+    <!-- Copy static content of the mapbuilder project  -->
+    <copy todir="${build.home}">
+      <fileset dir="${basedir}" excludes="tools/*.pyc "
+          includes="index.html
+                    lib/proj4js.js,
+                    lib/proj4js-combined.js
+                    lib/proj4js-compressed.js
+                    lib/defs/**
+                    lib/projCode/**
+                    build/**
+                    demo/**
+                    test/**
+                    tools/**"
+    </copy>
+  </target>
+<!-- ==================== Clean Target ==================================== -->
+  The "clean" target deletes any previous "build" and "dist" directory,
+  so that you can be ensured the application can be built from scratch.
+  <target description="Delete old build and dist directories" name="clean">
+    <delete dir="${build.home}"/>
+    <delete dir="${dist.home}"/>
+  </target>
+<!-- ==================== Documentation =================================== -->
+  <target description="Create documentation" name="docs" depends="prepare">
+    <mkdir dir="${build.home}/docs"/>
+    <mkdir dir="${build.home}/docs/NaturalDocs"/>
+    <echo message="Generating documentation"/>
+    <exec executable="cmd" os="Windows XP" dir="${build.home}">
+        <arg line="/c perl C:\Progra~1\NaturalDocs\NaturalDocs -i ./lib -o html ./docs/NaturalDocs -p ./docs/NaturalDocs -r"/>
+    </exec>
+  </target>
+<!-- ==================== Dist Target ===================================== -->
+  The "dist" target creates the zip file distribution for the Apache/PHP
+  environment.
+  <target name="dist" description="Create binary distribution" depends="clean,prepare,docs">
+    <mkdir dir="${dist.home}"/>
+    <!-- Create application zip file -->
+    <zip destfile="${dist.home}/${app.name}-${app.version}.zip" update="true">
+      <zipfileset dir="${build.home}" prefix="proj4js"/>
+    </zip>
+  </target>
+</project>
Added: trunk/mapbender/http/extensions/proj4js/build/buildUncompressed.py
--- trunk/mapbender/http/extensions/proj4js/build/buildUncompressed.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/buildUncompressed.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,25 @@
+import sys
+outputFilename = "../lib/proj4js-combined.js"
+merged = file("license.txt").read() + merged
+file(outputFilename, "w").write(merged)
+print "Done."
Added: trunk/mapbender/http/extensions/proj4js/build/library.cfg
--- trunk/mapbender/http/extensions/proj4js/build/library.cfg	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/library.cfg	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,11 @@
+[first]
+proj4js.js
+[last]
+[include]
+projCode/*.js
+defs/GOOGLE.js
+[exclude]
+defs/*
Added: trunk/mapbender/http/extensions/proj4js/build/license.txt
--- trunk/mapbender/http/extensions/proj4js/build/license.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/build/license.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,11 @@
+  proj4js.js -- Javascript reprojection library.
+  Authors:      Mike Adair madairATdmsolutions.ca
+                Richard Greenwood richATgreenwoodmap.com
+                Didier Richard
+                Stephen Irons
+  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+                Note: This program is an almost direct port of the C library
+                Proj4.
Added: trunk/mapbender/http/extensions/proj4js/demo/ProjPane.js
--- trunk/mapbender/http/extensions/proj4js/demo/ProjPane.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/demo/ProjPane.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,91 @@
+var panes = {
+  mapL: {},
+  mapLL: {},
+  mapR: {}
+ProjPane = Class.create();
+ProjPane.prototype = {
+  id: null,
+  map: null,
+  proj: null,
+  initialize: function(pane, code) {
+    this.id = pane;
+    if (code) this.setProj(code);
+  updateCoords: function(coords) {
+    document.getElementById(this.id+'_coords').innerHTML = coords.toString();
+    var pt = this.map.getLayerPxFromLonLat(coords);
+    this.marker.moveTo(pt);
+  setProj: function(code) {
+    document.getElementById(this.id+'_proj').value = code;
+    this.proj = new Proj4js.Proj(code);
+    var mapDef = Proj4js.maps[this.proj.srsCode];
+    if (this.map) this.map.destroy();
+    this.map = new OpenLayers.Map(this.id, mapDef.mapOptions);
+    this.mapLayer = new OpenLayers.Layer.WMS(mapDef.layerName, mapDef.layerUrl, mapDef.layerParams, mapDef.layerOptions);
+    this.map.addLayer(this.mapLayer);
+    this.map.addLayer(new OpenLayers.Layer.Markers(''));
+    this.marker = new OpenLayers.Marker(new OpenLayers.LonLat(0,0));
+    this.map.layers[1].addMarker(this.marker);
+    this.marker.map = this.map;
+    if (window.bounds) {
+      this.map.addLayer(new OpenLayers.Layer.Boxes());
+      this.map.layers[2].addMarker(new OpenLayers.Marker.Box(bounds));
+      this.map.setCenter(bounds.getCenterLonLat());
+    } else {
+      this.map.zoomToMaxExtent();
+    this.map.events.register('click', this.map, this.mapClicked.bind(this));
+    document.getElementById(this.id+'_units').innerHTML = this.proj.units;
+    document.getElementById(this.id+'_title').innerHTML = this.proj.title;
+    document.getElementById(this.id+'_class').innerHTML = this.proj.projName;
+  mapClicked: function(ev) {
+    var olc = this.map.getLonLatFromViewPortPx(ev.xy);
+    c = new Proj4js.Point(olc.lon, olc.lat);
+    this.updateCoords(c);
+    if (this.opposite && this.opposite.proj) {
+      var newCoords = this.proj.transform(c, this.opposite.proj);
+      this.opposite.updateCoords(newCoords);
+    if (this.common) {
+      var newCoords = this.proj.inverse(c);
+      this.common.updateCoords(newCoords);
+    if (this.projected1 && this.projected1.proj) {
+      var newCoords = this.projected1.proj.forward(c);
+      this.projected1.updateCoords(newCoords);
+    if (this.projected2 && this.projected2.proj) {
+      var newCoords = this.projected2.proj.forward(c);
+      this.projected2.updateCoords(newCoords);
+function init() {
+  panes['mapLL'] = new ProjPane('mapLL',Proj4js.defaultDatum);
+  panes['mapL'] = new ProjPane('mapL');
+  panes['mapR'] = new ProjPane('mapR');
+  panes['mapLL'].projected1 = panes['mapL'];
+  panes['mapLL'].projected2 = panes['mapR'];
+  panes['mapL'].opposite = panes['mapR'];
+  panes['mapR'].opposite = panes['mapL'];
+  panes['mapL'].common = panes['mapLL'];
+  panes['mapR'].common = panes['mapLL'];
Added: trunk/mapbender/http/extensions/proj4js/demo/base.css
--- trunk/mapbender/http/extensions/proj4js/demo/base.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/demo/base.css	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,22 @@
+#footer {
+  margin-top: 20px;
+  border-top: 1px solid #eee;
+  padding: 10px;
+body {
+ font-family:Verdana;
+#header {
+  background: #9D9FA1;
+  color: #FFFFFF;
+  font-family: "Trebuchet MS", Helvetica, Arial, sans-serif;
+  font-size: 18px;
+  text-shadow: 2px 2px 3px gray;
+  height: 3em;
+  padding: 4px 16px 0px 16px;
+  vertical-align: top;
+  margin:-10px -5px 0px -5px;
+  border-bottom: 10px solid #e9eef9;
+#header h1{margin-top: 0px;font-weight:normal;}
+#navbar { background-color: #eee; margin: 0px -5px 10px -5px; padding: 10px;  }
Added: trunk/mapbender/http/extensions/proj4js/demo/index.html
--- trunk/mapbender/http/extensions/proj4js/demo/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/demo/index.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,20 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+  <link href="base.css" type="text/css" rel="stylesheet"/>
+  <title>Proj4js Demonstration Page</title>
+  <script src="http://openlayers.org/api/OpenLayers.js"></script>
+  <script src="../lib/proj4js.js"></script>
+  <script src="../lib/maps/EPSG27563.js"></script>
+  <!--script src="../lib/defs/EPSG27563.js"></script-->
+  <script src="ProjPane.js"></script>
+</head>
+<body onload="init()">
+  <div id="header">
+    <h1>Proj4js demo page</h1>
+    <p>coming soon!</p>
+  </div>
+</body>
+</html>
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG27563.js
--- trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG27563.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG27563.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,11 @@
+Proj4js.maps.EPSG27563 = {
+  mapOptions: {
+    projection: 'EPSG:27563',
+    units: 'm',
+    maxResolution: 2000000/512
+  layerName: 'metacarta default',
+  layerUrl: 'http://labs.metacarta.com/wms-c/Basic.py',
+  layerParams: {'layers':'basic'},
+  layerOptions: null
Added: trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG42304.js
--- trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG42304.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/demo/maps/EPSG42304.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,12 @@
+Proj4js.maps.EPSG43204 = {
+  mapOptions : {
+    maxExtent: new OpenLayers.Bounds(-3631568.75,-1293815.5,4491139.5833333321,4937122),
+    scales: [50000000,23207944.16806,10772173.45016,5000000,2320794.41681,1077217.34502,500000,232079.44168,107721.7345,50000],
+    units: 'm',
+    projection: 'EPSG:42304'
+  layerName: 'DM Solutions Demo',
+  layerUrl: "http://localhost/cgi-bin/mapserv.exe?MAP=/ms4w/apps/gmap/htdocs/gmap75_wms.map",
+  layerParams: {layers: "bathymetry,land_fn,park,drain_fn,drainage,prov_bound,fedlimit,rail,road,popplace", transparent: "false", format: "image/png" },
+  layerOptions: {singleTile: true}
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ClassHierarchy.nd
(Binary files differ)
Property changes on: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ClassHierarchy.nd
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ConfigFileInfo.nd
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ConfigFileInfo.nd	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/ConfigFileInfo.nd	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+#HæzÐHæzÐHæzÐHæzÐHæzÐ
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/FileInfo.nd
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/FileInfo.nd	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/FileInfo.nd	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,45 @@
+1.35
+JavaScript
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG26591.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG26591.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\utm.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\utm.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG102758.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG102758.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\sinu.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\sinu.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\gauss.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\gauss.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG900913.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG900913.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4272.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4272.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG26912.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG26912.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\nzmg.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\nzmg.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\proj4js-compressed.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\proj4js-compressed.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\GOOGLE.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\GOOGLE.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\proj4js-combined.js	1223064271	1	Proj4js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\omerc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\omerc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\aeqd.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\aeqd.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\equi.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\equi.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\lcc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\lcc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG42304.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG42304.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG41001.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG41001.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\laea.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\laea.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4302.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4302.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG102757.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG102757.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\sterea.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\sterea.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4181.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4181.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG27563.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG27563.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\merc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\merc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\gstmerc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\gstmerc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\stere.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\stere.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\moll.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\moll.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\poly.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\poly.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\vandg.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\vandg.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\mill.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\mill.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\ortho.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\ortho.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG27200.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG27200.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\aea.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\aea.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\eqdc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\eqdc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG900913.txt	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG900913.txt
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\proj4js.js	1223064271	1	Proj4js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG21781.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG21781.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\eqc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\eqc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\geocent.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\geocent.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\somerc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\somerc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\tmerc.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\projCode\tmerc.js
+C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4139.js	1223064271	0	C:\Documents and Settings\Mike\My Documents\devtree\osgeo\proj4js\tags\proj4js-1.0.0-RC1\tempBuild\lib\defs\EPSG4139.js
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousMenuState.nd
Property changes on: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousMenuState.nd
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousSettings.nd
Property changes on: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/PreviousSettings.nd
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/SymbolTable.nd
Property changes on: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Data/SymbolTable.nd
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Languages.txt
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Languages.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Languages.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,113 @@
+Format: 1.35
+# This is the Natural Docs languages file for this project.  If you change
+# anything here, it will apply to THIS PROJECT ONLY.  If you'd like to change
+# something for all your projects, edit the Languages.txt in Natural Docs'
+# Config directory instead.
+# You can prevent certain file extensions from being scanned like this:
+# Ignore Extensions: [extension] [extension] ...
+# SYNTAX:
+# Unlike other Natural Docs configuration files, in this file all comments
+# MUST be alone on a line.  Some languages deal with the # character, so you
+# cannot put comments on the same line as content.
+# Also, all lists are separated with spaces, not commas, again because some
+# languages may need to use them.
+# Language: [name]
+# Alter Language: [name]
+#    Defines a new language or alters an existing one.  Its name can use any
+#    characters.  If any of the properties below have an add/replace form, you
+#    must use that when using Alter Language.
+#    The language Shebang Script is special.  It's entry is only used for
+#    extensions, and files with those extensions have their shebang (#!) lines
+#    read to determine the real language of the file.  Extensionless files are
+#    always treated this way.
+#    The language Text File is also special.  It's treated as one big comment
+#    so you can put Natural Docs content in them without special symbols.  Also,
+#    if you don't specify a package separator, ignored prefixes, or enum value
+#    behavior, it will copy those settings from the language that is used most
+#    in the source tree.
+# Extensions: [extension] [extension] ...
+# [Add/Replace] Extensions: [extension] [extension] ...
+#    Defines the file extensions of the language's source files.  You can
+#    redefine extensions found in the main languages file.  You can use * to
+#    mean any undefined extension.
+# Shebang Strings: [string] [string] ...
+# [Add/Replace] Shebang Strings: [string] [string] ...
+#    Defines a list of strings that can appear in the shebang (#!) line to
+#    designate that it's part of the language.  You can redefine strings found
+#    in the main languages file.
+# Ignore Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
+# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+#    Specifies prefixes that should be ignored when sorting symbols in an
+#    index.  Can be specified in general or for a specific topic type.
+# For basic language support only:
+# Line Comments: [symbol] [symbol] ...
+#    Defines a space-separated list of symbols that are used for line comments,
+#    if any.
+# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
+#    Defines a space-separated list of symbol pairs that are used for block
+#    comments, if any.
+# Package Separator: [symbol]
+#    Defines the default package separator symbol.  The default is a dot.
+# [Topic Type] Prototype Enders: [symbol] [symbol] ...
+#    When defined, Natural Docs will attempt to get a prototype from the code
+#    immediately following the topic type.  It stops when it reaches one of
+#    these symbols.  Use \n for line breaks.
+# Line Extender: [symbol]
+#    Defines the symbol that allows a prototype to span multiple lines if
+#    normally a line break would end it.
+# Enum Values: [global|under type|under parent]
+#    Defines how enum values are referenced.  The default is global.
+#    global       - Values are always global, referenced as 'value'.
+#    under type   - Values are under the enum type, referenced as
+#               'package.enum.value'.
+#    under parent - Values are under the enum's parent, referenced as
+#               'package.value'.
+# Perl Package: [perl package]
+#    Specifies the Perl package used to fine-tune the language behavior in ways
+#    too complex to do in this file.
+# For full language support only:
+# Full Language Support: [perl package]
+#    Specifies the Perl package that has the parsing routines necessary for full
+#    language support.
+# The following languages are defined in the main file, if you'd like to alter
+# them:
+#    Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
+#    PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
+#    ActionScript, ColdFusion, R, Fortran
+# If you add a language that you think would be useful to other developers
+# and should be included in Natural Docs by default, please e-mail it to
+# languages [at] naturaldocs [dot] org.
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Menu.txt
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Menu.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Menu.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,43 @@
+Format: 1.35
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu.  Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries.  Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file.  Natural Docs will clean it up the next
+# time it is run.  When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+File: Proj4js  (proj4js.js)
+File: Proj4js  (proj4js-combined.js)
+Group: Index  {
+   Index: Everything
+   Class Index: Classes
+   Function Index: Functions
+   Property Index: Properties
+   }  # Group: Index
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Topics.txt
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Topics.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/Topics.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,84 @@
+Format: 1.35
+# This is the Natural Docs topics file for this project.  If you change anything
+# here, it will apply to THIS PROJECT ONLY.  If you'd like to change something
+# for all your projects, edit the Topics.txt in Natural Docs' Config directory
+# instead.
+# If you'd like to prevent keywords from being recognized by Natural Docs, you
+# can do it like this:
+# Ignore Keywords: [keyword], [keyword], ...
+# Or you can use the list syntax like how they are defined:
+# Ignore Keywords:
+#    [keyword]
+#    [keyword], [plural keyword]
+# SYNTAX:
+# Topic Type: [name]
+# Alter Topic Type: [name]
+#    Creates a new topic type or alters one from the main file.  Each type gets
+#    its own index and behavior settings.  Its name can have letters, numbers,
+#    spaces, and these charaters: - / . '
+# Plural: [name]
+#    Sets the plural name of the topic type, if different.
+# Keywords:
+#    [keyword]
+#    Defines or adds to the list of keywords for the topic type.  They may only
+#    contain letters, numbers, and spaces and are not case sensitive.  Plural
+#    keywords are used for list topics.  You can redefine keywords found in the
+#    main topics file.
+# Index: [yes|no]
+#    Whether the topics get their own index.  Defaults to yes.  Everything is
+#    included in the general index regardless of this setting.
+# Scope: [normal|start|end|always global]
+#    How the topics affects scope.  Defaults to normal.
+#    normal        - Topics stay within the current scope.
+#    start         - Topics start a new scope for all the topics beneath it,
+#                    like class topics.
+#    end           - Topics reset the scope back to global for all the topics
+#                    beneath it.
+#    always global - Topics are defined as global, but do not change the scope
+#                    for any other topics.
+# Class Hierarchy: [yes|no]
+#    Whether the topics are part of the class hierarchy.  Defaults to no.
+# Variable Type: [yes|no]
+#    Whether the topics can be a variable type.  Defaults to no.
+# Page Title If First: [yes|no]
+#    Whether the topic's title becomes the page title if it's the first one in
+#    a file.  Defaults to no.
+# Break Lists: [yes|no]
+#    Whether list topics should be broken into individual topics in the output.
+#    Defaults to no.
+# Can Group With: [type], [type], ...
+#    Defines a list of topic types that this one can possibly be grouped with.
+#    Defaults to none.
+# The following topics are defined in the main file, if you'd like to alter
+# their behavior or add keywords:
+#    Generic, Class, Interface, Section, File, Group, Function, Variable,
+#    Property, Type, Constant, Enumeration, Event, Delegate, Macro,
+#    Database, Database Table, Database View, Database Index, Database
+#    Cursor, Database Trigger, Cookie, Build Target
+# If you add something that you think would be useful to other developers
+# topics [at] naturaldocs [dot] org.
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-combined-js.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-combined-js.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-combined-js.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,94 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Proj4js</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class=UnframedPage onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.35 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile><a href="proj4js-js.html">Proj4js</a></div></div><div class=MEntry><div class=MFile id=MSelected>Proj4js</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Properties.html">Properties</a></div></div></div></div></div><!--END_ND_MENU--></td>
+<td class=ContentSection valign=top><div class=CClass id=MainTopic><div class=CTopic><h1 class=CTitle><a name="Proj4js"></a>Proj4js</h1><div class=CBody><p class=CParagraph>Proj4js is a JavaScript library to transform point coordinates from one coordinate system to another, including datum transformations.</p><p class=CParagraph>This library is a port of both the Proj.4 and GCTCP C libraries to JavaScript.&nbsp; Enabling these transformations in the browser allows geographic data stored in different projections to be combined in browser-based web mapping applications.</p><p class=CParagraph>Proj4js must have access to coordinate system initialization strings (which are the same as for PROJ.4 command line).&nbsp;  Thes can be included in your application using a &lt;script&gt; tag or Proj4js can load CS initialization strings from a local directory or a web service such as spatialreference.org.</p><p class=CParagraph>Similarly, Proj4js must have access to projection transform code.&nbsp;  These can be included individually using a &lt;script&gt; tag in your page, built into a custom build of Proj4js or loaded dynamically at run-time.&nbsp;  Using the -combined and -compressed versions of Proj4js includes all projection class code by default.</p><p class=CParagraph>Note that dynamic loading of defs and code happens ascynchrously, check the Proj.readyToUse flag before using the Proj object.&nbsp;  If the defs and code required by your application are loaded through script tags, dynamic loading is not required and the Proj object will be readyToUse on return from the constructor.</p><p class=CParagraph>All coordinates are handled as points which have a .x and a .y property which will be modified in place.</p><p class=CParagraph>Override Proj4js.reportError for output of alerts and warnings.</p><p class=CParagraph>See <a href="http://trac.osgeo.org/proj4js/wiki/UserGuide" class=LURL>http://trac.osgeo.org/proj4js/wiki/UserGuide</a> for full details.</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr><td class=SEntrySize><div class=SMain><div class=SEntry><a href="#Proj4js" >Proj4js</a></div></div></td><td class=SDescriptionSize><div class=SMain><div class=SDescription>Proj4js is a JavaScript library to transform point coordinates from one coordinate system to another, including datum transformations.</div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><div class=SIndent1><a href="#Proj4js.Properties" >Properties</a></div></div></div></td><td><div class=SGroup><div class=SDescription><div class=SIndent1></div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.defaultDatum" >defaultDatum</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>The datum to use when no others a specified</div></div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><div class=SIndent1><a href="#Proj4js.Functions" >Functions</a></div></div></div></td><td><div class=SGroup><div class=SDescription><div class=SIndent1></div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.transform(source,dest,point)" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">transform(source, dest, point)</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Transform a point coordinate from one map projection to another. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.reportError" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">reportError</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>An internal method to report errors back to user. </div></div></div></td></tr><tr><td><div class=SSection><div class=SEntry><a href="#Private_Methods" >Private Methods</a></div></div></td><td><div class=SSection><div class=SDescription>The following properties and methods are intended for internal use only.</div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><div class=SIndent1><a href="#Functions_and_Properties" >Functions and Properties</a></div></div></div></td><td><div class=SGroup><div class=SDescription><div class=SIndent1></div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#extend" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">extend</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Copy all properties of a source object to a destination object. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Class" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">Class</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Base class used to construct all other classes. </div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#bind" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">bind</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Bind a function to an object. </div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#defsLookupService" >defsLookupService</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>AJAX service to retreive projection definition parameters from</div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#libPath" >libPath</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>internal: http server path to library code.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#getScriptLocation" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')">getScriptLocation</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Return the path to this script.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#loadScript" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')">loadScript</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Load a JS file from a URL into a &lt;script&gt; tag in the page.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#checkReadyState" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')">checkReadyState</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>IE workaround since there is no onerror handler. </div></div></div></td></tr><tr><td><div class=SClass><div class=SEntry><a href="#Proj4js.Proj" >Proj4js.Proj</a></div></div></td><td><div class=SClass><div class=SDescription>Proj objects provide transformation methods for point coordinates between geodetic latitude/longitude and a projected coordinate system. </div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.Properties" >Properties</a></div></div></div></td><td><div class=SGroup><div class=SDescription><div class=SIndent1></div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.readyToUse" >readyToUse</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>Flag to indicate if initialization is complete for this Proj object</div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.title" >title</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>The title to describe the projection</div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.projName" >projName</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>The projection class for this projection, e.g. </div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.units" >units</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>The units of the projection. </div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.datum" >datum</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent2>The datum specified for the projection</div></div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.Functions" >Functions</a></div></div></div></td><td><div class=SGroup><div class=SDescription><div class=SIndent1></div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.initialize" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')">initialize</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Constructor for Proj4js.Proj objects</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.loadProjDefinition" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')">loadProjDefinition</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Loads the coordinate system initialization string if required. </div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.loadFromService" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')">loadFromService</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Creates the REST URL for loading the definition from a web service and loads it.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.defsLoaded" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')">defsLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Continues the Proj object initilization once the def file is loaded</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.checkDefsLoaded" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')">checkDefsLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>This is the loadCheck method to see if the def object exists</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.defsFailed" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')">defsFailed</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Report an error in loading the defs file, but continue on using WGS84</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.loadProjCode" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')">loadProjCode</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Loads projection class code dynamically if required. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.loadProjCodeSuccess" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')">loadProjCodeSuccess</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Loads any proj dependencies or continue on to final initialization.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.defsFailed" >defsFailed</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Report an error in loading the proj file. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.checkCodeLoaded" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')">checkCodeLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>This is the loadCheck method to see if the projection code is loaded</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.initTransforms" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')">initTransforms</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Finalize the initialization of the Proj object</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.parseDefs" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')">parseDefs</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Parses the PROJ.4 initialization string and sets the associated properties.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent2><a href="#Proj4js.Proj.deriveConstants" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')">deriveConstants</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent2>Sets several derived constant values and initialization of datum and ellipse parameters.</div></div></div></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class=CGroup><div class=CTopic><h3 class=CTitle><a name="Proj4js.Properties"></a>Properties</h3></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.defaultDatum"></a>defaultDatum</h3><div class=CBody><p class=CParagraph>The datum to use when no others a specified</p></div></div></div>
+<div class=CGroup><div class=CTopic><h3 class=CTitle><a name="Proj4js.Functions"></a>Functions</h3></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.transform(source,dest,point)"></a>transform(source, dest, point)</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>transform: function(</td><td class=PParameter nowrap>source,</td></tr><tr><td></td><td class=PParameter nowrap>dest,</td></tr><tr><td></td><td class=PParameter nowrap>point</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Transform a point coordinate from one map projection to another.&nbsp;  This is really the only public method you should need to use.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>source</td><td class=CDLDescription>{Proj4js.Proj} source map projection for the transformation</td></tr><tr><td class=CDLEntry>dest</td><td class=CDLDescription>{Proj4js.Proj} destination map projection for the transformation</td></tr><tr><td class=CDLEntry>point</td><td class=CDLDescription>{Object} point to transform, may be geodetic (long, lat) or projected Cartesian (x,y), but should always have x,y properties.</td></tr></table></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.reportError"></a>reportError</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>reportError: function(</td><td class=PParameter nowrap>msg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>An internal method to report errors back to user.&nbsp; Override this in applications to report error messages or throw exceptions.</p></div></div></div>
+<div class=CSection><div class=CTopic><h2 class=CTitle><a name="Private_Methods"></a>Private Methods</h2><div class=CBody><p class=CParagraph>The following properties and methods are intended for internal use only.</p><p class=CParagraph>This is a minimal implementation of JavaScript inheritance methods so that Proj4js can be used as a stand-alone library.&nbsp; These are copies of the equivalent OpenLayers methods at v2.7</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr><td class=SEntrySize><div class=SGroup><div class=SEntry><a href="#Functions_and_Properties" >Functions and Properties</a></div></div></td><td class=SDescriptionSize><div class=SGroup><div class=SDescription></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#extend" id=link21 onMouseOver="ShowTip(event, 'tt3', 'link21')" onMouseOut="HideTip('tt3')">extend</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Copy all properties of a source object to a destination object. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Class" id=link22 onMouseOver="ShowTip(event, 'tt4', 'link22')" onMouseOut="HideTip('tt4')">Class</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Base class used to construct all other classes. </div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#bind" id=link23 onMouseOver="ShowTip(event, 'tt5', 'link23')" onMouseOut="HideTip('tt5')">bind</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Bind a function to an object. </div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#defsLookupService" >defsLookupService</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>AJAX service to retreive projection definition parameters from</div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#libPath" >libPath</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>internal: http server path to library code.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#getScriptLocation" id=link24 onMouseOver="ShowTip(event, 'tt6', 'link24')" onMouseOut="HideTip('tt6')">getScriptLocation</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Return the path to this script.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#loadScript" id=link25 onMouseOver="ShowTip(event, 'tt7', 'link25')" onMouseOut="HideTip('tt7')">loadScript</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Load a JS file from a URL into a &lt;script&gt; tag in the page.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#checkReadyState" id=link26 onMouseOver="ShowTip(event, 'tt8', 'link26')" onMouseOut="HideTip('tt8')">checkReadyState</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>IE workaround since there is no onerror handler. </div></div></div></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class=CGroup><div class=CTopic><h3 class=CTitle><a name="Functions_and_Properties"></a>Functions and Properties</h3></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="extend"></a>extend</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>extend: function(</td><td class=PParameter nowrap>destination,</td></tr><tr><td></td><td class=PParameter nowrap>source</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Copy all properties of a source object to a destination object.&nbsp;  Modifies the passed in destination object.&nbsp;  Any properties on the source object that are set to undefined will not be (re)set on the destination object.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>destination</td><td class=CDLDescription>{Object} The object that will be modified</td></tr><tr><td class=CDLEntry>source</td><td class=CDLDescription>{Object} The object with properties to be set on the destination</td></tr></table><h4 class=CHeading>Returns</h4><p class=CParagraph>{Object} The destination object.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Class"></a>Class</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Class: function()</td></tr></table></blockquote><p class=CParagraph>Base class used to construct all other classes.&nbsp; Includes support for multiple inheritance.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="bind"></a>bind</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>bind: function(</td><td class=PParameter nowrap>func,</td></tr><tr><td></td><td class=PParameter nowrap>object</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Bind a function to an object.&nbsp;  Method to easily create closures with &lsquo;this&rsquo; altered.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>func</td><td class=CDLDescription>{Function} Input function.</td></tr><tr><td class=CDLEntry>object</td><td class=CDLDescription>{Object} The object to bind to the input function (as this).</td></tr></table><h4 class=CHeading>Returns</h4><p class=CParagraph>{Function} A closure with &lsquo;this&rsquo; set to the passed in object.</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="defsLookupService"></a>defsLookupService</h3><div class=CBody><p class=CParagraph>AJAX service to retreive projection definition parameters from</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="libPath"></a>libPath</h3><div class=CBody><p class=CParagraph>internal: http server path to library code.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="getScriptLocation"></a>getScriptLocation</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>getScriptLocation: function ()</td></tr></table></blockquote><p class=CParagraph>Return the path to this script.</p><h4 class=CHeading>Returns</h4><p class=CParagraph>Path to this script</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="loadScript"></a>loadScript</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadScript: function(</td><td class=PParameter nowrap>url,</td></tr><tr><td></td><td class=PParameter nowrap>onload,</td></tr><tr><td></td><td class=PParameter nowrap>onfail,</td></tr><tr><td></td><td class=PParameter nowrap>loadCheck</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Load a JS file from a URL into a &lt;script&gt; tag in the page.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>url</td><td class=CDLDescription>{String} The URL containing the script to load</td></tr><tr><td class=CDLEntry>onload</td><td class=CDLDescription>{Function} A method to be executed when the script loads successfully</td></tr><tr><td class=CDLEntry>onfail</td><td class=CDLDescription>{Function} A method to be executed when there is an error loading the script</td></tr><tr><td class=CDLEntry>loadCheck</td><td class=CDLDescription>{Function} A boolean method that checks to see if the script has loaded.&nbsp;  Typically this just checks for the existance of an object in the file just loaded.</td></tr></table></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="checkReadyState"></a>checkReadyState</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkReadyState: function()</td></tr></table></blockquote><p class=CParagraph>IE workaround since there is no onerror handler.&nbsp;  Calls the user defined loadCheck method to determine if the script is loaded.</p></div></div></div>
+<div class=CClass><div class=CTopic><h2 class=CTitle><a name="Proj4js.Proj"></a>Proj4js.Proj</h2><div class=CBody><p class=CParagraph>Proj objects provide transformation methods for point coordinates between geodetic latitude/longitude and a projected coordinate system. once they have been initialized with a projection code.</p><p class=CParagraph>Initialization of Proj objects is with a projection code, usually EPSG codes, which is the key that will be used with the Proj4js.defs array.</p><p class=CParagraph>The code passed in will be stripped of colons and converted to uppercase to locate projection definition files.</p><p class=CParagraph>A projection object has properties for units and title strings.</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr><td class=SEntrySize><div class=SGroup><div class=SEntry><a href="#Proj4js.Proj.Properties" >Properties</a></div></div></td><td class=SDescriptionSize><div class=SGroup><div class=SDescription></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.readyToUse" >readyToUse</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>Flag to indicate if initialization is complete for this Proj object</div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.title" >title</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>The title to describe the projection</div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.projName" >projName</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>The projection class for this projection, e.g. </div></div></div></td></tr><tr><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.units" >units</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>The units of the projection. </div></div></div></td></tr><tr class=SMarked><td><div class=SProperty><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.datum" >datum</a></div></div></div></td><td><div class=SProperty><div class=SDescription><div class=SIndent1>The datum specified for the projection</div></div></div></td></tr><tr><td><div class=SGroup><div class=SEntry><a href="#Proj4js.Proj.Functions" >Functions</a></div></div></td><td><div class=SGroup><div class=SDescription></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.initialize" id=link27 onMouseOver="ShowTip(event, 'tt9', 'link27')" onMouseOut="HideTip('tt9')">initialize</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Constructor for Proj4js.Proj objects</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.loadProjDefinition" id=link28 onMouseOver="ShowTip(event, 'tt10', 'link28')" onMouseOut="HideTip('tt10')">loadProjDefinition</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Loads the coordinate system initialization string if required. </div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.loadFromService" id=link29 onMouseOver="ShowTip(event, 'tt11', 'link29')" onMouseOut="HideTip('tt11')">loadFromService</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Creates the REST URL for loading the definition from a web service and loads it.</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.defsLoaded" id=link30 onMouseOver="ShowTip(event, 'tt12', 'link30')" onMouseOut="HideTip('tt12')">defsLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Continues the Proj object initilization once the def file is loaded</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.checkDefsLoaded" id=link31 onMouseOver="ShowTip(event, 'tt13', 'link31')" onMouseOut="HideTip('tt13')">checkDefsLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>This is the loadCheck method to see if the def object exists</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.defsFailed" id=link32 onMouseOver="ShowTip(event, 'tt14', 'link32')" onMouseOut="HideTip('tt14')">defsFailed</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Report an error in loading the defs file, but continue on using WGS84</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.loadProjCode" id=link33 onMouseOver="ShowTip(event, 'tt15', 'link33')" onMouseOut="HideTip('tt15')">loadProjCode</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Loads projection class code dynamically if required. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.loadProjCodeSuccess" id=link34 onMouseOver="ShowTip(event, 'tt16', 'link34')" onMouseOut="HideTip('tt16')">loadProjCodeSuccess</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Loads any proj dependencies or continue on to final initialization.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.defsFailed" >defsFailed</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Report an error in loading the proj file. </div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.checkCodeLoaded" id=link35 onMouseOver="ShowTip(event, 'tt17', 'link35')" onMouseOut="HideTip('tt17')">checkCodeLoaded</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>This is the loadCheck method to see if the projection code is loaded</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.initTransforms" id=link36 onMouseOver="ShowTip(event, 'tt18', 'link36')" onMouseOut="HideTip('tt18')">initTransforms</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Finalize the initialization of the Proj object</div></div></div></td></tr><tr><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.parseDefs" id=link37 onMouseOver="ShowTip(event, 'tt19', 'link37')" onMouseOut="HideTip('tt19')">parseDefs</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Parses the PROJ.4 initialization string and sets the associated properties.</div></div></div></td></tr><tr class=SMarked><td><div class=SFunction><div class=SEntry><div class=SIndent1><a href="#Proj4js.Proj.deriveConstants" id=link38 onMouseOver="ShowTip(event, 'tt20', 'link38')" onMouseOut="HideTip('tt20')">deriveConstants</a></div></div></div></td><td><div class=SFunction><div class=SDescription><div class=SIndent1>Sets several derived constant values and initialization of datum and ellipse parameters.</div></div></div></td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class=CGroup><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.Properties"></a>Properties</h3></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.readyToUse"></a>readyToUse</h3><div class=CBody><p class=CParagraph>Flag to indicate if initialization is complete for this Proj object</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.title"></a>title</h3><div class=CBody><p class=CParagraph>The title to describe the projection</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.projName"></a>projName</h3><div class=CBody><p class=CParagraph>The projection class for this projection, e.g. lcc (lambert conformal conic, or merc for mercator.&nbsp;  These are exactly equicvalent to their Proj4 counterparts.</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.units"></a>units</h3><div class=CBody><p class=CParagraph>The units of the projection.&nbsp;  Values include &lsquo;m&rsquo; and &lsquo;degrees&rsquo;</p></div></div></div>
+<div class=CProperty><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.datum"></a>datum</h3><div class=CBody><p class=CParagraph>The datum specified for the projection</p></div></div></div>
+<div class=CGroup><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.Functions"></a>Functions</h3></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.initialize"></a>initialize</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>initialize: function(</td><td class=PParameter nowrap>srsCode</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Constructor for Proj4js.Proj objects</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>srsCode</td><td class=CDLDescription>a code for map projection definition parameters.&nbsp;  These are usually (but not always) EPSG codes.</td></tr></table></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.loadProjDefinition"></a>loadProjDefinition</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadProjDefinition: function()</td></tr></table></blockquote><p class=CParagraph>Loads the coordinate system initialization string if required.&nbsp; Note that dynamic loading happens asynchronously so an application must wait for the readyToUse property is set to true.&nbsp; To prevent dynamic loading, include the defs through a script tag in your application.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.loadFromService"></a>loadFromService</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadFromService: function()</td></tr></table></blockquote><p class=CParagraph>Creates the REST URL for loading the definition from a web service and loads it.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.defsLoaded"></a>defsLoaded</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsLoaded: function()</td></tr></table></blockquote><p class=CParagraph>Continues the Proj object initilization once the def file is loaded</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.checkDefsLoaded"></a>checkDefsLoaded</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkDefsLoaded: function()</td></tr></table></blockquote><p class=CParagraph>This is the loadCheck method to see if the def object exists</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.defsFailed"></a>defsFailed</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsFailed: function()</td></tr></table></blockquote><p class=CParagraph>Report an error in loading the defs file, but continue on using WGS84</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.loadProjCode"></a>loadProjCode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCode: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Loads projection class code dynamically if required.&nbsp; Projection code may be included either through a script tag or in a built version of proj4js</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.loadProjCodeSuccess"></a>loadProjCodeSuccess</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCodeSuccess: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>Loads any proj dependencies or continue on to final initialization.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.defsFailed"></a>defsFailed</h3><div class=CBody><p class=CParagraph>Report an error in loading the proj file.&nbsp;  Initialization of the Proj object has failed and the readyToUse flag will never be set.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.checkCodeLoaded"></a>checkCodeLoaded</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>checkCodeLoaded: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p class=CParagraph>This is the loadCheck method to see if the projection code is loaded</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.initTransforms"></a>initTransforms</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>initTransforms: function()</td></tr></table></blockquote><p class=CParagraph>Finalize the initialization of the Proj object</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.parseDefs"></a>parseDefs</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>parseDefs: function()</td></tr></table></blockquote><p class=CParagraph>Parses the PROJ.4 initialization string and sets the associated properties.</p></div></div></div>
+<div class=CFunction><div class=CTopic><h3 class=CTitle><a name="Proj4js.Proj.deriveConstants"></a>deriveConstants</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>deriveConstants: function()</td></tr></table></blockquote><p class=CParagraph>Sets several derived constant values and initialization of datum and ellipse parameters.</p></div></div></div>
+</td>
+</tr></table><div class=Footer><!--START_ND_FOOTER-->Generated by <a href="http://www.naturaldocs.org">Natural Docs</a><!--END_ND_FOOTER--></div>
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>transform: function(</td><td class=PParameter nowrap>source,</td></tr><tr><td></td><td class=PParameter nowrap>dest,</td></tr><tr><td></td><td class=PParameter nowrap>point</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Transform a point coordinate from one map projection to another. </div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>reportError: function(</td><td class=PParameter nowrap>msg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>An internal method to report errors back to user. </div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>extend: function(</td><td class=PParameter nowrap>destination,</td></tr><tr><td></td><td class=PParameter nowrap>source</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Copy all properties of a source object to a destination object. </div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Class: function()</td></tr></table></blockquote>Base class used to construct all other classes. </div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>bind: function(</td><td class=PParameter nowrap>func,</td></tr><tr><td></td><td class=PParameter nowrap>object</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Bind a function to an object. </div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>getScriptLocation: function ()</td></tr></table></blockquote>Return the path to this script.</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadScript: function(</td><td class=PParameter nowrap>url,</td></tr><tr><td></td><td class=PParameter nowrap>onload,</td></tr><tr><td></td><td class=PParameter nowrap>onfail,</td></tr><tr><td></td><td class=PParameter nowrap>loadCheck</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Load a JS file from a URL into a script tag in the page.</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkReadyState: function()</td></tr></table></blockquote>IE workaround since there is no onerror handler. </div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>initialize: function(</td><td class=PParameter nowrap>srsCode</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Constructor for Proj4js.Proj objects</div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadProjDefinition: function()</td></tr></table></blockquote>Loads the coordinate system initialization string if required. </div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadFromService: function()</td></tr></table></blockquote>Creates the REST URL for loading the definition from a web service and loads it.</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsLoaded: function()</td></tr></table></blockquote>Continues the Proj object initilization once the def file is loaded</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkDefsLoaded: function()</td></tr></table></blockquote>This is the loadCheck method to see if the def object exists</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsFailed: function()</td></tr></table></blockquote>Report an error in loading the defs file, but continue on using WGS84</div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCode: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads projection class code dynamically if required. </div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCodeSuccess: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads any proj dependencies or continue on to final initialization.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>checkCodeLoaded: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>This is the loadCheck method to see if the projection code is loaded</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>initTransforms: function()</td></tr></table></blockquote>Finalize the initialization of the Proj object</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>parseDefs: function()</td></tr></table></blockquote>Parses the PROJ.4 initialization string and sets the associated properties.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>deriveConstants: function()</td></tr></table></blockquote>Sets several derived constant values and initialization of datum and ellipse parameters.</div></div><!--END_ND_TOOLTIPS-->
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-js.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-js.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/files/proj4js-js.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,94 @@
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile id=MSelected>Proj4js</div></div><div class=MEntry><div class=MFile><a href="proj4js-combined-js.html">Proj4js</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Properties.html">Properties</a></div></div></div></div></div><!--END_ND_MENU--></td>
+</td>
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Classes.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Classes.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Classes.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,16 @@
+<html><head><title>Class Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class=UnframedPage onLoad="NDOnLoad()"><script language=JavaScript><!--
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile><a href="../files/proj4js-js.html">Proj4js</a></div></div><div class=MEntry><div class=MFile><a href="../files/proj4js-combined-js.html">Proj4js</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div></div></div></div><!--END_ND_MENU--></td><td class=IndexSection valign=top><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; M &middot; N &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; R &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js" id=link2 onMouseOver="ShowTip(event, 'tt1', 'link2')" onMouseOut="HideTip('tt1')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj" id=link3 onMouseOver="ShowTip(event, 'tt2', 'link3')" onMouseOut="HideTip('tt2')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')" class=IFile>proj4js.js</a></div></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CClass>Proj4js is a JavaScript library to transform point coordinates from one coordinate system to another, including datum transformations.</div></div><div class=CToolTip id="tt2"><div class=CClass>Proj objects provide transformation methods for point coordinates between geodetic latitude/longitude and a projected coordinate system. </div></div><!--END_ND_TOOLTIPS-->
+</td></tr></table><div class=Footer><!--START_ND_FOOTER-->Generated by <a href="http://www.naturaldocs.org">Natural Docs</a><!--END_ND_FOOTER--></div><script language=JavaScript><!--
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Functions.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Functions.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Functions.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,52 @@
+<html><head><title>Function Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class=UnframedPage onLoad="NDOnLoad()"><script language=JavaScript><!--
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile><a href="../files/proj4js-js.html">Proj4js</a></div></div><div class=MEntry><div class=MFile><a href="../files/proj4js-combined-js.html">Proj4js</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div></div></div></div><!--END_ND_MENU--></td><td class=IndexSection valign=top><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; F &middot; <a href="#G">G</a> &middot; H &middot; <a href="#I">I</a> &middot; J &middot; K &middot; <a href="#L">L</a> &middot; M &middot; N &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; <a href="#T">T</a> &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>bind</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#bind" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#bind" id=link2 onMouseOver="ShowTip(event, 'tt1', 'link2')" onMouseOut="HideTip('tt1')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkCodeLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.checkCodeLoaded" id=link3 onMouseOver="ShowTip(event, 'tt2', 'link3')" onMouseOut="HideTip('tt2')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.checkCodeLoaded" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkDefsLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.checkDefsLoaded" id=link5 onMouseOver="ShowTip(event, 'tt3', 'link5')" onMouseOut="HideTip('tt3')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.checkDefsLoaded" id=link6 onMouseOver="ShowTip(event, 'tt3', 'link6')" onMouseOut="HideTip('tt3')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkReadyState</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#checkReadyState" id=link7 onMouseOver="ShowTip(event, 'tt4', 'link7')" onMouseOut="HideTip('tt4')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#checkReadyState" id=link8 onMouseOver="ShowTip(event, 'tt4', 'link8')" onMouseOut="HideTip('tt4')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Class</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Class" id=link9 onMouseOver="ShowTip(event, 'tt5', 'link9')" onMouseOut="HideTip('tt5')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Class" id=link10 onMouseOver="ShowTip(event, 'tt5', 'link10')" onMouseOut="HideTip('tt5')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsFailed</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.defsFailed" id=link11 onMouseOver="ShowTip(event, 'tt6', 'link11')" onMouseOut="HideTip('tt6')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.defsFailed" id=link12 onMouseOver="ShowTip(event, 'tt6', 'link12')" onMouseOut="HideTip('tt6')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.defsLoaded" id=link13 onMouseOver="ShowTip(event, 'tt7', 'link13')" onMouseOut="HideTip('tt7')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.defsLoaded" id=link14 onMouseOver="ShowTip(event, 'tt7', 'link14')" onMouseOut="HideTip('tt7')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>deriveConstants</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.deriveConstants" id=link15 onMouseOver="ShowTip(event, 'tt8', 'link15')" onMouseOut="HideTip('tt8')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.deriveConstants" id=link16 onMouseOver="ShowTip(event, 'tt8', 'link16')" onMouseOut="HideTip('tt8')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>extend</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#extend" id=link17 onMouseOver="ShowTip(event, 'tt9', 'link17')" onMouseOut="HideTip('tt9')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#extend" id=link18 onMouseOver="ShowTip(event, 'tt9', 'link18')" onMouseOut="HideTip('tt9')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>getScriptLocation</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#getScriptLocation" id=link19 onMouseOver="ShowTip(event, 'tt10', 'link19')" onMouseOut="HideTip('tt10')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#getScriptLocation" id=link20 onMouseOver="ShowTip(event, 'tt10', 'link20')" onMouseOut="HideTip('tt10')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>initialize</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.initialize" id=link21 onMouseOver="ShowTip(event, 'tt11', 'link21')" onMouseOut="HideTip('tt11')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.initialize" id=link22 onMouseOver="ShowTip(event, 'tt11', 'link22')" onMouseOut="HideTip('tt11')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>initTransforms</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.initTransforms" id=link23 onMouseOver="ShowTip(event, 'tt12', 'link23')" onMouseOut="HideTip('tt12')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.initTransforms" id=link24 onMouseOver="ShowTip(event, 'tt12', 'link24')" onMouseOut="HideTip('tt12')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadFromService</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadFromService" id=link25 onMouseOver="ShowTip(event, 'tt13', 'link25')" onMouseOut="HideTip('tt13')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadFromService" id=link26 onMouseOver="ShowTip(event, 'tt13', 'link26')" onMouseOut="HideTip('tt13')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjCode</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjCode" id=link27 onMouseOver="ShowTip(event, 'tt14', 'link27')" onMouseOut="HideTip('tt14')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjCode" id=link28 onMouseOver="ShowTip(event, 'tt14', 'link28')" onMouseOut="HideTip('tt14')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjCodeSuccess</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjCodeSuccess" id=link29 onMouseOver="ShowTip(event, 'tt15', 'link29')" onMouseOut="HideTip('tt15')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjCodeSuccess" id=link30 onMouseOver="ShowTip(event, 'tt15', 'link30')" onMouseOut="HideTip('tt15')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjDefinition</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjDefinition" id=link31 onMouseOver="ShowTip(event, 'tt16', 'link31')" onMouseOut="HideTip('tt16')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjDefinition" id=link32 onMouseOver="ShowTip(event, 'tt16', 'link32')" onMouseOut="HideTip('tt16')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadScript</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#loadScript" id=link33 onMouseOver="ShowTip(event, 'tt17', 'link33')" onMouseOut="HideTip('tt17')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#loadScript" id=link34 onMouseOver="ShowTip(event, 'tt17', 'link34')" onMouseOut="HideTip('tt17')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>parseDefs</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.parseDefs" id=link35 onMouseOver="ShowTip(event, 'tt18', 'link35')" onMouseOut="HideTip('tt18')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.parseDefs" id=link36 onMouseOver="ShowTip(event, 'tt18', 'link36')" onMouseOut="HideTip('tt18')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>reportError</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.reportError" id=link37 onMouseOver="ShowTip(event, 'tt19', 'link37')" onMouseOut="HideTip('tt19')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.reportError" id=link38 onMouseOver="ShowTip(event, 'tt19', 'link38')" onMouseOut="HideTip('tt19')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>transform(source,dest,point)</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.transform(source,dest,point)" id=link39 onMouseOver="ShowTip(event, 'tt20', 'link39')" onMouseOut="HideTip('tt20')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.transform(source,dest,point)" id=link40 onMouseOver="ShowTip(event, 'tt20', 'link40')" onMouseOut="HideTip('tt20')" class=IFile>proj4js.js</a></div></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>bind: function(</td><td class=PParameter nowrap>func,</td></tr><tr><td></td><td class=PParameter nowrap>object</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Bind a function to an object. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>checkCodeLoaded: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>This is the loadCheck method to see if the projection code is loaded</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkDefsLoaded: function()</td></tr></table></blockquote>This is the loadCheck method to see if the def object exists</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>checkReadyState: function()</td></tr></table></blockquote>IE workaround since there is no onerror handler. </div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Class: function()</td></tr></table></blockquote>Base class used to construct all other classes. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsFailed: function()</td></tr></table></blockquote>Report an error in loading the defs file, but continue on using WGS84</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsLoaded: function()</td></tr></table></blockquote>Continues the Proj object initilization once the def file is loaded</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>deriveConstants: function()</td></tr></table></blockquote>Sets several derived constant values and initialization of datum and ellipse parameters.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>extend: function(</td><td class=PParameter nowrap>destination,</td></tr><tr><td></td><td class=PParameter nowrap>source</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Copy all properties of a source object to a destination object. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>getScriptLocation: function ()</td></tr></table></blockquote>Return the path to this script.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>initialize: function(</td><td class=PParameter nowrap>srsCode</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Constructor for Proj4js.Proj objects</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>initTransforms: function()</td></tr></table></blockquote>Finalize the initialization of the Proj object</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadFromService: function()</td></tr></table></blockquote>Creates the REST URL for loading the definition from a web service and loads it.</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCode: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads projection class code dynamically if required. </div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCodeSuccess: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads any proj dependencies or continue on to final initialization.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadProjDefinition: function()</td></tr></table></blockquote>Loads the coordinate system initialization string if required. </div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadScript: function(</td><td class=PParameter nowrap>url,</td></tr><tr><td></td><td class=PParameter nowrap>onload,</td></tr><tr><td></td><td class=PParameter nowrap>onfail,</td></tr><tr><td></td><td class=PParameter nowrap>loadCheck</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Load a JS file from a URL into a script tag in the page.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>parseDefs: function()</td></tr></table></blockquote>Parses the PROJ.4 initialization string and sets the associated properties.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>reportError: function(</td><td class=PParameter nowrap>msg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>An internal method to report errors back to user. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>transform: function(</td><td class=PParameter nowrap>source,</td></tr><tr><td></td><td class=PParameter nowrap>dest,</td></tr><tr><td></td><td class=PParameter nowrap>point</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Transform a point coordinate from one map projection to another. </div></div><!--END_ND_TOOLTIPS-->
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/General.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/General.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/General.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,60 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class=UnframedPage onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.35 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile><a href="../files/proj4js-js.html">Proj4js</a></div></div><div class=MEntry><div class=MFile><a href="../files/proj4js-combined-js.html">Proj4js</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Properties.html">Properties</a></div></div></div></div></div><!--END_ND_MENU--></td><td class=IndexSection valign=top><div class=IPageTitle>Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; H &middot; <a href="#I">I</a> &middot; J &middot; K &middot; <a href="#L">L</a> &middot; M &middot; N &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>bind</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#bind" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#bind" id=link2 onMouseOver="ShowTip(event, 'tt1', 'link2')" onMouseOut="HideTip('tt1')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkCodeLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.checkCodeLoaded" id=link3 onMouseOver="ShowTip(event, 'tt2', 'link3')" onMouseOut="HideTip('tt2')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.checkCodeLoaded" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkDefsLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.checkDefsLoaded" id=link5 onMouseOver="ShowTip(event, 'tt3', 'link5')" onMouseOut="HideTip('tt3')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.checkDefsLoaded" id=link6 onMouseOver="ShowTip(event, 'tt3', 'link6')" onMouseOut="HideTip('tt3')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>checkReadyState</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#checkReadyState" id=link7 onMouseOver="ShowTip(event, 'tt4', 'link7')" onMouseOut="HideTip('tt4')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#checkReadyState" id=link8 onMouseOver="ShowTip(event, 'tt4', 'link8')" onMouseOut="HideTip('tt4')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Class</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Class" id=link9 onMouseOver="ShowTip(event, 'tt5', 'link9')" onMouseOut="HideTip('tt5')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Class" id=link10 onMouseOver="ShowTip(event, 'tt5', 'link10')" onMouseOut="HideTip('tt5')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>datum</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.datum" id=link11 onMouseOver="ShowTip(event, 'tt6', 'link11')" onMouseOut="HideTip('tt6')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.datum" id=link12 onMouseOver="ShowTip(event, 'tt6', 'link12')" onMouseOut="HideTip('tt6')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defaultDatum</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.defaultDatum" id=link13 onMouseOver="ShowTip(event, 'tt7', 'link13')" onMouseOut="HideTip('tt7')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.defaultDatum" id=link14 onMouseOver="ShowTip(event, 'tt7', 'link14')" onMouseOut="HideTip('tt7')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsFailed</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.defsFailed" id=link15 onMouseOver="ShowTip(event, 'tt8', 'link15')" onMouseOut="HideTip('tt8')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.defsFailed" id=link16 onMouseOver="ShowTip(event, 'tt8', 'link16')" onMouseOut="HideTip('tt8')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsLoaded</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.defsLoaded" id=link17 onMouseOver="ShowTip(event, 'tt9', 'link17')" onMouseOut="HideTip('tt9')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.defsLoaded" id=link18 onMouseOver="ShowTip(event, 'tt9', 'link18')" onMouseOut="HideTip('tt9')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsLookupService</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#defsLookupService" id=link19 onMouseOver="ShowTip(event, 'tt10', 'link19')" onMouseOut="HideTip('tt10')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#defsLookupService" id=link20 onMouseOver="ShowTip(event, 'tt10', 'link20')" onMouseOut="HideTip('tt10')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>deriveConstants</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.deriveConstants" id=link21 onMouseOver="ShowTip(event, 'tt11', 'link21')" onMouseOut="HideTip('tt11')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.deriveConstants" id=link22 onMouseOver="ShowTip(event, 'tt11', 'link22')" onMouseOut="HideTip('tt11')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>extend</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#extend" id=link23 onMouseOver="ShowTip(event, 'tt12', 'link23')" onMouseOut="HideTip('tt12')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#extend" id=link24 onMouseOver="ShowTip(event, 'tt12', 'link24')" onMouseOut="HideTip('tt12')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Functions"  class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Functions"  class=IFile>proj4js.js</a></div><span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.Functions"  class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.Functions"  class=IFile>proj4js.js</a></div></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions and Properties</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Functions_and_Properties"  class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Functions_and_Properties"  class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>getScriptLocation</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#getScriptLocation" id=link25 onMouseOver="ShowTip(event, 'tt13', 'link25')" onMouseOut="HideTip('tt13')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#getScriptLocation" id=link26 onMouseOver="ShowTip(event, 'tt13', 'link26')" onMouseOut="HideTip('tt13')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>initialize</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.initialize" id=link27 onMouseOver="ShowTip(event, 'tt14', 'link27')" onMouseOut="HideTip('tt14')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.initialize" id=link28 onMouseOver="ShowTip(event, 'tt14', 'link28')" onMouseOut="HideTip('tt14')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>initTransforms</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.initTransforms" id=link29 onMouseOver="ShowTip(event, 'tt15', 'link29')" onMouseOut="HideTip('tt15')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.initTransforms" id=link30 onMouseOver="ShowTip(event, 'tt15', 'link30')" onMouseOut="HideTip('tt15')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>libPath</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#libPath" id=link31 onMouseOver="ShowTip(event, 'tt16', 'link31')" onMouseOut="HideTip('tt16')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#libPath" id=link32 onMouseOver="ShowTip(event, 'tt16', 'link32')" onMouseOut="HideTip('tt16')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadFromService</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadFromService" id=link33 onMouseOver="ShowTip(event, 'tt17', 'link33')" onMouseOut="HideTip('tt17')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadFromService" id=link34 onMouseOver="ShowTip(event, 'tt17', 'link34')" onMouseOut="HideTip('tt17')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjCode</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjCode" id=link35 onMouseOver="ShowTip(event, 'tt18', 'link35')" onMouseOut="HideTip('tt18')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjCode" id=link36 onMouseOver="ShowTip(event, 'tt18', 'link36')" onMouseOut="HideTip('tt18')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjCodeSuccess</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjCodeSuccess" id=link37 onMouseOver="ShowTip(event, 'tt19', 'link37')" onMouseOut="HideTip('tt19')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjCodeSuccess" id=link38 onMouseOver="ShowTip(event, 'tt19', 'link38')" onMouseOut="HideTip('tt19')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadProjDefinition</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.loadProjDefinition" id=link39 onMouseOver="ShowTip(event, 'tt20', 'link39')" onMouseOut="HideTip('tt20')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.loadProjDefinition" id=link40 onMouseOver="ShowTip(event, 'tt20', 'link40')" onMouseOut="HideTip('tt20')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>loadScript</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#loadScript" id=link41 onMouseOver="ShowTip(event, 'tt21', 'link41')" onMouseOut="HideTip('tt21')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#loadScript" id=link42 onMouseOver="ShowTip(event, 'tt21', 'link42')" onMouseOut="HideTip('tt21')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>parseDefs</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.parseDefs" id=link43 onMouseOver="ShowTip(event, 'tt22', 'link43')" onMouseOut="HideTip('tt22')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.parseDefs" id=link44 onMouseOver="ShowTip(event, 'tt22', 'link44')" onMouseOut="HideTip('tt22')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Private Methods</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Private_Methods" id=link45 onMouseOver="ShowTip(event, 'tt23', 'link45')" onMouseOut="HideTip('tt23')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Private_Methods" id=link46 onMouseOver="ShowTip(event, 'tt23', 'link46')" onMouseOut="HideTip('tt23')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js" id=link47 onMouseOver="ShowTip(event, 'tt24', 'link47')" onMouseOut="HideTip('tt24')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js" id=link48 onMouseOver="ShowTip(event, 'tt24', 'link48')" onMouseOut="HideTip('tt24')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj" id=link49 onMouseOver="ShowTip(event, 'tt25', 'link49')" onMouseOut="HideTip('tt25')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj" id=link50 onMouseOver="ShowTip(event, 'tt25', 'link50')" onMouseOut="HideTip('tt25')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>projName</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.projName" id=link51 onMouseOver="ShowTip(event, 'tt26', 'link51')" onMouseOut="HideTip('tt26')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.projName" id=link52 onMouseOver="ShowTip(event, 'tt26', 'link52')" onMouseOut="HideTip('tt26')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Properties</span><div class=ISubIndex><span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Properties"  class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Properties"  class=IFile>proj4js.js</a></div><span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.Properties"  class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.Properties"  class=IFile>proj4js.js</a></div></div></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>readyToUse</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.readyToUse" id=link53 onMouseOver="ShowTip(event, 'tt27', 'link53')" onMouseOut="HideTip('tt27')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.readyToUse" id=link54 onMouseOver="ShowTip(event, 'tt27', 'link54')" onMouseOut="HideTip('tt27')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>reportError</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.reportError" id=link55 onMouseOver="ShowTip(event, 'tt28', 'link55')" onMouseOut="HideTip('tt28')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.reportError" id=link56 onMouseOver="ShowTip(event, 'tt28', 'link56')" onMouseOut="HideTip('tt28')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>title</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.title" id=link57 onMouseOver="ShowTip(event, 'tt29', 'link57')" onMouseOut="HideTip('tt29')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.title" id=link58 onMouseOver="ShowTip(event, 'tt29', 'link58')" onMouseOut="HideTip('tt29')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>transform(source,dest,point)</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.transform(source,dest,point)" id=link59 onMouseOver="ShowTip(event, 'tt30', 'link59')" onMouseOut="HideTip('tt30')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.transform(source,dest,point)" id=link60 onMouseOver="ShowTip(event, 'tt30', 'link60')" onMouseOut="HideTip('tt30')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>units</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.units" id=link61 onMouseOver="ShowTip(event, 'tt31', 'link61')" onMouseOut="HideTip('tt31')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.units" id=link62 onMouseOver="ShowTip(event, 'tt31', 'link62')" onMouseOut="HideTip('tt31')" class=IFile>proj4js.js</a></div></td></tr></table>
+<div class=CToolTip id="tt6"><div class=CProperty>The datum specified for the projection</div></div><div class=CToolTip id="tt7"><div class=CProperty>The datum to use when no others a specified</div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsFailed: function()</td></tr></table></blockquote>Report an error in loading the defs file, but continue on using WGS84</div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>defsLoaded: function()</td></tr></table></blockquote>Continues the Proj object initilization once the def file is loaded</div></div><div class=CToolTip id="tt10"><div class=CProperty>AJAX service to retreive projection definition parameters from</div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>deriveConstants: function()</td></tr></table></blockquote>Sets several derived constant values and initialization of datum and ellipse parameters.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>extend: function(</td><td class=PParameter nowrap>destination,</td></tr><tr><td></td><td class=PParameter nowrap>source</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Copy all properties of a source object to a destination object. </div></div><!--END_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>getScriptLocation: function ()</td></tr></table></blockquote>Return the path to this script.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>initialize: function(</td><td class=PParameter nowrap>srsCode</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Constructor for Proj4js.Proj objects</div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>initTransforms: function()</td></tr></table></blockquote>Finalize the initialization of the Proj object</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CProperty>internal: http server path to library code.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadFromService: function()</td></tr></table></blockquote>Creates the REST URL for loading the definition from a web service and loads it.</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCode: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads projection class code dynamically if required. </div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadProjCodeSuccess: function(</td><td class=PParameter nowrap>projName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Loads any proj dependencies or continue on to final initialization.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>loadProjDefinition: function()</td></tr></table></blockquote>Loads the coordinate system initialization string if required. </div></div><div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>loadScript: function(</td><td class=PParameter nowrap>url,</td></tr><tr><td></td><td class=PParameter nowrap>onload,</td></tr><tr><td></td><td class=PParameter nowrap>onfail,</td></tr><tr><td></td><td class=PParameter nowrap>loadCheck</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Load a JS file from a URL into a script tag in the page.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>parseDefs: function()</td></tr></table></blockquote>Parses the PROJ.4 initialization string and sets the associated properties.</div></div><div class=CToolTip id="tt23"><div class=CSection>The following properties and methods are intended for internal use only.</div></div><div class=CToolTip id="tt24"><div class=CClass>Proj4js is a JavaScript library to transform point coordinates from one coordinate system to another, including datum transformations.</div></div><div class=CToolTip id="tt25"><div class=CClass>Proj objects provide transformation methods for point coordinates between geodetic latitude/longitude and a projected coordinate system. </div></div><div class=CToolTip id="tt26"><div class=CProperty>The projection class for this projection, e.g. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt27"><div class=CProperty>Flag to indicate if initialization is complete for this Proj object</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>reportError: function(</td><td class=PParameter nowrap>msg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>An internal method to report errors back to user. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CProperty>The title to describe the projection</div></div><div class=CToolTip id="tt30"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>transform: function(</td><td class=PParameter nowrap>source,</td></tr><tr><td></td><td class=PParameter nowrap>dest,</td></tr><tr><td></td><td class=PParameter nowrap>point</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Transform a point coordinate from one map projection to another. </div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt31"><div class=CProperty>The units of the projection. </div></div><!--END_ND_TOOLTIPS-->
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Properties.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Properties.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index/Properties.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,36 @@
+<html><head><title>Property Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class=UnframedPage onLoad="NDOnLoad()"><script language=JavaScript><!--
+<table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td class=MenuSection valign=top><!--START_ND_MENU--><div class=MEntry><div class=MFile><a href="../files/proj4js-js.html">Proj4js</a></div></div><div class=MEntry><div class=MFile><a href="../files/proj4js-combined-js.html">Proj4js</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">Index</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Properties</div></div></div></div></div><!--END_ND_MENU--></td><td class=IndexSection valign=top><div class=IPageTitle>Property Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; <a href="#D">D</a> &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; <a href="#L">L</a> &middot; M &middot; N &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>datum</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.datum" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.datum" id=link2 onMouseOver="ShowTip(event, 'tt1', 'link2')" onMouseOut="HideTip('tt1')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defaultDatum</span>, <span class=IParent>Proj4js</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.defaultDatum" id=link3 onMouseOver="ShowTip(event, 'tt2', 'link3')" onMouseOut="HideTip('tt2')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.defaultDatum" id=link4 onMouseOver="ShowTip(event, 'tt2', 'link4')" onMouseOut="HideTip('tt2')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>defsLookupService</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#defsLookupService" id=link5 onMouseOver="ShowTip(event, 'tt3', 'link5')" onMouseOut="HideTip('tt3')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#defsLookupService" id=link6 onMouseOver="ShowTip(event, 'tt3', 'link6')" onMouseOut="HideTip('tt3')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>libPath</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#libPath" id=link7 onMouseOver="ShowTip(event, 'tt4', 'link7')" onMouseOut="HideTip('tt4')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#libPath" id=link8 onMouseOver="ShowTip(event, 'tt4', 'link8')" onMouseOut="HideTip('tt4')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>projName</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.projName" id=link9 onMouseOver="ShowTip(event, 'tt5', 'link9')" onMouseOut="HideTip('tt5')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.projName" id=link10 onMouseOver="ShowTip(event, 'tt5', 'link10')" onMouseOut="HideTip('tt5')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>readyToUse</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.readyToUse" id=link11 onMouseOver="ShowTip(event, 'tt6', 'link11')" onMouseOut="HideTip('tt6')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.readyToUse" id=link12 onMouseOver="ShowTip(event, 'tt6', 'link12')" onMouseOut="HideTip('tt6')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>title</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.title" id=link13 onMouseOver="ShowTip(event, 'tt7', 'link13')" onMouseOut="HideTip('tt7')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.title" id=link14 onMouseOver="ShowTip(event, 'tt7', 'link14')" onMouseOut="HideTip('tt7')" class=IFile>proj4js.js</a></div></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>units</span>, <span class=IParent>Proj4js.Proj</span><div class=ISubIndex><a href="../files/proj4js-combined-js.html#Proj4js.Proj.units" id=link15 onMouseOver="ShowTip(event, 'tt8', 'link15')" onMouseOut="HideTip('tt8')" class=IFile>proj4js-combined.js</a><a href="../files/proj4js-js.html#Proj4js.Proj.units" id=link16 onMouseOver="ShowTip(event, 'tt8', 'link16')" onMouseOut="HideTip('tt8')" class=IFile>proj4js.js</a></div></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CProperty>The datum specified for the projection</div></div><div class=CToolTip id="tt2"><div class=CProperty>The datum to use when no others a specified</div></div><div class=CToolTip id="tt3"><div class=CProperty>AJAX service to retreive projection definition parameters from</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CProperty>internal: http server path to library code.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CProperty>The projection class for this projection, e.g. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt6"><div class=CProperty>Flag to indicate if initialization is complete for this Proj object</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt7"><div class=CProperty>The title to describe the projection</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CProperty>The units of the projection. </div></div><!--END_ND_TOOLTIPS-->
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index.html
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/index.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/proj4js-js.html"></head></html>
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/javascript/main.js
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/javascript/main.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/javascript/main.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,276 @@
+// This file is part of Natural Docs, which is Copyright (C) 2003-2005 Greg Valure
+// Natural Docs is licensed under the GPL
+//  Browser Styles
+// ____________________________________________________________________________
+var agt=navigator.userAgent.toLowerCase();
+var browserType;
+var browserVer;
+if (agt.indexOf("opera") != -1)
+    browserType = "Opera";
+    if (agt.indexOf("opera 5") != -1 || agt.indexOf("opera/5") != -1)
+        {  browserVer = "Opera5";  }
+    else if (agt.indexOf("opera 6") != -1 || agt.indexOf("opera/6") != -1)
+        {  browserVer = "Opera6";  }
+    else if (agt.indexOf("opera 7") != -1 || agt.indexOf("opera/7") != -1)
+        {  browserVer = "Opera7";  }
+else if (agt.indexOf("khtml") != -1 || agt.indexOf("konq") != -1 || agt.indexOf("safari") != -1)
+    browserType = "KHTML";
+else if (agt.indexOf("msie") != -1)
+    browserType = "IE";
+    if (agt.indexOf("msie 4") != -1)
+        {  browserVer = "IE4";  }
+    else if (agt.indexOf("msie 5") != -1)
+        {  browserVer = "IE5";  }
+    else if (agt.indexOf("msie 6") != -1)
+        {  browserVer = "IE6";  }
+else if (agt.indexOf("gecko") != -1)
+    browserType = "Gecko";
+// Opera already taken care of.
+else if (agt.indexOf("mozilla") != -1 && agt.indexOf("compatible") == -1 && agt.indexOf("spoofer") == -1 &&
+           agt.indexOf("webtv") == -1 && agt.indexOf("hotjava") == -1)
+    browserType = "Netscape";
+    if (agt.indexOf("mozilla/4") != -1)
+        {  browserVer = "Netscape4";  }
+//  Menu
+function ToggleMenu(id)
+    if (!window.document.getElementById)
+        {  return;  };
+    var display = window.document.getElementById(id).style.display;
+    if (display == "none")
+        {  display = "block";  }
+    else
+        {  display = "none";  }
+    window.document.getElementById(id).style.display = display;
+//  Tooltips
+var tooltipTimer = 0;
+function ShowTip(event, tooltipID, linkID)
+    if (tooltipTimer)
+        {  clearTimeout(tooltipTimer);  };
+    var docX = event.clientX + window.pageXOffset;
+    var docY = event.clientY + window.pageYOffset;
+    var showCommand = "ReallyShowTip('" + tooltipID + "', '" + linkID + "', " + docX + ", " + docY + ")";
+    // KHTML cant handle showing on a timer right now.
+    if (browserType != "KHTML")
+        {  tooltipTimer = setTimeout(showCommand, 1000);  }
+    else
+        {  eval(showCommand);  };
+function ReallyShowTip(tooltipID, linkID, docX, docY)
+    tooltipTimer = 0;
+    var tooltip;
+    var link;
+    if (document.getElementById)
+        tooltip = document.getElementById(tooltipID);
+        link = document.getElementById(linkID);
+    else if (document.all)
+        tooltip = eval("document.all['" + tooltipID + "']");
+        link = eval("document.all['" + linkID + "']");
+    if (tooltip)
+        var left = 0;
+        var top = 0;
+        // Not everything supports offsetTop/Left/Width, and some, like Konqueror and Opera 5, think they do but do it badly.
+        if (link && link.offsetWidth != null && browserType != "KHTML" && browserVer != "Opera5")
+            var item = link;
+            while (item != document.body)
+                left += item.offsetLeft;
+                item = item.offsetParent;
+            item = link;
+                top += item.offsetTop;
+            top += link.offsetHeight;
+        // The fallback method is to use the mouse X and Y relative to the document.  We use a separate if and test if its a number
+        // in case some browser snuck through the above if statement but didn't support everything.
+        if (!isFinite(top) || top == 0)
+            left = docX;
+            top = docY;
+        // Some spacing to get it out from under the cursor.
+        top += 10;
+        // Make sure the tooltip doesnt get smushed by being too close to the edge, or in some browsers, go off the edge of the
+        // page.  We do it here because Konqueror does get offsetWidth right even if it doesnt get the positioning right.
+        if (tooltip.offsetWidth != null)
+            var width = tooltip.offsetWidth;
+            var docWidth = document.body.clientWidth;
+            if (left + width > docWidth)
+                {  left = docWidth - width - 1;  }
+        // Opera 5 chokes on the px extension, so it can use the Microsoft one instead.
+        if (tooltip.style.left != null && browserVer != "Opera5")
+            tooltip.style.left = left + "px";
+            tooltip.style.top = top + "px";
+        else if (tooltip.style.pixelLeft != null)
+            tooltip.style.pixelLeft = left;
+            tooltip.style.pixelTop = top;
+        tooltip.style.visibility = "visible";
+function HideTip(tooltipID)
+    if (tooltipTimer)
+        clearTimeout(tooltipTimer);
+        tooltipTimer = 0;
+    var tooltip;
+        {  tooltip = document.getElementById(tooltipID); }
+        {  tooltip = eval("document.all['" + tooltipID + "']");  }
+    if (tooltip)
+        {  tooltip.style.visibility = "hidden";  }
+//  Event Handlers
+function NDOnLoad()
+    if (browserType == "IE")
+        var scrollboxes = document.getElementsByTagName('blockquote');
+        if (scrollboxes.item(0))
+            var width = scrollboxes.item(0).parentNode.offsetWidth - scrollboxes.item(0).offsetLeft;
+            var i = 0;
+            var item;
+            while (item = scrollboxes.item(i))
+                item.style.width = width;
+                i++;
+            window.onresize=NDOnResize;
+var resizeTimer = 0;
+function NDOnResize()
+        if (resizeTimer != 0)
+            {  clearTimeout(resizeTimer);  };
+        resizeTimer = setTimeout(NDDoResize, 500);
+function NDDoResize()
+    var i;
+    var item;
+    i = 0;
+        item.style.width = "100px";
+        i++;
+    i = 0;
+        i++;
+    clearTimeout(resizeTimer);
+    resizeTimer = 0;
Added: trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/styles/main.css
--- trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/styles/main.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/docs/NaturalDocs/styles/main.css	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,540 @@
+   IMPORTANT: If you're editing this file in the output directory of one of
+   your projects, your changes will be overwritten the next time you run
+   Natural Docs.  Instead, copy this file to your project directory, make your
+   changes, and you can use it with -s.  Even better would be to make a CSS
+   file in your project directory with only your changes, which you can then
+   use with -s [original style] [your changes].
+   On the other hand, if you're editing this file in the Natural Docs styles
+   directory, the changes will automatically be applied to all your projects
+   that use this style the next time Natural Docs is run on them.
+   This file is part of Natural Docs, which is Copyright (C) 2003-2005 Greg Valure
+   Natural Docs is licensed under the GPL
+body {
+    font-family: Verdana, Arial, sans-serif;
+    color: #000000;
+    margin: 0px; padding: 0px }
+body.UnframedPage {
+    background-color: #E8E8E8 }
+a:link,
+a:visited { color: #900000; text-decoration: none }
+a:hover { color: #900000; text-decoration: underline }
+a:active { color: #FF0000; text-decoration: underline }
+td {
+    vertical-align: top }
+    Comment out this line to use web-style paragraphs (blank line between
+    paragraphs, no indent) instead of print-style paragraphs (no blank line,
+    indented.)
+p {
+    text-indent: 5ex; margin: 0 }
+/*  Can't use something like display: none or it won't break.  */
+.HB {
+    font-size: 1px;
+    visibility: hidden;
+/*  Blockquotes are used as containers for things that may need to scroll.  */
+blockquote {
+    padding: 0;
+    margin: 0;
+    overflow: auto;
+/*  This will be fixed in JavaScript.  We just need a default if it's turned off.  */
+.IE blockquote {
+    width: 400px;  }
+.Gecko blockquote {
+    padding-bottom: .5em;
+/*  Turn off scrolling when printing.  */
+ at media print {
+    blockquote {
+        overflow: visible;
+    .IE blockquote {
+        width: auto;
+body.FramedMenuPage,
+.MenuSection {
+    font-size: 9pt;
+    background-color: #E8E8E8;
+    padding: 10px 0 0 0 }
+.MenuSection {
+    width: 27ex }
+    .MTitle {
+        font-size: 16pt; font-weight: bold; font-variant: small-caps;
+        text-align: center;
+        padding: 5px 10px 15px 10px;
+        border-bottom: 1px dotted #000000;
+        margin-bottom: 15px }
+    .MSubTitle {
+        font-size: 9pt; font-weight: normal; font-variant: normal;
+        margin-top: 1ex; margin-bottom: 5px }
+    .MEntry a:link,
+    .MEntry a:hover,
+    .MEntry a:visited { color: #606060; margin-right: 0 }
+    .MEntry a:active { color: #A00000; margin-right: 0 }
+    .MGroup {
+        font-variant: small-caps; font-weight: bold;
+        margin: 1em 0 1em 10px }
+    /*  Konqueror just can't do margins.  */
+    .KHTML .MGroup {
+        margin-bottom: 0; padding-bottom: 1em }
+    .MGroupContent {
+        font-variant: normal; font-weight: normal }
+    .MGroup a:link,
+    .MGroup a:hover,
+    .MGroup a:visited { color: #545454; margin-right: 10px }
+    .MGroup a:active { color: #A00000; margin-right: 10px }
+    .MFile,
+    .MText,
+    .MLink,
+    .MIndex {
+        padding: 1px 17px 2px 10px;
+        margin: .25em 0 .25em 0 }
+    .MText {
+        font-size: 8pt; font-style: italic }
+    .MLink {
+        font-style: italic }
+    #MSelected {
+        color: #000000; background-color: #FFFFFF;
+        /*  Replace padding with border.  */
+        padding: 0 10px 0 10px;
+        border-width: 1px 2px 2px 0; border-style: solid; border-color: #000000;
+        margin-right: 5px }
+    /*  Close off the left side when its in a group.  */
+    .MGroup #MSelected {
+        padding-left: 9px; border-left-width: 1px }
+    /*  A treat for Mozilla users.  Blatantly non-standard.  Will be replaced with CSS 3 attributes when finalized/supported.  */
+    .Gecko #MSelected {
+        -moz-border-radius-topright: 10px;
+        -moz-border-radius-bottomright: 10px }
+    .Gecko .MGroup #MSelected {
+        -moz-border-radius-topleft: 10px;
+        -moz-border-radius-bottomleft: 10px }
+body.FramedContentPage,
+.ContentSection {
+    background-color: #FFFFFF;
+    padding-bottom: 15px }
+.ContentSection {
+    border-width: 0 0 1px 1px; border-style: solid; border-color: #000000 }
+    .CTopic {
+        font-size: 10pt;
+        /*  This should be a margin but Konq 3.1.1 sucks.  */
+        padding-bottom: 3em }
+    .CTitle {
+        font-size: 12pt; font-weight: bold;
+        border-width: 0 0 1px 0; border-style: solid; border-color: #A0A0A0;
+        margin: 0 15px .5em 15px }
+    .CGroup .CTitle {
+        font-size: 16pt; font-variant: small-caps;
+        padding-left: 15px; padding-right: 15px;
+        border-width: 0 0 2px 0; border-color: #000000;
+        margin-left: 0; margin-right: 0 }
+    .CClass .CTitle,
+    .CInterface .CTitle,
+    .CDatabase .CTitle,
+    .CDatabaseTable .CTitle,
+    .CSection .CTitle {
+        font-size: 18pt;
+        color: #FFFFFF; background-color: #A0A0A0;
+        padding: 10px 15px 10px 15px;
+        border-width: 2px 0; border-color: #000000;
+    #MainTopic .CTitle {
+        font-size: 20pt;
+        color: #FFFFFF; background-color: #7070C0;
+        border-width: 0 0 3px 0; border-color: #000000;
+    .CBody {
+        margin-left: 15px; margin-right: 15px }
+    .CToolTip {
+        position: absolute; visibility: hidden;
+        left: 0; top: 0; max-width: 50%;
+        background-color: #FFFFE0;
+        padding: 5px;
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #000000;
+        font-size: 8pt }
+    /*  Opera 6 gives it a huge height otherwise.  */
+    .Opera6 .CTooltip, .Opera5 .CTooltip {
+        max-width: 100% }
+    /*  Scrollbars would be useless.  */
+    .CToolTip blockquote {
+        overflow: hidden;
+    .CHeading {
+        font-weight: bold; font-size: 10pt;
+        margin-top: 1.5em; margin-bottom: .5em }
+    .CCode {
+        font: 10pt "Courier New", Courier, monospace;
+    .CBulletList {
+        /*  I don't know why CBody's margin doesn't apply, but it's consistent across browsers so whatever.
+             Reapply it here as padding.  */
+        margin: .5em 5ex .5em 5ex;
+    .CDescriptionList {
+        margin: .5em 5ex 0 5ex }
+    /* IE 4 and Konqueror always makes it too long.  */
+    .IE4 .CDescriptionList,
+    .KHTML .CDescriptionList {
+        width: 85% }
+        .CDLEntry {
+            font: 10pt "Courier New", Courier, monospace; color: #808080;
+            padding-bottom: .25em;
+            white-space: nowrap }
+        .CDLDescription {
+            font-size: 10pt;  /*  For browsers that don't inherit correctly, like Opera 5.  */
+            padding-bottom: .5em; padding-left: 5ex }
+.Prototype {
+    padding: 5px 3ex;
+    border-width: 1px; border-style: solid;
+    margin: 0 5ex 1.5em 5ex;
+    .Prototype td {
+        font-size: 10pt;
+    .PDefaultValue,
+    .PDefaultValuePrefix,
+    .PTypePrefix {
+        color: #8F8F8F;
+    .PTypePrefix {
+        text-align: right;
+    .PAfterParameters {
+        vertical-align: bottom;
+    .IE .Prototype table {
+        padding: 0;
+    .CFunction .Prototype {
+        background-color: #F4F4F4; border-color: #D0D0D0 }
+    .CProperty .Prototype {
+        background-color: #F4F4FF; border-color: #C0C0E8 }
+    .CVariable .Prototype {
+        background-color: #FFFFF0; border-color: #E0E0A0 }
+    .CDatabaseIndex .Prototype,
+    .CConstant .Prototype {
+        background-color: #D0D0D0; border-color: #000000 }
+    .CType .Prototype {
+        background-color: #FFF8F8; border-color: #E8C8C8 }
+    .CDatabaseTrigger .Prototype,
+    .CEvent .Prototype,
+    .CDelegate .Prototype {
+        background-color: #F0FCF0; border-color: #B8E4B8 }
+    .CToolTip .Prototype {
+        margin: 0 0 .5em 0;
+        white-space: nowrap;
+.Summary {
+    margin: 1.5em 5ex 0 5ex }
+    .STitle {
+        margin-bottom: .5em }
+    .SBorder {
+        padding: 15px;
+        border: 1px solid #C0C060 }
+    /* Let's observe the evolution of IE's brokeness, shall we?
+        IE 4 always makes them too long, there's no way around it.  */
+    .IE4 .SBorder {
+        width: 85% }
+    /* IE 5 will make them too long unless you set the width to 100%.  Isn't this implied for a div?  */
+    .IE5 .SBorder {
+        width: 100% }
+    /* IE 6 behaves like 5 when it's in a frame, but without frames it will be correct without a width or slightly too long
+        (but not enough to scroll) with a width.  This arbitrary weirdness simply astounds me.  */
+    body.FramedContentPage .IE6 .SBorder {
+        width: 100% }
+    .Gecko .SBorder {
+        -moz-border-radius: 20px }
+    .STable {
+        font-size: 9pt; width: 100% }
+    .SEntrySize {
+        width: 30% }
+    .SDescriptionSize {
+        width: 70% }
+    .SMarked {
+        background-color: #F8F8D8 }
+    .SEntry .SIndent1 {
+        margin-left: 1.5ex }
+    .SEntry .SIndent2 {
+        margin-left: 3ex }
+    .SEntry .SIndent3 {
+        margin-left: 4.5ex }
+    .SEntry .SIndent4 {
+        margin-left: 6ex }
+    .SEntry .SIndent5 {
+        margin-left: 7.5ex }
+    .SDescription {
+        padding-left: 3ex }
+    .SDescription a { color: #800000}
+    .SDescription a:active { color: #A00000 }
+    .SGroup {
+        margin-top: .5em; margin-bottom: .25em }
+    .SGroup .SEntry {
+        font-weight: bold; font-variant: small-caps }
+    .SGroup .SEntry a { color: #800000 }
+    .SGroup .SEntry a:active { color: #F00000 }
+    .SMain .SEntry,
+    .SClass .SEntry,
+    .SDatabase .SEntry,
+    .SDatabaseTable .SEntry,
+    .SSection .SEntry {
+        margin-bottom: .25em }
+    .SClass,
+    .SDatabase,
+    .SDatabaseTable,
+    .SSection {
+        margin-top: 1em }
+    .SMain .SEntry a,
+    .SClass .SEntry a,
+    .SDatabase .SEntry a,
+    .SDatabaseTable .SEntry a,
+    .SSection .SEntry a { color: #000000 }
+    .SMain .SEntry a:active,
+    .SClass .SEntry a:active,
+    .SDatabase .SEntry a:active,
+    .SDatabaseTable .SEntry a:active,
+    .SSection .SEntry a:active { color: #A00000 }
+.ClassHierarchy {
+    margin: 0 15px 1em 15px }
+    .CHEntry {
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0A0;
+        margin-bottom: 3px;
+        padding: 2px 2ex;
+        font-size: 10pt;
+        background-color: #F4F4F4; color: #606060;
+    .Gecko .CHEntry {
+        -moz-border-radius: 4px;
+    .CHCurrent .CHEntry {
+        border-color: #000000;
+        color: #000000;
+    .CHChildNote .CHEntry {
+        font-style: italic;
+        font-size: 8pt;
+    .CHIndent {
+        margin-left: 3ex;
+    .CHEntry a:link,
+    .CHEntry a:visited,
+    .CHEntry a:hover {
+        color: #606060;
+    .CHEntry a:active {
+        color: #800000;
+body.FramedIndexPage,
+.IndexSection {
+    font-size: 10pt;
+    padding: 15px }
+.IndexSection {
+    .IPageTitle {
+        font-size: 20pt; font-weight: bold;
+        border-width: 0 0 3px 0; border-color: #000000; border-style: solid;
+        margin: -15px -15px 0 -15px }
+    .INavigationBar {
+        padding: 5px;
+        border-bottom: solid 1px black;
+        margin: 0 -15px 15px -15px }
+    .INavigationBar a {
+        font-weight: bold }
+    .IHeading {
+        padding: 2.5em 0 .5em 0;
+        width: 3.5ex;
+    #IFirstHeading {
+        padding-top: 0;
+    .IEntry {
+        padding-left: 1ex;  }
+    .ISubIndex {
+        padding-left: 3ex; padding-bottom: .5em }
+    /*  While it may cause some entries to look like links when they aren't, I found it's much easier to read the
+         index if everything's the same color.  */
+    .ISymbol {
+        font-weight: bold; color: #900000  }
+    .ISymbolPrefix {
+        color: #C47C7C;
+        background-color: #F8F8F8;
+        border-right: 3px solid #E0E0E0;
+        border-left: 1px solid #E0E0E0;
+        padding: 0 1px 0 2px;
+    #IFirstSymbolPrefix {
+        border-top: 1px solid #E0E0E0;
+    #ILastSymbolPrefix {
+        border-bottom: 1px solid #E0E0E0;
+    #IOnlySymbolPrefix {
+    a.IParent,
+    a.IFile {
+        display: block;
+.Footer {
+    font-size: 8pt; color: #909090 }
+body.UnframedPage .Footer {
+    margin: 2px }
+body.FramedMenuPage .Footer {
+    margin: 5em 10px 0 10px}
+    .Footer a:link,
+    .Footer a:hover,
+    .Footer a:visited { color: #909090 }
+    .Footer a:active { color: #A00000 }
Added: trunk/mapbender/http/extensions/proj4js/index.html
--- trunk/mapbender/http/extensions/proj4js/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/index.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,172 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+  <title>Proj4js</title>
+  <style type="text/css">
+    @import url(test/base.css);
+    #descSource, #descDest {
+        color: #999;
+    #xySource, #xyDest {
+        width: 100%;
+  </style>
+  <script src="lib/proj4js.js"></script>
+  <script src="lib/defs/EPSG27200.js"></script>
+  <script src="lib/defs/EPSG4272.js"></script>
+  <script src="lib/defs/EPSG54009.js"></script>
+  <script src="lib/defs/EPSG42304.js"></script>
+  <script src="lib/defs/EPSG25833.js"></script>
+  <script src="lib/defs/EPSG27563.js"></script>
+  <script src="lib/defs/EPSG4139.js"></script>
+  <script src="lib/defs/EPSG4302.js"></script>
+  <script src="lib/defs/EPSG31285.js"></script>
+  <script src="lib/defs/EPSG900913.js"></script>
+  <script type="text/javascript">
+  var projHash = {};
+  function initProj4js() {
+    var crsSource = document.getElementById('crsSource');
+    var crsDest = document.getElementById('crsDest');
+    var optIndex = 0;
+    for (var def in Proj4js.defs) {
+       projHash[def] = new Proj4js.Proj(def);    //create a Proj for each definition
+       var label = def+" - "+ (projHash[def].title ? projHash[def].title : '');
+       var opt = new Option(label, def);
+       crsSource.options[optIndex]= opt;
+       crsDest.options[optIndex]= opt;
+       ++optIndex;
+    }  // for
+    updateCrs('Source');
+    updateCrs('Dest');
+  function updateCrs(id) {
+    var crs = document.getElementById('crs'+id);
+    if (crs.value) {
+      var proj = projHash[crs.value];
+      var str = 'projection: ' + proj.projName + ' - datum: ' + proj.datumName;
+      var desc = document.getElementById('desc'+id);
+      desc.innerHTML = str;
+      var units = document.getElementById('units'+id);
+      units.innerHTML = proj.units;
+  function transform() {
+    var projSource = null;
+    if (crsSource.value) {
+      projSource = projHash[crsSource.value];
+    } else {
+      alert("Select a source coordinate system");
+      return;
+    var projDest = null;
+    if (crsDest.value) {
+      projDest = projHash[crsDest.value];
+    } else {
+      alert("Select a destination coordinate system");
+      return;
+    var pointInput = document.getElementById('xySource');
+    if (pointInput.value) {
+      var pointSource = new Proj4js.Point(pointInput.value);
+      var pointDest = Proj4js.transform(projSource, projDest, pointSource);
+      document.getElementById('xyDest').value = pointDest.toShortString();
+    } else {
+      alert("Enter source coordinates");
+      return;
+  </script>
+</head>
+<body onload="initProj4js()">
+  <div id="header">
+    <h1>Proj4js Home Page</h1>
+  </div>
+  <div id="navbar">
+    <a href="http://trac.osgeo.org/proj4js">Proj4js Wiki/Trac</a> |
+    <a href="http://wiki.osgeo.org/wiki/MetaCRS">OSGeo MetaCRS</a> |
+    <a href="http://spatialreference.org/">spatialreference.org</a> |
+    <a href="http://communitymapbuilder.org/">MapBuilder</a> |
+    <a href="http://openlayers.org/">OpenLayers</a> |
+  </div>
+  <h1>Welcome to Proj4js</h1>
+  <p>
+This is a JavaScript library that provides methods for coordinate
+transformations between map projections and longitude/latitude,
+including datum transformations, in a web client.
+  </p>
+  <p>
+To use the Proj4js, you first create a source and destination Proj4js.Proj
+objects, passing in a projection code (e.g. EPSG:4326).
+You can then use the Proj4js.transform() method, passing in map XY as a point
+object and the source and destination projection objects,
+and it returns the point coordinate in the destination projection.
+  </p>
+  <form>
+  <table>
+    <tbody>
+      <tr>
+        <th colspan="3">source</th>
+        <th></th>
+        <th colspan="3">dest</th>
+      </tr>
+      <tr>
+        <td>CRS:</td>
+        <td colspan="2">
+          <select name="crsSource" id="crsSource" onchange="updateCrs('Source')">
+            <option value selected="selected">Select a CRS</option>
+          </select>
+        </td>
+        <td></td>
+        <td>CRS:</td>
+        <td colspan="2">
+          <select name="crsDest" id="crsDest" onchange="updateCrs('Dest')">
+          </select>
+        </td>
+      </tr>
+      <tr>
+        <td></td>
+        <td colspan="2" id="descSource">Projection - datum</td>
+        <td></td>
+        <td></td>
+        <td colspan="2" id="descDest">Projection - datum</td>
+      </tr>
+      <tr>
+        <td>x,y</td>
+        <td><input name="xySource" id="xySource" type="text"/></td>
+        <td id="unitsSource">units</td>
+        <td><input type="button" value="--> transform -->" onclick="transform();"/></td>
+        <td>x,y</td>
+        <td><input name="xyDest" id="xyDest" type="text"></td>
+        <td id="unitsDest">units</td>
+      </tr>
+      <tr>
+        <td colspan="7" align="center"><input type="reset" value="reset"/></td>
+      </tr>
+    </tbody>
+  </table>
+  </form>
+  <p>
+For more information on Proj4js and to report bugs, please visit the
+<a href="http://trac.osgeo.org/proj4js">Proj4js Trac and Wiki</a> at OSGeo.
+  </p>
+</body>
+</html>
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102757.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102757.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102757.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:102757"] = "+title=NAD 1983 StatePlane Wyoming West Central FIPS 4903 Feet +proj=tmerc +lat_0=40.5 +lon_0=-108.75 +x_0=600000.0 +y_0=0 +k=0.999938 +a=6378137.0  +b=6356752.3141403 +to_meter=0.3048006096012192";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102758.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102758.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG102758.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:102758"] = "+title=NAD 1983 StatePlane Wyoming West FIPS 4904 Feet +proj=tmerc +lat_0=40.5  +lon_0=-110.0833333333333 +x_0=800000  +y_0=100000  +k=0.999938 +a=6378137.0 +b=6356752.3141403 +to_meter=0.3048006096012192";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG21781.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG21781.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG21781.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:21781"] = "+title=CH1903 / LV03 +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333 +x_0=600000 +y_0=200000 +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +units=m +no_defs";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26591.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26591.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26591.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:26591"] = "+title= Monte Mario (Rome) / Italy zone 1 EPSG:26591 +proj=tmerc +lat_0=0 +lon_0=-3.45233333333333 +from_greenwich=12.45233333333333 +k=0.999600 +x_0=1500000 +y_0=0 +a=6378388.0, +b=6356911.94612795 +units=m";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26912.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26912.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG26912.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG26912"] = "+title=NAD83 / UTM zone 12N +proj=utm +zone=12 +a=6378137.0 +b=6356752.3141403";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27200.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27200.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27200.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,5 @@
+Proj4js.defs["EPSG:27200"] = "+title=New Zealand Map Grid\
+  +proj=nzmg \
+  +lat_0=-41 +lon_0=173 \
+  +x_0=2510000 +y_0=6023150 \
+  +ellps=intl +datum=nzgd49 +units=m +no_defs"
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27563.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27563.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG27563.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:27563"]="+title=NTF (Paris)/Lambert Sud France +proj=lcc +lat_1=44.10000000000001 +lat_0=44.10000000000001 +lon_0=0 +k_0=0.9998774990000001 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs ";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG41001.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG41001.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG41001.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:41001"] = "+title=simple mercator EPSG:41001 +proj=merc +lat_ts=0 +lon_0=0 +k=1.000000 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4139.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4139.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4139.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:4139"] = "+title=Puerto Rico EPSG:4139 (3 param datum shift) +proj=longlat +towgs84 = 11,72,-101,0,0,0,0 +a=6378206.4 +b=6356583.8";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4181.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4181.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4181.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:4181"] = "+title=Luxembourg 1930 EPSG:4181 (7 param datum shift) +proj=longlat +towgs84=-193,13.7,-39.3,-0.41,-2.933,2.688,0.43 +a=6378388.0, +b=6356911.94612795";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG42304.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG42304.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG42304.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:42304"]="+title=Atlas of Canada, LCC +proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4272.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4272.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4272.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1 @@
+Proj4js.defs["EPSG:4272"] = "+title=NZGD49 +proj=longlat +ellps=intl +datum=nzgd49 +no_defs ";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4302.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4302.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG4302.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,2 @@
+Proj4js.defs["EPSG:4302"] = "+title=Trinidad 1903 EPSG:4302 (7 param datum shift) +proj=longlat +a=6378293.63683822 +b=6356617.979337744 +towgs84=-61.702,284.488,472.052,0,0,0,0";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,5 @@
+// Google Mercator projection
+// Used in combination with GoogleMercator layer type in OpenLayers
+//+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
+Proj4js.defs["EPSG:900913"]= "+title= Google Mercator EPSG:900913 +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.txt
--- trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/EPSG900913.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,11 @@
+csList.EPSG900913= "\
+  +title= Google Mercator EPSG:900913\
+  +proj=merc +a=6378137 +b=6378137 \
+  +lat_ts=0.0 +lon_0=0.0 \
+  +x_0=0.0 +y_0=0 +k=1.0 \
+  +units=m +nadgrids=@null +no_defs \
Added: trunk/mapbender/http/extensions/proj4js/lib/defs/GOOGLE.js
--- trunk/mapbender/http/extensions/proj4js/lib/defs/GOOGLE.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/defs/GOOGLE.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,2 @@
+Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
+Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];
Added: trunk/mapbender/http/extensions/proj4js/lib/proj4js-combined.js
--- trunk/mapbender/http/extensions/proj4js/lib/proj4js-combined.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/proj4js-combined.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,4597 @@
+  proj4js.js -- Javascript reprojection library.
+  Authors:      Mike Adair madairATdmsolutions.ca
+                Richard Greenwood richATgreenwoodmap.com
+                Didier Richard
+                Stephen Irons
+  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+                Note: This program is an almost direct port of the C library
+                Proj4.
+    proj4js.js
+Author:       Mike Adair madairATdmsolutions.ca
+              Richard Greenwood rich at greenwoodmap.com
+License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+$Id: Proj.js 2956 2007-07-09 12:17:52Z steven $
+ * Namespace: Proj4js
+ * Proj4js is a JavaScript library to transform point coordinates from one
+ * coordinate system to another, including datum transformations.
+ * This library is a port of both the Proj.4 and GCTCP C libraries to JavaScript.
+ * Enabling these transformations in the browser allows geographic data stored
+ * in different projections to be combined in browser-based web mapping
+ * applications.
+ * Proj4js must have access to coordinate system initialization strings (which
+ * are the same as for PROJ.4 command line).  Thes can be included in your
+ * application using a <script> tag or Proj4js can load CS initialization
+ * strings from a local directory or a web service such as spatialreference.org.
+ * Similarly, Proj4js must have access to projection transform code.  These can
+ * be included individually using a <script> tag in your page, built into a
+ * custom build of Proj4js or loaded dynamically at run-time.  Using the
+ * -combined and -compressed versions of Proj4js includes all projection class
+ * code by default.
+ * Note that dynamic loading of defs and code happens ascynchrously, check the
+ * Proj.readyToUse flag before using the Proj object.  If the defs and code
+ * required by your application are loaded through script tags, dynamic loading
+ * is not required and the Proj object will be readyToUse on return from the
+ * constructor.
+ * All coordinates are handled as points which have a .x and a .y property
+ * which will be modified in place.
+ * Override Proj4js.reportError for output of alerts and warnings.
+ * See http://trac.osgeo.org/proj4js/wiki/UserGuide for full details.
+ * Global namespace object for Proj4js library
+Proj4js = {
+     * Property: defaultDatum
+     * The datum to use when no others a specified
+    defaultDatum: 'WGS84',                  //default datum
+    * Method: transform(source, dest, point)
+    * Transform a point coordinate from one map projection to another.  This is
+    * really the only public method you should need to use.
+    * Parameters:
+    * source - {Proj4js.Proj} source map projection for the transformation
+    * dest - {Proj4js.Proj} destination map projection for the transformation
+    * point - {Object} point to transform, may be geodetic (long, lat) or
+    *     projected Cartesian (x,y), but should always have x,y properties.
+    transform: function(source, dest, point) {
+        if (!source.readyToUse || !dest.readyToUse) {
+            this.reportError("Proj4js initialization for "+source.srsCode+" not yet complete");
+            return point;
+        // Workaround for Spherical Mercator
+        if ((source.srsProjNumber =="900913" && dest.datumCode != "WGS84") ||
+            (dest.srsProjNumber == "900913" && source.datumCode != "WGS84")) {
+            var wgs84 = Proj4js.WGS84;
+            this.transform(source, wgs84, point);
+            source = wgs84;
+        // Transform source points to long/lat, if they aren't already.
+        if ( source.projName=="longlat") {
+            point.x *= Proj4js.common.D2R;  // convert degrees to radians
+            point.y *= Proj4js.common.D2R;
+        } else {
+            if (source.to_meter) {
+                point.x *= source.to_meter;
+                point.y *= source.to_meter;
+            source.inverse(point); // Convert Cartesian to longlat
+        // Adjust for the prime meridian if necessary
+        if (source.from_greenwich) {
+            point.x += source.from_greenwich;
+        // Convert datums if needed, and if possible.
+        point = this.datum_transform( source.datum, dest.datum, point );
+        if (dest.from_greenwich) {
+            point.x -= dest.from_greenwich;
+        if( dest.projName=="longlat" ) {
+            // convert radians to decimal degrees
+            point.x *= Proj4js.common.R2D;
+            point.y *= Proj4js.common.R2D;
+        } else  {               // else project
+            dest.forward(point);
+            if (dest.to_meter) {
+                point.x /= dest.to_meter;
+                point.y /= dest.to_meter;
+        return point;
+    }, // transform()
+    /** datum_transform()
+      source coordinate system definition,
+      destination coordinate system definition,
+      point to transform in geodetic coordinates (long, lat, height)
+    datum_transform : function( source, dest, point ) {
+      // Short cut if the datums are identical.
+      if( source.compare_datums( dest ) ) {
+          return point; // in this case, zero is sucess,
+                    // whereas cs_compare_datums returns 1 to indicate TRUE
+                    // confusing, should fix this
+      // Explicitly skip datum transform by setting 'datum=none' as parameter for either source or dest
+      if( source.datum_type == Proj4js.common.PJD_NODATUM
+          || dest.datum_type == Proj4js.common.PJD_NODATUM) {
+          return point;
+      // If this datum requires grid shifts, then apply it to geodetic coordinates.
+      if( source.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+        alert("ERROR: Grid shift transformations are not implemented yet.");
+          pj_apply_gridshift( pj_param(source.params,"snadgrids").s, 0,
+                              point_count, point_offset, x, y, z );
+          CHECK_RETURN;
+          src_a = SRS_WGS84_SEMIMAJOR;
+          src_es = 0.006694379990;
+      if( dest.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+          dst_a = ;
+          dst_es = 0.006694379990;
+      // Do we need to go through geocentric coordinates?
+      if( source.es != dest.es || source.a != dest.a
+          || source.datum_type == Proj4js.common.PJD_3PARAM
+          || source.datum_type == Proj4js.common.PJD_7PARAM
+          || dest.datum_type == Proj4js.common.PJD_3PARAM
+          || dest.datum_type == Proj4js.common.PJD_7PARAM)
+        // Convert to geocentric coordinates.
+        source.geodetic_to_geocentric( point );
+        // CHECK_RETURN;
+        // Convert between datums
+        if( source.datum_type == Proj4js.common.PJD_3PARAM || source.datum_type == Proj4js.common.PJD_7PARAM ) {
+          source.geocentric_to_wgs84(point);
+          // CHECK_RETURN;
+        if( dest.datum_type == Proj4js.common.PJD_3PARAM || dest.datum_type == Proj4js.common.PJD_7PARAM ) {
+          dest.geocentric_from_wgs84(point);
+          // CHECK_RETURN;
+        // Convert back to geodetic coordinates
+        dest.geocentric_to_geodetic( point );
+          // CHECK_RETURN;
+      // Apply grid shift to destination if required
+        // pj_apply_gridshift( pj_param(dest.params,"snadgrids").s, 1, point);
+        // CHECK_RETURN;
+      return point;
+    }, // cs_datum_transform
+     * Function: reportError
+     * An internal method to report errors back to user.
+     * Override this in applications to report error messages or throw exceptions.
+    reportError: function(msg) {
+      //console.log(msg);
+ * Title: Private Methods
+ * The following properties and methods are intended for internal use only.
+ * This is a minimal implementation of JavaScript inheritance methods so that
+ * Proj4js can be used as a stand-alone library.
+ * These are copies of the equivalent OpenLayers methods at v2.7
+ * Function: extend
+ * Copy all properties of a source object to a destination object.  Modifies
+ *     the passed in destination object.  Any properties on the source object
+ *     that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+    extend: function(destination, source) {
+      destination = destination || {};
+      if(source) {
+          for(var property in source) {
+              var value = source[property];
+              if(value !== undefined) {
+                  destination[property] = value;
+      return destination;
+ * Constructor: Class
+ * Base class used to construct all other classes. Includes support for
+ *     multiple inheritance.
+    Class: function() {
+      var Class = function() {
+          this.initialize.apply(this, arguments);
+      var extended = {};
+      var parent;
+      for(var i=0; i<arguments.length; ++i) {
+          if(typeof arguments[i] == "function") {
+              // get the prototype of the superclass
+              parent = arguments[i].prototype;
+          } else {
+              // in this case we're extending with the prototype
+              parent = arguments[i];
+          Proj4js.extend(extended, parent);
+      Class.prototype = extended;
+      return Class;
+     * Function: bind
+     * Bind a function to an object.  Method to easily create closures with
+     *     'this' altered.
+     * Parameters:
+     * func - {Function} Input function.
+     * object - {Object} The object to bind to the input function (as this).
+     * Returns:
+     * {Function} A closure with 'this' set to the passed in object.
+    bind: function(func, object) {
+        // create a reference to all arguments past the second one
+        var args = Array.prototype.slice.apply(arguments, [2]);
+        return function() {
+            // Push on any additional arguments from the actual function call.
+            // These will come after those sent to the bind call.
+            var newArgs = args.concat(
+                Array.prototype.slice.apply(arguments, [0])
+            return func.apply(object, newArgs);
+ * The following properties and methods handle dynamic loading of JSON objects.
+     * Property: scriptName
+     * {String} The filename of this script without any path.
+    scriptName: "proj4js.js",
+     * Property: defsLookupService
+     * AJAX service to retreive projection definition parameters from
+    defsLookupService: 'http://spatialreference.org/ref',
+     * Property: libPath
+     * internal: http server path to library code.
+    libPath: null,
+     * Function: getScriptLocation
+     * Return the path to this script.
+     * Returns:
+     * Path to this script
+    getScriptLocation: function () {
+        if (this.libPath) return this.libPath;
+        var scriptName = this.scriptName;
+        var scriptNameLen = scriptName.length;
+        var scripts = document.getElementsByTagName('script');
+        for (var i = 0; i < scripts.length; i++) {
+            var src = scripts[i].getAttribute('src');
+            if (src) {
+                var index = src.lastIndexOf(scriptName);
+                // is it found, at the end of the URL?
+                if ((index > -1) && (index + scriptNameLen == src.length)) {
+                    this.libPath = src.slice(0, -scriptNameLen);
+                    break;
+        return this.libPath||"";
+     * Function: loadScript
+     * Load a JS file from a URL into a <script> tag in the page.
+     * Parameters:
+     * url - {String} The URL containing the script to load
+     * onload - {Function} A method to be executed when the script loads successfully
+     * onfail - {Function} A method to be executed when there is an error loading the script
+     * loadCheck - {Function} A boolean method that checks to see if the script
+     *            has loaded.  Typically this just checks for the existance of
+     *            an object in the file just loaded.
+    loadScript: function(url, onload, onfail, loadCheck) {
+      var script = document.createElement('script');
+      script.defer = false;
+      script.type = "text/javascript";
+      script.id = url;
+      script.src = url;
+      script.onload = onload;
+      script.onerror = onfail;
+      script.loadCheck = loadCheck;
+      if (/MSIE/.test(navigator.userAgent)) {
+        script.onreadystatechange = this.checkReadyState;
+      document.getElementsByTagName('head')[0].appendChild(script);
+     * Function: checkReadyState
+     * IE workaround since there is no onerror handler.  Calls the user defined
+     * loadCheck method to determine if the script is loaded.
+    checkReadyState: function() {
+      if (this.readyState == 'loaded') {
+        if (!this.loadCheck()) {
+          this.onerror();
+        } else {
+          this.onload();
+ * Class: Proj4js.Proj
+ * Proj objects provide transformation methods for point coordinates
+ * between geodetic latitude/longitude and a projected coordinate system.
+ * once they have been initialized with a projection code.
+ * Initialization of Proj objects is with a projection code, usually EPSG codes,
+ * which is the key that will be used with the Proj4js.defs array.
+ * The code passed in will be stripped of colons and converted to uppercase
+ * to locate projection definition files.
+ * A projection object has properties for units and title strings.
+Proj4js.Proj = Proj4js.Class({
+   * Property: readyToUse
+   * Flag to indicate if initialization is complete for this Proj object
+  readyToUse: false,
+   * Property: title
+   * The title to describe the projection
+  title: null,
+   * Property: projName
+   * The projection class for this projection, e.g. lcc (lambert conformal conic,
+   * or merc for mercator.  These are exactly equicvalent to their Proj4
+   * counterparts.
+  projName: null,
+   * Property: units
+   * The units of the projection.  Values include 'm' and 'degrees'
+  units: null,
+   * Property: datum
+   * The datum specified for the projection
+  datum: null,
+   * Constructor: initialize
+   * Constructor for Proj4js.Proj objects
+  * Parameters:
+  * srsCode - a code for map projection definition parameters.  These are usually
+  * (but not always) EPSG codes.
+  initialize: function(srsCode) {
+      this.srsCode = srsCode.toUpperCase();
+      if (this.srsCode.indexOf("EPSG") == 0) {
+          this.srsCode = this.srsCode;
+          this.srsAuth = 'epsg';
+          this.srsProjNumber = this.srsCode.substring(5);
+      // DGR 2007-11-20 : authority IGNF
+      } else if (this.srsCode.indexOf("IGNF") == 0) {
+          this.srsAuth = 'IGNF';
+      // DGR 2008-06-19 : pseudo-authority CRS for WMS
+      } else if (this.srsCode.indexOf("CRS") == 0) {
+          this.srsAuth = 'CRS';
+          this.srsProjNumber = this.srsCode.substring(4);
+      } else {
+          this.srsAuth = '';
+          this.srsProjNumber = this.srsCode;
+      this.loadProjDefinition();
+ * Function: loadProjDefinition
+ *    Loads the coordinate system initialization string if required.
+ *    Note that dynamic loading happens asynchronously so an application must
+ *    wait for the readyToUse property is set to true.
+ *    To prevent dynamic loading, include the defs through a script tag in
+ *    your application.
+    loadProjDefinition: function() {
+      //check in memory
+      if (Proj4js.defs[this.srsCode]) {
+        this.defsLoaded();
+        return;
+      //else check for def on the server
+      var url = Proj4js.getScriptLocation() + 'defs/' + this.srsAuth.toUpperCase() + this.srsProjNumber + '.js';
+      Proj4js.loadScript(url,
+                Proj4js.bind(this.defsLoaded, this),
+                Proj4js.bind(this.loadFromService, this),
+                Proj4js.bind(this.checkDefsLoaded, this) );
+ * Function: loadFromService
+ *    Creates the REST URL for loading the definition from a web service and
+ *    loads it.
+    loadFromService: function() {
+      //else load from web service
+      var url = Proj4js.defsLookupService +'/' + this.srsAuth +'/'+ this.srsProjNumber + '/proj4js';
+            Proj4js.bind(this.defsFailed, this),
+ * Function: defsLoaded
+ * Continues the Proj object initilization once the def file is loaded
+    defsLoaded: function() {
+      this.parseDefs();
+      this.loadProjCode(this.projName);
+ * Function: checkDefsLoaded
+ *    This is the loadCheck method to see if the def object exists
+    checkDefsLoaded: function() {
+        return true;
+      } else {
+        return false;
+ * Function: defsFailed
+ *    Report an error in loading the defs file, but continue on using WGS84
+   defsFailed: function() {
+      Proj4js.reportError('failed to load projection definition for: '+this.srsCode);
+      Proj4js.extend(Proj4js.defs[this.srsCode], Proj4js.defs['WGS84']);  //set it to something so it can at least continue
+ * Function: loadProjCode
+ *    Loads projection class code dynamically if required.
+ *     Projection code may be included either through a script tag or in
+ *     a built version of proj4js
+    loadProjCode: function(projName) {
+      if (Proj4js.Proj[projName]) {
+        this.initTransforms();
+        return;
+      //the URL for the projection code
+      var url = Proj4js.getScriptLocation() + 'projCode/' + projName + '.js';
+              Proj4js.bind(this.loadProjCodeSuccess, this, projName),
+              Proj4js.bind(this.loadProjCodeFailure, this, projName),
+              Proj4js.bind(this.checkCodeLoaded, this, projName) );
+ * Function: loadProjCodeSuccess
+ *    Loads any proj dependencies or continue on to final initialization.
+    loadProjCodeSuccess: function(projName) {
+      if (Proj4js.Proj[projName].dependsOn){
+        this.loadProjCode(Proj4js.Proj[projName].dependsOn);
+      } else {
+ *    Report an error in loading the proj file.  Initialization of the Proj
+ *    object has failed and the readyToUse flag will never be set.
+    loadProjCodeFailure: function(projName) {
+      Proj4js.reportError("failed to find projection file for: " + projName);
+      //TBD initialize with identity transforms so proj will still work?
+ * Function: checkCodeLoaded
+ *    This is the loadCheck method to see if the projection code is loaded
+    checkCodeLoaded: function(projName) {
+        return true;
+      } else {
+        return false;
+ * Function: initTransforms
+ *    Finalize the initialization of the Proj object
+    initTransforms: function() {
+      Proj4js.extend(this, Proj4js.Proj[this.projName]);
+      this.init();
+      this.readyToUse = true;
+ * Function: parseDefs
+ * Parses the PROJ.4 initialization string and sets the associated properties.
+  parseDefs: function() {
+      this.defData = Proj4js.defs[this.srsCode];
+      var paramName, paramVal;
+      var paramArray=this.defData.split("+");
+      for (var prop=0; prop<paramArray.length; prop++) {
+          var property = paramArray[prop].split("=");
+          paramName = property[0].toLowerCase();
+          paramVal = property[1];
+          switch (paramName.replace(/\s/gi,"")) {  // trim out spaces
+              case "": break;   // throw away nameless parameter
+              case "title":  this.title = paramVal; break;
+              case "proj":   this.projName =  paramVal.replace(/\s/gi,""); break;
+              case "units":  this.units = paramVal.replace(/\s/gi,""); break;
+              case "datum":  this.datumCode = paramVal.replace(/\s/gi,""); break;
+              case "nadgrids": this.nagrids = paramVal.replace(/\s/gi,""); break;
+              case "ellps":  this.ellps = paramVal.replace(/\s/gi,""); break;
+              case "a":      this.a =  parseFloat(paramVal); break;  // semi-major radius
+              case "b":      this.b =  parseFloat(paramVal); break;  // semi-minor radius
+              // DGR 2007-11-20
+              case "rf":     this.rf = parseFloat(paramVal); break; // inverse flattening rf= a/(a-b)
+              case "lat_0":  this.lat0 = paramVal*Proj4js.common.D2R; break;        // phi0, central latitude
+              case "lat_1":  this.lat1 = paramVal*Proj4js.common.D2R; break;        //standard parallel 1
+              case "lat_2":  this.lat2 = paramVal*Proj4js.common.D2R; break;        //standard parallel 2
+              case "lat_ts": this.lat_ts = paramVal*Proj4js.common.D2R; break;      // used in merc and eqc
+              case "lon_0":  this.long0 = paramVal*Proj4js.common.D2R; break;       // lam0, central longitude
+              case "alpha":  this.alpha =  parseFloat(paramVal)*Proj4js.common.D2R; break;  //for somerc projection
+              case "lonc":   this.longc = paramVal*Proj4js.common.D2R; break;       //for somerc projection
+              case "x_0":    this.x0 = parseFloat(paramVal); break;  // false easting
+              case "y_0":    this.y0 = parseFloat(paramVal); break;  // false northing
+              case "k_0":    this.k0 = parseFloat(paramVal); break;  // projection scale factor
+              case "k":      this.k0 = parseFloat(paramVal); break;  // both forms returned
+              case "R_A":    this.R = true; break;   //Spheroid radius
+              case "zone":   this.zone = parseInt(paramVal); break;  // UTM Zone
+              case "south":   this.utmSouth = true; break;  // UTM north/south
+              case "towgs84":this.datum_params = paramVal.split(","); break;
+              case "to_meter": this.to_meter = parseFloat(paramVal); break; // cartesian scaling
+              case "from_greenwich": this.from_greenwich = paramVal*Proj4js.common.D2R; break;
+              // DGR 2008-07-09 : if pm is not a well-known prime meridian take
+              // the value instead of 0.0, then convert to radians
+              case "pm":     paramVal = paramVal.replace(/\s/gi,"");
+                             this.from_greenwich = Proj4js.PrimeMeridian[paramVal] ?
+                                Proj4js.PrimeMeridian[paramVal] : parseFloat(paramVal);
+                             this.from_greenwich *= Proj4js.common.D2R;
+                             break;
+              case "no_defs": break;
+              default: //alert("Unrecognized parameter: " + paramName);
+          } // switch()
+      } // for paramArray
+      this.deriveConstants();
+ * Function: deriveConstants
+ * Sets several derived constant values and initialization of datum and ellipse
+ *     parameters.
+  deriveConstants: function() {
+      if (this.nagrids == '@null') this.datumCode = 'none';
+      if (this.datumCode && this.datumCode != 'none') {
+        var datumDef = Proj4js.Datum[this.datumCode];
+        if (datumDef) {
+          this.datum_params = datumDef.towgs84.split(',');
+          this.ellps = datumDef.ellipse;
+          this.datumName = datumDef.datumName ? datumDef.datumName : this.datumCode;
+      if (!this.a) {    // do we have an ellipsoid?
+          var ellipse = Proj4js.Ellipsoid[this.ellps] ? Proj4js.Ellipsoid[this.ellps] : Proj4js.Ellipsoid['WGS84'];
+          Proj4js.extend(this, ellipse);
+      if (this.rf && !this.b) this.b = (1.0 - 1.0/this.rf) * this.a;
+      if (Math.abs(this.a - this.b)<Proj4js.common.EPSLN) {
+        this.sphere = true;
+        this.b= this.a;
+      this.a2 = this.a * this.a;          // used in geocentric
+      this.b2 = this.b * this.b;          // used in geocentric
+      this.es = (this.a2-this.b2)/this.a2;  // e ^ 2
+      this.e = Math.sqrt(this.es);        // eccentricity
+      if (this.R_A) {
+        this.a *= 1. - this.es * (Proj4js.common.SIXTH + this.es * (Proj4js.RA4 + this.es * Proj4js.RA6));
+        this.es = 0.;
+      this.ep2=(this.a2-this.b2)/this.b2; // used in geocentric
+      if (!this.k0) this.k0 = 1.0;    //default value
+      this.datum = new Proj4js.datum(this);
+Proj4js.Proj.longlat = {
+  init: function() {
+    //no-op for longlat
+  forward: function(pt) {
+    //identity transform
+    return pt;
+  inverse: function(pt) {
+    return pt;
+  Proj4js.defs is a collection of coordinate system definition objects in the
+  PROJ.4 command line format.
+  Generally a def is added by means of a separate .js file for example:
+    <SCRIPT type="text/javascript" src="defs/EPSG26912.js"></SCRIPT>
+  def is a CS definition in PROJ.4 WKT format, for example:
+    +proj="tmerc"   //longlat, etc.
+    +a=majorRadius
+    +b=minorRadius
+    +lat0=somenumber
+    +long=somenumber
+Proj4js.defs = {
+  // These are so widely used, we'll go ahead and throw them in
+  // without requiring a separate .js file
+  'WGS84': "+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4326': "+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4269': "+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees"
+//+a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84",
+Proj4js.common = {
+  PI : 3.141592653589793238, //Math.PI,
+  HALF_PI : 1.570796326794896619, //Math.PI*0.5,
+  TWO_PI : 6.283185307179586477, //Math.PI*2,
+  FORTPI : 0.78539816339744833,
+  R2D : 57.29577951308232088,
+  D2R : 0.01745329251994329577,
+  SEC_TO_RAD : 4.84813681109535993589914102357e-6, /* SEC_TO_RAD = Pi/180/3600 */
+  EPSLN : 1.0e-10,
+  MAX_ITER : 20,
+  // following constants from geocent.c
+  COS_67P5 : 0.38268343236508977,  /* cosine of 67.5 degrees */
+  AD_C : 1.0026000,                /* Toms region 1 constant */
+  /* datum_type values */
+  PJD_UNKNOWN  : 0,
+  PJD_3PARAM   : 1,
+  PJD_7PARAM   : 2,
+  PJD_GRIDSHIFT: 3,
+  PJD_WGS84    : 4,   // WGS84 or equivalent
+  PJD_NODATUM  : 5,   // WGS84 or equivalent
+  SRS_WGS84_SEMIMAJOR : 6378137.0,  // only used in grid shift transforms
+  // ellipoid pj_set_ell.c
+  SIXTH : .1666666666666666667, /* 1/6 */
+  RA4   : .04722222222222222222, /* 17/360 */
+  RA6   : .02215608465608465608, /* 67/3024 */
+  RV4   : .06944444444444444444, /* 5/72 */
+  RV6   : .04243827160493827160, /* 55/1296 */
+// Function to compute the constant small m which is the radius of
+//   a parallel of latitude, phi, divided by the semimajor axis.
+  msfnz : function(eccent, sinphi, cosphi) {
+      var con = eccent * sinphi;
+      return cosphi/(Math.sqrt(1.0 - con * con));
+// Function to compute the constant small t for use in the forward
+//   computations in the Lambert Conformal Conic and the Polar
+//   Stereographic projections.
+  tsfnz : function(eccent, phi, sinphi) {
+    var com = .5 * eccent;
+    con = Math.pow(((1.0 - con) / (1.0 + con)), com);
+    return (Math.tan(.5 * (this.HALF_PI - phi))/con);
+// Function to compute the latitude angle, phi2, for the inverse of the
+//   Lambert Conformal Conic and Polar Stereographic projections.
+  phi2z : function(eccent, ts) {
+    var eccnth = .5 * eccent;
+    var con, dphi;
+    var phi = this.HALF_PI - 2 * Math.atan(ts);
+    for (i = 0; i <= 15; i++) {
+      con = eccent * Math.sin(phi);
+      dphi = this.HALF_PI - 2 * Math.atan(ts *(Math.pow(((1.0 - con)/(1.0 + con)),eccnth))) - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) return phi;
+    alert("phi2z has NoConvergence");
+    return (-9999);
+/* Function to compute constant small q which is the radius of a
+   parallel of latitude, phi, divided by the semimajor axis.
+  qsfnz : function(eccent,sinphi,cosphi) {
+    var con;
+    if (eccent > 1.0e-7) {
+      con = eccent * sinphi;
+      return (( 1.0- eccent * eccent) * (sinphi /(1.0 - con * con) - (.5/eccent)*Math.log((1.0 - con)/(1.0 + con))));
+    } else {
+      return(2.0 * sinphi);
+/* Function to eliminate roundoff errors in asin
+  asinz : function(x) {
+    if (Math.abs(x)>1.0) {
+      x=(x>1.0)?1.0:-1.0;
+    return Math.asin(x);
+// following functions from gctpc cproj.c for transverse mercator projections
+  e0fn : function(x) {return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},
+  e1fn : function(x) {return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},
+  e2fn : function(x) {return(0.05859375*x*x*(1.0+0.75*x));},
+  e3fn : function(x) {return(x*x*x*(35.0/3072.0));},
+  mlfn : function(e0,e1,e2,e3,phi) {return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},
+  srat : function(esinp, exp) {
+    return(Math.pow((1.0-esinp)/(1.0+esinp), exp));
+// Function to return the sign of an argument
+  sign : function(x) { if (x < 0.0) return(-1); else return(1);},
+// Function to adjust longitude to -180 to 180; input in radians
+  adjust_lon : function(x) {
+    x = (Math.abs(x) < this.PI) ? x: (x - (this.sign(x)*this.TWO_PI) );
+    return x;
+// IGNF - DGR : algorithms used by IGN France
+// Function to adjust latitude to -90 to 90; input in radians
+  adjust_lat : function(x) {
+    x= (Math.abs(x) < this.HALF_PI) ? x: (x - (this.sign(x)*this.PI) );
+    return x;
+// Latitude Isometrique - close to tsfnz ...
+  latiso : function(eccent, phi, sinphi)
+    if (Math.abs(phi) > this.HALF_PI) return +Number.NaN;
+    if (phi==this.HALF_PI) return Number.POSITIVE_INFINITY;
+    if (phi==-1.0*this.HALF_PI) return -1.0*Number.POSITIVE_INFINITY;
+    var con= eccent*sinphi;
+    return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;
+  fL : function(x,L) {
+    return 2.0*Math.atan(x*Math.exp(L)) - this.HALF_PI;
+// Inverse Latitude Isometrique - close to ph2z
+  invlatiso : function(eccent, ts) {
+    var phi= this.fL(1.0,ts);
+    var Iphi= 0.0;
+    var con= 0.0;
+    do {
+      Iphi= phi;
+      con= eccent*Math.sin(Iphi);
+      phi= this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)
+    } while (Math.abs(phi-Iphi)>1.0e-12);
+    return phi;
+// Needed for Gauss Laborde
+// Original:  Denis Makarov (info at binarythings.com)
+// Web Site:  http://www.binarythings.com
+  sinh : function(x)
+    var r= Math.exp(x);
+    r= (r-1.0/r)/2.0;
+    return r;
+  cosh : function(x)
+    r= (r+1.0/r)/2.0;
+    return r;
+  tanh : function(x)
+    r= (r-1.0/r)/(r+1.0/r);
+    return r;
+  asinh : function(x)
+    var s= (x>= 0? 1.0:-1.0);
+    return s*(Math.log( Math.abs(x) + Math.sqrt(x*x+1.0) ));
+  acosh : function(x)
+    return 2.0*Math.log(Math.sqrt((x+1.0)/2.0) + Math.sqrt((x-1.0)/2.0));
+  atanh : function(x)
+    return Math.log((x-1.0)/(x+1.0))/2.0;
+// Grande Normale
+  gN : function(a,e,sinphi)
+    var temp= e*sinphi;
+    return a/Math.sqrt(1.0 - temp*temp);
+/** datum object
+Proj4js.datum = Proj4js.Class({
+  initialize : function(proj) {
+    this.datum_type = Proj4js.common.PJD_WGS84;   //default setting
+    if (proj.datumCode && proj.datumCode == 'none') {
+      this.datum_type = Proj4js.common.PJD_NODATUM;
+    if (proj && proj.datum_params) {
+      for (var i=0; i<proj.datum_params.length; i++) {
+        proj.datum_params[i]=parseFloat(proj.datum_params[i]);
+      if (proj.datum_params[0] != 0 || proj.datum_params[1] != 0 || proj.datum_params[2] != 0 ) {
+        this.datum_type = Proj4js.common.PJD_3PARAM;
+      if (proj.datum_params.length > 3) {
+        if (proj.datum_params[3] != 0 || proj.datum_params[4] != 0 ||
+            proj.datum_params[5] != 0 || proj.datum_params[6] != 0 ) {
+          this.datum_type = Proj4js.common.PJD_7PARAM;
+          proj.datum_params[3] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[4] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[5] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[6] = (proj.datum_params[6]/1000000.0) + 1.0;
+    if (proj) {
+      this.a = proj.a;    //datum object also uses these values
+      this.b = proj.b;
+      this.es = proj.es;
+      this.ep2 = proj.ep2;
+      this.datum_params = proj.datum_params;
+  // cs_compare_datums()
+  //   Returns 1 (TRUE) if the two datums match, otherwise 0 (FALSE).
+  compare_datums : function( dest ) {
+    if( this.datum_type != dest.datum_type ) {
+      return false; // false, datums are not equal
+    } else if( this.a != dest.a || Math.abs(this.es-dest.es) > 0.000000000050 ) {
+      // the tolerence for es is to ensure that GRS80 and WGS84
+      // are considered identical
+      return false;
+    } else if( this.datum_type == Proj4js.common.PJD_3PARAM ) {
+      return (this.datum_params[0] == dest.datum_params[0]
+              && this.datum_params[1] == dest.datum_params[1]
+              && this.datum_params[2] == dest.datum_params[2]);
+    } else if( this.datum_type == Proj4js.common.PJD_7PARAM ) {
+              && this.datum_params[3] == dest.datum_params[3]
+              && this.datum_params[4] == dest.datum_params[4]
+              && this.datum_params[5] == dest.datum_params[5]
+              && this.datum_params[6] == dest.datum_params[6]);
+    } else if( this.datum_type == Proj4js.common.PJD_GRIDSHIFT ) {
+      return strcmp( pj_param(this.params,"snadgrids").s,
+                     pj_param(dest.params,"snadgrids").s ) == 0;
+    } else {
+      return true; // datums are equal
+  }, // cs_compare_datums()
+   * The function Convert_Geodetic_To_Geocentric converts geodetic coordinates
+   * (latitude, longitude, and height) to geocentric coordinates (X, Y, Z),
+   * according to the current ellipsoid parameters.
+   *    Latitude  : Geodetic latitude in radians                     (input)
+   *    Longitude : Geodetic longitude in radians                    (input)
+   *    Height    : Geodetic height, in meters                       (input)
+   *    X         : Calculated Geocentric X coordinate, in meters    (output)
+   *    Y         : Calculated Geocentric Y coordinate, in meters    (output)
+   *    Z         : Calculated Geocentric Z coordinate, in meters    (output)
+  geodetic_to_geocentric : function(p) {
+    var Longitude = p.x;
+    var Latitude = p.y;
+    var Height = p.z ? p.z : 0;   //Z value not always supplied
+    var X;  // output
+    var Y;
+    var Z;
+    var Error_Code=0;  //  GEOCENT_NO_ERROR;
+    var Rn;            /*  Earth radius at location  */
+    var Sin_Lat;       /*  Math.sin(Latitude)  */
+    var Sin2_Lat;      /*  Square of Math.sin(Latitude)  */
+    var Cos_Lat;       /*  Math.cos(Latitude)  */
+    ** Don't blow up if Latitude is just a little out of the value
+    ** range as it may just be a rounding issue.  Also removed longitude
+    ** test, it should be wrapped by Math.cos() and Math.sin().  NFW for PROJ.4, Sep/2001.
+    if( Latitude < -Proj4js.common.HALF_PI && Latitude > -1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = -Proj4js.common.HALF_PI;
+    } else if( Latitude > Proj4js.common.HALF_PI && Latitude < 1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = Proj4js.common.HALF_PI;
+    } else if ((Latitude < -Proj4js.common.HALF_PI) || (Latitude > Proj4js.common.HALF_PI)) {
+      /* Latitude out of range */
+      Proj4js.reportError('geocent:lat out of range:'+Latitude);
+      return null;
+    if (Longitude > Proj4js.common.PI) Longitude -= (2*Proj4js.common.PI);
+    Sin_Lat = Math.sin(Latitude);
+    Cos_Lat = Math.cos(Latitude);
+    Sin2_Lat = Sin_Lat * Sin_Lat;
+    Rn = this.a / (Math.sqrt(1.0e0 - this.es * Sin2_Lat));
+    X = (Rn + Height) * Cos_Lat * Math.cos(Longitude);
+    Y = (Rn + Height) * Cos_Lat * Math.sin(Longitude);
+    Z = ((Rn * (1 - this.es)) + Height) * Sin_Lat;
+    p.x = X;
+    p.y = Y;
+    p.z = Z;
+    return Error_Code;
+  }, // cs_geodetic_to_geocentric()
+  geocentric_to_geodetic : function (p) {
+/* local defintions and variables */
+/* end-criterium of loop, accuracy of sin(Latitude) */
+var genau = 1.E-12;
+var genau2 = (genau*genau);
+var maxiter = 30;
+    var P;        /* distance between semi-minor axis and location */
+    var RR;       /* distance between center and location */
+    var CT;       /* sin of geocentric latitude */
+    var ST;       /* cos of geocentric latitude */
+    var RX;
+    var RK;
+    var RN;       /* Earth radius at location */
+    var CPHI0;    /* cos of start or old geodetic latitude in iterations */
+    var SPHI0;    /* sin of start or old geodetic latitude in iterations */
+    var CPHI;     /* cos of searched geodetic latitude */
+    var SPHI;     /* sin of searched geodetic latitude */
+    var SDPHI;    /* end-criterium: addition-theorem of sin(Latitude(iter)-Latitude(iter-1)) */
+    var At_Pole;     /* indicates location is in polar region */
+    var iter;        /* # of continous iteration, max. 30 is always enough (s.a.) */
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0.0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    At_Pole = false;
+    P = Math.sqrt(X*X+Y*Y);
+    RR = Math.sqrt(X*X+Y*Y+Z*Z);
+/*      special cases for latitude and longitude */
+    if (P/this.a < genau) {
+/*  special case, if P=0. (X=0., Y=0.) */
+        At_Pole = true;
+        Longitude = 0.0;
+/*  if (X,Y,Z)=(0.,0.,0.) then Height becomes semi-minor axis
+ *  of ellipsoid (=center of mass), Latitude becomes PI/2 */
+        if (RR/this.a < genau) {
+            Height   = -this.b;
+            return;
+    } else {
+/*  ellipsoidal (geodetic) longitude
+ *  interval: -PI < Longitude <= +PI */
+        Longitude=Math.atan2(Y,X);
+ * Following iterative algorithm was developped by
+ * "Institut für Erdmessung", University of Hannover, July 1988.
+ * Internet: www.ife.uni-hannover.de
+ * Iterative computation of CPHI,SPHI and Height.
+ * Iteration of CPHI and SPHI to 10**-12 radian resp.
+ * 2*10**-7 arcsec.
+    CT = Z/RR;
+    ST = P/RR;
+    RX = 1.0/Math.sqrt(1.0-this.es*(2.0-this.es)*ST*ST);
+    CPHI0 = ST*(1.0-this.es)*RX;
+    SPHI0 = CT*RX;
+    iter = 0;
+/* loop to find sin(Latitude) resp. Latitude
+ * until |sin(Latitude(iter)-Latitude(iter-1))| < genau */
+    do
+        iter++;
+        RN = this.a/Math.sqrt(1.0-this.es*SPHI0*SPHI0);
+/*  ellipsoidal (geodetic) height */
+        Height = P*CPHI0+Z*SPHI0-RN*(1.0-this.es*SPHI0*SPHI0);
+        RK = this.es*RN/(RN+Height);
+        RX = 1.0/Math.sqrt(1.0-RK*(2.0-RK)*ST*ST);
+        CPHI = ST*(1.0-RK)*RX;
+        SPHI = CT*RX;
+        SDPHI = SPHI*CPHI0-CPHI*SPHI0;
+        CPHI0 = CPHI;
+        SPHI0 = SPHI;
+    while (SDPHI*SDPHI > genau2 && iter < maxiter);
+/*      ellipsoidal (geodetic) latitude */
+    Latitude=Math.atan(SPHI/Math.abs(CPHI));
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // cs_geocentric_to_geodetic()
+  /** Convert_Geocentric_To_Geodetic
+   * The method used here is derived from 'An Improved Algorithm for
+   * Geocentric to Geodetic Coordinate Conversion', by Ralph Toms, Feb 1996
+  geocentric_to_geodetic_noniter : function (p) {
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    var W;        /* distance from Z axis */
+    var W2;       /* square of distance from Z axis */
+    var T0;       /* initial estimate of vertical component */
+    var T1;       /* corrected estimate of vertical component */
+    var S0;       /* initial estimate of horizontal component */
+    var S1;       /* corrected estimate of horizontal component */
+    var Sin_B0;   /* Math.sin(B0), B0 is estimate of Bowring aux variable */
+    var Sin3_B0;  /* cube of Math.sin(B0) */
+    var Cos_B0;   /* Math.cos(B0) */
+    var Sin_p1;   /* Math.sin(phi1), phi1 is estimated latitude */
+    var Cos_p1;   /* Math.cos(phi1) */
+    var Sum;      /* numerator of Math.cos(phi1) */
+    X = parseFloat(X);  // cast from string to float
+    Y = parseFloat(Y);
+    Z = parseFloat(Z);
+    At_Pole = false;
+    if (X != 0.0)
+        Longitude = Math.atan2(Y,X);
+    else
+        if (Y > 0)
+            Longitude = Proj4js.common.HALF_PI;
+        else if (Y < 0)
+            Longitude = -Proj4js.common.HALF_PI;
+        else
+            At_Pole = true;
+            Longitude = 0.0;
+            if (Z > 0.0)
+            {  /* north pole */
+            else if (Z < 0.0)
+            {  /* south pole */
+            else
+            {  /* center of earth */
+                Height = -this.b;
+                return;
+    W2 = X*X + Y*Y;
+    W = Math.sqrt(W2);
+    T0 = Z * Proj4js.common.AD_C;
+    S0 = Math.sqrt(T0 * T0 + W2);
+    Sin_B0 = T0 / S0;
+    Cos_B0 = W / S0;
+    Sin3_B0 = Sin_B0 * Sin_B0 * Sin_B0;
+    T1 = Z + this.b * this.ep2 * Sin3_B0;
+    Sum = W - this.a * this.es * Cos_B0 * Cos_B0 * Cos_B0;
+    S1 = Math.sqrt(T1*T1 + Sum * Sum);
+    Sin_p1 = T1 / S1;
+    Cos_p1 = Sum / S1;
+    Rn = this.a / Math.sqrt(1.0 - this.es * Sin_p1 * Sin_p1);
+    if (Cos_p1 >= Proj4js.common.COS_67P5)
+        Height = W / Cos_p1 - Rn;
+    else if (Cos_p1 <= -Proj4js.common.COS_67P5)
+        Height = W / -Cos_p1 - Rn;
+    else
+        Height = Z / Sin_p1 + Rn * (this.es - 1.0);
+    if (At_Pole == false)
+        Latitude = Math.atan(Sin_p1 / Cos_p1);
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // geocentric_to_geodetic_noniter()
+  // pj_geocentic_to_wgs84( p )
+  //  p = point to transform in geocentric coordinates (x,y,z)
+  geocentric_to_wgs84 : function ( p ) {
+    if( this.datum_type == Proj4js.common.PJD_3PARAM )
+      // if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x += this.datum_params[0];
+      p.y += this.datum_params[1];
+      p.z += this.datum_params[2];
+    else if (this.datum_type == Proj4js.common.PJD_7PARAM)
+      var Dx_BF =this.datum_params[0];
+      var Dy_BF =this.datum_params[1];
+      var Dz_BF =this.datum_params[2];
+      var Rx_BF =this.datum_params[3];
+      var Ry_BF =this.datum_params[4];
+      var Rz_BF =this.datum_params[5];
+      var M_BF  =this.datum_params[6];
+      //    continue;
+      var x_out = M_BF*(       p.x - Rz_BF*p.y + Ry_BF*p.z) + Dx_BF;
+      var y_out = M_BF*( Rz_BF*p.x +       p.y - Rx_BF*p.z) + Dy_BF;
+      var z_out = M_BF*(-Ry_BF*p.x + Rx_BF*p.y +       p.z) + Dz_BF;
+      p.x = x_out;
+      p.y = y_out;
+      p.z = z_out;
+  }, // cs_geocentric_to_wgs84
+  // pj_geocentic_from_wgs84()
+  //  coordinate system definition,
+  //  point to transform in geocentric coordinates (x,y,z)
+  geocentric_from_wgs84 : function( p ) {
+      //if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x -= this.datum_params[0];
+      p.y -= this.datum_params[1];
+      p.z -= this.datum_params[2];
+      var x_tmp = (p.x - Dx_BF) / M_BF;
+      var y_tmp = (p.y - Dy_BF) / M_BF;
+      var z_tmp = (p.z - Dz_BF) / M_BF;
+      //    continue;
+      p.x =        x_tmp + Rz_BF*y_tmp - Ry_BF*z_tmp;
+      p.y = -Rz_BF*x_tmp +       y_tmp + Rx_BF*z_tmp;
+      p.z =  Ry_BF*x_tmp - Rx_BF*y_tmp +       z_tmp;
+    } //cs_geocentric_from_wgs84()
+/** point object, nothing fancy, just allows values to be
+    passed back and forth by reference rather than by value.
+    Other point classes may be used as long as they have
+    x and y properties, which will get modified in the transform method.
+Proj4js.Point = Proj4js.Class({
+     * Constructor! Proj4js.Point
+     * Parameters:
+     * - x {float} or {Array} either the first coordinates component or
+     *     the full coordinates
+     * - y {float} the second component
+     * - z {float} the third component, optional.
+    initialize : function(x,y,z) {
+      if (typeof x == 'object') {
+        this.x = x[0];
+        this.y = x[1];
+        this.z = x[2] || 0.0;
+      } else if (typeof x == 'string') {
+        var coords = x.split(',');
+        this.x = parseFloat(coords[0]);
+        this.y = parseFloat(coords[1]);
+        this.z = parseFloat(coords[2]) || 0.0;
+      } else {
+        this.x = x;
+        this.y = y;
+        this.z = z || 0.0;
+     * APIMethod: clone
+     * Build a copy of a Proj4js.Point object.
+     * Return:
+     * {Proj4js}.Point the cloned point.
+    clone : function() {
+      return new Proj4js.Point(this.x, this.y, this.z);
+     * APIMethod: toString
+     * Return a readable string version of the point
+     * Return:
+     * {String} String representation of Proj4js.Point object.
+     *           (ex. <i>"x=5,y=42"</i>)
+    toString : function() {
+        return ("x=" + this.x + ",y=" + this.y);
+     * APIMethod: toShortString
+     * Return a short string version of the point.
+     * Return:
+     * {String} Shortened String representation of Proj4js.Point object.
+     *         (ex. <i>"5, 42"</i>)
+    toShortString : function() {
+        return (this.x + ", " + this.y);
+Proj4js.PrimeMeridian = {
+    "greenwich": 0.0,               //"0dE",
+    "lisbon":     -9.131906111111,   //"9d07'54.862\"W",
+    "paris":       2.337229166667,   //"2d20'14.025\"E",
+    "bogota":    -74.080916666667,  //"74d04'51.3\"W",
+    "madrid":     -3.687938888889,  //"3d41'16.58\"W",
+    "rome":       12.452333333333,  //"12d27'8.4\"E",
+    "bern":        7.439583333333,  //"7d26'22.5\"E",
+    "jakarta":   106.807719444444,  //"106d48'27.79\"E",
+    "ferro":     -17.666666666667,  //"17d40'W",
+    "brussels":    4.367975,        //"4d22'4.71\"E",
+    "stockholm":  18.058277777778,  //"18d3'29.8\"E",
+    "athens":     23.7163375,       //"23d42'58.815\"E",
+    "oslo":       10.722916666667   //"10d43'22.5\"E"
+Proj4js.Ellipsoid = {
+  "MERIT": {a:6378137.0, rf:298.257, ellipseName:"MERIT 1983"},
+  "SGS85": {a:6378136.0, rf:298.257, ellipseName:"Soviet Geodetic System 85"},
+  "GRS80": {a:6378137.0, rf:298.257222101, ellipseName:"GRS 1980(IUGG, 1980)"},
+  "IAU76": {a:6378140.0, rf:298.257, ellipseName:"IAU 1976"},
+  "airy": {a:6377563.396, b:6356256.910, ellipseName:"Airy 1830"},
+  "APL4.": {a:6378137, rf:298.25, ellipseName:"Appl. Physics. 1965"},
+  "NWL9D": {a:6378145.0, rf:298.25, ellipseName:"Naval Weapons Lab., 1965"},
+  "mod_airy": {a:6377340.189, b:6356034.446, ellipseName:"Modified Airy"},
+  "andrae": {a:6377104.43, rf:300.0, ellipseName:"Andrae 1876 (Den., Iclnd.)"},
+  "aust_SA": {a:6378160.0, rf:298.25, ellipseName:"Australian Natl & S. Amer. 1969"},
+  "GRS67": {a:6378160.0, rf:298.2471674270, ellipseName:"GRS 67(IUGG 1967)"},
+  "bessel": {a:6377397.155, rf:299.1528128, ellipseName:"Bessel 1841"},
+  "bess_nam": {a:6377483.865, rf:299.1528128, ellipseName:"Bessel 1841 (Namibia)"},
+  "clrk66": {a:6378206.4, b:6356583.8, ellipseName:"Clarke 1866"},
+  "clrk80": {a:6378249.145, rf:293.4663, ellipseName:"Clarke 1880 mod."},
+  "CPM": {a:6375738.7, rf:334.29, ellipseName:"Comm. des Poids et Mesures 1799"},
+  "delmbr": {a:6376428.0, rf:311.5, ellipseName:"Delambre 1810 (Belgium)"},
+  "engelis": {a:6378136.05, rf:298.2566, ellipseName:"Engelis 1985"},
+  "evrst30": {a:6377276.345, rf:300.8017, ellipseName:"Everest 1830"},
+  "evrst48": {a:6377304.063, rf:300.8017, ellipseName:"Everest 1948"},
+  "evrst56": {a:6377301.243, rf:300.8017, ellipseName:"Everest 1956"},
+  "evrst69": {a:6377295.664, rf:300.8017, ellipseName:"Everest 1969"},
+  "evrstSS": {a:6377298.556, rf:300.8017, ellipseName:"Everest (Sabah & Sarawak)"},
+  "fschr60": {a:6378166.0, rf:298.3, ellipseName:"Fischer (Mercury Datum) 1960"},
+  "fschr60m": {a:6378155.0, rf:298.3, ellipseName:"Fischer 1960"},
+  "fschr68": {a:6378150.0, rf:298.3, ellipseName:"Fischer 1968"},
+  "helmert": {a:6378200.0, rf:298.3, ellipseName:"Helmert 1906"},
+  "hough": {a:6378270.0, rf:297.0, ellipseName:"Hough"},
+  "intl": {a:6378388.0, rf:297.0, ellipseName:"International 1909 (Hayford)"},
+  "kaula": {a:6378163.0, rf:298.24, ellipseName:"Kaula 1961"},
+  "lerch": {a:6378139.0, rf:298.257, ellipseName:"Lerch 1979"},
+  "mprts": {a:6397300.0, rf:191.0, ellipseName:"Maupertius 1738"},
+  "new_intl": {a:6378157.5, b:6356772.2, ellipseName:"New International 1967"},
+  "plessis": {a:6376523.0, rf:6355863.0, ellipseName:"Plessis 1817 (France)"},
+  "krass": {a:6378245.0, rf:298.3, ellipseName:"Krassovsky, 1942"},
+  "SEasia": {a:6378155.0, b:6356773.3205, ellipseName:"Southeast Asia"},
+  "walbeck": {a:6376896.0, b:6355834.8467, ellipseName:"Walbeck"},
+  "WGS60": {a:6378165.0, rf:298.3, ellipseName:"WGS 60"},
+  "WGS66": {a:6378145.0, rf:298.25, ellipseName:"WGS 66"},
+  "WGS72": {a:6378135.0, rf:298.26, ellipseName:"WGS 72"},
+  "WGS84": {a:6378137.0, rf:298.257223563, ellipseName:"WGS 84"},
+  "sphere": {a:6370997.0, b:6370997.0, ellipseName:"Normal Sphere (r=6370997)"}
+Proj4js.Datum = {
+  "WGS84": {towgs84: "0,0,0", ellipse: "WGS84", datumName: "WGS84"},
+  "GGRS87": {towgs84: "-199.87,74.79,246.62", ellipse: "GRS80", datumName: "Greek_Geodetic_Reference_System_1987"},
+  "NAD83": {towgs84: "0,0,0", ellipse: "GRS80", datumName: "North_American_Datum_1983"},
+  "NAD27": {nadgrids: "@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat", ellipse: "clrk66", datumName: "North_American_Datum_1927"},
+  "potsdam": {towgs84: "606.0,23.0,413.0", ellipse: "bessel", datumName: "Potsdam Rauenberg 1950 DHDN"},
+  "carthage": {towgs84: "-263.0,6.0,431.0", ellipse: "clark80", datumName: "Carthage 1934 Tunisia"},
+  "hermannskogel": {towgs84: "653.0,-212.0,449.0", ellipse: "bessel", datumName: "Hermannskogel"},
+  "ire65": {towgs84: "482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15", ellipse: "mod_airy", datumName: "Ireland 1965"},
+  "nzgd49": {towgs84: "59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993", ellipse: "intl", datumName: "New Zealand Geodetic Datum 1949"},
+  "OSGB36": {towgs84: "446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894", ellipse: "airy", datumName: "Airy 1830"}
+Proj4js.WGS84 = new Proj4js.Proj('WGS84');
+Proj4js.Datum['OSB36'] = Proj4js.Datum['OSGB36']; //as returned from spatialreference.org
+    projCode/aea.js
+NAME                     ALBERS CONICAL EQUAL AREA
+PURPOSE:	Transforms input longitude and latitude to Easting and Northing
+		for the Albers Conical Equal Area projection.  The longitude
+		and latitude must be in radians.  The Easting and Northing
+		values will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan,       	Feb, 1992
+ALGORITHM REFERENCES
+1.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+2.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+    Printing Office, Washington D.C., 1989.
+Proj4js.Proj.aea = {
+  init : function() {
+    if (Math.abs(this.lat1 + this.lat2) < Proj4js.common.EPSLN) {
+       Proj4js.reportError("aeaInitEqualLatitudes");
+       return;
+    this.temp = this.b / this.a;
+    this.es = 1.0 - Math.pow(this.temp,2);
+    this.e3 = Math.sqrt(this.es);
+    this.sin_po=Math.sin(this.lat1);
+    this.cos_po=Math.cos(this.lat1);
+    this.t1=this.sin_po
+    this.con = this.sin_po;
+    this.ms1 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs1 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat2);
+    this.cos_po=Math.cos(this.lat2);
+    this.t2=this.sin_po;
+    this.ms2 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs2 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat0);
+    this.cos_po=Math.cos(this.lat0);
+    this.t3=this.sin_po;
+    this.qs0 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    if (Math.abs(this.lat1 - this.lat2) > Proj4js.common.EPSLN) {
+      this.ns0 = (this.ms1 * this.ms1 - this.ms2 *this.ms2)/ (this.qs2 - this.qs1);
+    } else {
+      this.ns0 = this.con;
+    this.c = this.ms1 * this.ms1 + this.ns0 * this.qs1;
+    this.rh = this.a * Math.sqrt(this.c - this.ns0 * this.qs0)/this.ns0;
+/* Albers Conical Equal Area forward equations--mapping lat,long to x,y
+  forward: function(p){
+    var lon=p.x;
+    var lat=p.y;
+    this.sin_phi=Math.sin(lat);
+    this.cos_phi=Math.cos(lat);
+    var qs = Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);
+    var rh1 =this.a * Math.sqrt(this.c - this.ns0 * qs)/this.ns0;
+    var theta = this.ns0 * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = rh1 * Math.sin(theta) + this.x0;
+    var y = this.rh - rh1 * Math.cos(theta) + this.y0;
+    p.x = x;
+    p.y = y;
+    return p;
+  inverse: function(p) {
+    var rh1,qs,con,theta,lon,lat;
+    p.x -= this.x0;
+    p.y = this.rh - p.y + this.y0;
+    if (this.ns0 >= 0) {
+      rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt(p.x * p.x + p.y *p.y);
+      con = -1.0;
+    theta = 0.0;
+    if (rh1 != 0.0) {
+      theta = Math.atan2(con * p.x, con * p.y);
+    con = rh1 * this.ns0 / this.a;
+    qs = (this.c - con * con) / this.ns0;
+    if (this.e3 >= 1e-10) {
+      con = 1 - .5 * (1.0 -this.es) * Math.log((1.0 - this.e3) / (1.0 + this.e3))/this.e3;
+      if (Math.abs(Math.abs(con) - Math.abs(qs)) > .0000000001 ) {
+          lat = this.phi1z(this.e3,qs);
+      } else {
+          if (qs >= 0) {
+             lat = .5 * PI;
+          } else {
+             lat = -.5 * PI;
+    } else {
+      lat = this.phi1z(e3,qs);
+    lon = Proj4js.common.adjust_lon(theta/this.ns0 + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
+/* Function to compute phi1, the latitude for the inverse of the
+   Albers Conical Equal-Area projection.
+  phi1z: function (eccent,qs) {
+    var con, com, dphi;
+    var phi = Proj4js.common.asinz(.5 * qs);
+    if (eccent < Proj4js.common.EPSLN) return phi;
+    var eccnts = eccent * eccent;
+    for (var i = 1; i <= 25; i++) {
+        sinphi = Math.sin(phi);
+        cosphi = Math.cos(phi);
+        com = 1.0 - con * con;
+        dphi = .5 * com * com / cosphi * (qs / (1.0 - eccnts) - sinphi / com + .5 / eccent * Math.log((1.0 - con) / (1.0 + con)));
+        phi = phi + dphi;
+        if (Math.abs(dphi) <= 1e-7) return phi;
+    Proj4js.reportError("aea:phi1z:Convergence error");
+    return null;
+    projCode/sterea.js
+Proj4js.Proj.sterea = {
+  dependsOn : 'gauss',
+    Proj4js.Proj['gauss'].init.apply(this);
+    if (!this.rc) {
+      Proj4js.reportError("sterea:init:E_ERROR_0");
+      return;
+    this.sinc0 = Math.sin(this.phic0);
+    this.cosc0 = Math.cos(this.phic0);
+    this.R2 = 2.0 * this.rc;
+    if (!this.title) this.title = "Oblique Stereographic Alternative";
+  forward : function(p) {
+    p.x = Proj4js.common.adjust_lon(p.x-this.long0); /* adjust del longitude */
+    Proj4js.Proj['gauss'].forward.apply(this, [p]);
+    sinc = Math.sin(p.y);
+    cosc = Math.cos(p.y);
+    cosl = Math.cos(p.x);
+    k = this.k0 * this.R2 / (1.0 + this.sinc0 * sinc + this.cosc0 * cosc * cosl);
+    p.x = k * cosc * Math.sin(p.x);
+    p.y = k * (this.cosc0 * sinc - this.sinc0 * cosc * cosl);
+    p.x = this.a * p.x + this.x0;
+    p.y = this.a * p.y + this.y0;
+    return p;
+  inverse : function(p) {
+    var lon,lat;
+    p.x = (p.x - this.x0) / this.a; /* descale and de-offset */
+    p.y = (p.y - this.y0) / this.a;
+    p.x /= this.k0;
+    p.y /= this.k0;
+    if ( (rho = Math.sqrt(p.x*p.x + p.y*p.y)) ) {
+      c = 2.0 * Math.atan2(rho, this.R2);
+      sinc = Math.sin(c);
+      cosc = Math.cos(c);
+      lat = Math.asin(cosc * this.sinc0 + p.y * sinc * this.cosc0 / rho);
+      lon = Math.atan2(p.x * sinc, rho * this.cosc0 * cosc - p.y * this.sinc0 * sinc);
+    } else {
+      lat = this.phic0;
+      lon = 0.;
+    p.x = lon;
+    p.y = lat;
+    Proj4js.Proj['gauss'].inverse.apply(this,[p]);
+    p.x = Proj4js.common.adjust_lon(p.x + this.long0); /* adjust longitude to CM */
+    return p;
+    projCode/poly.js
+/* Function to compute, phi4, the latitude for the inverse of the
+   Polyconic projection.
+function phi4z (eccent,e0,e1,e2,e3,a,b,c,phi) {
+	var sinphi, sin2ph, tanph, ml, mlp, con1, con2, con3, dphi, i;
+	phi = a;
+	for (i = 1; i <= 15; i++) {
+		tanphi = Math.tan(phi);
+		c = tanphi * Math.sqrt (1.0 - eccent * sinphi * sinphi);
+		sin2ph = Math.sin (2.0 * phi);
+		ml = e0 * *phi - e1 * sin2ph + e2 * sin (4.0 *  *phi);
+		mlp = e0 - 2.0 * e1 * cos (2.0 *  *phi) + 4.0 * e2 *  cos (4.0 *  *phi);
+		ml = e0 * phi - e1 * sin2ph + e2 * Math.sin (4.0 *  phi) - e3 * Math.sin (6.0 * phi);
+		mlp = e0 - 2.0 * e1 * Math.cos (2.0 *  phi) + 4.0 * e2 * Math.cos (4.0 *  phi) - 6.0 * e3 * Math.cos (6.0 *  phi);
+		con1 = 2.0 * ml + c * (ml * ml + b) - 2.0 * a *  (c * ml + 1.0);
+		con2 = eccent * sin2ph * (ml * ml + b - 2.0 * a * ml) / (2.0 *c);
+		con3 = 2.0 * (a - ml) * (c * mlp - 2.0 / sin2ph) - 2.0 * mlp;
+		dphi = con1 / (con2 + con3);
+		phi += dphi;
+		if (Math.abs(dphi) <= .0000000001 ) return(phi);
+	Proj4js.reportError("phi4z: No convergence");
+	return null;
+/* Function to compute the constant e4 from the input of the eccentricity
+   of the spheroid, x.  This constant is used in the Polar Stereographic
+   projection.
+function e4fn(x) {
+	var con, com;
+	con = 1.0 + x;
+	com = 1.0 - x;
+	return (Math.sqrt((Math.pow(con,con))*(Math.pow(com,com))));
+NAME                             POLYCONIC
+		Northing for the Polyconic projection.  The
+		longitude and latitude must be in radians.  The Easting
+		and Northing values will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan		Mar, 1993
+Proj4js.Proj.poly = {
+	/* Initialize the POLYCONIC projection
+		var temp;			/* temporary variable		*/
+		if (this.lat0=0) this.lat0=90;//this.lat0 ca
+		/* Place parameters in static storage for common use
+		this.es = 1.0 - Math.pow(this.temp,2);// devait etre dans tmerc.js mais n y est pas donc je commente sinon retour de valeurs nulles
+		this.e0 = Proj4js.common.e0fn(this.es);
+		this.e1 = Proj4js.common.e1fn(this.es);
+		this.e2 = Proj4js.common.e2fn(this.es);
+		this.e3 = Proj4js.common.e3fn(this.es);
+		this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this.e2, this.e3, this.lat0);//si que des zeros le calcul ne se fait pas
+		//if (!this.ml0) {this.ml0=0;}
+	/* Polyconic forward equations--mapping lat,long to x,y
+	forward: function(p) {
+		var sinphi, cosphi;	/* sin and cos value				*/
+		var al;				/* temporary values				*/
+		var c;				/* temporary values				*/
+		var con, ml;		/* cone constant, small m			*/
+		var ms;				/* small m					*/
+		var x,y;
+		var lon=p.x;
+		var lat=p.y;
+		con = Proj4js.common.adjust_lon(lon - this.long0);
+		if (Math.abs(lat) <= .0000001) {
+			x = this.x0 + this.a * con;
+			y = this.y0 - this.a * this.ml0;
+		} else {
+			sinphi = Math.sin(lat);
+			cosphi = Math.cos(lat);
+			ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+			ms = Proj4js.common.msfnz(this.e,sinphi,cosphi);
+			con = sinphi;
+			x = this.x0 + this.a * ms * Math.sin(con)/sinphi;
+			y = this.y0 + this.a * (ml - this.ml0 + ms * (1.0 - Math.cos(con))/sinphi);
+		p.x=x;
+		p.y=y;
+		return p;
+	/* Inverse equations
+		var sin_phi, cos_phi;	/* sin and cos value				*/
+		var b;					/* temporary values				*/
+		var iflg;				/* error flag					*/
+		var lon,lat;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		al = this.ml0 + p.y/this.a;
+		iflg = 0;
+		if (Math.abs(al) <= .0000001) {
+			lon = p.x/this.a + this.long0;
+			lat = 0.0;
+		} else {
+			b = al * al + (p.x/this.a) * (p.x/this.a);
+			iflg = phi4z(this.es,this.e0,this.e1,this.e2,this.e3,this.al,b,c,lat);
+			if (iflg != 1) return(iflg);
+			lon = Proj4js.common.adjust_lon((asinz(p.x * c / this.a) / Math.sin(lat)) + this.long0);
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/equi.js
+NAME                             EQUIRECTANGULAR
+		Northing for the Equirectangular projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.equi = {
+    if(!this.x0) this.x0=0;
+    if(!this.y0) this.y0=0;
+    if(!this.lat0) this.lat0=0;
+    if(!this.long0) this.long0=0;
+    ///this.t2;
+/* Equirectangular forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    var x = this.x0 +this. a * dlon *Math.cos(this.lat0);
+    var y = this.y0 + this.a * lat;
+    this.t1=x;
+    this.t2=Math.cos(this.lat0);
+    p.x=x;
+    p.y=y;
+    return p;
+  },  //equiFwd()
+/* Equirectangular inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lat = p.y /this. a;
+    if ( Math.abs(lat) > Proj4js.common.HALF_PI) {
+        Proj4js.reportError("equi:Inv:DataError");
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x / (this.a * Math.cos(this.lat0)));
+    p.x=lon;
+    p.y=lat;
+  }//equiInv()
+    projCode/merc.js
+NAME                            MERCATOR
+		Northing for the Mercator projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      Nov, 1991
+//static double r_major = a;		   /* major axis 				*/
+//static double r_minor = b;		   /* minor axis 				*/
+//static double lon_center = long0;	   /* Center longitude (projection center) */
+//static double lat_origin =  lat0;	   /* center latitude			*/
+//static double e,es;		           /* eccentricity constants		*/
+//static double m1;		               /* small value m			*/
+//static double false_northing = y0;   /* y offset in meters			*/
+//static double false_easting = x0;	   /* x offset in meters			*/
+//scale_fact = k0
+Proj4js.Proj.merc = {
+	//?this.temp = this.r_minor / this.r_major;
+	//this.temp = this.b / this.a;
+	//this.es = 1.0 - Math.sqrt(this.temp);
+	//this.e = Math.sqrt( this.es );
+	//?this.m1 = Math.cos(this.lat_origin) / (Math.sqrt( 1.0 - this.es * Math.sin(this.lat_origin) * Math.sin(this.lat_origin)));
+	//this.m1 = Math.cos(0.0) / (Math.sqrt( 1.0 - this.es * Math.sin(0.0) * Math.sin(0.0)));
+    if (this.lat_ts) {
+      if (this.sphere) {
+        this.k0 = Math.cos(this.lat_ts);
+      } else {
+        this.k0 = Proj4js.common.msfnz(this.es, Math.sin(this.lat_ts), Math.cos(this.lat_ts));
+/* Mercator forward equations--mapping lat,long to x,y
+    //alert("ll2m coords : "+coords);
+    var lon = p.x;
+    var lat = p.y;
+    // convert to radians
+    if ( lat*Proj4js.common.R2D > 90.0 &&
+          lat*Proj4js.common.R2D < -90.0 &&
+          lon*Proj4js.common.R2D > 180.0 &&
+          lon*Proj4js.common.R2D < -180.0) {
+      Proj4js.reportError("merc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+      return null;
+    var x,y;
+    if(Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI)  <= Proj4js.common.EPSLN) {
+      Proj4js.reportError("merc:forward: ll2mAtPoles");
+      return null;
+    } else {
+        x = this.x0 + this.a * this.k0 * Proj4js.common.adjust_lon(lon - this.long0);
+        y = this.y0 + this.a * this.k0 * Math.log(Math.tan(Proj4js.common.FORTPI + 0.5*lat));
+      } else {
+        var sinphi = Math.sin(lat);
+        var ts = Proj4js.common.tsfnz(this.e,lat,sinphi);
+        y = this.y0 - this.a * this.k0 * Math.log(ts);
+      p.x = x;
+      p.y = y;
+      return p;
+  /* Mercator inverse equations--mapping x,y to lat/long
+    var x = p.x - this.x0;
+    var y = p.y - this.y0;
+    var lon,lat;
+      lat = Proj4js.common.HALF_PI - 2.0 * Math.atan(Math.exp(-y / this.a * this.k0));
+    } else {
+      var ts = Math.exp(-y / (this.a * this.k0));
+      lat = Proj4js.common.phi2z(this.e,ts);
+      if(lat == -9999) {
+        Proj4js.reportError("merc:inverse: lat = -9999");
+        return null;
+    lon = Proj4js.common.adjust_lon(this.long0+ x / (this.a * this.k0));
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/utm.js
+NAME                            TRANSVERSE MERCATOR
+		Northing for the Transverse Mercator projection.  The
+  Initialize Transverse Mercator projection
+Proj4js.Proj.utm = {
+  dependsOn : 'tmerc',
+    if (!this.zone) {
+      Proj4js.reportError("utm:init: zone must be specified for UTM");
+      return;
+    this.lat0 = 0.0;
+    this.long0 = ((6 * Math.abs(this.zone)) - 183) * Proj4js.common.D2R;
+    this.x0 = 500000.0;
+    this.y0 = this.utmSouth ? 10000000.0 : 0.0;
+    this.k0 = 0.9996;
+    Proj4js.Proj['tmerc'].init.apply(this);
+    this.forward = Proj4js.Proj['tmerc'].forward;
+    this.inverse = Proj4js.Proj['tmerc'].inverse;
+    projCode/eqdc.js
+NAME                            EQUIDISTANT CONIC
+		for the Equidistant Conic projection.  The longitude and
+		latitude must be in radians.  The Easting and Northing values
+		will be returned in meters.
+PROGRAMMER              DATE
+/* Variables common to all subroutines in this code file
+Proj4js.Proj.eqdc = {
+/* Initialize the Equidistant Conic projection
+    if(!this.mode) this.mode=0;//chosen default mode
+    this.sinphi=Math.sin(this.lat1);
+    this.cosphi=Math.cos(this.lat1);
+    this.ms1 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+    this.ml1 = Proj4js.common.mlfn(this.e0, this.e1, this.e2,this.e3, this.lat1);
+    /* format B
+    if (this.mode != 0) {
+            Proj4js.reportError("eqdc:Init:EqualLatitudes");
+            //return(81);
+       this.sinphi=Math.sin(this.lat2);
+       this.cosphi=Math.cos(this.lat2);
+       this.ms2 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+       this.ml2 = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat2);
+       if (Math.abs(this.lat1 - this.lat2) >= Proj4js.common.EPSLN) {
+         this.ns = (this.ms1 - this.ms2) / (this.ml2 - this.ml1);
+       } else {
+          this.ns = this.sinphi;
+    } else {
+    this.g = this.ml1 + this.ms1/this.ns;
+    this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this. e2, this.e3, this.lat0);
+    this.rh = this.a * (this.g - this.ml0);
+/* Equidistant Conic forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    /* Forward equations
+    var ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+    var rh1 = this.a * (this.g - ml);
+    var theta = this.ns * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = this.x0  + rh1 * Math.sin(theta);
+    var y = this.y0 + this.rh - rh1 * Math.cos(theta);
+    p.x=x;
+    p.y=y;
+    return p;
+/* Inverse equations
+    p.x -= this.x0;
+    var con, rh1;
+    if (this.ns >= 0) {
+       var rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+       var con = 1.0;
+    } else {
+       rh1 = -Math.sqrt(p.x *p. x +p. y * p.y);
+       con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0.0) theta = Math.atan2(con *p.x, con *p.y);
+    var ml = this.g - rh1 /this.a;
+    var lat = this.phi3z(this.ml,this.e0,this.e1,this.e2,this.e3);
+    var lon = Proj4js.common.adjust_lon(this.long0 + theta / this.ns);
+     p.x=lon;
+     p.y=lat;
+     return p;
+/* Function to compute latitude, phi3, for the inverse of the Equidistant
+   Conic projection.
+  phi3z: function(ml,e0,e1,e2,e3) {
+    var phi;
+    var dphi;
+    phi = ml;
+    for (var i = 0; i < 15; i++) {
+      dphi = (ml + e1 * Math.sin(2.0 * phi) - e2 * Math.sin(4.0 * phi) + e3 * Math.sin(6.0 * phi))/ e0 - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) {
+        return phi;
+    Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");
+    return null;
+    projCode/tmerc.js
+Proj4js.Proj.tmerc = {
+    this.ml0 = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat0);
+    Transverse Mercator Forward  - long/lat to x/y
+    long/lat in radians
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lon = Proj4js.common.adjust_lon(lon - this.long0); // Delta longitude
+    var con;    // cone constant
+    var x, y;
+    var sin_phi=Math.sin(lat);
+    var cos_phi=Math.cos(lat);
+    if (this.sphere) {  /* spherical form */
+      var b = cos_phi * Math.sin(delta_lon);
+      if ((Math.abs(Math.abs(b) - 1.0)) < .0000000001)  {
+        Proj4js.reportError("tmerc:forward: Point projects into infinity");
+        return(93);
+      } else {
+        x = .5 * this.a * this.k0 * Math.log((1.0 + b)/(1.0 - b));
+        con = Math.acos(cos_phi * Math.cos(delta_lon)/Math.sqrt(1.0 - b*b));
+        if (lat < 0) con = - con;
+        y = this.a * this.k0 * (con - this.lat0);
+    } else {
+      var al  = cos_phi * delta_lon;
+      var als = Math.pow(al,2);
+      var c   = this.ep2 * Math.pow(cos_phi,2);
+      var tq  = Math.tan(lat);
+      var t   = Math.pow(tq,2);
+      con = 1.0 - this.es * Math.pow(sin_phi,2);
+      var n   = this.a / Math.sqrt(con);
+      var ml  = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+      x = this.k0 * n * al * (1.0 + als / 6.0 * (1.0 - t + c + als / 20.0 * (5.0 - 18.0 * t + Math.pow(t,2) + 72.0 * c - 58.0 * this.ep2))) + this.x0;
+      y = this.k0 * (ml - this.ml0 + n * tq * (als * (0.5 + als / 24.0 * (5.0 - t + 9.0 * c + 4.0 * Math.pow(c,2) + als / 30.0 * (61.0 - 58.0 * t + Math.pow(t,2) + 600.0 * c - 330.0 * this.ep2))))) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+  }, // tmercFwd()
+    Transverse Mercator Inverse  -  x/y to long/lat
+    var con, phi;  /* temporary angles       */
+    var delta_phi; /* difference between longitudes    */
+    var i;
+    var max_iter = 6;      /* maximun number of iterations */
+    var lat, lon;
+      var f = Math.exp(p.x/(this.a * this.k0));
+      var g = .5 * (f - 1/f);
+      var temp = this.lat0 + p.y/(this.a * this.k0);
+      var h = Math.cos(temp);
+      con = Math.sqrt((1.0 - h * h)/(1.0 + g * g));
+      lat = Math.asinz(con);
+      if (temp < 0)
+        lat = -lat;
+      if ((g == 0) && (h == 0)) {
+        lon = this.long0;
+      } else {
+        lon = Proj4js.common.adjust_lon(Math.atan2(g,h) + this.long0);
+    } else {    // ellipsoidal form
+      con = (this.ml0 + y / this.k0) / this.a;
+      phi = con;
+      for (i=0;;i++) {
+        delta_phi=((con + this.e1 * Math.sin(2.0*phi) - this.e2 * Math.sin(4.0*phi) + this.e3 * Math.sin(6.0*phi)) / this.e0) - phi;
+        phi += delta_phi;
+        if (Math.abs(delta_phi) <= Proj4js.common.EPSLN) break;
+        if (i >= max_iter) {
+          Proj4js.reportError("tmerc:inverse: Latitude failed to converge");
+          return(95);
+      } // for()
+      if (Math.abs(phi) < Proj4js.common.HALF_PI) {
+        // sincos(phi, &sin_phi, &cos_phi);
+        var sin_phi=Math.sin(phi);
+        var cos_phi=Math.cos(phi);
+        var tan_phi = Math.tan(phi);
+        var cs = Math.pow(c,2);
+        var t = Math.pow(tan_phi,2);
+        var ts = Math.pow(t,2);
+        var r = n * (1.0 - this.es) / con;
+        var d = x / (n * this.k0);
+        var ds = Math.pow(d,2);
+        lat = phi - (n * tan_phi * ds / r) * (0.5 - ds / 24.0 * (5.0 + 3.0 * t + 10.0 * c - 4.0 * cs - 9.0 * this.ep2 - ds / 30.0 * (61.0 + 90.0 * t + 298.0 * c + 45.0 * ts - 252.0 * this.ep2 - 3.0 * cs)));
+        lon = Proj4js.common.adjust_lon(this.long0 + (d * (1.0 - ds / 6.0 * (1.0 + 2.0 * t + c - ds / 20.0 * (5.0 - 2.0 * c + 28.0 * t - 3.0 * cs + 8.0 * this.ep2 + 24.0 * ts))) / cos_phi));
+      } else {
+        lat = Proj4js.common.HALF_PI * Proj4js.common.sign(y);
+        lon = this.long0;
+    p.x = lon;
+    p.y = lat;
+    return p;
+  } // tmercInv()
+    defs/GOOGLE.js
+Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";
+Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];
+    projCode/gstmerc.js
+Proj4js.Proj.gstmerc = {
+    // array of:  a, b, lon0, lat0, k0, x0, y0
+      var temp= this.b / this.a;
+      this.e= Math.sqrt(1.0 - temp*temp);
+      this.lc= this.long0;
+      this.rs= Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));
+      var sinz= Math.sin(this.lat0);
+      var pc= Math.asin(sinz/this.rs);
+      var sinzpc= Math.sin(pc);
+      this.cp= Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);
+      this.n2= this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);
+      this.xs= this.x0;
+      this.ys= this.y0-this.n2*pc;
+      if (!this.title) this.title = "Gauss Schreiber transverse mercator";
+    // forward equations--mapping lat,long to x,y
+      var lon= p.x;
+      var lat= p.y;
+      var L= this.rs*(lon-this.lc);
+      var Ls= this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));
+      var lat1= Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));
+      var Ls1= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+      p.x= this.xs+(this.n2*Ls1);
+      p.y= this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));
+      return p;
+  // inverse equations--mapping x,y to lat/long
+    var x= p.x;
+    var y= p.y;
+    var L= Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));
+    var lat1= Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));
+    var LC= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+    p.x= this.lc+L/this.rs;
+    p.y= Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);
+    return p;
+    projCode/ortho.js
+NAME                             ORTHOGRAPHIC
+		Northing for the Orthographic projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.ortho = {
+  /* Initialize the Orthographic projection
+  init: function(def) {
+    //double temp;			/* temporary variable		*/
+    this.sin_p14=Math.sin(this.lat0);
+    this.cos_p14=Math.cos(this.lat0);
+  /* Orthographic forward equations--mapping lat,long to x,y
+    var dlon;		/* delta longitude value			*/
+    var coslon;		/* cos of longitude				*/
+    var ksp;		/* scale factor					*/
+    var g;
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    sinphi=Math.sin(lat);
+    cosphi=Math.cos(lat);
+    coslon = Math.cos(dlon);
+    g = this.sin_p14 * sinphi + this.cos_p14 * cosphi * coslon;
+    ksp = 1.0;
+    if ((g > 0) || (Math.abs(g) <= Proj4js.common.EPSLN)) {
+      var x = this.a * ksp * cosphi * Math.sin(dlon);
+      var y = this.y0 + this.a * ksp * (this.cos_p14 * sinphi - this.sin_p14 * cosphi * coslon);
+    } else {
+      Proj4js.reportError("orthoFwdPointError");
+    p.x=x;
+    p.y=y;
+    return p;
+    var rh;		/* height above ellipsoid			*/
+    var z;		/* angle					*/
+    var sinz,cosz;	/* sin of z and cos of z			*/
+    var temp;
+    var con;
+    var lon , lat;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    rh = Math.sqrt(p.x * p.x + p.y * p.y);
+    if (rh > this.a + .0000001) {
+      Proj4js.reportError("orthoInvDataError");
+    z = Proj4js.common.asinz(rh / this.a);
+    sinz=Math.sin(z);
+    cosi=Math.cos(z);
+    lon = this.long0;
+    if (Math.abs(rh) <= Proj4js.common.EPSLN) {
+      lat = this.lat0;
+    lat = Proj4js.common.asinz(cosz * this.sin_p14 + (y * sinz * this.cos_p14)/rh);
+    con = Math.abs(lat0) - Proj4js.common.HALF_PI;
+    if (Math.abs(con) <= Proj4js.common.EPSLN) {
+       if (this.lat0 >= 0) {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x, -p.y));
+       } else {
+          lon = Proj4js.common.adjust_lon(this.long0 -Math.atan2(-p.x, p.y));
+    con = cosz - this.sin_p14 * Math.sin(lat);
+    if ((Math.abs(con) >= Proj4js.common.EPSLN) || (Math.abs(x) >= Proj4js.common.EPSLN)) {
+       lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2((p.x * sinz * this.cos_p14), (con * rh)));
+    p.x=lon;
+    p.y=lat;
+    return p;
+    projCode/somerc.js
+NAME                       SWISS OBLIQUE MERCATOR
+PURPOSE:	Swiss projection.
+WARNING:  X and Y are inverted (weird) in the swiss coordinate system. Not
+   here, since we want X to be horizontal and Y vertical.
+1. "Formules et constantes pour le Calcul pour la
+ projection cylindrique conforme à axe oblique et pour la transformation entre
+ des systèmes de référence".
+ http://www.swisstopo.admin.ch/internet/swisstopo/fr/home/topics/survey/sys/refsys/switzerland.parsysrelated1.31216.downloadList.77004.DownloadFile.tmp/swissprojectionfr.pdf
+Proj4js.Proj.somerc = {
+    var phy0 = this.lat0;
+    this.lambda0 = this.long0;
+    var sinPhy0 = Math.sin(phy0);
+    var semiMajorAxis = this.a;
+    var invF = this.rf;
+    var flattening = 1 / invF;
+    var e2 = 2 * flattening - Math.pow(flattening, 2);
+    var e = this.e = Math.sqrt(e2);
+    this.R = semiMajorAxis * Math.sqrt(1 - e2) / (1 - e2 * Math.pow(sinPhy0, 2.0));
+    this.alpha = Math.sqrt(1 + e2 / (1 - e2) * Math.pow(Math.cos(phy0), 4.0));
+    this.b0 = Math.asin(sinPhy0 / this.alpha);
+    this.K = Math.log(Math.tan(Math.PI / 4.0 + this.b0 / 2.0))
+            - this.alpha
+            * Math.log(Math.tan(Math.PI / 4.0 + phy0 / 2.0))
+            + this.alpha
+            * e / 2
+            * Math.log((1 + e * sinPhy0)
+            / (1 - e * sinPhy0));
+    var Sa1 = Math.log(Math.tan(Math.PI / 4.0 - p.y / 2.0));
+    var Sa2 = this.e / 2.0
+            * Math.log((1 + this.e * Math.sin(p.y))
+            / (1 - this.e * Math.sin(p.y)));
+    var S = -this.alpha * (Sa1 + Sa2) + this.K;
+        // spheric latitude
+    var b = 2.0 * (Math.atan(Math.exp(S)) - Math.PI / 4.0);
+        // spheric longitude
+    var I = this.alpha * (p.x - this.lambda0);
+        // psoeudo equatorial rotation
+    var rotI = Math.atan(Math.sin(I)
+            / (Math.sin(this.b0) * Math.tan(b) +
+               Math.cos(this.b0) * Math.cos(I)));
+    var rotB = Math.asin(Math.cos(this.b0) * Math.sin(b) -
+                         Math.sin(this.b0) * Math.cos(b) * Math.cos(I));
+    p.y = this.R / 2.0
+            * Math.log((1 + Math.sin(rotB)) / (1 - Math.sin(rotB)))
+            + this.y0;
+    p.x = this.R * rotI + this.x0;
+    return p;
+    var Y = p.x - this.x0;
+    var X = p.y - this.y0;
+    var rotI = Y / this.R;
+    var rotB = 2 * (Math.atan(Math.exp(X / this.R)) - Math.PI / 4.0);
+    var b = Math.asin(Math.cos(this.b0) * Math.sin(rotB)
+            + Math.sin(this.b0) * Math.cos(rotB) * Math.cos(rotI));
+    var I = Math.atan(Math.sin(rotI)
+            / (Math.cos(this.b0) * Math.cos(rotI) - Math.sin(this.b0)
+            * Math.tan(rotB)));
+    var lambda = this.lambda0 + I / this.alpha;
+    var S = 0.0;
+    var phy = b;
+    var prevPhy = -1000.0;
+    var iteration = 0;
+    while (Math.abs(phy - prevPhy) > 0.0000001)
+      if (++iteration > 20)
+        Proj4js.reportError("omercFwdInfinity");
+        return;
+      //S = Math.log(Math.tan(Math.PI / 4.0 + phy / 2.0));
+      S = 1.0
+              / this.alpha
+              * (Math.log(Math.tan(Math.PI / 4.0 + b / 2.0)) - this.K)
+              + this.e
+              + Math.asin(this.e * Math.sin(phy))
+              / 2.0));
+      prevPhy = phy;
+      phy = 2.0 * Math.atan(Math.exp(S)) - Math.PI / 2.0;
+    p.x = lambda;
+    p.y = phy;
+    return p;
+    projCode/stere.js
+// Initialize the Stereographic projection
+Proj4js.Proj.stere = {
+  ssfn_: function(phit, sinphi, eccen) {
+  	sinphi *= eccen;
+  	return (Math.tan (.5 * (Proj4js.common.HALF_PI + phit)) * Math.pow((1. - sinphi) / (1. + sinphi), .5 * eccen));
+  TOL:	1.e-8,
+  NITER:	8,
+  CONV:	1.e-10,
+  S_POLE:	0,
+  N_POLE:	1,
+  OBLIQ:	2,
+  EQUIT:	3,
+  	this.phits = this.lat_ts ? this.lat_ts : Proj4js.common.HALF_PI;
+    var t = Math.abs(this.lat0);
+  	if ((Math.abs(t) - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  		this.mode = this.lat0 < 0. ? this.S_POLE : this.N_POLE;
+  	} else {
+  		this.mode = t > Proj4js.common.EPSLN ? this.OBLIQ : this.EQUIT;
+  	this.phits = Math.abs(this.phits);
+  	if (this.es) {
+  		var X;
+  		switch (this.mode) {
+  		case this.N_POLE:
+  		case this.S_POLE:
+  			if (Math.abs(this.phits - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  				this.akm1 = 2. * this.k0 / Math.sqrt(Math.pow(1+this.e,1+this.e)*Math.pow(1-this.e,1-this.e));
+  			} else {
+          t = Math.sin(this.phits);
+  				this.akm1 = Math.cos(this.phits) / Proj4js.common.tsfnz(this.e, this.phits, t);
+  				t *= this.e;
+  				this.akm1 /= Math.sqrt(1. - t * t);
+  			break;
+  		case this.EQUIT:
+  			this.akm1 = 2. * this.k0;
+  			break;
+  		case this.OBLIQ:
+  			t = Math.sin(this.lat0);
+  			X = 2. * Math.atan(this.ssfn_(this.lat0, t, this.e)) - Proj4js.common.HALF_PI;
+  			t *= this.e;
+  			this.akm1 = 2. * this.k0 * Math.cos(this.lat0) / Math.sqrt(1. - t * t);
+  			this.sinX1 = Math.sin(X);
+  			this.cosX1 = Math.cos(X);
+  			break;
+  	} else {
+  		case this.OBLIQ:
+  			this.sinph0 = Math.sin(this.lat0);
+  			this.cosph0 = Math.cos(this.lat0);
+  		case this.EQUIT:
+  			break;
+  		case this.S_POLE:
+  		case this.N_POLE:
+  			this.akm1 = Math.abs(this.phits - Proj4js.common.HALF_PI) >= Proj4js.common.EPSLN ?
+  			   Math.cos(this.phits) / Math.tan(Proj4js.common.FORTPI - .5 * this.phits) :
+  			   2. * this.k0 ;
+  			break;
+// Stereographic forward equations--mapping lat,long to x,y
+    var lon = p.x;
+    var lat = p.y;
+    var x, y
+    	var  sinphi, cosphi, coslam, sinlam;
+    	coslam = Math.cos(lon);
+    	sinlam = Math.sin(lon);
+    	case this.EQUIT:
+    		y = 1. + cosphi * coslam;
+    		if (y <= Proj4js.common.EPSLN) {
+          F_ERROR;
+        y = this.akm1 / y;
+    		x = y * cosphi * sinlam;
+        y *= sinphi;
+    		break;
+    	case this.OBLIQ:
+    		y = 1. + this.sinph0 * sinphi + this.cosph0 * cosphi * coslam;
+          F_ERROR;
+    		y *= this.cosph0 * sinphi - this.sinph0 * cosphi * coslam;
+    		break;
+    	case this.N_POLE:
+    		coslam = -coslam;
+    		lat = -lat;
+        //Note  no break here so it conitnues through S_POLE
+    	case this.S_POLE:
+    		if (Math.abs(lat - Proj4js.common.HALF_PI) < this.TOL) {
+          F_ERROR;
+        y = this.akm1 * Math.tan(Proj4js.common.FORTPI + .5 * lat)
+    		x = sinlam * y;
+    		y *= coslam;
+    		break;
+    } else {
+    	if (this.mode == this.OBLIQ || this.mode == this.EQUIT) {
+        X = 2. * Math.atan(this.ssfn_(lat, sinphi, this.e));
+    		sinX = Math.sin(X - Proj4js.common.HALF_PI);
+    		cosX = Math.cos(X);
+    	case this.OBLIQ:
+    		A = this.akm1 / (this.cosX1 * (1. + this.sinX1 * sinX + this.cosX1 * cosX * coslam));
+    		y = A * (this.cosX1 * sinX - this.sinX1 * cosX * coslam);
+    		x = A * cosX;
+    		break;
+    	case this.EQUIT:
+    		A = 2. * this.akm1 / (1. + cosX * coslam);
+    		y = A * sinX;
+    		x = A * cosX;
+    		break;
+    	case this.S_POLE:
+    		lat = -lat;
+    		coslam = - coslam;
+    		sinphi = -sinphi;
+    	case this.N_POLE:
+    		x = this.akm1 * Proj4js.common.tsfnz(this.e, lat, sinphi);
+    		y = - x * coslam;
+    		break;
+    	x = x * sinlam;
+    p.x = x*this.a + this.x0;
+    p.y = y*this.a + this.y0;
+    return p;
+//* Stereographic inverse equations--mapping x,y to lat/long
+    var x = (p.x - this.x0)/this.a;   /* descale and de-offset */
+    var y = (p.y - this.y0)/this.a;
+    var lon, lat
+    var cosphi, sinphi, tp=0.0, phi_l=0.0, rho, halfe=0.0, pi2=0.0;
+    var i;
+    	var  c, rh, sinc, cosc;
+      rh = Math.sqrt(x*x + y*y);
+      c = 2. * Math.atan(rh / this.akm1);
+    	lon = 0.;
+    	case this.EQUIT:
+    			lat = 0.;
+    		} else {
+    			lat = Math.asin(y * sinc / rh);
+    		if (cosc != 0. || x != 0.) lon = Math.atan2(x * sinc, cosc * rh);
+    		break;
+    	case this.OBLIQ:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(cosc * sinph0 + y * sinc * cosph0 / rh);
+        c = cosc - sinph0 * Math.sin(lat);
+    		if (c != 0. || x != 0.) {
+    			lon = Math.atan2(x * sinc * cosph0, c * rh);
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(this.mode == this.S_POLE ? -cosc : cosc);
+    		lon = (x == 0. && y == 0.) ? 0. : Math.atan2(x, y);
+    		break;
+    } else {
+    	rho = Math.sqrt(x*x + y*y);
+    	case this.OBLIQ:
+    	case this.EQUIT:
+        tp = 2. * Math.atan2(rho * this.cosX1 , this.akm1);
+    		cosphi = Math.cos(tp);
+    		sinphi = Math.sin(tp);
+        if( rho == 0.0 ) {
+    		  phi_l = Math.asin(cosphi * this.sinX1);
+        } else {
+    		  phi_l = Math.asin(cosphi * this.sinX1 + (y * sinphi * this.cosX1 / rho));
+    		tp = Math.tan(.5 * (Proj4js.common.HALF_PI + phi_l));
+    		x *= sinphi;
+    		y = rho * this.cosX1 * cosphi - y * this.sinX1* sinphi;
+    		pi2 = Proj4js.common.HALF_PI;
+    		halfe = .5 * this.e;
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+        tp = - rho / this.akm1
+    		phi_l = Proj4js.common.HALF_PI - 2. * Math.atan(tp);
+    		pi2 = -Proj4js.common.HALF_PI;
+    		halfe = -.5 * this.e;
+    		break;
+    	for (i = this.NITER; i--; phi_l = lat) { //check this
+    		sinphi = this.e * Math.sin(phi_l);
+    		lat = 2. * Math.atan(tp * Math.pow((1.+sinphi)/(1.-sinphi), halfe)) - pi2;
+    		if (Math.abs(phi_l - lat) < this.CONV) {
+    			if (this.mode == this.S_POLE) lat = -lat;
+          p.x = lon;
+          p.y = lat
+    			return p;
+    projCode/nzmg.js
+NAME                            NEW ZEALAND MAP GRID
+		Northing for the New Zealand Map Grid projection.  The
+1.  Department of Land and Survey Technical Circular 1973/32
+      http://www.linz.govt.nz/docs/miscellaneous/nz-map-definition.pdf
+2.  OSG Technical Report 4.1
+      http://www.linz.govt.nz/docs/miscellaneous/nzmg.pdf
+IMPLEMENTATION NOTES
+The two references use different symbols for the calculated values. This
+implementation uses the variable names similar to the symbols in reference [1].
+The alogrithm uses different units for delta latitude and delta longitude.
+The delta latitude is assumed to be in units of seconds of arc x 10^-5.
+The delta longitude is the usual radians. Look out for these conversions.
+The algorithm is described using complex arithmetic. There were three
+options:
+   * find and use a Javascript library for complex arithmetic
+   * write my own complex library
+   * expand the complex arithmetic by hand to simple arithmetic
+This implementation has expanded the complex multiplication operations
+into parallel simple arithmetic operations for the real and imaginary parts.
+The imaginary part is way over to the right of the display; this probably
+violates every coding standard in the world, but, to me, it makes it much
+more obvious what is going on.
+The following complex operations are used:
+   - addition
+   - multiplication
+   - division
+   - complex number raised to integer power
+   - summation
+A summary of complex arithmetic operations:
+   (from http://en.wikipedia.org/wiki/Complex_arithmetic)
+   addition:       (a + bi) + (c + di) = (a + c) + (b + d)i
+   subtraction:    (a + bi) - (c + di) = (a - c) + (b - d)i
+   multiplication: (a + bi) x (c + di) = (ac - bd) + (bc + ad)i
+   division:       (a + bi) / (c + di) = [(ac + bd)/(cc + dd)] + [(bc - ad)/(cc + dd)]i
+The algorithm needs to calculate summations of simple and complex numbers. This is
+implemented using a for-loop, pre-loading the summed value to zero.
+The algorithm needs to calculate theta^2, theta^3, etc while doing a summation.
+There are three possible implementations:
+   - use Math.pow in the summation loop - except for complex numbers
+   - precalculate the values before running the loop
+   - calculate theta^n = theta^(n-1) * theta during the loop
+This implementation uses the third option for both real and complex arithmetic.
+For example
+   psi_n = 1;
+   sum = 0;
+   for (n = 1; n <=6; n++) {
+      psi_n1 = psi_n * psi;       // calculate psi^(n+1)
+      psi_n = psi_n1;
+      sum = sum + A[n] * psi_n;
+TEST VECTORS
+NZMG E, N:         2487100.638      6751049.719     metres
+NZGD49 long, lat:      172.739194       -34.444066  degrees
+NZMG E, N:         2486533.395      6077263.661     metres
+NZGD49 long, lat:      172.723106       -40.512409  degrees
+NZMG E, N:         2216746.425      5388508.765     metres
+NZGD49 long, lat:      169.172062       -46.651295  degrees
+Note that these test vectors convert from NZMG metres to lat/long referenced
+to NZGD49, not the more usual WGS84. The difference is about 70m N/S and about
+10m E/W.
+These test vectors are provided in reference [1]. Many more test
+vectors are available in
+   http://www.linz.govt.nz/docs/topography/topographicdata/placenamesdatabase/nznamesmar08.zip
+which is a catalog of names on the 260-series maps.
+EPSG CODES
+NZMG     EPSG:27200
+NZGD49   EPSG:4272
+http://spatialreference.org/ defines these as
+  Proj4js.defs["EPSG:4272"] = "+proj=longlat +ellps=intl +datum=nzgd49 +no_defs ";
+  Proj4js.defs["EPSG:27200"] = "+proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150 +ellps=intl +datum=nzgd49 +units=m +no_defs ";
+LICENSE
+  Copyright: Stephen Irons 2008
+  Released under terms of the LGPL as per: http://www.gnu.org/copyleft/lesser.html
+  Initialize New Zealand Map Grip projection
+Proj4js.Proj.nzmg = {
+   * iterations: Number of iterations to refine inverse transform.
+   *     0 -> km accuracy
+   *     1 -> m accuracy -- suitable for most mapping applications
+   *     2 -> mm accuracy
+  iterations: 1,
+    this.A = new Array();
+    this.A[1]  = +0.6399175073;
+    this.A[2]  = -0.1358797613;
+    this.A[3]  = +0.063294409;
+    this.A[4]  = -0.02526853;
+    this.A[5]  = +0.0117879;
+    this.A[6]  = -0.0055161;
+    this.A[7]  = +0.0026906;
+    this.A[8]  = -0.001333;
+    this.A[9]  = +0.00067;
+    this.A[10] = -0.00034;
+    this.B_re = new Array();        this.B_im = new Array();
+    this.B_re[1] = +0.7557853228;   this.B_im[1] =  0.0;
+    this.B_re[2] = +0.249204646;    this.B_im[2] = +0.003371507;
+    this.B_re[3] = -0.001541739;    this.B_im[3] = +0.041058560;
+    this.B_re[4] = -0.10162907;     this.B_im[4] = +0.01727609;
+    this.B_re[5] = -0.26623489;     this.B_im[5] = -0.36249218;
+    this.B_re[6] = -0.6870983;      this.B_im[6] = -1.1651967;
+    this.C_re = new Array();        this.C_im = new Array();
+    this.C_re[1] = +1.3231270439;   this.C_im[1] =  0.0;
+    this.C_re[2] = -0.577245789;    this.C_im[2] = -0.007809598;
+    this.C_re[3] = +0.508307513;    this.C_im[3] = -0.112208952;
+    this.C_re[4] = -0.15094762;     this.C_im[4] = +0.18200602;
+    this.C_re[5] = +1.01418179;     this.C_im[5] = +1.64497696;
+    this.C_re[6] = +1.9660549;      this.C_im[6] = +2.5127645;
+    this.D = new Array();
+    this.D[1] = +1.5627014243;
+    this.D[2] = +0.5185406398;
+    this.D[3] = -0.03333098;
+    this.D[4] = -0.1052906;
+    this.D[5] = -0.0368594;
+    this.D[6] = +0.007317;
+    this.D[7] = +0.01220;
+    this.D[8] = +0.00394;
+    this.D[9] = -0.0013;
+    New Zealand Map Grid Forward  - long/lat to x/y
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lat = lat - this.lat0;
+    var delta_lon = lon - this.long0;
+    // 1. Calculate d_phi and d_psi    ...                          // and d_lambda
+    // For this algorithm, delta_latitude is in seconds of arc x 10-5, so we need to scale to those units. Longitude is radians.
+    var d_phi = delta_lat / Proj4js.common.SEC_TO_RAD * 1E-5;       var d_lambda = delta_lon;
+    var d_phi_n = 1;  // d_phi^0
+    var d_psi = 0;
+    for (n = 1; n <= 10; n++) {
+      d_phi_n = d_phi_n * d_phi;
+      d_psi = d_psi + this.A[n] * d_phi_n;
+    // 2. Calculate theta
+    var th_re = d_psi;                                              var th_im = d_lambda;
+    // 3. Calculate z
+    var th_n_re = 1;                                                var th_n_im = 0;  // theta^0
+    var th_n_re1;                                                   var th_n_im1;
+    var z_re = 0;                                                   var z_im = 0;
+    for (n = 1; n <= 6; n++) {
+      th_n_re1 = th_n_re*th_re - th_n_im*th_im;                     th_n_im1 = th_n_im*th_re + th_n_re*th_im;
+      th_n_re = th_n_re1;                                           th_n_im = th_n_im1;
+      z_re = z_re + this.B_re[n]*th_n_re - this.B_im[n]*th_n_im;    z_im = z_im + this.B_im[n]*th_n_re + this.B_re[n]*th_n_im;
+    // 4. Calculate easting and northing
+    x = (z_im * this.a) + this.x0;
+    y = (z_re * this.a) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+    New Zealand Map Grid Inverse  -  x/y to long/lat
+    var x = p.x;
+    var y = p.y;
+    var delta_x = x - this.x0;
+    var delta_y = y - this.y0;
+    // 1. Calculate z
+    var z_re = delta_y / this.a;                                              var z_im = delta_x / this.a;
+    // 2a. Calculate theta - first approximation gives km accuracy
+    var z_n_re = 1;                                                           var z_n_im = 0;  // z^0
+    var z_n_re1;                                                              var z_n_im1;
+    var th_re = 0;                                                            var th_im = 0;
+      z_n_re1 = z_n_re*z_re - z_n_im*z_im;                                    z_n_im1 = z_n_im*z_re + z_n_re*z_im;
+      z_n_re = z_n_re1;                                                       z_n_im = z_n_im1;
+      th_re = th_re + this.C_re[n]*z_n_re - this.C_im[n]*z_n_im;              th_im = th_im + this.C_im[n]*z_n_re + this.C_re[n]*z_n_im;
+    // 2b. Iterate to refine the accuracy of the calculation
+    //        0 iterations gives km accuracy
+    //        1 iteration gives m accuracy -- good enough for most mapping applications
+    //        2 iterations bives mm accuracy
+    for (i = 0; i < this.iterations; i++) {
+       var th_n_re = th_re;                                                      var th_n_im = th_im;
+       var num_re = z_re;                                                        var num_im = z_im;
+       for (n = 2; n <= 6; n++) {
+         num_re = num_re + (n-1)*(this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);  num_im = num_im + (n-1)*(this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       th_n_re = 1;                                                              th_n_im = 0;
+       var den_re = this.B_re[1];                                                var den_im = this.B_im[1];
+         den_re = den_re + n * (this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);    den_im = den_im + n * (this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       // Complex division
+       var den2 = den_re*den_re + den_im*den_im;
+       th_re = (num_re*den_re + num_im*den_im) / den2;                           th_im = (num_im*den_re - num_re*den_im) / den2;
+    // 3. Calculate d_phi              ...                                    // and d_lambda
+    var d_psi = th_re;                                                        var d_lambda = th_im;
+    var d_psi_n = 1;  // d_psi^0
+    var d_phi = 0;
+    for (n = 1; n <= 9; n++) {
+       d_psi_n = d_psi_n * d_psi;
+       d_phi = d_phi + this.D[n] * d_psi_n;
+    // 4. Calculate latitude and longitude
+    // d_phi is calcuated in second of arc * 10^-5, so we need to scale back to radians. d_lambda is in radians.
+    var lat = this.lat0 + (d_phi * Proj4js.common.SEC_TO_RAD * 1E5);
+    var lon = this.long0 +  d_lambda;
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/mill.js
+NAME                    MILLER CYLINDRICAL
+		Northing for the Miller Cylindrical projection.  The
+PROGRAMMER              DATE
+T. Mittan		March, 1993
+This function was adapted from the Lambert Azimuthal Equal Area projection
+code (FORTRAN) in the General Cartographic Transformation Package software
+which is available from the U.S. Geological Survey National Mapping Division.
+1.  "New Equal-Area Map Projections for Noncircular Regions", John P. Snyder,
+    The American Cartographer, Vol 15, No. 4, October 1988, pp. 341-355.
+2.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+3.  "Software Documentation for GCTP General Cartographic Transformation
+    Package", U.S. Geological Survey National Mapping Division, May 1982.
+Proj4js.Proj.mill = {
+/* Initialize the Miller Cylindrical projection
+  init: function() {
+    //no-op
+  /* Miller Cylindrical forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon -this.long0);
+    var x = this.x0 + this.a * dlon;
+    var y = this.y0 + this.a * Math.log(Math.tan((Proj4js.common.PI / 4.0) + (lat / 2.5))) * 1.25;
+    p.x=x;
+    p.y=y;
+    return p;
+  },//millFwd()
+  /* Miller Cylindrical inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x /this.a);
+    var lat = 2.5 * (Math.atan(Math.exp(0.8*p.y/this.a)) - Proj4js.common.PI / 4.0);
+    p.x=lon;
+    p.y=lat;
+    return p;
+  }//millInv()
+    projCode/sinu.js
+NAME                  		SINUSOIDAL
+		Northing for the Sinusoidal projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      May, 1991
+This function was adapted from the Sinusoidal projection code (FORTRAN) in the
+General Cartographic Transformation Package software which is available from
+the U.S. Geological Survey National Mapping Division.
+2.  "Software Documentation for GCTP General Cartographic Transformation
+Proj4js.Proj.sinu = {
+	/* Initialize the Sinusoidal projection
+		this.R = 6370997.0; //Radius of earth
+	/* Sinusoidal forward equations--mapping lat,long to x,y
+		var x,y,delta_lon;
+		var lon=p.x;
+		var lat=p.y;
+		delta_lon = Proj4js.common.adjust_lon(lon - this.long0);
+		x = this.R * delta_lon * Math.cos(lat) + this.x0;
+		y = this.R * lat + this.y0;
+		p.x=x;
+		p.y=y;
+		return p;
+		var lat,temp,lon;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		lat = p.y / this.R;
+		if (Math.abs(lat) > Proj4js.common.HALF_PI) {
+		    Proj4js.reportError("sinu:Inv:DataError");
+		temp = Math.abs(lat) - Proj4js.common.HALF_PI;
+		if (Math.abs(temp) > Proj4js.common.EPSLN) {
+			temp = this.long0+ p.x / (this.R *Math.cos(lat));
+			lon = Proj4js.common.adjust_lon(temp);
+		} else {
+			lon = this.long0;
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/geocent.js
+Author:       Richard Greenwood rich at greenwoodmap.com
+License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+ * convert between geodetic coordinates (longitude, latitude, height)
+ * and gecentric coordinates (X, Y, Z)
+ * ported from Proj 4.9.9 geocent.c
+// following constants #define'd in geocent.h
+// var GEOCENT_NO_ERROR  = 0x0000;
+var GEOCENT_LAT_ERROR = 0x0001;
+// var GEOCENT_LON_ERROR = 0x0002;
+// var cs.a_ERROR        = 0x0004;
+// var cs.b_ERROR        = 0x0008;
+// var cs.a_LESS_B_ERROR = 0x0010;
+// following constants from geocent.c
+var COS_67P5  = 0.38268343236508977;  /* cosine of 67.5 degrees */
+var AD_C      = 1.0026000;            /* Toms region 1 constant */
+function cs_geodetic_to_geocentric (cs, p) {
+  var Height = p.z;
+  var X;  // output
+  var Y;
+  var Z;
+  if( Latitude < -HALF_PI && Latitude > -1.001 * HALF_PI )
+      Latitude = -HALF_PI;
+  else if( Latitude > HALF_PI && Latitude < 1.001 * HALF_PI )
+      Latitude = HALF_PI;
+  else if ((Latitude < -HALF_PI) || (Latitude > HALF_PI))
+  { /* Latitude out of range */
+    Error_Code |= GEOCENT_LAT_ERROR;
+  if (!Error_Code)
+  { /* no errors */
+    if (Longitude > PI)
+      Longitude -= (2*PI);
+    Rn = cs.a / (Math.sqrt(1.0e0 - cs.es * Sin2_Lat));
+    Z = ((Rn * (1 - cs.es)) + Height) * Sin_Lat;
+  p.x = X;
+  p.y = Y;
+  p.z = Z;
+} // cs_geodetic_to_geocentric()
+/** Convert_Geocentric_To_Geodetic
+function cs_geocentric_to_geodetic (cs, p) {
+  var X =p.x;
+  var Y = p.y;
+  var Z = p.z;
+  var Longitude;
+  var Latitude;
+  var Height;
+  At_Pole = false;
+  if (X != 0.0)
+  else
+      if (Y > 0)
+          Longitude = HALF_PI;
+      else if (Y < 0)
+          Longitude = -HALF_PI;
+      else
+          At_Pole = true;
+          Longitude = 0.0;
+          if (Z > 0.0)
+          else if (Z < 0.0)
+          else
+              Height = -cs.b;
+              return;
+  W2 = X*X + Y*Y;
+  T0 = Z * AD_C;
+  Sin_B0 = T0 / S0;
+  Cos_B0 = W / S0;
+  T1 = Z + cs.b * cs.ep2 * Sin3_B0;
+  Sum = W - cs.a * cs.es * Cos_B0 * Cos_B0 * Cos_B0;
+  Sin_p1 = T1 / S1;
+  Rn = cs.a / Math.sqrt(1.0 - cs.es * Sin_p1 * Sin_p1);
+  if (Cos_p1 >= COS_67P5)
+  else if (Cos_p1 <= -COS_67P5)
+  else
+      Height = Z / Sin_p1 + Rn * (cs.es - 1.0);
+  p.x = Longitude;
+  p.y =Latitude;
+  p.z = Height;
+  return 0;
+} // cs_geocentric_to_geodetic()
+// pj_geocentic_to_wgs84(defn, p )
+//    defn = coordinate system definition,
+//  p = point to transform in geocentric coordinates (x,y,z)
+function cs_geocentric_to_wgs84( defn, p ) {
+  if( defn.datum_type == PJD_3PARAM )
+    //    continue;
+    p.x += defn.datum_params[0];
+    p.y += defn.datum_params[1];
+    p.z += defn.datum_params[2];
+  else  // if( defn.datum_type == PJD_7PARAM )
+    var Dx_BF =defn.datum_params[0];
+    var Dy_BF =defn.datum_params[1];
+    var Dz_BF =defn.datum_params[2];
+    var Rx_BF =defn.datum_params[3];
+    var Ry_BF =defn.datum_params[4];
+    var Rz_BF =defn.datum_params[5];
+    var M_BF  =defn.datum_params[6];
+    //    continue;
+    p.x = x_out;
+    p.y = y_out;
+    p.z = z_out;
+} // cs_geocentric_to_wgs84
+// pj_geocentic_from_wgs84()
+//  coordinate system definition,
+//  point to transform in geocentric coordinates (x,y,z)
+function cs_geocentric_from_wgs84( defn, p ) {
+    //    continue;
+    p.x -= defn.datum_params[0];
+    p.y -= defn.datum_params[1];
+    p.z -= defn.datum_params[2];
+    //    continue;
+} //cs_geocentric_from_wgs84()
+    projCode/vandg.js
+NAME                    VAN DER GRINTEN
+PURPOSE:	Transforms input Easting and Northing to longitude and
+		latitude for the Van der Grinten projection.  The
+		Easting and Northing must be in meters.  The longitude
+		and latitude values will be returned in radians.
+PROGRAMMER              DATE
+This function was adapted from the Van Der Grinten projection code
+(FORTRAN) in the General Cartographic Transformation Package software
+Proj4js.Proj.vandg = {
+/* Initialize the Van Der Grinten projection
+		var lon=p.x;
+		var lat=p.y;
+		var x,y;
+		if (Math.abs(lat) <= Proj4js.common.EPSLN) {
+			x = this.x0  + this.R * dlon;
+			y = this.y0;
+		var theta = Proj4js.common.asinz(2.0 * Math.abs(lat / Proj4js.common.PI));
+		if ((Math.abs(dlon) <= Proj4js.common.EPSLN) || (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN)) {
+			x = this.x0;
+			if (lat >= 0) {
+				y = this.y0 + Proj4js.common.PI * this.R * Math.tan(.5 * theta);
+			} else {
+				y = this.y0 + Proj4js.common.PI * this.R * - Math.tan(.5 * theta);
+			//  return(OK);
+		var al = .5 * Math.abs((Proj4js.common.PI / dlon) - (dlon / Proj4js.common.PI));
+		var asq = al * al;
+		var sinth = Math.sin(theta);
+		var costh = Math.cos(theta);
+		var g = costh / (sinth + costh - 1.0);
+		var gsq = g * g;
+		var m = g * (2.0 / sinth - 1.0);
+		var msq = m * m;
+		var con = Proj4js.common.PI * this.R * (al * (g - msq) + Math.sqrt(asq * (g - msq) * (g - msq) - (msq + asq) * (gsq - msq))) / (msq + asq);
+		if (dlon < 0) {
+		 con = -con;
+		x = this.x0 + con;
+		con = Math.abs(con / (Proj4js.common.PI * this.R));
+		if (lat >= 0) {
+		 y = this.y0 + Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		} else {
+		 y = this.y0 - Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		p.x = x;
+		p.y = y;
+		return p;
+/* Van Der Grinten inverse equations--mapping x,y to lat/long
+		var dlon;
+		var xx,yy,xys,c1,c2,c3;
+		var al,asq;
+		var a1;
+		var m1;
+		var con;
+		var th1;
+		var d;
+		/* inverse equations
+		p.x -= this.x0;
+		p.y -= this.y0;
+		con = Proj4js.common.PI * this.R;
+		xx = p.x / con;
+		yy =p.y / con;
+		xys = xx * xx + yy * yy;
+		c1 = -Math.abs(yy) * (1.0 + xys);
+		c2 = c1 - 2.0 * yy * yy + xx * xx;
+		c3 = -2.0 * c1 + 1.0 + 2.0 * yy * yy + xys * xys;
+		d = yy * yy / c3 + (2.0 * c2 * c2 * c2 / c3 / c3 / c3 - 9.0 * c1 * c2 / c3 /c3) / 27.0;
+		a1 = (c1 - c2 * c2 / 3.0 / c3) / c3;
+		m1 = 2.0 * Math.sqrt( -a1 / 3.0);
+		con = ((3.0 * d) / a1) / m1;
+		if (Math.abs(con) > 1.0) {
+			if (con >= 0.0) {
+				con = 1.0;
+			} else {
+				con = -1.0;
+		th1 = Math.acos(con) / 3.0;
+		if (p.y >= 0) {
+			lat = (-m1 *Math.cos(th1 + Proj4js.common.PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		} else {
+			lat = -(-m1 * Math.cos(th1 + PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		if (Math.abs(xx) < Proj4js.common.EPSLN) {
+			lon = this.long0;
+		lon = Proj4js.common.adjust_lon(this.long0 + Proj4js.common.PI * (xys - 1.0 + Math.sqrt(1.0 + 2.0 * (xx * xx - yy * yy) + xys * xys)) / 2.0 / xx);
+		p.x=lon;
+		p.y=lat;
+		return p;
+    projCode/eqc.js
+/* similar to equi.js FIXME proj4 uses eqc */
+Proj4js.Proj.eqc = {
+      if(!this.lat_ts) this.lat_ts=0;
+      if (!this.title) this.title = "Equidistant Cylindrical (Plate Carre)";
+      this.rc= Math.cos(this.lat_ts);
+      var lon= p.x;
+      var lat= p.y;
+      var dlat = Proj4js.common.adjust_lat(lat - this.lat0 );
+      p.x= this.x0 + (this.a*dlon*this.rc);
+      p.y= this.y0 + (this.a*dlat        );
+      return p;
+    var x= p.x;
+    var y= p.y;
+    p.x= Proj4js.common.adjust_lon(this.long0 + ((x - this.x0)/(this.a*this.rc)));
+    p.y= Proj4js.common.adjust_lat(this.lat0  + ((y - this.y0)/(this.a        )));
+    return p;
+    projCode/gauss.js
+Proj4js.Proj.gauss = {
+    sphi = Math.sin(this.lat0);
+    cphi = Math.cos(this.lat0);
+    cphi *= cphi;
+    this.rc = Math.sqrt(1.0 - this.es) / (1.0 - this.es * sphi * sphi);
+    this.C = Math.sqrt(1.0 + this.es * cphi * cphi / (1.0 - this.es));
+    this.phic0 = Math.asin(sphi / this.C);
+    this.ratexp = 0.5 * this.C * this.e;
+    this.K = Math.tan(0.5 * this.phic0 + Proj4js.common.FORTPI) / (Math.pow(Math.tan(0.5*this.lat0 + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e*sphi, this.ratexp));
+    var lon = p.x;
+    var lat = p.y;
+    p.y = 2.0 * Math.atan( this.K * Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e * Math.sin(lat), this.ratexp) ) - Proj4js.common.HALF_PI;
+    p.x = this.C * lon;
+    return p;
+    var DEL_TOL = 1e-14;
+    var lon = p.x / this.C;
+    var lat = p.y;
+    num = Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI)/this.K, 1./this.C);
+    for (var i = Proj4js.common.MAX_ITER; i>0; --i) {
+      lat = 2.0 * Math.atan(num * Proj4js.common.srat(this.e * Math.sin(p.y), -0.5 * this.e)) - Proj4js.common.HALF_PI;
+      if (Math.abs(lat - p.y) < DEL_TOL) break;
+      p.y = lat;
+    /* convergence failed */
+    if (!i) {
+      Proj4js.reportError("gauss:inverse:convergence failed");
+      return null;
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/omerc.js
+NAME                       OBLIQUE MERCATOR (HOTINE)
+		Northing for the Oblique Mercator projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.omerc = {
+  /* Initialize the Oblique Mercator  projection
+    if (!this.mode) this.mode=0;
+    if (!this.lon1)   {this.lon1=0;this.mode=1;}
+    if (!this.lon2)   this.lon2=0;
+    if (!this.lat2)    this.lat2=0;
+    var temp = this.b/ this.a;
+    var es = 1.0 - Math.pow(temp,2);
+    var e = Math.sqrt(es);
+    this.sin_p20=Math.sin(this.lat0);
+    this.cos_p20=Math.cos(this.lat0);
+    this.con = 1.0 - this.es * this.sin_p20 * this.sin_p20;
+    this.com = Math.sqrt(1.0 - es);
+    this.bl = Math.sqrt(1.0 + this.es * Math.pow(this.cos_p20,4.0)/(1.0 - es));
+    this.al = this.a * this.bl * this.k0 * this.com / this.con;
+    if (Math.abs(this.lat0) < Proj4js.common.EPSLN) {
+       this.ts = 1.0;
+       this.d = 1.0;
+       this.el = 1.0;
+    } else {
+       this.ts = Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);
+       this.con = Math.sqrt(this.con);
+       this.d = this.bl * this.com / (this.cos_p20 * this.con);
+       if ((this.d * this.d - 1.0) > 0.0) {
+          if (this.lat0 >= 0.0) {
+             this.f = this.d + Math.sqrt(this.d * this.d - 1.0);
+          } else {
+             this.f = this.d - Math.sqrt(this.d * this.d - 1.0);
+       } else {
+         this.f = this.d;
+       this.el = this.f * Math.pow(this.ts,this.bl);
+    //this.longc=52.60353916666667;
+       this.g = .5 * (this.f - 1.0/this.f);
+       this.gama = Proj4js.common.asinz(Math.sin(this.alpha) / this.d);
+       this.longc= this.longc - Proj4js.common.asinz(this.g * Math.tan(this.gama))/this.bl;
+       /* Report parameters common to format B
+       //genrpt(azimuth * R2D,"Azimuth of Central Line:    ");
+       //cenlon(lon_origin);
+      // cenlat(lat_origin);
+       this.con = Math.abs(this.lat0);
+       if ((this.con > Proj4js.common.EPSLN) && (Math.abs(this.con - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN)) {
+            this.singam=Math.sin(this.gama);
+            this.cosgam=Math.cos(this.gama);
+            this.sinaz=Math.sin(this.alpha);
+            this.cosaz=Math.cos(this.alpha);
+            if (this.lat0>= 0) {
+               this.u =  (this.al / this.bl) * Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+            } else {
+               this.u =  -(this.al / this.bl) *Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+          } else {
+            Proj4js.reportError("omerc:Init:DataError");
+       } else {
+       this.sinphi =Math. sin(this.at1);
+       this.ts1 = Proj4js.common.tsfnz(this.e,this.lat1,this.sinphi);
+       this.sinphi = Math.sin(this.lat2);
+       this.ts2 = Proj4js.common.tsfnz(this.e,this.lat2,this.sinphi);
+       this.h = Math.pow(this.ts1,this.bl);
+       this.l = Math.pow(this.ts2,this.bl);
+       this.f = this.el/this.h;
+       this.j = (this.el * this.el - this.l * this.h)/(this.el * this.el + this.l * this.h);
+       this.p = (this.l - this.h) / (this.l + this.h);
+       this.dlon = this.lon1 - this.lon2;
+       if (this.dlon < -Proj4js.common.PI) this.lon2 = this.lon2 - 2.0 * Proj4js.common.PI;
+       if (this.dlon > Proj4js.common.PI) this.lon2 = this.lon2 + 2.0 * Proj4js.common.PI;
+       this.longc = .5 * (this.lon1 + this.lon2) -Math.atan(this.j * Math.tan(.5 * this.bl * this.dlon)/this.p)/this.bl;
+       this.dlon  = Proj4js.common.adjust_lon(this.lon1 - this.longc);
+       this.gama = Math.atan(Math.sin(this.bl * this.dlon)/this.g);
+       this.alpha = Proj4js.common.asinz(this.d * Math.sin(this.gama));
+       /* Report parameters common to format A
+       if (Math.abs(this.lat1 - this.lat2) <= Proj4js.common.EPSLN) {
+          Proj4js.reportError("omercInitDataError");
+          //return(202);
+       } else {
+          this.con = Math.abs(this.lat1);
+       if ((this.con <= Proj4js.common.EPSLN) || (Math.abs(this.con - HALF_PI) <= Proj4js.common.EPSLN)) {
+                //return(202);
+       } else {
+         if (Math.abs(Math.abs(this.lat0) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN) {
+            //return(202);
+       this.singam=Math.sin(this.gam);
+       this.cosgam=Math.cos(this.gam);
+          this.u =  (this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+       } else {
+          this.u = -(this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+  /* Oblique Mercator forward equations--mapping lat,long to x,y
+    var theta;		/* angle					*/
+    var sin_phi, cos_phi;/* sin and cos value				*/
+    var c, t, tq;	/* temporary values				*/
+    var con, n, ml;	/* cone constant, small m			*/
+    var q,us,vl;
+    var ul,vs;
+    var s;
+    var dlon;
+    var ts1;
+    var lon=p.x;
+    var lat=p.y;
+    sin_phi = Math.sin(lat);
+    dlon = Proj4js.common.adjust_lon(lon - this.longc);
+    vl = Math.sin(this.bl * dlon);
+    if (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN) {
+       ts1 = Proj4js.common.tsfnz(this.e,lat,sin_phi);
+       q = this.el / (Math.pow(ts1,this.bl));
+       s = .5 * (q - 1.0 / q);
+       t = .5 * (q + 1.0/ q);
+       ul = (s * this.singam - vl * this.cosgam) / t;
+       con = Math.cos(this.bl * dlon);
+       if (Math.abs(con) < .0000001) {
+          us = this.al * this.bl * dlon;
+       } else {
+          us = this.al * Math.atan((s * this.cosgam + vl * this.singam) / con)/this.bl;
+          if (con < 0) us = us + Proj4js.common.PI * this.al / this.bl;
+    } else {
+       if (lat >= 0) {
+          ul = this.singam;
+       } else {
+          ul = -this.singam;
+       us = this.al * lat / this.bl;
+    if (Math.abs(Math.abs(ul) - 1.0) <= Proj4js.common.EPSLN) {
+       //alert("Point projects into infinity","omer-for");
+       //return(205);
+    vs = .5 * this.al * Math.log((1.0 - ul)/(1.0 + ul)) / this.bl;
+    us = us - this.u;
+    var x = this.x0 + vs * this.cosaz + us * this.sinaz;
+    var y = this.y0 + us * this.cosaz - vs * this.sinaz;
+    p.x=x;
+    p.y=y;
+    return p;
+    var delta_lon;	/* Delta longitude (Given longitude - center 	*/
+    var delta_theta;	/* adjusted longitude				*/
+    var vs,us,q,s,ts1;
+    var vl,ul,bs;
+    var dlon;
+    var  flag;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    flag = 0;
+    vs = p.x * this.cosaz - p.y * this.sinaz;
+    us = p.y * this.cosaz + p.x * this.sinaz;
+    us = us + this.u;
+    q = Math.exp(-this.bl * vs / this.al);
+    s = .5 * (q - 1.0/q);
+    t = .5 * (q + 1.0/q);
+    vl = Math.sin(this.bl * us / this.al);
+    ul = (vl * this.cosgam + s * this.singam)/t;
+       lon = this.longc;
+       if (ul >= 0.0) {
+          lat = Proj4js.common.HALF_PI;
+       } else {
+         lat = -Proj4js.common.HALF_PI;
+    } else {
+       con = 1.0 / this.bl;
+       ts1 =Math.pow((this.el / Math.sqrt((1.0 + ul) / (1.0 - ul))),con);
+       lat = Proj4js.common.phi2z(this.e,ts1);
+       //if (flag != 0)
+          //return(flag);
+       //~ con = Math.cos(this.bl * us /al);
+       theta = this.longc - Math.atan2((s * this.cosgam - vl * this.singam) , con)/this.bl;
+       lon = Proj4js.common.adjust_lon(theta);
+    p.x=lon;
+    p.y=lat;
+    return p;
+    projCode/lcc.js
+NAME                            LAMBERT CONFORMAL CONIC
+		Northing for the Lambert Conformal Conic projection.  The
+//<2104> +proj=lcc +lat_1=10.16666666666667 +lat_0=10.16666666666667 +lon_0=-71.60561777777777 +k_0=1 +x0=-17044 +x0=-23139.97 +ellps=intl +units=m +no_defs  no_defs
+// Initialize the Lambert Conformal conic projection
+//Proj4js.Proj.lcc = Class.create();
+Proj4js.Proj.lcc = {
+    // array of:  r_maj,r_min,lat1,lat2,c_lon,c_lat,false_east,false_north
+    //double c_lat;                   /* center latitude                      */
+    //double c_lon;                   /* center longitude                     */
+    //double lat1;                    /* first standard parallel              */
+    //double lat2;                    /* second standard parallel             */
+    //double r_maj;                   /* major axis                           */
+    //double r_min;                   /* minor axis                           */
+    //double false_east;              /* x offset in meters                   */
+    //double false_north;             /* y offset in meters                   */
+      if (!this.lat2){this.lat2=this.lat0;}//if lat2 is not defined
+      if (!this.k0) this.k0 = 1.0;
+    // Standard Parallels cannot be equal and on opposite sides of the equator
+      if (Math.abs(this.lat1+this.lat2) < Proj4js.common.EPSLN) {
+        Proj4js.reportError("lcc:init: Equal Latitudes");
+        return;
+      var temp = this.b / this.a;
+      this.e = Math.sqrt(1.0 - temp*temp);
+      var sin1 = Math.sin(this.lat1);
+      var cos1 = Math.cos(this.lat1);
+      var ms1 = Proj4js.common.msfnz(this.e, sin1, cos1);
+      var ts1 = Proj4js.common.tsfnz(this.e, this.lat1, sin1);
+      var sin2 = Math.sin(this.lat2);
+      var cos2 = Math.cos(this.lat2);
+      var ms2 = Proj4js.common.msfnz(this.e, sin2, cos2);
+      var ts2 = Proj4js.common.tsfnz(this.e, this.lat2, sin2);
+      var ts0 = Proj4js.common.tsfnz(this.e, this.lat0, Math.sin(this.lat0));
+        this.ns = Math.log(ms1/ms2)/Math.log(ts1/ts2);
+      } else {
+        this.ns = sin1;
+      this.f0 = ms1 / (this.ns * Math.pow(ts1, this.ns));
+      this.rh = this.a * this.f0 * Math.pow(ts0, this.ns);
+      if (!this.title) this.title = "Lambert Conformal Conic";
+    // Lambert Conformal conic forward equations--mapping lat,long to x,y
+      var lon = p.x;
+      var lat = p.y;
+      if ( lat <= 90.0 && lat >= -90.0 && lon <= 180.0 && lon >= -180.0) {
+        //lon = lon * Proj4js.common.D2R;
+        //lat = lat * Proj4js.common.D2R;
+      } else {
+        Proj4js.reportError("lcc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+        return null;
+      var con  = Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI);
+      var ts;
+      if (con > Proj4js.common.EPSLN) {
+        ts = Proj4js.common.tsfnz(this.e, lat, Math.sin(lat) );
+        rh1 = this.a * this.f0 * Math.pow(ts, this.ns);
+      } else {
+        con = lat * this.ns;
+        if (con <= 0) {
+          Proj4js.reportError("lcc:forward: No Projection");
+          return null;
+        rh1 = 0;
+      p.x = this.k0 * (rh1 * Math.sin(theta)) + this.x0;
+      p.y = this.k0 * (this.rh - rh1 * Math.cos(theta)) + this.y0;
+      return p;
+  // Lambert Conformal Conic inverse equations--mapping x,y to lat/long
+    var rh1, con, ts;
+    var lat, lon;
+    x = (p.x - this.x0)/this.k0;
+    y = (this.rh - (p.y - this.y0)/this.k0);
+    if (this.ns > 0) {
+      rh1 = Math.sqrt (x * x + y * y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt (x * x + y * y);
+      con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0) {
+      theta = Math.atan2((con * x),(con * y));
+    if ((rh1 != 0) || (this.ns > 0.0)) {
+      con = 1.0/this.ns;
+      ts = Math.pow((rh1/(this.a * this.f0)), con);
+      lat = Proj4js.common.phi2z(this.e, ts);
+      if (lat == -9999) return null;
+    } else {
+    lon = Proj4js.common.adjust_lon(theta/this.ns + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/laea.js
+NAME                  LAMBERT AZIMUTHAL EQUAL-AREA
+PURPOSE:	Transforms input longitude and latitude to Easting and
+		Northing for the Lambert Azimuthal Equal-Area projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      March, 1991
+ALGORITHM REFERENCES
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+Proj4js.Proj.laea = {
+/* Initialize the Lambert Azimuthal Equal Area projection
+    this.sin_lat_o=Math.sin(this.lat0);
+    this.cos_lat_o=Math.cos(this.lat0);
+/* Lambert Azimuthal Equal Area forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    //v 1.0
+    var sin_lat=Math.sin(lat);
+    var cos_lat=Math.cos(lat);
+    var sin_delta_lon=Math.sin(delta_lon);
+    var cos_delta_lon=Math.cos(delta_lon);
+    var g =this.sin_lat_o * sin_lat +this.cos_lat_o * cos_lat * cos_delta_lon;
+    if (g == -1.0) {
+      Proj4js.reportError("laea:fwd:Point projects to a circle of radius "+ 2.0 * R);
+      return null;
+    var ksp = this.a * Math.sqrt(2.0 / (1.0 + g));
+    var x = ksp * cos_lat * sin_delta_lon + this.x0;
+    var y = ksp * (this.cos_lat_o * sin_lat - this.sin_lat_o * cos_lat * cos_delta_lon) + this.y0;
+    p.x = x;
+    p.y = y
+    return p;
+  },//lamazFwd()
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var Rh = Math.sqrt(p.x *p.x +p.y * p.y);
+    var temp = Rh / (2.0 * this.a);
+    if (temp > 1) {
+      Proj4js.reportError("laea:Inv:DataError");
+      return null;
+    var z = 2.0 * Proj4js.common.asinz(temp);
+    var sin_z=Math.sin(z);
+    var cos_z=Math.cos(z);
+    var lon =this.long0;
+    if (Math.abs(Rh) > Proj4js.common.EPSLN) {
+       var lat = Proj4js.common.asinz(this.sin_lat_o * cos_z +this. cos_lat_o * sin_z *p.y / Rh);
+       var temp =Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+          temp = cos_z -this.sin_lat_o * Math.sin(lat);
+          if(temp!=0.0) lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x*sin_z*this.cos_lat_o,temp*Rh));
+       } else if (this.lat0 < 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x,p.y));
+       } else {
+    } else {
+      lat = this.lat0;
+    //return(OK);
+    p.x = lon;
+    p.y = lat;
+    return p;
+  }//lamazInv()
+    projCode/aeqd.js
+Proj4js.Proj.aeqd = {
+  init : function() {
+    this.sin_p12=Math.sin(this.lat0)
+    this.cos_p12=Math.cos(this.lat0)
+    var lon=p.x;
+    var lat=p.y;
+    var ksp;
+    var sinphi=Math.sin(p.y);
+    var cosphi=Math.cos(p.y);
+    var coslon = Math.cos(dlon);
+    var g = this.sin_p12 * sinphi + this.cos_p12 * cosphi * coslon;
+    if (Math.abs(Math.abs(g) - 1.0) < Proj4js.common.EPSLN) {
+       ksp = 1.0;
+       if (g < 0.0) {
+         Proj4js.reportError("aeqd:Fwd:PointError");
+         return;
+    } else {
+       var z = Math.acos(g);
+       ksp = z/Math.sin(z);
+    p.x = this.x0 + this.a * ksp * cosphi * Math.sin(dlon);
+    p.y = this.y0 + this.a * ksp * (this.cos_p12 * sinphi - this.sin_p12 * cosphi * coslon);
+    return p;
+  inverse: function(p){
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var rh = Math.sqrt(p.x * p.x + p.y *p.y);
+    if (rh > (2.0 * Proj4js.common.HALF_PI * this.a)) {
+       Proj4js.reportError("aeqdInvDataError");
+       return;
+    var z = rh / this.a;
+    var sinz=Math.sin(z)
+    var cosz=Math.cos(z)
+    var lon = this.long0;
+    var lat;
+      lat = this.lat0;
+    } else {
+      lat = Proj4js.common.asinz(cosz * this.sin_p12 + (p.y * sinz * this.cos_p12) / rh);
+      var con = Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+        if (lat0 >= 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x , -p.y));
+        } else {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x , p.y));
+      } else {
+        con = cosz - this.sin_p12 * Math.sin(lat);
+        if ((Math.abs(con) < Proj4js.common.EPSLN) && (Math.abs(p.x) < Proj4js.common.EPSLN)) {
+           //no-op, just keep the lon value as is
+        } else {
+          var temp = Math.atan2((p.x * sinz * this.cos_p12), (con * rh));
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2((p.x * sinz * this.cos_p12), (con * rh)));
+    p.x = lon;
+    p.y = lat;
+    return p;
+    projCode/moll.js
+NAME                            MOLLWEIDE
+		Northing for the MOllweide projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      May, 1991;  Updated Sept, 1992; Updated Feb, 1993
+S. Nelson, EDC		Jun, 2993;	Made corrections in precision and
+					number of iterations.
+1.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+    Printing Office, Washington D.C., 1989.
+Proj4js.Proj.moll = {
+  /* Initialize the Mollweide projection
+  init: function(){
+    //no-op
+  /* Mollweide forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var theta = lat;
+    var con = Proj4js.common.PI * Math.sin(lat);
+    /* Iterate using the Newton-Raphson method to find theta
+    for (var i=0;;i++) {
+       var delta_theta = -(theta + Math.sin(theta) - con)/ (1.0 + Math.cos(theta));
+       theta += delta_theta;
+       if (Math.abs(delta_theta) < Proj4js.common.EPSLN) break;
+       if (i >= 50) {
+          Proj4js.reportError("moll:Fwd:IterationError");
+         //return(241);
+    theta /= 2.0;
+    /* If the latitude is 90 deg, force the x coordinate to be "0 + false easting"
+       this is done here because of precision problems with "cos(theta)"
+    if (Proj4js.common.PI/2 - Math.abs(lat) < Proj4js.common.EPSLN) delta_lon =0;
+    var x = 0.900316316158 * this.a * delta_lon * Math.cos(theta) + this.x0;
+    var y = 1.4142135623731 * this.a * Math.sin(theta) + this.y0;
+    p.x=x;
+    p.y=y;
+    return p;
+    var theta;
+    var arg;
+    p.x-= this.x0;
+    //~ p.y -= this.y0;
+    var arg = p.y /  (1.4142135623731 * this.a);
+    /* Because of division by zero problems, 'arg' can not be 1.0.  Therefore
+       a number very close to one is used instead.
+    if(Math.abs(arg) > 0.999999999999) arg=0.999999999999;
+    var theta =Math.asin(arg);
+    var lon = Proj4js.common.adjust_lon(this.long0 + (p.x / (0.900316316158 * this.a * Math.cos(theta))));
+    if(lon < (-Proj4js.common.PI)) lon= -Proj4js.common.PI;
+    if(lon > Proj4js.common.PI) lon= Proj4js.common.PI;
+    arg = (2.0 * theta + Math.sin(2.0 * theta)) / Proj4js.common.PI;
+    if(Math.abs(arg) > 1.0)arg=1.0;
+    var lat = Math.asin(arg);
+    //return(OK);
+    p.x=lon;
+    p.y=lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/proj4js-compressed.js
--- trunk/mapbender/http/extensions/proj4js/lib/proj4js-compressed.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/proj4js-compressed.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,240 @@
+  proj4js.js -- Javascript reprojection library.
+  Authors:      Mike Adair madairATdmsolutions.ca
+                Richard Greenwood richATgreenwoodmap.com
+                Didier Richard
+                Stephen Irons
+  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+                Note: This program is an almost direct port of the C library
+                Proj4.
+Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse||!dest.readyToUse){this.reportError("Proj4js initialization for "+source.srsCode+" not yet complete");return point;}
+if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84")||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84")){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
+if(source.projName=="longlat"){point.x*=Proj4js.common.D2R;point.y*=Proj4js.common.D2R;}else{if(source.to_meter){point.x*=source.to_meter;point.y*=source.to_meter;}
+source.inverse(point);}
+if(source.from_greenwich){point.x+=source.from_greenwich;}
+point=this.datum_transform(source.datum,dest.datum,point);if(dest.from_greenwich){point.x-=dest.from_greenwich;}
+if(dest.projName=="longlat"){point.x*=Proj4js.common.R2D;point.y*=Proj4js.common.R2D;}else{dest.forward(point);if(dest.to_meter){point.x/=dest.to_meter;point.y/=dest.to_meter;}}
+return point;},datum_transform:function(source,dest,point){if(source.compare_datums(dest)){return point;}
+if(source.datum_type==Proj4js.common.PJD_NODATUM||dest.datum_type==Proj4js.common.PJD_NODATUM){return point;}
+if(source.datum_type==Proj4js.common.PJD_GRIDSHIFT)
+{alert("ERROR: Grid shift transformations are not implemented yet.");}
+if(dest.datum_type==Proj4js.common.PJD_GRIDSHIFT)
+if(source.es!=dest.es||source.a!=dest.a||source.datum_type==Proj4js.common.PJD_3PARAM||source.datum_type==Proj4js.common.PJD_7PARAM||dest.datum_type==Proj4js.common.PJD_3PARAM||dest.datum_type==Proj4js.common.PJD_7PARAM)
+{source.geodetic_to_geocentric(point);if(source.datum_type==Proj4js.common.PJD_3PARAM||source.datum_type==Proj4js.common.PJD_7PARAM){source.geocentric_to_wgs84(point);}
+if(dest.datum_type==Proj4js.common.PJD_3PARAM||dest.datum_type==Proj4js.common.PJD_7PARAM){dest.geocentric_from_wgs84(point);}
+dest.geocentric_to_geodetic(point);}
+return point;},reportError:function(msg){},extend:function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}}
+return destination;},Class:function(){var Class=function(){this.initialize.apply(this,arguments);};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
+Proj4js.extend(extended,parent);}
+Class.prototype=extended;return Class;},bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},scriptName:"proj4js.js",defsLookupService:'http://spatialreference.org/ref',libPath:null,getScriptLocation:function(){if(this.libPath)return this.libPath;var scriptName=this.scriptName;var scriptNameLen=scriptName.length;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);if((index>-1)&&(index+scriptNameLen==src.length)){this.libPath=src.slice(0,-scriptNameLen);break;}}}
+return this.libPath||"";},loadScript:function(url,onload,onfail,loadCheck){var script=document.createElement('script');script.defer=false;script.type="text/javascript";script.id=url;script.src=url;script.onload=onload;script.onerror=onfail;script.loadCheck=loadCheck;if(/MSIE/.test(navigator.userAgent)){script.onreadystatechange=this.checkReadyState;}
+document.getElementsByTagName('head')[0].appendChild(script);},checkReadyState:function(){if(this.readyState=='loaded'){if(!this.loadCheck()){this.onerror();}else{this.onload();}}}};Proj4js.Proj=Proj4js.Class({readyToUse:false,title:null,projName:null,units:null,datum:null,initialize:function(srsCode){this.srsCode=srsCode.toUpperCase();if(this.srsCode.indexOf("EPSG")==0){this.srsCode=this.srsCode;this.srsAuth='epsg';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("IGNF")==0){this.srsCode=this.srsCode;this.srsAuth='IGNF';this.srsProjNumber=this.srsCode.substring(5);}else if(this.srsCode.indexOf("CRS")==0){this.srsCode=this.srsCode;this.srsAuth='CRS';this.srsProjNumber=this.srsCode.substring(4);}else{this.srsAuth='';this.srsProjNumber=this.srsCode;}
+this.loadProjDefinition();},loadProjDefinition:function(){if(Proj4js.defs[this.srsCode]){this.defsLoaded();return;}
+var url=Proj4js.getScriptLocation()+'defs/'+this.srsAuth.toUpperCase()+this.srsProjNumber+'.js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.loadFromService,this),Proj4js.bind(this.checkDefsLoaded,this));},loadFromService:function(){var url=Proj4js.defsLookupService+'/'+this.srsAuth+'/'+this.srsProjNumber+'/proj4js';Proj4js.loadScript(url,Proj4js.bind(this.defsLoaded,this),Proj4js.bind(this.defsFailed,this),Proj4js.bind(this.checkDefsLoaded,this));},defsLoaded:function(){this.parseDefs();this.loadProjCode(this.projName);},checkDefsLoaded:function(){if(Proj4js.defs[this.srsCode]){return true;}else{return false;}},defsFailed:function(){Proj4js.reportError('failed to load projection definition for: '+this.srsCode);Proj4js.extend(Proj4js.defs[this.srsCode],Proj4js.defs['WGS84']);this.defsLoaded();},loadProjCode:function(projName){if(Proj4js.Proj[projName]){this.initTransforms();return;}
+var url=Proj4js.getScriptLocation()+'projCode/'+projName+'.js';Proj4js.loadScript(url,Proj4js.bind(this.loadProjCodeSuccess,this,projName),Proj4js.bind(this.loadProjCodeFailure,this,projName),Proj4js.bind(this.checkCodeLoaded,this,projName));},loadProjCodeSuccess:function(projName){if(Proj4js.Proj[projName].dependsOn){this.loadProjCode(Proj4js.Proj[projName].dependsOn);}else{this.initTransforms();}},loadProjCodeFailure:function(projName){Proj4js.reportError("failed to find projection file for: "+projName);},checkCodeLoaded:function(projName){if(Proj4js.Proj[projName]){return true;}else{return false;}},initTransforms:function(){Proj4js.extend(this,Proj4js.Proj[this.projName]);this.init();this.readyToUse=true;},parseDefs:function(){this.defData=Proj4js.defs[this.srsCode];var paramName,paramVal;var paramArray=this.defData.split("+");for(var prop=0;prop<paramArray.length;prop++){var property=paramArray[prop].split("=");paramName=property[0].toLowerCase();paramVal=property[1];switch(paramName.replace(/\s/gi,"")){case"":break;case"title":this.title=paramVal;break;case"proj":this.projName=paramVal.replace(/\s/gi,"");break;case"units":this.units=paramVal.replace(/\s/gi,"");break;case"datum":this.datumCode=paramVal.replace(/\s/gi,"");break;case"nadgrids":this.nagrids=paramVal.replace(/\s/gi,"");break;case"ellps":this.ellps=paramVal.replace(/\s/gi,"");break;case"a":this.a=parseFloat(paramVal);break;case"b":this.b=parseFloat(paramVal);break;case"rf":this.rf=parseFloat(paramVal);break;case"lat_0":this.lat0=paramVal*Proj4js.common.D2R;break;case"lat_1":this.lat1=paramVal*Proj4js.common.D2R;break;case"lat_2":this.lat2=paramVal*Proj4js.common.D2R;break;case"lat_ts":this.lat_ts=paramVal*Proj4js.common.D2R;break;case"lon_0":this.long0=paramVal*Proj4js.common.D2R;break;case"alpha":this.alpha=parseFloat(paramVal)*Proj4js.common.D2R;break;case"lonc":this.longc=paramVal*Proj4js.common.D2R;break;case"x_0":this.x0=parseFloat(paramVal);break;case"y_0":this.y0=parseFloat(paramVal);break;case"k_0":this.k0=parseFloat(paramVal);break;case"k":this.k0=parseFloat(paramVal);break;case"R_A":this.R=true;break;case"zone":this.zone=parseInt(paramVal);break;case"south":this.utmSouth=true;break;case"towgs84":this.datum_params=paramVal.split(",");break;case"to_meter":this.to_meter=parseFloat(paramVal);break;case"from_greenwich":this.from_greenwich=paramVal*Proj4js.common.D2R;break;case"pm":paramVal=paramVal.replace(/\s/gi,"");this.from_greenwich=Proj4js.PrimeMeridian[paramVal]?Proj4js.PrimeMeridian[paramVal]:parseFloat(paramVal);this.from_greenwich*=Proj4js.common.D2R;break;case"no_defs":break;default:}}
+this.deriveConstants();},deriveConstants:function(){if(this.nagrids=='@null')this.datumCode='none';if(this.datumCode&&this.datumCode!='none'){var datumDef=Proj4js.Datum[this.datumCode];if(datumDef){this.datum_params=datumDef.towgs84.split(',');this.ellps=datumDef.ellipse;this.datumName=datumDef.datumName?datumDef.datumName:this.datumCode;}}
+if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
+if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
+this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.RA4+this.es*Proj4js.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
+this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees"};Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.283185307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
+alert("phi2z has NoConvergence");return(-9999);},qsfnz:function(eccent,sinphi,cosphi){var con;if(eccent>1.0e-7){con=eccent*sinphi;return((1.0-eccent*eccent)*(sinphi/(1.0-con*con)-(.5/eccent)*Math.log((1.0-con)/(1.0+con))));}else{return(2.0*sinphi);}},asinz:function(x){if(Math.abs(x)>1.0){x=(x>1.0)?1.0:-1.0;}
+return Math.asin(x);},e0fn:function(x){return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},e1fn:function(x){return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},e2fn:function(x){return(0.05859375*x*x*(1.0+0.75*x));},e3fn:function(x){return(x*x*x*(35.0/3072.0));},mlfn:function(e0,e1,e2,e3,phi){return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},srat:function(esinp,exp){return(Math.pow((1.0-esinp)/(1.0+esinp),exp));},sign:function(x){if(x<0.0)return(-1);else return(1);},adjust_lon:function(x){x=(Math.abs(x)<this.PI)?x:(x-(this.sign(x)*this.TWO_PI));return x;},adjust_lat:function(x){x=(Math.abs(x)<this.HALF_PI)?x:(x-(this.sign(x)*this.PI));return x;},latiso:function(eccent,phi,sinphi)
+{if(Math.abs(phi)>this.HALF_PI)return+Number.NaN;if(phi==this.HALF_PI)return Number.POSITIVE_INFINITY;if(phi==-1.0*this.HALF_PI)return-1.0*Number.POSITIVE_INFINITY;var con=eccent*sinphi;return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;},fL:function(x,L){return 2.0*Math.atan(x*Math.exp(L))-this.HALF_PI;},invlatiso:function(eccent,ts){var phi=this.fL(1.0,ts);var Iphi=0.0;var con=0.0;do{Iphi=phi;con=eccent*Math.sin(Iphi);phi=this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)}while(Math.abs(phi-Iphi)>1.0e-12);return phi;},sinh:function(x)
+{var r=Math.exp(x);r=(r-1.0/r)/2.0;return r;},cosh:function(x)
+{var r=Math.exp(x);r=(r+1.0/r)/2.0;return r;},tanh:function(x)
+{var r=Math.exp(x);r=(r-1.0/r)/(r+1.0/r);return r;},asinh:function(x)
+{var s=(x>=0?1.0:-1.0);return s*(Math.log(Math.abs(x)+Math.sqrt(x*x+1.0)));},acosh:function(x)
+{return 2.0*Math.log(Math.sqrt((x+1.0)/2.0)+Math.sqrt((x-1.0)/2.0));},atanh:function(x)
+{return Math.log((x-1.0)/(x+1.0))/2.0;},gN:function(a,e,sinphi)
+{var temp=e*sinphi;return a/Math.sqrt(1.0-temp*temp);}};Proj4js.datum=Proj4js.Class({initialize:function(proj){this.datum_type=Proj4js.common.PJD_WGS84;if(proj.datumCode&&proj.datumCode=='none'){this.datum_type=Proj4js.common.PJD_NODATUM;}
+if(proj&&proj.datum_params){for(var i=0;i<proj.datum_params.length;i++){proj.datum_params[i]=parseFloat(proj.datum_params[i]);}
+if(proj.datum_params[0]!=0||proj.datum_params[1]!=0||proj.datum_params[2]!=0){this.datum_type=Proj4js.common.PJD_3PARAM;}
+if(proj.datum_params.length>3){if(proj.datum_params[3]!=0||proj.datum_params[4]!=0||proj.datum_params[5]!=0||proj.datum_params[6]!=0){this.datum_type=Proj4js.common.PJD_7PARAM;proj.datum_params[3]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[4]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[5]*=Proj4js.common.SEC_TO_RAD;proj.datum_params[6]=(proj.datum_params[6]/1000000.0)+1.0;}}}
+if(proj){this.a=proj.a;this.b=proj.b;this.es=proj.es;this.ep2=proj.ep2;this.datum_params=proj.datum_params;}},compare_datums:function(dest){if(this.datum_type!=dest.datum_type){return false;}else if(this.a!=dest.a||Math.abs(this.es-dest.es)>0.000000000050){return false;}else if(this.datum_type==Proj4js.common.PJD_3PARAM){return(this.datum_params[0]==dest.datum_params[0]&&this.datum_params[1]==dest.datum_params[1]&&this.datum_params[2]==dest.datum_params[2]);}else if(this.datum_type==Proj4js.common.PJD_7PARAM){return(this.datum_params[0]==dest.datum_params[0]&&this.datum_params[1]==dest.datum_params[1]&&this.datum_params[2]==dest.datum_params[2]&&this.datum_params[3]==dest.datum_params[3]&&this.datum_params[4]==dest.datum_params[4]&&this.datum_params[5]==dest.datum_params[5]&&this.datum_params[6]==dest.datum_params[6]);}else if(this.datum_type==Proj4js.common.PJD_GRIDSHIFT){return strcmp(pj_param(this.params,"snadgrids").s,pj_param(dest.params,"snadgrids").s)==0;}else{return true;}},geodetic_to_geocentric:function(p){var Longitude=p.x;var Latitude=p.y;var Height=p.z?p.z:0;var X;var Y;var Z;var Error_Code=0;var Rn;var Sin_Lat;var Sin2_Lat;var Cos_Lat;if(Latitude<-Proj4js.common.HALF_PI&&Latitude>-1.001*Proj4js.common.HALF_PI){Latitude=-Proj4js.common.HALF_PI;}else if(Latitude>Proj4js.common.HALF_PI&&Latitude<1.001*Proj4js.common.HALF_PI){Latitude=Proj4js.common.HALF_PI;}else if((Latitude<-Proj4js.common.HALF_PI)||(Latitude>Proj4js.common.HALF_PI)){Proj4js.reportError('geocent:lat out of range:'+Latitude);return null;}
+if(Longitude>Proj4js.common.PI)Longitude-=(2*Proj4js.common.PI);Sin_Lat=Math.sin(Latitude);Cos_Lat=Math.cos(Latitude);Sin2_Lat=Sin_Lat*Sin_Lat;Rn=this.a/(Math.sqrt(1.0e0-this.es*Sin2_Lat));X=(Rn+Height)*Cos_Lat*Math.cos(Longitude);Y=(Rn+Height)*Cos_Lat*Math.sin(Longitude);Z=((Rn*(1-this.es))+Height)*Sin_Lat;p.x=X;p.y=Y;p.z=Z;return Error_Code;},geocentric_to_geodetic:function(p){var genau=1.E-12;var genau2=(genau*genau);var maxiter=30;var P;var RR;var CT;var ST;var RX;var RK;var RN;var CPHI0;var SPHI0;var CPHI;var SPHI;var SDPHI;var At_Pole;var iter;var X=p.x;var Y=p.y;var Z=p.z?p.z:0.0;var Longitude;var Latitude;var Height;At_Pole=false;P=Math.sqrt(X*X+Y*Y);RR=Math.sqrt(X*X+Y*Y+Z*Z);if(P/this.a<genau){At_Pole=true;Longitude=0.0;if(RR/this.a<genau){Latitude=Proj4js.common.HALF_PI;Height=-this.b;return;}}else{Longitude=Math.atan2(Y,X);}
+CT=Z/RR;ST=P/RR;RX=1.0/Math.sqrt(1.0-this.es*(2.0-this.es)*ST*ST);CPHI0=ST*(1.0-this.es)*RX;SPHI0=CT*RX;iter=0;do
+{iter++;RN=this.a/Math.sqrt(1.0-this.es*SPHI0*SPHI0);Height=P*CPHI0+Z*SPHI0-RN*(1.0-this.es*SPHI0*SPHI0);RK=this.es*RN/(RN+Height);RX=1.0/Math.sqrt(1.0-RK*(2.0-RK)*ST*ST);CPHI=ST*(1.0-RK)*RX;SPHI=CT*RX;SDPHI=SPHI*CPHI0-CPHI*SPHI0;CPHI0=CPHI;SPHI0=SPHI;}
+while(SDPHI*SDPHI>genau2&&iter<maxiter);Latitude=Math.atan(SPHI/Math.abs(CPHI));p.x=Longitude;p.y=Latitude;p.z=Height;return p;},geocentric_to_geodetic_noniter:function(p){var X=p.x;var Y=p.y;var Z=p.z?p.z:0;var Longitude;var Latitude;var Height;var W;var W2;var T0;var T1;var S0;var S1;var Sin_B0;var Sin3_B0;var Cos_B0;var Sin_p1;var Cos_p1;var Rn;var Sum;var At_Pole;X=parseFloat(X);Y=parseFloat(Y);Z=parseFloat(Z);At_Pole=false;if(X!=0.0)
+{Longitude=Math.atan2(Y,X);}
+else
+{if(Y>0)
+{Longitude=Proj4js.common.HALF_PI;}
+else if(Y<0)
+{Longitude=-Proj4js.common.HALF_PI;}
+else
+{At_Pole=true;Longitude=0.0;if(Z>0.0)
+{Latitude=Proj4js.common.HALF_PI;}
+else if(Z<0.0)
+{Latitude=-Proj4js.common.HALF_PI;}
+else
+{Latitude=Proj4js.common.HALF_PI;Height=-this.b;return;}}}
+W2=X*X+Y*Y;W=Math.sqrt(W2);T0=Z*Proj4js.common.AD_C;S0=Math.sqrt(T0*T0+W2);Sin_B0=T0/S0;Cos_B0=W/S0;Sin3_B0=Sin_B0*Sin_B0*Sin_B0;T1=Z+this.b*this.ep2*Sin3_B0;Sum=W-this.a*this.es*Cos_B0*Cos_B0*Cos_B0;S1=Math.sqrt(T1*T1+Sum*Sum);Sin_p1=T1/S1;Cos_p1=Sum/S1;Rn=this.a/Math.sqrt(1.0-this.es*Sin_p1*Sin_p1);if(Cos_p1>=Proj4js.common.COS_67P5)
+{Height=W/Cos_p1-Rn;}
+else if(Cos_p1<=-Proj4js.common.COS_67P5)
+{Height=W/-Cos_p1-Rn;}
+else
+{Height=Z/Sin_p1+Rn*(this.es-1.0);}
+if(At_Pole==false)
+{Latitude=Math.atan(Sin_p1/Cos_p1);}
+p.x=Longitude;p.y=Latitude;p.z=Height;return p;},geocentric_to_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
+{p.x+=this.datum_params[0];p.y+=this.datum_params[1];p.z+=this.datum_params[2];}
+else if(this.datum_type==Proj4js.common.PJD_7PARAM)
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}},geocentric_from_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
+{p.x-=this.datum_params[0];p.y-=this.datum_params[1];p.z-=this.datum_params[2];}
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,ellipseName:"GRS 67(IUGG 1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"},"fschr68":{a:6378150.0,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6370997.0,b:6370997.0,ellipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
+this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e3=Math.sqrt(this.es);this.sin_po=Math.sin(this.lat1);this.cos_po=Math.cos(this.lat1);this.t1=this.sin_po
+this.con=this.sin_po;this.ms1=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs1=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat2);this.cos_po=Math.cos(this.lat2);this.t2=this.sin_po;this.ms2=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs2=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat0);this.cos_po=Math.cos(this.lat0);this.t3=this.sin_po;this.qs0=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns0=(this.ms1*this.ms1-this.ms2*this.ms2)/(this.qs2-this.qs1);}else{this.ns0=this.con;}
+this.c=this.ms1*this.ms1+this.ns0*this.qs1;this.rh=this.a*Math.sqrt(this.c-this.ns0*this.qs0)/this.ns0;},forward:function(p){var lon=p.x;var lat=p.y;this.sin_phi=Math.sin(lat);this.cos_phi=Math.cos(lat);var qs=Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);var rh1=this.a*Math.sqrt(this.c-this.ns0*qs)/this.ns0;var theta=this.ns0*Proj4js.common.adjust_lon(lon-this.long0);var x=rh1*Math.sin(theta)+this.x0;var y=this.rh-rh1*Math.cos(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var rh1,qs,con,theta,lon,lat;p.x-=this.x0;p.y=this.rh-p.y+this.y0;if(this.ns0>=0){rh1=Math.sqrt(p.x*p.x+p.y*p.y);con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
+theta=0.0;if(rh1!=0.0){theta=Math.atan2(con*p.x,con*p.y);}
+con=rh1*this.ns0/this.a;qs=(this.c-con*con)/this.ns0;if(this.e3>=1e-10){con=1-.5*(1.0-this.es)*Math.log((1.0-this.e3)/(1.0+this.e3))/this.e3;if(Math.abs(Math.abs(con)-Math.abs(qs))>.0000000001){lat=this.phi1z(this.e3,qs);}else{if(qs>=0){lat=.5*PI;}else{lat=-.5*PI;}}}else{lat=this.phi1z(e3,qs);}
+lon=Proj4js.common.adjust_lon(theta/this.ns0+this.long0);p.x=lon;p.y=lat;return p;},phi1z:function(eccent,qs){var con,com,dphi;var phi=Proj4js.common.asinz(.5*qs);if(eccent<Proj4js.common.EPSLN)return phi;var eccnts=eccent*eccent;for(var i=1;i<=25;i++){sinphi=Math.sin(phi);cosphi=Math.cos(phi);con=eccent*sinphi;com=1.0-con*con;dphi=.5*com*com/cosphi*(qs/(1.0-eccnts)-sinphi/com+.5/eccent*Math.log((1.0-con)/(1.0+con)));phi=phi+dphi;if(Math.abs(dphi)<=1e-7)return phi;}
+Proj4js.reportError("aea:phi1z:Convergence error");return null;}};Proj4js.Proj.sterea={dependsOn:'gauss',init:function(){Proj4js.Proj['gauss'].init.apply(this);if(!this.rc){Proj4js.reportError("sterea:init:E_ERROR_0");return;}
+this.sinc0=Math.sin(this.phic0);this.cosc0=Math.cos(this.phic0);this.R2=2.0*this.rc;if(!this.title)this.title="Oblique Stereographic Alternative";},forward:function(p){p.x=Proj4js.common.adjust_lon(p.x-this.long0);Proj4js.Proj['gauss'].forward.apply(this,[p]);sinc=Math.sin(p.y);cosc=Math.cos(p.y);cosl=Math.cos(p.x);k=this.k0*this.R2/(1.0+this.sinc0*sinc+this.cosc0*cosc*cosl);p.x=k*cosc*Math.sin(p.x);p.y=k*(this.cosc0*sinc-this.sinc0*cosc*cosl);p.x=this.a*p.x+this.x0;p.y=this.a*p.y+this.y0;return p;},inverse:function(p){var lon,lat;p.x=(p.x-this.x0)/this.a;p.y=(p.y-this.y0)/this.a;p.x/=this.k0;p.y/=this.k0;if((rho=Math.sqrt(p.x*p.x+p.y*p.y))){c=2.0*Math.atan2(rho,this.R2);sinc=Math.sin(c);cosc=Math.cos(c);lat=Math.asin(cosc*this.sinc0+p.y*sinc*this.cosc0/rho);lon=Math.atan2(p.x*sinc,rho*this.cosc0*cosc-p.y*this.sinc0*sinc);}else{lat=this.phic0;lon=0.;}
+p.x=lon;p.y=lat;Proj4js.Proj['gauss'].inverse.apply(this,[p]);p.x=Proj4js.common.adjust_lon(p.x+this.long0);return p;}};function phi4z(eccent,e0,e1,e2,e3,a,b,c,phi){var sinphi,sin2ph,tanph,ml,mlp,con1,con2,con3,dphi,i;phi=a;for(i=1;i<=15;i++){sinphi=Math.sin(phi);tanphi=Math.tan(phi);c=tanphi*Math.sqrt(1.0-eccent*sinphi*sinphi);sin2ph=Math.sin(2.0*phi);ml=e0*phi-e1*sin2ph+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi);mlp=e0-2.0*e1*Math.cos(2.0*phi)+4.0*e2*Math.cos(4.0*phi)-6.0*e3*Math.cos(6.0*phi);con1=2.0*ml+c*(ml*ml+b)-2.0*a*(c*ml+1.0);con2=eccent*sin2ph*(ml*ml+b-2.0*a*ml)/(2.0*c);con3=2.0*(a-ml)*(c*mlp-2.0/sin2ph)-2.0*mlp;dphi=con1/(con2+con3);phi+=dphi;if(Math.abs(dphi)<=.0000000001)return(phi);}
+Proj4js.reportError("phi4z: No convergence");return null;}
+function e4fn(x){var con,com;con=1.0+x;com=1.0-x;return(Math.sqrt((Math.pow(con,con))*(Math.pow(com,com))));}
+Proj4js.Proj.poly={init:function(){var temp;if(this.lat0=0)this.lat0=90;this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e=Math.sqrt(this.es);this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.ml0=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);},forward:function(p){var sinphi,cosphi;var al;var c;var con,ml;var ms;var x,y;var lon=p.x;var lat=p.y;con=Proj4js.common.adjust_lon(lon-this.long0);if(Math.abs(lat)<=.0000001){x=this.x0+this.a*con;y=this.y0-this.a*this.ml0;}else{sinphi=Math.sin(lat);cosphi=Math.cos(lat);ml=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);ms=Proj4js.common.msfnz(this.e,sinphi,cosphi);con=sinphi;x=this.x0+this.a*ms*Math.sin(con)/sinphi;y=this.y0+this.a*(ml-this.ml0+ms*(1.0-Math.cos(con))/sinphi);}
+p.x=x;p.y=y;return p;},inverse:function(p){var sin_phi,cos_phi;var al;var b;var c;var con,ml;var iflg;var lon,lat;p.x-=this.x0;p.y-=this.y0;al=this.ml0+p.y/this.a;iflg=0;if(Math.abs(al)<=.0000001){lon=p.x/this.a+this.long0;lat=0.0;}else{b=al*al+(p.x/this.a)*(p.x/this.a);iflg=phi4z(this.es,this.e0,this.e1,this.e2,this.e3,this.al,b,c,lat);if(iflg!=1)return(iflg);lon=Proj4js.common.adjust_lon((asinz(p.x*c/this.a)/Math.sin(lat))+this.long0);}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.equi={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon*Math.cos(this.lat0);var y=this.y0+this.a*lat;this.t1=x;this.t2=Math.cos(this.lat0);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lat=p.y/this.a;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("equi:Inv:DataError");}
+var lon=Proj4js.common.adjust_lon(this.long0+p.x/(this.a*Math.cos(this.lat0)));p.x=lon;p.y=lat;}};Proj4js.Proj.merc={init:function(){if(this.lat_ts){if(this.sphere){this.k0=Math.cos(this.lat_ts);}else{this.k0=Proj4js.common.msfnz(this.es,Math.sin(this.lat_ts),Math.cos(this.lat_ts));}}},forward:function(p){var lon=p.x;var lat=p.y;if(lat*Proj4js.common.R2D>90.0&&lat*Proj4js.common.R2D<-90.0&&lon*Proj4js.common.R2D>180.0&&lon*Proj4js.common.R2D<-180.0){Proj4js.reportError("merc:forward: llInputOutOfRange: "+lon+" : "+lat);return null;}
+var x,y;if(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN){Proj4js.reportError("merc:forward: ll2mAtPoles");return null;}else{if(this.sphere){x=this.x0+this.a*this.k0*Proj4js.common.adjust_lon(lon-this.long0);y=this.y0+this.a*this.k0*Math.log(Math.tan(Proj4js.common.FORTPI+0.5*lat));}else{var sinphi=Math.sin(lat);var ts=Proj4js.common.tsfnz(this.e,lat,sinphi);x=this.x0+this.a*this.k0*Proj4js.common.adjust_lon(lon-this.long0);y=this.y0-this.a*this.k0*Math.log(ts);}
+p.x=x;p.y=y;return p;}},inverse:function(p){var x=p.x-this.x0;var y=p.y-this.y0;var lon,lat;if(this.sphere){lat=Proj4js.common.HALF_PI-2.0*Math.atan(Math.exp(-y/this.a*this.k0));}else{var ts=Math.exp(-y/(this.a*this.k0));lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999){Proj4js.reportError("merc:inverse: lat = -9999");return null;}}
+lon=Proj4js.common.adjust_lon(this.long0+x/(this.a*this.k0));p.x=lon;p.y=lat;return p;}};Proj4js.Proj.utm={dependsOn:'tmerc',init:function(){if(!this.zone){Proj4js.reportError("utm:init: zone must be specified for UTM");return;}
+this.lat0=0.0;this.long0=((6*Math.abs(this.zone))-183)*Proj4js.common.D2R;this.x0=500000.0;this.y0=this.utmSouth?10000000.0:0.0;this.k0=0.9996;Proj4js.Proj['tmerc'].init.apply(this);this.forward=Proj4js.Proj['tmerc'].forward;this.inverse=Proj4js.Proj['tmerc'].inverse;}};Proj4js.Proj.eqdc={init:function(){if(!this.mode)this.mode=0;this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e=Math.sqrt(this.es);this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.sinphi=Math.sin(this.lat1);this.cosphi=Math.cos(this.lat1);this.ms1=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml1=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat1);if(this.mode!=0){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("eqdc:Init:EqualLatitudes");}
+this.sinphi=Math.sin(this.lat2);this.cosphi=Math.cos(this.lat2);this.ms2=Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);this.ml2=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat2);if(Math.abs(this.lat1-this.lat2)>=Proj4js.common.EPSLN){this.ns=(this.ms1-this.ms2)/(this.ml2-this.ml1);}else{this.ns=this.sinphi;}}else{this.ns=this.sinphi;}
+this.g=this.ml1+this.ms1/this.ns;this.ml0=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);this.rh=this.a*(this.g-this.ml0);},forward:function(p){var lon=p.x;var lat=p.y;var ml=Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);var rh1=this.a*(this.g-ml);var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+rh1*Math.sin(theta);var y=this.y0+this.rh-rh1*Math.cos(theta);p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y=this.rh-p.y+this.y0;var con,rh1;if(this.ns>=0){var rh1=Math.sqrt(p.x*p.x+p.y*p.y);var con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
+var theta=0.0;if(rh1!=0.0)theta=Math.atan2(con*p.x,con*p.y);var ml=this.g-rh1/this.a;var lat=this.phi3z(this.ml,this.e0,this.e1,this.e2,this.e3);var lon=Proj4js.common.adjust_lon(this.long0+theta/this.ns);p.x=lon;p.y=lat;return p;},phi3z:function(ml,e0,e1,e2,e3){var phi;var dphi;phi=ml;for(var i=0;i<15;i++){dphi=(ml+e1*Math.sin(2.0*phi)-e2*Math.sin(4.0*phi)+e3*Math.sin(6.0*phi))/e0-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001){return phi;}}
+Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");return null;}};Proj4js.Proj.tmerc={init:function(){this.e0=Proj4js.common.e0fn(this.es);this.e1=Proj4js.common.e1fn(this.es);this.e2=Proj4js.common.e2fn(this.es);this.e3=Proj4js.common.e3fn(this.es);this.ml0=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,this.lat0);},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var con;var x,y;var sin_phi=Math.sin(lat);var cos_phi=Math.cos(lat);if(this.sphere){var b=cos_phi*Math.sin(delta_lon);if((Math.abs(Math.abs(b)-1.0))<.0000000001){Proj4js.reportError("tmerc:forward: Point projects into infinity");return(93);}else{x=.5*this.a*this.k0*Math.log((1.0+b)/(1.0-b));con=Math.acos(cos_phi*Math.cos(delta_lon)/Math.sqrt(1.0-b*b));if(lat<0)con=-con;y=this.a*this.k0*(con-this.lat0);}}else{var al=cos_phi*delta_lon;var als=Math.pow(al,2);var c=this.ep2*Math.pow(cos_phi,2);var tq=Math.tan(lat);var t=Math.pow(tq,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var ml=this.a*Proj4js.common.mlfn(this.e0,this.e1,this.e2,this.e3,lat);x=this.k0*n*al*(1.0+als/6.0*(1.0-t+c+als/20.0*(5.0-18.0*t+Math.pow(t,2)+72.0*c-58.0*this.ep2)))+this.x0;y=this.k0*(ml-this.ml0+n*tq*(als*(0.5+als/24.0*(5.0-t+9.0*c+4.0*Math.pow(c,2)+als/30.0*(61.0-58.0*t+Math.pow(t,2)+600.0*c-330.0*this.ep2)))))+this.y0;}
+p.x=x;p.y=y;return p;},inverse:function(p){var con,phi;var delta_phi;var i;var max_iter=6;var lat,lon;if(this.sphere){var f=Math.exp(p.x/(this.a*this.k0));var g=.5*(f-1/f);var temp=this.lat0+p.y/(this.a*this.k0);var h=Math.cos(temp);con=Math.sqrt((1.0-h*h)/(1.0+g*g));lat=Math.asinz(con);if(temp<0)
+lat=-lat;if((g==0)&&(h==0)){lon=this.long0;}else{lon=Proj4js.common.adjust_lon(Math.atan2(g,h)+this.long0);}}else{var x=p.x-this.x0;var y=p.y-this.y0;con=(this.ml0+y/this.k0)/this.a;phi=con;for(i=0;;i++){delta_phi=((con+this.e1*Math.sin(2.0*phi)-this.e2*Math.sin(4.0*phi)+this.e3*Math.sin(6.0*phi))/this.e0)-phi;phi+=delta_phi;if(Math.abs(delta_phi)<=Proj4js.common.EPSLN)break;if(i>=max_iter){Proj4js.reportError("tmerc:inverse: Latitude failed to converge");return(95);}}
+if(Math.abs(phi)<Proj4js.common.HALF_PI){var sin_phi=Math.sin(phi);var cos_phi=Math.cos(phi);var tan_phi=Math.tan(phi);var c=this.ep2*Math.pow(cos_phi,2);var cs=Math.pow(c,2);var t=Math.pow(tan_phi,2);var ts=Math.pow(t,2);con=1.0-this.es*Math.pow(sin_phi,2);var n=this.a/Math.sqrt(con);var r=n*(1.0-this.es)/con;var d=x/(n*this.k0);var ds=Math.pow(d,2);lat=phi-(n*tan_phi*ds/r)*(0.5-ds/24.0*(5.0+3.0*t+10.0*c-4.0*cs-9.0*this.ep2-ds/30.0*(61.0+90.0*t+298.0*c+45.0*ts-252.0*this.ep2-3.0*cs)));lon=Proj4js.common.adjust_lon(this.long0+(d*(1.0-ds/6.0*(1.0+2.0*t+c-ds/20.0*(5.0-2.0*c+28.0*t-3.0*cs+8.0*this.ep2+24.0*ts)))/cos_phi));}else{lat=Proj4js.common.HALF_PI*Proj4js.common.sign(y);lon=this.long0;}}
+p.x=lon;p.y=lat;return p;}};Proj4js.defs["GOOGLE"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs";Proj4js.defs["EPSG:900913"]=Proj4js.defs["GOOGLE"];Proj4js.Proj.gstmerc={init:function(){var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);this.lc=this.long0;this.rs=Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));var sinz=Math.sin(this.lat0);var pc=Math.asin(sinz/this.rs);var sinzpc=Math.sin(pc);this.cp=Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);this.n2=this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);this.xs=this.x0;this.ys=this.y0-this.n2*pc;if(!this.title)this.title="Gauss Schreiber transverse mercator";},forward:function(p){var lon=p.x;var lat=p.y;var L=this.rs*(lon-this.lc);var Ls=this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));var lat1=Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));var Ls1=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.xs+(this.n2*Ls1);p.y=this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));return p;},inverse:function(p){var x=p.x;var y=p.y;var L=Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));var lat1=Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));var LC=Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));p.x=this.lc+L/this.rs;p.y=Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);return p;}};Proj4js.Proj.ortho={init:function(def){;this.sin_p14=Math.sin(this.lat0);this.cos_p14=Math.cos(this.lat0);},forward:function(p){var sinphi,cosphi;var dlon;var coslon;var ksp;var g;var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslon=Math.cos(dlon);g=this.sin_p14*sinphi+this.cos_p14*cosphi*coslon;ksp=1.0;if((g>0)||(Math.abs(g)<=Proj4js.common.EPSLN)){var x=this.a*ksp*cosphi*Math.sin(dlon);var y=this.y0+this.a*ksp*(this.cos_p14*sinphi-this.sin_p14*cosphi*coslon);}else{Proj4js.reportError("orthoFwdPointError");}
+p.x=x;p.y=y;return p;},inverse:function(p){var rh;var z;var sinz,cosz;var temp;var con;var lon,lat;p.x-=this.x0;p.y-=this.y0;rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>this.a+.0000001){Proj4js.reportError("orthoInvDataError");}
+z=Proj4js.common.asinz(rh/this.a);sinz=Math.sin(z);cosi=Math.cos(z);lon=this.long0;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}
+lat=Proj4js.common.asinz(cosz*this.sin_p14+(y*sinz*this.cos_p14)/rh);con=Math.abs(lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(this.lat0>=0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}
+con=cosz-this.sin_p14*Math.sin(lat);if((Math.abs(con)>=Proj4js.common.EPSLN)||(Math.abs(x)>=Proj4js.common.EPSLN)){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p14),(con*rh)));}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.somerc={init:function(){var phy0=this.lat0;this.lambda0=this.long0;var sinPhy0=Math.sin(phy0);var semiMajorAxis=this.a;var invF=this.rf;var flattening=1/invF;var e2=2*flattening-Math.pow(flattening,2);var e=this.e=Math.sqrt(e2);this.R=semiMajorAxis*Math.sqrt(1-e2)/(1-e2*Math.pow(sinPhy0,2.0));this.alpha=Math.sqrt(1+e2/(1-e2)*Math.pow(Math.cos(phy0),4.0));this.b0=Math.asin(sinPhy0/this.alpha);this.K=Math.log(Math.tan(Math.PI/4.0+this.b0/2.0))
+-this.alpha*Math.log(Math.tan(Math.PI/4.0+phy0/2.0))
++this.alpha*e/2*Math.log((1+e*sinPhy0)/(1-e*sinPhy0));},forward:function(p){var Sa1=Math.log(Math.tan(Math.PI/4.0-p.y/2.0));var Sa2=this.e/2.0*Math.log((1+this.e*Math.sin(p.y))/(1-this.e*Math.sin(p.y)));var S=-this.alpha*(Sa1+Sa2)+this.K;var b=2.0*(Math.atan(Math.exp(S))-Math.PI/4.0);var I=this.alpha*(p.x-this.lambda0);var rotI=Math.atan(Math.sin(I)/(Math.sin(this.b0)*Math.tan(b)+
+Math.cos(this.b0)*Math.cos(I)));var rotB=Math.asin(Math.cos(this.b0)*Math.sin(b)-
+Math.sin(this.b0)*Math.cos(b)*Math.cos(I));p.y=this.R/2.0*Math.log((1+Math.sin(rotB))/(1-Math.sin(rotB)))
++this.y0;p.x=this.R*rotI+this.x0;return p;},inverse:function(p){var Y=p.x-this.x0;var X=p.y-this.y0;var rotI=Y/this.R;var rotB=2*(Math.atan(Math.exp(X/this.R))-Math.PI/4.0);var b=Math.asin(Math.cos(this.b0)*Math.sin(rotB)
++Math.sin(this.b0)*Math.cos(rotB)*Math.cos(rotI));var I=Math.atan(Math.sin(rotI)/(Math.cos(this.b0)*Math.cos(rotI)-Math.sin(this.b0)*Math.tan(rotB)));var lambda=this.lambda0+I/this.alpha;var S=0.0;var phy=b;var prevPhy=-1000.0;var iteration=0;while(Math.abs(phy-prevPhy)>0.0000001)
+{if(++iteration>20)
+{Proj4js.reportError("omercFwdInfinity");return;}
+S=1.0/this.alpha*(Math.log(Math.tan(Math.PI/4.0+b/2.0))-this.K)
++this.e*Math.log(Math.tan(Math.PI/4.0
++Math.asin(this.e*Math.sin(phy))/2.0));prevPhy=phy;phy=2.0*Math.atan(Math.exp(S))-Math.PI/2.0;}
+p.x=lambda;p.y=phy;return p;}};Proj4js.Proj.stere={ssfn_:function(phit,sinphi,eccen){sinphi*=eccen;return(Math.tan(.5*(Proj4js.common.HALF_PI+phit))*Math.pow((1.-sinphi)/(1.+sinphi),.5*eccen));},TOL:1.e-8,NITER:8,CONV:1.e-10,S_POLE:0,N_POLE:1,OBLIQ:2,EQUIT:3,init:function(){this.phits=this.lat_ts?this.lat_ts:Proj4js.common.HALF_PI;var t=Math.abs(this.lat0);if((Math.abs(t)-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.mode=this.lat0<0.?this.S_POLE:this.N_POLE;}else{this.mode=t>Proj4js.common.EPSLN?this.OBLIQ:this.EQUIT;}
+this.phits=Math.abs(this.phits);if(this.es){var X;switch(this.mode){case this.N_POLE:case this.S_POLE:if(Math.abs(this.phits-Proj4js.common.HALF_PI)<Proj4js.common.EPSLN){this.akm1=2.*this.k0/Math.sqrt(Math.pow(1+this.e,1+this.e)*Math.pow(1-this.e,1-this.e));}else{t=Math.sin(this.phits);this.akm1=Math.cos(this.phits)/Proj4js.common.tsfnz(this.e,this.phits,t);t*=this.e;this.akm1/=Math.sqrt(1.-t*t);}
+break;case this.EQUIT:this.akm1=2.*this.k0;break;case this.OBLIQ:t=Math.sin(this.lat0);X=2.*Math.atan(this.ssfn_(this.lat0,t,this.e))-Proj4js.common.HALF_PI;t*=this.e;this.akm1=2.*this.k0*Math.cos(this.lat0)/Math.sqrt(1.-t*t);this.sinX1=Math.sin(X);this.cosX1=Math.cos(X);break;}}else{switch(this.mode){case this.OBLIQ:this.sinph0=Math.sin(this.lat0);this.cosph0=Math.cos(this.lat0);case this.EQUIT:this.akm1=2.*this.k0;break;case this.S_POLE:case this.N_POLE:this.akm1=Math.abs(this.phits-Proj4js.common.HALF_PI)>=Proj4js.common.EPSLN?Math.cos(this.phits)/Math.tan(Proj4js.common.FORTPI-.5*this.phits):2.*this.k0;break;}}},forward:function(p){var lon=p.x;var lat=p.y;var x,y
+if(this.sphere){var sinphi,cosphi,coslam,sinlam;sinphi=Math.sin(lat);cosphi=Math.cos(lat);coslam=Math.cos(lon);sinlam=Math.sin(lon);switch(this.mode){case this.EQUIT:y=1.+cosphi*coslam;if(y<=Proj4js.common.EPSLN){F_ERROR;}
+y=this.akm1/y;x=y*cosphi*sinlam;y*=sinphi;break;case this.OBLIQ:y=1.+this.sinph0*sinphi+this.cosph0*cosphi*coslam;if(y<=Proj4js.common.EPSLN){F_ERROR;}
+y=this.akm1/y;x=y*cosphi*sinlam;y*=this.cosph0*sinphi-this.sinph0*cosphi*coslam;break;case this.N_POLE:coslam=-coslam;lat=-lat;case this.S_POLE:if(Math.abs(lat-Proj4js.common.HALF_PI)<this.TOL){F_ERROR;}
+y=this.akm1*Math.tan(Proj4js.common.FORTPI+.5*lat)
+x=sinlam*y;y*=coslam;break;}}else{coslam=Math.cos(lon);sinlam=Math.sin(lon);sinphi=Math.sin(lat);if(this.mode==this.OBLIQ||this.mode==this.EQUIT){X=2.*Math.atan(this.ssfn_(lat,sinphi,this.e));sinX=Math.sin(X-Proj4js.common.HALF_PI);cosX=Math.cos(X);}
+switch(this.mode){case this.OBLIQ:A=this.akm1/(this.cosX1*(1.+this.sinX1*sinX+this.cosX1*cosX*coslam));y=A*(this.cosX1*sinX-this.sinX1*cosX*coslam);x=A*cosX;break;case this.EQUIT:A=2.*this.akm1/(1.+cosX*coslam);y=A*sinX;x=A*cosX;break;case this.S_POLE:lat=-lat;coslam=-coslam;sinphi=-sinphi;case this.N_POLE:x=this.akm1*Proj4js.common.tsfnz(this.e,lat,sinphi);y=-x*coslam;break;}
+x=x*sinlam;}
+p.x=x*this.a+this.x0;p.y=y*this.a+this.y0;return p;},inverse:function(p){var x=(p.x-this.x0)/this.a;var y=(p.y-this.y0)/this.a;var lon,lat
+var cosphi,sinphi,tp=0.0,phi_l=0.0,rho,halfe=0.0,pi2=0.0;var i;if(this.sphere){var c,rh,sinc,cosc;rh=Math.sqrt(x*x+y*y);c=2.*Math.atan(rh/this.akm1);sinc=Math.sin(c);cosc=Math.cos(c);lon=0.;switch(this.mode){case this.EQUIT:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=0.;}else{lat=Math.asin(y*sinc/rh);}
+if(cosc!=0.||x!=0.)lon=Math.atan2(x*sinc,cosc*rh);break;case this.OBLIQ:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(cosc*sinph0+y*sinc*cosph0/rh);}
+c=cosc-sinph0*Math.sin(lat);if(c!=0.||x!=0.){lon=Math.atan2(x*sinc*cosph0,c*rh);}
+break;case this.N_POLE:y=-y;case this.S_POLE:if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.phi0;}else{lat=Math.asin(this.mode==this.S_POLE?-cosc:cosc);}
+lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);break;}}else{rho=Math.sqrt(x*x+y*y);switch(this.mode){case this.OBLIQ:case this.EQUIT:tp=2.*Math.atan2(rho*this.cosX1,this.akm1);cosphi=Math.cos(tp);sinphi=Math.sin(tp);if(rho==0.0){phi_l=Math.asin(cosphi*this.sinX1);}else{phi_l=Math.asin(cosphi*this.sinX1+(y*sinphi*this.cosX1/rho));}
+tp=Math.tan(.5*(Proj4js.common.HALF_PI+phi_l));x*=sinphi;y=rho*this.cosX1*cosphi-y*this.sinX1*sinphi;pi2=Proj4js.common.HALF_PI;halfe=.5*this.e;break;case this.N_POLE:y=-y;case this.S_POLE:tp=-rho/this.akm1
+phi_l=Proj4js.common.HALF_PI-2.*Math.atan(tp);pi2=-Proj4js.common.HALF_PI;halfe=-.5*this.e;break;}
+for(i=this.NITER;i--;phi_l=lat){sinphi=this.e*Math.sin(phi_l);lat=2.*Math.atan(tp*Math.pow((1.+sinphi)/(1.-sinphi),halfe))-pi2;if(Math.abs(phi_l-lat)<this.CONV){if(this.mode==this.S_POLE)lat=-lat;lon=(x==0.&&y==0.)?0.:Math.atan2(x,y);p.x=lon;p.y=lat
+return p;}}}}};Proj4js.Proj.nzmg={iterations:1,init:function(){this.A=new Array();this.A[1]=+0.6399175073;this.A[2]=-0.1358797613;this.A[3]=+0.063294409;this.A[4]=-0.02526853;this.A[5]=+0.0117879;this.A[6]=-0.0055161;this.A[7]=+0.0026906;this.A[8]=-0.001333;this.A[9]=+0.00067;this.A[10]=-0.00034;this.B_re=new Array();this.B_im=new Array();this.B_re[1]=+0.7557853228;this.B_im[1]=0.0;this.B_re[2]=+0.249204646;this.B_im[2]=+0.003371507;this.B_re[3]=-0.001541739;this.B_im[3]=+0.041058560;this.B_re[4]=-0.10162907;this.B_im[4]=+0.01727609;this.B_re[5]=-0.26623489;this.B_im[5]=-0.36249218;this.B_re[6]=-0.6870983;this.B_im[6]=-1.1651967;this.C_re=new Array();this.C_im=new Array();this.C_re[1]=+1.3231270439;this.C_im[1]=0.0;this.C_re[2]=-0.577245789;this.C_im[2]=-0.007809598;this.C_re[3]=+0.508307513;this.C_im[3]=-0.112208952;this.C_re[4]=-0.15094762;this.C_im[4]=+0.18200602;this.C_re[5]=+1.01418179;this.C_im[5]=+1.64497696;this.C_re[6]=+1.9660549;this.C_im[6]=+2.5127645;this.D=new Array();this.D[1]=+1.5627014243;this.D[2]=+0.5185406398;this.D[3]=-0.03333098;this.D[4]=-0.1052906;this.D[5]=-0.0368594;this.D[6]=+0.007317;this.D[7]=+0.01220;this.D[8]=+0.00394;this.D[9]=-0.0013;},forward:function(p){var lon=p.x;var lat=p.y;var delta_lat=lat-this.lat0;var delta_lon=lon-this.long0;var d_phi=delta_lat/Proj4js.common.SEC_TO_RAD*1E-5;var d_lambda=delta_lon;var d_phi_n=1;var d_psi=0;for(n=1;n<=10;n++){d_phi_n=d_phi_n*d_phi;d_psi=d_psi+this.A[n]*d_phi_n;}
+var th_re=d_psi;var th_im=d_lambda;var th_n_re=1;var th_n_im=0;var th_n_re1;var th_n_im1;var z_re=0;var z_im=0;for(n=1;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;z_re=z_re+this.B_re[n]*th_n_re-this.B_im[n]*th_n_im;z_im=z_im+this.B_im[n]*th_n_re+this.B_re[n]*th_n_im;}
+x=(z_im*this.a)+this.x0;y=(z_re*this.a)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var x=p.x;var y=p.y;var delta_x=x-this.x0;var delta_y=y-this.y0;var z_re=delta_y/this.a;var z_im=delta_x/this.a;var z_n_re=1;var z_n_im=0;var z_n_re1;var z_n_im1;var th_re=0;var th_im=0;for(n=1;n<=6;n++){z_n_re1=z_n_re*z_re-z_n_im*z_im;z_n_im1=z_n_im*z_re+z_n_re*z_im;z_n_re=z_n_re1;z_n_im=z_n_im1;th_re=th_re+this.C_re[n]*z_n_re-this.C_im[n]*z_n_im;th_im=th_im+this.C_im[n]*z_n_re+this.C_re[n]*z_n_im;}
+for(i=0;i<this.iterations;i++){var th_n_re=th_re;var th_n_im=th_im;var th_n_re1;var th_n_im1;var num_re=z_re;var num_im=z_im;for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;num_re=num_re+(n-1)*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);num_im=num_im+(n-1)*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
+th_n_re=1;th_n_im=0;var den_re=this.B_re[1];var den_im=this.B_im[1];for(n=2;n<=6;n++){th_n_re1=th_n_re*th_re-th_n_im*th_im;th_n_im1=th_n_im*th_re+th_n_re*th_im;th_n_re=th_n_re1;th_n_im=th_n_im1;den_re=den_re+n*(this.B_re[n]*th_n_re-this.B_im[n]*th_n_im);den_im=den_im+n*(this.B_im[n]*th_n_re+this.B_re[n]*th_n_im);}
+var den2=den_re*den_re+den_im*den_im;th_re=(num_re*den_re+num_im*den_im)/den2;th_im=(num_im*den_re-num_re*den_im)/den2;}
+var d_psi=th_re;var d_lambda=th_im;var d_psi_n=1;var d_phi=0;for(n=1;n<=9;n++){d_psi_n=d_psi_n*d_psi;d_phi=d_phi+this.D[n]*d_psi_n;}
+var lat=this.lat0+(d_phi*Proj4js.common.SEC_TO_RAD*1E5);var lon=this.long0+d_lambda;p.x=lon;p.y=lat;return p;}};Proj4js.Proj.mill={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;dlon=Proj4js.common.adjust_lon(lon-this.long0);var x=this.x0+this.a*dlon;var y=this.y0+this.a*Math.log(Math.tan((Proj4js.common.PI/4.0)+(lat/2.5)))*1.25;p.x=x;p.y=y;return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var lon=Proj4js.common.adjust_lon(this.long0+p.x/this.a);var lat=2.5*(Math.atan(Math.exp(0.8*p.y/this.a))-Proj4js.common.PI/4.0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.sinu={init:function(){this.R=6370997.0;},forward:function(p){var x,y,delta_lon;var lon=p.x;var lat=p.y;delta_lon=Proj4js.common.adjust_lon(lon-this.long0);x=this.R*delta_lon*Math.cos(lat)+this.x0;y=this.R*lat+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var lat,temp,lon;p.x-=this.x0;p.y-=this.y0;lat=p.y/this.R;if(Math.abs(lat)>Proj4js.common.HALF_PI){Proj4js.reportError("sinu:Inv:DataError");}
+temp=Math.abs(lat)-Proj4js.common.HALF_PI;if(Math.abs(temp)>Proj4js.common.EPSLN){temp=this.long0+p.x/(this.R*Math.cos(lat));lon=Proj4js.common.adjust_lon(temp);}else{lon=this.long0;}
+p.x=lon;p.y=lat;return p;}};var GEOCENT_LAT_ERROR=0x0001;var COS_67P5=0.38268343236508977;var AD_C=1.0026000;function cs_geodetic_to_geocentric(cs,p){var Longitude=p.x;var Latitude=p.y;var Height=p.z;var X;var Y;var Z;var Error_Code=0;var Rn;var Sin_Lat;var Sin2_Lat;var Cos_Lat;if(Latitude<-HALF_PI&&Latitude>-1.001*HALF_PI)
+Latitude=-HALF_PI;else if(Latitude>HALF_PI&&Latitude<1.001*HALF_PI)
+Latitude=HALF_PI;else if((Latitude<-HALF_PI)||(Latitude>HALF_PI))
+{Error_Code|=GEOCENT_LAT_ERROR;}
+if(!Error_Code)
+{if(Longitude>PI)
+Longitude-=(2*PI);Sin_Lat=Math.sin(Latitude);Cos_Lat=Math.cos(Latitude);Sin2_Lat=Sin_Lat*Sin_Lat;Rn=cs.a/(Math.sqrt(1.0e0-cs.es*Sin2_Lat));X=(Rn+Height)*Cos_Lat*Math.cos(Longitude);Y=(Rn+Height)*Cos_Lat*Math.sin(Longitude);Z=((Rn*(1-cs.es))+Height)*Sin_Lat;}
+p.x=X;p.y=Y;p.z=Z;return Error_Code;}
+function cs_geocentric_to_geodetic(cs,p){var X=p.x;var Y=p.y;var Z=p.z;var Longitude;var Latitude;var Height;var W;var W2;var T0;var T1;var S0;var S1;var Sin_B0;var Sin3_B0;var Cos_B0;var Sin_p1;var Cos_p1;var Rn;var Sum;var At_Pole;X=parseFloat(X);Y=parseFloat(Y);Z=parseFloat(Z);At_Pole=false;if(X!=0.0)
+else
+{if(Y>0)
+{Longitude=HALF_PI;}
+else if(Y<0)
+{Longitude=-HALF_PI;}
+else
+{Latitude=HALF_PI;}
+else if(Z<0.0)
+{Latitude=-HALF_PI;}
+else
+{Latitude=HALF_PI;Height=-cs.b;return;}}}
+W2=X*X+Y*Y;W=Math.sqrt(W2);T0=Z*AD_C;S0=Math.sqrt(T0*T0+W2);Sin_B0=T0/S0;Cos_B0=W/S0;Sin3_B0=Sin_B0*Sin_B0*Sin_B0;T1=Z+cs.b*cs.ep2*Sin3_B0;Sum=W-cs.a*cs.es*Cos_B0*Cos_B0*Cos_B0;S1=Math.sqrt(T1*T1+Sum*Sum);Sin_p1=T1/S1;Cos_p1=Sum/S1;Rn=cs.a/Math.sqrt(1.0-cs.es*Sin_p1*Sin_p1);if(Cos_p1>=COS_67P5)
+else if(Cos_p1<=-COS_67P5)
+else
+{Height=Z/Sin_p1+Rn*(cs.es-1.0);}
+if(At_Pole==false)
+p.x=Longitude;p.y=Latitude;p.z=Height;return 0;}
+function cs_geocentric_to_wgs84(defn,p){if(defn.datum_type==PJD_3PARAM)
+{p.x+=defn.datum_params[0];p.y+=defn.datum_params[1];p.z+=defn.datum_params[2];}
+else
+{var Dx_BF=defn.datum_params[0];var Dy_BF=defn.datum_params[1];var Dz_BF=defn.datum_params[2];var Rx_BF=defn.datum_params[3];var Ry_BF=defn.datum_params[4];var Rz_BF=defn.datum_params[5];var M_BF=defn.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}}
+function cs_geocentric_from_wgs84(defn,p){if(defn.datum_type==PJD_3PARAM)
+{p.x-=defn.datum_params[0];p.y-=defn.datum_params[1];p.z-=defn.datum_params[2];}
+else
+{var Dx_BF=defn.datum_params[0];var Dy_BF=defn.datum_params[1];var Dz_BF=defn.datum_params[2];var Rx_BF=defn.datum_params[3];var Ry_BF=defn.datum_params[4];var Rz_BF=defn.datum_params[5];var M_BF=defn.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}
+Proj4js.Proj.vandg={init:function(){this.R=6370997.0;},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var x,y;if(Math.abs(lat)<=Proj4js.common.EPSLN){x=this.x0+this.R*dlon;y=this.y0;}
+var theta=Proj4js.common.asinz(2.0*Math.abs(lat/Proj4js.common.PI));if((Math.abs(dlon)<=Proj4js.common.EPSLN)||(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN)){x=this.x0;if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.tan(.5*theta);}else{y=this.y0+Proj4js.common.PI*this.R*-Math.tan(.5*theta);}}
+var al=.5*Math.abs((Proj4js.common.PI/dlon)-(dlon/Proj4js.common.PI));var asq=al*al;var sinth=Math.sin(theta);var costh=Math.cos(theta);var g=costh/(sinth+costh-1.0);var gsq=g*g;var m=g*(2.0/sinth-1.0);var msq=m*m;var con=Proj4js.common.PI*this.R*(al*(g-msq)+Math.sqrt(asq*(g-msq)*(g-msq)-(msq+asq)*(gsq-msq)))/(msq+asq);if(dlon<0){con=-con;}
+x=this.x0+con;con=Math.abs(con/(Proj4js.common.PI*this.R));if(lat>=0){y=this.y0+Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}else{y=this.y0-Proj4js.common.PI*this.R*Math.sqrt(1.0-con*con-2.0*al*con);}
+p.x=x;p.y=y;return p;},inverse:function(p){var dlon;var xx,yy,xys,c1,c2,c3;var al,asq;var a1;var m1;var con;var th1;var d;p.x-=this.x0;p.y-=this.y0;con=Proj4js.common.PI*this.R;xx=p.x/con;yy=p.y/con;xys=xx*xx+yy*yy;c1=-Math.abs(yy)*(1.0+xys);c2=c1-2.0*yy*yy+xx*xx;c3=-2.0*c1+1.0+2.0*yy*yy+xys*xys;d=yy*yy/c3+(2.0*c2*c2*c2/c3/c3/c3-9.0*c1*c2/c3/c3)/27.0;a1=(c1-c2*c2/3.0/c3)/c3;m1=2.0*Math.sqrt(-a1/3.0);con=((3.0*d)/a1)/m1;if(Math.abs(con)>1.0){if(con>=0.0){con=1.0;}else{con=-1.0;}}
+th1=Math.acos(con)/3.0;if(p.y>=0){lat=(-m1*Math.cos(th1+Proj4js.common.PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}else{lat=-(-m1*Math.cos(th1+PI/3.0)-c2/3.0/c3)*Proj4js.common.PI;}
+if(Math.abs(xx)<Proj4js.common.EPSLN){lon=this.long0;}
+lon=Proj4js.common.adjust_lon(this.long0+Proj4js.common.PI*(xys-1.0+Math.sqrt(1.0+2.0*(xx*xx-yy*yy)+xys*xys))/2.0/xx);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.eqc={init:function(){if(!this.x0)this.x0=0;if(!this.y0)this.y0=0;if(!this.lat0)this.lat0=0;if(!this.long0)this.long0=0;if(!this.lat_ts)this.lat_ts=0;if(!this.title)this.title="Equidistant Cylindrical (Plate Carre)";this.rc=Math.cos(this.lat_ts);},forward:function(p){var lon=p.x;var lat=p.y;var dlon=Proj4js.common.adjust_lon(lon-this.long0);var dlat=Proj4js.common.adjust_lat(lat-this.lat0);p.x=this.x0+(this.a*dlon*this.rc);p.y=this.y0+(this.a*dlat);return p;},inverse:function(p){var x=p.x;var y=p.y;p.x=Proj4js.common.adjust_lon(this.long0+((x-this.x0)/(this.a*this.rc)));p.y=Proj4js.common.adjust_lat(this.lat0+((y-this.y0)/(this.a)));return p;}};Proj4js.Proj.gauss={init:function(){sphi=Math.sin(this.lat0);cphi=Math.cos(this.lat0);cphi*=cphi;this.rc=Math.sqrt(1.0-this.es)/(1.0-this.es*sphi*sphi);this.C=Math.sqrt(1.0+this.es*cphi*cphi/(1.0-this.es));this.phic0=Math.asin(sphi/this.C);this.ratexp=0.5*this.C*this.e;this.K=Math.tan(0.5*this.phic0+Proj4js.common.FORTPI)/(Math.pow(Math.tan(0.5*this.lat0+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*sphi,this.ratexp));},forward:function(p){var lon=p.x;var lat=p.y;p.y=2.0*Math.atan(this.K*Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI),this.C)*Proj4js.common.srat(this.e*Math.sin(lat),this.ratexp))-Proj4js.common.HALF_PI;p.x=this.C*lon;return p;},inverse:function(p){var DEL_TOL=1e-14;var lon=p.x/this.C;var lat=p.y;num=Math.pow(Math.tan(0.5*lat+Proj4js.common.FORTPI)/this.K,1./this.C);for(var i=Proj4js.common.MAX_ITER;i>0;--i){lat=2.0*Math.atan(num*Proj4js.common.srat(this.e*Math.sin(p.y),-0.5*this.e))-Proj4js.common.HALF_PI;if(Math.abs(lat-p.y)<DEL_TOL)break;p.y=lat;}
+if(!i){Proj4js.reportError("gauss:inverse:convergence failed");return null;}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.omerc={init:function(){if(!this.mode)this.mode=0;if(!this.lon1){this.lon1=0;this.mode=1;}
+if(!this.lon2)this.lon2=0;if(!this.lat2)this.lat2=0;var temp=this.b/this.a;var es=1.0-Math.pow(temp,2);var e=Math.sqrt(es);this.sin_p20=Math.sin(this.lat0);this.cos_p20=Math.cos(this.lat0);this.con=1.0-this.es*this.sin_p20*this.sin_p20;this.com=Math.sqrt(1.0-es);this.bl=Math.sqrt(1.0+this.es*Math.pow(this.cos_p20,4.0)/(1.0-es));this.al=this.a*this.bl*this.k0*this.com/this.con;if(Math.abs(this.lat0)<Proj4js.common.EPSLN){this.ts=1.0;this.d=1.0;this.el=1.0;}else{this.ts=Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);this.con=Math.sqrt(this.con);this.d=this.bl*this.com/(this.cos_p20*this.con);if((this.d*this.d-1.0)>0.0){if(this.lat0>=0.0){this.f=this.d+Math.sqrt(this.d*this.d-1.0);}else{this.f=this.d-Math.sqrt(this.d*this.d-1.0);}}else{this.f=this.d;}
+this.el=this.f*Math.pow(this.ts,this.bl);}
+if(this.mode!=0){this.g=.5*(this.f-1.0/this.f);this.gama=Proj4js.common.asinz(Math.sin(this.alpha)/this.d);this.longc=this.longc-Proj4js.common.asinz(this.g*Math.tan(this.gama))/this.bl;this.con=Math.abs(this.lat0);if((this.con>Proj4js.common.EPSLN)&&(Math.abs(this.con-Proj4js.common.HALF_PI)>Proj4js.common.EPSLN)){this.singam=Math.sin(this.gama);this.cosgam=Math.cos(this.gama);this.sinaz=Math.sin(this.alpha);this.cosaz=Math.cos(this.alpha);if(this.lat0>=0){this.u=(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}else{this.u=-(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}}else{Proj4js.reportError("omerc:Init:DataError");}}else{this.sinphi=Math.sin(this.at1);this.ts1=Proj4js.common.tsfnz(this.e,this.lat1,this.sinphi);this.sinphi=Math.sin(this.lat2);this.ts2=Proj4js.common.tsfnz(this.e,this.lat2,this.sinphi);this.h=Math.pow(this.ts1,this.bl);this.l=Math.pow(this.ts2,this.bl);this.f=this.el/this.h;this.g=.5*(this.f-1.0/this.f);this.j=(this.el*this.el-this.l*this.h)/(this.el*this.el+this.l*this.h);this.p=(this.l-this.h)/(this.l+this.h);this.dlon=this.lon1-this.lon2;if(this.dlon<-Proj4js.common.PI)this.lon2=this.lon2-2.0*Proj4js.common.PI;if(this.dlon>Proj4js.common.PI)this.lon2=this.lon2+2.0*Proj4js.common.PI;this.dlon=this.lon1-this.lon2;this.longc=.5*(this.lon1+this.lon2)-Math.atan(this.j*Math.tan(.5*this.bl*this.dlon)/this.p)/this.bl;this.dlon=Proj4js.common.adjust_lon(this.lon1-this.longc);this.gama=Math.atan(Math.sin(this.bl*this.dlon)/this.g);this.alpha=Proj4js.common.asinz(this.d*Math.sin(this.gama));if(Math.abs(this.lat1-this.lat2)<=Proj4js.common.EPSLN){Proj4js.reportError("omercInitDataError");}else{this.con=Math.abs(this.lat1);}
+if((this.con<=Proj4js.common.EPSLN)||(Math.abs(this.con-HALF_PI)<=Proj4js.common.EPSLN)){Proj4js.reportError("omercInitDataError");}else{if(Math.abs(Math.abs(this.lat0)-Proj4js.common.HALF_PI)<=Proj4js.common.EPSLN){Proj4js.reportError("omercInitDataError");}}
+this.singam=Math.sin(this.gam);this.cosgam=Math.cos(this.gam);this.sinaz=Math.sin(this.alpha);this.cosaz=Math.cos(this.alpha);if(this.lat0>=0){this.u=(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}else{this.u=-(this.al/this.bl)*Math.atan(Math.sqrt(this.d*this.d-1.0)/this.cosaz);}}},forward:function(p){var theta;var sin_phi,cos_phi;var b;var c,t,tq;var con,n,ml;var q,us,vl;var ul,vs;var s;var dlon;var ts1;var lon=p.x;var lat=p.y;sin_phi=Math.sin(lat);dlon=Proj4js.common.adjust_lon(lon-this.longc);vl=Math.sin(this.bl*dlon);if(Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI)>Proj4js.common.EPSLN){ts1=Proj4js.common.tsfnz(this.e,lat,sin_phi);q=this.el/(Math.pow(ts1,this.bl));s=.5*(q-1.0/q);t=.5*(q+1.0/q);ul=(s*this.singam-vl*this.cosgam)/t;con=Math.cos(this.bl*dlon);if(Math.abs(con)<.0000001){us=this.al*this.bl*dlon;}else{us=this.al*Math.atan((s*this.cosgam+vl*this.singam)/con)/this.bl;if(con<0)us=us+Proj4js.common.PI*this.al/this.bl;}}else{if(lat>=0){ul=this.singam;}else{ul=-this.singam;}
+us=this.al*lat/this.bl;}
+if(Math.abs(Math.abs(ul)-1.0)<=Proj4js.common.EPSLN){Proj4js.reportError("omercFwdInfinity");}
+vs=.5*this.al*Math.log((1.0-ul)/(1.0+ul))/this.bl;us=us-this.u;var x=this.x0+vs*this.cosaz+us*this.sinaz;var y=this.y0+us*this.cosaz-vs*this.sinaz;p.x=x;p.y=y;return p;},inverse:function(p){var delta_lon;var theta;var delta_theta;var sin_phi,cos_phi;var b;var c,t,tq;var con,n,ml;var vs,us,q,s,ts1;var vl,ul,bs;var dlon;var flag;p.x-=this.x0;p.y-=this.y0;flag=0;vs=p.x*this.cosaz-p.y*this.sinaz;us=p.y*this.cosaz+p.x*this.sinaz;us=us+this.u;q=Math.exp(-this.bl*vs/this.al);s=.5*(q-1.0/q);t=.5*(q+1.0/q);vl=Math.sin(this.bl*us/this.al);ul=(vl*this.cosgam+s*this.singam)/t;if(Math.abs(Math.abs(ul)-1.0)<=Proj4js.common.EPSLN)
+{lon=this.longc;if(ul>=0.0){lat=Proj4js.common.HALF_PI;}else{lat=-Proj4js.common.HALF_PI;}}else{con=1.0/this.bl;ts1=Math.pow((this.el/Math.sqrt((1.0+ul)/(1.0-ul))),con);lat=Proj4js.common.phi2z(this.e,ts1);theta=this.longc-Math.atan2((s*this.cosgam-vl*this.singam),con)/this.bl;lon=Proj4js.common.adjust_lon(theta);}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.lcc={init:function(){if(!this.lat2){this.lat2=this.lat0;}
+if(!this.k0)this.k0=1.0;if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("lcc:init: Equal Latitudes");return;}
+var temp=this.b/this.a;this.e=Math.sqrt(1.0-temp*temp);var sin1=Math.sin(this.lat1);var cos1=Math.cos(this.lat1);var ms1=Proj4js.common.msfnz(this.e,sin1,cos1);var ts1=Proj4js.common.tsfnz(this.e,this.lat1,sin1);var sin2=Math.sin(this.lat2);var cos2=Math.cos(this.lat2);var ms2=Proj4js.common.msfnz(this.e,sin2,cos2);var ts2=Proj4js.common.tsfnz(this.e,this.lat2,sin2);var ts0=Proj4js.common.tsfnz(this.e,this.lat0,Math.sin(this.lat0));if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns=Math.log(ms1/ms2)/Math.log(ts1/ts2);}else{this.ns=sin1;}
+this.f0=ms1/(this.ns*Math.pow(ts1,this.ns));this.rh=this.a*this.f0*Math.pow(ts0,this.ns);if(!this.title)this.title="Lambert Conformal Conic";},forward:function(p){var lon=p.x;var lat=p.y;if(lat<=90.0&&lat>=-90.0&&lon<=180.0&&lon>=-180.0){}else{Proj4js.reportError("lcc:forward: llInputOutOfRange: "+lon+" : "+lat);return null;}
+var con=Math.abs(Math.abs(lat)-Proj4js.common.HALF_PI);var ts;if(con>Proj4js.common.EPSLN){ts=Proj4js.common.tsfnz(this.e,lat,Math.sin(lat));rh1=this.a*this.f0*Math.pow(ts,this.ns);}else{con=lat*this.ns;if(con<=0){Proj4js.reportError("lcc:forward: No Projection");return null;}
+rh1=0;}
+var theta=this.ns*Proj4js.common.adjust_lon(lon-this.long0);p.x=this.k0*(rh1*Math.sin(theta))+this.x0;p.y=this.k0*(this.rh-rh1*Math.cos(theta))+this.y0;return p;},inverse:function(p){var rh1,con,ts;var lat,lon;x=(p.x-this.x0)/this.k0;y=(this.rh-(p.y-this.y0)/this.k0);if(this.ns>0){rh1=Math.sqrt(x*x+y*y);con=1.0;}else{rh1=-Math.sqrt(x*x+y*y);con=-1.0;}
+var theta=0.0;if(rh1!=0){theta=Math.atan2((con*x),(con*y));}
+if((rh1!=0)||(this.ns>0.0)){con=1.0/this.ns;ts=Math.pow((rh1/(this.a*this.f0)),con);lat=Proj4js.common.phi2z(this.e,ts);if(lat==-9999)return null;}else{lat=-Proj4js.common.HALF_PI;}
+lon=Proj4js.common.adjust_lon(theta/this.ns+this.long0);p.x=lon;p.y=lat;return p;}};Proj4js.Proj.laea={init:function(){this.sin_lat_o=Math.sin(this.lat0);this.cos_lat_o=Math.cos(this.lat0);},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var sin_lat=Math.sin(lat);var cos_lat=Math.cos(lat);var sin_delta_lon=Math.sin(delta_lon);var cos_delta_lon=Math.cos(delta_lon);var g=this.sin_lat_o*sin_lat+this.cos_lat_o*cos_lat*cos_delta_lon;if(g==-1.0){Proj4js.reportError("laea:fwd:Point projects to a circle of radius "+2.0*R);return null;}
+var ksp=this.a*Math.sqrt(2.0/(1.0+g));var x=ksp*cos_lat*sin_delta_lon+this.x0;var y=ksp*(this.cos_lat_o*sin_lat-this.sin_lat_o*cos_lat*cos_delta_lon)+this.y0;p.x=x;p.y=y
+return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var Rh=Math.sqrt(p.x*p.x+p.y*p.y);var temp=Rh/(2.0*this.a);if(temp>1){Proj4js.reportError("laea:Inv:DataError");return null;}
+var z=2.0*Proj4js.common.asinz(temp);var sin_z=Math.sin(z);var cos_z=Math.cos(z);var lon=this.long0;if(Math.abs(Rh)>Proj4js.common.EPSLN){var lat=Proj4js.common.asinz(this.sin_lat_o*cos_z+this.cos_lat_o*sin_z*p.y/Rh);var temp=Math.abs(this.lat0)-Proj4js.common.HALF_PI;if(Math.abs(temp)>Proj4js.common.EPSLN){temp=cos_z-this.sin_lat_o*Math.sin(lat);if(temp!=0.0)lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x*sin_z*this.cos_lat_o,temp*Rh));}else if(this.lat0<0.0){lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}else{lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}}else{lat=this.lat0;}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.aeqd={init:function(){this.sin_p12=Math.sin(this.lat0)
+this.cos_p12=Math.cos(this.lat0)},forward:function(p){var lon=p.x;var lat=p.y;var ksp;var sinphi=Math.sin(p.y);var cosphi=Math.cos(p.y);var dlon=Proj4js.common.adjust_lon(lon-this.long0);var coslon=Math.cos(dlon);var g=this.sin_p12*sinphi+this.cos_p12*cosphi*coslon;if(Math.abs(Math.abs(g)-1.0)<Proj4js.common.EPSLN){ksp=1.0;if(g<0.0){Proj4js.reportError("aeqd:Fwd:PointError");return;}}else{var z=Math.acos(g);ksp=z/Math.sin(z);}
+p.x=this.x0+this.a*ksp*cosphi*Math.sin(dlon);p.y=this.y0+this.a*ksp*(this.cos_p12*sinphi-this.sin_p12*cosphi*coslon);return p;},inverse:function(p){p.x-=this.x0;p.y-=this.y0;var rh=Math.sqrt(p.x*p.x+p.y*p.y);if(rh>(2.0*Proj4js.common.HALF_PI*this.a)){Proj4js.reportError("aeqdInvDataError");return;}
+var z=rh/this.a;var sinz=Math.sin(z)
+var cosz=Math.cos(z)
+var lon=this.long0;var lat;if(Math.abs(rh)<=Proj4js.common.EPSLN){lat=this.lat0;}else{lat=Proj4js.common.asinz(cosz*this.sin_p12+(p.y*sinz*this.cos_p12)/rh);var con=Math.abs(this.lat0)-Proj4js.common.HALF_PI;if(Math.abs(con)<=Proj4js.common.EPSLN){if(lat0>=0.0){lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x,-p.y));}else{lon=Proj4js.common.adjust_lon(this.long0-Math.atan2(-p.x,p.y));}}else{con=cosz-this.sin_p12*Math.sin(lat);if((Math.abs(con)<Proj4js.common.EPSLN)&&(Math.abs(p.x)<Proj4js.common.EPSLN)){}else{var temp=Math.atan2((p.x*sinz*this.cos_p12),(con*rh));lon=Proj4js.common.adjust_lon(this.long0+Math.atan2((p.x*sinz*this.cos_p12),(con*rh)));}}}
+p.x=lon;p.y=lat;return p;}};Proj4js.Proj.moll={init:function(){},forward:function(p){var lon=p.x;var lat=p.y;var delta_lon=Proj4js.common.adjust_lon(lon-this.long0);var theta=lat;var con=Proj4js.common.PI*Math.sin(lat);for(var i=0;;i++){var delta_theta=-(theta+Math.sin(theta)-con)/(1.0+Math.cos(theta));theta+=delta_theta;if(Math.abs(delta_theta)<Proj4js.common.EPSLN)break;if(i>=50){Proj4js.reportError("moll:Fwd:IterationError");}}
+theta/=2.0;if(Proj4js.common.PI/2-Math.abs(lat)<Proj4js.common.EPSLN)delta_lon=0;var x=0.900316316158*this.a*delta_lon*Math.cos(theta)+this.x0;var y=1.4142135623731*this.a*Math.sin(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var theta;var arg;p.x-=this.x0;var arg=p.y/(1.4142135623731*this.a);if(Math.abs(arg)>0.999999999999)arg=0.999999999999;var theta=Math.asin(arg);var lon=Proj4js.common.adjust_lon(this.long0+(p.x/(0.900316316158*this.a*Math.cos(theta))));if(lon<(-Proj4js.common.PI))lon=-Proj4js.common.PI;if(lon>Proj4js.common.PI)lon=Proj4js.common.PI;arg=(2.0*theta+Math.sin(2.0*theta))/Proj4js.common.PI;if(Math.abs(arg)>1.0)arg=1.0;var lat=Math.asin(arg);p.x=lon;p.y=lat;return p;}};
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/lib/proj4js.js
--- trunk/mapbender/http/extensions/proj4js/lib/proj4js.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/proj4js.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,1479 @@
+Author:       Mike Adair madairATdmsolutions.ca
+              Richard Greenwood rich at greenwoodmap.com
+License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+$Id: Proj.js 2956 2007-07-09 12:17:52Z steven $
+ * Namespace: Proj4js
+ * Proj4js is a JavaScript library to transform point coordinates from one
+ * coordinate system to another, including datum transformations.
+ * This library is a port of both the Proj.4 and GCTCP C libraries to JavaScript.
+ * Enabling these transformations in the browser allows geographic data stored
+ * in different projections to be combined in browser-based web mapping
+ * applications.
+ * Proj4js must have access to coordinate system initialization strings (which
+ * are the same as for PROJ.4 command line).  Thes can be included in your
+ * application using a <script> tag or Proj4js can load CS initialization
+ * strings from a local directory or a web service such as spatialreference.org.
+ * Similarly, Proj4js must have access to projection transform code.  These can
+ * be included individually using a <script> tag in your page, built into a
+ * custom build of Proj4js or loaded dynamically at run-time.  Using the
+ * -combined and -compressed versions of Proj4js includes all projection class
+ * code by default.
+ * Note that dynamic loading of defs and code happens ascynchrously, check the
+ * Proj.readyToUse flag before using the Proj object.  If the defs and code
+ * required by your application are loaded through script tags, dynamic loading
+ * is not required and the Proj object will be readyToUse on return from the
+ * constructor.
+ * All coordinates are handled as points which have a .x and a .y property
+ * which will be modified in place.
+ * Override Proj4js.reportError for output of alerts and warnings.
+ * See http://trac.osgeo.org/proj4js/wiki/UserGuide for full details.
+ * Global namespace object for Proj4js library
+Proj4js = {
+     * Property: defaultDatum
+     * The datum to use when no others a specified
+    defaultDatum: 'WGS84',                  //default datum
+    * Method: transform(source, dest, point)
+    * Transform a point coordinate from one map projection to another.  This is
+    * really the only public method you should need to use.
+    * Parameters:
+    * source - {Proj4js.Proj} source map projection for the transformation
+    * dest - {Proj4js.Proj} destination map projection for the transformation
+    * point - {Object} point to transform, may be geodetic (long, lat) or
+    *     projected Cartesian (x,y), but should always have x,y properties.
+    transform: function(source, dest, point) {
+        if (!source.readyToUse || !dest.readyToUse) {
+            this.reportError("Proj4js initialization for "+source.srsCode+" not yet complete");
+            return point;
+        // Workaround for Spherical Mercator
+        if ((source.srsProjNumber =="900913" && dest.datumCode != "WGS84") ||
+            (dest.srsProjNumber == "900913" && source.datumCode != "WGS84")) {
+            var wgs84 = Proj4js.WGS84;
+            this.transform(source, wgs84, point);
+            source = wgs84;
+        // Transform source points to long/lat, if they aren't already.
+        if ( source.projName=="longlat") {
+            point.x *= Proj4js.common.D2R;  // convert degrees to radians
+            point.y *= Proj4js.common.D2R;
+        } else {
+            if (source.to_meter) {
+                point.x *= source.to_meter;
+                point.y *= source.to_meter;
+            source.inverse(point); // Convert Cartesian to longlat
+        // Adjust for the prime meridian if necessary
+        if (source.from_greenwich) {
+            point.x += source.from_greenwich;
+        // Convert datums if needed, and if possible.
+        point = this.datum_transform( source.datum, dest.datum, point );
+        if (dest.from_greenwich) {
+            point.x -= dest.from_greenwich;
+        if( dest.projName=="longlat" ) {
+            // convert radians to decimal degrees
+            point.x *= Proj4js.common.R2D;
+            point.y *= Proj4js.common.R2D;
+        } else  {               // else project
+            dest.forward(point);
+            if (dest.to_meter) {
+                point.x /= dest.to_meter;
+                point.y /= dest.to_meter;
+        return point;
+    }, // transform()
+    /** datum_transform()
+      source coordinate system definition,
+      destination coordinate system definition,
+      point to transform in geodetic coordinates (long, lat, height)
+    datum_transform : function( source, dest, point ) {
+      // Short cut if the datums are identical.
+      if( source.compare_datums( dest ) ) {
+          return point; // in this case, zero is sucess,
+                    // whereas cs_compare_datums returns 1 to indicate TRUE
+                    // confusing, should fix this
+      // Explicitly skip datum transform by setting 'datum=none' as parameter for either source or dest
+      if( source.datum_type == Proj4js.common.PJD_NODATUM
+          || dest.datum_type == Proj4js.common.PJD_NODATUM) {
+          return point;
+      // If this datum requires grid shifts, then apply it to geodetic coordinates.
+      if( source.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+        alert("ERROR: Grid shift transformations are not implemented yet.");
+          pj_apply_gridshift( pj_param(source.params,"snadgrids").s, 0,
+                              point_count, point_offset, x, y, z );
+          CHECK_RETURN;
+          src_a = SRS_WGS84_SEMIMAJOR;
+          src_es = 0.006694379990;
+      if( dest.datum_type == Proj4js.common.PJD_GRIDSHIFT )
+          dst_a = ;
+          dst_es = 0.006694379990;
+      // Do we need to go through geocentric coordinates?
+      if( source.es != dest.es || source.a != dest.a
+          || source.datum_type == Proj4js.common.PJD_3PARAM
+          || source.datum_type == Proj4js.common.PJD_7PARAM
+          || dest.datum_type == Proj4js.common.PJD_3PARAM
+          || dest.datum_type == Proj4js.common.PJD_7PARAM)
+        // Convert to geocentric coordinates.
+        source.geodetic_to_geocentric( point );
+        // CHECK_RETURN;
+        // Convert between datums
+        if( source.datum_type == Proj4js.common.PJD_3PARAM || source.datum_type == Proj4js.common.PJD_7PARAM ) {
+          source.geocentric_to_wgs84(point);
+          // CHECK_RETURN;
+        if( dest.datum_type == Proj4js.common.PJD_3PARAM || dest.datum_type == Proj4js.common.PJD_7PARAM ) {
+          dest.geocentric_from_wgs84(point);
+          // CHECK_RETURN;
+        // Convert back to geodetic coordinates
+        dest.geocentric_to_geodetic( point );
+          // CHECK_RETURN;
+      // Apply grid shift to destination if required
+        // pj_apply_gridshift( pj_param(dest.params,"snadgrids").s, 1, point);
+        // CHECK_RETURN;
+      return point;
+    }, // cs_datum_transform
+     * Function: reportError
+     * An internal method to report errors back to user.
+     * Override this in applications to report error messages or throw exceptions.
+    reportError: function(msg) {
+      //console.log(msg);
+ * Title: Private Methods
+ * The following properties and methods are intended for internal use only.
+ * This is a minimal implementation of JavaScript inheritance methods so that
+ * Proj4js can be used as a stand-alone library.
+ * These are copies of the equivalent OpenLayers methods at v2.7
+ * Function: extend
+ * Copy all properties of a source object to a destination object.  Modifies
+ *     the passed in destination object.  Any properties on the source object
+ *     that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+    extend: function(destination, source) {
+      destination = destination || {};
+      if(source) {
+          for(var property in source) {
+              var value = source[property];
+              if(value !== undefined) {
+                  destination[property] = value;
+      return destination;
+ * Constructor: Class
+ * Base class used to construct all other classes. Includes support for
+ *     multiple inheritance.
+    Class: function() {
+      var Class = function() {
+          this.initialize.apply(this, arguments);
+      var extended = {};
+      var parent;
+      for(var i=0; i<arguments.length; ++i) {
+          if(typeof arguments[i] == "function") {
+              // get the prototype of the superclass
+              parent = arguments[i].prototype;
+          } else {
+              // in this case we're extending with the prototype
+              parent = arguments[i];
+          Proj4js.extend(extended, parent);
+      Class.prototype = extended;
+      return Class;
+     * Function: bind
+     * Bind a function to an object.  Method to easily create closures with
+     *     'this' altered.
+     * Parameters:
+     * func - {Function} Input function.
+     * object - {Object} The object to bind to the input function (as this).
+     * Returns:
+     * {Function} A closure with 'this' set to the passed in object.
+    bind: function(func, object) {
+        // create a reference to all arguments past the second one
+        var args = Array.prototype.slice.apply(arguments, [2]);
+        return function() {
+            // Push on any additional arguments from the actual function call.
+            // These will come after those sent to the bind call.
+            var newArgs = args.concat(
+                Array.prototype.slice.apply(arguments, [0])
+            return func.apply(object, newArgs);
+ * The following properties and methods handle dynamic loading of JSON objects.
+     * Property: scriptName
+     * {String} The filename of this script without any path.
+    scriptName: "proj4js.js",
+     * Property: defsLookupService
+     * AJAX service to retreive projection definition parameters from
+    defsLookupService: 'http://spatialreference.org/ref',
+     * Property: libPath
+     * internal: http server path to library code.
+    libPath: null,
+     * Function: getScriptLocation
+     * Return the path to this script.
+     * Returns:
+     * Path to this script
+    getScriptLocation: function () {
+        if (this.libPath) return this.libPath;
+        var scriptName = this.scriptName;
+        var scriptNameLen = scriptName.length;
+        var scripts = document.getElementsByTagName('script');
+        for (var i = 0; i < scripts.length; i++) {
+            var src = scripts[i].getAttribute('src');
+            if (src) {
+                var index = src.lastIndexOf(scriptName);
+                // is it found, at the end of the URL?
+                if ((index > -1) && (index + scriptNameLen == src.length)) {
+                    this.libPath = src.slice(0, -scriptNameLen);
+                    break;
+        return this.libPath||"";
+     * Function: loadScript
+     * Load a JS file from a URL into a <script> tag in the page.
+     * Parameters:
+     * url - {String} The URL containing the script to load
+     * onload - {Function} A method to be executed when the script loads successfully
+     * onfail - {Function} A method to be executed when there is an error loading the script
+     * loadCheck - {Function} A boolean method that checks to see if the script
+     *            has loaded.  Typically this just checks for the existance of
+     *            an object in the file just loaded.
+    loadScript: function(url, onload, onfail, loadCheck) {
+      var script = document.createElement('script');
+      script.defer = false;
+      script.type = "text/javascript";
+      script.id = url;
+      script.src = url;
+      script.onload = onload;
+      script.onerror = onfail;
+      script.loadCheck = loadCheck;
+      if (/MSIE/.test(navigator.userAgent)) {
+        script.onreadystatechange = this.checkReadyState;
+      document.getElementsByTagName('head')[0].appendChild(script);
+     * Function: checkReadyState
+     * IE workaround since there is no onerror handler.  Calls the user defined
+     * loadCheck method to determine if the script is loaded.
+    checkReadyState: function() {
+      if (this.readyState == 'loaded') {
+        if (!this.loadCheck()) {
+          this.onerror();
+        } else {
+          this.onload();
+ * Class: Proj4js.Proj
+ * Proj objects provide transformation methods for point coordinates
+ * between geodetic latitude/longitude and a projected coordinate system.
+ * once they have been initialized with a projection code.
+ * Initialization of Proj objects is with a projection code, usually EPSG codes,
+ * which is the key that will be used with the Proj4js.defs array.
+ * The code passed in will be stripped of colons and converted to uppercase
+ * to locate projection definition files.
+ * A projection object has properties for units and title strings.
+Proj4js.Proj = Proj4js.Class({
+   * Property: readyToUse
+   * Flag to indicate if initialization is complete for this Proj object
+  readyToUse: false,
+   * Property: title
+   * The title to describe the projection
+  title: null,
+   * Property: projName
+   * The projection class for this projection, e.g. lcc (lambert conformal conic,
+   * or merc for mercator.  These are exactly equicvalent to their Proj4
+   * counterparts.
+  projName: null,
+   * Property: units
+   * The units of the projection.  Values include 'm' and 'degrees'
+  units: null,
+   * Property: datum
+   * The datum specified for the projection
+  datum: null,
+   * Constructor: initialize
+   * Constructor for Proj4js.Proj objects
+  * Parameters:
+  * srsCode - a code for map projection definition parameters.  These are usually
+  * (but not always) EPSG codes.
+  initialize: function(srsCode) {
+      this.srsCode = srsCode.toUpperCase();
+      if (this.srsCode.indexOf("EPSG") == 0) {
+          this.srsCode = this.srsCode;
+          this.srsAuth = 'epsg';
+          this.srsProjNumber = this.srsCode.substring(5);
+      // DGR 2007-11-20 : authority IGNF
+      } else if (this.srsCode.indexOf("IGNF") == 0) {
+          this.srsAuth = 'IGNF';
+      // DGR 2008-06-19 : pseudo-authority CRS for WMS
+      } else if (this.srsCode.indexOf("CRS") == 0) {
+          this.srsAuth = 'CRS';
+          this.srsProjNumber = this.srsCode.substring(4);
+      } else {
+          this.srsAuth = '';
+          this.srsProjNumber = this.srsCode;
+      this.loadProjDefinition();
+ * Function: loadProjDefinition
+ *    Loads the coordinate system initialization string if required.
+ *    Note that dynamic loading happens asynchronously so an application must
+ *    wait for the readyToUse property is set to true.
+ *    To prevent dynamic loading, include the defs through a script tag in
+ *    your application.
+    loadProjDefinition: function() {
+      //check in memory
+      if (Proj4js.defs[this.srsCode]) {
+        this.defsLoaded();
+        return;
+      //else check for def on the server
+      var url = Proj4js.getScriptLocation() + 'defs/' + this.srsAuth.toUpperCase() + this.srsProjNumber + '.js';
+      Proj4js.loadScript(url,
+                Proj4js.bind(this.defsLoaded, this),
+                Proj4js.bind(this.loadFromService, this),
+                Proj4js.bind(this.checkDefsLoaded, this) );
+ * Function: loadFromService
+ *    Creates the REST URL for loading the definition from a web service and
+ *    loads it.
+    loadFromService: function() {
+      //else load from web service
+      var url = Proj4js.defsLookupService +'/' + this.srsAuth +'/'+ this.srsProjNumber + '/proj4js';
+            Proj4js.bind(this.defsFailed, this),
+ * Function: defsLoaded
+ * Continues the Proj object initilization once the def file is loaded
+    defsLoaded: function() {
+      this.parseDefs();
+      this.loadProjCode(this.projName);
+ * Function: checkDefsLoaded
+ *    This is the loadCheck method to see if the def object exists
+    checkDefsLoaded: function() {
+        return true;
+      } else {
+        return false;
+ * Function: defsFailed
+ *    Report an error in loading the defs file, but continue on using WGS84
+   defsFailed: function() {
+      Proj4js.reportError('failed to load projection definition for: '+this.srsCode);
+      Proj4js.extend(Proj4js.defs[this.srsCode], Proj4js.defs['WGS84']);  //set it to something so it can at least continue
+ * Function: loadProjCode
+ *    Loads projection class code dynamically if required.
+ *     Projection code may be included either through a script tag or in
+ *     a built version of proj4js
+    loadProjCode: function(projName) {
+      if (Proj4js.Proj[projName]) {
+        this.initTransforms();
+        return;
+      //the URL for the projection code
+      var url = Proj4js.getScriptLocation() + 'projCode/' + projName + '.js';
+              Proj4js.bind(this.loadProjCodeSuccess, this, projName),
+              Proj4js.bind(this.loadProjCodeFailure, this, projName),
+              Proj4js.bind(this.checkCodeLoaded, this, projName) );
+ * Function: loadProjCodeSuccess
+ *    Loads any proj dependencies or continue on to final initialization.
+    loadProjCodeSuccess: function(projName) {
+      if (Proj4js.Proj[projName].dependsOn){
+        this.loadProjCode(Proj4js.Proj[projName].dependsOn);
+      } else {
+ *    Report an error in loading the proj file.  Initialization of the Proj
+ *    object has failed and the readyToUse flag will never be set.
+    loadProjCodeFailure: function(projName) {
+      Proj4js.reportError("failed to find projection file for: " + projName);
+      //TBD initialize with identity transforms so proj will still work?
+ * Function: checkCodeLoaded
+ *    This is the loadCheck method to see if the projection code is loaded
+    checkCodeLoaded: function(projName) {
+        return true;
+      } else {
+        return false;
+ * Function: initTransforms
+ *    Finalize the initialization of the Proj object
+    initTransforms: function() {
+      Proj4js.extend(this, Proj4js.Proj[this.projName]);
+      this.init();
+      this.readyToUse = true;
+ * Function: parseDefs
+ * Parses the PROJ.4 initialization string and sets the associated properties.
+  parseDefs: function() {
+      this.defData = Proj4js.defs[this.srsCode];
+      var paramName, paramVal;
+      var paramArray=this.defData.split("+");
+      for (var prop=0; prop<paramArray.length; prop++) {
+          var property = paramArray[prop].split("=");
+          paramName = property[0].toLowerCase();
+          paramVal = property[1];
+          switch (paramName.replace(/\s/gi,"")) {  // trim out spaces
+              case "": break;   // throw away nameless parameter
+              case "title":  this.title = paramVal; break;
+              case "proj":   this.projName =  paramVal.replace(/\s/gi,""); break;
+              case "units":  this.units = paramVal.replace(/\s/gi,""); break;
+              case "datum":  this.datumCode = paramVal.replace(/\s/gi,""); break;
+              case "nadgrids": this.nagrids = paramVal.replace(/\s/gi,""); break;
+              case "ellps":  this.ellps = paramVal.replace(/\s/gi,""); break;
+              case "a":      this.a =  parseFloat(paramVal); break;  // semi-major radius
+              case "b":      this.b =  parseFloat(paramVal); break;  // semi-minor radius
+              // DGR 2007-11-20
+              case "rf":     this.rf = parseFloat(paramVal); break; // inverse flattening rf= a/(a-b)
+              case "lat_0":  this.lat0 = paramVal*Proj4js.common.D2R; break;        // phi0, central latitude
+              case "lat_1":  this.lat1 = paramVal*Proj4js.common.D2R; break;        //standard parallel 1
+              case "lat_2":  this.lat2 = paramVal*Proj4js.common.D2R; break;        //standard parallel 2
+              case "lat_ts": this.lat_ts = paramVal*Proj4js.common.D2R; break;      // used in merc and eqc
+              case "lon_0":  this.long0 = paramVal*Proj4js.common.D2R; break;       // lam0, central longitude
+              case "alpha":  this.alpha =  parseFloat(paramVal)*Proj4js.common.D2R; break;  //for somerc projection
+              case "lonc":   this.longc = paramVal*Proj4js.common.D2R; break;       //for somerc projection
+              case "x_0":    this.x0 = parseFloat(paramVal); break;  // false easting
+              case "y_0":    this.y0 = parseFloat(paramVal); break;  // false northing
+              case "k_0":    this.k0 = parseFloat(paramVal); break;  // projection scale factor
+              case "k":      this.k0 = parseFloat(paramVal); break;  // both forms returned
+              case "R_A":    this.R = true; break;   //Spheroid radius
+              case "zone":   this.zone = parseInt(paramVal); break;  // UTM Zone
+              case "south":   this.utmSouth = true; break;  // UTM north/south
+              case "towgs84":this.datum_params = paramVal.split(","); break;
+              case "to_meter": this.to_meter = parseFloat(paramVal); break; // cartesian scaling
+              case "from_greenwich": this.from_greenwich = paramVal*Proj4js.common.D2R; break;
+              // DGR 2008-07-09 : if pm is not a well-known prime meridian take
+              // the value instead of 0.0, then convert to radians
+              case "pm":     paramVal = paramVal.replace(/\s/gi,"");
+                             this.from_greenwich = Proj4js.PrimeMeridian[paramVal] ?
+                                Proj4js.PrimeMeridian[paramVal] : parseFloat(paramVal);
+                             this.from_greenwich *= Proj4js.common.D2R;
+                             break;
+              case "no_defs": break;
+              default: //alert("Unrecognized parameter: " + paramName);
+          } // switch()
+      } // for paramArray
+      this.deriveConstants();
+ * Function: deriveConstants
+ * Sets several derived constant values and initialization of datum and ellipse
+ *     parameters.
+  deriveConstants: function() {
+      if (this.nagrids == '@null') this.datumCode = 'none';
+      if (this.datumCode && this.datumCode != 'none') {
+        var datumDef = Proj4js.Datum[this.datumCode];
+        if (datumDef) {
+          this.datum_params = datumDef.towgs84.split(',');
+          this.ellps = datumDef.ellipse;
+          this.datumName = datumDef.datumName ? datumDef.datumName : this.datumCode;
+      if (!this.a) {    // do we have an ellipsoid?
+          var ellipse = Proj4js.Ellipsoid[this.ellps] ? Proj4js.Ellipsoid[this.ellps] : Proj4js.Ellipsoid['WGS84'];
+          Proj4js.extend(this, ellipse);
+      if (this.rf && !this.b) this.b = (1.0 - 1.0/this.rf) * this.a;
+      if (Math.abs(this.a - this.b)<Proj4js.common.EPSLN) {
+        this.sphere = true;
+        this.b= this.a;
+      this.a2 = this.a * this.a;          // used in geocentric
+      this.b2 = this.b * this.b;          // used in geocentric
+      this.es = (this.a2-this.b2)/this.a2;  // e ^ 2
+      this.e = Math.sqrt(this.es);        // eccentricity
+      if (this.R_A) {
+        this.a *= 1. - this.es * (Proj4js.common.SIXTH + this.es * (Proj4js.RA4 + this.es * Proj4js.RA6));
+        this.es = 0.;
+      this.ep2=(this.a2-this.b2)/this.b2; // used in geocentric
+      if (!this.k0) this.k0 = 1.0;    //default value
+      this.datum = new Proj4js.datum(this);
+Proj4js.Proj.longlat = {
+  init: function() {
+    //no-op for longlat
+  forward: function(pt) {
+    //identity transform
+    return pt;
+  inverse: function(pt) {
+    return pt;
+  Proj4js.defs is a collection of coordinate system definition objects in the
+  PROJ.4 command line format.
+  Generally a def is added by means of a separate .js file for example:
+    <SCRIPT type="text/javascript" src="defs/EPSG26912.js"></SCRIPT>
+  def is a CS definition in PROJ.4 WKT format, for example:
+    +proj="tmerc"   //longlat, etc.
+    +a=majorRadius
+    +b=minorRadius
+    +lat0=somenumber
+    +long=somenumber
+Proj4js.defs = {
+  // These are so widely used, we'll go ahead and throw them in
+  // without requiring a separate .js file
+  'WGS84': "+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4326': "+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",
+  'EPSG:4269': "+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees"
+//+a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84",
+Proj4js.common = {
+  PI : 3.141592653589793238, //Math.PI,
+  HALF_PI : 1.570796326794896619, //Math.PI*0.5,
+  TWO_PI : 6.283185307179586477, //Math.PI*2,
+  FORTPI : 0.78539816339744833,
+  R2D : 57.29577951308232088,
+  D2R : 0.01745329251994329577,
+  SEC_TO_RAD : 4.84813681109535993589914102357e-6, /* SEC_TO_RAD = Pi/180/3600 */
+  EPSLN : 1.0e-10,
+  MAX_ITER : 20,
+  // following constants from geocent.c
+  COS_67P5 : 0.38268343236508977,  /* cosine of 67.5 degrees */
+  AD_C : 1.0026000,                /* Toms region 1 constant */
+  /* datum_type values */
+  PJD_UNKNOWN  : 0,
+  PJD_3PARAM   : 1,
+  PJD_7PARAM   : 2,
+  PJD_GRIDSHIFT: 3,
+  PJD_WGS84    : 4,   // WGS84 or equivalent
+  PJD_NODATUM  : 5,   // WGS84 or equivalent
+  SRS_WGS84_SEMIMAJOR : 6378137.0,  // only used in grid shift transforms
+  // ellipoid pj_set_ell.c
+  SIXTH : .1666666666666666667, /* 1/6 */
+  RA4   : .04722222222222222222, /* 17/360 */
+  RA6   : .02215608465608465608, /* 67/3024 */
+  RV4   : .06944444444444444444, /* 5/72 */
+  RV6   : .04243827160493827160, /* 55/1296 */
+// Function to compute the constant small m which is the radius of
+//   a parallel of latitude, phi, divided by the semimajor axis.
+  msfnz : function(eccent, sinphi, cosphi) {
+      var con = eccent * sinphi;
+      return cosphi/(Math.sqrt(1.0 - con * con));
+// Function to compute the constant small t for use in the forward
+//   computations in the Lambert Conformal Conic and the Polar
+//   Stereographic projections.
+  tsfnz : function(eccent, phi, sinphi) {
+    var com = .5 * eccent;
+    con = Math.pow(((1.0 - con) / (1.0 + con)), com);
+    return (Math.tan(.5 * (this.HALF_PI - phi))/con);
+// Function to compute the latitude angle, phi2, for the inverse of the
+//   Lambert Conformal Conic and Polar Stereographic projections.
+  phi2z : function(eccent, ts) {
+    var eccnth = .5 * eccent;
+    var con, dphi;
+    var phi = this.HALF_PI - 2 * Math.atan(ts);
+    for (i = 0; i <= 15; i++) {
+      con = eccent * Math.sin(phi);
+      dphi = this.HALF_PI - 2 * Math.atan(ts *(Math.pow(((1.0 - con)/(1.0 + con)),eccnth))) - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) return phi;
+    alert("phi2z has NoConvergence");
+    return (-9999);
+/* Function to compute constant small q which is the radius of a
+   parallel of latitude, phi, divided by the semimajor axis.
+  qsfnz : function(eccent,sinphi,cosphi) {
+    var con;
+    if (eccent > 1.0e-7) {
+      con = eccent * sinphi;
+      return (( 1.0- eccent * eccent) * (sinphi /(1.0 - con * con) - (.5/eccent)*Math.log((1.0 - con)/(1.0 + con))));
+    } else {
+      return(2.0 * sinphi);
+/* Function to eliminate roundoff errors in asin
+  asinz : function(x) {
+    if (Math.abs(x)>1.0) {
+      x=(x>1.0)?1.0:-1.0;
+    return Math.asin(x);
+// following functions from gctpc cproj.c for transverse mercator projections
+  e0fn : function(x) {return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},
+  e1fn : function(x) {return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},
+  e2fn : function(x) {return(0.05859375*x*x*(1.0+0.75*x));},
+  e3fn : function(x) {return(x*x*x*(35.0/3072.0));},
+  mlfn : function(e0,e1,e2,e3,phi) {return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},
+  srat : function(esinp, exp) {
+    return(Math.pow((1.0-esinp)/(1.0+esinp), exp));
+// Function to return the sign of an argument
+  sign : function(x) { if (x < 0.0) return(-1); else return(1);},
+// Function to adjust longitude to -180 to 180; input in radians
+  adjust_lon : function(x) {
+    x = (Math.abs(x) < this.PI) ? x: (x - (this.sign(x)*this.TWO_PI) );
+    return x;
+// IGNF - DGR : algorithms used by IGN France
+// Function to adjust latitude to -90 to 90; input in radians
+  adjust_lat : function(x) {
+    x= (Math.abs(x) < this.HALF_PI) ? x: (x - (this.sign(x)*this.PI) );
+    return x;
+// Latitude Isometrique - close to tsfnz ...
+  latiso : function(eccent, phi, sinphi)
+    if (Math.abs(phi) > this.HALF_PI) return +Number.NaN;
+    if (phi==this.HALF_PI) return Number.POSITIVE_INFINITY;
+    if (phi==-1.0*this.HALF_PI) return -1.0*Number.POSITIVE_INFINITY;
+    var con= eccent*sinphi;
+    return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;
+  fL : function(x,L) {
+    return 2.0*Math.atan(x*Math.exp(L)) - this.HALF_PI;
+// Inverse Latitude Isometrique - close to ph2z
+  invlatiso : function(eccent, ts) {
+    var phi= this.fL(1.0,ts);
+    var Iphi= 0.0;
+    var con= 0.0;
+    do {
+      Iphi= phi;
+      con= eccent*Math.sin(Iphi);
+      phi= this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)
+    } while (Math.abs(phi-Iphi)>1.0e-12);
+    return phi;
+// Needed for Gauss Laborde
+// Original:  Denis Makarov (info at binarythings.com)
+// Web Site:  http://www.binarythings.com
+  sinh : function(x)
+    var r= Math.exp(x);
+    r= (r-1.0/r)/2.0;
+    return r;
+  cosh : function(x)
+    r= (r+1.0/r)/2.0;
+    return r;
+  tanh : function(x)
+    r= (r-1.0/r)/(r+1.0/r);
+    return r;
+  asinh : function(x)
+    var s= (x>= 0? 1.0:-1.0);
+    return s*(Math.log( Math.abs(x) + Math.sqrt(x*x+1.0) ));
+  acosh : function(x)
+    return 2.0*Math.log(Math.sqrt((x+1.0)/2.0) + Math.sqrt((x-1.0)/2.0));
+  atanh : function(x)
+    return Math.log((x-1.0)/(x+1.0))/2.0;
+// Grande Normale
+  gN : function(a,e,sinphi)
+    var temp= e*sinphi;
+    return a/Math.sqrt(1.0 - temp*temp);
+/** datum object
+Proj4js.datum = Proj4js.Class({
+  initialize : function(proj) {
+    this.datum_type = Proj4js.common.PJD_WGS84;   //default setting
+    if (proj.datumCode && proj.datumCode == 'none') {
+      this.datum_type = Proj4js.common.PJD_NODATUM;
+    if (proj && proj.datum_params) {
+      for (var i=0; i<proj.datum_params.length; i++) {
+        proj.datum_params[i]=parseFloat(proj.datum_params[i]);
+      if (proj.datum_params[0] != 0 || proj.datum_params[1] != 0 || proj.datum_params[2] != 0 ) {
+        this.datum_type = Proj4js.common.PJD_3PARAM;
+      if (proj.datum_params.length > 3) {
+        if (proj.datum_params[3] != 0 || proj.datum_params[4] != 0 ||
+            proj.datum_params[5] != 0 || proj.datum_params[6] != 0 ) {
+          this.datum_type = Proj4js.common.PJD_7PARAM;
+          proj.datum_params[3] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[4] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[5] *= Proj4js.common.SEC_TO_RAD;
+          proj.datum_params[6] = (proj.datum_params[6]/1000000.0) + 1.0;
+    if (proj) {
+      this.a = proj.a;    //datum object also uses these values
+      this.b = proj.b;
+      this.es = proj.es;
+      this.ep2 = proj.ep2;
+      this.datum_params = proj.datum_params;
+  // cs_compare_datums()
+  //   Returns 1 (TRUE) if the two datums match, otherwise 0 (FALSE).
+  compare_datums : function( dest ) {
+    if( this.datum_type != dest.datum_type ) {
+      return false; // false, datums are not equal
+    } else if( this.a != dest.a || Math.abs(this.es-dest.es) > 0.000000000050 ) {
+      // the tolerence for es is to ensure that GRS80 and WGS84
+      // are considered identical
+      return false;
+    } else if( this.datum_type == Proj4js.common.PJD_3PARAM ) {
+      return (this.datum_params[0] == dest.datum_params[0]
+              && this.datum_params[1] == dest.datum_params[1]
+              && this.datum_params[2] == dest.datum_params[2]);
+    } else if( this.datum_type == Proj4js.common.PJD_7PARAM ) {
+              && this.datum_params[3] == dest.datum_params[3]
+              && this.datum_params[4] == dest.datum_params[4]
+              && this.datum_params[5] == dest.datum_params[5]
+              && this.datum_params[6] == dest.datum_params[6]);
+    } else if( this.datum_type == Proj4js.common.PJD_GRIDSHIFT ) {
+      return strcmp( pj_param(this.params,"snadgrids").s,
+                     pj_param(dest.params,"snadgrids").s ) == 0;
+    } else {
+      return true; // datums are equal
+  }, // cs_compare_datums()
+   * The function Convert_Geodetic_To_Geocentric converts geodetic coordinates
+   * (latitude, longitude, and height) to geocentric coordinates (X, Y, Z),
+   * according to the current ellipsoid parameters.
+   *    Latitude  : Geodetic latitude in radians                     (input)
+   *    Longitude : Geodetic longitude in radians                    (input)
+   *    Height    : Geodetic height, in meters                       (input)
+   *    X         : Calculated Geocentric X coordinate, in meters    (output)
+   *    Y         : Calculated Geocentric Y coordinate, in meters    (output)
+   *    Z         : Calculated Geocentric Z coordinate, in meters    (output)
+  geodetic_to_geocentric : function(p) {
+    var Longitude = p.x;
+    var Latitude = p.y;
+    var Height = p.z ? p.z : 0;   //Z value not always supplied
+    var X;  // output
+    var Y;
+    var Z;
+    var Error_Code=0;  //  GEOCENT_NO_ERROR;
+    var Rn;            /*  Earth radius at location  */
+    var Sin_Lat;       /*  Math.sin(Latitude)  */
+    var Sin2_Lat;      /*  Square of Math.sin(Latitude)  */
+    var Cos_Lat;       /*  Math.cos(Latitude)  */
+    ** Don't blow up if Latitude is just a little out of the value
+    ** range as it may just be a rounding issue.  Also removed longitude
+    ** test, it should be wrapped by Math.cos() and Math.sin().  NFW for PROJ.4, Sep/2001.
+    if( Latitude < -Proj4js.common.HALF_PI && Latitude > -1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = -Proj4js.common.HALF_PI;
+    } else if( Latitude > Proj4js.common.HALF_PI && Latitude < 1.001 * Proj4js.common.HALF_PI ) {
+        Latitude = Proj4js.common.HALF_PI;
+    } else if ((Latitude < -Proj4js.common.HALF_PI) || (Latitude > Proj4js.common.HALF_PI)) {
+      /* Latitude out of range */
+      Proj4js.reportError('geocent:lat out of range:'+Latitude);
+      return null;
+    if (Longitude > Proj4js.common.PI) Longitude -= (2*Proj4js.common.PI);
+    Sin_Lat = Math.sin(Latitude);
+    Cos_Lat = Math.cos(Latitude);
+    Sin2_Lat = Sin_Lat * Sin_Lat;
+    Rn = this.a / (Math.sqrt(1.0e0 - this.es * Sin2_Lat));
+    X = (Rn + Height) * Cos_Lat * Math.cos(Longitude);
+    Y = (Rn + Height) * Cos_Lat * Math.sin(Longitude);
+    Z = ((Rn * (1 - this.es)) + Height) * Sin_Lat;
+    p.x = X;
+    p.y = Y;
+    p.z = Z;
+    return Error_Code;
+  }, // cs_geodetic_to_geocentric()
+  geocentric_to_geodetic : function (p) {
+/* local defintions and variables */
+/* end-criterium of loop, accuracy of sin(Latitude) */
+var genau = 1.E-12;
+var genau2 = (genau*genau);
+var maxiter = 30;
+    var P;        /* distance between semi-minor axis and location */
+    var RR;       /* distance between center and location */
+    var CT;       /* sin of geocentric latitude */
+    var ST;       /* cos of geocentric latitude */
+    var RX;
+    var RK;
+    var RN;       /* Earth radius at location */
+    var CPHI0;    /* cos of start or old geodetic latitude in iterations */
+    var SPHI0;    /* sin of start or old geodetic latitude in iterations */
+    var CPHI;     /* cos of searched geodetic latitude */
+    var SPHI;     /* sin of searched geodetic latitude */
+    var SDPHI;    /* end-criterium: addition-theorem of sin(Latitude(iter)-Latitude(iter-1)) */
+    var At_Pole;     /* indicates location is in polar region */
+    var iter;        /* # of continous iteration, max. 30 is always enough (s.a.) */
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0.0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    At_Pole = false;
+    P = Math.sqrt(X*X+Y*Y);
+    RR = Math.sqrt(X*X+Y*Y+Z*Z);
+/*      special cases for latitude and longitude */
+    if (P/this.a < genau) {
+/*  special case, if P=0. (X=0., Y=0.) */
+        At_Pole = true;
+        Longitude = 0.0;
+/*  if (X,Y,Z)=(0.,0.,0.) then Height becomes semi-minor axis
+ *  of ellipsoid (=center of mass), Latitude becomes PI/2 */
+        if (RR/this.a < genau) {
+            Height   = -this.b;
+            return;
+    } else {
+/*  ellipsoidal (geodetic) longitude
+ *  interval: -PI < Longitude <= +PI */
+        Longitude=Math.atan2(Y,X);
+ * Following iterative algorithm was developped by
+ * "Institut für Erdmessung", University of Hannover, July 1988.
+ * Internet: www.ife.uni-hannover.de
+ * Iterative computation of CPHI,SPHI and Height.
+ * Iteration of CPHI and SPHI to 10**-12 radian resp.
+ * 2*10**-7 arcsec.
+    CT = Z/RR;
+    ST = P/RR;
+    RX = 1.0/Math.sqrt(1.0-this.es*(2.0-this.es)*ST*ST);
+    CPHI0 = ST*(1.0-this.es)*RX;
+    SPHI0 = CT*RX;
+    iter = 0;
+/* loop to find sin(Latitude) resp. Latitude
+ * until |sin(Latitude(iter)-Latitude(iter-1))| < genau */
+    do
+        iter++;
+        RN = this.a/Math.sqrt(1.0-this.es*SPHI0*SPHI0);
+/*  ellipsoidal (geodetic) height */
+        Height = P*CPHI0+Z*SPHI0-RN*(1.0-this.es*SPHI0*SPHI0);
+        RK = this.es*RN/(RN+Height);
+        RX = 1.0/Math.sqrt(1.0-RK*(2.0-RK)*ST*ST);
+        CPHI = ST*(1.0-RK)*RX;
+        SPHI = CT*RX;
+        SDPHI = SPHI*CPHI0-CPHI*SPHI0;
+        CPHI0 = CPHI;
+        SPHI0 = SPHI;
+    while (SDPHI*SDPHI > genau2 && iter < maxiter);
+/*      ellipsoidal (geodetic) latitude */
+    Latitude=Math.atan(SPHI/Math.abs(CPHI));
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // cs_geocentric_to_geodetic()
+  /** Convert_Geocentric_To_Geodetic
+   * The method used here is derived from 'An Improved Algorithm for
+   * Geocentric to Geodetic Coordinate Conversion', by Ralph Toms, Feb 1996
+  geocentric_to_geodetic_noniter : function (p) {
+    var X = p.x;
+    var Y = p.y;
+    var Z = p.z ? p.z : 0;   //Z value not always supplied
+    var Longitude;
+    var Latitude;
+    var Height;
+    var W;        /* distance from Z axis */
+    var W2;       /* square of distance from Z axis */
+    var T0;       /* initial estimate of vertical component */
+    var T1;       /* corrected estimate of vertical component */
+    var S0;       /* initial estimate of horizontal component */
+    var S1;       /* corrected estimate of horizontal component */
+    var Sin_B0;   /* Math.sin(B0), B0 is estimate of Bowring aux variable */
+    var Sin3_B0;  /* cube of Math.sin(B0) */
+    var Cos_B0;   /* Math.cos(B0) */
+    var Sin_p1;   /* Math.sin(phi1), phi1 is estimated latitude */
+    var Cos_p1;   /* Math.cos(phi1) */
+    var Sum;      /* numerator of Math.cos(phi1) */
+    X = parseFloat(X);  // cast from string to float
+    Y = parseFloat(Y);
+    Z = parseFloat(Z);
+    At_Pole = false;
+    if (X != 0.0)
+        Longitude = Math.atan2(Y,X);
+    else
+        if (Y > 0)
+            Longitude = Proj4js.common.HALF_PI;
+        else if (Y < 0)
+            Longitude = -Proj4js.common.HALF_PI;
+        else
+            At_Pole = true;
+            Longitude = 0.0;
+            if (Z > 0.0)
+            {  /* north pole */
+            else if (Z < 0.0)
+            {  /* south pole */
+            else
+            {  /* center of earth */
+                Height = -this.b;
+                return;
+    W2 = X*X + Y*Y;
+    W = Math.sqrt(W2);
+    T0 = Z * Proj4js.common.AD_C;
+    S0 = Math.sqrt(T0 * T0 + W2);
+    Sin_B0 = T0 / S0;
+    Cos_B0 = W / S0;
+    Sin3_B0 = Sin_B0 * Sin_B0 * Sin_B0;
+    T1 = Z + this.b * this.ep2 * Sin3_B0;
+    Sum = W - this.a * this.es * Cos_B0 * Cos_B0 * Cos_B0;
+    S1 = Math.sqrt(T1*T1 + Sum * Sum);
+    Sin_p1 = T1 / S1;
+    Cos_p1 = Sum / S1;
+    Rn = this.a / Math.sqrt(1.0 - this.es * Sin_p1 * Sin_p1);
+    if (Cos_p1 >= Proj4js.common.COS_67P5)
+        Height = W / Cos_p1 - Rn;
+    else if (Cos_p1 <= -Proj4js.common.COS_67P5)
+        Height = W / -Cos_p1 - Rn;
+    else
+        Height = Z / Sin_p1 + Rn * (this.es - 1.0);
+    if (At_Pole == false)
+        Latitude = Math.atan(Sin_p1 / Cos_p1);
+    p.x = Longitude;
+    p.y = Latitude;
+    p.z = Height;
+    return p;
+  }, // geocentric_to_geodetic_noniter()
+  // pj_geocentic_to_wgs84( p )
+  //  p = point to transform in geocentric coordinates (x,y,z)
+  geocentric_to_wgs84 : function ( p ) {
+    if( this.datum_type == Proj4js.common.PJD_3PARAM )
+      // if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x += this.datum_params[0];
+      p.y += this.datum_params[1];
+      p.z += this.datum_params[2];
+    else if (this.datum_type == Proj4js.common.PJD_7PARAM)
+      var Dx_BF =this.datum_params[0];
+      var Dy_BF =this.datum_params[1];
+      var Dz_BF =this.datum_params[2];
+      var Rx_BF =this.datum_params[3];
+      var Ry_BF =this.datum_params[4];
+      var Rz_BF =this.datum_params[5];
+      var M_BF  =this.datum_params[6];
+      //    continue;
+      var x_out = M_BF*(       p.x - Rz_BF*p.y + Ry_BF*p.z) + Dx_BF;
+      var y_out = M_BF*( Rz_BF*p.x +       p.y - Rx_BF*p.z) + Dy_BF;
+      var z_out = M_BF*(-Ry_BF*p.x + Rx_BF*p.y +       p.z) + Dz_BF;
+      p.x = x_out;
+      p.y = y_out;
+      p.z = z_out;
+  }, // cs_geocentric_to_wgs84
+  // pj_geocentic_from_wgs84()
+  //  coordinate system definition,
+  //  point to transform in geocentric coordinates (x,y,z)
+  geocentric_from_wgs84 : function( p ) {
+      //if( x[io] == HUGE_VAL )
+      //    continue;
+      p.x -= this.datum_params[0];
+      p.y -= this.datum_params[1];
+      p.z -= this.datum_params[2];
+      var x_tmp = (p.x - Dx_BF) / M_BF;
+      var y_tmp = (p.y - Dy_BF) / M_BF;
+      var z_tmp = (p.z - Dz_BF) / M_BF;
+      //    continue;
+      p.x =        x_tmp + Rz_BF*y_tmp - Ry_BF*z_tmp;
+      p.y = -Rz_BF*x_tmp +       y_tmp + Rx_BF*z_tmp;
+      p.z =  Ry_BF*x_tmp - Rx_BF*y_tmp +       z_tmp;
+    } //cs_geocentric_from_wgs84()
+/** point object, nothing fancy, just allows values to be
+    passed back and forth by reference rather than by value.
+    Other point classes may be used as long as they have
+    x and y properties, which will get modified in the transform method.
+Proj4js.Point = Proj4js.Class({
+     * Constructor! Proj4js.Point
+     * Parameters:
+     * - x {float} or {Array} either the first coordinates component or
+     *     the full coordinates
+     * - y {float} the second component
+     * - z {float} the third component, optional.
+    initialize : function(x,y,z) {
+      if (typeof x == 'object') {
+        this.x = x[0];
+        this.y = x[1];
+        this.z = x[2] || 0.0;
+      } else if (typeof x == 'string') {
+        var coords = x.split(',');
+        this.x = parseFloat(coords[0]);
+        this.y = parseFloat(coords[1]);
+        this.z = parseFloat(coords[2]) || 0.0;
+      } else {
+        this.x = x;
+        this.y = y;
+        this.z = z || 0.0;
+     * APIMethod: clone
+     * Build a copy of a Proj4js.Point object.
+     * Return:
+     * {Proj4js}.Point the cloned point.
+    clone : function() {
+      return new Proj4js.Point(this.x, this.y, this.z);
+     * APIMethod: toString
+     * Return a readable string version of the point
+     * Return:
+     * {String} String representation of Proj4js.Point object.
+     *           (ex. <i>"x=5,y=42"</i>)
+    toString : function() {
+        return ("x=" + this.x + ",y=" + this.y);
+     * APIMethod: toShortString
+     * Return a short string version of the point.
+     * Return:
+     * {String} Shortened String representation of Proj4js.Point object.
+     *         (ex. <i>"5, 42"</i>)
+    toShortString : function() {
+        return (this.x + ", " + this.y);
+Proj4js.PrimeMeridian = {
+    "greenwich": 0.0,               //"0dE",
+    "lisbon":     -9.131906111111,   //"9d07'54.862\"W",
+    "paris":       2.337229166667,   //"2d20'14.025\"E",
+    "bogota":    -74.080916666667,  //"74d04'51.3\"W",
+    "madrid":     -3.687938888889,  //"3d41'16.58\"W",
+    "rome":       12.452333333333,  //"12d27'8.4\"E",
+    "bern":        7.439583333333,  //"7d26'22.5\"E",
+    "jakarta":   106.807719444444,  //"106d48'27.79\"E",
+    "ferro":     -17.666666666667,  //"17d40'W",
+    "brussels":    4.367975,        //"4d22'4.71\"E",
+    "stockholm":  18.058277777778,  //"18d3'29.8\"E",
+    "athens":     23.7163375,       //"23d42'58.815\"E",
+    "oslo":       10.722916666667   //"10d43'22.5\"E"
+Proj4js.Ellipsoid = {
+  "MERIT": {a:6378137.0, rf:298.257, ellipseName:"MERIT 1983"},
+  "SGS85": {a:6378136.0, rf:298.257, ellipseName:"Soviet Geodetic System 85"},
+  "GRS80": {a:6378137.0, rf:298.257222101, ellipseName:"GRS 1980(IUGG, 1980)"},
+  "IAU76": {a:6378140.0, rf:298.257, ellipseName:"IAU 1976"},
+  "airy": {a:6377563.396, b:6356256.910, ellipseName:"Airy 1830"},
+  "APL4.": {a:6378137, rf:298.25, ellipseName:"Appl. Physics. 1965"},
+  "NWL9D": {a:6378145.0, rf:298.25, ellipseName:"Naval Weapons Lab., 1965"},
+  "mod_airy": {a:6377340.189, b:6356034.446, ellipseName:"Modified Airy"},
+  "andrae": {a:6377104.43, rf:300.0, ellipseName:"Andrae 1876 (Den., Iclnd.)"},
+  "aust_SA": {a:6378160.0, rf:298.25, ellipseName:"Australian Natl & S. Amer. 1969"},
+  "GRS67": {a:6378160.0, rf:298.2471674270, ellipseName:"GRS 67(IUGG 1967)"},
+  "bessel": {a:6377397.155, rf:299.1528128, ellipseName:"Bessel 1841"},
+  "bess_nam": {a:6377483.865, rf:299.1528128, ellipseName:"Bessel 1841 (Namibia)"},
+  "clrk66": {a:6378206.4, b:6356583.8, ellipseName:"Clarke 1866"},
+  "clrk80": {a:6378249.145, rf:293.4663, ellipseName:"Clarke 1880 mod."},
+  "CPM": {a:6375738.7, rf:334.29, ellipseName:"Comm. des Poids et Mesures 1799"},
+  "delmbr": {a:6376428.0, rf:311.5, ellipseName:"Delambre 1810 (Belgium)"},
+  "engelis": {a:6378136.05, rf:298.2566, ellipseName:"Engelis 1985"},
+  "evrst30": {a:6377276.345, rf:300.8017, ellipseName:"Everest 1830"},
+  "evrst48": {a:6377304.063, rf:300.8017, ellipseName:"Everest 1948"},
+  "evrst56": {a:6377301.243, rf:300.8017, ellipseName:"Everest 1956"},
+  "evrst69": {a:6377295.664, rf:300.8017, ellipseName:"Everest 1969"},
+  "evrstSS": {a:6377298.556, rf:300.8017, ellipseName:"Everest (Sabah & Sarawak)"},
+  "fschr60": {a:6378166.0, rf:298.3, ellipseName:"Fischer (Mercury Datum) 1960"},
+  "fschr60m": {a:6378155.0, rf:298.3, ellipseName:"Fischer 1960"},
+  "fschr68": {a:6378150.0, rf:298.3, ellipseName:"Fischer 1968"},
+  "helmert": {a:6378200.0, rf:298.3, ellipseName:"Helmert 1906"},
+  "hough": {a:6378270.0, rf:297.0, ellipseName:"Hough"},
+  "intl": {a:6378388.0, rf:297.0, ellipseName:"International 1909 (Hayford)"},
+  "kaula": {a:6378163.0, rf:298.24, ellipseName:"Kaula 1961"},
+  "lerch": {a:6378139.0, rf:298.257, ellipseName:"Lerch 1979"},
+  "mprts": {a:6397300.0, rf:191.0, ellipseName:"Maupertius 1738"},
+  "new_intl": {a:6378157.5, b:6356772.2, ellipseName:"New International 1967"},
+  "plessis": {a:6376523.0, rf:6355863.0, ellipseName:"Plessis 1817 (France)"},
+  "krass": {a:6378245.0, rf:298.3, ellipseName:"Krassovsky, 1942"},
+  "SEasia": {a:6378155.0, b:6356773.3205, ellipseName:"Southeast Asia"},
+  "walbeck": {a:6376896.0, b:6355834.8467, ellipseName:"Walbeck"},
+  "WGS60": {a:6378165.0, rf:298.3, ellipseName:"WGS 60"},
+  "WGS66": {a:6378145.0, rf:298.25, ellipseName:"WGS 66"},
+  "WGS72": {a:6378135.0, rf:298.26, ellipseName:"WGS 72"},
+  "WGS84": {a:6378137.0, rf:298.257223563, ellipseName:"WGS 84"},
+  "sphere": {a:6370997.0, b:6370997.0, ellipseName:"Normal Sphere (r=6370997)"}
+Proj4js.Datum = {
+  "WGS84": {towgs84: "0,0,0", ellipse: "WGS84", datumName: "WGS84"},
+  "GGRS87": {towgs84: "-199.87,74.79,246.62", ellipse: "GRS80", datumName: "Greek_Geodetic_Reference_System_1987"},
+  "NAD83": {towgs84: "0,0,0", ellipse: "GRS80", datumName: "North_American_Datum_1983"},
+  "NAD27": {nadgrids: "@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat", ellipse: "clrk66", datumName: "North_American_Datum_1927"},
+  "potsdam": {towgs84: "606.0,23.0,413.0", ellipse: "bessel", datumName: "Potsdam Rauenberg 1950 DHDN"},
+  "carthage": {towgs84: "-263.0,6.0,431.0", ellipse: "clark80", datumName: "Carthage 1934 Tunisia"},
+  "hermannskogel": {towgs84: "653.0,-212.0,449.0", ellipse: "bessel", datumName: "Hermannskogel"},
+  "ire65": {towgs84: "482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15", ellipse: "mod_airy", datumName: "Ireland 1965"},
+  "nzgd49": {towgs84: "59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993", ellipse: "intl", datumName: "New Zealand Geodetic Datum 1949"},
+  "OSGB36": {towgs84: "446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894", ellipse: "airy", datumName: "Airy 1830"}
+Proj4js.WGS84 = new Proj4js.Proj('WGS84');
+Proj4js.Datum['OSB36'] = Proj4js.Datum['OSGB36']; //as returned from spatialreference.org
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/aea.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/aea.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/aea.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,149 @@
+NAME                     ALBERS CONICAL EQUAL AREA
+PURPOSE:	Transforms input longitude and latitude to Easting and Northing
+		for the Albers Conical Equal Area projection.  The longitude
+		and latitude must be in radians.  The Easting and Northing
+		values will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan,       	Feb, 1992
+ALGORITHM REFERENCES
+1.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+2.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+    Printing Office, Washington D.C., 1989.
+Proj4js.Proj.aea = {
+  init : function() {
+    if (Math.abs(this.lat1 + this.lat2) < Proj4js.common.EPSLN) {
+       Proj4js.reportError("aeaInitEqualLatitudes");
+       return;
+    this.temp = this.b / this.a;
+    this.es = 1.0 - Math.pow(this.temp,2);
+    this.e3 = Math.sqrt(this.es);
+    this.sin_po=Math.sin(this.lat1);
+    this.cos_po=Math.cos(this.lat1);
+    this.t1=this.sin_po
+    this.con = this.sin_po;
+    this.ms1 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs1 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat2);
+    this.cos_po=Math.cos(this.lat2);
+    this.t2=this.sin_po;
+    this.ms2 = Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);
+    this.qs2 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    this.sin_po=Math.sin(this.lat0);
+    this.cos_po=Math.cos(this.lat0);
+    this.t3=this.sin_po;
+    this.qs0 = Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);
+    if (Math.abs(this.lat1 - this.lat2) > Proj4js.common.EPSLN) {
+      this.ns0 = (this.ms1 * this.ms1 - this.ms2 *this.ms2)/ (this.qs2 - this.qs1);
+    } else {
+      this.ns0 = this.con;
+    this.c = this.ms1 * this.ms1 + this.ns0 * this.qs1;
+    this.rh = this.a * Math.sqrt(this.c - this.ns0 * this.qs0)/this.ns0;
+/* Albers Conical Equal Area forward equations--mapping lat,long to x,y
+  forward: function(p){
+    var lon=p.x;
+    var lat=p.y;
+    this.sin_phi=Math.sin(lat);
+    this.cos_phi=Math.cos(lat);
+    var qs = Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);
+    var rh1 =this.a * Math.sqrt(this.c - this.ns0 * qs)/this.ns0;
+    var theta = this.ns0 * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = rh1 * Math.sin(theta) + this.x0;
+    var y = this.rh - rh1 * Math.cos(theta) + this.y0;
+    p.x = x;
+    p.y = y;
+    return p;
+  inverse: function(p) {
+    var rh1,qs,con,theta,lon,lat;
+    p.x -= this.x0;
+    p.y = this.rh - p.y + this.y0;
+    if (this.ns0 >= 0) {
+      rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt(p.x * p.x + p.y *p.y);
+      con = -1.0;
+    theta = 0.0;
+    if (rh1 != 0.0) {
+      theta = Math.atan2(con * p.x, con * p.y);
+    con = rh1 * this.ns0 / this.a;
+    qs = (this.c - con * con) / this.ns0;
+    if (this.e3 >= 1e-10) {
+      con = 1 - .5 * (1.0 -this.es) * Math.log((1.0 - this.e3) / (1.0 + this.e3))/this.e3;
+      if (Math.abs(Math.abs(con) - Math.abs(qs)) > .0000000001 ) {
+          lat = this.phi1z(this.e3,qs);
+      } else {
+          if (qs >= 0) {
+             lat = .5 * PI;
+          } else {
+             lat = -.5 * PI;
+    } else {
+      lat = this.phi1z(e3,qs);
+    lon = Proj4js.common.adjust_lon(theta/this.ns0 + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
+/* Function to compute phi1, the latitude for the inverse of the
+   Albers Conical Equal-Area projection.
+  phi1z: function (eccent,qs) {
+    var con, com, dphi;
+    var phi = Proj4js.common.asinz(.5 * qs);
+    if (eccent < Proj4js.common.EPSLN) return phi;
+    var eccnts = eccent * eccent;
+    for (var i = 1; i <= 25; i++) {
+        sinphi = Math.sin(phi);
+        cosphi = Math.cos(phi);
+        com = 1.0 - con * con;
+        dphi = .5 * com * com / cosphi * (qs / (1.0 - eccnts) - sinphi / com + .5 / eccent * Math.log((1.0 - con) / (1.0 + con)));
+        phi = phi + dphi;
+        if (Math.abs(dphi) <= 1e-7) return phi;
+    Proj4js.reportError("aea:phi1z:Convergence error");
+    return null;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/aeqd.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/aeqd.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/aeqd.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,75 @@
+Proj4js.Proj.aeqd = {
+    this.sin_p12=Math.sin(this.lat0)
+    this.cos_p12=Math.cos(this.lat0)
+  forward: function(p) {
+    var lon=p.x;
+    var lat=p.y;
+    var ksp;
+    var sinphi=Math.sin(p.y);
+    var cosphi=Math.cos(p.y);
+    var dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    var coslon = Math.cos(dlon);
+    var g = this.sin_p12 * sinphi + this.cos_p12 * cosphi * coslon;
+    if (Math.abs(Math.abs(g) - 1.0) < Proj4js.common.EPSLN) {
+       ksp = 1.0;
+       if (g < 0.0) {
+         Proj4js.reportError("aeqd:Fwd:PointError");
+         return;
+    } else {
+       var z = Math.acos(g);
+       ksp = z/Math.sin(z);
+    p.x = this.x0 + this.a * ksp * cosphi * Math.sin(dlon);
+    p.y = this.y0 + this.a * ksp * (this.cos_p12 * sinphi - this.sin_p12 * cosphi * coslon);
+    return p;
+  inverse: function(p){
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var rh = Math.sqrt(p.x * p.x + p.y *p.y);
+    if (rh > (2.0 * Proj4js.common.HALF_PI * this.a)) {
+       Proj4js.reportError("aeqdInvDataError");
+       return;
+    var z = rh / this.a;
+    var sinz=Math.sin(z)
+    var cosz=Math.cos(z)
+    var lon = this.long0;
+    var lat;
+    if (Math.abs(rh) <= Proj4js.common.EPSLN) {
+      lat = this.lat0;
+    } else {
+      lat = Proj4js.common.asinz(cosz * this.sin_p12 + (p.y * sinz * this.cos_p12) / rh);
+      var con = Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+      if (Math.abs(con) <= Proj4js.common.EPSLN) {
+        if (lat0 >= 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x , -p.y));
+        } else {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x , p.y));
+      } else {
+        con = cosz - this.sin_p12 * Math.sin(lat);
+        if ((Math.abs(con) < Proj4js.common.EPSLN) && (Math.abs(p.x) < Proj4js.common.EPSLN)) {
+           //no-op, just keep the lon value as is
+        } else {
+          var temp = Math.atan2((p.x * sinz * this.cos_p12), (con * rh));
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2((p.x * sinz * this.cos_p12), (con * rh)));
+    p.x = lon;
+    p.y = lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/eqc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/eqc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/eqc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,42 @@
+/* similar to equi.js FIXME proj4 uses eqc */
+Proj4js.Proj.eqc = {
+      if(!this.x0) this.x0=0;
+      if(!this.y0) this.y0=0;
+      if(!this.lat0) this.lat0=0;
+      if(!this.long0) this.long0=0;
+      if(!this.lat_ts) this.lat_ts=0;
+      if (!this.title) this.title = "Equidistant Cylindrical (Plate Carre)";
+      this.rc= Math.cos(this.lat_ts);
+    // forward equations--mapping lat,long to x,y
+    forward : function(p) {
+      var lon= p.x;
+      var lat= p.y;
+      var dlat = Proj4js.common.adjust_lat(lat - this.lat0 );
+      p.x= this.x0 + (this.a*dlon*this.rc);
+      p.y= this.y0 + (this.a*dlat        );
+      return p;
+  // inverse equations--mapping x,y to lat/long
+  inverse : function(p) {
+    var x= p.x;
+    var y= p.y;
+    p.x= Proj4js.common.adjust_lon(this.long0 + ((x - this.x0)/(this.a*this.rc)));
+    p.y= Proj4js.common.adjust_lat(this.lat0  + ((y - this.y0)/(this.a        )));
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/eqdc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/eqdc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/eqdc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,140 @@
+NAME                            EQUIDISTANT CONIC
+		for the Equidistant Conic projection.  The longitude and
+		latitude must be in radians.  The Easting and Northing values
+		will be returned in meters.
+PROGRAMMER              DATE
+T. Mittan		Mar, 1993
+/* Variables common to all subroutines in this code file
+Proj4js.Proj.eqdc = {
+/* Initialize the Equidistant Conic projection
+    /* Place parameters in static storage for common use
+    if(!this.mode) this.mode=0;//chosen default mode
+    this.e0 = Proj4js.common.e0fn(this.es);
+    this.e1 = Proj4js.common.e1fn(this.es);
+    this.e2 = Proj4js.common.e2fn(this.es);
+    this.e3 = Proj4js.common.e3fn(this.es);
+    this.sinphi=Math.sin(this.lat1);
+    this.cosphi=Math.cos(this.lat1);
+    this.ms1 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+    this.ml1 = Proj4js.common.mlfn(this.e0, this.e1, this.e2,this.e3, this.lat1);
+    /* format B
+    if (this.mode != 0) {
+            Proj4js.reportError("eqdc:Init:EqualLatitudes");
+            //return(81);
+       this.sinphi=Math.sin(this.lat2);
+       this.cosphi=Math.cos(this.lat2);
+       this.ms2 = Proj4js.common.msfnz(this.e,this.sinphi,this.cosphi);
+       this.ml2 = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat2);
+       if (Math.abs(this.lat1 - this.lat2) >= Proj4js.common.EPSLN) {
+         this.ns = (this.ms1 - this.ms2) / (this.ml2 - this.ml1);
+       } else {
+          this.ns = this.sinphi;
+    } else {
+    this.g = this.ml1 + this.ms1/this.ns;
+    this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this. e2, this.e3, this.lat0);
+    this.rh = this.a * (this.g - this.ml0);
+/* Equidistant Conic forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    /* Forward equations
+    var ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+    var rh1 = this.a * (this.g - ml);
+    var theta = this.ns * Proj4js.common.adjust_lon(lon - this.long0);
+    var x = this.x0  + rh1 * Math.sin(theta);
+    var y = this.y0 + this.rh - rh1 * Math.cos(theta);
+    p.x=x;
+    p.y=y;
+    return p;
+/* Inverse equations
+    p.x -= this.x0;
+    var con, rh1;
+    if (this.ns >= 0) {
+       var rh1 = Math.sqrt(p.x *p.x + p.y * p.y);
+       var con = 1.0;
+    } else {
+       rh1 = -Math.sqrt(p.x *p. x +p. y * p.y);
+       con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0.0) theta = Math.atan2(con *p.x, con *p.y);
+    var ml = this.g - rh1 /this.a;
+    var lat = this.phi3z(this.ml,this.e0,this.e1,this.e2,this.e3);
+    var lon = Proj4js.common.adjust_lon(this.long0 + theta / this.ns);
+     p.x=lon;
+     p.y=lat;
+     return p;
+/* Function to compute latitude, phi3, for the inverse of the Equidistant
+   Conic projection.
+  phi3z: function(ml,e0,e1,e2,e3) {
+    var phi;
+    var dphi;
+    phi = ml;
+    for (var i = 0; i < 15; i++) {
+      dphi = (ml + e1 * Math.sin(2.0 * phi) - e2 * Math.sin(4.0 * phi) + e3 * Math.sin(6.0 * phi))/ e0 - phi;
+      phi += dphi;
+      if (Math.abs(dphi) <= .0000000001) {
+        return phi;
+    Proj4js.reportError("PHI3Z-CONV:Latitude failed to converge after 15 iterations");
+    return null;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/equi.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/equi.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/equi.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,72 @@
+NAME                             EQUIRECTANGULAR
+		Northing for the Equirectangular projection.  The
+		longitude and latitude must be in radians.  The Easting
+		and Northing values will be returned in meters.
+PROGRAMMER              DATE
+Proj4js.Proj.equi = {
+    ///this.t2;
+/* Equirectangular forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var x = this.x0 +this. a * dlon *Math.cos(this.lat0);
+    var y = this.y0 + this.a * lat;
+    this.t1=x;
+    this.t2=Math.cos(this.lat0);
+    p.x=x;
+    p.y=y;
+    return p;
+  },  //equiFwd()
+/* Equirectangular inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lat = p.y /this. a;
+    if ( Math.abs(lat) > Proj4js.common.HALF_PI) {
+        Proj4js.reportError("equi:Inv:DataError");
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x / (this.a * Math.cos(this.lat0)));
+    p.x=lon;
+    p.y=lat;
+  }//equiInv()
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/gauss.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/gauss.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/gauss.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,44 @@
+Proj4js.Proj.gauss = {
+    sphi = Math.sin(this.lat0);
+    cphi = Math.cos(this.lat0);
+    cphi *= cphi;
+    this.rc = Math.sqrt(1.0 - this.es) / (1.0 - this.es * sphi * sphi);
+    this.C = Math.sqrt(1.0 + this.es * cphi * cphi / (1.0 - this.es));
+    this.phic0 = Math.asin(sphi / this.C);
+    this.ratexp = 0.5 * this.C * this.e;
+    this.K = Math.tan(0.5 * this.phic0 + Proj4js.common.FORTPI) / (Math.pow(Math.tan(0.5*this.lat0 + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e*sphi, this.ratexp));
+    var lon = p.x;
+    var lat = p.y;
+    p.y = 2.0 * Math.atan( this.K * Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI), this.C) * Proj4js.common.srat(this.e * Math.sin(lat), this.ratexp) ) - Proj4js.common.HALF_PI;
+    p.x = this.C * lon;
+    return p;
+    var DEL_TOL = 1e-14;
+    var lon = p.x / this.C;
+    var lat = p.y;
+    num = Math.pow(Math.tan(0.5 * lat + Proj4js.common.FORTPI)/this.K, 1./this.C);
+    for (var i = Proj4js.common.MAX_ITER; i>0; --i) {
+      lat = 2.0 * Math.atan(num * Proj4js.common.srat(this.e * Math.sin(p.y), -0.5 * this.e)) - Proj4js.common.HALF_PI;
+      if (Math.abs(lat - p.y) < DEL_TOL) break;
+      p.y = lat;
+    /* convergence failed */
+    if (!i) {
+      Proj4js.reportError("gauss:inverse:convergence failed");
+      return null;
+    p.x = lon;
+    p.y = lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/geocent.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/geocent.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/geocent.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,264 @@
+Author:       Richard Greenwood rich at greenwoodmap.com
+ * convert between geodetic coordinates (longitude, latitude, height)
+ * and gecentric coordinates (X, Y, Z)
+ * ported from Proj 4.9.9 geocent.c
+// following constants #define'd in geocent.h
+// var GEOCENT_NO_ERROR  = 0x0000;
+var GEOCENT_LAT_ERROR = 0x0001;
+// var GEOCENT_LON_ERROR = 0x0002;
+// var cs.a_ERROR        = 0x0004;
+// var cs.b_ERROR        = 0x0008;
+// var cs.a_LESS_B_ERROR = 0x0010;
+// following constants from geocent.c
+var COS_67P5  = 0.38268343236508977;  /* cosine of 67.5 degrees */
+var AD_C      = 1.0026000;            /* Toms region 1 constant */
+function cs_geodetic_to_geocentric (cs, p) {
+  var Height = p.z;
+  var X;  // output
+  var Y;
+  var Z;
+  if( Latitude < -HALF_PI && Latitude > -1.001 * HALF_PI )
+      Latitude = -HALF_PI;
+  else if( Latitude > HALF_PI && Latitude < 1.001 * HALF_PI )
+      Latitude = HALF_PI;
+  else if ((Latitude < -HALF_PI) || (Latitude > HALF_PI))
+  { /* Latitude out of range */
+    Error_Code |= GEOCENT_LAT_ERROR;
+  if (!Error_Code)
+  { /* no errors */
+    if (Longitude > PI)
+      Longitude -= (2*PI);
+    Rn = cs.a / (Math.sqrt(1.0e0 - cs.es * Sin2_Lat));
+    Z = ((Rn * (1 - cs.es)) + Height) * Sin_Lat;
+  p.x = X;
+  p.y = Y;
+  p.z = Z;
+} // cs_geodetic_to_geocentric()
+/** Convert_Geocentric_To_Geodetic
+function cs_geocentric_to_geodetic (cs, p) {
+  var X =p.x;
+  var Y = p.y;
+  var Z = p.z;
+  var Longitude;
+  var Latitude;
+  var Height;
+  At_Pole = false;
+  if (X != 0.0)
+  else
+      if (Y > 0)
+          Longitude = HALF_PI;
+      else if (Y < 0)
+          Longitude = -HALF_PI;
+      else
+          At_Pole = true;
+          Longitude = 0.0;
+          if (Z > 0.0)
+          else if (Z < 0.0)
+          else
+              Height = -cs.b;
+              return;
+  W2 = X*X + Y*Y;
+  T0 = Z * AD_C;
+  Sin_B0 = T0 / S0;
+  Cos_B0 = W / S0;
+  T1 = Z + cs.b * cs.ep2 * Sin3_B0;
+  Sum = W - cs.a * cs.es * Cos_B0 * Cos_B0 * Cos_B0;
+  Sin_p1 = T1 / S1;
+  Rn = cs.a / Math.sqrt(1.0 - cs.es * Sin_p1 * Sin_p1);
+  if (Cos_p1 >= COS_67P5)
+  else if (Cos_p1 <= -COS_67P5)
+  else
+      Height = Z / Sin_p1 + Rn * (cs.es - 1.0);
+  p.x = Longitude;
+  p.y =Latitude;
+  p.z = Height;
+  return 0;
+} // cs_geocentric_to_geodetic()
+// pj_geocentic_to_wgs84(defn, p )
+//    defn = coordinate system definition,
+//  p = point to transform in geocentric coordinates (x,y,z)
+function cs_geocentric_to_wgs84( defn, p ) {
+  if( defn.datum_type == PJD_3PARAM )
+    //    continue;
+    p.x += defn.datum_params[0];
+    p.y += defn.datum_params[1];
+    p.z += defn.datum_params[2];
+  else  // if( defn.datum_type == PJD_7PARAM )
+    var Dx_BF =defn.datum_params[0];
+    var Dy_BF =defn.datum_params[1];
+    var Dz_BF =defn.datum_params[2];
+    var Rx_BF =defn.datum_params[3];
+    var Ry_BF =defn.datum_params[4];
+    var Rz_BF =defn.datum_params[5];
+    var M_BF  =defn.datum_params[6];
+    //    continue;
+    p.x = x_out;
+    p.y = y_out;
+    p.z = z_out;
+} // cs_geocentric_to_wgs84
+// pj_geocentic_from_wgs84()
+//  coordinate system definition,
+//  point to transform in geocentric coordinates (x,y,z)
+function cs_geocentric_from_wgs84( defn, p ) {
+    //    continue;
+    p.x -= defn.datum_params[0];
+    p.y -= defn.datum_params[1];
+    p.z -= defn.datum_params[2];
+    //    continue;
+} //cs_geocentric_from_wgs84()
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/gstmerc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/gstmerc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/gstmerc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,52 @@
+Proj4js.Proj.gstmerc = {
+    // array of:  a, b, lon0, lat0, k0, x0, y0
+      var temp= this.b / this.a;
+      this.e= Math.sqrt(1.0 - temp*temp);
+      this.lc= this.long0;
+      this.rs= Math.sqrt(1.0+this.e*this.e*Math.pow(Math.cos(this.lat0),4.0)/(1.0-this.e*this.e));
+      var sinz= Math.sin(this.lat0);
+      var pc= Math.asin(sinz/this.rs);
+      var sinzpc= Math.sin(pc);
+      this.cp= Proj4js.common.latiso(0.0,pc,sinzpc)-this.rs*Proj4js.common.latiso(this.e,this.lat0,sinz);
+      this.n2= this.k0*this.a*Math.sqrt(1.0-this.e*this.e)/(1.0-this.e*this.e*sinz*sinz);
+      this.xs= this.x0;
+      this.ys= this.y0-this.n2*pc;
+      if (!this.title) this.title = "Gauss Schreiber transverse mercator";
+      var lon= p.x;
+      var lat= p.y;
+      var L= this.rs*(lon-this.lc);
+      var Ls= this.cp+(this.rs*Proj4js.common.latiso(this.e,lat,Math.sin(lat)));
+      var lat1= Math.asin(Math.sin(L)/Proj4js.common.cosh(Ls));
+      var Ls1= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+      p.x= this.xs+(this.n2*Ls1);
+      p.y= this.ys+(this.n2*Math.atan(Proj4js.common.sinh(Ls)/Math.cos(L)));
+      return p;
+    var x= p.x;
+    var y= p.y;
+    var L= Math.atan(Proj4js.common.sinh((x-this.xs)/this.n2)/Math.cos((y-this.ys)/this.n2));
+    var lat1= Math.asin(Math.sin((y-this.ys)/this.n2)/Proj4js.common.cosh((x-this.xs)/this.n2));
+    var LC= Proj4js.common.latiso(0.0,lat1,Math.sin(lat1));
+    p.x= this.lc+L/this.rs;
+    p.y= Proj4js.common.invlatiso(this.e,(LC-this.cp)/this.rs);
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/laea.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/laea.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/laea.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,111 @@
+NAME                  LAMBERT AZIMUTHAL EQUAL-AREA
+		Northing for the Lambert Azimuthal Equal-Area projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      March, 1991
+This function was adapted from the Lambert Azimuthal Equal Area projection
+code (FORTRAN) in the General Cartographic Transformation Package software
+which is available from the U.S. Geological Survey National Mapping Division.
+1.  "New Equal-Area Map Projections for Noncircular Regions", John P. Snyder,
+    The American Cartographer, Vol 15, No. 4, October 1988, pp. 341-355.
+2.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+3.  "Software Documentation for GCTP General Cartographic Transformation
+    Package", U.S. Geological Survey National Mapping Division, May 1982.
+Proj4js.Proj.laea = {
+/* Initialize the Lambert Azimuthal Equal Area projection
+    this.sin_lat_o=Math.sin(this.lat0);
+    this.cos_lat_o=Math.cos(this.lat0);
+/* Lambert Azimuthal Equal Area forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var delta_lon = Proj4js.common.adjust_lon(lon - this.long0);
+    //v 1.0
+    var sin_lat=Math.sin(lat);
+    var cos_lat=Math.cos(lat);
+    var sin_delta_lon=Math.sin(delta_lon);
+    var cos_delta_lon=Math.cos(delta_lon);
+    var g =this.sin_lat_o * sin_lat +this.cos_lat_o * cos_lat * cos_delta_lon;
+    if (g == -1.0) {
+      Proj4js.reportError("laea:fwd:Point projects to a circle of radius "+ 2.0 * R);
+      return null;
+    var ksp = this.a * Math.sqrt(2.0 / (1.0 + g));
+    var x = ksp * cos_lat * sin_delta_lon + this.x0;
+    var y = ksp * (this.cos_lat_o * sin_lat - this.sin_lat_o * cos_lat * cos_delta_lon) + this.y0;
+    p.x = x;
+    p.y = y
+    return p;
+  },//lamazFwd()
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var Rh = Math.sqrt(p.x *p.x +p.y * p.y);
+    var temp = Rh / (2.0 * this.a);
+    if (temp > 1) {
+      Proj4js.reportError("laea:Inv:DataError");
+      return null;
+    var z = 2.0 * Proj4js.common.asinz(temp);
+    var sin_z=Math.sin(z);
+    var cos_z=Math.cos(z);
+    var lon =this.long0;
+    if (Math.abs(Rh) > Proj4js.common.EPSLN) {
+       var lat = Proj4js.common.asinz(this.sin_lat_o * cos_z +this. cos_lat_o * sin_z *p.y / Rh);
+       var temp =Math.abs(this.lat0) - Proj4js.common.HALF_PI;
+       if (Math.abs(temp) > Proj4js.common.EPSLN) {
+          temp = cos_z -this.sin_lat_o * Math.sin(lat);
+          if(temp!=0.0) lon=Proj4js.common.adjust_lon(this.long0+Math.atan2(p.x*sin_z*this.cos_lat_o,temp*Rh));
+       } else if (this.lat0 < 0.0) {
+          lon = Proj4js.common.adjust_lon(this.long0 - Math.atan2(-p.x,p.y));
+       } else {
+          lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2(p.x, -p.y));
+    } else {
+      lat = this.lat0;
+    //return(OK);
+    p.x = lon;
+    p.y = lat;
+    return p;
+  }//lamazInv()
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/lcc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/lcc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/lcc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,148 @@
+NAME                            LAMBERT CONFORMAL CONIC
+		Northing for the Lambert Conformal Conic projection.  The
+//<2104> +proj=lcc +lat_1=10.16666666666667 +lat_0=10.16666666666667 +lon_0=-71.60561777777777 +k_0=1 +x0=-17044 +x0=-23139.97 +ellps=intl +units=m +no_defs  no_defs
+// Initialize the Lambert Conformal conic projection
+//Proj4js.Proj.lcc = Class.create();
+Proj4js.Proj.lcc = {
+    // array of:  r_maj,r_min,lat1,lat2,c_lon,c_lat,false_east,false_north
+    //double c_lat;                   /* center latitude                      */
+    //double c_lon;                   /* center longitude                     */
+    //double lat1;                    /* first standard parallel              */
+    //double lat2;                    /* second standard parallel             */
+    //double r_maj;                   /* major axis                           */
+    //double r_min;                   /* minor axis                           */
+    //double false_east;              /* x offset in meters                   */
+    //double false_north;             /* y offset in meters                   */
+      if (!this.lat2){this.lat2=this.lat0;}//if lat2 is not defined
+    // Standard Parallels cannot be equal and on opposite sides of the equator
+      if (Math.abs(this.lat1+this.lat2) < Proj4js.common.EPSLN) {
+        Proj4js.reportError("lcc:init: Equal Latitudes");
+        return;
+      var temp = this.b / this.a;
+      this.e = Math.sqrt(1.0 - temp*temp);
+      var sin1 = Math.sin(this.lat1);
+      var cos1 = Math.cos(this.lat1);
+      var ms1 = Proj4js.common.msfnz(this.e, sin1, cos1);
+      var ts1 = Proj4js.common.tsfnz(this.e, this.lat1, sin1);
+      var sin2 = Math.sin(this.lat2);
+      var cos2 = Math.cos(this.lat2);
+      var ms2 = Proj4js.common.msfnz(this.e, sin2, cos2);
+      var ts2 = Proj4js.common.tsfnz(this.e, this.lat2, sin2);
+      var ts0 = Proj4js.common.tsfnz(this.e, this.lat0, Math.sin(this.lat0));
+        this.ns = Math.log(ms1/ms2)/Math.log(ts1/ts2);
+      } else {
+        this.ns = sin1;
+      this.f0 = ms1 / (this.ns * Math.pow(ts1, this.ns));
+      this.rh = this.a * this.f0 * Math.pow(ts0, this.ns);
+      if (!this.title) this.title = "Lambert Conformal Conic";
+    // Lambert Conformal conic forward equations--mapping lat,long to x,y
+      var lon = p.x;
+      var lat = p.y;
+    // convert to radians
+      if ( lat <= 90.0 && lat >= -90.0 && lon <= 180.0 && lon >= -180.0) {
+        //lon = lon * Proj4js.common.D2R;
+        //lat = lat * Proj4js.common.D2R;
+      } else {
+        Proj4js.reportError("lcc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+        return null;
+      var con  = Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI);
+      var ts;
+      if (con > Proj4js.common.EPSLN) {
+        ts = Proj4js.common.tsfnz(this.e, lat, Math.sin(lat) );
+        rh1 = this.a * this.f0 * Math.pow(ts, this.ns);
+      } else {
+        con = lat * this.ns;
+        if (con <= 0) {
+          Proj4js.reportError("lcc:forward: No Projection");
+          return null;
+        rh1 = 0;
+      p.x = this.k0 * (rh1 * Math.sin(theta)) + this.x0;
+      p.y = this.k0 * (this.rh - rh1 * Math.cos(theta)) + this.y0;
+      return p;
+  // Lambert Conformal Conic inverse equations--mapping x,y to lat/long
+    var rh1, con, ts;
+    var lat, lon;
+    x = (p.x - this.x0)/this.k0;
+    y = (this.rh - (p.y - this.y0)/this.k0);
+    if (this.ns > 0) {
+      rh1 = Math.sqrt (x * x + y * y);
+      con = 1.0;
+    } else {
+      rh1 = -Math.sqrt (x * x + y * y);
+      con = -1.0;
+    var theta = 0.0;
+    if (rh1 != 0) {
+      theta = Math.atan2((con * x),(con * y));
+    if ((rh1 != 0) || (this.ns > 0.0)) {
+      con = 1.0/this.ns;
+      ts = Math.pow((rh1/(this.a * this.f0)), con);
+      lat = Proj4js.common.phi2z(this.e, ts);
+      if (lat == -9999) return null;
+    } else {
+      lat = -Proj4js.common.HALF_PI;
+    lon = Proj4js.common.adjust_lon(theta/this.ns + this.long0);
+    p.x = lon;
+    p.y = lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/merc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/merc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/merc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,115 @@
+NAME                            MERCATOR
+		Northing for the Mercator projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      Nov, 1991
+//static double r_major = a;		   /* major axis 				*/
+//static double r_minor = b;		   /* minor axis 				*/
+//static double lon_center = long0;	   /* Center longitude (projection center) */
+//static double lat_origin =  lat0;	   /* center latitude			*/
+//static double e,es;		           /* eccentricity constants		*/
+//static double m1;		               /* small value m			*/
+//static double false_northing = y0;   /* y offset in meters			*/
+//static double false_easting = x0;	   /* x offset in meters			*/
+//scale_fact = k0
+Proj4js.Proj.merc = {
+	//?this.temp = this.r_minor / this.r_major;
+	//this.temp = this.b / this.a;
+	//this.es = 1.0 - Math.sqrt(this.temp);
+	//this.e = Math.sqrt( this.es );
+	//?this.m1 = Math.cos(this.lat_origin) / (Math.sqrt( 1.0 - this.es * Math.sin(this.lat_origin) * Math.sin(this.lat_origin)));
+	//this.m1 = Math.cos(0.0) / (Math.sqrt( 1.0 - this.es * Math.sin(0.0) * Math.sin(0.0)));
+    if (this.lat_ts) {
+      if (this.sphere) {
+        this.k0 = Math.cos(this.lat_ts);
+      } else {
+        this.k0 = Proj4js.common.msfnz(this.es, Math.sin(this.lat_ts), Math.cos(this.lat_ts));
+/* Mercator forward equations--mapping lat,long to x,y
+    //alert("ll2m coords : "+coords);
+    var lon = p.x;
+    var lat = p.y;
+    if ( lat*Proj4js.common.R2D > 90.0 &&
+          lat*Proj4js.common.R2D < -90.0 &&
+          lon*Proj4js.common.R2D > 180.0 &&
+          lon*Proj4js.common.R2D < -180.0) {
+      Proj4js.reportError("merc:forward: llInputOutOfRange: "+ lon +" : " + lat);
+      return null;
+    var x,y;
+    if(Math.abs( Math.abs(lat) - Proj4js.common.HALF_PI)  <= Proj4js.common.EPSLN) {
+      Proj4js.reportError("merc:forward: ll2mAtPoles");
+      return null;
+    } else {
+        x = this.x0 + this.a * this.k0 * Proj4js.common.adjust_lon(lon - this.long0);
+        y = this.y0 + this.a * this.k0 * Math.log(Math.tan(Proj4js.common.FORTPI + 0.5*lat));
+      } else {
+        var sinphi = Math.sin(lat);
+        var ts = Proj4js.common.tsfnz(this.e,lat,sinphi);
+        y = this.y0 - this.a * this.k0 * Math.log(ts);
+      p.x = x;
+      p.y = y;
+      return p;
+  /* Mercator inverse equations--mapping x,y to lat/long
+    var x = p.x - this.x0;
+    var y = p.y - this.y0;
+    var lon,lat;
+      lat = Proj4js.common.HALF_PI - 2.0 * Math.atan(Math.exp(-y / this.a * this.k0));
+    } else {
+      var ts = Math.exp(-y / (this.a * this.k0));
+      lat = Proj4js.common.phi2z(this.e,ts);
+      if(lat == -9999) {
+        Proj4js.reportError("merc:inverse: lat = -9999");
+        return null;
+    lon = Proj4js.common.adjust_lon(this.long0+ x / (this.a * this.k0));
+    p.x = lon;
+    p.y = lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/mill.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/mill.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/mill.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,68 @@
+NAME                    MILLER CYLINDRICAL
+		Northing for the Miller Cylindrical projection.  The
+PROGRAMMER              DATE
+T. Mittan		March, 1993
+Proj4js.Proj.mill = {
+/* Initialize the Miller Cylindrical projection
+    //no-op
+  /* Miller Cylindrical forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon -this.long0);
+    var x = this.x0 + this.a * dlon;
+    var y = this.y0 + this.a * Math.log(Math.tan((Proj4js.common.PI / 4.0) + (lat / 2.5))) * 1.25;
+    p.x=x;
+    p.y=y;
+    return p;
+  },//millFwd()
+  /* Miller Cylindrical inverse equations--mapping x,y to lat/long
+    p.x -= this.x0;
+    p.y -= this.y0;
+    var lon = Proj4js.common.adjust_lon(this.long0 + p.x /this.a);
+    var lat = 2.5 * (Math.atan(Math.exp(0.8*p.y/this.a)) - Proj4js.common.PI / 4.0);
+    p.x=lon;
+    p.y=lat;
+    return p;
+  }//millInv()
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/moll.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/moll.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/moll.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,100 @@
+NAME                            MOLLWEIDE
+		Northing for the MOllweide projection.  The
+PROGRAMMER              DATE
+D. Steinwand, EROS      May, 1991;  Updated Sept, 1992; Updated Feb, 1993
+S. Nelson, EDC		Jun, 2993;	Made corrections in precision and
+					number of iterations.
+1.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+Proj4js.Proj.moll = {
+  /* Initialize the Mollweide projection
+  init: function(){
+    //no-op
+  /* Mollweide forward equations--mapping lat,long to x,y
+    var lon=p.x;
+    var lat=p.y;
+    var theta = lat;
+    var con = Proj4js.common.PI * Math.sin(lat);
+    /* Iterate using the Newton-Raphson method to find theta
+    for (var i=0;;i++) {
+       var delta_theta = -(theta + Math.sin(theta) - con)/ (1.0 + Math.cos(theta));
+       theta += delta_theta;
+       if (Math.abs(delta_theta) < Proj4js.common.EPSLN) break;
+       if (i >= 50) {
+          Proj4js.reportError("moll:Fwd:IterationError");
+         //return(241);
+    theta /= 2.0;
+    /* If the latitude is 90 deg, force the x coordinate to be "0 + false easting"
+       this is done here because of precision problems with "cos(theta)"
+    if (Proj4js.common.PI/2 - Math.abs(lat) < Proj4js.common.EPSLN) delta_lon =0;
+    var x = 0.900316316158 * this.a * delta_lon * Math.cos(theta) + this.x0;
+    var y = 1.4142135623731 * this.a * Math.sin(theta) + this.y0;
+    p.x=x;
+    p.y=y;
+    return p;
+    var theta;
+    var arg;
+    /* Inverse equations
+    p.x-= this.x0;
+    //~ p.y -= this.y0;
+    var arg = p.y /  (1.4142135623731 * this.a);
+    /* Because of division by zero problems, 'arg' can not be 1.0.  Therefore
+       a number very close to one is used instead.
+    if(Math.abs(arg) > 0.999999999999) arg=0.999999999999;
+    var theta =Math.asin(arg);
+    var lon = Proj4js.common.adjust_lon(this.long0 + (p.x / (0.900316316158 * this.a * Math.cos(theta))));
+    if(lon < (-Proj4js.common.PI)) lon= -Proj4js.common.PI;
+    if(lon > Proj4js.common.PI) lon= Proj4js.common.PI;
+    arg = (2.0 * theta + Math.sin(2.0 * theta)) / Proj4js.common.PI;
+    if(Math.abs(arg) > 1.0)arg=1.0;
+    var lat = Math.asin(arg);
+    //return(OK);
+    p.x=lon;
+    p.y=lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/nzmg.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/nzmg.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/nzmg.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,286 @@
+NAME                            NEW ZEALAND MAP GRID
+		Northing for the New Zealand Map Grid projection.  The
+1.  Department of Land and Survey Technical Circular 1973/32
+      http://www.linz.govt.nz/docs/miscellaneous/nz-map-definition.pdf
+2.  OSG Technical Report 4.1
+      http://www.linz.govt.nz/docs/miscellaneous/nzmg.pdf
+IMPLEMENTATION NOTES
+The two references use different symbols for the calculated values. This
+implementation uses the variable names similar to the symbols in reference [1].
+The alogrithm uses different units for delta latitude and delta longitude.
+The delta latitude is assumed to be in units of seconds of arc x 10^-5.
+The delta longitude is the usual radians. Look out for these conversions.
+The algorithm is described using complex arithmetic. There were three
+options:
+   * find and use a Javascript library for complex arithmetic
+   * write my own complex library
+   * expand the complex arithmetic by hand to simple arithmetic
+This implementation has expanded the complex multiplication operations
+into parallel simple arithmetic operations for the real and imaginary parts.
+The imaginary part is way over to the right of the display; this probably
+violates every coding standard in the world, but, to me, it makes it much
+more obvious what is going on.
+The following complex operations are used:
+   - addition
+   - multiplication
+   - division
+   - complex number raised to integer power
+   - summation
+A summary of complex arithmetic operations:
+   (from http://en.wikipedia.org/wiki/Complex_arithmetic)
+   addition:       (a + bi) + (c + di) = (a + c) + (b + d)i
+   subtraction:    (a + bi) - (c + di) = (a - c) + (b - d)i
+   multiplication: (a + bi) x (c + di) = (ac - bd) + (bc + ad)i
+   division:       (a + bi) / (c + di) = [(ac + bd)/(cc + dd)] + [(bc - ad)/(cc + dd)]i
+The algorithm needs to calculate summations of simple and complex numbers. This is
+implemented using a for-loop, pre-loading the summed value to zero.
+The algorithm needs to calculate theta^2, theta^3, etc while doing a summation.
+There are three possible implementations:
+   - use Math.pow in the summation loop - except for complex numbers
+   - precalculate the values before running the loop
+   - calculate theta^n = theta^(n-1) * theta during the loop
+This implementation uses the third option for both real and complex arithmetic.
+For example
+   psi_n = 1;
+   sum = 0;
+   for (n = 1; n <=6; n++) {
+      psi_n1 = psi_n * psi;       // calculate psi^(n+1)
+      psi_n = psi_n1;
+      sum = sum + A[n] * psi_n;
+TEST VECTORS
+NZMG E, N:         2487100.638      6751049.719     metres
+NZGD49 long, lat:      172.739194       -34.444066  degrees
+NZMG E, N:         2486533.395      6077263.661     metres
+NZGD49 long, lat:      172.723106       -40.512409  degrees
+NZMG E, N:         2216746.425      5388508.765     metres
+NZGD49 long, lat:      169.172062       -46.651295  degrees
+Note that these test vectors convert from NZMG metres to lat/long referenced
+to NZGD49, not the more usual WGS84. The difference is about 70m N/S and about
+10m E/W.
+These test vectors are provided in reference [1]. Many more test
+vectors are available in
+   http://www.linz.govt.nz/docs/topography/topographicdata/placenamesdatabase/nznamesmar08.zip
+which is a catalog of names on the 260-series maps.
+EPSG CODES
+NZMG     EPSG:27200
+NZGD49   EPSG:4272
+http://spatialreference.org/ defines these as
+  Proj4js.defs["EPSG:4272"] = "+proj=longlat +ellps=intl +datum=nzgd49 +no_defs ";
+  Proj4js.defs["EPSG:27200"] = "+proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150 +ellps=intl +datum=nzgd49 +units=m +no_defs ";
+LICENSE
+  Copyright: Stephen Irons 2008
+  Released under terms of the LGPL as per: http://www.gnu.org/copyleft/lesser.html
+  Initialize New Zealand Map Grip projection
+Proj4js.Proj.nzmg = {
+   * iterations: Number of iterations to refine inverse transform.
+   *     0 -> km accuracy
+   *     1 -> m accuracy -- suitable for most mapping applications
+   *     2 -> mm accuracy
+  iterations: 1,
+    this.A = new Array();
+    this.A[1]  = +0.6399175073;
+    this.A[2]  = -0.1358797613;
+    this.A[3]  = +0.063294409;
+    this.A[4]  = -0.02526853;
+    this.A[5]  = +0.0117879;
+    this.A[6]  = -0.0055161;
+    this.A[7]  = +0.0026906;
+    this.A[8]  = -0.001333;
+    this.A[9]  = +0.00067;
+    this.A[10] = -0.00034;
+    this.B_re = new Array();        this.B_im = new Array();
+    this.B_re[1] = +0.7557853228;   this.B_im[1] =  0.0;
+    this.B_re[2] = +0.249204646;    this.B_im[2] = +0.003371507;
+    this.B_re[3] = -0.001541739;    this.B_im[3] = +0.041058560;
+    this.B_re[4] = -0.10162907;     this.B_im[4] = +0.01727609;
+    this.B_re[5] = -0.26623489;     this.B_im[5] = -0.36249218;
+    this.B_re[6] = -0.6870983;      this.B_im[6] = -1.1651967;
+    this.C_re = new Array();        this.C_im = new Array();
+    this.C_re[1] = +1.3231270439;   this.C_im[1] =  0.0;
+    this.C_re[2] = -0.577245789;    this.C_im[2] = -0.007809598;
+    this.C_re[3] = +0.508307513;    this.C_im[3] = -0.112208952;
+    this.C_re[4] = -0.15094762;     this.C_im[4] = +0.18200602;
+    this.C_re[5] = +1.01418179;     this.C_im[5] = +1.64497696;
+    this.C_re[6] = +1.9660549;      this.C_im[6] = +2.5127645;
+    this.D = new Array();
+    this.D[1] = +1.5627014243;
+    this.D[2] = +0.5185406398;
+    this.D[3] = -0.03333098;
+    this.D[4] = -0.1052906;
+    this.D[5] = -0.0368594;
+    this.D[6] = +0.007317;
+    this.D[7] = +0.01220;
+    this.D[8] = +0.00394;
+    this.D[9] = -0.0013;
+    New Zealand Map Grid Forward  - long/lat to x/y
+    long/lat in radians
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lat = lat - this.lat0;
+    var delta_lon = lon - this.long0;
+    // 1. Calculate d_phi and d_psi    ...                          // and d_lambda
+    // For this algorithm, delta_latitude is in seconds of arc x 10-5, so we need to scale to those units. Longitude is radians.
+    var d_phi = delta_lat / Proj4js.common.SEC_TO_RAD * 1E-5;       var d_lambda = delta_lon;
+    var d_phi_n = 1;  // d_phi^0
+    var d_psi = 0;
+    for (n = 1; n <= 10; n++) {
+      d_phi_n = d_phi_n * d_phi;
+      d_psi = d_psi + this.A[n] * d_phi_n;
+    // 2. Calculate theta
+    var th_re = d_psi;                                              var th_im = d_lambda;
+    // 3. Calculate z
+    var th_n_re = 1;                                                var th_n_im = 0;  // theta^0
+    var th_n_re1;                                                   var th_n_im1;
+    var z_re = 0;                                                   var z_im = 0;
+    for (n = 1; n <= 6; n++) {
+      th_n_re1 = th_n_re*th_re - th_n_im*th_im;                     th_n_im1 = th_n_im*th_re + th_n_re*th_im;
+      th_n_re = th_n_re1;                                           th_n_im = th_n_im1;
+      z_re = z_re + this.B_re[n]*th_n_re - this.B_im[n]*th_n_im;    z_im = z_im + this.B_im[n]*th_n_re + this.B_re[n]*th_n_im;
+    // 4. Calculate easting and northing
+    x = (z_im * this.a) + this.x0;
+    y = (z_re * this.a) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+    New Zealand Map Grid Inverse  -  x/y to long/lat
+    var x = p.x;
+    var y = p.y;
+    var delta_x = x - this.x0;
+    var delta_y = y - this.y0;
+    // 1. Calculate z
+    var z_re = delta_y / this.a;                                              var z_im = delta_x / this.a;
+    // 2a. Calculate theta - first approximation gives km accuracy
+    var z_n_re = 1;                                                           var z_n_im = 0;  // z^0
+    var z_n_re1;                                                              var z_n_im1;
+    var th_re = 0;                                                            var th_im = 0;
+      z_n_re1 = z_n_re*z_re - z_n_im*z_im;                                    z_n_im1 = z_n_im*z_re + z_n_re*z_im;
+      z_n_re = z_n_re1;                                                       z_n_im = z_n_im1;
+      th_re = th_re + this.C_re[n]*z_n_re - this.C_im[n]*z_n_im;              th_im = th_im + this.C_im[n]*z_n_re + this.C_re[n]*z_n_im;
+    // 2b. Iterate to refine the accuracy of the calculation
+    //        0 iterations gives km accuracy
+    //        1 iteration gives m accuracy -- good enough for most mapping applications
+    //        2 iterations bives mm accuracy
+    for (i = 0; i < this.iterations; i++) {
+       var th_n_re = th_re;                                                      var th_n_im = th_im;
+       var num_re = z_re;                                                        var num_im = z_im;
+       for (n = 2; n <= 6; n++) {
+         num_re = num_re + (n-1)*(this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);  num_im = num_im + (n-1)*(this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       th_n_re = 1;                                                              th_n_im = 0;
+       var den_re = this.B_re[1];                                                var den_im = this.B_im[1];
+         den_re = den_re + n * (this.B_re[n]*th_n_re - this.B_im[n]*th_n_im);    den_im = den_im + n * (this.B_im[n]*th_n_re + this.B_re[n]*th_n_im);
+       // Complex division
+       var den2 = den_re*den_re + den_im*den_im;
+       th_re = (num_re*den_re + num_im*den_im) / den2;                           th_im = (num_im*den_re - num_re*den_im) / den2;
+    // 3. Calculate d_phi              ...                                    // and d_lambda
+    var d_psi = th_re;                                                        var d_lambda = th_im;
+    var d_psi_n = 1;  // d_psi^0
+    var d_phi = 0;
+    for (n = 1; n <= 9; n++) {
+       d_psi_n = d_psi_n * d_psi;
+       d_phi = d_phi + this.D[n] * d_psi_n;
+    // 4. Calculate latitude and longitude
+    // d_phi is calcuated in second of arc * 10^-5, so we need to scale back to radians. d_lambda is in radians.
+    var lat = this.lat0 + (d_phi * Proj4js.common.SEC_TO_RAD * 1E5);
+    var lon = this.long0 +  d_lambda;
+    p.x = lon;
+    p.y = lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/omerc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/omerc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/omerc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,256 @@
+NAME                       OBLIQUE MERCATOR (HOTINE)
+		Northing for the Oblique Mercator projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.omerc = {
+  /* Initialize the Oblique Mercator  projection
+  init: function() {
+    if (!this.mode) this.mode=0;
+    if (!this.lon1)   {this.lon1=0;this.mode=1;}
+    if (!this.lon2)   this.lon2=0;
+    if (!this.lat2)    this.lat2=0;
+    var temp = this.b/ this.a;
+    var es = 1.0 - Math.pow(temp,2);
+    var e = Math.sqrt(es);
+    this.sin_p20=Math.sin(this.lat0);
+    this.cos_p20=Math.cos(this.lat0);
+    this.con = 1.0 - this.es * this.sin_p20 * this.sin_p20;
+    this.com = Math.sqrt(1.0 - es);
+    this.bl = Math.sqrt(1.0 + this.es * Math.pow(this.cos_p20,4.0)/(1.0 - es));
+    this.al = this.a * this.bl * this.k0 * this.com / this.con;
+    if (Math.abs(this.lat0) < Proj4js.common.EPSLN) {
+       this.ts = 1.0;
+       this.d = 1.0;
+       this.el = 1.0;
+    } else {
+       this.ts = Proj4js.common.tsfnz(this.e,this.lat0,this.sin_p20);
+       this.con = Math.sqrt(this.con);
+       this.d = this.bl * this.com / (this.cos_p20 * this.con);
+       if ((this.d * this.d - 1.0) > 0.0) {
+          if (this.lat0 >= 0.0) {
+             this.f = this.d + Math.sqrt(this.d * this.d - 1.0);
+          } else {
+             this.f = this.d - Math.sqrt(this.d * this.d - 1.0);
+       } else {
+         this.f = this.d;
+       this.el = this.f * Math.pow(this.ts,this.bl);
+    //this.longc=52.60353916666667;
+       this.g = .5 * (this.f - 1.0/this.f);
+       this.gama = Proj4js.common.asinz(Math.sin(this.alpha) / this.d);
+       this.longc= this.longc - Proj4js.common.asinz(this.g * Math.tan(this.gama))/this.bl;
+       /* Report parameters common to format B
+       //genrpt(azimuth * R2D,"Azimuth of Central Line:    ");
+       //cenlon(lon_origin);
+      // cenlat(lat_origin);
+       this.con = Math.abs(this.lat0);
+       if ((this.con > Proj4js.common.EPSLN) && (Math.abs(this.con - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN)) {
+            this.singam=Math.sin(this.gama);
+            this.cosgam=Math.cos(this.gama);
+            this.sinaz=Math.sin(this.alpha);
+            this.cosaz=Math.cos(this.alpha);
+            if (this.lat0>= 0) {
+               this.u =  (this.al / this.bl) * Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+            } else {
+               this.u =  -(this.al / this.bl) *Math.atan(Math.sqrt(this.d*this.d - 1.0)/this.cosaz);
+          } else {
+            Proj4js.reportError("omerc:Init:DataError");
+       } else {
+       this.sinphi =Math. sin(this.at1);
+       this.ts1 = Proj4js.common.tsfnz(this.e,this.lat1,this.sinphi);
+       this.sinphi = Math.sin(this.lat2);
+       this.ts2 = Proj4js.common.tsfnz(this.e,this.lat2,this.sinphi);
+       this.h = Math.pow(this.ts1,this.bl);
+       this.l = Math.pow(this.ts2,this.bl);
+       this.f = this.el/this.h;
+       this.j = (this.el * this.el - this.l * this.h)/(this.el * this.el + this.l * this.h);
+       this.p = (this.l - this.h) / (this.l + this.h);
+       this.dlon = this.lon1 - this.lon2;
+       if (this.dlon < -Proj4js.common.PI) this.lon2 = this.lon2 - 2.0 * Proj4js.common.PI;
+       if (this.dlon > Proj4js.common.PI) this.lon2 = this.lon2 + 2.0 * Proj4js.common.PI;
+       this.longc = .5 * (this.lon1 + this.lon2) -Math.atan(this.j * Math.tan(.5 * this.bl * this.dlon)/this.p)/this.bl;
+       this.dlon  = Proj4js.common.adjust_lon(this.lon1 - this.longc);
+       this.gama = Math.atan(Math.sin(this.bl * this.dlon)/this.g);
+       this.alpha = Proj4js.common.asinz(this.d * Math.sin(this.gama));
+       /* Report parameters common to format A
+       if (Math.abs(this.lat1 - this.lat2) <= Proj4js.common.EPSLN) {
+          Proj4js.reportError("omercInitDataError");
+          //return(202);
+       } else {
+          this.con = Math.abs(this.lat1);
+       if ((this.con <= Proj4js.common.EPSLN) || (Math.abs(this.con - HALF_PI) <= Proj4js.common.EPSLN)) {
+                //return(202);
+       } else {
+         if (Math.abs(Math.abs(this.lat0) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN) {
+            //return(202);
+       this.singam=Math.sin(this.gam);
+       this.cosgam=Math.cos(this.gam);
+       if (this.lat0 >= 0) {
+          this.u =  (this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+       } else {
+          this.u = -(this.al/this.bl) * Math.atan(Math.sqrt(this.d * this.d - 1.0)/this.cosaz);
+  /* Oblique Mercator forward equations--mapping lat,long to x,y
+    var theta;		/* angle					*/
+    var sin_phi, cos_phi;/* sin and cos value				*/
+    var b;		/* temporary values				*/
+    var c, t, tq;	/* temporary values				*/
+    var con, n, ml;	/* cone constant, small m			*/
+    var q,us,vl;
+    var ul,vs;
+    var s;
+    var dlon;
+    var ts1;
+    var lon=p.x;
+    var lat=p.y;
+    sin_phi = Math.sin(lat);
+    dlon = Proj4js.common.adjust_lon(lon - this.longc);
+    vl = Math.sin(this.bl * dlon);
+    if (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) > Proj4js.common.EPSLN) {
+       ts1 = Proj4js.common.tsfnz(this.e,lat,sin_phi);
+       q = this.el / (Math.pow(ts1,this.bl));
+       s = .5 * (q - 1.0 / q);
+       t = .5 * (q + 1.0/ q);
+       ul = (s * this.singam - vl * this.cosgam) / t;
+       con = Math.cos(this.bl * dlon);
+       if (Math.abs(con) < .0000001) {
+          us = this.al * this.bl * dlon;
+       } else {
+          us = this.al * Math.atan((s * this.cosgam + vl * this.singam) / con)/this.bl;
+          if (con < 0) us = us + Proj4js.common.PI * this.al / this.bl;
+    } else {
+       if (lat >= 0) {
+          ul = this.singam;
+       } else {
+          ul = -this.singam;
+       us = this.al * lat / this.bl;
+    if (Math.abs(Math.abs(ul) - 1.0) <= Proj4js.common.EPSLN) {
+       //alert("Point projects into infinity","omer-for");
+       Proj4js.reportError("omercFwdInfinity");
+       //return(205);
+    vs = .5 * this.al * Math.log((1.0 - ul)/(1.0 + ul)) / this.bl;
+    us = us - this.u;
+    var x = this.x0 + vs * this.cosaz + us * this.sinaz;
+    var y = this.y0 + us * this.cosaz - vs * this.sinaz;
+    p.x=x;
+    p.y=y;
+    return p;
+    var delta_lon;	/* Delta longitude (Given longitude - center 	*/
+    var delta_theta;	/* adjusted longitude				*/
+    var vs,us,q,s,ts1;
+    var vl,ul,bs;
+    var dlon;
+    var  flag;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    flag = 0;
+    vs = p.x * this.cosaz - p.y * this.sinaz;
+    us = p.y * this.cosaz + p.x * this.sinaz;
+    us = us + this.u;
+    q = Math.exp(-this.bl * vs / this.al);
+    s = .5 * (q - 1.0/q);
+    t = .5 * (q + 1.0/q);
+    vl = Math.sin(this.bl * us / this.al);
+    ul = (vl * this.cosgam + s * this.singam)/t;
+       lon = this.longc;
+       if (ul >= 0.0) {
+          lat = Proj4js.common.HALF_PI;
+       } else {
+    } else {
+       con = 1.0 / this.bl;
+       ts1 =Math.pow((this.el / Math.sqrt((1.0 + ul) / (1.0 - ul))),con);
+       lat = Proj4js.common.phi2z(this.e,ts1);
+       //if (flag != 0)
+          //return(flag);
+       //~ con = Math.cos(this.bl * us /al);
+       theta = this.longc - Math.atan2((s * this.cosgam - vl * this.singam) , con)/this.bl;
+       lon = Proj4js.common.adjust_lon(theta);
+    p.x=lon;
+    p.y=lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/ortho.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/ortho.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/ortho.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,113 @@
+NAME                             ORTHOGRAPHIC
+		Northing for the Orthographic projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.ortho = {
+  /* Initialize the Orthographic projection
+  init: function(def) {
+    //double temp;			/* temporary variable		*/
+    this.sin_p14=Math.sin(this.lat0);
+    this.cos_p14=Math.cos(this.lat0);
+  /* Orthographic forward equations--mapping lat,long to x,y
+    var sinphi, cosphi;	/* sin and cos value				*/
+    var dlon;		/* delta longitude value			*/
+    var coslon;		/* cos of longitude				*/
+    var ksp;		/* scale factor					*/
+    var g;
+    var lon=p.x;
+    var lat=p.y;
+    dlon = Proj4js.common.adjust_lon(lon - this.long0);
+    sinphi=Math.sin(lat);
+    cosphi=Math.cos(lat);
+    coslon = Math.cos(dlon);
+    g = this.sin_p14 * sinphi + this.cos_p14 * cosphi * coslon;
+    ksp = 1.0;
+    if ((g > 0) || (Math.abs(g) <= Proj4js.common.EPSLN)) {
+      var x = this.a * ksp * cosphi * Math.sin(dlon);
+      var y = this.y0 + this.a * ksp * (this.cos_p14 * sinphi - this.sin_p14 * cosphi * coslon);
+    } else {
+      Proj4js.reportError("orthoFwdPointError");
+    p.x=x;
+    p.y=y;
+    return p;
+    var rh;		/* height above ellipsoid			*/
+    var z;		/* angle					*/
+    var sinz,cosz;	/* sin of z and cos of z			*/
+    var temp;
+    var con;
+    var lon , lat;
+    p.x -= this.x0;
+    p.y -= this.y0;
+    rh = Math.sqrt(p.x * p.x + p.y * p.y);
+    if (rh > this.a + .0000001) {
+      Proj4js.reportError("orthoInvDataError");
+    z = Proj4js.common.asinz(rh / this.a);
+    sinz=Math.sin(z);
+    cosi=Math.cos(z);
+    lon = this.long0;
+      lat = this.lat0;
+    lat = Proj4js.common.asinz(cosz * this.sin_p14 + (y * sinz * this.cos_p14)/rh);
+    con = Math.abs(lat0) - Proj4js.common.HALF_PI;
+       } else {
+          lon = Proj4js.common.adjust_lon(this.long0 -Math.atan2(-p.x, p.y));
+    con = cosz - this.sin_p14 * Math.sin(lat);
+    if ((Math.abs(con) >= Proj4js.common.EPSLN) || (Math.abs(x) >= Proj4js.common.EPSLN)) {
+       lon = Proj4js.common.adjust_lon(this.long0 + Math.atan2((p.x * sinz * this.cos_p14), (con * rh)));
+    p.x=lon;
+    p.y=lat;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/poly.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/poly.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/poly.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,157 @@
+/* Function to compute, phi4, the latitude for the inverse of the
+   Polyconic projection.
+function phi4z (eccent,e0,e1,e2,e3,a,b,c,phi) {
+	var sinphi, sin2ph, tanph, ml, mlp, con1, con2, con3, dphi, i;
+	phi = a;
+	for (i = 1; i <= 15; i++) {
+		tanphi = Math.tan(phi);
+		c = tanphi * Math.sqrt (1.0 - eccent * sinphi * sinphi);
+		sin2ph = Math.sin (2.0 * phi);
+		ml = e0 * *phi - e1 * sin2ph + e2 * sin (4.0 *  *phi);
+		mlp = e0 - 2.0 * e1 * cos (2.0 *  *phi) + 4.0 * e2 *  cos (4.0 *  *phi);
+		ml = e0 * phi - e1 * sin2ph + e2 * Math.sin (4.0 *  phi) - e3 * Math.sin (6.0 * phi);
+		mlp = e0 - 2.0 * e1 * Math.cos (2.0 *  phi) + 4.0 * e2 * Math.cos (4.0 *  phi) - 6.0 * e3 * Math.cos (6.0 *  phi);
+		con1 = 2.0 * ml + c * (ml * ml + b) - 2.0 * a *  (c * ml + 1.0);
+		con2 = eccent * sin2ph * (ml * ml + b - 2.0 * a * ml) / (2.0 *c);
+		con3 = 2.0 * (a - ml) * (c * mlp - 2.0 / sin2ph) - 2.0 * mlp;
+		dphi = con1 / (con2 + con3);
+		phi += dphi;
+		if (Math.abs(dphi) <= .0000000001 ) return(phi);
+	Proj4js.reportError("phi4z: No convergence");
+	return null;
+/* Function to compute the constant e4 from the input of the eccentricity
+   of the spheroid, x.  This constant is used in the Polar Stereographic
+   projection.
+function e4fn(x) {
+	var con, com;
+	con = 1.0 + x;
+	com = 1.0 - x;
+	return (Math.sqrt((Math.pow(con,con))*(Math.pow(com,com))));
+NAME                             POLYCONIC
+		Northing for the Polyconic projection.  The
+PROGRAMMER              DATE
+Proj4js.Proj.poly = {
+	/* Initialize the POLYCONIC projection
+		var temp;			/* temporary variable		*/
+		if (this.lat0=0) this.lat0=90;//this.lat0 ca
+		this.es = 1.0 - Math.pow(this.temp,2);// devait etre dans tmerc.js mais n y est pas donc je commente sinon retour de valeurs nulles
+		this.e = Math.sqrt(this.es);
+		this.ml0 = Proj4js.common.mlfn(this.e0, this.e1,this.e2, this.e3, this.lat0);//si que des zeros le calcul ne se fait pas
+		//if (!this.ml0) {this.ml0=0;}
+	/* Polyconic forward equations--mapping lat,long to x,y
+		var al;				/* temporary values				*/
+		var c;				/* temporary values				*/
+		var con, ml;		/* cone constant, small m			*/
+		var ms;				/* small m					*/
+		var x,y;
+		var lon=p.x;
+		var lat=p.y;
+		con = Proj4js.common.adjust_lon(lon - this.long0);
+		if (Math.abs(lat) <= .0000001) {
+			x = this.x0 + this.a * con;
+			y = this.y0 - this.a * this.ml0;
+		} else {
+			sinphi = Math.sin(lat);
+			cosphi = Math.cos(lat);
+			ml = Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+			ms = Proj4js.common.msfnz(this.e,sinphi,cosphi);
+			con = sinphi;
+			x = this.x0 + this.a * ms * Math.sin(con)/sinphi;
+			y = this.y0 + this.a * (ml - this.ml0 + ms * (1.0 - Math.cos(con))/sinphi);
+		p.x=x;
+		p.y=y;
+		return p;
+		var sin_phi, cos_phi;	/* sin and cos value				*/
+		var iflg;				/* error flag					*/
+		var lon,lat;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		al = this.ml0 + p.y/this.a;
+		iflg = 0;
+		if (Math.abs(al) <= .0000001) {
+			lon = p.x/this.a + this.long0;
+			lat = 0.0;
+		} else {
+			b = al * al + (p.x/this.a) * (p.x/this.a);
+			iflg = phi4z(this.es,this.e0,this.e1,this.e2,this.e3,this.al,b,c,lat);
+			if (iflg != 1) return(iflg);
+			lon = Proj4js.common.adjust_lon((asinz(p.x * c / this.a) / Math.sin(lat)) + this.long0);
+		p.x=lon;
+		p.y=lat;
+		return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/sinu.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/sinu.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/sinu.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,79 @@
+NAME                  		SINUSOIDAL
+		Northing for the Sinusoidal projection.  The
+PROGRAMMER              DATE
+This function was adapted from the Sinusoidal projection code (FORTRAN) in the
+General Cartographic Transformation Package software which is available from
+the U.S. Geological Survey National Mapping Division.
+2.  "Software Documentation for GCTP General Cartographic Transformation
+Proj4js.Proj.sinu = {
+	/* Initialize the Sinusoidal projection
+		this.R = 6370997.0; //Radius of earth
+	/* Sinusoidal forward equations--mapping lat,long to x,y
+		var x,y,delta_lon;
+		var lon=p.x;
+		var lat=p.y;
+		delta_lon = Proj4js.common.adjust_lon(lon - this.long0);
+		x = this.R * delta_lon * Math.cos(lat) + this.x0;
+		y = this.R * lat + this.y0;
+		p.x=x;
+		p.y=y;
+		return p;
+		var lat,temp,lon;
+		p.x -= this.x0;
+		p.y -= this.y0;
+		lat = p.y / this.R;
+		if (Math.abs(lat) > Proj4js.common.HALF_PI) {
+		    Proj4js.reportError("sinu:Inv:DataError");
+		temp = Math.abs(lat) - Proj4js.common.HALF_PI;
+			temp = this.long0+ p.x / (this.R *Math.cos(lat));
+			lon = Proj4js.common.adjust_lon(temp);
+		} else {
+			lon = this.long0;
+		p.x=lon;
+		p.y=lat;
+		return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/somerc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/somerc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/somerc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,110 @@
+NAME                       SWISS OBLIQUE MERCATOR
+PURPOSE:	Swiss projection.
+WARNING:  X and Y are inverted (weird) in the swiss coordinate system. Not
+   here, since we want X to be horizontal and Y vertical.
+1. "Formules et constantes pour le Calcul pour la
+ projection cylindrique conforme à axe oblique et pour la transformation entre
+ des systèmes de référence".
+ http://www.swisstopo.admin.ch/internet/swisstopo/fr/home/topics/survey/sys/refsys/switzerland.parsysrelated1.31216.downloadList.77004.DownloadFile.tmp/swissprojectionfr.pdf
+Proj4js.Proj.somerc = {
+    var phy0 = this.lat0;
+    this.lambda0 = this.long0;
+    var sinPhy0 = Math.sin(phy0);
+    var semiMajorAxis = this.a;
+    var invF = this.rf;
+    var flattening = 1 / invF;
+    var e2 = 2 * flattening - Math.pow(flattening, 2);
+    var e = this.e = Math.sqrt(e2);
+    this.R = semiMajorAxis * Math.sqrt(1 - e2) / (1 - e2 * Math.pow(sinPhy0, 2.0));
+    this.alpha = Math.sqrt(1 + e2 / (1 - e2) * Math.pow(Math.cos(phy0), 4.0));
+    this.b0 = Math.asin(sinPhy0 / this.alpha);
+    this.K = Math.log(Math.tan(Math.PI / 4.0 + this.b0 / 2.0))
+            - this.alpha
+            * Math.log(Math.tan(Math.PI / 4.0 + phy0 / 2.0))
+            + this.alpha
+            * e / 2
+            * Math.log((1 + e * sinPhy0)
+            / (1 - e * sinPhy0));
+    var Sa1 = Math.log(Math.tan(Math.PI / 4.0 - p.y / 2.0));
+    var Sa2 = this.e / 2.0
+            * Math.log((1 + this.e * Math.sin(p.y))
+            / (1 - this.e * Math.sin(p.y)));
+    var S = -this.alpha * (Sa1 + Sa2) + this.K;
+        // spheric latitude
+    var b = 2.0 * (Math.atan(Math.exp(S)) - Math.PI / 4.0);
+        // spheric longitude
+    var I = this.alpha * (p.x - this.lambda0);
+        // psoeudo equatorial rotation
+    var rotI = Math.atan(Math.sin(I)
+            / (Math.sin(this.b0) * Math.tan(b) +
+               Math.cos(this.b0) * Math.cos(I)));
+    var rotB = Math.asin(Math.cos(this.b0) * Math.sin(b) -
+                         Math.sin(this.b0) * Math.cos(b) * Math.cos(I));
+    p.y = this.R / 2.0
+            * Math.log((1 + Math.sin(rotB)) / (1 - Math.sin(rotB)))
+            + this.y0;
+    p.x = this.R * rotI + this.x0;
+    return p;
+    var Y = p.x - this.x0;
+    var X = p.y - this.y0;
+    var rotI = Y / this.R;
+    var rotB = 2 * (Math.atan(Math.exp(X / this.R)) - Math.PI / 4.0);
+    var b = Math.asin(Math.cos(this.b0) * Math.sin(rotB)
+            + Math.sin(this.b0) * Math.cos(rotB) * Math.cos(rotI));
+    var I = Math.atan(Math.sin(rotI)
+            / (Math.cos(this.b0) * Math.cos(rotI) - Math.sin(this.b0)
+            * Math.tan(rotB)));
+    var lambda = this.lambda0 + I / this.alpha;
+    var S = 0.0;
+    var phy = b;
+    var prevPhy = -1000.0;
+    var iteration = 0;
+    while (Math.abs(phy - prevPhy) > 0.0000001)
+      if (++iteration > 20)
+        return;
+      //S = Math.log(Math.tan(Math.PI / 4.0 + phy / 2.0));
+      S = 1.0
+              / this.alpha
+              * (Math.log(Math.tan(Math.PI / 4.0 + b / 2.0)) - this.K)
+              + this.e
+              + Math.asin(this.e * Math.sin(phy))
+              / 2.0));
+      prevPhy = phy;
+      phy = 2.0 * Math.atan(Math.exp(S)) - Math.PI / 2.0;
+    p.x = lambda;
+    p.y = phy;
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/stere.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/stere.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/stere.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,243 @@
+// Initialize the Stereographic projection
+Proj4js.Proj.stere = {
+  ssfn_: function(phit, sinphi, eccen) {
+  	sinphi *= eccen;
+  	return (Math.tan (.5 * (Proj4js.common.HALF_PI + phit)) * Math.pow((1. - sinphi) / (1. + sinphi), .5 * eccen));
+  TOL:	1.e-8,
+  NITER:	8,
+  CONV:	1.e-10,
+  S_POLE:	0,
+  N_POLE:	1,
+  OBLIQ:	2,
+  EQUIT:	3,
+  	this.phits = this.lat_ts ? this.lat_ts : Proj4js.common.HALF_PI;
+    var t = Math.abs(this.lat0);
+  	if ((Math.abs(t) - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  		this.mode = this.lat0 < 0. ? this.S_POLE : this.N_POLE;
+  	} else {
+  		this.mode = t > Proj4js.common.EPSLN ? this.OBLIQ : this.EQUIT;
+  	this.phits = Math.abs(this.phits);
+  	if (this.es) {
+  		var X;
+  		switch (this.mode) {
+  		case this.N_POLE:
+  		case this.S_POLE:
+  			if (Math.abs(this.phits - Proj4js.common.HALF_PI) < Proj4js.common.EPSLN) {
+  				this.akm1 = 2. * this.k0 / Math.sqrt(Math.pow(1+this.e,1+this.e)*Math.pow(1-this.e,1-this.e));
+  			} else {
+          t = Math.sin(this.phits);
+  				this.akm1 = Math.cos(this.phits) / Proj4js.common.tsfnz(this.e, this.phits, t);
+  				t *= this.e;
+  				this.akm1 /= Math.sqrt(1. - t * t);
+  			break;
+  		case this.EQUIT:
+  			this.akm1 = 2. * this.k0;
+  			break;
+  		case this.OBLIQ:
+  			t = Math.sin(this.lat0);
+  			X = 2. * Math.atan(this.ssfn_(this.lat0, t, this.e)) - Proj4js.common.HALF_PI;
+  			t *= this.e;
+  			this.akm1 = 2. * this.k0 * Math.cos(this.lat0) / Math.sqrt(1. - t * t);
+  			this.sinX1 = Math.sin(X);
+  			this.cosX1 = Math.cos(X);
+  			break;
+  	} else {
+  		case this.OBLIQ:
+  			this.sinph0 = Math.sin(this.lat0);
+  			this.cosph0 = Math.cos(this.lat0);
+  		case this.EQUIT:
+  			break;
+  		case this.S_POLE:
+  		case this.N_POLE:
+  			this.akm1 = Math.abs(this.phits - Proj4js.common.HALF_PI) >= Proj4js.common.EPSLN ?
+  			   Math.cos(this.phits) / Math.tan(Proj4js.common.FORTPI - .5 * this.phits) :
+  			   2. * this.k0 ;
+  			break;
+// Stereographic forward equations--mapping lat,long to x,y
+    var lon = p.x;
+    var lat = p.y;
+    var x, y
+    	var  sinphi, cosphi, coslam, sinlam;
+    	coslam = Math.cos(lon);
+    	sinlam = Math.sin(lon);
+    	case this.EQUIT:
+    		y = 1. + cosphi * coslam;
+    		if (y <= Proj4js.common.EPSLN) {
+          F_ERROR;
+        y = this.akm1 / y;
+    		x = y * cosphi * sinlam;
+        y *= sinphi;
+    		break;
+    	case this.OBLIQ:
+    		y = 1. + this.sinph0 * sinphi + this.cosph0 * cosphi * coslam;
+          F_ERROR;
+    		y *= this.cosph0 * sinphi - this.sinph0 * cosphi * coslam;
+    		break;
+    	case this.N_POLE:
+    		coslam = -coslam;
+    		lat = -lat;
+        //Note  no break here so it conitnues through S_POLE
+    	case this.S_POLE:
+    		if (Math.abs(lat - Proj4js.common.HALF_PI) < this.TOL) {
+          F_ERROR;
+        y = this.akm1 * Math.tan(Proj4js.common.FORTPI + .5 * lat)
+    		x = sinlam * y;
+    		y *= coslam;
+    		break;
+    } else {
+    	if (this.mode == this.OBLIQ || this.mode == this.EQUIT) {
+        X = 2. * Math.atan(this.ssfn_(lat, sinphi, this.e));
+    		sinX = Math.sin(X - Proj4js.common.HALF_PI);
+    		cosX = Math.cos(X);
+    	case this.OBLIQ:
+    		A = this.akm1 / (this.cosX1 * (1. + this.sinX1 * sinX + this.cosX1 * cosX * coslam));
+    		y = A * (this.cosX1 * sinX - this.sinX1 * cosX * coslam);
+    		x = A * cosX;
+    		break;
+    	case this.EQUIT:
+    		A = 2. * this.akm1 / (1. + cosX * coslam);
+    		y = A * sinX;
+    		x = A * cosX;
+    		break;
+    	case this.S_POLE:
+    		lat = -lat;
+    		coslam = - coslam;
+    		sinphi = -sinphi;
+    	case this.N_POLE:
+    		x = this.akm1 * Proj4js.common.tsfnz(this.e, lat, sinphi);
+    		y = - x * coslam;
+    		break;
+    	x = x * sinlam;
+    p.x = x*this.a + this.x0;
+    p.y = y*this.a + this.y0;
+    return p;
+//* Stereographic inverse equations--mapping x,y to lat/long
+    var x = (p.x - this.x0)/this.a;   /* descale and de-offset */
+    var y = (p.y - this.y0)/this.a;
+    var lon, lat
+    var cosphi, sinphi, tp=0.0, phi_l=0.0, rho, halfe=0.0, pi2=0.0;
+    var i;
+    	var  c, rh, sinc, cosc;
+      rh = Math.sqrt(x*x + y*y);
+      c = 2. * Math.atan(rh / this.akm1);
+    	sinc = Math.sin(c);
+    	cosc = Math.cos(c);
+    	lon = 0.;
+    	case this.EQUIT:
+    			lat = 0.;
+    		} else {
+    			lat = Math.asin(y * sinc / rh);
+    		if (cosc != 0. || x != 0.) lon = Math.atan2(x * sinc, cosc * rh);
+    		break;
+    	case this.OBLIQ:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(cosc * sinph0 + y * sinc * cosph0 / rh);
+        c = cosc - sinph0 * Math.sin(lat);
+    		if (c != 0. || x != 0.) {
+    			lon = Math.atan2(x * sinc * cosph0, c * rh);
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+    			lat = this.phi0;
+    		} else {
+    			lat = Math.asin(this.mode == this.S_POLE ? -cosc : cosc);
+    		lon = (x == 0. && y == 0.) ? 0. : Math.atan2(x, y);
+    		break;
+    } else {
+    	rho = Math.sqrt(x*x + y*y);
+    	case this.OBLIQ:
+    	case this.EQUIT:
+        tp = 2. * Math.atan2(rho * this.cosX1 , this.akm1);
+    		cosphi = Math.cos(tp);
+    		sinphi = Math.sin(tp);
+        if( rho == 0.0 ) {
+    		  phi_l = Math.asin(cosphi * this.sinX1);
+        } else {
+    		  phi_l = Math.asin(cosphi * this.sinX1 + (y * sinphi * this.cosX1 / rho));
+    		tp = Math.tan(.5 * (Proj4js.common.HALF_PI + phi_l));
+    		x *= sinphi;
+    		y = rho * this.cosX1 * cosphi - y * this.sinX1* sinphi;
+    		pi2 = Proj4js.common.HALF_PI;
+    		halfe = .5 * this.e;
+    		break;
+    	case this.N_POLE:
+    		y = -y;
+    	case this.S_POLE:
+        tp = - rho / this.akm1
+    		phi_l = Proj4js.common.HALF_PI - 2. * Math.atan(tp);
+    		pi2 = -Proj4js.common.HALF_PI;
+    		halfe = -.5 * this.e;
+    		break;
+    	for (i = this.NITER; i--; phi_l = lat) { //check this
+    		sinphi = this.e * Math.sin(phi_l);
+    		lat = 2. * Math.atan(tp * Math.pow((1.+sinphi)/(1.-sinphi), halfe)) - pi2;
+    		if (Math.abs(phi_l - lat) < this.CONV) {
+    			if (this.mode == this.S_POLE) lat = -lat;
+          p.x = lon;
+          p.y = lat
+    			return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/sterea.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/sterea.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/sterea.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,56 @@
+Proj4js.Proj.sterea = {
+  dependsOn : 'gauss',
+  init : function() {
+    Proj4js.Proj['gauss'].init.apply(this);
+    if (!this.rc) {
+      Proj4js.reportError("sterea:init:E_ERROR_0");
+      return;
+    this.sinc0 = Math.sin(this.phic0);
+    this.cosc0 = Math.cos(this.phic0);
+    this.R2 = 2.0 * this.rc;
+    if (!this.title) this.title = "Oblique Stereographic Alternative";
+    p.x = Proj4js.common.adjust_lon(p.x-this.long0); /* adjust del longitude */
+    Proj4js.Proj['gauss'].forward.apply(this, [p]);
+    sinc = Math.sin(p.y);
+    cosc = Math.cos(p.y);
+    cosl = Math.cos(p.x);
+    k = this.k0 * this.R2 / (1.0 + this.sinc0 * sinc + this.cosc0 * cosc * cosl);
+    p.x = k * cosc * Math.sin(p.x);
+    p.y = k * (this.cosc0 * sinc - this.sinc0 * cosc * cosl);
+    p.x = this.a * p.x + this.x0;
+    p.y = this.a * p.y + this.y0;
+    return p;
+    var lon,lat;
+    p.x = (p.x - this.x0) / this.a; /* descale and de-offset */
+    p.y = (p.y - this.y0) / this.a;
+    p.x /= this.k0;
+    p.y /= this.k0;
+    if ( (rho = Math.sqrt(p.x*p.x + p.y*p.y)) ) {
+      c = 2.0 * Math.atan2(rho, this.R2);
+      lat = Math.asin(cosc * this.sinc0 + p.y * sinc * this.cosc0 / rho);
+      lon = Math.atan2(p.x * sinc, rho * this.cosc0 * cosc - p.y * this.sinc0 * sinc);
+    } else {
+      lat = this.phic0;
+      lon = 0.;
+    p.x = lon;
+    p.y = lat;
+    Proj4js.Proj['gauss'].inverse.apply(this,[p]);
+    p.x = Proj4js.common.adjust_lon(p.x + this.long0); /* adjust longitude to CM */
+    return p;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/tmerc.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/tmerc.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/tmerc.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,141 @@
+NAME                            TRANSVERSE MERCATOR
+PURPOSE:	Transforms input longitude and latitude to Easting and
+		Northing for the Transverse Mercator projection.  The
+ALGORITHM REFERENCES
+1.  Snyder, John P., "Map Projections--A Working Manual", U.S. Geological
+    Survey Professional Paper 1395 (Supersedes USGS Bulletin 1532), United
+    State Government Printing Office, Washington D.C., 1987.
+2.  Snyder, John P. and Voxland, Philip M., "An Album of Map Projections",
+    U.S. Geological Survey Professional Paper 1453 , United State Government
+    Printing Office, Washington D.C., 1989.
+  Initialize Transverse Mercator projection
+Proj4js.Proj.tmerc = {
+    this.ml0 = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, this.lat0);
+    Transverse Mercator Forward  - long/lat to x/y
+    var lon = p.x;
+    var lat = p.y;
+    var delta_lon = Proj4js.common.adjust_lon(lon - this.long0); // Delta longitude
+    var con;    // cone constant
+    var x, y;
+    var sin_phi=Math.sin(lat);
+    var cos_phi=Math.cos(lat);
+    if (this.sphere) {  /* spherical form */
+      var b = cos_phi * Math.sin(delta_lon);
+      if ((Math.abs(Math.abs(b) - 1.0)) < .0000000001)  {
+        Proj4js.reportError("tmerc:forward: Point projects into infinity");
+        return(93);
+      } else {
+        x = .5 * this.a * this.k0 * Math.log((1.0 + b)/(1.0 - b));
+        con = Math.acos(cos_phi * Math.cos(delta_lon)/Math.sqrt(1.0 - b*b));
+        if (lat < 0) con = - con;
+        y = this.a * this.k0 * (con - this.lat0);
+    } else {
+      var al  = cos_phi * delta_lon;
+      var als = Math.pow(al,2);
+      var c   = this.ep2 * Math.pow(cos_phi,2);
+      var tq  = Math.tan(lat);
+      var t   = Math.pow(tq,2);
+      con = 1.0 - this.es * Math.pow(sin_phi,2);
+      var n   = this.a / Math.sqrt(con);
+      var ml  = this.a * Proj4js.common.mlfn(this.e0, this.e1, this.e2, this.e3, lat);
+      x = this.k0 * n * al * (1.0 + als / 6.0 * (1.0 - t + c + als / 20.0 * (5.0 - 18.0 * t + Math.pow(t,2) + 72.0 * c - 58.0 * this.ep2))) + this.x0;
+      y = this.k0 * (ml - this.ml0 + n * tq * (als * (0.5 + als / 24.0 * (5.0 - t + 9.0 * c + 4.0 * Math.pow(c,2) + als / 30.0 * (61.0 - 58.0 * t + Math.pow(t,2) + 600.0 * c - 330.0 * this.ep2))))) + this.y0;
+    p.x = x; p.y = y;
+    return p;
+  }, // tmercFwd()
+    Transverse Mercator Inverse  -  x/y to long/lat
+    var con, phi;  /* temporary angles       */
+    var delta_phi; /* difference between longitudes    */
+    var i;
+    var max_iter = 6;      /* maximun number of iterations */
+    var lat, lon;
+      var f = Math.exp(p.x/(this.a * this.k0));
+      var g = .5 * (f - 1/f);
+      var temp = this.lat0 + p.y/(this.a * this.k0);
+      var h = Math.cos(temp);
+      con = Math.sqrt((1.0 - h * h)/(1.0 + g * g));
+      lat = Math.asinz(con);
+      if (temp < 0)
+        lat = -lat;
+      if ((g == 0) && (h == 0)) {
+        lon = this.long0;
+      } else {
+        lon = Proj4js.common.adjust_lon(Math.atan2(g,h) + this.long0);
+    } else {    // ellipsoidal form
+      con = (this.ml0 + y / this.k0) / this.a;
+      phi = con;
+      for (i=0;;i++) {
+        delta_phi=((con + this.e1 * Math.sin(2.0*phi) - this.e2 * Math.sin(4.0*phi) + this.e3 * Math.sin(6.0*phi)) / this.e0) - phi;
+        phi += delta_phi;
+        if (Math.abs(delta_phi) <= Proj4js.common.EPSLN) break;
+        if (i >= max_iter) {
+          Proj4js.reportError("tmerc:inverse: Latitude failed to converge");
+          return(95);
+      } // for()
+      if (Math.abs(phi) < Proj4js.common.HALF_PI) {
+        // sincos(phi, &sin_phi, &cos_phi);
+        var sin_phi=Math.sin(phi);
+        var cos_phi=Math.cos(phi);
+        var tan_phi = Math.tan(phi);
+        var cs = Math.pow(c,2);
+        var t = Math.pow(tan_phi,2);
+        var ts = Math.pow(t,2);
+        var r = n * (1.0 - this.es) / con;
+        var d = x / (n * this.k0);
+        var ds = Math.pow(d,2);
+        lat = phi - (n * tan_phi * ds / r) * (0.5 - ds / 24.0 * (5.0 + 3.0 * t + 10.0 * c - 4.0 * cs - 9.0 * this.ep2 - ds / 30.0 * (61.0 + 90.0 * t + 298.0 * c + 45.0 * ts - 252.0 * this.ep2 - 3.0 * cs)));
+        lon = Proj4js.common.adjust_lon(this.long0 + (d * (1.0 - ds / 6.0 * (1.0 + 2.0 * t + c - ds / 20.0 * (5.0 - 2.0 * c + 28.0 * t - 3.0 * cs + 8.0 * this.ep2 + 24.0 * ts))) / cos_phi));
+      } else {
+        lat = Proj4js.common.HALF_PI * Proj4js.common.sign(y);
+        lon = this.long0;
+    p.x = lon;
+    p.y = lat;
+    return p;
+  } // tmercInv()
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/utm.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/utm.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/utm.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,43 @@
+Proj4js.Proj.utm = {
+  dependsOn : 'tmerc',
+    if (!this.zone) {
+      Proj4js.reportError("utm:init: zone must be specified for UTM");
+      return;
+    this.lat0 = 0.0;
+    this.long0 = ((6 * Math.abs(this.zone)) - 183) * Proj4js.common.D2R;
+    this.x0 = 500000.0;
+    this.y0 = this.utmSouth ? 10000000.0 : 0.0;
+    this.k0 = 0.9996;
+    Proj4js.Proj['tmerc'].init.apply(this);
+    this.forward = Proj4js.Proj['tmerc'].forward;
+    this.inverse = Proj4js.Proj['tmerc'].inverse;
Added: trunk/mapbender/http/extensions/proj4js/lib/projCode/vandg.js
--- trunk/mapbender/http/extensions/proj4js/lib/projCode/vandg.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/lib/projCode/vandg.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,137 @@
+NAME                    VAN DER GRINTEN
+PURPOSE:	Transforms input Easting and Northing to longitude and
+		latitude for the Van der Grinten projection.  The
+		Easting and Northing must be in meters.  The longitude
+		and latitude values will be returned in radians.
+PROGRAMMER              DATE
+This function was adapted from the Van Der Grinten projection code
+(FORTRAN) in the General Cartographic Transformation Package software
+Proj4js.Proj.vandg = {
+/* Initialize the Van Der Grinten projection
+	forward: function(p) {
+		var lon=p.x;
+		var lat=p.y;
+		/* Forward equations
+		var dlon = Proj4js.common.adjust_lon(lon - this.long0);
+		var x,y;
+		if (Math.abs(lat) <= Proj4js.common.EPSLN) {
+			x = this.x0  + this.R * dlon;
+			y = this.y0;
+		var theta = Proj4js.common.asinz(2.0 * Math.abs(lat / Proj4js.common.PI));
+		if ((Math.abs(dlon) <= Proj4js.common.EPSLN) || (Math.abs(Math.abs(lat) - Proj4js.common.HALF_PI) <= Proj4js.common.EPSLN)) {
+			x = this.x0;
+			if (lat >= 0) {
+				y = this.y0 + Proj4js.common.PI * this.R * Math.tan(.5 * theta);
+			} else {
+				y = this.y0 + Proj4js.common.PI * this.R * - Math.tan(.5 * theta);
+			//  return(OK);
+		var al = .5 * Math.abs((Proj4js.common.PI / dlon) - (dlon / Proj4js.common.PI));
+		var asq = al * al;
+		var sinth = Math.sin(theta);
+		var costh = Math.cos(theta);
+		var g = costh / (sinth + costh - 1.0);
+		var gsq = g * g;
+		var m = g * (2.0 / sinth - 1.0);
+		var msq = m * m;
+		var con = Proj4js.common.PI * this.R * (al * (g - msq) + Math.sqrt(asq * (g - msq) * (g - msq) - (msq + asq) * (gsq - msq))) / (msq + asq);
+		if (dlon < 0) {
+		 con = -con;
+		x = this.x0 + con;
+		con = Math.abs(con / (Proj4js.common.PI * this.R));
+		if (lat >= 0) {
+		 y = this.y0 + Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		} else {
+		 y = this.y0 - Proj4js.common.PI * this.R * Math.sqrt(1.0 - con * con - 2.0 * al * con);
+		p.x = x;
+		p.y = y;
+		return p;
+/* Van Der Grinten inverse equations--mapping x,y to lat/long
+	inverse: function(p) {
+		var dlon;
+		var xx,yy,xys,c1,c2,c3;
+		var al,asq;
+		var a1;
+		var m1;
+		var con;
+		var th1;
+		var d;
+		/* inverse equations
+		p.x -= this.x0;
+		p.y -= this.y0;
+		con = Proj4js.common.PI * this.R;
+		xx = p.x / con;
+		yy =p.y / con;
+		xys = xx * xx + yy * yy;
+		c1 = -Math.abs(yy) * (1.0 + xys);
+		c2 = c1 - 2.0 * yy * yy + xx * xx;
+		c3 = -2.0 * c1 + 1.0 + 2.0 * yy * yy + xys * xys;
+		d = yy * yy / c3 + (2.0 * c2 * c2 * c2 / c3 / c3 / c3 - 9.0 * c1 * c2 / c3 /c3) / 27.0;
+		a1 = (c1 - c2 * c2 / 3.0 / c3) / c3;
+		m1 = 2.0 * Math.sqrt( -a1 / 3.0);
+		con = ((3.0 * d) / a1) / m1;
+		if (Math.abs(con) > 1.0) {
+			if (con >= 0.0) {
+				con = 1.0;
+			} else {
+				con = -1.0;
+		th1 = Math.acos(con) / 3.0;
+		if (p.y >= 0) {
+			lat = (-m1 *Math.cos(th1 + Proj4js.common.PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		} else {
+			lat = -(-m1 * Math.cos(th1 + PI / 3.0) - c2 / 3.0 / c3) * Proj4js.common.PI;
+		if (Math.abs(xx) < Proj4js.common.EPSLN) {
+			lon = this.long0;
+		lon = Proj4js.common.adjust_lon(this.long0 + Proj4js.common.PI * (xys - 1.0 + Math.sqrt(1.0 + 2.0 * (xx * xx - yy * yy) + xys * xys)) / 2.0 / xx);
+		p.x=lon;
+		p.y=lat;
+		return p;
Added: trunk/mapbender/http/extensions/proj4js/test/base.css
--- trunk/mapbender/http/extensions/proj4js/test/base.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/test/base.css	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,29 @@
+#footer {
+  margin-top: 20px;
+  border-top: 1px solid #eee;
+  padding: 10px;
+body {
+ font-family:Verdana;
+#header {
+  background: #9D9FA1;
+  color: #FFFFFF;
+  font-family: "Trebuchet MS", Helvetica, Arial, sans-serif;
+  font-size: 18px;
+  text-shadow: 2px 2px 3px gray;
+  height: 3em;
+  padding: 4px 16px 0px 16px;
+  vertical-align: top;
+  margin: -10px -5px 0px -5px;
+  border-bottom: 10px solid #e9eef9;
+#header h1{margin-top: 0px;font-weight:normal;}
+#navbar { background-color: #eee; margin: 0px -5px 10px -5px; padding: 10px;  }
+td {
+  font-size: 75%;
+td.error {
+  background-color: red;
Added: trunk/mapbender/http/extensions/proj4js/test/index.html
--- trunk/mapbender/http/extensions/proj4js/test/index.html	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/test/index.html	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,34 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+  <link href="base.css" type="text/css" rel="stylesheet"/>
+  <title>Proj4js Test Page</title>
+  <script src="../lib/proj4js.js"></script>
+  <script src="../lib/defs/EPSG42304.js"></script>
+  <script src="../lib/defs/EPSG25833.js"></script>
+  <script src="../lib/defs/EPSG27563.js"></script>
+  <script src="testdata.js"></script>
+  <script src="runtests.js"></script>
+</head>
+<body onload="runTests()">
+  <div id="header">
+    <h1>Proj4js test page</h1>
+  </div>
+  <div id="navbar">
+    <a href="http://trac.osgeo.org/proj4js">Proj4js Wiki/Trac</a> |
+    <a href="http://wiki.osgeo.org/wiki/MetaCRS">OSGeo MetaCRS</a> |
+    <a href="http://spatialreference.org/">spatialreference.org</a> |
+    <a href="http://communitymapbuilder.org/">MapBuilder</a> |
+    <a href="http://openlayers.org/">OpenLayers</a> |
+  </div>
+  <table id="testResult" border="1">
+      <tr>
+        <th>projection</th>
+        <th>class</th>
+        <th colspan="3">forward (m)</th>
+        <th colspan="3">inverse (dd)</th>
+      </tr>
+  </table>
+</body>
+</html>
Added: trunk/mapbender/http/extensions/proj4js/test/runtests.js
--- trunk/mapbender/http/extensions/proj4js/test/runtests.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/test/runtests.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,83 @@
+/* Loop through the test points and create a Proj object for each
+function runTests() {
+  for (var i=0; i < Proj4js.testPoints.length; ++i) {
+    var test = Proj4js.testPoints[i];
+    var proj = new Proj4js.Proj(test.code);
+    checkProjLoaded.call(proj, test);
+/* a timer that waits for the readyToUse flag to be set.  This gets called in
+ * the context of the Proj4js.Proj object
+function checkProjLoaded(test) {
+    if (!this.readyToUse) {
+      window.setTimeout(Proj4js.bind(checkProjLoaded, this, test), 500);
+    } else {
+      showResults(this, test);
+/* a callback function to run the test for this test point since we are using
+ the dynamic load capabilities in the test page
+function showResults(proj, test) {
+  //var test = proj.testPoint;
+  var xyEPSLN = 1.0e-2;
+  var llEPSLN = 1.0e-6;
+    var row = document.createElement('tr');
+    var td = document.createElement('td');
+    td.innerHTML = test.code;
+    row.appendChild(td);
+    td.innerHTML = proj.projName;
+    //transform from lon/lat to projected x/y and cmopare
+    var xyResult = Proj4js.transform(Proj4js.WGS84, proj, new Proj4js.Point(test.ll));
+    if (xyResult) {
+      var deltaX = Math.abs(xyResult.x - test.xy[0]);
+      var deltaY = Math.abs(xyResult.y - test.xy[1]);
+      td = document.createElement('td');
+      td.innerHTML = "in:"+test.ll[0]+","+test.ll[1];
+      td.innerHTML = "out:"+xyResult.x+","+xyResult.y;
+      td.innerHTML = "dx:"+deltaX+ " dy:"+deltaY;
+      if ( deltaX>xyEPSLN || deltaY>xyEPSLN ) td.style.backgroundColor='red';
+    } else {
+      td.innerHTML = "proj undefined";
+    //transform from map x/y to lon/lat and compare
+    var llResult = Proj4js.transform(proj, Proj4js.WGS84, new Proj4js.Point(test.xy));
+    if (llResult) {
+      var deltaX = Math.abs(llResult.x - test.ll[0]);
+      var deltaY = Math.abs(llResult.y - test.ll[1]);
+      td.innerHTML = "in:"+test.xy[0]+","+test.xy[1];
+      td.innerHTML = "out:"+llResult.x+","+llResult.y;
+      if ( deltaX>llEPSLN || deltaY>llEPSLN ) td.style.backgroundColor='red';
+    } else {
+    var testTable = document.getElementById('testResult');
+    testTable.tBodies[0].appendChild(row);
Added: trunk/mapbender/http/extensions/proj4js/test/testdata.js
--- trunk/mapbender/http/extensions/proj4js/test/testdata.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/test/testdata.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,110 @@
+// a set of points in map XY and Lon/Lat that are supposed to correspond between
+// forward and invers transforms
+Proj4js.testPoints = [
+  {code: 'EPSG:3573',
+    xy: [2923052.02009, 1054885.46559],
+    ll: [9.84375, 61.875]
+  {code: 'EPSG:54009',
+    xy: [-10617602.79013849,4108337.84708608,0.00000000 ],
+    ll: [-119,34,0]
+  {code: 'EPSG:31466',
+    xy: [2547685.01212,5699155.7345],
+    ll: [6.685,51.425]
+  {code: 'EPSG:54029',
+    xy: [1094702.50,6496789.74,-6468.21],
+    ll: [11.0, 53.0,0.0]
+  {code: 'EPSG:54008',
+    xy: [738509.49,5874620.38],
+    ll: [11.0, 53.0]
+  {code: 'EPSG:29100',
+    xy: [5110899.06,10552971.81,-22.99],
+    ll: [-53.0, 5.0,0.0]    /**
+  {code: 'EPSG:2057',
+    xy: [-11608322.26,18282612.23,-281.67],
+    xy: [804759.21,6164983.82,-13598.03],
+    ll: [11.0, 53.0, 0.0]
+  {code: 'EPSG:54003',
+    xy: [1223145.57,6491218.13,-6468.21],
+    ll: [11.0, 53.0]
+  {code: 'EPSG:3035',
+    xy: [4388138.60, 3321736.46],
+    ll: [11.0, 53.0]
+  {code: 'EPSG:102026',
+    xy: [3000242.40, 5092492.64],
+    ll: [40.0, 40.0]
+  {code: 'EPSG:54032',
+    xy: [-4024426.19, 6432026.98],
+    ll: [-127.0, 52.11]
+  {code: 'EPSG:3153',
+    xy: [931625.91, 789252.65],
+  {code: 'EPSG:27492',
+    xy: [25260.493584, -9579.245052],
+    ll: [-7.84, 39.58]
+  {code: 'EPSG:27700',
+    xy: [343733.14, 612144.53, -51.89],
+    ll: [-2.89, 55.4, 0]
+  {code: 'EPSG:32615',
+    xy: [500000, 4649776.22482],
+    ll: [-93, 42]
+  {code: 'EPSG:32612',
+    xy: [383357.429537, 6684599.06392],
+    ll: [-113.109375, 60.28125]
+  {code: 'EPSG:3031',
+    xy: [-992481.633786, 628482.06328],
+    ll: [-57.65625, -79.21875]
+  {code: 'EPSG:31285',
+    xy: [450055.70, 5262356.33],
+    ll: [13.33333333333, 47.5]
+  {code: 'EPSG:27563',
+    xy: [653704.865208, 176887.660037],
+    ll: [3.005, 43.89]
+  {code: 'EPSG:2736',
+    xy: [603933.40,	7677505.64],
+    ll: [34.0, -21.0]
+  {code: 'EPSG:42304',
+    xy: [-358185.267976, -40271.099023],
+    ll: [-99.84375, 48.515625]
+  {code: 'google',
+    xy: [-8531595.34908, 6432756.94421],
+    ll: [-76.640625, 49.921875]
+  {code: 'EPSG:28992',
+    xy: [148312.15,	457804.79, 698.48],
+    ll: [5.29, 52.11]
+  {code: 'EPSG:2403',
+    xy: [27500000.00,	4198690.08, -109.02],
+    ll: [81, 37.92, 0]      ****/
\ No newline at end of file
Added: trunk/mapbender/http/extensions/proj4js/tools/README.txt
--- trunk/mapbender/http/extensions/proj4js/tools/README.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/README.txt	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,7 @@
+This directory contains tools used in the packaging or deployment of proj4js.
+Javascript minimizing tools:
+ * jsmin.c, jsmin.py:
+   jsmin.py is a direct translation of the jsmin.c code into Python. jsmin.py
+   will therefore run anyplace Python runs... but at significantly slower speed.
Added: trunk/mapbender/http/extensions/proj4js/tools/catalogues/CRS
--- trunk/mapbender/http/extensions/proj4js/tools/catalogues/CRS	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/catalogues/CRS	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,2 @@
+# WGS 84 longitude - latitude
+<84> +title=WGS 84 longitude-latitude +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs  <>
Added: trunk/mapbender/http/extensions/proj4js/tools/catalogues/EPSG
--- trunk/mapbender/http/extensions/proj4js/tools/catalogues/EPSG	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/catalogues/EPSG	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,220 @@
+# CH1903
+<4149> +title=CH1903 +proj=longlat +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs  <>
+# CH1903+
+<4150> +title=CH1903plus +proj=longlat +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs  <>
+# CHTRF95
+<4151> +title=CHTRF95 +proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# RGF93
+<4171> +title=RGF93 +proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# ED50
+<4230> +title=ED50 +proj=longlat +ellps=intl +no_defs  <>
+# Guyane Francaise
+<4235> +title=Guyane Francaise +proj=longlat +ellps=intl +no_defs  <>
+# ETRS89
+<4258> +title=ETRS89 +proj=longlat +ellps=GRS80 +no_defs  <>
+# NTF
+<4275> +title=NTF +proj=longlat +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +no_defs  <>
+# WGS 72
+<4322> +title=WGS 72 +proj=longlat +ellps=WGS72 +no_defs  <>
+# WGS 84
+<4326> +title=WGS 84 +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs  <>
+# Fort Marigot
+<4621> +title=Fort Marigot +proj=longlat +ellps=intl +towgs84=137,248,-430,0,0,0,0 +no_defs  <>
+# Guadeloupe 1948
+<4622> +title=Guadeloupe 1948 +proj=longlat +ellps=intl +no_defs  <>
+# CSG67
+<4623> +title=CSG67 +proj=longlat +ellps=intl +towgs84=-186,230,110,0,0,0,0 +no_defs  <>
+# RGFG95
+<4624> +title=RGFG95 +proj=longlat +ellps=GRS80 +towgs84=2,2,-2,0,0,0,0 +no_defs  <>
+# Martinique 1938
+<4625> +title=Martinique 1938 +proj=longlat +ellps=intl +no_defs  <>
+# Reunion 1947
+<4626> +title=Reunion 1947 +proj=longlat +ellps=intl +no_defs  <>
+# RGR92
+<4627> +title=RGR92 +proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# Tahiti 52
+<4628> +title=Tahiti 52 +proj=longlat +ellps=intl +towgs84=162,117,154,0,0,0,0 +no_defs  <>
+# Tahaa 54
+<4629> +title=Tahaa 54 +proj=longlat +ellps=intl +no_defs  <>
+# IGN72 Nuku Hiva
+<4630> +title=IGN72 Nuku Hiva +proj=longlat +ellps=intl +no_defs  <>
+# Combani 1950
+<4632> +title=Combani 1950 +proj=longlat +ellps=intl +towgs84=-382,-59,-262,0,0,0,0 +no_defs  <>
+# IGN56 Lifou
+<4633> +title=IGN56 Lifou +proj=longlat +ellps=intl +no_defs  <>
+# IGN72 Grand Terre
+<4634> +title=IGN72 Grand Terre +proj=longlat +ellps=intl +no_defs  <>
+# Perroud 1950
+<4637> +title=Perroud 1950 +proj=longlat +ellps=intl +towgs84=325,154,172,0,0,0,0 +no_defs  <>
+# Saint Pierre et Miquelon 1950
+<4638> +title=Saint Pierre et Miquelon 1950 +proj=longlat +ellps=clrk66 +towgs84=30,430,368,0,0,0,0 +no_defs  <>
+# RRAF 1991
+<4640> +title=RRAF 1991 +proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# IGN53 Mare
+<4641> +title=IGN53 Mare +proj=longlat +ellps=intl +no_defs  <>
+# RGNC 1991
+<4645> +title=RGNC 1991 +proj=longlat +ellps=intl +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# IGN72 Grande Terre
+<4662> +title=IGN72 Grande Terre +proj=longlat +ellps=intl +no_defs  <>
+# IGN63 Hiva Oa
+<4689> +title=IGN63 Hiva Oa +proj=longlat +ellps=intl +no_defs  <>
+# Tahiti 79
+<4690> +title=Tahiti 79 +proj=longlat +ellps=intl +no_defs  <>
+# Moorea 87
+<4691> +title=Moorea 87 +proj=longlat +ellps=intl +towgs84=215.525,149.593,176.229,-3.2624,-1.692,-1.1571,10.4773 +no_defs  <>
+# Maupiti 83
+<4692> +title=Maupiti 83 +proj=longlat +ellps=intl +towgs84=217.037,86.959,23.956,0,0,0,0 +no_defs  <>
+# IGN 1962 Kerguelen
+<4698> +title=IGN 1962 Kerguelen +proj=longlat +ellps=intl +towgs84=145,-187,103,0,0,0,0 +no_defs  <>
+# RGNC91-93
+<4749> +title=RGNC91-93 +proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs  <>
+# ST87 Ouvea
+<4750> +title=ST87 Ouvea +proj=longlat +ellps=WGS84 +towgs84=-56.263,16.136,-22.856,0,0,0,0 +no_defs  <>
+# NTF (Paris)
+<4807> +title=NTF (Paris) +proj=longlat +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +no_defs  <>
+# CH1903+ / LV95
+<2056> +title=CH1903+ / LV95 +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333 +x_0=2600000 +y_0=1200000 +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +units=m +no_defs  <>
+# RGF93 / Lambert-93
+<2154> +title=RGF93 / Lambert-93 +proj=lcc +lat_1=49 +lat_2=44 +lat_0=46.5 +lon_0=3 +x_0=700000 +y_0=6600000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# ETRS89 / TM 30 NE
+<2213> +title=ETRS89 / TM 30 NE +proj=tmerc +lat_0=0 +lon_0=30 +k=0.9996 +x_0=500000 +y_0=0 +ellps=GRS80 +units=m +no_defs  <>
+# Fort Marigot / UTM zone 20N
+<2969> +title=Fort Marigot / UTM zone 20N +proj=utm +zone=20 +ellps=intl +towgs84=137,248,-430,0,0,0,0 +units=m +no_defs  <>
+# Guadeloupe 1948 / UTM zone 20N
+<2970> +title=Guadeloupe 1948 / UTM zone 20N +proj=utm +zone=20 +ellps=intl +units=m +no_defs  <>
+# CSG67 / UTM zone 22N
+<2971> +title=CSG67 / UTM zone 22N +proj=utm +zone=22 +ellps=intl +towgs84=-186,230,110,0,0,0,0 +units=m +no_defs  <>
+# RGFG95 / UTM zone 22N
+<2972> +title=RGFG95 / UTM zone 22N +proj=utm +zone=22 +ellps=GRS80 +towgs84=2,2,-2,0,0,0,0 +units=m +no_defs  <>
+# Martinique 1938 / UTM zone 20N
+<2973> +title=Martinique 1938 / UTM zone 20N +proj=utm +zone=20 +ellps=intl +units=m +no_defs  <>
+# RGR92 / UTM zone 40S
+<2975> +title=RGR92 / UTM zone 40S +proj=utm +zone=40 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# Tahiti 52 / UTM zone 6S
+<2976> +title=Tahiti 52 / UTM zone 6S +proj=utm +zone=6 +south +ellps=intl +towgs84=162,117,154,0,0,0,0 +units=m +no_defs  <>
+# Tahaa 54 / UTM zone 5S
+<2977> +title=Tahaa 54 / UTM zone 5S +proj=utm +zone=5 +south +ellps=intl +units=m +no_defs  <>
+# IGN72 Nuku Hiva / UTM zone 7S
+<2978> +title=IGN72 Nuku Hiva / UTM zone 7S +proj=utm +zone=7 +south +ellps=intl +units=m +no_defs  <>
+# Combani 1950 / UTM zone 38S
+<2980> +title=Combani 1950 / UTM zone 38S +proj=utm +zone=38 +south +ellps=intl +towgs84=-382,-59,-262,0,0,0,0 +units=m +no_defs  <>
+# IGN56 Lifou / UTM zone 58S
+<2981> +title=IGN56 Lifou / UTM zone 58S +proj=utm +zone=58 +south +ellps=intl +units=m +no_defs  <>
+# IGN72 Grand Terre / UTM zone 58S (deprecated)
+<2982> +title=IGN72 Grand Terre / UTM zone 58S (deprecated) +proj=utm +zone=58 +south +ellps=intl +units=m +no_defs  <>
+# RGNC 1991 / Lambert New Caledonia (deprecated)
+<2984> +title=RGNC 1991 / Lambert New Caledonia (deprecated) +proj=lcc +lat_1=-20.66666666666667 +lat_2=-22.33333333333333 +lat_0=-21.5 +lon_0=166 +x_0=400000 +y_0=300000 +ellps=intl +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# Saint Pierre et Miquelon 1950 / UTM zone 21N
+<2987> +title=Saint Pierre et Miquelon 1950 / UTM zone 21N +proj=utm +zone=21 +ellps=clrk66 +towgs84=30,430,368,0,0,0,0 +units=m +no_defs  <>
+# RRAF 1991 / UTM zone 20N
+<2989> +title=RRAF 1991 / UTM zone 20N +proj=utm +zone=20 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# Reunion 1947 / TM Reunion (deprecated)
+<2990> +title=Reunion 1947 / TM Reunion (deprecated) +proj=tmerc +lat_0=-21.11666666666667 +lon_0=55.53333333333333 +k=1 +x_0=50000 +y_0=160000 +ellps=intl +units=m +no_defs  <>
+# IGN53 Mare / UTM zone 58S
+<2995> +title=IGN53 Mare / UTM zone 58S +proj=utm +zone=58 +south +ellps=intl +units=m +no_defs  <>
+# ETRS89 / ETRS-LCC
+<3034> +title=ETRS89 / ETRS-LCC +proj=lcc +lat_1=35 +lat_2=65 +lat_0=52 +lon_0=10 +x_0=4000000 +y_0=2800000 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / ETRS-LAEA
+<3035> +title=ETRS89 / ETRS-LAEA +proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / ETRS-TM30
+<3042> +title=ETRS89 / ETRS-TM30 +proj=utm +zone=30 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / ETRS-TM31
+<3043> +title=ETRS89 / ETRS-TM31 +proj=utm +zone=31 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / ETRS-TM32
+<3044> +title=ETRS89 / ETRS-TM32 +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs  <>
+# IGN72 Grande Terre / UTM zone 58S
+<3060> +title=IGN72 Grande Terre / UTM zone 58S +proj=utm +zone=58 +south +ellps=intl +units=m +no_defs  <>
+# RGNC91-93 / Lambert New Caledonia
+<3163> +title=RGNC91-93 / Lambert New Caledonia +proj=lcc +lat_1=-20.66666666666667 +lat_2=-22.33333333333333 +lat_0=-21.5 +lon_0=166 +x_0=400000 +y_0=300000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# ST87 Ouvea / UTM zone 58S
+<3164> +title=ST87 Ouvea / UTM zone 58S +proj=utm +zone=58 +south +ellps=WGS84 +towgs84=-56.263,16.136,-22.856,0,0,0,0 +units=m +no_defs  <>
+# NEA74 Noumea / Noumea Lambert
+<3165> +title=NEA74 Noumea / Noumea Lambert +proj=lcc +lat_1=-22.24469175 +lat_2=-22.29469175 +lat_0=-22.26969175 +lon_0=166.44242575 +x_0=0.66 +y_0=1.02 +ellps=intl +units=m +no_defs  <>
+# NEA74 Noumea / Noumea Lambert 2
+<3166> +title=NEA74 Noumea / Noumea Lambert 2 +proj=lcc +lat_1=-22.24472222222222 +lat_2=-22.29472222222222 +lat_0=-22.26972222222222 +lon_0=166.4425 +x_0=8.313000000000001 +y_0=-2.354 +ellps=intl +units=m +no_defs  <>
+# RGNC91-93 / UTM zone 57S
+<3169> +title=RGNC91-93 / UTM zone 57S +proj=utm +zone=57 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# RGNC91-93 / UTM zone 58S
+<3170> +title=RGNC91-93 / UTM zone 58S +proj=utm +zone=58 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# RGNC91-93 / UTM zone 59S
+<3171> +title=RGNC91-93 / UTM zone 59S +proj=utm +zone=59 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs  <>
+# IGN53 Mare / UTM zone 59S
+<3172> +title=IGN53 Mare / UTM zone 59S +proj=utm +zone=59 +south +ellps=intl +units=m +no_defs  <>
+# RGPF / UTM zone 5S
+<3296> +title=RGPF / UTM zone 5S +proj=utm +zone=5 +south +ellps=GRS80 +units=m +no_defs  <>
+# RGPF / UTM zone 6S
+<3297> +title=RGPF / UTM zone 6S +proj=utm +zone=6 +south +ellps=GRS80 +units=m +no_defs  <>
+# RGPF / UTM zone 7S
+<3298> +title=RGPF / UTM zone 7S +proj=utm +zone=7 +south +ellps=GRS80 +units=m +no_defs  <>
+# RGPF / UTM zone 8S
+<3299> +title=RGPF / UTM zone 8S +proj=utm +zone=8 +south +ellps=GRS80 +units=m +no_defs  <>
+# IGN63 Hiva Oa / UTM zone 7S
+<3302> +title=IGN63 Hiva Oa / UTM zone 7S +proj=utm +zone=7 +south +ellps=intl +units=m +no_defs  <>
+# Fatu Iva 72 / UTM zone 7S
+<3303> +title=Fatu Iva 72 / UTM zone 7S +proj=utm +zone=7 +south +ellps=intl +towgs84=347.103,1078.12,2623.92,-33.8875,70.6773,-9.3943,186.074 +units=m +no_defs  <>
+# Tahiti 79 / UTM zone 6S
+<3304> +title=Tahiti 79 / UTM zone 6S +proj=utm +zone=6 +south +ellps=intl +units=m +no_defs  <>
+# Moorea 87 / UTM zone 6S
+<3305> +title=Moorea 87 / UTM zone 6S +proj=utm +zone=6 +south +ellps=intl +towgs84=215.525,149.593,176.229,-3.2624,-1.692,-1.1571,10.4773 +units=m +no_defs  <>
+# Maupiti 83 / UTM zone 5S
+<3306> +title=Maupiti 83 / UTM zone 5S +proj=utm +zone=5 +south +ellps=intl +towgs84=217.037,86.959,23.956,0,0,0,0 +units=m +no_defs  <>
+# CSG67 / UTM zone 21N
+<3312> +title=CSG67 / UTM zone 21N +proj=utm +zone=21 +ellps=intl +towgs84=-186,230,110,0,0,0,0 +units=m +no_defs  <>
+# RGFG95 / UTM zone 21N
+<3313> +title=RGFG95 / UTM zone 21N +proj=utm +zone=21 +ellps=GRS80 +towgs84=2,2,-2,0,0,0,0 +units=m +no_defs  <>
+# IGN 1962 Kerguelen / UTM zone 42S
+<3336> +title=IGN 1962 Kerguelen / UTM zone 42S +proj=utm +zone=42 +south +ellps=intl +towgs84=145,-187,103,0,0,0,0 +units=m +no_defs  <>
+# WGS 84 / World Mercator
+<3395> +title=WGS 84 / World Mercator +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
+<3727> +title=Reunion 1947 / TM Reunion +proj=tmerc +lat_0=-21.11666666666667 +lon_0=55.53333333333333 +k=1 +x_0=160000 +y_0=50000 +ellps=intl +units=m +no_defs  <>
+# CH1903 / LV03
+<21781> +title=CH1903 / LV03 +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333 +x_0=600000 +y_0=200000 +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +units=m +no_defs  <>
+# ETRS89 / UTM zone 30N
+<25830> +title=ETRS89 / UTM zone 30N +proj=utm +zone=30 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / UTM zone 31N
+<25831> +title=ETRS89 / UTM zone 31N +proj=utm +zone=31 +ellps=GRS80 +units=m +no_defs  <>
+# ETRS89 / UTM zone 32N
+<25832> +title=ETRS89 / UTM zone 32N +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs  <>
+# NTF (Paris) / Lambert Nord France
+<27561> +title=NTF (Paris) / Lambert Nord France +proj=lcc +lat_1=49.50000000000001 +lat_0=49.50000000000001 +lon_0=0 +k_0=0.999877341 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert Centre France
+<27562> +title=NTF (Paris) / Lambert Centre France +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert Sud France
+<27563> +title=NTF (Paris) / Lambert Sud France +proj=lcc +lat_1=44.10000000000001 +lat_0=44.10000000000001 +lon_0=0 +k_0=0.9998774990000001 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert Corse
+<27564> +title=NTF (Paris) / Lambert Corse +proj=lcc +lat_1=42.16500000000001 +lat_0=42.16500000000001 +lon_0=0 +k_0=0.9999447100000001 +x_0=234.358 +y_0=185861.369 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert zone I
+<27571> +title=NTF (Paris) / Lambert zone I +proj=lcc +lat_1=49.50000000000001 +lat_0=49.50000000000001 +lon_0=0 +k_0=0.999877341 +x_0=600000 +y_0=1200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert zone II
+<27572> +title=NTF (Paris) / Lambert zone II +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert zone III
+<27573> +title=NTF (Paris) / Lambert zone III +proj=lcc +lat_1=44.10000000000001 +lat_0=44.10000000000001 +lon_0=0 +k_0=0.9998774990000001 +x_0=600000 +y_0=3200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Lambert zone IV
+<27574> +title=NTF (Paris) / Lambert zone IV +proj=lcc +lat_1=42.16500000000001 +lat_0=42.16500000000001 +lon_0=0 +k_0=0.9999447100000001 +x_0=234.358 +y_0=4185861.369 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / France I (deprecated)
+<27581> +title=NTF (Paris) / France I (deprecated) +proj=lcc +lat_1=49.50000000000001 +lat_0=49.50000000000001 +lon_0=0 +k_0=0.999877341 +x_0=600000 +y_0=1200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / France II (deprecated)
+<27582> +title=NTF (Paris) / France II (deprecated) +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / France III (deprecated)
+<27583> +title=NTF (Paris) / France III (deprecated) +proj=lcc +lat_1=44.10000000000001 +lat_0=44.10000000000001 +lon_0=0 +k_0=0.9998774990000001 +x_0=600000 +y_0=3200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / France IV (deprecated)
+<27584> +title=NTF (Paris) / France IV (deprecated) +proj=lcc +lat_1=42.16500000000001 +lat_0=42.16500000000001 +lon_0=0 +k_0=0.9999447100000001 +x_0=234.358 +y_0=4185861.369 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Nord France (deprecated)
+<27591> +title=NTF (Paris) / Nord France (deprecated) +proj=lcc +lat_1=49.50000000000001 +lat_0=49.50000000000001 +lon_0=0 +k_0=0.999877341 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Centre France (deprecated)
+<27592> +title=NTF (Paris) / Centre France (deprecated) +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Sud France (deprecated)
+<27593> +title=NTF (Paris) / Sud France (deprecated) +proj=lcc +lat_1=44.10000000000001 +lat_0=44.10000000000001 +lon_0=0 +k_0=0.9998774990000001 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# NTF (Paris) / Corse (deprecated)
+<27594> +title=NTF (Paris) / Corse (deprecated) +proj=lcc +lat_1=42.16500000000001 +lat_0=42.16500000000001 +lon_0=0 +k_0=0.9999447100000001 +x_0=234.358 +y_0=185861.369 +a=6378249.2 +b=6356515 +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs  <>
+# WGS 84 / Plate Carree
+<32662> +title=WGS 84 / Plate Carree +proj=eqc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
+# WGS 84 / UTM zone 1S
+<32701> +title=WGS 84 / UTM zone 1S +proj=utm +zone=1 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
+# WGS 84 / UTM zone 39S
+<32739> +title=WGS 84 / UTM zone 39S +proj=utm +zone=39 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
+# WGS 84 / UTM zone 42S
+<32742> +title=WGS 84 / UTM zone 42S +proj=utm +zone=42 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
+# WGS 84 / UTM zone 43S
+<32743> +title=WGS 84 / UTM zone 43S +proj=utm +zone=43 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
Added: trunk/mapbender/http/extensions/proj4js/tools/catalogues/IGNF
--- trunk/mapbender/http/extensions/proj4js/tools/catalogues/IGNF	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/catalogues/IGNF	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,128 @@
+<CROZ63> +title=Crozet 1963 +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<CSG67> +title=Guyane CSG67 +proj=geocent +towgs84=-193.0660,236.9930,105.4470,0.4814,-0.8074,0.1276,1.564900 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<ED50> +title=ED50 +proj=geocent +towgs84=-84.0000,-97.0000,-117.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<GUAD48> +title=Guadeloupe Ste Anne +proj=geocent +towgs84=-472.2900,-5.6300,-304.1200,0.4362,-0.8374,0.2563,1.898400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<GUADFM49> +title=Guadeloupe Fort Marigot +proj=geocent +towgs84=136.5960,248.1480,-429.7890 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<IGN63> +title=IGN 1963 (Hiva Oa, Tahuata, Mohotani) +proj=geocent +towgs84=410.7210,55.0490,80.7460,-2.5779,-2.3514,-0.6664,17.331100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<IGN72> +title=IGN 1972 Grande-Terre / Ile des Pins +proj=geocent +towgs84=-11.6400,-348.6000,291.6800 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+# W [JULES55]
+<KERG62CAR> +title=Kerguelen - K0 +proj=geocent +towgs84=145.0000,-187.0000,103.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<MART38> +title=Martinique Fort-Desaix +proj=geocent +towgs84=126.9260,547.9390,130.4090,-2.7867,5.1612,-0.8584,13.822650 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+# W [MAUPITI]
+<MAYO50> +title=Mayotte Combani +proj=geocent +towgs84=-599.9280,-275.5520,-195.6650,-0.0835,-0.4715,0.0602,49.281400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<MOOREA87> +title=Moorea 1987 +proj=geocent +towgs84=215.9820,149.5930,176.2290,3.2624,1.6920,1.1571,10.477300 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<NTF> +title=Nouvelle Triangulation Francaise +proj=geocent +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +units=m +no_defs <>
+<NUKU72> +title=IGN 1972 Nuku Hiva +proj=geocent +towgs84=165.7320,216.7200,180.5050,-0.6434,-0.4512,-0.0791,7.420400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<REUN47> +title=Reunion 1947 +proj=geocent +towgs84=789.5240,-626.4860,-89.9040,0.6006,76.7946,-10.5788,-32.324100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<RGF93> +title=Reseau geodesique francais 1993 +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGFG95> +title=Reseau geodesique francais de Guyane 1995 +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGM04> +title=RGM04 (Reseau Geodesique de Mayotte 2004) +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGNC> +title=Reseau Geodesique de Nouvelle-Caledonie +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGPF> +title=RGPF (Reseau Geodesique de Polynesie Francaise) +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGR92> +title=Reseau geodesique Reunion 1992 +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGSPM06> +title=Reseau Geodesique Saint-Pierre-et-Miquelon (2006) +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RRAF91> +title=RRAF 1991 (Reseau de Reference des Antilles Francaises) +proj=geocent +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<STPM50> +title=St Pierre et Miquelon 1950 +proj=geocent +towgs84=-95.5930,573.7630,173.4420,-0.9602,1.2510,-1.3918,42.626500 +a=6378206.4000 +rf=294.9786982000000 +units=m +no_defs <>
+<TAHAA> +title=Raiatea - Tahaa 51-54 (Tahaa, Base Terme Est) +proj=geocent +towgs84=72.4380,345.9180,79.4860,-1.6045,-0.8823,-0.5565,1.374600 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<TAHI79> +title=IGN79 (Tahiti) Iles de la Societe +proj=geocent +towgs84=221.5250,152.9480,176.7680,2.3847,1.3896,0.8770,11.474100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<TERA50> +title=Pointe Geologie - Perroud 1950 +proj=geocent +towgs84=324.8000,153.6000,172.1000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<WALL78> +title=Wallis-Uvea 1978 (MOP78) +proj=geocent +towgs84=253.0000,-133.0000,-127.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<WGS72> +title=World Geodetic System 1972 +proj=geocent +towgs84=0.0000,12.0000,6.0000 +a=6378135.0000 +rf=298.2600000000000 +units=m +no_defs <>
+<WGS84> +title=World Geodetic System 1984 +proj=geocent +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<CROZ63GEO> +title=Crozet 1963 +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<CSG67GEO> +title=Guyane CSG67 UTM fuseau 21 +proj=longlat +towgs84=-193.0660,236.9930,105.4470,0.4814,-0.8074,0.1276,1.564900 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<ED50G> +title=ED50 +proj=longlat +towgs84=-84.0000,-97.0000,-117.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<GUAD48GEO> +title=Guadeloupe Ste Anne +proj=longlat +towgs84=-472.2900,-5.6300,-304.1200,0.4362,-0.8374,0.2563,1.898400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<GUADFM49GEO> +title=Guadeloupe Fort Marigot +proj=longlat +towgs84=136.5960,248.1480,-429.7890 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<IGN63GEO> +title=IGN 1963 (Hiva Oa, Tahuata, Mohotani) +proj=longlat +towgs84=410.7210,55.0490,80.7460,-2.5779,-2.3514,-0.6664,17.331100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<IGN72GEO> +title=IGN 1972 Grande-Terre / Ile des Pins +proj=longlat +towgs84=-11.6400,-348.6000,291.6800 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<KERG62GEO> +title=Kerguelen - K0 +proj=longlat +towgs84=145.0000,-187.0000,103.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<MART38GEO> +title=Martinique Fort-Desaix +proj=longlat +towgs84=126.9260,547.9390,130.4090,-2.7867,5.1612,-0.8584,13.822650 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<MAYO50GEO> +title=Mayotte Combani +proj=longlat +towgs84=-599.9280,-275.5520,-195.6650,-0.0835,-0.4715,0.0602,49.281400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<MOOREA87GEO> +title=Moorea 1987 +proj=longlat +towgs84=215.9820,149.5930,176.2290,3.2624,1.6920,1.1571,10.477300 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<NTFG> +title=Nouvelle Triangulation Francaise Greenwich degres sexagesimaux +proj=longlat +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +units=m +no_defs <>
+<NTFP> +title=Nouvelle Triangulation Francaise Paris grades +proj=longlat +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +units=m +no_defs <>
+<NUKU72GEO> +title=IGN 1972 Nuku Hiva +proj=longlat +towgs84=165.7320,216.7200,180.5050,-0.6434,-0.4512,-0.0791,7.420400 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<REUN47GEO> +title=Reunion 1947 +proj=longlat +towgs84=789.5240,-626.4860,-89.9040,0.6006,76.7946,-10.5788,-32.324100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<RGF93G> +title=Reseau geodesique francais 1993 +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGFG95GEO> +title=Reseau geodesique francais de Guyane 1995 +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGM04GEO> +title=RGM04 (Reseau Geodesique de Mayotte 2004) +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGNCGEO> +title=Reseau Geodesique de Nouvelle-Caledonie +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGPFGEO> +title=RGPF (Reseau Geodesique de Polynesie Francaise) +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGR92GEO> +title=Reseau geodesique de la Reunion 1992 +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<RGSPM06GEO> +title=Saint-Pierre-et-Miquelon (2006) +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<STPM50GEO> +title=St Pierre et Miquelon 1950  +proj=longlat +towgs84=-95.5930,573.7630,173.4420,-0.9602,1.2510,-1.3918,42.626500 +a=6378206.4000 +rf=294.9786982000000 +units=m +no_defs <>
+<TAHAAGEO> +title=Raiatea - Tahaa 51-54 (Tahaa, Base Terme Est) +proj=longlat +towgs84=72.4380,345.9180,79.4860,-1.6045,-0.8823,-0.5565,1.374600 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<TAHI79GEO> +title=IGN79 (Tahiti) Iles de la Societe +proj=longlat +towgs84=221.5250,152.9480,176.7680,2.3847,1.3896,0.8770,11.474100 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<TERA50GEO> +title=Pointe Geologie - Perroud 1950 +proj=longlat +towgs84=324.8000,153.6000,172.1000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<WALL78GEO> +title=Wallis - Uvea 1978 (MOP78) +proj=longlat +towgs84=253.0000,-133.0000,-127.0000 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
+<WGS72G> +title=WGS72 +proj=longlat +towgs84=0.0000,12.0000,6.0000 +a=6378135.0000 +rf=298.2600000000000 +units=m +no_defs <>
+<WGS84G> +title=World Geodetic System 1984 +proj=longlat +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<WGS84RRAFGEO> +title=Reseau de reference des Antilles francaises (1988-1991) +proj=longlat +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<XGEO> +title=Systeme CIO-BIH +proj=longlat +towgs84=0.0000,0.0000,0.5000,0.0000,0.0000,0.0140,-0.100000 +a=6378137.0000 +rf=298.2572221010000 +units=m +no_defs <>
+<CROZ63UTM39S> +title=Crozet 1963 +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=51.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<CSG67UTM21> +title=Guyane CSG67 UTM fuseau 21 +proj=tmerc +towgs84=-193.0660,236.9930,105.4470,0.4814,-0.8074,0.1276,1.564900 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-57.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<CSG67UTM22> +title=Guyane CSG67 UTM fuseau 22 +proj=tmerc +towgs84=-193.0660,236.9930,105.4470,0.4814,-0.8074,0.1276,1.564900 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-51.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALANF> +title=Geoportail - Antilles francaises +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=15.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALCRZ> +title=Geoportail - Crozet +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-46.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALFXX> +title=Geoportail - France metropolitaine +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=46.500000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALGUF> +title=Geoportail - Guyane +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=4.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+# FIXME : Bug Geoconcept : +lat_ts=-49.500000000 a été remplacé par +lat_ts=-47.300000000 (soluce temporaire)
+<GEOPORTALKER> +title=Geoportail - Kerguelen +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-47.300000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALMYT> +title=Geoportail - Mayotte +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-12.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALNCL> +title=Geoportail - Nouvelle-Caledonie +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-22.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALPYF> +title=Geoportail - Polynesie francaise +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-15.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALREU> +title=Geoportail - Reunion et dependances +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-21.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALSPM> +title=Geoportail - Saint-Pierre et Miquelon +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=47.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GEOPORTALWLF> +title=Geoportail - Wallis et Futuna +proj=eqc +nadgrids=null +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=0.000000000 +lat_ts=-14.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<GUAD48UTM20> +title=Guadeloupe Ste Anne +proj=tmerc +towgs84=-472.2900,-5.6300,-304.1200,0.4362,-0.8374,0.2563,1.898400 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-63.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<GUADFM49U20> +title=Guadeloupe Fort Marigot  +proj=tmerc +towgs84=136.5960,248.1480,-429.7890 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-63.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<IGN63UTM7S> +title=IGN 1963 - Hiva Oa, Tahuata, Mohotani - UTM fuseau 7 Sud +proj=tmerc +towgs84=410.7210,55.0490,80.7460,-2.5779,-2.3514,-0.6664,17.331100 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-141.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<IGN72UTM58S> +title=IGN 1972 - UTM fuseau 58 Sud +proj=tmerc +towgs84=-11.6400,-348.6000,291.6800 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=165.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<KERG62UTM42S> +title=Kerguelen 1962 +proj=tmerc +towgs84=145.0000,-187.0000,103.0000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=69.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<LAMB1> +title=Lambert I +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=49.500000000 +lon_0=0.000000000 +k_0=0.99987734 +lat_1=49.500000000 +x_0=600000.000 +y_0=200000.000 +units=m +no_defs <>
+<LAMB1C> +title=Lambert I Carto +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=49.500000000 +lon_0=0.000000000 +k_0=0.99987734 +lat_1=49.500000000 +x_0=600000.000 +y_0=1200000.000 +units=m +no_defs <>
+<LAMB2> +title=Lambert II +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=46.800000000 +lon_0=0.000000000 +k_0=0.99987742 +lat_1=46.800000000 +x_0=600000.000 +y_0=200000.000 +units=m +no_defs <>
+<LAMB2C> +title=Lambert II Carto +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=46.800000000 +lon_0=0.000000000 +k_0=0.99987742 +lat_1=46.800000000 +x_0=600000.000 +y_0=2200000.000 +units=m +no_defs <>
+<LAMB3> +title=Lambert III +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=44.100000000 +lon_0=0.000000000 +k_0=0.99987750 +lat_1=44.100000000 +x_0=600000.000 +y_0=200000.000 +units=m +no_defs <>
+<LAMB3C> +title=Lambert III Carto +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=44.100000000 +lon_0=0.000000000 +k_0=0.99987750 +lat_1=44.100000000 +x_0=600000.000 +y_0=3200000.000 +units=m +no_defs <>
+<LAMB4> +title=Lambert IV +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=42.165000000 +lon_0=0.000000000 +k_0=0.99994471 +lat_1=42.165000000 +x_0=234.358 +y_0=185861.369 +units=m +no_defs <>
+<LAMB4C> +title=Lambert IV Carto +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=42.165000000 +lon_0=0.000000000 +k_0=0.99994471 +lat_1=42.165000000 +x_0=234.358 +y_0=4185861.369 +units=m +no_defs <>
+<LAMB93> +title=Lambert 93 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=46.500000000 +lon_0=3.000000000 +lat_1=44.000000000 +lat_2=49.000000000 +x_0=700000.000 +y_0=6600000.000 +units=m +no_defs <>
+<RGF93CC42> +title=Lambert conique conforme Zone 1 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=42.000000000 +lon_0=3.000000000 +lat_1=41.200000000 +lat_2=42.800000000 +x_0=1700000.000 +y_0=1200000.000 +units=m +no_defs <>
+<RGF93CC43> +title=Lambert conique conforme Zone 2 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=43.000000000 +lon_0=3.000000000 +lat_1=42.200000000 +lat_2=43.800000000 +x_0=1700000.000 +y_0=2200000.000 +units=m +no_defs <>
+<RGF93CC44> +title=Lambert conique conforme Zone 3 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=44.000000000 +lon_0=3.000000000 +lat_1=43.200000000 +lat_2=44.800000000 +x_0=1700000.000 +y_0=3200000.000 +units=m +no_defs <>
+<RGF93CC45> +title=Lambert conique conforme Zone 4 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=45.000000000 +lon_0=3.000000000 +lat_1=44.200000000 +lat_2=45.800000000 +x_0=1700000.000 +y_0=4200000.000 +units=m +no_defs <>
+<RGF93CC46> +title=Lambert conique conforme Zone 5 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=46.000000000 +lon_0=3.000000000 +lat_1=45.200000000 +lat_2=46.800000000 +x_0=1700000.000 +y_0=5200000.000 +units=m +no_defs <>
+<RGF93CC47> +title=Lambert conique conforme Zone 6 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=47.000000000 +lon_0=3.000000000 +lat_1=46.200000000 +lat_2=47.800000000 +x_0=1700000.000 +y_0=6200000.000 +units=m +no_defs <>
+<RGF93CC48> +title=Lambert conique conforme Zone 7 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=48.000000000 +lon_0=3.000000000 +lat_1=47.200000000 +lat_2=48.800000000 +x_0=1700000.000 +y_0=7200000.000 +units=m +no_defs <>
+<RGF93CC49> +title=Lambert conique conforme Zone 8 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=49.000000000 +lon_0=3.000000000 +lat_1=48.200000000 +lat_2=49.800000000 +x_0=1700000.000 +y_0=8200000.000 +units=m +no_defs <>
+<RGF93CC50> +title=Lambert conique conforme Zone 9 +proj=lcc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=50.000000000 +lon_0=3.000000000 +lat_1=49.200000000 +lat_2=50.800000000 +x_0=1700000.000 +y_0=9200000.000 +units=m +no_defs <>
+<LAMBE> +title=Lambert II etendu +proj=lcc +nadgrids=ntf_r93.gsb,null +towgs84=-168.0000,-60.0000,320.0000 +a=6378249.2000 +rf=293.4660210000000 +pm=2.337229167 +lat_0=46.800000000 +lon_0=0.000000000 +k_0=0.99987742 +lat_1=46.800000000 +x_0=600000.000 +y_0=2200000.000 +units=m +no_defs <>
+<MART38UTM20> +title=Martinique Fort-Desaix +proj=tmerc +towgs84=126.9260,547.9390,130.4090,-2.7867,5.1612,-0.8584,13.822650 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-63.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<MAYO50UTM38S> +title=Mayotte Combani +proj=tmerc +towgs84=-599.9280,-275.5520,-195.6650,-0.0835,-0.4715,0.0602,49.281400 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=45.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<MILLER> +title=Geoportail - Monde +proj=mill +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lon_0=0.000000000 +x_0=0.000 +y_0=0.000 +units=m +no_defs <>
+<MOOREA87U6S> +title=Moorea 1987 - UTM fuseau 6 Sud +proj=tmerc +towgs84=215.9820,149.5930,176.2290,3.2624,1.6920,1.1571,10.477300 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-147.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<NUKU72U7S> +title=IGN 1972 Nuku Hiva - UTM fuseau 7 Sud +proj=tmerc +towgs84=165.7320,216.7200,180.5050,-0.6434,-0.4512,-0.0791,7.420400 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-141.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<REUN47GAUSSL> +title=Reunion Gauss Laborde +proj=gstmerc +towgs84=789.5240,-626.4860,-89.9040,0.6006,76.7946,-10.5788,-32.324100 +a=6378388.0000 +rf=297.0000000000000 +lat_0=-21.116666667 +lon_0=55.533333333 +k_0=1.00000000 +x_0=160000.000 +y_0=50000.000 +units=m +no_defs <>
+<RGM04UTM38S> +title=UTM fuseau 38 Sud (Reseau Geodesique de Mayotte 2004) +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=45.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGNCUTM57S> +title=Reseau Geodesique de Nouvelle-Caledonie - UTM fuseau 57 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=159.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGNCUTM58S> +title=Reseau Geodesique de Nouvelle-Caledonie - UTM fuseau 58 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=165.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGNCUTM59S> +title=Reseau Geodesique de Nouvelle-Caledonie - UTM fuseau 59 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=171.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGPFUTM5S> +title=RGPF - UTM fuseau 5 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=-153.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGPFUTM6S> +title=RGPF - UTM fuseau 6 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=-147.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGPFUTM7S> +title=RGPF - UTM fuseau 7 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=-141.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGR92UTM40S> +title=RGR92 UTM fuseau 40 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=57.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<RGSPM06U21> +title=Saint-Pierre-et-Miquelon (2006) UTM Fuseau 21 Nord +proj=tmerc +towgs84=0.0000,0.0000,0.0000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=-57.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<STEREOSX> +title=Stereographique polaire Sud +proj=sterea +towgs84=0.0000,0.0000,0.5000,0.0000,0.0000,0.0140,-0.100000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=-90.000000000 +lon_0=140.000000000 +k=0.96027295 +x_0=300000.000 +y_0=-2299363.482 +units=m +no_defs <>
+<STPM50UTM21> +title=St Pierre et Miquelon 1950 +proj=tmerc +towgs84=-95.5930,573.7630,173.4420,-0.9602,1.2510,-1.3918,42.626500 +a=6378206.4000 +rf=294.9786982000000 +lat_0=0.000000000 +lon_0=-57.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=0.000 +units=m +no_defs <>
+<TAHAAUTM05S> +title=Tahaa 1951 +proj=tmerc +towgs84=72.4380,345.9180,79.4860,-1.6045,-0.8823,-0.5565,1.374600 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-153.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<TAHI51UTM06S> +title=Tahiti-Terme Nord UTM fuseau 6 Sud +proj=tmerc +towgs84=162.0000,117.0000,154.0000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-147.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<TAHI79UTM6S> +title=Tahiti 1979 +proj=tmerc +towgs84=221.5250,152.9480,176.7680,2.3847,1.3896,0.8770,11.474100 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-147.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<TERA50SPTA> +title=Terre Adelie Stereo polaire Terre Adelie +proj=sterea +towgs84=324.8000,153.6000,172.1000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=-67.000000000 +lon_0=140.000000000 +k=1.00000000 +x_0=300000.000 +y_0=200000.000 +units=m +no_defs <>
+<TERA50STEREO> +title=Terre Adelie 1950 +proj=sterea +towgs84=324.8000,153.6000,172.1000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=-90.000000000 +lon_0=140.000000000 +k=0.96027295 +x_0=300000.000 +y_0=-2299363.482 +units=m +no_defs <>
+<UTM01SW84> +title=World Geodetic System 1984 UTM fuseau 01 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=-177.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<UTM39SW84> +title=World Geodetic System 1984 UTM fuseau 39 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=51.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<UTM42SW84> +title=World Geodetic System 1984 UTM fuseau 42 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=69.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<UTM43SW84> +title=World Geodetic System 1984 UTM fuseau 43 Sud +proj=tmerc +towgs84=0.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.000000 +a=6378137.0000 +rf=298.2572221010000 +lat_0=0.000000000 +lon_0=75.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
+<WALL78UTM1S> +title=Wallis-Uvea 1978 (MOP78) UTM 1 SUD +proj=tmerc +towgs84=253.0000,-133.0000,-127.0000 +a=6378388.0000 +rf=297.0000000000000 +lat_0=0.000000000 +lon_0=-177.000000000 +k_0=0.99960000 +x_0=500000.000 +y_0=10000000.000 +units=m +no_defs <>
Added: trunk/mapbender/http/extensions/proj4js/tools/jsmin.c
--- trunk/mapbender/http/extensions/proj4js/tools/jsmin.c	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/jsmin.c	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,272 @@
+/* jsmin.c
+   2006-05-04
+Copyright (c) 2002 Douglas Crockford  (www.crockford.com)
+Permission is hereby granted, free of charge, to any person obtaining a copy of
+this software and associated documentation files (the "Software"), to deal in
+the Software without restriction, including without limitation the rights to
+use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
+of the Software, and to permit persons to whom the Software is furnished to do
+so, subject to the following conditions:
+The above copyright notice and this permission notice shall be included in all
+copies or substantial portions of the Software.
+The Software shall be used for Good, not Evil.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+SOFTWARE.
+#include <stdlib.h>
+#include <stdio.h>
+static int   theA;
+static int   theB;
+static int   theLookahead = EOF;
+/* isAlphanum -- return true if the character is a letter, digit, underscore,
+        dollar sign, or non-ASCII character.
+static int
+isAlphanum(int c)
+    return ((c >= 'a' && c <= 'z') || (c >= '0' && c <= '9') ||
+        (c >= 'A' && c <= 'Z') || c == '_' || c == '$' || c == '\\' ||
+        c > 126);
+/* get -- return the next character from stdin. Watch out for lookahead. If
+        the character is a control character, translate it to a space or
+        linefeed.
+static int
+get()
+    int c = theLookahead;
+    theLookahead = EOF;
+    if (c == EOF) {
+        c = getc(stdin);
+    if (c >= ' ' || c == '\n' || c == EOF) {
+        return c;
+    if (c == '\r') {
+        return '\n';
+    return ' ';
+/* peek -- get the next character without getting it.
+static int
+peek()
+    theLookahead = get();
+    return theLookahead;
+/* next -- get the next character, excluding comments. peek() is used to see
+        if a '/' is followed by a '/' or '*'.
+static int
+next()
+    int c = get();
+    if  (c == '/') {
+        switch (peek()) {
+        case '/':
+            for (;;) {
+                c = get();
+                if (c <= '\n') {
+                    return c;
+        case '*':
+            get();
+            for (;;) {
+                switch (get()) {
+                case '*':
+                    if (peek() == '/') {
+                        get();
+                        return ' ';
+                    break;
+                case EOF:
+                    fprintf(stderr, "Error: JSMIN Unterminated comment.\n");
+                    exit(1);
+        default:
+            return c;
+    return c;
+/* action -- do something! What you do is determined by the argument:
+        1   Output A. Copy B to A. Get the next B.
+        2   Copy B to A. Get the next B. (Delete A).
+        3   Get the next B. (Delete B).
+   action treats a string as a single character. Wow!
+   action recognizes a regular expression if it is preceded by ( or , or =.
+static void
+action(int d)
+    switch (d) {
+    case 1:
+        putc(theA, stdout);
+    case 2:
+        theA = theB;
+        if (theA == '\'' || theA == '"') {
+            for (;;) {
+                theA = get();
+                if (theA == theB) {
+                    break;
+                if (theA <= '\n') {
+                    fprintf(stderr,
+"Error: JSMIN unterminated string literal: %c\n", theA);
+                    exit(1);
+                if (theA == '\\') {
+                    theA = get();
+    case 3:
+        theB = next();
+        if (theB == '/' && (theA == '(' || theA == ',' || theA == '=' ||
+                theA == ':' || theA == '[' || theA == '!' || theA == '&' ||
+                theA == '|')) {
+            putc(theB, stdout);
+            for (;;) {
+                theA = get();
+                if (theA == '/') {
+                    break;
+                } else if (theA =='\\') {
+                    theA = get();
+                } else if (theA <= '\n') {
+                    fprintf(stderr,
+"Error: JSMIN unterminated Regular Expression literal.\n", theA);
+                    exit(1);
+            theB = next();
+/* jsmin -- Copy the input to the output, deleting the characters which are
+        insignificant to JavaScript. Comments will be removed. Tabs will be
+        replaced with spaces. Carriage returns will be replaced with linefeeds.
+        Most spaces and linefeeds will be removed.
+static void
+jsmin()
+    theA = '\n';
+    action(3);
+    while (theA != EOF) {
+        switch (theA) {
+        case ' ':
+            if (isAlphanum(theB)) {
+                action(1);
+            } else {
+                action(2);
+            break;
+        case '\n':
+            switch (theB) {
+            case '{':
+            case '[':
+            case '(':
+            case '+':
+            case '-':
+                action(1);
+                break;
+            case ' ':
+                action(3);
+                break;
+            default:
+                    action(1);
+                } else {
+                    action(2);
+            break;
+        default:
+            switch (theB) {
+            case ' ':
+                if (isAlphanum(theA)) {
+                    action(1);
+                    break;
+                action(3);
+                break;
+            case '\n':
+                switch (theA) {
+                case '}':
+                case ']':
+                case ')':
+                case '+':
+                case '-':
+                case '"':
+                case '\'':
+                    action(1);
+                    break;
+                default:
+                        action(1);
+                    } else {
+                        action(3);
+                break;
+            default:
+                action(1);
+                break;
+/* main -- Output any command line arguments as comments
+        and then minify the input.
+extern int
+main(int argc, char* argv[])
+    int i;
+    for (i = 1; i < argc; i += 1) {
+        fprintf(stdout, "// %s\n", argv[i]);
+    jsmin();
+    return 0;
Added: trunk/mapbender/http/extensions/proj4js/tools/jsmin.py
--- trunk/mapbender/http/extensions/proj4js/tools/jsmin.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/jsmin.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,216 @@
+#!/usr/bin/python
+# This code is original from jsmin by Douglas Crockford, it was translated to
+# Python by Baruch Even. The original code had the following copyright and
+# license.
+# /* jsmin.c
+#    2007-01-08
+# Copyright (c) 2002 Douglas Crockford  (www.crockford.com)
+# Permission is hereby granted, free of charge, to any person obtaining a copy of
+# this software and associated documentation files (the "Software"), to deal in
+# the Software without restriction, including without limitation the rights to
+# use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
+# of the Software, and to permit persons to whom the Software is furnished to do
+# so, subject to the following conditions:
+# The above copyright notice and this permission notice shall be included in all
+# copies or substantial portions of the Software.
+# The Software shall be used for Good, not Evil.
+# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+# SOFTWARE.
+from StringIO import StringIO
+def jsmin(js):
+    ins = StringIO(js)
+    outs = StringIO()
+    JavascriptMinify().minify(ins, outs)
+    str = outs.getvalue()
+    if len(str) > 0 and str[0] == '\n':
+        str = str[1:]
+    return str
+def isAlphanum(c):
+    """return true if the character is a letter, digit, underscore,
+    return ((c >= 'a' and c <= 'z') or (c >= '0' and c <= '9') or
+            (c >= 'A' and c <= 'Z') or c == '_' or c == '$' or c == '\\' or (c is not None and ord(c) > 126));
+class UnterminatedComment(Exception):
+    pass
+class UnterminatedStringLiteral(Exception):
+    pass
+class UnterminatedRegularExpression(Exception):
+    pass
+class JavascriptMinify(object):
+    def _outA(self):
+        self.outstream.write(self.theA)
+    def _outB(self):
+        self.outstream.write(self.theB)
+    def _get(self):
+        """return the next character from stdin. Watch out for lookahead. If
+           linefeed.
+        c = self.theLookahead
+        self.theLookahead = None
+        if c == None:
+            c = self.instream.read(1)
+        if c >= ' ' or c == '\n':
+            return c
+        if c == '': # EOF
+            return '\000'
+        if c == '\r':
+            return '\n'
+        return ' '
+    def _peek(self):
+        self.theLookahead = self._get()
+        return self.theLookahead
+    def _next(self):
+        """get the next character, excluding comments. peek() is used to see
+        c = self._get()
+        if c == '/':
+            p = self._peek()
+            if p == '/':
+                c = self._get()
+                while c > '\n':
+                    c = self._get()
+                return c
+            if p == '*':
+                c = self._get()
+                while 1:
+                    c = self._get()
+                    if c == '*':
+                        if self._peek() == '/':
+                            self._get()
+                            return ' '
+                    if c == '\000':
+                        raise UnterminatedComment()
+        return c
+    def _action(self, action):
+        """do something! What you do is determined by the argument:
+        if action <= 1:
+            self._outA()
+        if action <= 2:
+            self.theA = self.theB
+            if self.theA == "'" or self.theA == '"':
+                while 1:
+                    self._outA()
+                    self.theA = self._get()
+                    if self.theA == self.theB:
+                        break
+                    if self.theA <= '\n':
+                        raise UnterminatedStringLiteral()
+                    if self.theA == '\\':
+                        self._outA()
+        if action <= 3:
+            self.theB = self._next()
+            if self.theB == '/' and (self.theA == '(' or self.theA == ',' or
+                                     self.theA == '=' or self.theA == ':' or
+                                     self.theA == '[' or self.theA == '?' or
+                                     self.theA == '!' or self.theA == '&' or
+                                     self.theA == '|'):
+                self._outA()
+                self._outB()
+                while 1:
+                    if self.theA == '/':
+                        break
+                    elif self.theA == '\\':
+                        self._outA()
+                    elif self.theA <= '\n':
+                        raise UnterminatedRegularExpression()
+                    self._outA()
+    def _jsmin(self):
+        """Copy the input to the output, deleting the characters which are
+        self.theA = '\n'
+        self._action(3)
+        while self.theA != '\000':
+            if self.theA == ' ':
+                if isAlphanum(self.theB):
+                    self._action(1)
+                else:
+                    self._action(2)
+            elif self.theA == '\n':
+                if self.theB in ['{', '[', '(', '+', '-']:
+                    self._action(1)
+                elif self.theB == ' ':
+                    self._action(3)
+                else:
+                        self._action(1)
+                    else:
+                        self._action(2)
+            else:
+                if self.theB == ' ':
+                    if isAlphanum(self.theA):
+                        self._action(1)
+                    else:
+                        self._action(3)
+                elif self.theB == '\n':
+                    if self.theA in ['}', ']', ')', '+', '-', '"', '\'']:
+                        self._action(1)
+                    else:
+                            self._action(1)
+                        else:
+                            self._action(3)
+                else:
+                    self._action(1)
+    def minify(self, instream, outstream):
+        self.instream = instream
+        self.outstream = outstream
+        self.theA = None
+        self.thaB = None
+        self._jsmin()
+        self.instream.close()
+if __name__ == '__main__':
+    import sys
+    jsm = JavascriptMinify()
+    jsm.minify(sys.stdin, sys.stdout)
Added: trunk/mapbender/http/extensions/proj4js/tools/mergejs.py
--- trunk/mapbender/http/extensions/proj4js/tools/mergejs.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/mergejs.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,267 @@
+#!/usr/bin/env python
+# Merge multiple JavaScript source code files into one.
+# Usage:
+# This script requires source files to have dependencies specified in them.
+# Dependencies are specified with a comment of the form:
+#     // @requires <file path>
+#  e.g.
+#    // @requires Geo/DataSource.js
+#  or (ideally) within a class comment definition
+#      * @class
+#      * @requires OpenLayers/Layer.js
+# This script should be executed like so:
+#     mergejs.py <output.js> <directory> [...]
+# e.g.
+#     mergejs.py openlayers.js Geo/ CrossBrowser/
+#  This example will cause the script to walk the `Geo` and
+#  `CrossBrowser` directories--and subdirectories thereof--and import
+#  all `*.js` files encountered. The dependency declarations will be extracted
+#  and then the source code from imported files will be output to
+#  a file named `openlayers.js` in an order which fulfils the dependencies
+#  specified.
+# Note: This is a very rough initial version of this code.
+# -- Copyright 2005-2007 MetaCarta, Inc. / OpenLayers project --
+# TODO: Allow files to be excluded. e.g. `Crossbrowser/DebugMode.js`?
+# TODO: Report error when dependency can not be found rather than KeyError.
+import re
+import os
+import sys
+import glob
+SUFFIX_JAVASCRIPT = ".js"
+RE_REQUIRE = "@requires (.*)\n" # TODO: Ensure in comment?
+class SourceFile:
+    Represents a Javascript source code file.
+    def __init__(self, filepath, source):
+        self.filepath = filepath
+        self.source = source
+        self.requiredBy = []
+    def _getRequirements(self):
+        Extracts the dependencies specified in the source code and returns
+        a list of them.
+        # TODO: Cache?
+        return re.findall(RE_REQUIRE, self.source)
+    requires = property(fget=_getRequirements, doc="")
+def usage(filename):
+    Displays a usage message.
+    print "%s [-c <config file>] <output.js> <directory> [...]" % filename
+class Config:
+    Represents a parsed configuration file.
+    A configuration file should be of the following form:
+        [first]
+        3rd/prototype.js
+        core/application.js
+        core/params.js
+        [last]
+        core/api.js
+        [exclude]
+        3rd/logger.js
+    All headings are required.
+    The files listed in the `first` section will be forced to load
+    *before* all other files (in the order listed). The files in `last`
+    section will be forced to load *after* all the other files (in the
+    order listed).
+    The files list in the `exclude` section will not be imported.
+    def __init__(self, filename):
+        Parses the content of the named file and stores the values.
+        lines = [line.strip() # Assumes end-of-line character is present
+                 for line in open(filename)
+                 if line.strip()] # Skip blank lines
+        self.forceFirst = lines[lines.index("[first]") + 1:lines.index("[last]")]
+        self.forceLast = lines[lines.index("[last]") + 1:lines.index("[include]")]
+        self.include =  lines[lines.index("[include]") + 1:lines.index("[exclude]")]
+        self.exclude =  lines[lines.index("[exclude]") + 1:]
+def run (sourceDirectory, outputFilename = None, configFile = None):
+    cfg = None
+    if configFile:
+        cfg = Config(configFile)
+    allFiles = []
+    ## Find all the Javascript source files
+    for root, dirs, files in os.walk(sourceDirectory):
+        for filename in files:
+            if filename.endswith(SUFFIX_JAVASCRIPT) and not filename.startswith("."):
+                filepath = os.path.join(root, filename)[len(sourceDirectory)+1:]
+                filepath = filepath.replace("\\", "/")
+                if cfg and cfg.include:
+                    include = False
+                    for included in cfg.include:
+                        if glob.fnmatch.fnmatch(filepath, included):
+                            include = True
+                    if include or filepath in cfg.forceFirst:
+                        allFiles.append(filepath)
+                elif (not cfg) or (filepath not in cfg.exclude):
+                    exclude = False
+                    for excluded in cfg.exclude:
+                        if glob.fnmatch.fnmatch(filepath, excluded):
+                            exclude = True
+                    if not exclude:
+    ## Header inserted at the start of each file in the output
+    HEADER = "/* " + "=" * 70 + "\n    %s\n" + "   " + "=" * 70 + " */\n\n"
+    files = {}
+    order = [] # List of filepaths to output, in a dependency satisfying order
+    ## Import file source code
+    ## TODO: Do import when we walk the directories above?
+    for filepath in allFiles:
+        print "Importing: %s" % filepath
+        fullpath = os.path.join(sourceDirectory, filepath)
+        content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
+        files[filepath] = SourceFile(filepath, content) # TODO: Chop path?
+    print
+    from toposort import toposort
+    complete = False
+    resolution_pass = 1
+    while not complete:
+        nodes = []
+        routes = []
+        ## Resolve the dependencies
+        print "Resolution pass %s... " % resolution_pass
+        resolution_pass += 1
+        for filepath, info in files.items():
+            nodes.append(filepath)
+            for neededFilePath in info.requires:
+                routes.append((neededFilePath, filepath))
+        for dependencyLevel in toposort(nodes, routes):
+            for filepath in dependencyLevel:
+                order.append(filepath)
+                if not files.has_key(filepath):
+        # Double check all dependencies have been met
+        complete = True
+        try:
+            for fp in order:
+                if max([order.index(rfp) for rfp in files[fp].requires] +
+                       [order.index(fp)]) != order.index(fp):
+                    complete = False
+        except:
+            complete = False
+        print
+    ## Move forced first and last files to the required position
+    if cfg:
+        print "Re-ordering files..."
+        order = cfg.forceFirst + [item
+                     for item in order
+                     if ((item not in cfg.forceFirst) and
+                         (item not in cfg.forceLast))] + cfg.forceLast
+    print
+    ## Output the files in the determined order
+    result = []
+    for fp in order:
+        f = files[fp]
+        print "Exporting: ", f.filepath
+        result.append(HEADER % f.filepath)
+        source = f.source
+        result.append(source)
+        if not source.endswith("\n"):
+            result.append("\n")
+    print "\nTotal files merged: %d " % len(files)
+    if outputFilename:
+        print "\nGenerating: %s" % (outputFilename)
+        open(outputFilename, "w").write("".join(result))
+    return "".join(result)
+if __name__ == "__main__":
+    import getopt
+    options, args = getopt.getopt(sys.argv[1:], "-c:")
+    try:
+        outputFilename = args[0]
+    except IndexError:
+        usage(sys.argv[0])
+        raise SystemExit
+    else:
+        sourceDirectory = args[1]
+        if not sourceDirectory:
+            raise SystemExit
+    configFile = None
+    if options and options[0][0] == "-c":
+        configFile = options[0][1]
+        print "Parsing configuration file: %s" % filename
+    run( sourceDirectory, outputFilename, configFile )
Added: trunk/mapbender/http/extensions/proj4js/tools/mkpjcat.py
--- trunk/mapbender/http/extensions/proj4js/tools/mkpjcat.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/mkpjcat.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,21 @@
+import sys
+sys.path.append(".")
+import pjjs
+resourcesDirectory = "catalogues"
+targetDirectory = "../lib/defs"
+if len(sys.argv) > 1:
+    resourcesDirectory = sys.argv[1]
+if len(sys.argv) > 2:
+    targetDirectory = sys.argv[2]
+print "Generating Proj4js catalogues."
+pjjs.pjcat2js_clean(resourcesDirectory,targetDirectory)
+pjjs.pjcat2js_run(resourcesDirectory,targetDirectory)
+print "Done."
Added: trunk/mapbender/http/extensions/proj4js/tools/pjjs.py
--- trunk/mapbender/http/extensions/proj4js/tools/pjjs.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/pjjs.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,85 @@
+# TODO explain
+# -- Copyright 2007 IGN France / Geoportail project --
+import sys
+import os
+import re
+def _pjcat2js_remove(rezDirectory,catName,targetDirectory):
+    pjCatFilename = os.path.join(rezDirectory, catName)
+    pjCat = open(pjCatFilename,'r')
+    comment_re = re.compile("^#")
+    srsdef_re = re.compile("^<([^>]*)>.* <>$")
+    l = pjCat.readline()
+    while len(l) != 0:
+        if comment_re.search(l) is None:
+            srsdef_mo = srsdef_re.match(l)
+            srsdef_fn = os.path.join(targetDirectory, catName+srsdef_mo.group(1)+".js")
+            if os.path.exists(srsdef_fn):
+                os.remove(srsdef_fn)
+    pjCat.close()
+def _pjcat2js_make(rezDirectory,catName,targetDirectory):
+    srsdef_re = re.compile("^<([^>]*)> *(.*) <>$")
+            srsdef = 'Proj4js.defs["'+catName+':'+srsdef_mo.group(1)+'"]="'+srsdef_mo.group(2)+'";'
+            file(srsdef_fn,'w').write(srsdef)
+    pjCat.close()
+def pjcat2js_clean(rezDirectory,targetDirectory):
+    if not os.path.isdir(rezDirectory):
+        return
+    if not os.path.isdir(targetDirectory):
+        return
+    if os.path.abspath(rezDirectory) == '/':
+        return
+    if os.path.abspath(targetDirectory) == '/':
+        return
+    rezDirectory_name_len = len(rezDirectory)
+    for root, dirs, filenames in os.walk(rezDirectory):
+        if 'CVS' in dirs:
+            dirs.remove('CVS')
+        if '.svn' in dirs:
+            dirs.remove('.svn')
+        for filename in filenames:
+            if not filename.endswith(SUFFIX_JAVASCRIPT) and not filename.startswith("."):
+                filepath = os.path.join(root, filename)[rezDirectory_name_len+1:]
+                _pjcat2js_remove(rezDirectory,filepath,targetDirectory)
+def pjcat2js_run(rezDirectory,targetDirectory):
+        return
+        return
+        return
+        return
+        if 'CVS' in dirs:
+                _pjcat2js_make(rezDirectory,filepath,targetDirectory)
Added: trunk/mapbender/http/extensions/proj4js/tools/toposort.py
--- trunk/mapbender/http/extensions/proj4js/tools/toposort.py	                        (rev 0)
+++ trunk/mapbender/http/extensions/proj4js/tools/toposort.py	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,260 @@
+# According to <http://www.vrplumber.com/programming/> this file
+# is licensed under a BSD-style license. We only use the section
+# originally by Tim Peters.
+# TODO: The use of this code needs to be okayed by someone.
+class RecursionError( OverflowError, ValueError ):
+    '''Unable to calculate result because of recursive structure'''
+def sort(nodes, routes, noRecursion=1):
+    '''Passed a list of node IDs and a list of source,dest ID routes
+    attempt to create a list of stages where each sub list
+    is one stage in a process.
+    children, parents = _buildChildrenLists(routes)
+    # first stage is those nodes
+    # having no incoming routes...
+    stage = []
+    stages = [stage]
+    taken = []
+    for node in nodes:
+        if (not parents.get(node)):
+            stage.append (node)
+    if nodes and not stage:
+        # there is no element which does not depend on
+        # some other element!!!
+        stage.append( nodes[0])
+    taken.extend( stage )
+    nodes = filter ( lambda x, l=stage: x not in l, nodes )
+    while nodes:
+        previousStageChildren = []
+        nodelen = len(nodes)
+        # second stage are those nodes
+        # which are direct children of the first stage
+        for node in stage:
+            for child in children.get (node, []):
+                if child not in previousStageChildren and child not in taken:
+                    previousStageChildren.append(child)
+                elif child in taken and noRecursion:
+                    raise RecursionError( (child, node) )
+        # unless they are children of other direct children...
+        # TODO, actually do that...
+        stage = previousStageChildren
+        removes = []
+        for current in stage:
+            currentParents = parents.get( current, [] )
+            for parent in currentParents:
+                if parent in stage and parent != current:
+                    # might wind up removing current...
+                    if not current in parents.get(parent, []):
+                        # is not mutually dependent...
+                        removes.append( current )
+        for remove in removes:
+            while remove in stage:
+                stage.remove( remove )
+        stages.append( stage)
+        if nodelen == len(nodes):
+            if noRecursion:
+                raise RecursionError( nodes )
+            else:
+                stages.append( nodes[:] )
+                nodes = []
+    return stages
+def _buildChildrenLists (routes):
+    childrenTable = {}
+    parentTable = {}
+    for sourceID,destinationID in routes:
+        currentChildren = childrenTable.get( sourceID, [])
+        currentParents = parentTable.get( destinationID, [])
+        if not destinationID in currentChildren:
+            currentChildren.append ( destinationID)
+        if not sourceID in currentParents:
+            currentParents.append ( sourceID)
+        childrenTable[sourceID] = currentChildren
+        parentTable[destinationID] = currentParents
+    return childrenTable, parentTable
+def toposort (nodes, routes, noRecursion=1):
+    '''Topological sort from Tim Peters, fairly efficient
+    in comparison (it seems).'''
+    #first calculate the recursion depth
+    dependencies = {}
+    inversedependencies = {}
+    if not nodes:
+        return []
+    if not routes:
+        return [nodes]
+        dependencies[ node ] = (0, node)
+        inversedependencies[ node ] = []
+    for depended, depends in routes:
+        # is it a null rule
+        try:
+            newdependencylevel, object = dependencies.get ( depends, (0, depends))
+        except TypeError:
+            print depends
+            raise
+        dependencies[ depends ] = (newdependencylevel + 1,  depends)
+        # "dependency (existence) of depended-on"
+        newdependencylevel,object = dependencies.get ( depended, (0, depended) )
+        dependencies[ depended ] = (newdependencylevel, depended)
+        # Inverse dependency set up
+        dependencieslist = inversedependencies.get ( depended, [])
+        dependencieslist.append (depends)
+        inversedependencies[depended] = dependencieslist
+    ### Now we do the actual sorting
+    # The first task is to create the sortable
+    # list of dependency-levels
+    sortinglist = dependencies.values()
+    sortinglist.sort ()
+    output = []
+    while sortinglist:
+        deletelist = []
+        generation = []
+        output.append( generation)
+        while sortinglist and sortinglist[0][0] == 0:
+            number, object = sortinglist[0]
+            generation.append ( object )
+            deletelist.append( object )
+            for inverse in inversedependencies.get(object, () ):
+                try:
+                    oldcount, inverse = dependencies [ inverse]
+                    if oldcount > 0:
+                        # will be dealt with on later pass
+                        dependencies [ inverse] = (oldcount-1, inverse)
+                    else:
+                        # will be dealt with on this pass,
+                        # so needs not to be in the sorting list next time
+                        deletelist.append( inverse )
+                    # just in case a loop comes through
+                    inversedependencies[object] = []
+                except KeyError:
+                    # dealing with a recursion-breaking run...
+                    pass
+            del sortinglist [0]
+        # if no elements could be deleted, then
+        # there is something which depends upon itself
+        if not deletelist:
+            if noRecursion:
+                raise RecursionError( sortinglist )
+            else:
+                # hack so that something gets deleted...
+##                import pdb
+##                pdb.set_trace()
+                dependencies[sortinglist[0][1]] = (0,sortinglist[0][1])
+        # delete the items that were dealt with
+        for item in deletelist:
+            try:
+                del dependencies [ item ]
+            except KeyError:
+                pass
+        # need to recreate the sortinglist
+        if not generation:
+            output.remove( generation )
+    return output
+    nodes = ['a', 'b', 'c', 'd', 'e', 'f']
+    route = [('a', 'b'), ('b', 'c'), ('b', 'd'), ('e','f')]
+    for x in  toposort( nodes, route):
+        for a in x:
+            print a
+    raise SystemExit
+    import pprint, traceback
+    nodes= [ 0,1,2,3,4,5 ]
+    testingValues = [
+        [ (0,1),(1,2),(2,3),(3,4),(4,5)],
+        [ (0,1),(0,2),(1,2),(3,4),(4,5)],
+        (0,1),
+        (0,2),
+        (0,2),
+                    (2,4),
+                    (2,5),
+                (3,2),
+        (0,3)],
+        (0,1), # 3-element cycle test, no orphan nodes
+        (1,2),
+        (2,0),
+                    (2,4),
+                    (2,5),
+                (3,2),
+        (0,3)],
+        (0,1),
+        (1,1),
+        (1,1),
+                (1,4),
+                (1,5),
+                (1,2),
+        (3,1),
+        (2,1),
+        (2,0)],
+            (0,1),
+            (1,0),
+            (0,2),
+            (0,3),
+            (0,1),
+            (1,0),
+            (0,2),
+            (3,1),
+    print 'sort, no recursion allowed'
+    for index in range(len(testingValues)):
+##        print '    %s -- %s'%( index, testingValues[index])
+        try:
+            print '        ', sort( nodes, testingValues[index] )
+        except:
+            print 'exception raised'
+    print 'toposort, no recursion allowed'
+        try:
+            print '        ', toposort( nodes, testingValues[index] )
+        except:
+    print 'sort, recursion allowed'
+        try:
+            print '        ', sort( nodes, testingValues[index],0 )
+        except:
+    print 'toposort, recursion allowed'
+        try:
+            print '        ', toposort( nodes, testingValues[index],0 )
+        except:
Added: trunk/mapbender/http/javascripts/mod_coordsLookup.js
--- trunk/mapbender/http/javascripts/mod_coordsLookup.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_coordsLookup.js	2009-08-31 13:30:38 UTC (rev 4581)
@@ -0,0 +1,140 @@
+ * Package: <Application element name>
+ * Description:
+ * <A description>
+ * Files:
+ *  - <path and filename, like http/javascripts/mod_zoomIn1.php>
+ * SQL:
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui_toni','coordsLookup',10,1,'','','div','','',1000,0,NULL ,NULL ,NULL ,'border:1px solid red;z-index:9999;','','div','mod_coordsLookup.js','../extensions/proj4js/lib/proj4js-combined.js','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_toni', 'coordsLookup', 'perimeters', '[50,200,1000,10000]', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_toni', 'coordsLookup', 'projections', '[''EPSG:31467'',''EPSG:31468'',''EPSG:31469'']', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/<wiki site name>
+ * Maintainer:
+ * http://www.mapbender.org/User:<user>
+ * Parameters:
+ * <normal element var name>      - <type and description>
+ * <optional element var name>    - *[optional]* <type and description>
+ * <deprecated element var name>  - *[deprecated]* <type and description>
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+// http://trac.osgeo.org/proj4js/wiki/UserGuide
+var CoordsLookup = function() {
+	if(
+		typeof options.target      === 'undefined' || options.target.length      === 0 ||
+		typeof options.projections === 'undefined' || options.projections.length === 0 ||
+		typeof options.perimeters  === 'undefined' || options.perimeters.length  === 0
+		return;
+	this.buildForm = function() {
+//		Container elements
+		this.formContainer             = $(document.createElement('form')).attr({'id':'coords-lookup-form'}).appendTo('#' + options.id);
+		this.coordsInputContainer      = $(document.createElement('p')).appendTo(this.formContainer);
+		this.projectionSelectContainer = $(document.createElement('p')).appendTo(this.formContainer);
+		this.perimeterSelectContainer  = $(document.createElement('p')).appendTo(this.formContainer);
+		this.triggerButtonContainer    = $(document.createElement('p')).appendTo(this.formContainer);
+//		Coordinates input with label
+		this.coordsInputLabel          = $(document.createElement('label')).attr({'for':'coord-x'}).text('Koordinaten:').appendTo(this.coordsInputContainer);
+		this.coordXInput               = $(document.createElement('input')).attr({'id':'coord-x','size':8}).appendTo(this.coordsInputContainer);
+		this.coordYInput               = $(document.createElement('input')).attr({'id':'coord-y','size':8}).appendTo(this.coordsInputContainer);
+		$(this.coordsInputLabel).after($(document.createElement('br')));
+		$(this.coordXInput).after('&nbsp;/&nbsp;');
+//		Projection select
+		this.projectionSelect          = $(document.createElement('select')).attr({'id':'projection-select'}).appendTo(this.projectionSelectContainer);
+//		Perimeter select
+		this.perimeterSelect           = $(document.createElement('select')).attr({'id':'perimeter-select'}).appendTo(this.perimeterSelectContainer);
+//		Trigger button
+		this.triggerButton             = $(document.createElement('input')).attr({'id':'trigger-button','type':'button','value':'Auf Koordinaten zoomen'}).appendTo(this.triggerButtonContainer);
+	this.initForm = function() {
+//		Fill projection select with options
+		for(var i = 0; i < options.projections.length; i++) {
+			$(new Option(options.projections[i],options.projections[i])).appendTo(this.projectionSelect);
+		$(new Option('Projektionssystem','',true,true)).prependTo(this.projectionSelect);
+//		Fill perimeter select with options
+		for(var i = 0; i < options.perimeters.length; i++) {
+			var optionValue = options.perimeters[i] + '';
+			optionValue = (optionValue.length < 4) ? (optionValue + ' m') : optionValue.replace(/(\d+)(\d{3})/, '$1' + '.' + '$2' + ' m');
+			$(new Option(optionValue,options.perimeters[i])).appendTo(this.perimeterSelect);
+		$(new Option('Umkreis','',true,true)).prependTo(this.perimeterSelect);
+//		Set action for trigger button
+		$(this.triggerButton).click(function() {
+			Mapbender.modules[options.id].zoomToCoordinates();
+	this.zoomToCoordinates = function() {
+		this.coords = {}
+		this.coords.x                = this.coordXInput.val().replace(',','.');
+		this.coords.y                = this.coordYInput.val().replace(',','.');
+		this.coords.sourceProjection = (this.projectionSelect.val().length) ? this.projectionSelect.val() : false;
+		this.coords.targetProjection = Mapbender.modules[options.target].getSRS();
+		this.coords.perimeter        = (this.perimeterSelect.val().length) ? this.perimeterSelect.val() : false;
+		if(
+			this.coords.x.length === 0 || isNaN(this.coords.x) ||
+			this.coords.y.length === 0 || isNaN(this.coords.y)
+			alert('Bitte geben Sie ein Koordinatenpaar ein.');
+			return;
+		if(this.coords.sourceProjection && (this.coords.sourceProjection != this.coords.targetProjection)) {
+			this.transformProjection();
+		zoom(options.target,true,1.0,this.coords.x,this.coords.y);
+	this.transformProjection = function() {
+//		proj4js debug
+		Proj4js.reportError = function(msg) {
+			console.log('proj4js debug message: %s',msg);
+		var sourceProjection = new Proj4js.Proj(this.coords.sourceProjection);
+		var targetProjection = new Proj4js.Proj(this.coords.targetProjection);
+		var coords           = new Proj4js.Point(this.coords.x,this.coords.y);
+		Proj4js.transform(sourceProjection,targetProjection,coords);
+		console.log('coords before transformation: %s/%s',this.coords.x,this.coords.y);
+		this.coords.x = coords.x;
+		this.coords.y = coords.y;
+		console.log('coords after transformation: %s/%s',this.coords.x,this.coords.y);
+	this.buildForm();
+	this.initForm();
+Mapbender.events.init.register(function() {
+	Mapbender.modules[options.id] = $.extend(new CoordsLookup(),Mapbender.modules[options.id]);
\ No newline at end of file
More information about the Mapbender_commits mailing list
