[Mapbender-commits] r5113 - trunk/mapbender/documents/api_js
svn_mapbender at osgeo.org
Fri Dec 11 05:41:16 EST 2009
Author: christoph
Date: 2009-12-11 05:41:14 -0500 (Fri, 11 Dec 2009)
New Revision: 5113
Added:
trunk/mapbender/documents/api_js/Languages.txt
trunk/mapbender/documents/api_js/Topics.txt
Added: trunk/mapbender/documents/api_js/Languages.txt
--- trunk/mapbender/documents/api_js/Languages.txt (rev 0)
+++ trunk/mapbender/documents/api_js/Languages.txt 2009-12-11 10:41:14 UTC (rev 5113)
@@ -0,0 +1,113 @@
+Format: 1.4
+# This is the Natural Docs languages file for this project. If you change
+# anything here, it will apply to THIS PROJECT ONLY. If you'd like to change
+# something for all your projects, edit the Languages.txt in Natural Docs'
+# Config directory instead.
+# You can prevent certain file extensions from being scanned like this:
+# Ignore Extensions: [extension] [extension] ...
+# SYNTAX:
+# Unlike other Natural Docs configuration files, in this file all comments
+# MUST be alone on a line. Some languages deal with the # character, so you
+# cannot put comments on the same line as content.
+# Also, all lists are separated with spaces, not commas, again because some
+# languages may need to use them.
+# Language: [name]
+# Alter Language: [name]
+# Defines a new language or alters an existing one. Its name can use any
+# characters. If any of the properties below have an add/replace form, you
+# must use that when using Alter Language.
+# The language Shebang Script is special. It's entry is only used for
+# extensions, and files with those extensions have their shebang (#!) lines
+# read to determine the real language of the file. Extensionless files are
+# always treated this way.
+# The language Text File is also special. It's treated as one big comment
+# so you can put Natural Docs content in them without special symbols. Also,
+# if you don't specify a package separator, ignored prefixes, or enum value
+# behavior, it will copy those settings from the language that is used most
+# in the source tree.
+# Extensions: [extension] [extension] ...
+# [Add/Replace] Extensions: [extension] [extension] ...
+# Defines the file extensions of the language's source files. You can
+# redefine extensions found in the main languages file. You can use * to
+# mean any undefined extension.
+# Shebang Strings: [string] [string] ...
+# [Add/Replace] Shebang Strings: [string] [string] ...
+# Defines a list of strings that can appear in the shebang (#!) line to
+# designate that it's part of the language. You can redefine strings found
+# in the main languages file.
+# Ignore Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
+# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+# Specifies prefixes that should be ignored when sorting symbols in an
+# index. Can be specified in general or for a specific topic type.
+# For basic language support only:
+# Line Comments: [symbol] [symbol] ...
+# Defines a space-separated list of symbols that are used for line comments,
+# if any.
+# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
+# Defines a space-separated list of symbol pairs that are used for block
+# comments, if any.
+# Package Separator: [symbol]
+# Defines the default package separator symbol. The default is a dot.
+# [Topic Type] Prototype Enders: [symbol] [symbol] ...
+# When defined, Natural Docs will attempt to get a prototype from the code
+# immediately following the topic type. It stops when it reaches one of
+# these symbols. Use \n for line breaks.
+# Line Extender: [symbol]
+# Defines the symbol that allows a prototype to span multiple lines if
+# normally a line break would end it.
+# Enum Values: [global|under type|under parent]
+# Defines how enum values are referenced. The default is global.
+# global - Values are always global, referenced as 'value'.
+# under type - Values are under the enum type, referenced as
+# 'package.enum.value'.
+# under parent - Values are under the enum's parent, referenced as
+# 'package.value'.
+# Perl Package: [perl package]
+# Specifies the Perl package used to fine-tune the language behavior in ways
+# too complex to do in this file.
+# For full language support only:
+# Full Language Support: [perl package]
+# Specifies the Perl package that has the parsing routines necessary for full
+# language support.
+# The following languages are defined in the main file, if you'd like to alter
+# them:
+# Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
+# PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
+# ActionScript, ColdFusion, R, Fortran
+# If you add a language that you think would be useful to other developers
+# and should be included in Natural Docs by default, please e-mail it to
+# languages [at] naturaldocs [dot] org.
Added: trunk/mapbender/documents/api_js/Topics.txt
--- trunk/mapbender/documents/api_js/Topics.txt (rev 0)
+++ trunk/mapbender/documents/api_js/Topics.txt 2009-12-11 10:41:14 UTC (rev 5113)
@@ -0,0 +1,81 @@
+Format: 1.4
+# This is the Natural Docs topics file for this project. If you change anything
+# here, it will apply to THIS PROJECT ONLY. If you'd like to change something
+# for all your projects, edit the Topics.txt in Natural Docs' Config directory
+# instead.
+# If you'd like to prevent keywords from being recognized by Natural Docs, you
+# can do it like this:
+# Ignore Keywords: [keyword], [keyword], ...
+# Or you can use the list syntax like how they are defined:
+# Ignore Keywords:
+# [keyword]
+# [keyword], [plural keyword]
+# SYNTAX:
+# Topic Type: [name]
+# Alter Topic Type: [name]
+# Creates a new topic type or alters one from the main file. Each type gets
+# its own index and behavior settings. Its name can have letters, numbers,
+# spaces, and these charaters: - / . '
+# Plural: [name]
+# Sets the plural name of the topic type, if different.
+# Keywords:
+# [keyword]
+# Defines or adds to the list of keywords for the topic type. They may only
+# contain letters, numbers, and spaces and are not case sensitive. Plural
+# keywords are used for list topics. You can redefine keywords found in the
+# main topics file.
+# Index: [yes|no]
+# Whether the topics get their own index. Defaults to yes. Everything is
+# included in the general index regardless of this setting.
+# Scope: [normal|start|end|always global]
+# How the topics affects scope. Defaults to normal.
+# normal - Topics stay within the current scope.
+# start - Topics start a new scope for all the topics beneath it,
+# like class topics.
+# end - Topics reset the scope back to global for all the topics
+# beneath it.
+# always global - Topics are defined as global, but do not change the scope
+# for any other topics.
+# Class Hierarchy: [yes|no]
+# Whether the topics are part of the class hierarchy. Defaults to no.
+# Page Title If First: [yes|no]
+# Whether the topic's title becomes the page title if it's the first one in
+# a file. Defaults to no.
+# Break Lists: [yes|no]
+# Whether list topics should be broken into individual topics in the output.
+# Defaults to no.
+# Can Group With: [type], [type], ...
+# Defines a list of topic types that this one can possibly be grouped with.
+# Defaults to none.
+# The following topics are defined in the main file, if you'd like to alter
+# their behavior or add keywords:
+# Generic, Class, Interface, Section, File, Group, Function, Variable,
+# Property, Type, Constant, Enumeration, Event, Delegate, Macro,
+# Database, Database Table, Database View, Database Index, Database
+# Cursor, Database Trigger, Cookie, Build Target
+# If you add something that you think would be useful to other developers
+# topics [at] naturaldocs [dot] org.
More information about the Mapbender_commits
