[Mapbender-commits] r5130 - in trunk/mapbender/documents/api_js: .
	Data files
    svn_mapbender at osgeo.org
    Fri Dec 11 06:39:10 EST 2009
Author: christoph
Date: 2009-12-11 06:39:10 -0500 (Fri, 11 Dec 2009)
New Revision: 5130
Added:
   trunk/mapbender/documents/api_js/Menu_Backup_2.txt
   trunk/mapbender/documents/api_js/Menu_Backup_3.txt
   trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
   trunk/mapbender/documents/api_js/files/core-php.html
   trunk/mapbender/documents/api_js/files/map_obj-js.html
   trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html
   trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html
   trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html
   trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html
   trunk/mapbender/documents/api_js/files/mod_log-js.html
   trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html
   trunk/mapbender/documents/api_js/files/mod_overview-js.html
   trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html
   trunk/mapbender/documents/api_js/files/mod_pan-js.html
   trunk/mapbender/documents/api_js/files/mod_reload-js.html
   trunk/mapbender/documents/api_js/files/mod_repaint-js.html
   trunk/mapbender/documents/api_js/files/mod_repaint-php.html
   trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html
   trunk/mapbender/documents/api_js/files/mod_sandclock-js.html
   trunk/mapbender/documents/api_js/files/mod_savewmc-js.html
   trunk/mapbender/documents/api_js/files/mod_scalebar-js.html
   trunk/mapbender/documents/api_js/files/mod_selArea-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
(Binary files differ)
Added: trunk/mapbender/documents/api_js/Menu_Backup_2.txt
--- trunk/mapbender/documents/api_js/Menu_Backup_2.txt	                        (rev 0)
+++ trunk/mapbender/documents/api_js/Menu_Backup_2.txt	2009-12-11 11:39:10 UTC (rev 5130)
@@ -0,0 +1,67 @@
+Format: 1.4
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+#   m     - One or two digit month.  January is "1"
+#   mm    - Always two digit month.  January is "01"
+#   mon   - Short month word.  January is "Jan"
+#   month - Long month word.  January is "January"
+#   d     - One or two digit day.  1 is "1"
+#   dd    - Always two digit day.  1 is "01"
+#   day   - Day with letter extension.  1 is "1st"
+#   yy    - Two digit year.  2006 is "06"
+#   yyyy  - Four digit year.  2006 is "2006"
+#   year  - Four digit year.  2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu.  Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries.  Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file.  Natural Docs will clean it up the next
+# time it is run.  When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+Group: modules  {
+   File: cookie  (mb_cookie.js)
+   File: i18n  (mb_i18n.js)
+   File: jq_datatables  (jq_datatables.js)
+   File: jq_ui_accordion  (jq_ui_accordion.js)
+   File: mb_zoomIn  (mb_zoomIn.js)
+   File: mb_zoomOut  (mb_zoomOut.js)
+   File: selectMapsize  (mb_selectMapsize.js)
+   File: wmsTimeInterval  (mb_wmsTimeInterval.js)
+   File: wmsTimeSliderYear  (mb_wmsTimeSliderYear.js)
+   }  # Group: modules
+Group: Index  {
+   Index: Everything
+   Class Index: Classes
+   }  # Group: Index
Added: trunk/mapbender/documents/api_js/Menu_Backup_3.txt
--- trunk/mapbender/documents/api_js/Menu_Backup_3.txt	                        (rev 0)
+++ trunk/mapbender/documents/api_js/Menu_Backup_3.txt	2009-12-11 11:39:10 UTC (rev 5130)
@@ -0,0 +1,81 @@
+Format: 1.4
+# Footer: [text]
+Group: modules  {
+   File: AddWmsFromTree  (mod_addWMSfromTree.js)
+   File: changeEPSG  (mod_changeEPSG.js)
+   File: coordsLookup  (mod_coordsLookup.js)
+   File: doubleclickZoom  (mod_doubleclickZoom.js)
+   File: Log  (mod_log.js)
+   File: Map  (map_obj.js)
+   File: Mapbender  (core.php)
+   File: mousewheelZoom  (mod_mousewheelZoom.js)
+   File: Overview  (mod_overview.js)
+   File: overviewToggle  (mod_overviewToggle.js)
+   File: Reload  (mod_reload.js)
+   File: repaint  (mod_repaint.js)
+   File: repaint  (mod_repaint.php)
+   File: ResizeMapsize  (mod_resize_mapsize.js)
+   File: Sandclock  (mod_sandclock.js)
+   File: savewmc  (mod_savewmc.js)
+   File: scalebar  (mod_scalebar.js)
+   File: selArea  (mod_pan.js)
+   File: selArea  (mod_selArea.js)
+   File: zoomFull  (mod_zoomFull.js)
+   File: ZoomIn1  (mod_zoomIn1.js)
+   File: ZoomOut1  (mod_zoomOut1.js)
+Group: Index  {
+   Index: Everything
+   Function Index: Functions
+   }  # Group: Index
Modified: trunk/mapbender/documents/api_js/files/core-php.html
--- trunk/mapbender/documents/api_js/files/core-php.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/core-php.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -19,7 +19,7 @@
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
 --></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option></select></div></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/files/map_obj-js.html
--- trunk/mapbender/documents/api_js/files/map_obj-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/map_obj-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html
--- trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -39,7 +39,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>AddWmsFromTree</div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>AddWmsFromTree</div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html
--- trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -35,7 +35,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile id=MSelected>changeEPSG</div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile id=MSelected>changeEPSG</div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html
--- trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -34,7 +34,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile id=MSelected>coordsLookup</div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile id=MSelected>coordsLookup</div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html
--- trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile id=MSelected>doubleclickZoom</div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile id=MSelected>doubleclickZoom</div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_log-js.html
--- trunk/mapbender/documents/api_js/files/mod_log-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_log-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -28,7 +28,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Log</div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Log</div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html
--- trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -30,7 +30,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile id=MSelected>mousewheelZoom</div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>mousewheelZoom</div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_overview-js.html
--- trunk/mapbender/documents/api_js/files/mod_overview-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_overview-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -37,7 +37,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Overview</div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Overview</div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html
--- trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -32,7 +32,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile id=MSelected>overviewToggle</div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile id=MSelected>overviewToggle</div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_pan-js.html
--- trunk/mapbender/documents/api_js/files/mod_pan-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_pan-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_reload-js.html
--- trunk/mapbender/documents/api_js/files/mod_reload-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_reload-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -29,7 +29,7 @@
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
 --></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option></select></div></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/files/mod_repaint-js.html
--- trunk/mapbender/documents/api_js/files/mod_repaint-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_repaint-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_repaint-php.html
--- trunk/mapbender/documents/api_js/files/mod_repaint-php.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_repaint-php.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html
--- trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -40,7 +40,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResizeMapsize</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResizeMapsize</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_sandclock-js.html
--- trunk/mapbender/documents/api_js/files/mod_sandclock-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_sandclock-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -40,7 +40,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_savewmc-js.html
--- trunk/mapbender/documents/api_js/files/mod_savewmc-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_savewmc-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -34,7 +34,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>savewmc</div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>savewmc</div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_scalebar-js.html
--- trunk/mapbender/documents/api_js/files/mod_scalebar-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_scalebar-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -24,7 +24,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile id=MSelected>scalebar</div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile id=MSelected>scalebar</div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_selArea-js.html
--- trunk/mapbender/documents/api_js/files/mod_selArea-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_selArea-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>zoomFull</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>zoomFull</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html	2009-12-11 11:38:33 UTC (rev 5129)
+++ trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html	2009-12-11 11:39:10 UTC (rev 5130)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomOut1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomOut1</div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Index</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
More information about the Mapbender_commits
