[Mapbender-commits] r5157 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Sat Dec 12 06:07:52 EST 2009
Author: verenadiewald
Date: 2009-12-12 06:07:52 -0500 (Sat, 12 Dec 2009)
New Revision: 5157
Added:
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
Removed:
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
renamed file update_2.6_to_2.7rc1_pgsql_UTF-8.sql
Deleted: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2009-12-12 11:05:58 UTC (rev 5156)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2009-12-12 11:07:52 UTC (rev 5157)
@@ -1,641 +0,0 @@
--- remove event handlers, are now in the script
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
-UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
--- new definition of addWMSfromfilteredList_ajax due to i18n
-UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
--- polish entries for translations table
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
--- update wfs conf module
-e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
-WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
-ALTER TABLE wfs_conf ADD COLUMN
-wfs_conf_type int4 NOT NULL DEFAULT 0;
--- new wfs conf columns
-ALTER TABLE wfs_conf_element ADD COLUMN
-f_helptext text;
-f_category_name varchar(255) NOT NULL DEFAULT '';
--- reload uses Mapbender API
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
--- init event is now triggered by jQuery
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
--- mapframe layers are now added dynamically by the modules
-UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
--- file extension is now .js
-UPDATE gui_element SET e_js_file = 'mod_log.js' WHERE e_id = 'log';
-UPDATE gui_element SET e_js_file = 'mod_resize_mapsize.js' WHERE e_id = 'resizeMapsize';
-UPDATE gui_element SET e_js_file = 'mod_sandclock.js' WHERE e_id = 'sandclock';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_zoomFull.js' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_repaint.js' WHERE e_id = 'repaint';
-UPDATE gui_element SET e_js_file = 'mod_changeEPSG.js' WHERE e_id = 'changeEPSG';
-UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
--- parameter: skip WMS request if current SRS is not supported
--- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
----------------------------------------------MONITORING BEGIN
--- Index: idx_mb_monitor_status
--- DROP INDEX idx_mb_monitor_status;
-CREATE INDEX idx_mb_monitor_status
- ON mb_monitor
- USING btree
- (status);
--- Index: idx_mb_monitor_upload_id
--- DROP INDEX idx_mb_monitor_upload_id;
-CREATE INDEX idx_mb_monitor_upload_id
- ON mb_monitor
- USING btree
- (upload_id);
--- Table: mb_wms_availability
--- DROP TABLE mb_wms_availability;
-CREATE TABLE mb_wms_availability
- fkey_wms_id integer,
- fkey_upload_id character varying,
- last_status integer,
- availability real,
- image integer,
- status_comment character varying,
- average_resp_time real,
- upload_url character varying,
- map_url character varying,
- CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
- REFERENCES wms (wms_id) MATCH SIMPLE
- ON UPDATE CASCADE ON DELETE CASCADE
-WITH OIDS;
--- Function: mb_monitor_after()
--- DROP FUNCTION mb_monitor_after();
-CREATE OR REPLACE FUNCTION mb_monitor_after()
- RETURNS "trigger" AS
-$BODY$DECLARE
- availability_new REAL;
- average_res_cap REAL;
- count_monitors REAL;
- BEGIN
- IF TG_OP = 'UPDATE' THEN
- count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
- --the following should be adopted if the duration of storing is changed!!!
- average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
- IF NEW.status > -1 THEN --service gives caps
- availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
- ELSE --service has problems with caps
- availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
- END IF;
- UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
- RETURN NEW;
- END IF;
- IF TG_OP = 'INSERT' THEN
- IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0 then -- service is not new
- UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
- else --service has not yet been monitored
- INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
- end if;
- RETURN NEW;
- END IF;
- END;
-$BODY$
- LANGUAGE 'plpgsql' VOLATILE;
--- Trigger: mb_monitor_after on mb_monitor
--- DROP TRIGGER mb_monitor_after ON mb_monitor;
-CREATE TRIGGER mb_monitor_after
- AFTER INSERT OR UPDATE
- ON mb_monitor
- FOR EACH ROW
- EXECUTE PROCEDURE mb_monitor_after();
--- Table: mb_user_abo_ows
--- DROP TABLE mb_user_abo_ows;
-CREATE TABLE mb_user_abo_ows
- fkey_mb_user_id integer,
- fkey_wfs_id integer,
- CONSTRAINT mb_user_abo_ows_user_id_fkey FOREIGN KEY (fkey_mb_user_id)
- REFERENCES mb_user (mb_user_id) MATCH SIMPLE
- ON UPDATE CASCADE ON DELETE CASCADE,
- CONSTRAINT mb_user_abo_ows_wfs_fkey FOREIGN KEY (fkey_wfs_id)
- REFERENCES wfs (wfs_id) MATCH SIMPLE
- CONSTRAINT mb_user_abo_ows_wms_fkey FOREIGN KEY (fkey_wms_id)
-WITHOUT OIDS;
--- Index: idx_wms_id
--- DROP INDEX idx_wms_id;
-CREATE INDEX idx_wms_id
- ON wms
- USING btree
- (wms_id);
--- add monitor subscriber notification to admin1
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/');
--- add monitor results to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/');
----------------------------------------------MONITORING END
--- OWS Proxy log
-CREATE TABLE mb_proxy_log (
- proxy_log_timestamp timestamp default now(),
- fkey_wms_id integer NOT NULL,
- fkey_mb_user_id integer NOT NULL,
- request varchar(4096),
- pixel bigint,
- price real
-with oids;
-ALTER TABLE wms ADD COLUMN wms_proxylog integer;
-ALTER TABLE wms ALTER COLUMN wms_proxylog SET STORAGE PLAIN;
-ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
-ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
--- http auth
-ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
--- Column: mb_user_digest
--- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
-ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
-ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
---Initial filling with empty strings
-UPDATE mb_user set mb_user_digest='';
---howto set up the http_auth digest hash
---update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
--- http://www.mapbender.org/FeatureInfo#considerScalehints --
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- greek updates for translations table
-update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr';
-update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr';
-update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr';
-UPDATE gui_element SET e_js_file = 'mod_selArea.js' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_js_file = 'mod_zoomIn1.js' WHERE e_id = 'zoomIn1';
-UPDATE gui_element SET e_js_file = 'mod_overview.js' WHERE e_id = 'overview';
-UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
--- set white background to Mapframe1
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
--- background to overview
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
-UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
--- remove title tag of Mapframe1 because it's displayed im Map
-UPDATE gui_element SET e_title='' WHERE e_id='mapframe1';
-UPDATE gui_element SET e_title='' WHERE e_id='overview';
--- resize admin frame in admin guis
-UPDATE gui_element SET e_width = 1000 WHERE e_id = 'AdminFrame';
--- CSW handling add CSW administration to admin2_de , admin2_en, admin1
--- admin2_en
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
--- admin2_de
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
--- admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
--- add CSW search to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW');
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
--- CSW Support - new Tables to build up CSW support
-CREATE TABLE cat
- cat_id serial NOT NULL, -- auto generated
- cat_version character varying(50) NOT NULL DEFAULT ''::character varying, -- get from cat version from xml - service_type_version
- --cat_name character varying(255), -- ows-service-id:title
- cat_title character varying(255) NOT NULL DEFAULT ''::character varying, --ows-service-id:title
- cat_abstract text, --ows-service-id:abstract
- --cat_keywords do we need them? There maybe a special table? - cs:keywords - another table to hold kw
- --UploadUrl
- cat_upload_url character varying(255),
- fees character varying(50), --servicetype-fees
- accessconstraints text, -- servicetype-accessconstraints
- --ServiceProvider
- providername character varying(255),
- providersite character varying(255),
- --ServiceContact
- individualname character varying(255),
- positionname character varying(255),
- --ContactInfo
- voice character varying(255), -- Phone
- facsimile character varying(255),
- --Address
- deliverypoint character varying(255),
- city character varying(255),
- administrativearea character varying(255),
- postalcode character varying(255),
- country character varying(255),
- electronicmailaddress character varying(255),
- --Whole Cap-doc
- cat_getcapabilities_doc text,
- --Information about Owner
- cat_owner integer,
- --Actuality
- cat_timestamp integer
-ALTER TABLE ONLY cat
- ADD CONSTRAINT cat_pkey PRIMARY KEY (cat_id);
-CREATE TABLE cat_keyword (
- fkey_cat_id integer NOT NULL,
- fkey_keyword_id integer NOT NULL
-ALTER TABLE ONLY cat_keyword
- ADD CONSTRAINT pk_cat_keyword PRIMARY KEY (fkey_cat_id, fkey_keyword_id);
- ADD CONSTRAINT fkey_keyword_id_fkey_cat_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
- ADD CONSTRAINT fkey_cat_id_fkey_keyword_id FOREIGN KEY (fkey_cat_id) REFERENCES cat(cat_id) ON UPDATE CASCADE ON DELETE CASCADE;
-CREATE TABLE gui_cat
- fkey_gui_id character varying(50) NOT NULL DEFAULT ''::character varying,
- fkey_cat_id integer NOT NULL DEFAULT 0,
- CONSTRAINT fkey_cat_gui_id FOREIGN KEY (fkey_gui_id)
- REFERENCES gui (gui_id) MATCH SIMPLE
- CONSTRAINT fkey_cat_cat_id FOREIGN KEY (fkey_cat_id)
- REFERENCES cat (cat_id) MATCH SIMPLE
-CREATE TABLE cat_op_conf
- fk_cat_id integer NOT NULL,
- param_name character varying(255) NOT NULL,
- param_value text NOT NULL,
- param_type character varying(255) NOT NULL,
- CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
- CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
--- remove obsolete src from treeGDE (no longer a frame)
-UPDATE gui_element SET e_src = '' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from treeGDE (no longer a frame)
-UPDATE gui_element SET e_attributes = 'onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from switchLocale_noreload
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'switchLocale_noreload';
--- add title
-UPDATE gui_element SET e_content = '<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>' WHERE e_id = 'setBackground';
--- remove nobr tag from mapbender
-UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
--- correct URL encoding
-UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();" onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
--- added mandatory action attribute
-UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
-UPDATE gui_element SET e_attributes = 'action="window.location.href" onsubmit="return mod_scaleText()"' WHERE e_id = 'scaleText';
-UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
--- attributes only valid for printPDF button (img)
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
--- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundColor','#799FEB','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundHoverColor','#577dc9','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-ALTER TABLE mb_user_wmc ADD COLUMN
-wmc_timestamp_create INTEGER;
-CREATE TABLE wmc_md_topic_category (
- fkey_wmc_id character varying(20) NOT NULL,
- fkey_md_topic_category_id integer NOT NULL
-ALTER TABLE ONLY wmc_md_topic_category
- ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
--- jQuery UI
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
--- jQuery datatables
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
--- jQuery UI tabs
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
--- jQuery upload
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','','');
--- jQuery CSS in Body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
-wmc_public INTEGER NOT NULL DEFAULT 0;
--- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
-UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
--- add jquery ui dialog to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
--- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'savewmc', 'overwrite', '0', '' ,'var');
--- add history to map object
-UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
- ADD COLUMN abstract TEXT,
- ADD COLUMN srs CHARACTER VARYING,
- ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN miny DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN maxx DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN maxy DOUBLE PRECISION DEFAULT 0;
-CREATE TABLE wmc_keyword (
- fkey_keyword_id INTEGER REFERENCES keyword(keyword_id) ON DELETE CASCADE ON UPDATE CASCADE,
- fkey_wmc_id CHARACTER VARYING(20) REFERENCES mb_user_wmc(wmc_id) ON DELETE CASCADE ON UPDATE CASCADE
-ALTER TABLE ONLY wmc_keyword
- ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
--- disable publish WMC and delete WMC for gui1
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'deleteWmc', '0', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'publishWmc', '0', '' ,'var');
--- add publish WMC to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame','');
--- add required modules for loadwmc and savewmc
-UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
-UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
--- set new element vars for existing gui elements of non-standard guis
--- element var skipWmsIfSrsNotSupported for gui element mapframe1
-SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars
-WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
--- element var skipWmsIfSrsNotSupported for gui element overview
-SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported'
-AND fkey_e_id = 'overview');
--- element var backGroundColor for gui element navFrame
-SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var'
-FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor'
-AND fkey_e_id = 'navFrame');
--- element var backGroundHoverColor for gui element navFrame
-SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var'
-WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
--- element var overwrite for gui element savewmc
-SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
-WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
--- element var deleteWmc for gui element loadwmc
-SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'loadwmc'
-AND gui_element.fkey_gui_id
-WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
--- element var publishWmc for gui element loadwmc
-SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element
-WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
-WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
--- element var switchwms for gui element treeGDE
-SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id
-WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext'
-FROM gui_element WHERE gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
--- increase fields for wfs featuretype attributes name
-ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
--- add georss in gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var');
--- element var initializeOnLoad for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
--- element var enableSearchWithoutParams for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
-UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
\ No newline at end of file
Copied: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql (from rev 5154, trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql)
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql (rev 0)
@@ -0,0 +1,659 @@
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
+UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
+-- new definition of addWMSfromfilteredList_ajax due to i18n
+UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
+-- polish entries for translations table
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
+-- update wfs conf module
+e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
+WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
+ALTER TABLE wfs_conf ADD COLUMN
+wfs_conf_type int4 NOT NULL DEFAULT 0;
+-- new wfs conf columns
+ALTER TABLE wfs_conf_element ADD COLUMN
+f_helptext text;
+f_category_name varchar(255) NOT NULL DEFAULT '';
+-- reload uses Mapbender API
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
+-- init event is now triggered by jQuery
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
+-- mapframe layers are now added dynamically by the modules
+UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
+-- file extension is now .js
+UPDATE gui_element SET e_js_file = 'mod_log.js' WHERE e_id = 'log';
+UPDATE gui_element SET e_js_file = 'mod_resize_mapsize.js' WHERE e_id = 'resizeMapsize';
+UPDATE gui_element SET e_js_file = 'mod_sandclock.js' WHERE e_id = 'sandclock';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomFull';
+UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_zoomFull.js' WHERE e_id = 'zoomFull';
+UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_repaint.js' WHERE e_id = 'repaint';
+UPDATE gui_element SET e_js_file = 'mod_changeEPSG.js' WHERE e_id = 'changeEPSG';
+UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
+-- parameter: skip WMS request if current SRS is not supported
+-- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+---------------------------------------------MONITORING BEGIN
+-- Index: idx_mb_monitor_status
+-- DROP INDEX idx_mb_monitor_status;
+CREATE INDEX idx_mb_monitor_status
+ ON mb_monitor
+ USING btree
+ (status);
+-- Index: idx_mb_monitor_upload_id
+-- DROP INDEX idx_mb_monitor_upload_id;
+CREATE INDEX idx_mb_monitor_upload_id
+ ON mb_monitor
+ USING btree
+ (upload_id);
+-- Table: mb_wms_availability
+-- DROP TABLE mb_wms_availability;
+CREATE TABLE mb_wms_availability
+ fkey_wms_id integer,
+ fkey_upload_id character varying,
+ last_status integer,
+ availability real,
+ image integer,
+ status_comment character varying,
+ average_resp_time real,
+ upload_url character varying,
+ map_url character varying,
+ CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
+ REFERENCES wms (wms_id) MATCH SIMPLE
+ ON UPDATE CASCADE ON DELETE CASCADE
+WITH OIDS;
+-- Function: mb_monitor_after()
+-- DROP FUNCTION mb_monitor_after();
+CREATE OR REPLACE FUNCTION mb_monitor_after()
+ RETURNS "trigger" AS
+$BODY$DECLARE
+ availability_new REAL;
+ average_res_cap REAL;
+ count_monitors REAL;
+ BEGIN
+ IF TG_OP = 'UPDATE' THEN
+ count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
+ --the following should be adopted if the duration of storing is changed!!!
+ average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
+ IF NEW.status > -1 THEN --service gives caps
+ availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
+ ELSE --service has problems with caps
+ availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
+ END IF;
+ UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
+ RETURN NEW;
+ END IF;
+ IF TG_OP = 'INSERT' THEN
+ IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0 then -- service is not new
+ UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
+ else --service has not yet been monitored
+ INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
+ end if;
+ RETURN NEW;
+ END IF;
+ END;
+$BODY$
+ LANGUAGE 'plpgsql' VOLATILE;
+-- Trigger: mb_monitor_after on mb_monitor
+-- DROP TRIGGER mb_monitor_after ON mb_monitor;
+CREATE TRIGGER mb_monitor_after
+ AFTER INSERT OR UPDATE
+ ON mb_monitor
+ FOR EACH ROW
+ EXECUTE PROCEDURE mb_monitor_after();
+-- Table: mb_user_abo_ows
+-- DROP TABLE mb_user_abo_ows;
+CREATE TABLE mb_user_abo_ows
+ fkey_mb_user_id integer,
+ fkey_wfs_id integer,
+ CONSTRAINT mb_user_abo_ows_user_id_fkey FOREIGN KEY (fkey_mb_user_id)
+ REFERENCES mb_user (mb_user_id) MATCH SIMPLE
+ ON UPDATE CASCADE ON DELETE CASCADE,
+ CONSTRAINT mb_user_abo_ows_wfs_fkey FOREIGN KEY (fkey_wfs_id)
+ REFERENCES wfs (wfs_id) MATCH SIMPLE
+ CONSTRAINT mb_user_abo_ows_wms_fkey FOREIGN KEY (fkey_wms_id)
+WITHOUT OIDS;
+-- Index: idx_wms_id
+-- DROP INDEX idx_wms_id;
+CREATE INDEX idx_wms_id
+ ON wms
+ USING btree
+ (wms_id);
+-- add monitor subscriber notification to admin1
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/');
+-- add monitor results to admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/');
+---------------------------------------------MONITORING END
+-- OWS Proxy log
+CREATE TABLE mb_proxy_log (
+ proxy_log_timestamp timestamp default now(),
+ fkey_wms_id integer NOT NULL,
+ fkey_mb_user_id integer NOT NULL,
+ request varchar(4096),
+ pixel bigint,
+ price real
+with oids;
+ALTER TABLE wms ADD COLUMN wms_proxylog integer;
+ALTER TABLE wms ALTER COLUMN wms_proxylog SET STORAGE PLAIN;
+ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
+ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
+-- http auth
+ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
+-- Column: mb_user_digest
+-- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
+ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
+ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
+--Initial filling with empty strings
+UPDATE mb_user set mb_user_digest='';
+--howto set up the http_auth digest hash
+--update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
+-- http://www.mapbender.org/FeatureInfo#considerScalehints --
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- greek updates for translations table
+update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr';
+update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr';
+update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr';
+UPDATE gui_element SET e_js_file = 'mod_selArea.js' WHERE e_id = 'selArea1';
+UPDATE gui_element SET e_js_file = 'mod_zoomIn1.js' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_js_file = 'mod_overview.js' WHERE e_id = 'overview';
+UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
+-- set white background to Mapframe1
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
+-- background to overview
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
+UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
+-- remove title tag of Mapframe1 because it's displayed im Map
+UPDATE gui_element SET e_title='' WHERE e_id='mapframe1';
+UPDATE gui_element SET e_title='' WHERE e_id='overview';
+-- resize admin frame in admin guis
+UPDATE gui_element SET e_width = 1000 WHERE e_id = 'AdminFrame';
+-- CSW handling add CSW administration to admin2_de , admin2_en, admin1
+-- admin2_en
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+-- admin2_de
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', '');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+-- admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+-- add CSW search to gui1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW');
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
+-- CSW Support - new Tables to build up CSW support
+CREATE TABLE cat
+ cat_id serial NOT NULL, -- auto generated
+ cat_version character varying(50) NOT NULL DEFAULT ''::character varying, -- get from cat version from xml - service_type_version
+ --cat_name character varying(255), -- ows-service-id:title
+ cat_title character varying(255) NOT NULL DEFAULT ''::character varying, --ows-service-id:title
+ cat_abstract text, --ows-service-id:abstract
+ --cat_keywords do we need them? There maybe a special table? - cs:keywords - another table to hold kw
+ --UploadUrl
+ cat_upload_url character varying(255),
+ fees character varying(50), --servicetype-fees
+ accessconstraints text, -- servicetype-accessconstraints
+ --ServiceProvider
+ providername character varying(255),
+ providersite character varying(255),
+ --ServiceContact
+ individualname character varying(255),
+ positionname character varying(255),
+ --ContactInfo
+ voice character varying(255), -- Phone
+ facsimile character varying(255),
+ --Address
+ deliverypoint character varying(255),
+ city character varying(255),
+ administrativearea character varying(255),
+ postalcode character varying(255),
+ country character varying(255),
+ electronicmailaddress character varying(255),
+ --Whole Cap-doc
+ cat_getcapabilities_doc text,
+ --Information about Owner
+ cat_owner integer,
+ --Actuality
+ cat_timestamp integer
+ALTER TABLE ONLY cat
+ ADD CONSTRAINT cat_pkey PRIMARY KEY (cat_id);
+CREATE TABLE cat_keyword (
+ fkey_cat_id integer NOT NULL,
+ fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY cat_keyword
+ ADD CONSTRAINT pk_cat_keyword PRIMARY KEY (fkey_cat_id, fkey_keyword_id);
+ ADD CONSTRAINT fkey_keyword_id_fkey_cat_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT fkey_cat_id_fkey_keyword_id FOREIGN KEY (fkey_cat_id) REFERENCES cat(cat_id) ON UPDATE CASCADE ON DELETE CASCADE;
+CREATE TABLE gui_cat
+ fkey_gui_id character varying(50) NOT NULL DEFAULT ''::character varying,
+ fkey_cat_id integer NOT NULL DEFAULT 0,
+ CONSTRAINT fkey_cat_gui_id FOREIGN KEY (fkey_gui_id)
+ REFERENCES gui (gui_id) MATCH SIMPLE
+ CONSTRAINT fkey_cat_cat_id FOREIGN KEY (fkey_cat_id)
+ REFERENCES cat (cat_id) MATCH SIMPLE
+CREATE TABLE cat_op_conf
+ fk_cat_id integer NOT NULL,
+ param_name character varying(255) NOT NULL,
+ param_value text NOT NULL,
+ param_type character varying(255) NOT NULL,
+ CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
+ CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
+-- remove obsolete src from treeGDE (no longer a frame)
+UPDATE gui_element SET e_src = '' WHERE e_id = 'treeGDE';
+-- remove frameborder = 0 from treeGDE (no longer a frame)
+UPDATE gui_element SET e_attributes = 'onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"' WHERE e_id = 'treeGDE';
+-- remove frameborder = 0 from switchLocale_noreload
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'switchLocale_noreload';
+-- add title
+UPDATE gui_element SET e_content = '<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>' WHERE e_id = 'setBackground';
+-- remove nobr tag from mapbender
+UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
+-- correct URL encoding
+UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();" onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
+-- added mandatory action attribute
+UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
+UPDATE gui_element SET e_attributes = 'action="window.location.href" onsubmit="return mod_scaleText()"' WHERE e_id = 'scaleText';
+UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
+-- attributes only valid for printPDF button (img)
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
+-- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundColor','#799FEB','set the background-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundHoverColor','#577dc9','set the background-hover-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
+INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
+ALTER TABLE mb_user_wmc ADD COLUMN
+wmc_timestamp_create INTEGER;
+CREATE TABLE wmc_md_topic_category (
+ fkey_wmc_id character varying(20) NOT NULL,
+ fkey_md_topic_category_id integer NOT NULL
+ALTER TABLE ONLY wmc_md_topic_category
+ ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- jQuery UI
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
+-- jQuery datatables
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+-- jQuery UI tabs
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
+-- jQuery upload
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','','');
+-- jQuery CSS in Body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+wmc_public INTEGER NOT NULL DEFAULT 0;
+-- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
+UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
+-- add jquery ui dialog to gui1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
+-- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'savewmc', 'overwrite', '0', '' ,'var');
+-- add history to map object
+UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
+ ADD COLUMN abstract TEXT,
+ ADD COLUMN srs CHARACTER VARYING,
+ ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
+ ADD COLUMN miny DOUBLE PRECISION DEFAULT 0,
+ ADD COLUMN maxx DOUBLE PRECISION DEFAULT 0,
+ ADD COLUMN maxy DOUBLE PRECISION DEFAULT 0;
+CREATE TABLE wmc_keyword (
+ fkey_keyword_id INTEGER REFERENCES keyword(keyword_id) ON DELETE CASCADE ON UPDATE CASCADE,
+ fkey_wmc_id CHARACTER VARYING(20) REFERENCES mb_user_wmc(wmc_id) ON DELETE CASCADE ON UPDATE CASCADE
+ALTER TABLE ONLY wmc_keyword
+ ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
+-- disable publish WMC and delete WMC for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'deleteWmc', '0', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'publishWmc', '0', '' ,'var');
+-- add publish WMC to admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame','');
+-- add required modules for loadwmc and savewmc
+UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
+UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
+-- set new element vars for existing gui elements of non-standard guis
+-- element var showResultInPopup for gui element gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'showResultInPopup' AND fkey_e_id = 'gazetteerWFS');
+-- element var wfs_spatial_request_conf_filename for gui element gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'wfs_spatial_request_conf_filename' AND fkey_e_id = 'gazetteerWFS');
+-- element var popupcss for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'popupcss' AND fkey_e_id = 'body');
+-- element var tablesortercss for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tablesortercss' AND fkey_e_id = 'body');
+-- element var use_load_message for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'use_load_message', 'true', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'use_load_message' AND fkey_e_id = 'body');
+-- element var includeWhileLoading for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'includeWhileLoading' AND fkey_e_id = 'body');
+-- element var cssfileAddWMS for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var capabilitiesInput for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'capabilitiesInput' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dball for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dball' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dbgroup for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgroup' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dbgui for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgui' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var featureInfoLayerPopup for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoLayerPopup' AND fkey_e_id = 'featureInfoTunnel');
+-- element var featureInfoPopupHeight for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupHeight' AND fkey_e_id = 'featureInfoTunnel');
+-- element var featureInfoPopupWidth for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupWidth' AND fkey_e_id = 'featureInfoTunnel');
+-- element var skipWmsIfSrsNotSupported for gui element mapframe1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
+-- element var skipWmsIfSrsNotSupported for gui element overview
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'overview');
+-- element var backGroundColor for gui element navFrame
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame');
+-- element var backGroundHoverColor for gui element navFrame
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
+-- element var overwrite for gui element savewmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
+-- element var deleteWmc for gui element loadwmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
+-- element var publishWmc for gui element loadwmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
+-- element var tooltip_noResultArray for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_noResultArray' AND fkey_e_id = 'tooltip');
+-- element var tooltip_disableWfs for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWfs' AND fkey_e_id = 'tooltip');
+-- element var tooltip_disableWms for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWms' AND fkey_e_id = 'tooltip');
+-- element var switchwms for gui element treeGDE
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var' FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+-- element var favicon for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon' AND fkey_e_id = 'body');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext' FROM gui_element WHERE gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
+-- increase fields for wfs featuretype attributes name
+ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
+-- add georss in gui1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var');
+-- element var initializeOnLoad for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
+-- element var enableSearchWithoutParams for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
+UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
Deleted: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-12-12 11:05:58 UTC (rev 5156)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-12-12 11:07:52 UTC (rev 5157)
@@ -1,659 +0,0 @@
--- remove event handlers, are now in the script
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
-UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
--- new definition of addWMSfromfilteredList_ajax due to i18n
-UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
--- polish entries for translations table
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
--- update wfs conf module
-e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
-WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
-ALTER TABLE wfs_conf ADD COLUMN
-wfs_conf_type int4 NOT NULL DEFAULT 0;
--- new wfs conf columns
-ALTER TABLE wfs_conf_element ADD COLUMN
-f_helptext text;
-f_category_name varchar(255) NOT NULL DEFAULT '';
--- reload uses Mapbender API
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
--- init event is now triggered by jQuery
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
--- mapframe layers are now added dynamically by the modules
-UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
--- file extension is now .js
-UPDATE gui_element SET e_js_file = 'mod_log.js' WHERE e_id = 'log';
-UPDATE gui_element SET e_js_file = 'mod_resize_mapsize.js' WHERE e_id = 'resizeMapsize';
-UPDATE gui_element SET e_js_file = 'mod_sandclock.js' WHERE e_id = 'sandclock';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_zoomFull.js' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_repaint.js' WHERE e_id = 'repaint';
-UPDATE gui_element SET e_js_file = 'mod_changeEPSG.js' WHERE e_id = 'changeEPSG';
-UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
--- parameter: skip WMS request if current SRS is not supported
--- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
----------------------------------------------MONITORING BEGIN
--- Index: idx_mb_monitor_status
--- DROP INDEX idx_mb_monitor_status;
-CREATE INDEX idx_mb_monitor_status
- ON mb_monitor
- USING btree
- (status);
--- Index: idx_mb_monitor_upload_id
--- DROP INDEX idx_mb_monitor_upload_id;
-CREATE INDEX idx_mb_monitor_upload_id
- ON mb_monitor
- USING btree
- (upload_id);
--- Table: mb_wms_availability
--- DROP TABLE mb_wms_availability;
-CREATE TABLE mb_wms_availability
- fkey_wms_id integer,
- fkey_upload_id character varying,
- last_status integer,
- availability real,
- image integer,
- status_comment character varying,
- average_resp_time real,
- upload_url character varying,
- map_url character varying,
- CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
- REFERENCES wms (wms_id) MATCH SIMPLE
- ON UPDATE CASCADE ON DELETE CASCADE
-WITH OIDS;
--- Function: mb_monitor_after()
--- DROP FUNCTION mb_monitor_after();
-CREATE OR REPLACE FUNCTION mb_monitor_after()
- RETURNS "trigger" AS
-$BODY$DECLARE
- availability_new REAL;
- average_res_cap REAL;
- count_monitors REAL;
- BEGIN
- IF TG_OP = 'UPDATE' THEN
- count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
- --the following should be adopted if the duration of storing is changed!!!
- average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
- IF NEW.status > -1 THEN --service gives caps
- availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
- ELSE --service has problems with caps
- availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
- END IF;
- UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
- RETURN NEW;
- END IF;
- IF TG_OP = 'INSERT' THEN
- IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0 then -- service is not new
- UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
- else --service has not yet been monitored
- INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
- end if;
- RETURN NEW;
- END IF;
- END;
-$BODY$
- LANGUAGE 'plpgsql' VOLATILE;
--- Trigger: mb_monitor_after on mb_monitor
--- DROP TRIGGER mb_monitor_after ON mb_monitor;
-CREATE TRIGGER mb_monitor_after
- AFTER INSERT OR UPDATE
- ON mb_monitor
- FOR EACH ROW
- EXECUTE PROCEDURE mb_monitor_after();
--- Table: mb_user_abo_ows
--- DROP TABLE mb_user_abo_ows;
-CREATE TABLE mb_user_abo_ows
- fkey_mb_user_id integer,
- fkey_wfs_id integer,
- CONSTRAINT mb_user_abo_ows_user_id_fkey FOREIGN KEY (fkey_mb_user_id)
- REFERENCES mb_user (mb_user_id) MATCH SIMPLE
- ON UPDATE CASCADE ON DELETE CASCADE,
- CONSTRAINT mb_user_abo_ows_wfs_fkey FOREIGN KEY (fkey_wfs_id)
- REFERENCES wfs (wfs_id) MATCH SIMPLE
- CONSTRAINT mb_user_abo_ows_wms_fkey FOREIGN KEY (fkey_wms_id)
-WITHOUT OIDS;
--- Index: idx_wms_id
--- DROP INDEX idx_wms_id;
-CREATE INDEX idx_wms_id
- ON wms
- USING btree
- (wms_id);
--- add monitor subscriber notification to admin1
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/');
--- add monitor results to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/');
----------------------------------------------MONITORING END
--- OWS Proxy log
-CREATE TABLE mb_proxy_log (
- proxy_log_timestamp timestamp default now(),
- fkey_wms_id integer NOT NULL,
- fkey_mb_user_id integer NOT NULL,
- request varchar(4096),
- pixel bigint,
- price real
-with oids;
-ALTER TABLE wms ADD COLUMN wms_proxylog integer;
-ALTER TABLE wms ALTER COLUMN wms_proxylog SET STORAGE PLAIN;
-ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
-ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
--- http auth
-ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
--- Column: mb_user_digest
--- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
-ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
-ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
---Initial filling with empty strings
-UPDATE mb_user set mb_user_digest='';
---howto set up the http_auth digest hash
---update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
--- http://www.mapbender.org/FeatureInfo#considerScalehints --
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- greek updates for translations table
-update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr';
-update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr';
-update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr';
-UPDATE gui_element SET e_js_file = 'mod_selArea.js' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_js_file = 'mod_zoomIn1.js' WHERE e_id = 'zoomIn1';
-UPDATE gui_element SET e_js_file = 'mod_overview.js' WHERE e_id = 'overview';
-UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
--- set white background to Mapframe1
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
--- background to overview
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
-UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
--- remove title tag of Mapframe1 because it's displayed im Map
-UPDATE gui_element SET e_title='' WHERE e_id='mapframe1';
-UPDATE gui_element SET e_title='' WHERE e_id='overview';
--- resize admin frame in admin guis
-UPDATE gui_element SET e_width = 1000 WHERE e_id = 'AdminFrame';
--- CSW handling add CSW administration to admin2_de , admin2_en, admin1
--- admin2_en
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
--- admin2_de
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
--- admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
--- add CSW search to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW');
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
--- CSW Support - new Tables to build up CSW support
-CREATE TABLE cat
- cat_id serial NOT NULL, -- auto generated
- cat_version character varying(50) NOT NULL DEFAULT ''::character varying, -- get from cat version from xml - service_type_version
- --cat_name character varying(255), -- ows-service-id:title
- cat_title character varying(255) NOT NULL DEFAULT ''::character varying, --ows-service-id:title
- cat_abstract text, --ows-service-id:abstract
- --cat_keywords do we need them? There maybe a special table? - cs:keywords - another table to hold kw
- --UploadUrl
- cat_upload_url character varying(255),
- fees character varying(50), --servicetype-fees
- accessconstraints text, -- servicetype-accessconstraints
- --ServiceProvider
- providername character varying(255),
- providersite character varying(255),
- --ServiceContact
- individualname character varying(255),
- positionname character varying(255),
- --ContactInfo
- voice character varying(255), -- Phone
- facsimile character varying(255),
- --Address
- deliverypoint character varying(255),
- city character varying(255),
- administrativearea character varying(255),
- postalcode character varying(255),
- country character varying(255),
- electronicmailaddress character varying(255),
- --Whole Cap-doc
- cat_getcapabilities_doc text,
- --Information about Owner
- cat_owner integer,
- --Actuality
- cat_timestamp integer
-ALTER TABLE ONLY cat
- ADD CONSTRAINT cat_pkey PRIMARY KEY (cat_id);
-CREATE TABLE cat_keyword (
- fkey_cat_id integer NOT NULL,
- fkey_keyword_id integer NOT NULL
-ALTER TABLE ONLY cat_keyword
- ADD CONSTRAINT pk_cat_keyword PRIMARY KEY (fkey_cat_id, fkey_keyword_id);
- ADD CONSTRAINT fkey_keyword_id_fkey_cat_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
- ADD CONSTRAINT fkey_cat_id_fkey_keyword_id FOREIGN KEY (fkey_cat_id) REFERENCES cat(cat_id) ON UPDATE CASCADE ON DELETE CASCADE;
-CREATE TABLE gui_cat
- fkey_gui_id character varying(50) NOT NULL DEFAULT ''::character varying,
- fkey_cat_id integer NOT NULL DEFAULT 0,
- CONSTRAINT fkey_cat_gui_id FOREIGN KEY (fkey_gui_id)
- REFERENCES gui (gui_id) MATCH SIMPLE
- CONSTRAINT fkey_cat_cat_id FOREIGN KEY (fkey_cat_id)
- REFERENCES cat (cat_id) MATCH SIMPLE
-CREATE TABLE cat_op_conf
- fk_cat_id integer NOT NULL,
- param_name character varying(255) NOT NULL,
- param_value text NOT NULL,
- param_type character varying(255) NOT NULL,
- CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
- CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
--- remove obsolete src from treeGDE (no longer a frame)
-UPDATE gui_element SET e_src = '' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from treeGDE (no longer a frame)
-UPDATE gui_element SET e_attributes = 'onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from switchLocale_noreload
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'switchLocale_noreload';
--- add title
-UPDATE gui_element SET e_content = '<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>' WHERE e_id = 'setBackground';
--- remove nobr tag from mapbender
-UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
--- correct URL encoding
-UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();" onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
--- added mandatory action attribute
-UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
-UPDATE gui_element SET e_attributes = 'action="window.location.href" onsubmit="return mod_scaleText()"' WHERE e_id = 'scaleText';
-UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
--- attributes only valid for printPDF button (img)
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
--- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundColor','#799FEB','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundHoverColor','#577dc9','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-ALTER TABLE mb_user_wmc ADD COLUMN
-wmc_timestamp_create INTEGER;
-CREATE TABLE wmc_md_topic_category (
- fkey_wmc_id character varying(20) NOT NULL,
- fkey_md_topic_category_id integer NOT NULL
-ALTER TABLE ONLY wmc_md_topic_category
- ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
--- jQuery UI
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
--- jQuery datatables
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
--- jQuery UI tabs
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
--- jQuery upload
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','','');
--- jQuery CSS in Body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
-wmc_public INTEGER NOT NULL DEFAULT 0;
--- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
-UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
--- add jquery ui dialog to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
--- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'savewmc', 'overwrite', '0', '' ,'var');
--- add history to map object
-UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
- ADD COLUMN abstract TEXT,
- ADD COLUMN srs CHARACTER VARYING,
- ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN miny DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN maxx DOUBLE PRECISION DEFAULT 0,
- ADD COLUMN maxy DOUBLE PRECISION DEFAULT 0;
-CREATE TABLE wmc_keyword (
- fkey_keyword_id INTEGER REFERENCES keyword(keyword_id) ON DELETE CASCADE ON UPDATE CASCADE,
- fkey_wmc_id CHARACTER VARYING(20) REFERENCES mb_user_wmc(wmc_id) ON DELETE CASCADE ON UPDATE CASCADE
-ALTER TABLE ONLY wmc_keyword
- ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
--- disable publish WMC and delete WMC for gui1
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'deleteWmc', '0', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'publishWmc', '0', '' ,'var');
--- add publish WMC to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame','');
--- add required modules for loadwmc and savewmc
-UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
-UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
--- set new element vars for existing gui elements of non-standard guis
--- element var showResultInPopup for gui element gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'showResultInPopup' AND fkey_e_id = 'gazetteerWFS');
--- element var wfs_spatial_request_conf_filename for gui element gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'wfs_spatial_request_conf_filename' AND fkey_e_id = 'gazetteerWFS');
--- element var popupcss for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'popupcss' AND fkey_e_id = 'body');
--- element var tablesortercss for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tablesortercss' AND fkey_e_id = 'body');
--- element var use_load_message for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'use_load_message', 'true', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'use_load_message' AND fkey_e_id = 'body');
--- element var includeWhileLoading for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'includeWhileLoading' AND fkey_e_id = 'body');
--- element var cssfileAddWMS for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var capabilitiesInput for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'capabilitiesInput' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dball for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dball' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dbgroup for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgroup' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dbgui for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgui' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var featureInfoLayerPopup for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoLayerPopup' AND fkey_e_id = 'featureInfoTunnel');
--- element var featureInfoPopupHeight for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupHeight' AND fkey_e_id = 'featureInfoTunnel');
--- element var featureInfoPopupWidth for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupWidth' AND fkey_e_id = 'featureInfoTunnel');
--- element var skipWmsIfSrsNotSupported for gui element mapframe1
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
--- element var skipWmsIfSrsNotSupported for gui element overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'overview');
--- element var backGroundColor for gui element navFrame
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame');
--- element var backGroundHoverColor for gui element navFrame
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
--- element var overwrite for gui element savewmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
--- element var deleteWmc for gui element loadwmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
--- element var publishWmc for gui element loadwmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
--- element var tooltip_noResultArray for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_noResultArray' AND fkey_e_id = 'tooltip');
--- element var tooltip_disableWfs for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWfs' AND fkey_e_id = 'tooltip');
--- element var tooltip_disableWms for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWms' AND fkey_e_id = 'tooltip');
--- element var switchwms for gui element treeGDE
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var' FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
--- element var favicon for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon' AND fkey_e_id = 'body');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext' FROM gui_element WHERE gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
--- increase fields for wfs featuretype attributes name
-ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
--- add georss in gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var');
--- element var initializeOnLoad for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
--- element var enableSearchWithoutParams for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
-UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
\ No newline at end of file
More information about the Mapbender_commits
