[Mapbender-commits] r5161 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Sat Dec 12 07:30:43 EST 2009
Author: topi
Date: 2009-12-12 07:30:41 -0500 (Sat, 12 Dec 2009)
New Revision: 5161
trunk/mapbender/http/plugins/jq_ui_accordion.js
Modified: trunk/mapbender/http/plugins/jq_ui_accordion.js
--- trunk/mapbender/http/plugins/jq_ui_accordion.js 2009-12-12 11:18:35 UTC (rev 5160)
+++ trunk/mapbender/http/plugins/jq_ui_accordion.js 2009-12-12 12:30:41 UTC (rev 5161)
@@ -3,27 +3,27 @@
* Description:
* An accordion decorator, replaces the deprecated element "tabs"
- * Enter the elements to be put in the accordion in its target field
+ * Enter the elements to be put in the accordion in its target field
* (comma-separated list of element ids).
- * Avoid styles in elements within the accordion.
- * The overview won't work in the accordion, as it cannot be positioned
+ * Avoid styles in elements within the accordion.
+ * The overview won't work in the accordion, as it cannot be positioned
* absolutely.
* The width of this module determines the accordion width, but the height
- * of the individual elements determines the height.
+ * of the individual elements determines the height.
* Files:
* - http/plugins/jq_ui_accordion.js
* - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js
* SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
* > e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>','jq_ui_accordion',2,1,
* > 'An accordion decorator, replaces the deprecated element tabs','','div',
* > '','',10,240,300,NULL ,2,'','','div','../plugins/jq_ui_accordion.js',
@@ -35,26 +35,26 @@
* Maintainer:
* http://www.mapbender.org/User:Christoph_Baudson
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
$this = $(this);
// tab to open onload
-var active = typeof options.active !== "number" ?
+var active = typeof options.active !== "number" ?
false : options.active - 1;
for (var i = 0; i < options.target.length; i++) {
$c = $("#" + options.target[i]);
$this.append(
- "<h3><a id='header_" + options.id + "_" + $c.attr("id") +
- "' href='#'>" + Mapbender.modules[$c.attr("id")].currentTitle +
+ "<h3><a id='header_" + options.id + "_" + $c.attr("id") +
+ "' href='#'>" + Mapbender.modules[$c.attr("id")].currentTitle +
"</a></h3>"
).append(
@@ -67,9 +67,14 @@
-$("#" + options.id).accordion({
+var accordionOptions = {
collapsible: true,
autoHeight: false,
active: active
+if (typeof options.attribute !== "undefined") {
+ accordionOptions[attribute] = options.attribute;
+$("#" + options.id).accordion(accordionOptions);
More information about the Mapbender_commits
