[Mapbender-commits] r5183 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 12 09:25:09 EST 2009
Author: verenadiewald
Date: 2009-12-12 09:25:09 -0500 (Sat, 12 Dec 2009)
New Revision: 5183
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
updates can now be applied multiple times without causing errors
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2009-12-12 14:21:22 UTC (rev 5182)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2009-12-12 14:25:09 UTC (rev 5183)
@@ -5,61 +5,111 @@
 UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
 -- new definition of addWMSfromfilteredList_ajax due to i18n
 UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
--- polish entries for translations table
+-- polish entries for translations table, delete old ones first to avoid multi entries for one locale
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Pan';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Display complete map';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom in';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom out';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Back';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Forward';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Coordinates';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom by rectangle';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Redraw';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Query';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logout';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'WMS preferences';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from filtered list';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set map center';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Help';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Show WMS infos';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Save workspace as web map context document';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Resize Mapsize';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Rubber';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Get Area';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Close Polygon';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Move back to your GUI list';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Legend';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Print';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Imprint';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Maps';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Search';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Meetingpoint';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Metadatasearch';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from List';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Info';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Projection';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Copyright';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Digitize';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Overview';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Drag Mapsize';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Mapframe';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Navigation Frame';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Select';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Text';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scalebar';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set Background';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom to Coordinates';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Password';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Load a web map context document';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logo';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Measure distance';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set language';
 INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
@@ -114,15 +164,18 @@
 -- parameter: skip WMS request if current SRS is not supported
 -- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui1', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui2', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES( 'gui_digitize', 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars
+WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
+-- element var skipWmsIfSrsNotSupported for gui element overview
+SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported'
+AND fkey_e_id = 'overview');
 ---------------------------------------------MONITORING BEGIN
 -- Index: idx_mb_monitor_status
@@ -177,7 +230,7 @@
    count_monitors REAL;
     BEGIN
      IF TG_OP = 'UPDATE' THEN
      count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
       --the following should be adopted if the duration of storing is changed!!!
       average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
@@ -236,9 +289,9 @@
       REFERENCES wms (wms_id) MATCH SIMPLE
       ON UPDATE CASCADE ON DELETE CASCADE
-WITHOUT OIDS;
+WITHOUT OIDS;
 -- Index: idx_wms_id
 -- DROP INDEX idx_wms_id;
@@ -247,28 +300,36 @@
   ON wms
   USING btree
   (wms_id);
 -- add monitor subscriber notification to admin1
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT gui.gui_id, 'monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/'
+FROM gui WHERE gui.gui_id = 'admin1' AND gui.gui_id
+WHERE e_id = 'monitor_abo_show' AND fkey_gui_id = 'admin1');
 -- add monitor results to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/');
+SELECT gui.gui_id, 'monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/'
+WHERE e_id = 'monitor_results');
 ---------------------------------------------MONITORING END
 -- OWS Proxy log
 CREATE TABLE mb_proxy_log (
     proxy_log_timestamp timestamp default now(),
     fkey_wms_id integer NOT NULL,
     fkey_mb_user_id integer NOT NULL,
     request varchar(4096),
     pixel bigint,
     price real
 with oids;
 ALTER TABLE wms ADD COLUMN wms_proxylog integer;
@@ -293,12 +354,12 @@
 --howto set up the http_auth digest hash
 --update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
 -- http://www.mapbender.org/FeatureInfo#considerScalehints --
 -- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
 -- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
 -- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
@@ -321,10 +382,10 @@
 UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
 -- set white background to Mapframe1
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
 -- background to overview
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
 -- file extension is now .js
 UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
@@ -341,29 +402,73 @@
 -- CSW handling add CSW administration to admin2_de , admin2_en, admin1
 -- admin2_en
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_en', 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', ''
+FROM gui WHERE gui.gui_id = 'admin2_en' AND gui.gui_id
+WHERE e_id = 'headline_Configure_CSW');
+SELECT gui.gui_id, 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+WHERE e_id = 'loadCSW');
+SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+WHERE e_id = 'loadCSWGUI');
 -- admin2_de
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', '');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('admin2_de', 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI');
+SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', ''
+FROM gui WHERE gui.gui_id = 'admin2_de' AND gui.gui_id
+SELECT gui.gui_id, 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
 -- admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+SELECT gui.gui_id, 'loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
+SELECT gui.gui_id, 'loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
 -- add CSW search to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW');
+SELECT gui.gui_id,'addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW'
+FROM gui WHERE gui.gui_id = 'gui1' AND gui.gui_id
+WHERE e_id = 'addCSW');
 -- remove event handlers, are now in the script
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
 -- CSW Support - new Tables to build up CSW support
 CREATE TABLE cat
   cat_id serial NOT NULL, -- auto generated
@@ -376,7 +481,7 @@
   cat_upload_url character varying(255),
   fees character varying(50), --servicetype-fees
   accessconstraints text, -- servicetype-accessconstraints
-  --ServiceProvider
+  --ServiceProvider
   providername character varying(255),
   providersite character varying(255),
   --ServiceContact
@@ -470,20 +575,25 @@
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
--- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui1','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundColor','#799FEB','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui2','navFrame','backGroundHoverColor','#577dc9','set the background-hover-color of the NavFrame' ,'php_var');
+-- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
+-- element var backGroundColor for gui element navFrame
+SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor'
+AND fkey_e_id = 'navFrame');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var');
-INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES('gui_digitize','navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var');
+-- element var backGroundHoverColor for gui element navFrame
+SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var'
+WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
 ALTER TABLE mb_user_wmc ADD COLUMN
 wmc_timestamp_create INTEGER;
@@ -497,41 +607,84 @@
     ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
 -- jQuery UI
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
+SELECT gui.gui_id,'jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','',''
+WHERE e_id = 'jq_ui');
+SELECT gui_element.fkey_gui_id, 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'jq_ui' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'css'
+AND fkey_e_id = 'jq_ui');
 -- jQuery datatables
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+SELECT gui.gui_id,'jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/'
+WHERE e_id = 'jq_datatables');
+SELECT gui_element.fkey_gui_id, 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'jq_datatables' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'defaultCss'
+AND fkey_e_id = 'jq_datatables');
 -- jQuery UI tabs
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
+SELECT gui.gui_id,'jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui',''
+WHERE e_id = 'jq_ui_tabs');
 -- jQuery upload
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','','');
+SELECT gui.gui_id,'jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','',''
+WHERE e_id = 'jq_upload');
 -- jQuery CSS in Body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+SELECT gui_element.fkey_gui_id, 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id = 'gui1' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_UI'
+AND fkey_e_id = 'body');
+SELECT gui_element.fkey_gui_id, 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_datatables'
+-- add jquery ui dialog to gui1
+SELECT gui.gui_id,'jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui',''
+WHERE e_id = 'jq_ui_dialog');
 wmc_public INTEGER NOT NULL DEFAULT 0;
 -- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
 UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
--- add jquery ui dialog to gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
 -- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'savewmc', 'overwrite', '0', '' ,'var');
+-- element var overwrite for gui element savewmc
+SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
+WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
 -- add history to map object
 UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
-ALTER TABLE mb_user_wmc
+ALTER TABLE mb_user_wmc
 		ADD COLUMN abstract TEXT,
 		ADD COLUMN srs CHARACTER VARYING,
 		ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
@@ -547,11 +700,26 @@
      ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
 -- disable publish WMC and delete WMC for gui1
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'deleteWmc', '0', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'loadwmc', 'publishWmc', '0', '' ,'var');
+SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'loadwmc'
+AND gui_element.fkey_gui_id
+WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
+-- element var publishWmc for gui element loadwmc
+SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element
+WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
+WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
 -- add publish WMC to admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame','');
+SELECT gui.gui_id, 'wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame',''
+WHERE e_id = 'wmcPublic' AND fkey_gui_id = 'admin1');
 -- add required modules for loadwmc and savewmc
 UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
@@ -560,102 +728,41 @@
 -- set new element vars for existing gui elements of non-standard guis
--- element var showResultInPopup for gui element gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'showResultInPopup' AND fkey_e_id = 'gazetteerWFS');
--- element var wfs_spatial_request_conf_filename for gui element gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'wfs_spatial_request_conf_filename' AND fkey_e_id = 'gazetteerWFS');
--- element var popupcss for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'popupcss' AND fkey_e_id = 'body');
--- element var tablesortercss for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tablesortercss' AND fkey_e_id = 'body');
--- element var use_load_message for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'use_load_message', 'true', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'use_load_message' AND fkey_e_id = 'body');
--- element var includeWhileLoading for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'includeWhileLoading' AND fkey_e_id = 'body');
--- element var cssfileAddWMS for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var capabilitiesInput for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'capabilitiesInput' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dball for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dball' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dbgroup for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgroup' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var option_dbgui for gui element addWMSfromfilteredList_ajax
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgui' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
--- element var featureInfoLayerPopup for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoLayerPopup' AND fkey_e_id = 'featureInfoTunnel');
--- element var featureInfoPopupHeight for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupHeight' AND fkey_e_id = 'featureInfoTunnel');
--- element var featureInfoPopupWidth for gui element featureInfoTunnel
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupWidth' AND fkey_e_id = 'featureInfoTunnel');
--- element var skipWmsIfSrsNotSupported for gui element mapframe1
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
--- element var skipWmsIfSrsNotSupported for gui element overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'overview');
--- element var backGroundColor for gui element navFrame
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame');
--- element var backGroundHoverColor for gui element navFrame
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
--- element var overwrite for gui element savewmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
--- element var deleteWmc for gui element loadwmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
--- element var publishWmc for gui element loadwmc
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
--- element var tooltip_noResultArray for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_noResultArray' AND fkey_e_id = 'tooltip');
--- element var tooltip_disableWfs for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWfs' AND fkey_e_id = 'tooltip');
--- element var tooltip_disableWms for gui element tooltip
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWms' AND fkey_e_id = 'tooltip');
 -- element var switchwms for gui element treeGDE
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var' FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id
+WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
--- element var favicon for gui element body
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon' AND fkey_e_id = 'body');
+-- element i18n for all guis
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext'
+FROM gui_element WHERE gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext' FROM gui_element WHERE gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
 -- increase fields for wfs featuretype attributes name
 ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
 -- add georss in gui1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var');
+SELECT gui.gui_id,'addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','',''
+WHERE e_id = 'addGeoRSS');
+SELECT gui_element.fkey_gui_id, 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'addGeoRSS' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'loadGeorssFromSession'
+AND fkey_e_id = 'addGeoRSS');
 -- element var initializeOnLoad for gazetteerWFS
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
 -- element var enableSearchWithoutParams for gazetteerWFS
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
 UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
 INSERT INTO cat VALUES (2, '2.0.2', 'NLR CSW', '			NLR CSW: XQuery based catalog service conform to the HTTP protocol binding  of the OpenGIS Catalogue Service specification version 2.0.2/2.0.1		', 'http://geomatics.nlr.nl/excat/csw?request=GetCapabilities&service=CSW&version=2.0.2', 'NONE', 'NONE', NULL, NULL, 'Rob van Swol', 'Senior Scientist NLR-ASSP', NULL, NULL, '', NULL, NULL, NULL, NULL, 'vanswol at nlr.nl', '<?xml version="1.0" encoding="UTF-8"?><csw:Capabilities xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:xlink="http://www.w3.org/1999/xlink" version="2.0.2">
More information about the Mapbender_commits mailing list
