[Mapbender-commits] r3523 - branches/2.5/http/classes
    svn_mapbender at osgeo.org
    Tue Feb 10 10:51:43 EST 2009
Author: christoph
Date: 2009-02-10 10:51:43 -0500 (Tue, 10 Feb 2009)
New Revision: 3523
   branches/2.5/http/classes/class_map.php
   branches/2.5/http/classes/class_wmc.php
   branches/2.5/http/classes/class_wmcToXml.php
   branches/2.5/http/classes/class_wms.php
selectability, global zoom
Modified: branches/2.5/http/classes/class_map.php
--- branches/2.5/http/classes/class_map.php	2009-02-08 17:33:13 UTC (rev 3522)
+++ branches/2.5/http/classes/class_map.php	2009-02-10 15:51:43 UTC (rev 3523)
@@ -11,6 +11,7 @@
 	private $frameName;
 	private $elementName = "maps";
 	private $extent;
+	private $zoomFullExtentArray = array();
 	private $isOverview = false;
 	private $wmsArray = array();
@@ -83,6 +84,14 @@
 		return $this->frameName;
+	public function addZoomFullExtent ($aMapbenderBbox) {
+		$e = new mb_exception("adding new box: " . $aMapbenderBbox);
+		array_push($this->zoomFullExtentArray, $aMapbenderBbox);
+	public function getZoomFullExtentArray () {
+		return $this->zoomFullExtentArray;
 	 * @param $value String
@@ -106,6 +115,16 @@
 		return $this->extent->epsg;
+	public function getWms ($index) {
+		if (is_numeric($index)) {
+			$i = intval($index, 10);
+			if ($i < count($this->wmsArray) && count($this->wmsArray) > 0 && $i >= 0) {
+				return $this->wmsArray[$i];
+		return null;
 	 * @return
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php	2009-02-08 17:33:13 UTC (rev 3522)
+++ branches/2.5/http/classes/class_wmc.php	2009-02-10 15:51:43 UTC (rev 3523)
@@ -86,7 +86,7 @@
 	var $monitoringIsOn = false;
 	var $saveWmcAsFile = false;
 	var $extensionNamespace = "mapbender";
-	var $extensionNamespaceUrl = "http://www.mapbender.org";
+	var $extensionNamespaceUrl = "http://www.mapbender.org/context";
 	// set in constructor
 	var $wmc_id;
@@ -360,26 +360,17 @@
 			for ($i = 0; $i < count($ovWmsArray); $i++) {
 				for ($j = 0; $j < count($wmsArray); $j++) {
 					if ($ovWmsArray[$i]->equals($wmsArray[$j])) {
-						$overviewWmsIndex = $j;
+						$overviewWmsIndex = $j;
+						$wmsIndexOverview = $i;
 						break;
 		// for all wms...
 		for ($i = 0; $i < count($wmsArray); $i++) {
-			// ..use settings from ov if available
-			if ($overviewWmsIndex !== null && $this->overviewMap !== null &&
-				$overviewWmsIndex == $i && count($ovWmsArray) > $i) {
-				array_push($wmcJsArray, $ovWmsArray[$i]->createJsObjFromWMS_());
-			else {
-				// ..otherwise use data from mapframe1
-				array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
+			array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
 		// delete existing map objects...
@@ -393,16 +384,16 @@
 		// .. and add main map ..
 		$wmcJsArray = array_merge($wmcJsArray, $this->mainMap->toJavaScript(null));
-		// set visibility of main map WMS (may be different from overview)
+		// set visibility of ov map WMS (may be different from main)
 		if ($this->overviewMap !== null) {
-			for ($i = 0; $i < count($wmsArray[$overviewWmsIndex]->objLayer); $i++) {
-				$visStr = "mb_mapObj[1].wms[" .$overviewWmsIndex . "].handleLayer(" .
-					"'" . $wmsArray[$overviewWmsIndex]->objLayer[$i]->layer_name . "', " .
+			for ($i = 0; $i < count($ovWmsArray[$wmsIndexOverview]->objLayer); $i++) {
+				$visStr = "mb_mapObj[0].wms[" .$wmsIndexOverview . "].handleLayer(" .
+					"'" . $ovWmsArray[$wmsIndexOverview]->objLayer[$i]->layer_name . "', " .
 					"'visible', " .
-					($wmsArray[$overviewWmsIndex]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
+					($ovWmsArray[$wmsIndexOverview]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
 				array_push($wmcJsArray, $visStr);
-			array_push($wmcJsArray, "mb_mapObj[1].restateLayers(" . $wmsArray[$overviewWmsIndex]->wms_id . ");");
+			array_push($wmcJsArray, "mb_mapObj[0].restateLayers(" . $ovWmsArray[$wmsIndexOverview]->wms_id . ");");
@@ -650,7 +641,19 @@
 					$this->setMapData();
 				if ($generalExtension) {
-					$this->generalExtensionArray[$tag] = $value;
+					if ($value !== "") {
+						if (isset($this->generalExtensionArray[$tag])) {
+							if (!is_array($this->generalExtensionArray[$tag])) {
+								$firstValue = $this->generalExtensionArray[$tag];
+								$this->generalExtensionArray[$tag] = array();
+								array_push($this->generalExtensionArray[$tag], $firstValue);
+							array_push($this->generalExtensionArray[$tag], $value);
+						else {
+							$this->generalExtensionArray[$tag] = $value;
 				if ($tag == "EXTENSION" && $type == "open") {
 					$generalExtension = true;
@@ -691,12 +694,12 @@
 						// we have all necessary information to CREATE
 						// a layer object and append it to the WMS object
-						if ($currentLayer["extension"]["ISOVERVIEWLAYER"] == "1") {
+						if (isset($currentLayer["extension"]["OVERVIEWHIDDEN"])) {
 							array_push($layerlistArray["overview"], $currentLayer);
-						else {
-							array_push($layerlistArray["main"], $currentLayer);
+						$modifiedLayer = $currentLayer;
+						unset($modifiedLayer["extension"]["OVERVIEWHIDDEN"]);
+						array_push($layerlistArray["main"], $modifiedLayer);
 				 		$layer = false;
 					if ($formatlist) {
@@ -856,6 +859,21 @@
 			$this->setLayerData($layerlistCompleteArray[$i]);
+		// set zoom full extent for root layer of first WMS
+		$firstWms = $this->mainMap->getWms(0);
+		$firstWms->objLayer[0]->layer_epsg = array();
+		$boxList = $this->mainMap->getZoomFullExtentArray();
+		for ($i = 0; $i < count($boxList); $i++) {
+			$currentBox = $boxList[$i];
+			array_push($firstWms->objLayer[0]->layer_epsg, array(
+				"epsg" => $currentBox->epsg,
+				"minx" => $currentBox->min->x,
+				"miny" => $currentBox->min->y,
+				"maxx" => $currentBox->max->x,
+				"maxy" => $currentBox->max->y
+		new mb_exception("NEW LAYER EPSG: " . serialize($this->mainMap->getWms(0)->objLayer[0]->layer_epsg));
 		return true;
@@ -893,7 +911,7 @@
 		$currentMap = $this->mainMap;
 		$currentMapIsOverview = false;
 			$currentMap = $this->overviewMap;
 			$currentMapIsOverview = true;
@@ -989,7 +1007,7 @@
 			$wms->objLayer[0]->layer_maxscale = 0;
 			$wms->objLayer[0]->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
 			$wms->objLayer[0]->gui_layer_status = 1;
-			$wms->objLayer[0]->gui_layer_selectable = 1;
+			$wms->objLayer[0]->gui_layer_selectable = $currentLayer["extension"]["WMS_SELECTABLE"];
 			$wms->objLayer[0]->gui_layer_visible = 1;
 			$wms->objLayer[0]->gui_layer_queryable = 0;
 			$wms->objLayer[0]->gui_layer_querylayer = 0;
@@ -1066,6 +1084,42 @@
 			$bbox = new Mapbender_bbox($this->generalExtensionArray["OV_MINX"], $this->generalExtensionArray["OV_MINY"], $this->generalExtensionArray["OV_MAXX"], $this->generalExtensionArray["OV_MAXY"], $this->generalExtensionArray["OV_SRS"]);
 			$this->overviewMap->setExtent($bbox);
+		if ($this->generalExtensionArray["EPSG"] &&
+			$this->generalExtensionArray["MINX"] &&
+			$this->generalExtensionArray["MINY"] &&
+			$this->generalExtensionArray["MAXX"] &&
+			$this->generalExtensionArray["MAXY"]) {
+			$mainEpsgArray = array();
+			$mainMinXArray = array();
+			$mainMinYArray = array();
+			$mainMaxXArray = array();
+			$mainMaxYArray = array();
+			if (!is_array($this->generalExtensionArray["EPSG"])) {
+				$mainEpsgArray[0] = $this->generalExtensionArray["EPSG"];
+				$mainMinXArray[0] = $this->generalExtensionArray["MINX"];
+				$mainMinYArray[0] = $this->generalExtensionArray["MINY"];
+				$mainMaxXArray[0] = $this->generalExtensionArray["MAXX"];
+				$mainMaxYArray[0] = $this->generalExtensionArray["MAXY"];
+			else {
+				$mainEpsgArray = $this->generalExtensionArray["EPSG"];
+				$mainMinXArray = $this->generalExtensionArray["MINX"];
+				$mainMinYArray = $this->generalExtensionArray["MINY"];
+				$mainMaxXArray = $this->generalExtensionArray["MAXX"];
+				$mainMaxYArray = $this->generalExtensionArray["MAXY"];
+			for ($i=0; $i < count($mainEpsgArray); $i++) {
+				$box = new Mapbender_bbox(
+					floatval($mainMinXArray[$i]), floatval($mainMinYArray[$i]),
+					floatval($mainMaxXArray[$i]), floatval($mainMaxYArray[$i]),
+					$mainEpsgArray[$i]
+				$this->mainMap->addZoomFullExtent($box);
 		if ($this->generalExtensionArray["MAIN_FRAMENAME"]) {
 			$this->mainMap->setFrameName($this->generalExtensionArray["MAIN_FRAMENAME"]);
Modified: branches/2.5/http/classes/class_wmcToXml.php
--- branches/2.5/http/classes/class_wmcToXml.php	2009-02-08 17:33:13 UTC (rev 3522)
+++ branches/2.5/http/classes/class_wmcToXml.php	2009-02-10 15:51:43 UTC (rev 3523)
@@ -56,12 +56,6 @@
 	private function toXml () {
-		// add main map and overview (if exists) to $mapArray
-		$mapArray = array($this->wmc->mainMap);
-		if ($this->wmc->overviewMap !== null) {
-			array_push($mapArray, $this->wmc->overviewMap);
 		// generate XML
 		$this->doc = new DOMDocument("1.0", CHARSET);
 		$this->doc->preserveWhiteSpace = false;
@@ -70,10 +64,9 @@
 		$e_view_context = $this->doc->createElementNS("http://www.opengis.net/context", "ViewContext");
 		$e_view_context->setAttribute("version", "1.1.0");
 		$e_view_context->setAttribute("id", $this->wmc->wmc_id);
-		$e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+		$e_view_context->setAttribute("xsi:schemaLocation", "http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd");
+		$e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
 		$e_view_context->setAttribute("xmlns:" . $this->wmc->extensionNamespace, $this->wmc->extensionNamespaceUrl);
-		$e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
-		$e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
 		// General
 		$e_general = $this->createGeneralNode();
@@ -83,22 +76,46 @@
 		// Layerlist
 		$e_layer_list = $this->doc->createElement("LayerList");
-		while (count($mapArray) > 0) {
+		// store overview layers
+		$overviewLayerArray = array();
+		if ($this->wmc->overviewMap !== null) {
+			$currentOverviewWmsArray = $this->wmc->overviewMap->getWmsArray();
+			for ($k = 0; $k < count($currentOverviewWmsArray); $k++) {
+				$currentOverviewWms = $currentOverviewWmsArray[$k];
+				for ($l = 0; $l < count($currentOverviewWms->objLayer); $l++) {
+					$currentOverviewLayer = $currentOverviewWms->objLayer[$l];
+					array_push($overviewLayerArray, $currentOverviewLayer);
+		$currentWmsArray = $this->wmc->mainMap->getWmsArray();
+		$currentMap = $this->wmc->mainMap;
+		for ($i = 0; $i < count($currentWmsArray); $i++) {
+			$currentWms = $currentWmsArray[$i];
-			$currentMap = array_pop($mapArray);
-			$currentWmsArray = $currentMap->getWmsArray();
-			for ($i = 0; $i < count($currentWmsArray); $i++) {
-				$currentWms = $currentWmsArray[$i];
+			for ($j = 0; $j < count($currentWms->objLayer); $j++) {
+				$currentLayer = $currentWms->objLayer[$j];
-				for ($j = 0; $j < count($currentWms->objLayer); $j++) {
-					$currentLayer = $currentWms->objLayer[$j];
+				$layerNode = null;
+				$found = false;
+				for ($k = 0; $k < count($overviewLayerArray); $k++) {
+					$currentOverviewLayer = $overviewLayerArray[$k];
+					if ($currentLayer->layer_uid == $currentOverviewLayer->layer_uid) {
+						$layerNode = $this->createLayerNode($currentMap, $currentWms, $currentLayer, $currentOverviewLayer);
+						$found = true;
+						break;
+				if (!$found) {
 					$layerNode = $this->createLayerNode($currentMap, $currentWms, $currentLayer);
-					if ($layerNode !== null) {
-						$e_layer_list->appendChild($layerNode);
+				if ($layerNode !== null) {
+					$e_layer_list->appendChild($layerNode);
 		$e_view_context->appendChild($e_layer_list);
@@ -121,6 +138,15 @@
 			$extensionData["ov_height"] = $this->wmc->overviewMap->getHeight();
+		// store epsg and bbox of root layer of 0th WMS
+		$firstWms = $this->wmc->mainMap->getWms(0);
+		if ($firstWms !== null) {
+			for ($i = 0; $i < count($firstWms->objLayer[0]->layer_epsg); $i++) {
+				$currentLayerEpsg = $firstWms->objLayer[0]->layer_epsg[$i];
+				$extensionData["mainMapBox" . $i] = $currentLayerEpsg;
 		if ($this->wmc->mainMap !== null) {
 			$extensionData["main_framename"] = $this->wmc->mainMap->getFrameName();
@@ -146,21 +172,19 @@
 		$e_bbox->setAttribute("maxy", $mainExtent->max->y);
 		$e_general->appendChild($e_bbox);
-		// Name
-		$e_name = $this->doc->createElement("Name", $this->wmc->wmc_name);
-		$e_general->appendChild($e_name);
 		// Title
 		$e_title = $this->doc->createElement("Title", $this->wmc->wmc_title);
 		$e_general->appendChild($e_title);
 		// Keywords
-		$e_keyword_list = $this->doc->createElement("KeywordList");
-		for ($i=0; $i < count($this->wmc->wmc_keyword); $i++) {
-			$e_keyword = $this->doc->createElement("Keyword", $this->wmc->wmc_keyword[$i]);
-			$e_keyword_list->appendChild($e_keyword);
+		if (count($this->wmc->wmc_keyword) > 0) {
+			$e_keyword_list = $this->doc->createElement("KeywordList");
+			for ($i=0; $i < count($this->wmc->wmc_keyword); $i++) {
+				$e_keyword = $this->doc->createElement("Keyword", $this->wmc->wmc_keyword[$i]);
+				$e_keyword_list->appendChild($e_keyword);
+			$e_general->appendChild($e_keyword_list);
-		$e_general->appendChild($e_keyword_list);
 		// Abstract
 		if ($this->wmc->wmc_abstract) {
@@ -210,7 +234,7 @@
 			$e_extensionGeneral = $this->doc->createElement("Extension");
 			foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
-				$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$keyExtensionData, $valueExtensionData);
+				$e_currentExtensionTag = $this->addExtension($keyExtensionData, $valueExtensionData);
 				$e_extensionGeneral->appendChild($e_currentExtensionTag);
 			$e_general->appendChild($e_extensionGeneral);
@@ -218,7 +242,22 @@
 		return $e_general;
-	private function createLayerNode ($currentMap, $currentWms, $currentLayer) {
+	private function createLayerNode () {
+		if (func_num_args() == 3) {
+			$currentMap = func_get_arg(0);
+			$currentWms = func_get_arg(1);
+			$currentLayer = func_get_arg(2);
+			$currentOverviewLayer = null;
+		else if (func_num_args() == 4) {
+			$currentOverviewLayer = func_get_arg(3);
+		else {
+			return null;
 		if ($currentLayer->layer_parent != '') {
 			// Layer
@@ -254,12 +293,6 @@
 				$e_layer->appendChild($e_layer_abstract);
-			// SRS
-			$srsNode = $this->createSrsNode($currentMap, $currentWms);
-			if ($srsNode !== null) {
-				$e_layer->appendChild($srsNode);
 			// Data URL
 			if ($currentLayer->layer_dataurl_href){
 				$e_layer_data_url = $this->doc->createElement("DataURL");
@@ -286,6 +319,12 @@
 				$e_layer->appendChild($e_layer_metadata_url);
+			// SRS
+			$srsNode = $this->createSrsNode($currentMap, $currentWms);
+			if ($srsNode !== null) {
+				$e_layer->appendChild($srsNode);
 			// Layer format
 			$formatListNode = $this->createLayerFormatListNode($currentWms);
 			if ($formatListNode !== null) {
@@ -299,11 +338,10 @@
 			// Extension
-			$extensionNode = $this->createLayerExtensionNode($currentMap, $currentWms, $currentLayer);
+			$extensionNode = $this->createLayerExtensionNode($currentMap, $currentWms, $currentLayer, $currentOverviewLayer);
 			if ($extensionNode !== null) {
 				$e_layer->appendChild($extensionNode);
 			return $e_layer;
 		return null;
@@ -353,7 +391,7 @@
 		return $e_layer_format;
-	private function createLayerExtensionNode ($currentMap, $currentWms, $currentLayer) {
+	private function createLayerExtensionNode ($currentMap, $currentWms, $currentLayer, $currentOverviewLayer) {
 		$layerExtensionData = array();
 		$layerExtensionData["wms_name"] = $currentWms->objLayer[0]->layer_name;
 		$layerExtensionData["minscale"] = $currentLayer->layer_minscale;
@@ -362,6 +400,7 @@
 		$layerExtensionData["gui_maxscale"] = $currentLayer->gui_layer_maxscale;
 		$layerExtensionData["layer_id"] = $currentLayer->layer_uid;
 		$layerExtensionData["wms_layer_id"] = $currentWms->objLayer[0]->layer_uid;
+		$layerExtensionData["wms_selectable"] = $currentWms->objLayer[0]->gui_layer_selectable;
 		$layerExtensionData["layer_pos"] = $currentLayer->layer_pos;
 		$layerExtensionData["layer_parent"] = $currentLayer->layer_parent;
 		$layerExtensionData["wms_id"] = $currentLayer->gui_layer_wms_id;
@@ -371,8 +410,8 @@
 		$layerExtensionData["gui_status"] = $currentLayer->gui_layer_status;
 		$layerExtensionData["layer_epsg"] = $currentLayer->layer_epsg;
-		if ($currentMap->isOverview()) {
-			$layerExtensionData["isOverviewLayer"] = 1;
+		if ($currentOverviewLayer != null) {
+			$layerExtensionData["overviewData"] = array("overviewHidden" => ($currentOverviewLayer->gui_layer_visible ? 0 : 1));
 		if ($currentLayer->gui_layer_wfs_featuretype) {
 			$layerExtensionData["wfsFeatureType"] = $currentLayer->gui_layer_wfs_featuretype;
@@ -395,6 +434,7 @@
 			if (is_numeric($key)) {
 				$key = "data" . $key;
+//			$e_currentExtensionTag = $this->doc->createElementNS($this->wmc->extensionNamespaceUrl, $this->wmc->extensionNamespace.":".$key);
 			$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key);
 			foreach ($value as $childKey => $childValue) {
 				$newNode = $this->addExtension($childKey, $childValue);
@@ -402,6 +442,7 @@
 		else {
+//			$e_currentExtensionTag = $this->doc->createElementNS($this->wmc->extensionNamespaceUrl, $this->wmc->extensionNamespace.":".$key, $value);
 			$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key, $value);
 		return $e_currentExtensionTag;
@@ -443,7 +484,7 @@
 				$e_layer_style->appendChild($e_layer_style_title);
-				$e_layer_style_legendurl = $this->doc->createElement("LegendUrl");
+				$e_layer_style_legendurl = $this->doc->createElement("LegendURL");
 				//TODO: determine correct layer style entries
 				$layerStyle_legendUrl_width = ""; // To Do: add proper data
Modified: branches/2.5/http/classes/class_wms.php
--- branches/2.5/http/classes/class_wms.php	2009-02-08 17:33:13 UTC (rev 3522)
+++ branches/2.5/http/classes/class_wms.php	2009-02-10 15:51:43 UTC (rev 3523)
@@ -861,7 +861,12 @@
 		$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
 		$newLayer->gui_layer_style = ""; // TODO: Add correct data
 		$newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
-		$newLayer->gui_layer_visible = $currentLayer["visible"];
+			$newLayer->gui_layer_visible = ($currentLayer["extension"]["OVERVIEWHIDDEN"] === "1") ? false : true;
+		else {
+			$newLayer->gui_layer_visible = $currentLayer["visible"];
 		$newLayer->gui_layer_queryable = $currentLayer["extension"]["GUI_QUERYABLE"];
 		$newLayer->gui_layer_querylayer = $currentLayer["extension"]["QUERYLAYER"];
 		$newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
@@ -1896,7 +1901,7 @@
 			$res_style = db_prep_query($sql,$v,$t);
 			$count_layer_style = 0;
 			while($row2 = db_fetch_array($res_style)){
-				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"] = $row2["name"] ? $row2["name"] : "default";
 				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
 				if($wmsowsproxy != ""){
 					if($row2["legendurl"]!=''){
More information about the Mapbender_commits
