[Mapbender-commits] r3526 - in branches/2.5/resources/db: mysql/iso
mysql/utf8 mysql/utf8/update postgresql/iso
postgresql/iso/update postgresql/utf8 postgresql/utf8/update
svn_mapbender at osgeo.org
Wed Feb 11 03:51:19 EST 2009
Author: christoph
Date: 2009-02-11 03:51:16 -0500 (Wed, 11 Feb 2009)
New Revision: 3526
Removed:
branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql
branches/2.5/resources/db/mysql/iso/mysql_data.sql
branches/2.5/resources/db/mysql/utf8/mysql_data.sql
branches/2.5/resources/db/mysql/utf8/update/update_2.5_to_2.5.1_mysql_UTF-8.sql
branches/2.5/resources/db/postgresql/iso/pgsql_data.sql
branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_ISO-8859-1.sql
branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
branches/2.5/resources/db/postgresql/utf8/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql
http://trac.osgeo.org/mapbender/ticket/380
Modified: branches/2.5/resources/db/mysql/iso/mysql_data.sql
--- branches/2.5/resources/db/mysql/iso/mysql_data.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/mysql/iso/mysql_data.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -1,17 +1,12 @@
-- mysql iso data dump
--- Mapbender 2.5.0
--- 2008/09/29
+-- Mapbender 2.5.1 rc1
--- PostgreSQL database dump
+-- MySQL database dump
SET FOREIGN_KEY_CHECKS=0;
@@ -22504,9 +22499,14 @@
INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (706, 'EPSG:4326');
INSERT INTO wms_srs (fkey_wms_id, wms_srs) VALUES (903, 'EPSG:25833');
+-- translations missing for bg,gr,nl
+INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (288, 'de', 'Set language', 'Sprache auswählen');
+INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (289, 'es', 'Set language', 'Seleccion del idioma');
+INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (290, 'it', 'Set language', 'Lingua');
+INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (291, 'fr', 'Set language', 'Choisir une langue');
--- PostgreSQL database dump complete
+-- MySQL database dump complete
SET FOREIGN_KEY_CHECKS=1;
\ No newline at end of file
Modified: branches/2.5/resources/db/mysql/utf8/mysql_data.sql
--- branches/2.5/resources/db/mysql/utf8/mysql_data.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/mysql/utf8/mysql_data.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -1,17 +1,12 @@
-- mysql utf8 data dump
--- Mapbender 2.5.0
--- 2008/09/29
+INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (289, 'es', 'Set language', 'Selección del idioma');
Modified: branches/2.5/resources/db/mysql/utf8/update/update_2.5_to_2.5.1_mysql_UTF-8.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_2.5_to_2.5.1_mysql_UTF-8.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/mysql/utf8/update/update_2.5_to_2.5.1_mysql_UTF-8.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -4,8 +4,3 @@
UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img'
--- translations missing for bg,gr,nl
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswählen');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Selección del idioma');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Lingua');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set language', 'Choisir une langue');
Modified: branches/2.5/resources/db/postgresql/iso/pgsql_data.sql
--- branches/2.5/resources/db/postgresql/iso/pgsql_data.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/postgresql/iso/pgsql_data.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -1,15 +1,10 @@
-- postgresql iso data dump
--- Mapbender 2.5.0
--- 2008/09/29
@@ -22504,7 +22499,13 @@
Modified: branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_ISO-8859-1.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_ISO-8859-1.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_ISO-8859-1.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -3,9 +3,3 @@
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswaehlen');
-INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Seleccion del idioma');
Deleted: branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/postgresql/iso/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -1,5 +0,0 @@
--- database changes in version 2.5.1
-UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img'
Modified: branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
--- branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -1,9 +1,7 @@
-- postgresql utf8 data dump
--- Mapbender 2.5.0
--- 2008/09/29
@@ -22504,10 +22502,10 @@
Modified: branches/2.5/resources/db/postgresql/utf8/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql
--- branches/2.5/resources/db/postgresql/utf8/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql 2009-02-10 15:54:07 UTC (rev 3525)
+++ branches/2.5/resources/db/postgresql/utf8/update/update_2.5_to_2.5.1_pgsql_UTF-8.sql 2009-02-11 08:51:16 UTC (rev 3526)
@@ -3,9 +3,3 @@
UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img';
More information about the Mapbender_commits
