[Mapbender-commits] r3554 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 17 05:33:20 EST 2009
Author: verenadiewald
Date: 2009-02-17 05:33:20 -0500 (Tue, 17 Feb 2009)
New Revision: 3554
   trunk/mapbender/resources/db/update/update_2.6.sql
additional sql statements for use of gazetteerWFS
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-02-17 10:23:18 UTC (rev 3553)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-02-17 10:33:20 UTC (rev 3554)
@@ -15,6 +15,19 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+--new element vars for body for css style of popups and tablesorter
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+--add all used modules for gazetteerWFS
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
 --add style class to element var text css of element digitize in gui_digitize
 UPDATE gui_element_vars SET var_value = '
 .digitizeGeometryList{
@@ -120,6 +133,7 @@
 DELETE FROM gui_element WHERE e_id = 'closePolygon';
 DELETE FROM gui_element WHERE e_id = 'rubber';
 DELETE FROM gui_element WHERE e_id = 'getArea';
+DELETE FROM gui_element WHERE e_id = 'rubberExt';
 UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
More information about the Mapbender_commits mailing list
