[Mapbender-commits] r3573 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Feb 18 12:36:04 EST 2009
Author: christoph
Date: 2009-02-18 12:36:04 -0500 (Wed, 18 Feb 2009)
New Revision: 3573
Added:
trunk/mapbender/http/classes/class_gml_geometry.php
trunk/mapbender/http/classes/class_wfs_configuration.php
trunk/mapbender/http/classes/class_gml.php
trunk/mapbender/http/classes/class_gml_2.php
trunk/mapbender/http/classes/class_gml_2_factory.php
trunk/mapbender/http/classes/class_gml_3.php
trunk/mapbender/http/classes/class_gml_3_factory.php
trunk/mapbender/http/classes/class_gml_factory.php
trunk/mapbender/http/classes/class_gml_line.php
trunk/mapbender/http/classes/class_gml_multiline.php
trunk/mapbender/http/classes/class_gml_multipolygon.php
trunk/mapbender/http/classes/class_gml_point.php
trunk/mapbender/http/classes/class_gml_polygon.php
trunk/mapbender/http/classes/class_map.php
trunk/mapbender/http/classes/class_ows.php
trunk/mapbender/http/classes/class_universal_gml_factory.php
trunk/mapbender/http/classes/class_wfs.php
bug fixes and wfs-t redesign
Modified: trunk/mapbender/http/classes/class_gml.php
--- trunk/mapbender/http/classes/class_gml.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -22,17 +22,31 @@
require_once(dirname(__FILE__)."/../classes/class_json.php");
require_once(dirname(__FILE__)."/../classes/class_gml_feature_collection.php");
-class Gml {
+abstract class Gml {
var $featureCollection = null;
var $geomFeaturetypeElement;
var $doc;
+ abstract public function toGml ();
public function toGeoJSON () {
if ($this->featureCollection === null) {
return null;
return $this->featureCollection->toGeoJSON();
+ * Shortcut for GeoJSON conversion
+ * @return String
+ * @param $geoJson String
+ public static function geoJsonToGml ($geoJson) {
+ $gmlFactory = new UniversalGmlFactory();
+ $myGmlObj = $gmlFactory->createFromGeoJson($geoJson);
+ return $myGmlObj->toGml();
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_gml_2.php
--- trunk/mapbender/http/classes/class_gml_2.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_2.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -23,5 +23,18 @@
require_once(dirname(__FILE__)."/../classes/class_gml.php");
class Gml_2 extends Gml {
+ public function toGml () {
+ $str = "";
+ foreach ($this->featureCollection->featureArray as $feature) {
+ if (!$feature->geometry) {
+ $e = new mb_exception("Feature doesn't have a geometry.");
+ return null;
+ $geometry = $feature->geometry;
+ $str .= $geometry->toGml2();
+ return $str;
Modified: trunk/mapbender/http/classes/class_gml_2_factory.php
--- trunk/mapbender/http/classes/class_gml_2_factory.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_2_factory.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -30,6 +30,18 @@
class Gml_2_Factory extends GmlFactory {
+ * Creates a GML object from a GeoJSON (http://www.geojson.org) String
+ * @return Gml_3
+ public function createFromGeoJson ($geoJson) {
+ $gml2 = new Gml_2();
+ return parent::createFromGeoJson($geoJson, $gml2);
function findNameSpace($s){
list($ns,$FeaturePropertyName) = split(":",$s);
$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
Modified: trunk/mapbender/http/classes/class_gml_3.php
--- trunk/mapbender/http/classes/class_gml_3.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_3.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -23,5 +23,10 @@
class Gml_3 extends Gml {
Modified: trunk/mapbender/http/classes/class_gml_3_factory.php
--- trunk/mapbender/http/classes/class_gml_3_factory.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_3_factory.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -31,6 +31,18 @@
class Gml_3_Factory extends GmlFactory {
+ * @return Gml_3
+ $gml3 = new Gml_3();
+ return parent::createFromGeoJson($geoJson, $gml3);
* Creates GML 3 objects from GML documents.
* @return Gml_3
Modified: trunk/mapbender/http/classes/class_gml_factory.php
--- trunk/mapbender/http/classes/class_gml_factory.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_factory.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -20,6 +20,7 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_connector.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
* Creates GML objects from GML documents.
@@ -33,6 +34,142 @@
+ * @return Gml
+ public function createFromGeoJson ($geoJson, $gml) {
+ $json = new Mapbender_JSON ();
+ $jsonObj = $json->decode($geoJson);
+ // check if valid feature collection
+ new mb_exception("Is Array? " . is_array($jsonObj->features));
+ new mb_exception("Type? " . strtoupper($jsonObj->type));
+ if (strtoupper($jsonObj->type) != "FEATURECOLLECTION" || !is_array($jsonObj->features)) {
+ $e = new mb_exception("Not a valid GeoJSON Feature Collection.");
+ return null;
+ $gml->featureCollection = new FeatureCollection();
+ foreach ($jsonObj->features as $currentFeature) {
+ $feature = new Feature();
+ if (!is_object($currentFeature->crs) || $currentFeature->crs->type !== "name") {
+ $e = new mb_exception("Feature doesn't have a SRS.");
+ return null;
+ $srs = $currentFeature->crs->properties->name;
+ // set geometry
+ if (is_object($currentFeature->geometry)) {
+ $currentGeometry = $currentFeature->geometry;
+ switch (strtoupper($currentGeometry->type)) {
+ case "POLYGON":
+ $geometry = new GMLPolygon();
+ for ($i = 0; $i < count($currentGeometry->coordinates); $i++) {
+ $currentRing = $currentGeometry->coordinates[$i];
+ foreach ($currentRing as $coords) {
+ list($x, $y) = $coords;
+ // exterior ring
+ if (0 == $i) {
+ $geometry->addPoint($x, $y);
+ // interior ring
+ else {
+ $geometry->addPointToRing($i, $x, $y);
+ break;
+ case "POINT":
+ $geometry = new GMLPoint();
+ list($x, $y) = $currentGeometry->coordinates;
+ $geometry->setPoint($x, $y);
+ break;
+ case "LINESTRING":
+ $geometry = new GMLLine();
+ $currentLinePoint = $currentGeometry->coordinates[$i];
+ list($x, $y) = $currentLinePoint;
+ break;
+ case "MULTIPOLYGON":
+ $geometry = new GMLMultiPolygon();
+ $currentPolygon = $currentGeometry->coordinates[$i];
+ for ($j = 0; $j < count($currentPolygon); $j++) {
+ $currentRing = $currentPolygon[$j];
+ // exterior ring
+ if (0 == $j) {
+ $geometry->addPoint($x, $y, $i);
+ // interior ring
+ else {
+ $geometry->addPointToRing($i, $j-1, $x, $y);
+ break;
+ case "MULTIPOINT":
+ $e = new mb_exception($currentGeometry->type . " are not supported!");
+ return null;
+ break;
+ case "MULTILINESTRING": // not tested!
+ $geometry = new GMLMultiLine();
+ $currentLine = $currentGeometry->coordinates[$i];
+ foreach ($currentLine as $currentLinePoint) {
+ break;
+ case "GEOMETRYCOLLECTION":
+ return null;
+ break;
+ default:
+ $e = new mb_exception($currentGeometry->type . " is not a valid geometry type");
+ return null;
+ break;
+ // add the geometry to the feature
+ $geometry->srs = $srs;
+ $feature->geometry = $geometry;
+ else {
+ $e = new mb_exception("This feature does not have a geometry.");
+ return null;
+ // set fid and properties
+ if (is_object($currentFeature->properties)) {
+ foreach ($currentFeature->properties as $pName => $pValue) {
+ if ("fid" == $pName) {
+ $feature->fid = $pValue;
+ else {
+ $feature->properties[$pName] = $pValue;
+ $gml->featureCollection->addFeature($feature);
+ return $gml;
* @return Gml
Added: trunk/mapbender/http/classes/class_gml_geometry.php
--- trunk/mapbender/http/classes/class_gml_geometry.php (rev 0)
+++ trunk/mapbender/http/classes/class_gml_geometry.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -0,0 +1,35 @@
+<?php
+# $Id: class_gml2.php 3099 2008-10-02 15:29:23Z nimix $
+# http://www.mapbender.org/index.php/class_gml2.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_gml_feature_collection.php");
+abstract class GmlGeometry {
+ abstract public function toGml2 ();
+ abstract public function toGml3 ();
+ abstract public function toGeoJSON ();
+ public $srs;
Modified: trunk/mapbender/http/classes/class_gml_line.php
--- trunk/mapbender/http/classes/class_gml_line.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_line.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -19,9 +19,10 @@
+require_once(dirname(__FILE__)."/../classes/class_gml_geometry.php");
-class GMLLine {
+class GMLLine extends GmlGeometry {
var $pointArray = array();
@@ -33,6 +34,25 @@
array_push($this->pointArray, array("x" => $x, "y" => $y));
+ public function toGml2 () {
+ $str = "<gml:MultiLineString srsName=\"$this->srs\">" .
+ "<gml:lineStringMember><gml:LineString><gml:coordinates>";
+ $ptArray = array();
+ foreach ($this->pointArray as $point) {
+ $ptArray[] = $point["x"] . "," . $point["y"];
+ $str .= implode(" ", $ptArray);
+ $str .= "</gml:coordinates></gml:LineString></gml:lineStringMember>";
+ $str .= "</gml:MultiLineString>";
+ return $str;
+ public function toGml3 () {
$numberOfPoints = count($this->pointArray);
$str = "";
Modified: trunk/mapbender/http/classes/class_gml_multiline.php
--- trunk/mapbender/http/classes/class_gml_multiline.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_multiline.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -19,9 +19,10 @@
-class GMLMultiLine {
+class GMLMultiLine extends GmlGeometry {
var $lineArray = array();
@@ -33,6 +34,25 @@
array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
+ $str = "<gml:MultiLineString srsName='$srsName'>";
+ foreach ($this->lineArray as $line) {
+ $str .= "<gml:lineStringMember><gml:LineString><gml:coordinates>";
+ foreach ($line as $point) {
+ $str .= "</gml:coordinates></gml:LineString>";
+ $str .= "<gml:lineStringMember><gml:MultiLineString>";
+ return $str;
$numberlineArray = count($this->lineArray);
$str = "";
Modified: trunk/mapbender/http/classes/class_gml_multipolygon.php
--- trunk/mapbender/http/classes/class_gml_multipolygon.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_multipolygon.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -19,8 +19,9 @@
-class GMLMultiPolygon {
+class GMLMultiPolygon extends GmlGeometry {
var $polygonArray = array();
var $innerRingArray = array();
@@ -30,17 +31,65 @@
public function addPointToRing ($i, $j, $x, $y) {
- if (count($this->innerRingArray[$i]) <= $j) {
+ while (count($this->innerRingArray) <= $i) {
+ array_push($this->innerRingArray, array());
+ while (count($this->innerRingArray[$i]) <= $j) {
array_push($this->innerRingArray[$i], array());
array_push($this->innerRingArray[$i][$j], array("x" => $x, "y" => $y));
public function addPoint ($x, $y, $i) {
+ while (count($this->polygonArray) <= $i) {
+ array_push($this->polygonArray, array());
array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
+ $str .= "<gml:MultiPolygon srsName='$srsName'>";
+ for ($i = 0; $i < count($this->polygonArray); $i++) {
+ $str .= "<gml:polygonMember><gml:Polygon>" .
+ "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ $currentExteriorRing = $this->polygonArray[$i];
+ for ($j = 0; $j < count($currentExteriorRing); $j++) {
+ $point = $currentExteriorRing[$j];
+ $str .= "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+ // interior rings exist
+ if (count($this->innerRingArray) > $i && count($this->innerRingArray[$i]) > 0) {
+ for ($j = 0; $j < count($this->innerRingArray[$i]); $j++) {
+ $currentInteriorRing = $this->innerRingArray[$i][$j];
+ $str .= "<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ for ($k = 0; $k < count($currentInteriorRing); $k++) {
+ $point = $currentInteriorRing[$k];
+ $str .= "</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>";
+ $str .= "</gml:Polygon></gml:polygonMember>";
+ $str .= "</gml:MultiPolygon>";
+ return $str;
$numberPolygonArray = count($this->polygonArray);
$str = "";
Modified: trunk/mapbender/http/classes/class_gml_point.php
--- trunk/mapbender/http/classes/class_gml_point.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_point.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -19,8 +19,9 @@
-class GMLPoint {
+class GMLPoint extends GmlGeometry {
var $point;
@@ -33,6 +34,17 @@
$this->point = array("x" => $x, "y" => $y);
+ $str = "<gml:Point srsName='$this->srs'><gml:coordinates>";
+ $str .= $this->point["x"] . "," . $this->point["y"];
+ $str .= "</gml:coordinates></gml:Point>";
+ return $str;
$str = "";
if ($this->point) {
Modified: trunk/mapbender/http/classes/class_gml_polygon.php
--- trunk/mapbender/http/classes/class_gml_polygon.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_gml_polygon.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -19,9 +19,10 @@
-class GMLPolygon {
+class GMLPolygon extends GmlGeometry {
@@ -44,6 +45,37 @@
array_push($this->innerRingArray[$currentIndex], array("x" => $x, "y" => $y));
+ $str = "<gml:MultiPolygon srsName=\"$this->srs\">" .
+ "<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs>" .
+ "<gml:LinearRing><gml:coordinates>";
+ $str .= '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>';
+ foreach ($this->innerRingArray as $ring) {
+ foreach ($ring as $point) {
+ $str .= "</gml:Polygon></gml:polygonMember></gml:MultiPolygon>";
+ return $str;
$str = "";
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_map.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -106,8 +106,39 @@
public function getExtent () {
return $this->extent;
+ * @return Mapbender_bbox extent information
+ public function getExtentInfo () {
+ return array($this->extent->min->x, $this->extent->min->y, $this->extent->max->x, $this->extent->max->y);
+ * converts the extent of the map so that the maximum extent will be displayed
+ public function calculateExtent($aMapbenderBbox) {
+ $relation_px_x = $this->getWidth() / $this->getHeight();
+ $relation_px_y = $this->getHeight() / $this->getWidth();
+ $extentx = ($aMapbenderBbox->max->x - $aMapbenderBbox->min->x);
+ $extenty = ($aMapbenderBbox->max->y - $aMapbenderBbox->min->y);
+ $centerx = $aMapbenderBbox->min->x + $extentx/2;
+ $centery = $aMapbenderBbox->min->y + $extenty/2;
+ $relation_bbox_x = $extentx / $extenty;
+ if($relation_bbox_x <= $relation_px_x){
+ $aMapbenderBbox->min->x = $centerx - $relation_px_x * $extenty / 2;
+ $aMapbenderBbox->max->x = $centerx + $relation_px_x * $extenty / 2;
+ if($relation_bbox_x > $relation_px_x){
+ $aMapbenderBbox->min->y = $centery - $relation_px_y * $extentx / 2;
+ $aMapbenderBbox->max->y = $centery + $relation_px_y * $extentx / 2;
+ $this->setExtent($aMapbenderBbox);
* @return String EPSG code of the map.
Modified: trunk/mapbender/http/classes/class_ows.php
--- trunk/mapbender/http/classes/class_ows.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_ows.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -56,7 +56,7 @@
final protected function getNameSpace($s) {
$c = strpos($s, ":");
- if ($c > 0) {
+ if ($c !== false) {
return substr($s, 0, $c);
return $s;
Modified: trunk/mapbender/http/classes/class_universal_gml_factory.php
--- trunk/mapbender/http/classes/class_universal_gml_factory.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_universal_gml_factory.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -56,6 +56,17 @@
+ * @return Gml
+ $gml2Factory = new Gml_2_Factory();
+ return $gml2Factory->createFromGeoJson($geoJson);
* Creates a GML object by parsing its XML representation.
* The GML version is determined by parsing
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php 2009-02-18 17:33:40 UTC (rev 3572)
+++ trunk/mapbender/http/classes/class_wfs.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -20,8 +20,10 @@
require_once(dirname(__FILE__)."/class_connector.php");
require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/class_gml.php");
require_once(dirname(__FILE__)."/class_ows.php");
require_once(dirname(__FILE__)."/class_wfsToDb.php");
+require_once(dirname(__FILE__)."/class_wfs_configuration.php");
* An abstract Web Feature Service (WFS) class, modelling for example
@@ -52,9 +54,20 @@
return $ft;
+ new mb_exception("This WFS doesn't have a featuretype with name " . $name);
return null;
+ protected function findFeatureTypeById ($id) {
+ foreach ($this->featureTypeArray as $ft) {
+ if ($ft->id == $id) {
+ return $ft;
+ new mb_exception("This WFS doesn't have a featuretype with ID " . $id);
+ return null;
protected function getFeatureGet ($featureTypeName, $filter) {
$url = $this->getFeature .
$this->getConjunctionCharacter($this->getFeature) .
@@ -72,6 +85,20 @@
return $data;
+ protected function post ($url, $postData) {
+ $connection = new connector();
+ $connection->set("httpType", "post");
+ $connection->set("httpContentType", "xml");
+ $connection->set("httpPostData", $postData);
+ $data = $connection->load($url);
+ if (!$data) {
+ $e = new mb_exception("WFS request returned no result: " . $url . "\n" . $postData);
+ return null;
+ return $data;
protected function getFeaturePost ($featureTypeName, $filter) {
$postData = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n" .
"<wfs:GetFeature version=\"" . $this->getVersion() . "\" " .
@@ -89,18 +116,7 @@
$postData .= "typeName=\"" . $featureTypeName . "\"/>" .
"</wfs:GetFeature>";
- $connection = new connector();
- $connection->set("httpType", "post");
- $connection->set("httpContentType", "xml");
- $connection->set("httpPostData", $postData);
- $data = $connection->load($this->getFeature);
- if (!$data) {
- $e = new mb_exception("WFS request returned no result: " . $url . "\n" . $postData);
- return null;
- return $data;
+ return $this->post($this->getFeature, $postData);
public function getFeature ($featureTypeName, $filter) {
@@ -110,7 +126,194 @@
return $this->getFeatureGet($featureTypeName, $filter);
+ * Performs a WFS transaction (delete, update or insert).
+ * @return String the WFS reply
+ * @param $method String "delete", "update" or "insert"
+ * @param $wfsConf WfsConfiguration
+ * @param $gmlObj Gml
+ public function transaction ($method, $wfsConf, $gmlObj) {
+ // get feature type and geometry column from WFS configuration
+ if (!($wfsConf instanceof WfsConfiguration)) {
+ $e = new mb_exception("Invalid WFS configuration.");
+ return null;
+ $featureType = $this->findFeatureTypeById($wfsConf->featureTypeId);
+ $featureTypeName = $featureType->name;
+ $geomColumnName = $wfsConf->getGeometryColumnName();
+ // GML string
+ if (!($gmlObj instanceof Gml)) {
+ $e = new mb_exception("Not a GML object.");
+ return null;
+ $gml = $gmlObj->toGml();
+ if (is_null($gml)) {
+ $e = new mb_exception("GML is not set.");
+ return null;
+ // I assume that only one feature is contained in the GeoJSON,
+ // so I just take the first from the collection.
+ $feature = $gmlObj->featureCollection->featureArray[0];
+ switch ($method) {
+ case "delete":
+ $requestData = $this->transactionDelete($feature, $featureTypeName);
+ break;
+ case "update":
+ $requestData = $this->transactionUpdate($feature, $featureTypeName, $gml, $geomColumnName);
+ break;
+ case "insert":
+ $requestData = $this->transactionInsert($feature, $featureTypeName, $gml, $geomColumnName);
+ break;
+ default:
+ $e = new mb_exception("Invalid transaction method: " . $method);
+ return null;
+ $postData = $this->wrapTransaction($featureType, $requestData);
+ return $this->post($this->transaction, $postData);
+ protected function transactionInsert ($feature, $featureTypeName, $gml, $geomColumnName) {
+ // add properties
+ $propertiesSegment = "";
+ foreach ($feature->properties as $key => $value) {
+ if (isset($value)) {
+ $propertiesSegment .= "<$key><![CDATA[$value]]></$key>";
+ // add spatial data
+ $geomSegment = "<$geomColumnName>" . $gml . "</$geomColumnName>";
+ return "<wfs:Insert><$featureTypeName>" . $propertiesSegment .
+ $geomSegment . "</$featureTypeName></wfs:Insert>";
+ protected function transactionUpdate ($feature, $featureTypeName, $gml, $geomColumnName) {
+ // add properties
+ $propertiesSegment .= "<wfs:Property><wfs:Name>$key</wfs:Name>" .
+ "<wfs:Value><![CDATA[$value]]></wfs:Value></wfs:Property>";
+ // filter
+ if (!isset($feature->fid)) {
+ $e = new mb_exception("Feature ID not set.");
+ return null;
+ $filterSegment = "<ogc:Filter><ogc:FeatureId fid=\"$feature->fid\"/></ogc:Filter>";
+ // add geometry
+ $geomSegment = "<wfs:Property><wfs:Name>$geomColumnName</wfs:Name>" .
+ "<wfs:Value>" . $gml . "</wfs:Value></wfs:Property>";
+ return "<wfs:Update typeName=\"$featureTypeName\">" .
+ $geomSegment .
+ $filterSegment .
+ "</wfs:Update>";
+ protected function transactionDelete ($feature, $featureTypeName) {
+ // filter
+ return null;
+ return "<wfs:Delete typeName=\"$featureTypeName\">" .
+ "<ogc:Filter><ogc:FeatureId fid=\"$feature->fid\"/></ogc:Filter>" .
+ "</wfs:Delete>";
+ protected function wrapTransaction ($featureType, $wfsRequest) {
+ $featureNS = $this->getNameSpace($featureType->name);
+ $str = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n" .
+ "<wfs:Transaction version=\"" . $this->getVersion() .
+ "\" service=\"WFS\" ";
+ $ns_gml = false;
+ $ns_ogc = false;
+ $ns_xsi = false;
+ $ns_wfs = false;
+ $ns_featureNS = false;
+ foreach ($featureType->namespaceArray as $namespace) {
+ if ($namespace->name == "gml"){
+ $ns_gml = true;
+ $str .= "xmlns:" . $namespace->name .
+ "=\"" . $namespace->value . "\" ";
+ else if ($namespace->name == "ogc") {
+ $ns_ogc = true;
+ else if ($namespace->name == "xsi") {
+ $ns_xsi = true;
+ else if ($namespace->name == "wfs") {
+ $ns_wfs = true;
+ else if ($namespace->name == $featureNS) {
+ $ns_featureNS = true;
+ $strForSchemaLocation = $namespace->value;
+ if (!$ns_gml) {
+ $str .= 'xmlns:gml="http://www.opengis.net/gml" ';
+ if (!$ns_ogc) {
+ $str .= 'xmlns:ogc="http://www.opengis.net/ogc" ';
+ if (!$ns_xsi) {
+ $str .= 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
+ if (!ns_featureNS) {
+ $str .= "xmlns:" . $featureNS . "=\"http://www.someserver.com/" . $featureNS . "\" ";
+ if (!$ns_wfs) {
+ $str .= "xmlns:wfs=\"http://www.opengis.net/wfs\" ";
+ $str .= "xsi:schemaLocation=\"http://www.opengis.net/wfs";
+ $str .= " http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd";
+ $str .= " " . $strForSchemaLocation;
+ $str .= " " . $this->describeFeatureType;
+ //$str .= mb_getConjunctionCharacter(myconf['wfs_describefeaturetype']);
+ //$str .= 'typename=' + myconf['featuretype_name'];
+ $str .= "\">";
+ $str .= $wfsRequest;
+ $str .= "</wfs:Transaction>";
+ return $str;
// Output formats
Added: trunk/mapbender/http/classes/class_wfs_configuration.php
--- trunk/mapbender/http/classes/class_wfs_configuration.php (rev 0)
+++ trunk/mapbender/http/classes/class_wfs_configuration.php 2009-02-18 17:36:04 UTC (rev 3573)
@@ -0,0 +1,170 @@
+<?php
+# $Id: class_wfs_conf.php 3510 2009-02-03 10:36:01Z christoph $
+# http://www.mapbender.org/index.php/class_wfs_conf.php
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+class WfsConfigurationElement {
+ var $name;
+ var $type;
+ var $search;
+ var $styleId;
+ var $toUpper;
+ var $label;
+ var $labelId;
+ var $geom;
+ var $show;
+ var $mandatory;
+ var $respos;
+ var $minInput;
+ var $formElementHtml;
+ var $authVarname;
+ var $detailPos;
+ var $operator;
+ var $showDetail;
+class WfsConfiguration {
+ var $id;
+ var $wfsId;
+ var $featureTypeId;
+ var $label;
+ var $labelId;
+ var $style;
+ var $button;
+ var $buttonId;
+ var $buffer;
+ var $resStyle;
+ var $elementArray = array();
+ function __construct () {
+ public function getGeometryColumnName () {
+ foreach ($this->elementArray as $element) {
+ if ($element->geom) {
+ return $element->name;
+ $e = new mb_warning("This WFS conf doesn't have a geometry column.");
+ return null;
+ * Checks if the user currently logged in is allowed to access
+ * the WFS configuration
+ * @return Boolean
+ private function accessAllowed () {
+ if ($_SESSION["mb_user_id"]) {
+ $user = new User($_SESSION["mb_user_id"]);
+ $allowedWfsConfIds = $user->getWfsConfByPermission();
+ $idArray = array_intersect(array($this->id), $allowedWfsConfIds);
+ if (count($idArray) === 1) {
+ return true;
+ return false;
+ * Creates an object from the database.
+ * Maybe we could have a factory for this later...let's
+ * keep it simple for now
+ * @return WfsConfiguration
+ * @param $id Integer
+ public static function createFromDb ($id) {
+ if (!is_numeric($id)) {
+ return null;
+ $wfsConf = new WfsConfiguration();
+ $wfsConf->id = intval($id);
+ if (!$wfsConf->accessAllowed()) {
+ return null;
+ $sql = <<<SQL
+SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id
+WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1
+SQL;
+ $v = array($wfsConf->id);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+ $row = db_fetch_array($res);
+ $wfsConf->label = $row["g_label"];
+ $wfsConf->labelId = $row["g_label_id"];
+ $wfsConf->style = $row["g_style"];
+ $wfsConf->button = $row["g_button"];
+ $wfsConf->buttonId = $row["g_button_id"];
+ $wfsConf->buffer = $row["g_buffer"];
+ $wfsConf->resStyle = $row["g_res_style"];
+ $wfsConf->wfsId = $row["fkey_wfs_id"];
+ $wfsConf->featureTypeId = $row["fkey_featuretype_id"];
+ $sql = <<<SQL
+SELECT * FROM wfs_conf_element JOIN wfs_element
+ON wfs_conf_element.f_id = wfs_element.element_id
+WHERE wfs_conf_element.fkey_wfs_conf_id = $1
+SQL;
+ $t = array('i');
+ while ($row = db_fetch_array($res)) {
+ $element = new WfsConfigurationElement();
+ $element->name = $row["element_name"];
+ $element->type = $row["element_type"];
+ $element->search = $row["f_search"];
+ $element->styleId = $row["f_style_id"];
+ $element->toUpper = $row["f_toupper"];
+ $element->label = $row["f_label"];
+ $element->labelId = $row["f_label_id"];
+ $element->geom = $row["f_geom"];
+ $element->show = $row["f_show"];
+ $element->mandatory = $row["f_mandatory"];
+ $element->respos = $row["f_respos"];
+ $element->minInput = $row["f_min_input"];
+ $element->formElementHtml = $row["f_form_element_html"];
+ $element->authVarname = $row["f_auth_varname"];
+ $element->detailpos = $row["f_detailpos"];
+ $element->operator = $row["f_operator"];
+ $element->showDetail = $row["f_show_detail"];
+ array_push($wfsConf->elementArray, $element);
+ return $wfsConf;
More information about the Mapbender_commits
