[Mapbender-commits] r3380 - in trunk/mapbender/http: html javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 2 04:52:02 EST 2009
Author: christoph
Date: 2009-01-02 04:52:02 -0500 (Fri, 02 Jan 2009)
New Revision: 3380
Added:
   trunk/mapbender/http/html/mod_treefolderPlain.php
   trunk/mapbender/http/javascripts/mapnf.php
   trunk/mapbender/http/javascripts/ovnf.php
http://trac.osgeo.org/mapbender/ticket/360
Added: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php	                        (rev 0)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php	2009-01-02 09:52:02 UTC (rev 3380)
@@ -0,0 +1,694 @@
+<?php
+# $Id: mod_treefolder2.php 2975 2008-09-18 12:58:42Z nimix $
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include '../include/dyn_js.php';
+function openwindow(Adresse) {
+Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+Fenster1.focus();
+<?php
+   echo "mod_treeGDE_map = '".$e_target[0]."';";
+session_write_close();
+var msgObj = {};
+msgObj.tooltipHandleWms = '<?php echo _mb("(De)activate this service");?>';
+msgObj.tooltipLayerVisible = '<?php echo _mb("Toggles the visibility of this service");?>';
+msgObj.tooltipLayerQuerylayer = '<?php echo _mb("Toggles the queryability of this service");?>';
+msgObj.tooltipLayerContextMenu = '<?php echo _mb("Opens the layer context menu");?>';
+msgObj.tooltipWmsContextMenu = '<?php echo _mb("Opens the WMS context menu");?>';
+msgObj.tooltipRemoveWms = '<?php echo _mb("Removes the selected WMS");?>';
+msgObj.tooltipMoveSelectionUp = '<?php echo _mb("Moves the selection up");?>';
+msgObj.tooltipMoveSelectionDown = '<?php echo _mb("Moves the selection down");?>';
+var jst_container = "document.getElementById('treeGDE')";
+var jst_image_folder = imagedir;
+var jst_display_root = false;
+var defaultTarget = 'examplemain';
+var lock=false;
+var lock_update=false;
+var lock_check=false;
+var selectedMap=-1;
+var selectedWMS=-1;
+var selectedLayer=-1;
+var initialized=false;
+var errors = 0;
+var state=Array();
+var treeState = "";
+<?php
+//load structure
+$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 ORDER BY lft;";
+$v = array($_SESSION["mb_user_gui"]);
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
+//init tree converting arrays
+$nr = array(); 			//array for nested sets numbers
+$str = array();			//array for js array elements
+$categories = array();	//array for wms folders
+$path = array();		//stack for actual path elements
+$rights = array();		//stack for rights of open elements
+//build javascript data array for jsTree
+while($row = db_fetch_array($res)){
+	//push javascript array elements to a single array with lefts and rights
+	$left = "['folder_".$row['id']."', ['".$row['my_layer_title']."', 'javascript:_foo()'],[";
+	$right = "]],";
+	array_push($nr, $row['lft']);
+	array_push($str, $left);
+	array_push($nr, $row['rgt']);
+	array_push($str, $right);
+	//finish all nodes that have no further childs
+	while(count($rights) > 0 && $rights[count($rights)-1]<$row['lft']){
+		array_pop($rights);
+		array_pop($path);
+	//set path for each wms that is referenced in this folder
+	array_push($rights, $row['rgt']);
+	array_push($path, "folder_".$row['id']);
+	if($row['wms_id']!=""){
+		foreach(explode(",",$row['wms_id']) as $wms){
+			array_push($categories, "'wms_".$wms."':\"root_id|".implode("|", $path)."\"");
+//if we have a configured structure output it
+if(count($str)>0){
+	//order js array elements
+	array_multisort($nr, $str);
+	//output javascript vars
+	echo "var arrNodesStr = \"[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];\";\n";
+	echo "var categories = {".implode(",", $categories)."};\n";
+else{
+//if there is no structure take default
+var arrNodesStr = "[['root_id', ['Layer','javascript:_foo()']]];";
+var categories = {};
+<?php
+var arrNodes = eval(arrNodesStr);
+function _foo(){selectedMap=-1;selectedWMS=-1;selectedLayer=-1}
+// some defaults
+if (typeof(reverse) === 'undefined')reverse = 'false';
+if (typeof(switchwms) === 'undefined')switchwms = 'true';
+if (typeof(ficheckbox) === 'undefined')ficheckbox = 'false';
+if (typeof(metadatalink) === 'undefined')metadatalink = 'false';
+if (typeof(wmsbuttons) === 'undefined')wmsbuttons = 'false';
+if (typeof(showstatus) === 'undefined')showstatus = 'false';
+if (typeof(alerterror) === 'undefined')alerterror = 'false';
+if (typeof(openfolder) === 'undefined')openfolder = 'false';
+if (typeof(handlesublayer) === 'undefined')handlesublayer = 'false';
+if (typeof(menu) === 'undefined')menu = '';
+if (typeof(redirectToMetadataUrl) !== 'undefined' && redirectToMetadataUrl == "false") {
+	redirectToMetadataUrl = false;
+else {
+	redirectToMetadataUrl = true;
+var defaultMetadataUrl = '../php/mod_layerMetadata.php?';
+if (redirectToMetadataUrl) {
+	defaultMetadataUrl += 'redirectToMetadataUrl=1';
+else {
+	defaultMetadataUrl += 'redirectToMetadataUrl=0';
+//menu elements
+var menu_move_up = ['menu_move_up', ['Move up&nbsp;','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_move_down = ['menu_move_down', ['Move down&nbsp;', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_delete = ['menu_delete', ['Remove&nbsp;', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
+var menu_opacity_up = ['menu_opacity_up', ['Opacity up&nbsp;','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_opacity_down = ['menu_opacity_down', ['Opacity down&nbsp;','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_metalink = ['menu_metalink', ['Information&nbsp;', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
+var menu_zoom = ['menu_zoom', ['Zoom&nbsp;', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
+var menu_hide = ['menu_hide', ['Hide menu&nbsp;', 'javascript:hideMenu()',,'hide.png']];
+//var menu_wms_switch = ['menu_zoom', ['Zoom&nbsp;', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_layer_switch = ['menu_zoom', ['Zjjj&nbsp;', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_info_switch = ['menu_zoom', ['Zmn&nbsp;', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//parent.eventMapRequestFailed.register(function(t){imgerror(t)});
+eventAfterLoadWMS.register(reloadTree);
+eventInit.register(loadTree);
+if(showstatus=='true'||alerterror=='true'){
+	eventAfterMapRequest.register(init_mapcheck);
+	init_mapcheck();
+eventAfterMapRequest.register(updateScale);
+eventAfterMapRequest.register(updateCheckState);
+if(wmsbuttons != "true")
+	jst_highlight = false;
+function select(i,ii,iii){
+	//ignore if selected
+	if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
+	if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
+		selectedMap=i;
+		selectedWMS=ii;
+		selectedLayer=iii;
+		return;
+	//scalehints
+	var scale = parseInt(mb_getScale(mod_treeGDE_map));
+	if(scale < parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
+		if(selectedLayer==0)
+		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
+		else
+		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
+	else if(scale > parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt( mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
+		else
+	else{
+		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
+		else
+		   	setNodeColor(arrNodes[0][0]+"|wms_"+ mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+ mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
+	selectedMap=i;
+	selectedWMS=ii;
+function updateScale(){
+	if(!initialized)return;
+	myMapObj = getMapObjByName(mod_treeGDE_map);
+	if(myMapObj){
+		var scale = parseInt( mb_getScale(mod_treeGDE_map));
+		for(var ii=0; ii< myMapObj.wms.length; ii++){
+			for(var iii=1; iii< myMapObj.wms[ii].objLayer.length; iii++){
+				if(scale < parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_minscale) != 0){
+						if(iii==0)
+					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '#999999');
+						else
+					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '#999999');
+				else if(scale > parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt( myMapObj.wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
+						if(iii==0)
+						else
+					else{
+						if(iii==0)
+					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id, '');
+						else
+					   	setNodeColor(arrNodes[0][0]+"|wms_"+ myMapObj.wms[ii].wms_id+"|"+ myMapObj.wms[ii].objLayer[iii].layer_id, '');
+function updateCheckState(){
+	if(!initialized||lock_check)return;
+	lock_check=true;
+	for(var i=0; i< mb_mapObj.length; i++){
+		if( mb_mapObj[i].elementName == mod_treeGDE_map){
+			for(var ii=0; ii< mb_mapObj[i].wms.length; ii++){
+				for(var iii=1; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
+					if(! mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
+						path = arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id+"|"+ mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
+						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible=='1', false);
+						if(ficheckbox == 'true')
+							checkNode(path, 1,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
+	lock_check=false;
+function operaLoad(){
+	initArray();
+	renderTree();
+	setTimeout('initWmsCheckboxen();updateScale();',100);
+function loadTree(){
+	if(window.opera){
+		setTimeout('operaLoad()',200);
+		return;
+	initArray();
+	renderTree();
+	initWmsCheckboxen();
+	updateScale();
+function reloadTree(){
+	if(!initialized) return;
+	selectedMap=-1;
+	selectedWMS=-1;
+	selectedLayer=-1;
+	initialized=false;
+	arrNodes = eval(arrNodesStr)
+	initArray();
+	if(showstatus=='true'||alerterror=='true')
+		init_mapcheck();
+	renderTree();
+	if(window.opera)
+	else{
+		updateScale();
+function imgerror(t){
+	var map= getMapObjIndexByName(mod_treeGDE_map);
+	var wms=Number(t.id.substr(4));
+	t.onerror=null;
+	t.onabort=null;
+	if(state[wms]!=-1 && alerterror=='true'){
+		state[wms]=-1;
+		if(confirm('Failed to Load WMS "'+ mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+ mb_mapObj[map].wms[wms].wms_getmap.substr(0, mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?')){
+			window.open(t.src,"");
+	state[wms]=-1;
+	errors++;
+	if(showstatus=='true')
+		setNodeImage(arrNodes[0][0]+"|wms_"+ mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
+function checkComplete(wms, map, img, first){
+	var ind= getMapObjIndexByName(mod_treeGDE_map);
+	if( mb_mapObj[ind].wms[wms].mapURL == false ||  frames[mod_treeGDE_map].document.getElementById(map).complete){
+		if(state[wms]!=-1){
+			for(var i=1;i< mb_mapObj[ind].wms[wms].objLayer.length;i++){
+				if( mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
+					state[wms]=1;
+						setNodeImage(img);
+					break;
+	else{
+		if(first){
+			state[wms]=0;
+//			 frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
+//			 frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
+				setNodeImage(img, "loading_folder.gif");
+			setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
+// mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
+function init_mapcheck(){
+	errors = 0;
+	var ind =  getMapObjIndexByName(mod_treeGDE_map);
+	if(! mb_mapObj[ind]||!initialized){
+		setTimeout("init_mapcheck();",100);
+		return;
+	for(var wms=0;wms< mb_mapObj[ind].wms.length;wms++){
+		var wmsimgid="map_"+wms;
+		if( frames[mod_treeGDE_map].document.getElementById(wmsimgid)){
+			checkComplete(wms, wmsimgid, arrNodes[0][0]+'|wms_'+ mb_mapObj[ind].wms[wms].wms_id, true);
+function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+	if(lock_update||lock_check)return;
+	var ind =  getMapObjIndexByName(mapObj);
+	for(var i=0; i< mb_mapObj[ind].wms.length; i++){
+		if( mb_mapObj[ind].wms[i].wms_id == wms_id){
+			 mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+			break;
+function zoomToLayer(j,k,l){
+	if(!j&&!k&&!l){
+		j=selectedMap;
+		k=selectedWMS;
+		l=selectedLayer;
+	var my= mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
+	for (var i=0;i<my.length;i++){
+		if(my[i]["epsg"]== mb_mapObj[j].epsg){
+			 mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
+			var arrayExt =  mb_mapObj[j].extent.split(",");
+			 mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
+			break;
+//---begin------------- opacity --------------------
+var opacityIncrement = 20;
+function opacity_up(j, k, l) {
+	handleOpacity(j, k, opacityIncrement);
+function opacity_down(j, k, l) {
+	handleOpacity(j, k, -opacityIncrement);
+function handleOpacity(mapObj_id, wms_id, increment) {
+	var opacity =  mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
+	 mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
+	reloadTree();
+//---end------------- opacity --------------------
+function move_up(j,k,l){
+	if(isNaN(j)&&isNaN(k)&&isNaN(l)){
+		j=selectedMap;
+		k=selectedWMS;
+		l=selectedLayer;
+	if(j==-1||k==-1||l==-1){
+		alert("You have to select the WMS you want to move up!")
+		return;
+	var lid= mb_mapObj[j].wms[k].objLayer[l].layer_id;
+	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
+		alert("Illegal move operation");
+		return;
+	treeState = getState();
+	 zoom( mb_mapObj[j].frameName, true, 1.0);
+	 mb_execloadWmsSubFunctions();
+	//find layer and select
+	for(k=0;k< mb_mapObj[j].wms.length;k++){
+		for(l=0;l< mb_mapObj[j].wms[k].objLayer.length;l++){
+			if( mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
+				select(j,k,l);
+				if(l!=0)
+					selectNode(String(lid));
+				else
+					selectNode("wms_"+String( mb_mapObj[j].wms[k].wms_id));
+function move_down(j,k,l){
+		j=selectedMap;
+		k=selectedWMS;
+		l=selectedLayer;
+		alert("You have to select the WMS you want to move down!")
+		return;
+	if(! mb_mapObj[j].move( mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
+		return;
+				select(j,k,l);
+				if(l!=0)
+				else
+function remove_wms(j,k,l){
+		j=selectedMap;
+		k=selectedWMS;
+		l=selectedLayer;
+		alert("You have to select the WMS you want to delete!")
+		return;
+	if(l!=0){
+		alert("It is not possible to delete a single layer, please select a WMS!")
+		return;
+	var visibleWMS=0;
+	for(var i=0;i< mb_mapObj[j].wms.length;i++)
+		if( mb_mapObj[j].wms[i].gui_wms_visible=='1'|| mb_mapObj[j].wms[i].gui_wms_visible==1)
+			visibleWMS++;
+	if(visibleWMS<=1){
+		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+		return;
+	if(confirm('Are you sure you want to remove "'+ mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
+  		 mb_mapObjremoveWMS(j,k);
+function updateParent(path){
+	if(lock_check)return;
+	var reset_lock=!lock_update;
+	lock_update=true;
+	var state=getChildrenCheckState(path, 0);
+	//enableCheckbox(path, (state!=-1)); //3rd state
+	checkNode(path, 0, (state==1));
+	if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
+		setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
+	if(reset_lock)
+		lock_update=false;
+function handleSelectedWMS(path){
+	if(lock_update)return;
+	var t = path.split("|");
+	var wms_id = t[t.length-1].substr(4);
+	var reset_lock=!lock_check;
+	var wms =  getWMSIndexById(mod_treeGDE_map,wms_id);
+	var layername =  mb_mapObj[ind].wms[wms].objLayer[0].layer_name;
+	var bChk = IsChecked(path, 0);
+	 mb_mapObj[ind].wms[wms].handleLayer(layername,"visible",bChk?"1":"0");
+	 mb_mapObj[ind].wms[wms].handleLayer(layername,"querylayer",bChk?"1":"0");
+	lock_check=true;
+	checkChildren(path, 0, bChk);
+	if(ficheckbox)checkChildren(path, 1, bChk);
+	if(bChk==false && showstatus=='true')
+	if(reset_lock)
+		 mb_restateLayers(mod_treeGDE_map,wms_id);
+		 setSingleMapRequest(mod_treeGDE_map,wms_id);
+		lock_check=false;
+function handleSelection(path, box){
+	lock_check=true;
+	var bChk = IsChecked(path, box);
+//	enableCheckbox(path, 0, true);
+	checkChildren(path, box, bChk);
+	if(reset_lock){
+		//find wms id from path
+		for(var i=1;t[i].indexOf("wms_")!=0;i++){}
+		var wms_id = t[i].substr(4);
+		//set maprequest
+		if(box==0)
+		lock_check=false;
+function initArray(){
+	var parentObj = "";
+	var controls="";
+	if( mb_mapObj.length > 0){
+					if( mb_mapObj[i].wms[ii].gui_wms_visible == '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+						for(var iii=0; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
+							var temp =  mb_mapObj[i].wms[ii].objLayer[iii];
+							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
+								if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
+									continue;
+								parentNode = arrNodes[0][0];
+								if(eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id) !== undefined)
+									parentNode = eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id);
+								else
+									eval("categories['wms_"+ mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
+								var c_menu="[";
+								if(reverse=="true"){
+									if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
+									if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
+								else{
+									if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
+									if(menu.indexOf("wms_down")!=-1 && ii!= mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
+								if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
+//								if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
+								if(menu.indexOf("opacity_up")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
+								if(menu.indexOf("opacity_down")!=-1 && parseFloat( mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
+								if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
+								c_menu+="]";
+								controls=null;
+								if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '" checked onclick="handleSelectedWMS(\''+parentNode+'|wms_'+ mb_mapObj[i].wms[ii].wms_id+'\');" />';
+								if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
+								addNode(parentNode,["wms_"+ mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+								parentObj = parentNode+"|wms_"+ mb_mapObj[i].wms[ii].wms_id;
+							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"|| mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
+								var parentLayer = "";
+								var j = iii;
+								while( mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
+									//find parent
+									for(var jj=0; jj <  mb_mapObj[i].wms[ii].objLayer.length; jj++){
+										if( mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt( mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
+											j=jj;
+											break;
+									parentLayer = "|" +  mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
+								if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+									var c_menu="[";
+										if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
+										if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
+									else{
+										if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
+										if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
+									if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
+									if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
+//									if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
+//									if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
+									c_menu+="]";
+									controls = [];
+									controls.push('<input type="checkbox"  title="' + msgObj.tooltipLayerVisible + '" ');
+									if(temp.layer_name=="")
+										controls.push('style="display:none;" ');
+									if(temp.gui_layer_visible=='1')
+										controls.push('checked ');
+									if(temp.gui_layer_selectable!='1')
+										controls.push('disabled ');
+									controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
+									if(ficheckbox == 'false')
+										controls.push("handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+									controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
+									controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
+									if(ficheckbox == 'true'){
+										controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerQuerylayer + '" ');
+										if(temp.gui_layer_querylayer=='1')
+										if(temp.gui_layer_queryable!='1')
+										controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+										controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
+									if(wmsbuttons == 'true'&&metadatalink == 'true'){
+										controls.push('<a href="javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');"><img src="'+imagedir+'/info.png" /></a>');
+									addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls.join(""),[i,ii,iii]]],false,false,reverse=="true");
+	initialized=true;
+function initWmsCheckboxen(){
+	var hidden=0;
+								updateParent(arrNodes[0][0]+"|"+ mb_mapObj[i].wms[ii].wms_id);
+					else if(ii<= parseInt(openfolder)+hidden)
+						hidden++;
+				closeAll()
+				if(treeState!='')
+					setState(treeState);
+				else if(openfolder!='false')
+					setState(arrNodes[0][0]+"|"+ mb_mapObj[i].wms[ parseInt(openfolder)+hidden].wms_id);
+if(wmsbuttons=='true'){
+	document.writeln("<div>");
+	document.writeln('<a href="javascript:move_up()"><img title="'+msgObj.tooltipMoveSelectionUp+'" src="'+imagedir+'/move_up.png" alt="move up" style="position:relative;top:0px;left:0px;"/></a>');
+	document.writeln('<a href="javascript:move_down()"><img title="'+msgObj.tooltipMoveSelectionDown+'" src="'+imagedir+'/move_down.png" alt="move down" style="position:relative;top:0px;left:-3px"/></a>');
+	document.writeln('<a href="javascript:remove_wms()"><img title="'+msgObj.tooltipRemoveWms+'" src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>');
+	document.writeln("</div>");
Added: trunk/mapbender/http/javascripts/mapnf.php
--- trunk/mapbender/http/javascripts/mapnf.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mapnf.php	2009-01-02 09:52:02 UTC (rev 3380)
@@ -0,0 +1 @@
+mb_registerMapObj('', 'mapframe1', null,500, 500);
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/ovnf.php
--- trunk/mapbender/http/javascripts/ovnf.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/ovnf.php	2009-01-02 09:52:02 UTC (rev 3380)
@@ -0,0 +1 @@
+mb_registerMapObj('', 'overview', null,150, 150);
More information about the Mapbender_commits mailing list
