[Mapbender-commits] r3389 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Fri Jan 2 08:15:58 EST 2009
Author: christoph
Date: 2009-01-02 08:15:58 -0500 (Fri, 02 Jan 2009)
New Revision: 3389
trunk/mapbender/resources/db/update/update_2.6.sql
http://trac.osgeo.org/mapbender/ticket/360
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-01-02 13:15:26 UTC (rev 3388)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-01-02 13:15:58 UTC (rev 3389)
@@ -89,3 +89,8 @@
UPDATE gui_element SET e_pos = 1, e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="mapframe1_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'mapnf.php' WHERE e_id = 'mapframe1';
UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'ovnf.php', e_target = '', e_requires = 'mapframe1' WHERE e_id = 'overview';
UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+DELETE FROM gui_element WHERE e_id = 'closePolygon';
+DELETE FROM gui_element WHERE e_id = 'rubber';
+DELETE FROM gui_element WHERE e_id = 'getArea';
More information about the Mapbender_commits
