[Mapbender-commits] r3396 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 2 10:23:56 EST 2009
Author: christoph
Date: 2009-01-02 10:23:56 -0500 (Fri, 02 Jan 2009)
New Revision: 3396
   trunk/mapbender/resources/db/update/update_2.6.sql
http://trac.osgeo.org/mapbender/ticket/360
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-01-02 15:17:03 UTC (rev 3395)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-01-02 15:23:56 UTC (rev 3396)
@@ -91,6 +91,12 @@
 INSERT INTO gui_element_vars select fkey_gui_id,'overview' as fkey_e_id, 'overview_wms' as var_name, '0' as var_value, 'wms that shows up as overview' as context, 'var' as var_type from gui_element where e_id = 'overview';
 UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
 INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
 DELETE FROM gui_element WHERE e_id = 'closePolygon';
 DELETE FROM gui_element WHERE e_id = 'rubber';
More information about the Mapbender_commits mailing list
