[Mapbender-commits] r3403 - branches/2.5/http/classes
svn_mapbender at osgeo.org
Mon Jan 5 05:34:37 EST 2009
Author: christoph
Date: 2009-01-05 05:34:37 -0500 (Mon, 05 Jan 2009)
New Revision: 3403
branches/2.5/http/classes/class_bbox.php
branches/2.5/http/classes/class_point.php
http://trac.osgeo.org/mapbender/ticket/361
Modified: branches/2.5/http/classes/class_bbox.php
--- branches/2.5/http/classes/class_bbox.php 2009-01-05 10:30:08 UTC (rev 3402)
+++ branches/2.5/http/classes/class_bbox.php 2009-01-05 10:34:37 UTC (rev 3403)
@@ -31,7 +31,23 @@
* @constructor
- function __construct($param0, $param1, $param2, $param3, $param4) {
+ function __construct() {
+ if (func_num_args() == 5) {
+ $param0 = func_get_arg(0);
+ $param1 = func_get_arg(1);
+ $param2 = func_get_arg(2);
+ $param3 = func_get_arg(3);
+ $param4 = func_get_arg(4);
+ else if (func_num_args() == 3) {
+ else {
+ return;
// params are point, point, epsg
if (is_a($param0, "Mapbender_point") && is_a($param1, "Mapbender_point") && !$param3 && !$param4) {
$e = new mb_notice("Mapbender_bbox: constructor: point1, point2, epsg");
@@ -144,6 +160,10 @@
return false;
+ function toHtml () {
+ return (string) $this->min->toHtml() . " | " . $this->max->toHtml();
function __toString() {
return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
Modified: branches/2.5/http/classes/class_point.php
--- branches/2.5/http/classes/class_point.php 2009-01-05 10:30:08 UTC (rev 3402)
+++ branches/2.5/http/classes/class_point.php 2009-01-05 10:34:37 UTC (rev 3403)
@@ -31,13 +31,23 @@
* @constructor
- function __construct($x, $y, $z, $epsg) {
- // may be called without $z; so $epsg is the third parameter, $z
- if (isset($x) && isset($y) && isset($z) && !isset($epsg)) {
- $e = new mb_notice("Mapbender_point: constructor: probably 2d call (x: ".$x.", y: ".$y.", z: ".$z.", epsg:".$epsg.")!");
- $epsg = $z;
+ if (func_num_args() == 4) {
+ $x = func_get_arg(0);
+ $y = func_get_arg(1);
+ $z = func_get_arg(2);
+ $epsg = func_get_arg(3);
$z = false;
+ $epsg = func_get_arg(2);
+ else {
+ return;
if (!isset($x) || !isset($y) || !isset($epsg)) {
$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", z: ".$z.", epsg:".$epsg.")!");
More information about the Mapbender_commits
