[Mapbender-commits] r3434 - in branches/print_dev/http: classes print/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 13 05:22:53 EST 2009
Author: mschulz
Date: 2009-01-13 05:22:53 -0500 (Tue, 13 Jan 2009)
New Revision: 3434
   branches/print_dev/http/classes/class_map.php
   branches/print_dev/http/print/classes/mbMapDecorator.php
added Mapbender map bbox adjustment
Modified: branches/print_dev/http/classes/class_map.php
--- branches/print_dev/http/classes/class_map.php	2009-01-13 08:41:38 UTC (rev 3433)
+++ branches/print_dev/http/classes/class_map.php	2009-01-13 10:22:53 UTC (rev 3434)
@@ -45,7 +45,7 @@
 	public function getWidth () {
 		return $this->width;
 	 * @param $value Integer
@@ -90,7 +90,38 @@
 	public function getExtent () {
 		return $this->extent;
+	 * @return Mapbender_bbox extent information
+	public function getExtentInfo () {
+		return array($this->extent->min->x, $this->extent->min->y, $this->extent->max->x, $this->extent->max->y);
+	 * converts the extent of the map so that the maximum	extent will be displayed
+	public function calculateExtent($aMapbenderBbox) {
+		$relation_px_x = $this->getWidth() / $this->getHeight();
+		$relation_px_y = $this->getHeight() / $this->getWidth();
+		$extentx = ($aMapbenderBbox->max->x - $aMapbenderBbox->min->x);
+		$extenty = ($aMapbenderBbox->max->y - $aMapbenderBbox->min->y);
+		$centerx = $aMapbenderBbox->min->x + $extentx/2;
+		$centery = $aMapbenderBbox->min->y + $extenty/2;
+		$relation_bbox_x = $extentx / $extenty;
+		if($relation_bbox_x <= $relation_px_x){
+			$aMapbenderBbox->min->x = $centerx - $relation_px_x * $extenty / 2;
+			$aMapbenderBbox->max->x = $centerx + $relation_px_x * $extenty / 2;
+		if($relation_bbox_x > $relation_px_x){
+			$aMapbenderBbox->min->y = $centery - $relation_px_y * $extentx / 2;
+			$aMapbenderBbox->max->y = $centery + $relation_px_y * $extentx / 2;
+		$this->setExtent($aMapbenderBbox);
 	 * @return String EPSG code of the map.
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php	2009-01-13 08:41:38 UTC (rev 3433)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php	2009-01-13 10:22:53 UTC (rev 3434)
@@ -2,6 +2,7 @@
 require_once(dirname(__FILE__)."/../../classes/class_stripRequest.php");
 require_once(dirname(__FILE__)."/../../classes/class_weldMaps2PNG.php");
+require_once(dirname(__FILE__)."/../../classes/class_map.php");
 class mbMapDecorator extends mbTemplatePdfDecorator {
@@ -20,18 +21,30 @@
 		$height = $this->conf->height;
 		$res = $this->pdf->k*($this->conf->res_dpi/72);
 		$myURL = new stripRequest($array_urls[0]);
-		$this->mapExtent = $myURL->get('BBOX');
+		$e = new mb_notice("mbMapDecorator: original bbox: ".$myURL->get('BBOX'));
+		$this->mapExtent = $this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs'));
+		$e = new mb_notice("mbMapDecorator: adjusted bbox: ".$this->mapExtent);
 		for($i=0; $i<count($array_urls); $i++){
 			$m = new stripRequest($array_urls[$i]);
 			$m->set('width',(intval($width*$res)));
 			$m->set('height',(intval($height*$res)));
+			$m->set('bbox', $this->mapExtent);
 			$array_urls[$i] = $m->url;
 		$i = new weldMaps2PNG(implode("___",$array_urls),$this->filename);
 		$this->pdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $width, $height,'png');
+	protected function adjustBbox($aBboxArray, $aSrsString) {
+		$aMbBbox = new Mapbender_bbox($aBboxArray[0],$aBboxArray[1],$aBboxArray[2],$aBboxArray[3],$aSrsString);
+		$aMap = new Map();
+		$aMap->setWidth($this->conf->width);
+		$aMap->setHeight($this->conf->height);
+		$aMap->calculateExtent($aMbBbox);
+		$adjustedMapExt = $aMap->getExtentInfo();
+		return implode(",",$adjustedMapExt);
\ No newline at end of file
More information about the Mapbender_commits mailing list
