[Mapbender-commits] r3441 - in branches/2.5: . tools
svn_mapbender at osgeo.org
Tue Jan 13 11:06:28 EST 2009
Author: astrid_emde
Date: 2009-01-13 11:06:28 -0500 (Tue, 13 Jan 2009)
New Revision: 3441
Added:
branches/2.5/tools/
branches/2.5/tools/mapFiler.php
folder moved for security reasons out of http
Copied: branches/2.5/tools (from rev 3366, branches/2.5/http/tools)
Copied: branches/2.5/tools/mapFiler.php (from rev 3440, branches/2.5/http/tools/mapFiler.php)
--- branches/2.5/tools/mapFiler.php (rev 0)
+++ branches/2.5/tools/mapFiler.php 2009-01-13 16:06:28 UTC (rev 3441)
@@ -0,0 +1,162 @@
+<html>
+ <head>
+ <title>MapFiler Version 0.2 for UMN MapServer 5.x</title>
+ <style></style>
+ <script type='text/javascript' >
+ function validate(){
+ /*eventuell den Inhalt (Pfad) noch aufbereiten?
+ * Slash und Backslash -> win, linux usw.
+ document.form1.location.type = 'text';
+ document.form1.myLocation.value = document.form1.location.value;
+ document.form1.submit();
+ </script>
+ </head>
+ <body>
+ <form name='form1' action='<?php $PHP_SELF ?>' method='POST'>
+ <b>MapFiler Version 0.2 for UMN MapServer 5.x </b>
+ <br><br>changes in Version 0.2
+ <li>multiplicate MAXSIZE with factor</li>
+ <li>division SYMBOLSCALE by factor</li>
+ <li>multiplicate WIDTH with factor</li>
+ <li>division MINSCALEDENOM and MAXSCALEDENOM by factor </li>
+ <br>
+ <table>
+ <tr>
+ <td>Location:</td>
+ <td>
+ <input type='file' name='location' >
+ <input type='hidden' name='myLocation'>
+ </td>
+ </tr>
+ <tr>
+ <td>all files with the same extension:</td>
+ <td>
+ <input type='checkbox' name='dir'>
+ </td>
+ </tr>
+ <tr>
+ <td>Factor:</td>
+ <td><input type='text' name='factor' value='4'></td>
+ </tr>
+ <tr>
+ <td><input type='button' value="let's go" onclick='validate()'></td>
+ <td></td>
+ </tr>
+ </table>
+ <?php
+import_request_variables('PG');
+/*********PARAMS***************/
+$countSymbolsFiles = 0;
+$arraySymbolsFiles;
+function modify($myDir, $myFile){
+ global $factor;
+ $myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen geöffnet werden!");
+ $myNewContent = fopen($myDir."/".str_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". str_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben geöffnet werden!");
+ fputs($myNewContent, "#Modified by MapbenderTools" . "Date: ". date("d.m.Y") . "Factor: ". $factor . "\n\n");
+ //fputs($myNewContent, "#Date: ". date("d.m.Y") . "Factor: ". $factor . "\n\n");
+ //fputs($myNewContent, "#Factor: ". $factor . "\n\n");
+ while(!feof($myContent)){
+ $myLine = fgets($myContent, 1024);
+ if(preg_match("/\bSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ if(count($matches) <= 2){
+ fputs($myNewContent, str_replace($matches[1], multiplicate($matches[1]), $myLine));
+ else if(preg_match("/(.*OFFSET)\s*(\d+.?\d*)(\s*)(\d+.?\d*)(\s*)/i",$myLine,$matches)){
+ $myNewOFFSET=$matches[1] . " " .multiplicate($matches[2]) . " " . multiplicate($matches[4]).$matches[5];
+ fputs($myNewContent,$myNewOFFSET);
+ else if(preg_match("/\bMAXSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ else if(preg_match("/\bMINSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ else if(preg_match("/\bWIDTH\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ //fputs($myNewContent, "# ". $myLine);
+ else if(preg_match("/\bSYMBOLSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ fputs($myNewContent, str_replace($matches[1], division($matches[1]), $myLine));
+ else if(preg_match("/\bMINSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ else if(preg_match("/\bMAXSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+ else if(preg_match("/\bSYMBOLSET\s*(.*)/i",$myLine,$matches)){ //noch nicht fertig
+ $arraySymbolFiles[$countSymbolsFiles] = str_replace("\"","",$matches[1]);
+ $countSymbolsFiles++;
+ fputs($myNewContent, $myLine);
+ #catch all
+ else{
+ fclose($myContent);
+ fclose($myNewContent);
+function multiplicate($x){
+ global $factor;
+ $x = floatval($x) * $factor;
+ return $x;
+function division($x){
+ global $factor;
+ $x = floatval($x) / $factor;
+ return $x;
+ if(isset($myLocation) && $myLocation != ""){
+ # what is to do...
+ $myFile = basename($myLocation);
+ $myDir = dirname($myLocation);
+ $suffix = strstr($myFile, ".");
+ if(!isset($dir)){
+ modify($myDir, $myFile);
+ echo "modified: " . $myDir . "/" . $myFile. "<br />";
+ else{
+ if($verz = opendir($myDir)){
+ while ($myFile = readdir ($verz)) {
+ if($myFile != ".." && $myFile != "." && is_file($myDir."/".$myFile) && strstr($myFile, $suffix)){
+ closedir($verz);
+ </form>
+ </body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
