[Mapbender-commits] r3451 - branches/print_dev/http/print/classes
svn_mapbender at osgeo.org
Wed Jan 14 12:16:51 EST 2009
Author: mschulz
Date: 2009-01-14 12:16:51 -0500 (Wed, 14 Jan 2009)
New Revision: 3451
branches/print_dev/http/print/classes/mbMapDecorator.php
branches/print_dev/http/print/classes/mbOverviewDecorator.php
branches/print_dev/http/print/classes/mbTemplatePdf.php
branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php
mapExtent available in templatePDF
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php 2009-01-13 23:09:18 UTC (rev 3450)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php 2009-01-14 17:16:51 UTC (rev 3451)
@@ -19,21 +19,21 @@
$array_urls = explode("___", $urls);
$width = $this->conf->width;
$height = $this->conf->height;
- $res = $this->pdf->k*($this->conf->res_dpi/72);
+ $res = $this->pdf->objPdf->k*($this->conf->res_dpi/72);
$myURL = new stripRequest($array_urls[0]);
$e = new mb_notice("mbMapDecorator: original bbox: ".$myURL->get('BBOX'));
- parent::setMapExtent($this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
- $e = new mb_notice("mbMapDecorator: adjusted bbox: ".parent::getMapExtent());
+ $this->pdf->setMapExtent($this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
+ $e = new mb_notice("mbMapDecorator: adjusted bbox: ".$this->pdf->getMapExtent());
for($i=0; $i<count($array_urls); $i++){
$m = new stripRequest($array_urls[$i]);
$m->set('width',(intval($width*$res)));
$m->set('height',(intval($height*$res)));
- $m->set('bbox', parent::getMapExtent());
+ $m->set('bbox', $this->pdf->getMapExtent());
$array_urls[$i] = $m->url;
- $i = new weldMaps2PNG(implode("___",$array_urls),$this->filename);
- $this->pdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $width, $height,'png');
+ $i = new weldMaps2PNG(implode("___",$array_urls), $this->filename);
+ $this->pdf->objPdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $width, $height,'png');
protected function adjustBbox($aBboxArray, $aSrsString) {
Modified: branches/print_dev/http/print/classes/mbOverviewDecorator.php
--- branches/print_dev/http/print/classes/mbOverviewDecorator.php 2009-01-13 23:09:18 UTC (rev 3450)
+++ branches/print_dev/http/print/classes/mbOverviewDecorator.php 2009-01-14 17:16:51 UTC (rev 3451)
@@ -18,7 +18,7 @@
$o_url = new stripRequest($overview_url);
$o_url->set('width',intval($width*$res));
$o_url->set('height',intval($height*$res));
$overview_url = $o_url->url;
@@ -26,10 +26,10 @@
$urls = $_REQUEST["map_url"];
- $myURL->set('bbox', parent::getMapExtent());
+ $myURL->set('bbox', $this->pdf->getMapExtent());
$i = new weldOverview2PNG($overview_url, $myURL->url, $this->filename);
Modified: branches/print_dev/http/print/classes/mbTemplatePdf.php
--- branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-13 23:09:18 UTC (rev 3450)
+++ branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-14 17:16:51 UTC (rev 3451)
@@ -17,7 +17,17 @@
$this->confPdf->format);
$this->outputFileName = $this->generateOutputFileName("map","pdf");
+ public function setMapExtent($aBboxString) {
+ $this->mapExtent = $aBboxString;
+ $e = new mb_notice("mbTemplatePdf: setting mapExtent to ".$this->mapExtent);
+ public function getMapExtent() {
+ $e = new mb_notice("mbTemplatePdf: getting mapExtent as ".$this->mapExtent);
+ return $this->mapExtent;
public function render() {
foreach ($this->confPdf->pages as $pageConf) {
/* apply the template to the pdf page */
@@ -29,10 +39,10 @@
foreach ($pageConf->elements as $pageElementId => $pageElementConf) {
switch ($pageElementId) {
case "map":
- $err = new mbMapDecorator($this->objPdf, $pageElementConf);
+ $err = new mbMapDecorator($this, $pageElementConf);
break;
case "overview":
- $err = new mbOverviewDecorator($this->objPdf, $pageElementConf);
+ $err = new mbOverviewDecorator($this, $pageElementConf);
break;
Modified: branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php
--- branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php 2009-01-13 23:09:18 UTC (rev 3450)
+++ branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php 2009-01-14 17:16:51 UTC (rev 3451)
@@ -2,7 +2,7 @@
abstract class mbTemplatePdfDecorator extends mbTemplatePdf {
- /* the pdf object to decorate */
+ /* the template pdf object to decorate */
public $pdf;
/* the conf object for the desired decoration */
public $conf;
@@ -14,16 +14,6 @@
$this->conf = $mapConf;
- public function setMapExtent($aBboxString) {
- parent::$mapExtent = $aBboxString;
- $e = new mb_notice("mbTemplatePdfDecorator: setting mapExtent to ".parent::$mapExtent);
- public function getMapExtent() {
- $e = new mb_notice("mbTemplatePdfDecorator: getting mapExtent as ".parent::$mapExtent);
- return parent::$mapExtent;
abstract public function decorate();
More information about the Mapbender_commits
