[Mapbender-commits] r3460 - branches/print_dev/http/print
svn_mapbender at osgeo.org
Wed Jan 14 16:44:36 EST 2009
Author: mschulz
Date: 2009-01-14 16:44:36 -0500 (Wed, 14 Jan 2009)
New Revision: 3460
branches/print_dev/http/print/mod_printPDF_div.php
branches/print_dev/http/print/testConfigTemplate.json
added select element in config and div
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php 2009-01-14 21:03:54 UTC (rev 3459)
+++ branches/print_dev/http/print/mod_printPDF_div.php 2009-01-14 21:44:36 UTC (rev 3460)
@@ -41,10 +41,23 @@
function buildForm(json) {
/* first let's build some defaults then the stuff from config */
- for (var element in json.controls) {
- var element_id = myId + "_" + json.controls[element].id;
- var str = '<label for="'+element_id+'">'+json.controls[element].label+'</label>';
- str += '<input type="'+json.controls[element].type+'" id="'+element_id+'" size="'+json.controls[element].size+'">';
+ for (var item in json.controls) {
+ var element = json.controls[item];
+ var element_id = myId + "_" + element.id;
+ var str = '<label class="print_label" for="'+element_id+'">'+element.label+'</label>\n';
+ switch (element.type) {
+ case "text":
+ str += '<input class="" type="'+element.type+'" id="'+element_id+'" size="'+element.size+'">\n';
+ break;
+ case "select":
+ str += '<select class="" id="'+element_id+'" size="'+element.size+'">\n';
+ for (var option_index in element.options) {
+ option = element.options[option_index];
+ str += '<option value="'+option.value+'">'+option.label+'</option>\n';
+ str += '</select>\n';
+ break;
$("#"+myId).append(str);
\ No newline at end of file
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json 2009-01-14 21:03:54 UTC (rev 3459)
+++ branches/print_dev/http/print/testConfigTemplate.json 2009-01-14 21:44:36 UTC (rev 3460)
@@ -9,7 +9,24 @@
"label" : "Titel",
"type" : "text",
"size" : 20
+ "id" : "dpi",
+ "label" : "DPI",
+ "type" : "select",
+ "size" : 20,
+ "options" : [{
+ "value" : "val1",
+ "label" : "label1"
+ "value" : "val2",
+ "label" : "label2"
+ "value" : "val3",
+ "label" : "label3"
"pages" : [
More information about the Mapbender_commits
