[Mapbender-commits] r3466 - in branches/print_dev/http/print: .
classes
svn_mapbender at osgeo.org
Tue Jan 20 09:53:02 EST 2009
Author: mschulz
Date: 2009-01-20 09:53:02 -0500 (Tue, 20 Jan 2009)
New Revision: 3466
Added:
branches/print_dev/http/print/printPDF_download.php
branches/print_dev/http/print/classes/mbPdf.php
branches/print_dev/http/print/mod_printPDF_div.php
branches/print_dev/http/print/testConfigTemplate.json
branches/print_dev/http/print/testfactories.php
div gui module with one-click download
Modified: branches/print_dev/http/print/classes/mbPdf.php
--- branches/print_dev/http/print/classes/mbPdf.php 2009-01-20 12:16:44 UTC (rev 3465)
+++ branches/print_dev/http/print/classes/mbPdf.php 2009-01-20 14:53:02 UTC (rev 3466)
@@ -22,15 +22,31 @@
public function returnPDF() {
if ($this->isSaved) {
- header('Content-Type:application/pdf');
- header('Content-Disposition:attachment;filename="'.$this->outputFileName.'"');
- $this->objPdf->Output($this->outputFileName,'D');
+ header('Content-Type: application/octet-stream');
+ header('Content-Disposition: attachment; filename="'.$this->outputFileName.'"');
+ header('Pragma: public');
+ ob_end_flush();
+ $this->objPdf->Output($this->outputFileName,'S');
else
die("PDF output not rendered yet.");
+ public function returnAbsoluteUrl() {
+ $mbjson = new Mapbender_JSON();
+ if ($this->isSaved) {
+ if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on")
+ $prot = "https://";
+ else
+ $prot = "http://";
+ $absoluteUrlToPdf = $prot.$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/printPDF_download.php?f=".$this->outputFileName."&".SID;
+ return $mbjson->encode(array("outputFileName"=>$absoluteUrlToPdf));
+ else
+ return $mbjson->encode(array("error"=>"Possibly no map urls delivered."));
- public function returnURL() {
+ public function returnUrl() {
return $mbjson->encode(array("outputFileName"=>TMPDIR."/".$this->outputFileName));
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php 2009-01-20 12:16:44 UTC (rev 3465)
+++ branches/print_dev/http/print/mod_printPDF_div.php 2009-01-20 14:53:02 UTC (rev 3466)
@@ -24,7 +24,6 @@
echo "var myTarget = '".$e_target[0]."';";
echo "var myId = '".$e_id."';";
-var exists = false;
eventInit.register(function () {
mod_printPDF_init();
@@ -41,16 +40,35 @@
function hookForm() {
var options = {
- url: '../print/testfactories.php',
- beforeSubmit: validate,
- success: showResult
+ url: '../print/testfactories.php',
+ type: 'post',
+ dataType: 'json',
+ beforeSubmit: validate,
+ success: showResult
$("#"+myId+"_form").ajaxForm(options);
+ * Change status of the working elements. These should begin with "$myId_working"
+ * @param {String} newStatus either "hide or "show"
+function showHideWorking(newStatus) {
+ if (newStatus=="hide")
+ $("[id^='"+myId+"_working']").hide();
+ else
+ $("[id^='"+myId+"_working']").show();
+ * Validates and updates form data values.
+ * Adds the elements before the submit button.
+ * @see jquery.forms#beforeSubmitHandler
function validate(formData, jqForm, options) {
- $('#printPDF_working_bg').show();
- $('#printPDF_working').show();
+ showHideWorking("show");
var ind = getMapObjIndexByName(myTarget);
var f = jqForm[0];
f.map_url.value = '';
@@ -61,7 +79,6 @@
if(f.map_url.value != ""){
f.map_url.value += '___';
- //alert(f.map_url.value);
f.map_url.value += mb_mapObj[ind].wms[i].mapURL;
@@ -77,7 +94,6 @@
var ind_overview = getMapObjIndexByName('overview');
if(mb_mapObj[ind_overview].mapURL != false ){
- //f.overview_url.value = mb_mapObj[ind_overview].mapURL;
for(var j=0; j < formData.length; j++){
if (formData[j].name == "overview_url") {
formData[j].value = mb_mapObj[ind_overview].mapURL;
@@ -89,28 +105,30 @@
if (f.map_url.value!="") {
return true;
} else {
- $('#printPDF_working_bg').hide();
- $('#printPDF_working').hide();
+ showHideWorking("hide");
return false;
-function showResult(res) {
- if (res.outputFileName)
- window.location = res.outputFileName;
- else
- $('#printPDF_result').html(text);
+function showResult(res, text) {
+ if (text == 'success') {
+ window.location = stripslashes(res.outputFileName);
+ else {
+ /* something went wrong */
+ $("#"+myId+"_result").html(text);
+ * Generates form elements as specified in the config controls object.
+ * @param {Object} json the config object in json
function buildForm(json) {
- /* first let's build some defaults then the stuff from config */
- /* this creates form elements from the json config */
var str = "";
for (var item in json.controls) {
var element = json.controls[item];
@@ -125,7 +143,7 @@
str += '<textarea id="'+element_id+'" name="'+element_id+'" size="'+element.size+'"></textarea><br>\n';
break;
case "select":
- str += '<select id="'+element_id+'" name="'+element_id+'" size="1" width="'+element.size+'">\n';
+ str += '<select id="'+element_id+'" name="'+element_id+'" size="1">\n';
for (var option_index in element.options) {
option = element.options[option_index];
str += '<option value="'+option.value+'">'+option.label+'</option>\n';
@@ -135,5 +153,9 @@
str += '</div>\n';
- $("#formsubmit").before(str);
+ if (str) $("#"+myId+"_formsubmit").before(str);
+function stripslashes( str ) {
+ return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
\ No newline at end of file
Added: branches/print_dev/http/print/printPDF_download.php
--- branches/print_dev/http/print/printPDF_download.php (rev 0)
+++ branches/print_dev/http/print/printPDF_download.php 2009-01-20 14:53:02 UTC (rev 3466)
@@ -0,0 +1,17 @@
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+if (isset($_REQUEST["f"]) && $_REQUEST["f"]!="" && file_exists(TMPDIR."/".$_REQUEST["f"])) {
+ $filename = TMPDIR."/".$_REQUEST["f"];
+ header('Content-Disposition: attachment; filename="'.basename($filename).'"');
+ ob_clean();
+ flush();
+ readfile($filename);
+ exit;
+else {
+ echo "not found";
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json 2009-01-20 12:16:44 UTC (rev 3465)
+++ branches/print_dev/http/print/testConfigTemplate.json 2009-01-20 14:53:02 UTC (rev 3466)
@@ -8,23 +8,25 @@
"id" : "title",
"label" : "Titel",
"type" : "text",
- "size" : 20
+ "size" : 20,
+ "pageElementsLink" : "title:value"
"id" : "dpi",
"label" : "DPI",
"type" : "select",
"size" : 20,
+ "pageElementsLink" : "map:res_dpi",
"options" : [
- "value" : "val1",
- "label" : "label1"
+ "value" : "56",
+ "label" : "niedrig (56)"
- "value" : "val2",
- "label" : "label2"
+ "value" : "72",
+ "label" : "normal (72)"
- "value" : "val3",
- "label" : "label3"
+ "value" : "144",
+ "label" : "hoch (dpi)"
@@ -32,7 +34,8 @@
"id" : "comment",
"label" : "Kommentar",
"type" : "textarea",
- "size" : 5
+ "size" : 5,
"pages" : [
Modified: branches/print_dev/http/print/testfactories.php
--- branches/print_dev/http/print/testfactories.php 2009-01-20 12:16:44 UTC (rev 3465)
+++ branches/print_dev/http/print/testfactories.php 2009-01-20 14:53:02 UTC (rev 3466)
@@ -7,6 +7,6 @@
$pdf->render();
$pdf->save();
-$pdf->returnPDF();
-//print $pdf->returnURL();
+print $pdf->returnAbsoluteUrl();
More information about the Mapbender_commits
