[Mapbender-commits] r3497 - in branches/print_dev/http/print: .
classes
svn_mapbender at osgeo.org
Wed Jan 28 11:23:40 EST 2009
Author: mschulz
Date: 2009-01-28 11:23:40 -0500 (Wed, 28 Jan 2009)
New Revision: 3497
branches/print_dev/http/print/classes/mbTemplatePdf.php
branches/print_dev/http/print/testConfigTemplate.json
Page elements now have an id and a type
Modified: branches/print_dev/http/print/classes/mbTemplatePdf.php
--- branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-26 22:09:00 UTC (rev 3496)
+++ branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-28 16:23:40 UTC (rev 3497)
@@ -37,7 +37,7 @@
$this->objPdf->useTemplate($tplidx);
foreach ($pageConf->elements as $pageElementId => $pageElementConf) {
- switch ($pageElementId) {
+ switch ($pageElementConf->type) {
case "map":
$err = new mbMapDecorator($this, $pageElementConf);
break;
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json 2009-01-26 22:09:00 UTC (rev 3496)
+++ branches/print_dev/http/print/testConfigTemplate.json 2009-01-28 16:23:40 UTC (rev 3497)
@@ -9,14 +9,14 @@
"label" : "Titel",
"type" : "text",
"size" : 20,
- "pageElementsLink" : "title:value"
+ "pageElementsLink" : "titel:value"
"id" : "dpi",
"label" : "DPI",
"type" : "select",
"size" : 20,
- "pageElementsLink" : "map:res_dpi",
+ "pageElementsLink" : "karte:res_dpi",
"options" : [
"value" : "56",
@@ -43,16 +43,16 @@
"tpl" : "mbtemplate1.pdf",
"useTplPage" : 1,
"elements" : {
- "map" : {
- "show" : true,
+ "karte" : {
+ "type" : "map",
"res_dpi" : 72,
"x_ul" : 10.1,
"y_ul" : 15.2,
"width" : 280,
"height" : 185
- "overview" : {
- "show" : true,
+ "minikarte" : {
+ "type" : "overview",
"res_dpi" : 72,
"x_ul" : 10.1,
"y_ul" : 15.2,
More information about the Mapbender_commits
