[Mapbender-commits] r3505 - branches/2.5/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 29 09:45:44 EST 2009
Author: christoph
Date: 2009-01-29 09:45:44 -0500 (Thu, 29 Jan 2009)
New Revision: 3505
   branches/2.5/http/javascripts/mod_legend.php
reverted to previous revision
Modified: branches/2.5/http/javascripts/mod_legend.php
--- branches/2.5/http/javascripts/mod_legend.php	2009-01-29 14:42:55 UTC (rev 3504)
+++ branches/2.5/http/javascripts/mod_legend.php	2009-01-29 14:45:44 UTC (rev 3505)
@@ -16,7 +16,7 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -45,7 +45,7 @@
 if($cnt > 1){
 	echo "alert('legend: ID not unique!');";
 $sql2 = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = $1";
 $v = array($gui_id);
 $t = array('s');
@@ -61,6 +61,7 @@
 <script type="text/javascript">
 mod_legend_offsetLeft = 25;
 mod_legend_offsetTop = -10;
@@ -115,13 +116,10 @@
 		var str = "";
 		var str_tmp = "";
 		for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
-   			var img_format = parent.mb_mapObj[ind].wms[i].gui_wms_mapformat;
-			if(parent.mb_mapObj[ind].wms[i].gui_wms_visible != 0){
-				var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
+			 	var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
 				for(var j=0; j<layerNames.length; j++){
 					var layerParent = parent.mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
 					var layerTitle = parent.mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
@@ -133,73 +131,39 @@
 					else{
 						legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
+					//console.log("layer_infos : %s",layerNames[j],"---",layerParent,"---",layerTitle,"---",layerStyle,"---",legendUrl);
-					var l = parent.mb_getchildsbyname(ind,i,layerNames[j]);
-					var tmp_name = "";
-					// handle grouped layers
-					if (l) {
-						for (var k=0; k<l["name"].length; k++){
-							if (l["legendurl"][k] != '' && l["legendurl"][k] != 0) {
-					 			if (tmp_name != l["title"][k]) {
-					 				if (showgroupedlayertitle == 'true'){
-				  						str_tmp += "<div><span class='titles'>" + l["title"][k] + "</span></div>";
-				 	  				str_tmp += "<div>";
-									if(legendlink == 'true'){
-										str_tmp += "<a href='../php/result.php?lingo=deutsch&layer=" +
-											layerNames[j] + l["name"][k] + "' class='legendlink' title='Zeigt Liste zum Thema: " +
-											titles[j]+"' target='result'>";
-                                	str_tmp += "<img border=0 src = '";
-					  				str_tmp += l["legendurl"][k];
-					  				str_tmp += "'></img>";
-					  				if (legendlink == 'true'){
-                                		str_tmp += "</a>";
-                                	str_tmp += "</div>";
-									tmp_name = l["title"][k];
-         			else {
-						if (legendUrl) {
-							if(layerParent == 0){
-								if(showlayertitle == 'true'){
-									str_tmp += "<div><span class='titles'>" + layerTitle + "</span></div>";
-									str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+
-										"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+
-										"' target='result'>";
-								str_tmp += legendUrl;
+					if (legendUrl !== false){
+//						console.log("legendUrl: %s, typeof(legendUrl): %s", legendUrl, typeof(legendUrl));
+//	 					if(layerParent == 0){
+		 					if(showlayertitle == 'true'){
+								str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
+							str_tmp += "<div>";
+		                    if(legendlink == 'true'){
+		                    	str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
+		                    str_tmp += "<img border=0 src = '";
+							str_tmp += legendUrl;
+							str_tmp += "'></img>";
+							if (legendlink == 'true'){
+		                    	str_tmp += "</a>";
+		                    str_tmp += "</div>";
 			if(str_tmp !=''){
 				if (showwmstitle == 'true'){
 					str += "<div><span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
 				str += str_tmp;
 				str_tmp ='';
-		if(str != ""){
+		//console.log("ind =%s",ind,"str =",str);
+	    if(str != ""){
 			parent.writeTag("legend", "leg", str);
 		else{
More information about the Mapbender_commits mailing list
