[Mapbender-commits] r4269 - in trunk/mapbender: core
http/javascripts
svn_mapbender at osgeo.org
Wed Jul 1 10:29:37 EDT 2009
Author: christoph
Date: 2009-07-01 10:29:37 -0400 (Wed, 01 Jul 2009)
New Revision: 4269
Added:
trunk/mapbender/http/javascripts/mod_doubleclickZoom.js
trunk/mapbender/http/javascripts/mod_mousewheelZoom.js
trunk/mapbender/core/system.php
trunk/mapbender/http/javascripts/map.php
trunk/mapbender/http/javascripts/mapnf.php
http://trac.osgeo.org/mapbender/ticket/489
Modified: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php 2009-07-01 14:28:22 UTC (rev 4268)
+++ trunk/mapbender/core/system.php 2009-07-01 14:29:37 UTC (rev 4269)
@@ -34,12 +34,10 @@
define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
-define("ZOOM_MOUSEWHEEL", "1.1");
define("MODULES_NOT_RELYING_ON_GLOBALS",
"mapframe1,featureInfo1,gazetteerWFS,back,forward,zoomCoords,zoomFull,zoomIn1," .
"zoomOut1,selArea1,pan1,copyright,dependentDiv,dragMapSize," .
"dynamicOverview,FeatureInfoRedirect,highlightPOI,navFrame,sandclock," .
"scaleBar,scaleSelect,setBBOX,setPOI2Scale,reload,overview,addWMS," .
- "repaint,changeEPSG"
+ "repaint,changeEPSG,mousewheelZoom,doubleclickZoom"
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2009-07-01 14:28:22 UTC (rev 4268)
+++ trunk/mapbender/http/javascripts/map.php 2009-07-01 14:29:37 UTC (rev 4269)
@@ -63,7 +63,6 @@
echo "Mapbender.versionNumber = '" . MB_VERSION_NUMBER . "';";
echo "Mapbender.versionAppendix = '" . MB_VERSION_APPENDIX . "';";
echo "Mapbender.releaseDate = new Date(".date("Y",MB_RELEASE_DATE).",".date("n",MB_RELEASE_DATE).",".date("j",MB_RELEASE_DATE).");";
-echo "Mapbender.zoomMousewheel = " . ZOOM_MOUSEWHEEL . ";";
echo "var owsproxy = '".OWSPROXY."';";
echo "var global_mb_log_js = '".LOG_JS."';";
echo "var global_mb_log_level = '".LOG_LEVEL."';";
@@ -202,7 +201,7 @@
if (!file_exists($currentFile)) {
$e = new mb_exception("Javascript not found: " . $currentFile);
echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
- die;
+ continue;
if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
ob_start();
@@ -246,6 +245,7 @@
echo "};\n";
require($currentFile);
+ $e = new mb_notice("LOADING JS : " . $currentFile);
Modified: trunk/mapbender/http/javascripts/mapnf.php
--- trunk/mapbender/http/javascripts/mapnf.php 2009-07-01 14:28:22 UTC (rev 4268)
+++ trunk/mapbender/http/javascripts/mapnf.php 2009-07-01 14:29:37 UTC (rev 4269)
@@ -17,78 +17,34 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- var mapTimeout;
- var sum_delta = 0;
- var lastTimestamp;
- var lastScrollPosition;
- eventInitMap.register(function () {
- Mapbender.modules[options.id] = new Mapbender.Map (
- options.id,
- options.width,
- options.height,
- null
- mb_mapObj.push(Mapbender.modules[options.id]);
- var mapObject = Mapbender.modules[options.id];
- try {
- if (restrictedExtent !== '') {
- mapObject.setRestrictedExtent(restrictedExtent);
- catch (e) {
- new Mb_notice("Restricted extent not set via element variable.");
- $(document).mousewheel(function (e, delta) {
- if (sum_delta == 0) {
- mapTimeout = setTimeout(function () {
- lastScrollPosition = mapObject.getMousePosition(e);
- mousewheelZoom();
- 100);
- sum_delta = sum_delta + (delta);
- var currentTime = new Date();
- lastTimestamp = currentTime.getTime();
- return false;
+var $this = $(this);
+eventInitMap.register(function () {
- function mousewheelZoom () {
+ $this.html('<div id="'+options.id+'_maps" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;"></div>');
+ Mapbender.modules[options.id] = new Mapbender.Map (
+ options.id,
+ options.width,
+ options.height,
+ null
- if (currentTime.getTime() - lastTimestamp > 200) {
- if (lastScrollPosition !== null) {
- var pos = mapObject.convertPixelToReal(lastScrollPosition);
+ mb_mapObj.push(Mapbender.modules[options.id]);
+ var mapObject = Mapbender.modules[options.id];
- if (sum_delta > 0) {
- mapObject.zoom(true, Math.pow(Mapbender.zoomMousewheel, sum_delta), pos.x, pos.y);
- else {
- mapObject.zoom(false, Math.pow(Mapbender.zoomMousewheel, -sum_delta), pos.x, pos.y);
- var newPos = new Point();
- newPos.x = mapObject.width - lastScrollPosition.x;
- newPos.y = mapObject.height - lastScrollPosition.y;
- var posAfterZoom = mapObject.convertPixelToReal(newPos);
- mapObject.zoom(false, 1.0, posAfterZoom.x, posAfterZoom.y);
- sum_delta = 0;
- clearTimeout(mapTimeout);
+ // set restricted extent
+ try {
+ if (restrictedExtent !== '') {
+ mapObject.setRestrictedExtent(restrictedExtent);
- else {
- mousewheelZoom(sum_delta);
- 100
+ catch (e) {
+ new Mb_notice("Restricted extent not set via element variable.");
Added: trunk/mapbender/http/javascripts/mod_doubleclickZoom.js
--- trunk/mapbender/http/javascripts/mod_doubleclickZoom.js (rev 0)
+++ trunk/mapbender/http/javascripts/mod_doubleclickZoom.js 2009-07-01 14:29:37 UTC (rev 4269)
@@ -0,0 +1,102 @@
+ * Package: <Application element name>
+ * Description:
+ * Adds behaviour to maps specified in the target field.
+ * Zoom in on left double click, zoom out on right double click.
+ * Deactivates the browser contextmenu!
+ * Files:
+ * - http/javascripts/mod_doubleclickZoom.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>',
+ * > 'doubleclickZoom',2,1,'adds doubleclick zoom to map module (target).
+ * > Deactivates the browser contextmenu!!!','Doubleclick zoom','div',
+ * > '','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div',
+ * > 'mod_doubleclickZoom.js','','mapframe1','','');
+ * Help:
+ * http://www.mapbender.org/DoubleclickZoom
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+eventInit.register(function () {
+ for (var i in options.target) {
+ (function () {
+ var currentTarget = options.target[i];
+ var mapObject = Mapbender.modules[currentTarget];
+ // Zoom out on right double click
+ mapObject.doubleClickZoomOut = function (lastScrollPosition) {
+ var pos = mapObject.convertPixelToReal(lastScrollPosition);
+ this.zoom(false, 2.0, pos.x, pos.y);
+ var newPos = new Point();
+ newPos.x = this.width - lastScrollPosition.x;
+ newPos.y = this.height - lastScrollPosition.y;
+ var posAfterZoom = this.convertPixelToReal(newPos);
+ this.zoom(false, 1.0, posAfterZoom.x, posAfterZoom.y);
+ // Zoom in on left double click
+ mapObject.doubleClickZoomIn = function (lastScrollPosition) {
+ this.zoom(true, 2.0, pos.x, pos.y);
+ // add doubleclick behaviour
+ $("#" + currentTarget).dblclick(function (e) {
+ mapObject.doubleClickZoomIn(mapObject.getMousePosition(e));
+ }).bind('contextmenu',function(){
+ return false
+ }).mouseup(function(e){
+ var rightclick = (e.which) ? (e.which == 3) : (e.button == 2);
+ var t = $(this);
+ if (rightclick) {
+ if (t.data('rightclicked')) {
+ mapObject.doubleClickZoomOut(mapObject.getMousePosition(e));
+ t.data('rightclicked',false);
+ clearTimeout(t.data('rcTimer'));
+ } else {
+ t.data('rightclicked',true);
+ t.data('rcTimer',setTimeout((function(t){
+ return function(){
+ t.data('rightclicked', false);
+ })(t), 800));
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/mod_mousewheelZoom.js
--- trunk/mapbender/http/javascripts/mod_mousewheelZoom.js (rev 0)
+++ trunk/mapbender/http/javascripts/mod_mousewheelZoom.js 2009-07-01 14:29:37 UTC (rev 4269)
@@ -0,0 +1,112 @@
+ * Package: mousewheelZoom
+ * Description:
+ * Zoom in/out with the mousewheel. Specify maps in target field.
+ * Files:
+ * - http/javascripts/mod_mousewheelZoom.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('<gui_id>','mousewheelZoom',
+ * > 2,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom',
+ * > 'div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div',
+ * > 'mod_mousewheelZoom.js','','mapframe1','','');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('<gui_id>', 'mousewheelZoom', 'factor', '2',
+ * > 'The factor by which the map is zoomed on each mousewheel unit' ,'var');
+ * Help:
+ * http://www.mapbender.org/MousewheelZoom
+ * Maintainer:
+ * Parameters:
+ * factor - *[optional]* {Float} The factor by which the map is zoomed on
+ * each mousewheel unit. Default is 2.
+ * License:
+if (options.factor === undefined) {
+ options.factor = 2;
+ (function () {
+ var mapTimeout;
+ var sum_delta = 0;
+ var lastTimestamp;
+ var lastScrollPosition;
+ var zoomMousewheel = options.factor;
+ mapObject.mousewheelZoom = function () {
+ var currentTime = new Date();
+ if (currentTime.getTime() - lastTimestamp > 200) {
+ if (lastScrollPosition !== null) {
+ if (sum_delta > 0) {
+ this.zoom(true, Math.pow(zoomMousewheel, sum_delta), pos.x, pos.y);
+ else {
+ this.zoom(false, Math.pow(zoomMousewheel, -sum_delta), pos.x, pos.y);
+ sum_delta = 0;
+ clearTimeout(mapTimeout);
+ else {
+ var that = this;
+ mapTimeout = setTimeout(function () {
+ that.mousewheelZoom();
+ 100
+ // add mousewheel behaviour
+ $("#" + currentTarget).mousewheel(function (e, delta) {
+ if (sum_delta == 0) {
+ lastScrollPosition = mapObject.getMousePosition(e);
+ mapObject.mousewheelZoom();
+ 100);
+ sum_delta = sum_delta + (delta);
+ lastTimestamp = currentTime.getTime();
+ return false;
More information about the Mapbender_commits
