[Mapbender-commits] r4271 - in branches/kmq_dev: . conf core documents documents/api_js documents/api_js/Data documents/api_js/files documents/api_js/files/docs documents/api_js/files/docs/javascript documents/api_js/files/http documents/api_js/files/http/javascripts documents/api_js/files/lib documents/api_js/index documents/api_js/javascript documents/api_js/search documents/api_js/styles http/classes http/extensions http/frames http/html http/img http/include http/javascripts http/php http/print http/sld lib license resources/db resources/db/update sql
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 1 10:40:20 EDT 2009
Author: kmq
Date: 2009-07-01 10:40:19 -0400 (Wed, 01 Jul 2009)
New Revision: 4271
Added:
   branches/kmq_dev/documents/api_js/
   branches/kmq_dev/documents/api_js/Data/
   branches/kmq_dev/documents/api_js/Data/ClassHierarchy.nd
   branches/kmq_dev/documents/api_js/Data/ConfigFileInfo.nd
   branches/kmq_dev/documents/api_js/Data/FileInfo.nd
   branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd
   branches/kmq_dev/documents/api_js/Data/ImageReferenceTable.nd
   branches/kmq_dev/documents/api_js/Data/IndexInfo.nd
   branches/kmq_dev/documents/api_js/Data/PreviousMenuState.nd
   branches/kmq_dev/documents/api_js/Data/PreviousSettings.nd
   branches/kmq_dev/documents/api_js/Data/SymbolTable.nd
   branches/kmq_dev/documents/api_js/Languages.txt
   branches/kmq_dev/documents/api_js/Menu.txt
   branches/kmq_dev/documents/api_js/Topics.txt
   branches/kmq_dev/documents/api_js/files/
   branches/kmq_dev/documents/api_js/files/docs/
   branches/kmq_dev/documents/api_js/files/docs/javascript/
   branches/kmq_dev/documents/api_js/files/docs/javascript/main-js.html
   branches/kmq_dev/documents/api_js/files/http/
   branches/kmq_dev/documents/api_js/files/http/javascripts/
   branches/kmq_dev/documents/api_js/files/http/javascripts/core-php.html
   branches/kmq_dev/documents/api_js/files/http/javascripts/map_obj-js.html
   branches/kmq_dev/documents/api_js/files/http/javascripts/mod_reload-php.html
   branches/kmq_dev/documents/api_js/files/http/javascripts/mod_sandclock-php.html
   branches/kmq_dev/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html
   branches/kmq_dev/documents/api_js/files/lib/
   branches/kmq_dev/documents/api_js/files/lib/event-js.html
   branches/kmq_dev/documents/api_js/index.html
   branches/kmq_dev/documents/api_js/index/
   branches/kmq_dev/documents/api_js/index/Classes.html
   branches/kmq_dev/documents/api_js/index/Files.html
   branches/kmq_dev/documents/api_js/index/Functions.html
   branches/kmq_dev/documents/api_js/index/General.html
   branches/kmq_dev/documents/api_js/index/Variables.html
   branches/kmq_dev/documents/api_js/javascript/
   branches/kmq_dev/documents/api_js/javascript/main.js
   branches/kmq_dev/documents/api_js/javascript/searchdata.js
   branches/kmq_dev/documents/api_js/search/
   branches/kmq_dev/documents/api_js/search/ClassesE.html
   branches/kmq_dev/documents/api_js/search/ClassesM.html
   branches/kmq_dev/documents/api_js/search/ClassesR.html
   branches/kmq_dev/documents/api_js/search/ClassesS.html
   branches/kmq_dev/documents/api_js/search/ClassesZ.html
   branches/kmq_dev/documents/api_js/search/FilesM.html
   branches/kmq_dev/documents/api_js/search/FunctionsA.html
   branches/kmq_dev/documents/api_js/search/FunctionsC.html
   branches/kmq_dev/documents/api_js/search/FunctionsD.html
   branches/kmq_dev/documents/api_js/search/FunctionsH.html
   branches/kmq_dev/documents/api_js/search/FunctionsI.html
   branches/kmq_dev/documents/api_js/search/FunctionsM.html
   branches/kmq_dev/documents/api_js/search/FunctionsO.html
   branches/kmq_dev/documents/api_js/search/FunctionsR.html
   branches/kmq_dev/documents/api_js/search/FunctionsS.html
   branches/kmq_dev/documents/api_js/search/FunctionsT.html
   branches/kmq_dev/documents/api_js/search/GeneralA.html
   branches/kmq_dev/documents/api_js/search/GeneralC.html
   branches/kmq_dev/documents/api_js/search/GeneralD.html
   branches/kmq_dev/documents/api_js/search/GeneralE.html
   branches/kmq_dev/documents/api_js/search/GeneralF.html
   branches/kmq_dev/documents/api_js/search/GeneralH.html
   branches/kmq_dev/documents/api_js/search/GeneralI.html
   branches/kmq_dev/documents/api_js/search/GeneralK.html
   branches/kmq_dev/documents/api_js/search/GeneralL.html
   branches/kmq_dev/documents/api_js/search/GeneralM.html
   branches/kmq_dev/documents/api_js/search/GeneralN.html
   branches/kmq_dev/documents/api_js/search/GeneralO.html
   branches/kmq_dev/documents/api_js/search/GeneralR.html
   branches/kmq_dev/documents/api_js/search/GeneralS.html
   branches/kmq_dev/documents/api_js/search/GeneralT.html
   branches/kmq_dev/documents/api_js/search/GeneralV.html
   branches/kmq_dev/documents/api_js/search/GeneralZ.html
   branches/kmq_dev/documents/api_js/search/NoResults.html
   branches/kmq_dev/documents/api_js/search/VariablesD.html
   branches/kmq_dev/documents/api_js/search/VariablesK.html
   branches/kmq_dev/documents/api_js/search/VariablesL.html
   branches/kmq_dev/documents/api_js/search/VariablesM.html
   branches/kmq_dev/documents/api_js/search/VariablesN.html
   branches/kmq_dev/documents/api_js/search/VariablesR.html
   branches/kmq_dev/documents/api_js/styles/
   branches/kmq_dev/documents/api_js/styles/main.css
   branches/kmq_dev/http/img/help.png
   branches/kmq_dev/http/include/dyn_js_object.php
   branches/kmq_dev/lib/backwards_compatibility_to_2.6.js
   branches/kmq_dev/lib/class_Mapbender.php
   branches/kmq_dev/lib/class_Mapbender_session.php
   branches/kmq_dev/lib/class_Singleton.php
   branches/kmq_dev/license/license.txt
   branches/kmq_dev/license/simplified_bsd.txt
   branches/kmq_dev/resources/db/install_2.6.sh
Removed:
   branches/kmq_dev/.project
   branches/kmq_dev/http/javascripts/mod_digitize_tab_category.php
   branches/kmq_dev/index.php
   branches/kmq_dev/
   branches/kmq_dev/conf/session.conf
   branches/kmq_dev/core/globalSettings.php
   branches/kmq_dev/core/i18n.php
   branches/kmq_dev/core/system.php
   branches/kmq_dev/http/classes/class_element.php
   branches/kmq_dev/http/classes/class_gui.php
   branches/kmq_dev/http/classes/class_kml_ows.php
   branches/kmq_dev/http/classes/class_locale.php
   branches/kmq_dev/http/classes/class_log.php
   branches/kmq_dev/http/classes/class_wfsToDb.php
   branches/kmq_dev/http/classes/class_wfs_conf.php
   branches/kmq_dev/http/classes/class_wfs_configuration.php
   branches/kmq_dev/http/classes/class_wfs_deprecated.php
   branches/kmq_dev/http/classes/class_wmc.php
   branches/kmq_dev/http/classes/class_wms.php
   branches/kmq_dev/http/extensions/ext_weldMaps.php
   branches/kmq_dev/http/frames/index.php
   branches/kmq_dev/http/frames/login.php
   branches/kmq_dev/http/html/mod_treefolder2.php
   branches/kmq_dev/http/html/mod_treefolder2_multiple.php
   branches/kmq_dev/http/html/mod_treefolderPlain.php
   branches/kmq_dev/http/javascripts/core.php
   branches/kmq_dev/http/javascripts/geometry.js
   branches/kmq_dev/http/javascripts/initOpenLayersWms.php
   branches/kmq_dev/http/javascripts/map.js
   branches/kmq_dev/http/javascripts/map.php
   branches/kmq_dev/http/javascripts/map_obj.js
   branches/kmq_dev/http/javascripts/mapnf.php
   branches/kmq_dev/http/javascripts/mod_addWMS.php
   branches/kmq_dev/http/javascripts/mod_addWMSfromList.php
   branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredList.php
   branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredListDB.php
   branches/kmq_dev/http/javascripts/mod_add_vendorspecific.php
   branches/kmq_dev/http/javascripts/mod_box1.js
   branches/kmq_dev/http/javascripts/mod_changeEPSG.php
   branches/kmq_dev/http/javascripts/mod_copyright.php
   branches/kmq_dev/http/javascripts/mod_digitize_tab.php
   branches/kmq_dev/http/javascripts/mod_dragMapSize.php
   branches/kmq_dev/http/javascripts/mod_dynamicOverview.php
   branches/kmq_dev/http/javascripts/mod_export_image.php
   branches/kmq_dev/http/javascripts/mod_help.php
   branches/kmq_dev/http/javascripts/mod_highlightPOI.php
   branches/kmq_dev/http/javascripts/mod_home.php
   branches/kmq_dev/http/javascripts/mod_horizTab.php
   branches/kmq_dev/http/javascripts/mod_initWmc.php
   branches/kmq_dev/http/javascripts/mod_insertKmlIntoDb.php
   branches/kmq_dev/http/javascripts/mod_insertLayerPreviewIntoDb.php
   branches/kmq_dev/http/javascripts/mod_legend.php
   branches/kmq_dev/http/javascripts/mod_loadwmc.php
   branches/kmq_dev/http/javascripts/mod_log.php
   branches/kmq_dev/http/javascripts/mod_owsproxy.php
   branches/kmq_dev/http/javascripts/mod_print1.php
   branches/kmq_dev/http/javascripts/mod_reload.php
   branches/kmq_dev/http/javascripts/mod_renderGML.php
   branches/kmq_dev/http/javascripts/mod_repaint.php
   branches/kmq_dev/http/javascripts/mod_resize_mapsize.php
   branches/kmq_dev/http/javascripts/mod_sandclock.php
   branches/kmq_dev/http/javascripts/mod_saveWmcKml.php
   branches/kmq_dev/http/javascripts/mod_savewmc.php
   branches/kmq_dev/http/javascripts/mod_scaleHint.php
   branches/kmq_dev/http/javascripts/mod_scaleSel.php
   branches/kmq_dev/http/javascripts/mod_scaleText.php
   branches/kmq_dev/http/javascripts/mod_selectMapsize.php
   branches/kmq_dev/http/javascripts/mod_setBBOX1.php
   branches/kmq_dev/http/javascripts/mod_setPOI2Scale.php
   branches/kmq_dev/http/javascripts/mod_switchLocale_noreload.php
   branches/kmq_dev/http/javascripts/mod_tab.php
   branches/kmq_dev/http/javascripts/mod_usemap.php
   branches/kmq_dev/http/javascripts/mod_wfs_gazetteer_client.php
   branches/kmq_dev/http/javascripts/mod_zoomCoords.php
   branches/kmq_dev/http/javascripts/mod_zoomFull.php
   branches/kmq_dev/http/javascripts/mod_zoomIn1.php
   branches/kmq_dev/http/javascripts/mod_zoomOut1.php
   branches/kmq_dev/http/javascripts/ovnf.php
   branches/kmq_dev/http/javascripts/user.php
   branches/kmq_dev/http/javascripts/wms.js
   branches/kmq_dev/http/php/mb_listKMLs.php
   branches/kmq_dev/http/php/mb_validatePermission.php
   branches/kmq_dev/http/php/mb_validateSession.php
   branches/kmq_dev/http/php/mod_WMSpreferences.php
   branches/kmq_dev/http/php/mod_addWMSfromfilteredList_server.php
   branches/kmq_dev/http/php/mod_button_tooltips.php
   branches/kmq_dev/http/php/mod_category_filteredGUI.php
   branches/kmq_dev/http/php/mod_changeEPSG_dynamic.php
   branches/kmq_dev/http/php/mod_changePassword.php
   branches/kmq_dev/http/php/mod_createJSObjFromDBByWMS.php
   branches/kmq_dev/http/php/mod_customTree_server.php
   branches/kmq_dev/http/php/mod_deleteFilteredGUI.php
   branches/kmq_dev/http/php/mod_deleteGUI.php
   branches/kmq_dev/http/php/mod_deleteWFS.php
   branches/kmq_dev/http/php/mod_deleteWMS.php
   branches/kmq_dev/http/php/mod_digitize_messages.php
   branches/kmq_dev/http/php/mod_editApplication.php
   branches/kmq_dev/http/php/mod_editApplication_server.php
   branches/kmq_dev/http/php/mod_editElements.php
   branches/kmq_dev/http/php/mod_editFilteredGroup.php
   branches/kmq_dev/http/php/mod_editFilteredUser.php
   branches/kmq_dev/http/php/mod_editGroup.php
   branches/kmq_dev/http/php/mod_editGuiWms.php
   branches/kmq_dev/http/php/mod_editSelf.php
   branches/kmq_dev/http/php/mod_editUser.php
   branches/kmq_dev/http/php/mod_editWMS_Metadata.php
   branches/kmq_dev/http/php/mod_edit_element_vars.php
   branches/kmq_dev/http/php/mod_edit_metadata.php
   branches/kmq_dev/http/php/mod_exportGUI.php
   branches/kmq_dev/http/php/mod_export_image.php
   branches/kmq_dev/http/php/mod_filteredGroup_Gui.php
   branches/kmq_dev/http/php/mod_filteredGroup_User.php
   branches/kmq_dev/http/php/mod_filteredGroup_filteredGui.php
   branches/kmq_dev/http/php/mod_filteredGroup_filteredUser.php
   branches/kmq_dev/http/php/mod_filteredGui_User.php
   branches/kmq_dev/http/php/mod_filteredGui_filteredGroup.php
   branches/kmq_dev/http/php/mod_filteredGui_filteredUser.php
   branches/kmq_dev/http/php/mod_filteredGui_group.php
   branches/kmq_dev/http/php/mod_filteredUser_Group.php
   branches/kmq_dev/http/php/mod_filteredUser_Gui.php
   branches/kmq_dev/http/php/mod_filteredUser_filteredGroup.php
   branches/kmq_dev/http/php/mod_filteredUser_filteredGui.php
   branches/kmq_dev/http/php/mod_filteredWms_layer_topic.php
   branches/kmq_dev/http/php/mod_filteredWms_topic.php
   branches/kmq_dev/http/php/mod_forgottenPassword.php
   branches/kmq_dev/http/php/mod_gazetteerMetadata.php
   branches/kmq_dev/http/php/mod_gazetteerMetadata_search.php
   branches/kmq_dev/http/php/mod_group_filteredGui.php
   branches/kmq_dev/http/php/mod_group_filteredUser.php
   branches/kmq_dev/http/php/mod_gui_filteredGroup.php
   branches/kmq_dev/http/php/mod_gui_filteredUser.php
   branches/kmq_dev/http/php/mod_gui_owner.php
   branches/kmq_dev/http/php/mod_loadCapabilities.php
   branches/kmq_dev/http/php/mod_loadCapabilitiesList.php
   branches/kmq_dev/http/php/mod_loadWFSCapabilities.php
   branches/kmq_dev/http/php/mod_loadwmc_server.php
   branches/kmq_dev/http/php/mod_log.php
   branches/kmq_dev/http/php/mod_map1.php
   branches/kmq_dev/http/php/mod_mapOV.php
   branches/kmq_dev/http/php/mod_meetingPoint.php
   branches/kmq_dev/http/php/mod_newGui.php
   branches/kmq_dev/http/php/mod_owsproxy_conf.php
   branches/kmq_dev/http/php/mod_printView1.php
   branches/kmq_dev/http/php/mod_renameGUI.php
   branches/kmq_dev/http/php/mod_savewmc_server.php
   branches/kmq_dev/http/php/mod_setLocale.php
   branches/kmq_dev/http/php/mod_showLoggedUser.php
   branches/kmq_dev/http/php/mod_tab_messages.php
   branches/kmq_dev/http/php/mod_updateWMS.php
   branches/kmq_dev/http/php/mod_usemap.php
   branches/kmq_dev/http/php/mod_user_filteredGroup.php
   branches/kmq_dev/http/php/mod_user_filteredGui.php
   branches/kmq_dev/http/php/mod_wfs.php
   branches/kmq_dev/http/php/mod_wfsSpatialRequest_messages.php
   branches/kmq_dev/http/php/mod_wfs_conf.php
   branches/kmq_dev/http/php/mod_wfs_conf_featuretype_elements.html
   branches/kmq_dev/http/php/mod_wfs_conf_interface.js
   branches/kmq_dev/http/php/mod_wfs_conf_server.php
   branches/kmq_dev/http/php/mod_wfs_gazetteer_server.php
   branches/kmq_dev/http/php/mod_wfs_result.php
   branches/kmq_dev/http/php/mod_wfs_server.php
   branches/kmq_dev/http/php/nestedSets.php
   branches/kmq_dev/http/print/mod_printPDF.php
   branches/kmq_dev/http/sld/sld_pick_color.php
   branches/kmq_dev/lib/ajax.js
   branches/kmq_dev/lib/ajax.php
   branches/kmq_dev/lib/basic.js
   branches/kmq_dev/lib/button.js
   branches/kmq_dev/lib/core.js
   branches/kmq_dev/lib/event.js
   branches/kmq_dev/lib/exception.js
   branches/kmq_dev/lib/point.js
   branches/kmq_dev/license/gpl.txt
   branches/kmq_dev/license/gpl_short.txt
   branches/kmq_dev/license/licence_reference.txt
   branches/kmq_dev/license/license_js.txt
   branches/kmq_dev/resources/db/install_2.6rc1.sh
   branches/kmq_dev/resources/db/update/update_2.7.sql
   branches/kmq_dev/sql/insert_wfs_conf_element.sql
   branches/kmq_dev/sql/update_wfs_conf_element.sql
merging in trunk
Property changes on: branches/kmq_dev
___________________________________________________________________
Added: svn:ignore
   + .project
Added: svn:mergeinfo
   + /trunk/mapbender:4021-4267
Deleted: branches/kmq_dev/.project
--- branches/kmq_dev/.project	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/.project	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,12 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<projectDescription>
-	<name>mapbender_trunk</name>
-	<comment></comment>
-	<projects>
-	</projects>
-	<buildSpec>
-	</buildSpec>
-	<natures>
-		<nature>com.aptana.ide.editor.php.phpnature</nature>
-	</natures>
-</projectDescription>
Modified: branches/kmq_dev/conf/session.conf
--- branches/kmq_dev/conf/session.conf	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/conf/session.conf	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,37 +1,41 @@
 <?php
-$_SESSION["mb_user_password"] = $password;
-$_SESSION["mb_user_id"] = $row["mb_user_id"];
-$_SESSION["mb_user_name"] = $name;
-$_SESSION["mb_user_ip"] =  $_SERVER['REMOTE_ADDR'];
-$_SESSION["mb_myBBOX"] = $_REQUEST["mb_myBBOX"];
-$_SESSION["mb_myKml"] = $_REQUEST["kml_id"];
-$_SESSION["mb_myPOI"] = $_REQUEST["mb_myPOI"];
-$_SESSION["mb_myPOI2SCALE"] = $_REQUEST["mb_myPOI2SCALE"];
-$_SESSION["mb_lang"] = $_REQUEST["lang"];
+require_once(dirname(__FILE__)."/../lib/class_Mapbender_session.php");
+new mb_notice("sessionConf.class.loading...");
-$_SESSION["command"] = strtoupper($_REQUEST["COMMAND"]);
+Mapbender::session()->set("mb_user_password",$password);
+Mapbender::session()->set("mb_user_id",$row["mb_user_id"]);
+Mapbender::session()->set("mb_user_name",$name);
+Mapbender::session()->set("mb_user_ip",$_SERVER['REMOTE_ADDR']);
+Mapbender::session()->set("mb_myBBOX",$_REQUEST["mb_myBBOX"]);
+Mapbender::session()->set("mb_myKml",$_REQUEST["kml_id"]);
+Mapbender::session()->set("mb_myPOI",$_REQUEST["mb_myPOI"]);
+Mapbender::session()->set("mb_myPOI2SCALE",$_REQUEST["mb_myPOI2SCALE"]);
+Mapbender::session()->set("mb_lang",$_REQUEST["lang"]);
+Mapbender::session()->set("command",strtoupper($_REQUEST["COMMAND"]));
 $i = 1;
-$_SESSION["wms"] = array();
+$arr_wms = array();
 while ($_REQUEST["wms".$i]) {
-	array_push($_SESSION["wms"], urldecode($_REQUEST["wms".$i]));
+	array_push($arr_wms, urldecode($_REQUEST["wms".$i]));
 	$i++;
+Mapbender::session()->set("wms",$arr_wms);
 unset($i);
-$_SESSION["mb_myWmc"] = "";
-$_SESSION["mb_myWmc_action"] = "";
+Mapbender::session()->set("mb_myWmc","");
+Mapbender::session()->set("mb_myWmc_action","");
 if ($_REQUEST["wmc_id"]) {
-	$_SESSION["mb_myWmc"] = $_REQUEST["wmc_id"];
-	$_SESSION["mb_myWmc_action"] = "load";
+	Mapbender::session()->set("mb_myWmc",$_REQUEST["wmc_id"]);
+	Mapbender::session()->set("mb_myWmc_action","load");
 else if ($_REQUEST["merge_wmc_id"]) {
-	$_SESSION["mb_myWmc"] = $_REQUEST["merge_wmc_id"];
-	$_SESSION["mb_myWmc_action"] = "merge";
+	Mapbender::session()->set("mb_myWmc",$_REQUEST["merge_wmc_id"]);
+	Mapbender::session()->set("mb_myWmc_action","merge");
 else if ($_REQUEST["append_wmc_id"]) {
-	$_SESSION["mb_myWmc"] = $_REQUEST["append_wmc_id"];
-	$_SESSION["mb_myWmc_action"] = "append";
+	Mapbender::session()->set("mb_myWmc",$_REQUEST["append_wmc_id"]);
+	Mapbender::session()->set("mb_myWmc_action","append");
Modified: branches/kmq_dev/core/globalSettings.php
--- branches/kmq_dev/core/globalSettings.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/core/globalSettings.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -17,9 +17,10 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-// start the session
+// initiates the session-handling
 session_start();
+require_once(dirname(__FILE__)."/../lib/class_Mapbender.php");
 // define LC_MESSAGES if unknown
@@ -61,7 +62,7 @@
 require_once(dirname(__FILE__) . "/../core/i18n.php");
 require_once(dirname(__FILE__) . "/../http/classes/class_locale.php");
-$localeObj = new Mb_locale($_SESSION["mb_lang"]);
+$localeObj = new Mb_locale(Mapbender::session()->get("mb_lang"));
 // establish database connection
@@ -72,11 +73,13 @@
 // Do not display PHP errors
-ini_set("display_errors", "0");
+ini_set("display_errors", "on");
 // AJAX wrapper
 require_once(dirname(__FILE__)."/../lib/ajax.php");
Modified: branches/kmq_dev/core/i18n.php
--- branches/kmq_dev/core/i18n.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/core/i18n.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -18,7 +18,7 @@
 	function _mb ($someString) {
 		if (USE_I18N) {
-//			$e = new mb_notice("Translating '" . $someString . "' to language " . $_SESSION["mb_locale"] . ": '" . _($someString) . "'");
+//			$e = new mb_notice("Translating '" . $someString . "' to language " . Mapbender::session()->get("mb_locale") . ": '" . _($someString) . "'");
 			return _($someString);
 		return $someString;
Modified: branches/kmq_dev/core/system.php
--- branches/kmq_dev/core/system.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/core/system.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,6 +1,6 @@
 <?php
 # $Id$
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
@@ -30,10 +30,16 @@
 define("MB_FEATURE_COUNT", "100");
 define("MB_SECURITY_PROXY", "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=");
-# available log levels
+# available log levels
 define("LOG_LEVEL_LIST", "off,error,warning,notice,all");
 define("ZOOM_MOUSEWHEEL", "1.1");
-define("MODULES_NOT_RELYING_ON_GLOBALS", "featureInfo1,gazetteerWFS,back,forward,zoomIn1,zoomOut1,selArea1,pan1,copyright,dependentDiv,dragMapSize,dynamicOverview,FeatureInfoRedirect,highlightPOI,navFrame,sandclock,scaleBar,scaleSel,setBBOX,setPOI2Scale");
+define("MODULES_NOT_RELYING_ON_GLOBALS",
+	"mapframe1,featureInfo1,gazetteerWFS,back,forward,zoomCoords,zoomFull,zoomIn1," .
+	"zoomOut1,selArea1,pan1,copyright,dependentDiv,dragMapSize," .
+	"dynamicOverview,FeatureInfoRedirect,highlightPOI,navFrame,sandclock," .
+	"scaleBar,scaleSelect,setBBOX,setPOI2Scale,reload,overview,addWMS," .
+	"repaint,changeEPSG"
Deleted: branches/kmq_dev/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/ClassHierarchy.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,2 +0,0 @@
-(    Event    */home/install/workspace/trunk/lib/event.js  	Mapbender    7/home/install/workspace/trunk/http/javascripts/core.php  SearchPanel    5/home/install/workspace/trunk/docs/javascript/main.js  	Sandclock    @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php  Reload    =/home/install/workspace/trunk/http/javascripts/mod_reload.php  ZoomIn1    >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php
-SearchResults    5/home/install/workspace/trunk/docs/javascript/main.js  Map    9/home/install/workspace/trunk/http/javascripts/map_obj.js
\ No newline at end of file
Copied: branches/kmq_dev/documents/api_js/Data/ClassHierarchy.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd)
--- branches/kmq_dev/documents/api_js/Data/ClassHierarchy.nd	                        (rev 0)
@@ -0,0 +1,2 @@
+(    Event    */home/install/workspace/trunk/lib/event.js  	Mapbender    7/home/install/workspace/trunk/http/javascripts/core.php  SearchPanel    5/home/install/workspace/trunk/docs/javascript/main.js  	Sandclock    @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php  Reload    =/home/install/workspace/trunk/http/javascripts/mod_reload.php  ZoomIn1    >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php
+SearchResults    5/home/install/workspace/trunk/docs/javascript/main.js  Map    9/home/install/workspace/trunk/http/javascripts/map_obj.js
Deleted: branches/kmq_dev/documents/api_js/Data/ConfigFileInfo.nd
--- trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/ConfigFileInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1 +0,0 @@
-(   JBEöJBEöJBEöJBEöJBEö
Copied: branches/kmq_dev/documents/api_js/Data/ConfigFileInfo.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd)
--- branches/kmq_dev/documents/api_js/Data/ConfigFileInfo.nd	                        (rev 0)
@@ -0,0 +1 @@
+(   JBEöJBEöJBEöJBEöJBEö
Deleted: branches/kmq_dev/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/FileInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,558 +0,0 @@
-1.4
-PHP
-/home/install/workspace/trunk/http/sld/classes/Fill.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Fill.php
-/home/install/workspace/trunk/lib/database-pgsql.php	1215532334	0	/home/install/workspace/trunk/lib/database-pgsql.php
-/home/install/workspace/trunk/http/classes/class_administration.php	1236782767	0	/home/install/workspace/trunk/http/classes/class_administration.php
-/home/install/workspace/trunk/http/classes/class_gml_multiline.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_multiline.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php	1245857248	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php
-/home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php
-/home/install/workspace/trunk/lib/style.js	1220515945	0	/home/install/workspace/trunk/lib/style.js
-/home/install/workspace/trunk/lib/draggableButton.js	1214236663	0	/home/install/workspace/trunk/lib/draggableButton.js
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
-/home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php	1235475918	0	/home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
-/home/install/workspace/trunk/http/sld/sld_main.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_main.php
-/home/install/workspace/trunk/http/javascripts/mod_export_image.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_export_image.php
-/home/install/workspace/trunk/http/php/mod_saveWKT.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_saveWKT.php
-/home/install/workspace/trunk/http/sld/classes/GraphicStroke.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/GraphicStroke.php
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
-/home/install/workspace/trunk/http/php/mod_wfs_conf_html.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_html.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php
-/home/install/workspace/trunk/docs/javascript/searchdata.js	1245847652	0	/home/install/workspace/trunk/docs/javascript/searchdata.js
-/home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php
-/home/install/workspace/trunk/http/sld/classes/Font.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Font.php
-/home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php
-/home/install/workspace/trunk/http/classes/class_wfs_conf.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_conf.php
-/home/install/workspace/trunk/http/php/mod_deleteWFS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteWFS.php
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/classes/class_weldMaps2Image.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_weldMaps2Image.php
-/home/install/workspace/trunk/http/frames/login.php	1245838522	0	/home/install/workspace/trunk/http/frames/login.php
-/home/install/workspace/trunk/http/php/mod_user_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_filteredGroup.php
-/home/install/workspace/trunk/http/extensions/datepicker/datepicker.php	1208966985	0	/home/install/workspace/trunk/http/extensions/datepicker/datepicker.php
-/home/install/workspace/trunk/license/licence_reference.txt	1144962192	0	/home/install/workspace/trunk/license/licence_reference.txt
-/home/install/workspace/trunk/http/php/mod_gazetteer_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteer_conf.php
-/home/install/workspace/trunk/http/javascripts/mod_state.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_state.php
-/home/install/workspace/trunk/lib/exception.js	1236874801	0	/home/install/workspace/trunk/lib/exception.js
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js
-/home/install/workspace/trunk/lib/alignButton.js	1214236663	0	/home/install/workspace/trunk/lib/alignButton.js
-/home/install/workspace/trunk/http/include/dyn_css.php	1238749332	0	/home/install/workspace/trunk/http/include/dyn_css.php
-/home/install/workspace/trunk/http/javascripts/popup.js	1240915413	0	/home/install/workspace/trunk/http/javascripts/popup.js
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php
-/home/install/workspace/trunk/http/classes/class_wfs_featuretype.php	1233827180	0	/home/install/workspace/trunk/http/classes/class_wfs_featuretype.php
-/home/install/workspace/trunk/http/sld/sld_edit_filter.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_edit_filter.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js
-/home/install/workspace/trunk/http/html/mod_treefolder2.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolder2.php
-/home/install/workspace/trunk/lib/class_Mapbender.php	1245838522	0	/home/install/workspace/trunk/lib/class_Mapbender.php
-/home/install/workspace/trunk/http/php/mod_tab_messages.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_tab_messages.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js
-/home/install/workspace/trunk/http/sld/classes/LabelPlacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LabelPlacement.php
-/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php
-/home/install/workspace/trunk/http/classes/class_kml_point.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_point.php
-/home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php	1208966985	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php
-/home/install/workspace/trunk/http/sld/classes/GraphicFill.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/GraphicFill.php
-/home/install/workspace/trunk/http/javascripts/mod_toggleModule.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_toggleModule.php
-/home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php	1219923953	0	/home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php
-/home/install/workspace/trunk/http/classes/class_mb_notice.php	1199464420	0	/home/install/workspace/trunk/http/classes/class_mb_notice.php
-/home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php	1217937298	0	/home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php
-/home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php	1186386922	0	/home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php
-/home/install/workspace/trunk/http/print/mod_printPDF_pdf.php	1237217323	0	/home/install/workspace/trunk/http/print/mod_printPDF_pdf.php
-/home/install/workspace/trunk/http/javascripts/mod_scaleText.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_scaleText.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js
-/home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php
-/home/install/workspace/trunk/http/javascripts/mod_coords.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_coords.php
-/home/install/workspace/trunk/http/php/mod_wfs_result.php	1235985010	0	/home/install/workspace/trunk/http/php/mod_wfs_result.php
-/home/install/workspace/trunk/http/classes/class_gml_feature_collection.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_gml_feature_collection.php
-/home/install/workspace/trunk/http/php/mod_zoomCoords.php	1243284290	0	/home/install/workspace/trunk/http/php/mod_zoomCoords.php
-/home/install/workspace/trunk/http/classes/class_point.php	1231151408	0	/home/install/workspace/trunk/http/classes/class_point.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
-/home/install/workspace/trunk/lib/core.js	1245778754	0	/home/install/workspace/trunk/lib/core.js
-/home/install/workspace/trunk/http/php/mb_validateInput.php	1150787814	0	/home/install/workspace/trunk/http/php/mb_validateInput.php
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
-/home/install/workspace/trunk/http/php/mb_validatePermission.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_validatePermission.php
-/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js
-/home/install/workspace/trunk/http/php/mod_wfs_conf_client.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_client.php
-/home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php
-/home/install/workspace/trunk/lib/event.js	1245780994	1	Event
-/home/install/workspace/trunk/http/php/mod_export_image.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_export_image.php
-/home/install/workspace/trunk/http/javascripts/mod_selArea1.php	1238739052	0	/home/install/workspace/trunk/http/javascripts/mod_selArea1.php
-/home/install/workspace/trunk/http/javascripts/mod_cardindex.js	1200384689	0	/home/install/workspace/trunk/http/javascripts/mod_cardindex.js
-/home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php
-/home/install/workspace/trunk/http/php/mb_validateSession.php	1245838522	0	/home/install/workspace/trunk/http/php/mb_validateSession.php
-/home/install/workspace/trunk/http/php/mod_gui_owner.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_owner.php
-/home/install/workspace/trunk/http/extensions/OpenLayers.js	1214236582	0	/home/install/workspace/trunk/http/extensions/OpenLayers.js
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
-/home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql	1218723822	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql
-/home/install/workspace/trunk/http/include/template_splash.php	1234437340	0	/home/install/workspace/trunk/http/include/template_splash.php
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql	1243796060	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
-/home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php
-/home/install/workspace/trunk/http/javascripts/mod_owsproxy.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_owsproxy.php
-/home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php
-/home/install/workspace/trunk/http/php/mod_editFilteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editFilteredGroup.php
-/home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php	1245771428	0	/home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php
-/home/install/workspace/trunk/http/php/mod_newGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_newGui.php
-/home/install/workspace/trunk/http/javascripts/mod_scaleSel.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_scaleSel.php
-/home/install/workspace/trunk/http/javascripts/mod_copyright.php	1245779661	0	/home/install/workspace/trunk/http/javascripts/mod_copyright.php
-/home/install/workspace/trunk/http/classes/class_wfs_factory.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_wfs_factory.php
-/home/install/workspace/trunk/http/php/mod_filteredWms_topic.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredWms_topic.php
-/home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php
-/home/install/workspace/trunk/http/php/mod_button_tooltips.php	1245855574	0	/home/install/workspace/trunk/http/php/mod_button_tooltips.php
-/home/install/workspace/trunk/tools/char_code.php	1152008002	0	/home/install/workspace/trunk/tools/char_code.php
-/home/install/workspace/trunk/http/javascripts/mod_sandclock2.php	1213021102	0	/home/install/workspace/trunk/http/javascripts/mod_sandclock2.php
-/home/install/workspace/trunk/http/extensions/ext_weldMaps.php	1245838522	0	/home/install/workspace/trunk/http/extensions/ext_weldMaps.php
-/home/install/workspace/trunk/http/php/mod_digitize_messages.php	1237899999	0	/home/install/workspace/trunk/http/php/mod_digitize_messages.php
-/home/install/workspace/trunk/http/javascripts/mod_savewmc.php	1231425706	0	/home/install/workspace/trunk/http/javascripts/mod_savewmc.php
-/home/install/workspace/trunk/lib/i18n.php	1208967270	0	/home/install/workspace/trunk/lib/i18n.php
-/home/install/workspace/trunk/http/javascripts/mod_loadwmc.js	1236875384	0	/home/install/workspace/trunk/http/javascripts/mod_loadwmc.js
-/home/install/workspace/trunk/http/classes/class_layer_monitor.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_layer_monitor.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
-/home/install/workspace/trunk/http/javascripts/mod_legend.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_legend.php
-/home/install/workspace/trunk/docs/javascript/main.js	1245847652	1	SearchPanel
-/home/install/workspace/trunk/http/javascripts/map_obj.js	1245853941	1	Map
-/home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php
-/home/install/workspace/trunk/lib/point.js	1235985010	0	/home/install/workspace/trunk/lib/point.js
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js
-/home/install/workspace/trunk/http/php/mod_treefolderClient.php	1229692761	0	/home/install/workspace/trunk/http/php/mod_treefolderClient.php
-/home/install/workspace/trunk/http/php/mod_loadCapabilities.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadCapabilities.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js
-/home/install/workspace/trunk/http/php/mod_renameGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_renameGUI.php
-/home/install/workspace/trunk/http/javascripts/mod_print1.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_print1.php
-/home/install/workspace/trunk/http/javascripts/mod_center1.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_center1.php
-/home/install/workspace/trunk/http/extensions/jquery.js	1208966985	0	/home/install/workspace/trunk/http/extensions/jquery.js
-/home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php	1197632053	0	/home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php
-/home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php
-/home/install/workspace/trunk/http/javascripts/mod_horizTabs.js	1204803057	0	/home/install/workspace/trunk/http/javascripts/mod_horizTabs.js
-/home/install/workspace/trunk/http/extensions/fisheye.js	1208966985	0	/home/install/workspace/trunk/http/extensions/fisheye.js
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/javascripts/mod_loadwmc.php	1236782767	0	/home/install/workspace/trunk/http/javascripts/mod_loadwmc.php
-/home/install/workspace/trunk/http/extensions/datepicker/datepicker.js	1208966985	0	/home/install/workspace/trunk/http/extensions/datepicker/datepicker.js
-/home/install/workspace/trunk/http/index.php	1237546299	0	/home/install/workspace/trunk/http/index.php
-/home/install/workspace/trunk/http/php/mod_zoomCoords_en.php	1210165862	0	/home/install/workspace/trunk/http/php/mod_zoomCoords_en.php
-/home/install/workspace/trunk/http/classes/class.ezpdf.php	1200385469	0	/home/install/workspace/trunk/http/classes/class.ezpdf.php
-/home/install/workspace/trunk/http/classes/class_keyword.php	1218442761	0	/home/install/workspace/trunk/http/classes/class_keyword.php
-/home/install/workspace/trunk/lib/resizableButton.js	1214236663	0	/home/install/workspace/trunk/lib/resizableButton.js
-/home/install/workspace/trunk/http/classes/class_locale.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_locale.php
-/home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php
-/home/install/workspace/trunk/docs/Menu_Backup.txt	1245781036	0	/home/install/workspace/trunk/docs/Menu_Backup.txt
-/home/install/workspace/trunk/http/php/mod_mapOV.php	1226479717	0	/home/install/workspace/trunk/http/php/mod_mapOV.php
-/home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php
-/home/install/workspace/trunk/http/classes/class_user.php	1244215918	0	/home/install/workspace/trunk/http/classes/class_user.php
-/home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php	1232623861	0	/home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php
-/home/install/workspace/trunk/http/sld/classes/UserStyle.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/UserStyle.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js
-/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
-/home/install/workspace/trunk/http/php/mod_editApplication_server.php	1214236840	0	/home/install/workspace/trunk/http/php/mod_editApplication_server.php
-/home/install/workspace/trunk/http/php/mod_exportGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_exportGUI.php
-/home/install/workspace/trunk/http/javascripts/mod_navFrame.php	1239028534	0	/home/install/workspace/trunk/http/javascripts/mod_navFrame.php
-/home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php
-/home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php	1225983996	0	/home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php
-/home/install/workspace/trunk/http/javascripts/geometry.js	1245779178	0	/home/install/workspace/trunk/http/javascripts/geometry.js
-/home/install/workspace/trunk/http/javascripts/map.js	1245744950	0	/home/install/workspace/trunk/http/javascripts/map.js
-/home/install/workspace/trunk/log/ReadMe.txt	1144962718	0	/home/install/workspace/trunk/log/ReadMe.txt
-/home/install/workspace/trunk/http/classes/class_ows_factory.php	1233742970	0	/home/install/workspace/trunk/http/classes/class_ows_factory.php
-/home/install/workspace/trunk/http/javascripts/map.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/map.php
-/home/install/workspace/trunk/http/classes/class_gml.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml.php
-/home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php
-/home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php
-/home/install/workspace/trunk/http/javascripts/mod_setTimeout.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_setTimeout.php
-/home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js	1236961566	0	/home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js
-/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php
-/home/install/workspace/trunk/Readme.txt	1240853897	0	/home/install/workspace/trunk/Readme.txt
-/home/install/workspace/trunk/lib/ajax.js	1239182831	0	/home/install/workspace/trunk/lib/ajax.js
-/home/install/workspace/trunk/lib/list.js	1213361788	0	/home/install/workspace/trunk/lib/list.js
-/home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php	1236782767	0	/home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
-/home/install/workspace/trunk/http/javascripts/mod_poi.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_poi.php
-/home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php
-/home/install/workspace/trunk/tools/send_post_curl.php	1243515049	0	/home/install/workspace/trunk/tools/send_post_curl.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php	1237043600	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
-/home/install/workspace/trunk/license/license_js.txt	1150726978	0	/home/install/workspace/trunk/license/license_js.txt
-/home/install/workspace/trunk/lib/class_mapbender_session.php	1245838522	0	/home/install/workspace/trunk/lib/class_mapbender_session.php
-/home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php
-/home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/img/button_blue/README.TXT	1150456812	0	/home/install/workspace/trunk/http/img/button_blue/README.TXT
-/home/install/workspace/trunk/http/classes/class_metadata.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_metadata.php
-/home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php	1239705380	0	/home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php
-/home/install/workspace/trunk/http/tmp/ReadMe.txt	1145003810	0	/home/install/workspace/trunk/http/tmp/ReadMe.txt
-/home/install/workspace/trunk/http/classes/class_ows.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_ows.php
-/home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js
-/home/install/workspace/trunk/http/sld/sld_function_getusersld.php	1231319765	0	/home/install/workspace/trunk/http/sld/sld_function_getusersld.php
-/home/install/workspace/trunk/http/php/mod_gui_user.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_user.php
-/home/install/workspace/trunk/http/extensions/wz_jsgraphics.js	1221663284	0	/home/install/workspace/trunk/http/extensions/wz_jsgraphics.js
-/home/install/workspace/trunk/http/javascripts/initWms.php	1236782767	0	/home/install/workspace/trunk/http/javascripts/initWms.php
-/home/install/workspace/trunk/http/javascripts/mod_back.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_back.php
-/home/install/workspace/trunk/http/php/mod_createCategory.php	1236068706	0	/home/install/workspace/trunk/http/php/mod_createCategory.php
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
-/home/install/workspace/trunk/http/php/mod_updateWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_updateWMS.php
-/home/install/workspace/trunk/http/sld/classes/ParameterValue.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ParameterValue.php
-/home/install/workspace/trunk/http/php/mod_gazetteer_edit.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteer_edit.php
-/home/install/workspace/trunk/http/classes/class_stripRequest.php	1227687853	0	/home/install/workspace/trunk/http/classes/class_stripRequest.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js
-/home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js	1214236840	0	/home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js
-/home/install/workspace/trunk/docs/Topics.txt	1245847652	0	/home/install/workspace/trunk/docs/Topics.txt
-/home/install/workspace/trunk/http/php/mod_usemap.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_usemap.php
-/home/install/workspace/trunk/http/sld/sld_parse.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_parse.php
-/home/install/workspace/trunk/http/include/dyn_js.php	1238749332	0	/home/install/workspace/trunk/http/include/dyn_js.php
-/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php
-/home/install/workspace/trunk/http/extensions/jquery.form.js	1236536525	0	/home/install/workspace/trunk/http/extensions/jquery.form.js
-/home/install/workspace/trunk/http/include/dyn_js_object.php	1245648655	0	/home/install/workspace/trunk/http/include/dyn_js_object.php
-/home/install/workspace/trunk/http/classes/class_checkInput.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_checkInput.php
-/home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php
-/home/install/workspace/trunk/http/classes/class_gml_multipolygon.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_multipolygon.php
-/home/install/workspace/trunk/http/javascripts/mod_box1.js	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_box1.js
-/home/install/workspace/trunk/http/javascripts/mod_home.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_home.php
-/home/install/workspace/trunk/http/sld/classes/Displacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Displacement.php
-/home/install/workspace/trunk/http/javascripts/mod_scalebar.php	1239704908	0	/home/install/workspace/trunk/http/javascripts/mod_scalebar.php
-/home/install/workspace/trunk/http/classes/class_kml_parser_ows.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_parser_ows.php
-/home/install/workspace/trunk/http/javascripts/mod_displayObj.js	1164286253	0	/home/install/workspace/trunk/http/javascripts/mod_displayObj.js
-/home/install/workspace/trunk/http/sld/classes/ElseFilter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ElseFilter.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js
-/home/install/workspace/trunk/http/javascripts/mod_tab.js	1236949870	0	/home/install/workspace/trunk/http/javascripts/mod_tab.js
-/home/install/workspace/trunk/http/php/mod_gui_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_group.php
-/home/install/workspace/trunk/lib/selectableButton.js	1214236663	0	/home/install/workspace/trunk/lib/selectableButton.js
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql	1238355978	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
-/home/install/workspace/trunk/http/javascripts/mod_body.js	1245680608	0	/home/install/workspace/trunk/http/javascripts/mod_body.js
-/home/install/workspace/trunk/http/php/mb_getGUIs.php	1150727701	0	/home/install/workspace/trunk/http/php/mb_getGUIs.php
-/home/install/workspace/trunk/http/javascripts/mod_sandclock.php	1245779179	1	Sandclock
-/home/install/workspace/trunk/http/classes/class_mb_exception.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_mb_exception.php
-/home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php
-/home/install/workspace/trunk/http/php/createImageFromText.php	1186565603	0	/home/install/workspace/trunk/http/php/createImageFromText.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js
-/home/install/workspace/trunk/http/php/mod_filteredGui_User.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_User.php
-/home/install/workspace/trunk/http/html/mod_treefolder.php	1208967270	0	/home/install/workspace/trunk/http/html/mod_treefolder.php
-/home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php
-/home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql
-/home/install/workspace/trunk/http/sld/sld_pick_color.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_pick_color.php
-/home/install/workspace/trunk/http/classes/class_wfs_configuration.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_configuration.php
-/home/install/workspace/trunk/core/globalSettings.php	1245838748	0	/home/install/workspace/trunk/core/globalSettings.php
-/home/install/workspace/trunk/http/php/mod_changeEPSG_server.php	1230909423	0	/home/install/workspace/trunk/http/php/mod_changeEPSG_server.php
-/home/install/workspace/trunk/lib/database-mysqli.php	1215768576	0	/home/install/workspace/trunk/lib/database-mysqli.php
-/home/install/workspace/trunk/http/sld/sld_function_handler.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_function_handler.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js
-/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php
-/home/install/workspace/trunk/http/classes/class_kml.php	1217937298	0	/home/install/workspace/trunk/http/classes/class_kml.php
-/home/install/workspace/trunk/http/sld/classes/Mark.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Mark.php
-/home/install/workspace/trunk/http/php/mod_exportMapImage_server.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_exportMapImage_server.php
-/home/install/workspace/trunk/http/classes/class_SaveLegend.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_SaveLegend.php
-/home/install/workspace/trunk/owsproxy/http/index.php	1222346431	0	/home/install/workspace/trunk/owsproxy/http/index.php
-/home/install/workspace/trunk/http/sld/classes/LegendGraphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LegendGraphic.php
-/home/install/workspace/trunk/http/frames/cleanurl.php	1208967270	0	/home/install/workspace/trunk/http/frames/cleanurl.php
-/home/install/workspace/trunk/http/javascripts/mod_treeConf.js	1150280597	0	/home/install/workspace/trunk/http/javascripts/mod_treeConf.js
-/home/install/workspace/trunk/http/classes/class_kml_multigeometry.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_multigeometry.php
-/home/install/workspace/trunk/license/gpl.txt	1144962192	0	/home/install/workspace/trunk/license/gpl.txt
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php
-/home/install/workspace/trunk/http/php/mod_group_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_filteredGui.php
-/home/install/workspace/trunk/http/sld/classes/Graphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Graphic.php
-/home/install/workspace/trunk/http/php/mod_wfs.php	1245245453	0	/home/install/workspace/trunk/http/php/mod_wfs.php
-/home/install/workspace/trunk/http/classes/class_gml_3_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_3_factory.php
-/home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js
-/home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php
-/home/install/workspace/trunk/lib/customTreeController.js	1236961566	0	/home/install/workspace/trunk/lib/customTreeController.js
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
-/home/install/workspace/trunk/http/javascripts/mod_displayWmc.php	1213362274	0	/home/install/workspace/trunk/http/javascripts/mod_displayWmc.php
-/home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php
-/home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php	1237887369	0	/home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js
-/home/install/workspace/trunk/http/classes/class_gui.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_gui.php
-/home/install/workspace/trunk/http/javascripts/mod_measure.php	1241379560	0	/home/install/workspace/trunk/http/javascripts/mod_measure.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php	1208966513	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php
-/home/install/workspace/trunk/http/javascripts/mod_tooltip.php	1239870590	0	/home/install/workspace/trunk/http/javascripts/mod_tooltip.php
-/home/install/workspace/trunk/http/classes/class_gml_line.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_line.php
-/home/install/workspace/trunk/http/php/mb_listKMLs.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_listKMLs.php
-/home/install/workspace/trunk/http/javascripts/mod_key.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_key.php
-/home/install/workspace/trunk/http/sld/classes/AddOperationModule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/AddOperationModule.php
-/home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql
-/home/install/workspace/trunk/http/classes/class_kml_placemark.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_placemark.php
-/home/install/workspace/trunk/http/javascripts/mapnf.php	1245778752	0	/home/install/workspace/trunk/http/javascripts/mapnf.php
-/home/install/workspace/trunk/lib/ajax.php	1239182831	0	/home/install/workspace/trunk/lib/ajax.php
-/home/install/workspace/trunk/http/classes/class.pdf.php	1200385469	0	/home/install/workspace/trunk/http/classes/class.pdf.php
-/home/install/workspace/trunk/http/php/mod_category_filteredGUI.php	1245855925	0	/home/install/workspace/trunk/http/php/mod_category_filteredGUI.php
-/home/install/workspace/trunk/license/gpl_short.txt	1144962192	0	/home/install/workspace/trunk/license/gpl_short.txt
-/home/install/workspace/trunk/http/javascripts/wfs.php	1238149835	0	/home/install/workspace/trunk/http/javascripts/wfs.php
-/home/install/workspace/trunk/http/classes/class_kml_polygon.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_polygon.php
-/home/install/workspace/trunk/http/php/mod_edit_element_vars.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_edit_element_vars.php
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/javascripts/mod_pan.php	1239119530	0	/home/install/workspace/trunk/http/javascripts/mod_pan.php
-/home/install/workspace/trunk/http/javascripts/core.php	1245856626	1	Mapbender
-/home/install/workspace/trunk/http/classes/class_wms.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wms.php
-/home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php
-/home/install/workspace/trunk/docs/Languages.txt	1245847652	0	/home/install/workspace/trunk/docs/Languages.txt
-/home/install/workspace/trunk/http/sld/classes/Rule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Rule.php
-/home/install/workspace/trunk/lib/div.js	1232466013	0	/home/install/workspace/trunk/lib/div.js
-/home/install/workspace/trunk/http/php/mod_map1.php	1226479717	0	/home/install/workspace/trunk/http/php/mod_map1.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMS.php	1245772744	0	/home/install/workspace/trunk/http/javascripts/mod_addWMS.php
-/home/install/workspace/trunk/http/php/mod_orphanWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_orphanWMS.php
-/home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php
-/home/install/workspace/trunk/http/classes/class_gml_envelope.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_gml_envelope.php
-/home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php
-/home/install/workspace/trunk/http/javascripts/mod_horizTab.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_horizTab.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
-/home/install/workspace/trunk/docs/Menu.txt	1245847652	0	/home/install/workspace/trunk/docs/Menu.txt
-/home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js
-/home/install/workspace/trunk/http/print/print_functions.php	1218808363	0	/home/install/workspace/trunk/http/print/print_functions.php
-/home/install/workspace/trunk/http/classes/class_gml2.php	1229347647	0	/home/install/workspace/trunk/http/classes/class_gml2.php
-/home/install/workspace/trunk/http/php/mod_editApplication.php	1237368148	0	/home/install/workspace/trunk/http/php/mod_editApplication.php
-/home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php
-/home/install/workspace/trunk/http/javascripts/mod_selArea.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_selArea.php
-/home/install/workspace/trunk/http/classes/class_gml_feature.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml_feature.php
-/home/install/workspace/trunk/sql/update_wfs_conf_element.sql	1245418009	0	/home/install/workspace/trunk/sql/update_wfs_conf_element.sql
-/home/install/workspace/trunk/http/extensions/jqjson.js	1191832183	0	/home/install/workspace/trunk/http/extensions/jqjson.js
-/home/install/workspace/trunk/http/php/mod_editElementVars.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editElementVars.php
-/home/install/workspace/trunk/http/php/mod_layerMetadata.php	1209634442	0	/home/install/workspace/trunk/http/php/mod_layerMetadata.php
-/home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php	1230887236	0	/home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php
-/home/install/workspace/trunk/http/javascripts/mod_forward.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_forward.php
-/home/install/workspace/trunk/http/php/mod_createUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_createUser.php
-/home/install/workspace/trunk/http/sld/classes/CssParameter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/CssParameter.php
-/home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php
-/home/install/workspace/trunk/http/javascripts/mod_fisheye.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_fisheye.php
-/home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php
-/home/install/workspace/trunk/http/php/mod_loadwms_temp.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadwms_temp.php
-/home/install/workspace/trunk/resources/db/reload.sql	1245681909	0	/home/install/workspace/trunk/resources/db/reload.sql
-/home/install/workspace/trunk/http/sld/classes/DbUtils.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/DbUtils.php
-/home/install/workspace/trunk/http/php/mod_user_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_filteredGui.php
-/home/install/workspace/trunk/sql/update_wfs_conf.sql	1244558916	0	/home/install/workspace/trunk/sql/update_wfs_conf.sql
-/home/install/workspace/trunk/http/classes/class_mb_log.php	1208966371	0	/home/install/workspace/trunk/http/classes/class_mb_log.php
-/home/install/workspace/trunk/http/classes/class_wfs_1_1.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs_1_1.php
-/home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php	1237200458	0	/home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php
-/home/install/workspace/trunk/http/php/mod_filteredGroup_User.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_User.php
-/home/install/workspace/trunk/http/classes/class_kml_ows.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_kml_ows.php
-/home/install/workspace/trunk/http/php/nestedSets.php	1218790491	0	/home/install/workspace/trunk/http/php/nestedSets.php
-/home/install/workspace/trunk/http/sld/classes/Halo.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Halo.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js
-/home/install/workspace/trunk/tools/mapbender_setup.php	1227084639	0	/home/install/workspace/trunk/tools/mapbender_setup.php
-/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php
-/home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js	1229072942	0	/home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js
-/home/install/workspace/trunk/lib/class_Singleton.php	1245838522	0	/home/install/workspace/trunk/lib/class_Singleton.php
-/home/install/workspace/trunk/tools/mapFiler.php	1231858528	0	/home/install/workspace/trunk/tools/mapFiler.php
-/home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php
-/home/install/workspace/trunk/http/javascripts/wfsFilter.js	1236351449	0	/home/install/workspace/trunk/http/javascripts/wfsFilter.js
-/home/install/workspace/trunk/http/php/mod_editGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editGroup.php
-/home/install/workspace/trunk/sql/insert_wfs_conf_element.sql	1245246454	0	/home/install/workspace/trunk/sql/insert_wfs_conf_element.sql
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js
-/home/install/workspace/trunk/license/Liberation-License.txt	1237290442	0	/home/install/workspace/trunk/license/Liberation-License.txt
-/home/install/workspace/trunk/http/php/mod_user_gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_gui.php
-/home/install/workspace/trunk/http/php/mod_wfs_server.php	1237225534	0	/home/install/workspace/trunk/http/php/mod_wfs_server.php
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
-/home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php	1230894465	0	/home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php
-/home/install/workspace/trunk/http/php/mod_customTree.php	1236961566	0	/home/install/workspace/trunk/http/php/mod_customTree.php
-/home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php
-/home/install/workspace/trunk/http/php/mod_editGuiWms.php	1236956732	0	/home/install/workspace/trunk/http/php/mod_editGuiWms.php
-/home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js
-/home/install/workspace/trunk/http/php/mod_group_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_filteredUser.php
-/home/install/workspace/trunk/http/php/mod_editUser.php	1225985335	0	/home/install/workspace/trunk/http/php/mod_editUser.php
-/home/install/workspace/trunk/http/php/mod_customTree_server.php	1245856564	0	/home/install/workspace/trunk/http/php/mod_customTree_server.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
-/home/install/workspace/trunk/http/php/mod_displayKML.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_displayKML.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js
-/home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php	1236875614	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php
-/home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php	1245413563	0	/home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php
-/home/install/workspace/trunk/http/classes/class_element.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_element.php
-/home/install/workspace/trunk/http/classes/class_json.php	1227084639	0	/home/install/workspace/trunk/http/classes/class_json.php
-/home/install/workspace/trunk/http/classes/class_bbox.php	1231151408	0	/home/install/workspace/trunk/http/classes/class_bbox.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql
-/home/install/workspace/trunk/http/classes/class_gml_polygon.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_polygon.php
-/home/install/workspace/trunk/http/javascripts/mod_perimeter.php	1214236736	0	/home/install/workspace/trunk/http/javascripts/mod_perimeter.php
-/home/install/workspace/trunk/http/extensions/DifferenceEngine.php	1235406337	0	/home/install/workspace/trunk/http/extensions/DifferenceEngine.php
-/home/install/workspace/trunk/http/sld/classes/Filter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Filter.php
-/home/install/workspace/trunk/http/php/mod_showLoggedUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_showLoggedUser.php
-/home/install/workspace/trunk/http/php/mod_treefolderAdmin.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_treefolderAdmin.php
-/home/install/workspace/trunk/http/classes/class_kml_line.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_line.php
-/home/install/workspace/trunk/http/php/mod_wfs_conf.php	1235136381	0	/home/install/workspace/trunk/http/php/mod_wfs_conf.php
-/home/install/workspace/trunk/http/html/mod_sync_treefolder.php	1208967270	0	/home/install/workspace/trunk/http/html/mod_sync_treefolder.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js
-/home/install/workspace/trunk/http/php/mod_getStyles.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_getStyles.php
-/home/install/workspace/trunk/http/php/mod_forgottenPassword.php	1229013681	0	/home/install/workspace/trunk/http/php/mod_forgottenPassword.php
-/home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php	1230887236	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php
-/home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql	1214236631	0	/home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql
-/home/install/workspace/trunk/http/javascripts/mod_add_SLD.php	1236875384	0	/home/install/workspace/trunk/http/javascripts/mod_add_SLD.php
-/home/install/workspace/trunk/http/php/mod_gui_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_filteredUser.php
-/home/install/workspace/trunk/http/php/mod_loadwmc_server.php	1240923997	0	/home/install/workspace/trunk/http/php/mod_loadwmc_server.php
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js
-/home/install/workspace/trunk/http/php/mod_owsproxy_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_owsproxy_conf.php
-/home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql	1218723822	0	/home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql
-/home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php
-/home/install/workspace/trunk/http/extensions/jquery.tablesorter.js	1234864590	0	/home/install/workspace/trunk/http/extensions/jquery.tablesorter.js
-/home/install/workspace/trunk/http/php/mod_savewmc_server.php	1240921307	0	/home/install/workspace/trunk/http/php/mod_savewmc_server.php
-/home/install/workspace/trunk/lib/buttonNew.js	1236875384	0	/home/install/workspace/trunk/lib/buttonNew.js
-/home/install/workspace/trunk/http/javascripts/mod_usemap.php	1213021210	0	/home/install/workspace/trunk/http/javascripts/mod_usemap.php
-/home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php	1235475918	0	/home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php
-/home/install/workspace/trunk/http/javascripts/mod_repaint.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_repaint.php
-/home/install/workspace/trunk/http/javascripts/ovnf.php	1245778750	0	/home/install/workspace/trunk/http/javascripts/ovnf.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js
-/home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php	1236005925	0	/home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php
-/home/install/workspace/trunk/tools/send_post.php	1186389031	0	/home/install/workspace/trunk/tools/send_post.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js
-/home/install/workspace/trunk/core/i18n.php	1245838522	0	/home/install/workspace/trunk/core/i18n.php
-/home/install/workspace/trunk/http/classes/class_wmcToXml.php	1236782767	0	/home/install/workspace/trunk/http/classes/class_wmcToXml.php
-/home/install/workspace/trunk/http/javascripts/wfs_obj.js	1208967664	0	/home/install/workspace/trunk/http/javascripts/wfs_obj.js
-/home/install/workspace/trunk/http/classes/class_kml_geometry.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_geometry.php
-/home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js	1235982146	0	/home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js
-/home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php
-/home/install/workspace/trunk/http/javascripts/mod_loadKML.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_loadKML.php
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/classes/class_gml_point.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_point.php
-/home/install/workspace/trunk/http/classes/class_wfs_deprecated.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_deprecated.php
-/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
-/home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php	1214236698	0	/home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php
-/home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php
-/home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT	1237290442	0	/home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT
-/home/install/workspace/trunk/http/classes/class_gml_2_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_2_factory.php
-/home/install/workspace/trunk/http/extensions/geom2wfst.php	1235739677	0	/home/install/workspace/trunk/http/extensions/geom2wfst.php
-/home/install/workspace/trunk/lib/button.js	1230887532	0	/home/install/workspace/trunk/lib/button.js
-/home/install/workspace/trunk/http/php/mod_filteredUser_Group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_Group.php
-/home/install/workspace/trunk/http/sld/classes/NamedLayer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/NamedLayer.php
-/home/install/workspace/trunk/http/php/mod_wfs_edit.php	1238145768	0	/home/install/workspace/trunk/http/php/mod_wfs_edit.php
-/home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php	1245854203	0	/home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php
-/home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php
-/home/install/workspace/trunk/http/php/mod_editSelf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editSelf.php
-/home/install/workspace/trunk/http/javascripts/mod_saveWKT.js	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_saveWKT.js
-/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
-/home/install/workspace/trunk/Install.txt	1237308524	0	/home/install/workspace/trunk/Install.txt
-/home/install/workspace/trunk/http/javascripts/mod_openlayers.php	1214236840	0	/home/install/workspace/trunk/http/javascripts/mod_openlayers.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js
-/home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php
-/home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php	1208967270	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php
-/home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js	1244215918	0	/home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js
-/home/install/workspace/trunk/http/php/mod_group_gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_gui.php
-/home/install/workspace/trunk/http/php/mod_group_user.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_user.php
-/home/install/workspace/trunk/http/php/mod_deleteGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteGUI.php
-/home/install/workspace/trunk/lib/customTreeModel.js	1236961566	0	/home/install/workspace/trunk/lib/customTreeModel.js
-/home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php
-/home/install/workspace/trunk/http/sld/sld_config.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_config.php
-/home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js	1245314856	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js
-/home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php
-/home/install/workspace/trunk/http/javascripts/mod_log.php	1216711579	0	/home/install/workspace/trunk/http/javascripts/mod_log.php
-/home/install/workspace/trunk/http/classes/class_wmc.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wmc.php
-/home/install/workspace/trunk/http/php/mod_printView1.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_printView1.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js
-/home/install/workspace/trunk/Changes.txt	1237308497	0	/home/install/workspace/trunk/Changes.txt
-/home/install/workspace/trunk/http/classes/class_map.php	1236951293	0	/home/install/workspace/trunk/http/classes/class_map.php
-/home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
-/home/install/workspace/trunk/http/sld/sld_filter_parse.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_filter_parse.php
-/home/install/workspace/trunk/http/javascripts/mod_setBackground.php	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_setBackground.php
-/home/install/workspace/trunk/lib/basic.js	1240904723	0	/home/install/workspace/trunk/lib/basic.js
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js
-/home/install/workspace/trunk/http/php/mod_editElements.php	1245746857	0	/home/install/workspace/trunk/http/php/mod_editElements.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js
-/home/install/workspace/trunk/http/php/mod_exportElement.php	1242242094	0	/home/install/workspace/trunk/http/php/mod_exportElement.php
-/home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php
-/home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js	1164040412	0	/home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js
-/home/install/workspace/trunk/http/print/mod_printPDF.php	1237200647	0	/home/install/workspace/trunk/http/print/mod_printPDF.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js
-/home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js
-/home/install/workspace/trunk/http/php/mod_deleteWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteWMS.php
-/home/install/workspace/trunk/http/php/mod_user_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_group.php
-/home/install/workspace/trunk/http/classes/class_connector.php	1239128635	0	/home/install/workspace/trunk/http/classes/class_connector.php
-/home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php
-/home/install/workspace/trunk/http/php/mod_meetingPoint.php	1237887556	0	/home/install/workspace/trunk/http/php/mod_meetingPoint.php
-/home/install/workspace/trunk/http/javascripts/mod_renderGML.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_renderGML.php
-/home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php	1186386971	0	/home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php
-/home/install/workspace/trunk/http/extensions/markResult.php	1208966985	0	/home/install/workspace/trunk/http/extensions/markResult.php
-/home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php
-/home/install/workspace/trunk/http/javascripts/mod_reload.php	1245856626	1	Reload
-/home/install/workspace/trunk/http/include/gui1_splash.php	1231153927	0	/home/install/workspace/trunk/http/include/gui1_splash.php
-/home/install/workspace/trunk/http/php/mod_logout.php	1218442761	0	/home/install/workspace/trunk/http/php/mod_logout.php
-/home/install/workspace/trunk/core/system.php	1245772744	0	/home/install/workspace/trunk/core/system.php
-/home/install/workspace/trunk/http/classes/class_wfs.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs.php
-/home/install/workspace/trunk/http/classes/class_universal_gml_factory.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_universal_gml_factory.php
-/home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php
-/home/install/workspace/trunk/http/php/mod_SelectKeyword.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_SelectKeyword.php
-/home/install/workspace/trunk/http/sld/classes/AnchorPoint.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/AnchorPoint.php
-/home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
-/home/install/workspace/trunk/http/php/mod_loadwms.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadwms.php
-/home/install/workspace/trunk/http/extensions/JSON.php	1173171435	0	/home/install/workspace/trunk/http/extensions/JSON.php
-/home/install/workspace/trunk/http/sld/classes/Stroke.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Stroke.php
-/home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php	1232465591	0	/home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
-/home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php	1245856041	0	/home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php
-/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js	1236961566	0	/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php
-/home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php
-/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php	1245779180	1	ZoomIn1
-/home/install/workspace/trunk/sql/insert_wfs_conf.sql	1244558916	0	/home/install/workspace/trunk/sql/insert_wfs_conf.sql
-/home/install/workspace/trunk/http/classes/class_mb_warning.php	1199464420	0	/home/install/workspace/trunk/http/classes/class_mb_warning.php
-/home/install/workspace/trunk/http/sld/classes/PointPlacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PointPlacement.php
-/home/install/workspace/trunk/http/php/mod_setLocale.php	1216713787	0	/home/install/workspace/trunk/http/php/mod_setLocale.php
-/home/install/workspace/trunk/http/javascripts/wms.js	1238749127	0	/home/install/workspace/trunk/http/javascripts/wms.js
-/home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js
-/home/install/workspace/trunk/http/php/mod_editFilteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editFilteredUser.php
-/home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php	1239129168	0	/home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php
-/home/install/workspace/trunk/http/php/mod_updateKmlInDb.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_updateKmlInDb.php
-/home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql	1153388414	0	/home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql
-/home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js
-/home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php	1236703351	0	/home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php
-/home/install/workspace/trunk/http/php/mod_loadwfs.php	1236703245	0	/home/install/workspace/trunk/http/php/mod_loadwfs.php
-/home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
-/home/install/workspace/trunk/http/classes/class_gml_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_factory.php
-/home/install/workspace/trunk/http/php/mod_filteredGui_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_group.php
-/home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php	1245856324	0	/home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
-/home/install/workspace/trunk/http/php/mb_listGUIs.php	1236876057	0	/home/install/workspace/trunk/http/php/mb_listGUIs.php
-/home/install/workspace/trunk/http/javascripts/jsTree.js	1230902123	0	/home/install/workspace/trunk/http/javascripts/jsTree.js
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
-/home/install/workspace/trunk/http/javascripts/mod_initWmc.php	1231425706	0	/home/install/workspace/trunk/http/javascripts/mod_initWmc.php
-/home/install/workspace/trunk/http/sld/classes/ColorMap.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ColorMap.php
-/home/install/workspace/trunk/http/javascripts/mod_scaleHint.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_scaleHint.php
-/home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php	1245779180	0	/home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php
-/home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php
-/home/install/workspace/trunk/http/php/mb_js_exception.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_js_exception.php
-/home/install/workspace/trunk/http/html/mod_treefolderPlain.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolderPlain.php
-/home/install/workspace/trunk/http/frames/index.php	1245838522	0	/home/install/workspace/trunk/http/frames/index.php
-/home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js	1208966985	0	/home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js
-/home/install/workspace/trunk/http/classes/class_gml_geometry.php	1234978564	0	/home/install/workspace/trunk/http/classes/class_gml_geometry.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
-/home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js	1244215918	0	/home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js
-/home/install/workspace/trunk/tools/url_code.php	1164106450	0	/home/install/workspace/trunk/tools/url_code.php
-/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
-/home/install/workspace/trunk/http/classes/class_gml_3.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml_3.php
-/home/install/workspace/trunk/http/php/mod_WMSpreferences.php	1236330438	0	/home/install/workspace/trunk/http/php/mod_WMSpreferences.php
-/home/install/workspace/trunk/http/javascripts/mod_featureInfo.php	1240326844	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfo.php
-/home/install/workspace/trunk/http/javascripts/mod_coords_div.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_coords_div.php
-/home/install/workspace/trunk/http/php/mod_log.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_log.php
-/home/install/workspace/trunk/http/php/mod_changePassword.php	1245856206	0	/home/install/workspace/trunk/http/php/mod_changePassword.php
-/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
-/home/install/workspace/trunk/http/javascripts/mod_tab.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_tab.php
-/home/install/workspace/trunk/http/javascripts/mod_help.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_help.php
-/home/install/workspace/trunk/http/classes/class_kml_linearring.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_linearring.php
-/home/install/workspace/trunk/http/classes/class_monitor.php	1235406337	0	/home/install/workspace/trunk/http/classes/class_monitor.php
-/home/install/workspace/trunk/http/classes/class_log.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_log.php
-/home/install/workspace/trunk/http/php/mod_wfs_conf_server.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_server.php
-/home/install/workspace/trunk/lib/database-mysql.php	1220516326	0	/home/install/workspace/trunk/lib/database-mysql.php
-/home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php
-/home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php
-/home/install/workspace/trunk/http/classes/class_wfs_1_0.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs_1_0.php
-/home/install/workspace/trunk/http/classes/class_wfsToDb.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfsToDb.php
-/home/install/workspace/trunk/http/php/mod_evalArea.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_evalArea.php
-/home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php	1238152673	0	/home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php
-/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
-/home/install/workspace/trunk/resources/db/update/update_2.7.sql	1245745690	0	/home/install/workspace/trunk/resources/db/update/update_2.7.sql
-/home/install/workspace/trunk/http/php/mod_edit_metadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_edit_metadata.php
-/home/install/workspace/trunk/http/php/mod_showGuiName.php	1221056958	0	/home/install/workspace/trunk/http/php/mod_showGuiName.php
-/home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js	1234281206	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js
-/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js
-/home/install/workspace/trunk/http/javascripts/mod_zoomFull.php	1245779180	0	/home/install/workspace/trunk/http/javascripts/mod_zoomFull.php
-/home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php
-/home/install/workspace/trunk/lib/saveButton.js	1214236663	0	/home/install/workspace/trunk/lib/saveButton.js
-/home/install/workspace/trunk/http/classes/class_gml_2.php	1234978564	0	/home/install/workspace/trunk/http/classes/class_gml_2.php
-/home/install/workspace/trunk/http/include/dyn_php.php	1200384506	0	/home/install/workspace/trunk/http/include/dyn_php.php
-/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
-/home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php
-/home/install/workspace/trunk/http/extensions/json.js	1190794313	0	/home/install/workspace/trunk/http/extensions/json.js
Copied: branches/kmq_dev/documents/api_js/Data/FileInfo.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/FileInfo.nd)
--- branches/kmq_dev/documents/api_js/Data/FileInfo.nd	                        (rev 0)
+++ branches/kmq_dev/documents/api_js/Data/FileInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,558 @@
+1.4
+PHP
+/home/install/workspace/trunk/http/sld/classes/Fill.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Fill.php
+/home/install/workspace/trunk/lib/database-pgsql.php	1215532334	0	/home/install/workspace/trunk/lib/database-pgsql.php
+/home/install/workspace/trunk/http/classes/class_administration.php	1236782767	0	/home/install/workspace/trunk/http/classes/class_administration.php
+/home/install/workspace/trunk/http/classes/class_gml_multiline.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_multiline.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php	1245857248	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList.php
+/home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_embedded_legend.php
+/home/install/workspace/trunk/lib/style.js	1220515945	0	/home/install/workspace/trunk/lib/style.js
+/home/install/workspace/trunk/lib/draggableButton.js	1214236663	0	/home/install/workspace/trunk/lib/draggableButton.js
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php	1235475918	0	/home/install/workspace/trunk/http/php/mod_gazetteerMetadata_search.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-nl.php
+/home/install/workspace/trunk/http/sld/sld_main.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_main.php
+/home/install/workspace/trunk/http/javascripts/mod_export_image.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_export_image.php
+/home/install/workspace/trunk/http/php/mod_saveWKT.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_saveWKT.php
+/home/install/workspace/trunk/http/sld/classes/GraphicStroke.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/GraphicStroke.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_wfs_conf_html.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_html.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpunit.php
+/home/install/workspace/trunk/docs/javascript/searchdata.js	1245847652	0	/home/install/workspace/trunk/docs/javascript/searchdata.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_main.php
+/home/install/workspace/trunk/http/sld/classes/Font.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Font.php
+/home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_saveLayerPreview.php
+/home/install/workspace/trunk/http/classes/class_wfs_conf.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_conf.php
+/home/install/workspace/trunk/http/php/mod_deleteWFS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteWFS.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/classes/class_weldMaps2Image.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_weldMaps2Image.php
+/home/install/workspace/trunk/http/frames/login.php	1245838522	0	/home/install/workspace/trunk/http/frames/login.php
+/home/install/workspace/trunk/http/php/mod_user_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_filteredGroup.php
+/home/install/workspace/trunk/http/extensions/datepicker/datepicker.php	1208966985	0	/home/install/workspace/trunk/http/extensions/datepicker/datepicker.php
+/home/install/workspace/trunk/license/licence_reference.txt	1144962192	0	/home/install/workspace/trunk/license/licence_reference.txt
+/home/install/workspace/trunk/http/php/mod_gazetteer_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteer_conf.php
+/home/install/workspace/trunk/http/javascripts/mod_state.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_state.php
+/home/install/workspace/trunk/lib/exception.js	1236874801	0	/home/install/workspace/trunk/lib/exception.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-CN.js
+/home/install/workspace/trunk/lib/alignButton.js	1214236663	0	/home/install/workspace/trunk/lib/alignButton.js
+/home/install/workspace/trunk/http/include/dyn_css.php	1238749332	0	/home/install/workspace/trunk/http/include/dyn_css.php
+/home/install/workspace/trunk/http/javascripts/popup.js	1240915413	0	/home/install/workspace/trunk/http/javascripts/popup.js
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredUser.php
+/home/install/workspace/trunk/http/classes/class_wfs_featuretype.php	1233827180	0	/home/install/workspace/trunk/http/classes/class_wfs_featuretype.php
+/home/install/workspace/trunk/http/sld/sld_edit_filter.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_edit_filter.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-tr.js
+/home/install/workspace/trunk/http/html/mod_treefolder2.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolder2.php
+/home/install/workspace/trunk/lib/class_Mapbender.php	1245838522	0	/home/install/workspace/trunk/lib/class_Mapbender.php
+/home/install/workspace/trunk/http/php/mod_tab_messages.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_tab_messages.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-no.js
+/home/install/workspace/trunk/http/sld/classes/LabelPlacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LabelPlacement.php
+/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGui.php
+/home/install/workspace/trunk/http/classes/class_kml_point.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_point.php
+/home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_wfsSpatialRequest_messages.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php	1208966985	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/phpmailer_test.php
+/home/install/workspace/trunk/http/sld/classes/GraphicFill.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/GraphicFill.php
+/home/install/workspace/trunk/http/javascripts/mod_toggleModule.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_toggleModule.php
+/home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php	1219923953	0	/home/install/workspace/trunk/http/extensions/ext_featureInfoTunnel.php
+/home/install/workspace/trunk/http/classes/class_mb_notice.php	1199464420	0	/home/install/workspace/trunk/http/classes/class_mb_notice.php
+/home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php	1217937298	0	/home/install/workspace/trunk/http/php/mod_loadCapabilitiesList.php
+/home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php	1186386922	0	/home/install/workspace/trunk/http/classes/class_weldLegend2PNG.php
+/home/install/workspace/trunk/http/print/mod_printPDF_pdf.php	1237217323	0	/home/install/workspace/trunk/http/print/mod_printPDF_pdf.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleText.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_scaleText.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-cs.js
+/home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadCapabilities_temp.php
+/home/install/workspace/trunk/http/javascripts/mod_coords.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_coords.php
+/home/install/workspace/trunk/http/php/mod_wfs_result.php	1235985010	0	/home/install/workspace/trunk/http/php/mod_wfs_result.php
+/home/install/workspace/trunk/http/classes/class_gml_feature_collection.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_gml_feature_collection.php
+/home/install/workspace/trunk/http/php/mod_zoomCoords.php	1243284290	0	/home/install/workspace/trunk/http/php/mod_zoomCoords.php
+/home/install/workspace/trunk/http/classes/class_point.php	1231151408	0	/home/install/workspace/trunk/http/classes/class_point.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/lib/core.js	1245778754	0	/home/install/workspace/trunk/lib/core.js
+/home/install/workspace/trunk/http/php/mb_validateInput.php	1150787814	0	/home/install/workspace/trunk/http/php/mb_validateInput.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-id.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-br.php
+/home/install/workspace/trunk/http/php/mb_validatePermission.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_validatePermission.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.min.js
+/home/install/workspace/trunk/http/php/mod_wfs_conf_client.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_client.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_Gui.php
+/home/install/workspace/trunk/lib/event.js	1245780994	1	Event
+/home/install/workspace/trunk/http/php/mod_export_image.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_export_image.php
+/home/install/workspace/trunk/http/javascripts/mod_selArea1.php	1238739052	0	/home/install/workspace/trunk/http/javascripts/mod_selArea1.php
+/home/install/workspace/trunk/http/javascripts/mod_cardindex.js	1200384689	0	/home/install/workspace/trunk/http/javascripts/mod_cardindex.js
+/home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_add_vendorspecific.php
+/home/install/workspace/trunk/http/php/mb_validateSession.php	1245838522	0	/home/install/workspace/trunk/http/php/mb_validateSession.php
+/home/install/workspace/trunk/http/php/mod_gui_owner.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_owner.php
+/home/install/workspace/trunk/http/extensions/OpenLayers.js	1214236582	0	/home/install/workspace/trunk/http/extensions/OpenLayers.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-cz.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql	1218723822	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_gettext.sql
+/home/install/workspace/trunk/http/include/template_splash.php	1234437340	0	/home/install/workspace/trunk/http/include/template_splash.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql	1243796060	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read.php
+/home/install/workspace/trunk/http/javascripts/mod_owsproxy.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_owsproxy.php
+/home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_dependentIframe.php
+/home/install/workspace/trunk/http/php/mod_editFilteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editFilteredGroup.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php	1245771428	0	/home/install/workspace/trunk/http/javascripts/mod_zoomCoords.php
+/home/install/workspace/trunk/http/php/mod_newGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_newGui.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleSel.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_scaleSel.php
+/home/install/workspace/trunk/http/javascripts/mod_copyright.php	1245779661	0	/home/install/workspace/trunk/http/javascripts/mod_copyright.php
+/home/install/workspace/trunk/http/classes/class_wfs_factory.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_wfs_factory.php
+/home/install/workspace/trunk/http/php/mod_filteredWms_topic.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredWms_topic.php
+/home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_wfs_gazetteer_client.php
+/home/install/workspace/trunk/http/php/mod_button_tooltips.php	1245855574	0	/home/install/workspace/trunk/http/php/mod_button_tooltips.php
+/home/install/workspace/trunk/tools/char_code.php	1152008002	0	/home/install/workspace/trunk/tools/char_code.php
+/home/install/workspace/trunk/http/javascripts/mod_sandclock2.php	1213021102	0	/home/install/workspace/trunk/http/javascripts/mod_sandclock2.php
+/home/install/workspace/trunk/http/extensions/ext_weldMaps.php	1245838522	0	/home/install/workspace/trunk/http/extensions/ext_weldMaps.php
+/home/install/workspace/trunk/http/php/mod_digitize_messages.php	1237899999	0	/home/install/workspace/trunk/http/php/mod_digitize_messages.php
+/home/install/workspace/trunk/http/javascripts/mod_savewmc.php	1231425706	0	/home/install/workspace/trunk/http/javascripts/mod_savewmc.php
+/home/install/workspace/trunk/lib/i18n.php	1208967270	0	/home/install/workspace/trunk/lib/i18n.php
+/home/install/workspace/trunk/http/javascripts/mod_loadwmc.js	1236875384	0	/home/install/workspace/trunk/http/javascripts/mod_loadwmc.js
+/home/install/workspace/trunk/http/classes/class_layer_monitor.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_layer_monitor.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/javascripts/mod_legend.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_legend.php
+/home/install/workspace/trunk/docs/javascript/main.js	1245847652	1	SearchPanel
+/home/install/workspace/trunk/http/javascripts/map_obj.js	1245853941	1	Map
+/home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/initOpenLayersWms.php
+/home/install/workspace/trunk/lib/point.js	1235985010	0	/home/install/workspace/trunk/lib/point.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hu.js
+/home/install/workspace/trunk/http/php/mod_treefolderClient.php	1229692761	0	/home/install/workspace/trunk/http/php/mod_treefolderClient.php
+/home/install/workspace/trunk/http/php/mod_loadCapabilities.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadCapabilities.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pt-BR.js
+/home/install/workspace/trunk/http/php/mod_renameGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_renameGUI.php
+/home/install/workspace/trunk/http/javascripts/mod_print1.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_print1.php
+/home/install/workspace/trunk/http/javascripts/mod_center1.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_center1.php
+/home/install/workspace/trunk/http/extensions/jquery.js	1208966985	0	/home/install/workspace/trunk/http/extensions/jquery.js
+/home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php	1197632053	0	/home/install/workspace/trunk/owsproxy/http/classes/class_QueryHandler.php
+/home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PolygonSymbolizer.php
+/home/install/workspace/trunk/http/javascripts/mod_horizTabs.js	1204803057	0	/home/install/workspace/trunk/http/javascripts/mod_horizTabs.js
+/home/install/workspace/trunk/http/extensions/fisheye.js	1208966985	0	/home/install/workspace/trunk/http/extensions/fisheye.js
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_loadwmc.php	1236782767	0	/home/install/workspace/trunk/http/javascripts/mod_loadwmc.php
+/home/install/workspace/trunk/http/extensions/datepicker/datepicker.js	1208966985	0	/home/install/workspace/trunk/http/extensions/datepicker/datepicker.js
+/home/install/workspace/trunk/http/index.php	1237546299	0	/home/install/workspace/trunk/http/index.php
+/home/install/workspace/trunk/http/php/mod_zoomCoords_en.php	1210165862	0	/home/install/workspace/trunk/http/php/mod_zoomCoords_en.php
+/home/install/workspace/trunk/http/classes/class.ezpdf.php	1200385469	0	/home/install/workspace/trunk/http/classes/class.ezpdf.php
+/home/install/workspace/trunk/http/classes/class_keyword.php	1218442761	0	/home/install/workspace/trunk/http/classes/class_keyword.php
+/home/install/workspace/trunk/lib/resizableButton.js	1214236663	0	/home/install/workspace/trunk/lib/resizableButton.js
+/home/install/workspace/trunk/http/classes/class_locale.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_locale.php
+/home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_gazetteerSQL_client.php
+/home/install/workspace/trunk/docs/Menu_Backup.txt	1245781036	0	/home/install/workspace/trunk/docs/Menu_Backup.txt
+/home/install/workspace/trunk/http/php/mod_mapOV.php	1226479717	0	/home/install/workspace/trunk/http/php/mod_mapOV.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_wfs_1_1_factory.php
+/home/install/workspace/trunk/http/classes/class_user.php	1244215918	0	/home/install/workspace/trunk/http/classes/class_user.php
+/home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php	1232623861	0	/home/install/workspace/trunk/http/javascripts/mod_dragMapSize.php
+/home/install/workspace/trunk/http/sld/classes/UserStyle.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/UserStyle.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-uk.js
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
+/home/install/workspace/trunk/http/php/mod_editApplication_server.php	1214236840	0	/home/install/workspace/trunk/http/php/mod_editApplication_server.php
+/home/install/workspace/trunk/http/php/mod_exportGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_exportGUI.php
+/home/install/workspace/trunk/http/javascripts/mod_navFrame.php	1239028534	0	/home/install/workspace/trunk/http/javascripts/mod_navFrame.php
+/home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_selectMapsize.php
+/home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php	1225983996	0	/home/install/workspace/trunk/http/javascripts/mod_switchLocale_noreload.php
+/home/install/workspace/trunk/http/javascripts/geometry.js	1245779178	0	/home/install/workspace/trunk/http/javascripts/geometry.js
+/home/install/workspace/trunk/http/javascripts/map.js	1245744950	0	/home/install/workspace/trunk/http/javascripts/map.js
+/home/install/workspace/trunk/log/ReadMe.txt	1144962718	0	/home/install/workspace/trunk/log/ReadMe.txt
+/home/install/workspace/trunk/http/classes/class_ows_factory.php	1233742970	0	/home/install/workspace/trunk/http/classes/class_ows_factory.php
+/home/install/workspace/trunk/http/javascripts/map.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/map.php
+/home/install/workspace/trunk/http/classes/class_gml.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml.php
+/home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_weldMaps2PNG.php
+/home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_insertLayerPreviewIntoDb.php
+/home/install/workspace/trunk/http/javascripts/mod_setTimeout.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_setTimeout.php
+/home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js	1236961566	0	/home/install/workspace/trunk/http/extensions/jquery.contextmenu.r2.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single.php
+/home/install/workspace/trunk/Readme.txt	1240853897	0	/home/install/workspace/trunk/Readme.txt
+/home/install/workspace/trunk/lib/ajax.js	1239182831	0	/home/install/workspace/trunk/lib/ajax.js
+/home/install/workspace/trunk/lib/list.js	1213361788	0	/home/install/workspace/trunk/lib/list.js
+/home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php	1236782767	0	/home/install/workspace/trunk/http/php/mod_createJSObjFromXML.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-en.php
+/home/install/workspace/trunk/http/javascripts/mod_poi.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_poi.php
+/home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolder2_multiple.php
+/home/install/workspace/trunk/tools/send_post_curl.php	1243515049	0	/home/install/workspace/trunk/tools/send_post_curl.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php	1237043600	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
+/home/install/workspace/trunk/license/license_js.txt	1150726978	0	/home/install/workspace/trunk/license/license_js.txt
+/home/install/workspace/trunk/lib/class_mapbender_session.php	1245838522	0	/home/install/workspace/trunk/lib/class_mapbender_session.php
+/home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/StyledLayerDescriptor.php
+/home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_mergePolygon.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/img/button_blue/README.TXT	1150456812	0	/home/install/workspace/trunk/http/img/button_blue/README.TXT
+/home/install/workspace/trunk/http/classes/class_metadata.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_metadata.php
+/home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php	1239705380	0	/home/install/workspace/trunk/http/javascripts/mod_addWmsFromFilteredList_button.php
+/home/install/workspace/trunk/http/tmp/ReadMe.txt	1145003810	0	/home/install/workspace/trunk/http/tmp/ReadMe.txt
+/home/install/workspace/trunk/http/classes/class_ows.php	1236703245	0	/home/install/workspace/trunk/http/classes/class_ows.php
+/home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery-1.2.6.min.js
+/home/install/workspace/trunk/http/sld/sld_function_getusersld.php	1231319765	0	/home/install/workspace/trunk/http/sld/sld_function_getusersld.php
+/home/install/workspace/trunk/http/php/mod_gui_user.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_user.php
+/home/install/workspace/trunk/http/extensions/wz_jsgraphics.js	1221663284	0	/home/install/workspace/trunk/http/extensions/wz_jsgraphics.js
+/home/install/workspace/trunk/http/javascripts/initWms.php	1236782767	0	/home/install/workspace/trunk/http/javascripts/initWms.php
+/home/install/workspace/trunk/http/javascripts/mod_back.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_back.php
+/home/install/workspace/trunk/http/php/mod_createCategory.php	1236068706	0	/home/install/workspace/trunk/http/php/mod_createCategory.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
+/home/install/workspace/trunk/http/php/mod_updateWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_updateWMS.php
+/home/install/workspace/trunk/http/sld/classes/ParameterValue.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ParameterValue.php
+/home/install/workspace/trunk/http/php/mod_gazetteer_edit.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteer_edit.php
+/home/install/workspace/trunk/http/classes/class_stripRequest.php	1227687853	0	/home/install/workspace/trunk/http/classes/class_stripRequest.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ca.js
+/home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js	1214236840	0	/home/install/workspace/trunk/http/javascripts/mod_openlayers_layerSwitch.js
+/home/install/workspace/trunk/docs/Topics.txt	1245847652	0	/home/install/workspace/trunk/docs/Topics.txt
+/home/install/workspace/trunk/http/php/mod_usemap.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_usemap.php
+/home/install/workspace/trunk/http/sld/sld_parse.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_parse.php
+/home/install/workspace/trunk/http/include/dyn_js.php	1238749332	0	/home/install/workspace/trunk/http/include/dyn_js.php
+/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_filteredGroup.php
+/home/install/workspace/trunk/http/extensions/jquery.form.js	1236536525	0	/home/install/workspace/trunk/http/extensions/jquery.form.js
+/home/install/workspace/trunk/http/include/dyn_js_object.php	1245648655	0	/home/install/workspace/trunk/http/include/dyn_js_object.php
+/home/install/workspace/trunk/http/classes/class_checkInput.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_checkInput.php
+/home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/UnaryLogicOp.php
+/home/install/workspace/trunk/http/classes/class_gml_multipolygon.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_multipolygon.php
+/home/install/workspace/trunk/http/javascripts/mod_box1.js	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_box1.js
+/home/install/workspace/trunk/http/javascripts/mod_home.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_home.php
+/home/install/workspace/trunk/http/sld/classes/Displacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Displacement.php
+/home/install/workspace/trunk/http/javascripts/mod_scalebar.php	1239704908	0	/home/install/workspace/trunk/http/javascripts/mod_scalebar.php
+/home/install/workspace/trunk/http/classes/class_kml_parser_ows.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_parser_ows.php
+/home/install/workspace/trunk/http/javascripts/mod_displayObj.js	1164286253	0	/home/install/workspace/trunk/http/javascripts/mod_displayObj.js
+/home/install/workspace/trunk/http/sld/classes/ElseFilter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ElseFilter.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-he.js
+/home/install/workspace/trunk/http/javascripts/mod_tab.js	1236949870	0	/home/install/workspace/trunk/http/javascripts/mod_tab.js
+/home/install/workspace/trunk/http/php/mod_gui_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_group.php
+/home/install/workspace/trunk/lib/selectableButton.js	1214236663	0	/home/install/workspace/trunk/lib/selectableButton.js
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql	1238355978	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/javascripts/mod_body.js	1245680608	0	/home/install/workspace/trunk/http/javascripts/mod_body.js
+/home/install/workspace/trunk/http/php/mb_getGUIs.php	1150727701	0	/home/install/workspace/trunk/http/php/mb_getGUIs.php
+/home/install/workspace/trunk/http/javascripts/mod_sandclock.php	1245779179	1	Sandclock
+/home/install/workspace/trunk/http/classes/class_mb_exception.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_mb_exception.php
+/home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/DisplayOperationModule.php
+/home/install/workspace/trunk/http/php/createImageFromText.php	1186565603	0	/home/install/workspace/trunk/http/php/createImageFromText.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ja.js
+/home/install/workspace/trunk/http/php/mod_filteredGui_User.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_User.php
+/home/install/workspace/trunk/http/html/mod_treefolder.php	1208967270	0	/home/install/workspace/trunk/http/html/mod_treefolder.php
+/home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_filteredGroup.php
+/home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/mysql_schema_2.5.sql
+/home/install/workspace/trunk/http/sld/sld_pick_color.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_pick_color.php
+/home/install/workspace/trunk/http/classes/class_wfs_configuration.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_configuration.php
+/home/install/workspace/trunk/core/globalSettings.php	1245838748	0	/home/install/workspace/trunk/core/globalSettings.php
+/home/install/workspace/trunk/http/php/mod_changeEPSG_server.php	1230909423	0	/home/install/workspace/trunk/http/php/mod_changeEPSG_server.php
+/home/install/workspace/trunk/lib/database-mysqli.php	1215768576	0	/home/install/workspace/trunk/lib/database-mysqli.php
+/home/install/workspace/trunk/http/sld/sld_function_handler.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_function_handler.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ro.js
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php	1235406337	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_read_single_diff.php
+/home/install/workspace/trunk/http/classes/class_kml.php	1217937298	0	/home/install/workspace/trunk/http/classes/class_kml.php
+/home/install/workspace/trunk/http/sld/classes/Mark.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Mark.php
+/home/install/workspace/trunk/http/php/mod_exportMapImage_server.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_exportMapImage_server.php
+/home/install/workspace/trunk/http/classes/class_SaveLegend.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_SaveLegend.php
+/home/install/workspace/trunk/owsproxy/http/index.php	1222346431	0	/home/install/workspace/trunk/owsproxy/http/index.php
+/home/install/workspace/trunk/http/sld/classes/LegendGraphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LegendGraphic.php
+/home/install/workspace/trunk/http/frames/cleanurl.php	1208967270	0	/home/install/workspace/trunk/http/frames/cleanurl.php
+/home/install/workspace/trunk/http/javascripts/mod_treeConf.js	1150280597	0	/home/install/workspace/trunk/http/javascripts/mod_treeConf.js
+/home/install/workspace/trunk/http/classes/class_kml_multigeometry.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_multigeometry.php
+/home/install/workspace/trunk/license/gpl.txt	1144962192	0	/home/install/workspace/trunk/license/gpl.txt
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.smtp.php
+/home/install/workspace/trunk/http/php/mod_group_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_filteredGui.php
+/home/install/workspace/trunk/http/sld/classes/Graphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Graphic.php
+/home/install/workspace/trunk/http/php/mod_wfs.php	1245245453	0	/home/install/workspace/trunk/http/php/mod_wfs.php
+/home/install/workspace/trunk/http/classes/class_gml_3_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_3_factory.php
+/home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsNull.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-da.js
+/home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_wfsLayerObj_conf.php
+/home/install/workspace/trunk/lib/customTreeController.js	1236961566	0	/home/install/workspace/trunk/lib/customTreeController.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-de.php
+/home/install/workspace/trunk/http/javascripts/mod_displayWmc.php	1213362274	0	/home/install/workspace/trunk/http/javascripts/mod_displayWmc.php
+/home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_universal_wfs_factory.php
+/home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php	1237887369	0	/home/install/workspace/trunk/http/javascripts/mod_highlightPOI.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ko.js
+/home/install/workspace/trunk/http/classes/class_gui.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_gui.php
+/home/install/workspace/trunk/http/javascripts/mod_measure.php	1241379560	0	/home/install/workspace/trunk/http/javascripts/mod_measure.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php	1208966513	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/mail.php
+/home/install/workspace/trunk/http/javascripts/mod_tooltip.php	1239870590	0	/home/install/workspace/trunk/http/javascripts/mod_tooltip.php
+/home/install/workspace/trunk/http/classes/class_gml_line.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_line.php
+/home/install/workspace/trunk/http/php/mb_listKMLs.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_listKMLs.php
+/home/install/workspace/trunk/http/javascripts/mod_key.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_key.php
+/home/install/workspace/trunk/http/sld/classes/AddOperationModule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/AddOperationModule.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_schema_2.5.sql
+/home/install/workspace/trunk/http/classes/class_kml_placemark.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_placemark.php
+/home/install/workspace/trunk/http/javascripts/mapnf.php	1245778752	0	/home/install/workspace/trunk/http/javascripts/mapnf.php
+/home/install/workspace/trunk/lib/ajax.php	1239182831	0	/home/install/workspace/trunk/lib/ajax.php
+/home/install/workspace/trunk/http/classes/class.pdf.php	1200385469	0	/home/install/workspace/trunk/http/classes/class.pdf.php
+/home/install/workspace/trunk/http/php/mod_category_filteredGUI.php	1245855925	0	/home/install/workspace/trunk/http/php/mod_category_filteredGUI.php
+/home/install/workspace/trunk/license/gpl_short.txt	1144962192	0	/home/install/workspace/trunk/license/gpl_short.txt
+/home/install/workspace/trunk/http/javascripts/wfs.php	1238149835	0	/home/install/workspace/trunk/http/javascripts/wfs.php
+/home/install/workspace/trunk/http/classes/class_kml_polygon.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_polygon.php
+/home/install/workspace/trunk/http/php/mod_edit_element_vars.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_edit_element_vars.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_pan.php	1239119530	0	/home/install/workspace/trunk/http/javascripts/mod_pan.php
+/home/install/workspace/trunk/http/javascripts/core.php	1245856626	1	Mapbender
+/home/install/workspace/trunk/http/classes/class_wms.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wms.php
+/home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteFilteredGUI.php
+/home/install/workspace/trunk/docs/Languages.txt	1245847652	0	/home/install/workspace/trunk/docs/Languages.txt
+/home/install/workspace/trunk/http/sld/classes/Rule.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Rule.php
+/home/install/workspace/trunk/lib/div.js	1232466013	0	/home/install/workspace/trunk/lib/div.js
+/home/install/workspace/trunk/http/php/mod_map1.php	1226479717	0	/home/install/workspace/trunk/http/php/mod_map1.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMS.php	1245772744	0	/home/install/workspace/trunk/http/javascripts/mod_addWMS.php
+/home/install/workspace/trunk/http/php/mod_orphanWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_orphanWMS.php
+/home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_setBackground_all.php
+/home/install/workspace/trunk/http/classes/class_gml_envelope.php	1233657361	0	/home/install/workspace/trunk/http/classes/class_gml_envelope.php
+/home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazLayerObj_edit.php
+/home/install/workspace/trunk/http/javascripts/mod_horizTab.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_horizTab.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromList.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-no.php
+/home/install/workspace/trunk/docs/Menu.txt	1245847652	0	/home/install/workspace/trunk/docs/Menu.txt
+/home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js	1214236582	0	/home/install/workspace/trunk/http/extensions/jquery.mousewheel.min.js
+/home/install/workspace/trunk/http/print/print_functions.php	1218808363	0	/home/install/workspace/trunk/http/print/print_functions.php
+/home/install/workspace/trunk/http/classes/class_gml2.php	1229347647	0	/home/install/workspace/trunk/http/classes/class_gml2.php
+/home/install/workspace/trunk/http/php/mod_editApplication.php	1237368148	0	/home/install/workspace/trunk/http/php/mod_editApplication.php
+/home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazLayerObj_conf.php
+/home/install/workspace/trunk/http/javascripts/mod_selArea.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_selArea.php
+/home/install/workspace/trunk/http/classes/class_gml_feature.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml_feature.php
+/home/install/workspace/trunk/sql/update_wfs_conf_element.sql	1245418009	0	/home/install/workspace/trunk/sql/update_wfs_conf_element.sql
+/home/install/workspace/trunk/http/extensions/jqjson.js	1191832183	0	/home/install/workspace/trunk/http/extensions/jqjson.js
+/home/install/workspace/trunk/http/php/mod_editElementVars.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editElementVars.php
+/home/install/workspace/trunk/http/php/mod_layerMetadata.php	1209634442	0	/home/install/workspace/trunk/http/php/mod_layerMetadata.php
+/home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php	1230887236	0	/home/install/workspace/trunk/http/javascripts/mod_dependentDiv.php
+/home/install/workspace/trunk/http/javascripts/mod_forward.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_forward.php
+/home/install/workspace/trunk/http/php/mod_createUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_createUser.php
+/home/install/workspace/trunk/http/sld/classes/CssParameter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/CssParameter.php
+/home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/FeatureTypeStyle.php
+/home/install/workspace/trunk/http/javascripts/mod_fisheye.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_fisheye.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_filteredGroup.php
+/home/install/workspace/trunk/http/php/mod_loadwms_temp.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadwms_temp.php
+/home/install/workspace/trunk/resources/db/reload.sql	1245681909	0	/home/install/workspace/trunk/resources/db/reload.sql
+/home/install/workspace/trunk/http/sld/classes/DbUtils.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/DbUtils.php
+/home/install/workspace/trunk/http/php/mod_user_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_filteredGui.php
+/home/install/workspace/trunk/sql/update_wfs_conf.sql	1244558916	0	/home/install/workspace/trunk/sql/update_wfs_conf.sql
+/home/install/workspace/trunk/http/classes/class_mb_log.php	1208966371	0	/home/install/workspace/trunk/http/classes/class_mb_log.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_1.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs_1_1.php
+/home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php	1237200458	0	/home/install/workspace/trunk/http/javascripts/mod_dynamicOverview.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_User.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_User.php
+/home/install/workspace/trunk/http/classes/class_kml_ows.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_kml_ows.php
+/home/install/workspace/trunk/http/php/nestedSets.php	1218790491	0	/home/install/workspace/trunk/http/php/nestedSets.php
+/home/install/workspace/trunk/http/sld/classes/Halo.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Halo.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-it.js
+/home/install/workspace/trunk/tools/mapbender_setup.php	1227084639	0	/home/install/workspace/trunk/tools/mapbender_setup.php
+/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGroup_filteredGui.php
+/home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js	1229072942	0	/home/install/workspace/trunk/http/javascripts/mod_adminNavigation.js
+/home/install/workspace/trunk/lib/class_Singleton.php	1245838522	0	/home/install/workspace/trunk/lib/class_Singleton.php
+/home/install/workspace/trunk/tools/mapFiler.php	1231858528	0	/home/install/workspace/trunk/tools/mapFiler.php
+/home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gazetteerSQL_server.php
+/home/install/workspace/trunk/http/javascripts/wfsFilter.js	1236351449	0	/home/install/workspace/trunk/http/javascripts/wfsFilter.js
+/home/install/workspace/trunk/http/php/mod_editGroup.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editGroup.php
+/home/install/workspace/trunk/sql/insert_wfs_conf_element.sql	1245246454	0	/home/install/workspace/trunk/sql/insert_wfs_conf_element.sql
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sv.js
+/home/install/workspace/trunk/license/Liberation-License.txt	1237290442	0	/home/install/workspace/trunk/license/Liberation-License.txt
+/home/install/workspace/trunk/http/php/mod_user_gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_gui.php
+/home/install/workspace/trunk/http/php/mod_wfs_server.php	1237225534	0	/home/install/workspace/trunk/http/php/mod_wfs_server.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
+/home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php	1230894465	0	/home/install/workspace/trunk/http/javascripts/mod_resize_mapsize.php
+/home/install/workspace/trunk/http/php/mod_customTree.php	1236961566	0	/home/install/workspace/trunk/http/php/mod_customTree.php
+/home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_saveWmcKml.php
+/home/install/workspace/trunk/http/php/mod_editGuiWms.php	1236956732	0	/home/install/workspace/trunk/http/php/mod_editGuiWms.php
+/home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_differencePolygon.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lv.js
+/home/install/workspace/trunk/http/php/mod_group_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_editUser.php	1225985335	0	/home/install/workspace/trunk/http/php/mod_editUser.php
+/home/install/workspace/trunk/http/php/mod_customTree_server.php	1245856564	0	/home/install/workspace/trunk/http/php/mod_customTree_server.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-se.php
+/home/install/workspace/trunk/http/php/mod_displayKML.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_displayKML.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-lt.js
+/home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php	1236875614	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfoTunnel.php
+/home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php	1245413563	0	/home/install/workspace/trunk/http/javascripts/mod_digitize_tab.php
+/home/install/workspace/trunk/http/classes/class_element.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_element.php
+/home/install/workspace/trunk/http/classes/class_json.php	1227084639	0	/home/install/workspace/trunk/http/classes/class_json.php
+/home/install/workspace/trunk/http/classes/class_bbox.php	1231151408	0	/home/install/workspace/trunk/http/classes/class_bbox.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/mysql_data_2.5.sql
+/home/install/workspace/trunk/http/classes/class_gml_polygon.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_polygon.php
+/home/install/workspace/trunk/http/javascripts/mod_perimeter.php	1214236736	0	/home/install/workspace/trunk/http/javascripts/mod_perimeter.php
+/home/install/workspace/trunk/http/extensions/DifferenceEngine.php	1235406337	0	/home/install/workspace/trunk/http/extensions/DifferenceEngine.php
+/home/install/workspace/trunk/http/sld/classes/Filter.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Filter.php
+/home/install/workspace/trunk/http/php/mod_showLoggedUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_showLoggedUser.php
+/home/install/workspace/trunk/http/php/mod_treefolderAdmin.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_treefolderAdmin.php
+/home/install/workspace/trunk/http/classes/class_kml_line.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_line.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf.php	1235136381	0	/home/install/workspace/trunk/http/php/mod_wfs_conf.php
+/home/install/workspace/trunk/http/html/mod_sync_treefolder.php	1208967270	0	/home/install/workspace/trunk/http/html/mod_sync_treefolder.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ar.js
+/home/install/workspace/trunk/http/php/mod_getStyles.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_getStyles.php
+/home/install/workspace/trunk/http/php/mod_forgottenPassword.php	1229013681	0	/home/install/workspace/trunk/http/php/mod_forgottenPassword.php
+/home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php	1230887236	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfoRedirect.php
+/home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql	1214236631	0	/home/install/workspace/trunk/resources/db/pgsql/openlayers_application.sql
+/home/install/workspace/trunk/http/javascripts/mod_add_SLD.php	1236875384	0	/home/install/workspace/trunk/http/javascripts/mod_add_SLD.php
+/home/install/workspace/trunk/http/php/mod_gui_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_gui_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_loadwmc_server.php	1240923997	0	/home/install/workspace/trunk/http/php/mod_loadwmc_server.php
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/pgsql_data_2.5.sql
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fr.js
+/home/install/workspace/trunk/http/php/mod_owsproxy_conf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_owsproxy_conf.php
+/home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql	1218723822	0	/home/install/workspace/trunk/resources/db/mysql/mysql_gettext.sql
+/home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_simpleWMSpreferences.php
+/home/install/workspace/trunk/http/extensions/jquery.tablesorter.js	1234864590	0	/home/install/workspace/trunk/http/extensions/jquery.tablesorter.js
+/home/install/workspace/trunk/http/php/mod_savewmc_server.php	1240921307	0	/home/install/workspace/trunk/http/php/mod_savewmc_server.php
+/home/install/workspace/trunk/lib/buttonNew.js	1236875384	0	/home/install/workspace/trunk/lib/buttonNew.js
+/home/install/workspace/trunk/http/javascripts/mod_usemap.php	1213021210	0	/home/install/workspace/trunk/http/javascripts/mod_usemap.php
+/home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php	1235475918	0	/home/install/workspace/trunk/http/php/mod_gazetteerMetadata.php
+/home/install/workspace/trunk/http/javascripts/mod_repaint.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_repaint.php
+/home/install/workspace/trunk/http/javascripts/ovnf.php	1245778750	0	/home/install/workspace/trunk/http/javascripts/ovnf.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-pl.js
+/home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php	1236005925	0	/home/install/workspace/trunk/http/php/mod_wfs_gazetteer_server.php
+/home/install/workspace/trunk/tools/send_post.php	1186389031	0	/home/install/workspace/trunk/tools/send_post.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-bg.js
+/home/install/workspace/trunk/core/i18n.php	1245838522	0	/home/install/workspace/trunk/core/i18n.php
+/home/install/workspace/trunk/http/classes/class_wmcToXml.php	1236782767	0	/home/install/workspace/trunk/http/classes/class_wmcToXml.php
+/home/install/workspace/trunk/http/javascripts/wfs_obj.js	1208967664	0	/home/install/workspace/trunk/http/javascripts/wfs_obj.js
+/home/install/workspace/trunk/http/classes/class_kml_geometry.php	1216711579	0	/home/install/workspace/trunk/http/classes/class_kml_geometry.php
+/home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js	1235982146	0	/home/install/workspace/trunk/http/javascripts/requestGeometryConstructor.js
+/home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_Gui.php
+/home/install/workspace/trunk/http/javascripts/mod_loadKML.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_loadKML.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/classes/class_gml_point.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_point.php
+/home/install/workspace/trunk/http/classes/class_wfs_deprecated.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfs_deprecated.php
+/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php	1214236698	0	/home/install/workspace/trunk/http/php/mod_addWmsFromFeatureInfo.php
+/home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/RasterSymbolizer.php
+/home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT	1237290442	0	/home/install/workspace/trunk/license/bitstream-COPYRIGHT.TXT
+/home/install/workspace/trunk/http/classes/class_gml_2_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_2_factory.php
+/home/install/workspace/trunk/http/extensions/geom2wfst.php	1235739677	0	/home/install/workspace/trunk/http/extensions/geom2wfst.php
+/home/install/workspace/trunk/lib/button.js	1230887532	0	/home/install/workspace/trunk/lib/button.js
+/home/install/workspace/trunk/http/php/mod_filteredUser_Group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredUser_Group.php
+/home/install/workspace/trunk/http/sld/classes/NamedLayer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/NamedLayer.php
+/home/install/workspace/trunk/http/php/mod_wfs_edit.php	1238145768	0	/home/install/workspace/trunk/http/php/mod_wfs_edit.php
+/home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php	1245854203	0	/home/install/workspace/trunk/http/php/mod_addWMSfromfilteredList_server.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_filteredUser.php
+/home/install/workspace/trunk/http/php/mod_editSelf.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editSelf.php
+/home/install/workspace/trunk/http/javascripts/mod_saveWKT.js	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_saveWKT.js
+/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
+/home/install/workspace/trunk/Install.txt	1237308524	0	/home/install/workspace/trunk/Install.txt
+/home/install/workspace/trunk/http/javascripts/mod_openlayers.php	1214236840	0	/home/install/workspace/trunk/http/javascripts/mod_openlayers.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-hy.js
+/home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_insertKmlIntoDb.php
+/home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php	1208967270	0	/home/install/workspace/trunk/tools/mod_monitorCapabilities_write.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js	1244215918	0	/home/install/workspace/trunk/http/extensions/jquery-ui-1.7.1.w.o.effects.min.js
+/home/install/workspace/trunk/http/php/mod_group_gui.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_gui.php
+/home/install/workspace/trunk/http/php/mod_group_user.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_group_user.php
+/home/install/workspace/trunk/http/php/mod_deleteGUI.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteGUI.php
+/home/install/workspace/trunk/lib/customTreeModel.js	1236961566	0	/home/install/workspace/trunk/lib/customTreeModel.js
+/home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsLike.php
+/home/install/workspace/trunk/http/sld/sld_config.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_config.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js	1245314856	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_interface.js
+/home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_exportMapImage.php
+/home/install/workspace/trunk/http/javascripts/mod_log.php	1216711579	0	/home/install/workspace/trunk/http/javascripts/mod_log.php
+/home/install/workspace/trunk/http/classes/class_wmc.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wmc.php
+/home/install/workspace/trunk/http/php/mod_printView1.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_printView1.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-de.js
+/home/install/workspace/trunk/Changes.txt	1237308497	0	/home/install/workspace/trunk/Changes.txt
+/home/install/workspace/trunk/http/classes/class_map.php	1236951293	0	/home/install/workspace/trunk/http/classes/class_map.php
+/home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_featuretypeMetadata.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-fr.php
+/home/install/workspace/trunk/http/sld/sld_filter_parse.php	1208967270	0	/home/install/workspace/trunk/http/sld/sld_filter_parse.php
+/home/install/workspace/trunk/http/javascripts/mod_setBackground.php	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_setBackground.php
+/home/install/workspace/trunk/lib/basic.js	1240904723	0	/home/install/workspace/trunk/lib/basic.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-th.js
+/home/install/workspace/trunk/http/php/mod_editElements.php	1245746857	0	/home/install/workspace/trunk/http/php/mod_editElements.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-fi.js
+/home/install/workspace/trunk/http/php/mod_exportElement.php	1242242094	0	/home/install/workspace/trunk/http/php/mod_exportElement.php
+/home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php	1223458316	0	/home/install/workspace/trunk/http/php/mod_digitize_splitPolygon.php
+/home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js	1164040412	0	/home/install/workspace/trunk/http/javascripts/mod_permanentHighlight.js
+/home/install/workspace/trunk/http/print/mod_printPDF.php	1237200647	0	/home/install/workspace/trunk/http/print/mod_printPDF.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-es.js
+/home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ExternalGraphic.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-sk.js
+/home/install/workspace/trunk/http/php/mod_deleteWMS.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_deleteWMS.php
+/home/install/workspace/trunk/http/php/mod_user_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_user_group.php
+/home/install/workspace/trunk/http/classes/class_connector.php	1239128635	0	/home/install/workspace/trunk/http/classes/class_connector.php
+/home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/LineSymbolizer.php
+/home/install/workspace/trunk/http/php/mod_meetingPoint.php	1237887556	0	/home/install/workspace/trunk/http/php/mod_meetingPoint.php
+/home/install/workspace/trunk/http/javascripts/mod_renderGML.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_renderGML.php
+/home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php	1186386971	0	/home/install/workspace/trunk/http/classes/class_weldOverview2PNG.php
+/home/install/workspace/trunk/http/extensions/markResult.php	1208966985	0	/home/install/workspace/trunk/http/extensions/markResult.php
+/home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/BinaryLogicOp.php
+/home/install/workspace/trunk/http/javascripts/mod_reload.php	1245856626	1	Reload
+/home/install/workspace/trunk/http/include/gui1_splash.php	1231153927	0	/home/install/workspace/trunk/http/include/gui1_splash.php
+/home/install/workspace/trunk/http/php/mod_logout.php	1218442761	0	/home/install/workspace/trunk/http/php/mod_logout.php
+/home/install/workspace/trunk/core/system.php	1245772744	0	/home/install/workspace/trunk/core/system.php
+/home/install/workspace/trunk/http/classes/class_wfs.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs.php
+/home/install/workspace/trunk/http/classes/class_universal_gml_factory.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_universal_gml_factory.php
+/home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PointSymbolizer.php
+/home/install/workspace/trunk/http/php/mod_SelectKeyword.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_SelectKeyword.php
+/home/install/workspace/trunk/http/sld/classes/AnchorPoint.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/AnchorPoint.php
+/home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PropertyIsBetween.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_loadwms.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadwms.php
+/home/install/workspace/trunk/http/extensions/JSON.php	1173171435	0	/home/install/workspace/trunk/http/extensions/JSON.php
+/home/install/workspace/trunk/http/sld/classes/Stroke.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/Stroke.php
+/home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php	1232465591	0	/home/install/workspace/trunk/http/javascripts/mod_changeEPSG.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php	1245856041	0	/home/install/workspace/trunk/http/php/mod_changeEPSG_dynamic.php
+/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js	1236961566	0	/home/install/workspace/trunk/http/extensions/jquery-ui-personalized-1.5.2.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/class.phpmailer.php
+/home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ColorMapEntry.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php	1245779180	1	ZoomIn1
+/home/install/workspace/trunk/sql/insert_wfs_conf.sql	1244558916	0	/home/install/workspace/trunk/sql/insert_wfs_conf.sql
+/home/install/workspace/trunk/http/classes/class_mb_warning.php	1199464420	0	/home/install/workspace/trunk/http/classes/class_mb_warning.php
+/home/install/workspace/trunk/http/sld/classes/PointPlacement.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/PointPlacement.php
+/home/install/workspace/trunk/http/php/mod_setLocale.php	1216713787	0	/home/install/workspace/trunk/http/php/mod_setLocale.php
+/home/install/workspace/trunk/http/javascripts/wms.js	1238749127	0	/home/install/workspace/trunk/http/javascripts/wms.js
+/home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredWms_layer_topic.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js
+/home/install/workspace/trunk/http/php/mod_editFilteredUser.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editFilteredUser.php
+/home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php	1239129168	0	/home/install/workspace/trunk/http/javascripts/mod_setBBOX1.php
+/home/install/workspace/trunk/http/php/mod_updateKmlInDb.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_updateKmlInDb.php
+/home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql	1153388414	0	/home/install/workspace/trunk/tools/wms_extent/wms_geometry.sql
+/home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php	1230887149	0	/home/install/workspace/trunk/http/javascripts/mod_setPOI2Scale.php
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-zh-TW.js
+/home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php	1236703351	0	/home/install/workspace/trunk/http/classes/class_wfs_1_0_factory.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php	1245838522	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSfromfilteredListDB.php
+/home/install/workspace/trunk/http/php/mod_loadwfs.php	1236703245	0	/home/install/workspace/trunk/http/php/mod_loadwfs.php
+/home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_loadWFSCapabilities.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/classes/class_gml_factory.php	1239895398	0	/home/install/workspace/trunk/http/classes/class_gml_factory.php
+/home/install/workspace/trunk/http/php/mod_filteredGui_group.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_filteredGui_group.php
+/home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php	1245856324	0	/home/install/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
+/home/install/workspace/trunk/http/php/mb_listGUIs.php	1236876057	0	/home/install/workspace/trunk/http/php/mb_listGUIs.php
+/home/install/workspace/trunk/http/javascripts/jsTree.js	1230902123	0	/home/install/workspace/trunk/http/javascripts/jsTree.js
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-it.php
+/home/install/workspace/trunk/http/javascripts/mod_initWmc.php	1231425706	0	/home/install/workspace/trunk/http/javascripts/mod_initWmc.php
+/home/install/workspace/trunk/http/sld/classes/ColorMap.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/ColorMap.php
+/home/install/workspace/trunk/http/javascripts/mod_scaleHint.php	1237199301	0	/home/install/workspace/trunk/http/javascripts/mod_scaleHint.php
+/home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php	1245779180	0	/home/install/workspace/trunk/http/javascripts/mod_zoomOut1.php
+/home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_createJSLayerObjFromXML.php
+/home/install/workspace/trunk/http/php/mb_js_exception.php	1208967664	0	/home/install/workspace/trunk/http/php/mb_js_exception.php
+/home/install/workspace/trunk/http/html/mod_treefolderPlain.php	1245838522	0	/home/install/workspace/trunk/http/html/mod_treefolderPlain.php
+/home/install/workspace/trunk/http/frames/index.php	1245838522	0	/home/install/workspace/trunk/http/frames/index.php
+/home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js	1208966985	0	/home/install/workspace/trunk/http/extensions/jquery.ajaxmanager.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-nl.js
+/home/install/workspace/trunk/http/classes/class_gml_geometry.php	1234978564	0	/home/install/workspace/trunk/http/classes/class_gml_geometry.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-tr.php
+/home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js	1244215918	0	/home/install/workspace/trunk/http/extensions/jquery-1.3.2.min.js
+/home/install/workspace/trunk/tools/url_code.php	1164106450	0	/home/install/workspace/trunk/tools/url_code.php
+/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
+/home/install/workspace/trunk/http/classes/class_gml_3.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_gml_3.php
+/home/install/workspace/trunk/http/php/mod_WMSpreferences.php	1236330438	0	/home/install/workspace/trunk/http/php/mod_WMSpreferences.php
+/home/install/workspace/trunk/http/javascripts/mod_featureInfo.php	1240326844	0	/home/install/workspace/trunk/http/javascripts/mod_featureInfo.php
+/home/install/workspace/trunk/http/javascripts/mod_coords_div.php	1230893633	0	/home/install/workspace/trunk/http/javascripts/mod_coords_div.php
+/home/install/workspace/trunk/http/php/mod_log.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_log.php
+/home/install/workspace/trunk/http/php/mod_changePassword.php	1245856206	0	/home/install/workspace/trunk/http/php/mod_changePassword.php
+/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	1237306575	0	/home/install/workspace/trunk/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
+/home/install/workspace/trunk/http/javascripts/mod_tab.php	1208967664	0	/home/install/workspace/trunk/http/javascripts/mod_tab.php
+/home/install/workspace/trunk/http/javascripts/mod_help.php	1245779179	0	/home/install/workspace/trunk/http/javascripts/mod_help.php
+/home/install/workspace/trunk/http/classes/class_kml_linearring.php	1222869057	0	/home/install/workspace/trunk/http/classes/class_kml_linearring.php
+/home/install/workspace/trunk/http/classes/class_monitor.php	1235406337	0	/home/install/workspace/trunk/http/classes/class_monitor.php
+/home/install/workspace/trunk/http/classes/class_log.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_log.php
+/home/install/workspace/trunk/http/php/mod_wfs_conf_server.php	1244215918	0	/home/install/workspace/trunk/http/php/mod_wfs_conf_server.php
+/home/install/workspace/trunk/lib/database-mysql.php	1220516326	0	/home/install/workspace/trunk/lib/database-mysql.php
+/home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editWMS_Metadata.php
+/home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_editGuiWmsMeta.php
+/home/install/workspace/trunk/http/classes/class_wfs_1_0.php	1235985010	0	/home/install/workspace/trunk/http/classes/class_wfs_1_0.php
+/home/install/workspace/trunk/http/classes/class_wfsToDb.php	1245838522	0	/home/install/workspace/trunk/http/classes/class_wfsToDb.php
+/home/install/workspace/trunk/http/php/mod_evalArea.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_evalArea.php
+/home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php	1238152673	0	/home/install/workspace/trunk/http/javascripts/mod_wfs_SpatialRequest.php
+/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql	1237306055	0	/home/install/workspace/trunk/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
+/home/install/workspace/trunk/resources/db/update/update_2.7.sql	1245745690	0	/home/install/workspace/trunk/resources/db/update/update_2.7.sql
+/home/install/workspace/trunk/http/php/mod_edit_metadata.php	1208967664	0	/home/install/workspace/trunk/http/php/mod_edit_metadata.php
+/home/install/workspace/trunk/http/php/mod_showGuiName.php	1221056958	0	/home/install/workspace/trunk/http/php/mod_showGuiName.php
+/home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js	1234281206	0	/home/install/workspace/trunk/http/javascripts/mod_addWMSgeneralFunctions.js
+/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js	1244216857	0	/home/install/workspace/trunk/http/extensions/i18n/ui.datepicker-is.js
+/home/install/workspace/trunk/http/javascripts/mod_zoomFull.php	1245779180	0	/home/install/workspace/trunk/http/javascripts/mod_zoomFull.php
+/home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/TextSymbolizer.php
+/home/install/workspace/trunk/lib/saveButton.js	1214236663	0	/home/install/workspace/trunk/lib/saveButton.js
+/home/install/workspace/trunk/http/classes/class_gml_2.php	1234978564	0	/home/install/workspace/trunk/http/classes/class_gml_2.php
+/home/install/workspace/trunk/http/include/dyn_php.php	1200384506	0	/home/install/workspace/trunk/http/include/dyn_php.php
+/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php	1144957108	0	/home/install/workspace/trunk/http/classes/phpmailer-1.72/language/phpmailer.lang-es.php
+/home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php	1208967270	0	/home/install/workspace/trunk/http/sld/classes/BinaryComparisonOp.php
+/home/install/workspace/trunk/http/extensions/json.js	1190794313	0	/home/install/workspace/trunk/http/extensions/json.js
Deleted: branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd
--- trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,3 +0,0 @@
-(    B/home/install/workspace/trunk/http/img/button_gray/addlist_off.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blink_red/pan_on.pngD>­¡  L/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/repaint_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_over.pngD—΃  @/home/install/workspace/trunk/http/img/button_gray/user_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/openlayers/east-mini.pngHw]à  F/home/install/workspace/trunk/http/img/button_digitize/new_node_on.pngD™@Ò  D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/query_off.pngD’“ì  J/home/install/workspace/trunk/http/img/button_silver_blue/measure_over.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/pan_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/back_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/add_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_gray/select_point_over.pngD–€‰  </home/install/workspace/trunk/http/img/openlayers/marker.pngHw]à  E/home/install/workspace/trunk/http/img/button_digitize/geomRemove.pngIäà  F/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_on.pngD>­¡  :/home/install/workspace/trunk/http/img/arrows/arrow_ne.gifD>¬¡  ?/home/install/workspace/trunk/http/img/button_gray/query_on.pngD>¯g  F/home/install/workspace/trunk/http/img/button_digitize/polygon_off.pngD™@Ò  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_on.pngHZ3£  U/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_plus.gifJ)?›  I/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/help3_off.pngD>­¡  K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blue/select_point_on.pngD–€Z  H/home/install/workspace/trunk/http/img/openlayers/measuring-stick-on.pngHw]à  H/home/install/workspace/trunk/http/img/button_gray/select_choose_off.pngD–€‰  F/home/install/workspace/trunk/http/img/button_blink_red/print_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_digitize/point_over.pngD™@Ò  I/home/install/workspace/trunk/http/img/button_blue/select_choose_over.pngD–€Z  I/home/install/workspace/trunk/http/img/button_silver_blue/polygon_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_gray/print_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/forward_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/coods_off.pngD>¯g  :/home/install/workspace/trunk/http/img/indicator_wheel.gifFå
-  A/home/install/workspace/trunk/http/img/button_gray/query_over.pngD>¯g  K/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/leg_over.pngHZ3£  9/home/install/workspace/trunk/http/img/arrows/arrow_w.gifD>¬¡  G/home/install/workspace/trunk/http/img/button_blink_red/selArea_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/reload_over.pngHb¸  9/home/install/workspace/trunk/http/img/arrows/arrow_s.gifD>¬¡  A/home/install/workspace/trunk/http/img/button_gray/measure_on.pngD>¯g  E/home/install/workspace/trunk/http/img/button_gray/metadata_layer.gifEè3€  K/home/install/workspace/trunk/http/img/button_blink_red/preferences_off.pngD>­¡  C/home/install/workspace/trunk/http/img/button_gray/perimeter_on.pngDFYÌ  F/home/install/workspace/trunk/http/img/button_blink_red/repaint_on.pngD>­¡  =/home/install/workspace/trunk/http/img/openlayers/zoombar.pngHw]à  I/home/install/workspace/trunk/http/css/images/ui-icons_888888_256x240.pngJ)>©  E/home/install/workspace/trunk/http/img/button_silver_blue/help_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_silver_blue/add_on.pngHZ3£  //home/install/workspace/trunk/http/img/help.pngJ8½Ã  D/home/install/workspace/trunk/http/img/button_gray/zoomfull2_off.pngD>¯g  ;/home/install/workspace/trunk/http/img/trafficlights/go.bmpDHþ  D/home/install/workspace/trunk/http/img/button_blink_red/tiles_on.pngD>­¡  =/home/install/workspace/trunk/http/img/trafficlights/wait.bmpDHþ  C/home/install/workspace/trunk/http/img/button_gray/metadata_off.pngD>½È  H/home/install/workspace/trunk/http/img/button_silver_blue/repaint_on.pngHZ3£  L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_on.pngD—΃  I/home/install/workspace/trunk/http/img/button_blink_red/metadata_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/repaint_off.pngD>­¡  9/home/install/workspace/trunk/http/img/mapbender_logo.pngD>±h  D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.gifD>¯g  a/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_leftright.gifJ)?›  R/home/install/workspace/trunk/http/img/button_silver_blue/forward_off_disabled.pngHZ3£  E/home/install/workspace/trunk/http/img/openlayers/panning-hand-on.pngHw]à  G/home/install/workspace/trunk/http/img/button_digitize/new_node_off.pngD™@Ò  E/home/install/workspace/trunk/http/img/button_blink_red/query_off.pngD>­¡  M/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_off.pngE5±  H/home/install/workspace/trunk/http/img/button_silver_blue/center_off.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/addlist_on.pngD>­¡  A/home/install/workspace/trunk/http/img/button_gray/rubber_off.gifD>¯g  9/home/install/workspace/trunk/http/img/arrows/arrow_n.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.gifD>½È  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_doc.gifJ)?›  H/home/install/workspace/trunk/http/img/button_silver_blue/logout_off.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/help_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/coords_on.pngD>½È  ;/home/install/workspace/trunk/http/img/tree_orange/file.gifD>°Ø  B/home/install/workspace/trunk/http/img/button_blue/metadata_on.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/add_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_blue/select_extent_over.pngD–€Z  G/home/install/workspace/trunk/http/img/button_digitize/move_node_on.pngD™@Ò  @/home/install/workspace/trunk/http/img/button_gray/print_off.gifD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_closed.gifJ)?›  9/home/install/workspace/trunk/http/img/tree_gray/file.gifD>°¤  5/home/install/workspace/trunk/http/img/close_icon.pngFú“  >/home/install/workspace/trunk/http/img/button_gray/help_on.pngD>¯g  T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_down.gifJ)?›  F/home/install/workspace/trunk/http/img/button_blue/preferences_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/selArea_on.gifD>½È  A/home/install/workspace/trunk/http/img/button_blue/rubber_off.pngD’“ì  V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_close.gifJ)?›  K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blue/select_choose_on.pngD–€Z  >/home/install/workspace/trunk/http/img/tree_gray/folder_on.gifD>°¤  E/home/install/workspace/trunk/http/img/openlayers/zoom-world-mini.pngHw]à  >/home/install/workspace/trunk/http/img/button_blue/pan_off.pngHb¸  5/home/install/workspace/trunk/http/img/OSGeo_logo.pngIÃrÄ  U/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_plus.gifJ)?›  >/home/install/workspace/trunk/http/img/button_gray/pan_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/user_off.gifD>½È  H/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off.pngHZ3£  9/home/install/workspace/trunk/http/img/button_gray/up.pngDÀ¼
-  B/home/install/workspace/trunk/http/img/button_digitize/line_on.pngD™Ao  8/home/install/workspace/trunk/http/img/tree_new/hide.pngE´l  A/home/install/workspace/trunk/http/img/button_gray/addlist_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_silver_blue/metadata_on.pngHZ3£  K/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_off.pngHZ3£  H/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-off.pngHw]à  J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.gifD>¯g  :/home/install/workspace/trunk/http/sld/img/script_save.pngH`f  B/home/install/workspace/trunk/http/img/button_gray/wmc_save_on.pngD>¯g  D/home/install/workspace/trunk/http/img/button_blink_red/down_off.pngH_ÇM  G/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_on.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/leg_over.pngD>½È  //home/install/workspace/trunk/http/img/desc.gifIš‰û  M/home/install/workspace/trunk/http/img/button_silver_blue/preferences_off.pngHZ3£  K/home/install/workspace/trunk/http/img/button_blue/select_rectangle_off.pngD–€Z  7/home/install/workspace/trunk/http/img/wfs_digitize.pngDš‘ï  O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_over.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/preferences_over.pngHZ3£  P/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/tree_new/last_closed.pngE´l  G/home/install/workspace/trunk/http/img/button_silver_blue/logout_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_digitize/trans.pngD>®  F/home/install/workspace/trunk/http/img/button_blink_red/coords_off.pngD>­¡  U/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_plus.gifJ)?›  V/home/install/workspace/trunk/http/css/images/ui-bg_highlight-soft_75_cccccc_1x100.pngJ)>©  >/home/install/workspace/trunk/http/img/button_gray/add_off.pngD>¯g  D/home/install/workspace/trunk/http/img/button_digitize/geomClone.pngIÈÚß  F/home/install/workspace/trunk/http/img/button_gray/preferences_off.pngD>½È  O/home/install/workspace/trunk/http/img/button_blink_red/change_password_off.pngD>­¡  I/home/install/workspace/trunk/http/img/button_gray/select_polygon_off.pngD–€‰  a/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_02_glass_65.pngJ)?›  L/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_off.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.gifD>¯g  P/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blink_red/up_on.pngH_ÇM  L/home/install/workspace/trunk/http/img/button_gray/select_rectangle_over.pngD–€‰  B/home/install/workspace/trunk/http/img/button_blue/zoomOut2_on.pngD’“ì  P/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/coords_off.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/select_choose_off.pngD–€Z  4/home/install/workspace/trunk/http/img/sandclock.gifD>±h  >/home/install/workspace/trunk/http/img/button_gray/add_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_digitize/line_off.pngD™Ao  C/home/install/workspace/trunk/http/img/button_gray/metadata_wms.gifEè3¹  O/home/install/workspace/trunk/http/img/button_silver_blue/select_point_over.pngHZ3£  9/home/install/workspace/trunk/http/img/tree_blue/file.gifD’¥â  >/home/install/workspace/trunk/http/img/button_blue/back_on.pngD’“ì  B/home/install/workspace/trunk/http/img/button_gray/center_over.gifD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/back_on_disabled.pngHZ3£  E/home/install/workspace/trunk/http/img/button_silver_blue/add_off.pngHZ3£  >/home/install/workspace/trunk/http/img/button_blue/add_off.pngD’“ì  B/home/install/workspace/trunk/http/img/button_blue/zoomFull_on.pngD’“ì  T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_down.gifJ)?›  A/home/install/workspace/trunk/http/img/button_gray/rubber_off.pngD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/user_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_digitize/move_node_over.pngD™@Ò  C/home/install/workspace/trunk/http/img/button_gray/selArea_over.gifD>¯g  2/home/install/workspace/trunk/http/img/no_info.gifD>±h  Q/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_off.pngD>­¡  L/home/install/workspace/trunk/http/img/button_blue/forward_over_disabled.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/helpbook_off.pngD>½È  B/home/install/workspace/trunk/http/img/tree_new/expanded_error.pngE´l  7/home/install/workspace/trunk/http/img/tree_blue/1w.gifD’¥â  J/home/install/workspace/trunk/http/img/openlayers/cloud-popup-relative.pngHw]à  E/home/install/workspace/trunk/http/img/button_gray/perimeter_over.pngDFYÝ  B/home/install/workspace/trunk/http/img/tree_new/loading_folder.gifE´l  L/home/install/workspace/trunk/http/img/button_silver_blue/preferences_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_gray/select_extent_over.pngD–€‰  J/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_on.pngHZ3£  0/home/install/workspace/trunk/http/img/white.gifD>±h  K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blue/wmc_load_on.pngD’“ì  K/home/install/workspace/trunk/http/img/button_silver_blue/new_node_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blue/center_over.pngD’“ì  A/home/install/workspace/trunk/http/img/tree_new/closed_folder.pngE´l  >/home/install/workspace/trunk/http/img/button_gray/user_on.pngD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/forward_off_disabled.pngD>­¡  M/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_on.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_off.pngD>­¡  H/home/install/workspace/trunk/http/img/button_silver_blue/addlist_on.pngHZ3£  :/home/install/workspace/trunk/http/img/tree/file_empty.gifD>¯É  ?/home/install/workspace/trunk/http/print/img/mapbender_logo.pngD>¹`  J/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_on.pngI¾p  C/home/install/workspace/trunk/http/img/button_blue/metadata_off.pngD’“ì  :/home/install/workspace/trunk/http/img/arrows/arrow_se.gifD>¬¡  =/home/install/workspace/trunk/http/img/button_gray/pan_on.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/logout_off.gifD>¯g  F/home/install/workspace/trunk/http/img/button_blink_red/selArea_on.pngD>­¡  Q/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/geomRemove.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/geomRemoveDb.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/help_off.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/tiles_over.pngD>­¡  @/home/install/workspace/trunk/http/img/button_gray/wmc_merge.pngD>¯g  U/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_right.gifJ)?›  I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.pngD>½È  6/home/install/workspace/trunk/http/img/transparent.gifD>±h  G/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_off.pngD>­¡  I/home/install/workspace/trunk/http/img/button_silver_blue/new_node_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/coords_on.pngD’“ì  D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/logout_over.pngD>­¡  C/home/install/workspace/trunk/http/img/button_blue/getArea_over.pngD’“ì  @/home/install/workspace/trunk/http/img/tree_orange/file_last.gifD>°Ø  @/home/install/workspace/trunk/http/img/button_gray/user_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_blue/metadata_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/add_over.pngHZ3£  K/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_over.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/smaller.gifD>½È  B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/print_off.pngD’“ì  N/home/install/workspace/trunk/http/img/button_blink_red/select_extent_over.pngD–€  M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_off.pngD>­¡  >/home/install/workspace/trunk/http/img/button_gray/wmc_xml.pngD>½È  G/home/install/workspace/trunk/http/img/button_silver_blue/point_off.pngHZ3£  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_dadada_1x400.pngJ)>©  a/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_leftright.gifJ)?›  A/home/install/workspace/trunk/http/img/button_blue/getArea_on.pngD’“ì  9/home/install/workspace/trunk/http/img/tree/file_last.gifD>¯É  @/home/install/workspace/trunk/http/img/button_gray/print_off.pngD>¯g  F/home/install/workspace/trunk/http/img/button_silver_blue/query_on.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/selArea_on.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/print_over.pngHZ3£  S/home/install/workspace/trunk/http/img/button_silver_blue/forward_over_disabled.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/repaint_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/getArea_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/print_on.pngD’“ì  :/home/install/workspace/trunk/http/sld/img/script_link.pngH`f  K/home/install/workspace/trunk/http/img/button_blink_red/addwmsblink_off.pngD>­¡  F/home/install/workspace/trunk/http/img/button_silver_blue/shape_on.pngHZ3£  ./home/install/workspace/trunk/http/img/wms.gifEìM  ?/home/install/workspace/trunk/http/img/button_gray/leg_over.gifD>½È  I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_over.pngHZ3£  L/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.pngD>½È  =/home/install/workspace/trunk/http/img/trafficlights/stop.bmpDHþ  P/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_over.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/reload_on.pngHb¸  J/home/install/workspace/trunk/http/img/button_digitize/delete_node_off.pngD™AL  =/home/install/workspace/trunk/http/img/button_gray/pan_on.pngD>¯g  N/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_on.pngD>­¡  F/home/install/workspace/trunk/http/img/button_silver_blue/point_on.pngHZ3£  K/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_off.pngI¾p  =/home/install/workspace/trunk/http/img/button_gray/add_on.pngD>¯g  C/home/install/workspace/trunk/http/img/button_gray/selArea_over.pngD>¯g  @/home/install/workspace/trunk/http/img/button_gray/reload_on.pngHb¸  B/home/install/workspace/trunk/http/img/button_blue/wmc_save_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.gifD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/reload_on.pngHb¸  A/home/install/workspace/trunk/http/img/button_blue/print_over.pngD’“ì  C/home/install/workspace/trunk/http/img/button_blue/zoomOut2_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_blue/logout_off.pngD’“ì  L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.gifD>¯g  ;/home/install/workspace/trunk/http/img/button_gray/logo.jpgD>½È  E/home/install/workspace/trunk/http/img/button_gray/logoutred_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/reload_over.pngHb¸  D/home/install/workspace/trunk/http/img/button_blink_red/exit_off.pngD>­¡  ;/home/install/workspace/trunk/http/img/button_gray/save.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blue/logout_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/leg_over.pngD>­¡  =/home/install/workspace/trunk/http/img/button_blue/add_on.pngD’“ì  ?/home/install/workspace/trunk/http/img/button_gray/print_on.gifD>½È  A/home/install/workspace/trunk/http/img/button_blue/reload_off.pngHb¸  D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blink_red/user_on.pngD>­¡  O/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_over.pngD–€  M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-maximize.pngHw]à  M/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_off.pngHZ3£  E/home/install/workspace/trunk/http/img/button_blue/gazetteer_over.pngD’“ì  B/home/install/workspace/trunk/http/img/button_blue/repaint_off.pngD’“ì  >/home/install/workspace/trunk/http/img/tree_blue/file_last.gifD’¥â  K/home/install/workspace/trunk/http/img/button_silver_blue/metadata_over.pngHZ3£  D/home/install/workspace/trunk/http/img/button_digitize/point_off.pngD™@Ò  D/home/install/workspace/trunk/http/img/button_blink_red/pan_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blink_red/exit_on.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/addlist_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_silver_blue/back_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/measure_off.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blue/select_polygon_over.pngD–€Z  G/home/install/workspace/trunk/http/img/button_gray/preferences_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_over.pngD>¯g  A/home/install/workspace/trunk/http/img/button_gray/logout_off.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/selArea_off.gifD>¯g  U/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_right.gifJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_off.pngHZ3£  5/home/install/workspace/trunk/http/img/balloon_lr.gifHë«  G/home/install/workspace/trunk/http/img/button_silver_blue/coords_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blue/select_polygon_off.pngD–€Z  H/home/install/workspace/trunk/http/img/button_silver_blue/shape_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.gifD>¯g  H/home/install/workspace/trunk/http/img/button_blink_red/addlist_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_blue/help_off.pngD’“ì  a/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_leftright.gifJ)?›  @/home/install/workspace/trunk/http/img/button_gray/back_over.pngD>¯g  Q/home/install/workspace/trunk/http/img/button_silver_blue/forward_on_disabled.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.gifD>¯g  @/home/install/workspace/trunk/http/extensions/datepicker/cal.gifH_I  ?/home/install/workspace/trunk/http/img/tree_gray/file_empty.gifD>°¤  I/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_over.pngD—΃  I/home/install/workspace/trunk/http/css/images/ui-icons_cd0a0a_256x240.pngJ)>©  C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/coods_over.pngD>¯g  V/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_minus.gifJ)?›  3/home/install/workspace/trunk/http/sld/img/plus.gifH`f  D/home/install/workspace/trunk/http/img/button_blink_red/user_off.pngD>­¡  A/home/install/workspace/trunk/http/img/tree_orange/folder_off.gifD>°Ø  C/home/install/workspace/trunk/http/img/button_gray/repaint_over.pngD>¯g  M/home/install/workspace/trunk/http/img/button_blink_red/select_choose_off.pngD–€  B/home/install/workspace/trunk/http/img/button_blue/zoomIn2_off.pngD’“ì  B/home/install/workspace/trunk/http/img/button_gray/getArea_off.gifD>¯g  5/home/install/workspace/trunk/http/img/balloon_ll.pngHë«  R/home/install/workspace/trunk/http/img/button_silver_blue/change_password_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_digitize/new_node_over.pngD™@Ò  M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.gifD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_off.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.pngD>¯g  9/home/install/workspace/trunk/http/img/tree/folder_on.gifD>¯É  \/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_open.gifJ)?›  @/home/install/workspace/trunk/http/img/button_blue/rubber_on.pngD’“ì  J/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_on.pngH¾…Å  F/home/install/workspace/trunk/http/img/button_blue/closePolygon_on.pngD’“ì  V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_minus.gifJ)?›  D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.pngDFY±  =/home/install/workspace/trunk/http/img/tree_new/move_down.pngE´l  H/home/install/workspace/trunk/http/img/button_blink_red/selArea_over.pngD>­¡  N/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_over.pngE5Ë  H/home/install/workspace/trunk/http/img/button_blink_red/metadata_off.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/metadata_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_down.gifJ)?›  B/home/install/workspace/trunk/http/img/button_gray/rubber_over.gifD>¯g  @/home/install/workspace/trunk/http/img/tree_new/delete_wmsmy.pngE´l  B/home/install/workspace/trunk/http/img/button_gray/measure_off.pngD>½È  C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.pngD>½È  ?/home/install/workspace/trunk/http/img/button_gray/tiles_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_blink_red/select_point_on.pngD–€  O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off2.pngHZ3£  </home/install/workspace/trunk/http/img/tree_new/expanded.pngE´l  H/home/install/workspace/trunk/http/img/button_silver_blue/forward_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/addlist_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/addlist_off.pngD>­¡  K/home/install/workspace/trunk/http/img/button_blue/change_password_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/query_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/query_on.gifD>½È  ?/home/install/workspace/trunk/http/img/button_gray/add_over.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/coords_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/select_point_off.pngD–€  B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.pngD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/tiles_off.pngD>­¡  L/home/install/workspace/trunk/http/img/button_blink_red/select_choose_on.pngD–€  C/home/install/workspace/trunk/http/img/button_blink_red/help_on.pngEbÿî  >/home/install/workspace/trunk/http/img/button_blue/home_on.pngD’“ì  >/home/install/workspace/trunk/http/img/button_blue/help_on.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/addwms_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_digitize/geomRemoveDb.pngE¸¹ö  G/home/install/workspace/trunk/http/img/button_digitize/polygon_over.pngD™@Ò  O/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_off.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/zoomfull2_on.pngD>¯g  S/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_off.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/coords_over.pngHZ3£  K/home/install/workspace/trunk/http/img/button_gray/select_rectangle_off.pngD–€‰  H/home/install/workspace/trunk/http/img/button_digitize/move_node_off.pngD™@Ò  B/home/install/workspace/trunk/http/img/button_blue/rubber_over.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/tiles_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.gifD>½È  I/home/install/workspace/trunk/http/img/button_silver_blue/forward_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_left.gifJ)?›  9/home/install/workspace/trunk/http/img/arrows/arrow_e.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.gifD>¯g  H/home/install/workspace/trunk/http/img/button_gray/exportMapimage_on.pngHb¸  T/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_over.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_on.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blink_red/select_extent_off.pngD–­Õ  O/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_off.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/select_point_over.pngD–€Z  A/home/install/workspace/trunk/http/img/button_gray/measure_on.gifD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_off.pngD–€  8/home/install/workspace/trunk/http/img/button_gray/x.pngD>¯g  C/home/install/workspace/trunk/http/img/button_gray/forward_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/zoomFull_off.pngD’“ì  ?/home/install/workspace/trunk/http/img/tree_blue/folder_off.gifD’¥â  :/home/install/workspace/trunk/http/img/tree_new/branch.pngE´l  B/home/install/workspace/trunk/http/img/button_digitize/polygon.pngHb¸  ?/home/install/workspace/trunk/http/img/button_gray/wmc_save.pngD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/select_point_off.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/home_on.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/preferences2_off.pngD>­¡  8/home/install/workspace/trunk/http/img/tree_new/leaf.pngE´l  V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_close.gifJ)?›  4/home/install/workspace/trunk/http/img/tree/file.gifD>¯É  G/home/install/workspace/trunk/http/img/button_silver_blue/center_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/helpbook_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/forward_off.pngD>¯g  >/home/install/workspace/trunk/http/img/tree_new/delete_wms.pngE´l  5/home/install/workspace/trunk/http/img/balloon_ur.gifHë«  L/home/install/workspace/trunk/http/css/images/ui-bg_flat_0_aaaaaa_40x100.pngJ)>©  B/home/install/workspace/trunk/http/img/button_blue/reload_over.pngHb¸  ./home/install/workspace/trunk/http/img/add.pngF”¤Ù  I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_on.pngHZ3£  >/home/install/workspace/trunk/http/img/tree_gray/file_last.gifD>°¤  D/home/install/workspace/trunk/http/img/button_gray/logoutred_off.pngD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_updown.gifJ)?›  F/home/install/workspace/trunk/http/img/button_gray/preferences_off.gifD>½È  B/home/install/workspace/trunk/http/img/button_blue/selArea_off.pngD’“ì  ;/home/install/workspace/trunk/http/print/img/northarrow.pngF‘û‰  A/home/install/workspace/trunk/http/img/button_gray/wmc_append.pngD>¯g  A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.gifD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/new_node_off.pngHZ3£  N/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_off.pngHb¸  G/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_on.pngD—΃  @/home/install/workspace/trunk/http/img/button_digitize/point.pngHb¸  S/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_over.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_doc.gifJ)?›  M/home/install/workspace/trunk/http/css/images/ui-bg_flat_75_ffffff_40x100.pngJ)>©  G/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-on.pngHw]à  5/home/install/workspace/trunk/http/img/balloon_ul.pngHë«  J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.pngD>½È  >/home/install/workspace/trunk/http/img/tree_blue/folder_on.gifD’¥â  >/home/install/workspace/trunk/http/img/button_gray/user_on.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/logout_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/forward_over.pngD>¯g  @/home/install/workspace/trunk/http/img/button_gray/query_off.gifD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/add_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_blue/closePolygon_off.pngD’“ì  A/home/install/workspace/trunk/http/img/openlayers/marker-gold.pngHw]à  A/home/install/workspace/trunk/http/img/button_gray/reload_off.pngHb¸  A/home/install/workspace/trunk/http/img/button_digitize/del_on.pngE¬Ìú  @/home/install/workspace/trunk/http/img/button_blue/home_over.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/query_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_off.pngD—΃  B/home/install/workspace/trunk/http/img/button_gray/rubber_over.pngD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_closed.gifJ)?›  ;/home/install/workspace/trunk/http/img/tree_new/move_up.pngE´l  A/home/install/workspace/trunk/http/img/button_gray/query_over.gifD>½È  K/home/install/workspace/trunk/http/img/button_digitize/delete_node_over.pngD™AL  H/home/install/workspace/trunk/http/img/button_silver_blue/point_over.pngHZ3£  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_65_ffffff_1x400.pngJ)>©  O/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_on.pngD–€  H/home/install/workspace/trunk/http/img/button_silver_blue/getArea_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off2.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/pan_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.pngD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/selArea_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_digitize/geomInfo.pngIäà  a/home/install/workspace/trunk/http/extensions/theme/images/e6e6e6_40x100_textures_02_glass_75.pngJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_blue/wmc_load_off.pngD’“ì  C/home/install/workspace/trunk/http/img/button_blue/repaint_over.pngD’“ì  M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-minimize.pngHw]à  R/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_up.gifJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/forward_over.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/metadata_over.pngD>¯g  A/home/install/workspace/trunk/http/img/button_blue/forward_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/measure_over.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/back_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/selArea_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/user_off.pngD>¯g  8/home/install/workspace/trunk/http/img/tree_new/info.pngE´l  2/home/install/workspace/trunk/http/img/info_on.gifD>±h  H/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_off.pngD>­¡  A/home/install/workspace/trunk/http/img/button_gray/repaint_on.pngD>¯g  `/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_01_flat_75.pngJ)?›  R/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/back_off_disabled.pngD’“ì  N/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/tiles_off.pngD>½È  @/home/install/workspace/trunk/http/img/button_gray/back_over.gifD>¯g  ?/home/install/workspace/trunk/http/img/tree_new/move_downmy.pngE´l  E/home/install/workspace/trunk/http/img/button_gray/zoomfull2_over.pngD>½È  B/home/install/workspace/trunk/http/img/button_gray/coords_over.pngD>¯g  E/home/install/workspace/trunk/http/img/button_silver_blue/line_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/logout_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/repaint_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/wmc_save_off.pngD’“ì  J/home/install/workspace/trunk/http/img/button_silver_blue/move_node_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_blue/selArea_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_blink_red/center_over.pngD>­¡  ,/home/install/workspace/trunk/http/img/x.gifD>±h  :/home/install/workspace/trunk/http/img/arrows/arrow_sw.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_off.pngHZ3£  6/home/install/workspace/trunk/http/img/scalebar_bw.gifD>±h  ?/home/install/workspace/trunk/http/img/button_gray/print_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_digitize/delete_node_on.pngD™AL  H/home/install/workspace/trunk/http/img/button_gray/select_polygon_on.pngD–€‰  J/home/install/workspace/trunk/http/img/button_blue/forward_on_disabled.pngD’“ì  5/home/install/workspace/trunk/http/img/balloon_ll.gifHë«  H/home/install/workspace/trunk/http/img/button_blink_red/forward_over.pngD>­¡  I/home/install/workspace/trunk/http/img/openlayers/measuring-stick-off.pngHw]à  5/home/install/workspace/trunk/http/img/balloon_ul.gifHë«  K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.gifD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/change_password_over.pngD>­¡  =/home/install/workspace/trunk/http/img/button_blue/pan_on.pngHb¸  B/home/install/workspace/trunk/http/img/button_blue/coords_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_gray/exportMapimage_off.pngHb¸  J/home/install/workspace/trunk/http/img/button_gray/select_polygon_over.pngD–€‰  @/home/install/workspace/trunk/http/img/button_blue/back_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/query_on.pngD>­¡  ./home/install/workspace/trunk/http/img/map.pngInQc  L/home/install/workspace/trunk/http/img/button_blue/select_rectangle_over.pngD–€Z  0/home/install/workspace/trunk/http/img/black.gifD>±h  D/home/install/workspace/trunk/http/img/button_blink_red/print_on.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_blue/home_off.pngD’“ì  O/home/install/workspace/trunk/http/img/button_silver_blue/back_off_disabled.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/wmc_load_off.pngD>¯g  4/home/install/workspace/trunk/http/sld/img/minus.gifH`f  H/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/preferences_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/back_off.gifD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/wmc_load.pngD>½È  =/home/install/workspace/trunk/http/img/tree_new/last_leaf.pngE´l  M/home/install/workspace/trunk/http/img/button_blink_red/select_point_over.pngD–€  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_e6e6e6_1x400.pngJ)>©  8/home/install/workspace/trunk/http/img/button_gray/x.gifD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_over.pngI¾Y  ./home/install/workspace/trunk/http/img/asc.gifIš‰û  G/home/install/workspace/trunk/http/img/button_blink_red/measure_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_blink_red/up_off.pngH_ÇM  T/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_doc.gifJ)?›  G/home/install/workspace/trunk/http/img/button_blink_red/addwms_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_silver_blue/reload_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_blink_red/help3_on.pngD>­¡  A/home/install/workspace/trunk/http/img/button_blue/repaint_on.pngD’“ì  R/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/coods_on.gifD>½È  J/home/install/workspace/trunk/http/img/button_silver_blue/polygon_over.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/help_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blink_red/preferences2_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/center_on.pngD>­¡  M/home/install/workspace/trunk/http/img/button_silver_blue/select_point_on.pngHZ3£  :/home/install/workspace/trunk/http/img/tree_new/closed.pngE´l  Q/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blue/measure_off.pngD’“ì  9/home/install/workspace/trunk/http/img/tree/file_vert.gifD>¯É  I/home/install/workspace/trunk/http/css/images/ui-icons_2e83ff_256x240.pngJ)>©  :/home/install/workspace/trunk/http/sld/img/map_magnify.pngH`f  J/home/install/workspace/trunk/http/img/button_blue/select_rectangle_on.pngD–€Z  A/home/install/workspace/trunk/http/img/button_gray/coods_over.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/center_off.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/change_password_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blue/preferences_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_silver_blue/del_on.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/query_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/line_off.pngHZ3£  R/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_up.gifJ)?›  ?/home/install/workspace/trunk/http/img/tree_blue/file_empty.gifD’¥â  E/home/install/workspace/trunk/http/img/button_blink_red/print_off.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/help_over.pngD>­¡  2/home/install/workspace/trunk/http/img/tree/1w.gifD>¯É  5/home/install/workspace/trunk/http/sld/img/script.pngH`f  1/home/install/workspace/trunk/http/img/resize.gifFú“  J/home/install/workspace/trunk/http/img/button_gray/change_password_off.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.pngD>½È  R/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/query_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_over.pngHb¸  8/home/install/workspace/trunk/http/img/tree_new/menu.pngE´l  J/home/install/workspace/trunk/http/img/button_gray/change_password_off.pngD>¯g  5/home/install/workspace/trunk/http/img/balloon_ur.pngHë«  A/home/install/workspace/trunk/http/img/button_gray/repaint_on.gifD>¯g  G/home/install/workspace/trunk/http/img/button_blue/select_point_off.pngD–€Z  B/home/install/workspace/trunk/http/img/button_blue/forward_off.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/polygon_on.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blink_red/preferences_on.pngD>­¡  3/home/install/workspace/trunk/http/img/digitize.pngInQc  O/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_on.pngHZ3£  @/home/install/workspace/trunk/http/img/tree_orange/file_vert.gifD>°Ø  7/home/install/workspace/trunk/http/img/tree_gray/1w.gifD>°¤  G/home/install/workspace/trunk/http/img/button_silver_blue/shape_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_blue/select_extent_on.pngD–­ø  ^/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_updown.gifJ)?›  D/home/install/workspace/trunk/http/img/button_blink_red/help_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blue/wmc_save_off_old.pngD’“ì  Q/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/wmc_load_on.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/selArea_off.pngD>¯g  :/home/install/workspace/trunk/http/img/button_gray/del.pngD>½È  G/home/install/workspace/trunk/http/img/button_gray/select_extent_on.pngD–®s  P/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_on.pngD>­¡  B/home/install/workspace/trunk/http/img/button_digitize/del_off.pngE¬Ìú  C/home/install/workspace/trunk/http/img/button_digitize/point_on.pngD™@Ò  K/home/install/workspace/trunk/http/img/button_blue/forward_off_disabled.pngD’“ì  G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.gifD>¯g  D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.gifD>¯g  B/home/install/workspace/trunk/http/img/button_gray/helpbook_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.gifD>¯g  :/home/install/workspace/trunk/http/img/tree/folder_off.gifD>¯É  A/home/install/workspace/trunk/http/img/tree_orange/file_empty.gifD>°Ø  9/home/install/workspace/trunk/http/img/tree_new/error.pngE´l  7/home/install/workspace/trunk/http/img/sandclock_oo.gifD>±h  G/home/install/workspace/trunk/http/img/button_silver_blue/line_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_digitize/polygon_on.pngD™@Ò  ?/home/install/workspace/trunk/http/img/button_digitize/line.pngHb¸  D/home/install/workspace/trunk/http/img/button_silver_blue/pan_on.pngHZ3£  G/home/install/workspace/trunk/http/img/button_blink_red/coords_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_silver_blue/del_off.pngHZ3£  6/home/install/workspace/trunk/http/img/exclamation.pngJ.  K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_over.pngHZ3£  U/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_right.gifJ)?›  H/home/install/workspace/trunk/http/img/button_silver_blue/measure_on.pngHZ3£  ;/home/install/workspace/trunk/http/img/button_gray/save.gifD>½È  B/home/install/workspace/trunk/http/img/button_gray/repaint_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_off.pngI¾Y  P/home/install/workspace/trunk/http/img/button_silver_blue/back_over_disabled.pngHZ3£  >/home/install/workspace/trunk/http/img/tree_gray/file_vert.gifD>°¤  E/home/install/workspace/trunk/http/img/button_blink_red/exit_over.pngD>­¡  0/home/install/workspace/trunk/http/img/admin.pngInQc  >/home/install/workspace/trunk/http/img/tree_blue/file_vert.gifD’¥â  </home/install/workspace/trunk/http/img/background_yellow.jpgDÀË,  O/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/print_off.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blue/change_password_off.pngD’“ì  Q/home/install/workspace/trunk/http/img/button_silver_blue/change_password_off.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/coods_off.gifD>¯g  >/home/install/workspace/trunk/http/img/button_gray/smaller.pngD>½È  Q/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_over.pngD–€  D/home/install/workspace/trunk/http/img/button_gray/wmc_load_over.pngD>¯g  I/home/install/workspace/trunk/http/css/images/ui-icons_222222_256x240.pngJ)>©  N/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_on.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/back_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blink_red/add_on.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/select_choose_on.pngD–€‰  J/home/install/workspace/trunk/http/img/button_gray/exportMapimage_over.pngHb¸  9/home/install/workspace/trunk/http/img/tree_orange/1w.gifD>°Ø  A/home/install/workspace/trunk/http/img/button_blue/zoomIn2_on.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/measure_on.pngD>­¡  L/home/install/workspace/trunk/http/img/button_silver_blue/move_node_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blue/gazetteer_on.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/selArea_off.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/measure_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_gray/wmc_save_off.pngD>¯g  8/home/install/workspace/trunk/http/img/header_yellow.jpgD™8B  E/home/install/workspace/trunk/http/img/button_blink_red/back_over.pngD>­¡  L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/measure_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/reload_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/repaint_off.gifD>¯g  2/home/install/workspace/trunk/http/img/eye_on_.gifD>±h  H/home/install/workspace/trunk/http/img/button_blink_red/logout_over2.pngD>­¡  8/home/install/workspace/trunk/http/img/tree_new/zoom.pngE´l  C/home/install/workspace/trunk/http/img/tree_new/expanded_folder.pngE´l  V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_minus.gifJ)?›  A/home/install/workspace/trunk/http/img/tree_new/last_expanded.pngE´l  K/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_off.pngH¾…Å  B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blue/back_over_disabled.pngD’“ì  >/home/install/workspace/trunk/http/sld/img/script_code_red.pngH`f  H/home/install/workspace/trunk/http/img/button_silver_blue/selArea_on.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/measure_off.gifD>¯g  G/home/install/workspace/trunk/http/img/button_blue/back_on_disabled.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/pan_over.pngHZ3£  1/home/install/workspace/trunk/http/img/eye_on.gifD>±h  H/home/install/workspace/trunk/http/img/button_blue/select_polygon_on.pngD–€Z  R/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_up.gifJ)?›  ?/home/install/workspace/trunk/http/img/tree_gray/folder_off.gifD>°¤  I/home/install/workspace/trunk/http/img/button_gray/select_choose_over.pngD–€‰  E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/select_extent_on.pngD–­Õ  @/home/install/workspace/trunk/http/img/openlayers/north-mini.pngHw]à  L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.pngD>¯g  8/home/install/workspace/trunk/http/sld/img/lightning.pngH`f  D/home/install/workspace/trunk/http/img/button_blue/wmc_load_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/reload_off.pngHb¸  P/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/pan_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_blue/wmc_save_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/geomInfo.pngHZ3£  1/home/install/workspace/trunk/http/img/pencil.pngGJÌ   F/home/install/workspace/trunk/http/img/button_blink_red/logout_off.pngD>­¡  H/home/install/workspace/trunk/http/img/button_silver_blue/reload_off.pngHZ3£  -/home/install/workspace/trunk/http/img/bg.gifIš‰û  C/home/install/workspace/trunk/http/img/button_blink_red/pan_off.pngD>­¡  F/home/install/workspace/trunk/http/img/button_gray/select_point_on.pngD–€‰  3/home/install/workspace/trunk/http/img/info_off.gifD>±h  F/home/install/workspace/trunk/http/img/button_blink_red/center_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_gray/forward_off.gifD>¯g  M/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_on.pngD–€  E/home/install/workspace/trunk/http/img/button_blink_red/coords_on.pngD>­¡  2/home/install/workspace/trunk/http/img/eye_off.gifD>±h  @/home/install/workspace/trunk/http/img/button_blue/center_on.pngD’“ì  F/home/install/workspace/trunk/http/img/openlayers/panning-hand-off.pngHw]à  a/home/install/workspace/trunk/http/extensions/theme/images/dadada_40x100_textures_02_glass_75.pngJ)?›  P/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/help_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_silver_blue/rubber_on.pngHZ3£  5/home/install/workspace/trunk/http/img/balloon_lr.pngHë«  C/home/install/workspace/trunk/http/img/button_blink_red/add_off.pngD>­¡  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_55_fbf9ee_1x400.pngJ)>©  A/home/install/workspace/trunk/http/img/openlayers/marker-blue.pngHw]à  B/home/install/workspace/trunk/http/img/button_gray/center_over.pngD>¯g  N/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_off.pngD–€  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_95_fef1ec_1x400.pngJ)>©  @/home/install/workspace/trunk/http/img/openlayers/south-mini.pngHw]à  B/home/install/workspace/trunk/http/img/openlayers/marker-green.pngHw]à  @/home/install/workspace/trunk/http/img/tree_orange/folder_on.gifD>°Ø  L/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_over.pngH¾…Å  F/home/install/workspace/trunk/http/img/button_silver_blue/del_over.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/center_on.gifD>¯g  \/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_open.gifJ)?›  ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_updown.gifJ)?›  @/home/install/workspace/trunk/http/img/tree_new/error_folder.pngE´l  I/home/install/workspace/trunk/http/img/button_silver_blue/repaint_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/coords_off.pngD’“ì  I/home/install/workspace/trunk/http/img/button_blue/change_password_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_digitize/del_over.pngE¬Ìú  I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blue/zoomIn2_over.pngD’“ì  T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_left.gifJ)?›  @/home/install/workspace/trunk/http/img/button_gray/center_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/query_on.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/center_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_off.pngD—΃  Z/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_resize_se.gifJ)?›  K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.gifD>½È  D/home/install/workspace/trunk/http/img/button_blue/zoomOut2_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_gray/select_point_off.pngD–€‰  ;/home/install/workspace/trunk/http/img/openlayers/blank.gifHw]à  I/home/install/workspace/trunk/http/img/button_silver_blue/addlist_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/coods_on.pngD>¯g  T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_left.gifJ)?›  B/home/install/workspace/trunk/http/img/button_gray/zoomFull_on.pngD>¯g  D/home/install/workspace/trunk/http/img/button_blue/gazetteer_off.pngD’“ì  ?/home/install/workspace/trunk/http/img/button_blue/pan_over.pngHb¸  M/home/install/workspace/trunk/http/img/button_blink_red/back_off_disabled.pngD>­¡  K/home/install/workspace/trunk/http/img/button_silver_blue/move_node_off.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/wmc_save_over.pngD>¯g  L/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_over.pngI¾p  D/home/install/workspace/trunk/http/img/openlayers/zoom-plus-mini.pngHw]à  J/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_on.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/preferences_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_digitize/line_over.pngD™Ao  K/home/install/workspace/trunk/http/img/button_gray/change_password_over.gifD>¯g  0/home/install/workspace/trunk/http/img/layer.gifEìM  A/home/install/workspace/trunk/http/img/button_gray/print_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/forward_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_gray/logout_over.pngD>½È  C/home/install/workspace/trunk/http/img/button_gray/metadata_off.gifD>¯g  =/home/install/workspace/trunk/http/img/tree_new/move_upmy.pngE´l  @/home/install/workspace/trunk/http/img/button_gray/home_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.gifD>¯g  E/home/install/workspace/trunk/http/img/openlayers/zoom-minus-mini.pngHw]à  M/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_on.pngHb¸  A/home/install/workspace/trunk/http/img/button_blue/measure_on.pngD’“ì  H/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_off.pngD>­¡  D/home/install/workspace/trunk/http/img/button_blink_red/back_off.pngD>­¡  N/home/install/workspace/trunk/http/img/button_blink_red/select_choose_over.pngD–€  ;/home/install/workspace/trunk/http/img/button_gray/down.pngDÀ¼Ÿ  C/home/install/workspace/trunk/http/img/button_blink_red/down_on.pngH_ÇM  ?/home/install/workspace/trunk/http/img/openlayers/west-mini.pngHw]à  2/home/install/workspace/trunk/http/img/redball.gifD>±h  H/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/rocks.pngD>¨´  J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_over.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/query_over.pngD>­¡  H/home/install/workspace/trunk/http/img/button_blink_red/measure_over.pngD>­¡  D/home/install/workspace/trunk/http/img/button_blue/zoomFull_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_gray/metadata_over.gifD>¯g  B/home/install/workspace/trunk/http/img/button_blue/getArea_off.pngD’“ì  :/home/install/workspace/trunk/http/img/arrows/arrow_nw.gifD>¬¡  I/home/install/workspace/trunk/http/css/images/ui-icons_454545_256x240.pngJ)>©  E/home/install/workspace/trunk/http/img/button_blink_red/addwms_on.pngD>­¡  E/home/install/workspace/trunk/http/img/button_silver_blue/pan_off.pngHZ3£  </home/install/workspace/trunk/http/img/openlayers/slider.pngHw]à  H/home/install/workspace/trunk/http/img/button_gray/select_extent_off.pngD–€‰  7/home/install/workspace/trunk/http/img/mapbender_oo.pngD™?ä  E/home/install/workspace/trunk/http/img/button_blue/preferences_on.pngD’“ì  K/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_on.pngD’“ì  A/home/install/workspace/trunk/http/img/button_blue/center_off.pngD’“ì  K/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_on.pngI¾Y  F/home/install/workspace/trunk/http/img/button_silver_blue/back_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_gray/center_off.gifD>¯g  H/home/install/workspace/trunk/http/img/button_blue/closePolygon_over.pngD’“ì  >/home/install/workspace/trunk/http/img/button_gray/logo_en.jpgD>½È  @/home/install/workspace/trunk/http/img/button_gray/help_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_blue/select_extent_off.pngD–€Z  H/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_over.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off2.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/print_on.pngHZ3£  J/home/install/workspace/trunk/http/img/button_gray/select_rectangle_on.pngD–€‰  ?/home/install/workspace/trunk/http/img/button_gray/home_off.pngD>¯g
\ No newline at end of file
Copied: branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/ImageFileInfo.nd)
--- branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd	                        (rev 0)
+++ branches/kmq_dev/documents/api_js/Data/ImageFileInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,3 @@
+(    B/home/install/workspace/trunk/http/img/button_gray/addlist_off.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blink_red/pan_on.pngD>­¡  L/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/repaint_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_over.pngD—΃  @/home/install/workspace/trunk/http/img/button_gray/user_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/openlayers/east-mini.pngHw]à  F/home/install/workspace/trunk/http/img/button_digitize/new_node_on.pngD™@Ò  D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/query_off.pngD’“ì  J/home/install/workspace/trunk/http/img/button_silver_blue/measure_over.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/pan_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/back_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/add_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_gray/select_point_over.pngD–€‰  </home/install/workspace/trunk/http/img/openlayers/marker.pngHw]à  E/home/install/workspace/trunk/http/img/button_digitize/geomRemove.pngIäà  F/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_on.pngD>­¡  :/home/install/workspace/trunk/http/img/arrows/arrow_ne.gifD>¬¡  ?/home/install/workspace/trunk/http/img/button_gray/query_on.pngD>¯g  F/home/install/workspace/trunk/http/img/button_digitize/polygon_off.pngD™@Ò  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_on.pngHZ3£  U/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_plus.gifJ)?›  I/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/help3_off.pngD>­¡  K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blue/select_point_on.pngD–€Z  H/home/install/workspace/trunk/http/img/openlayers/measuring-stick-on.pngHw]à  H/home/install/workspace/trunk/http/img/button_gray/select_choose_off.pngD–€‰  F/home/install/workspace/trunk/http/img/button_blink_red/print_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_digitize/point_over.pngD™@Ò  I/home/install/workspace/trunk/http/img/button_blue/select_choose_over.pngD–€Z  I/home/install/workspace/trunk/http/img/button_silver_blue/polygon_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_gray/print_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/forward_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/coods_off.pngD>¯g  :/home/install/workspace/trunk/http/img/indicator_wheel.gifFå
+  A/home/install/workspace/trunk/http/img/button_gray/query_over.pngD>¯g  K/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/leg_over.pngHZ3£  9/home/install/workspace/trunk/http/img/arrows/arrow_w.gifD>¬¡  G/home/install/workspace/trunk/http/img/button_blink_red/selArea_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/reload_over.pngHb¸  9/home/install/workspace/trunk/http/img/arrows/arrow_s.gifD>¬¡  A/home/install/workspace/trunk/http/img/button_gray/measure_on.pngD>¯g  E/home/install/workspace/trunk/http/img/button_gray/metadata_layer.gifEè3€  K/home/install/workspace/trunk/http/img/button_blink_red/preferences_off.pngD>­¡  C/home/install/workspace/trunk/http/img/button_gray/perimeter_on.pngDFYÌ  F/home/install/workspace/trunk/http/img/button_blink_red/repaint_on.pngD>­¡  =/home/install/workspace/trunk/http/img/openlayers/zoombar.pngHw]à  I/home/install/workspace/trunk/http/css/images/ui-icons_888888_256x240.pngJ)>©  E/home/install/workspace/trunk/http/img/button_silver_blue/help_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_silver_blue/add_on.pngHZ3£  //home/install/workspace/trunk/http/img/help.pngJ8½Ã  D/home/install/workspace/trunk/http/img/button_gray/zoomfull2_off.pngD>¯g  ;/home/install/workspace/trunk/http/img/trafficlights/go.bmpDHþ  D/home/install/workspace/trunk/http/img/button_blink_red/tiles_on.pngD>­¡  =/home/install/workspace/trunk/http/img/trafficlights/wait.bmpDHþ  C/home/install/workspace/trunk/http/img/button_gray/metadata_off.pngD>½È  H/home/install/workspace/trunk/http/img/button_silver_blue/repaint_on.pngHZ3£  L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_on.pngD—΃  I/home/install/workspace/trunk/http/img/button_blink_red/metadata_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/repaint_off.pngD>­¡  9/home/install/workspace/trunk/http/img/mapbender_logo.pngD>±h  D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.gifD>¯g  a/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_leftright.gifJ)?›  R/home/install/workspace/trunk/http/img/button_silver_blue/forward_off_disabled.pngHZ3£  E/home/install/workspace/trunk/http/img/openlayers/panning-hand-on.pngHw]à  G/home/install/workspace/trunk/http/img/button_digitize/new_node_off.pngD™@Ò  E/home/install/workspace/trunk/http/img/button_blink_red/query_off.pngD>­¡  M/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_off.pngE5±  H/home/install/workspace/trunk/http/img/button_silver_blue/center_off.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/addlist_on.pngD>­¡  A/home/install/workspace/trunk/http/img/button_gray/rubber_off.gifD>¯g  9/home/install/workspace/trunk/http/img/arrows/arrow_n.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.gifD>½È  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomOut2_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_doc.gifJ)?›  H/home/install/workspace/trunk/http/img/button_silver_blue/logout_off.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/help_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/coords_on.pngD>½È  ;/home/install/workspace/trunk/http/img/tree_orange/file.gifD>°Ø  B/home/install/workspace/trunk/http/img/button_blue/metadata_on.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/add_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_blue/select_extent_over.pngD–€Z  G/home/install/workspace/trunk/http/img/button_digitize/move_node_on.pngD™@Ò  @/home/install/workspace/trunk/http/img/button_gray/print_off.gifD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_closed.gifJ)?›  9/home/install/workspace/trunk/http/img/tree_gray/file.gifD>°¤  5/home/install/workspace/trunk/http/img/close_icon.pngFú“  >/home/install/workspace/trunk/http/img/button_gray/help_on.pngD>¯g  T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_down.gifJ)?›  F/home/install/workspace/trunk/http/img/button_blue/preferences_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/selArea_on.gifD>½È  A/home/install/workspace/trunk/http/img/button_blue/rubber_off.pngD’“ì  V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_close.gifJ)?›  K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blue/select_choose_on.pngD–€Z  >/home/install/workspace/trunk/http/img/tree_gray/folder_on.gifD>°¤  E/home/install/workspace/trunk/http/img/openlayers/zoom-world-mini.pngHw]à  >/home/install/workspace/trunk/http/img/button_blue/pan_off.pngHb¸  5/home/install/workspace/trunk/http/img/OSGeo_logo.pngIÃrÄ  U/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_plus.gifJ)?›  >/home/install/workspace/trunk/http/img/button_gray/pan_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/user_off.gifD>½È  H/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off.pngHZ3£  9/home/install/workspace/trunk/http/img/button_gray/up.pngDÀ¼
+  B/home/install/workspace/trunk/http/img/button_digitize/line_on.pngD™Ao  8/home/install/workspace/trunk/http/img/tree_new/hide.pngE´l  A/home/install/workspace/trunk/http/img/button_gray/addlist_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_silver_blue/metadata_on.pngHZ3£  K/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_off.pngHZ3£  H/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-off.pngHw]à  J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.gifD>¯g  :/home/install/workspace/trunk/http/sld/img/script_save.pngH`f  B/home/install/workspace/trunk/http/img/button_gray/wmc_save_on.pngD>¯g  D/home/install/workspace/trunk/http/img/button_blink_red/down_off.pngH_ÇM  G/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_on.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/leg_over.pngD>½È  //home/install/workspace/trunk/http/img/desc.gifIš‰û  M/home/install/workspace/trunk/http/img/button_silver_blue/preferences_off.pngHZ3£  K/home/install/workspace/trunk/http/img/button_blue/select_rectangle_off.pngD–€Z  7/home/install/workspace/trunk/http/img/wfs_digitize.pngDš‘ï  O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_over.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/preferences_over.pngHZ3£  P/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/tree_new/last_closed.pngE´l  G/home/install/workspace/trunk/http/img/button_silver_blue/logout_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_digitize/trans.pngD>®  F/home/install/workspace/trunk/http/img/button_blink_red/coords_off.pngD>­¡  U/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_plus.gifJ)?›  V/home/install/workspace/trunk/http/css/images/ui-bg_highlight-soft_75_cccccc_1x100.pngJ)>©  >/home/install/workspace/trunk/http/img/button_gray/add_off.pngD>¯g  D/home/install/workspace/trunk/http/img/button_digitize/geomClone.pngIÈÚß  F/home/install/workspace/trunk/http/img/button_gray/preferences_off.pngD>½È  O/home/install/workspace/trunk/http/img/button_blink_red/change_password_off.pngD>­¡  I/home/install/workspace/trunk/http/img/button_gray/select_polygon_off.pngD–€‰  a/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_02_glass_65.pngJ)?›  L/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_off.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.gifD>¯g  P/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blink_red/up_on.pngH_ÇM  L/home/install/workspace/trunk/http/img/button_gray/select_rectangle_over.pngD–€‰  B/home/install/workspace/trunk/http/img/button_blue/zoomOut2_on.pngD’“ì  P/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/coords_off.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/select_choose_off.pngD–€Z  4/home/install/workspace/trunk/http/img/sandclock.gifD>±h  >/home/install/workspace/trunk/http/img/button_gray/add_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_digitize/line_off.pngD™Ao  C/home/install/workspace/trunk/http/img/button_gray/metadata_wms.gifEè3¹  O/home/install/workspace/trunk/http/img/button_silver_blue/select_point_over.pngHZ3£  9/home/install/workspace/trunk/http/img/tree_blue/file.gifD’¥â  >/home/install/workspace/trunk/http/img/button_blue/back_on.pngD’“ì  B/home/install/workspace/trunk/http/img/button_gray/center_over.gifD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/back_on_disabled.pngHZ3£  E/home/install/workspace/trunk/http/img/button_silver_blue/add_off.pngHZ3£  >/home/install/workspace/trunk/http/img/button_blue/add_off.pngD’“ì  B/home/install/workspace/trunk/http/img/button_blue/zoomFull_on.pngD’“ì  T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_down.gifJ)?›  A/home/install/workspace/trunk/http/img/button_gray/rubber_off.pngD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/user_over.pngD>­¡  I/home/install/workspace/trunk/http/img/button_digitize/move_node_over.pngD™@Ò  C/home/install/workspace/trunk/http/img/button_gray/selArea_over.gifD>¯g  2/home/install/workspace/trunk/http/img/no_info.gifD>±h  Q/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_off.pngD>­¡  L/home/install/workspace/trunk/http/img/button_blue/forward_over_disabled.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/helpbook_off.pngD>½È  B/home/install/workspace/trunk/http/img/tree_new/expanded_error.pngE´l  7/home/install/workspace/trunk/http/img/tree_blue/1w.gifD’¥â  J/home/install/workspace/trunk/http/img/openlayers/cloud-popup-relative.pngHw]à  E/home/install/workspace/trunk/http/img/button_gray/perimeter_over.pngDFYÝ  B/home/install/workspace/trunk/http/img/tree_new/loading_folder.gifE´l  L/home/install/workspace/trunk/http/img/button_silver_blue/preferences_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_gray/select_extent_over.pngD–€‰  J/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_on.pngHZ3£  0/home/install/workspace/trunk/http/img/white.gifD>±h  K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blue/wmc_load_on.pngD’“ì  K/home/install/workspace/trunk/http/img/button_silver_blue/new_node_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blue/center_over.pngD’“ì  A/home/install/workspace/trunk/http/img/tree_new/closed_folder.pngE´l  >/home/install/workspace/trunk/http/img/button_gray/user_on.pngD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/forward_off_disabled.pngD>­¡  M/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_on.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_off.pngD>­¡  H/home/install/workspace/trunk/http/img/button_silver_blue/addlist_on.pngHZ3£  :/home/install/workspace/trunk/http/img/tree/file_empty.gifD>¯É  ?/home/install/workspace/trunk/http/print/img/mapbender_logo.pngD>¹`  J/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_on.pngI¾p  C/home/install/workspace/trunk/http/img/button_blue/metadata_off.pngD’“ì  :/home/install/workspace/trunk/http/img/arrows/arrow_se.gifD>¬¡  =/home/install/workspace/trunk/http/img/button_gray/pan_on.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/logout_off.gifD>¯g  F/home/install/workspace/trunk/http/img/button_blink_red/selArea_on.pngD>­¡  Q/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_silver_blue/geomRemove.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/geomRemoveDb.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/help_off.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/tiles_over.pngD>­¡  @/home/install/workspace/trunk/http/img/button_gray/wmc_merge.pngD>¯g  U/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_right.gifJ)?›  I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.pngD>½È  6/home/install/workspace/trunk/http/img/transparent.gifD>±h  G/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_off.pngD>­¡  I/home/install/workspace/trunk/http/img/button_silver_blue/new_node_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/coords_on.pngD’“ì  D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/logout_over.pngD>­¡  C/home/install/workspace/trunk/http/img/button_blue/getArea_over.pngD’“ì  @/home/install/workspace/trunk/http/img/tree_orange/file_last.gifD>°Ø  @/home/install/workspace/trunk/http/img/button_gray/user_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_blue/metadata_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/add_over.pngHZ3£  K/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_over.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/smaller.gifD>½È  B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/print_off.pngD’“ì  N/home/install/workspace/trunk/http/img/button_blink_red/select_extent_over.pngD–€  M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_off.pngD>­¡  >/home/install/workspace/trunk/http/img/button_gray/wmc_xml.pngD>½È  G/home/install/workspace/trunk/http/img/button_silver_blue/point_off.pngHZ3£  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_dadada_1x400.pngJ)>©  a/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_leftright.gifJ)?›  A/home/install/workspace/trunk/http/img/button_blue/getArea_on.pngD’“ì  9/home/install/workspace/trunk/http/img/tree/file_last.gifD>¯É  @/home/install/workspace/trunk/http/img/button_gray/print_off.pngD>¯g  F/home/install/workspace/trunk/http/img/button_silver_blue/query_on.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/selArea_on.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/print_over.pngHZ3£  S/home/install/workspace/trunk/http/img/button_silver_blue/forward_over_disabled.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/repaint_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/getArea_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/print_on.pngD’“ì  :/home/install/workspace/trunk/http/sld/img/script_link.pngH`f  K/home/install/workspace/trunk/http/img/button_blink_red/addwmsblink_off.pngD>­¡  F/home/install/workspace/trunk/http/img/button_silver_blue/shape_on.pngHZ3£  ./home/install/workspace/trunk/http/img/wms.gifEìM  ?/home/install/workspace/trunk/http/img/button_gray/leg_over.gifD>½È  I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_over.pngHZ3£  L/home/install/workspace/trunk/http/img/button_silver_blue/gazetteer_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.pngD>½È  =/home/install/workspace/trunk/http/img/trafficlights/stop.bmpDHþ  P/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_over.pngHZ3£  @/home/install/workspace/trunk/http/img/button_blue/reload_on.pngHb¸  J/home/install/workspace/trunk/http/img/button_digitize/delete_node_off.pngD™AL  =/home/install/workspace/trunk/http/img/button_gray/pan_on.pngD>¯g  N/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_on.pngD>­¡  F/home/install/workspace/trunk/http/img/button_silver_blue/point_on.pngHZ3£  K/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_off.pngI¾p  =/home/install/workspace/trunk/http/img/button_gray/add_on.pngD>¯g  C/home/install/workspace/trunk/http/img/button_gray/selArea_over.pngD>¯g  @/home/install/workspace/trunk/http/img/button_gray/reload_on.pngHb¸  B/home/install/workspace/trunk/http/img/button_blue/wmc_save_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/zoomOut2_off.gifD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/reload_on.pngHb¸  A/home/install/workspace/trunk/http/img/button_blue/print_over.pngD’“ì  C/home/install/workspace/trunk/http/img/button_blue/zoomOut2_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_blue/logout_off.pngD’“ì  L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.gifD>¯g  ;/home/install/workspace/trunk/http/img/button_gray/logo.jpgD>½È  E/home/install/workspace/trunk/http/img/button_gray/logoutred_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/reload_over.pngHb¸  D/home/install/workspace/trunk/http/img/button_blink_red/exit_off.pngD>­¡  ;/home/install/workspace/trunk/http/img/button_gray/save.pngD>¯g  B/home/install/workspace/trunk/http/img/button_blue/logout_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/leg_over.pngD>­¡  =/home/install/workspace/trunk/http/img/button_blue/add_on.pngD’“ì  ?/home/install/workspace/trunk/http/img/button_gray/print_on.gifD>½È  A/home/install/workspace/trunk/http/img/button_blue/reload_off.pngHb¸  D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blink_red/user_on.pngD>­¡  O/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_over.pngD–€  M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-maximize.pngHw]à  M/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_off.pngHZ3£  E/home/install/workspace/trunk/http/img/button_blue/gazetteer_over.pngD’“ì  B/home/install/workspace/trunk/http/img/button_blue/repaint_off.pngD’“ì  >/home/install/workspace/trunk/http/img/tree_blue/file_last.gifD’¥â  K/home/install/workspace/trunk/http/img/button_silver_blue/metadata_over.pngHZ3£  D/home/install/workspace/trunk/http/img/button_digitize/point_off.pngD™@Ò  D/home/install/workspace/trunk/http/img/button_blink_red/pan_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blink_red/exit_on.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/addlist_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_silver_blue/back_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/measure_off.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blue/select_polygon_over.pngD–€Z  G/home/install/workspace/trunk/http/img/button_gray/preferences_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_over.pngD>¯g  A/home/install/workspace/trunk/http/img/button_gray/logout_off.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/selArea_off.gifD>¯g  U/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_right.gifJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_off.pngHZ3£  5/home/install/workspace/trunk/http/img/balloon_lr.gifHë«  G/home/install/workspace/trunk/http/img/button_silver_blue/coords_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/zoomFull_over.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blue/select_polygon_off.pngD–€Z  H/home/install/workspace/trunk/http/img/button_silver_blue/shape_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.gifD>¯g  H/home/install/workspace/trunk/http/img/button_blink_red/addlist_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_blue/help_off.pngD’“ì  a/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_leftright.gifJ)?›  @/home/install/workspace/trunk/http/img/button_gray/back_over.pngD>¯g  Q/home/install/workspace/trunk/http/img/button_silver_blue/forward_on_disabled.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/gazetteer_on.gifD>¯g  @/home/install/workspace/trunk/http/extensions/datepicker/cal.gifH_I  ?/home/install/workspace/trunk/http/img/tree_gray/file_empty.gifD>°¤  I/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_over.pngD—΃  I/home/install/workspace/trunk/http/css/images/ui-icons_cd0a0a_256x240.pngJ)>©  C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/coods_over.pngD>¯g  V/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_minus.gifJ)?›  3/home/install/workspace/trunk/http/sld/img/plus.gifH`f  D/home/install/workspace/trunk/http/img/button_blink_red/user_off.pngD>­¡  A/home/install/workspace/trunk/http/img/tree_orange/folder_off.gifD>°Ø  C/home/install/workspace/trunk/http/img/button_gray/repaint_over.pngD>¯g  M/home/install/workspace/trunk/http/img/button_blink_red/select_choose_off.pngD–€  B/home/install/workspace/trunk/http/img/button_blue/zoomIn2_off.pngD’“ì  B/home/install/workspace/trunk/http/img/button_gray/getArea_off.gifD>¯g  5/home/install/workspace/trunk/http/img/balloon_ll.pngHë«  R/home/install/workspace/trunk/http/img/button_silver_blue/change_password_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_digitize/new_node_over.pngD™@Ò  M/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_over.gifD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_off.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/zoomOut2_over.pngD>¯g  9/home/install/workspace/trunk/http/img/tree/folder_on.gifD>¯É  \/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_folder_open.gifJ)?›  @/home/install/workspace/trunk/http/img/button_blue/rubber_on.pngD’“ì  J/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_on.pngH¾…Å  F/home/install/workspace/trunk/http/img/button_blue/closePolygon_on.pngD’“ì  V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_minus.gifJ)?›  D/home/install/workspace/trunk/http/img/button_gray/perimeter_off.pngDFY±  =/home/install/workspace/trunk/http/img/tree_new/move_down.pngE´l  H/home/install/workspace/trunk/http/img/button_blink_red/selArea_over.pngD>­¡  N/home/install/workspace/trunk/http/img/button_blink_red/resizemapsize_over.pngE5Ë  H/home/install/workspace/trunk/http/img/button_blink_red/metadata_off.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/metadata_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_down.gifJ)?›  B/home/install/workspace/trunk/http/img/button_gray/rubber_over.gifD>¯g  @/home/install/workspace/trunk/http/img/tree_new/delete_wmsmy.pngE´l  B/home/install/workspace/trunk/http/img/button_gray/measure_off.pngD>½È  C/home/install/workspace/trunk/http/img/button_gray/zoomIn2_over.pngD>½È  ?/home/install/workspace/trunk/http/img/button_gray/tiles_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_blink_red/select_point_on.pngD–€  O/home/install/workspace/trunk/http/img/button_silver_blue/closePolygon_off2.pngHZ3£  </home/install/workspace/trunk/http/img/tree_new/expanded.pngE´l  H/home/install/workspace/trunk/http/img/button_silver_blue/forward_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/addlist_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/addlist_off.pngD>­¡  K/home/install/workspace/trunk/http/img/button_blue/change_password_over.pngD’“ì  @/home/install/workspace/trunk/http/img/button_gray/query_off.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/query_on.gifD>½È  ?/home/install/workspace/trunk/http/img/button_gray/add_over.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/coords_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/select_point_off.pngD–€  B/home/install/workspace/trunk/http/img/button_gray/zoomIn2_off.pngD>¯g  E/home/install/workspace/trunk/http/img/button_blink_red/tiles_off.pngD>­¡  L/home/install/workspace/trunk/http/img/button_blink_red/select_choose_on.pngD–€  C/home/install/workspace/trunk/http/img/button_blink_red/help_on.pngEbÿî  >/home/install/workspace/trunk/http/img/button_blue/home_on.pngD’“ì  >/home/install/workspace/trunk/http/img/button_blue/help_on.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/addwms_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_digitize/geomRemoveDb.pngE¸¹ö  G/home/install/workspace/trunk/http/img/button_digitize/polygon_over.pngD™@Ò  O/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_off.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/zoomfull2_on.pngD>¯g  S/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_off.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/coords_over.pngHZ3£  K/home/install/workspace/trunk/http/img/button_gray/select_rectangle_off.pngD–€‰  H/home/install/workspace/trunk/http/img/button_digitize/move_node_off.pngD™@Ò  B/home/install/workspace/trunk/http/img/button_blue/rubber_over.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/tiles_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.gifD>½È  I/home/install/workspace/trunk/http/img/button_silver_blue/forward_off.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_left.gifJ)?›  9/home/install/workspace/trunk/http/img/arrows/arrow_e.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_gray/back_over_disabled.gifD>¯g  H/home/install/workspace/trunk/http/img/button_gray/exportMapimage_on.pngHb¸  T/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_over.pngHZ3£  N/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_on.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blink_red/select_extent_off.pngD–­Õ  O/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_off.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/select_point_over.pngD–€Z  A/home/install/workspace/trunk/http/img/button_gray/measure_on.gifD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_off.pngD–€  8/home/install/workspace/trunk/http/img/button_gray/x.pngD>¯g  C/home/install/workspace/trunk/http/img/button_gray/forward_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/zoomFull_off.pngD’“ì  ?/home/install/workspace/trunk/http/img/tree_blue/folder_off.gifD’¥â  :/home/install/workspace/trunk/http/img/tree_new/branch.pngE´l  B/home/install/workspace/trunk/http/img/button_digitize/polygon.pngHb¸  ?/home/install/workspace/trunk/http/img/button_gray/wmc_save.pngD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/select_point_off.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/home_on.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/preferences2_off.pngD>­¡  8/home/install/workspace/trunk/http/img/tree_new/leaf.pngE´l  V/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_close.gifJ)?›  4/home/install/workspace/trunk/http/img/tree/file.gifD>¯É  G/home/install/workspace/trunk/http/img/button_silver_blue/center_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/helpbook_over.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/forward_off.pngD>¯g  >/home/install/workspace/trunk/http/img/tree_new/delete_wms.pngE´l  5/home/install/workspace/trunk/http/img/balloon_ur.gifHë«  L/home/install/workspace/trunk/http/css/images/ui-bg_flat_0_aaaaaa_40x100.pngJ)>©  B/home/install/workspace/trunk/http/img/button_blue/reload_over.pngHb¸  ./home/install/workspace/trunk/http/img/add.pngF”¤Ù  I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_load_on.pngHZ3£  >/home/install/workspace/trunk/http/img/tree_gray/file_last.gifD>°¤  D/home/install/workspace/trunk/http/img/button_gray/logoutred_off.pngD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_arrows_updown.gifJ)?›  F/home/install/workspace/trunk/http/img/button_gray/preferences_off.gifD>½È  B/home/install/workspace/trunk/http/img/button_blue/selArea_off.pngD’“ì  ;/home/install/workspace/trunk/http/print/img/northarrow.pngF‘û‰  A/home/install/workspace/trunk/http/img/button_gray/wmc_append.pngD>¯g  A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.gifD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/new_node_off.pngHZ3£  N/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_off.pngHb¸  G/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_on.pngD—΃  @/home/install/workspace/trunk/http/img/button_digitize/point.pngHb¸  S/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_over.pngHZ3£  T/home/install/workspace/trunk/http/extensions/theme/images/454545_11x11_icon_doc.gifJ)?›  M/home/install/workspace/trunk/http/css/images/ui-bg_flat_75_ffffff_40x100.pngJ)>©  G/home/install/workspace/trunk/http/img/openlayers/drag-rectangle-on.pngHw]à  5/home/install/workspace/trunk/http/img/balloon_ul.pngHë«  J/home/install/workspace/trunk/http/img/button_gray/overviewgermany_off.pngD>½È  >/home/install/workspace/trunk/http/img/tree_blue/folder_on.gifD’¥â  >/home/install/workspace/trunk/http/img/button_gray/user_on.gifD>¯g  @/home/install/workspace/trunk/http/img/button_blue/logout_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/forward_over.pngD>¯g  @/home/install/workspace/trunk/http/img/button_gray/query_off.gifD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/add_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_blue/closePolygon_off.pngD’“ì  A/home/install/workspace/trunk/http/img/openlayers/marker-gold.pngHw]à  A/home/install/workspace/trunk/http/img/button_gray/reload_off.pngHb¸  A/home/install/workspace/trunk/http/img/button_digitize/del_on.pngE¬Ìú  @/home/install/workspace/trunk/http/img/button_blue/home_over.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/query_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/wmc_load_off.pngD—΃  B/home/install/workspace/trunk/http/img/button_gray/rubber_over.pngD>¯g  ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_closed.gifJ)?›  ;/home/install/workspace/trunk/http/img/tree_new/move_up.pngE´l  A/home/install/workspace/trunk/http/img/button_gray/query_over.gifD>½È  K/home/install/workspace/trunk/http/img/button_digitize/delete_node_over.pngD™AL  H/home/install/workspace/trunk/http/img/button_silver_blue/point_over.pngHZ3£  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_65_ffffff_1x400.pngJ)>©  O/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_on.pngD–€  H/home/install/workspace/trunk/http/img/button_silver_blue/getArea_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/rubber_off2.pngHZ3£  >/home/install/workspace/trunk/http/img/button_gray/pan_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_gray/zoomFull_off.pngD>¯g  J/home/install/workspace/trunk/http/img/button_silver_blue/selArea_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_digitize/geomInfo.pngIäà  a/home/install/workspace/trunk/http/extensions/theme/images/e6e6e6_40x100_textures_02_glass_75.pngJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_blue/wmc_load_off.pngD’“ì  C/home/install/workspace/trunk/http/img/button_blue/repaint_over.pngD’“ì  M/home/install/workspace/trunk/http/img/openlayers/layer-switcher-minimize.pngHw]à  R/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_up.gifJ)?›  J/home/install/workspace/trunk/http/img/button_silver_blue/forward_over.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/metadata_over.pngD>¯g  A/home/install/workspace/trunk/http/img/button_blue/forward_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_gray/measure_over.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/back_off.pngD’“ì  A/home/install/workspace/trunk/http/img/button_gray/selArea_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/user_off.pngD>¯g  8/home/install/workspace/trunk/http/img/tree_new/info.pngE´l  2/home/install/workspace/trunk/http/img/info_on.gifD>±h  H/home/install/workspace/trunk/http/img/button_blink_red/zoomOut2_off.pngD>­¡  A/home/install/workspace/trunk/http/img/button_gray/repaint_on.pngD>¯g  `/home/install/workspace/trunk/http/extensions/theme/images/ffffff_40x100_textures_01_flat_75.pngJ)?›  R/home/install/workspace/trunk/http/img/button_silver_blue/add_filtered_list_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blue/back_off_disabled.pngD’“ì  N/home/install/workspace/trunk/http/img/button_silver_blue/select_choose_on.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/tiles_off.pngD>½È  @/home/install/workspace/trunk/http/img/button_gray/back_over.gifD>¯g  ?/home/install/workspace/trunk/http/img/tree_new/move_downmy.pngE´l  E/home/install/workspace/trunk/http/img/button_gray/zoomfull2_over.pngD>½È  B/home/install/workspace/trunk/http/img/button_gray/coords_over.pngD>¯g  E/home/install/workspace/trunk/http/img/button_silver_blue/line_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/logout_over.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/repaint_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/wmc_save_off.pngD’“ì  J/home/install/workspace/trunk/http/img/button_silver_blue/move_node_on.pngHZ3£  C/home/install/workspace/trunk/http/img/button_blue/selArea_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_blink_red/center_over.pngD>­¡  ,/home/install/workspace/trunk/http/img/x.gifD>±h  :/home/install/workspace/trunk/http/img/arrows/arrow_sw.gifD>¬¡  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_off.pngHZ3£  6/home/install/workspace/trunk/http/img/scalebar_bw.gifD>±h  ?/home/install/workspace/trunk/http/img/button_gray/print_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_digitize/delete_node_on.pngD™AL  H/home/install/workspace/trunk/http/img/button_gray/select_polygon_on.pngD–€‰  J/home/install/workspace/trunk/http/img/button_blue/forward_on_disabled.pngD’“ì  5/home/install/workspace/trunk/http/img/balloon_ll.gifHë«  H/home/install/workspace/trunk/http/img/button_blink_red/forward_over.pngD>­¡  I/home/install/workspace/trunk/http/img/openlayers/measuring-stick-off.pngHw]à  5/home/install/workspace/trunk/http/img/balloon_ul.gifHë«  K/home/install/workspace/trunk/http/img/button_gray/forward_off_disabled.gifD>¯g  P/home/install/workspace/trunk/http/img/button_blink_red/change_password_over.pngD>­¡  =/home/install/workspace/trunk/http/img/button_blue/pan_on.pngHb¸  B/home/install/workspace/trunk/http/img/button_blue/coords_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_gray/exportMapimage_off.pngHb¸  J/home/install/workspace/trunk/http/img/button_gray/select_polygon_over.pngD–€‰  @/home/install/workspace/trunk/http/img/button_blue/back_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_blink_red/query_on.pngD>­¡  ./home/install/workspace/trunk/http/img/map.pngInQc  L/home/install/workspace/trunk/http/img/button_blue/select_rectangle_over.pngD–€Z  0/home/install/workspace/trunk/http/img/black.gifD>±h  D/home/install/workspace/trunk/http/img/button_blink_red/print_on.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_blue/home_off.pngD’“ì  O/home/install/workspace/trunk/http/img/button_silver_blue/back_off_disabled.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/wmc_load_off.pngD>¯g  4/home/install/workspace/trunk/http/sld/img/minus.gifH`f  H/home/install/workspace/trunk/http/img/button_gray/zoomFullarrow_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/preferences_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/back_off.gifD>¯g  ?/home/install/workspace/trunk/http/img/button_gray/wmc_load.pngD>½È  =/home/install/workspace/trunk/http/img/tree_new/last_leaf.pngE´l  M/home/install/workspace/trunk/http/img/button_blink_red/select_point_over.pngD–€  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_75_e6e6e6_1x400.pngJ)>©  8/home/install/workspace/trunk/http/img/button_gray/x.gifD>¯g  N/home/install/workspace/trunk/http/img/button_silver_blue/delete_node_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_over.pngI¾Y  ./home/install/workspace/trunk/http/img/asc.gifIš‰û  G/home/install/workspace/trunk/http/img/button_blink_red/measure_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_blink_red/up_off.pngH_ÇM  T/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_doc.gifJ)?›  G/home/install/workspace/trunk/http/img/button_blink_red/addwms_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_silver_blue/reload_on.pngHZ3£  D/home/install/workspace/trunk/http/img/button_blink_red/help3_on.pngD>­¡  A/home/install/workspace/trunk/http/img/button_blue/repaint_on.pngD’“ì  R/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/coods_on.gifD>½È  J/home/install/workspace/trunk/http/img/button_silver_blue/polygon_over.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/help_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blink_red/preferences2_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/center_on.pngD>­¡  M/home/install/workspace/trunk/http/img/button_silver_blue/select_point_on.pngHZ3£  :/home/install/workspace/trunk/http/img/tree_new/closed.pngE´l  Q/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blue/measure_off.pngD’“ì  9/home/install/workspace/trunk/http/img/tree/file_vert.gifD>¯É  I/home/install/workspace/trunk/http/css/images/ui-icons_2e83ff_256x240.pngJ)>©  :/home/install/workspace/trunk/http/sld/img/map_magnify.pngH`f  J/home/install/workspace/trunk/http/img/button_blue/select_rectangle_on.pngD–€Z  A/home/install/workspace/trunk/http/img/button_gray/coods_over.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/center_off.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/change_password_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blue/preferences_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_silver_blue/del_on.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/query_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/line_off.pngHZ3£  R/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_up.gifJ)?›  ?/home/install/workspace/trunk/http/img/tree_blue/file_empty.gifD’¥â  E/home/install/workspace/trunk/http/img/button_blink_red/print_off.pngD>­¡  E/home/install/workspace/trunk/http/img/button_blink_red/help_over.pngD>­¡  2/home/install/workspace/trunk/http/img/tree/1w.gifD>¯É  5/home/install/workspace/trunk/http/sld/img/script.pngH`f  1/home/install/workspace/trunk/http/img/resize.gifFú“  J/home/install/workspace/trunk/http/img/button_gray/change_password_off.gifD>¯g  A/home/install/workspace/trunk/http/img/button_gray/zoomIn2_on.pngD>½È  R/home/install/workspace/trunk/http/img/button_silver_blue/select_rectangle_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/query_off.pngHZ3£  O/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_over.pngHb¸  8/home/install/workspace/trunk/http/img/tree_new/menu.pngE´l  J/home/install/workspace/trunk/http/img/button_gray/change_password_off.pngD>¯g  5/home/install/workspace/trunk/http/img/balloon_ur.pngHë«  A/home/install/workspace/trunk/http/img/button_gray/repaint_on.gifD>¯g  G/home/install/workspace/trunk/http/img/button_blue/select_point_off.pngD–€Z  B/home/install/workspace/trunk/http/img/button_blue/forward_off.pngD’“ì  H/home/install/workspace/trunk/http/img/button_silver_blue/polygon_on.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blink_red/preferences_on.pngD>­¡  3/home/install/workspace/trunk/http/img/digitize.pngInQc  O/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_on.pngHZ3£  @/home/install/workspace/trunk/http/img/tree_orange/file_vert.gifD>°Ø  7/home/install/workspace/trunk/http/img/tree_gray/1w.gifD>°¤  G/home/install/workspace/trunk/http/img/button_silver_blue/shape_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_blue/select_extent_on.pngD–­ø  ^/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_arrows_updown.gifJ)?›  D/home/install/workspace/trunk/http/img/button_blink_red/help_off.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blue/wmc_save_off_old.pngD’“ì  Q/home/install/workspace/trunk/http/img/button_silver_blue/select_polygon_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/wmc_load_on.pngD>¯g  B/home/install/workspace/trunk/http/img/button_gray/selArea_off.pngD>¯g  :/home/install/workspace/trunk/http/img/button_gray/del.pngD>½È  G/home/install/workspace/trunk/http/img/button_gray/select_extent_on.pngD–®s  P/home/install/workspace/trunk/http/img/button_blink_red/add_filtered_list_on.pngD>­¡  B/home/install/workspace/trunk/http/img/button_digitize/del_off.pngE¬Ìú  C/home/install/workspace/trunk/http/img/button_digitize/point_on.pngD™@Ò  K/home/install/workspace/trunk/http/img/button_blue/forward_off_disabled.pngD’“ì  G/home/install/workspace/trunk/http/img/button_gray/closePolygon_off.gifD>¯g  D/home/install/workspace/trunk/http/img/button_gray/gazetteer_off.gifD>¯g  B/home/install/workspace/trunk/http/img/button_gray/helpbook_on.pngD>¯g  K/home/install/workspace/trunk/http/img/button_gray/overviewgermany_over.gifD>¯g  :/home/install/workspace/trunk/http/img/tree/folder_off.gifD>¯É  A/home/install/workspace/trunk/http/img/tree_orange/file_empty.gifD>°Ø  9/home/install/workspace/trunk/http/img/tree_new/error.pngE´l  7/home/install/workspace/trunk/http/img/sandclock_oo.gifD>±h  G/home/install/workspace/trunk/http/img/button_silver_blue/line_over.pngHZ3£  E/home/install/workspace/trunk/http/img/button_digitize/polygon_on.pngD™@Ò  ?/home/install/workspace/trunk/http/img/button_digitize/line.pngHb¸  D/home/install/workspace/trunk/http/img/button_silver_blue/pan_on.pngHZ3£  G/home/install/workspace/trunk/http/img/button_blink_red/coords_over.pngD>­¡  E/home/install/workspace/trunk/http/img/button_silver_blue/del_off.pngHZ3£  6/home/install/workspace/trunk/http/img/exclamation.pngJ.  K/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_over.pngHZ3£  U/home/install/workspace/trunk/http/extensions/theme/images/454545_7x7_arrow_right.gifJ)?›  H/home/install/workspace/trunk/http/img/button_silver_blue/measure_on.pngHZ3£  ;/home/install/workspace/trunk/http/img/button_gray/save.gifD>½È  B/home/install/workspace/trunk/http/img/button_gray/repaint_off.pngD>¯g  L/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_off.pngI¾Y  P/home/install/workspace/trunk/http/img/button_silver_blue/back_over_disabled.pngHZ3£  >/home/install/workspace/trunk/http/img/tree_gray/file_vert.gifD>°¤  E/home/install/workspace/trunk/http/img/button_blink_red/exit_over.pngD>­¡  0/home/install/workspace/trunk/http/img/admin.pngInQc  >/home/install/workspace/trunk/http/img/tree_blue/file_vert.gifD’¥â  </home/install/workspace/trunk/http/img/background_yellow.jpgDÀË,  O/home/install/workspace/trunk/http/img/button_silver_blue/resizemapsize_off.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/print_off.pngHZ3£  J/home/install/workspace/trunk/http/img/button_blue/change_password_off.pngD’“ì  Q/home/install/workspace/trunk/http/img/button_silver_blue/change_password_off.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/coods_off.gifD>¯g  >/home/install/workspace/trunk/http/img/button_gray/smaller.pngD>½È  Q/home/install/workspace/trunk/http/img/button_blink_red/select_rectangle_over.pngD–€  D/home/install/workspace/trunk/http/img/button_gray/wmc_load_over.pngD>¯g  I/home/install/workspace/trunk/http/css/images/ui-icons_222222_256x240.pngJ)>©  N/home/install/workspace/trunk/http/img/button_silver_blue/select_extent_on.pngHZ3£  G/home/install/workspace/trunk/http/img/button_silver_blue/back_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_blink_red/add_on.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/select_choose_on.pngD–€‰  J/home/install/workspace/trunk/http/img/button_gray/exportMapimage_over.pngHb¸  9/home/install/workspace/trunk/http/img/tree_orange/1w.gifD>°Ø  A/home/install/workspace/trunk/http/img/button_blue/zoomIn2_on.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/measure_on.pngD>­¡  L/home/install/workspace/trunk/http/img/button_silver_blue/move_node_over.pngHZ3£  H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blue/gazetteer_on.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/selArea_off.pngHZ3£  C/home/install/workspace/trunk/http/img/button_gray/measure_over.gifD>¯g  C/home/install/workspace/trunk/http/img/button_gray/wmc_save_off.pngD>¯g  8/home/install/workspace/trunk/http/img/header_yellow.jpgD™8B  E/home/install/workspace/trunk/http/img/button_blink_red/back_over.pngD>­¡  L/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_off.gifD>¯g  C/home/install/workspace/trunk/http/img/button_blue/measure_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/reload_over.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/repaint_off.gifD>¯g  2/home/install/workspace/trunk/http/img/eye_on_.gifD>±h  H/home/install/workspace/trunk/http/img/button_blink_red/logout_over2.pngD>­¡  8/home/install/workspace/trunk/http/img/tree_new/zoom.pngE´l  C/home/install/workspace/trunk/http/img/tree_new/expanded_folder.pngE´l  V/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_minus.gifJ)?›  A/home/install/workspace/trunk/http/img/tree_new/last_expanded.pngE´l  K/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_off.pngH¾…Å  B/home/install/workspace/trunk/http/img/button_gray/zoomOut2_on.pngD>¯g  I/home/install/workspace/trunk/http/img/button_blue/back_over_disabled.pngD’“ì  >/home/install/workspace/trunk/http/sld/img/script_code_red.pngH`f  H/home/install/workspace/trunk/http/img/button_silver_blue/selArea_on.pngHZ3£  B/home/install/workspace/trunk/http/img/button_gray/measure_off.gifD>¯g  G/home/install/workspace/trunk/http/img/button_blue/back_on_disabled.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/pan_over.pngHZ3£  1/home/install/workspace/trunk/http/img/eye_on.gifD>±h  H/home/install/workspace/trunk/http/img/button_blue/select_polygon_on.pngD–€Z  R/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_up.gifJ)?›  ?/home/install/workspace/trunk/http/img/tree_gray/folder_off.gifD>°¤  I/home/install/workspace/trunk/http/img/button_gray/select_choose_over.pngD–€‰  E/home/install/workspace/trunk/http/img/button_gray/gazetteer_over.pngD>¯g  L/home/install/workspace/trunk/http/img/button_blink_red/select_extent_on.pngD–­Õ  @/home/install/workspace/trunk/http/img/openlayers/north-mini.pngHw]à  L/home/install/workspace/trunk/http/img/button_gray/forward_over_disabled.pngD>¯g  8/home/install/workspace/trunk/http/sld/img/lightning.pngH`f  D/home/install/workspace/trunk/http/img/button_blue/wmc_load_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_blink_red/reload_off.pngHb¸  P/home/install/workspace/trunk/http/img/button_silver_blue/exportMapimage_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/pan_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_blue/wmc_save_over.pngD’“ì  F/home/install/workspace/trunk/http/img/button_silver_blue/geomInfo.pngHZ3£  1/home/install/workspace/trunk/http/img/pencil.pngGJÌ   F/home/install/workspace/trunk/http/img/button_blink_red/logout_off.pngD>­¡  H/home/install/workspace/trunk/http/img/button_silver_blue/reload_off.pngHZ3£  -/home/install/workspace/trunk/http/img/bg.gifIš‰û  C/home/install/workspace/trunk/http/img/button_blink_red/pan_off.pngD>­¡  F/home/install/workspace/trunk/http/img/button_gray/select_point_on.pngD–€‰  3/home/install/workspace/trunk/http/img/info_off.gifD>±h  F/home/install/workspace/trunk/http/img/button_blink_red/center_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_gray/forward_off.gifD>¯g  M/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_on.pngD–€  E/home/install/workspace/trunk/http/img/button_blink_red/coords_on.pngD>­¡  2/home/install/workspace/trunk/http/img/eye_off.gifD>±h  @/home/install/workspace/trunk/http/img/button_blue/center_on.pngD’“ì  F/home/install/workspace/trunk/http/img/openlayers/panning-hand-off.pngHw]à  a/home/install/workspace/trunk/http/extensions/theme/images/dadada_40x100_textures_02_glass_75.pngJ)?›  P/home/install/workspace/trunk/http/img/button_blink_red/overviewgermany_over.pngD>­¡  ?/home/install/workspace/trunk/http/img/button_gray/help_off.pngD>¯g  G/home/install/workspace/trunk/http/img/button_silver_blue/rubber_on.pngHZ3£  5/home/install/workspace/trunk/http/img/balloon_lr.pngHë«  C/home/install/workspace/trunk/http/img/button_blink_red/add_off.pngD>­¡  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_55_fbf9ee_1x400.pngJ)>©  A/home/install/workspace/trunk/http/img/openlayers/marker-blue.pngHw]à  B/home/install/workspace/trunk/http/img/button_gray/center_over.pngD>¯g  N/home/install/workspace/trunk/http/img/button_blink_red/select_polygon_off.pngD–€  M/home/install/workspace/trunk/http/css/images/ui-bg_glass_95_fef1ec_1x400.pngJ)>©  @/home/install/workspace/trunk/http/img/openlayers/south-mini.pngHw]à  B/home/install/workspace/trunk/http/img/openlayers/marker-green.pngHw]à  @/home/install/workspace/trunk/http/img/tree_orange/folder_on.gifD>°Ø  L/home/install/workspace/trunk/http/img/button_digitize/splitPolygon_over.pngH¾…Å  F/home/install/workspace/trunk/http/img/button_silver_blue/del_over.pngHZ3£  @/home/install/workspace/trunk/http/img/button_gray/center_on.gifD>¯g  \/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_folder_open.gifJ)?›  ^/home/install/workspace/trunk/http/extensions/theme/images/888888_11x11_icon_arrows_updown.gifJ)?›  @/home/install/workspace/trunk/http/img/tree_new/error_folder.pngE´l  I/home/install/workspace/trunk/http/img/button_silver_blue/repaint_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_blue/coords_off.pngD’“ì  I/home/install/workspace/trunk/http/img/button_blue/change_password_on.pngD’“ì  C/home/install/workspace/trunk/http/img/button_digitize/del_over.pngE¬Ìú  I/home/install/workspace/trunk/http/img/button_gray/overviewgermany_on.pngD>¯g  C/home/install/workspace/trunk/http/img/button_blue/zoomIn2_over.pngD’“ì  T/home/install/workspace/trunk/http/extensions/theme/images/888888_7x7_arrow_left.gifJ)?›  @/home/install/workspace/trunk/http/img/button_gray/center_on.pngD>¯g  ?/home/install/workspace/trunk/http/img/button_blue/query_on.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/wmc_save_on.pngHZ3£  I/home/install/workspace/trunk/http/img/button_silver_blue/center_over.pngHZ3£  M/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_over.pngD’“ì  I/home/install/workspace/trunk/http/img/button_silver_blue/zoomFull_on.pngHZ3£  H/home/install/workspace/trunk/http/img/button_blink_red/wmc_save_off.pngD—΃  Z/home/install/workspace/trunk/http/extensions/theme/images/222222_11x11_icon_resize_se.gifJ)?›  K/home/install/workspace/trunk/http/img/button_gray/add_filtered_list_on.gifD>½È  D/home/install/workspace/trunk/http/img/button_blue/zoomOut2_over.pngD’“ì  G/home/install/workspace/trunk/http/img/button_gray/select_point_off.pngD–€‰  ;/home/install/workspace/trunk/http/img/openlayers/blank.gifHw]à  I/home/install/workspace/trunk/http/img/button_silver_blue/addlist_off.pngHZ3£  ?/home/install/workspace/trunk/http/img/button_gray/coods_on.pngD>¯g  T/home/install/workspace/trunk/http/extensions/theme/images/222222_7x7_arrow_left.gifJ)?›  B/home/install/workspace/trunk/http/img/button_gray/zoomFull_on.pngD>¯g  D/home/install/workspace/trunk/http/img/button_blue/gazetteer_off.pngD’“ì  ?/home/install/workspace/trunk/http/img/button_blue/pan_over.pngHb¸  M/home/install/workspace/trunk/http/img/button_blink_red/back_off_disabled.pngD>­¡  K/home/install/workspace/trunk/http/img/button_silver_blue/move_node_off.pngHZ3£  D/home/install/workspace/trunk/http/img/button_gray/wmc_save_over.pngD>¯g  L/home/install/workspace/trunk/http/img/button_digitize/punchPolygon_over.pngI¾p  D/home/install/workspace/trunk/http/img/openlayers/zoom-plus-mini.pngHw]à  J/home/install/workspace/trunk/http/img/button_blink_red/zoomfull2_over.pngD>­¡  G/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_on.pngD>­¡  G/home/install/workspace/trunk/http/img/button_gray/preferences_over.gifD>¯g  D/home/install/workspace/trunk/http/img/button_digitize/line_over.pngD™Ao  K/home/install/workspace/trunk/http/img/button_gray/change_password_over.gifD>¯g  0/home/install/workspace/trunk/http/img/layer.gifEìM  A/home/install/workspace/trunk/http/img/button_gray/print_over.pngD>¯g  G/home/install/workspace/trunk/http/img/button_blink_red/forward_off.pngD>­¡  B/home/install/workspace/trunk/http/img/button_gray/logout_over.pngD>½È  C/home/install/workspace/trunk/http/img/button_gray/metadata_off.gifD>¯g  =/home/install/workspace/trunk/http/img/tree_new/move_upmy.pngE´l  @/home/install/workspace/trunk/http/img/button_gray/home_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_gray/back_off_disabled.gifD>¯g  E/home/install/workspace/trunk/http/img/openlayers/zoom-minus-mini.pngHw]à  M/home/install/workspace/trunk/http/img/button_blink_red/exportMapimage_on.pngHb¸  A/home/install/workspace/trunk/http/img/button_blue/measure_on.pngD’“ì  H/home/install/workspace/trunk/http/img/button_blink_red/zoomFull_off.pngD>­¡  D/home/install/workspace/trunk/http/img/button_blink_red/back_off.pngD>­¡  N/home/install/workspace/trunk/http/img/button_blink_red/select_choose_over.pngD–€  ;/home/install/workspace/trunk/http/img/button_gray/down.pngDÀ¼Ÿ  C/home/install/workspace/trunk/http/img/button_blink_red/down_on.pngH_ÇM  ?/home/install/workspace/trunk/http/img/openlayers/west-mini.pngHw]à  2/home/install/workspace/trunk/http/img/redball.gifD>±h  H/home/install/workspace/trunk/http/classes/phpmailer-1.72/test/rocks.pngD>¨´  J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_over.pngHZ3£  J/home/install/workspace/trunk/http/img/button_silver_blue/zoomIn2_over.pngHZ3£  F/home/install/workspace/trunk/http/img/button_blink_red/query_over.pngD>­¡  H/home/install/workspace/trunk/http/img/button_blink_red/measure_over.pngD>­¡  D/home/install/workspace/trunk/http/img/button_blue/zoomFull_over.pngD’“ì  D/home/install/workspace/trunk/http/img/button_gray/metadata_over.gifD>¯g  B/home/install/workspace/trunk/http/img/button_blue/getArea_off.pngD’“ì  :/home/install/workspace/trunk/http/img/arrows/arrow_nw.gifD>¬¡  I/home/install/workspace/trunk/http/css/images/ui-icons_454545_256x240.pngJ)>©  E/home/install/workspace/trunk/http/img/button_blink_red/addwms_on.pngD>­¡  E/home/install/workspace/trunk/http/img/button_silver_blue/pan_off.pngHZ3£  </home/install/workspace/trunk/http/img/openlayers/slider.pngHw]à  H/home/install/workspace/trunk/http/img/button_gray/select_extent_off.pngD–€‰  7/home/install/workspace/trunk/http/img/mapbender_oo.pngD™?ä  E/home/install/workspace/trunk/http/img/button_blue/preferences_on.pngD’“ì  K/home/install/workspace/trunk/http/img/button_blue/add_filtered_list_on.pngD’“ì  A/home/install/workspace/trunk/http/img/button_blue/center_off.pngD’“ì  K/home/install/workspace/trunk/http/img/button_digitize/mergePolygons_on.pngI¾Y  F/home/install/workspace/trunk/http/img/button_silver_blue/back_off.pngHZ3£  A/home/install/workspace/trunk/http/img/button_gray/center_off.gifD>¯g  H/home/install/workspace/trunk/http/img/button_blue/closePolygon_over.pngD’“ì  >/home/install/workspace/trunk/http/img/button_gray/logo_en.jpgD>½È  @/home/install/workspace/trunk/http/img/button_gray/help_over.pngD>¯g  H/home/install/workspace/trunk/http/img/button_blue/select_extent_off.pngD–€Z  H/home/install/workspace/trunk/http/img/button_blink_red/zoomIn2_over.pngD>­¡  J/home/install/workspace/trunk/http/img/button_silver_blue/getArea_off2.pngHZ3£  F/home/install/workspace/trunk/http/img/button_silver_blue/print_on.pngHZ3£  J/home/install/workspace/trunk/http/img/button_gray/select_rectangle_on.pngD–€‰  ?/home/install/workspace/trunk/http/img/button_gray/home_off.pngD>¯g
\ No newline at end of file
Deleted: branches/kmq_dev/documents/api_js/Data/ImageReferenceTable.nd
--- trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/ImageReferenceTable.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/Data/ImageReferenceTable.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/ImageReferenceTable.nd)
--- branches/kmq_dev/documents/api_js/Data/ImageReferenceTable.nd	                        (rev 0)
@@ -0,0 +1 @@
Deleted: branches/kmq_dev/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/IndexInfo.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1 +0,0 @@
-(    General            Function                   Variable                       Class
Copied: branches/kmq_dev/documents/api_js/Data/IndexInfo.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/IndexInfo.nd)
--- branches/kmq_dev/documents/api_js/Data/IndexInfo.nd	                        (rev 0)
@@ -0,0 +1 @@
+(    General            Function                   Variable                       Class
Deleted: branches/kmq_dev/documents/api_js/Data/PreviousMenuState.nd
--- trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/PreviousMenuState.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,2 +0,0 @@
-(    	Mapbender  	Mapbender 7/home/install/workspace/trunk/http/javascripts/core.php  Event */home/install/workspace/trunk/lib/event.js  Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js modules  Reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php  	Sandclock @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php  ZoomIn1 >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php    SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js Index
-Everything general Classes class 	Functions function 	Variables variable
Copied: branches/kmq_dev/documents/api_js/Data/PreviousMenuState.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd)
--- branches/kmq_dev/documents/api_js/Data/PreviousMenuState.nd	                        (rev 0)
@@ -0,0 +1,2 @@
+(    	Mapbender  	Mapbender 7/home/install/workspace/trunk/http/javascripts/core.php  Event */home/install/workspace/trunk/lib/event.js  Map 9/home/install/workspace/trunk/http/javascripts/map_obj.js modules  Reload =/home/install/workspace/trunk/http/javascripts/mod_reload.php  	Sandclock @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php  ZoomIn1 >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php    SearchPanel 5/home/install/workspace/trunk/docs/javascript/main.js Index
+Everything general Classes class 	Functions function 	Variables variable
Deleted: branches/kmq_dev/documents/api_js/Data/PreviousSettings.nd
--- trunk/mapbender/documents/api_js/Data/PreviousSettings.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/PreviousSettings.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1 +0,0 @@
-(         /home/install/workspace/trunk 1 ./home/install/workspace/trunk/documents/api_js HTML
Copied: branches/kmq_dev/documents/api_js/Data/PreviousSettings.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/PreviousSettings.nd)
--- branches/kmq_dev/documents/api_js/Data/PreviousSettings.nd	                        (rev 0)
@@ -0,0 +1 @@
+(         /home/install/workspace/trunk 1 ./home/install/workspace/trunk/documents/api_js HTML
Deleted: branches/kmq_dev/documents/api_js/Data/SymbolTable.nd
--- trunk/mapbender/documents/api_js/Data/SymbolTable.nd	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Data/SymbolTable.nd	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-(    SearchPanel mode  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.mode \The mode the search is going to work in, such as &quot;HTML&quot; or &quot;FramedHTML&quot;.
-SearchResults Toggle  5/home/install/workspace/trunk/docs/javascript/main.js function this.Toggle = function(id) 0Toggles the visibility of the passed element ID. SearchPanel deactivateTimeout  5/home/install/workspace/trunk/docs/javascript/main.js variable   aThe timeout used between when a control is deactivated and when the entire panel is deactivated.  Reload 	Functions  =/home/install/workspace/trunk/http/javascripts/mod_reload.php group     SearchPanel Action Functions  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel lastResultsPage  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastResultsPage The last results page.  SearchPanel DOMSearchField  5/home/install/workspace/trunk/docs/javascript/main.js function  this.DOMSearchField = function()   SearchPanel
-keyTimeout  5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeout DThe timeout used between a keystroke and when a search is performed. Reload  =/home/install/workspace/trunk/http/javascripts/mod_reload.php class   'A button that reloads the whole window. SearchPanel InactivateAfterTimeout  5/home/install/workspace/trunk/docs/javascript/main.js function (this.InactivateAfterTimeout = function() ÇCalled by <link target="inactivateTimeout" name="inactivateTimeout" original="&lt;inactivateTimeout&gt;">, which is set by <link target="Activate()" name="Activate()" original="&lt;Activate()&gt;">.  SearchPanel OnSearchTypeChange  5/home/install/workspace/trunk/docs/javascript/main.js function $this.OnSearchTypeChange = function() 'Called when the search type is changed. SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js class   =A class handling everything associated with the search panel. SearchPanel
-DOMSearchType  5/home/install/workspace/trunk/docs/javascript/main.js function this.DOMSearchType = function()
-SearchResults mode  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.mode \The mode the search is going to work in, such as &quot;HTML&quot; or &quot;FramedHTML&quot;.
-SearchResults 	Variables  5/home/install/workspace/trunk/docs/javascript/main.js group     	Sandclock hide  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.hide = function () Hides the sandclock Map Map  9/home/install/workspace/trunk/http/javascripts/map_obj.js function KMapbender.Map = function (frameName, elementName, width, height, wms_index)   SearchPanel name  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.name PThe name of the global variable that will be storing this instance of the class.
-SearchResults Search  5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function(search)  Searches for the passed string.  	Sandclock 	Functions  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php group     SearchPanel Event Handlers  5/home/install/workspace/trunk/docs/javascript/main.js group     	Mapbender  7/home/install/workspace/trunk/http/javascripts/core.php class   4All Mapbender functionality is within this namespace SearchPanel lastSearchValue  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastSearchValue <The last search string executed, or an empty string if none. 	Sandclock  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php class   .Displays an arbitrary sandclock image on a map SearchPanel DOMPopupSearchResultsWindow  5/home/install/workspace/trunk/docs/javascript/main.js function -this.DOMPopupSearchResultsWindow = function()
-SearchResults lastMatchCount  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastMatchCount pThe number of matches from the last run of <link target="Search()" name="Search()" original="&lt;Search()&gt;">. SearchPanel DOMSearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js function  this.DOMSearchPanel = function()   SearchPanel Activate  5/home/install/workspace/trunk/docs/javascript/main.js function 9this.Activate = function(isActive, ignoreDeactivateDelay) bActivates or deactivates the search panel, resetting things to their default values if necessary.  Map  9/home/install/workspace/trunk/http/javascripts/map_obj.js class   DThis is the central module for displaying the composite map overlay.
-SearchResults  5/home/install/workspace/trunk/docs/javascript/main.js class   =The class that handles everything on the search results page. SearchPanel deactivateTimeoutLength  5/home/install/workspace/trunk/docs/javascript/main.js variable this.deactivateTimeoutLength ‰The length of <link target="deactivateTimeout" name="deactivateTimeout" original="&lt;deactivateTimeout&gt;"> in thousandths of a second.
-SearchResults 	Functions  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel DOM Elements  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel Activation Functions  5/home/install/workspace/trunk/docs/javascript/main.js group   @Functions that handle whether the entire panel is active or not. Event  */home/install/workspace/trunk/lib/event.js class
-An event.  SearchPanel keyTimeoutLength  5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeoutLength tThe length of <link target="keyTimeout" name="keyTimeout" original="&lt;keyTimeout&gt;"> in thousandths of a second. SearchPanel DOMPopupSearchResults  5/home/install/workspace/trunk/docs/javascript/main.js function 'this.DOMPopupSearchResults = function()   SearchPanel Search  5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function() Performs a search. Reload reload  =/home/install/workspace/trunk/http/javascripts/mod_reload.php function this.reload = function () Reloads the window. Map 	setExtent  9/home/install/workspace/trunk/http/javascripts/map_obj.js function 1this.setExtent = function(minx, miny, maxx, maxy) set the extent of the wms SearchPanel resultsPath  5/home/install/workspace/trunk/docs/javascript/main.js variable this.resultsPath KThe relative path from the current HTML page to the results page directory. SearchPanel OnSearchFieldFocus  5/home/install/workspace/trunk/docs/javascript/main.js function ,this.OnSearchFieldFocus = function(isActive) <Called when focus is added or removed from the search field. SearchPanel CloseResultsWindow  5/home/install/workspace/trunk/docs/javascript/main.js function $this.CloseResultsWindow = function() Closes the results window. ZoomIn1  >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php class   ƒClick button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number).  Map 	Functions  9/home/install/workspace/trunk/http/javascripts/map_obj.js group     SearchPanel 	Variables  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel OnSearchTypeFocus  5/home/install/workspace/trunk/docs/javascript/main.js function +this.OnSearchTypeFocus = function(isActive) ;Called when focus is added or removed from the search type. SearchPanel OnSearchFieldChange  5/home/install/workspace/trunk/docs/javascript/main.js function %this.OnSearchFieldChange = function() 7Called when the content of the search field is changed. 	Sandclock show  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.show = function (mapId) Displays the sandclock  Search
-JavaScript
-SearchResults  5/home/install/workspace/trunk/docs/javascript/main.js inactivateTimeout
-JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js lastSearchValue
-JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js Activate
-JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js NaturalDocs Builder Base CommandLineOption
-JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js deactivateTimeout
-keyTimeout
Copied: branches/kmq_dev/documents/api_js/Data/SymbolTable.nd (from rev 4267, trunk/mapbender/documents/api_js/Data/SymbolTable.nd)
--- branches/kmq_dev/documents/api_js/Data/SymbolTable.nd	                        (rev 0)
@@ -0,0 +1,20 @@
+(    SearchPanel mode  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.mode \The mode the search is going to work in, such as &quot;HTML&quot; or &quot;FramedHTML&quot;.
+SearchResults Toggle  5/home/install/workspace/trunk/docs/javascript/main.js function this.Toggle = function(id) 0Toggles the visibility of the passed element ID. SearchPanel deactivateTimeout  5/home/install/workspace/trunk/docs/javascript/main.js variable   aThe timeout used between when a control is deactivated and when the entire panel is deactivated.  Reload 	Functions  =/home/install/workspace/trunk/http/javascripts/mod_reload.php group     SearchPanel Action Functions  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel lastResultsPage  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastResultsPage The last results page.  SearchPanel DOMSearchField  5/home/install/workspace/trunk/docs/javascript/main.js function  this.DOMSearchField = function()   SearchPanel
+keyTimeout  5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeout DThe timeout used between a keystroke and when a search is performed. Reload  =/home/install/workspace/trunk/http/javascripts/mod_reload.php class   'A button that reloads the whole window. SearchPanel InactivateAfterTimeout  5/home/install/workspace/trunk/docs/javascript/main.js function (this.InactivateAfterTimeout = function() ÇCalled by <link target="inactivateTimeout" name="inactivateTimeout" original="&lt;inactivateTimeout&gt;">, which is set by <link target="Activate()" name="Activate()" original="&lt;Activate()&gt;">.  SearchPanel OnSearchTypeChange  5/home/install/workspace/trunk/docs/javascript/main.js function $this.OnSearchTypeChange = function() 'Called when the search type is changed. SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js class   =A class handling everything associated with the search panel. SearchPanel
+DOMSearchType  5/home/install/workspace/trunk/docs/javascript/main.js function this.DOMSearchType = function()
+SearchResults mode  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.mode \The mode the search is going to work in, such as &quot;HTML&quot; or &quot;FramedHTML&quot;.
+SearchResults 	Variables  5/home/install/workspace/trunk/docs/javascript/main.js group     	Sandclock hide  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.hide = function () Hides the sandclock Map Map  9/home/install/workspace/trunk/http/javascripts/map_obj.js function KMapbender.Map = function (frameName, elementName, width, height, wms_index)   SearchPanel name  5/home/install/workspace/trunk/docs/javascript/main.js variable 	this.name PThe name of the global variable that will be storing this instance of the class.
+SearchResults Search  5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function(search)  Searches for the passed string.  	Sandclock 	Functions  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php group     SearchPanel Event Handlers  5/home/install/workspace/trunk/docs/javascript/main.js group     	Mapbender  7/home/install/workspace/trunk/http/javascripts/core.php class   4All Mapbender functionality is within this namespace SearchPanel lastSearchValue  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastSearchValue <The last search string executed, or an empty string if none. 	Sandclock  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php class   .Displays an arbitrary sandclock image on a map SearchPanel DOMPopupSearchResultsWindow  5/home/install/workspace/trunk/docs/javascript/main.js function -this.DOMPopupSearchResultsWindow = function()
+SearchResults lastMatchCount  5/home/install/workspace/trunk/docs/javascript/main.js variable this.lastMatchCount pThe number of matches from the last run of <link target="Search()" name="Search()" original="&lt;Search()&gt;">. SearchPanel DOMSearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js function  this.DOMSearchPanel = function()   SearchPanel Activate  5/home/install/workspace/trunk/docs/javascript/main.js function 9this.Activate = function(isActive, ignoreDeactivateDelay) bActivates or deactivates the search panel, resetting things to their default values if necessary.  Map  9/home/install/workspace/trunk/http/javascripts/map_obj.js class   DThis is the central module for displaying the composite map overlay.
+SearchResults  5/home/install/workspace/trunk/docs/javascript/main.js class   =The class that handles everything on the search results page. SearchPanel deactivateTimeoutLength  5/home/install/workspace/trunk/docs/javascript/main.js variable this.deactivateTimeoutLength ‰The length of <link target="deactivateTimeout" name="deactivateTimeout" original="&lt;deactivateTimeout&gt;"> in thousandths of a second.
+SearchResults 	Functions  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel DOM Elements  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel Activation Functions  5/home/install/workspace/trunk/docs/javascript/main.js group   @Functions that handle whether the entire panel is active or not. Event  */home/install/workspace/trunk/lib/event.js class
+An event.  SearchPanel keyTimeoutLength  5/home/install/workspace/trunk/docs/javascript/main.js variable this.keyTimeoutLength tThe length of <link target="keyTimeout" name="keyTimeout" original="&lt;keyTimeout&gt;"> in thousandths of a second. SearchPanel DOMPopupSearchResults  5/home/install/workspace/trunk/docs/javascript/main.js function 'this.DOMPopupSearchResults = function()   SearchPanel Search  5/home/install/workspace/trunk/docs/javascript/main.js function this.Search = function() Performs a search. Reload reload  =/home/install/workspace/trunk/http/javascripts/mod_reload.php function this.reload = function () Reloads the window. Map 	setExtent  9/home/install/workspace/trunk/http/javascripts/map_obj.js function 1this.setExtent = function(minx, miny, maxx, maxy) set the extent of the wms SearchPanel resultsPath  5/home/install/workspace/trunk/docs/javascript/main.js variable this.resultsPath KThe relative path from the current HTML page to the results page directory. SearchPanel OnSearchFieldFocus  5/home/install/workspace/trunk/docs/javascript/main.js function ,this.OnSearchFieldFocus = function(isActive) <Called when focus is added or removed from the search field. SearchPanel CloseResultsWindow  5/home/install/workspace/trunk/docs/javascript/main.js function $this.CloseResultsWindow = function() Closes the results window. ZoomIn1  >/home/install/workspace/trunk/http/javascripts/mod_zoomIn1.php class   ƒClick button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number).  Map 	Functions  9/home/install/workspace/trunk/http/javascripts/map_obj.js group     SearchPanel 	Variables  5/home/install/workspace/trunk/docs/javascript/main.js group     SearchPanel OnSearchTypeFocus  5/home/install/workspace/trunk/docs/javascript/main.js function +this.OnSearchTypeFocus = function(isActive) ;Called when focus is added or removed from the search type. SearchPanel OnSearchFieldChange  5/home/install/workspace/trunk/docs/javascript/main.js function %this.OnSearchFieldChange = function() 7Called when the content of the search field is changed. 	Sandclock show  @/home/install/workspace/trunk/http/javascripts/mod_sandclock.php function this.show = function (mapId) Displays the sandclock  Search
+JavaScript
+SearchResults  5/home/install/workspace/trunk/docs/javascript/main.js inactivateTimeout
+JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js lastSearchValue
+JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js Activate
+JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js NaturalDocs Builder Base CommandLineOption
+JavaScript SearchPanel  5/home/install/workspace/trunk/docs/javascript/main.js deactivateTimeout
+keyTimeout
Deleted: branches/kmq_dev/documents/api_js/Languages.txt
--- trunk/mapbender/documents/api_js/Languages.txt	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Languages.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,113 +0,0 @@
-Format: 1.4
-# This is the Natural Docs languages file for this project.  If you change
-# anything here, it will apply to THIS PROJECT ONLY.  If you'd like to change
-# something for all your projects, edit the Languages.txt in Natural Docs'
-# Config directory instead.
-# You can prevent certain file extensions from being scanned like this:
-# Ignore Extensions: [extension] [extension] ...
-# SYNTAX:
-# Unlike other Natural Docs configuration files, in this file all comments
-# MUST be alone on a line.  Some languages deal with the # character, so you
-# cannot put comments on the same line as content.
-# Also, all lists are separated with spaces, not commas, again because some
-# languages may need to use them.
-# Language: [name]
-# Alter Language: [name]
-#    Defines a new language or alters an existing one.  Its name can use any
-#    characters.  If any of the properties below have an add/replace form, you
-#    must use that when using Alter Language.
-#    The language Shebang Script is special.  It's entry is only used for
-#    extensions, and files with those extensions have their shebang (#!) lines
-#    read to determine the real language of the file.  Extensionless files are
-#    always treated this way.
-#    The language Text File is also special.  It's treated as one big comment
-#    so you can put Natural Docs content in them without special symbols.  Also,
-#    if you don't specify a package separator, ignored prefixes, or enum value
-#    behavior, it will copy those settings from the language that is used most
-#    in the source tree.
-# Extensions: [extension] [extension] ...
-# [Add/Replace] Extensions: [extension] [extension] ...
-#    Defines the file extensions of the language's source files.  You can
-#    redefine extensions found in the main languages file.  You can use * to
-#    mean any undefined extension.
-# Shebang Strings: [string] [string] ...
-# [Add/Replace] Shebang Strings: [string] [string] ...
-#    Defines a list of strings that can appear in the shebang (#!) line to
-#    designate that it's part of the language.  You can redefine strings found
-#    in the main languages file.
-# Ignore Prefixes in Index: [prefix] [prefix] ...
-# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
-# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
-# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
-#    Specifies prefixes that should be ignored when sorting symbols in an
-#    index.  Can be specified in general or for a specific topic type.
-# For basic language support only:
-# Line Comments: [symbol] [symbol] ...
-#    Defines a space-separated list of symbols that are used for line comments,
-#    if any.
-# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
-#    Defines a space-separated list of symbol pairs that are used for block
-#    comments, if any.
-# Package Separator: [symbol]
-#    Defines the default package separator symbol.  The default is a dot.
-# [Topic Type] Prototype Enders: [symbol] [symbol] ...
-#    When defined, Natural Docs will attempt to get a prototype from the code
-#    immediately following the topic type.  It stops when it reaches one of
-#    these symbols.  Use \n for line breaks.
-# Line Extender: [symbol]
-#    Defines the symbol that allows a prototype to span multiple lines if
-#    normally a line break would end it.
-# Enum Values: [global|under type|under parent]
-#    Defines how enum values are referenced.  The default is global.
-#    global       - Values are always global, referenced as 'value'.
-#    under type   - Values are under the enum type, referenced as
-#               'package.enum.value'.
-#    under parent - Values are under the enum's parent, referenced as
-#               'package.value'.
-# Perl Package: [perl package]
-#    Specifies the Perl package used to fine-tune the language behavior in ways
-#    too complex to do in this file.
-# For full language support only:
-# Full Language Support: [perl package]
-#    Specifies the Perl package that has the parsing routines necessary for full
-#    language support.
-# The following languages are defined in the main file, if you'd like to alter
-# them:
-#    Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
-#    PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
-#    ActionScript, ColdFusion, R, Fortran
-# If you add a language that you think would be useful to other developers
-# and should be included in Natural Docs by default, please e-mail it to
-# languages [at] naturaldocs [dot] org.
Copied: branches/kmq_dev/documents/api_js/Languages.txt (from rev 4267, trunk/mapbender/documents/api_js/Languages.txt)
--- branches/kmq_dev/documents/api_js/Languages.txt	                        (rev 0)
@@ -0,0 +1,113 @@
+Format: 1.4
+# This is the Natural Docs languages file for this project.  If you change
+# anything here, it will apply to THIS PROJECT ONLY.  If you'd like to change
+# something for all your projects, edit the Languages.txt in Natural Docs'
+# Config directory instead.
+# You can prevent certain file extensions from being scanned like this:
+# Ignore Extensions: [extension] [extension] ...
+# SYNTAX:
+# Unlike other Natural Docs configuration files, in this file all comments
+# MUST be alone on a line.  Some languages deal with the # character, so you
+# cannot put comments on the same line as content.
+# Also, all lists are separated with spaces, not commas, again because some
+# languages may need to use them.
+# Language: [name]
+# Alter Language: [name]
+#    Defines a new language or alters an existing one.  Its name can use any
+#    characters.  If any of the properties below have an add/replace form, you
+#    must use that when using Alter Language.
+#    The language Shebang Script is special.  It's entry is only used for
+#    extensions, and files with those extensions have their shebang (#!) lines
+#    read to determine the real language of the file.  Extensionless files are
+#    always treated this way.
+#    The language Text File is also special.  It's treated as one big comment
+#    so you can put Natural Docs content in them without special symbols.  Also,
+#    if you don't specify a package separator, ignored prefixes, or enum value
+#    behavior, it will copy those settings from the language that is used most
+#    in the source tree.
+# Extensions: [extension] [extension] ...
+# [Add/Replace] Extensions: [extension] [extension] ...
+#    Defines the file extensions of the language's source files.  You can
+#    redefine extensions found in the main languages file.  You can use * to
+#    mean any undefined extension.
+# Shebang Strings: [string] [string] ...
+# [Add/Replace] Shebang Strings: [string] [string] ...
+#    Defines a list of strings that can appear in the shebang (#!) line to
+#    designate that it's part of the language.  You can redefine strings found
+#    in the main languages file.
+# Ignore Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
+# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+#    Specifies prefixes that should be ignored when sorting symbols in an
+#    index.  Can be specified in general or for a specific topic type.
+# For basic language support only:
+# Line Comments: [symbol] [symbol] ...
+#    Defines a space-separated list of symbols that are used for line comments,
+#    if any.
+# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
+#    Defines a space-separated list of symbol pairs that are used for block
+#    comments, if any.
+# Package Separator: [symbol]
+#    Defines the default package separator symbol.  The default is a dot.
+# [Topic Type] Prototype Enders: [symbol] [symbol] ...
+#    When defined, Natural Docs will attempt to get a prototype from the code
+#    immediately following the topic type.  It stops when it reaches one of
+#    these symbols.  Use \n for line breaks.
+# Line Extender: [symbol]
+#    Defines the symbol that allows a prototype to span multiple lines if
+#    normally a line break would end it.
+# Enum Values: [global|under type|under parent]
+#    Defines how enum values are referenced.  The default is global.
+#    global       - Values are always global, referenced as 'value'.
+#    under type   - Values are under the enum type, referenced as
+#               'package.enum.value'.
+#    under parent - Values are under the enum's parent, referenced as
+#               'package.value'.
+# Perl Package: [perl package]
+#    Specifies the Perl package used to fine-tune the language behavior in ways
+#    too complex to do in this file.
+# For full language support only:
+# Full Language Support: [perl package]
+#    Specifies the Perl package that has the parsing routines necessary for full
+#    language support.
+# The following languages are defined in the main file, if you'd like to alter
+# them:
+#    Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
+#    PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
+#    ActionScript, ColdFusion, R, Fortran
+# If you add a language that you think would be useful to other developers
+# and should be included in Natural Docs by default, please e-mail it to
+# languages [at] naturaldocs [dot] org.
Deleted: branches/kmq_dev/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Menu.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,73 +0,0 @@
-Format: 1.4
-# You can add a title and sub-title to your menu like this:
-# Title: [project name]
-# SubTitle: [subtitle]
-# You can add a footer to your documentation like this:
-# Footer: [text]
-# If you want to add a copyright notice, this would be the place to do it.
-# You can add a timestamp to your documentation like one of these:
-# Timestamp: Generated on month day, year
-# Timestamp: Updated mm/dd/yyyy
-# Timestamp: Last updated mon day
-#   m     - One or two digit month.  January is "1"
-#   mm    - Always two digit month.  January is "01"
-#   mon   - Short month word.  January is "Jan"
-#   month - Long month word.  January is "January"
-#   d     - One or two digit day.  1 is "1"
-#   dd    - Always two digit day.  1 is "01"
-#   day   - Day with letter extension.  1 is "1st"
-#   yy    - Two digit year.  2006 is "06"
-#   yyyy  - Four digit year.  2006 is "2006"
-#   year  - Four digit year.  2006 is "2006"
-# Cut and paste the lines below to change the order in which your files
-# appear on the menu.  Don't worry about adding or removing files, Natural
-# Docs will take care of that.
-# You can further organize the menu by grouping the entries.  Add a
-# "Group: [name] {" line to start a group, and add a "}" to end it.
-# You can add text and web links to the menu by adding "Text: [text]" and
-# "Link: [name] ([URL])" lines, respectively.
-# The formatting and comments are auto-generated, so don't worry about
-# neatness when editing the file.  Natural Docs will clean it up the next
-# time it is run.  When working with groups, just deal with the braces and
-# forget about the indentation and comments.
-Group: Mapbender  {
-   File: Mapbender  (http/javascripts/core.php)
-   File: Event  (lib/event.js)
-   File: Map  (http/javascripts/map_obj.js)
-   Group: modules  {
-      File: Reload  (http/javascripts/mod_reload.php)
-      File: Sandclock  (http/javascripts/mod_sandclock.php)
-      File: ZoomIn1  (http/javascripts/mod_zoomIn1.php)
-      }  # Group: modules
-   }  # Group: Mapbender
-File: SearchPanel  (docs/javascript/main.js)
-Group: Index  {
-   Index: Everything
-   Class Index: Classes
-   Function Index: Functions
-   Variable Index: Variables
-   }  # Group: Index
Copied: branches/kmq_dev/documents/api_js/Menu.txt (from rev 4267, trunk/mapbender/documents/api_js/Menu.txt)
--- branches/kmq_dev/documents/api_js/Menu.txt	                        (rev 0)
@@ -0,0 +1,73 @@
+Format: 1.4
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+#   m     - One or two digit month.  January is "1"
+#   mm    - Always two digit month.  January is "01"
+#   mon   - Short month word.  January is "Jan"
+#   month - Long month word.  January is "January"
+#   d     - One or two digit day.  1 is "1"
+#   dd    - Always two digit day.  1 is "01"
+#   day   - Day with letter extension.  1 is "1st"
+#   yy    - Two digit year.  2006 is "06"
+#   yyyy  - Four digit year.  2006 is "2006"
+#   year  - Four digit year.  2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu.  Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries.  Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file.  Natural Docs will clean it up the next
+# time it is run.  When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+Group: Mapbender  {
+   File: Mapbender  (http/javascripts/core.php)
+   File: Event  (lib/event.js)
+   File: Map  (http/javascripts/map_obj.js)
+   Group: modules  {
+      File: Reload  (http/javascripts/mod_reload.php)
+      File: Sandclock  (http/javascripts/mod_sandclock.php)
+      File: ZoomIn1  (http/javascripts/mod_zoomIn1.php)
+      }  # Group: modules
+   }  # Group: Mapbender
+File: SearchPanel  (docs/javascript/main.js)
+Group: Index  {
+   Index: Everything
+   Class Index: Classes
+   Function Index: Functions
+   Variable Index: Variables
+   }  # Group: Index
Deleted: branches/kmq_dev/documents/api_js/Topics.txt
--- trunk/mapbender/documents/api_js/Topics.txt	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/Topics.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,81 +0,0 @@
-Format: 1.4
-# This is the Natural Docs topics file for this project.  If you change anything
-# here, it will apply to THIS PROJECT ONLY.  If you'd like to change something
-# for all your projects, edit the Topics.txt in Natural Docs' Config directory
-# instead.
-# If you'd like to prevent keywords from being recognized by Natural Docs, you
-# can do it like this:
-# Ignore Keywords: [keyword], [keyword], ...
-# Or you can use the list syntax like how they are defined:
-# Ignore Keywords:
-#    [keyword]
-#    [keyword], [plural keyword]
-# SYNTAX:
-# Topic Type: [name]
-# Alter Topic Type: [name]
-#    Creates a new topic type or alters one from the main file.  Each type gets
-#    its own index and behavior settings.  Its name can have letters, numbers,
-#    spaces, and these charaters: - / . '
-# Plural: [name]
-#    Sets the plural name of the topic type, if different.
-# Keywords:
-#    [keyword]
-#    Defines or adds to the list of keywords for the topic type.  They may only
-#    contain letters, numbers, and spaces and are not case sensitive.  Plural
-#    keywords are used for list topics.  You can redefine keywords found in the
-#    main topics file.
-# Index: [yes|no]
-#    Whether the topics get their own index.  Defaults to yes.  Everything is
-#    included in the general index regardless of this setting.
-# Scope: [normal|start|end|always global]
-#    How the topics affects scope.  Defaults to normal.
-#    normal        - Topics stay within the current scope.
-#    start         - Topics start a new scope for all the topics beneath it,
-#                    like class topics.
-#    end           - Topics reset the scope back to global for all the topics
-#                    beneath it.
-#    always global - Topics are defined as global, but do not change the scope
-#                    for any other topics.
-# Class Hierarchy: [yes|no]
-#    Whether the topics are part of the class hierarchy.  Defaults to no.
-# Page Title If First: [yes|no]
-#    Whether the topic's title becomes the page title if it's the first one in
-#    a file.  Defaults to no.
-# Break Lists: [yes|no]
-#    Whether list topics should be broken into individual topics in the output.
-#    Defaults to no.
-# Can Group With: [type], [type], ...
-#    Defines a list of topic types that this one can possibly be grouped with.
-#    Defaults to none.
-# The following topics are defined in the main file, if you'd like to alter
-# their behavior or add keywords:
-#    Generic, Class, Interface, Section, File, Group, Function, Variable,
-#    Property, Type, Constant, Enumeration, Event, Delegate, Macro,
-#    Database, Database Table, Database View, Database Index, Database
-#    Cursor, Database Trigger, Cookie, Build Target
-# If you add something that you think would be useful to other developers
-# topics [at] naturaldocs [dot] org.
Copied: branches/kmq_dev/documents/api_js/Topics.txt (from rev 4267, trunk/mapbender/documents/api_js/Topics.txt)
--- branches/kmq_dev/documents/api_js/Topics.txt	                        (rev 0)
@@ -0,0 +1,81 @@
+Format: 1.4
+# This is the Natural Docs topics file for this project.  If you change anything
+# here, it will apply to THIS PROJECT ONLY.  If you'd like to change something
+# for all your projects, edit the Topics.txt in Natural Docs' Config directory
+# instead.
+# If you'd like to prevent keywords from being recognized by Natural Docs, you
+# can do it like this:
+# Ignore Keywords: [keyword], [keyword], ...
+# Or you can use the list syntax like how they are defined:
+# Ignore Keywords:
+#    [keyword]
+#    [keyword], [plural keyword]
+# SYNTAX:
+# Topic Type: [name]
+# Alter Topic Type: [name]
+#    Creates a new topic type or alters one from the main file.  Each type gets
+#    its own index and behavior settings.  Its name can have letters, numbers,
+#    spaces, and these charaters: - / . '
+# Plural: [name]
+#    Sets the plural name of the topic type, if different.
+# Keywords:
+#    [keyword]
+#    Defines or adds to the list of keywords for the topic type.  They may only
+#    contain letters, numbers, and spaces and are not case sensitive.  Plural
+#    keywords are used for list topics.  You can redefine keywords found in the
+#    main topics file.
+# Index: [yes|no]
+#    Whether the topics get their own index.  Defaults to yes.  Everything is
+#    included in the general index regardless of this setting.
+# Scope: [normal|start|end|always global]
+#    How the topics affects scope.  Defaults to normal.
+#    normal        - Topics stay within the current scope.
+#    start         - Topics start a new scope for all the topics beneath it,
+#                    like class topics.
+#    end           - Topics reset the scope back to global for all the topics
+#                    beneath it.
+#    always global - Topics are defined as global, but do not change the scope
+#                    for any other topics.
+# Class Hierarchy: [yes|no]
+#    Whether the topics are part of the class hierarchy.  Defaults to no.
+# Page Title If First: [yes|no]
+#    Whether the topic's title becomes the page title if it's the first one in
+#    a file.  Defaults to no.
+# Break Lists: [yes|no]
+#    Whether list topics should be broken into individual topics in the output.
+#    Defaults to no.
+# Can Group With: [type], [type], ...
+#    Defines a list of topic types that this one can possibly be grouped with.
+#    Defaults to none.
+# The following topics are defined in the main file, if you'd like to alter
+# their behavior or add keywords:
+#    Generic, Class, Interface, Section, File, Group, Function, Variable,
+#    Property, Type, Constant, Enumeration, Event, Delegate, Macro,
+#    Database, Database Table, Database View, Database Index, Database
+#    Cursor, Database Trigger, Cookie, Build Target
+# If you add something that you think would be useful to other developers
+# topics [at] naturaldocs [dot] org.
Deleted: branches/kmq_dev/documents/api_js/files/docs/javascript/main-js.html
--- trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/docs/javascript/main-js.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,106 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><title>SearchPanel</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="SearchPanel"></a>SearchPanel</h1><div class=CBody><p>A class handling everything associated with the search panel.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>name</td><td class=CDLDescription>The name of the global variable that will be storing this instance.&nbsp;  Is needed to be able to set timeouts.</td></tr><tr><td class=CDLEntry>mode</td><td class=CDLDescription>The mode the search is going to work in.&nbsp;  Pass &lt;NaturalDocs::Builder::Base-&gt;CommandLineOption()&gt;, so the value will be something like &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#SearchPanel" >SearchPanel</a></td><td class=SDescription>A class handling everything associated with the search panel.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">name</a></td><td class=SDescription>The name of the global variable that will be storing this instance of the class.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.mode" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.resultsPath" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">resultsPath</a></td><td class=SDescription>The relative path from the current HTML page to the results page directory.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.keyTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">keyTimeout</a></td><td class=SDescription>The timeout used between a keystroke and when a search is performed.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.keyTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">keyTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link6 onMouseOver="ShowTip(event, 'tt4', 'link6')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt6', 'link7')" onMouseOut="HideTip('tt6')">lastSearchValue</a></td><td class=SDescription>The last search string executed, or an empty string if none.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.lastResultsPage" id=link8 onMouseOver="ShowTip(event, 'tt7', 'link8')" onMouseOut="HideTip('tt7')">lastResultsPage</a></td><td class=SDescription>The last results page. </td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.deactivateTimeout" >deactivateTimeout</a></td><td class=SDescription>The timeout used between when a control is deactivated and when the entire panel is deactivated. </td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.deactivateTimeoutLength" id=link9 onMouseOver="ShowTip(event, 'tt8', 'link9')" onMouseOut="HideTip('tt8')">deactivateTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link10 onMouseOver="ShowTip(event, 'tt9', 'link10')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.DOM_Elements" >DOM Elements</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchField" id=link11 onMouseOver="ShowTip(event, 'tt10', 'link11')" onMouseOut="HideTip('tt10')">DOMSearchField</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMSearchType" id=link12 onMouseOver="ShowTip(event, 'tt11', 'link12')" onMouseOut="HideTip('tt11')">DOMSearchType</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResults" id=link13 onMouseOver="ShowTip(event, 'tt12', 'link13')" onMouseOut="HideTip('tt12')">DOMPopupSearchResults</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResultsWindow" id=link14 onMouseOver="ShowTip(event, 'tt13', 'link14')" onMouseOut="HideTip('tt13')">DOMPopupSearchResultsWindow</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchPanel" id=link15 onMouseOver="ShowTip(event, 'tt14', 'link15')" onMouseOut="HideTip('tt14')">DOMSearchPanel</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Event_Handlers" >Event Handlers</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchFieldFocus" id=link16 onMouseOver="ShowTip(event, 'tt15', 'link16')" onMouseOut="HideTip('tt15')">OnSearchFieldFocus</a></td><td class=SDescription>Called when focus is added or removed from the search field.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchFieldChange" id=link17 onMouseOver="ShowTip(event, 'tt16', 'link17')" onMouseOut="HideTip('tt16')">OnSearchFieldChange</a></td><td class=SDescription>Called when the content of the search field is changed.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchTypeFocus" id=link18 onMouseOver="ShowTip(event, 'tt17', 'link18')" onMouseOut="HideTip('tt17')">OnSearchTypeFocus</a></td><td class=SDescription>Called when focus is added or removed from the search type.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchTypeChange" id=link19 onMouseOver="ShowTip(event, 'tt18', 'link19')" onMouseOut="HideTip('tt18')">OnSearchTypeChange</a></td><td class=SDescription>Called when the search type is changed.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Action_Functions" >Action Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.CloseResultsWindow" id=link20 onMouseOver="ShowTip(event, 'tt19', 'link20')" onMouseOut="HideTip('tt19')">CloseResultsWindow</a></td><td class=SDescription>Closes the results window.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.Search" id=link21 onMouseOver="ShowTip(event, 'tt20', 'link21')" onMouseOut="HideTip('tt20')">Search</a></td><td class=SDescription>Performs a search.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Activation_Functions" >Activation Functions</a></td><td class=SDescription>Functions that handle whether the entire panel is active or not.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.Activate" id=link22 onMouseOver="ShowTip(event, 'tt21', 'link22')" onMouseOut="HideTip('tt21')">Activate</a></td><td class=SDescription>Activates or deactivates the search panel, resetting things to their default values if necessary. </td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.InactivateAfterTimeout" id=link23 onMouseOver="ShowTip(event, 'tt22', 'link23')" onMouseOut="HideTip('tt22')">InactivateAfterTimeout</a></td><td class=SDescription>Called by &lt;inactivateTimeout&gt;, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link24 onMouseOver="ShowTip(event, 'tt21', 'link24')" onMouseOut="HideTip('tt21')">Activate()</a>. </td></tr><tr class="SClass"><td class=SEntry><a href="#SearchResults" >SearchResults</a></td><td class=SDescription>The class that handles everything on the search results page.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link25 onMouseOver="ShowTip(event, 'tt23', 'link25')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link26 onMouseOver="ShowTip(event, 'tt24', 'link26')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link27 onMouseOver="ShowTip(event, 'tt25', 'link27')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link28 onMouseOver="ShowTip(event, 'tt26', 'link28')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchResults.Search" id=link29 onMouseOver="ShowTip(event, 'tt25', 'link29')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Variables"></a>Variables</h3></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.name"></a>name</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote><p>The name of the global variable that will be storing this instance of the class.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.resultsPath"></a>resultsPath</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote><p>The relative path from the current HTML page to the results page directory.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeout"></a>keyTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote><p>The timeout used between a keystroke and when a search is performed.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeoutLength"></a>keyTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link30 onMouseOver="ShowTip(event, 'tt4', 'link30')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastSearchValue"></a>lastSearchValue</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote><p>The last search string executed, or an empty string if none.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastResultsPage"></a>lastResultsPage</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote><p>The last results page.&nbsp;  The value is only relevant if <a href="#SearchPanel.lastSearchValue" class=LVariable id=link31 onMouseOver="ShowTip(event, 'tt6', 'link31')" onMouseOut="HideTip('tt6')">lastSearchValue</a> is set.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeout"></a>deactivateTimeout</h3><div class=CBody><p>The timeout used between when a control is deactivated and when the entire panel is deactivated.&nbsp;  Is necessary because a control may be deactivated in favor of another control in the same panel, in which case it should stay active.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeoutLength"></a>deactivateTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link32 onMouseOver="ShowTip(event, 'tt9', 'link32')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</p></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOM_Elements"></a>DOM Elements</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchField"></a>DOMSearchField</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchType"></a>DOMSearchType</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResults"></a>DOMPopupSearchResults</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResultsWindow"></a>DOMPopupSearchResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchPanel"></a>DOMSearchPanel</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Event_Handlers"></a>Event Handlers</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldFocus"></a>OnSearchFieldFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search field.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldChange"></a>OnSearchFieldChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote><p>Called when the content of the search field is changed.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeFocus"></a>OnSearchTypeFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search type.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeChange"></a>OnSearchTypeChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote><p>Called when the search type is changed.</p></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Action_Functions"></a>Action Functions</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.CloseResultsWindow"></a>CloseResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote><p>Closes the results window.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote><p>Performs a search.</p></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activation_Functions"></a>Activation Functions</h3><div class=CBody><p>Functions that handle whether the entire panel is active or not.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activate"></a>Activate</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Activates or deactivates the search panel, resetting things to their default values if necessary.&nbsp;  You can call this on every control&rsquo;s OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>isActive</td><td class=CDLDescription>Whether you&rsquo;re activating or deactivating the panel.</td></tr><tr><td class=CDLEntry>ignoreDeactivateDelay</td><td class=CDLDescription>Set if you&rsquo;re positive the action will deactivate the panel and thus want to skip the delay.</td></tr></table></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.InactivateAfterTimeout"></a>InactivateAfterTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote><p>Called by &lt;inactivateTimeout&gt;, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link33 onMouseOver="ShowTip(event, 'tt21', 'link33')" onMouseOut="HideTip('tt21')">Activate()</a>.&nbsp;  Inactivation occurs on a timeout because a control may receive OnBlur() when focus is really transferring to another control in the search panel.&nbsp;  In this case we don&rsquo;t want to actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.&nbsp; So by doing it on a timeout instead, there&rsquo;s a short period where the second control&rsquo;s OnFocus() can cancel the deactivation.</p></div></div></div>
-<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="SearchResults"></a>SearchResults</h2><div class=CBody><p>The class that handles everything on the search results page.</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link34 onMouseOver="ShowTip(event, 'tt23', 'link34')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link35 onMouseOver="ShowTip(event, 'tt24', 'link35')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link36 onMouseOver="ShowTip(event, 'tt25', 'link36')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link37 onMouseOver="ShowTip(event, 'tt26', 'link37')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#SearchResults.Search" id=link38 onMouseOver="ShowTip(event, 'tt25', 'link38')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Variables"></a>Variables</h3></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</p></div></div></div>
-<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.lastMatchCount"></a>lastMatchCount</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote><p>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link39 onMouseOver="ShowTip(event, 'tt25', 'link39')" onMouseOut="HideTip('tt25')">Search()</a>.</p></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Functions"></a>Functions</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Toggle"></a>Toggle</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Toggles the visibility of the passed element ID.</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Searches for the passed string.&nbsp;  If there is no parameter, it takes it from the URL query.</p><p>Always returns true, since other documents may try to call it and that may or may not be possible.</p></div></div></div>
-</div><!--Content-->
-<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile id=MSelected>SearchPanel</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt9"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
-<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
-<script language=JavaScript><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Copied: branches/kmq_dev/documents/api_js/files/docs/javascript/main-js.html (from rev 4267, trunk/mapbender/documents/api_js/files/docs/javascript/main-js.html)
--- branches/kmq_dev/documents/api_js/files/docs/javascript/main-js.html	                        (rev 0)
@@ -0,0 +1,106 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>SearchPanel</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="SearchPanel"></a>SearchPanel</h1><div class=CBody><p>A class handling everything associated with the search panel.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>name</td><td class=CDLDescription>The name of the global variable that will be storing this instance.&nbsp;  Is needed to be able to set timeouts.</td></tr><tr><td class=CDLEntry>mode</td><td class=CDLDescription>The mode the search is going to work in.&nbsp;  Pass &lt;NaturalDocs::Builder::Base-&gt;CommandLineOption()&gt;, so the value will be something like &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#SearchPanel" >SearchPanel</a></td><td class=SDescription>A class handling everything associated with the search panel.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">name</a></td><td class=SDescription>The name of the global variable that will be storing this instance of the class.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.mode" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.resultsPath" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">resultsPath</a></td><td class=SDescription>The relative path from the current HTML page to the results page directory.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.keyTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">keyTimeout</a></td><td class=SDescription>The timeout used between a keystroke and when a search is performed.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.keyTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">keyTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link6 onMouseOver="ShowTip(event, 'tt4', 'link6')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt6', 'link7')" onMouseOut="HideTip('tt6')">lastSearchValue</a></td><td class=SDescription>The last search string executed, or an empty string if none.</td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.lastResultsPage" id=link8 onMouseOver="ShowTip(event, 'tt7', 'link8')" onMouseOut="HideTip('tt7')">lastResultsPage</a></td><td class=SDescription>The last results page. </td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchPanel.deactivateTimeout" >deactivateTimeout</a></td><td class=SDescription>The timeout used between when a control is deactivated and when the entire panel is deactivated. </td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.deactivateTimeoutLength" id=link9 onMouseOver="ShowTip(event, 'tt8', 'link9')" onMouseOut="HideTip('tt8')">deactivateTimeoutLength</a></td><td class=SDescription>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link10 onMouseOver="ShowTip(event, 'tt9', 'link10')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.DOM_Elements" >DOM Elements</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchField" id=link11 onMouseOver="ShowTip(event, 'tt10', 'link11')" onMouseOut="HideTip('tt10')">DOMSearchField</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMSearchType" id=link12 onMouseOver="ShowTip(event, 'tt11', 'link12')" onMouseOut="HideTip('tt11')">DOMSearchType</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResults" id=link13 onMouseOver="ShowTip(event, 'tt12', 'link13')" onMouseOut="HideTip('tt12')">DOMPopupSearchResults</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.DOMPopupSearchResultsWindow" id=link14 onMouseOver="ShowTip(event, 'tt13', 'link14')" onMouseOut="HideTip('tt13')">DOMPopupSearchResultsWindow</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.DOMSearchPanel" id=link15 onMouseOver="ShowTip(event, 'tt14', 'link15')" onMouseOut="HideTip('tt14')">DOMSearchPanel</a></td><td class=SDescription></td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Event_Handlers" >Event Handlers</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchFieldFocus" id=link16 onMouseOver="ShowTip(event, 'tt15', 'link16')" onMouseOut="HideTip('tt15')">OnSearchFieldFocus</a></td><td class=SDescription>Called when focus is added or removed from the search field.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchFieldChange" id=link17 onMouseOver="ShowTip(event, 'tt16', 'link17')" onMouseOut="HideTip('tt16')">OnSearchFieldChange</a></td><td class=SDescription>Called when the content of the search field is changed.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.OnSearchTypeFocus" id=link18 onMouseOver="ShowTip(event, 'tt17', 'link18')" onMouseOut="HideTip('tt17')">OnSearchTypeFocus</a></td><td class=SDescription>Called when focus is added or removed from the search type.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.OnSearchTypeChange" id=link19 onMouseOver="ShowTip(event, 'tt18', 'link19')" onMouseOut="HideTip('tt18')">OnSearchTypeChange</a></td><td class=SDescription>Called when the search type is changed.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Action_Functions" >Action Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.CloseResultsWindow" id=link20 onMouseOver="ShowTip(event, 'tt19', 'link20')" onMouseOut="HideTip('tt19')">CloseResultsWindow</a></td><td class=SDescription>Closes the results window.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.Search" id=link21 onMouseOver="ShowTip(event, 'tt20', 'link21')" onMouseOut="HideTip('tt20')">Search</a></td><td class=SDescription>Performs a search.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchPanel.Activation_Functions" >Activation Functions</a></td><td class=SDescription>Functions that handle whether the entire panel is active or not.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchPanel.Activate" id=link22 onMouseOver="ShowTip(event, 'tt21', 'link22')" onMouseOut="HideTip('tt21')">Activate</a></td><td class=SDescription>Activates or deactivates the search panel, resetting things to their default values if necessary. </td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchPanel.InactivateAfterTimeout" id=link23 onMouseOver="ShowTip(event, 'tt22', 'link23')" onMouseOut="HideTip('tt22')">InactivateAfterTimeout</a></td><td class=SDescription>Called by &lt;inactivateTimeout&gt;, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link24 onMouseOver="ShowTip(event, 'tt21', 'link24')" onMouseOut="HideTip('tt21')">Activate()</a>. </td></tr><tr class="SClass"><td class=SEntry><a href="#SearchResults" >SearchResults</a></td><td class=SDescription>The class that handles everything on the search results page.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link25 onMouseOver="ShowTip(event, 'tt23', 'link25')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent2"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link26 onMouseOver="ShowTip(event, 'tt24', 'link26')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link27 onMouseOver="ShowTip(event, 'tt25', 'link27')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link28 onMouseOver="ShowTip(event, 'tt26', 'link28')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#SearchResults.Search" id=link29 onMouseOver="ShowTip(event, 'tt25', 'link29')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Variables"></a>Variables</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.name"></a>name</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote><p>The name of the global variable that will be storing this instance of the class.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.resultsPath"></a>resultsPath</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote><p>The relative path from the current HTML page to the results page directory.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeout"></a>keyTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote><p>The timeout used between a keystroke and when a search is performed.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.keyTimeoutLength"></a>keyTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.keyTimeout" class=LVariable id=link30 onMouseOver="ShowTip(event, 'tt4', 'link30')" onMouseOut="HideTip('tt4')">keyTimeout</a> in thousandths of a second.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastSearchValue"></a>lastSearchValue</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote><p>The last search string executed, or an empty string if none.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.lastResultsPage"></a>lastResultsPage</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote><p>The last results page.&nbsp;  The value is only relevant if <a href="#SearchPanel.lastSearchValue" class=LVariable id=link31 onMouseOver="ShowTip(event, 'tt6', 'link31')" onMouseOut="HideTip('tt6')">lastSearchValue</a> is set.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeout"></a>deactivateTimeout</h3><div class=CBody><p>The timeout used between when a control is deactivated and when the entire panel is deactivated.&nbsp;  Is necessary because a control may be deactivated in favor of another control in the same panel, in which case it should stay active.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.deactivateTimeoutLength"></a>deactivateTimeoutLength</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote><p>The length of <a href="#SearchPanel.deactivateTimeout" class=LVariable id=link32 onMouseOver="ShowTip(event, 'tt9', 'link32')" onMouseOut="HideTip('tt9')">deactivateTimeout</a> in thousandths of a second.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOM_Elements"></a>DOM Elements</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchField"></a>DOMSearchField</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchType"></a>DOMSearchType</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResults"></a>DOMPopupSearchResults</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMPopupSearchResultsWindow"></a>DOMPopupSearchResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.DOMSearchPanel"></a>DOMSearchPanel</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Event_Handlers"></a>Event Handlers</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldFocus"></a>OnSearchFieldFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search field.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchFieldChange"></a>OnSearchFieldChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote><p>Called when the content of the search field is changed.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeFocus"></a>OnSearchTypeFocus</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Called when focus is added or removed from the search type.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.OnSearchTypeChange"></a>OnSearchTypeChange</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote><p>Called when the search type is changed.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Action_Functions"></a>Action Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.CloseResultsWindow"></a>CloseResultsWindow</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote><p>Closes the results window.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote><p>Performs a search.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activation_Functions"></a>Activation Functions</h3><div class=CBody><p>Functions that handle whether the entire panel is active or not.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.Activate"></a>Activate</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Activates or deactivates the search panel, resetting things to their default values if necessary.&nbsp;  You can call this on every control&rsquo;s OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>isActive</td><td class=CDLDescription>Whether you&rsquo;re activating or deactivating the panel.</td></tr><tr><td class=CDLEntry>ignoreDeactivateDelay</td><td class=CDLDescription>Set if you&rsquo;re positive the action will deactivate the panel and thus want to skip the delay.</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchPanel.InactivateAfterTimeout"></a>InactivateAfterTimeout</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote><p>Called by &lt;inactivateTimeout&gt;, which is set by <a href="#SearchPanel.Activate" class=LFunction id=link33 onMouseOver="ShowTip(event, 'tt21', 'link33')" onMouseOut="HideTip('tt21')">Activate()</a>.&nbsp;  Inactivation occurs on a timeout because a control may receive OnBlur() when focus is really transferring to another control in the search panel.&nbsp;  In this case we don&rsquo;t want to actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.&nbsp; So by doing it on a timeout instead, there&rsquo;s a short period where the second control&rsquo;s OnFocus() can cancel the deactivation.</p></div></div></div>
+<div class="CClass"><div class=CTopic><h2 class=CTitle><a name="SearchResults"></a>SearchResults</h2><div class=CBody><p>The class that handles everything on the search results page.</p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Variables" >Variables</a></td><td class=SDescription></td></tr><tr class="SVariable SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.mode" id=link34 onMouseOver="ShowTip(event, 'tt23', 'link34')" onMouseOut="HideTip('tt23')">mode</a></td><td class=SDescription>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</td></tr><tr class="SVariable SIndent1"><td class=SEntry><a href="#SearchResults.lastMatchCount" id=link35 onMouseOver="ShowTip(event, 'tt24', 'link35')" onMouseOut="HideTip('tt24')">lastMatchCount</a></td><td class=SDescription>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link36 onMouseOver="ShowTip(event, 'tt25', 'link36')" onMouseOut="HideTip('tt25')">Search()</a>.</td></tr><tr class="SGroup"><td class=SEntry><a href="#SearchResults.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent1 SMarked"><td class=SEntry><a href="#SearchResults.Toggle" id=link37 onMouseOver="ShowTip(event, 'tt26', 'link37')" onMouseOut="HideTip('tt26')">Toggle</a></td><td class=SDescription>Toggles the visibility of the passed element ID.</td></tr><tr class="SFunction SIndent1"><td class=SEntry><a href="#SearchResults.Search" id=link38 onMouseOver="ShowTip(event, 'tt25', 'link38')" onMouseOut="HideTip('tt25')">Search</a></td><td class=SDescription>Searches for the passed string. </td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Variables"></a>Variables</h3></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.mode"></a>mode</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote><p>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</p></div></div></div>
+<div class="CVariable"><div class=CTopic><h3 class=CTitle><a name="SearchResults.lastMatchCount"></a>lastMatchCount</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote><p>The number of matches from the last run of <a href="#SearchResults.Search" class=LFunction id=link39 onMouseOver="ShowTip(event, 'tt25', 'link39')" onMouseOut="HideTip('tt25')">Search()</a>.</p></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Toggle"></a>Toggle</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Toggles the visibility of the passed element ID.</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="SearchResults.Search"></a>Search</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Searches for the passed string.&nbsp;  If there is no parameter, it takes it from the URL query.</p><p>Always returns true, since other documents may try to call it and that may or may not be possible.</p></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile id=MSelected>SearchPanel</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt9"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Deleted: branches/kmq_dev/documents/api_js/files/http/javascripts/core-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/http/javascripts/core-php.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,38 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><title>Mapbender</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Mapbender"></a>Mapbender</h1><div class=CBody><p>All Mapbender functionality is within this namespace</p></div></div></div>
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-<!--END_ND_TOOLTIPS-->
Copied: branches/kmq_dev/documents/api_js/files/http/javascripts/core-php.html (from rev 4267, trunk/mapbender/documents/api_js/files/http/javascripts/core-php.html)
--- branches/kmq_dev/documents/api_js/files/http/javascripts/core-php.html	                        (rev 0)
@@ -0,0 +1,38 @@
+<html><head><title>Mapbender</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Mapbender"></a>Mapbender</h1><div class=CBody><p>All Mapbender functionality is within this namespace</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<!--END_ND_TOOLTIPS-->
Deleted: branches/kmq_dev/documents/api_js/files/http/javascripts/map_obj-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/http/javascripts/map_obj-js.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,44 +0,0 @@
-<html><head><title>Map</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Map"></a>Map</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This is the central module for displaying the composite map overlay.</p><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Mapframe" class=LURL target=_top>http://www.mapbender.org/Mapframe</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Map" >Map</a></td><td class=SDescription>This is the central module for displaying the composite map overlay.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Map.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Map.Map" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Map</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Map.setExtent" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">setExtent</a></td><td class=SDescription>set the extent of the wms</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Map.Functions"></a>Functions</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.Map"></a>Map</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>frameName</td><td class=CDLDescription><b>[deprecated]</b> the name of the iframe, for backwards compatibility only, use &ldquo;&rdquo; for maps in DIVs</td></tr><tr><td class=CDLEntry>elementName</td><td class=CDLDescription>the ID of the DOM node</td></tr><tr><td class=CDLEntry>width</td><td class=CDLDescription>width of the map in pixel</td></tr><tr><td class=CDLEntry>height</td><td class=CDLDescription>height of the map in pixel</td></tr><tr><td class=CDLEntry>wms_index</td><td class=CDLDescription>restrict the WMS in the map to the WMS with this ID (useful for overview maps)</td></tr></table></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.setExtent"></a>setExtent</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>set the extent of the wms</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>minx</td><td class=CDLDescription>x of south west</td></tr><tr><td class=CDLEntry>miny</td><td class=CDLDescription>y of south west</td></tr><tr><td class=CDLEntry>maxx</td><td class=CDLDescription>x of north east</td></tr><tr><td class=CDLEntry>maxy</td><td class=CDLDescription>y of north east</td></tr></table></div></div></div>
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><!--END_ND_TOOLTIPS-->
Copied: branches/kmq_dev/documents/api_js/files/http/javascripts/map_obj-js.html (from rev 4267, trunk/mapbender/documents/api_js/files/http/javascripts/map_obj-js.html)
--- branches/kmq_dev/documents/api_js/files/http/javascripts/map_obj-js.html	                        (rev 0)
@@ -0,0 +1,44 @@
+<html><head><title>Map</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Map"></a>Map</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This is the central module for displaying the composite map overlay.</p><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/Mapframe" class=LURL target=_top>http://www.mapbender.org/Mapframe</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Map" >Map</a></td><td class=SDescription>This is the central module for displaying the composite map overlay.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Map.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Map.Map" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Map</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Map.setExtent" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">setExtent</a></td><td class=SDescription>set the extent of the wms</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Map.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.Map"></a>Map</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>frameName</td><td class=CDLDescription><b>[deprecated]</b> the name of the iframe, for backwards compatibility only, use &ldquo;&rdquo; for maps in DIVs</td></tr><tr><td class=CDLEntry>elementName</td><td class=CDLDescription>the ID of the DOM node</td></tr><tr><td class=CDLEntry>width</td><td class=CDLDescription>width of the map in pixel</td></tr><tr><td class=CDLEntry>height</td><td class=CDLDescription>height of the map in pixel</td></tr><tr><td class=CDLEntry>wms_index</td><td class=CDLDescription>restrict the WMS in the map to the WMS with this ID (useful for overview maps)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Map.setExtent"></a>setExtent</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>set the extent of the wms</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>minx</td><td class=CDLDescription>x of south west</td></tr><tr><td class=CDLEntry>miny</td><td class=CDLDescription>y of south west</td></tr><tr><td class=CDLEntry>maxx</td><td class=CDLDescription>x of north east</td></tr><tr><td class=CDLEntry>maxy</td><td class=CDLDescription>y of north east</td></tr></table></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><!--END_ND_TOOLTIPS-->
Deleted: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_reload-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/http/javascripts/mod_reload-php.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,48 +0,0 @@
-<html><head><title>Reload</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Reload"></a>Reload</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A button that reloads the whole window.</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
-e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
-e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
-e_mb_mod, e_target, e_requires, e_url) VALUES ('&lt;gui_id&gt;', 'reload',
-2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
-60,24,24,1,'','','','mod_reload.php','','mapframe1','',
-'http://www.mapbender.org/index.php/Reload');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/index.php/Reload" class=LURL target=_top>http://www.mapbender.org/index.php/Reload</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Vera_Schulze" class=LURL target=_top>http://www.mapbender.org/User:Vera_Schulze</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Reload" >Reload</a></td><td class=SDescription>A button that reloads the whole window.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Reload.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Reload.reload" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">reload</a></td><td class=SDescription>Reloads the window.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Reload.Functions"></a>Functions</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Reload.reload"></a>reload</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote><p>Reloads the window.</p></div></div></div>
-</div><!--Content-->
-<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-var searchPanel = new SearchPanel("searchPanel", "HTML", "../../../search");
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
-<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
-<script language=JavaScript><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Copied: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_reload-php.html (from rev 4267, trunk/mapbender/documents/api_js/files/http/javascripts/mod_reload-php.html)
--- branches/kmq_dev/documents/api_js/files/http/javascripts/mod_reload-php.html	                        (rev 0)
@@ -0,0 +1,48 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Reload</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Reload"></a>Reload</h1><div class=CBody><h4 class=CHeading>Description</h4><p>A button that reloads the whole window.</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('&lt;gui_id&gt;', 'reload',
+2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
+60,24,24,1,'','','','mod_reload.php','','mapframe1','',
+'http://www.mapbender.org/index.php/Reload');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/index.php/Reload" class=LURL target=_top>http://www.mapbender.org/index.php/Reload</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Vera_Schulze" class=LURL target=_top>http://www.mapbender.org/User:Vera_Schulze</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Reload" >Reload</a></td><td class=SDescription>A button that reloads the whole window.</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Reload.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Reload.reload" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">reload</a></td><td class=SDescription>Reloads the window.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Reload.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Reload.reload"></a>reload</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote><p>Reloads the window.</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
Deleted: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_sandclock-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/http/javascripts/mod_sandclock-php.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,55 +0,0 @@
-<html><head><title>Sandclock</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Sandclock"></a>Sandclock</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Displays an arbitrary sandclock image on a map</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
-e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
-e_mb_mod, e_target, e_requires) VALUES ('&lt;gui_id&gt;', 'sandclock', '0002',
-'1', 'displays a sand clock while waiting for requests', 'div', '',
-'', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
-'mapframe1', '');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
-var_value, context, var_type) VALUES ('&lt;gui_id&gt;', 'sandclock',
-'mod_sandclock_image', '../img/sandclock.gif',
-'define a sandclock-image', 'var');</pre></blockquote><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>mod_sandclock_img</td><td class=CDLDescription><b>[optional]</b> the filename and path to the sandclock image</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Sandclock" >Sandclock</a></td><td class=SDescription>Displays an arbitrary sandclock image on a map</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Sandclock.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Sandclock.show" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">show</a></td><td class=SDescription>Displays the sandclock</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Sandclock.hide" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">hide</a></td><td class=SDescription>Hides the sandclock</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
-<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Sandclock.Functions"></a>Functions</h3></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.show"></a>show</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Displays the sandclock</p></div></div></div>
-<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.hide"></a>hide</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote><p>Hides the sandclock</p></div></div></div>
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
Copied: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_sandclock-php.html (from rev 4267, trunk/mapbender/documents/api_js/files/http/javascripts/mod_sandclock-php.html)
--- branches/kmq_dev/documents/api_js/files/http/javascripts/mod_sandclock-php.html	                        (rev 0)
@@ -0,0 +1,55 @@
+<html><head><title>Sandclock</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Sandclock"></a>Sandclock</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Displays an arbitrary sandclock image on a map</p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
+e_mb_mod, e_target, e_requires) VALUES ('&lt;gui_id&gt;', 'sandclock', '0002',
+'1', 'displays a sand clock while waiting for requests', 'div', '',
+'', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
+'mapframe1', '');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('&lt;gui_id&gt;', 'sandclock',
+'mod_sandclock_image', '../img/sandclock.gif',
+'define a sandclock-image', 'var');</pre></blockquote><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>mod_sandclock_img</td><td class=CDLDescription><b>[optional]</b> the filename and path to the sandclock image</td></tr></table><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Sandclock" >Sandclock</a></td><td class=SDescription>Displays an arbitrary sandclock image on a map</td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Sandclock.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Sandclock.show" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">show</a></td><td class=SDescription>Displays the sandclock</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Sandclock.hide" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">hide</a></td><td class=SDescription>Hides the sandclock</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Sandclock.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.show"></a>show</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><p>Displays the sandclock</p></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Sandclock.hide"></a>hide</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote><p>Hides the sandclock</p></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
Deleted: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,45 +0,0 @@
-<html><head><title>ZoomIn1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ZoomIn1"></a>ZoomIn1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number).&nbsp; Image size is not affected.</p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
-e_comment, e_title, e_element, e_src, e_attributes, e_left,
-e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
-e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
-'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
-'','','','mod_zoomIn1.php','','mapframe1','',
-'http://www.mapbender.org/index.php/ZoomIn');</pre></blockquote><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomIn1.php</li></ul></div></div></div>
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html (from rev 4267, trunk/mapbender/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html)
--- branches/kmq_dev/documents/api_js/files/http/javascripts/mod_zoomIn1-php.html	                        (rev 0)
@@ -0,0 +1,45 @@
+<html><head><title>ZoomIn1</title><link rel="stylesheet" type="text/css" href="../../../styles/main.css"><script language=JavaScript src="../../../javascript/main.js"></script><script language=JavaScript src="../../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="ZoomIn1"></a>ZoomIn1</h1><div class=CBody><h4 class=CHeading>Description</h4><p>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number).&nbsp; Image size is not affected.</p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>SQL</h4><blockquote><pre>INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+e_comment, e_title, e_element, e_src, e_attributes, e_left,
+e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+'','','','mod_zoomIn1.php','','mapframe1','',
+'http://www.mapbender.org/index.php/ZoomIn');</pre></blockquote><h4 class=CHeading>Files</h4><ul><li>http/javascripts/mod_zoomIn1.php</li></ul></div></div></div>
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../../lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/files/lib/event-js.html
--- trunk/mapbender/documents/api_js/files/lib/event-js.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/files/lib/event-js.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,47 +0,0 @@
-<html><head><title>Event</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Event"></a>Event</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An event.&nbsp; What happens, when the event occurs, depends on which functions have been registered with the event.</p><h4 class=CHeading>usage</h4><blockquote><pre>// create a new Event
-var eventAfterMapRequest = new MapbenderEvent();
-// register a function with that event
-eventAfterMapRequest.register(function () {
-// trigger the event
-eventAfterMapRequest.trigger();</pre></blockquote></div></div></div>
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>Event</div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
Copied: branches/kmq_dev/documents/api_js/files/lib/event-js.html (from rev 4267, trunk/mapbender/documents/api_js/files/lib/event-js.html)
--- branches/kmq_dev/documents/api_js/files/lib/event-js.html	                        (rev 0)
@@ -0,0 +1,47 @@
+<html><head><title>Event</title><link rel="stylesheet" type="text/css" href="../../styles/main.css"><script language=JavaScript src="../../javascript/main.js"></script><script language=JavaScript src="../../javascript/searchdata.js"></script></head><body class="ContentPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="Event"></a>Event</h1><div class=CBody><h4 class=CHeading>Description</h4><p>An event.&nbsp; What happens, when the event occurs, depends on which functions have been registered with the event.</p><h4 class=CHeading>usage</h4><blockquote><pre>// create a new Event
+var eventAfterMapRequest = new MapbenderEvent();
+// register a function with that event
+eventAfterMapRequest.register(function () {
+// trigger the event
+eventAfterMapRequest.trigger();</pre></blockquote></div></div></div>
+</div><!--Content-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>Event</div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="../../index/Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
+<!--START_ND_TOOLTIPS-->
Deleted: branches/kmq_dev/documents/api_js/index/Classes.html
--- trunk/mapbender/documents/api_js/index/Classes.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index/Classes.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,49 +0,0 @@
-<html><head><title>Class Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Event</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Map</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Mapbender</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Reload</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>SearchResults</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>ZoomIn1</a></td></tr></table>
-<div class=CToolTip id="tt1"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt2"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt3"><div class=CClass>All Mapbender functionality is within this namespace</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt4"><div class=CClass>A button that reloads the whole window.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt5"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt6"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt7"><div class=CClass>The class that handles everything on the search results page.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
-</div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
Copied: branches/kmq_dev/documents/api_js/index/Classes.html (from rev 4267, trunk/mapbender/documents/api_js/index/Classes.html)
--- branches/kmq_dev/documents/api_js/index/Classes.html	                        (rev 0)
@@ -0,0 +1,49 @@
+<html><head><title>Class Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Class Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; <a href="#E">E</a> &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Event</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Map</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>Mapbender</a></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>Reload</a></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>SearchResults</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>ZoomIn1</a></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt3"><div class=CClass>All Mapbender functionality is within this namespace</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CClass>A button that reloads the whole window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt6"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt7"><div class=CClass>The class that handles everything on the search results page.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Deleted: branches/kmq_dev/documents/api_js/index/Files.html
--- trunk/mapbender/documents/api_js/index/Files.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index/Files.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,33 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><title>File Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; O &middot; P &middot; Q &middot; R &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php"  class=ISymbol>mod_addWMSfromfilteredList.php</a></td></tr></table>
-<!--END_ND_TOOLTIPS-->
-</div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html">mod_addWMSfromfilteredList.php</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
Copied: branches/kmq_dev/documents/api_js/index/Files.html (from rev 4267, trunk/mapbender/documents/api_js/index/Files.html)
--- branches/kmq_dev/documents/api_js/index/Files.html	                        (rev 0)
@@ -0,0 +1,33 @@
+<html><head><title>File Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>File Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; D &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; O &middot; P &middot; Q &middot; R &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php"  class=ISymbol>mod_addWMSfromfilteredList.php</a></td></tr></table>
+<!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html">mod_addWMSfromfilteredList.php</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Files</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Files">Files</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
Deleted: branches/kmq_dev/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index/Functions.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,69 +0,0 @@
-<html><head><title>Function Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; E &middot; F &middot; G &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; <a href="#O">O</a> &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr></table>
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><!--END_ND_TOOLTIPS-->
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
-</div><!--Index-->
-<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
-<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
-<script language=JavaScript><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Copied: branches/kmq_dev/documents/api_js/index/Functions.html (from rev 4267, trunk/mapbender/documents/api_js/index/Functions.html)
--- branches/kmq_dev/documents/api_js/index/Functions.html	                        (rev 0)
@@ -0,0 +1,69 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Function Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; E &middot; F &middot; G &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; J &middot; K &middot; L &middot; <a href="#M">M</a> &middot; N &middot; <a href="#O">O</a> &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index/General.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,97 +0,0 @@
-<html><head><title>Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; G &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; J &middot; <a href="#K">K</a> &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="#O">O</a> &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; U &middot; <a href="#V">V</a> &middot; W &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions"  class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements"  class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers"  class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions"  class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions"  class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions"  class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions"  class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>SearchResults</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=IHeading><a name="V"></a>V</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Variables</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables"  class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables"  class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>ZoomIn1</a></td></tr></table>
-<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt2"><div class=CGroup>Functions that handle whether the entire panel is active or not.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt4"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt11"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt14"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt15"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt16"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt17"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt18"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt19"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt21"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt22"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt31"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt32"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt35"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt36"><div class=CClass>The class that handles everything on the search results page.</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
-<!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt40"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
-</div><!--Index-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
-var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
Copied: branches/kmq_dev/documents/api_js/index/General.html (from rev 4267, trunk/mapbender/documents/api_js/index/General.html)
--- branches/kmq_dev/documents/api_js/index/General.html	                        (rev 0)
@@ -0,0 +1,97 @@
+<html><head><title>Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; G &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; J &middot; <a href="#K">K</a> &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="#O">O</a> &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; U &middot; <a href="#V">V</a> &middot; W &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions"  class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements"  class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers"  class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions"  class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions"  class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions"  class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions"  class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Search</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>SearchResults</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>SearchPanel</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>SearchResults</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=IHeading><a name="V"></a>V</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Variables</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables"  class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables"  class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>ZoomIn1</a></td></tr></table>
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Activate = function(</td><td class=PParameter nowrap>isActive,</td></tr><tr><td></td><td class=PParameter nowrap>ignoreDeactivateDelay</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Activates or deactivates the search panel, resetting things to their default values if necessary. </div></div><div class=CToolTip id="tt2"><div class=CGroup>Functions that handle whether the entire panel is active or not.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.CloseResultsWindow = function()</td></tr></table></blockquote>Closes the results window.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt4"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResults = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMPopupSearchResultsWindow = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt8"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchField = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt9"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchPanel = function()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt10"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.DOMSearchType = function()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CClass>An event. </div></div><!--END_ND_TOOLTIPS-->
+<!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt12"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.hide = function ()</td></tr></table></blockquote>Hides the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt13"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.InactivateAfterTimeout = function()</td></tr></table></blockquote>Called by inactivateTimeout, which is set by Activate(). </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt15"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt16"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt17"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt18"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt19"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function (</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt21"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt22"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt23"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchFieldChange = function()</td></tr></table></blockquote>Called when the content of the search field is changed.</div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchFieldFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search field.</div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.OnSearchTypeChange = function()</td></tr></table></blockquote>Called when the search type is changed.</div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.OnSearchTypeFocus = function(</td><td class=PParameter nowrap>isActive</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Called when focus is added or removed from the search type.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt31"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt32"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.Search = function()</td></tr></table></blockquote>Performs a search.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Search = function(</td><td class=PParameter nowrap>search</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Searches for the passed string. </div></div><div class=CToolTip id="tt35"><div class=CClass>A class handling everything associated with the search panel.</div></div><div class=CToolTip id="tt36"><div class=CClass>The class that handles everything on the search results page.</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>mapId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.Toggle = function(</td><td class=PParameter nowrap>id</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Toggles the visibility of the passed element ID.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt40"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex><a href="Variables.html">Variables</a></div></div></div></div></div><script type="text/javascript"><!--
+var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
+--></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
+<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
+<script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Deleted: branches/kmq_dev/documents/api_js/index/Variables.html
--- trunk/mapbender/documents/api_js/index/Variables.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index/Variables.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,53 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><title>Variable Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Index><div class=IPageTitle>Variable Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; <a href="#D">D</a> &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; <a href="#K">K</a> &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr></table>
-<!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt1"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt9"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt10"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt11"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
-</div><!--Index-->
-<div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Variables</div></div></div></div></div><script type="text/javascript"><!--
---></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option><option value="Variables">Variables</option></select></div></div><!--Menu-->
-<div id=MSearchResultsWindow><iframe src="" frameborder=0 name=MSearchResults id=MSearchResults></iframe><a href="javascript:searchPanel.CloseResultsWindow()" id=MSearchResultsWindowClose>Close</a></div>
-<script language=JavaScript><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Copied: branches/kmq_dev/documents/api_js/index/Variables.html (from rev 4267, trunk/mapbender/documents/api_js/index/Variables.html)
--- branches/kmq_dev/documents/api_js/index/Variables.html	                        (rev 0)
@@ -0,0 +1,53 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><title>Variable Index</title><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script><script language=JavaScript src="../javascript/searchdata.js"></script></head><body class="IndexPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Index><div class=IPageTitle>Variable Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; A &middot; B &middot; C &middot; <a href="#D">D</a> &middot; E &middot; F &middot; G &middot; H &middot; I &middot; J &middot; <a href="#K">K</a> &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; P &middot; Q &middot; <a href="#R">R</a> &middot; S &middot; T &middot; U &middot; V &middot; W &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="K"></a>K</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>mode</span><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=IParent>SearchResults</a></div></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></td></tr></table>
+<div class=CToolTip id="tt1"><div class=CVariable>The timeout used between when a control is deactivated and when the entire panel is deactivated. </div></div><div class=CToolTip id="tt2"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.deactivateTimeoutLength</td></tr></table></blockquote>The length of deactivateTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt3"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeout</td></tr></table></blockquote>The timeout used between a keystroke and when a search is performed.</div></div><div class=CToolTip id="tt4"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.keyTimeoutLength</td></tr></table></blockquote>The length of keyTimeout in thousandths of a second.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt5"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastMatchCount</td></tr></table></blockquote>The number of matches from the last run of Search().</div></div><div class=CToolTip id="tt6"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastResultsPage</td></tr></table></blockquote>The last results page. </div></div><div class=CToolTip id="tt7"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.lastSearchValue</td></tr></table></blockquote>The last search string executed, or an empty string if none.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt8"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><div class=CToolTip id="tt9"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.mode</td></tr></table></blockquote>The mode the search is going to work in, such as &ldquo;HTML&rdquo; or &ldquo;FramedHTML&rdquo;.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt10"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.name</td></tr></table></blockquote>The name of the global variable that will be storing this instance of the class.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt11"><div class=CVariable><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.resultsPath</td></tr></table></blockquote>The relative path from the current HTML page to the results page directory.</div></div><!--END_ND_TOOLTIPS-->
+</div><!--Index-->
+<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/http/javascripts/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/lib/event-js.html">Event</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_reload-php.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_sandclock-php.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/http/javascripts/mod_zoomIn1-php.html">ZoomIn1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MFile><a href="../files/docs/javascript/main-js.html">SearchPanel</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Variables</div></div></div></div></div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/index.html
--- trunk/mapbender/documents/api_js/index.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/index.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1 +0,0 @@
-<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/javascripts/core-php.html"></head></html>
Copied: branches/kmq_dev/documents/api_js/index.html (from rev 4267, trunk/mapbender/documents/api_js/index.html)
--- branches/kmq_dev/documents/api_js/index.html	                        (rev 0)
@@ -0,0 +1 @@
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/javascripts/core-php.html"></head></html>
Deleted: branches/kmq_dev/documents/api_js/javascript/main.js
--- trunk/mapbender/documents/api_js/javascript/main.js	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/javascript/main.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,836 +0,0 @@
-// This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
-// Natural Docs is licensed under the GPL
-//  Browser Styles
-// ____________________________________________________________________________
-var agt=navigator.userAgent.toLowerCase();
-var browserType;
-var browserVer;
-if (agt.indexOf("opera") != -1)
-    browserType = "Opera";
-    if (agt.indexOf("opera 7") != -1 || agt.indexOf("opera/7") != -1)
-        {  browserVer = "Opera7";  }
-    else if (agt.indexOf("opera 8") != -1 || agt.indexOf("opera/8") != -1)
-        {  browserVer = "Opera8";  }
-    else if (agt.indexOf("opera 9") != -1 || agt.indexOf("opera/9") != -1)
-        {  browserVer = "Opera9";  }
-else if (agt.indexOf("applewebkit") != -1)
-    browserType = "Safari";
-    if (agt.indexOf("version/3") != -1)
-        {  browserVer = "Safari3";  }
-    else if (agt.indexOf("safari/4") != -1)
-        {  browserVer = "Safari2";  }
-else if (agt.indexOf("khtml") != -1)
-    browserType = "Konqueror";
-else if (agt.indexOf("msie") != -1)
-    browserType = "IE";
-    if (agt.indexOf("msie 6") != -1)
-        {  browserVer = "IE6";  }
-    else if (agt.indexOf("msie 7") != -1)
-        {  browserVer = "IE7";  }
-else if (agt.indexOf("gecko") != -1)
-    browserType = "Firefox";
-    if (agt.indexOf("rv:1.7") != -1)
-        {  browserVer = "Firefox1";  }
-    else if (agt.indexOf("rv:1.8)") != -1 || agt.indexOf("rv:1.8.0") != -1)
-        {  browserVer = "Firefox15";  }
-    else if (agt.indexOf("rv:1.8.1") != -1)
-        {  browserVer = "Firefox2";  }
-//  Support Functions
-function GetXPosition(item)
-    var position = 0;
-    if (item.offsetWidth != null)
-        while (item != document.body && item != null)
-            position += item.offsetLeft;
-            item = item.offsetParent;
-    return position;
-function GetYPosition(item)
-    var position = 0;
-            position += item.offsetTop;
-    return position;
-function MoveToPosition(item, x, y)
-    // Opera 5 chokes on the px extension, so it can use the Microsoft one instead.
-    if (item.style.left != null)
-        item.style.left = x + "px";
-        item.style.top = y + "px";
-    else if (item.style.pixelLeft != null)
-        item.style.pixelLeft = x;
-        item.style.pixelTop = y;
-//  Menu
-function ToggleMenu(id)
-    if (!window.document.getElementById)
-        {  return;  };
-    var display = window.document.getElementById(id).style.display;
-    if (display == "none")
-        {  display = "block";  }
-    else
-        {  display = "none";  }
-    window.document.getElementById(id).style.display = display;
-function HideAllBut(ids, max)
-    if (document.getElementById)
-        ids.sort( function(a,b) { return a - b; } );
-        var number = 1;
-        while (number < max)
-            if (ids.length > 0 && number == ids[0])
-                {  ids.shift();  }
-            else
-                document.getElementById("MGroupContent" + number).style.display = "none";
-            number++;
-//  Tooltips
-var tooltipTimer = 0;
-function ShowTip(event, tooltipID, linkID)
-    if (tooltipTimer)
-        {  clearTimeout(tooltipTimer);  };
-    var docX = event.clientX + window.pageXOffset;
-    var docY = event.clientY + window.pageYOffset;
-    var showCommand = "ReallyShowTip('" + tooltipID + "', '" + linkID + "', " + docX + ", " + docY + ")";
-    tooltipTimer = setTimeout(showCommand, 1000);
-function ReallyShowTip(tooltipID, linkID, docX, docY)
-    tooltipTimer = 0;
-    var tooltip;
-    var link;
-        tooltip = document.getElementById(tooltipID);
-        link = document.getElementById(linkID);
-/*    else if (document.all)
-        tooltip = eval("document.all['" + tooltipID + "']");
-        link = eval("document.all['" + linkID + "']");
-    if (tooltip)
-        var left = GetXPosition(link);
-        var top = GetYPosition(link);
-        top += link.offsetHeight;
-        // The fallback method is to use the mouse X and Y relative to the document.  We use a separate if and test if its a number
-        // in case some browser snuck through the above if statement but didn't support everything.
-        if (!isFinite(top) || top == 0)
-            left = docX;
-            top = docY;
-        // Some spacing to get it out from under the cursor.
-        top += 10;
-        // Make sure the tooltip doesnt get smushed by being too close to the edge, or in some browsers, go off the edge of the
-        // page.  We do it here because Konqueror does get offsetWidth right even if it doesnt get the positioning right.
-        if (tooltip.offsetWidth != null)
-            var width = tooltip.offsetWidth;
-            var docWidth = document.body.clientWidth;
-            if (left + width > docWidth)
-                {  left = docWidth - width - 1;  }
-            // If there's a horizontal scroll bar we could go past zero because it's using the page width, not the window width.
-            if (left < 0)
-                {  left = 0;  };
-        MoveToPosition(tooltip, left, top);
-        tooltip.style.visibility = "visible";
-function HideTip(tooltipID)
-    if (tooltipTimer)
-        clearTimeout(tooltipTimer);
-        tooltipTimer = 0;
-    var tooltip;
-        {  tooltip = document.getElementById(tooltipID); }
-    else if (document.all)
-        {  tooltip = eval("document.all['" + tooltipID + "']");  }
-    if (tooltip)
-        {  tooltip.style.visibility = "hidden";  }
-//  Blockquote fix for IE
-function NDOnLoad()
-    if (browserVer == "IE6")
-        var scrollboxes = document.getElementsByTagName('blockquote');
-        if (scrollboxes.item(0))
-            NDDoResize();
-            window.onresize=NDOnResize;
-var resizeTimer = 0;
-function NDOnResize()
-    if (resizeTimer != 0)
-        {  clearTimeout(resizeTimer);  };
-    resizeTimer = setTimeout(NDDoResize, 250);
-function NDDoResize()
-    var i;
-    var item;
-    i = 0;
-    while (item = scrollboxes.item(i))
-        item.style.width = 100;
-        i++;
-    i = 0;
-        item.style.width = item.parentNode.offsetWidth;
-        i++;
-    clearTimeout(resizeTimer);
-    resizeTimer = 0;
-/* ________________________________________________________________________________________________________
-    Class: SearchPanel
-    ________________________________________________________________________________________________________
-    A class handling everything associated with the search panel.
-    Parameters:
-        name - The name of the global variable that will be storing this instance.  Is needed to be able to set timeouts.
-        mode - The mode the search is going to work in.  Pass <NaturalDocs::Builder::Base->CommandLineOption()>, so the
-                   value will be something like "HTML" or "FramedHTML".
-function SearchPanel(name, mode, resultsPath)
-    if (!name || !mode || !resultsPath)
-        {  alert("Incorrect parameters to SearchPanel.");  };
-    // Group: Variables
-    // ________________________________________________________________________
-        var: name
-        The name of the global variable that will be storing this instance of the class.
-    this.name = name;
-        var: mode
-        The mode the search is going to work in, such as "HTML" or "FramedHTML".
-    this.mode = mode;
-        var: resultsPath
-        The relative path from the current HTML page to the results page directory.
-    this.resultsPath = resultsPath;
-        var: keyTimeout
-        The timeout used between a keystroke and when a search is performed.
-    this.keyTimeout = 0;
-        var: keyTimeoutLength
-        The length of <keyTimeout> in thousandths of a second.
-    this.keyTimeoutLength = 500;
-        var: lastSearchValue
-        The last search string executed, or an empty string if none.
-    this.lastSearchValue = "";
-        var: lastResultsPage
-        The last results page.  The value is only relevant if <lastSearchValue> is set.
-    this.lastResultsPage = "";
-        var: deactivateTimeout
-        The timeout used between when a control is deactivated and when the entire panel is deactivated.  Is necessary
-        because a control may be deactivated in favor of another control in the same panel, in which case it should stay
-        active.
-    this.deactivateTimout = 0;
-        var: deactivateTimeoutLength
-        The length of <deactivateTimeout> in thousandths of a second.
-    this.deactivateTimeoutLength = 200;
-    // Group: DOM Elements
-    // Function: DOMSearchField
-    this.DOMSearchField = function()
-        {  return document.getElementById("MSearchField");  };
-    // Function: DOMSearchType
-    this.DOMSearchType = function()
-        {  return document.getElementById("MSearchType");  };
-    // Function: DOMPopupSearchResults
-    this.DOMPopupSearchResults = function()
-        {  return document.getElementById("MSearchResults");  };
-    // Function: DOMPopupSearchResultsWindow
-    this.DOMPopupSearchResultsWindow = function()
-        {  return document.getElementById("MSearchResultsWindow");  };
-    // Function: DOMSearchPanel
-    this.DOMSearchPanel = function()
-        {  return document.getElementById("MSearchPanel");  };
-    // Group: Event Handlers
-        Function: OnSearchFieldFocus
-        Called when focus is added or removed from the search field.
-    this.OnSearchFieldFocus = function(isActive)
-        this.Activate(isActive);
-        Function: OnSearchFieldChange
-        Called when the content of the search field is changed.
-    this.OnSearchFieldChange = function()
-        if (this.keyTimeout)
-            clearTimeout(this.keyTimeout);
-        var searchValue = this.DOMSearchField().value.replace(/ +/g, "");
-        if (searchValue != this.lastSearchValue)
-            if (searchValue != "")
-                this.keyTimeout = setTimeout(this.name + ".Search()", this.keyTimeoutLength);
-            else
-                if (this.mode == "HTML")
-                    {  this.DOMPopupSearchResultsWindow().style.display = "none";  };
-        Function: OnSearchTypeFocus
-        Called when focus is added or removed from the search type.
-    this.OnSearchTypeFocus = function(isActive)
-        Function: OnSearchTypeChange
-        Called when the search type is changed.
-    this.OnSearchTypeChange = function()
-            this.Search();
-    // Group: Action Functions
-        Function: CloseResultsWindow
-        Closes the results window.
-    this.CloseResultsWindow = function()
-        this.DOMPopupSearchResultsWindow().style.display = "none";
-        this.Activate(false, true);
-        Function: Search
-        Performs a search.
-    this.Search = function()
-        var searchValue = this.DOMSearchField().value.replace(/^ +/, "");
-        var searchTopic = this.DOMSearchType().value;
-        var pageExtension = searchValue.substr(0,1);
-        if (pageExtension.match(/^[a-z]/i))
-            {  pageExtension = pageExtension.toUpperCase();  }
-        else if (pageExtension.match(/^[0-9]/))
-            {  pageExtension = 'Numbers';  }
-        else
-            {  pageExtension = "Symbols";  };
-        var resultsPage;
-        var resultsPageWithSearch;
-        var hasResultsPage;
-        // indexSectionsWithContent is defined in searchdata.js
-        if (indexSectionsWithContent[searchTopic][pageExtension] == true)
-            resultsPage = this.resultsPath + '/' + searchTopic + pageExtension + '.html';
-            resultsPageWithSearch = resultsPage+'?'+escape(searchValue);
-            hasResultsPage = true;
-        else
-            resultsPage = this.resultsPath + '/NoResults.html';
-            resultsPageWithSearch = resultsPage;
-            hasResultsPage = false;
-        var resultsFrame;
-            {  resultsFrame = window.frames.MSearchResults;  }
-        else if (this.mode == "FramedHTML")
-            {  resultsFrame = window.top.frames['Content'];  };
-        if (resultsPage != this.lastResultsPage ||
-            // Bug in IE.  If everything becomes hidden in a run, none of them will be able to be reshown in the next for some
-            // reason.  It counts the right number of results, and you can even read the display as "block" after setting it, but it
-            // just doesn't work in IE 6 or IE 7.  So if we're on the right page but the previous search had no results, reload the
-            // page anyway to get around the bug.
-            (browserType == "IE" && hasResultsPage &&
-            	(!resultsFrame.searchResults || resultsFrame.searchResults.lastMatchCount == 0)) )
-            resultsFrame.location.href = resultsPageWithSearch;
-        // So if the results page is right and there's no IE bug, reperform the search on the existing page.  We have to check if there
-        // are results because NoResults.html doesn't have any JavaScript, and it would be useless to do anything on that page even
-        // if it did.
-        else if (hasResultsPage)
-            // We need to check if this exists in case the frame is present but didn't finish loading.
-            if (resultsFrame.searchResults)
-                {  resultsFrame.searchResults.Search(searchValue);  }
-            // Otherwise just reload instead of waiting.
-            else
-                {  resultsFrame.location.href = resultsPageWithSearch;  };
-        var domPopupSearchResultsWindow = this.DOMPopupSearchResultsWindow();
-        if (this.mode == "HTML" && domPopupSearchResultsWindow.style.display != "block")
-            var domSearchType = this.DOMSearchType();
-            var left = GetXPosition(domSearchType);
-            var top = GetYPosition(domSearchType) + domSearchType.offsetHeight;
-            MoveToPosition(domPopupSearchResultsWindow, left, top);
-            domPopupSearchResultsWindow.style.display = 'block';
-        this.lastSearchValue = searchValue;
-        this.lastResultsPage = resultsPage;
-    // Group: Activation Functions
-    // Functions that handle whether the entire panel is active or not.
-        Function: Activate
-        Activates or deactivates the search panel, resetting things to their default values if necessary.  You can call this on every
-        control's OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.
-        Parameters:
-            isActive - Whether you're activating or deactivating the panel.
-            ignoreDeactivateDelay - Set if you're positive the action will deactivate the panel and thus want to skip the delay.
-    this.Activate = function(isActive, ignoreDeactivateDelay)
-        // We want to ignore isActive being false while the results window is open.
-        if (isActive || (this.mode == "HTML" && this.DOMPopupSearchResultsWindow().style.display == "block"))
-            if (this.inactivateTimeout)
-                clearTimeout(this.inactivateTimeout);
-                this.inactivateTimeout = 0;
-            this.DOMSearchPanel().className = 'MSearchPanelActive';
-            var searchField = this.DOMSearchField();
-            if (searchField.value == 'Search')
-                 {  searchField.value = "";  }
-        else if (!ignoreDeactivateDelay)
-            this.inactivateTimeout = setTimeout(this.name + ".InactivateAfterTimeout()", this.inactivateTimeoutLength);
-        else
-            this.InactivateAfterTimeout();
-        Function: InactivateAfterTimeout
-        Called by <inactivateTimeout>, which is set by <Activate()>.  Inactivation occurs on a timeout because a control may
-        receive OnBlur() when focus is really transferring to another control in the search panel.  In this case we don't want to
-        actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.
-        So by doing it on a timeout instead, there's a short period where the second control's OnFocus() can cancel the deactivation.
-    this.InactivateAfterTimeout = function()
-        this.DOMSearchPanel().className = 'MSearchPanelInactive';
-        this.DOMSearchField().value = "Search";
-   Class: SearchResults
-   _________________________________________________________________________________________________________
-   The class that handles everything on the search results page.
-function SearchResults(name, mode)
-        var: mode
-    this.mode = mode;
-        var: lastMatchCount
-        The number of matches from the last run of <Search()>.
-    this.lastMatchCount = 0;
-        Function: Toggle
-        Toggles the visibility of the passed element ID.
-    this.Toggle = function(id)
-        if (this.mode == "FramedHTML")
-            {  return;  };
-        var parentElement = document.getElementById(id);
-        var element = parentElement.firstChild;
-        while (element && element != parentElement)
-            if (element.nodeName == 'DIV' && element.className == 'ISubIndex')
-                if (element.style.display == 'block')
-                    {  element.style.display = "none";  }
-                else
-                    {  element.style.display = 'block';  }
-            if (element.nodeName == 'DIV' && element.hasChildNodes())
-                {  element = element.firstChild;  }
-            else if (element.nextSibling)
-                {  element = element.nextSibling;  }
-            else
-                do
-                    element = element.parentNode;
-                while (element && element != parentElement && !element.nextSibling);
-                if (element && element != parentElement)
-                    {  element = element.nextSibling;  };
-        Function: Search
-        Searches for the passed string.  If there is no parameter, it takes it from the URL query.
-        Always returns true, since other documents may try to call it and that may or may not be possible.
-    this.Search = function(search)
-        if (!search)
-            search = window.location.search;
-            search = search.substring(1);  // Remove the leading ?
-            search = unescape(search);
-        search = search.replace(/^ +/, "");
-        search = search.replace(/ +$/, "");
-        search = search.toLowerCase();
-        if (search.match(/[^a-z0-9]/)) // Just a little speedup so it doesn't have to go through the below unnecessarily.
-            search = search.replace(/\_/g, "_und");
-            search = search.replace(/\ +/gi, "_spc");
-            search = search.replace(/\~/g, "_til");
-            search = search.replace(/\!/g, "_exc");
-            search = search.replace(/\@/g, "_att");
-            search = search.replace(/\#/g, "_num");
-            search = search.replace(/\$/g, "_dol");
-            search = search.replace(/\%/g, "_pct");
-            search = search.replace(/\^/g, "_car");
-            search = search.replace(/\&/g, "_amp");
-            search = search.replace(/\*/g, "_ast");
-            search = search.replace(/\(/g, "_lpa");
-            search = search.replace(/\)/g, "_rpa");
-            search = search.replace(/\-/g, "_min");
-            search = search.replace(/\+/g, "_plu");
-            search = search.replace(/\=/g, "_equ");
-            search = search.replace(/\{/g, "_lbc");
-            search = search.replace(/\}/g, "_rbc");
-            search = search.replace(/\[/g, "_lbk");
-            search = search.replace(/\]/g, "_rbk");
-            search = search.replace(/\:/g, "_col");
-            search = search.replace(/\;/g, "_sco");
-            search = search.replace(/\"/g, "_quo");
-            search = search.replace(/\'/g, "_apo");
-            search = search.replace(/\</g, "_lan");
-            search = search.replace(/\>/g, "_ran");
-            search = search.replace(/\,/g, "_com");
-            search = search.replace(/\./g, "_per");
-            search = search.replace(/\?/g, "_que");
-            search = search.replace(/\//g, "_sla");
-            search = search.replace(/[^a-z0-9\_]i/gi, "_zzz");
-        var resultRows = document.getElementsByTagName("div");
-        var matches = 0;
-        var i = 0;
-        while (i < resultRows.length)
-            var row = resultRows.item(i);
-            if (row.className == "SRResult")
-                var rowMatchName = row.id.toLowerCase();
-                rowMatchName = rowMatchName.replace(/^sr\d*_/, '');
-                if (search.length <= rowMatchName.length && rowMatchName.substr(0, search.length) == search)
-                    row.style.display = "block";
-                    matches++;
-                else
-                    {  row.style.display = "none";  };
-            i++;
-        document.getElementById("Searching").style.display="none";
-        if (matches == 0)
-            {  document.getElementById("NoMatches").style.display="block";  }
-        else
-            {  document.getElementById("NoMatches").style.display="none";  }
-        this.lastMatchCount = matches;
-        return true;
Copied: branches/kmq_dev/documents/api_js/javascript/main.js (from rev 4267, trunk/mapbender/documents/api_js/javascript/main.js)
--- branches/kmq_dev/documents/api_js/javascript/main.js	                        (rev 0)
@@ -0,0 +1,836 @@
+// This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+// Natural Docs is licensed under the GPL
+//  Browser Styles
+// ____________________________________________________________________________
+var agt=navigator.userAgent.toLowerCase();
+var browserType;
+var browserVer;
+if (agt.indexOf("opera") != -1)
+    browserType = "Opera";
+    if (agt.indexOf("opera 7") != -1 || agt.indexOf("opera/7") != -1)
+        {  browserVer = "Opera7";  }
+    else if (agt.indexOf("opera 8") != -1 || agt.indexOf("opera/8") != -1)
+        {  browserVer = "Opera8";  }
+    else if (agt.indexOf("opera 9") != -1 || agt.indexOf("opera/9") != -1)
+        {  browserVer = "Opera9";  }
+else if (agt.indexOf("applewebkit") != -1)
+    browserType = "Safari";
+    if (agt.indexOf("version/3") != -1)
+        {  browserVer = "Safari3";  }
+    else if (agt.indexOf("safari/4") != -1)
+        {  browserVer = "Safari2";  }
+else if (agt.indexOf("khtml") != -1)
+    browserType = "Konqueror";
+else if (agt.indexOf("msie") != -1)
+    browserType = "IE";
+    if (agt.indexOf("msie 6") != -1)
+        {  browserVer = "IE6";  }
+    else if (agt.indexOf("msie 7") != -1)
+        {  browserVer = "IE7";  }
+else if (agt.indexOf("gecko") != -1)
+    browserType = "Firefox";
+    if (agt.indexOf("rv:1.7") != -1)
+        {  browserVer = "Firefox1";  }
+    else if (agt.indexOf("rv:1.8)") != -1 || agt.indexOf("rv:1.8.0") != -1)
+        {  browserVer = "Firefox15";  }
+    else if (agt.indexOf("rv:1.8.1") != -1)
+        {  browserVer = "Firefox2";  }
+//  Support Functions
+function GetXPosition(item)
+    var position = 0;
+    if (item.offsetWidth != null)
+        while (item != document.body && item != null)
+            position += item.offsetLeft;
+            item = item.offsetParent;
+    return position;
+function GetYPosition(item)
+    var position = 0;
+            position += item.offsetTop;
+    return position;
+function MoveToPosition(item, x, y)
+    // Opera 5 chokes on the px extension, so it can use the Microsoft one instead.
+    if (item.style.left != null)
+        item.style.left = x + "px";
+        item.style.top = y + "px";
+    else if (item.style.pixelLeft != null)
+        item.style.pixelLeft = x;
+        item.style.pixelTop = y;
+//  Menu
+function ToggleMenu(id)
+    if (!window.document.getElementById)
+        {  return;  };
+    var display = window.document.getElementById(id).style.display;
+    if (display == "none")
+        {  display = "block";  }
+    else
+        {  display = "none";  }
+    window.document.getElementById(id).style.display = display;
+function HideAllBut(ids, max)
+    if (document.getElementById)
+        ids.sort( function(a,b) { return a - b; } );
+        var number = 1;
+        while (number < max)
+            if (ids.length > 0 && number == ids[0])
+                {  ids.shift();  }
+            else
+                document.getElementById("MGroupContent" + number).style.display = "none";
+            number++;
+//  Tooltips
+var tooltipTimer = 0;
+function ShowTip(event, tooltipID, linkID)
+    if (tooltipTimer)
+        {  clearTimeout(tooltipTimer);  };
+    var docX = event.clientX + window.pageXOffset;
+    var docY = event.clientY + window.pageYOffset;
+    var showCommand = "ReallyShowTip('" + tooltipID + "', '" + linkID + "', " + docX + ", " + docY + ")";
+    tooltipTimer = setTimeout(showCommand, 1000);
+function ReallyShowTip(tooltipID, linkID, docX, docY)
+    tooltipTimer = 0;
+    var tooltip;
+    var link;
+        tooltip = document.getElementById(tooltipID);
+        link = document.getElementById(linkID);
+/*    else if (document.all)
+        tooltip = eval("document.all['" + tooltipID + "']");
+        link = eval("document.all['" + linkID + "']");
+    if (tooltip)
+        var left = GetXPosition(link);
+        var top = GetYPosition(link);
+        top += link.offsetHeight;
+        // The fallback method is to use the mouse X and Y relative to the document.  We use a separate if and test if its a number
+        // in case some browser snuck through the above if statement but didn't support everything.
+        if (!isFinite(top) || top == 0)
+            left = docX;
+            top = docY;
+        // Some spacing to get it out from under the cursor.
+        top += 10;
+        // Make sure the tooltip doesnt get smushed by being too close to the edge, or in some browsers, go off the edge of the
+        // page.  We do it here because Konqueror does get offsetWidth right even if it doesnt get the positioning right.
+        if (tooltip.offsetWidth != null)
+            var width = tooltip.offsetWidth;
+            var docWidth = document.body.clientWidth;
+            if (left + width > docWidth)
+                {  left = docWidth - width - 1;  }
+            // If there's a horizontal scroll bar we could go past zero because it's using the page width, not the window width.
+            if (left < 0)
+                {  left = 0;  };
+        MoveToPosition(tooltip, left, top);
+        tooltip.style.visibility = "visible";
+function HideTip(tooltipID)
+    if (tooltipTimer)
+        clearTimeout(tooltipTimer);
+        tooltipTimer = 0;
+    var tooltip;
+        {  tooltip = document.getElementById(tooltipID); }
+    else if (document.all)
+        {  tooltip = eval("document.all['" + tooltipID + "']");  }
+    if (tooltip)
+        {  tooltip.style.visibility = "hidden";  }
+//  Blockquote fix for IE
+function NDOnLoad()
+    if (browserVer == "IE6")
+        var scrollboxes = document.getElementsByTagName('blockquote');
+        if (scrollboxes.item(0))
+            NDDoResize();
+            window.onresize=NDOnResize;
+var resizeTimer = 0;
+function NDOnResize()
+    if (resizeTimer != 0)
+        {  clearTimeout(resizeTimer);  };
+    resizeTimer = setTimeout(NDDoResize, 250);
+function NDDoResize()
+    var i;
+    var item;
+    i = 0;
+    while (item = scrollboxes.item(i))
+        item.style.width = 100;
+        i++;
+    i = 0;
+        item.style.width = item.parentNode.offsetWidth;
+        i++;
+    clearTimeout(resizeTimer);
+    resizeTimer = 0;
+/* ________________________________________________________________________________________________________
+    Class: SearchPanel
+    ________________________________________________________________________________________________________
+    A class handling everything associated with the search panel.
+    Parameters:
+        name - The name of the global variable that will be storing this instance.  Is needed to be able to set timeouts.
+        mode - The mode the search is going to work in.  Pass <NaturalDocs::Builder::Base->CommandLineOption()>, so the
+                   value will be something like "HTML" or "FramedHTML".
+function SearchPanel(name, mode, resultsPath)
+    if (!name || !mode || !resultsPath)
+        {  alert("Incorrect parameters to SearchPanel.");  };
+    // Group: Variables
+    // ________________________________________________________________________
+        var: name
+        The name of the global variable that will be storing this instance of the class.
+    this.name = name;
+        var: mode
+        The mode the search is going to work in, such as "HTML" or "FramedHTML".
+    this.mode = mode;
+        var: resultsPath
+        The relative path from the current HTML page to the results page directory.
+    this.resultsPath = resultsPath;
+        var: keyTimeout
+        The timeout used between a keystroke and when a search is performed.
+    this.keyTimeout = 0;
+        var: keyTimeoutLength
+        The length of <keyTimeout> in thousandths of a second.
+    this.keyTimeoutLength = 500;
+        var: lastSearchValue
+        The last search string executed, or an empty string if none.
+    this.lastSearchValue = "";
+        var: lastResultsPage
+        The last results page.  The value is only relevant if <lastSearchValue> is set.
+    this.lastResultsPage = "";
+        var: deactivateTimeout
+        The timeout used between when a control is deactivated and when the entire panel is deactivated.  Is necessary
+        because a control may be deactivated in favor of another control in the same panel, in which case it should stay
+        active.
+    this.deactivateTimout = 0;
+        var: deactivateTimeoutLength
+        The length of <deactivateTimeout> in thousandths of a second.
+    this.deactivateTimeoutLength = 200;
+    // Group: DOM Elements
+    // Function: DOMSearchField
+    this.DOMSearchField = function()
+        {  return document.getElementById("MSearchField");  };
+    // Function: DOMSearchType
+    this.DOMSearchType = function()
+        {  return document.getElementById("MSearchType");  };
+    // Function: DOMPopupSearchResults
+    this.DOMPopupSearchResults = function()
+        {  return document.getElementById("MSearchResults");  };
+    // Function: DOMPopupSearchResultsWindow
+    this.DOMPopupSearchResultsWindow = function()
+        {  return document.getElementById("MSearchResultsWindow");  };
+    // Function: DOMSearchPanel
+    this.DOMSearchPanel = function()
+        {  return document.getElementById("MSearchPanel");  };
+    // Group: Event Handlers
+        Function: OnSearchFieldFocus
+        Called when focus is added or removed from the search field.
+    this.OnSearchFieldFocus = function(isActive)
+        this.Activate(isActive);
+        Function: OnSearchFieldChange
+        Called when the content of the search field is changed.
+    this.OnSearchFieldChange = function()
+        if (this.keyTimeout)
+            clearTimeout(this.keyTimeout);
+        var searchValue = this.DOMSearchField().value.replace(/ +/g, "");
+        if (searchValue != this.lastSearchValue)
+            if (searchValue != "")
+                this.keyTimeout = setTimeout(this.name + ".Search()", this.keyTimeoutLength);
+            else
+                if (this.mode == "HTML")
+                    {  this.DOMPopupSearchResultsWindow().style.display = "none";  };
+        Function: OnSearchTypeFocus
+        Called when focus is added or removed from the search type.
+    this.OnSearchTypeFocus = function(isActive)
+        Function: OnSearchTypeChange
+        Called when the search type is changed.
+    this.OnSearchTypeChange = function()
+            this.Search();
+    // Group: Action Functions
+        Function: CloseResultsWindow
+        Closes the results window.
+    this.CloseResultsWindow = function()
+        this.DOMPopupSearchResultsWindow().style.display = "none";
+        this.Activate(false, true);
+        Function: Search
+        Performs a search.
+    this.Search = function()
+        var searchValue = this.DOMSearchField().value.replace(/^ +/, "");
+        var searchTopic = this.DOMSearchType().value;
+        var pageExtension = searchValue.substr(0,1);
+        if (pageExtension.match(/^[a-z]/i))
+            {  pageExtension = pageExtension.toUpperCase();  }
+        else if (pageExtension.match(/^[0-9]/))
+            {  pageExtension = 'Numbers';  }
+        else
+            {  pageExtension = "Symbols";  };
+        var resultsPage;
+        var resultsPageWithSearch;
+        var hasResultsPage;
+        // indexSectionsWithContent is defined in searchdata.js
+        if (indexSectionsWithContent[searchTopic][pageExtension] == true)
+            resultsPage = this.resultsPath + '/' + searchTopic + pageExtension + '.html';
+            resultsPageWithSearch = resultsPage+'?'+escape(searchValue);
+            hasResultsPage = true;
+        else
+            resultsPage = this.resultsPath + '/NoResults.html';
+            resultsPageWithSearch = resultsPage;
+            hasResultsPage = false;
+        var resultsFrame;
+            {  resultsFrame = window.frames.MSearchResults;  }
+        else if (this.mode == "FramedHTML")
+            {  resultsFrame = window.top.frames['Content'];  };
+        if (resultsPage != this.lastResultsPage ||
+            // Bug in IE.  If everything becomes hidden in a run, none of them will be able to be reshown in the next for some
+            // reason.  It counts the right number of results, and you can even read the display as "block" after setting it, but it
+            // just doesn't work in IE 6 or IE 7.  So if we're on the right page but the previous search had no results, reload the
+            // page anyway to get around the bug.
+            (browserType == "IE" && hasResultsPage &&
+            	(!resultsFrame.searchResults || resultsFrame.searchResults.lastMatchCount == 0)) )
+            resultsFrame.location.href = resultsPageWithSearch;
+        // So if the results page is right and there's no IE bug, reperform the search on the existing page.  We have to check if there
+        // are results because NoResults.html doesn't have any JavaScript, and it would be useless to do anything on that page even
+        // if it did.
+        else if (hasResultsPage)
+            // We need to check if this exists in case the frame is present but didn't finish loading.
+            if (resultsFrame.searchResults)
+                {  resultsFrame.searchResults.Search(searchValue);  }
+            // Otherwise just reload instead of waiting.
+            else
+                {  resultsFrame.location.href = resultsPageWithSearch;  };
+        var domPopupSearchResultsWindow = this.DOMPopupSearchResultsWindow();
+        if (this.mode == "HTML" && domPopupSearchResultsWindow.style.display != "block")
+            var domSearchType = this.DOMSearchType();
+            var left = GetXPosition(domSearchType);
+            var top = GetYPosition(domSearchType) + domSearchType.offsetHeight;
+            MoveToPosition(domPopupSearchResultsWindow, left, top);
+            domPopupSearchResultsWindow.style.display = 'block';
+        this.lastSearchValue = searchValue;
+        this.lastResultsPage = resultsPage;
+    // Group: Activation Functions
+    // Functions that handle whether the entire panel is active or not.
+        Function: Activate
+        Activates or deactivates the search panel, resetting things to their default values if necessary.  You can call this on every
+        control's OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.
+        Parameters:
+            isActive - Whether you're activating or deactivating the panel.
+            ignoreDeactivateDelay - Set if you're positive the action will deactivate the panel and thus want to skip the delay.
+    this.Activate = function(isActive, ignoreDeactivateDelay)
+        // We want to ignore isActive being false while the results window is open.
+        if (isActive || (this.mode == "HTML" && this.DOMPopupSearchResultsWindow().style.display == "block"))
+            if (this.inactivateTimeout)
+                clearTimeout(this.inactivateTimeout);
+                this.inactivateTimeout = 0;
+            this.DOMSearchPanel().className = 'MSearchPanelActive';
+            var searchField = this.DOMSearchField();
+            if (searchField.value == 'Search')
+                 {  searchField.value = "";  }
+        else if (!ignoreDeactivateDelay)
+            this.inactivateTimeout = setTimeout(this.name + ".InactivateAfterTimeout()", this.inactivateTimeoutLength);
+        else
+            this.InactivateAfterTimeout();
+        Function: InactivateAfterTimeout
+        Called by <inactivateTimeout>, which is set by <Activate()>.  Inactivation occurs on a timeout because a control may
+        receive OnBlur() when focus is really transferring to another control in the search panel.  In this case we don't want to
+        actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.
+        So by doing it on a timeout instead, there's a short period where the second control's OnFocus() can cancel the deactivation.
+    this.InactivateAfterTimeout = function()
+        this.DOMSearchPanel().className = 'MSearchPanelInactive';
+        this.DOMSearchField().value = "Search";
+   Class: SearchResults
+   _________________________________________________________________________________________________________
+   The class that handles everything on the search results page.
+function SearchResults(name, mode)
+        var: mode
+    this.mode = mode;
+        var: lastMatchCount
+        The number of matches from the last run of <Search()>.
+    this.lastMatchCount = 0;
+        Function: Toggle
+        Toggles the visibility of the passed element ID.
+    this.Toggle = function(id)
+        if (this.mode == "FramedHTML")
+            {  return;  };
+        var parentElement = document.getElementById(id);
+        var element = parentElement.firstChild;
+        while (element && element != parentElement)
+            if (element.nodeName == 'DIV' && element.className == 'ISubIndex')
+                if (element.style.display == 'block')
+                    {  element.style.display = "none";  }
+                else
+                    {  element.style.display = 'block';  }
+            if (element.nodeName == 'DIV' && element.hasChildNodes())
+                {  element = element.firstChild;  }
+            else if (element.nextSibling)
+                {  element = element.nextSibling;  }
+            else
+                do
+                    element = element.parentNode;
+                while (element && element != parentElement && !element.nextSibling);
+                if (element && element != parentElement)
+                    {  element = element.nextSibling;  };
+        Function: Search
+        Searches for the passed string.  If there is no parameter, it takes it from the URL query.
+        Always returns true, since other documents may try to call it and that may or may not be possible.
+    this.Search = function(search)
+        if (!search)
+            search = window.location.search;
+            search = search.substring(1);  // Remove the leading ?
+            search = unescape(search);
+        search = search.replace(/^ +/, "");
+        search = search.replace(/ +$/, "");
+        search = search.toLowerCase();
+        if (search.match(/[^a-z0-9]/)) // Just a little speedup so it doesn't have to go through the below unnecessarily.
+            search = search.replace(/\_/g, "_und");
+            search = search.replace(/\ +/gi, "_spc");
+            search = search.replace(/\~/g, "_til");
+            search = search.replace(/\!/g, "_exc");
+            search = search.replace(/\@/g, "_att");
+            search = search.replace(/\#/g, "_num");
+            search = search.replace(/\$/g, "_dol");
+            search = search.replace(/\%/g, "_pct");
+            search = search.replace(/\^/g, "_car");
+            search = search.replace(/\&/g, "_amp");
+            search = search.replace(/\*/g, "_ast");
+            search = search.replace(/\(/g, "_lpa");
+            search = search.replace(/\)/g, "_rpa");
+            search = search.replace(/\-/g, "_min");
+            search = search.replace(/\+/g, "_plu");
+            search = search.replace(/\=/g, "_equ");
+            search = search.replace(/\{/g, "_lbc");
+            search = search.replace(/\}/g, "_rbc");
+            search = search.replace(/\[/g, "_lbk");
+            search = search.replace(/\]/g, "_rbk");
+            search = search.replace(/\:/g, "_col");
+            search = search.replace(/\;/g, "_sco");
+            search = search.replace(/\"/g, "_quo");
+            search = search.replace(/\'/g, "_apo");
+            search = search.replace(/\</g, "_lan");
+            search = search.replace(/\>/g, "_ran");
+            search = search.replace(/\,/g, "_com");
+            search = search.replace(/\./g, "_per");
+            search = search.replace(/\?/g, "_que");
+            search = search.replace(/\//g, "_sla");
+            search = search.replace(/[^a-z0-9\_]i/gi, "_zzz");
+        var resultRows = document.getElementsByTagName("div");
+        var matches = 0;
+        var i = 0;
+        while (i < resultRows.length)
+            var row = resultRows.item(i);
+            if (row.className == "SRResult")
+                var rowMatchName = row.id.toLowerCase();
+                rowMatchName = rowMatchName.replace(/^sr\d*_/, '');
+                if (search.length <= rowMatchName.length && rowMatchName.substr(0, search.length) == search)
+                    row.style.display = "block";
+                    matches++;
+                else
+                    {  row.style.display = "none";  };
+            i++;
+        document.getElementById("Searching").style.display="none";
+        if (matches == 0)
+            {  document.getElementById("NoMatches").style.display="block";  }
+        else
+            {  document.getElementById("NoMatches").style.display="none";  }
+        this.lastMatchCount = matches;
+        return true;
Deleted: branches/kmq_dev/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/javascript/searchdata.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,122 +0,0 @@
-var indexSectionsWithContent = {
-   "General": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": true,
-      "B": false,
-      "C": true,
-      "D": true,
-      "E": true,
-      "F": true,
-      "G": false,
-      "H": true,
-      "I": true,
-      "J": false,
-      "K": true,
-      "L": true,
-      "M": true,
-      "N": true,
-      "O": true,
-      "P": false,
-      "Q": false,
-      "R": true,
-      "S": true,
-      "T": true,
-      "U": false,
-      "V": true,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": true
-   "Variables": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": false,
-      "D": true,
-      "E": false,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": false,
-      "J": false,
-      "K": true,
-      "L": true,
-      "M": true,
-      "N": true,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": true,
-      "S": false,
-      "T": false,
-      "U": false,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": false
-   "Functions": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": true,
-      "B": false,
-      "C": true,
-      "D": true,
-      "E": false,
-      "F": false,
-      "G": false,
-      "H": true,
-      "I": true,
-      "J": false,
-      "K": false,
-      "L": false,
-      "M": true,
-      "N": false,
-      "O": true,
-      "P": false,
-      "Q": false,
-      "R": true,
-      "S": true,
-      "T": true,
-      "U": false,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": false
-   "Classes": {
-      "Symbols": false,
-      "Numbers": false,
-      "A": false,
-      "B": false,
-      "C": false,
-      "D": false,
-      "E": true,
-      "F": false,
-      "G": false,
-      "H": false,
-      "I": false,
-      "J": false,
-      "K": false,
-      "L": false,
-      "M": true,
-      "N": false,
-      "O": false,
-      "P": false,
-      "Q": false,
-      "R": true,
-      "S": true,
-      "T": false,
-      "U": false,
-      "V": false,
-      "W": false,
-      "X": false,
-      "Y": false,
-      "Z": true
Copied: branches/kmq_dev/documents/api_js/javascript/searchdata.js (from rev 4267, trunk/mapbender/documents/api_js/javascript/searchdata.js)
--- branches/kmq_dev/documents/api_js/javascript/searchdata.js	                        (rev 0)
@@ -0,0 +1,122 @@
+var indexSectionsWithContent = {
+   "General": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": true,
+      "B": false,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": true,
+      "G": false,
+      "H": true,
+      "I": true,
+      "J": false,
+      "K": true,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": false,
+      "V": true,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": true
+   "Variables": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": false,
+      "C": false,
+      "D": true,
+      "E": false,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": false,
+      "J": false,
+      "K": true,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": false,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": false,
+      "T": false,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Functions": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": true,
+      "B": false,
+      "C": true,
+      "D": true,
+      "E": false,
+      "F": false,
+      "G": false,
+      "H": true,
+      "I": true,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": true,
+      "N": false,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Classes": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": false,
+      "C": false,
+      "D": false,
+      "E": true,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": false,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": true,
+      "N": false,
+      "O": false,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": false,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": true
\ No newline at end of file
Deleted: branches/kmq_dev/documents/api_js/search/ClassesE.html
--- trunk/mapbender/documents/api_js/search/ClassesE.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/ClassesE.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
-document.getElementById("Loading").style.display="none";
-document.getElementById("NoMatches").style.display="none";
-var searchResults = new SearchResults("searchResults", "HTML");
-searchResults.Search();
---></script></div><script language=JavaScript><!--
Copied: branches/kmq_dev/documents/api_js/search/ClassesE.html (from rev 4267, trunk/mapbender/documents/api_js/search/ClassesE.html)
--- branches/kmq_dev/documents/api_js/search/ClassesE.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+document.getElementById("Loading").style.display="none";
+document.getElementById("NoMatches").style.display="none";
+var searchResults = new SearchResults("searchResults", "HTML");
+searchResults.Search();
+--></script></div><script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Deleted: branches/kmq_dev/documents/api_js/search/ClassesM.html
--- trunk/mapbender/documents/api_js/search/ClassesM.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/ClassesM.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=ISymbol>Map</a></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/ClassesM.html (from rev 4267, trunk/mapbender/documents/api_js/search/ClassesM.html)
--- branches/kmq_dev/documents/api_js/search/ClassesM.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=ISymbol>Map</a></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/ClassesR.html
--- trunk/mapbender/documents/api_js/search/ClassesR.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/ClassesR.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/ClassesR.html (from rev 4267, trunk/mapbender/documents/api_js/search/ClassesR.html)
--- branches/kmq_dev/documents/api_js/search/ClassesR.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/ClassesS.html
--- trunk/mapbender/documents/api_js/search/ClassesS.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/ClassesS.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/ClassesS.html (from rev 4267, trunk/mapbender/documents/api_js/search/ClassesS.html)
--- branches/kmq_dev/documents/api_js/search/ClassesS.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/ClassesZ.html
--- trunk/mapbender/documents/api_js/search/ClassesZ.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/ClassesZ.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_ZoomIn1><div class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" target=_parent class=ISymbol>ZoomIn1</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/ClassesZ.html (from rev 4267, trunk/mapbender/documents/api_js/search/ClassesZ.html)
--- branches/kmq_dev/documents/api_js/search/ClassesZ.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_ZoomIn1><div class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-php.html#ZoomIn1" target=_parent class=ISymbol>ZoomIn1</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FilesM.html
--- trunk/mapbender/documents/api_js/search/FilesM.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FilesM.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mod_undaddWMSfromfilteredList_perphp><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php" target=_parent class=ISymbol>mod_addWMSfromfilteredList.php</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Copied: branches/kmq_dev/documents/api_js/search/FilesM.html (from rev 4267, trunk/mapbender/documents/api_js/search/FilesM.html)
--- branches/kmq_dev/documents/api_js/search/FilesM.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mod_undaddWMSfromfilteredList_perphp><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php" target=_parent class=ISymbol>mod_addWMSfromfilteredList.php</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsA.html
--- trunk/mapbender/documents/api_js/search/FunctionsA.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsA.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsA.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsA.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsA.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsC.html
--- trunk/mapbender/documents/api_js/search/FunctionsC.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsC.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_CloseResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" target=_parent class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsC.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsC.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsC.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_CloseResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.CloseResultsWindow" target=_parent class=ISymbol>CloseResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsD.html
--- trunk/mapbender/documents/api_js/search/FunctionsD.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsD.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsD.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsD.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsD.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsH.html
--- trunk/mapbender/documents/api_js/search/FunctionsH.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsH.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_hide><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" target=_parent class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsH.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsH.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsH.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_hide><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.hide" target=_parent class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsI.html
--- trunk/mapbender/documents/api_js/search/FunctionsI.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsI.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_InactivateAfterTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" target=_parent class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsI.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsI.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsI.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_InactivateAfterTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.InactivateAfterTimeout" target=_parent class=ISymbol>InactivateAfterTimeout</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsM.html
--- trunk/mapbender/documents/api_js/search/FunctionsM.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsM.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=ISymbol>Map</a>, <span class=IParent>Map</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsM.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsM.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsM.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=ISymbol>Map</a>, <span class=IParent>Map</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsO.html
--- trunk/mapbender/documents/api_js/search/FunctionsO.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsO.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_OnSearchFieldChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" target=_parent class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchFieldFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" target=_parent class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" target=_parent class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" target=_parent class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsO.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsO.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsO.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_OnSearchFieldChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldChange" target=_parent class=ISymbol>OnSearchFieldChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchFieldFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchFieldFocus" target=_parent class=ISymbol>OnSearchFieldFocus</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeChange><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeChange" target=_parent class=ISymbol>OnSearchTypeChange</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_OnSearchTypeFocus><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.OnSearchTypeFocus" target=_parent class=ISymbol>OnSearchTypeFocus</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsR.html
--- trunk/mapbender/documents/api_js/search/FunctionsR.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsR.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsR.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsR.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsR.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsS.html
--- trunk/mapbender/documents/api_js/search/FunctionsS.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsS.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsS.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsS.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsS.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/FunctionsT.html
--- trunk/mapbender/documents/api_js/search/FunctionsT.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/FunctionsT.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Toggle><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" target=_parent class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/FunctionsT.html (from rev 4267, trunk/mapbender/documents/api_js/search/FunctionsT.html)
--- branches/kmq_dev/documents/api_js/search/FunctionsT.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Toggle><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.Toggle" target=_parent class=ISymbol>Toggle</a>, <span class=IParent>SearchResults</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralA.html
--- trunk/mapbender/documents/api_js/search/GeneralA.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralA.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Action_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions" target=_parent class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activation_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" target=_parent class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralA.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralA.html)
--- branches/kmq_dev/documents/api_js/search/GeneralA.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Action_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Action_Functions" target=_parent class=ISymbol>Action Functions</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activate><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activate" target=_parent class=ISymbol>Activate</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_Activation_spcFunctions><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Activation_Functions" target=_parent class=ISymbol>Activation Functions</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralC.html
--- trunk/mapbender/documents/api_js/search/GeneralC.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralC.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/GeneralC.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralC.html)
--- branches/kmq_dev/documents/api_js/search/GeneralC.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/GeneralD.html
--- trunk/mapbender/documents/api_js/search/GeneralD.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralD.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOM_spcElements><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements" target=_parent class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralD.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralD.html)
--- branches/kmq_dev/documents/api_js/search/GeneralD.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOM_spcElements><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOM_Elements" target=_parent class=ISymbol>DOM Elements</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResults" target=_parent class=ISymbol>DOMPopupSearchResults</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMPopupSearchResultsWindow><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMPopupSearchResultsWindow" target=_parent class=ISymbol>DOMPopupSearchResultsWindow</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchField><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchField" target=_parent class=ISymbol>DOMSearchField</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchPanel" target=_parent class=ISymbol>DOMSearchPanel</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_DOMSearchType><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.DOMSearchType" target=_parent class=ISymbol>DOMSearchType</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralE.html
--- trunk/mapbender/documents/api_js/search/GeneralE.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralE.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Event_spcHandlers><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers" target=_parent class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralE.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralE.html)
--- branches/kmq_dev/documents/api_js/search/GeneralE.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_Event_spcHandlers><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.Event_Handlers" target=_parent class=ISymbol>Event Handlers</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralF.html
--- trunk/mapbender/documents/api_js/search/GeneralF.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralF.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralF.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralF.html)
--- branches/kmq_dev/documents/api_js/search/GeneralF.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/http/javascripts/mod_reload-php.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/docs/javascript/main-js.html#SearchResults.Functions" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralH.html
--- trunk/mapbender/documents/api_js/search/GeneralH.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralH.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/GeneralH.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralH.html)
--- branches/kmq_dev/documents/api_js/search/GeneralH.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/GeneralI.html
--- trunk/mapbender/documents/api_js/search/GeneralI.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralI.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/GeneralI.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralI.html)
--- branches/kmq_dev/documents/api_js/search/GeneralI.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/GeneralK.html
--- trunk/mapbender/documents/api_js/search/GeneralK.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralK.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_keyTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" target=_parent class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_keyTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" target=_parent class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralK.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralK.html)
--- branches/kmq_dev/documents/api_js/search/GeneralK.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_keyTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" target=_parent class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_keyTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" target=_parent class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralL.html
--- trunk/mapbender/documents/api_js/search/GeneralL.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralL.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_lastMatchCount><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" target=_parent class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></div></div><div class=SRResult id=SR_lastResultsPage><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" target=_parent class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_lastSearchValue><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" target=_parent class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralL.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralL.html)
--- branches/kmq_dev/documents/api_js/search/GeneralL.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_lastMatchCount><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" target=_parent class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></div></div><div class=SRResult id=SR_lastResultsPage><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" target=_parent class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_lastSearchValue><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" target=_parent class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralM.html
--- trunk/mapbender/documents/api_js/search/GeneralM.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralM.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Map')" class=ISymbol>Map</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=IParent>Map</a></div></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralM.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralM.html)
--- branches/kmq_dev/documents/api_js/search/GeneralM.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Map><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Map')" class=ISymbol>Map</a><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" target=_parent class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" target=_parent class=IParent>Map</a></div></div></div><div class=SRResult id=SR_Mapbender><div class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" target=_parent class=ISymbol>Mapbender</a></div></div><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralN.html
--- trunk/mapbender/documents/api_js/search/GeneralN.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralN.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_name><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" target=_parent class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralN.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralN.html)
--- branches/kmq_dev/documents/api_js/search/GeneralN.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_name><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.name" target=_parent class=ISymbol>name</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralO.html
--- trunk/mapbender/documents/api_js/search/GeneralO.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralO.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/GeneralO.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralO.html)
--- branches/kmq_dev/documents/api_js/search/GeneralO.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/GeneralR.html
--- trunk/mapbender/documents/api_js/search/GeneralR.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralR.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralR.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralR.html)
--- branches/kmq_dev/documents/api_js/search/GeneralR.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-php.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralS.html
--- trunk/mapbender/documents/api_js/search/GeneralS.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralS.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralS.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralS.html)
--- branches/kmq_dev/documents/api_js/search/GeneralS.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Sandclock><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock" target=_parent class=ISymbol>Sandclock</a></div></div><div class=SRResult id=SR_Search><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Search')" class=ISymbol>Search</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Search" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Search" target=_parent class=IParent>SearchResults</a></div></div></div><div class=SRResult id=SR_SearchPanel><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel" target=_parent class=ISymbol>SearchPanel</a></div></div><div class=SRResult id=SR_SearchResults><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults" target=_parent class=ISymbol>SearchResults</a></div></div><div class=SRResult id=SR_setExtent><div class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" target=_parent class=ISymbol>setExtent</a>, <span class=IParent>Map</span></div></div><div class=SRResult id=SR_show><div class=IEntry><a href="../files/http/javascripts/mod_sandclock-php.html#Sandclock.show" target=_parent class=ISymbol>show</a>, <span class=IParent>Sandclock</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/GeneralT.html
--- trunk/mapbender/documents/api_js/search/GeneralT.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralT.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/GeneralT.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralT.html)
--- branches/kmq_dev/documents/api_js/search/GeneralT.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/GeneralV.html
--- trunk/mapbender/documents/api_js/search/GeneralV.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralV.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Variables><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Variables')" class=ISymbol>Variables</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/GeneralV.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralV.html)
--- branches/kmq_dev/documents/api_js/search/GeneralV.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Variables><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Variables')" class=ISymbol>Variables</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.Variables" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.Variables" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
\ No newline at end of file
Deleted: branches/kmq_dev/documents/api_js/search/GeneralZ.html
--- trunk/mapbender/documents/api_js/search/GeneralZ.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/GeneralZ.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
Copied: branches/kmq_dev/documents/api_js/search/GeneralZ.html (from rev 4267, trunk/mapbender/documents/api_js/search/GeneralZ.html)
--- branches/kmq_dev/documents/api_js/search/GeneralZ.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/NoResults.html
--- trunk/mapbender/documents/api_js/search/NoResults.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/NoResults.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,15 +0,0 @@
-<div id=Index><div class=SRStatus id=NoMatches>No Matches</div></div><script language=JavaScript><!--
Copied: branches/kmq_dev/documents/api_js/search/NoResults.html (from rev 4267, trunk/mapbender/documents/api_js/search/NoResults.html)
--- branches/kmq_dev/documents/api_js/search/NoResults.html	                        (rev 0)
@@ -0,0 +1,15 @@
+<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+<div id=Index><div class=SRStatus id=NoMatches>No Matches</div></div><script language=JavaScript><!--
Deleted: branches/kmq_dev/documents/api_js/search/VariablesD.html
--- trunk/mapbender/documents/api_js/search/VariablesD.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesD.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
-document.getElementById("Loading").style.display="none";
-document.getElementById("NoMatches").style.display="none";
-var searchResults = new SearchResults("searchResults", "HTML");
-searchResults.Search();
---></script></div><script language=JavaScript><!--
Copied: branches/kmq_dev/documents/api_js/search/VariablesD.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesD.html)
--- branches/kmq_dev/documents/api_js/search/VariablesD.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_deactivateTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeout" target=_parent class=ISymbol>deactivateTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_deactivateTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.deactivateTimeoutLength" target=_parent class=ISymbol>deactivateTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+document.getElementById("Loading").style.display="none";
+document.getElementById("NoMatches").style.display="none";
+var searchResults = new SearchResults("searchResults", "HTML");
+searchResults.Search();
+--></script></div><script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Deleted: branches/kmq_dev/documents/api_js/search/VariablesK.html
--- trunk/mapbender/documents/api_js/search/VariablesK.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesK.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/VariablesK.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesK.html)
--- branches/kmq_dev/documents/api_js/search/VariablesK.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/VariablesL.html
--- trunk/mapbender/documents/api_js/search/VariablesL.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesL.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/VariablesL.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesL.html)
--- branches/kmq_dev/documents/api_js/search/VariablesL.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/VariablesM.html
--- trunk/mapbender/documents/api_js/search/VariablesM.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesM.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/VariablesM.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesM.html)
--- branches/kmq_dev/documents/api_js/search/VariablesM.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/search/VariablesN.html
--- trunk/mapbender/documents/api_js/search/VariablesN.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesN.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
Copied: branches/kmq_dev/documents/api_js/search/VariablesN.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesN.html)
--- branches/kmq_dev/documents/api_js/search/VariablesN.html	                        (rev 0)
@@ -0,0 +1,20 @@
Deleted: branches/kmq_dev/documents/api_js/search/VariablesR.html
--- trunk/mapbender/documents/api_js/search/VariablesR.html	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/search/VariablesR.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Copied: branches/kmq_dev/documents/api_js/search/VariablesR.html (from rev 4267, trunk/mapbender/documents/api_js/search/VariablesR.html)
--- branches/kmq_dev/documents/api_js/search/VariablesR.html	                        (rev 0)
@@ -0,0 +1,20 @@
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: branches/kmq_dev/documents/api_js/styles/main.css
--- trunk/mapbender/documents/api_js/styles/main.css	2009-07-01 09:58:49 UTC (rev 4267)
+++ branches/kmq_dev/documents/api_js/styles/main.css	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,767 +0,0 @@
-   IMPORTANT: If you're editing this file in the output directory of one of
-   your projects, your changes will be overwritten the next time you run
-   Natural Docs.  Instead, copy this file to your project directory, make your
-   changes, and you can use it with -s.  Even better would be to make a CSS
-   file in your project directory with only your changes, which you can then
-   use with -s [original style] [your changes].
-   On the other hand, if you're editing this file in the Natural Docs styles
-   directory, the changes will automatically be applied to all your projects
-   that use this style the next time Natural Docs is run on them.
-   This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
-   Natural Docs is licensed under the GPL
-body {
-    font: 10pt Verdana, Arial, sans-serif;
-    color: #000000;
-    margin: 0; padding: 0;
-.ContentPage,
-.IndexPage,
-.FramedMenuPage {
-    background-color: #E8E8E8;
-.FramedContentPage,
-.FramedIndexPage,
-.FramedSearchResultsPage,
-.PopupSearchResultsPage {
-    background-color: #FFFFFF;
-a:link,
-a:visited { color: #900000; text-decoration: none }
-a:hover { color: #900000; text-decoration: underline }
-a:active { color: #FF0000; text-decoration: underline }
-td {
-    vertical-align: top }
-img { border: 0;  }
-    Comment out this line to use web-style paragraphs (blank line between
-    paragraphs, no indent) instead of print-style paragraphs (no blank line,
-    indented.)
-p {
-    text-indent: 5ex; margin: 0 }
-/*  Opera doesn't break with just wbr, but will if you add this.  */
-.Opera wbr:after {
-	content: "\00200B";
-/*  Blockquotes are used as containers for things that may need to scroll.  */
-blockquote {
-    padding: 0;
-    margin: 0;
-    overflow: auto;
-.Firefox1 blockquote {
-    padding-bottom: .5em;
-/*  Turn off scrolling when printing.  */
- at media print {
-    blockquote {
-        overflow: visible;
-    .IE blockquote {
-        width: auto;
-#Menu {
-    font-size: 9pt;
-    padding: 10px 0 0 0;
-.ContentPage #Menu,
-.IndexPage #Menu {
-    position: absolute;
-    top: 0;
-    left: 0;
-    width: 31ex;
-    overflow: hidden;
-.ContentPage .Firefox #Menu,
-.IndexPage .Firefox #Menu {
-    width: 27ex;
-    .MTitle {
-        font-size: 16pt; font-weight: bold; font-variant: small-caps;
-        text-align: center;
-        padding: 5px 10px 15px 10px;
-        border-bottom: 1px dotted #000000;
-        margin-bottom: 15px }
-    .MSubTitle {
-        font-size: 9pt; font-weight: normal; font-variant: normal;
-        margin-top: 1ex; margin-bottom: 5px }
-    .MEntry a:link,
-    .MEntry a:hover,
-    .MEntry a:visited { color: #606060; margin-right: 0 }
-    .MEntry a:active { color: #A00000; margin-right: 0 }
-    .MGroup {
-        font-variant: small-caps; font-weight: bold;
-        margin: 1em 0 1em 10px;
-    .MGroupContent {
-        font-variant: normal; font-weight: normal }
-    .MGroup a:link,
-    .MGroup a:hover,
-    .MGroup a:visited { color: #545454; margin-right: 10px }
-    .MGroup a:active { color: #A00000; margin-right: 10px }
-    .MFile,
-    .MText,
-    .MLink,
-    .MIndex {
-        padding: 1px 17px 2px 10px;
-        margin: .25em 0 .25em 0;
-    .MText {
-        font-size: 8pt; font-style: italic }
-    .MLink {
-        font-style: italic }
-    #MSelected {
-        color: #000000; background-color: #FFFFFF;
-        /*  Replace padding with border.  */
-        padding: 0 10px 0 10px;
-        border-width: 1px 2px 2px 0; border-style: solid; border-color: #000000;
-        margin-right: 5px;
-    /*  Close off the left side when its in a group.  */
-    .MGroup #MSelected {
-        padding-left: 9px; border-left-width: 1px }
-    /*  A treat for Mozilla users.  Blatantly non-standard.  Will be replaced with CSS 3 attributes when finalized/supported.  */
-    .Firefox #MSelected {
-        -moz-border-radius-topright: 10px;
-        -moz-border-radius-bottomright: 10px }
-    .Firefox .MGroup #MSelected {
-        -moz-border-radius-topleft: 10px;
-        -moz-border-radius-bottomleft: 10px }
-    #MSearchPanel {
-        padding: 0px 6px;
-        margin: .25em 0;
-    #MSearchField {
-        font: italic 9pt Verdana, sans-serif;
-        color: #606060;
-        border: none;
-        padding: 2px 4px;
-        width: 100%;
-    /* Only Opera gets it right. */
-    .Firefox #MSearchField,
-    .IE #MSearchField,
-    .Safari #MSearchField {
-        width: 94%;
-    .Opera9 #MSearchField,
-    .Konqueror #MSearchField {
-        width: 97%;
-    .FramedMenuPage .Firefox #MSearchField,
-    .FramedMenuPage .Safari #MSearchField,
-    .FramedMenuPage .Konqueror #MSearchField {
-        width: 98%;
-    /* Firefox doesn't do this right in frames without #MSearchPanel added on.
-        It's presence doesn't hurt anything other browsers. */
-    #MSearchPanel.MSearchPanelInactive:hover #MSearchField {
-        border: 1px solid #C0C0C0;
-        padding: 1px 3px;
-    .MSearchPanelActive #MSearchField {
-        font-style: normal;
-        padding: 1px 3px;
-    #MSearchType {
-        visibility: hidden;
-        font: 8pt Verdana, sans-serif;
-        width: 98%;
-        padding: 0;
-    .MSearchPanelActive #MSearchType,
-    /*  As mentioned above, Firefox doesn't do this right in frames without #MSearchPanel added on. */
-    #MSearchPanel.MSearchPanelInactive:hover #MSearchType,
-    #MSearchType:focus {
-        visibility: visible;
-        color: #606060;
-    #MSearchType option#MSearchEverything {
-        font-weight: bold;
-    .Opera8 .MSearchPanelInactive:hover,
-    .Opera8 .MSearchPanelActive {
-        margin-left: -1px;
-    iframe#MSearchResults {
-        width: 60ex;
-        height: 15em;
-    #MSearchResultsWindow {
-        display: none;
-        left: 0; top: 0;
-        border: 1px solid #000000;
-    #MSearchResultsWindowClose {
-        font-size: 8pt;
-        display: block;
-        padding: 2px 5px;
-    #MSearchResultsWindowClose:link,
-    #MSearchResultsWindowClose:visited {
-        color: #000000;
-        text-decoration: none;
-    #MSearchResultsWindowClose:active,
-    #MSearchResultsWindowClose:hover {
-        color: #800000;
-        background-color: #F4F4F4;
-#Content {
-    padding-bottom: 15px;
-.ContentPage #Content {
-    border-width: 0 0 1px 1px;
-    border-style: solid;
-    border-color: #000000;
-    font-size: 9pt;  /* To make 31ex match the menu's 31ex. */
-    margin-left: 31ex;
-.ContentPage .Firefox #Content {
-    margin-left: 27ex;
-    .CTopic {
-        font-size: 10pt;
-        margin-bottom: 3em;
-    .CTitle {
-        font-size: 12pt; font-weight: bold;
-        border-width: 0 0 1px 0; border-style: solid; border-color: #A0A0A0;
-        margin: 0 15px .5em 15px }
-    .CGroup .CTitle {
-        font-size: 16pt; font-variant: small-caps;
-        padding-left: 15px; padding-right: 15px;
-        border-width: 0 0 2px 0; border-color: #000000;
-        margin-left: 0; margin-right: 0 }
-    .CClass .CTitle,
-    .CInterface .CTitle,
-    .CDatabase .CTitle,
-    .CDatabaseTable .CTitle,
-    .CSection .CTitle {
-        font-size: 18pt;
-        color: #FFFFFF; background-color: #A0A0A0;
-        padding: 10px 15px 10px 15px;
-        border-width: 2px 0; border-color: #000000;
-    #MainTopic .CTitle {
-        font-size: 20pt;
-        color: #FFFFFF; background-color: #7070C0;
-        border-width: 0 0 3px 0; border-color: #000000;
-    .CBody {
-        margin-left: 15px; margin-right: 15px }
-    .CToolTip {
-        position: absolute; visibility: hidden;
-        left: 0; top: 0;
-        background-color: #FFFFE0;
-        padding: 5px;
-        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #000000;
-        font-size: 8pt;
-    .Opera .CToolTip {
-        max-width: 98%;
-    /*  Scrollbars would be useless.  */
-    .CToolTip blockquote {
-        overflow: hidden;
-    .IE6 .CToolTip blockquote {
-    .CHeading {
-        font-weight: bold; font-size: 10pt;
-        margin: 1.5em 0 .5em 0;
-    .CBody pre {
-        font: 10pt "Courier New", Courier, monospace;
-        margin: 1em 0;
-    .CBody ul {
-        /*  I don't know why CBody's margin doesn't apply, but it's consistent across browsers so whatever.
-             Reapply it here as padding.  */
-        margin: .5em 5ex .5em 5ex;
-    .CDescriptionList {
-        margin: .5em 5ex 0 5ex }
-        .CDLEntry {
-            font: 10pt "Courier New", Courier, monospace; color: #808080;
-            padding-bottom: .25em;
-            white-space: nowrap }
-        .CDLDescription {
-            font-size: 10pt;  /*  For browsers that don't inherit correctly, like Opera 5.  */
-            padding-bottom: .5em; padding-left: 5ex }
-    .CTopic img {
-        display: block;
-        margin: 1em auto;
-    .CImageCaption {
-        font-size: 8pt;
-        color: #808080;
-        position: relative;
-        top: 1em;
-    .CImageLink {
-        color: #808080;
-        font-style: italic;
-    a.CImageLink:link,
-    a.CImageLink:visited,
-    a.CImageLink:hover { color: #808080 }
-.Prototype {
-    padding: 5px 3ex;
-    border-width: 1px; border-style: solid;
-    margin: 0 5ex 1.5em 5ex;
-    .Prototype td {
-        font-size: 10pt;
-    .PDefaultValue,
-    .PDefaultValuePrefix,
-    .PTypePrefix {
-        color: #8F8F8F;
-    .PTypePrefix {
-        text-align: right;
-    .PAfterParameters {
-        vertical-align: bottom;
-    .IE .Prototype table {
-        padding: 0;
-    .CFunction .Prototype {
-        background-color: #F4F4F4; border-color: #D0D0D0 }
-    .CProperty .Prototype {
-        background-color: #F4F4FF; border-color: #C0C0E8 }
-    .CVariable .Prototype {
-        background-color: #FFFFF0; border-color: #E0E0A0 }
-    .CClass .Prototype {
-        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0A0;
-    .CInterface .Prototype {
-        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0D0;
-    .CDatabaseIndex .Prototype,
-    .CConstant .Prototype {
-        background-color: #D0D0D0; border-color: #000000 }
-    .CType .Prototype,
-    .CEnumeration .Prototype {
-        background-color: #FAF0F0; border-color: #E0B0B0;
-    .CDatabaseTrigger .Prototype,
-    .CEvent .Prototype,
-    .CDelegate .Prototype {
-        background-color: #F0FCF0; border-color: #B8E4B8 }
-    .CToolTip .Prototype {
-        margin: 0 0 .5em 0;
-        white-space: nowrap;
-.Summary {
-    margin: 1.5em 5ex 0 5ex }
-    .STitle {
-        margin-bottom: .5em }
-    .SBorder {
-        padding: 15px;
-        border: 1px solid #C0C060 }
-    /* In a frame IE 6 will make them too long unless you set the width to 100%.  Without frames it will be correct without a width
-        or slightly too long (but not enough to scroll) with a width.  This arbitrary weirdness simply astounds me.  IE 7 has the same
-        problem with frames, haven't tested it without.  */
-    .FramedContentPage .IE .SBorder {
-        width: 100% }
-    .Firefox .SBorder {
-        -moz-border-radius: 20px }
-    .STable {
-        font-size: 9pt; width: 100% }
-    .SEntry {
-        width: 30% }
-    .SDescription {
-        width: 70% }
-    .SMarked {
-        background-color: #F8F8D8 }
-    .SDescription { padding-left: 2ex }
-    .SIndent1 .SEntry { padding-left: 1.5ex }   .SIndent1 .SDescription { padding-left: 3.5ex }
-    .SIndent2 .SEntry { padding-left: 3.0ex }   .SIndent2 .SDescription { padding-left: 5.0ex }
-    .SIndent3 .SEntry { padding-left: 4.5ex }   .SIndent3 .SDescription { padding-left: 6.5ex }
-    .SIndent4 .SEntry { padding-left: 6.0ex }   .SIndent4 .SDescription { padding-left: 8.0ex }
-    .SIndent5 .SEntry { padding-left: 7.5ex }   .SIndent5 .SDescription { padding-left: 9.5ex }
-    .SDescription a { color: #800000}
-    .SDescription a:active { color: #A00000 }
-    .SGroup td {
-        padding-top: .5em; padding-bottom: .25em }
-    .SGroup .SEntry {
-        font-weight: bold; font-variant: small-caps }
-    .SGroup .SEntry a { color: #800000 }
-    .SGroup .SEntry a:active { color: #F00000 }
-    .SMain td,
-    .SClass td,
-    .SDatabase td,
-    .SDatabaseTable td,
-    .SSection td {
-        font-size: 10pt;
-        padding-bottom: .25em }
-    .SClass td,
-    .SDatabase td,
-    .SSection td {
-        padding-top: 1em }
-    .SMain .SEntry,
-    .SClass .SEntry,
-    .SDatabase .SEntry,
-    .SDatabaseTable .SEntry,
-    .SSection .SEntry {
-    .SMain .SEntry a,
-    .SClass .SEntry a,
-    .SDatabase .SEntry a,
-    .SDatabaseTable .SEntry a,
-    .SSection .SEntry a { color: #000000 }
-    .SMain .SEntry a:active,
-    .SClass .SEntry a:active,
-    .SDatabase .SEntry a:active,
-    .SDatabaseTable .SEntry a:active,
-    .SSection .SEntry a:active { color: #A00000 }
-.ClassHierarchy {
-    margin: 0 15px 1em 15px }
-    .CHEntry {
-        margin-bottom: 3px;
-        padding: 2px 2ex;
-        font-size: 10pt;
-        background-color: #F4F4F4; color: #606060;
-    .Firefox .CHEntry {
-        -moz-border-radius: 4px;
-    .CHCurrent .CHEntry {
-        color: #000000;
-    .CHChildNote .CHEntry {
-        font-size: 8pt;
-    .CHIndent {
-        margin-left: 3ex;
-    .CHEntry a:link,
-    .CHEntry a:visited,
-    .CHEntry a:hover {
-        color: #606060;
-    .CHEntry a:active {
-        color: #800000;
-#Index {
-/*  As opposed to .PopupSearchResultsPage #Index  */
-.IndexPage #Index,
-.FramedIndexPage #Index,
-.FramedSearchResultsPage #Index {
-    padding: 15px;
-.IndexPage #Index {
-    font-size: 9pt;  /* To make 27ex match the menu's 27ex. */
-    .IPageTitle {
-        font-size: 20pt; font-weight: bold;
-        border-width: 0 0 3px 0; border-color: #000000; border-style: solid;
-        margin: -15px -15px 0 -15px }
-    .FramedSearchResultsPage .IPageTitle {
-        margin-bottom: 15px;
-    .INavigationBar {
-        font-size: 10pt;
-        padding: 5px;
-        border-bottom: solid 1px black;
-        margin: 0 -15px 15px -15px;
-    .INavigationBar a {
-        font-weight: bold }
-    .IHeading {
-        padding: 2.5em 0 .5em 0;
-        width: 3.5ex;
-    #IFirstHeading {
-        padding-top: 0;
-    .IEntry {
-        font-size: 10pt;
-        padding-left: 1ex;
-    .PopupSearchResultsPage .IEntry {
-        font-size: 8pt;
-        padding: 1px 5px;
-    .PopupSearchResultsPage .Opera9 .IEntry,
-    .FramedSearchResultsPage .Opera9 .IEntry {
-        text-align: left;
-    .FramedSearchResultsPage .IEntry {
-        padding: 0;
-    .ISubIndex {
-        padding-left: 3ex; padding-bottom: .5em }
-    .PopupSearchResultsPage .ISubIndex {
-        display: none;
-    /*  While it may cause some entries to look like links when they aren't, I found it's much easier to read the
-         index if everything's the same color.  */
-    .ISymbol {
-        font-weight: bold; color: #900000  }
-    .IndexPage .ISymbolPrefix,
-    .FramedIndexPage .ISymbolPrefix {
-        font-size: 10pt;
-        color: #C47C7C;
-        background-color: #F8F8F8;
-        border-right: 3px solid #E0E0E0;
-        border-left: 1px solid #E0E0E0;
-        padding: 0 1px 0 2px;
-    .PopupSearchResultsPage .ISymbolPrefix,
-    .FramedSearchResultsPage .ISymbolPrefix {
-        color: #900000;
-    .PopupSearchResultsPage .ISymbolPrefix {
-        font-size: 8pt;
-    .IndexPage #IFirstSymbolPrefix,
-    .FramedIndexPage #IFirstSymbolPrefix {
-        border-top: 1px solid #E0E0E0;
-    .IndexPage #ILastSymbolPrefix,
-    .FramedIndexPage #ILastSymbolPrefix {
-        border-bottom: 1px solid #E0E0E0;
-    .IndexPage #IOnlySymbolPrefix,
-    .FramedIndexPage #IOnlySymbolPrefix {
-    a.IParent,
-    a.IFile {
-        display: block;
-    .PopupSearchResultsPage .SRStatus {
-        padding: 2px 5px;
-        font-size: 8pt;
-    .FramedSearchResultsPage .SRStatus {
-        font-size: 10pt;
-    .SRResult {
-        display: none;
-#Footer {
-    font-size: 8pt;
-    color: #989898;
-#Footer p {
-    text-indent: 0;
-    margin-bottom: .5em;
-.ContentPage #Footer,
-.IndexPage #Footer {
-    margin: 2px;
-.FramedMenuPage #Footer {
-    margin: 5em 10px 10px 10px;
-    padding-top: 1em;
-    border-top: 1px solid #C8C8C8;
-    #Footer a:link,
-    #Footer a:hover,
-    #Footer a:visited { color: #989898 }
-    #Footer a:active { color: #A00000 }
Copied: branches/kmq_dev/documents/api_js/styles/main.css (from rev 4267, trunk/mapbender/documents/api_js/styles/main.css)
--- branches/kmq_dev/documents/api_js/styles/main.css	                        (rev 0)
@@ -0,0 +1,767 @@
+   IMPORTANT: If you're editing this file in the output directory of one of
+   your projects, your changes will be overwritten the next time you run
+   Natural Docs.  Instead, copy this file to your project directory, make your
+   changes, and you can use it with -s.  Even better would be to make a CSS
+   file in your project directory with only your changes, which you can then
+   use with -s [original style] [your changes].
+   On the other hand, if you're editing this file in the Natural Docs styles
+   directory, the changes will automatically be applied to all your projects
+   that use this style the next time Natural Docs is run on them.
+   This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+   Natural Docs is licensed under the GPL
+body {
+    font: 10pt Verdana, Arial, sans-serif;
+    color: #000000;
+    margin: 0; padding: 0;
+.ContentPage,
+.IndexPage,
+.FramedMenuPage {
+    background-color: #E8E8E8;
+.FramedContentPage,
+.FramedIndexPage,
+.FramedSearchResultsPage,
+.PopupSearchResultsPage {
+    background-color: #FFFFFF;
+a:link,
+a:visited { color: #900000; text-decoration: none }
+a:hover { color: #900000; text-decoration: underline }
+a:active { color: #FF0000; text-decoration: underline }
+td {
+    vertical-align: top }
+img { border: 0;  }
+    Comment out this line to use web-style paragraphs (blank line between
+    paragraphs, no indent) instead of print-style paragraphs (no blank line,
+    indented.)
+p {
+    text-indent: 5ex; margin: 0 }
+/*  Opera doesn't break with just wbr, but will if you add this.  */
+.Opera wbr:after {
+	content: "\00200B";
+/*  Blockquotes are used as containers for things that may need to scroll.  */
+blockquote {
+    padding: 0;
+    margin: 0;
+    overflow: auto;
+.Firefox1 blockquote {
+    padding-bottom: .5em;
+/*  Turn off scrolling when printing.  */
+ at media print {
+    blockquote {
+        overflow: visible;
+    .IE blockquote {
+        width: auto;
+#Menu {
+    font-size: 9pt;
+    padding: 10px 0 0 0;
+.ContentPage #Menu,
+.IndexPage #Menu {
+    position: absolute;
+    top: 0;
+    left: 0;
+    width: 31ex;
+    overflow: hidden;
+.ContentPage .Firefox #Menu,
+.IndexPage .Firefox #Menu {
+    width: 27ex;
+    .MTitle {
+        font-size: 16pt; font-weight: bold; font-variant: small-caps;
+        text-align: center;
+        padding: 5px 10px 15px 10px;
+        border-bottom: 1px dotted #000000;
+        margin-bottom: 15px }
+    .MSubTitle {
+        font-size: 9pt; font-weight: normal; font-variant: normal;
+        margin-top: 1ex; margin-bottom: 5px }
+    .MEntry a:link,
+    .MEntry a:hover,
+    .MEntry a:visited { color: #606060; margin-right: 0 }
+    .MEntry a:active { color: #A00000; margin-right: 0 }
+    .MGroup {
+        font-variant: small-caps; font-weight: bold;
+        margin: 1em 0 1em 10px;
+    .MGroupContent {
+        font-variant: normal; font-weight: normal }
+    .MGroup a:link,
+    .MGroup a:hover,
+    .MGroup a:visited { color: #545454; margin-right: 10px }
+    .MGroup a:active { color: #A00000; margin-right: 10px }
+    .MFile,
+    .MText,
+    .MLink,
+    .MIndex {
+        padding: 1px 17px 2px 10px;
+        margin: .25em 0 .25em 0;
+    .MText {
+        font-size: 8pt; font-style: italic }
+    .MLink {
+        font-style: italic }
+    #MSelected {
+        color: #000000; background-color: #FFFFFF;
+        /*  Replace padding with border.  */
+        padding: 0 10px 0 10px;
+        border-width: 1px 2px 2px 0; border-style: solid; border-color: #000000;
+        margin-right: 5px;
+    /*  Close off the left side when its in a group.  */
+    .MGroup #MSelected {
+        padding-left: 9px; border-left-width: 1px }
+    /*  A treat for Mozilla users.  Blatantly non-standard.  Will be replaced with CSS 3 attributes when finalized/supported.  */
+    .Firefox #MSelected {
+        -moz-border-radius-topright: 10px;
+        -moz-border-radius-bottomright: 10px }
+    .Firefox .MGroup #MSelected {
+        -moz-border-radius-topleft: 10px;
+        -moz-border-radius-bottomleft: 10px }
+    #MSearchPanel {
+        padding: 0px 6px;
+        margin: .25em 0;
+    #MSearchField {
+        font: italic 9pt Verdana, sans-serif;
+        color: #606060;
+        border: none;
+        padding: 2px 4px;
+        width: 100%;
+    /* Only Opera gets it right. */
+    .Firefox #MSearchField,
+    .IE #MSearchField,
+    .Safari #MSearchField {
+        width: 94%;
+    .Opera9 #MSearchField,
+    .Konqueror #MSearchField {
+        width: 97%;
+    .FramedMenuPage .Firefox #MSearchField,
+    .FramedMenuPage .Safari #MSearchField,
+    .FramedMenuPage .Konqueror #MSearchField {
+        width: 98%;
+    /* Firefox doesn't do this right in frames without #MSearchPanel added on.
+        It's presence doesn't hurt anything other browsers. */
+    #MSearchPanel.MSearchPanelInactive:hover #MSearchField {
+        border: 1px solid #C0C0C0;
+        padding: 1px 3px;
+    .MSearchPanelActive #MSearchField {
+        font-style: normal;
+        padding: 1px 3px;
+    #MSearchType {
+        visibility: hidden;
+        font: 8pt Verdana, sans-serif;
+        width: 98%;
+        padding: 0;
+    .MSearchPanelActive #MSearchType,
+    /*  As mentioned above, Firefox doesn't do this right in frames without #MSearchPanel added on. */
+    #MSearchPanel.MSearchPanelInactive:hover #MSearchType,
+    #MSearchType:focus {
+        visibility: visible;
+        color: #606060;
+    #MSearchType option#MSearchEverything {
+        font-weight: bold;
+    .Opera8 .MSearchPanelInactive:hover,
+    .Opera8 .MSearchPanelActive {
+        margin-left: -1px;
+    iframe#MSearchResults {
+        width: 60ex;
+        height: 15em;
+    #MSearchResultsWindow {
+        display: none;
+        left: 0; top: 0;
+        border: 1px solid #000000;
+    #MSearchResultsWindowClose {
+        font-size: 8pt;
+        display: block;
+        padding: 2px 5px;
+    #MSearchResultsWindowClose:link,
+    #MSearchResultsWindowClose:visited {
+        color: #000000;
+        text-decoration: none;
+    #MSearchResultsWindowClose:active,
+    #MSearchResultsWindowClose:hover {
+        color: #800000;
+        background-color: #F4F4F4;
+#Content {
+    padding-bottom: 15px;
+.ContentPage #Content {
+    border-width: 0 0 1px 1px;
+    border-style: solid;
+    border-color: #000000;
+    font-size: 9pt;  /* To make 31ex match the menu's 31ex. */
+    margin-left: 31ex;
+.ContentPage .Firefox #Content {
+    margin-left: 27ex;
+    .CTopic {
+        font-size: 10pt;
+        margin-bottom: 3em;
+    .CTitle {
+        font-size: 12pt; font-weight: bold;
+        border-width: 0 0 1px 0; border-style: solid; border-color: #A0A0A0;
+        margin: 0 15px .5em 15px }
+    .CGroup .CTitle {
+        font-size: 16pt; font-variant: small-caps;
+        padding-left: 15px; padding-right: 15px;
+        border-width: 0 0 2px 0; border-color: #000000;
+        margin-left: 0; margin-right: 0 }
+    .CClass .CTitle,
+    .CInterface .CTitle,
+    .CDatabase .CTitle,
+    .CDatabaseTable .CTitle,
+    .CSection .CTitle {
+        font-size: 18pt;
+        color: #FFFFFF; background-color: #A0A0A0;
+        padding: 10px 15px 10px 15px;
+        border-width: 2px 0; border-color: #000000;
+    #MainTopic .CTitle {
+        font-size: 20pt;
+        color: #FFFFFF; background-color: #7070C0;
+        border-width: 0 0 3px 0; border-color: #000000;
+    .CBody {
+        margin-left: 15px; margin-right: 15px }
+    .CToolTip {
+        position: absolute; visibility: hidden;
+        left: 0; top: 0;
+        background-color: #FFFFE0;
+        padding: 5px;
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #000000;
+        font-size: 8pt;
+    .Opera .CToolTip {
+        max-width: 98%;
+    /*  Scrollbars would be useless.  */
+    .CToolTip blockquote {
+        overflow: hidden;
+    .IE6 .CToolTip blockquote {
+    .CHeading {
+        font-weight: bold; font-size: 10pt;
+        margin: 1.5em 0 .5em 0;
+    .CBody pre {
+        font: 10pt "Courier New", Courier, monospace;
+        margin: 1em 0;
+    .CBody ul {
+        /*  I don't know why CBody's margin doesn't apply, but it's consistent across browsers so whatever.
+             Reapply it here as padding.  */
+        margin: .5em 5ex .5em 5ex;
+    .CDescriptionList {
+        margin: .5em 5ex 0 5ex }
+        .CDLEntry {
+            font: 10pt "Courier New", Courier, monospace; color: #808080;
+            padding-bottom: .25em;
+            white-space: nowrap }
+        .CDLDescription {
+            font-size: 10pt;  /*  For browsers that don't inherit correctly, like Opera 5.  */
+            padding-bottom: .5em; padding-left: 5ex }
+    .CTopic img {
+        display: block;
+        margin: 1em auto;
+    .CImageCaption {
+        font-size: 8pt;
+        color: #808080;
+        position: relative;
+        top: 1em;
+    .CImageLink {
+        color: #808080;
+        font-style: italic;
+    a.CImageLink:link,
+    a.CImageLink:visited,
+    a.CImageLink:hover { color: #808080 }
+.Prototype {
+    padding: 5px 3ex;
+    border-width: 1px; border-style: solid;
+    margin: 0 5ex 1.5em 5ex;
+    .Prototype td {
+        font-size: 10pt;
+    .PDefaultValue,
+    .PDefaultValuePrefix,
+    .PTypePrefix {
+        color: #8F8F8F;
+    .PTypePrefix {
+        text-align: right;
+    .PAfterParameters {
+        vertical-align: bottom;
+    .IE .Prototype table {
+        padding: 0;
+    .CFunction .Prototype {
+        background-color: #F4F4F4; border-color: #D0D0D0 }
+    .CProperty .Prototype {
+        background-color: #F4F4FF; border-color: #C0C0E8 }
+    .CVariable .Prototype {
+        background-color: #FFFFF0; border-color: #E0E0A0 }
+    .CClass .Prototype {
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0A0;
+    .CInterface .Prototype {
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0D0;
+    .CDatabaseIndex .Prototype,
+    .CConstant .Prototype {
+        background-color: #D0D0D0; border-color: #000000 }
+    .CType .Prototype,
+    .CEnumeration .Prototype {
+        background-color: #FAF0F0; border-color: #E0B0B0;
+    .CDatabaseTrigger .Prototype,
+    .CEvent .Prototype,
+    .CDelegate .Prototype {
+        background-color: #F0FCF0; border-color: #B8E4B8 }
+    .CToolTip .Prototype {
+        margin: 0 0 .5em 0;
+        white-space: nowrap;
+.Summary {
+    margin: 1.5em 5ex 0 5ex }
+    .STitle {
+        margin-bottom: .5em }
+    .SBorder {
+        padding: 15px;
+        border: 1px solid #C0C060 }
+    /* In a frame IE 6 will make them too long unless you set the width to 100%.  Without frames it will be correct without a width
+        or slightly too long (but not enough to scroll) with a width.  This arbitrary weirdness simply astounds me.  IE 7 has the same
+        problem with frames, haven't tested it without.  */
+    .FramedContentPage .IE .SBorder {
+        width: 100% }
+    .Firefox .SBorder {
+        -moz-border-radius: 20px }
+    .STable {
+        font-size: 9pt; width: 100% }
+    .SEntry {
+        width: 30% }
+    .SDescription {
+        width: 70% }
+    .SMarked {
+        background-color: #F8F8D8 }
+    .SDescription { padding-left: 2ex }
+    .SIndent1 .SEntry { padding-left: 1.5ex }   .SIndent1 .SDescription { padding-left: 3.5ex }
+    .SIndent2 .SEntry { padding-left: 3.0ex }   .SIndent2 .SDescription { padding-left: 5.0ex }
+    .SIndent3 .SEntry { padding-left: 4.5ex }   .SIndent3 .SDescription { padding-left: 6.5ex }
+    .SIndent4 .SEntry { padding-left: 6.0ex }   .SIndent4 .SDescription { padding-left: 8.0ex }
+    .SIndent5 .SEntry { padding-left: 7.5ex }   .SIndent5 .SDescription { padding-left: 9.5ex }
+    .SDescription a { color: #800000}
+    .SDescription a:active { color: #A00000 }
+    .SGroup td {
+        padding-top: .5em; padding-bottom: .25em }
+    .SGroup .SEntry {
+        font-weight: bold; font-variant: small-caps }
+    .SGroup .SEntry a { color: #800000 }
+    .SGroup .SEntry a:active { color: #F00000 }
+    .SMain td,
+    .SClass td,
+    .SDatabase td,
+    .SDatabaseTable td,
+    .SSection td {
+        font-size: 10pt;
+        padding-bottom: .25em }
+    .SClass td,
+    .SDatabase td,
+    .SSection td {
+        padding-top: 1em }
+    .SMain .SEntry,
+    .SClass .SEntry,
+    .SDatabase .SEntry,
+    .SDatabaseTable .SEntry,
+    .SSection .SEntry {
+    .SMain .SEntry a,
+    .SClass .SEntry a,
+    .SDatabase .SEntry a,
+    .SDatabaseTable .SEntry a,
+    .SSection .SEntry a { color: #000000 }
+    .SMain .SEntry a:active,
+    .SClass .SEntry a:active,
+    .SDatabase .SEntry a:active,
+    .SDatabaseTable .SEntry a:active,
+    .SSection .SEntry a:active { color: #A00000 }
+.ClassHierarchy {
+    margin: 0 15px 1em 15px }
+    .CHEntry {
+        margin-bottom: 3px;
+        padding: 2px 2ex;
+        font-size: 10pt;
+        background-color: #F4F4F4; color: #606060;
+    .Firefox .CHEntry {
+        -moz-border-radius: 4px;
+    .CHCurrent .CHEntry {
+        color: #000000;
+    .CHChildNote .CHEntry {
+        font-size: 8pt;
+    .CHIndent {
+        margin-left: 3ex;
+    .CHEntry a:link,
+    .CHEntry a:visited,
+    .CHEntry a:hover {
+        color: #606060;
+    .CHEntry a:active {
+        color: #800000;
+#Index {
+/*  As opposed to .PopupSearchResultsPage #Index  */
+.IndexPage #Index,
+.FramedIndexPage #Index,
+.FramedSearchResultsPage #Index {
+    padding: 15px;
+.IndexPage #Index {
+    font-size: 9pt;  /* To make 27ex match the menu's 27ex. */
+    .IPageTitle {
+        font-size: 20pt; font-weight: bold;
+        border-width: 0 0 3px 0; border-color: #000000; border-style: solid;
+        margin: -15px -15px 0 -15px }
+    .FramedSearchResultsPage .IPageTitle {
+        margin-bottom: 15px;
+    .INavigationBar {
+        font-size: 10pt;
+        padding: 5px;
+        border-bottom: solid 1px black;
+        margin: 0 -15px 15px -15px;
+    .INavigationBar a {
+        font-weight: bold }
+    .IHeading {
+        padding: 2.5em 0 .5em 0;
+        width: 3.5ex;
+    #IFirstHeading {
+        padding-top: 0;
+    .IEntry {
+        font-size: 10pt;
+        padding-left: 1ex;
+    .PopupSearchResultsPage .IEntry {
+        font-size: 8pt;
+        padding: 1px 5px;
+    .PopupSearchResultsPage .Opera9 .IEntry,
+    .FramedSearchResultsPage .Opera9 .IEntry {
+        text-align: left;
+    .FramedSearchResultsPage .IEntry {
+        padding: 0;
+    .ISubIndex {
+        padding-left: 3ex; padding-bottom: .5em }
+    .PopupSearchResultsPage .ISubIndex {
+        display: none;
+    /*  While it may cause some entries to look like links when they aren't, I found it's much easier to read the
+         index if everything's the same color.  */
+    .ISymbol {
+        font-weight: bold; color: #900000  }
+    .IndexPage .ISymbolPrefix,
+    .FramedIndexPage .ISymbolPrefix {
+        font-size: 10pt;
+        color: #C47C7C;
+        background-color: #F8F8F8;
+        border-right: 3px solid #E0E0E0;
+        border-left: 1px solid #E0E0E0;
+        padding: 0 1px 0 2px;
+    .PopupSearchResultsPage .ISymbolPrefix,
+    .FramedSearchResultsPage .ISymbolPrefix {
+        color: #900000;
+    .PopupSearchResultsPage .ISymbolPrefix {
+        font-size: 8pt;
+    .IndexPage #IFirstSymbolPrefix,
+    .FramedIndexPage #IFirstSymbolPrefix {
+        border-top: 1px solid #E0E0E0;
+    .IndexPage #ILastSymbolPrefix,
+    .FramedIndexPage #ILastSymbolPrefix {
+        border-bottom: 1px solid #E0E0E0;
+    .IndexPage #IOnlySymbolPrefix,
+    .FramedIndexPage #IOnlySymbolPrefix {
+    a.IParent,
+    a.IFile {
+        display: block;
+    .PopupSearchResultsPage .SRStatus {
+        padding: 2px 5px;
+        font-size: 8pt;
+    .FramedSearchResultsPage .SRStatus {
+        font-size: 10pt;
+    .SRResult {
+        display: none;
+#Footer {
+    font-size: 8pt;
+    color: #989898;
+#Footer p {
+    text-indent: 0;
+    margin-bottom: .5em;
+.ContentPage #Footer,
+.IndexPage #Footer {
+    margin: 2px;
+.FramedMenuPage #Footer {
+    margin: 5em 10px 10px 10px;
+    padding-top: 1em;
+    border-top: 1px solid #C8C8C8;
+    #Footer a:link,
+    #Footer a:hover,
+    #Footer a:visited { color: #989898 }
+    #Footer a:active { color: #A00000 }
Modified: branches/kmq_dev/http/classes/class_element.php
--- branches/kmq_dev/http/classes/class_element.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_element.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -58,7 +58,7 @@
 				"e_content, e_closetag, e_js_file, e_mb_mod, e_target, " .
 				"e_requires, e_url FROM gui_element WHERE e_id = $2 AND " .
 				"fkey_gui_id = $3 LIMIT 1";
-		$v = array ($_SESSION["mb_lang"], $id, $applicationId);
+		$v = array (Mapbender::session()->get("mb_lang"), $id, $applicationId);
 		$t = array ("s", "s", "s");
 		$res = db_prep_query($sql, $v, $t);
 		$row = db_fetch_array($res);
Modified: branches/kmq_dev/http/classes/class_gui.php
--- branches/kmq_dev/http/classes/class_gui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_gui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -246,7 +246,7 @@
 			else {
 				// users of original gui are not copied, the current user is set as owner
 				array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')");
-				array_push($v, array($newGuiName, $_SESSION["mb_user_id"]));
+				array_push($v, array($newGuiName, Mapbender::session()->get("mb_user_id")));
 				array_push($t, array('s', 'i'));
 			array_push($sql, "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT $1, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = $2;");
Modified: branches/kmq_dev/http/classes/class_kml_ows.php
--- branches/kmq_dev/http/classes/class_kml_ows.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_kml_ows.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -430,7 +430,7 @@
 	 * @return boolean true, if the KML could be stored in the database; else false.
 	private function storeInDb () {
-		if ($_SESSION["mb_user_id"] && $_SESSION["mb_user_gui"]) {
+		if (Mapbender::session()->get("mb_user_id") && Mapbender::session()->get("mb_user_gui")) {
 			$con = db_connect(DBSERVER,OWNER,PW);
 			db_select_db(DB,$con);
@@ -438,7 +438,7 @@
 			$sql .= "(fkey_mb_user_id, fkey_gui_id, kml_doc, kml_name, kml_description, kml_timestamp) ";
 			$sql .= "VALUES ";
 			$sql .= "($1, $2, $3, $4, $5, $6)";
-			$v = array ($_SESSION["mb_user_id"], $_SESSION["mb_user_gui"], $this->kml, "name", "description", time());
+			$v = array (Mapbender::session()->get("mb_user_id"), Mapbender::session()->get("mb_user_gui"), $this->kml, "name", "description", time());
 			$t = array ("i", "s", "s", "s", "s", "s");
 			if (!$res) {
@@ -466,7 +466,7 @@
 # for now, do not restrict access
 #		$sql = "SELECT kml_doc FROM gui_kml WHERE kml_id = $1 AND fkey_mb_user_id = $2 AND fkey_gui_id = $3 LIMIT 1";
-#		$v = array($kmlId, $_SESSION["mb_user_id"], $_SESSION["mb_user_gui"]);
+#		$v = array($kmlId, Mapbender::session()->get("mb_user_id"), Mapbender::session()->get("mb_user_gui"));
 #		$t = array("i", "i", "s");
 		$sql = "SELECT kml_doc FROM gui_kml WHERE kml_id = $1 LIMIT 1";
Modified: branches/kmq_dev/http/classes/class_locale.php
--- branches/kmq_dev/http/classes/class_locale.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_locale.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -104,8 +104,8 @@
 				if ($selectedLocale) {
 					$this->name = $selectedLocale;
-					$_SESSION["mb_lang"] = $languageId;
-					$_SESSION["mb_locale"] = $this->name;
+					Mapbender::session()->set("mb_lang",$languageId);
+					Mapbender::session()->set("mb_locale",$this->name);
 					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
 					// from http://de3.php.net/manual/de/function.gettext.php
Modified: branches/kmq_dev/http/classes/class_log.php
--- branches/kmq_dev/http/classes/class_log.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_log.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -50,13 +50,13 @@
 					for($i = 0; $i < count($this->url); $i++){
 						$content = strtotime("now")." ";
 						$content .= "[".date("d/M/Y:H:i:s O")."]";
-						$content .= " " . $_SESSION["mb_user_ip"];
+						$content .= " " . Mapbender::session()->get("mb_user_ip");
 						$content .= ' "';
 						if($this->log_username == true){
-							$content .= $_SESSION["mb_user_name"];
+							$content .= Mapbender::session()->get("mb_user_name");
 						$content .= '"';
-						$content .= " " . $_SESSION["mb_user_id"];
+						$content .= " " . Mapbender::session()->get("mb_user_id");
 						$content .= " " . $module;
 						$content .= ' "' . $this->url[$i] . '"';
 						$content .= chr(13).chr(10);
@@ -80,7 +80,7 @@
 				$sql .= "gui, module, ip, username, userid, request";
 				$sql .= ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10)";
-				$v = array($time_client, strtotime("now"), "[".date("d/M/Y:H:i:s O")."]", SID, $_SESSION["mb_user_gui"], $module, $_SESSION["mb_user_ip"], $_SESSION["mb_user_name"], $_SESSION["mb_user_id"], $this->url[$i]);
+				$v = array($time_client, strtotime("now"), "[".date("d/M/Y:H:i:s O")."]", SID, Mapbender::session()->get("mb_user_gui"), $module, Mapbender::session()->get("mb_user_ip"), Mapbender::session()->get("mb_user_name"), Mapbender::session()->get("mb_user_id"), $this->url[$i]);
 				$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
 				$res = db_prep_query($sql, $v, $t)or die(db_error());
Modified: branches/kmq_dev/http/classes/class_wfsToDb.php
--- branches/kmq_dev/http/classes/class_wfsToDb.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wfsToDb.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -65,7 +65,7 @@
 			$aWfs->transaction,
 			$aWfs->fees,
 			$aWfs->accessconstraints,
-			$_SESSION["mb_user_id"],
+			Mapbender::session()->get("mb_user_id"),
 			strtotime("now")
Modified: branches/kmq_dev/http/classes/class_wfs_conf.php
--- branches/kmq_dev/http/classes/class_wfs_conf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wfs_conf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -64,8 +64,8 @@
 				// If a user ID is given, remove the ones the user has no access to
-				if ($_SESSION["mb_user_id"]) {
-					$user = new User($_SESSION["mb_user_id"]);
+				if (Mapbender::session()->get("mb_user_id")) {
+					$user = new User(Mapbender::session()->get("mb_user_id"));
 					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
Modified: branches/kmq_dev/http/classes/class_wfs_configuration.php
--- branches/kmq_dev/http/classes/class_wfs_configuration.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wfs_configuration.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -27,6 +27,7 @@
  * to a configuration of a WFS featuretype.
 class WfsConfigurationElement {
+	var $id;
 	var $name;
 	var $type;
 	var $search;
@@ -43,7 +44,9 @@
 	var $authVarname;
 	var $detailPos;
 	var $operator;
-	var $showDetail;
+	var $showDetail;
+	var $helptext;
+	var $category;
 	 * Creates a WFS featuretype element configuration from an object.
@@ -59,22 +62,22 @@
 		$element->type = $obj->type;
 		$element->search = intval($obj->search);
 		$element->pos = intval($obj->pos);
-		$element->styleId = $obj->styleid;
-		$element->toUpper = intval($obj->toupper);
+		$element->styleId = $obj->styleId;
+		$element->toUpper = intval($obj->toUpper);
 		$element->edit = intval($obj->edit);
 		$element->label = $obj->label;
-		$element->labelId = $obj->labelid;
+		$element->labelId = $obj->labelId;
 		$element->geom = intval($obj->geom);
 		$element->show = intval($obj->show);
 		$element->mandatory = intval($obj->mandatory);
 		$element->respos = intval($obj->respos);
-		$element->minInput = intval($obj->mininput);
+		$element->minInput = intval($obj->minInput);
 //		$element->formElementHtmlTemplate = $row["f_html_template"];
-		$element->formElementHtml = $obj->formelementhtml;
-		$element->authVarname = $obj->authvarname;
-		$element->detailPos = intval($obj->respos);
+		$element->formElementHtml = $obj->formElementHtml;
+		$element->authVarname = $obj->authVarname;
+		$element->detailPos = intval($obj->detailPos);
 		$element->operator = $obj->operator;
-		$element->showDetail = intval($obj->showdetail);
+		$element->showDetail = intval($obj->showDetail);
 		$element->helptext = $obj->helptext;
 		$element->category = $obj->category;
 		return $element;
@@ -94,11 +97,11 @@
 			$el->styleId, $el->toUpper,	$el->label,	$el->labelId,
 			$el->show, $el->respos, $el->formElementHtml, $el->edit,
 			$el->mandatory,	$el->authVarname, $el->operator,
-			$el->showDetail, $el->minInput, $el->helptext, $el->category
+			$el->showDetail, $el->detailPos, $el->minInput, $el->helptext, $el->category
 		$t = array(
 			"i", "i", "i", "i", "i", "s", "i", "s", "s", "i",
-			"i", "s", "i", "i", "s", "s", "i", "i", "s", "s"
+			"i", "s", "i", "i", "s", "s", "i", "i", "i", "s", "s"
@@ -114,18 +117,18 @@
 	 * @return Boolean true if succeeded; else false
 	 * @param $el WfsConfigurationElement
-	public static function updateInDb ($el) {
+	public static function updateInDb ($wfsConfId, $el) {
 		$sql = file_get_contents("../../sql/update_wfs_conf_element.sql");
 		$v = array(
 			$el->geom, $el->search, $el->pos, $el->styleId, $el->toUpper,
 			$el->label,	$el->labelId, $el->show, $el->respos,
 			$el->formElementHtml, $el->edit, $el->mandatory,
-			$el->authVarname, $el->operator, $el->showDetail,
-			$el->minInput, $el->helptext, $el->category, $el->id
+			$el->authVarname, $el->operator, $el->showDetail, $el->detailPos,
+			$el->minInput, $el->helptext, $el->category, $el->id, $wfsConfId
 		$t = array(
 			"i", "i", "i", "s", "i", "s", "s", "i", "i",
-			"s", "i", "i", "s", "s", "i", "i", "s", "s", "i"
+			"s", "i", "i", "s", "s", "i", "i", "i", "s", "s", "i", "i"
@@ -204,8 +207,8 @@
 	 * @return Boolean
 	private function accessAllowed () {
 			$allowedWfsConfIds = $user->getWfsConfByWfsOwner();
@@ -215,7 +218,7 @@
 				return true;
-		$e = new mb_exception("User '" . $_SESSION["mb_user_id"] . "' is not allowed to access Wfs conf " . $this->id . ".");
+		$e = new mb_exception("User '" . Mapbender::session()->get("mb_user_id") . "' is not allowed to access Wfs conf " . $this->id . ".");
 		return false;
@@ -246,22 +249,22 @@
 			// TO DO: check if access is allowed!
 			// (use the new WFS classes for this)
 			$wfsConf->wfsId = intval($obj->wfsId);
-			$wfsConf->featureTypeId = intval($obj->wfsFeaturetypeId);
+			$wfsConf->featureTypeId = intval($obj->featuretypeId);
 		$wfsConf->type = intval($obj->type);
 		$wfsConf->label = $obj->label;
-		$wfsConf->labelId = $obj->label_id;
+		$wfsConf->labelId = $obj->labelId;
 		$wfsConf->button = $obj->button;
-		$wfsConf->buttonId = $obj->button_id;
+		$wfsConf->buttonId = $obj->buttonId;
 		$wfsConf->style = $obj->style;
 		$wfsConf->buffer = floatval($obj->buffer);
-		$wfsConf->resStyle = $obj->result_style;
-		$wfsConf->abstr = $obj->title;
+		$wfsConf->resStyle = $obj->resStyle;
+		$wfsConf->abstr = $obj->abstr;
 		$wfsConf->description = $obj->description;
-		for ($i = 0; $i < count($obj->elements); $i++) {
-			$element = WfsConfigurationElement::createFromObject($obj->elements[$i]);
+		for ($i = 0; $i < count($obj->elementArray); $i++) {
+			$element = WfsConfigurationElement::createFromObject($obj->elementArray[$i]);
 			$wfsConf->elementArray[]= $element;
 		return $wfsConf;
@@ -301,7 +304,7 @@
 		for ($i = 0; $i < count($wfsConf->elementArray); $i++) {
 			$el = $wfsConf->elementArray[$i];
-			$success = WfsConfigurationElement::updateInDb($el);
+			$success = WfsConfigurationElement::updateInDb($wfsConf->id, $el);
 			if (!$success) {
 				db_rollback();
 				return null;
@@ -414,9 +417,9 @@
 		$wfsConf->buttonId = $row["g_button_id"];
 		$wfsConf->buffer = $row["g_buffer"];
 		$wfsConf->resStyle = $row["g_res_style"];
-		$wfsConf->wfsId = $row["fkey_wfs_id"];
+		$wfsConf->wfsId = intval($row["fkey_wfs_id"]);
 		$wfsConf->type = intval($row["wfs_conf_type"]);
-		$wfsConf->featureTypeId = $row["fkey_featuretype_id"];
+		$wfsConf->featureTypeId = intval($row["fkey_featuretype_id"]);
 		$sql = <<<SQL
 SELECT * FROM wfs_conf_element JOIN wfs_element
@@ -432,11 +435,12 @@
 		while ($row = db_fetch_array($res)) {
 			$element = new WfsConfigurationElement();
-			$element->id = $row["element_id"];
+			$element->id = intval($row["element_id"]);
 			$element->name = $row["element_name"];
 			$element->type = $row["element_type"];
 			$element->search = intval($row["f_search"]);
 			$element->pos = intval($row["f_pos"]);
+			$element->edit = intval($row["f_edit"]);
 			$element->styleId = $row["f_style_id"];
 			$element->toUpper = intval($row["f_toupper"]);
 			$element->label = $row["f_label"];
@@ -444,20 +448,21 @@
 			$element->geom = intval($row["f_geom"]);
 			$element->show = intval($row["f_show"]);
 			$element->mandatory = intval($row["f_mandatory"]);
-			$element->respos = $row["f_respos"];
-			$element->minInput = $row["f_min_input"];
-			$element->formElementHtmlTemplate = $row["f_html_template"];
+			$element->respos = intval($row["f_respos"]);
+			$element->minInput = intval($row["f_min_input"]);
+//			$element->formElementHtmlTemplate = $row["f_html_template"];
 			$element->formElementHtml = stripslashes($row["f_form_element_html"]);
 			$element->authVarname = stripslashes($row["f_auth_varname"]);
-			$element->detailPos = $row["f_detailpos"];
+			$element->detailPos = intval($row["f_detailpos"]);
 			$element->operator = $row["f_operator"];
 			$element->showDetail = intval($row["f_show_detail"]);
 			$element->helptext = $row["f_helptext"];
-			$element->category = $row["f_category"];
+			$element->category = $row["f_category_name"];
+		$wfsConf->id = intval($id);
 		return $wfsConf;
Modified: branches/kmq_dev/http/classes/class_wfs_deprecated.php
--- branches/kmq_dev/http/classes/class_wfs_deprecated.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wfs_deprecated.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -273,7 +273,7 @@
 		$this->wfs_abstract, $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc,
 		$this->wfs_upload_url, $this->wfs_describefeaturetype, $this->wfs_getfeature,
 		$this->wfs_transaction, $this->fees, $this->accessconstraints,
-		$_SESSION["mb_user_id"], strtotime("now"));
+		Mapbender::session()->get("mb_user_id"), strtotime("now"));
 	$t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i');
@@ -304,7 +304,7 @@
 	$v = array($this->wfs_version, $this->wfs_name, $this->wfs_title, $this->wfs_abstract,
 		$this->wfs_getcapabilities, $this->wfs_getcapabilities_doc, $this->wfs_upload_url,
 		$this->wfs_describefeaturetype, $this->wfs_getfeature, $this->wfs_transaction,
-		$this->fees, $this->accessconstraints, $_SESSION["mb_user_id"],strtotime("now"),
+		$this->fees, $this->accessconstraints, Mapbender::session()->get("mb_user_id"),strtotime("now"),
 		$this->wfs_id);
 	$t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s' ,'i' ,'i' ,'i');
Modified: branches/kmq_dev/http/classes/class_wmc.php
--- branches/kmq_dev/http/classes/class_wmc.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wmc.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -120,7 +120,7 @@
 	var $wmc_descriptionurl_type;
 	public function __construct () {
-		$this->userId = $_SESSION["mb_user_id"];
+		$this->userId = Mapbender::session()->get("mb_user_id");
 		$this->wmc_id = time();
@@ -252,7 +252,7 @@
 	public static function delete ($wmcId, $userId) {
 		if (!isset($userId) || $userId === null) {
-			$userId = $_SESSION["mb_user_id"];
+			$userId = Mapbender::session()->get("mb_user_id");
 		$sql = "DELETE FROM mb_user_wmc ";
@@ -273,7 +273,7 @@
 	public static function getDocument ($id) {
 		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND fkey_user_id = $2";
-		$v = array($id, $_SESSION["mb_user_id"]);
+		$v = array($id, Mapbender::session()->get("mb_user_id"));
 		$t = array('s', 'i');
 		$res = db_prep_query($sql,$v,$t);
Modified: branches/kmq_dev/http/classes/class_wms.php
--- branches/kmq_dev/http/classes/class_wms.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/classes/class_wms.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1165,7 +1165,7 @@
 			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
 			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
 			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
-			$_SESSION['mb_user_id'],strtotime("now"),
+			Mapbender::session()->get('mb_user_id'),strtotime("now"),
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
 		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
@@ -1501,7 +1501,7 @@
 		$v = array($this->wms_version,$this->wms_getcapabilities,
 			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
-			$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
+			$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,Mapbender::session()->get("mb_user_id"),strtotime("now"),
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
 		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
@@ -2178,7 +2178,7 @@
 	public static function selectMyWmsByApplication ($appId) {
 		// check if user is permitted to access the application
-		$currentUser = new User($_SESSION["mb_user_id"]);
+		$currentUser = new User(Mapbender::session()->get("mb_user_id"));
 		$appArray = $currentUser->getApplicationsByPermission(false);
 		if (!in_array($appId, $appArray)) {
 			$e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
Modified: branches/kmq_dev/http/extensions/ext_weldMaps.php
--- branches/kmq_dev/http/extensions/ext_weldMaps.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/extensions/ext_weldMaps.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -19,8 +19,8 @@
 * extension weldMaps
-* expects an array $_SESSION["mb_print_urls"] containing the mapRequests
-* expects $_SESSION["mb_print_resolution"]
+* expects an array Mapbender::session()->get("mb_print_urls") containing the mapRequests
+* expects Mapbender::session()->get("mb_print_resolution")
 require(dirname(__FILE__)."/../php/mb_validateSession.php");
@@ -114,7 +114,7 @@
 		return $newResolution;
-session_start();
-$map_urls = explode("###",$_SESSION["mb_print_url"]);
-$output = new weldMaps($map_urls, $_SESSION["mb_print_resolution"]);
+$map_urls = explode("###",Mapbender::session()->get("mb_print_url"));
+$output = new weldMaps($map_urls, Mapbender::session()->get("mb_print_resolution"));
Modified: branches/kmq_dev/http/frames/index.php
--- branches/kmq_dev/http/frames/index.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/frames/index.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -18,17 +18,19 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require("../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once("../php/mb_validateSession.php");
 require_once(dirname(__FILE__)."/../classes/class_gui.php");
-$_SESSION["mb_user_gui"] = $gui_id;
+Mapbender::session()->set("mb_user_gui",$gui_id);
 // check if user is allowed to access current GUI;
 // if not, return to login screen
-if (!in_array($gui_id, $_SESSION["mb_user_guis"])) {
-	$e = new mb_exception("mb_validateSession.php: User: " . $_SESSION["mb_user_id"] . " not allowed to access GUI " . $gui_id);
+if (!in_array($gui_id, Mapbender::session()->get("mb_user_guis"))) {
+	$e = new mb_exception("mb_validateSession.php: User: " . Mapbender::session()->get("mb_user_id")  . " not allowed to access GUI " . $gui_id);
 	session_write_close();
 	header("Location: ".LOGIN);
 	die();
Modified: branches/kmq_dev/http/frames/login.php
--- branches/kmq_dev/http/frames/login.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/frames/login.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -7,7 +7,7 @@
 # the Free Software Foundation; either version 2, or (at your option)
 # any later version.
-# This program is distributed in the hope that it will be useful,
+# This program is distributed in the hope that it will be us*/eful,
 # but WITHOUT ANY WARRANTY; without even the implied warranty of
 # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 # GNU General Public License for more details.
@@ -18,6 +18,7 @@
 ob_start();
+require_once(dirname(__FILE__)."/../../lib/class_Mapbender_session.php");
 function auth_user($name,$pw){
 	$setEncPw = false;
@@ -57,14 +58,10 @@
 function setSession(){
 	session_start();
+	session_write_close();
 function killSession(){
-	if (isset($_COOKIE[session_name()])) {
-    	setcookie(session_name(), '', time()-42000, '/');
-	if(session_id()){
-		session_destroy();
+	Mapbender::session()->kill();
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -147,21 +144,22 @@
 		setSession();
 		include(dirname(__FILE__)."/../../conf/session.conf");
-	if($_SESSION["mb_user_id"]){
+	if(Mapbender::session()->get("mb_user_id")){
 		if($row["mb_user_login_count"] <= MAXLOGIN){
 			$sql_del_cnt =  "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_id = $1";
-			$v = array($_SESSION['mb_user_id']);
+			$v = array(Mapbender::session()->get('mb_user_id'));
 			$t = array("i");
 			db_prep_query($sql_del_cnt, $v, $t);
 			require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
 			$arrayGUIs = mb_getGUIs($row["mb_user_id"]);
-			$_SESSION["mb_user_guis"] = $arrayGUIs;
-			$_SESSION["mb_login"] = $login;
+			new mb_notice("login.setSession.mb_user_guis: ".serialize($arrayGUIs)." in session: " .session_id());
+			Mapbender::session()->set("mb_user_guis",$arrayGUIs);
+			Mapbender::session()->set("mb_login",$login);
 			# a gui is explicitly ordered
-			if((isset($_REQUEST["mb_user_myGui"]) || isset($_SESSION["mb_user_myGui"])) && in_array($_REQUEST["mb_user_myGui"], $arrayGUIs)){
+			if((isset($_REQUEST["mb_user_myGui"]) || Mapbender::session()->get("mb_user_myGui")) && in_array($_REQUEST["mb_user_myGui"], $arrayGUIs)){
 				unset($arrayGUIs);
 				if(isset($_REQUEST["mb_user_myGui"])){ $arrayGUIs[0] = $_REQUEST["mb_user_myGui"];}
-				else{ $arrayGUIs[0] = $_SESSION["mb_user_myGui"];}
+				else{ $arrayGUIs[0] = Mapbender::session()->set("mb_user_myGui");}
 			#only one gui is provided
 			if(count($arrayGUIs) == 1){
Modified: branches/kmq_dev/http/html/mod_treefolder2.php
--- branches/kmq_dev/http/html/mod_treefolder2.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/html/mod_treefolder2.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -18,7 +18,7 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$gui_id = $_SESSION["mb_user_gui"];
+$gui_id = Mapbender::session()->get("mb_user_gui");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
 <HTML>
@@ -41,7 +41,7 @@
 <?php
 echo "<script language='JavaScript'>";
    $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
-   $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
+   $v = array($_REQUEST['e_id_css'],Mapbender::session()->get("mb_user_gui"));
    $t = array('s','s');
    $e_target = db_result($res,0,"e_target");
@@ -78,7 +78,7 @@
 <?php
 //load structure
 $sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 AND NOT lft = 1 ORDER BY lft;";
-$v = array($_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_user_gui"));
 $t = array("s");
@@ -417,7 +417,7 @@
 	for (var i=0;i<my.length;i++){
 		if(my[i]["epsg"]==parent.mb_mapObj[j].epsg){
 			parent.mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
-			var arrayExt = parent.mb_mapObj[j].extent.split(",");
+			var arrayExt = parent.mb_mapObj[j].extent.toString().split(",");
 			parent.mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
 			break;
Modified: branches/kmq_dev/http/html/mod_treefolder2_multiple.php
--- branches/kmq_dev/http/html/mod_treefolder2_multiple.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/html/mod_treefolder2_multiple.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -26,7 +26,7 @@
 <HTML>
@@ -49,7 +49,7 @@
 <?php
@@ -98,7 +98,7 @@
 //load structure
 $t = array("s");
@@ -427,7 +427,7 @@
 			break;
Modified: branches/kmq_dev/http/html/mod_treefolderPlain.php
--- branches/kmq_dev/http/html/mod_treefolderPlain.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/html/mod_treefolderPlain.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -55,7 +55,7 @@
 <?php
 //load structure
 $t = array("s");
@@ -382,7 +382,7 @@
 		if(my[i]["epsg"]== mb_mapObj[j].epsg){
-			var arrayExt =  mb_mapObj[j].extent.split(",");
+			var arrayExt =  mb_mapObj[j].extent.toString().split(",");
 			break;
Copied: branches/kmq_dev/http/img/help.png (from rev 4267, trunk/mapbender/http/img/help.png)
(Binary files differ)
Copied: branches/kmq_dev/http/include/dyn_js_object.php (from rev 4267, trunk/mapbender/http/include/dyn_js_object.php)
--- branches/kmq_dev/http/include/dyn_js_object.php	                        (rev 0)
+++ branches/kmq_dev/http/include/dyn_js_object.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,62 @@
+<?php
+# $Id: dyn_js.php 3850 2009-04-03 09:02:12Z christoph $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wfs.php,v 1.15 2006/03/09 13:55:46 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+if (isset($gui_id)) {
+	$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 and var_type='var'";
+	$v = array($e_id, $gui_id);
+	$t = array('s', 's');
+   	$res = db_prep_query($sql, $v, $t);
+	$arrays = array();
+	$varArray = array();
+	while ($row = db_fetch_array($res)) {
+		if (mb_strpos($row["var_name"], "[")) {
+			$arrayname = mb_substr($row["var_name"], 0, mb_strpos($row["var_name"], "["));
+			if (!in_array($arrayname, $arrays)) {
+				$i++;
+				$arrays[$i] = $arrayname;
+				$varArray[]= $arrayname  . ": []";
+		if (is_numeric(stripslashes($row["var_value"]))) {
+			$varArray[]= $row["var_name"].": ".stripslashes($row["var_value"]);
+		elseif (strpos(stripslashes($row["var_value"]), "[") === 0 ||
+				strpos(stripslashes($row["var_value"]), "{") === 0) {
+		else {
+			$varArray[]= $row["var_name"].": '" .
+				str_replace(
+					array('"',"'", "\r", "\n", "\0"),
+					array('\"','\\\'','\r', '\n', '\0'),
+					stripslashes($row["var_value"])
+	echo "$.extend(options, {";
+	echo implode(",\n", $varArray);
+	echo "});";
+else {
+	$e = new mb_exception("Application ID not set while retrieving element vars of module " . $e_id);
\ No newline at end of file
Modified: branches/kmq_dev/http/javascripts/core.php
--- branches/kmq_dev/http/javascripts/core.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/core.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -17,8 +17,29 @@
+header('Content-type: application/x-javascript');
+ * Class: Mapbender
+ * All Mapbender functionality is within this namespace
+ var Mapbender = {
+ 	events: {
+ 	modules: {
+ 	getTimestamp: function () {
+		var d = new Date();
+		var ts = Math.round(Date.parse(d)/1000);
+		return ts;
+<?php
 ob_start();
-header('Content-type: application/x-javascript');
 require_once(dirname(__FILE__) . "/../../lib/event.js");
 require_once(dirname(__FILE__) . "/../../lib/core.js");
Modified: branches/kmq_dev/http/javascripts/geometry.js
--- branches/kmq_dev/http/javascripts/geometry.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/geometry.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1499,8 +1499,8 @@
 	 * @private
  	this.drawGeometry = function(t,g,col){
- 		var mapframeWidth = mb_mapObj[mapObjInd].width;
-		var mapframeHeight = mb_mapObj[mapObjInd].height;
+ 		var mapframeWidth = map.width;
+		var mapframeHeight = map.height;
 		if(t == geomType.point) {
 			var poiIcon = g.e.getElementValueByName("Mapbender:icon");
@@ -1669,13 +1669,16 @@
 	 * @type DivTag
 	var mapframe = aMapframe;
-	var mapObjInd = getMapObjIndexByName(mapframe);
-	if (mb_mapObj[mapObjInd].getDomElement().frameName) {
+	var map = Mapbender.modules[mapframe];
+	if (!map) {
+		new Mb_exception(mapframe + " not found by geometry.js.");
+		return;
+	if (map.getDomElement().frameName) {
 		this.canvasDivTag = new DivTag(aTagName, mapName, aStyle);
 	else {
-		this.canvasDivTag = new DivTag(aTagName, "", aStyle, mb_mapObj[mapObjInd].getDomElement());
+		this.canvasDivTag = new DivTag(aTagName, "", aStyle, map.getDomElement());
 	var that = this;
@@ -1684,7 +1687,7 @@
 	var minWidth = 8;
 	var lineWidth = aLineWidth || 2;
 	var style = aStyle;
-	var canvas = new jsGraphics(aTagName, mb_mapObj[mapObjInd].getDomElement().frameName ? window.frames[mapframe] : window);
+	var canvas = new jsGraphics(aTagName, map.getDomElement().frameName ? window.frames[mapframe] : window);
 	canvas.setStroke(lineWidth);
 	mb_registerPanSubElement(aTagName);
Modified: branches/kmq_dev/http/javascripts/initOpenLayersWms.php
--- branches/kmq_dev/http/javascripts/initOpenLayersWms.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/initOpenLayersWms.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -21,14 +21,14 @@
 require_once(dirname(__FILE__)."/../classes/class_wms.php");
 $sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
 $t = array('s');
 $cnt=0;
 while($row = db_fetch_array($res)){
 	$mywms = new wms();
-	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
+	$mywms->createObjFromDB(Mapbender::session()->get("mb_user_gui"),$row["fkey_wms_id"]);
 	$mywms->createOlObjFromWMS($cnt==0);
 	$cnt++;
Modified: branches/kmq_dev/http/javascripts/map.js
--- branches/kmq_dev/http/javascripts/map.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/map.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,14 +16,81 @@
  * @type Object
 function Extent(minx,miny,maxx,maxy) {
-	this.minx = parseFloat(minx);
-	this.miny = parseFloat(miny);
-	this.maxx = parseFloat(maxx);
-	this.maxy = parseFloat(maxy);
-	this.extentx = this.maxx - this.minx;
-	this.extenty = this.maxy - this.miny;
-	this.centerx = this.minx + this.extentx/2;
-	this.centery = this.miny + this.extenty/2;
+	var that = this;
+	var setMin = function (min) {
+		that.min = min;
+		that.minx = min.x;
+		that.miny = min.y;
+	var setMax = function (max) {
+		that.max = max;
+		that.maxx = max.x;
+		that.maxy = max.y;
+	var setExtent = function (extent) {
+		that.extent = extent;
+		that.extentx = extent.x;
+		that.extenty = extent.y;
+	var setCenter = function (center) {
+		that.center = center;
+		that.centerx = center.x;
+		that.centery = center.y;
+	 * Allows to set the center (one param) or the extent (two params)
+	 * @param {Point} min or center
+	 * @param {Point} max [obsolete if first is center]
+	this.set = function (min, max) {
+		// only one parameter (center)
+		if (typeof max === "undefined") {
+			var newLowerLeft = min.minus(this.extent.dividedBy(2));
+			var newUpperRight = min.plus(this.extent.dividedBy(2));
+			setMin(newLowerLeft);
+			setMax(newUpperRight);
+			setCenter(min);
+		// two parameters (lower left and upper right ( = extent))
+		else {
+			setMin(min);
+			setMax(max);
+			setExtent(max.minus(min));
+			setCenter((min.plus(max)).dividedBy(2));
+	this.toString = function () {
+		return this.min.x + "," + this.min.y + "," + this.max.x + "," + this.max.y;
+	var isPoint = function (param) {
+		if (typeof param === "object" && param.constructor === Point) {
+			return true;
+		return false;
+	if (isPoint(minx) && isPoint(miny) &&
+		typeof maxx === "undefined" &&
+		typeof maxy === "undefined") {
+		// input is "point, point"
+		this.set(minx, miny);
+	else {
+		// input is "coordinate, coordinate, coordinate, coordinate"
+		// deprecated
+		this.set(
+			new Point(parseFloat(minx), parseFloat(miny)),
+			new Point(parseFloat(maxx), parseFloat(maxy))
 	return this;
@@ -72,8 +139,11 @@
+ * @deprecated
 function mb_registerMapObj(frameName, elementName,wms_index,width, height){
-	var newMapObj = new mb_mapObj_const(frameName, elementName, width, height, wms_index);
+	var newMapObj = new Map(frameName, elementName, width, height, wms_index);
 	mb_mapObj.push(newMapObj);
 	return newMapObj;
@@ -144,7 +214,7 @@
 				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
 				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
 				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
+				requestParams += "BBOX="+mb_mapObj[i].extent.toString()+"&";
 				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
 				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
 				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
@@ -167,8 +237,8 @@
 					var vendorSpecificString = eval(mb_vendorSpecific[v]);
 					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
+				if(Mapbender.log && validation){
+					var tmp = eval(Mapbender.log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
 				if(document.getElementById("FeatureInfoRedirect") && validation){
 					newfeatureInfoRequest += requestParams;
@@ -361,7 +431,7 @@
 function mb_repaint(frameName,minx,miny,maxx,maxy){
 	new Mb_warning("The function mb_repaint is deprecated.");
 	var ind = getMapObjIndexByName(frameName);
-	mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+	mb_mapObj[ind].extent = new Extent(minx, miny, maxx, maxy);
 	setMapRequest(frameName);
@@ -375,7 +445,7 @@
- * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
+ * converts the extent of the mapobject so that the maximum	extent will be displayed {@link Map#calculateExtent}
  * use: mb_mapObj.calculateExtent
  * @deprecated
@@ -385,4 +455,4 @@
   var map = getMapObjByName(frameName);
   var extent = new Extent(minx,miny,maxx,maxy);
   map.calculateExtent(extent);
Modified: branches/kmq_dev/http/javascripts/map.php
--- branches/kmq_dev/http/javascripts/map.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/map.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -18,7 +18,10 @@
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$json = new Mapbender_JSON();
 // see http://trac.osgeo.org/mapbender/ticket/79
 ini_set('session.bug_compat_42',0);
 ini_set('session.bug_compat_warn',0);
@@ -28,37 +31,35 @@
 $gui_changed=0;
 $new_wmc=0;
-if (!$_REQUEST["layer_preview"] && isset($_SESSION["mb_user_gui"]) && $_SESSION["mb_user_gui"] != $_REQUEST["gui_id"]) {
+if (!$_REQUEST["layer_preview"] && Mapbender::session()->get("mb_user_gui") && Mapbender::session()->get("mb_user_gui") != $_REQUEST["gui_id"]) {
 	$gui_changed=1;
-if (!isset($_SESSION['mb_wmc']) || ($gui_changed==1) ||	($_REQUEST['layer_preview'] && $_REQUEST['portal_services'])) {
+if (!Mapbender::session()->get('mb_wmc') || ($gui_changed==1) ||	($_REQUEST['layer_preview'] && $_REQUEST['portal_services'])) {
 	$new_wmc=1;
 if (isset($_REQUEST['layer_preview']) && $_REQUEST['layer_preview'] != 0) {
-	$_SESSION['layer_preview'] = $_REQUEST['portal_services'];
+	Mapbender::session()->set('layer_preview',$_REQUEST['portal_services');
 else {
-	$_SESSION['layer_preview'] = 0;
+	Mapbender::session()->set('layer_preview',0);
+Mapbender::session()->set("mb_user_gui", $gui_id);
 ob_start();
 // Define global variables (TODO: move to mapbender object later on)
 echo "var mb_nr = '".session_id()."';";
 echo "var mb_session_name = '".session_name()."';";
-echo "var mb_myLogin = '".$_SESSION["mb_login"]."';";
-echo "var mb_styleID = '".md5($_SESSION["mb_user_name"])."';";
-echo "var mb_myBBOX = '".$_SESSION["mb_myBBOX"]."';";
-echo "var Mapbender = {};";
-echo "Mapbender.locale = '" . $_SESSION["mb_locale"] . "';";
-echo "Mapbender.languageId = '" . $_SESSION["mb_lang"] . "';";
+echo "var mb_myLogin = '".Mapbender::session()->get("mb_login")."';";
+echo "var mb_styleID = '".md5(Mapbender::session()->get("mb_user_name"))."';";
+echo "var mb_myBBOX = '".Mapbender::session()->get("mb_myBBOX")."';";
+echo "Mapbender.locale = '" . Mapbender::session()->get("mb_locale") . "';";
+echo "Mapbender.languageId = '" . Mapbender::session()->get("mb_lang") . "';";
 echo "Mapbender.versionNumber = '" . MB_VERSION_NUMBER . "';";
 echo "Mapbender.versionAppendix = '" . MB_VERSION_APPENDIX . "';";
 echo "Mapbender.releaseDate = new Date(".date("Y",MB_RELEASE_DATE).",".date("n",MB_RELEASE_DATE).",".date("j",MB_RELEASE_DATE).");";
@@ -92,6 +93,23 @@
+// this replaces the old init function
+$(function () {
+	initModules();
+	// creates the map objects (mapframe1, overview...)
+	eventInitMap.trigger();
+	eventBeforeInit.trigger();
+	// initialisation
+	eventInit.trigger();
+	eventAfterInit.trigger();
+<?php
 // Load internal JavaScript libraries
@@ -103,7 +121,9 @@
 						"list.js",
 						"point.js",
 						"style.js",
-						"button.js");
+						"button.js",
+						"backwards_compatibility_to_2.6.js"
 for ($i = 0; $i < count($libFileArray); $i++) {
 	$currentFile = $libPath . $libFileArray[$i];
@@ -148,8 +168,18 @@
 $modulesNotRelyingOnGlobalsArray = explode(",", MODULES_NOT_RELYING_ON_GLOBALS);
+Mapbender.modules = {};
+Mapbender.addModule = function (name, obj) {
+	if (name && !Mapbender.modules[name]) {
+		Mapbender.modules[name] = obj;
+		return true;
+	return false;
+<?php
+$executeJsPluginsArray = array();
-echo "\nMapbender.Modules = {};\n";
 $mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos, " .
 		"e_url, e_left, e_top, e_width, e_height, e_requires FROM gui_element WHERE e_public = 1 AND " .
 		"fkey_gui_id = $1 ORDER BY e_pos";
@@ -160,46 +190,67 @@
 	if($row_js["e_js_file"] != ""){
 		$jsArray = explode(",", $row_js["e_js_file"]);
 		for ($i = 0; $i < count($jsArray); $i++) {
-			$e_id = $row_js["e_id"];
+			$e_id = isset($row_js["e_id"]) ? $row_js["e_id"] : "";
 			$e_src = $row_js["e_src"];
 			$e_require = $row_js["e_requires"];
 			$e_target = explode(",",$row_js["e_target"]);
 			$e_width = intval($row_js["e_width"]);
 			$e_height = intval($row_js["e_height"]);
+			$e_top = intval($row_js["e_top"]);
+			$e_left = intval($row_js["e_left"]);
 			$currentFile = trim($jsArray[$i]);
-			if (file_exists($currentFile)) {
-				echo "Mapbender.Modules." . $e_id . " = {\n";
+			if (!file_exists($currentFile)) {
+				$e = new mb_exception("Javascript not found: " . $currentFile);
+				echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
+				die;
+			if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
+				ob_start();
+				echo "var options = {" .
+					"id:'$e_id'," .
+					"target:" . ($e_target[0] != "" ? $json->encode($e_target) : "[]") . "," .
+					"top:$e_top," .
+					"left:$e_left," .
+					"width:$e_width," .
+					"height:$e_height," .
+					"src:'$e_src'" .
+				include "../include/dyn_js_object.php";
+				echo <<<JS
+$.fn.$e_id = function (options) {
+	return this.each(function () {
+JS;
+				require($currentFile);
+				echo <<<JS
+JS;
+				echo "$('#$e_id').$e_id(options);";
+				$executeJsPluginsArray[] = ob_get_contents();
+				ob_end_clean();
+				echo "Mapbender.modules.$e_id = {};\n";
+			else {
+				echo "Mapbender.modules." . $e_id . " = {\n";
 				echo "id:'".$row_js["e_id"]."',";
 				echo "url:'".$row_js["e_url"]."',";
 				echo "top:'".$row_js["e_top"]."',";
 				echo "left:'".$row_js["e_left"]."',";
 				echo "width:'".$row_js["e_width"]."',";
 				echo "height:'".$row_js["e_height"]."'";
-				if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
-					echo ",\ninit : function () {\n";
-					require($currentFile);
-					echo "}\n";
-					echo "};\n";
-				else {
-					echo "};\n";
+				echo "};\n";
-			else {
-				$e = new mb_exception("Javascript not found: " . $currentFile);
-				echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
-				die;
-eventBeforeInit.register(function () {
-	for (var module in Mapbender.Modules) {
-		var initFunction = Mapbender.Modules[module].init;
-		if (typeof(initFunction) == "function") {
-			Mapbender.Modules[module].init();
+echo "function initModules () {";
+echo implode("\n", $executeJsPluginsArray);
+echo "}\n";
Modified: branches/kmq_dev/http/javascripts/map_obj.js
--- branches/kmq_dev/http/javascripts/map_obj.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/map_obj.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -3,25 +3,56 @@
 * COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
 * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-var mb_mapObj = [];
-function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+ * Package: Map
+ * Description:
+ * This is the central module for displaying the composite map overlay.
+ * Help:
+ * http://www.mapbender.org/Mapframe
+ * Constructor: Map
+ * Parameters:
+ * frameName		- *[deprecated]* the name of the iframe, for backwards
+ * 						compatibility only, use "" for maps in DIVs
+ * elementName		- the ID of the DOM node
+ * width			- width of the map in pixel
+ * height			- height of the map in pixel
+ * wms_index		- restrict the WMS in the map to the WMS with this ID
+ * 						(useful for overview maps)
+Mapbender.Map = function (frameName, elementName, width, height, wms_index) {
+	 * Method: setExtent
+	 * Description:
 	 * set the extent of the wms
+	 * Parameters:
+	 * minx		- x of south west
+	 * miny		- y of south west
+	 * maxx		- x of north east
+	 * maxy		- y of north east
 	this.setExtent = function(minx, miny, maxx, maxy){
 		this.extent = String(minx) + "," + String(miny) + "," + String(maxx) + "," + String(maxy);
 	this.restrictedExtent = function (extent) {
 		this.restrictedExtent = extent;
 	 * get the width of the mapObj
-	 * @member mb_mapObj_const
+	 * @member Map
 	 * @return width of the mapObj
 	 * @type integer
@@ -48,7 +79,7 @@
 	 * get the height of the mapObj
+	 * @member Map
 	 * @type integer
@@ -160,9 +191,10 @@
 		this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
 		return ext;
+	// private
 	this.width = width;
+	// private
 	this.height = height;
 	this.frameName = frameName;
 	this.type = (frameName !== "") ? "IFRAME" : "DIV";
@@ -173,10 +205,10 @@
 	this.geom = "";
 	this.gml = "";
 	this.wms = [];
 	// Add pointers to WMS objects which are in this map.
-	// If wms_index is set (=map is overview), only this
+	// If wms_index is set (=map is overview), only this
 	// WMS is being pointed to.
 	var index = 0;
@@ -242,7 +274,6 @@
 	var wmsExtent = new Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
 	this.calculateExtent(wmsExtent);
 	this.mapURL = [];
@@ -255,12 +286,12 @@
 	 * get the extent of the mapObj
+	 * @member Map
 	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
 	 * @type string
 	this.getExtent = function(){
-		return this.extent;
+		return this.extent.toString();
@@ -270,7 +301,7 @@
 	 * @type Object
 	this.getExtentInfos = function(){
-		var c = this.getExtent().split(",");
+		var c = this.extent.toString().split(",");
 		var ext = new Extent(c[0], c[1], c[2], c[3]);
 		return ext;
@@ -319,7 +350,7 @@
 	 * @param {Object} direction
 	this.pan = function (direction) {
-		var arrayBBox = this.extent.split(",");
+		var arrayBBox = this.extent.toString().split(",");
 		var minx = parseFloat(arrayBBox[0]);
 		var miny = parseFloat(arrayBBox[1]);
 		var maxx = parseFloat(arrayBBox[2]);
@@ -370,9 +401,8 @@
 				maxx -= (xtentx * factor);
 				break;
-		this.extent = minx + "," + miny + "," + maxx + "," + maxy;
-		this.restrictedExtent;
+		this.setExtent(minx, miny, maxx, maxy);
+//		this.restrictedExtent;
 		this.setMapRequest();
@@ -393,7 +423,7 @@
 					var newExtent = this.calculateExtent(wmsExtent);
-					this.repaint(new Point(newExtent.minx, newExtent.miny), new Point(newExtent.maxx, newExtent.maxy));
+					this.repaint(newExtent.min, newExtent.max);
 					break;
@@ -460,7 +490,6 @@
@@ -474,7 +503,7 @@
 	this.convertPixelToReal = function (aPoint) {
 		var minX = parseFloat(arrayBBox[0]);
 		var minY = parseFloat(arrayBBox[1]);
 		var maxX = parseFloat(arrayBBox[2]);
@@ -508,7 +537,7 @@
 	 * Convert real world coordinates to pixel coordinates
 	this.convertRealToPixel = function (aPoint) {
@@ -585,7 +614,7 @@
 		url += "&";
 		url += "SRS=" + this.epsg + "&";
-		url += "BBOX=" + this.extent + "&";
+		url += "BBOX=" + this.extent.toString() + "&";
 		url += "WIDTH=" + this.width + "&";
 		url += "HEIGHT=" + this.height + "&";
 		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
@@ -624,7 +653,7 @@
 	 * get all featureInfoRequests
+	 * @member Map
 	 * @param float x the x-value of the click position in pixel
 	 * @param float y the y-value of the click position in pixel
 	 * @return array of all featureInfoRequests of this map object
@@ -659,13 +688,13 @@
 	 * calculation of the mapscale
+	 * @member Map
 	 * @return scale
 	 * @type integer
 	this.getScale = function(){
 		var scale;
-		var bbox = this.extent.split(",");
+		var bbox = this.extent.toString().split(",");
 		var xtenty;
 		if (this.epsg == "EPSG:4326") {
 			var pxLenx = (parseFloat(bbox[2]) - parseFloat(bbox[0])) / this.width;
@@ -723,7 +752,7 @@
 	this.repaintScale = function(x, y, scale){
 		if (x === null && y === null) {
 			x = parseFloat(arrayBBox[0]) +
 			((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
 			2);
@@ -739,7 +768,9 @@
 	this.repaint = function(min, max){
-		this.extent = min.x + "," + min.y + "," + max.x + "," + max.y;
+		if (typeof min !== "undefined" && typeof max !== "undefined") {
+			this.extent = new Extent(min, max);
@@ -755,8 +786,9 @@
 			var newMapRequest = getLayerHtmlCode(ii);
-			if (mb_log) {
-				var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+			if (Mapbender.log) {
 			var myDivId = this.elementName + "_div_" + ii;
 			writeTag(this.frameName, myDivId, newMapRequest);
@@ -775,7 +807,7 @@
 		this.mb_MapFutureObj[cnt].width = this.width;
 		this.mb_MapFutureObj[cnt].height = this.height;
 		this.mb_MapFutureObj[cnt].epsg = this.epsg;
-		this.mb_MapFutureObj[cnt].extent = this.extent;
+		this.mb_MapFutureObj[cnt].extent = this.extent.toString();
 		this.mb_MapFutureObj[cnt].layers = [];
 		for(var i=0; i<this.layers.length;i++){
@@ -873,8 +905,9 @@
 		that.mapURL[ii]= newMapURL;
 		currentWms.mapURL = newMapURL;
-		if (mb_log && currentWms.mapURL) {
-			var tmp = eval(mb_log + "('" +newMapURL + "','" + ts + "')");
+		if (Mapbender.log && currentWms.mapURL) {
 		return newMapRequest;
@@ -1001,13 +1034,20 @@
 		return new Point(clickX, clickY);
+	 * Triggered after the map has been resized
+	this.eventResizeMap = new MapbenderEvent();
 	eventAfterMapObjectConstruction.trigger();
-mb_mapObj_const.prototype.getWfsConfIds = function (wfs_config) {
+Mapbender.Map.prototype.getWfsConfIds = function (wfs_config) {
 	var db_wfs_conf_id = [];
 	var js_wfs_conf_id = [];
 	//search configurations that are selected (and in scale)
 	for (var i=0; i < this.wms.length; i++){
 		for(var ii=0; ii < this.wms[i].objLayer.length; ii++){
@@ -1025,6 +1065,6 @@
 				break;
 	return js_wfs_conf_id;
Modified: branches/kmq_dev/http/javascripts/mapnf.php
--- branches/kmq_dev/http/javascripts/mapnf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mapnf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,27 +16,25 @@
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-(function () {
-<?php
-include(dirname(__FILE__) . "/../include/dyn_js.php");
 	var mapTimeout;
 	var	sum_delta = 0;
 	var lastTimestamp;
 	var lastScrollPosition;
-	var mapObject;
-	eventInitMap.register(function init_mod_map1(){
-		mapObject = mb_registerMapObj('', '<?php echo $e_id; ?>', null,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
+	eventInitMap.register(function () {
+		Mapbender.modules[options.id] = new Mapbender.Map (
+			options.id,
+			options.width,
+			options.height,
+			null
+		mb_mapObj.push(Mapbender.modules[options.id]);
+		var mapObject = Mapbender.modules[options.id];
 		try {
 			if (restrictedExtent !== '') {
 				mapObject.setRestrictedExtent(restrictedExtent);
@@ -94,4 +92,3 @@
Modified: branches/kmq_dev/http/javascripts/mod_addWMS.php
--- branches/kmq_dev/http/javascripts/mod_addWMS.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_addWMS.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_addWMS.php
-# Copyright (C) 2002 CCGIS
@@ -16,17 +16,26 @@
+var mod_addWMS_data = options.requires;
+var mod_addWMS_target1 = options.target[0];
+var mod_addWMS_target2 = options.target[1];
+$(this).click(function () {
+	mod_addWMS();
+}).mouseover(function () {
+	if (options.src) {
+		this.src = options.src.replace(/_off/, "_over");
+}).mouseout(function () {
+		this.src = options.src;
-echo "var mod_addWMS_data = '".$e_require."';";
-echo "var mod_addWMS_target1 = '".trim($e_target[0])."';";
-echo "var mod_addWMS_target2 = '".trim($e_target[1])."';";
 function mod_addWMS(){
    var load = prompt("Capabilities - URL:","");
    if(load){
-      mod_addWMS_load(load);
+      mod_addWMS_load(load);
Modified: branches/kmq_dev/http/javascripts/mod_addWMSfromList.php
--- branches/kmq_dev/http/javascripts/mod_addWMSfromList.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_addWMSfromList.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -74,9 +74,9 @@
 $exists = false;
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
-$logged_gui_id=$_SESSION["mb_user_gui"];
+$logged_user_name=Mapbender::session()->get("mb_user_name");
+$logged_user_id=Mapbender::session()->get("mb_user_id");
+$logged_gui_id=Mapbender::session()->get("mb_user_gui");
 /*get infos from gui_element ********************************************************************************************/
Modified: branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredList.php
--- branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredList.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredList.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -195,15 +195,15 @@
 $cnt_group_name = 0;
 $cnt_gui_table = 0;
 $exists = false;
-######   SQL   #####################################################################################
+#   SQL
-/*get infos from gui_element ********************************************************/
+//get infos from gui_element
-/*get group from logged user  *******************************************************/
+//get group from logged user
 $sql_user_group = "SELECT * FROM mb_user_mb_group WHERE fkey_mb_user_id= $1 ";
 $array_values = array($logged_user_id);
 $array_types = array('s');
@@ -284,9 +284,9 @@
 	$fkey_wms_id[$cnt_gui_wms] = $row["fkey_wms_id"];
 	$cnt_gui_wms++;
-/*get allocated wms from allocated gui  ********************************************************************************************/
+//get allocated wms from allocated gui
-/*get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+//get allocated wms-Abstract and wms-Capabilities from allocated gui
 $sql_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
 $v = $fkey_wms_id;
 $t = array();
@@ -307,7 +307,7 @@
 					$wms_version[$cnt_wms] = $row["wms_version"];
 					$cnt_wms++;
 /*INSERT HTML*/
@@ -369,9 +369,9 @@
 			$cnt_fkey_group_gui_wms++;
-		/*get group gui WMS  ********************************************************************************************/
+		//get group gui WMS
-		/*group: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+		//group - get allocated wms-Abstract and wms-Capabilities from allocated gui
 		if(count($fkey_group_gui_wms_id)>0){
 			$sql_group_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
 			$v = $fkey_group_gui_wms_id;
@@ -397,9 +397,9 @@
-	/*table with allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+	//table with allocated wms-Abstract and wms-Capabilities from allocated gui
 	#if ($show_group_wms > 0)
 	if ($cnt_group_gui_wms > 0){
 		/*get goup name for showing in the table ********************************************************************************************/
@@ -462,7 +462,7 @@
-	/*gui: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+	//gui - get allocated wms-Abstract and wms-Capabilities from allocated gui
 	if(count($fkey_show_gui_wms_id)>0){
 		$sql_show_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_id, wms_version FROM wms WHERE wms_id IN (";
 		$v = $fkey_show_gui_wms_id;
@@ -486,7 +486,7 @@
 			#echo"$gui_wms_title[$cnt_show_gui_wms]";
 			$cnt_show_gui_wms++;
 		#if (isset($cnt_show_gui_wms > 0))
@@ -556,7 +556,7 @@
@@ -580,14 +580,14 @@
 	if ($cnt_show_gui_wms > 0){
-	/*get selected gui name for table caption ********************************************************************************************/
+	//get selected gui name for table caption
 	$sql_gui_table = "SELECT * FROM gui WHERE gui_id = $1";
 	$v = array($show_gui_configured_wms);
 	$t = array("s");
Modified: branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredListDB.php
--- branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredListDB.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_addWMSfromfilteredListDB.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -88,9 +88,9 @@
 $cnt_gui_table = 0;
 $exists = false;
 /*get allocated gui  ********************************************************************************************/
Modified: branches/kmq_dev/http/javascripts/mod_add_vendorspecific.php
--- branches/kmq_dev/http/javascripts/mod_add_vendorspecific.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_add_vendorspecific.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,7 @@
 mb_registerVendorSpecific("mod_vs_init()");
 function mod_vs_init(){
-   var re = "vendorspecific=<?php echo $_SESSION['mb_user_name'] ?>";
+   var re = "vendorspecific=<?php echo Mapbender::session()->get('mb_user_name') ?>";
    return re;
Modified: branches/kmq_dev/http/javascripts/mod_box1.js
--- branches/kmq_dev/http/javascripts/mod_box1.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_box1.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -60,7 +60,7 @@
 function mb_drawBox(left,top,right,bottom){
 	//Look if we have the Box elements
-	mb_boxMapObj = getMapObjByName(mb_isBF);
+	mb_boxMapObj = Mapbender.modules[mb_isBF];
 	var map_el = mb_boxMapObj.getDomElement();
 	if(!map_el.ownerDocument.getElementById(mb_boxMapObj.elementName+"_l_top")){
 		//create Box Elements
Modified: branches/kmq_dev/http/javascripts/mod_changeEPSG.php
--- branches/kmq_dev/http/javascripts/mod_changeEPSG.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_changeEPSG.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,26 +16,16 @@
-require(dirname(__FILE__)."/../php/mb_validateSession.php");
-include(dirname(__FILE__)."/../include/dyn_js.php");
-echo "var myTarget = '".$e_target[0]."';";
-echo "var myId = '".$e_id."';";
+var that = this;
 var exists = false;
 eventAfterMapRequest.register(function () {
 	mod_changeEPSG_setBox();
-eventInit.register(function () {
-//	mod_changeEPSG_init();
 function mod_changeEPSG_setBox(){
-	$("#"+myId+" option").each(function () {
+	$("#"+options.id+" option").each(function () {
 		if (this.value == mb_mapObj[0].epsg) {
 			isEPSG = true;
 			$(this).attr("selected", "selected");
@@ -43,13 +33,13 @@
-$("#"+myId).change(function () {
+$(this).change(function () {
 	var srsArray = [];
 	for (var i = 0; i < mb_mapObj.length; i++) {
 		var currentSrs = {
 			"frameName" : mb_mapObj[i].elementName,
 			"epsg" : mb_mapObj[i].epsg,
-			"extent" : mb_mapObj[i].extent,
+			"extent" : mb_mapObj[i].extent.toString(),
 			"width" : mb_mapObj[i].width,
 			"height" : mb_mapObj[i].height
@@ -57,53 +47,61 @@
 	var req = new Mapbender.Ajax.Request({
-		"method":"changeEpsg",
-		"parameters":{
-			"srs":srsArray,
-			"newSrs": $("#"+myId).get(0).value
-	req.send("../php/mod_changeEPSG_server.php", function (obj, success, message) {
-		if (!success) {
-			new Mb_exception("!!!!!!"+message);
-			return;
-		var newExtent = obj;
-		for(var i = 0; i < newExtent.length; i++) {
-			if(newExtent[i].frameName == myTarget){
-				var ind = getMapObjIndexByName(myTarget);
-				for(var ii = 0; ii < mb_mapObj[ind].mb_MapHistoryObj.length; ii++) {
-					if (mb_mapObj[ind].mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
-						exists = ii;
-						var goback = true;
+		url: "../php/mod_changeEPSG_server.php",
+		method: "changeEpsg",
+		parameters: {
+			srs: srsArray,
+			newSrs: $("#"+options.id).get(0).value
+		callback: function (obj, success, message) {
+			if (!success) {
+				new Mapbender.Exception(message);
+				return;
+			var newExtent = obj;
+			for (var i = 0; i < newExtent.length; i++) {
+				if(newExtent[i].frameName == options.target){
+					var map = Mapbender.modules[options.target];
+					for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
+						if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+							exists = ii;
+							var goback = true;
+					if (goback) {
+						map.epsg = newExtent[i].newSrs;
+						map.extent = map.mb_MapHistoryObj[exists].extent;
+						map.setMapRequest();
+					else{
+						map.extent = new Extent(
+							parseFloat(newExtent[i].minx),
+							parseFloat(newExtent[i].miny),
+							parseFloat(newExtent[i].maxx),
+							parseFloat(newExtent[i].maxy)
-				if (goback) {
-					mb_mapObj[ind].epsg = newExtent[i].newSrs;
-					mb_mapObj[ind].extent = mb_mapObj[ind].mb_MapHistoryObj[exists].extent;
-					setMapRequest(newExtent[i].frameName);
+				else {
+					var map = Mapbender.modules[newExtent[i].frameName];
-				else{
-					mb_mapObj[ind].extent = parseFloat(newExtent[i].minx) + "," + parseFloat(newExtent[i].miny) + "," +
-						parseFloat(newExtent[i].maxx) + "," + parseFloat(newExtent[i].maxy);
-			else {
-				var ind = getMapObjIndexByName(newExtent[i].frameName);
+	req.send();
Modified: branches/kmq_dev/http/javascripts/mod_copyright.php
--- branches/kmq_dev/http/javascripts/mod_copyright.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_copyright.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_copyright.php
@@ -16,18 +16,16 @@
-include '../include/dyn_js.php';
-echo "var mod_copyright_target = '".$e_target[0]."';";
+var mod_copyright_target = options.target;
 try{
-	if (mod_copyright_text){}
+	if (options.mod_copyright_text){}
 catch(e){
-	mod_copyright_text = "mapbender.org"
+	options.mod_copyright_text = "mapbender.org";
+var mod_copyright_text = options.mod_copyright_text;
 var mod_copyright_left = 5;
 var mod_copyright_bottom = 20;
@@ -40,14 +38,13 @@
 	mod_copyright();
 function mod_copyright(){
-	var ind = getMapObjIndexByName(mod_copyright_target);
-	var myMapObj = mb_mapObj[ind];
+	var myMapObj = Mapbender.modules[mod_copyright_target];
 	var str_c = "<div>";
-	str_c += "<img src='../img/transparent.gif' width ='"+mb_mapObj[ind].width+"' height='"+mb_mapObj[ind].height+"'>";
-	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color1+";position:absolute;top:"+(mb_mapObj[ind].height - (mod_copyright_bottom-1))+"px;left:"+mod_copyright_left+"px'>"+mod_copyright_text+"</div>";
-	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color1+";position:absolute;top:"+(mb_mapObj[ind].height - mod_copyright_bottom)+"px;left:"+mod_copyright_left+"px'>"+mod_copyright_text+"</div>";
-	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color2+";position:absolute;top:"+(mb_mapObj[ind].height - mod_copyright_bottom)+"px;left:"+(mod_copyright_left+1)+"px'>"+mod_copyright_text+"</div>";
+	str_c += "<img src='../img/transparent.gif' width ='"+myMapObj.width+"' height='"+myMapObj.height+"'>";
+	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color1+";position:absolute;top:"+(myMapObj.height - (mod_copyright_bottom-1))+"px;left:"+mod_copyright_left+"px'>"+mod_copyright_text+"</div>";
+	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color1+";position:absolute;top:"+(myMapObj.height - mod_copyright_bottom)+"px;left:"+mod_copyright_left+"px'>"+mod_copyright_text+"</div>";
+	str_c += "<div style='font-family:"+mod_copyright_font+";font-size:"+mod_copyright_fontsize+";color:"+mod_copyright_color2+";position:absolute;top:"+(myMapObj.height - mod_copyright_bottom)+"px;left:"+(mod_copyright_left+1)+"px'>"+mod_copyright_text+"</div>";
 	str_c += "</div>";
 	var map_el = myMapObj.getDomElement();
@@ -57,15 +54,11 @@
 		el_top.style.position = "absolute";
 		el_top.style.top = "0px";
 		el_top.style.left = "0px";
-		el_top.style.width = "0px";
-		el_top.style.height = "0px";
 		el_top.style.overflow = "hidden";
-		el_top.style.zIndex = "10";
-		el_top.style.visibility = "hidden";
+		el_top.style.zIndex = "1000";
 		el_top.style.cursor = "crosshair";
-		el_top.style.backgroundColor = "#ff0000";
 		el_top.id = myMapObj.elementName+"_copyright";
 		map_el.appendChild(el_top);
 	writeTag(myMapObj.frameName, myMapObj.elementName+"_copyright", str_c);
Modified: branches/kmq_dev/http/javascripts/mod_digitize_tab.php
--- branches/kmq_dev/http/javascripts/mod_digitize_tab.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_digitize_tab.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -131,9 +131,62 @@
 try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
 try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
+function toggleTabs(tabId) {
+	if(!initialTab) {
+		return;
+	var tabHeaders = wfsWindow.document.getElementsByTagName('a');
+	var tabs       = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < tabHeaders.length; i++) {
+		if(tabHeaders[i].id.indexOf('tabheader') != -1) {
+			tabHeaders[i].className = 'tabheader';
+	for(var i = 0; i < tabs.length; i++) {
+		if(tabs[i].className === 'tabcontent') {
+			tabs[i].style.visibility = 'hidden';
+			tabs[i].style.display    = 'none';
+	wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
+	wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('tab_' + tabId).style.display    = 'block';
+	return false;
+function showHelptext(helptextId) {
+	hideHelptext();
+	wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'block';
+	return false;
+function hideHelptext(helptextId) {
+	if(helptextId) {
+		wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+		wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'none';
+	var helptext = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < helptext.length; i++) {
+		if(helptext[i].className === 'helptext') {
+			helptext[i].style.visibility = 'hidden';
+			helptext[i].style.display    = 'none';
+	return false;
 function getMousePosition(e) {
-	parent.mb_getMousePos(e, mod_digitize_target);
+	parent.mb_getMousePos(e);
 	var currentPos = null;
 	if (mapType == "DIV") {
 		currentPos = new parent.Point(
@@ -998,7 +1051,7 @@
 	var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
 	var width = mapObj.width;
 	var height = mapObj.height;
-	var arrayBBox = mapObj.extent.split(",")
+	var arrayBBox = mapObj.extent.toString().split(",")
@@ -1321,19 +1374,26 @@
 function validBoxEntrySelected(form){
 	var isCorrect = true;
 	var errorMessage = "";
+	var name = "";
 	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
 		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
-			if (parseInt(form.childNodes[i].selectedIndex) == 0) {
-				return {"isCorrect":false, "errorMessage":errorMessage};
+			name += form.childNodes[i].name;
+			if (parseInt(form.childNodes[i].selectedIndex) == 0 && form.childNodes[i].getAttribute("mandatory") == "true") {
+				var msg = name + ": " + msgObj.messageSelectAnOption + "\n"
+				var categ = form.childNodes[i].getAttribute("category");
+				if (typeof(categ) != "undefined") {
+					msg = categ + " => " + msg;
+				return {"isCorrect":false, "errorMessage":msg};
 		else if (form.childNodes[i].hasChildNodes()) {
-			isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
+			var res = validBoxEntrySelected(form.childNodes[i]);
+			errorMessage = res.errorMessage + errorMessage;
+			isCorrect = res.isCorrect;
-	if (!isCorrect) {
-		errorMessage = msgObj.messageSelectAnOption + "\n";
 	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
@@ -1554,8 +1614,9 @@
 	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
-	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
+	onChangeText += "window.opener.buildElementForm(this.value, " + geometryIndex + ");";
 	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+	onChangeText += "$('.hasDatepicker').datepicker();";
 	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
 	str += " onChange=\""+ onChangeText +"\"";
@@ -1577,25 +1638,155 @@
 	str += "</select>\n\t\t</form>\n\t";
-	str += "<div id='elementForm'>\n</div>";
+	var elForm = "";
 	if (defaultIndex != -1) {
-		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
-		wfsWindow.document.write(str);
-		wfsWindow.document.close();
-		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
+		elForm = buildElementForm(defaultIndex, geometryIndex);
+		var headStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
+		headStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
+		headStr += '<style type="text/css">'
+		headStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
+		headStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
+		headStr += 'div.tabcontent { visibility: hidden;display: none;margin: 1px 0 5px 0;padding: 5px;border: 1px solid #666; }';
+		headStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
+		headStr += 'div.helptext p { margin: 0 ; }';
+		headStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
+		headStr += 'a img { vertical-align: middle;border: 0; }';
+		headStr += '</style>';
+		headStr += '</head><body onload="window.opener.toggleTabs(\''+initialTab+'\'); var $dp = $(\'.hasdatepicker\');$dp.datepicker();">';
+		wfsWindow.document.write(headStr);
 	else {
-		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
+		var headStr = "<html><head><style type='text/css'></style></head><body>";
+	str += "<div id='elementForm'>\n" + elForm + "</div>";
+	str += "<script type='text/javascript' src='../extensions/jquery-1.3.2.min.js'><\/script>";
+	str += "<script type='text/javascript' src='../extensions/jquery-ui-1.7.1.w.o.effects.min.js'><\/script>";
+	str += "</body></html>";
+	wfsWindow.document.write(str);
+	wfsWindow.document.close();
+//	toggleTabs(initialTab);
 function setWfsWindowStyle(wfsConfIndex) {
 	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+function prepareSelectBox (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+	if (categoryName) {
+		var patternString = "<select";
+		var pattern = new RegExp(patternString);
+		formElementHtml = formElementHtml.replace(pattern, patternString + " category='" + categoryName + "' ");
+	if (isMandatory) {
+		// set border if mandatory
+		patternString = "<select";
+		pattern = new RegExp(patternString);
+		formElementHtml = formElementHtml.replace(pattern, patternString + " mandatory='true' style='border:1px solid red' ");
+	// set name of select box to elementlabel
+	patternString = "name\s*=\s*\\*'\w+\\*'";
+	if (pattern.test(formElementHtml)) {
+		formElementHtml = formElementHtml.replace(pattern, "name='" + elementLabel + "'");
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<select name='" + elementLabel + "'");
+	// preselect the correct entry of the box
+	patternString = "option( )+value( )*=( )*'"+elementValue+"'";
+	var patternStringForReplace = "option value = '"+elementValue+"'";
+	formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
+	return formElementHtml;
+function prepareDatepicker (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+		var patternString = "<input";
+		patternString = "<input";
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<input name='" + elementLabel + "'");
+	formElementHtml = formElementHtml.replace(pattern, patternString + " value='"+elementValue+"'");
+function prepareTextArea (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+		var patternString = "<textarea";
+		patternString = "<textarea";
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<textarea name='" + elementLabel + "'");
+	patternString = "<\/textarea>";
+	formElementHtml = formElementHtml.replace(pattern, elementValue + patternString);
+// Returns a form with the elements of a selected WFS grouped in tabs
+// (if the original WFS is the selected WFS, the values are set too)
+var initialTab = false;
 // returns a form with the elements of a selected wfs
 // (if the original wfs is the selected wfs, the values are set too)
 function buildElementForm(wfsConfIndex, memberIndex){
@@ -1613,78 +1804,163 @@
 	if (typeof(featureTypeArray["element"]) !== "undefined") {
-		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
 		featureTypeElementArray = featureTypeArray["element"];
-		// 2. add rows to form
-		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
-			var featureTypeElement = featureTypeElementArray[i];
-			var elementName = featureTypeElement['element_name'];
-			var elementType = featureTypeElement['element_type'];
-			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
-			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
-			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
-			var elementLabelExists = (featureTypeElement['f_label'] != "");
-			var elementLabel = "";
-			if (elementLabelExists) {
-				elementLabel = featureTypeElement['f_label'];
+		// Check if there are categories given and
+		// build the form in tabs if necessary
+		var elementCategories = [];
+		for(var i = 0; i < featureTypeElementArray.length; i++){
+			var categoryName         = featureTypeElementArray[i].f_category_name;
+			var categoryNameIsUnique = true;
+			if(categoryName.length === 0) { continue; }
+			for(var j = 0; j < elementCategories.length; j++) {
+				if(elementCategories[j] == categoryName) {
+					categoryNameIsUnique = false;
-			var elementLabelStyle = featureTypeElement['f_label_id'];
+			if(categoryNameIsUnique) {
+				elementCategories.push(categoryName);
-			if (!isGeomColumn) {
-				if (isEditable) {
-					str += "\t\t<tr>\n";
-					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
-					str += "\t\t\t<td>\n";
+		str += "<form id='"+featureTypeElementFormId+"'>\n\t";
+		var hasCategories = (elementCategories.length > 0);
+		if (hasCategories) {
+			elementCategories.sort();
+			initialTab = elementCategories[0];
+			for (var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
+				str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
+		for (var currentCategory = 0; currentCategory < elementCategories.length || !hasCategories; currentCategory++) {
+				str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
+			str += '<table>';
-					var elementValue = "";
-					if (!featureTypeMismatch) {
-						for (var j = 0 ; j < memberElements.count() ; j ++) {
-							if (memberElements.getName(j) == featureTypeElement['element_name']) {
-								elementValue = memberElements.getValue(j);
+			// 2. add rows to form
+			for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
+				var featureTypeElement = featureTypeElementArray[i];
+				var elementName = featureTypeElement['element_name'];
+				var elementType = featureTypeElement['element_type'];
+				var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+				var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+				var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+				if(hasCategories && featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
+					continue;
+				var elementLabelExists = (featureTypeElement['f_label'] != "");
+				var elementLabel = "";
+				if (elementLabelExists) {
+					elementLabel = featureTypeElement['f_label'];
+				var elementLabelStyle = featureTypeElement['f_label_id'];
+				if (!isGeomColumn) {
+					if (isEditable) {
+						str += "\t\t<tr>\n";
+						if(elementLabelExists) {
+							str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+							str += "\t\t\t<td>\n";
+						else {
+							str += '<td colspan="2">';
+						var elementValue = "";
+						if (!featureTypeMismatch) {
+							for (var j = 0 ; j < memberElements.count() ; j ++) {
+								if (memberElements.getName(j) == featureTypeElement['element_name']) {
+									elementValue = memberElements.getValue(j);
-					var formElementHtml = featureTypeElement['f_form_element_html'];
-					if (!formElementHtml || !formElementHtml.match(/&lt;select/)) {
-						str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
-						str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
-						str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
-					else {
+						var formElementHtml = featureTypeElement['f_form_element_html'];
+						if (!formElementHtml) {
+							mandatoryHint = '';
+							var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
+							str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+							str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+							if (!hasCategories) {
+								str += "\t\t\t\t<input id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+							else {
+								str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+						else {
 							while (formElementHtml.match(/\\/)) {
 								formElementHtml = formElementHtml.replace(/\\/, "");
-							str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
-							str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
-							// preselect the correct entry of the box
-							var patternString = "option value( )*=( )*'"+elementValue+"'";
-							var pattern = new RegExp(patternString);
-							var patternStringForReplace = "option value = '"+elementValue+"'";
-							formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
-							formElementHtml = formElementHtml.replace(/&lt;/g,'<');
-							formElementHtml = formElementHtml.replace(/&gt;/g,'>');
-							formElementHtml = formElementHtml.replace(/&#039;/g,'\'');
+								formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
+							var patternString = "hasdatepicker";
+								formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
+								formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
 							str += formElementHtml;
+						if(featureTypeElement.f_helptext.length > 0) {
+							str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../img/help.png" width="16" height="16" alt="?" /></a> ';
+							str += '<div id="helptext' +i+ '" class="helptext">';
+							str += '<p>';
+							str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+							str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
+							str += '</p>';
+							str += '</div>';
+						str += "\t\t\t</td>\n\t\t</tr>\n";
-					str += "\t\t\t</td>\n\t\t</tr>\n";
+				else {
+					hasGeometryColumn = true;
-			else {
-				hasGeometryColumn = true;
+			str += '</table>';
+				str += '</div>';
+			// if no categories exist, the for loop would be
+			// infinite without this break
+				break;
 		// 3. add buttons "save", "update", "delete"
-		str += "</table><table>";
+		str += "<table>";
 		var isTransactional = (featureTypeArray['wfs_transaction']);
 		if (isTransactional) {
@@ -1742,7 +2018,10 @@
 	var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
 	var proceed = true;
-	if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
+	var patternString = parent.mb_mapObj[mapObjInd].epsg.toUpperCase();
+	if(!myconf['featuretype_srs'].match(pattern)){
 		proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
 	if (proceed) {
Deleted: branches/kmq_dev/http/javascripts/mod_digitize_tab_category.php
--- branches/kmq_dev/http/javascripts/mod_digitize_tab_category.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_digitize_tab_category.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,2206 +0,0 @@
-<?php
-# $Id: mod_digitize_tab.php 3939 2009-05-12 19:43:45Z marc $
-# http://www.mapbender.org/index.php/mod_digitize_tab.php
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-$e_target = $_GET["e_target"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Digitize</title>
-<?php
-$digitize_conf_filename = "digitize_default.conf";
-include '../include/dyn_css.php';
-<script language='JavaScript'>
-// Returns a form with the elements of a selected WFS grouped in tabs
-// (if the original WFS is the selected WFS, the values are set too)
-var initialTab = false;
-function buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex) {
-	var featureTypeMismatch = false;
-	if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
-	var str = "";
-	var hasGeometryColumn = false;
-	var featureTypeArray = wfsConf[wfsConfIndex];
-	var memberElements;
-	var fid = false;
-		memberElements = d.get(memberIndex).e;
-		fid = memberElements.getElementValueByName('fid');
-	if (typeof(featureTypeArray["element"]) !== "undefined") {
-		featureTypeElementArray = featureTypeArray["element"];
-		elementCategories.sort();
-		str += "<form id='"+featureTypeElementFormId+"'>\n\t\n";
-		initialTab = elementCategories[0];
-		for(var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
-			str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
-			for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
-				if(featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
-					continue;
-				str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
-				str += '<table>';
-					if (isEditable) {
-						if(elementLabelExists) {
-						else {
-							str += '<td colspan="2">';
-						if (!formElementHtml) {
-							mandatoryHint = '';
-							var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
-							str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
-						else {
-							while (formElementHtml.match(/\\/)) {
-								formElementHtml = formElementHtml.replace(/\\/, "");
-							var patternString = "<select";
-							pattern = new RegExp(patternString);
-							if (pattern.test(formElementHtml)) {
-								formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
-							var patternString = "hasdatepicker";
-								formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
-							var patternString = "<textarea";
-								formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
-							str += formElementHtml;
-						if(featureTypeElement.f_helptext.length > 0) {
-							str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
-							str += '<div id="helptext' +i+ '" class="helptext">';
-							str += '<p>';
-							str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
-							str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
-							str += '</p>';
-							str += '</div>';
-				else {
-			str += '</table>';
-			str += '</div>';
-		// 3. add buttons "save", "update", "delete"
-		str += "<table>";
-		var isTransactional = (featureTypeArray['wfs_transaction']);
-		if (isTransactional) {
-			var options = ["save", "update", "delete", "abort"];
-			for (var i = 0 ; i < options.length ; i++) {
-				var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
-				onClickText += 	"if (result.isCorrect) {";
-				onClickText += 		"window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
-//				onClickText +=      "window.close();";
-				onClickText += 	"}";
-				onClickText += 	"else {";
-				onClickText += 		"alert(result.errorMessage);this.disabled=false;"
-				if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
-					str += "\t\t\t<td><input type='button' name='saveButton' value='"+buttonLabelSaveGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\" /></td>\n";
-				if (!featureTypeMismatch && fid) {
-					if (options[i] == "update" && hasGeometryColumn) {
-						str += "\t\t\t<td><input type='button' name='updateButton' value='"+buttonLabelUpdateGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\"/></td>\n";
-					if (options[i] == "delete"){
-						var deleteOnClickText = "var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');";
-						deleteOnClickText += "if (deltrans){";
-						deleteOnClickText += onClickText + "}";
-						str += "\t\t\t<td><input type='button' name='deleteButton' value='"+buttonLabelDeleteGeometry[selectedLanguage]+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
-				if (options[i] == "abort") {
-					str += "\t\t\t<td><input type='button' name='abortButton' value='"+buttonLabelAbort[selectedLanguage]+"' onclick=\"window.close();\" /></td>\n";
-			str += "\t\t</tr>\n";
-		str += "\t</table>\n";
-		str += "<input type='hidden' id='fid' value='"+fid+"'>";
-//			str += "<input type='text' name='mb_wfs_conf'>";
-		str += "</form>\n";
-	return str;
-// Buttons
-function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
-	buttonDig_id.push(id);
-	buttonDig_on.push(isOn);
-	buttonDig_src.push(src);
-	buttonDig_title_off.push(titleOff);
-	buttonDig_title_on.push(titleOn);
-	buttonDig_x.push(x);
-	buttonDig_y.push(y);
-function htmlspecialchars(p_string) {
-	p_string = p_string.replace(/&/g, '&amp;');
-	p_string = p_string.replace(/</g, '&lt;');
-	p_string = p_string.replace(/>/g, '&gt;');
-	p_string = p_string.replace(/"/g, '&quot;');
-	//	p_string = p_string.replace(/'/g, '&#039;');
-	return p_string;
-//default definition of image directory for digitize buttons, might
-//be overwritten with digitize conf data
-var buttonDig_imgdir = "../img/button_digitize/";
-var buttonDig_id = [];
-var buttonDig_on = [];
-var buttonDig_src = [];
-var buttonDig_title_off = [];
-var buttonDig_title_on = [];
-var buttonDig_x = [];
-var buttonDig_y = [];
-var mapWindow;
-var mapDomElement;
-var mapType = "";
-parent.eventInit.register(function () {
-	var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
-	mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
-	mapType = mapDomElement.tagName.toUpperCase();
-	if (mapType == "DIV") {
-		mapWindow = parent.window;
-	else if (mapType == "IFRAME") {
-		mapWindow = mapDomElement.window;
-	else {
-		new parent.Mb_warning("Could not set CSS for map in digitizing module.");
-<?php
-echo "var mod_digitize_target = '".$e_target."';";
-$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
-if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
-	include($digitizeConfFilenameAndPath);
-var wfsWindow;
-var wfsConf = [];
-var d;
-var mod_digitize_width;
-var mod_digitize_height;
-var mod_digitizeEvent = false;
-var nonTransactionalHighlight;
-var button_point = "Point";
-var button_line = "Line";
-var button_polygon = "Polygon";
-var button_move = "dragBasePoint";
-var button_insert = "setBasePoint";
-var button_delete = "delBasePoint";
-var button_clear = "clear";
-var button_split = "digitizeSplit";
-var button_merge = "digitizeMerge";
-var button_difference = "digitizeDifference";
-var digitizeDivTag;
-var GeometryArray;
-var MultiGeometry = parent.MultiGeometry;
-var Geometry;
-var Point;
-var geomType;
-var msgObj;
-var featureTypeElementFormId = "featureTypeElementForm";
-try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
-try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
-try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
-function toggleTabs(tabId) {
-	if(!initialTab) {
-		return;
-	var tabHeaders = wfsWindow.document.getElementsByTagName('a');
-	var tabs       = wfsWindow.document.getElementsByTagName('div');
-	for(var i = 0; i < tabHeaders.length; i++) {
-		if(tabHeaders[i].id.indexOf('tabheader') != -1) {
-			tabHeaders[i].className = 'tabheader';
-	for(var i = 0; i < tabs.length; i++) {
-		if(tabs[i].className === 'tabcontent') {
-			tabs[i].style.visibility = 'hidden';
-			tabs[i].style.display    = 'none';
-	wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
-	wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
-	wfsWindow.document.getElementById('tab_' + tabId).style.display    = 'block';
-	return false;
-function showHelptext(helptextId) {
-	hideHelptext();
-	wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
-	wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'block';
-	return false;
-function hideHelptext(helptextId) {
-	if(helptextId) {
-		wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
-		wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'none';
-	var helptext = wfsWindow.document.getElementsByTagName('div');
-	for(var i = 0; i < helptext.length; i++) {
-		if(helptext[i].className === 'helptext') {
-			helptext[i].style.visibility = 'hidden';
-			helptext[i].style.display    = 'none';
-	return false;
-function getMousePosition(e) {
-	var currentPos = null;
-		currentPos = new parent.Point(
-			parent.clickX - parseInt(mapDomElement.style.left),
-			parent.clickY - parseInt(mapDomElement.style.top)
-	else {
-			parent.clickX,
-			parent.clickY
-	return currentPos;
-function initializeDigitize () {
-	d = new parent.GeometryArray();
-	GeometryArray = parent.GeometryArray;
-	Geometry = parent.Geometry;
-	Point = parent.Point;
-	geomType = parent.geomType;
- * Append geometries from KML when KML has been loaded
-function appendGeometryArrayFromKML () {
-	try {
-		parent.kmlHasLoaded.register(function(properties){
-			d.importGeoJSON(properties);
-//			d = parent.geoJsonToGeometryArray(properties);
-			executeDigitizeSubFunctions();
-	catch (e) {
-		var exc = new parent.Mb_warning(e);
-// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
-function appendGeometryArray(obj) {
-	executeDigitizePreFunctions();
-	for (i=0; i<obj.count(); i++) {
-		d.addCopy(obj.get(i));
-function mod_digitize_go(e){
-	// ie workaround
-	if (e == undefined) {
-		e = mapWindow.event;
-	if (e) {
-		// track mouse position
-		var currentPos = getMousePosition(e);
-		s.check(currentPos);
-	else {
-//		s.clean();
-	var el = mapDomElement;
-	el.onmousedown = mod_digitize_start;
-function mod_digitize_timeout(){
-	el.onmousedown = null;
-	el.onmouseup = null;
-	el.onmousemove = null;
-function mod_digitize_start(e){
-	// check if a proper geometry is selected
-	if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
-		if (mod_digitizeEvent != false) {
-			alert(msgObj.errorMessageNoGeometrySelected);
-		return false;
-	var realWorldPos;
-	if (s.isSnapped()) {
-		realWorldPos = s.getSnappedPoint();
-		s.clean();
-	else {
-		realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
-	if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
-		// close the polygon
-		d.close();
-		parent.mb_disableThisButton(button_polygon);
-		return true;
-	else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
-		// close the line
-		d.close();
-		parent.mb_disableThisButton(button_line);
-		return true;
-	else {
-		// set the calculated real world position as point of the geometry
-		d.getGeometry(-1,-1).addPoint(realWorldPos);
-		d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
-		if(d.get(-1).geomType == parent.geomType.point){
-			d.close();
-			parent.mb_disableThisButton(button_point);
-			return true;
-		// add first point of polygon to snapping list (if three points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
-			s.add(d.getPoint(-1, -1, 0));
-		// add last point of line to snapping list (if at least two points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
-			if (mod_digitizeEvent != button_move) {
-				s.store(d);
-			s.add(d.getPoint(-1, -1, -1));
-	return true;
-// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
-var basepointObject = false;
-var basepointMemberIndex = null;
-var basepointGeometryIndex = null;
-var basepointRingIndex = null;
-var basepointPointIndex = null;
-var basepointDragActive = false;
-function handleBasepoint(obj,memberIndex, geometryIndex, ringIndex, pointIndex){
-	if (!(
-		mod_digitizeEvent == button_move ||
-		mod_digitizeEvent == button_insert ||
-		mod_digitizeEvent == button_delete)
-		return false;
-	basepointObject = obj;
-	basepointMemberIndex = memberIndex;
-	basepointGeometryIndex = geometryIndex;
-	if (pointIndex == undefined) {
-		pointIndex = ringIndex;
-		basepointRingIndex = undefined;
-	else {
-		basepointRingIndex = ringIndex;
-	basepointPointIndex = pointIndex;
-	if(mod_digitizeEvent == button_move){
-		mod_digitize_timeout();
-		basepointObject.style.cursor = 'move';
-		basepointObject.onmousedown = parent.frames[mod_digitize_elName].selectBasepoint;
-	if(mod_digitizeEvent == button_delete){
-		basepointObject.style.cursor = 'crosshair';
-		basepointObject.onmousedown = parent.frames[mod_digitize_elName].deleteBasepoint;
-function convertLinepointToBasepoint(obj, memberIndex, geomIndex, ringIndex, pointIndex){
-	if(!(mod_digitizeEvent == button_insert)){ return false; }
-	if(mod_digitizeEvent == button_insert){
-		obj.style.cursor = 'crosshair';
-		obj.onclick = insertBasepoint;
-		basepointGeometryIndex = geomIndex;
-function insertBasepoint(e){
-	var i = basepointMemberIndex;
-	var j = basepointGeometryIndex;
-	var k = basepointRingIndex;
-	var l = basepointPointIndex;
-	var ind = parent.getMapObjIndexByName(mod_digitize_target);
-	var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(currentPos.x, currentPos.y));
-	if (k == undefined) {
-		d.getGeometry(i,j).addPointAtIndex(p, l);
-	else {
-		d.getGeometry(i,j).innerRings.get(k).addPointAtIndex(p, l);
-function deleteBasepoint(){
-	if (k != undefined) {
-		d.delAllPointsLike(d.getPoint(i, j, k, l));
-	else {
-		d.delAllPointsLike(d.getPoint(i, j, l));
-function selectBasepoint(e){
-	if(!basepointDragActive && mod_digitizeEvent == button_move){
-		basepointDragActive = true;
-		s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
-		// replace basepoint by transparent blob
-		basepointObject.style.width = mod_digitize_width;
-		basepointObject.style.height = mod_digitize_height;
-		basepointObject.style.left = 0;
-		basepointObject.style.top = 0;
-		if (parent.ie) {
-			// ie cannot handle backgroundColor = 'transparent'
-			basepointObject.style.background = "url(../img/transparent.gif)";
-		else{
-			basepointObject.style.backgroundColor = 'transparent';
-		basepointObject.onmouseup = releaseBasepoint;
-		basepointObject.onmousemove = dragBasepoint;
-function dragBasepoint(e){
-	if(basepointDragActive){
-		var res = s.check(currentPos);
-function updateAllPointsOfNonTransactionalLike(oldP, newP){
-	for (var i = 0; i < d.count(); i++) {
-		if (isTransactional(d.get(i))) {
-			d.get(i).updateAllPointsLike(oldP, newP);
-function releaseBasepoint(e){
-	basepointDragActive = false;
-	var basepointDragEnd = currentPos;
-	basepointObject.onmousedown = null;
-	var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(basepointDragEnd.x, basepointDragEnd.y));
-	var oldPoint;
-		oldPoint = parent.cloneObject(d.getPoint(i,j,l));
-	else {
-		oldPoint = parent.cloneObject(d.getPoint(i,j,k,l));
-		var snappedPoint = parent.cloneObject(s.getSnappedPoint());
-		if (!nonTransactionalEditable) {
-			updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
-		else {
-			d.updateAllPointsLike(oldPoint, snappedPoint);
-		s.clean();
-	else {
-			updateAllPointsOfNonTransactionalLike(oldPoint, p);
-		else {
-			d.updateAllPointsLike(oldPoint, p);
-	basepointMemberIndex = null;
-	basepointGeometryIndex = null;
-	basepointPointIndex = null;
-// --- basepoint handling (end) -----------------------------------------------------------------------------------------
-// --- registered functions (begin) ---------------------------------------------------------------------------------------
-function registerDigitizePreFunctions(stringFunction){
-	mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
-function registerDigitizeSubFunctions(stringFunction){
-	mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
-function executeDigitizeSubFunctions(){
-	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
-		eval(mod_digitizeSubFunctions[i]);
-function executeDigitizePreFunctions(){
-	for(var i=0; i<mod_digitizePreFunctions.length; i++){
-		eval(mod_digitizePreFunctions[i]);
-function registerFunctions(){
-	mod_digitizePreFunctions = [];
-	mod_digitizeSubFunctions = [];
-	registerDigitizePreFunctions("updateExtent()");
-	registerDigitizePreFunctions("drawDashedLine()");
-	registerDigitizeSubFunctions("updateListOfGeometries()");
-	registerDigitizeSubFunctions("drawDashedLine()");
-	parent.eventInit.register(function () {
-		initializeDigitize();
-		setStyleForTargetFrame();
-		checkDigitizeTag();
-		initialiseSnapping();
-//		appendGeometryArrayFromKML();
-			initialiseHighlight();
-		initialiseMeasure();
-		getMessages();
-	parent.eventLocalize.register(function() {
-		getMessages();
-	parent.eventAfterMapRequest.register(function () {
-		updateExtent();
-	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
-function checkDigitizeTag(){
-	var digitizeTagName = "digitizeDiv";
-	var digitizeTagStyle;
-		digitizeTagStyle = {"z-index":digitizeTransactionalZIndex, "font-size":"10px"};
-		digitizeDivTag = new parent.DivTag(digitizeTagName, "", digitizeTagStyle, mapDomElement);
-	else {
-		digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
-		digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
-	parent.mb_registerPanSubElement(digitizeTagName);
-	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
-function setStyleForTargetFrame(){
-	var cssLink = mapWindow.document.createElement("link");
-	var cssHead = mapWindow.document.getElementsByTagName("head")[0];
-	cssLink.setAttribute("href", cssUrl);
-	cssLink.setAttribute("type", "text/css");
-	cssLink.setAttribute("rel", "stylesheet");
-	cssHead.appendChild(cssLink);
-function initialiseSnapping(){
-	s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
-function initialiseHighlight(){
-	nonTransactionalHighlight = new parent.Highlight([mod_digitize_target], "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
-function initialiseMeasure(){
-		measureDivTag = new parent.DivTag(measureTagName, "", measureTagStyle);
-	else {
-		measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
-	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
-// --- registered functions (end) -----------------------------------------------------------------------------------------
-function updateMeasureTag () {
-	if (d.count() > 0 ) {
-		if (d.get(-1).count() > 0) {
-			if (d.getGeometry(-1, -1).count() > 0) {
-				if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
-					var measureString = "";
-					measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
-					measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
-					measureDivTag.write(measureString);
-					return true;
-	measureDivTag.clean();
-// --- button handling (begin) --------------------------------------------------------------------------------------------
-function displayButtons(){
-	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
-		if (parseInt(buttonDig_on[i])==1) {
-			var divTag = document.createElement("div");
-			divTag.setAttribute("id", "div_" + buttonDig_id[i]);
-// FIREFOX
-			document.getElementById("digButtons").appendChild(divTag);
-//IE WORKAROUND, WORKS ALSO FOR FIREFOX
-			var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
-			parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
-function updateButtons() {
-			var currentButton = document.getElementById(buttonDig_id[i]);
-			var currentStatus = buttonDig_id[i].status;
-			var currentTitle = "";
-			switch (buttonDig_id[i]) {
-				case "Point":
-					if (currentStatus == 1) {
-						currentTitle = msgObj.buttonLabelPointOn;
-					else {
-						currentTitle = msgObj.buttonLabelPointOff;
-					break;
-				case "Line":
-						currentTitle = msgObj.buttonLabelLineOn;
-					else {
-						currentTitle = msgObj.buttonLabelLineOff;
-					break;
-				case "Polygon":
-						currentTitle = msgObj.buttonLabelPolygonOn;
-					else {
-						currentTitle = msgObj.buttonLabelPolygonOff;
-					break;
-				case "dragBasePoint":
-						currentTitle = msgObj.buttonLabelMoveBasepointOn;
-					else {
-						currentTitle = msgObj.buttonLabelMoveBasepointOff;
-					break;
-				case "setBasePoint":
-						currentTitle = msgObj.buttonLabelInsertBasepointOn;
-					else {
-						currentTitle = msgObj.buttonLabelInsertBasepointOff;
-					break;
-				case "delBasePoint":
-						currentTitle = msgObj.buttonLabelDeleteBasepointOn;
-					else {
-						currentTitle = msgObj.buttonLabelDeleteBasepointOff;
-					break;
-				case "clear":
-						currentTitle = msgObj.buttonLabelClearListOn;
-					else {
-						currentTitle = msgObj.buttonLabelClearListOff;
-					break;
-				case "digitizeSplit":
-						currentTitle = msgObj.buttonLabelSplitOn;
-					else {
-						currentTitle = msgObj.buttonLabelSplitOff;
-					break;
-				case "digitizeMerge":
-						currentTitle = msgObj.buttonLabelMergeOn;
-					else {
-						currentTitle = msgObj.buttonLabelMergeOff;
-					break;
-				case "digitizeDifference":
-						currentTitle = msgObj.buttonLabelDifferenceOn;
-					else {
-						currentTitle = msgObj.buttonLabelDifferenceOff;
-					break;
-			currentButton.title = currentTitle;
-function initDigButton(ind, pos){
-	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
-	parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
-	parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
-	parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
-	parent.mb_button[ind].title_on = buttonDig_title_on[pos];
-	parent.mb_button[ind].title_off = buttonDig_title_off[pos];
-	parent.mb_button[ind].status = 0;
-	parent.mb_button[ind].elName = buttonDig_id[pos];
-	parent.mb_button[ind].fName = "";
-	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
-	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
-function digitizeEnable(obj) {
-	if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
-		mod_digitizeEvent = obj.id;
-	else if (obj.id == button_point || obj.id == button_line ||
-				obj.id == button_polygon || obj.id == button_clear ||
-				obj.id == button_split || obj.id == button_merge ||
-				obj.id == button_difference){
-		el.onmousemove = mod_digitize_go;
-		if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
-			s.store(d);
-		obj.title = obj.title_on;
-		if (obj.id == button_point) {
-			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
-				if (d.get(-1).geomType != parent.geomType.point) {
-					d.close();
-				else {
-			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
-				d.addMember(parent.geomType.point);
-				d.get(-1).addGeometry();
-			else {
-// delete existing line or polygon
-				d.del(-1);
-		else if (obj.id == button_polygon) {
-				if (d.get(-1).geomType != parent.geomType.polygon) {
-					d.close();
-				else {
-				// new geometry
-				d.addMember(parent.geomType.polygon);
-			else {
-// continue a line as a polygon
-					var geometryTemplate = parent.cloneObject(d.get(-1));
-					d.del(-1);
-					for (var i = 0; i < geometryTemplate.count(); i++) {
-						for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
-							d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
-		else if (obj.id == button_line) {
-				if (d.get(-1).geomType != parent.geomType.line) {
-					d.close();
-				else {
-				d.addMember(parent.geomType.line);
-			else {
-// continue a polygon as a line
-					d.del(-1);
-		else if (obj.id == button_clear) {
-			var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
-			if (clear) {
-				parent.mb_disableThisButton(button_clear);
-		else if (obj.id == button_merge) {
-			var applicable = (d.count() > 1);
-			var polygonTextArray = [];
-				if (d.get(i).geomType != parent.geomType.polygon) {
-					applicable = false;
-					polygonTextArray = [];
-					break;
-				polygonTextArray.push(d.get(i).toText());
-			if (!applicable) {
-				alert(msgObj.messageErrorMergeNotApplicable);
-				parent.mb_disableThisButton(button_merge);
-				return false;
-			parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
-				var response = eval('(' + json + ')');
-				var polygon = response.polygon;
-				d.importGeometryFromText(polygon, parent.mb_mapObj[mapIndex].epsg);
-				// remove the original polygons
-				var len = d.count();
-				for (var i = 0; i < len-1; i++) {
-					d.del(0);
-		else if (obj.id == button_split) {
-			var applicable = (d.count() == 2) &&
-							(d.get(0).geomType == parent.geomType.polygon) &&
-							(d.get(1).geomType == parent.geomType.line);
-				alert(msgObj.messageErrorSplitNotApplicable);
-				parent.mb_disableThisButton(button_split);
-				return false;
-			var polygonText = d.get(0).toText();
-			var lineText = d.get(1).toText();
-			parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
-				var polygonArray = response.polygons;
-				var wfsConfId = d.get(0).wfs_conf;
-				for (var i in polygonArray) {
-					d.importGeometryFromText(polygonArray[i], parent.mb_mapObj[mapIndex].epsg);
-					d.get(-1).wfs_conf = wfsConfId;
-				// remove the original polygon and the temporary line
-				d.del(0);
-				d.del(0);
-		else if (obj.id == button_difference) {
-							(d.get(1).geomType == parent.geomType.polygon);
-				alert(msgObj.messageErrorDifferenceNotApplicable);
-				parent.mb_disableThisButton(button_difference);
-				return false;
-			var polygon1Text = d.get(0).toText();
-			var polygon2Text = d.get(1).toText();
-			parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
-				var wfsProperties = d.get(0).e;
-					d.get(-1).e = wfsProperties;
-				// remove the original and the temporary polygon
-				d.del(0);
-				d.del(0);
-function digitizeDisable(obj) {
-	if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
-		obj.title = obj.title_off;
-		if (d.get(-1).get(-1).count() == 0) {
-			d.delGeometry(-1,-1);
-	mod_digitizeEvent = false;
-// --- button handling (end) ----------------------------------------------------------------------------------------------
-// --- display (begin) -----------------------------------------------------------------------------------------
-function updateExtent() {
-	var anInd = parent.getMapObjIndexByName(mod_digitize_target);
-	var change = false;
-	if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
-		mod_digitize_width = parent.mb_mapObj[anInd].width;
-		change = true;
-	if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
-		mod_digitize_height = parent.mb_mapObj[anInd].height;
-		change = true;
-	if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
-		mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
-		change = true;
-//	if (change) {
-//		drawDashedLine();
-function drawDashedLine(){
-		nonTransactionalHighlight.clean();
-	var smP = "";
-	smP += "<div class='t_img'>";
-	smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
-	smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-	var smPArray = [];
-	smPArray[smPArray.length] = "<div class='t_img'>"
-			+ "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
-			+ "<div class='t_img'>"
-			+ "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-	var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
-	var width = mapObj.width;
-	var height = mapObj.height;
-	var minX = parseFloat(arrayBBox[0]);
-	var minY = parseFloat(arrayBBox[1]);
-	var maxX = parseFloat(arrayBBox[2]);
-	var maxY = parseFloat(arrayBBox[3]);
-	var cx = width/(maxX - minX);
-	var cy = height/(maxY - minY);
-	var isMoveOrInsertOrDelete = mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete;
-	var minDist = 6;
-	for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
-		var currentGeomArray = d.get(i);
-		if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
-			nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
-		else {
-			for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
-				var currentGeometry = d.getGeometry(i,j);
-				var isPolygon = currentGeomArray.geomType == parent.geomType.polygon;
-				var isLine = currentGeomArray.geomType == parent.geomType.line;
-				var isComplete = currentGeometry.isComplete();
-				var lastPaintedPoint = false;
-				for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
-					var currentPoint = currentGeometry.get(k);
-					var currentPointMap = new Point(Math.round((currentPoint.x - minX)*cx), Math.round((maxY - currentPoint.y)*cy));
-//					var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
-//					if (!isTooCloseToPrevious) {
-						var currentPointIsVisible = currentPointMap.x > 0 && currentPointMap.x < width && currentPointMap.y > 0 && currentPointMap.y < height;
-						if (currentPointIsVisible) {
-							if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint-1 && isLine))) {
-								smPArray[smPArray.length] = "<div class='bp' style='top:"+
-									(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+
-									digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
-							else {
-								smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
-							if(k==0 && isPolygon && !isComplete){
-								smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
-							if(isMoveOrInsertOrDelete) {
-								smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
-							smPArray[smPArray.length] = "></div>";
-							lastPaintedPoint = currentPointMap;
-						if (k > 0) {
-							points = parent.calculateVisibleDash(currentPointMap, previousPointMap, width, height);
-							if (points != false) {
-								smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
-					var previousPointMap = currentPointMap;
-				if (isPolygon && currentGeometry.innerRings.count() > 0) {
-					// draw inner rings
-					for (var l = 0, lenRings = currentGeometry.innerRings.count(); l < lenRings; l++) {
-						var currentRing = currentGeometry.innerRings.get(l);
-						for (var m = 0, lenPoint = currentRing.count(); m < lenPoint; m++) {
-							var currentPoint = currentRing.get(m);
-							var currentPointMap = new Point(Math.round((currentPoint.x - minX) * cx), Math.round((maxY - currentPoint.y) * cy));
-							//					var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
-							//					if (!isTooCloseToPrevious) {
-								if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint - 1 && isLine))) {
-									smPArray[smPArray.length] = "<div class='bp' style='top:" +
-									(currentPointMap.y - 2) +
-									"px;left:" +
-									(currentPointMap.x - 2) +
-									"px;z-index:" +
-									digitizeTransactionalZIndex +
-									";background-color:" +
-									linepointColor +
-								else {
-									smPArray[smPArray.length] = "<div class='bp' style='top:" + (currentPointMap.y - 2) + "px;left:" + (currentPointMap.x - 2) + "px;z-index:" + digitizeTransactionalZIndex + ";'";
-								if (m == 0 && isPolygon && !isComplete) {
-									smPArray[smPArray.length] = " title='" + msgObj.closePolygon_title + "' ";
-								if (isMoveOrInsertOrDelete) {
-									smPArray[smPArray.length] = " onmouseover='parent.window.frames[\"" + mod_digitize_elName + "\"].handleBasepoint(this," + i + "," + j + "," + l + "," + m + ")' ;";
-							if (m > 0) {
-									smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, l, m);
-	digitizeDivTag.write(smPArray.join(""));
-function evaluateDashes(start, end, memberIndex, geomIndex, ringIndex, pointIndex){
-		ringIndex = undefined;
-	var strArray = [];
-	var delta = new parent.Point(end.x - start.x, end.y - start.y);
-	var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
-	var vecLength = start.dist(end);
-	var n = Math.round(vecLength/dotDistance);
-	if (n > 0) {
-		var step = delta.dividedBy(n);
-	for(var i=1; i < n; i++){
-		var x = Math.round(start.x + i * step.x) - 2;
-		var y = Math.round(start.y + i * step.y) - 2;
-		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
-			if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
-				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
-			else {
-				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
-			if(mod_digitizeEvent == button_insert) {
-				strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+ringIndex+","+pointIndex+")'";
-			strArray[strArray.length] = "></div>";
-	return strArray.join("");
-function isTransactional(geom) {
-//	alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
-	if (typeof(geom.wfs_conf) == 'number') {
-		if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
-			var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
-			if (isTransactionalGeom) {
-				return true;
-			else{
-				return false;
-	else if (typeof(geom.wfs_conf) == 'undefined') {
-		return true;
-function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
-	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
-function getName (geom) {
-	wfsConfId = geom.wfs_conf;
-	wfsConf = parent.get_complete_wfs_conf();
-	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
-		var resultName = "";
-		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
-			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
-				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
-		if (resultName == "") {
-			resultName = wfsConf[wfsConfId]['g_label'];
-		return resultName;
-	else if (geom.e.getElementValueByName("name")) {
-		return geom.e.getElementValueByName("name");
-	else {
-		return msgObj.digitizeDefaultGeometryName;
-function updateListOfGeometries(){
-	var listOfGeom = "<ul>";
-	if (d.count() > 0) {
-		for (var i = 0 ; i < d.count(); i ++) {
-			if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
-				// for the geometries from a kml, there is another save dialogue
-				if (d.get(i).isFromKml()) {
-					// if the kml is in the db (id = id in database)
-					if (d.get(i).e.getElementValueByName("Mapbender:id")) {
-						// button: geometry information, update kml
-						listOfGeom += "<li>";
-						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>";
-				else {
-					// button: geometry information, save, update, delete
-					if (wfsExistsForGeom(d.get(i), wfsConf)) {
-						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>";
-					// button: remove this geometry
-					listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>";
-					// button clone this geometry
-					if (addCloneGeometryButton === true) {
-						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_clone_src+"' title='"+msgObj.buttonDig_clone_title+"' onclick='d.addCopy(d.get("+i+"));d.get(-1).e.delElement(\"fid\");executeDigitizeSubFunctions();'>";
-				// button: remove geometry from database
-				if (d.get(i).e.getElementValueByName('fid')) {
-					listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">";
-				listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
-				listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"),\""+geomHighlightColour+"\")' ";
-				listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
-				var geomName = getName(d.get(i));
-				var currentGeomType;
-				if (d.get(i).geomType == parent.geomType.polygon) {
-					currentGeomType = msgObj.messageDescriptionPolygon;
-				else if (d.get(i).geomType == parent.geomType.line) {
-					currentGeomType = msgObj.messageDescriptionLine;
-				else if (d.get(i).geomType == parent.geomType.point) {
-					currentGeomType = msgObj.messageDescriptionPoint;
-				var multi = "";
-				if (d.get(i).count() > 1) {
-					multi = "multi";
-				listOfGeom += ">" + htmlspecialchars(geomName) +" (" + multi + currentGeomType + ")</div>";
-				// multigeometries
-				listOfGeom += "<ul>";
-				for (var j = 0; j < d.get(i).count(); j++) {
-					var currentGeom = d.get(i).get(j);
-					if (d.get(i).count() > 1 || (d.get(i).geomType == geomType.polygon &&
-						d.get(i).get(j).innerRings &&
-						d.get(i).get(j).innerRings.count() > 0)) {
-						listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").del(" + j + ");executeDigitizeSubFunctions();'>";
-						listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
-						listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\")' ";
-						listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
-						listOfGeom += ">" + currentGeomType + "#" + (j+1) +"</div></li>";
-					if (d.get(i).geomType == geomType.polygon &&
-						d.get(i).get(j).innerRings.count() > 0) {
-						for (var k = 0; k < d.get(i).get(j).innerRings.count(); k++) {
-							var currentRing = d.get(i).get(j).innerRings.get(k);
-							listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").get(" + j + ").innerRings.del(" + k + ");executeDigitizeSubFunctions();'>";
-							listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
-							listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\")' ";
-							listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
-							listOfGeom += ">inner ring #" + (k+1) +"</div></li>";
-						listOfGeom += "</ul>";
-				listOfGeom += "</li>";
-	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
-// --- display (end) -----------------------------------------------------------------------------------------
-// --- wfs window (begin) -----------------------------------------------------------------------------------------
-// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
-function formCorrect(doc, formId) {
-	var isCorrect = true;
-	var errorMessage = "";
-	var result;
-	var form = doc.getElementById(formId);
-	result = mandatoryFieldsNotEmpty(doc, form);
-	isCorrect = isCorrect && result.isCorrect;
-	errorMessage += result.errorMessage;
-	//select box is now checked within function mandatoryFieldsNotEmpty
-	//result = validBoxEntrySelected(form);
-	//isCorrect = isCorrect && result.isCorrect;
-	//errorMessage += result.errorMessage;
-	result = dataTypeIsCorrect(doc, form);
-	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
-function validBoxEntrySelected(form){
-	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
-		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
-		else if (form.childNodes[i].hasChildNodes()) {
-	if (!isCorrect) {
-function mandatoryFieldsNotEmpty(doc, node){
-	nodeArray = doc.getElementsByName("mandatory");
-	for (var i = 0; i < nodeArray.length && isCorrect; i++) {
-		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
-			var nodeId = nodeArray[i].id.substr(10);
-			if (nodeArray[i].value == "true") {
-				if (doc.getElementById(nodeId).value == "") {
-					isCorrect = false;
-					errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
-		if (nodeArray[i].nodeName.toUpperCase() == "SELECT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
-function isInteger(str) {
-	if (str.match(/^\d*$/)) {
-		return true;
-	return false;
-function isFloat(str) {
-	if (isInteger(str)) {
-		return true;
-	if (str.match(/^\d+\.\d+$/)) {
-		return true;
-	return false;
-function replaceCommaByDecimalPoint(str) {
-	var patternString = ",";
-	while (str.match(pattern)) {
-		str = str.replace(pattern, ".");
-	return str;
-function dataTypeIsCorrect(doc, node){
-	nodeArray = doc.getElementsByName("datatype");
-	for (var i = 0; i < nodeArray.length ; i++) {
-		if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
-			var nodeId = nodeArray[i].id.substr(9);
-			var nodeValue = doc.getElementById(nodeId).value;
-			if (nodeArray[i].value == "int") {
-				if (!isInteger(nodeValue)) {
-					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
-			else if (nodeArray[i].value == "double") {
-				nodeValue = replaceCommaByDecimalPoint(nodeValue);
-				if (!isFloat(nodeValue)) {
-					errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
-				else {
-					doc.getElementById(nodeId).value = nodeValue;
-// --- wfs window form check (end) -----------------------------------------------------------------------------------------
-function getAvailableWfsForGeom(geom, wfsConf) {
-	var wfsConfIndices = [];
-	for (var attr in wfsConf) {
-		var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
-		if (!isTrans) {
-			continue;
-		if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
-			if (parseInt(geom.wfs_conf) == parseInt(attr)) {
-				wfsConfIndices.push(attr);
-		else {
-			for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
-				var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
-				if (isGeomColumn) {
-					var isMultiPolygon = (
-						geom.geomType == parent.geomType.polygon &&
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType' ||
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiSurfacePropertyType'
-					var isPolygon = (
-						geom.count() == 1 &&
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType' ||
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'SurfacePropertyType'
-					var isMultiLine = (
-						geom.geomType == parent.geomType.line &&
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType' ||
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiCurvePropertyType'
-					var isLine = (
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType' ||
-						wfsConf[attr]['element'][elementIndex]['element_type'] == 'CurvePropertyType'
-					var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
-//					alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
-					if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
-	return wfsConfIndices;
-function wfsExistsForGeom(geom, wfsConf) {
-	wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
-//	alert(wfsConfIndices.join(","));
-	if (wfsConfIndices.length > 0) {
-		return true;
-	return false;
-function showWfsKml (geometryIndex) {
-	wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
-	wfsKmlWindow.document.open("text/html");
-	wfsKmlWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
-	wfsKmlWindow.document.close();
-	str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
-	var properties = d.get(geometryIndex).e;
-	var propertyCount = properties.count();
-	for (var i = 0; i < propertyCount; i++) {
-		var key = properties.getName(i);
-		var value = properties.getValue(i);
-		var expr = /Mapbender:/;
-		if (!key.match(expr)) {
-			str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
-			str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
-	var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
-	var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
-	deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
-	str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
-// delete button not yet implemented
-//	str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
-	str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
-	wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
-// this method opens a new window and displays the attributes in wfs_conf
-function showWfs(geometryIndex) {
-	wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
-	wfsWindow.document.open("text/html");
-	var str = "";
-	var strStyle = "";
-	var defaultIndex = -1;
-	str += "<form id='wfs'>\n";
-	// 1. add select box
-	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
-	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
-	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
-	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
-	str += " onChange=\""+ onChangeText +"\"";
-	str += ">\n\t\t";
-	var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
-	var selected = false;
-	for (var i = 0; i < wfsConfIndices.length ; i++) {
-		str += "<option value='" + wfsConfIndices[i] + "'";
-		if (!selected) {
-			str += " selected";
-			selected = true;
-			defaultIndex = parseInt(wfsConfIndices[i]);
-		str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
-		str += "</option>\n\t\t";
-	str += "</select>\n\t\t</form>\n\t";
-	str += "<div id='elementForm'>\n</div>";
-	if (defaultIndex != -1) {
-		var htmlStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
-		htmlStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
-		htmlStr += '<style type="text/css">'
-		htmlStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
-		htmlStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
-		htmlStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
-		htmlStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
-		htmlStr += 'div.helptext p { margin: 0 ; }';
-		htmlStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
-		htmlStr += 'a img { vertical-align: middle;border: 0; }';
-		htmlStr += '</style>';
-		htmlStr += '</head><body></body></html>';
-//		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
-		wfsWindow.document.write(htmlStr);
-		wfsWindow.document.write(str);
-		wfsWindow.document.close();
-		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
-	else {
-		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
-function setWfsWindowStyle(wfsConfIndex) {
-	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
-// returns a form with the elements of a selected wfs
-// (if the original wfs is the selected wfs, the values are set too)
-function buildElementForm(wfsConfIndex, memberIndex){
-	var str = "";
-	var fid = false;
-		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
-		// Check if there are categories given and
-		// build the form in tabs if necessary
-		var elementCategories = ['abc','def','123'];
-		for(var i = 0; i < featureTypeElementArray.length; i++){
-			var categoryName         = featureTypeElementArray[i].f_category_name;
-			var categoryNameIsUnique = true;
-			if(categoryName.length === 0) { continue; }
-			for(var j = 0; j < elementCategories.length; j++) {
-				if(elementCategories[j] == categoryName) {
-					categoryNameIsUnique = false;
-			if(categoryNameIsUnique) {
-				elementCategories.push(categoryName);
-		if(elementCategories.length > 0) {
-			return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
-		// 2. add rows to form
-		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
-			var featureTypeElement = featureTypeElementArray[i];
-			var elementName = featureTypeElement['element_name'];
-			var elementType = featureTypeElement['element_type'];
-			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
-			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
-			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
-			var elementLabelExists = (featureTypeElement['f_label'] != "");
-			var elementLabel = "";
-			if (elementLabelExists) {
-				elementLabel = featureTypeElement['f_label'];
-			var elementLabelStyle = featureTypeElement['f_label_id'];
-			if (!isGeomColumn) {
-				if (isEditable) {
-					str += "\t\t<tr>\n";
-					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
-					str += "\t\t\t<td>\n";
-					var elementValue = "";
-					if (!featureTypeMismatch) {
-						for (var j = 0 ; j < memberElements.count() ; j ++) {
-							if (memberElements.getName(j) == featureTypeElement['element_name']) {
-								elementValue = memberElements.getValue(j);
-					else {
-						str += '<p>';
-						str += '</p>';
-						str += '</div>';
-			else {
-			var options = ["insert", "update", "delete", "abort"];
-				if (options[i] == "insert" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
-					str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
-						str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
-						var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
-						str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
-					str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
-	return str;
-function dbGeom(type,m) {
-	if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
-		d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
-		d.get(m).e = new parent.Wfs_element();
-	else {
-	var myconf = wfsConf[d.get(m).wfs_conf];
-	var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
-	var proceed = true;
-		proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
-	if (proceed) {
-		var fid = false;
-			myform = wfsWindow.document.getElementById(featureTypeElementFormId);
-			for (var i=0; i<myform.length; i++){
-				if (myform.elements[i].id == "fid") {
-					fid = myform.elements[i].value;
-					if (fid == "false") {
-						fid = false;
-					else {
-						d.get(m).e.setElement('fid', fid);
-				else if (myform.elements[i].type == 'text' ){
-					if (myform.elements[i].id) {
-						var elementId = String(myform.elements[i].id).replace(/mb_digitize_form_/, "");
-						d.get(m).e.setElement(elementId, myform.elements[i].value);
-					else {
-						errorMessage = msgObj.messageErrorFormEvaluation;
-				// selectbox
-				else if (typeof(myform.elements[i].selectedIndex) == 'number') {
-						d.get(m).e.setElement(elementId, myform.elements[i].options[myform.elements[i].selectedIndex].value);
-					else {
-		else {
-			fid = d.get(m).e.getElementValueByName('fid');
-//		str = parent.get_wfs_str(myconf, d, m, type, fid);
-		var geoJson = d.featureToString(m);
-			"../extensions/geom2wfst.php",
-				'geoJson' : geoJson,
-				'method' : type,
-				'wfs_conf_id' : wfsConf[d.get(m).wfs_conf]['wfs_conf_id']
-			function(json,status){
-				var result = eval('('+json+')');
-				var success = result.success;
-				var fid = result.fid;
-				wfsSubWrite(m, type, status, success, fid);
-function wfsSubWrite(m, type, status, success, fid) {
-	if (status == "success" && success) {
-		if (type == 'insert' && fid) {
-			d.get(m).e.setElement("fid", fid);
-		if (type == 'delete') {
-			parent.mb_disableThisButton(mod_digitizeEvent);
-			d.del(m);
-		var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
-	else {
-		var wfsWriteMessage = msgObj.messageErrorWfsWrite;
-	parent.mb_execWfsWriteSubFunctions();
-		wfsWindow.alert(wfsWriteMessage);
-		window.setTimeout("wfsWindow.close()",0);
-	else {
-		alert(wfsWriteMessage);
-function getMultiGeometryIdsByPlacemarkId (placemarkId) {
-	var multiGeometryIdArray = [];
-		var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
-		if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
-			multiGeometryIdArray.push(i);
-	return multiGeometryIdArray;
-function updateKmlInDb (geometryIndex, command) {
-	var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
-	var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
-	if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
-		// update properties from form
-		myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
-		for (var i=0; i < myform.length; i++){
-			if (myform.elements[i].type == 'text' ){
-					var key = myform.elements[i].name;
-					var value = myform.elements[i].value;
-					// update all geometries with the same placemark id
-					for (var j = 0; j < multiGeometryIdArray.length; j++) {
-						var currentProperties = d.get(j).e;
-						currentProperties.setElement(key, value);
-		var kmlId = properties.getElementValueByName("Mapbender:id");
-		parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
-			if (obj === "1") {
-				wfsKmlWindow.alert("KML updated.");
-				var link = wfsKmlWindow.document.createElement("a");
-				link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
-				link.target = "_blank";
-				link.innerHTML = "KML";
-				wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
-				wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
-			else {
-				wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
-function getMessages() {
-	parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
-		msgObj = obj;
-		applyMessages();
-function applyMessages() {
-	updateMeasureTag();
-	updateListOfGeometries();
-	updateButtons();
-	</script>
-	</head>
-	<body onload="registerFunctions();displayButtons();">
-		<div id='digButtons'></div>
-		<div id='listOfGeometries' class='digitizeGeometryList'></div>
-	</body>
-</html>
\ No newline at end of file
Modified: branches/kmq_dev/http/javascripts/mod_dragMapSize.php
--- branches/kmq_dev/http/javascripts/mod_dragMapSize.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_dragMapSize.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -108,7 +108,7 @@
 	targetObject.setWidth(targetObject.getWidth() + parseFloat(dif_x));
 	targetObject.setHeight(targetObject.getHeight() + parseFloat(dif_y));
-	var mybbox = targetObject.extent.split(",");
+	var mybbox = targetObject.extent.toString().split(",");
 	targetObject.setExtent(mybbox[0], pos[1], pos[0], mybbox[3]);
 	targetObject.setMapRequest();
 	eventResizeMap.trigger();
Modified: branches/kmq_dev/http/javascripts/mod_dynamicOverview.php
--- branches/kmq_dev/http/javascripts/mod_dynamicOverview.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_dynamicOverview.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -84,7 +84,7 @@
 	if (map.elementName == map0.elementName) {
 		// get center in coords:
-		var coords = map0.extent.split(",");
+		var coords = map0.extent.toString().split(",");
 		var minx = parseFloat(coords[0]);
 		var miny = parseFloat(coords[1]);
 		var maxx = parseFloat(coords[2]);
Modified: branches/kmq_dev/http/javascripts/mod_export_image.php
--- branches/kmq_dev/http/javascripts/mod_export_image.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_export_image.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -52,13 +52,13 @@
 include(dirname(__FILE__)."/../../conf/print.conf");
-$sql = "SELECT * from gui_element WHERE fkey_gui_id = '".$_SESSION["mb_user_gui"]."' AND e_id = $1";
+$sql = "SELECT * from gui_element WHERE fkey_gui_id = '".Mapbender::session()->get("mb_user_gui")."' AND e_id = $1";
 $v = array($mb_module_id);
 $t = array('s');
 $res = db_prep_query($sql, $v, $t);
 echo "<script type='text/javascript'>";
-#echo "var mb_user_resolution = ".$_SESSION["mb_user_resolution"]." / 2.54;";
+#echo "var mb_user_resolution = ".Mapbender::session()->get("mb_user_resolution")." / 2.54;";
 echo "var deformation = ".$deformation.";";
 #echo "var DPC = 28.35 * deformation;";
 echo "var DPC = 28.35;";
@@ -111,7 +111,7 @@
 	if(ind_size != 0 && ind_format != 0){
 		var ind = window.opener.getMapObjIndexByName(mod_print1_target);
-		var coord = window.opener.mb_mapObj[ind].extent.split(",");
+		var coord = window.opener.mb_mapObj[ind].extent.toString().split(",");
 		var centerX = parseInt(coord[0]) + (parseInt(coord[2]) - parseInt(coord[0]))/2
 		var centerY = parseInt(coord[1]) + (parseInt(coord[3]) - parseInt(coord[1]))/2
 		if(document.form1.size.options[ind_size].value == "A4" && document.form1.format.options[ind_format].value == "portrait"){
@@ -158,7 +158,12 @@
 		window.opener.window.frames[mod_print1_target].document.getElementById("maps").style.width = document.form1.map_width.value;
 		window.opener.window.frames[mod_print1_target].document.getElementById("maps").style.height = document.form1.map_height.value;
-		window.opener.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," +  coord[3];
+		window.opener.mb_mapObj[ind].extent = new window.opener.Extent(
+			coord[0],
+			pos[1],
+			pos[0],
+			coord[3]
 		window.opener.setMapRequest(mod_print1_target);
@@ -180,7 +185,7 @@
 			cnt_urls++;
-	document.form1.map_extent.value = window.opener.mb_mapObj[ind].extent;
+	document.form1.map_extent.value = window.opener.mb_mapObj[ind].extent.toString();
 	document.form1.map_scale.value = window.opener.mb_getScale(mod_print1_target);
 function printMap(){
Modified: branches/kmq_dev/http/javascripts/mod_help.php
--- branches/kmq_dev/http/javascripts/mod_help.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_help.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -51,8 +51,8 @@
 	mod_help_set();
 	//request help string
 	var usemapHtml = "";
-	for (var module in Mapbender.Modules) {
-		var currentModule = Mapbender.Modules[module];
+	for (var module in Mapbender.modules) {
+		var currentModule = Mapbender.modules[module];
 		var top = parseInt(currentModule.top) || 0;
 		var left = parseInt(currentModule.left) || 0;
 		var width = parseInt(currentModule.width) || 0;
@@ -79,9 +79,9 @@
 	$('#mod_help_img').empty().html(html);
 		(function () {
 			if (currentModule.url) {
 				$("#helpArea_" + module).click(function () {
 					mod_help_disable();
@@ -135,7 +135,7 @@
 function mod_help_update(){
 	//try to update tab coords
 	try{
 			var tab = $("#tabs_" + module).get(0);
 			if (tab) {
 				var area = $("#helpArea_" + module).get(0);
Modified: branches/kmq_dev/http/javascripts/mod_highlightPOI.php
--- branches/kmq_dev/http/javascripts/mod_highlightPOI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_highlightPOI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,152 +1,152 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_highlightPOI.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "var mod_highlightPOI_target = '".$e_target[0]."';";
-include('../include/dyn_js.php');
-try{
-	if (poi_image){}
-catch(e){
-	poi_image = '../img/redball.gif';
-try{
-	if (poi_width){}
-catch(e){
-	poi_width = 14;
-try{
-	if (poi_height){}
-catch(e){
-	poi_height = 14;
-try{
-	if (poi_style){}
-catch(e){
-	poi_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
-eventInit.register(function () {
-	mod_highlightPOI_init();
-eventAfterMapRequest.register(function () {
-	mod_highlightPOI_draw();
-var mod_highlightPOI_minx;
-var mod_highlightPOI_miny;
-var mod_highlightPOI_maxx;
-var mod_highlightPOI_maxy;
-var mod_highlightPOI_name = new Array();
-var mod_highlightPOI_x = new Array();
-var mod_highlightPOI_y = new Array();
-var mod_highlightPOI_params = new Array();
-var myPOI;
-function mod_highlightPOI_init(){
-		var myPOI = "<?php if (CHARSET == 'UTF-8'){
-				echo preg_replace("/\n/", "<br>", $_SESSION['mb_myPOI']);
-			}else{
-				echo preg_replace("/\n/", "<br>", utf8_decode($_SESSION['mb_myPOI']));
-	if(myPOI != ""){
- 		mod_highlightPOI_params = myPOI.split("|");
-	  for(var i=0; i<mod_highlightPOI_params.length; i=i+3){
-	    if(i==0){
-	      mod_highlightPOI_name[i] = mod_highlightPOI_params[i];
-	      mod_highlightPOI_minx = parseInt(mod_highlightPOI_params[i+1]);
-	      mod_highlightPOI_miny = parseInt(mod_highlightPOI_params[i+2]);
-	      mod_highlightPOI_maxx = parseInt(mod_highlightPOI_params[i+1]);
-	      mod_highlightPOI_maxy = parseInt(mod_highlightPOI_params[i+2]);
-	    else{
-	      if(mod_highlightPOI_params[i+1] < mod_highlightPOI_minx){
-	      if(mod_highlightPOI_params[i+2] < mod_highlightPOI_miny){
-	      if(mod_highlightPOI_params[i+1] > mod_highlightPOI_maxx){
-	      if(mod_highlightPOI_params[i+2] > mod_highlightPOI_maxy){
-	  if((mod_highlightPOI_maxx - mod_highlightPOI_minx) < 100){
-	    mod_highlightPOI_minx -= 50;
-	    mod_highlightPOI_maxx += 50;
-	  if((mod_highlightPOI_maxy - mod_highlightPOI_miny) < 100){
-	    mod_highlightPOI_miny -= 50;
-	    mod_highlightPOI_maxy += 50;
-	  //mb_calculateExtent( mod_highlightPOI_target,mod_highlightPOI_minx,mod_highlightPOI_miny,mod_highlightPOI_maxx,mod_highlightPOI_maxy);
-function mod_highlightPOI_draw(){
-	var mapObject = getMapObjByName(mod_highlightPOI_target);
-	var map_el = mapObject.getDomElement();
-	if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
-		//create Box Elements
-		var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
-		$div.css({
-			position: "absolute",
-			top: "0px",
-			left: "0px",
-			zIndex: 13
-		map_el.appendChild($div.get(0));
-	var tagSource = "";
-	for (var i = 0; i < mod_highlightPOI_params.length; i = i + 3) {
-		var pointFromUrl = new Point(parseFloat(mod_highlightPOI_params[i+1]), parseFloat(mod_highlightPOI_params[i+2]));
-		var pos = mapObject.convertRealToPixel(pointFromUrl);
-		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos.x-Math.round(0.5*poi_width))+"px;top:"+(pos.y-Math.round(0.5*poi_height))+"px'>";
-		tagSource += "<img src='"+poi_image+"'>";
-		tagSource += "<span style='"+poi_style+"'>"+mod_highlightPOI_params[i]+"<span>";
-		tagSource += "</div>";
-	$("#" + mapObject.elementName + "_permanent").html(tagSource);
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_highlightPOI.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+echo "var mod_highlightPOI_target = '".$e_target[0]."';";
+include('../include/dyn_js.php');
+try{
+	if (poi_image){}
+catch(e){
+	poi_image = '../img/redball.gif';
+try{
+	if (poi_width){}
+catch(e){
+	poi_width = 14;
+try{
+	if (poi_height){}
+catch(e){
+	poi_height = 14;
+try{
+	if (poi_style){}
+catch(e){
+	poi_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
+eventInit.register(function () {
+	mod_highlightPOI_init();
+eventAfterMapRequest.register(function () {
+	mod_highlightPOI_draw();
+var mod_highlightPOI_minx;
+var mod_highlightPOI_miny;
+var mod_highlightPOI_maxx;
+var mod_highlightPOI_maxy;
+var mod_highlightPOI_name = new Array();
+var mod_highlightPOI_x = new Array();
+var mod_highlightPOI_y = new Array();
+var mod_highlightPOI_params = new Array();
+var myPOI;
+function mod_highlightPOI_init(){
+		var myPOI = "<?php if (CHARSET == 'UTF-8'){
+				echo preg_replace("/\n/", "<br>", Mapbender::session()->get("mb_myPOI"));
+			}else{
+				echo preg_replace("/\n/", "<br>", utf8_decode(Mapbender::session()->get("mb_myPOI")));
+	if(myPOI != ""){
+ 		mod_highlightPOI_params = myPOI.split("|");
+	  for(var i=0; i<mod_highlightPOI_params.length; i=i+3){
+	    if(i==0){
+	      mod_highlightPOI_name[i] = mod_highlightPOI_params[i];
+	      mod_highlightPOI_minx = parseInt(mod_highlightPOI_params[i+1]);
+	      mod_highlightPOI_miny = parseInt(mod_highlightPOI_params[i+2]);
+	      mod_highlightPOI_maxx = parseInt(mod_highlightPOI_params[i+1]);
+	      mod_highlightPOI_maxy = parseInt(mod_highlightPOI_params[i+2]);
+	    else{
+	      if(mod_highlightPOI_params[i+1] < mod_highlightPOI_minx){
+	      if(mod_highlightPOI_params[i+2] < mod_highlightPOI_miny){
+	      if(mod_highlightPOI_params[i+1] > mod_highlightPOI_maxx){
+	      if(mod_highlightPOI_params[i+2] > mod_highlightPOI_maxy){
+	  if((mod_highlightPOI_maxx - mod_highlightPOI_minx) < 100){
+	    mod_highlightPOI_minx -= 50;
+	    mod_highlightPOI_maxx += 50;
+	  if((mod_highlightPOI_maxy - mod_highlightPOI_miny) < 100){
+	    mod_highlightPOI_miny -= 50;
+	    mod_highlightPOI_maxy += 50;
+	  //mb_calculateExtent( mod_highlightPOI_target,mod_highlightPOI_minx,mod_highlightPOI_miny,mod_highlightPOI_maxx,mod_highlightPOI_maxy);
+function mod_highlightPOI_draw(){
+	var mapObject = getMapObjByName(mod_highlightPOI_target);
+	var map_el = mapObject.getDomElement();
+	if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
+		//create Box Elements
+		var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
+		$div.css({
+			position: "absolute",
+			top: "0px",
+			left: "0px",
+			zIndex: 13
+		map_el.appendChild($div.get(0));
+	var tagSource = "";
+	for (var i = 0; i < mod_highlightPOI_params.length; i = i + 3) {
+		var pointFromUrl = new Point(parseFloat(mod_highlightPOI_params[i+1]), parseFloat(mod_highlightPOI_params[i+2]));
+		var pos = mapObject.convertRealToPixel(pointFromUrl);
+		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos.x-Math.round(0.5*poi_width))+"px;top:"+(pos.y-Math.round(0.5*poi_height))+"px'>";
+		tagSource += "<img src='"+poi_image+"'>";
+		tagSource += "<span style='"+poi_style+"'>"+mod_highlightPOI_params[i]+"<span>";
+		tagSource += "</div>";
+	$("#" + mapObject.elementName + "_permanent").html(tagSource);
Modified: branches/kmq_dev/http/javascripts/mod_home.php
--- branches/kmq_dev/http/javascripts/mod_home.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_home.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,39 +1,39 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_home
-function mod_home_init(){
-<?php
-echo "var url = '".LOGIN."';";
-echo "var name = '".urlencode($_SESSION["mb_user_name"])."';";
-echo "var pw = '".$_SESSION["mb_user_password"]."';";
-	var str = "<form name='myGuiList_form' method='POST' action='' target='_self'>";
-	str += "<input type='hidden' name='name' value='"+name+"' />";
-	str += "<input type='hidden' name='password' value='"+pw+"' />";
-	str += "</form>";
-	var mod_home_div = document.createElement('div');
-	mod_home_div.setAttribute("id","mod_home_d");
-	var tmp = document.body.appendChild(mod_home_div);
-	document.getElementById("mod_home_d").innerHTML = str;
-	document.forms.myGuiList_form.action = url;
-	document.forms.myGuiList_form.submit();
-	//document.location.href = url + "?name=" + name + "&password=" + pw;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_home
+function mod_home_init(){
+<?php
+echo "var url = '".LOGIN."';";
+echo "var name = '".urlencode(Mapbender::session()->get("mb_user_name"))."';";
+echo "var pw = '".Mapbender::session()->get("mb_user_password")."';";
+	var str = "<form name='myGuiList_form' method='POST' action='' target='_self'>";
+	str += "<input type='hidden' name='name' value='"+name+"' />";
+	str += "<input type='hidden' name='password' value='"+pw+"' />";
+	str += "</form>";
+	var mod_home_div = document.createElement('div');
+	mod_home_div.setAttribute("id","mod_home_d");
+	var tmp = document.body.appendChild(mod_home_div);
+	document.getElementById("mod_home_d").innerHTML = str;
+	document.forms.myGuiList_form.action = url;
+	document.forms.myGuiList_form.submit();
+	//document.location.href = url + "?name=" + name + "&password=" + pw;
Modified: branches/kmq_dev/http/javascripts/mod_horizTab.php
--- branches/kmq_dev/http/javascripts/mod_horizTab.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_horizTab.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -39,7 +39,7 @@
 echo "$(\"#".$e_id."\").tabControl()";
 for ($i=0; $i < count($tab_ids); $i++) {
 	$sql = "SELECT gettext($1, e_title) AS e_title FROM gui_element WHERE fkey_gui_id = $2 AND e_id = $3";
-	$v = array($_SESSION["mb_lang"], $gui_id, $tab_ids[$i]);
+	$v = array(Mapbender::session()->get("mb_lang"), $gui_id, $tab_ids[$i]);
 	$t = array("s", "s", "s");
 	$row = db_fetch_array($res);
Modified: branches/kmq_dev/http/javascripts/mod_initWmc.php
--- branches/kmq_dev/http/javascripts/mod_initWmc.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_initWmc.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,116 +1,116 @@
-<?php
-require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-require_once(dirname(__FILE__) . "/../classes/class_kml.php");
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-if ($_SESSION['mb_myWmc'] && $_SESSION['mb_myWmc_action'] &&
-	in_array($_SESSION['mb_myWmc_action'],
-	array("load", "merge", "append"))) {
-	$action = $_SESSION['mb_myWmc_action'];
-	$wmc_id = $_SESSION['mb_myWmc'];
-$user = $_SESSION['mb_user_id'];
-$meetingPointId = $_SESSION['mb_myKml'];
-$x = false;
-$y = false;
-$icon = false;
-$alt = false;
-$url = false;
-$adm = new administration();
-//KML
-if (isset($meetingPointId)) {
-	$sql = "SELECT * FROM mb_meetingpoint WHERE mb_meetingpoint_id = $1";
-	$v = array($meetingPointId);
-	$t = array('s');
-	$res = db_prep_query($sql,$v,$t);
-	if($row = db_fetch_array($res)){
-		$user = $row['fkey_mb_user_id'];
-		$password = $row['mb_user_password'];
-		$gui = $row['fkey_gui_id'];
-		$wmc_id = $row['fkey_wmc_id'];
-		$kml_doc = $row['kml'];
-		$kml = new kml("", "", 0, 0, "");
-		$value = $kml->createObjFromKML($kml_doc);
-		$x = $kml->x;
-		$y = $kml->y;
-		$icon = $kml->icon;
-		if ($kml->title) {
-			if ($kml->description) $alt = $kml->title . ", " .$kml->description;
-			else $alt = $kml->title;
-		else $alt = $kml->description;
-		if (mb_ereg("^.*,[[:space:]]((([[:alpha:]]+://)|(www.))[^<>[:space:]]+[[:alnum:]/]).*$", $kml->title)) {
-			$url = mb_ereg_replace("^.*,[[:space:]]((([[:alpha:]]+://)|(www.))[^<>[:space:]]+[[:alnum:]/]).*$", "\\1", $kml->title);
-			if (mb_substr($url, 0, 4) == "www.") {
-				$url = "http://" . $url;
-	else {
-		$js_error .= "alert('Meetingpoint ID id ".$meetingPointId." is not valid. Default GUI will be loaded instead.');";
-//WMC
-if (isset($wmc_id)) {
-	$myInitWmc = new wmc();
-	$success = $myInitWmc->createFromDb($wmc_id);
-	if ($success) {
-		$js_wmc = implode("", $myInitWmc->toJavaScript());
-		new mb_exception("WMC JS: " . $js_wmc);
-		if (!empty($x) && !empty($y) && !empty($icon)) {
-			$js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
-			// 7 is half the width of pin.png
-			$js_kml .= "myPoint.x -= 7;";
-			// 20 is the height of pin.png
-			$js_kml .= "myPoint.y -= 20;";
-			$js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
-			$js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
-			$js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
-			if ($url) {
-				$js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
-			$js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
-			$js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
-			$js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
-			$js_kml .= "meeting_img.style.position = 'absolute';";
-			$js_kml .= "meeting_img.style.top = myPoint.y;";
-			$js_kml .= "meeting_img.style.left = myPoint.x;";
-			$js_kml .= "mb_registerPanSubElement('meeting_logo');";
-	else {
-		$js_error .= "alert('WMC id ".$wmc_id." is not valid. Default GUI will be loaded instead.');";
-echo "function mod_initWMC_init() {";
-echo $js_wmc;
-echo $js_kml;
-echo $js_error;
-echo "}";
-echo "function addFlag() {";
-echo $js_kml;
-echo "}";
-mb_registerInitFunctions("mod_initWMC()");
-function mod_initWMC(){
-	mod_initWMC_init();
-	mb_registerSubFunctions('addFlag()');
+<?php
+require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+require_once(dirname(__FILE__) . "/../classes/class_kml.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+if (Mapbender::session()->get("mb_myWmc") && Mapbender::session()->get("mb_myWmc_action") &&
+	in_array(Mapbender::session()->get("mb_myWmc_action"),
+	array("load", "merge", "append"))) {
+	$action = Mapbender::session()->get("mb_myWmc_action");
+	$wmc_id = Mapbender::session()->get("mb_myWmc");
+$user = Mapbender::session()->get("mb_user_id");
+$meetingPointId = Mapbender::session()->get("mb_myKml");
+$x = false;
+$y = false;
+$icon = false;
+$alt = false;
+$url = false;
+$adm = new administration();
+//KML
+if (isset($meetingPointId)) {
+	$sql = "SELECT * FROM mb_meetingpoint WHERE mb_meetingpoint_id = $1";
+	$v = array($meetingPointId);
+	$t = array('s');
+	$res = db_prep_query($sql,$v,$t);
+	if($row = db_fetch_array($res)){
+		$user = $row['fkey_mb_user_id'];
+		$password = $row['mb_user_password'];
+		$gui = $row['fkey_gui_id'];
+		$wmc_id = $row['fkey_wmc_id'];
+		$kml_doc = $row['kml'];
+		$kml = new kml("", "", 0, 0, "");
+		$value = $kml->createObjFromKML($kml_doc);
+		$x = $kml->x;
+		$y = $kml->y;
+		$icon = $kml->icon;
+		if ($kml->title) {
+			if ($kml->description) $alt = $kml->title . ", " .$kml->description;
+			else $alt = $kml->title;
+		else $alt = $kml->description;
+		if (mb_ereg("^.*,[[:space:]]((([[:alpha:]]+://)|(www.))[^<>[:space:]]+[[:alnum:]/]).*$", $kml->title)) {
+			$url = mb_ereg_replace("^.*,[[:space:]]((([[:alpha:]]+://)|(www.))[^<>[:space:]]+[[:alnum:]/]).*$", "\\1", $kml->title);
+			if (mb_substr($url, 0, 4) == "www.") {
+				$url = "http://" . $url;
+	else {
+		$js_error .= "alert('Meetingpoint ID id ".$meetingPointId." is not valid. Default GUI will be loaded instead.');";
+//WMC
+if (isset($wmc_id)) {
+	$myInitWmc = new wmc();
+	$success = $myInitWmc->createFromDb($wmc_id);
+	if ($success) {
+		$js_wmc = implode("", $myInitWmc->toJavaScript());
+		new mb_exception("WMC JS: " . $js_wmc);
+		if (!empty($x) && !empty($y) && !empty($icon)) {
+			$js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
+			// 7 is half the width of pin.png
+			$js_kml .= "myPoint.x -= 7;";
+			// 20 is the height of pin.png
+			$js_kml .= "myPoint.y -= 20;";
+			$js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
+			$js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
+			$js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
+			if ($url) {
+				$js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
+			$js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
+			$js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
+			$js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
+			$js_kml .= "meeting_img.style.position = 'absolute';";
+			$js_kml .= "meeting_img.style.top = myPoint.y;";
+			$js_kml .= "meeting_img.style.left = myPoint.x;";
+			$js_kml .= "mb_registerPanSubElement('meeting_logo');";
+	else {
+		$js_error .= "alert('WMC id ".$wmc_id." is not valid. Default GUI will be loaded instead.');";
+echo "function mod_initWMC_init() {";
+echo $js_wmc;
+echo $js_kml;
+echo $js_error;
+echo "}";
+echo "function addFlag() {";
+echo $js_kml;
+echo "}";
+mb_registerInitFunctions("mod_initWMC()");
+function mod_initWMC(){
+	mod_initWMC_init();
+	mb_registerSubFunctions('addFlag()');
Modified: branches/kmq_dev/http/javascripts/mod_insertKmlIntoDb.php
--- branches/kmq_dev/http/javascripts/mod_insertKmlIntoDb.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_insertKmlIntoDb.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,98 +1,98 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-include(dirname(__FILE__) . "/../classes/class_kml.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-Licensing: See the GNU General Public License for more details.
-http://www.gnu.org/copyleft/gpl.html
-or:
-mapbender/licence/
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>MB2 - <?php  echo  $gui_id;?></title>
-</head>
-<body>
-<?php
-if ($_POST["data"]) {
-	$d = explode("____", $_POST["data"]);
-	$wmc_id = $d[0];
-	$x = $d[1];
-	$y = $d[2];
-	$icon = $d[3];
-	$gui_id = $d[4];
-	$title_array = array();
-	if ($_POST['name']) $title_array[count($title_array)] = $_POST['name'];
-	if ($_POST['street']) $title_array[count($title_array)] = $_POST['street'];
-	if ($_POST['postcode']) {
-		if ($_POST['city']) {
-			$title_array[count($title_array)] = $_POST['postcode'] . " " . $_POST['city'];
-		else {
-			$title_array[count($title_array)] = $_POST['postcode'];
-	elseif ($_POST['city']) {
-		$title_array[count($title_array)] = $_POST['city'];
-	if ($_POST['website']) $title_array[count($title_array)] = $_POST['website'];
-	$title = implode(", ", $title_array);
-	$description = $_POST['description'];
-	$kml = new kml($title, $description, $x, $y, $icon);
-	$kml->createKMLFromObj();
-	$sql = "INSERT INTO mb_meetingpoint VALUES ($1, $2, $3, $4, $5, $6)";
-	$v = array($kml->kml_id, $wmc_id, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)), $_SESSION["mb_user_id"], $_SESSION["mb_user_password"], $gui_id);
-	$t = array('s', 's', 's', 'i', 's', 's');
-	$res = db_prep_query($sql, $v, $t);
-	if (db_error()) {
-		echo "<script>var title = \"" . $title . "\";alert(\"Error while saving KML document \" + title + \"! ".db_error()."\");</script>";
-	else {
-		if ($alert) {
-			 echo "<script>var title = \"" . $title . "\";alert(\"KML document \" + title + \"has been saved!\")</script>";
-	$filename = "../tmp/".$kml->kml_id.'.kml';
-	$handle = fopen($filename, "w");
-	fputs($handle, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)));
-	fclose($handle);
-	echo "Please feel free to add the <a href = 'http://".$_SERVER['HTTP_HOST']."/mburl/".$kml->kml_id."'>link</a> to your meeting point to your website.<br><br>";
-	echo "<a href='".$filename."'>kml</a>";
-</body>
-</html>
+<?php
+#$Id$
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+include(dirname(__FILE__) . "/../classes/class_kml.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+Licensing: See the GNU General Public License for more details.
+http://www.gnu.org/copyleft/gpl.html
+or:
+mapbender/licence/
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>MB2 - <?php  echo  $gui_id;?></title>
+</head>
+<body>
+<?php
+if ($_POST["data"]) {
+	$d = explode("____", $_POST["data"]);
+	$wmc_id = $d[0];
+	$x = $d[1];
+	$y = $d[2];
+	$icon = $d[3];
+	$gui_id = $d[4];
+	$title_array = array();
+	if ($_POST['name']) $title_array[count($title_array)] = $_POST['name'];
+	if ($_POST['street']) $title_array[count($title_array)] = $_POST['street'];
+	if ($_POST['postcode']) {
+		if ($_POST['city']) {
+			$title_array[count($title_array)] = $_POST['postcode'] . " " . $_POST['city'];
+		else {
+			$title_array[count($title_array)] = $_POST['postcode'];
+	elseif ($_POST['city']) {
+		$title_array[count($title_array)] = $_POST['city'];
+	if ($_POST['website']) $title_array[count($title_array)] = $_POST['website'];
+	$title = implode(", ", $title_array);
+	$description = $_POST['description'];
+	$kml = new kml($title, $description, $x, $y, $icon);
+	$kml->createKMLFromObj();
+	$sql = "INSERT INTO mb_meetingpoint VALUES ($1, $2, $3, $4, $5, $6)";
+	$v = array($kml->kml_id, $wmc_id, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)), Mapbender::session()->get("mb_user_id"), Mapbender::session()->get("mb_user_password"), $gui_id);
+	$t = array('s', 's', 's', 'i', 's', 's');
+	$res = db_prep_query($sql, $v, $t);
+	if (db_error()) {
+		echo "<script>var title = \"" . $title . "\";alert(\"Error while saving KML document \" + title + \"! ".db_error()."\");</script>";
+	else {
+		if ($alert) {
+			 echo "<script>var title = \"" . $title . "\";alert(\"KML document \" + title + \"has been saved!\")</script>";
+	$filename = "../tmp/".$kml->kml_id.'.kml';
+	$handle = fopen($filename, "w");
+	fputs($handle, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)));
+	fclose($handle);
+	echo "Please feel free to add the <a href = 'http://".$_SERVER['HTTP_HOST']."/mburl/".$kml->kml_id."'>link</a> to your meeting point to your website.<br><br>";
+	echo "<a href='".$filename."'>kml</a>";
+</body>
+</html>
Modified: branches/kmq_dev/http/javascripts/mod_insertLayerPreviewIntoDb.php
--- branches/kmq_dev/http/javascripts/mod_insertLayerPreviewIntoDb.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_insertLayerPreviewIntoDb.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,163 +1,163 @@
-<?php
-#$Id$
-#include(dirname(__FILE__)."/../../conf/geoportal.conf");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_connector.php");
-function savePreview($fileName, $fileContent) {
-	if (strlen($fileContent) > 0) {
-		$fileMapImg = fopen("..".LAYER_PREVIEW_URL."/".$fileName, 'w+');
-		if ($fileMapImg) {
-			rewind($fileMapImg);
-			$bytesWritten = fwrite($fileMapImg, $fileContent);
-			if ($bytesWritten) {
-				fflush($fileMapImg);
-				ftruncate($fileMapImg, ftell($fileMapImg));
-				fclose($fileMapImg);
-				return true;
-			$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": 0 bytes written.");
-			return false;
-		$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": could not open.");
-		return false;
-	$e = new mb_exception($fileName.": no file content.");
-	return false;
-	$mapurl = $d[0];
-	$legendurl = $d[1];
-	$mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_WIDTH."\\2", $mapurl);
-	$mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_HEIGHT."\\2", $mapurl);
-	$adm = new administration();
-	$layer_id = $_SESSION['layer_preview'];
-	if (!$layer_id) {
-		 echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
-	else {
-		session_write_close();
-		$con1 = new connector($mapurl);
-		$fileNameMap = $layer_id."_layer_map_preview.png";
-		$fileContentMap = $con1->file;
-		$success = savePreview($fileNameMap, $fileContentMap);
-		if (!$success) $fileNameMap = "";
-		$con2 = new	connector($legendurl);
-		$fileNameLegend = $layer_id."_layer_legend_preview.png";
-		$fileContentLegend = $con2->file;
-		$success = savePreview($fileNameLegend, $fileContentLegend);
-		if (!$success) $fileNameLegend = "";
-//		$rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
-		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
-		$sql = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'";
-		$v = array($layer_id);
-		$t = array('i');
-		$row = db_fetch_array($res);
-		if ($row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
-			$extent_layer_id = $layer_id;
-			$layer_4326_box = array($row['minx'], $row['miny'], $row['maxx'], $row['maxy']);
-		else {
-			$sql = "SELECT * FROM (SELECT fkey_wms_id FROM layer WHERE layer_id = $1 LIMIT 1) AS w, layer_epsg AS e, layer AS l WHERE l.fkey_wms_id = w.fkey_wms_id AND l.layer_pos = 0 AND l.layer_id = e.fkey_layer_id AND e.epsg = 'EPSG:4326'";
-			$t = array('i');
-			if ($row['epsg'] && $row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
-				$extent_layer_id = $row['layer_id'];
-			else {
-				$layer_4326_box = $rlp_4326_box;
-		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
-			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
-				$rlp_4326_box[0] = $layer_4326_box[0];
-			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
-				$rlp_4326_box[2] = $layer_4326_box[2];
-			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
-				$rlp_4326_box[1] = $layer_4326_box[1];
-			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
-				$rlp_4326_box[3] = $layer_4326_box[3];
-			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
-			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
-			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
-			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
-			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
-			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
-			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
-			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
-			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
-			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
-		$con3 = new connector(LAYER_EXTENT_URL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
-		$fileNameExtent = $layer_id."_layer_extent_preview.png";
-		$fileContentExtent = $con3->file;
-		$success = savePreview($fileNameExtent, $fileContentExtent);
-		if (!$success) $fileNameExtent = "";
-		$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
-		$t = array('i');
-		if ($row['fkey_layer_id'] == $layer_id) {
-			$sql = "UPDATE layer_preview SET layer_map_preview_filename = $1, layer_extent_preview_filename = $2, layer_legend_preview_filename = $3 WHERE fkey_layer_id = $4";
-			$v = array($fileNameMap, $fileNameExtent, $fileNameLegend, $layer_id);
-			$t = array('s', 's', 's', 'i');
-		else {
-			$sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview_filename, layer_extent_preview_filename, layer_legend_preview_filename) VALUES ($1, $2, $3, $4)";
-			$v = array($layer_id, $fileNameMap, $fileNameExtent, $fileNameLegend);
-			$t = array('i', 's', 's', 's');
-		if (db_error()) {
-			 echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
-		else {
-			 echo "<script>try{parent.opener.document.getElementById('".$layer_id."_dp').style.display='';}catch(e){};alert(\"Layer preview has been saved!\")</script>";
-</body>
-<html>
+<?php
+#$Id$
+#include(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+function savePreview($fileName, $fileContent) {
+	if (strlen($fileContent) > 0) {
+		$fileMapImg = fopen("..".LAYER_PREVIEW_URL."/".$fileName, 'w+');
+		if ($fileMapImg) {
+			rewind($fileMapImg);
+			$bytesWritten = fwrite($fileMapImg, $fileContent);
+			if ($bytesWritten) {
+				fflush($fileMapImg);
+				ftruncate($fileMapImg, ftell($fileMapImg));
+				fclose($fileMapImg);
+				return true;
+			$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": 0 bytes written.");
+			return false;
+		$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": could not open.");
+		return false;
+	$e = new mb_exception($fileName.": no file content.");
+	return false;
+	$mapurl = $d[0];
+	$legendurl = $d[1];
+	$mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_WIDTH."\\2", $mapurl);
+	$mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_HEIGHT."\\2", $mapurl);
+	$adm = new administration();
+	$layer_id = Mapbender::session()->get("layer_preview");
+	if (!$layer_id) {
+		 echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
+	else {
+		session_write_close();
+		$con1 = new connector($mapurl);
+		$fileNameMap = $layer_id."_layer_map_preview.png";
+		$fileContentMap = $con1->file;
+		$success = savePreview($fileNameMap, $fileContentMap);
+		if (!$success) $fileNameMap = "";
+		$con2 = new	connector($legendurl);
+		$fileNameLegend = $layer_id."_layer_legend_preview.png";
+		$fileContentLegend = $con2->file;
+		$success = savePreview($fileNameLegend, $fileContentLegend);
+		if (!$success) $fileNameLegend = "";
+//		$rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
+		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
+		$sql = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'";
+		$v = array($layer_id);
+		$t = array('i');
+		$row = db_fetch_array($res);
+		if ($row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+			$extent_layer_id = $layer_id;
+			$layer_4326_box = array($row['minx'], $row['miny'], $row['maxx'], $row['maxy']);
+		else {
+			$sql = "SELECT * FROM (SELECT fkey_wms_id FROM layer WHERE layer_id = $1 LIMIT 1) AS w, layer_epsg AS e, layer AS l WHERE l.fkey_wms_id = w.fkey_wms_id AND l.layer_pos = 0 AND l.layer_id = e.fkey_layer_id AND e.epsg = 'EPSG:4326'";
+			$t = array('i');
+			if ($row['epsg'] && $row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+				$extent_layer_id = $row['layer_id'];
+			else {
+				$layer_4326_box = $rlp_4326_box;
+		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
+			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
+				$rlp_4326_box[0] = $layer_4326_box[0];
+			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
+				$rlp_4326_box[2] = $layer_4326_box[2];
+			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
+				$rlp_4326_box[1] = $layer_4326_box[1];
+			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
+				$rlp_4326_box[3] = $layer_4326_box[3];
+			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
+			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
+			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
+			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
+			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
+			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
+			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
+			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
+			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
+			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
+		$con3 = new connector(LAYER_EXTENT_URL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
+		$fileNameExtent = $layer_id."_layer_extent_preview.png";
+		$fileContentExtent = $con3->file;
+		$success = savePreview($fileNameExtent, $fileContentExtent);
+		if (!$success) $fileNameExtent = "";
+		$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
+		$t = array('i');
+		if ($row['fkey_layer_id'] == $layer_id) {
+			$sql = "UPDATE layer_preview SET layer_map_preview_filename = $1, layer_extent_preview_filename = $2, layer_legend_preview_filename = $3 WHERE fkey_layer_id = $4";
+			$v = array($fileNameMap, $fileNameExtent, $fileNameLegend, $layer_id);
+			$t = array('s', 's', 's', 'i');
+		else {
+			$sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview_filename, layer_extent_preview_filename, layer_legend_preview_filename) VALUES ($1, $2, $3, $4)";
+			$v = array($layer_id, $fileNameMap, $fileNameExtent, $fileNameLegend);
+			$t = array('i', 's', 's', 's');
+		if (db_error()) {
+			 echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
+		else {
+			 echo "<script>try{parent.opener.document.getElementById('".$layer_id."_dp').style.display='';}catch(e){};alert(\"Layer preview has been saved!\")</script>";
+</body>
+<html>
Modified: branches/kmq_dev/http/javascripts/mod_legend.php
--- branches/kmq_dev/http/javascripts/mod_legend.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_legend.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -129,7 +129,7 @@
 					var layerStyle = parent.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
 					var legendUrl = false;
 					if(layerStyle == false){
-						legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"default");
+						legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
 					else{
 						legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
Modified: branches/kmq_dev/http/javascripts/mod_loadwmc.php
--- branches/kmq_dev/http/javascripts/mod_loadwmc.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_loadwmc.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -25,28 +25,32 @@
 function createJs ($mergeWms) {
 	$jsString = "";
 	$wmc = new wmc();
-	if (!isset($_SESSION['mb_wmc'])) {
-		$e = new mb_notice("wmc not set, generating from app: " . $_SESSION["mb_user_gui"]);
-		$wmc->createFromApplication($_SESSION["mb_user_gui"]);
-		$_SESSION["mb_wmc"] = $wmc->toXml();
+	if (!Mapbender::session()->get("mb_wmc")) {
+		$e = new mb_notice("wmc not set, generating from app: " . Mapbender::session()->get("mb_user_gui"));
+		$wmc->createFromApplication(Mapbender::session()->get("mb_user_gui"));
+		Mapbender::session()->set("mb_wmc",$wmc->toXml());
 		$e = new mb_notice("creating initial WMC.");
-	if (isset($_SESSION['mb_wmc'])) {
+	if (Mapbender::session()->get("mb_wmc")) {
-		if ($wmc->createFromXml($_SESSION['mb_wmc'])) {
+		if ($wmc->createFromXml(Mapbender::session()->get("mb_wmc"))) {
 			if ($mergeWms) {
 				$e = new mb_notice("merging with WMS.");
 				$wmsArray = array();
-				for ($i = 0; $i < count($_SESSION["wms"]); $i++) {
-					$currentWms = new wms();
-					$currentWms->createObjFromXML($_SESSION["wms"][$i]);
-					array_push($wmsArray, $currentWms);
+				$inputWmsArray = Mapbender::session()->get("wms");
+				if ($inputWmsArray && is_array($inputWmsArray)) {
+					for ($i = 0; $i < count(); $i++) {
+						$currentWms = new wms();
+						$currentWms->createObjFromXML($inputWmsArray[$i]);
+						array_push($wmsArray, $currentWms);
 				$wmc->mergeWmsArray($wmsArray);
-				$_SESSION["command"] = "";
-				$_SESSION["wms"] = array();
+				Mapbender::session()->set("command","");
+				Mapbender::session()->set("wms",array());
 			$javaScriptArray = array();
@@ -72,7 +76,7 @@
 function load_wmc_session() {
 <?php
-if ($_SESSION["command"] && $_SESSION["command"] == "ADDWMS") {
+if (Mapbender::session()->get("command") && Mapbender::session()->get("command") == "ADDWMS") {
 	$e = new mb_notice("merging with WMS in Session...");
 	$output = createJs(true);
Modified: branches/kmq_dev/http/javascripts/mod_log.php
--- branches/kmq_dev/http/javascripts/mod_log.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_log.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,13 +1,13 @@
-<?php
-require(dirname(__FILE__)."/../php/mb_validatePermission.php");
-mb_registerInitFunctions("mb_log_init()");
-function mb_log_init(){
-	mb_log = "mb_log_set";
-try{if(logtype){}}catch(e){logtype="";}
-function mb_log_set(req, time_client){
-	var url = "../php/mod_log.php?<?php echo $urlParameters;?>&req=" + escape(req) + "&time_client=" + time_client;
-	mb_ajax_post(url, {req:req, time:time_client});
-	return true;
+Mapbender.events.init.register(function () {
+	eventAfterMapRequest.register(function (options) {
+		var parameters = {
+			req : options.url,
+			time_client : Mapbender.getTimestamp()
+		var notification = new Mapbender.Ajax.Notification({
+			url: "../php/mod_log.php",
+			parameters: parameters
+		notification.send();
Modified: branches/kmq_dev/http/javascripts/mod_owsproxy.php
--- branches/kmq_dev/http/javascripts/mod_owsproxy.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_owsproxy.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -27,7 +27,7 @@
 <table>
 <?php
 $n = new administration();
-$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
+$myguis = $n->getGuisByPermission(Mapbender::session()->get("mb_user_id"),true);
 $mywms = $n->getWmsByOwnGuis($myguis);
 $v = array();
 $t = array();
Modified: branches/kmq_dev/http/javascripts/mod_print1.php
--- branches/kmq_dev/http/javascripts/mod_print1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_print1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -51,13 +51,13 @@
 $mb_module_id = "print1";
 $t = array('s');
@@ -110,7 +110,7 @@
@@ -157,7 +157,12 @@
+			coord[0],
+			pos[1],
+			pos[0],
+			coord[3]
@@ -180,7 +185,7 @@
 			cnt_urls++;
Modified: branches/kmq_dev/http/javascripts/mod_reload.php
--- branches/kmq_dev/http/javascripts/mod_reload.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_reload.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,25 +16,55 @@
-var mod_reload_img = new Image();
-mod_reload_img.src = "<?php  echo $e_src;  ?>";
-var mod_reload_img_over = new Image();
-mod_reload_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+ * Package: Reload
+ * Description:
+ * A button that reloads the whole window.
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public,
+ * > e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>', 'reload',
+ * > 2,1,'reload','img','../img/button_blink_red/reload_off.png', '',335,
+ * > 60,24,24,1,'','','','mod_reload.php','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/Reload');
+ * Help:
+ * http://www.mapbender.org/index.php/Reload
+ * Maintainer:
+ * http://www.mapbender.org/User:Vera_Schulze
+var Reload = function (options) {
+	var that = this;
+	var domElement = $("#" + options.id);
+	domElement.src = options.src;
+	if (!options.src) {
+		new Mb_exception(options.id + " requires a src.");
+	else {
+		$(domElement).mouseover(function () {
+			domElement.src = options.src.replace(/_off/,"_over");
+		}).mouseout(function () {
+		}).click(function () {
+		   that.reload();
+	 * Method: reload
+	 * Reloads the window.
+	this.reload = function () {
+		location.reload();
-function mod_reload(){
-    location.reload();
-function mod_reload_init(obj){
-	document.getElementById("reload").src = mod_reload_img_over.src;
-	obj.onmouseover = new Function("mod_reload_over()");
-	obj.onmouseout = new Function("mod_reload_out()");
-function mod_reload_over(){
-function mod_reload_out(){
-	document.getElementById("reload").src = mod_reload_img.src;
+var reload = new Reload(options);
Modified: branches/kmq_dev/http/javascripts/mod_renderGML.php
--- branches/kmq_dev/http/javascripts/mod_renderGML.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_renderGML.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,50 +1,51 @@
-<?php
-# http://www.mapbender.org/index.php/Monitor_Capabilities
-require_once(dirname(__FILE__)."/../classes/class_gml2.php");
-$gml_string = $_SESSION["GML"];
-if ($gml_string) {
-	$gml = new gml2();
-	$gml->parse_xml($gml_string);
-	$bbox = $gml->bbox;
-	echo "mb_registerInitFunctions('highlight_init()');\n";
-	echo "function highlight_init() {\n";
-	echo "var mf = new Array(";
-	for ($i=0; $i<count($e_target); $i++) {
-		if ($i>0) echo ", ";
-		echo "'".$e_target[$i]."'";
-	echo ");\n";
-	echo "hl = new Highlight(mf, 'GML_rendering', {'position':'absolute', 'top':'0px', 'left':'0px', 'z-index':" . GML_HIGHLIGHT_Z_INDEX . "});\n";
-	echo $gml->exportMemberToJS(0, false);
-	echo "hl.add(q);\n";
-	echo "hl.paint();\n";
-	echo "mb_registerSubFunctions('hl.paint()');\n";
-	echo "}\n";
-	$e = new mb_notice("renderGML: GML: " . $_SESSION["GML"] . "; EPSG: " . $_SESSION["epsg"] . "; BBOX: " . implode(", ", $bbox));
-	$_SESSION["GML"] = NULL;
-	$e = new mb_notice("renderGML: deleting GML...");
-else {
-	$e = new mb_notice("renderGML: no GML.");
+<?php
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+$gml_string = Mapbender::session()->get("GML");
+if ($gml_string) {
+	$gml = new gml2();
+	$gml->parse_xml($gml_string);
+	$bbox = $gml->bbox;
+	echo "mb_registerInitFunctions('highlight_init()');\n";
+	echo "function highlight_init() {\n";
+	echo "var mf = new Array(";
+	for ($i=0; $i<count($e_target); $i++) {
+		if ($i>0) echo ", ";
+		echo "'".$e_target[$i]."'";
+	echo ");\n";
+	echo "hl = new Highlight(mf, 'GML_rendering', {'position':'absolute', 'top':'0px', 'left':'0px', 'z-index':" . GML_HIGHLIGHT_Z_INDEX . "});\n";
+	echo $gml->exportMemberToJS(0, false);
+	echo "hl.add(q);\n";
+	echo "hl.paint();\n";
+	echo "mb_registerSubFunctions('hl.paint()');\n";
+	echo "}\n";
+	$e = new mb_notice("renderGML: GML: " . Mapbender::session()->get("GML") . "; EPSG: " . Mapbender::session()->get("epsg") . "; BBOX: " . implode(", ", $bbox));
+	Mapbender::session()->set("GML",NULL);
+	$e = new mb_notice("renderGML: deleting GML...");
+else {
+	$e = new mb_notice("renderGML: no GML.");
Modified: branches/kmq_dev/http/javascripts/mod_repaint.php
--- branches/kmq_dev/http/javascripts/mod_repaint.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_repaint.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_repaint.php
@@ -16,25 +16,21 @@
-var mod_repaint_img = new Image();
-mod_repaint_img.src = "<?php  echo $e_src;  ?>";
-var mod_repaint_img_over = new Image();
-mod_repaint_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function mod_repaint(){
-	zoom("<?php  echo $e_target[0];  ?>", true,0.999);
-function mod_repaint_init(obj){
-	document.getElementById("repaint").src = mod_repaint_img_over.src;
-	obj.onmouseover = new Function("mod_repaint_over()");
-	obj.onmouseout = new Function("mod_repaint_out()");
-function mod_repaint_over(){
-function mod_repaint_out(){
-	document.getElementById("repaint").src = mod_repaint_img.src;
+$(this).click(function () {
+	if (!options.target) {
+		return;
+	if (!Mapbender.modules[options.target]) {
+		return;
+	Mapbender.modules[options.target].zoom(true, 0.999);
+}).mouseover(function () {
+	if (options.src) {
+		this.src = options.src.replace(/_off/, "_over");
+}).mouseout(function () {
+		this.src = options.src;
Modified: branches/kmq_dev/http/javascripts/mod_resize_mapsize.php
--- branches/kmq_dev/http/javascripts/mod_resize_mapsize.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_resize_mapsize.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -90,7 +90,7 @@
 	var ind = getMapObjIndexByName("<?php  echo $e_target;  ?>");
 	var mapheight = frameHeight() - <?php echo $e_top ?> + parseInt(adjust_height);
 	var mapwidth = frameWidth() - map_frame_left - legend_width + parseInt(adjust_width) ;
-	var coords = mb_mapObj[ind].extent.split(",");
+	var coords = mb_mapObj[ind].extent.toString().split(",");
 	midcoordx=parseFloat((parseFloat(coords[2])-parseFloat(coords[0]))/2)+parseFloat(coords[0]);
 	midcoordy=parseFloat((parseFloat(coords[3])-parseFloat(coords[1]))/2)+parseFloat(coords[1]);
 	mb_mapObj[ind].setWidth(mapwidth);
Modified: branches/kmq_dev/http/javascripts/mod_sandclock.php
--- branches/kmq_dev/http/javascripts/mod_sandclock.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_sandclock.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,76 +16,136 @@
-echo "var mod_sandclock_target = '".$e_target[0]."';";
-include '../include/dyn_js.php';
-try{
-	if (mod_sandclock_image){}
-catch(e){
-	mod_sandclock_image = "../img/sandclock.gif";
+ * Package: Sandclock
+ * Description:
+ * Displays an arbitrary sandclock image on a map
+ * SQL:
+ * > e_height, e_z_index, e_more_styles, e_content, e_closeTag, e_js_file,
+ * > e_mb_mod, e_target, e_requires) VALUES ('<gui_id>', 'sandclock', '0002',
+ * > '1', 'displays a sand clock while waiting for requests', 'div', '',
+ * > '', '', '', '', '', '', '', '', 'div', 'mod_sandclock.php', '',
+ * > 'mapframe1', '');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<gui_id>', 'sandclock',
+ * > 'mod_sandclock_image', '../img/sandclock.gif',
+ * > 'define a sandclock-image', 'var');
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * mod_sandclock_img - *[optional]* the filename and path to the sandclock image
+var Sandclock = function (options) {
+	var that = this;
-var mod_sandclock_img = new Image();
-mod_sandclock_img.src = mod_sandclock_image;
+	// check if target is set correctly
+		new Mb_Exception(this.id + "requires a target.");
+		return;
+		new Mb_exception("Target " + options.target + " not found by " + this.id)
+	var map;
+	// element vars
+	if (!options.mod_sandclock_image) {
+		options.mod_sandclock_image = "../img/sandclock.gif";
-eventAfterMapRequest.register(function (obj) {
-	mod_sandclock(true,obj.myMapId);
+	var mod_sandclock_img = new Image();
+	mod_sandclock_img.src = options.mod_sandclock_image;
+	// constructor
+	eventAfterMapRequest.register(function (obj) {
+		that.show(obj.myMapId);
-function mod_sandclock(start,myMapId){
-	var ind = getMapObjIndexByName(mod_sandclock_target);
-	if(start){
+	var isInitialised = false;
+	var aktiv;
+	 * Method: show
+	 * Displays the sandclock
+	this.show = function (mapId) {
 		var temp = "<img src='"+mod_sandclock_img.src+"'>";
-		var map_el = mb_mapObj[ind].getDomElement();
-		if(!map_el.ownerDocument.getElementById(mb_mapObj[ind].elementName+"_sandclock")){
-			el_top = map_el.ownerDocument.createElement("div");
-			el_top.style.position = "absolute";
-			el_top.style.top = "0px";
-			el_top.style.left = "0px";
-			el_top.style.overflow = "hidden";
-			el_top.style.zIndex = "10";
-			el_top.style.visibility = "visible";
-			el_top.style.cursor = "crosshair";
-			el_top.id = mb_mapObj[ind].elementName+"_sandclock";
-			map_el.appendChild(el_top);
+		if (!isInitialised) {
+			map = Mapbender.modules[options.target];
+			var map_el = map.getDomElement();
+			if(!map_el.ownerDocument.getElementById(map.elementName+"_sandclock")){
+				el_top = map_el.ownerDocument.createElement("div");
+				el_top.style.position = "absolute";
+				el_top.style.top = "0px";
+				el_top.style.left = "0px";
+				el_top.style.overflow = "hidden";
+				el_top.style.zIndex = "1000";
+				el_top.style.visibility = "visible";
+				el_top.style.cursor = "crosshair";
+				el_top.id = map.elementName+"_sandclock";
+				map_el.appendChild(el_top);
+			isInitialised = true;
-		writeTag(mb_mapObj[ind].frameName, mb_mapObj[ind].elementName+"_sandclock", temp);
-		mb_arrangeElement("", mod_sandclock_target+"_sandclock", (mb_mapObj[ind].width/2 - 16), (mb_mapObj[ind].height/2 - 16));
-	// if myMapId is nopt given, the sandclock has to be turned off manually
-	// by calling mod_sandclock_off. Usually this is done in a callback
-	// function.
-	if (typeof myMapId !== "undefined") {
-		aktiv = setTimeout(function () {
-			mod_sandclock('',myMapId);
+		writeTag(map.frameName, map.elementName+"_sandclock", temp);
+		mb_arrangeElement("", options.target+"_sandclock", (map.width/2 - 16), (map.height/2 - 16));
+		// if mapId is not given, the sandclock has to be turned off manually
+		// by calling hide(). Usually this is done in a callback
+		// function.
+		if (typeof mapId !== "undefined") {
+			aktiv = setTimeout(function () {
+				that.show(mapId);
 			},10);
-		var myMapIdArray = myMapId.split(",");
-		var complete = true;
-		var myMapId;
-		for (var i = 0; i < myMapIdArray.length && complete; i++) {
-			myMapId = myMapIdArray[i];
-			var myDoc = mb_mapObj[ind].getDomElement().ownerDocument;
-			if(myDoc.getElementById(myMapId) &&
-				!myDoc.getElementById(myMapId).complete) {
-				complete = false;
+			var mapIdArray = mapId.split(",");
+			var complete = true;
+			var mapId;
+			for (var i = 0; i < mapIdArray.length && complete; i++) {
+				mapId = mapIdArray[i];
+				var myDoc = map.getDomElement().ownerDocument;
+				if(myDoc.getElementById(mapId) &&
+					!myDoc.getElementById(mapId).complete) {
+					complete = false;
+			if (complete) {
+				clearTimeout(aktiv);
+				that.hide(map);
-		if (complete) {
-			clearTimeout(aktiv);
-			mod_sandclock_off(mb_mapObj[ind]);
+	 * Method: hide
+	 * Hides the sandclock
+	this.hide = function () {
+		writeTag(map.frameName, map.elementName+"_sandclock", "");
-function mod_sandclock_off() {
-	var mapObj = getMapObjByName(mod_sandclock_target);
-	writeTag(mapObj.frameName, mapObj.elementName+"_sandclock", "");
+var sandclock = new Sandclock(options);
Modified: branches/kmq_dev/http/javascripts/mod_saveWmcKml.php
--- branches/kmq_dev/http/javascripts/mod_saveWmcKml.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_saveWmcKml.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,108 +1,108 @@
-<?php
-# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
-# http://www.mapbender.org/index.php/mod_savewmc.php
-echo "mod_savewmc_target = '".$e_target[0]."';";
-var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
-//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function mod_saveWmcKml(obj){
-	current_user = "<?php echo $_SESSION["mb_user_id"]; ?>";
-	current_password = "<?php echo $_SESSION["mb_user_password"];?>";
-	current_gui = "<?php echo $gui_id;?>";
-	alert('Please set the meeting point by clicking the map.');
-	var ind = getMapObjIndexByName(mod_savewmc_target);
-	var el = frames[mod_savewmc_target].document;
-	el.onmousedown = mod_getMousePos;
-	el.onmouseup = null;
-	el.onmousemove = null;
-	el.onmouseover = null;
-function mod_getMousePos(e) {
-	mb_getMousePos(e,mod_savewmc_target);
-	var q = new Point(clickX,clickY);
-	var realWorldPos = mapToReal(mod_savewmc_target,q);
-	el.onmousedown = null;
-	//alert(realWorldPos);
-	//document.sendData.target = "_blank";
-	//document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
-	//document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
-	//document.sendData.submit();
-	saveWindow = open("", "save", "width=400, height=300, resizable, dependent=yes, scrollbars=yes");
-	saveWindow.document.open("text/html");
-	var cssLink = saveWindow.document.createElement("link");
-	cssLink.setAttribute("href", wfsCssUrl);
-	cssLink.setAttribute("type", "text/css");
-	cssLink.setAttribute("rel", "stylesheet");
-	var cssTmp = saveWindow.document.getElementsByTagName("head")[0];
-	cssTmp.appendChild(cssLink);
-	var wmc_title = "meetingpoint";
-	var icon = "http://wms1.ccgis.de/mapbender_dev/img/pin.png";
-	var str = "";
-	var onclick = "wmcid=window.opener.mod_savewmc('"+wmc_title+"');";
-	onclick += "document.sendData.action = '../javascripts/mod_insertKmlIntoDb.php?<?php echo SID;?>';";
-	onclick += "document.sendData.data.value = wmcid + '____" + realWorldPos.x + "____" + realWorldPos.y + "____"+ icon + "____<?php echo $gui_id;?>';";
-	onclick += "document.sendData.submit();"
-	str += "<form name='sendData' method='post'>\n";
-	str += "<table>\n";
-	str += "<tr>\n";
-	str += "<td>Name</td>\n";
-	str += "<td><input type='text' name='name'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Strasse</td>\n";
-	str += "<td><input type='text' name='street'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>PLZ</td>\n";
-	str += "<td><input type='text' name='postcode'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Ort</td>\n";
-	str += "<td><input type='text' name='city'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Webseite</td>\n";
-	str += "<td><input type='text' name='website'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Beschreibung</td>\n";
-	str += "<td><textarea name='description'></textarea></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td colspan=2><input type='button' value='URL generieren' name='generateUrl' onclick=\""+onclick+"\"></td>\n";
-	str += "</tr>\n";
-	str += "</table>\n";
-	str += "<input type=hidden name=data>\n";
-	str += "</form>";
-	saveWindow.document.write(str);
-	saveWindow.document.close();
+<?php
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
+echo "mod_savewmc_target = '".$e_target[0]."';";
+var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
+//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+function mod_saveWmcKml(obj){
+	current_user = "<?php echo Mapbender::session()->get("mb_user_id"); ?>";
+	current_password = "<?php echo Mapbender::session()->get("mb_user_password");?>";
+	current_gui = "<?php echo $gui_id;?>";
+	alert('Please set the meeting point by clicking the map.');
+	var ind = getMapObjIndexByName(mod_savewmc_target);
+	var el = frames[mod_savewmc_target].document;
+	el.onmousedown = mod_getMousePos;
+	el.onmouseup = null;
+	el.onmousemove = null;
+	el.onmouseover = null;
+function mod_getMousePos(e) {
+	mb_getMousePos(e,mod_savewmc_target);
+	var q = new Point(clickX,clickY);
+	var realWorldPos = mapToReal(mod_savewmc_target,q);
+	el.onmousedown = null;
+	//alert(realWorldPos);
+	//document.sendData.target = "_blank";
+	//document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
+	//document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
+	//document.sendData.submit();
+	saveWindow = open("", "save", "width=400, height=300, resizable, dependent=yes, scrollbars=yes");
+	saveWindow.document.open("text/html");
+	var cssLink = saveWindow.document.createElement("link");
+	cssLink.setAttribute("href", wfsCssUrl);
+	cssLink.setAttribute("type", "text/css");
+	cssLink.setAttribute("rel", "stylesheet");
+	var cssTmp = saveWindow.document.getElementsByTagName("head")[0];
+	cssTmp.appendChild(cssLink);
+	var wmc_title = "meetingpoint";
+	var icon = "http://wms1.ccgis.de/mapbender_dev/img/pin.png";
+	var str = "";
+	var onclick = "wmcid=window.opener.mod_savewmc('"+wmc_title+"');";
+	onclick += "document.sendData.action = '../javascripts/mod_insertKmlIntoDb.php?<?php echo SID;?>';";
+	onclick += "document.sendData.data.value = wmcid + '____" + realWorldPos.x + "____" + realWorldPos.y + "____"+ icon + "____<?php echo $gui_id;?>';";
+	onclick += "document.sendData.submit();"
+	str += "<form name='sendData' method='post'>\n";
+	str += "<table>\n";
+	str += "<tr>\n";
+	str += "<td>Name</td>\n";
+	str += "<td><input type='text' name='name'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Strasse</td>\n";
+	str += "<td><input type='text' name='street'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>PLZ</td>\n";
+	str += "<td><input type='text' name='postcode'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Ort</td>\n";
+	str += "<td><input type='text' name='city'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Webseite</td>\n";
+	str += "<td><input type='text' name='website'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Beschreibung</td>\n";
+	str += "<td><textarea name='description'></textarea></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td colspan=2><input type='button' value='URL generieren' name='generateUrl' onclick=\""+onclick+"\"></td>\n";
+	str += "</tr>\n";
+	str += "</table>\n";
+	str += "<input type=hidden name=data>\n";
+	str += "</form>";
+	saveWindow.document.write(str);
+	saveWindow.document.close();
\ No newline at end of file
Modified: branches/kmq_dev/http/javascripts/mod_savewmc.php
--- branches/kmq_dev/http/javascripts/mod_savewmc.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_savewmc.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,82 +1,82 @@
-<?php
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-include(dirname(__FILE__) . "/../include/dyn_js.php");
-function setOnUnload() {
-	if (ie) {
-		document.getElementsByTagName('body')[0].onunload = function() {
-			var x = new Function ("", "mod_savewmc_session()"); x();
-	else {
-		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
-try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
-if (saveInSession == 1) {
-	eventAfterMapRequest.register(function () {
-		mod_savewmc_session();
-//	mb_registerInitFunctions('setOnUnload()');
-<?php
-if ($e_src) {
-	sprintf("var mod_savewmc_img = new Image();
-			mod_savewmc_img.src = '%s';", $e_src);
-function mod_savewmc_session(){
-	sendMapDataToServer("session", 1, function(result, status) {});
-function mod_savewmc(title){
-	var generalTitle = title ? title : prompt("Save WMC as...");
-	if (generalTitle != "" && generalTitle != null) {
-		sendMapDataToServer(generalTitle, 0, function(result, status) {alert(status + ": " + result);});
-function sendMapDataToServer(generalTitle, storeInSession, callbackFunction) {
-	var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
-	var	extensionDataString = "";
-	if (currentWmcExtensionData != null) {
-		extensionDataString = $.toJSON(currentWmcExtensionData);
-	if (storeInSession) {
-		$.ajaxSetup({async:false});
-	$.post("../php/mod_savewmc_server.php", {
-		"saveInSession":storeInSession,
-		"generalTitle":generalTitle,
-		"extensionData":extensionDataString,
-		"mapObject":$.toJSON(mb_mapObj)
-	}, callbackFunction);
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+include(dirname(__FILE__) . "/../include/dyn_js.php");
+function setOnUnload() {
+	if (ie) {
+		document.getElementsByTagName('body')[0].onunload = function() {
+			var x = new Function ("", "mod_savewmc_session()"); x();
+	else {
+		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
+try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
+if (saveInSession == 1) {
+	eventAfterMapRequest.register(function () {
+		mod_savewmc_session();
+//	mb_registerInitFunctions('setOnUnload()');
+<?php
+if ($e_src) {
+	sprintf("var mod_savewmc_img = new Image();
+			mod_savewmc_img.src = '%s';", $e_src);
+function mod_savewmc_session(){
+	sendMapDataToServer("session", 1, function(result, status) {});
+function mod_savewmc(title){
+	var generalTitle = title ? title : prompt("Save WMC as...");
+	if (generalTitle != "" && generalTitle != null) {
+		sendMapDataToServer(generalTitle, 0, function(result, status) {alert(status + ": " + result);});
+function sendMapDataToServer(generalTitle, storeInSession, callbackFunction) {
+	var user = "<?php echo Mapbender::session()->get("mb_user_id"); ?>";
+	var	extensionDataString = "";
+	if (currentWmcExtensionData != null) {
+		extensionDataString = $.toJSON(currentWmcExtensionData);
+	if (storeInSession) {
+		$.ajaxSetup({async:false});
+	$.post("../php/mod_savewmc_server.php", {
+		"saveInSession":storeInSession,
+		"generalTitle":generalTitle,
+		"extensionData":extensionDataString,
+		"mapObject":$.toJSON(mb_mapObj)
+	}, callbackFunction);
Modified: branches/kmq_dev/http/javascripts/mod_scaleHint.php
--- branches/kmq_dev/http/javascripts/mod_scaleHint.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_scaleHint.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -41,14 +41,19 @@
 				var newScale = mod_scaleHint_max;
 			var ind = getMapObjIndexByName(frameName);
-			var arrayBBox = mb_mapObj[ind].extent.split(",");
+			var arrayBBox = mb_mapObj[ind].extent.toString().split(",");
 			var x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
 			var y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
 			var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
 			var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
 			var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
 			var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
-			mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+			mb_mapObj[ind].extent = new Extent(
+				minx,
+				miny,
+				maxx,
+				maxy
 	return true;
Modified: branches/kmq_dev/http/javascripts/mod_scaleSel.php
--- branches/kmq_dev/http/javascripts/mod_scaleSel.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_scaleSel.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_scaleSel.php
-# Copyright (C) 2002 CCGIS
@@ -16,22 +16,27 @@
+var mod_scaleSelect_target = options.target;
-echo "var mod_scaleSelect_target = '".$e_target[0]."';";
 	mod_scaleSelect_val(obj.map.elementName);
 function mod_scaleSelect(obj){
+	var myMapObj = Mapbender.modules[mod_scaleSelect_target];
 	var ind = obj.selectedIndex;
-	mb_repaintScale(mod_scaleSelect_target,null,null,obj.options[ind].value);
+	myMapObj.repaintScale(null,null,obj.options[ind].value);
 function mod_scaleSelect_val(frameName){
 	if(frameName == mod_scaleSelect_target){
-		var ind = getMapObjIndexByName(frameName);
-		var scale = mb_mapObj[ind].getScale();
+		var scale = myMapObj.getScale();
 		document.getElementById("scaleSelect").options[0].text = "1 : " + scale;
 		document.getElementById("scaleSelect").options[0].selected = true;
+$(this).change(function () {
+	mod_scaleSelect(this);
Modified: branches/kmq_dev/http/javascripts/mod_scaleText.php
--- branches/kmq_dev/http/javascripts/mod_scaleText.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_scaleText.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -31,7 +31,7 @@
 		return;
@@ -39,7 +39,12 @@
 	var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale.value);
 	var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale.value);
 	var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale.value);
+		minx,
+		miny,
+		maxx,
+		maxy
 	setMapRequest(frameName);
 	scale.value = "";
Modified: branches/kmq_dev/http/javascripts/mod_selectMapsize.php
--- branches/kmq_dev/http/javascripts/mod_selectMapsize.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_selectMapsize.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -27,8 +27,13 @@
 	var w = parseInt(p[0]) ;
 	var h = parseInt(p[1]);
 	var pos = makeClickPos2RealWorldPos(mod_selectMapsize_target,w,h);
-	mb_mapObj[ind].extent = coords[0] + "," + pos[1] + "," + pos[0] + "," + coords[3];
+		coords[0],
+		pos[1],
+		pos[0],
+		coords[3]
 	mb_mapObj[ind].width = w;
 	mb_mapObj[ind].height = h;
 	document.getElementById(mod_selectMapsize_target).style.width = mb_mapObj[ind].width;
Modified: branches/kmq_dev/http/javascripts/mod_setBBOX1.php
--- branches/kmq_dev/http/javascripts/mod_setBBOX1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_setBBOX1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -25,7 +25,7 @@
 function mod_setBBOX_init(){
 	var my_target = mod_setBBOX_target.split(",");
-	var myBBOX = "<?php echo $_SESSION['mb_myBBOX'] ?>";
+	var myBBOX = "<?php echo Mapbender::session()->get("mb_myBBOX") ?>";
 	for(var i=0; i<my_target.length; i++){
 		if(myBBOX != ""){
 			var mapObj = getMapObjByName(my_target);
Modified: branches/kmq_dev/http/javascripts/mod_setPOI2Scale.php
--- branches/kmq_dev/http/javascripts/mod_setPOI2Scale.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_setPOI2Scale.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,51 +1,51 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_setPOI2Scale.php
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-echo "var mod_setPOI2Scale_target = '".$e_target[0]."';";
-try{
-	if (mod_setPOI2Scale_defScale){}
-catch(e){
-	mod_setPOI2Scale_defScale = 5000;
-eventInit.register(function () {
-	mod_setPOI2Scale();
-function mod_setPOI2Scale(){
-	var my_target = mod_setPOI2Scale_target.split(",");
-	var myPOI = "<?php echo $_SESSION['mb_myPOI2SCALE'] ?>";
-	if(myPOI && myPOI != ""){
-		var coord = myPOI.split(",");
-		if(coord.length == 2){
-			coord[2] = mod_setPOI2Scale_defScale;
-		for(var i=0; i<my_target.length; i++){
-			if(myPOI != ""){
-				mb_repaintScale(my_target[i], coord[0], coord[1], coord[2]);
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_setPOI2Scale.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+echo "var mod_setPOI2Scale_target = '".$e_target[0]."';";
+try{
+	if (mod_setPOI2Scale_defScale){}
+catch(e){
+	mod_setPOI2Scale_defScale = 5000;
+eventInit.register(function () {
+	mod_setPOI2Scale();
+function mod_setPOI2Scale(){
+	var my_target = mod_setPOI2Scale_target.split(",");
+	var myPOI = "<?php echo Mapbender::session()->get("mb_myPOI2SCALE") ?>";
+	if(myPOI && myPOI != ""){
+		var coord = myPOI.split(",");
+		if(coord.length == 2){
+			coord[2] = mod_setPOI2Scale_defScale;
+		for(var i=0; i<my_target.length; i++){
+			if(myPOI != ""){
+				mb_repaintScale(my_target[i], coord[0], coord[1], coord[2]);
Modified: branches/kmq_dev/http/javascripts/mod_switchLocale_noreload.php
--- branches/kmq_dev/http/javascripts/mod_switchLocale_noreload.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_switchLocale_noreload.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,54 +1,54 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/localeSwitch
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_locale.php");
-if (!USE_I18N) {
-	echo "var languages = '" . $_SESSION["mb_lang"] . "';";
-function validate_locale(){
-	var index = document.getElementById("language").selectedIndex;
-	var lang = document.getElementById("language").options[index].value;
-	mb_ajax_post("../php/mod_setLocale.php", {"lang":lang}, function(result, status) {
-		Mapbender.locale = result;
-		eventLocalize.trigger();
-	var localeSelectNode = document.getElementById('language');
-	var languageArray = languages.split(",");
-	var selected = false;
-	for (var i = 0; i < languageArray.length; i++) {
-		if (languageArray[i] == '<?php echo $_SESSION["mb_lang"];?>') {
-			selected = true;
-		else {
-			selected = false;
-		var currentOption = new Option(languageArray[i], languageArray[i], selected, selected);
-		localeSelectNode.options[i] = currentOption;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/localeSwitch
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_locale.php");
+if (!USE_I18N) {
+	echo "var languages = '" . Mapbender::session()->get("mb_lang") . "';";
+function validate_locale(){
+	var index = document.getElementById("language").selectedIndex;
+	var lang = document.getElementById("language").options[index].value;
+	mb_ajax_post("../php/mod_setLocale.php", {"lang":lang}, function(result, status) {
+		Mapbender.locale = result;
+		eventLocalize.trigger();
+	var localeSelectNode = document.getElementById('language');
+	var languageArray = languages.split(",");
+	var selected = false;
+	for (var i = 0; i < languageArray.length; i++) {
+		if (languageArray[i] == '<?php echo Mapbender::session()->get("mb_lang");?>') {
+			selected = true;
+		else {
+			selected = false;
+		var currentOption = new Option(languageArray[i], languageArray[i], selected, selected);
+		localeSelectNode.options[i] = currentOption;
Modified: branches/kmq_dev/http/javascripts/mod_tab.php
--- branches/kmq_dev/http/javascripts/mod_tab.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_tab.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -30,7 +30,7 @@
 echo "var tab_titles = [];\n";
 for ($i=0; $i < count($tab_ids); $i++) {
 	$sql = "SELECT gettext($1, e_title) AS e_title FROM gui_element WHERE fkey_gui_id = $2 AND e_id = $3";
-	$v = array($_SESSION["mb_lang"], $gui_id, $tab_ids[$i]);
+	$v = array(Mapbender::session()->get("mb_lang"), $gui_id, $tab_ids[$i]);
 	$t = array("s", "s", "s");
Modified: branches/kmq_dev/http/javascripts/mod_usemap.php
--- branches/kmq_dev/http/javascripts/mod_usemap.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_usemap.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/UseMap
@@ -24,11 +24,11 @@
 var um_draw;
 mb_registerSubFunctions('mod_usemap_init()');
-mb_registerInitFunctions("um_init()")
+mb_registerInitFunctions("um_init()");
 function mod_usemap_init(){
 	var ind = getMapObjIndexByName(mod_usemap_target);
-	var extent = mb_mapObj[ind].extent;
+	var extent = mb_mapObj[ind].extent.toString();
 	var url = "../php/mod_usemap.php?url="
 	url += escape(mod_usemap_wfs + "&BBOX=" + extent);
 	url += "&extent=" + extent;
@@ -37,7 +37,8 @@
 	url += "&gui_id=<?php echo $gui_id;?>";
 	url += "&e_id=<?php echo $e_id;?>";
 	document.getElementById('usemap').src = url;
-	var myImg = window.frames[mod_usemap_target].document.getElementById("um_img").style;
+	var myImg = document.getElementById("um_img").style;
+	myImg.zIndex = "10000";
 	myImg.width = mb_mapObj[ind].width;
 	myImg.height = mb_mapObj[ind].height;
@@ -45,12 +46,12 @@
 	var str = "";
 	for(var i=0; i<title.length; i++){
 		var pos = makeRealWorld2mapPos(mod_usemap_target,x[i],y[i]);
-		str += "<AREA  onmouseover='parent.over(event, \"" + title[i] + "\", this)' ";
+		str += "<AREA onmouseover='parent.over(event, \"" + title[i] + "\", this)' ";
 		str += "onmouseout=parent.out(this) shape='circle'  coords='";
 		str += Math.round(pos[0]) + "," + Math.round(pos[1]) + "," + mod_usemap_px + "'";
 		str += " href='#'>";
-	writeTag(mod_usemap_target, 'um', str);
+	writeTag('', 'um', str);
 /* Opacity for hilighting */
@@ -64,7 +65,7 @@
 	var Xcoords = '';
 	for (var z = 0; z<coords.length; z=z+2){
 		if (z > 0){
-			Xcoords += ', ';
+			Xcoords += ', ';
 		Xcoords += parseInt(coords[z]);
@@ -106,9 +107,9 @@
 			canvas.paint();
 			canvas.setColor(cw_bndcolor);
 			canvas.drawEllipse(parseInt(c[0])-mod_usemap_px/2,parseInt(c[1])-mod_usemap_px/2,parseInt(c[2]),parseInt(c[2]));
-			canvas.paint();
+			canvas.paint();
-		canvasHasDrawing = true;
+		canvasHasDrawing = true;
 		return true;
@@ -127,7 +128,7 @@
 		isOver = area;
 		setFocus(area);
-	mb_arrangeElement(mod_usemap_target, 'um_title', parseInt(coords[0])+mod_usemap_px, parseInt(coords[1])+mod_usemap_px);
+	mb_arrangeElement('', 'um_title', parseInt(coords[0])+mod_usemap_px, parseInt(coords[1])+mod_usemap_px);
@@ -140,9 +141,10 @@
 function um_init(){
-	um_title = window.frames[mod_usemap_target].document.getElementById("um_title"); /* tooltip */
-	um_draw = window.frames[mod_usemap_target].document.getElementById("um_draw"); /* tooltip */
-	canvas = new jsGraphics('um_draw', window.frames['mapframe1']);
+	um_title = document.getElementById("um_title"); /* tooltip */
+	um_draw = document.getElementById("um_draw"); /* tooltip */
+	var mapObjInd = getMapObjIndexByName(mod_usemap_target);
+	canvas = new jsGraphics('um_draw', mb_mapObj[mapObjInd].getDomElement().frameName ? window.frames[mapframe] : window);
 	canvas.setStroke(2);
 	canvasHasDrawing = false;
 	isOver = false;
Modified: branches/kmq_dev/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/kmq_dev/http/javascripts/mod_wfs_gazetteer_client.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_wfs_gazetteer_client.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -125,8 +125,12 @@
 // end of button management spatialRequest ///////////
-parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initModWfsGazetteer()");
-parent.mb_registerInitFunctions("window.frames['"+this.name+"'].init_wfsSpatialRequest()");
+parent.Mapbender.events.init.register(function () {
+	initModWfsGazetteer();
+	init_wfsSpatialRequest();
 function init_wfsSpatialRequest() {
 		buttonWfs_id = [];
@@ -731,7 +735,7 @@
 	else{
 		if(inputNotEnough.length==0){
-			var andConditions = "";
+			var andConditions = [];
 			var el = global_wfsConfObj[global_selectedWfsConfId].element;
 			var srs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
@@ -867,49 +871,50 @@
 					if(a.length > 1){
-						andConditions += "<Or>" + orConditions + "</Or>";
+						andConditions.push("<Or>" + orConditions + "</Or>");
 					else {
-						andConditions += orConditions;
+						andConditions.push(orConditions);
 			if(spatialRequestGeom!=null){
+				var currentAndCondition = "";
 				if(spatialRequestGeom.geomType == "polygon"){
 					if(buttonPolygon.filteroption=='within'){
-						andConditions += "<Within><ogc:PropertyName>";
+						currentAndCondition = "<Within><ogc:PropertyName>";
 						for (var j=0; j < el.length; j++) {
 							if(el[j]['f_geom']==1){
 								var elementName = el[j]['element_name'];
-								andConditions += el[j]['element_name'];
+								currentAndCondition += el[j]['element_name'];
-						andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
-						andConditions += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+						currentAndCondition += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
+						currentAndCondition += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
 						for(var k=0; k<spatialRequestGeom.count(); k++){
-							if(k>0)	andConditions += " ";
-							andConditions += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
+							if(k>0)	currentAndCondition += " ";
+							currentAndCondition += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
-						andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
-						andConditions += "</gml:Polygon></Within>";
+						currentAndCondition += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+						currentAndCondition += "</gml:Polygon></Within>";
 					else if(buttonPolygon.filteroption=='intersects'){
-						andConditions += "<Intersects><ogc:PropertyName>";
+						currentAndCondition = "<Intersects><ogc:PropertyName>";
-						andConditions += "</gml:Polygon></Intersects>";
+						currentAndCondition += "</gml:Polygon></Intersects>";
 				else if(spatialRequestGeom.geomType == "line"){
@@ -917,48 +922,48 @@
 					rectangle = spatialRequestGeom.getBBox();
 					if(buttonRectangle.filteroption=='within'){
-						andConditions += rectangle[0].x+","+rectangle[0].y;
-						andConditions += " ";
-						andConditions += rectangle[0].x+","+rectangle[1].y;
-						andConditions += rectangle[1].x+","+rectangle[1].y;
-						andConditions += rectangle[1].x+","+rectangle[0].y;
+						currentAndCondition += rectangle[0].x+","+rectangle[0].y;
+						currentAndCondition += " ";
+						currentAndCondition += rectangle[0].x+","+rectangle[1].y;
+						currentAndCondition += rectangle[1].x+","+rectangle[1].y;
+						currentAndCondition += rectangle[1].x+","+rectangle[0].y;
 					else if(buttonRectangle.filteroption=='intersects'){
 				else if(spatialRequestGeom.geomType == "point"){
@@ -973,28 +978,33 @@
 					var realWorld2 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
 					var realWorld3 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYAddPix);
 					var realWorld4 = parent.makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
-					andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
-					andConditions += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
-					andConditions += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
-					andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
+					currentAndCondition += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+					currentAndCondition += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
+					currentAndCondition += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+					currentAndCondition += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
 				//andConditions += "<ogc:Not><ogc:PropertyIsNull>";
 	            //andConditions += "<ogc:PropertyName>" + elementName + "</ogc:PropertyName>";
 	       		//andConditions += "</ogc:PropertyIsNull></ogc:Not>";
+				if (currentAndCondition !== "") {
+					andConditions.push(currentAndCondition);
-			if (filterParameterCount > 1 || spatialRequestGeom != null) {
-				andConditions = "<And>" + andConditions + "</And>";
+			var andConditionString = andConditions.join("");
+			if (andConditions.length > 1) {
+				andConditionString = "<And>" + andConditionString + "</And>";
-			var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
+			var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditionString+"</ogc:Filter>";
 			document.getElementById("res").innerHTML = "<table><tr><td><img src='"+progressIndicatorImg+"'></td><td>"+progressIndicatorText+"</td></tr></table>";
 			var parameters = {
@@ -1288,6 +1298,6 @@
 <div name='displaySpatialButtons' id='displaySpatialButtons' style='width:180px;margin-top:5px;background-color:#FFFFFF;'></div>
 <form name='wfsForm' id='wfsForm' onsubmit='return validate()'>
 </form>
-<div class='resultDiv' name='res' id='res' style='width:180px'></div>
+<div name='res' id='res' style='width:180px'></div>
 </body>
 </html>
Modified: branches/kmq_dev/http/javascripts/mod_zoomCoords.php
--- branches/kmq_dev/http/javascripts/mod_zoomCoords.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_zoomCoords.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,7 +1,7 @@
 <?php
 #$Id$
 # http://www.mapbender.org/Mapbender_without_iframes
@@ -18,50 +18,46 @@
-include(dirname(__FILE__)."/../include/dyn_js.php");
+var mod_zoomCoords_target = options.target;
 try{
-	if (zoomCoords_permanentHighlight){}
+	if (options.zoomCoords_permanentHighlight){}
 catch(e){
-	zoomCoords_permanentHighlight = 'false';
+	options.zoomCoords_permanentHighlight = 'false';
-var mod_zoomCoords_target = '<?php echo $e_target[0];?>';
-mod_zoomCoords_target = mod_zoomCoords_target.split(',');
-function zoomCoordinate(x,y){
+function zoomCoordinate (x,y) {
    x=x.replace(",",".");
    y=y.replace(",",".");
    document.zoomCoordsForm.X.value=x;
    document.zoomCoordsForm.Y.value=y;
-   if (isNaN(x)==true || isNaN(y)==true){
+   if (isNaN(x)==true || isNaN(y)==true) {
        alert ("<?php echo _mb("Please type a number.");?>");
-   }else{
-	   if(zoomCoords_permanentHighlight =='true'){
+   else {
+	   if(options.zoomCoords_permanentHighlight =='true'){
 		   setPermanentMarker(x,y);
-  		hideHighlight()
-      	zoom(mod_zoomCoords_target[0],true, 1.0,x,y);
+  		hideHighlight();
+      	Mapbender.Modules[mod_zoomCoords_target[0]].zoom(true, 1.0, x, y);
 function highlight(x, y){
-	if(x!='' && y!=''){
+	if (x!='' && y!='') {
-	   else{
+	   else {
 			for(var i=0;i<mod_zoomCoords_target.length;i++){
 				mb_showHighlight(mod_zoomCoords_target[i],x,y);
@@ -80,28 +76,34 @@
  	mod_permanentHighlight_x = parseFloat(x);
    	mod_permanentHighlight_y = parseFloat(y);
    	mod_permanentHighlight_text = x + ' / '+ y;
    	mod_permanentHighlight_init();
-parent.eventInitMap.register(function zoomCoorsInit(){
-	var el = document.getElementById("zoomCoords");
-	if(el){
-		el.innerHTML="<?php
-echo "<form style='font-family : Arial, Helvetica, sans-serif;font-size: 11px;' name='zoomCoordsForm' action='" . $PHP_SELF . "?".SID."' method='post'>";
-#coordinates
-   # Deutsche Version
+parent.eventInitMap.register(function zoomCoordsInit(){
+	if($(this)){
+		$("<form />").attr({"id":"zoomCoordsForm","name":"zoomCoordsForm","method":"post"}).appendTo($("#zoomCoords"));
+		$("<span />").attr({"id":"spanLon","name":"spanLon"}).appendTo($("#zoomCoordsForm"));
+		$("<span />").attr({"id":"spanLat","name":"spanLat"}).appendTo($("#zoomCoordsForm"));
+		$("<input type='text'/>").attr({"id":"fieldX","name":"X"}).appendTo($("#zoomCoordsForm"));
+		$("<input type='text'/>").attr({"id":"fieldY","name":"Y"}).appendTo($("#zoomCoordsForm"));
+		$("<input type='button'/>").attr({"id":"buttonZoomCoord","name":"buttonZoomCoord","value":"<?php echo _mb("ok"); ?>"}).appendTo($("#zoomCoordsForm"));
-   # English Version
-      echo "<span style='position: absolute;left: 5px;top:5px;color: Gray;'>"._mb("Longitude").":</span>";
-      echo "<span style='position: absolute;left: 80px;top:5px;color: Gray;'>"._mb("Latitude").":</span>";
-      echo "<input style='position: absolute;left:5px;top:20px;color: Gray;width:65px;border: solid thin;height:20px;' type='text' name='X'>";
-      echo "<input style='position: absolute;left:80px;top:20px;color: Gray;width:65px;border: solid thin;height:20px;'class='texty' type='text' name='Y'>";
-      echo "<input style='position: absolute;left:150px;top:20px;color: Gray;border: solid thin;height:20px;' type='button' value='"._mb("ok")."' onclick='zoomCoordinate(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value); highlight(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value)' onmouseover='highlight(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value)' onmouseout='hideHighlight(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value)' >";
+		$("#zoomCoordsForm").css({"font-family":"Arial, Helvetica, sans-serif","font-size":"11px"});
+		$("#spanLon").css({"position":"absolute","left":"5px","top":"5px","color":"Gray"}).text("<?php echo _mb("Longitude");?>");
+		$("#spanLat").css({"position":"absolute","left":"80px","top":"5px","color":"Gray"}).text("<?php echo _mb("Latitude");?>");
+		$("#fieldX").css({"position":"absolute","left":"5px","top":"20px","color":"Gray","width":"65px","border":"solid thin","height":"20px"});
+		$("#fieldY").css({"position":"absolute","left":"80px","top":"20px","color":"Gray","width":"65px","border":"solid thin","height":"20px"});
+		$("#buttonZoomCoord").css({"position":"absolute","left":"150px","top":"20px","color":"Gray","border":"solid thin","height":"20px"});
-echo "</form>";
+		$("#buttonZoomCoord").click(function () {
+			zoomCoordinate(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value);
+			highlight(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value);
+		}).mouseover(function () {
+			hideHighlight(document.zoomCoordsForm.X.value, document.zoomCoordsForm.Y.value);
Modified: branches/kmq_dev/http/javascripts/mod_zoomFull.php
--- branches/kmq_dev/http/javascripts/mod_zoomFull.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_zoomFull.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,31 +1,49 @@
 <?php
 #$Id$
 #$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomFull.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-   var mod_zoomFull_img = new Image();
-   mod_zoomFull_img.src = "<?php  echo $e_src;  ?>";
-   var mod_zoomFull_img_over = new Image();
-   mod_zoomFull_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+ * Package: zoomFull
+ * Description:
+ * Click button to zoom to the full extent of the BoundingBox.
+ * Files:
+ *  - http/javascripts/mod_zoomFull.php
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','zoomFull',2,1,
+ * > 'zoom to full extent button','Display complete map','img',
+ * > '../img/button_blink_red/zoomFull_off.png','',335,60,24,24,2,'','','',
+ * > 'mod_zoomFull.php','','mapframe1','',
+ * >'http://www.mapbender.org/index.php/ZoomFull');
+ * Help:
+ * http://www.mapbender.org/ZoomFull
+ * Maintainer:
+ * http://www.mapbender.org/User:Verena_Diewald
-function mod_zoomFull(){
-	var frameName = "<?php  echo $e_target[0];  ?>"
-    var ind = this.getMapObjIndexByName(frameName);
-	mb_mapObj[ind].zoomFull();
-function mod_zoomFull_init(obj){
-   document.getElementById("zoomFull").src = mod_zoomFull_img_over.src;
-   obj.onmouseover = new Function("mod_zoomFull_over()");
-   obj.onmouseout = new Function("mod_zoomFull_out()");
-function mod_zoomFull_over(){
-function mod_zoomFull_out(){
-   document.getElementById("zoomFull").src = mod_zoomFull_img.src;
+		return;
+		return;
+	Mapbender.modules[options.target].zoomFull();
Modified: branches/kmq_dev/http/javascripts/mod_zoomIn1.php
--- branches/kmq_dev/http/javascripts/mod_zoomIn1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_zoomIn1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,30 +16,45 @@
-var zoomin1Id = '<?php echo $e_id; ?>';
-var mod_zoom1_img = new Image();
-mod_zoom1_img.src = "<?php  echo $e_src;  ?>";
-var mod_zoom1_img_over = new Image();
-mod_zoom1_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-var $zoomin1Button = $("#"+zoomin1Id);
-$zoomin1Button.click(function () {
-	zoom("<?php  echo $e_target[0];  ?>", true, 2.0);
-function mod_zoomIn1_init(obj){
-	document.getElementById("zoomIn1").src = mod_zoom1_img_over.src;
-	obj.onmouseover = new Function("mod_zoomIn1_over()");
-	obj.onmouseout = new Function("mod_zoomIn1_out()");
-function mod_zoomIn1_over(){
-function mod_zoomIn1_out(){
-	document.getElementById("zoomIn1").src = mod_zoom1_img.src;
+ * Package: ZoomIn1
+ * Description:
+ * Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.
+ * Maintainer:
+ * SQL:
+ * > e_comment, e_title, e_element, e_src, e_attributes, e_left,
+ * > e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+ * > VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+ * > 'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+ * > '','','','mod_zoomIn1.php','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/ZoomIn');
+ * Files:
+ *  - http/javascripts/mod_zoomIn1.php
+		return;
+		return;
+	Mapbender.modules[options.target].zoom(true, 2.0);
Modified: branches/kmq_dev/http/javascripts/mod_zoomOut1.php
--- branches/kmq_dev/http/javascripts/mod_zoomOut1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/mod_zoomOut1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,31 +1,21 @@
 <?php
 #$Id$
 #$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomOut1.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-var mod_zoomOut_img = new Image();
-mod_zoomOut_img.src = "<?php  echo $e_src;  ?>";
-var mod_zoomOut_img_over = new Image();
-mod_zoomOut_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-var zoomOut1Id = '<?php echo $e_id; ?>';
-var $zoomOut1Button = $("#"+zoomOut1Id);
-$zoomOut1Button.click(function () {
-	zoom("<?php  echo $e_target[0];  ?>", false, 2.0);
-function mod_zoomOut1_init(obj){
-   document.getElementById("zoomOut1").src = mod_zoomOut_img_over.src;
-   obj.onmouseover = new Function("mod_zoomOut1_over()");
-   obj.onmouseout = new Function("mod_zoomOut1_out()");
-function mod_zoomOut1_over(){
-function mod_zoomOut1_out(){
-   document.getElementById("zoomOut1").src = mod_zoomOut_img.src;
+		return;
+		return;
+	Mapbender.modules[options.target].zoom(false, 2.0);
Modified: branches/kmq_dev/http/javascripts/ovnf.php
--- branches/kmq_dev/http/javascripts/ovnf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/ovnf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,53 +16,57 @@
-var mod_overview_target = "<?php echo $e_target[0]; ?>";
-if (typeof(overview_wms) === 'undefined')overview_wms = 0;
-overview_wms = parseInt(overview_wms);
-var mod_overview_width = <?php echo $e_width; ?>;
-var mod_overview_height = <?php echo $e_height; ?>;
-mb_registerMapObj('', 'overview', overview_wms ,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
-parent.eventInitMap.register(function init_overview(){
-		var ind = getMapObjIndexByName('overview');
-		var el = mb_mapObj[ind].getDomElement();
-		el.onmouseover = mod_ovSetHandler;
-		el.onmousedown = mod_box_start;
-		el.onmouseup = mod_ovGetExtent;
-		el.onmousemove = mod_box_run;
-		var ov_extent = mb_mapObj[ind].getExtentInfos();
-		mb_mapObj[ind].isOverview = true;
+if (typeof options.overview_wms === 'undefined') {
+	options.overview_wms = 0;
+options.overview_wms = parseInt(options.overview_wms);
+if (!options.target) {
+	new Mb_exception(options.id + " needs a target.");
+	return;
+parent.eventInitMap.register(function () {
+	var map = Mapbender.modules[options.id] = new Mapbender.Map (
+		options.id,
+		options.width,
+		options.height,
+	mb_mapObj.push(map);
+	var el = map.getDomElement();
+	el.onmouseover = mod_ovSetHandler;
+	el.onmousedown = mod_box_start;
+	el.onmouseup = mod_ovGetExtent;
+	el.onmousemove = mod_box_run;
+	var ov_extent = map.getExtentInfos();
+	map.isOverview = true;
 function mod_ovSetHandler(e){
 	mb_isBF = 'overview';
-	mb_zF = mod_overview_target;
+	mb_zF = options.target;
 function mod_ovGetExtent(e){
 	mod_box_setValidClipping(mod_box_stop(e));
-	var targetMapObj = getMapObjByName(mod_overview_target);
+	var targetMapObj = Mapbender.modules[options.target];
 	if (!targetMapObj) {
 		return;
-	var arrayBBox = targetMapObj.extent.split(",");
+	var arrayBBox = targetMapObj.extent.toString().split(",");
 	var minX = parseFloat(arrayBBox[0]);
 	var minY = parseFloat(arrayBBox[1]);
 	var maxX = parseFloat(arrayBBox[2]);
 	var maxY = parseFloat(arrayBBox[3]);
-	var mapObj = getMapObjByName("overview");
+	var mapObj = Mapbender.modules[options.id];
 	var pointMin = mapObj.convertRealToPixel(new Point(minX, maxY));
 	var pointMax = mapObj.convertRealToPixel(new Point(maxX, minY));
 	var px1 = pointMin.x;
@@ -71,7 +75,7 @@
 	var py2 = pointMax.y;
 	mb_isBF = "overview";
 	while((px2 - px1) < 8){
 		px1 -= 1;
@@ -83,15 +87,15 @@
 	if(px1 < 0){px1 = 1;}
-	if(px1 > mod_overview_width){px1 = mod_overview_width-1;}
+	if(px1 > options.width){px1 = options.width-1;}
 	if(py1 < 0){py1 = 1;}
-	if(py1 > mod_overview_height){py1 = mod_overview_height-1;}
+	if(py1 > options.height){py1 = options.height-1;}
-	if(px2 > mod_overview_width){px2 = mod_overview_width-1;}
+	if(px2 > options.width){px2 = options.width-1;}
 	if(px2 < 0){px2 = 1;}
-	if(py2 > mod_overview_height){py2 = mod_overview_height-1;}
+	if(py2 > options.height){py2 = options.height-1;}
 	if(py2 < 0){py2 = 1;}
 	mb_drawBox(px1,py1,px2,py2);
Modified: branches/kmq_dev/http/javascripts/user.php
--- branches/kmq_dev/http/javascripts/user.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/user.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -7,8 +7,8 @@
 //echo http_get_request_headers();
-$http_body  = file_get_contents('php://input');
-$ajaxResponse  = new AjaxRPC($http_body);
+#$http_body  = file_get_contents('php://input');
+$ajaxResponse  = new AjaxResponse($_REQUEST);
 $method = $ajaxResponse->getMethod(); //get from JSON-RPC
 $id = $ajaxResponse->getId();
@@ -109,27 +109,32 @@
       break;
-    case 'lIST':
+    case 'list':
         //get list of users
         $result = '[';
         $users = User::getList('');
-        if(!$sers)
+        if(!$users)
           $ajaxResponse->setSuccess(false);
           $ajaxResponse->setMessage(_mb("Error fetching list of users"));
+        print "USER is: " . count($users);
         foreach( $users as $user)
+          //FIXME: need proper way to set result
           $result .= '{"name":"'. $user->name .'",';
           $result .= '"value":"'. $user->name .'"},';
         $result = $result; //TODO:remove trailing ','
         $result .= ']';
+        $ajaxResponse->setResult("users",$result);
       break;
     default:
+      $ajaxResponse->setSuccess(false);
+      $ajaxResponse->setMessage(_mb("invalid method"));
Modified: branches/kmq_dev/http/javascripts/wms.js
--- branches/kmq_dev/http/javascripts/wms.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/javascripts/wms.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -380,8 +380,9 @@
 				return false;
 			for(var k=0; k< this.objLayer[i].layer_style.length; k++){
-				if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
-					var legendUrl = this.objLayer[i].layer_style[k].legendurl;
+				var legendUrl = '';
+				if(guiLayerStyle == '' && k == 0){
+					legendUrl = this.objLayer[i].layer_style[k].legendurl;
 					if (this.gui_wms_sldurl !== "") {
 					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
@@ -391,6 +392,17 @@
 					else {
 						return false;
+				}else if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
+					if (this.gui_wms_sldurl !== "") {
+					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
+					if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
+						return legendUrl;
+					else {
+						return false;
@@ -738,7 +750,6 @@
 	this.gui_layer_maxscale = gui_layer_maxscale;
 	this.gui_layer_style = gui_layer_style;
 	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
-	this.gui_layer_style = null;
 	this.has_childs = false;
 	this.layer_style = [];
 	wms_layer_count++;
Modified: branches/kmq_dev/http/php/mb_listKMLs.php
--- branches/kmq_dev/http/php/mb_listKMLs.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mb_listKMLs.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -21,8 +21,8 @@
 require_once(dirname(__FILE__) . "/../classes/class_connector.php");
 require_once(dirname(__FILE__) . "/../classes/class_kml_ows.php");
-$gui_id = $_SESSION["mb_user_gui"];
-$user_id = $_SESSION["mb_user_id"];
+$gui_id = Mapbender::session()->get("mb_user_gui");
+$user_id = Mapbender::session()->get("mb_user_id");
 $action = $_GET["action"];
 $kmlId = $_GET["kml_id"];
Modified: branches/kmq_dev/http/php/mb_validatePermission.php
--- branches/kmq_dev/http/php/mb_validatePermission.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mb_validatePermission.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -38,7 +38,7 @@
 // check if the user is allowed to access this module
-$isAllowed = $admin->getModulPermission($_SESSION["mb_user_id"], $gui_id, $e_id);
+$isAllowed = $admin->getModulPermission(Mapbender::session()->get("mb_user_id"), $gui_id, $e_id);
 // if the module is an iframe, also check if the filename matches the
@@ -55,7 +55,7 @@
 	$t = array("s", "s");
 	$res = db_prep_query($sql, $v, $t);
 	while ($row = db_fetch_array($res)) {
-		if (!$admin->checkModulePermission_new($_SESSION["mb_user_id"], $_SERVER["PHP_SELF"], $row["e_element"])) {
+		if (!$admin->checkModulePermission_new(Mapbender::session()->get("mb_user_id"), $_SERVER["PHP_SELF"], $row["e_element"])) {
 			$isCorrectScript = false;
 			break;
@@ -68,7 +68,7 @@
 // If the user is not allowed to access the module, return to the login screen.
 if (!$isAllowed) {
-	$msg = "mb_validatePermission.php: User " . $_SESSION["mb_user_id"] . " is not allowed to access ".
+	$msg = "mb_validatePermission.php: User " . Mapbender::session()->get("mb_user_id") . " is not allowed to access ".
 			"module " . $e_id;
 	$e = new mb_exception($msg);
 	header("Location: ".LOGIN);
Modified: branches/kmq_dev/http/php/mb_validateSession.php
--- branches/kmq_dev/http/php/mb_validateSession.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mb_validateSession.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -19,17 +19,16 @@
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 $e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
 // check if user data is valid; if not, return to login screen
-if (!isset($_SESSION["mb_user_id"]) ||
-	!isset($_SESSION["mb_user_ip"]) ||
-	$_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']) {
+if (!Mapbender::session()->get("mb_user_id") ||
+	!Mapbender::session()->get("mb_user_ip") ||
+	Mapbender::session()->get('mb_user_ip') != $_SERVER['REMOTE_ADDR']) {
-		$e = new mb_exception("mb_validateSession.php: Invalid user: " . $_SESSION["mb_user_id"]);
+		$e = new mb_exception("mb_validateSession.php: Invalid user: " . Mapbender::session()->get("mb_user_id"));
 		header("Location: " . LOGIN);
 		die();
Modified: branches/kmq_dev/http/php/mod_WMSpreferences.php
--- branches/kmq_dev/http/php/mod_WMSpreferences.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_WMSpreferences.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,66 +1,66 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>WMS Preferences</title>
-<?php
-include '../include/dyn_css.php';
-<STYLE TYPE="text/css">
-   body{
-   	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
-   	color:#0066cc;
-      font-size:10pt
-   table{
-   	color:#808080;;
-      font-size:9pt
-   th{
-   	background-color:#F0F0F0;
-   select{
-		width:240px;
-</STYLE>
-<?php
-echo '<script type="text/javascript">';
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>WMS Preferences</title>
+<?php
+include '../include/dyn_css.php';
+<STYLE TYPE="text/css">
+   body{
+   	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+   	color:#0066cc;
+      font-size:10pt
+   table{
+   	color:#808080;;
+      font-size:9pt
+   th{
+   	background-color:#F0F0F0;
+   select{
+		width:240px;
+</STYLE>
+<?php
+echo '<script type="text/javascript">';
 $sql = "SELECT * FROM gui_element WHERE e_id = 'WMS_preferences' AND fkey_gui_id = $1";
-$v = array($_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_user_gui"));
 $t = array("s");
 $cnt = 0;
@@ -73,215 +73,215 @@
 if($cnt > 1){ echo "alert('WMS_preferences: ID not unique!');";}
 $e_target = explode(",", $e_target);
-echo "var mod_WMSpreferences_target1 = '".trim($e_target[0])."';";
-echo "var mod_WMSpreferences_target2 = '".trim($e_target[1])."';";
-echo "</script>";
-$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
-$t = array("s");
-$res_visible = db_prep_query($sql_visible, $v, $t);
-$cnt_visible = 0;
-while($row = db_fetch_array($res_visible)){
-	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
-	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
-	if($cnt_visible>0){
-		$vis .= ",";
-		$wmsid .= ",";
-	$vis .= $gui_wms_visible[$cnt_visible];
-	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
-	$cnt_visible++;
-echo "var mod_gui_wms_visible = '".$vis."';";
-echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
-echo "</script>";
-<script type="text/javascript">
-var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
-var my = window.opener.mb_mapObj[ind];
+echo "var mod_WMSpreferences_target1 = '".trim($e_target[0])."';";
+echo "var mod_WMSpreferences_target2 = '".trim($e_target[1])."';";
+echo "</script>";
+$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
+$t = array("s");
+$res_visible = db_prep_query($sql_visible, $v, $t);
+$cnt_visible = 0;
+while($row = db_fetch_array($res_visible)){
+	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
+	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
+	if($cnt_visible>0){
+		$vis .= ",";
+		$wmsid .= ",";
+	$vis .= $gui_wms_visible[$cnt_visible];
+	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
+	$cnt_visible++;
+echo "var mod_gui_wms_visible = '".$vis."';";
+echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
+echo "</script>";
+<script type="text/javascript">
+var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
+var my = window.opener.mb_mapObj[ind];
  function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
- 	var myMapObj = window.opener.mb_mapObj[mapObj_ind];
-	if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
-		upper = myMapObj.wms[indexA];
-		myMapObj.wms[indexA] = myMapObj.wms[indexB];
-		myMapObj.wms[indexB] = upper;
-		var upperLayers = myMapObj.layers[indexA];
-		var upperStyles = myMapObj.styles[indexA];
-		var upperQuerylayers = myMapObj.querylayers[indexA];
-		myMapObj.layers[indexA] = myMapObj.layers[indexB];
-		myMapObj.styles[indexA] = myMapObj.styles[indexB];
-		myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
-		myMapObj.layers[indexB] = upperLayers;
-		myMapObj.styles[indexB] = upperStyles;
-		myMapObj.querylayers[indexB] = upperQuerylayers;
-		return true;
-	else {
-		return false;
-// Opacity version
+ 	var myMapObj = window.opener.mb_mapObj[mapObj_ind];
+	if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
+		upper = myMapObj.wms[indexA];
+		myMapObj.wms[indexA] = myMapObj.wms[indexB];
+		myMapObj.wms[indexB] = upper;
+		var upperLayers = myMapObj.layers[indexA];
+		var upperStyles = myMapObj.styles[indexA];
+		var upperQuerylayers = myMapObj.querylayers[indexA];
+		myMapObj.layers[indexA] = myMapObj.layers[indexB];
+		myMapObj.styles[indexA] = myMapObj.styles[indexB];
+		myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
+		myMapObj.layers[indexB] = upperLayers;
+		myMapObj.styles[indexB] = upperStyles;
+		myMapObj.querylayers[indexB] = upperQuerylayers;
+		return true;
+	else {
+		return false;
+// Opacity version
 function cambia_opacity(id,incremento){
 	opacity = my.wms[id].gui_wms_mapopacity*100 + parseInt(incremento);
 	my.wms[id].setOpacity(opacity);
 	loadWMS();
-function setMapformat(val){
-	var tmp = val.split(",");
-	my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
-	loadWMS();
-function setFeatureformat(val){
-	my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
-	loadWMS();
-function setExceptionformat(val){
-	my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
-	loadWMS();
-function swap(index1, index2){
-	if (mb_swapWmsByIndex(ind, index1, index2) == true) {
-		loadWMS();
-		window.opener.zoom(mod_WMSpreferences_target1, true, 1.0);
-		window.opener.mb_execloadWmsSubFunctions();
-function remove_wms(num){
-	var cnt_vis=0;
-	var wms_visible_down = mod_gui_wms_visible.split(",");
-	var wms_vis_down = wms_visible_down.length;
-	//check if there are more than two visible wms's
-	for(var i=0; i < wms_visible_down.length; i++){
-		var my_wms_visible = wms_visible_down[i];
-		if(my_wms_visible == 0){
-  			var cnt_vis = cnt_vis+1;
-	if(my.wms.length - cnt_vis>1){
-	  	var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
-  		window.opener.mb_mapObjremoveWMS(ind,num)
-//  	window.opener.frames[mod_WMSpreferences_target2].document.location.reload();
-  		window.location.reload();
-	else{
-		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
-function loadWMS(){
-	var str = "";
-	var wms_visible = mod_gui_wms_visible.split(",");
-	var wms_id_visible = mod_fkey_wms_id_visible.split(",");
-	var visibleWmsIndexArray = new Array();
-	for(var i=0; i < my.wms.length; i++){
-		var found = false;
-		for(var j=0; j < wms_id_visible.length; j++){
-			if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
-				visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
-				found = true;
-		if (found == false && my.wms[i].gui_wms_visible == 1) {
-	for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
-		z = visibleWmsIndexArray[i];
-		var mapString = "";
-		var featureinfoString = "";
-		var exceptionString = "";
-		for(var j=0; j<my.wms[z].data_type.length; j++){
-			if(my.wms[z].data_type[j] == 'map'){
-				mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
-					mapString += "selected";
-				mapString += ">"+my.wms[z].data_format[j]+"</option>";
-			else if(my.wms[z].data_type[j] == 'featureinfo'){
-				featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
-					featureinfoString += "selected";
-				featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
-			else if(my.wms[z].data_type[j] == 'exception'){
-				exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
-					exceptionString += "selected";
-				exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
-		str += "<table border='1' rules='rows'>";
-		str += "<tr><th>";
-		str += "<img src='../img/button_gray/up.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+visibleWmsIndexArray[i-1]+","+z+")' value='up' title='move WMS up'>&nbsp;";
-		str += "<img src='../img/button_gray/down.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+z+", "+visibleWmsIndexArray[i+1]+")'value='down'title='move WMS down'>&nbsp;</td>";
-		str += "<img src='../img/button_gray/del.png' onclick='remove_wms("+z+")' value='remove' title='remove WMS from GUI'>&nbsp;";
-		str += "</th><th  width='300'><div id ='id_"+my.wms[z].wms_id+"' style='cursor:pointer' onmouseover = 'title=\""+"id:"+my.wms[z].wms_id+" "+my.wms[z].wms_abstract+"\"'><b>"+my.wms[z].wms_title+"</b>";
-		str += "</div></th></tr>";
-		//str += "<tr><td>ID:</td><td>"+my.wms[z].wms_id+"</td></tr>";
-		str += "<tr><td>MapImageFormat: </td><td>";
-		str += "<select onchange='setMapformat(this.value)'>"
-		str += mapString;
-		str += "</select></td></tr>";
-		str += "<tr><td>FeatureInfoFormat: </td><td>";
-		str += "<select onchange='setFeatureformat(this.value)'>";
-		str += featureinfoString;
-		str += "<tr><td>ExceptionFormat: </td><td>";
-		str += "<select onchange='setExceptionformat(this.value)'>"
-		str += exceptionString;
-		str += "</select></td></tr></table>";
-		str += "<table><tr>";
-		//opacity version
-		str += "<tr><td>Opacity:</td><td><input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','-10')\" value=\"-\">";
-		str += "<input id=\"valor_opacity_"+visibleWmsIndexArray[i]+"\" type=\"text\" disabled=\"disabled\" size=\"3\" value=\""+my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100+" %\">";
-		str += "<input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','+10')\" value=\"+\">";
-		str += "</td></tr>";
-		str += "</tr></table><br>";
-	document.getElementById('data').innerHTML = str;
-</script>
-</head>
-<body onload='loadWMS()'>
-<div id='data'><div>
-<form>
-<input type='hidden' name='visibility' value=''>
-</form>
-</body>
-</html>
+function setMapformat(val){
+	var tmp = val.split(",");
+	my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
+	loadWMS();
+function setFeatureformat(val){
+	my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
+	loadWMS();
+function setExceptionformat(val){
+	my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
+	loadWMS();
+function swap(index1, index2){
+	if (mb_swapWmsByIndex(ind, index1, index2) == true) {
+		loadWMS();
+		window.opener.zoom(mod_WMSpreferences_target1, true, 1.0);
+		window.opener.mb_execloadWmsSubFunctions();
+function remove_wms(num){
+	var cnt_vis=0;
+	var wms_visible_down = mod_gui_wms_visible.split(",");
+	var wms_vis_down = wms_visible_down.length;
+	//check if there are more than two visible wms's
+	for(var i=0; i < wms_visible_down.length; i++){
+		var my_wms_visible = wms_visible_down[i];
+		if(my_wms_visible == 0){
+  			var cnt_vis = cnt_vis+1;
+	if(my.wms.length - cnt_vis>1){
+	  	var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
+  		window.opener.mb_mapObjremoveWMS(ind,num)
+//  	window.opener.frames[mod_WMSpreferences_target2].document.location.reload();
+  		window.location.reload();
+	else{
+		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+function loadWMS(){
+	var str = "";
+	var wms_visible = mod_gui_wms_visible.split(",");
+	var wms_id_visible = mod_fkey_wms_id_visible.split(",");
+	var visibleWmsIndexArray = new Array();
+	for(var i=0; i < my.wms.length; i++){
+		var found = false;
+		for(var j=0; j < wms_id_visible.length; j++){
+			if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
+				visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
+				found = true;
+		if (found == false && my.wms[i].gui_wms_visible == 1) {
+	for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
+		z = visibleWmsIndexArray[i];
+		var mapString = "";
+		var featureinfoString = "";
+		var exceptionString = "";
+		for(var j=0; j<my.wms[z].data_type.length; j++){
+			if(my.wms[z].data_type[j] == 'map'){
+				mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
+					mapString += "selected";
+				mapString += ">"+my.wms[z].data_format[j]+"</option>";
+			else if(my.wms[z].data_type[j] == 'featureinfo'){
+				featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
+					featureinfoString += "selected";
+				featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
+			else if(my.wms[z].data_type[j] == 'exception'){
+				exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
+					exceptionString += "selected";
+				exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
+		str += "<table border='1' rules='rows'>";
+		str += "<tr><th>";
+		str += "<img src='../img/button_gray/up.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+visibleWmsIndexArray[i-1]+","+z+")' value='up' title='move WMS up'>&nbsp;";
+		str += "<img src='../img/button_gray/down.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+z+", "+visibleWmsIndexArray[i+1]+")'value='down'title='move WMS down'>&nbsp;</td>";
+		str += "<img src='../img/button_gray/del.png' onclick='remove_wms("+z+")' value='remove' title='remove WMS from GUI'>&nbsp;";
+		str += "</th><th  width='300'><div id ='id_"+my.wms[z].wms_id+"' style='cursor:pointer' onmouseover = 'title=\""+"id:"+my.wms[z].wms_id+" "+my.wms[z].wms_abstract+"\"'><b>"+my.wms[z].wms_title+"</b>";
+		str += "</div></th></tr>";
+		//str += "<tr><td>ID:</td><td>"+my.wms[z].wms_id+"</td></tr>";
+		str += "<tr><td>MapImageFormat: </td><td>";
+		str += "<select onchange='setMapformat(this.value)'>"
+		str += mapString;
+		str += "</select></td></tr>";
+		str += "<tr><td>FeatureInfoFormat: </td><td>";
+		str += "<select onchange='setFeatureformat(this.value)'>";
+		str += featureinfoString;
+		str += "<tr><td>ExceptionFormat: </td><td>";
+		str += "<select onchange='setExceptionformat(this.value)'>"
+		str += exceptionString;
+		str += "</select></td></tr></table>";
+		str += "<table><tr>";
+		//opacity version
+		str += "<tr><td>Opacity:</td><td><input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','-10')\" value=\"-\">";
+		str += "<input id=\"valor_opacity_"+visibleWmsIndexArray[i]+"\" type=\"text\" disabled=\"disabled\" size=\"3\" value=\""+my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100+" %\">";
+		str += "<input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','+10')\" value=\"+\">";
+		str += "</td></tr>";
+		str += "</tr></table><br>";
+	document.getElementById('data').innerHTML = str;
+</script>
+</head>
+<body onload='loadWMS()'>
+<div id='data'><div>
+<form>
+<input type='hidden' name='visibility' value=''>
+</form>
+</body>
+</html>
Modified: branches/kmq_dev/http/php/mod_addWMSfromfilteredList_server.php
--- branches/kmq_dev/http/php/mod_addWMSfromfilteredList_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_addWMSfromfilteredList_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,8 @@
 require_once(dirname(__FILE__)."/../classes/class_administration.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
-$userId = $_SESSION["mb_user_id"];
+$userId = Mapbender::session()->get("mb_user_id");
 $command = $_GET["command"];
 $guiId = $_GET["guiId"];
 $groupId = $_GET["groupId"];
@@ -39,7 +40,7 @@
 	$sql .= "FROM mb_group, mb_user_mb_group ";
 	$sql .= "WHERE fkey_mb_group_id = mb_group_id AND fkey_mb_user_id = $2 ";
 	$sql .= "ORDER BY mb_group_name";
-	$v = array($_SESSION["mb_lang"], $userId);
+	$v = array(Mapbender::session()->get("mb_lang"), $userId);
 	$t = array("s", "i");
@@ -53,7 +54,8 @@
 	$resultObj["gui"] = array();
 	$sql = "SELECT gui_id, gui_name, gettext($1, gui_description) as gui_description FROM gui WHERE gui_id IN (";
-	$v = array($_SESSION["mb_lang"]);
+	$v = array(Mapbender::session()->get("mb_lang"));
 	$t = array("s");
 	for ($i = 0; $i < count($guiIdArray); $i++) {
@@ -79,7 +81,7 @@
 	$sql = "SELECT DISTINCT wms.wms_id, wms.wms_title, gettext($1, wms.wms_abstract) as wms_abstract, wms.wms_getcapabilities, wms.wms_version ";
 	$sql .= "FROM wms, gui_wms ";
 	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id IN (";
 	$t = array("s");
@@ -105,7 +107,7 @@
 	$sql = "SELECT DISTINCT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version ";
 	$sql .= "FROM wms, gui_wms, gui_mb_group ";
 	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id = gui_mb_group.fkey_gui_id AND gui_mb_group.fkey_mb_group_id = $2";
-	$v = array($_SESSION["mb_lang"], $groupId);
+	$v = array(Mapbender::session()->get("mb_lang"), $groupId);
@@ -119,7 +121,7 @@
 	$sql .= "FROM wms, gui_wms WHERE wms.wms_id = gui_wms.fkey_wms_id AND fkey_gui_id = $2";
-	$v = array($_SESSION["mb_lang"], $guiId);
+	$v = array(Mapbender::session()->get("mb_lang"), $guiId);
Modified: branches/kmq_dev/http/php/mod_button_tooltips.php
--- branches/kmq_dev/http/php/mod_button_tooltips.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_button_tooltips.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,8 @@
 $buttonObj = array();
 $sql = "SELECT e_id, gettext($1, e_title) AS e_title FROM gui_element WHERE fkey_gui_id = $2 AND e_element = 'img'";
-$v = array($_SESSION["mb_lang"], $_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_lang"), Mapbender::session()->get("mb_user_gui"));
Modified: branches/kmq_dev/http/php/mod_category_filteredGUI.php
--- branches/kmq_dev/http/php/mod_category_filteredGUI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_category_filteredGUI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -97,8 +97,8 @@
 $cnt_gui_category = 0;
 $cnt_gui_gui = 0;
 $exists = false;
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
+$logged_user_name=Mapbender::session()->get("mb_user_name");
+$logged_user_id=Mapbender::session()->get("mb_user_id");
 $admin = new administration();
Modified: branches/kmq_dev/http/php/mod_changeEPSG_dynamic.php
--- branches/kmq_dev/http/php/mod_changeEPSG_dynamic.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_changeEPSG_dynamic.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -41,7 +41,7 @@
 </style>
 <?php
 $con = db_connect($DBSERVER,$OWNER,$PW);
 db_select_db(DB,$con);
 $sql = "SELECT e_target FROM gui_element WHERE e_id = 'changeEPSG' AND fkey_gui_id = $1";
@@ -188,14 +188,24 @@
 				else{
 					parent.mb_mapObj[ind].epsg = temp[1];
-					parent.mb_mapObj[ind].extent = parseFloat(temp[2]) + "," + parseFloat(temp[3]) + "," + parseFloat(temp[4]) + "," + parseFloat(temp[5]);
+					parent.mb_mapObj[ind].extent = new parent.Extent(
+						parseFloat(temp[2]),
+						parseFloat(temp[3]),
+						parseFloat(temp[4]),
 					parent.setMapRequest(temp[0]);
 			if(temp[0] != myTarget){
 				var ind = parent.getMapObjIndexByName(temp[0]);
@@ -215,7 +225,7 @@
 	str_srs = "";
 	for(var i=0; i<parent.mb_mapObj.length; i++){
 	if(i>0){str_srs += "###";}
-		str_srs += parent.mb_mapObj[i].frameName + "," + parent.mb_mapObj[i].epsg + "," + parent.mb_mapObj[i].extent + ","+parent.mb_mapObj[i].width+","+parent.mb_mapObj[i].height;
+		str_srs += parent.mb_mapObj[i].frameName + "," + parent.mb_mapObj[i].epsg + "," + parent.mb_mapObj[i].extent.toString() + ","+parent.mb_mapObj[i].width+","+parent.mb_mapObj[i].height;
 	document.forms[0].srs.value = str_srs;
 	var ind = document.forms[0].epsg.selectedIndex;
Modified: branches/kmq_dev/http/php/mod_changePassword.php
--- branches/kmq_dev/http/php/mod_changePassword.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_changePassword.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -106,8 +106,8 @@
 /* handle INSERT and DELETE */
 if($upd){
Modified: branches/kmq_dev/http/php/mod_createJSObjFromDBByWMS.php
--- branches/kmq_dev/http/php/mod_createJSObjFromDBByWMS.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_createJSObjFromDBByWMS.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,7 @@
 $wms_id = $_GET["wms_id"];
Modified: branches/kmq_dev/http/php/mod_customTree_server.php
--- branches/kmq_dev/http/php/mod_customTree_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_customTree_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -21,7 +21,7 @@
 $data = array();
 $e = new mb_exception("command: " . $queryObj->command);
-$userId = $_SESSION[mb_user_id];
 $user = new User($userId);
 switch($queryObj->command){
Modified: branches/kmq_dev/http/php/mod_deleteFilteredGUI.php
--- branches/kmq_dev/http/php/mod_deleteFilteredGUI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_deleteFilteredGUI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,7 @@
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
Modified: branches/kmq_dev/http/php/mod_deleteGUI.php
--- branches/kmq_dev/http/php/mod_deleteGUI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_deleteGUI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -53,8 +53,8 @@
 <?php
 require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
 ###delete
 if($guiList){
Modified: branches/kmq_dev/http/php/mod_deleteWFS.php
--- branches/kmq_dev/http/php/mod_deleteWFS.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_deleteWFS.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,96 +1,96 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/DeleteWFS
-import_request_variables("PG");
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-<html>
-<head>
-<?php
-<title>Delete WFS - All Users</title>
-<?php
-function validate(){
-	var ind = document.form1.wfsList.selectedIndex;
-	if(ind > -1){
-		var permission =  confirm("delete: "  + document.form1.wfsList.options[ind].text + " ?");
-		if(permission === true){
-			document.form1.del.value = 1;
-			document.form1.submit();
-</script>
-<style type="text/css">
-  	body{
-      background-color: #ffffff;
-  		font-family: Arial, Helvetica, sans-serif;
-  		font-size : 12px;
-  		color: #808080
-</style>
-</head>
-<body>
-<?php
-###delete
-if($wfsList){
-	 $sql = "DELETE FROM wfs WHERE wfs_id = $1";
-	 $v = array($wfsList);
-	 $t = array("i");
-	 $res = db_prep_query($sql, $v, $t);
-$sql_wfs = "SELECT * FROM wfs ORDER BY wfs_id";
-$res_wfs = db_query($sql_wfs);
-$cnt_wfs = 0;
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<br><b>WFS List: <b><br><br>";
-echo "<select class='wfsList' size='20' name='wfsList' >";
-while($row = db_fetch_array($res_wfs)){
-	echo "<option value='".$row["wfs_id"]."'>".$row["wfs_id"]." ".$row["wfs_name"]." - ".$row["wfs_title"]."</option>";
-	$cnt_wfs++;
-echo "</select><br><br>";
-echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
-<input type='hidden' name='del'>
-</form>
-</body>
-</html>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/DeleteWFS
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+<html>
+<head>
+<?php
+<title>Delete WFS - All Users</title>
+<?php
+function validate(){
+	var ind = document.form1.wfsList.selectedIndex;
+	if(ind > -1){
+		var permission =  confirm("delete: "  + document.form1.wfsList.options[ind].text + " ?");
+		if(permission === true){
+			document.form1.del.value = 1;
+			document.form1.submit();
+</script>
+<style type="text/css">
+  	body{
+      background-color: #ffffff;
+  		font-family: Arial, Helvetica, sans-serif;
+  		font-size : 12px;
+  		color: #808080
+</style>
+</head>
+<body>
+<?php
+###delete
+if($wfsList){
+	 $sql = "DELETE FROM wfs WHERE wfs_id = $1";
+	 $v = array($wfsList);
+	 $t = array("i");
+	 $res = db_prep_query($sql, $v, $t);
+$sql_wfs = "SELECT * FROM wfs ORDER BY wfs_id";
+$res_wfs = db_query($sql_wfs);
+$cnt_wfs = 0;
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<br><b>WFS List: <b><br><br>";
+echo "<select class='wfsList' size='20' name='wfsList' >";
+while($row = db_fetch_array($res_wfs)){
+	echo "<option value='".$row["wfs_id"]."'>".$row["wfs_id"]." ".$row["wfs_name"]." - ".$row["wfs_title"]."</option>";
+	$cnt_wfs++;
+echo "</select><br><br>";
+echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
+<input type='hidden' name='del'>
+</form>
+</body>
+</html>
Modified: branches/kmq_dev/http/php/mod_deleteWMS.php
--- branches/kmq_dev/http/php/mod_deleteWMS.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_deleteWMS.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -118,12 +118,12 @@
 	$wms = $_POST["wms_name"];
 	if (!$_POST["from"])
-		$fromName = $_SESSION["mb_user_name"];
+		$fromName = Mapbender::session()->get("mb_user_name");
 	else
 		$fromName = $_POST["from"];
 	if (!$_POST["replyto"])
-		$email = $admin->getEmailByUserId($_SESSION["mb_user_id"]);
+		$email = $admin->getEmailByUserId(Mapbender::session()->get("mb_user_id"));
 	else
 		$email = $_POST["replyto"];
@@ -174,7 +174,7 @@
 	// display WMS List
-	$wms_id_own = $admin->getWmsByOwner($_SESSION["mb_user_id"],true);
+	$wms_id_own = $admin->getWmsByOwner(Mapbender::session()->get("mb_user_id"),true);
 	if (count($wms_id_own)>0){
 		$v = array();
@@ -277,14 +277,14 @@
 			echo "</p>";
 			//previously, a WMS could only be deleted if it was owned by a single owner
-			//if(count($owner)==1 && $owner[0] == $_SESSION["mb_user_name"]){
+			//if(count($owner)==1 && $owner[0] == Mapbender::session()->get("mb_user_name")){
 			//now, any owner can delete, any non-owner can suggest deletions
 			//if a wms has no owner, anyone can delete
-	    		if($owner && in_array($_SESSION["mb_user_id"], $owner) && count($owner) == 1) {
+	    		if($owner && in_array(Mapbender::session()->get("mb_user_id"), $owner) && count($owner) == 1) {
-	    		elseif ($owner && in_array($_SESSION["mb_user_id"], $owner) && count($owner) > 1) {
+	    		elseif ($owner && in_array(Mapbender::session()->get("mb_user_id"), $owner) && count($owner) > 1) {
 	    			// delete suggestion button only appears when mailing is enabled in mapbender.conf
 	    			if ($use_php_mailing) {
Modified: branches/kmq_dev/http/php/mod_digitize_messages.php
--- branches/kmq_dev/http/php/mod_digitize_messages.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_digitize_messages.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,85 +1,85 @@
-<?php
-#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
-$e = new mb_notice(setlocale(LC_ALL, $_SESSION["mb_locale"]));
-// Messages
-$msg_obj = array();
-$msg_obj["messageDescriptionPolygon"] = _mb("polygon");
-$msg_obj["messageDescriptionLine"] = _mb("line");
-$msg_obj["messageDescriptionPoint"] = _mb("point");
-$msg_obj["messageErrorNotAnInteger"] = _mb("Not an integer value.");
-$msg_obj["messageErrorNotAFloat"] = _mb("Not a double value.");
-$msg_obj["messageErrorFieldIsEmpty"] = _mb("This field may not be empty.");
-$msg_obj["messageErrorFormEvaluation"] = _mb("Failure during form evaluation.");
-$msg_obj["messageErrorWfsWrite"] = _mb("An error occured.");
-$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
-$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon, the second geometry shall be a line.");
-$msg_obj["messageErrorDifferenceNotApplicable"] = _mb("Exactly two polygons must be available.");
-$msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
-$msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
-$msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
-$msg_obj["messageSelectAnOption"] = _mb("Please select an entry.");
-$msg_obj["buttonLabelSaveGeometry"] = _mb("Save");
-$msg_obj["buttonLabelUpdateGeometry"] = _mb("Update");
-$msg_obj["buttonLabelDeleteGeometry"] = _mb("Delete");
-$msg_obj["buttonLabelAbort"] = _mb("Abort");
-$msg_obj["errorMessageEpsgMismatch"] = _mb("Fatal error: EPSG mismatch. ");
-$msg_obj["errorMessageNoGeometrySelected"] = _mb("No geometry selected!");
-$msg_obj["buttonLabelPointOff"] = _mb("add point");
-$msg_obj["buttonLabelPointOn"] = _mb("cancel editing");
-$msg_obj["buttonLabelLineOff"] = _mb("add line");
-$msg_obj["buttonLabelLineOn"] = _mb("finish line");
-$msg_obj["buttonLabelPolygonOff"] = _mb("add polygon");
-$msg_obj["buttonLabelPolygonOn"] = _mb("close polygon");
-$msg_obj["buttonLabelMoveBasepointOff"] = _mb("move basepoint");
-$msg_obj["buttonLabelMoveBasepointOn"] = _mb("move basepoint");
-$msg_obj["buttonLabelInsertBasepointOff"] = _mb("Insert basepoint");
-$msg_obj["buttonLabelInsertBasepointOn"] = _mb("Insert basepoint");
-$msg_obj["buttonLabelDeleteBasepointOff"] = _mb("Delete basepoint");
-$msg_obj["buttonLabelDeleteBasepointOn"] = _mb("Delete basepoint");
-$msg_obj["buttonLabelClearListOff"] = _mb("clear list of geometries");
-$msg_obj["buttonLabelClearListOn"] = _mb("clear list of geometries");
-$msg_obj["buttonLabelMergeOff"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
-$msg_obj["buttonLabelMergeOn"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
-$msg_obj["buttonLabelSplitOff"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
-$msg_obj["buttonLabelSplitOn"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
-$msg_obj["buttonLabelDifferenceOff"] = _mb("Combine two polygons (to create en- and exclave or to compute the difference)");
-$msg_obj["buttonLabelDifferenceOn"] = _mb("Split geometries");
-$msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
-$msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
-$msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
-$msg_obj["buttonDig_clone_title"] = _mb("clone this geometry");
-$msg_obj["closePolygon_title"] = _mb("click the first basepoint to close the polygon");
-$msg_obj["measureTagLabelCurrent"] = _mb("Current: ");
-$msg_obj["measureTagLabelTotal"] = _mb("Total: ");
-$msg_obj["digitizeDefaultGeometryName"] = _mb("new");
-$json = new Mapbender_JSON();
-$output = $json->encode($msg_obj);
-header("Content-type:application/x-json; charset=utf-8");
-echo $output;
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$e = new mb_notice("locale: " . Mapbender::session()->get("mb_locale") . "; lang: " . Mapbender::session()->get("mb_lang"));
+$e = new mb_notice(setlocale(LC_ALL, Mapbender::session()->get("mb_locale")));
+// Messages
+$msg_obj = array();
+$msg_obj["messageDescriptionPolygon"] = _mb("polygon");
+$msg_obj["messageDescriptionLine"] = _mb("line");
+$msg_obj["messageDescriptionPoint"] = _mb("point");
+$msg_obj["messageErrorNotAnInteger"] = _mb("Not an integer value.");
+$msg_obj["messageErrorNotAFloat"] = _mb("Not a double value.");
+$msg_obj["messageErrorFieldIsEmpty"] = _mb("This field may not be empty.");
+$msg_obj["messageErrorFormEvaluation"] = _mb("Failure during form evaluation.");
+$msg_obj["messageErrorWfsWrite"] = _mb("An error occured.");
+$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
+$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon, the second geometry shall be a line.");
+$msg_obj["messageErrorDifferenceNotApplicable"] = _mb("Exactly two polygons must be available.");
+$msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
+$msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
+$msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
+$msg_obj["messageSelectAnOption"] = _mb("Please select an entry.");
+$msg_obj["buttonLabelSaveGeometry"] = _mb("Save");
+$msg_obj["buttonLabelUpdateGeometry"] = _mb("Update");
+$msg_obj["buttonLabelDeleteGeometry"] = _mb("Delete");
+$msg_obj["buttonLabelAbort"] = _mb("Abort");
+$msg_obj["errorMessageEpsgMismatch"] = _mb("Fatal error: EPSG mismatch. ");
+$msg_obj["errorMessageNoGeometrySelected"] = _mb("No geometry selected!");
+$msg_obj["buttonLabelPointOff"] = _mb("add point");
+$msg_obj["buttonLabelPointOn"] = _mb("cancel editing");
+$msg_obj["buttonLabelLineOff"] = _mb("add line");
+$msg_obj["buttonLabelLineOn"] = _mb("finish line");
+$msg_obj["buttonLabelPolygonOff"] = _mb("add polygon");
+$msg_obj["buttonLabelPolygonOn"] = _mb("close polygon");
+$msg_obj["buttonLabelMoveBasepointOff"] = _mb("move basepoint");
+$msg_obj["buttonLabelMoveBasepointOn"] = _mb("move basepoint");
+$msg_obj["buttonLabelInsertBasepointOff"] = _mb("Insert basepoint");
+$msg_obj["buttonLabelInsertBasepointOn"] = _mb("Insert basepoint");
+$msg_obj["buttonLabelDeleteBasepointOff"] = _mb("Delete basepoint");
+$msg_obj["buttonLabelDeleteBasepointOn"] = _mb("Delete basepoint");
+$msg_obj["buttonLabelClearListOff"] = _mb("clear list of geometries");
+$msg_obj["buttonLabelClearListOn"] = _mb("clear list of geometries");
+$msg_obj["buttonLabelMergeOff"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
+$msg_obj["buttonLabelMergeOn"] = _mb("Merge two polygons into a single polygon (will be added to the geometry list)");
+$msg_obj["buttonLabelSplitOff"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
+$msg_obj["buttonLabelSplitOn"] = _mb("Split a polygon by a line (the new polygons will be added to the geometry list)");
+$msg_obj["buttonLabelDifferenceOff"] = _mb("Combine two polygons (to create en- and exclave or to compute the difference)");
+$msg_obj["buttonLabelDifferenceOn"] = _mb("Split geometries");
+$msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
+$msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
+$msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
+$msg_obj["buttonDig_clone_title"] = _mb("clone this geometry");
+$msg_obj["closePolygon_title"] = _mb("click the first basepoint to close the polygon");
+$msg_obj["measureTagLabelCurrent"] = _mb("Current: ");
+$msg_obj["measureTagLabelTotal"] = _mb("Total: ");
+$msg_obj["digitizeDefaultGeometryName"] = _mb("new");
+$json = new Mapbender_JSON();
+$output = $json->encode($msg_obj);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
Modified: branches/kmq_dev/http/php/mod_editApplication.php
--- branches/kmq_dev/http/php/mod_editApplication.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editApplication.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -23,7 +23,7 @@
 $editApplicationId = $_REQUEST["editApplicationId"];
-$user = new User($_SESSION["mb_user_id"]);
+$user = new User(Mapbender::session()->get("mb_user_id"));
 $myApplicationArray = $user->getApplicationsByPermission(false);
 if (!in_array($editApplicationId, $myApplicationArray)) {
 	die("You are not allowed to edit the application '" . $editApplicationId . "'");
@@ -164,7 +164,7 @@
 $sql .= "e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,";
 $sql .= "e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires,e_url FROM gui_element WHERE ";
 $sql .= "e_public = 1 AND fkey_gui_id = $2 ORDER BY e_pos";
-$v = array($_SESSION["mb_lang"], $editApplicationId);
+$v = array(Mapbender::session()->get("mb_lang"), $editApplicationId);
 $t = array('s', 's');
 $res = db_prep_query($sql,$v,$t);
 $i = 0;
Modified: branches/kmq_dev/http/php/mod_editApplication_server.php
--- branches/kmq_dev/http/php/mod_editApplication_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editApplication_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -22,7 +22,7 @@
Modified: branches/kmq_dev/http/php/mod_editElements.php
--- branches/kmq_dev/http/php/mod_editElements.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editElements.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -120,7 +120,7 @@
 	$alert .= "module-path. Please contact your mapbender system administrator.";
 	$mod = new administration();
-	$aGuis = $mod->getGuisByPermission($_SESSION["mb_user_id"],true);
+	$aGuis = $mod->getGuisByPermission(Mapbender::session()->get("mb_user_id"),true);
 	$modPermAlert = false;
 	if($check == true){
@@ -180,6 +180,8 @@
 		if($e_width < 1){$e_width = NULL;}
 		if($e_height < 1){$e_height = NULL;}
 		if($e_z_index < 1){$e_z_index = NULL;}
+		if($e_pos == ''){$e_pos = 2;}
+		if($e_public == ''){$e_public = 1;}
 		$sql = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,";
 		$sql .= "e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,";
@@ -233,9 +235,10 @@
 	$e_target = ""; $e_requires = ""; $e_url = "";
 if(isset($myShow) && $myShow == '1'){
-   $_SESSION["mb_user_myGui"] = $guiList1;
+	 Mapbender::session()->set("mb_user_myGui",$guiList1);
    echo "<script language='javascript'>";
-   echo "window.open('../frames/login.php?".strip_tags (SID)."&name=".$_SESSION["mb_user_name"]."&password=".urlencode($_SESSION["mb_user_password"])."&mb_user_myGui=".$guiList1."','','');";
+   echo "window.open('../frames/login.php?".strip_tags (SID)."&name=".Mapbender::session()->get("mb_user_name")."&password=".urlencode(Mapbender::session()->get("mb_user_password"))."&mb_user_myGui=".$guiList1."','','');";
    echo "</script>";
 if(isset($all) && $all == '1'){
@@ -379,8 +382,8 @@
 <?php
-$permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"],true);
+$permguis = $admin->getGuisByPermission(Mapbender::session()->get("mb_user_id"),true);
 echo "<form name='form1' action='" . $self ."' method='post'>\n";
 if(count($ownguis)>0){
 	$v = array();
@@ -470,7 +473,7 @@
 	   		"onclick='if (confirm(\"" .
 			_mb("Please make sure you have made a backup of your application before using this feature! Continue?") .
 			"\")) window.open(\"mod_editApplication.php?" . SID . "&" .
-	   		"guiID=" . $_SESSION["mb_user_gui"] . "&" .
+	   		"guiID=" . Mapbender::session()->get("mb_user_gui") . "&" .
 	   		"editApplicationId=" . $guiList1 . "\", " .
 	   		"\"edit application\", " .
 	   		"\"width=500,height=500,dependent\");'> \n";
Modified: branches/kmq_dev/http/php/mod_editFilteredGroup.php
--- branches/kmq_dev/http/php/mod_editFilteredGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editFilteredGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -115,8 +115,8 @@
 if (!isset($name) || $selected_group == 'new'){
   $name = "";
-  $owner_id = $_SESSION["mb_user_id"];
-  $owner_name = $_SESSION["mb_user_name"];
+  $owner_id = Mapbender::session()->get("mb_user_id");
+  $owner_name = Mapbender::session()->get("mb_user_name");
   $description = "";
 $myGroup = true;
@@ -138,7 +138,7 @@
 	$t = array();
 	if(isset($myGroup)){
 		$sql .= "WHERE mb_group_owner = $1";
-		array_push($v, $_SESSION["mb_user_id"]);
+		array_push($v, Mapbender::session()->get("mb_user_id"));
 		array_push($t, "i");
 	$sql .= " ORDER BY mb_group_name ";
@@ -204,7 +204,7 @@
 if($selected_group == 'new' || !isset($selected_group)){
    echo "<input type='button' value='save'  onclick='validate(\"save\")'>";
-if($_SESSION["mb_user_id"] == $owner_id && $selected_group != 'new' && $selected_group != '' ){
+if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_group != 'new' && $selected_group != '' ){
    echo "<input type='button' value='save'  onclick='validate(\"update\")'>";
    echo "<input type='button' value='delete'  onclick='validate(\"delete\")'>";
Modified: branches/kmq_dev/http/php/mod_editFilteredUser.php
--- branches/kmq_dev/http/php/mod_editFilteredUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editFilteredUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -186,8 +186,8 @@
 if (!isset($name) || $selected_user == 'new'){
   $name = "";
   $password = "";
   $description = "";
   $login_count = 0;
   $email = "";
@@ -215,7 +215,7 @@
 	$t = array();
 	if (isset($myUser)) {
 		$sql .= "WHERE mb_user_owner = $1";
 	$sql .= " ORDER BY mb_user_name ";
@@ -355,7 +355,7 @@
 if($selected_user == 'new' || !isset($selected_user)){
-if($_SESSION["mb_user_id"] == $owner_id && $selected_user != 'new' && $selected_user != '' ){
+if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_user != 'new' && $selected_user != '' ){
Modified: branches/kmq_dev/http/php/mod_editGroup.php
--- branches/kmq_dev/http/php/mod_editGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -112,9 +112,9 @@
   $name = "";
-  $description = "";
+	$description = "";
 /*HTML*****************************************************************************************************/
@@ -134,7 +134,7 @@
    $t = array();
    if (isset($myGroup)) {
@@ -200,7 +200,7 @@
Modified: branches/kmq_dev/http/php/mod_editGuiWms.php
--- branches/kmq_dev/http/php/mod_editGuiWms.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editGuiWms.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,743 +1,743 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_editGuiWms.php
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-<html>
-<head>
-<?php
-<title>Edit GUI WMS</title>
-<?php
-include_once '../include/dyn_css.php';
-function toImage($text) {
-	$angle = 90;
-	if (extension_loaded("gd2")) {
-		return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
-	return $text;
-<script language="JavaScript">
-function edit_gaz(gui,wms,layer){
-	window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
-function validate(wert){
-	if(wert == 'delete_wms'){
-		if(document.form1.wmsList.selectedIndex == -1){
-			document.form1.wmsList.style.background = '#ff0000';
-		}else{
-			var secure = confirm("Remove WMS in this GUI ?");
-			if(secure == true){
-				document.form1.del.value='true';
-	if(wert == 'up_wms'){
-		}else{
-			if (document.form1.wmsList.selectedIndex>0){
-				document.form1.up.value='true';
-	if(wert == 'down_wms'){
-		}else{
-			if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
-				document.form1.down.value='true';
-function checkBoxValue(){
-   for(var i=0; i<document.forms[0].elements.length; i++){
-      if(document.forms[0].elements[i].type == 'checkbox'){
-         if(document.forms[0].elements[i].checked == true){
-            document.forms[0].elements[i].value = '1';
-         else{
-            document.forms[0].elements[i].value = '0';
-            document.forms[0].elements[i].checked = true;
-      if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
-         var nr = parseInt(document.forms[0].elements[i].value);
-         if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
-         else{document.forms[0].elements[i].value = nr;}
-   document.forms[0].update_content.value=1;
-   document.forms[0].submit();
-function getAllLayer(){
-   var arrayLayer = new Array();
-   var cntLayer = 0;
-      if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
-         arrayLayer[cntLayer] = document.forms[0].elements[i].value;
-         cntLayer++;
-   return arrayLayer;
-function setSubs(){
-   var arrayLayer = getAllLayer();
-   for(var i=0; i<arrayLayer.length; i++){
-      if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
-         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
-function setLayer(def,status){
-   if(def == 'querylayer'){
-      for(var i=1; i<arrayLayer.length; i++){
-         if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
-            eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
-   if(def == 'visible'){
-         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
-function showSld(origUrl){
-	var url = document.getElementById("this_gui_wms_sldurl").value;
-	if(url==""){
-		if(origUrl=="")
-			return;
-		url=origUrl;
-	window.open(url);
-</script>
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$mb_user_id=$_SESSION["mb_user_id"];
-#delete gui_wms from gui
-if($del && $del == 'true'){
-	$sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
-	$v = array($guiList,$wmsList);
-	$t = array('s','i');
-	$res = db_prep_query($sql,$v,$t);
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		$wms_position = $row["gui_wms_position"];
-		$cnt++;
-	#if($cnt > 1){die("Error: WMS (ID) not unique!");}
-		$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
-		$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
-		$del='false';
-		$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
-		$sql .= " AND fkey_gui_id = $2 ";
-		$v = array($wms_position,$guiList);
-		$t = array('i','s');
-	unset($wmsList);
-#update gui_wms_position
-if($up && $up == 'true'){
-	if ($wmsList!=""){
-		$sql = "SELECT gui_wms_position ";
-		$sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-		if($row = db_fetch_array($res)){
-	if($wms_position > 0){
-		$sql = "UPDATE gui_wms SET ";
-		$sql .= "gui_wms_position = $1";
-		$sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
-		$v = array(($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','s','i');
-		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
-		$v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
-		$t = array('i','i','s','i');
-if($down && $down == 'true'){
-	$max = 0;
-		$sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
-		$v = array($guiList);
-		$t = array('s');
-			$max = $row["max"];
-	if($wms_position < $max){
-		$v = array(($wms_position + 1),$guiList,$wmsList);
-		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
-		$v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
-/*handle Updates*/
-if(isset($update_content) && $update_content == "1"){
-   if(isset($this_gui_wms_epsg)){
-      $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
-      $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
-      $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
-      $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
-		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','s','i','i','s','s','i');
-   else{
-		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
-		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
-		$sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
-		$sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
-		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
-		$t = array('s','s','s','i','i','s','s','i');
-   $cnt = 0;
-   while(list($key,$val) = each($_REQUEST)){
-		if(preg_match("/___/", $key)){
-			$myKey = explode("___", $key);
-			if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
-				$sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
-				$v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
-				if($myKey[1]=='gui_layer_style'){
-					$t = array('s','s','i');
-				else{
-				if(!$res = db_prep_query($sql,$v,$t)){
-					echo "FEHLER in ZEILE 288";
-echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
-echo "<tr>";
-echo "<td>";
-echo "GUI";
-echo "</td>";
-echo "<td>";
-echo "WMS-TITLE";
-echo "</td>";
-echo "<td>";
-echo "</td>";
-echo "<tr>";
-echo "<td>";
-$admin = new administration();
-$gui_id =array();
-if (count($ownguis)>0){
-	for($i=0; $i<count($ownguis); $i++){
-		$gui_id[$i]=$ownguis[$i];
-echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
-$selected_gui_id="";
-for ($i=0; $i<count($ownguis);$i++){
-   echo "<option value='".$gui_id[$i]."' ";
-   if($guiList && $guiList == $gui_id[$i]){
-      echo "selected";
-      $selected_gui_id=$gui_id[$i];
-   else{
-      if ($i==0){
-         echo "selected";
-   echo ">".$gui_id[$i]."</option>";
-echo "</select>";
-echo "</td>";
-echo "<td>";
-$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
-$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
-$v = array($selected_gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$count_wms = 0;
-echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
-while($row = db_fetch_array($res)){
-	echo "<option value='".$row["wms_id"]."' ";
-	if(isset($wmsList) && $wmsList == $row["wms_id"]){
-		echo "selected";
-	echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
-	$count_wms++;
-echo "</select>";
-echo "</td><td>";
-echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
-echo "<input type='hidden' name='up' value=''><br><br>";
-echo "<input class='myButton' type='button' name='down_wms' value='down'  onClick='validate(\"down_wms\")'>";
-echo "<input type='hidden' name='down' value=''><br><br>";
-echo "<input class='myButton' type='button' name='delete_wms' value='remove'  onClick='validate(\"delete_wms\")'>";
-echo "<input type='hidden' name='del' value=''>";
-echo "</td>";
-echo "</tr>";
-echo "</table>";
-if(isset($wmsList)){
-#gui_wms
-$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-$v = array($guiList,$wmsList);
-$t = array('s','i');
-$res_gw = db_prep_query($sql_gw,$v,$t);
-$cnt_gw = 0;
-while($row = db_fetch_array($res_gw)){
-   $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
-   $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
-   $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
-   $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
-   $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
-   $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
-   $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
-   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
-   $cnt_gw++;
-#wms
-$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
-$v = array($wmsList);
-$t = array('i');
-$res_w = db_prep_query($sql_w,$v,$t);
-$cnt_w = 0;
-while($row = db_fetch_array($res_w)){
-   $wms_id[$cnt_w] = $row["wms_id"];
-   $wms_version[$cnt_w] = $row["wms_version"];
-   $wms_title[$cnt_w] = $row["wms_title"];
-   $wms_abstract[$cnt_w] = $row["wms_abstract"];
-   $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
-   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
-   $cnt_w++;
-#wms_format
-$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
-$t = array('i');
-$res_wf = db_prep_query($sql_wf,$v,$t);
-$cnt_wf = 0;
-while($row = db_fetch_array($res_wf)){
-   $data_type[$cnt_wf] = $row["data_type"];
-   $data_format[$cnt_wf] = $row["data_format"];
-   $cnt_wf++;
-#gui_layer
-$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
-$v = array($wmsList,$guiList,$guiList,$mb_user_id);
-$t = array('i','s','s','i');
-$res_gl = db_prep_query($sql_gl,$v,$t);
-$gui_layer_status = array();
-$gui_layer_selectable = array();
-$gui_layer_visible = array();
-$gui_layer_queryable = array();
-$gui_layer_querylayer = array();
-$gui_layer_minscale = array();
-$gui_layer_maxscale = array();
-$gui_layer_priority = array();
-$gui_layer_style = array();
-$gui_layer_wfs_featuretype = array();
-$layer_maxscale = array();
-$layer_id = array();
-$layer_parent = array();
-$layer_name = array();
-$layer_title = array();
-$layer_queryable = array();
-$layer_minscale = array();
-$sld_user_layer_id = array();
-$use_sld = array();
-while($row = db_fetch_array($res_gl)){
-	array_push($gui_layer_status, $row["gui_layer_status"]);
-	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
-	array_push($gui_layer_visible, $row["gui_layer_visible"]);
-	array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
-	array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
-	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
-	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
-	array_push($gui_layer_priority, $row["gui_layer_priority"]);
-	array_push($gui_layer_style, $row["gui_layer_style"]);
-	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
-	array_push($layer_id, $row["layer_id"]);
-	array_push($layer_parent, $row["layer_parent"]);
-	array_push($layer_name, $row["layer_name"]);
-	array_push($layer_title, $row["layer_title"]);
-	array_push($layer_queryable, $row["layer_queryable"]);
-	array_push($layer_minscale, $row["layer_minscale"]);
-	array_push($layer_maxscale, $row["layer_maxscale"]);
-	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
-	array_push($use_sld, $row["use_sld"]);
-#layer_epsg
-$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
-$v = array($layer_id[0]);
-$t = array('i');
-$res_le = db_prep_query($sql_le,$v,$t);
-$cnt_le = 0;
-while($row = db_fetch_array($res_le)){
-   $epsg[$cnt_le] = $row["epsg"];
-   $cnt_le++;
-echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
-echo "<table class='table_top'>";
-echo "<tr>";
-echo "<td colspan='2'>";
-echo "<a href='".$wms_getcapabilities[0];
-echo wms::getConjunctionCharacter($wms_getcapabilities[0]);
-if ($wms_version[0] == "1.0.0") {
-	echo "WMTVER=". $wms_version[0]."&REQUEST=capabilities";
-else {
-	echo "VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";
-echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
-echo "</td>";
-echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
-echo "<tr>";
-#epsg
-if($gui_wms_position[0] == 0){
-  echo "<tr>";
-     echo "<td>EPSG: </td><td>";
-     echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
-        for($i=0; $i<count($epsg); $i++){
-           echo "<option value='".$epsg[$i]."' ";
-           if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
-           echo ">".$epsg[$i]."</option>";
-     echo "</select>";
-     echo "</td>";
-  echo "</tr>";
-#format
-echo "<tr>";
-   echo "<td>Mapformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
-        for($i=0; $i<count($data_format); $i++){
-           if($data_type[$i] == 'map'){
-              echo "<option value='".$data_format[$i]."' ";
-              if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
-              echo ">".$data_format[$i]."</option>";
-     echo "</select>";
-   echo "</td>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Infoformat: </td><td>";
-        echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
-        echo "<option value='text/html'>text/html</option>";
-           if($data_type[$i] == 'featureinfo'){
-              if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr>";
-echo "<tr>";
-   echo "<td>Exceptionformat: </td><td>";
-        echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
-           if($data_type[$i] == 'exception'){
-              if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
-     echo "</select>";
-   echo "</td>";
-echo "</tr><br>";
-# visibility
-echo "<tr>";
-	echo "<td>Visibility: </td><td>";
-	echo "<select class='mySelect' name='this_gui_wms_visible'>";
-	for($i=0; $i<3; $i++){
-		echo "<option value='".$i."' ";
-		if($i == $gui_wms_visible[0]){ echo "selected";}
-		echo ">";
-		if($i == '0'){
-			echo "hidden";
-		if($i == '1'){
-			echo "visible";
-		echo "</option>";
-	echo "</select>";
-	echo "</td>";
-echo "</tr>";
-# opacity
-echo "<tr>";
-	echo "<td>Opacity: </td><td>";
-	echo "<select class='mySelect' name='this_gui_wms_opacity'>";
-	for($i=0; $i<=100; $i+=10){
-		if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
-		echo ">";
-		echo $i."%";
-		echo "</option>";
-	echo "</select>";
-	echo "</td>";
-echo "</tr>";
-# sld support
-if($wms_supportsld[0]) {
-		echo "<tr>";
-		echo "<td>SLD-URL: </td><td>";
-		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
-		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
-		#$layer_names = implode(",", $layer_name);
-        echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
-		echo "</td>";
-	echo "</tr>";
-} else {
-	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
-echo "</table><br>";
-echo "<table border='1' cellpadding='1'>";
-		echo "<tr>";
-                echo "<td>Nr.</td>";
-                echo "<td>ID</td>";
-                echo "<td>" . toImage('Parent') . "</td>";
-                echo "<td>Name</td>";
-                echo "<td>Title</td>";
-                echo "<td>" . toImage('on/off') . "</td>";
-                echo "<td>" . toImage('sel') . "</td>";
-                echo "<td>" . toImage('sel_default') . "</td>";
-                echo "<td>" . toImage('info') . "</td>";
-                echo "<td>" . toImage('info_default') . "</td>";
-                echo "<td>" . toImage('minScale 1:') . "</td>";
-                echo "<td>" . toImage('maxScale 1:') . "</td>";
-                echo "<td>" . toImage('Style') . "</td>";
-                echo "<td>" . toImage('Prio') . "</td>";
-                echo "<td>" . toImage('setWFS') . "</td>";
-                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
-        echo "</tr>";
-#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
-echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
-echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
-echo "</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
-echo"</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
-echo "</td><td></td><td></td><td></td></tr>";
-for($i=0; $i<count($layer_id); $i++){
-#layer_styles
-$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
-$v = array($layer_id[$i]);
-$t = array('i');
-$res_styles = db_prep_query($sql_styles,$v,$t);
-$cnt_styles= 0;
-$style = array();
-while($row = db_fetch_array($res_styles)){
-   $style[$cnt_styles] = $row["name"];
-   $cnt_styles++;
- echo "<tr align='center'>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
-  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
-  echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
-  echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
-  if($gui_layer_status[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
-  if($gui_layer_selectable[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
-  if($gui_layer_visible[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
-  if($gui_layer_queryable[$i] == 1){ echo "checked";}
-  if($layer_queryable[$i] == 0){ echo "disabled";}
-  echo "></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
-  if($gui_layer_querylayer[$i] == 1){ echo "checked";}
-  echo "></td>";
-  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
-  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
-  echo "<td>\n";
-  echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
-  	   echo "<option value=''";
-  	   if(count($style) ==0){ echo "selected";}
-  	   echo ">---</option>\n";
-  for($j=0;$j<count($style); $j++){
-       echo "<option value='".$style[$j]."'";
-       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
-       echo ">".$style[$j]."</option>\n";
-  echo "</select></td>\n";
-  echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
-  for($j=0; $j<count($gui_layer_priority); $j++){
-     echo "<option value='".$j."'";
-     if($j == $gui_layer_priority[$i]){echo "selected";}
-     echo ">".$j;
-     echo "</option>";
-  /* wfs configuration */
-	echo "<td>";
-	if ($i > 0) {
-		echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
-		if($gui_layer_wfs_featuretype[$i] == ""){
-			echo "setWFS";
-		else{
-			echo "wfs ".$gui_layer_wfs_featuretype[$i];
-		echo "'>";
-	echo "</td>";
-		echo "<td>";
-		if ($i > 0) {
-			echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".$urlParameters."&sld_gui_id=".$guiList."&sld_wms_id=".$wms_id[0]."&sld_layer_name=".$layer_name[$i]."\");' value='";
-			if ($sld_user_layer_id[$i] != "")
-				echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
-			else
-				echo "SLD";
-			echo "'>";
-		echo "</td>";
- echo "</tr>\n";
- if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
-echo "</table>\n";
-echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
-echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
-echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
-echo "<input type='hidden' name='update_content' value=''>\n";
-echo "</form>\n";
-</body>
-</html>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_editGuiWms.php
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Edit GUI WMS</title>
+<?php
+include_once '../include/dyn_css.php';
+function toImage($text) {
+	$angle = 90;
+	if (extension_loaded("gd2")) {
+		return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
+	return $text;
+<script language="JavaScript">
+function edit_gaz(gui,wms,layer){
+	window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
+function validate(wert){
+	if(wert == 'delete_wms'){
+		if(document.form1.wmsList.selectedIndex == -1){
+			document.form1.wmsList.style.background = '#ff0000';
+		}else{
+			var secure = confirm("Remove WMS in this GUI ?");
+			if(secure == true){
+				document.form1.del.value='true';
+	if(wert == 'up_wms'){
+		}else{
+			if (document.form1.wmsList.selectedIndex>0){
+				document.form1.up.value='true';
+	if(wert == 'down_wms'){
+		}else{
+			if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
+				document.form1.down.value='true';
+function checkBoxValue(){
+   for(var i=0; i<document.forms[0].elements.length; i++){
+      if(document.forms[0].elements[i].type == 'checkbox'){
+         if(document.forms[0].elements[i].checked == true){
+            document.forms[0].elements[i].value = '1';
+         else{
+            document.forms[0].elements[i].value = '0';
+            document.forms[0].elements[i].checked = true;
+      if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
+         var nr = parseInt(document.forms[0].elements[i].value);
+         if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
+         else{document.forms[0].elements[i].value = nr;}
+   document.forms[0].update_content.value=1;
+   document.forms[0].submit();
+function getAllLayer(){
+   var arrayLayer = new Array();
+   var cntLayer = 0;
+      if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
+         arrayLayer[cntLayer] = document.forms[0].elements[i].value;
+         cntLayer++;
+   return arrayLayer;
+function setSubs(){
+   var arrayLayer = getAllLayer();
+   for(var i=0; i<arrayLayer.length; i++){
+      if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
+         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
+function setLayer(def,status){
+   if(def == 'querylayer'){
+      for(var i=1; i<arrayLayer.length; i++){
+         if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
+            eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
+   if(def == 'visible'){
+         eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
+function showSld(origUrl){
+	var url = document.getElementById("this_gui_wms_sldurl").value;
+	if(url==""){
+		if(origUrl=="")
+			return;
+		url=origUrl;
+	window.open(url);
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$mb_user_id = Mapbender::session()->get("mb_user_id");
+#delete gui_wms from gui
+if($del && $del == 'true'){
+	$sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
+	$v = array($guiList,$wmsList);
+	$t = array('s','i');
+	$res = db_prep_query($sql,$v,$t);
+	$cnt = 0;
+	while($row = db_fetch_array($res)){
+		$wms_position = $row["gui_wms_position"];
+		$cnt++;
+	#if($cnt > 1){die("Error: WMS (ID) not unique!");}
+		$sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
+		$sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
+		$del='false';
+		$sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
+		$sql .= " AND fkey_gui_id = $2 ";
+		$v = array($wms_position,$guiList);
+		$t = array('i','s');
+	unset($wmsList);
+#update gui_wms_position
+if($up && $up == 'true'){
+	if ($wmsList!=""){
+		$sql = "SELECT gui_wms_position ";
+		$sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+		if($row = db_fetch_array($res)){
+	if($wms_position > 0){
+		$sql = "UPDATE gui_wms SET ";
+		$sql .= "gui_wms_position = $1";
+		$sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
+		$v = array(($wms_position - 1),$guiList,$wmsList);
+		$t = array('i','s','i');
+		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
+		$v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
+		$t = array('i','i','s','i');
+if($down && $down == 'true'){
+	$max = 0;
+		$sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
+		$v = array($guiList);
+		$t = array('s');
+			$max = $row["max"];
+	if($wms_position < $max){
+		$v = array(($wms_position + 1),$guiList,$wmsList);
+		$sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
+		$v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
+/*handle Updates*/
+if(isset($update_content) && $update_content == "1"){
+   if(isset($this_gui_wms_epsg)){
+      $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
+      $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
+      $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
+      $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
+		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+		$t = array('s','s','s','s','i','i','s','s','i');
+   else{
+		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
+		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
+		$sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
+		$sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
+		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+		$t = array('s','s','s','i','i','s','s','i');
+   $cnt = 0;
+   while(list($key,$val) = each($_REQUEST)){
+		if(preg_match("/___/", $key)){
+			$myKey = explode("___", $key);
+			if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
+				$sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+				$v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
+				if($myKey[1]=='gui_layer_style'){
+					$t = array('s','s','i');
+				else{
+				if(!$res = db_prep_query($sql,$v,$t)){
+					echo "FEHLER in ZEILE 288";
+echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
+echo "<tr>";
+echo "<td>";
+echo "GUI";
+echo "</td>";
+echo "<td>";
+echo "WMS-TITLE";
+echo "</td>";
+echo "<td>";
+echo "</td>";
+echo "<tr>";
+echo "<td>";
+$admin = new administration();
+$gui_id =array();
+if (count($ownguis)>0){
+	for($i=0; $i<count($ownguis); $i++){
+		$gui_id[$i]=$ownguis[$i];
+echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
+$selected_gui_id="";
+for ($i=0; $i<count($ownguis);$i++){
+   echo "<option value='".$gui_id[$i]."' ";
+   if($guiList && $guiList == $gui_id[$i]){
+      echo "selected";
+      $selected_gui_id=$gui_id[$i];
+   else{
+      if ($i==0){
+         echo "selected";
+   echo ">".$gui_id[$i]."</option>";
+echo "</select>";
+echo "</td>";
+echo "<td>";
+$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
+$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
+$v = array($selected_gui_id);
+$t = array('s');
+$res = db_prep_query($sql,$v,$t);
+$count_wms = 0;
+echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
+while($row = db_fetch_array($res)){
+	echo "<option value='".$row["wms_id"]."' ";
+	if(isset($wmsList) && $wmsList == $row["wms_id"]){
+		echo "selected";
+	echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
+	$count_wms++;
+echo "</select>";
+echo "</td><td>";
+echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
+echo "<input type='hidden' name='up' value=''><br><br>";
+echo "<input class='myButton' type='button' name='down_wms' value='down'  onClick='validate(\"down_wms\")'>";
+echo "<input type='hidden' name='down' value=''><br><br>";
+echo "<input class='myButton' type='button' name='delete_wms' value='remove'  onClick='validate(\"delete_wms\")'>";
+echo "<input type='hidden' name='del' value=''>";
+echo "</td>";
+echo "</tr>";
+echo "</table>";
+if(isset($wmsList)){
+#gui_wms
+$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+$v = array($guiList,$wmsList);
+$t = array('s','i');
+$res_gw = db_prep_query($sql_gw,$v,$t);
+$cnt_gw = 0;
+while($row = db_fetch_array($res_gw)){
+   $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
+   $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
+   $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
+   $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
+   $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
+   $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
+   $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
+   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
+   $cnt_gw++;
+#wms
+$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
+$v = array($wmsList);
+$t = array('i');
+$res_w = db_prep_query($sql_w,$v,$t);
+$cnt_w = 0;
+while($row = db_fetch_array($res_w)){
+   $wms_id[$cnt_w] = $row["wms_id"];
+   $wms_version[$cnt_w] = $row["wms_version"];
+   $wms_title[$cnt_w] = $row["wms_title"];
+   $wms_abstract[$cnt_w] = $row["wms_abstract"];
+   $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
+   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
+   $cnt_w++;
+#wms_format
+$sql_wf = "SELECT * FROM  wms_format WHERE  fkey_wms_id = $1";
+$t = array('i');
+$res_wf = db_prep_query($sql_wf,$v,$t);
+$cnt_wf = 0;
+while($row = db_fetch_array($res_wf)){
+   $data_type[$cnt_wf] = $row["data_type"];
+   $data_format[$cnt_wf] = $row["data_format"];
+   $cnt_wf++;
+#gui_layer
+$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
+$v = array($wmsList,$guiList,$guiList,$mb_user_id);
+$t = array('i','s','s','i');
+$res_gl = db_prep_query($sql_gl,$v,$t);
+$gui_layer_status = array();
+$gui_layer_selectable = array();
+$gui_layer_visible = array();
+$gui_layer_queryable = array();
+$gui_layer_querylayer = array();
+$gui_layer_minscale = array();
+$gui_layer_maxscale = array();
+$gui_layer_priority = array();
+$gui_layer_style = array();
+$gui_layer_wfs_featuretype = array();
+$layer_maxscale = array();
+$layer_id = array();
+$layer_parent = array();
+$layer_name = array();
+$layer_title = array();
+$layer_queryable = array();
+$layer_minscale = array();
+$sld_user_layer_id = array();
+$use_sld = array();
+while($row = db_fetch_array($res_gl)){
+	array_push($gui_layer_status, $row["gui_layer_status"]);
+	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
+	array_push($gui_layer_visible, $row["gui_layer_visible"]);
+	array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
+	array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
+	array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
+	array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
+	array_push($gui_layer_priority, $row["gui_layer_priority"]);
+	array_push($gui_layer_style, $row["gui_layer_style"]);
+	array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
+	array_push($layer_id, $row["layer_id"]);
+	array_push($layer_parent, $row["layer_parent"]);
+	array_push($layer_name, $row["layer_name"]);
+	array_push($layer_title, $row["layer_title"]);
+	array_push($layer_queryable, $row["layer_queryable"]);
+	array_push($layer_minscale, $row["layer_minscale"]);
+	array_push($layer_maxscale, $row["layer_maxscale"]);
+	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
+	array_push($use_sld, $row["use_sld"]);
+#layer_epsg
+$sql_le = "SELECT * FROM layer_epsg WHERE  fkey_layer_id = $1";
+$v = array($layer_id[0]);
+$t = array('i');
+$res_le = db_prep_query($sql_le,$v,$t);
+$cnt_le = 0;
+while($row = db_fetch_array($res_le)){
+   $epsg[$cnt_le] = $row["epsg"];
+   $cnt_le++;
+echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
+echo "<table class='table_top'>";
+echo "<tr>";
+echo "<td colspan='2'>";
+echo "<a href='".$wms_getcapabilities[0];
+echo wms::getConjunctionCharacter($wms_getcapabilities[0]);
+if ($wms_version[0] == "1.0.0") {
+	echo "WMTVER=". $wms_version[0]."&REQUEST=capabilities";
+else {
+	echo "VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";
+echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
+echo "</td>";
+echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
+echo "<tr>";
+#epsg
+if($gui_wms_position[0] == 0){
+  echo "<tr>";
+     echo "<td>EPSG: </td><td>";
+     echo "<select class='mySelect'  name='this_gui_wms_epsg'>";
+        for($i=0; $i<count($epsg); $i++){
+           echo "<option value='".$epsg[$i]."' ";
+           if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
+           echo ">".$epsg[$i]."</option>";
+     echo "</select>";
+     echo "</td>";
+  echo "</tr>";
+#format
+echo "<tr>";
+   echo "<td>Mapformat: </td><td>";
+        echo "<select class='mySelect'  name='this_gui_wms_mapformat'>";
+        for($i=0; $i<count($data_format); $i++){
+           if($data_type[$i] == 'map'){
+              echo "<option value='".$data_format[$i]."' ";
+              if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
+              echo ">".$data_format[$i]."</option>";
+     echo "</select>";
+   echo "</td>";
+echo "</tr>";
+echo "<tr>";
+   echo "<td>Infoformat: </td><td>";
+        echo "<select class='mySelect'  name='this_gui_wms_featureinfoformat'>";
+        echo "<option value='text/html'>text/html</option>";
+           if($data_type[$i] == 'featureinfo'){
+              if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
+     echo "</select>";
+   echo "</td>";
+echo "</tr>";
+echo "<tr>";
+   echo "<td>Exceptionformat: </td><td>";
+        echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
+           if($data_type[$i] == 'exception'){
+              if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
+     echo "</select>";
+   echo "</td>";
+echo "</tr><br>";
+# visibility
+echo "<tr>";
+	echo "<td>Visibility: </td><td>";
+	echo "<select class='mySelect' name='this_gui_wms_visible'>";
+	for($i=0; $i<3; $i++){
+		echo "<option value='".$i."' ";
+		if($i == $gui_wms_visible[0]){ echo "selected";}
+		echo ">";
+		if($i == '0'){
+			echo "hidden";
+		if($i == '1'){
+			echo "visible";
+		echo "</option>";
+	echo "</select>";
+	echo "</td>";
+echo "</tr>";
+# opacity
+echo "<tr>";
+	echo "<td>Opacity: </td><td>";
+	echo "<select class='mySelect' name='this_gui_wms_opacity'>";
+	for($i=0; $i<=100; $i+=10){
+		if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
+		echo ">";
+		echo $i."%";
+		echo "</option>";
+	echo "</select>";
+	echo "</td>";
+echo "</tr>";
+# sld support
+if($wms_supportsld[0]) {
+		echo "<tr>";
+		echo "<td>SLD-URL: </td><td>";
+		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
+		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
+		#$layer_names = implode(",", $layer_name);
+        echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
+		echo "</td>";
+	echo "</tr>";
+} else {
+	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
+echo "</table><br>";
+echo "<table border='1' cellpadding='1'>";
+		echo "<tr>";
+                echo "<td>Nr.</td>";
+                echo "<td>ID</td>";
+                echo "<td>" . toImage('Parent') . "</td>";
+                echo "<td>Name</td>";
+                echo "<td>Title</td>";
+                echo "<td>" . toImage('on/off') . "</td>";
+                echo "<td>" . toImage('sel') . "</td>";
+                echo "<td>" . toImage('sel_default') . "</td>";
+                echo "<td>" . toImage('info') . "</td>";
+                echo "<td>" . toImage('info_default') . "</td>";
+                echo "<td>" . toImage('minScale 1:') . "</td>";
+                echo "<td>" . toImage('maxScale 1:') . "</td>";
+                echo "<td>" . toImage('Style') . "</td>";
+                echo "<td>" . toImage('Prio') . "</td>";
+                echo "<td>" . toImage('setWFS') . "</td>";
+                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
+        echo "</tr>";
+#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
+echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
+echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
+echo "</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'>&nbsp;";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
+echo"</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'>&nbsp;";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
+echo "</td><td></td><td></td><td></td></tr>";
+for($i=0; $i<count($layer_id); $i++){
+#layer_styles
+$sql_styles = "SELECT * FROM layer_style WHERE  fkey_layer_id = $1";
+$v = array($layer_id[$i]);
+$t = array('i');
+$res_styles = db_prep_query($sql_styles,$v,$t);
+$cnt_styles= 0;
+$style = array();
+while($row = db_fetch_array($res_styles)){
+   $style[$cnt_styles] = $row["name"];
+   $cnt_styles++;
+ echo "<tr align='center'>";
+  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
+  echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
+  echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
+  echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
+  echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
+  if($gui_layer_status[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
+  if($gui_layer_selectable[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
+  if($gui_layer_visible[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
+  if($gui_layer_queryable[$i] == 1){ echo "checked";}
+  if($layer_queryable[$i] == 0){ echo "disabled";}
+  echo "></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
+  if($gui_layer_querylayer[$i] == 1){ echo "checked";}
+  echo "></td>";
+  echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
+  echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
+  echo "<td>\n";
+  echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
+  	   echo "<option value=''";
+  	   if(count($style) ==0){ echo "selected";}
+  	   echo ">---</option>\n";
+  for($j=0;$j<count($style); $j++){
+       echo "<option value='".$style[$j]."'";
+       if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
+       echo ">".$style[$j]."</option>\n";
+  echo "</select></td>\n";
+  echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
+  for($j=0; $j<count($gui_layer_priority); $j++){
+     echo "<option value='".$j."'";
+     if($j == $gui_layer_priority[$i]){echo "selected";}
+     echo ">".$j;
+     echo "</option>";
+  /* wfs configuration */
+	echo "<td>";
+	if ($i > 0) {
+		echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
+		if($gui_layer_wfs_featuretype[$i] == ""){
+			echo "setWFS";
+		else{
+			echo "wfs ".$gui_layer_wfs_featuretype[$i];
+		echo "'>";
+	echo "</td>";
+		echo "<td>";
+		if ($i > 0) {
+			echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".$urlParameters."&sld_gui_id=".$guiList."&sld_wms_id=".$wms_id[0]."&sld_layer_name=".$layer_name[$i]."\");' value='";
+			if ($sld_user_layer_id[$i] != "")
+				echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
+			else
+				echo "SLD";
+			echo "'>";
+		echo "</td>";
+ echo "</tr>\n";
+ if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
+echo "</table>\n";
+echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
+echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
+echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
+echo "<input type='hidden' name='update_content' value=''>\n";
+echo "</form>\n";
+</body>
+</html>
Modified: branches/kmq_dev/http/php/mod_editSelf.php
--- branches/kmq_dev/http/php/mod_editSelf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editSelf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -196,8 +196,8 @@
   $name = "";
   $password = "";
   $description = "";
   $login_count = 0;
   $email = "";
@@ -206,17 +206,17 @@
   $resolution = 72;
-$selected_user = $_SESSION["mb_user_id"];
+$selected_user = Mapbender::session()->get("mb_user_id");
 echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<input type='hidden' name='selected_user' value='" . $_SESSION["mb_user_id"] . "'>";
+echo "<input type='hidden' name='selected_user' value='" . Mapbender::session()->get("mb_user_id") . "'>";
 echo "<table border='0'>";
 if(isset($selected_user) && $selected_user != 0){
    $sql = "SELECT * FROM mb_user WHERE mb_user_id = $1";
-   $v = array($_SESSION["mb_user_id"]);
+   $v = array(Mapbender::session()->get("mb_user_id"));
    $t = array('i');
@@ -229,7 +229,7 @@
       $phone = $row["mb_user_phone"];
       $department = $row["mb_user_department"];
       $resolution = $row["mb_user_resolution"];
    	$edit = true;
    else {
@@ -329,7 +329,7 @@
-if($_SESSION["mb_user_id"] == $owner_id && $selected_user != '' ){
+if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_user != '' ){
Modified: branches/kmq_dev/http/php/mod_editUser.php
--- branches/kmq_dev/http/php/mod_editUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -195,8 +195,8 @@
   $name = "";
   $password = "";
   $description = "";
   $login_count = 0;
   $email = "";
@@ -224,7 +224,7 @@
    $t = array();
@@ -364,7 +364,7 @@
Modified: branches/kmq_dev/http/php/mod_editWMS_Metadata.php
--- branches/kmq_dev/http/php/mod_editWMS_Metadata.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_editWMS_Metadata.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,497 +1,497 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php?title=Edit_WMS_Metadata
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$adm = new administration();
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>Edit WMS Metadata</title>
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>">
-var dTarget;
-function save() {
-function deletepreview(layer_id) {
-	var url = String(document.location);
-	url = url.substr(0, url.indexOf('?'));
-	window.open(url+"?<?php echo $urlParameters; ?>&delete_preview=1&layer_id="+layer_id,'delete preview', 'height=50, width=150, dependent=yes');
-	document.getElementById(layer_id+"_dp").style.display="none";
-function pick_the_date(obj) {
-    dTarget = obj;
-	var datePickerParameters = "m=Jan_Feb_Mrz_Apr_Mai_Jun_Jul_Aug_Sep_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute";
-	var datePickerStyle = "left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0"
-    var dp = window.open('../extensions/datepicker/datepicker.php?' + datePickerParameters,'dp',datePickerStyle);
-    dp.focus();
-    return false;
-</script>
-</head>
-<body>
-<?php
-function guessTimestamp($timestr) {
-     if (mb_strpos($timestr, '.')) {
-        list($day, $month, $year) = explode(".", $timestr);
-     elseif (mb_strpos($timestr, '/')) {
-        list($month, $day, $year) = explode("/", $timestr);
-     elseif (mb_strpos($timestr, '-')) {
-        list($year, $month, $day) = explode("-", $timestr);
-     else {
-     	$year = 0;
-        $month = 0;
-        $day = 0;
-     return mktime(0, 0, 0, $month, $day, intval($year));
-#Update handling
-if (isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true) {
-	$update_wms_sql = "UPDATE wms SET ";
-	$update_wms_sql .= "wms_title = $1, wms_abstract = $2, fees = $3, ";
-	$update_wms_sql .= "accessconstraints = $4, contactperson = $5, ";
-	$update_wms_sql .= "contactposition = $6, contactorganization = $7, ";
-	$update_wms_sql .= "address = $8, city = $9, stateorprovince = $10, ";
-	$update_wms_sql .= "postcode = $11, country = $12, ";
-	$update_wms_sql .= "contactvoicetelephone = $13, ";
-	$update_wms_sql .= "contactfacsimiletelephone = $14, ";
-	$update_wms_sql .= "contactelectronicmailaddress = $15 ";
-	$v = array();
-	array_push($v, $_REQUEST['wms_title_box']);
-	array_push($v, $_REQUEST['wms_abstract_box']);
-	array_push($v, $_REQUEST['fees_box']);
-	array_push($v, $_REQUEST['accessconstraints_box']);
-	array_push($v, $_REQUEST['contactperson_box']);
-	array_push($v, $_REQUEST['contactposition_box']);
-	array_push($v, $_REQUEST['contactorganization_box']);
-	array_push($v, $_REQUEST['address_box']);
-	array_push($v, $_REQUEST['city_box']);
-	array_push($v, $_REQUEST['stateorprovince_box']);
-	array_push($v, $_REQUEST['postcode_box']);
-	array_push($v, $_REQUEST['country_box']);
-	array_push($v, $_REQUEST['contactvoicetelephone_box']);
-	array_push($v, $_REQUEST['contactfacsimiletelephone_box']);
-	array_push($v, $_REQUEST['contactelectronicmailaddress_box']);
-	$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
-	if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "") {
-        $update_wms_sql .= ", wms_timestamp = $16 ";
-		array_push($v, guessTimestamp($_REQUEST['wms_timestamp_box']));
-		array_push($t, "s");
-		$update_wms_sql .= "WHERE wms_id = $17";
-	else {
-		$update_wms_sql .= "WHERE wms_id = $16";
-	array_push($v, 	$_REQUEST['wms_id']);
-    $res_update_wms_sql = db_prep_query($update_wms_sql, $v, $t);
-    while(list($key,$val) = each($_REQUEST)) {
-        if(preg_match("/___/", $key)) {
-            $layer_id = preg_replace("/L_/","",$myKey[0]);
-            if($myKey[1]=="layer_abstract") {
-				$layer_sql = "UPDATE layer SET layer_abstract = $1 ";
-				$layer_sql .= "WHERE layer_id = $2 AND fkey_wms_id = $3";
-                $v = array($val, $layer_id, $_REQUEST['wms_id']);
-                $t = array("s", "i", "s");
-                $res_keyword_sql = db_prep_query($layer_sql, $v, $t);
-            if($myKey[1]=="layer_keywords") {
-                #Get all keywords depending on the given layer after user modification
-                $keywords  = explode(",",$val);
-                #delete all blanks from the keywords list
-                for ($j = 0; $j < count($keywords); $j++) {
-                    $word = $keywords[$j];
-                    $word = trim($word);
-                    $keywords[$j] = $word;
-                #echo "1: Keywords eines Layers: id des Layers: ", $layer_id, ", �bergebener String: ", $val, ";<br>";
-                #Get all keywords depending on this layer from database
-                $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
-                               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
-                               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
-                               "AND layer.fkey_wms_id = $1 " .
-                               "AND layer.layer_id = $2";
-                $v = array($_REQUEST['wms_id'], $layer_id);
-                $t = array("s", "i");
-                $res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
-                while($keyword_row = db_fetch_array($res_keyword_sql))
-                    $keyword = $keyword_row['keyword'];
-                    $keyword_id = $keyword_row['keyword_id'];
-                    #keyword has been deleted or has been modified
-                    #keyword exists in database but not in user data
-                    $index = -1;
-                    #echo "1a: Abfrage ob DB Keywords in User Liste: Keyword: ", $keyword, ";<br>";
-                    if(in_array($keyword, $keywords) == false)
-                        #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
-                        #Deleting reference to the keyword from the layer_keyword table.
-                        $keyword_sql = "DELETE FROM layer_keyword " .
-                                       "WHERE fkey_layer_id = $1 " .
-                                       "AND fkey_keyword_id = $2";
-                        $v = array($layer_id, $keyword_id);
-                        $t = array("i", "i");
-                        db_prep_query($keyword_sql, $v, $t);
-                        #Checking, if the keyword is in use by any layer
-                        $layer_sql = "SELECT * FROM layer_keyword " .
-                                       "WHERE fkey_keyword_id = $1";
-                        $v = array($keyword_id);
-                        $t = array("i");
-                        $res_layer_sql = db_prep_query($layer_sql, $v, $t);
-                        if(!($row = db_fetch_array($res_layer_sql)))
-                            #If keyword will not longer be in use, delete it from keyword table
-                            $keyword_sql = "DELETE FROM keyword " .
-                                           "WHERE keyword_id = $1";
-                            $t = array("i");
-                    #Keyword exists in the database and in the user data
-                    else
-                        #echo "1d: Keyword ist in User Liste: Keyword: ", $keyword, ";<br>";
-                        for($i = 0; $i < count($keywords); $i++)
-                            #Delete keyword from the user data list, because the data
-                            #have not to be updated within the database
-                            if($keywords[$i] == $keyword)
-                                $keywords[$i] = null;
-                #Inserting keyword, that are not existing in the database
-                    #echo "2: Alle Eintr�ge des Keyword arrays: Keyword: ", $keywords[$i], "; Index: ", $i, ";<br>";
-                    if($keywords[$i] != null)
-                        #echo "3: Eintr�ge ungleich null: Keyword: ", $keywords[$i], "; Index: ", $i, ";<nr>";
-                        $keyword = trim($keywords[$i]);
-                        #Check, if the keyword is exsiting in the database
-                        $keyword_sql = "SELECT keyword_id FROM keyword " .
-                                       "WHERE UPPER(keyword) = UPPER($1)";
-                        $v = array($keyword);
-                        $t = array("s");
-                        $keyword_row = db_fetch_array($res_keyword_sql);
-                        if($keyword_row != null)
-                            $keyword_id = $keyword_row[0];
-                            #echo "4: Keyword in Datenbank vorhanden: id des Keywords: ", $keyword_id, ";<br>";
-                        #Keyword does not exist in the database
-                        else
-                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ($1)";
-                            $t = array("s");
-                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
-                            $t = array("s");
-                                #echo "4: Keyword in der Datenbank nicht vorhanden: id des Keywords: ", $keyword_id, ";<br>";
-                        #Inserting the reference between layer and keyword in the layer_keyword table
-                        $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
-                                       "VALUES ($1, $2)";
-                        $t = array("s", "s");
-                #Delete all elements from array
-                unset($keywords);
-unset($update_content);
-#delete preview
-if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
-	&& isset($_REQUEST['layer_id']))
-    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = $1";
-    $v = array($_REQUEST['layer_id']);
-    $t = array("s");
-    $res_preview_sql = db_prep_query($preview_sql, $v, $t);
-    die("Preview has been deleted!</body></html>");
-<form name='form1' action='<?php echo $self . "&show_wms_list=true"; ?>' method='post'>
-<table border='0'>
-<tr>
-<td WIDTH="300" align="left">
-<B>WMS Metadaten<B/>
-<td/>
-<td WIDTH="160">
-<td/>
-</tr>
-<?php
-#Use select box to select a wms
-if (isset($_REQUEST['show_wms_list']) && $_REQUEST['show_wms_list'] == true)
-    #Querying information from wms data table
-    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = $1 ORDER BY wms_title";
-    $t = array("i");
-    $res_wms_sql = db_prep_query($wms_sql, $v, $t);
-    #wms-selection
-    $selectBox = "";
-    while($row = db_fetch_array($res_wms_sql)) {
-        if ($adm->getWmsPermission($row["wms_id"], $_SESSION['mb_user_id'])) {
-	        $selectBox .= "<option value='".$row["wms_id"]."' ";
-	        if(isset($_REQUEST['wmsList']) && $_REQUEST['wmsList'] == $row["wms_id"]) {
-	            $selectBox .= "selected";
-	        $selectBox .= "> ".$row["wms_title"]."</option>";
-    if ($selectBox != "") {
-	    echo "<tr><td>";
-	    echo "<select size=6 name='wmsList' onchange='submit()'>".$selectBox."</select>";
-	    echo "</td><td width='160px' align='right'>";
-	    echo "<input type='button' class='sbutton' value='save' onclick='save()'>";
-		echo "</td></tr>";
-    else {
-    	echo "<div>no wms owner.</div>";
-    	die;
-    if(isset($_REQUEST['wmsList']) == true && $_REQUEST['wmsList'] <>0)
-    editWMSByWMSID ($_REQUEST['wmsList']);
-echo "</table>";
-//$wms_id;
-function editWMSByWMSID($param_wms_id)
-    global $wms_id;
-    $wms_id = $param_wms_id;
-if(isset($wms_id) == true && $wms_id <>0)
-	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = $1";
-	$v = array($wms_id);
-	$t = array("s");
-    $res_selected_wms_sql = db_prep_query($selected_wms_sql, $v, $t);
-    $selected_row = db_fetch_array($res_selected_wms_sql);
-    <table border='0' class='table_top' >
-    <tr>
-    <td>WMS-Titel:<td><td/>
-    <input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
-    <td>WMS- Abstract:<td><td/>
-    <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
-    <td >Fees:<td><td/>
-    <input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Access Constraints:<td><td/>
-    <input type='text' name='accessconstraints_box' value='<?php echo $selected_row["accessconstraints"]?>'/><td/>
-    <td>Contact Person:<td><td/>
-    <input type='text' name='contactperson_box' value='<?php echo $selected_row["contactperson"]?>'/><td/>
-    <td>Contact Position:<td><td/>
-    <input type='text' name='contactposition_box' value='<?php echo $selected_row["contactposition"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Contact Organization:<td><td/>
-    <input type='text' name='contactorganization_box' value='<?php echo $selected_row["contactorganization"]?>'/><td/>
-    <td>Address:<td><td/>
-    <input type='text' name='address_box' value='<?php echo $selected_row["address"]?>'/><td/>
-    <td style="width:">City:<td><td/>
-    <input type='text' name='city_box' value='<?php echo $selected_row["city"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>State or Province:<td><td/>
-    <input type='text' name='stateorprovince_box' value='<?php echo $selected_row["stateorprovince"]?>'/><td/>
-    <td>Postcode:<td><td/>
-    <input type='text' name='postcode_box' value='<?php echo $selected_row["postcode"]?>'/><td/>
-    <td>Country:<td><td/>
-    <input type='text' name='country_box' value='<?php echo $selected_row["country"]?>'/><td/>
-    <tr/>
-    <tr>
-    <td>Telephone:<td><td/>
-    <input type='text' name='contactvoicetelephone_box'
-        value='<?php echo $selected_row["contactvoicetelephone"]?>'/><td/>
-    <td>Fax:<td><td/>
-    <input type='text' name='contactfacsimiletelephone_box' value='<?php echo $selected_row["contactfacsimiletelephone"]?>'/><td/>
-    <td>E-Mail:<td><td/>
-    <input type='text' name='contactelectronicmailaddress_box' value='<?php echo $selected_row["contactelectronicmailaddress"]?>'/><td/>
-    <tr/>
-    <tr>
-    <?php
-  if (isset($selected_row["wms_timestamp"]) && $selected_row["wms_timestamp"] <> "") {
-    $datum = date("d.m.Y",$selected_row["wms_timestamp"]);
-  else $datum = ""
-    <td>Date:<td><td/>
-    <input type='text' name='wms_timestamp_box' value='<?php echo $datum?>' onClick='pick_the_date(document.form1.wms_timestamp_box)'/><td/>
-    <tr/>
-    <table class="table_layer">
-    <tr><td>Nr.</td><td>Title</td><td>Abstract</td><td>Keywords</td><td></td></tr>
-<?php
-    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1" .
-                 " ORDER BY layer_pos";
-    $t = array("s");
-    while($layer_row = db_fetch_array($res_layer_sql))
-        <tr align='center'>
-        <td><input type='text' size='1' name='L_<?php echo $layer_row['layer_id']?>___layer_nr'
-            value='<?php echo $layer_row['layer_pos']?>' readonly></td>
-        <td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
-            value='<?php echo $layer_row['layer_title']?>' readonly></td>
-        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
-            value='<?php echo $layer_row['layer_abstract']?>'>
-    <?php
-        $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
-        $v = array($wms_id, $layer_row['layer_id']);
-        $keywordList = "";
-        $seperator = "";
-            if($keywordList != "")
-                $seperator = ",";
-            $keywordList .= $seperator.$keyword_row["keyword"];
-        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
-             value='<?php echo $keywordList?>'>
-        </td>
-        <td>
-        <input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');">
-        </td>
-        <td>
-<?php
-    $preview_sql = "SELECT * FROM layer_preview " .
-                   "WHERE fkey_layer_id = ".$layer_row['layer_id']."";
-    $res_preview_sql = db_query($preview_sql);
-	if(db_numrows($res_preview_sql)>0){?>
-        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
-<?php }else{?>
-        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
-<?php }*/?>
-        </td>
-        </tr>
-    <?php
-    #editWMSByWMSID(961);
-    </table>
-    <input type='hidden' name='update_content' value=''/>
-    <input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
-    <input type="hidden" value='' name='delete_preview'>
-    <input type="hidden" value='' name='layer_id'>
-    </form>
-    </body>
-    </html>
-<?php
+<?php
+# $Id$
+# http://www.mapbender.org/index.php?title=Edit_WMS_Metadata
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$adm = new administration();
+<html>
+<head>
+<title>Edit WMS Metadata</title>
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>">
+var dTarget;
+function save() {
+function deletepreview(layer_id) {
+	var url = String(document.location);
+	url = url.substr(0, url.indexOf('?'));
+	window.open(url+"?<?php echo $urlParameters; ?>&delete_preview=1&layer_id="+layer_id,'delete preview', 'height=50, width=150, dependent=yes');
+	document.getElementById(layer_id+"_dp").style.display="none";
+function pick_the_date(obj) {
+    dTarget = obj;
+	var datePickerParameters = "m=Jan_Feb_Mrz_Apr_Mai_Jun_Jul_Aug_Sep_Okt_Nov_Dez&d=Mo_Di_Mi_Do_Fr_Sa_So&t=heute";
+	var datePickerStyle = "left=200,top=200,width=230,height=210,toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=0"
+    var dp = window.open('../extensions/datepicker/datepicker.php?' + datePickerParameters,'dp',datePickerStyle);
+    dp.focus();
+    return false;
+</script>
+</head>
+<body>
+<?php
+function guessTimestamp($timestr) {
+     if (mb_strpos($timestr, '.')) {
+        list($day, $month, $year) = explode(".", $timestr);
+     elseif (mb_strpos($timestr, '/')) {
+        list($month, $day, $year) = explode("/", $timestr);
+     elseif (mb_strpos($timestr, '-')) {
+        list($year, $month, $day) = explode("-", $timestr);
+     else {
+     	$year = 0;
+        $month = 0;
+        $day = 0;
+     return mktime(0, 0, 0, $month, $day, intval($year));
+#Update handling
+if (isset($_REQUEST['update_content']) && $_REQUEST['update_content'] == true) {
+	$update_wms_sql = "UPDATE wms SET ";
+	$update_wms_sql .= "wms_title = $1, wms_abstract = $2, fees = $3, ";
+	$update_wms_sql .= "accessconstraints = $4, contactperson = $5, ";
+	$update_wms_sql .= "contactposition = $6, contactorganization = $7, ";
+	$update_wms_sql .= "address = $8, city = $9, stateorprovince = $10, ";
+	$update_wms_sql .= "postcode = $11, country = $12, ";
+	$update_wms_sql .= "contactvoicetelephone = $13, ";
+	$update_wms_sql .= "contactfacsimiletelephone = $14, ";
+	$update_wms_sql .= "contactelectronicmailaddress = $15 ";
+	$v = array();
+	array_push($v, $_REQUEST['wms_title_box']);
+	array_push($v, $_REQUEST['wms_abstract_box']);
+	array_push($v, $_REQUEST['fees_box']);
+	array_push($v, $_REQUEST['accessconstraints_box']);
+	array_push($v, $_REQUEST['contactperson_box']);
+	array_push($v, $_REQUEST['contactposition_box']);
+	array_push($v, $_REQUEST['contactorganization_box']);
+	array_push($v, $_REQUEST['address_box']);
+	array_push($v, $_REQUEST['city_box']);
+	array_push($v, $_REQUEST['stateorprovince_box']);
+	array_push($v, $_REQUEST['postcode_box']);
+	array_push($v, $_REQUEST['country_box']);
+	array_push($v, $_REQUEST['contactvoicetelephone_box']);
+	array_push($v, $_REQUEST['contactfacsimiletelephone_box']);
+	array_push($v, $_REQUEST['contactelectronicmailaddress_box']);
+	$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
+	if (isset($_REQUEST['wms_timestamp_box']) && $_REQUEST['wms_timestamp_box'] <> "") {
+        $update_wms_sql .= ", wms_timestamp = $16 ";
+		array_push($v, guessTimestamp($_REQUEST['wms_timestamp_box']));
+		array_push($t, "s");
+		$update_wms_sql .= "WHERE wms_id = $17";
+	else {
+		$update_wms_sql .= "WHERE wms_id = $16";
+	array_push($v, 	$_REQUEST['wms_id']);
+    $res_update_wms_sql = db_prep_query($update_wms_sql, $v, $t);
+    while(list($key,$val) = each($_REQUEST)) {
+        if(preg_match("/___/", $key)) {
+            $layer_id = preg_replace("/L_/","",$myKey[0]);
+            if($myKey[1]=="layer_abstract") {
+				$layer_sql = "UPDATE layer SET layer_abstract = $1 ";
+				$layer_sql .= "WHERE layer_id = $2 AND fkey_wms_id = $3";
+                $v = array($val, $layer_id, $_REQUEST['wms_id']);
+                $t = array("s", "i", "s");
+                $res_keyword_sql = db_prep_query($layer_sql, $v, $t);
+            if($myKey[1]=="layer_keywords") {
+                #Get all keywords depending on the given layer after user modification
+                $keywords  = explode(",",$val);
+                #delete all blanks from the keywords list
+                for ($j = 0; $j < count($keywords); $j++) {
+                    $word = $keywords[$j];
+                    $word = trim($word);
+                    $keywords[$j] = $word;
+                #echo "1: Keywords eines Layers: id des Layers: ", $layer_id, ", �bergebener String: ", $val, ";<br>";
+                #Get all keywords depending on this layer from database
+                $keyword_sql = "SELECT keyword_id, keyword FROM keyword, layer_keyword, layer " .
+                               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+                               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+                               "AND layer.fkey_wms_id = $1 " .
+                               "AND layer.layer_id = $2";
+                $v = array($_REQUEST['wms_id'], $layer_id);
+                $t = array("s", "i");
+                $res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
+                while($keyword_row = db_fetch_array($res_keyword_sql))
+                    $keyword = $keyword_row['keyword'];
+                    $keyword_id = $keyword_row['keyword_id'];
+                    #keyword has been deleted or has been modified
+                    #keyword exists in database but not in user data
+                    $index = -1;
+                    #echo "1a: Abfrage ob DB Keywords in User Liste: Keyword: ", $keyword, ";<br>";
+                    if(in_array($keyword, $keywords) == false)
+                        #echo "1c: Keyword nicht in User Liste: Keyword: ", $keyword, ";<br>";
+                        #Deleting reference to the keyword from the layer_keyword table.
+                        $keyword_sql = "DELETE FROM layer_keyword " .
+                                       "WHERE fkey_layer_id = $1 " .
+                                       "AND fkey_keyword_id = $2";
+                        $v = array($layer_id, $keyword_id);
+                        $t = array("i", "i");
+                        db_prep_query($keyword_sql, $v, $t);
+                        #Checking, if the keyword is in use by any layer
+                        $layer_sql = "SELECT * FROM layer_keyword " .
+                                       "WHERE fkey_keyword_id = $1";
+                        $v = array($keyword_id);
+                        $t = array("i");
+                        $res_layer_sql = db_prep_query($layer_sql, $v, $t);
+                        if(!($row = db_fetch_array($res_layer_sql)))
+                            #If keyword will not longer be in use, delete it from keyword table
+                            $keyword_sql = "DELETE FROM keyword " .
+                                           "WHERE keyword_id = $1";
+                            $t = array("i");
+                    #Keyword exists in the database and in the user data
+                    else
+                        #echo "1d: Keyword ist in User Liste: Keyword: ", $keyword, ";<br>";
+                        for($i = 0; $i < count($keywords); $i++)
+                            #Delete keyword from the user data list, because the data
+                            #have not to be updated within the database
+                            if($keywords[$i] == $keyword)
+                                $keywords[$i] = null;
+                #Inserting keyword, that are not existing in the database
+                    #echo "2: Alle Eintr�ge des Keyword arrays: Keyword: ", $keywords[$i], "; Index: ", $i, ";<br>";
+                    if($keywords[$i] != null)
+                        #echo "3: Eintr�ge ungleich null: Keyword: ", $keywords[$i], "; Index: ", $i, ";<nr>";
+                        $keyword = trim($keywords[$i]);
+                        #Check, if the keyword is exsiting in the database
+                        $keyword_sql = "SELECT keyword_id FROM keyword " .
+                                       "WHERE UPPER(keyword) = UPPER($1)";
+                        $v = array($keyword);
+                        $t = array("s");
+                        $keyword_row = db_fetch_array($res_keyword_sql);
+                        if($keyword_row != null)
+                            $keyword_id = $keyword_row[0];
+                            #echo "4: Keyword in Datenbank vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Keyword does not exist in the database
+                        else
+                            $keyword_sql = "INSERT INTO keyword (keyword) VALUES ($1)";
+                            $t = array("s");
+                            $keyword_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+                            $t = array("s");
+                                #echo "4: Keyword in der Datenbank nicht vorhanden: id des Keywords: ", $keyword_id, ";<br>";
+                        #Inserting the reference between layer and keyword in the layer_keyword table
+                        $keyword_sql = "INSERT INTO layer_keyword (fkey_layer_id, fkey_keyword_id) " .
+                                       "VALUES ($1, $2)";
+                        $t = array("s", "s");
+                #Delete all elements from array
+                unset($keywords);
+unset($update_content);
+#delete preview
+if(isset($_REQUEST['delete_preview']) && $_REQUEST['delete_preview']=='1'
+	&& isset($_REQUEST['layer_id']))
+    $preview_sql = "DELETE FROM layer_preview WHERE fkey_layer_id = $1";
+    $v = array($_REQUEST['layer_id']);
+    $t = array("s");
+    $res_preview_sql = db_prep_query($preview_sql, $v, $t);
+    die("Preview has been deleted!</body></html>");
+<form name='form1' action='<?php echo $self . "&show_wms_list=true"; ?>' method='post'>
+<table border='0'>
+<tr>
+<td WIDTH="300" align="left">
+<B>WMS Metadaten<B/>
+<td/>
+<td WIDTH="160">
+<td/>
+</tr>
+<?php
+#Use select box to select a wms
+if (isset($_REQUEST['show_wms_list']) && $_REQUEST['show_wms_list'] == true)
+    #Querying information from wms data table
+    $wms_sql = "SELECT wms_id, wms_title FROM wms WHERE wms_owner = $1 ORDER BY wms_title";
+    $t = array("i");
+    $res_wms_sql = db_prep_query($wms_sql, $v, $t);
+    #wms-selection
+    $selectBox = "";
+    while($row = db_fetch_array($res_wms_sql)) {
+        if ($adm->getWmsPermission($row["wms_id"], Mapbender::session()->get("mb_user_id"))) {
+	        $selectBox .= "<option value='".$row["wms_id"]."' ";
+	        if(isset($_REQUEST['wmsList']) && $_REQUEST['wmsList'] == $row["wms_id"]) {
+	            $selectBox .= "selected";
+	        $selectBox .= "> ".$row["wms_title"]."</option>";
+    if ($selectBox != "") {
+	    echo "<tr><td>";
+	    echo "<select size=6 name='wmsList' onchange='submit()'>".$selectBox."</select>";
+	    echo "</td><td width='160px' align='right'>";
+	    echo "<input type='button' class='sbutton' value='save' onclick='save()'>";
+		echo "</td></tr>";
+    else {
+    	echo "<div>no wms owner.</div>";
+    	die;
+    if(isset($_REQUEST['wmsList']) == true && $_REQUEST['wmsList'] <>0)
+    editWMSByWMSID ($_REQUEST['wmsList']);
+echo "</table>";
+//$wms_id;
+function editWMSByWMSID($param_wms_id)
+    global $wms_id;
+    $wms_id = $param_wms_id;
+if(isset($wms_id) == true && $wms_id <>0)
+	$selected_wms_sql = "SELECT * FROM wms WHERE wms_id = $1";
+	$v = array($wms_id);
+	$t = array("s");
+    $res_selected_wms_sql = db_prep_query($selected_wms_sql, $v, $t);
+    $selected_row = db_fetch_array($res_selected_wms_sql);
+    <table border='0' class='table_top' >
+    <tr>
+    <td>WMS-Titel:<td><td/>
+    <input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
+    <td>WMS- Abstract:<td><td/>
+    <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
+    <td >Fees:<td><td/>
+    <input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Access Constraints:<td><td/>
+    <input type='text' name='accessconstraints_box' value='<?php echo $selected_row["accessconstraints"]?>'/><td/>
+    <td>Contact Person:<td><td/>
+    <input type='text' name='contactperson_box' value='<?php echo $selected_row["contactperson"]?>'/><td/>
+    <td>Contact Position:<td><td/>
+    <input type='text' name='contactposition_box' value='<?php echo $selected_row["contactposition"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Contact Organization:<td><td/>
+    <input type='text' name='contactorganization_box' value='<?php echo $selected_row["contactorganization"]?>'/><td/>
+    <td>Address:<td><td/>
+    <input type='text' name='address_box' value='<?php echo $selected_row["address"]?>'/><td/>
+    <td style="width:">City:<td><td/>
+    <input type='text' name='city_box' value='<?php echo $selected_row["city"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>State or Province:<td><td/>
+    <input type='text' name='stateorprovince_box' value='<?php echo $selected_row["stateorprovince"]?>'/><td/>
+    <td>Postcode:<td><td/>
+    <input type='text' name='postcode_box' value='<?php echo $selected_row["postcode"]?>'/><td/>
+    <td>Country:<td><td/>
+    <input type='text' name='country_box' value='<?php echo $selected_row["country"]?>'/><td/>
+    <tr/>
+    <tr>
+    <td>Telephone:<td><td/>
+    <input type='text' name='contactvoicetelephone_box'
+        value='<?php echo $selected_row["contactvoicetelephone"]?>'/><td/>
+    <td>Fax:<td><td/>
+    <input type='text' name='contactfacsimiletelephone_box' value='<?php echo $selected_row["contactfacsimiletelephone"]?>'/><td/>
+    <td>E-Mail:<td><td/>
+    <input type='text' name='contactelectronicmailaddress_box' value='<?php echo $selected_row["contactelectronicmailaddress"]?>'/><td/>
+    <tr/>
+    <tr>
+    <?php
+  if (isset($selected_row["wms_timestamp"]) && $selected_row["wms_timestamp"] <> "") {
+    $datum = date("d.m.Y",$selected_row["wms_timestamp"]);
+  else $datum = ""
+    <td>Date:<td><td/>
+    <input type='text' name='wms_timestamp_box' value='<?php echo $datum?>' onClick='pick_the_date(document.form1.wms_timestamp_box)'/><td/>
+    <tr/>
+    <table class="table_layer">
+    <tr><td>Nr.</td><td>Title</td><td>Abstract</td><td>Keywords</td><td></td></tr>
+<?php
+    $layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1" .
+                 " ORDER BY layer_pos";
+    $t = array("s");
+    while($layer_row = db_fetch_array($res_layer_sql))
+        <tr align='center'>
+        <td><input type='text' size='1' name='L_<?php echo $layer_row['layer_id']?>___layer_nr'
+            value='<?php echo $layer_row['layer_pos']?>' readonly></td>
+        <td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
+            value='<?php echo $layer_row['layer_title']?>' readonly></td>
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
+            value='<?php echo $layer_row['layer_abstract']?>'>
+    <?php
+        $keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
+        $v = array($wms_id, $layer_row['layer_id']);
+        $keywordList = "";
+        $seperator = "";
+            if($keywordList != "")
+                $seperator = ",";
+            $keywordList .= $seperator.$keyword_row["keyword"];
+        <td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
+             value='<?php echo $keywordList?>'>
+        </td>
+        <td>
+        <input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');">
+        </td>
+        <td>
+<?php
+    $preview_sql = "SELECT * FROM layer_preview " .
+                   "WHERE fkey_layer_id = ".$layer_row['layer_id']."";
+    $res_preview_sql = db_query($preview_sql);
+	if(db_numrows($res_preview_sql)>0){?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }else{?>
+        <input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
+<?php }*/?>
+        </td>
+        </tr>
+    <?php
+    #editWMSByWMSID(961);
+    </table>
+    <input type='hidden' name='update_content' value=''/>
+    <input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
+    <input type="hidden" value='' name='delete_preview'>
+    <input type="hidden" value='' name='layer_id'>
+    </form>
+    </body>
+    </html>
+<?php
\ No newline at end of file
Modified: branches/kmq_dev/http/php/mod_edit_element_vars.php
--- branches/kmq_dev/http/php/mod_edit_element_vars.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_edit_element_vars.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -157,7 +157,7 @@
    $e_more_styles = ""; $e_content = ""; $e_closetag = ""; $e_js_file = ""; $e_mb_mod = ""; $e_target = ""; $e_requires = "";
 if(isset($myShow) && $myShow == '1'){
-   $_SESSION["mb_user_myGui"] = $guiList1;
+	 Mapbender::session()->set("mb_user_myGui",$guiList1);
    echo "<script language='javascript'>";
    echo "window.open('../frames/login.php?".strip_tags (SID)."&mb_user_myGui=".$guiList1."','','');";
    echo "</script>";
Modified: branches/kmq_dev/http/php/mod_edit_metadata.php
--- branches/kmq_dev/http/php/mod_edit_metadata.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_edit_metadata.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -207,7 +207,7 @@
+   Mapbender::session()->get("mb_user_myGui") = $guiList1;
    echo "</script>";
@@ -353,8 +353,8 @@
 <?php
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-$permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"],true);
+$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
+$permguis = $admin->getGuisByPermission(Mapbender::session()->get("mb_user_id"),true);
 echo "<form name='form1' action='" . $self ."' method='post'>\n";
 $sql = "SELECT * from gui WHERE gui.gui_id IN (";
Modified: branches/kmq_dev/http/php/mod_exportGUI.php
--- branches/kmq_dev/http/php/mod_exportGUI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_exportGUI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -57,7 +57,7 @@
  ###export
Modified: branches/kmq_dev/http/php/mod_export_image.php
--- branches/kmq_dev/http/php/mod_export_image.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_export_image.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -20,8 +20,8 @@
 import_request_variables("PG");
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$_SESSION["mb_print_url"] = $map_url;
-$_SESSION["mb_print_resolution"] = $quality;
+Mapbender::session()->set("mb_print_url",$map_url);
+Mapbender::session()->set("mb_print_resolution",$quality);
 header("Content-type: application/png"); // mark the following content as PNG file
 $date = date("d.m.y");
 header("Content-Disposition: attachment; filename=export".$date.".png");
@@ -35,6 +35,6 @@
 #map
 //include "../classes/class_weldMaps2PNG.php";
 include "../extensions/exp_weldMaps.php";
-//$i = new weldMaps($map_urls, $_SESSION["mb_print_resolution"]);
+//$i = new weldMaps($map_urls, Mapbender::session()->get("mb_print_resolution"));
 //print $i;
Modified: branches/kmq_dev/http/php/mod_filteredGroup_Gui.php
--- branches/kmq_dev/http/php/mod_filteredGroup_Gui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGroup_Gui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -72,10 +72,9 @@
 $exists = false;
 $gui_id_array = array();
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
+$logged_user_name = Mapbender::session()->get("mb_user_name");
+$logged_user_id = Mapbender::session()->get("mb_user_id");
 /*handle remove, update and insert*****************************************************************/
 if($insert){
 	if(count($selected_gui)>0){
Modified: branches/kmq_dev/http/php/mod_filteredGroup_User.php
--- branches/kmq_dev/http/php/mod_filteredGroup_User.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGroup_User.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -122,8 +122,8 @@
 $cnt_group_group = 0;
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredGroup_filteredGui.php
--- branches/kmq_dev/http/php/mod_filteredGroup_filteredGui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGroup_filteredGui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -71,10 +71,9 @@
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredGroup_filteredUser.php
--- branches/kmq_dev/http/php/mod_filteredGroup_filteredUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGroup_filteredUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -123,11 +123,9 @@
 $exists = false;
 if($insert){
 	if(count($selected_user)>0){
Modified: branches/kmq_dev/http/php/mod_filteredGui_User.php
--- branches/kmq_dev/http/php/mod_filteredGui_User.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGui_User.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -124,10 +124,10 @@
 $exists = false;
-#echo $_SESSION["mb_user_name"];
+#echo Mapbender::session()->get("mb_user_name");
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredGui_filteredGroup.php
--- branches/kmq_dev/http/php/mod_filteredGui_filteredGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGui_filteredGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -72,8 +72,8 @@
 $exists = false;
 /*handle remove, update and insert****************************************************************/
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredGui_filteredUser.php
--- branches/kmq_dev/http/php/mod_filteredGui_filteredUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGui_filteredUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -125,8 +125,8 @@
 $gui_id_array=array();
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredGui_group.php
--- branches/kmq_dev/http/php/mod_filteredGui_group.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredGui_group.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -70,8 +70,8 @@
 $cnt_gui_group = 0;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredUser_Group.php
--- branches/kmq_dev/http/php/mod_filteredUser_Group.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredUser_Group.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -121,8 +121,8 @@
 $cnt_group_user = 0;
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredUser_Gui.php
--- branches/kmq_dev/http/php/mod_filteredUser_Gui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredUser_Gui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -127,10 +127,9 @@
 $cnt_gui_logged_user = 0;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredUser_filteredGroup.php
--- branches/kmq_dev/http/php/mod_filteredUser_filteredGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredUser_filteredGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -121,8 +121,8 @@
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredUser_filteredGui.php
--- branches/kmq_dev/http/php/mod_filteredUser_filteredGui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredUser_filteredGui.php	2009-07-01 14:40:19 UTC (rev 4271)
 if($insert){
Modified: branches/kmq_dev/http/php/mod_filteredWms_layer_topic.php
--- branches/kmq_dev/http/php/mod_filteredWms_layer_topic.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredWms_layer_topic.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -20,8 +20,8 @@
 require_once(dirname(__FILE__) . "/../classes/class_administration.php");
-$logged_user_name = $_SESSION["mb_user_name"];
-$logged_user_id = $_SESSION["mb_user_id"];
 <html>
Modified: branches/kmq_dev/http/php/mod_filteredWms_topic.php
--- branches/kmq_dev/http/php/mod_filteredWms_topic.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_filteredWms_topic.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -69,8 +69,8 @@
 	$language_suffix = "de";
 $own_gui_id_array = $admin->getGuisByOwner($logged_user_id,true);
Modified: branches/kmq_dev/http/php/mod_forgottenPassword.php
--- branches/kmq_dev/http/php/mod_forgottenPassword.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_forgottenPassword.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -57,8 +57,8 @@
 	echo "</script>";
 else {
-	$logged_user_name=$_SESSION["mb_user_name"];
-	$logged_user_id=$_SESSION["mb_user_id"];
+	$logged_user_name = Mapbender::session()->get("mb_user_name");
+	$logged_user_id = Mapbender::session()->get("mb_user_id");
 	$upd = false;
Modified: branches/kmq_dev/http/php/mod_gazetteerMetadata.php
--- branches/kmq_dev/http/php/mod_gazetteerMetadata.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_gazetteerMetadata.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,268 +1,268 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/gazetteerMetadata
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$user_id = $_SESSION["mb_user_id"];
-<html>
-<head>
-<meta name="author" content="V. Diewald">
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<meta name="DC.Rights" content="WhereGroup GmbH & Co.KG, Bonn">
-<title>Metadata search</title>
-include_once(dirname(__FILE__) . "/../include/dyn_css.php");
-<style type="text/css">
-	body{
-		font-family : Arial, Helvetica, sans-serif;
-		font-size : 12px;
-		font-weight : bold;
-		color: #808080;
-	a:link{
-		text-decoration : none;
-		color: #808080;
-		font-size : 12px;
-		font-weight : normal;
-	a:visited{
-		color: #808080;
-		font-size : 12px;
-	a:hover{
-		color: #808080;
-	a:active{
-		color: #808080;
-	.textfield{
-		border : 2 solid #D3D3D3;
-		font-size : 12px;
-		color: #000000;
-		width: 120px;
-	.result{
-		position: absolute;
-		top: 40px;
-		left: 0px;
-</style>
-<script type="text/javascript">
-function validate(){
-   if(document.form1.search.value.length < 1){
-      alert("Please insert a keyword!");
-      document.form1.search.focus();
-      return false;
-   else{
-		document.getElementById("resultDivTag").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
-		var ind = parent.getMapObjIndexByName('mapframe1');
-		parent.mb_ajax_json(
-			"../php/mod_gazetteerMetadata_search.php",
-				"search" : document.form1.search.value,
-				"srs" : parent.mb_mapObj[ind].epsg
-			function(jsonObj, status){
-				document.getElementById("resultDivTag").innerHTML = displayTable(jsonObj);
-		return false;
-function displayTable(obj) {
-	var text = "<table>";
-	for (var attr in obj) {
-		var resultObj = obj[attr];
-		if (typeof(resultObj) != 'function') {
-			text += "<tr><td valign='top'>";
-			var imgUrl = "";
-			var onclickFunction = "";
-			if (typeof(resultObj.layer_name) !== "undefined") {
-				imgUrl = "../img/button_gray/metadata_layer.gif";
-				onclickFunction = "mod_addWMSLayerfromfilteredList(\"" +
-					resultObj.wms_getcapabilities + "\",\"" +
-					resultObj.wms_version + "\", \"" +
-					resultObj.layer_name+"\");";
-			else {
-				imgUrl = "../img/button_gray/metadata_wms.gif";
-				onclickFunction = "mod_addWMSfromfilteredList(\"" +
-					resultObj.wms_version+"\");";
-			text += "<img name='add_wms' src='" + imgUrl + "' ";
-			text += "border='0' title='Load' ";
-			text += "onclick='" + onclickFunction + "'>";
-			if (resultObj.extent && resultObj.extent[0] !== null) {
-				text += "<img src='../img/tree_new/zoom.png' " +
-					"onclick='" +
-					"parent.mb_calculateExtent(\"mapframe1\", " +
-					resultObj.extent[0] + "," +
-					resultObj.extent[1] + "," +
-					resultObj.extent[2] + "," +
-					resultObj.extent[3] + ");" +
-					"parent.zoom(\"mapframe1\", \"true\", 1.0);" +
-			text += "</td><td>";
-			text += "<a href='#' ";
-			text += "onclick='javascript:window.open(\"mod_layerMetadata.php?id=" +
-				resultObj.layer_id +
-				"\", \"metadata\", \"width=450, height=600\");' title='Info'>";
-			text += resultObj.title+"</a>";
-			text += "</td></tr>";
-	text += "</table>";
-	return text;
-function handleLayer(sel_lay, wms_title){
-	//var wms_title = document.forms[0].wmsTitle.value
-	var x = new Array();
-    x[0] = sel_lay;
-    var y = new Array();
-    if (backlink =='parent'){
-		var wms_ID = parent.parent.getWMSIDByTitle('mapframe1',wms_title);
-	else{
-		var wms_ID = parent.getWMSIDByTitle('mapframe1',wms_title);
-    y[0] = wms_ID;
-	//alert(wms_title + " -- X "+ x + "wms_id" + wms_ID);
-		parent.parent.handleSelectedLayer_array('mapframe1',y,x,'querylayer',1);
-		parent.parent.handleSelectedLayer_array('mapframe1',y,x,'visible',1);
-	else{
-		parent.handleSelectedLayer_array('mapframe1',y,x,'querylayer',1);
-		parent.handleSelectedLayer_array('mapframe1',y,x,'visible',1);
-function mod_addWMSfromfilteredList(pointer_name,version){
-	pointer_name=pointer_name + parent.parent.mb_getConjunctionCharacter(pointer_name);
-	if (version == '1.0.0'){
-		var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
-		var load = cap;
-	else if (version == '1.1.0'){
-		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
-		var load = cap;
-	else if (version == '1.1.1'){
-		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
-		var load = cap;
-	//alert (load);
-	if(load){
-		if(load.charAt(0) == '/' && load.charAt(1) == 'c'){
-			parent.parent.mod_addWMS_load('http://localhost' + load);
-		else{
-			parent.parent.mod_addWMS_load(load);
-function mod_addWMSLayerfromfilteredList(pointer_name,version,layer_name){
-		var load = cap;
-		var layer_name = layer_name;
-		var load = cap;
-		var load = cap;
-	//alert (load);
-	if(load){
-			parent.parent.mod_addLayer_load('http://localhost' + load, layer_name);
-		else{
-			parent.parent.mod_addLayer_load(load, layer_name);
-</script>
-</head>
-<body leftmargin="2" topmargin="0" bgcolor="#ffffff">
-<form name='form1' target='result' onsubmit='return validate();'>
-<p>
-<input class='textfield' name='search' type='text' style='width:110px'>
-<img src="../img/add.png" title="keywords" onclick="window.open('mod_SelectKeyword.php','SelectKeyword','width=600,height=400,status=no');">
-<input type='submit' name='send' value='ok'>
-</p>
-</form>
-<div id='resultDivTag' class='result'></div>
-</body>
-</html>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/gazetteerMetadata
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$user_id = Mapbender::session()->get("mb_user_id");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta name="author" content="V. Diewald">
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<meta name="DC.Rights" content="WhereGroup GmbH & Co.KG, Bonn">
+<title>Metadata search</title>
+include_once(dirname(__FILE__) . "/../include/dyn_css.php");
+<style type="text/css">
+	body{
+		font-family : Arial, Helvetica, sans-serif;
+		font-size : 12px;
+		font-weight : bold;
+		color: #808080;
+	a:link{
+		text-decoration : none;
+		color: #808080;
+		font-size : 12px;
+		font-weight : normal;
+	a:visited{
+		color: #808080;
+		font-size : 12px;
+	a:hover{
+		color: #808080;
+	a:active{
+		color: #808080;
+	.textfield{
+		border : 2 solid #D3D3D3;
+		font-size : 12px;
+		color: #000000;
+		width: 120px;
+	.result{
+		position: absolute;
+		top: 40px;
+		left: 0px;
+</style>
+<script type="text/javascript">
+function validate(){
+   if(document.form1.search.value.length < 1){
+      alert("Please insert a keyword!");
+      document.form1.search.focus();
+      return false;
+   else{
+		document.getElementById("resultDivTag").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
+		var ind = parent.getMapObjIndexByName('mapframe1');
+		parent.mb_ajax_json(
+			"../php/mod_gazetteerMetadata_search.php",
+				"search" : document.form1.search.value,
+				"srs" : parent.mb_mapObj[ind].epsg
+			function(jsonObj, status){
+				document.getElementById("resultDivTag").innerHTML = displayTable(jsonObj);
+		return false;
+function displayTable(obj) {
+	var text = "<table>";
+	for (var attr in obj) {
+		var resultObj = obj[attr];
+		if (typeof(resultObj) != 'function') {
+			text += "<tr><td valign='top'>";
+			var imgUrl = "";
+			var onclickFunction = "";
+			if (typeof(resultObj.layer_name) !== "undefined") {
+				imgUrl = "../img/button_gray/metadata_layer.gif";
+				onclickFunction = "mod_addWMSLayerfromfilteredList(\"" +
+					resultObj.wms_getcapabilities + "\",\"" +
+					resultObj.wms_version + "\", \"" +
+					resultObj.layer_name+"\");";
+			else {
+				imgUrl = "../img/button_gray/metadata_wms.gif";
+				onclickFunction = "mod_addWMSfromfilteredList(\"" +
+					resultObj.wms_version+"\");";
+			text += "<img name='add_wms' src='" + imgUrl + "' ";
+			text += "border='0' title='Load' ";
+			text += "onclick='" + onclickFunction + "'>";
+			if (resultObj.extent && resultObj.extent[0] !== null) {
+				text += "<img src='../img/tree_new/zoom.png' " +
+					"onclick='" +
+					"parent.mb_calculateExtent(\"mapframe1\", " +
+					resultObj.extent[0] + "," +
+					resultObj.extent[1] + "," +
+					resultObj.extent[2] + "," +
+					resultObj.extent[3] + ");" +
+					"parent.zoom(\"mapframe1\", \"true\", 1.0);" +
+			text += "</td><td>";
+			text += "<a href='#' ";
+			text += "onclick='javascript:window.open(\"mod_layerMetadata.php?id=" +
+				resultObj.layer_id +
+				"\", \"metadata\", \"width=450, height=600\");' title='Info'>";
+			text += resultObj.title+"</a>";
+			text += "</td></tr>";
+	text += "</table>";
+	return text;
+function handleLayer(sel_lay, wms_title){
+	//var wms_title = document.forms[0].wmsTitle.value
+	var x = new Array();
+    x[0] = sel_lay;
+    var y = new Array();
+    if (backlink =='parent'){
+		var wms_ID = parent.parent.getWMSIDByTitle('mapframe1',wms_title);
+	else{
+		var wms_ID = parent.getWMSIDByTitle('mapframe1',wms_title);
+    y[0] = wms_ID;
+	//alert(wms_title + " -- X "+ x + "wms_id" + wms_ID);
+		parent.parent.handleSelectedLayer_array('mapframe1',y,x,'querylayer',1);
+		parent.parent.handleSelectedLayer_array('mapframe1',y,x,'visible',1);
+	else{
+		parent.handleSelectedLayer_array('mapframe1',y,x,'querylayer',1);
+		parent.handleSelectedLayer_array('mapframe1',y,x,'visible',1);
+function mod_addWMSfromfilteredList(pointer_name,version){
+	pointer_name=pointer_name + parent.parent.mb_getConjunctionCharacter(pointer_name);
+	if (version == '1.0.0'){
+		var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
+		var load = cap;
+	else if (version == '1.1.0'){
+		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
+		var load = cap;
+	else if (version == '1.1.1'){
+		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
+		var load = cap;
+	//alert (load);
+	if(load){
+		if(load.charAt(0) == '/' && load.charAt(1) == 'c'){
+			parent.parent.mod_addWMS_load('http://localhost' + load);
+		else{
+			parent.parent.mod_addWMS_load(load);
+function mod_addWMSLayerfromfilteredList(pointer_name,version,layer_name){
+		var load = cap;
+		var layer_name = layer_name;
+		var load = cap;
+		var load = cap;
+	//alert (load);
+	if(load){
+			parent.parent.mod_addLayer_load('http://localhost' + load, layer_name);
+		else{
+			parent.parent.mod_addLayer_load(load, layer_name);
+</script>
+</head>
+<body leftmargin="2" topmargin="0" bgcolor="#ffffff">
+<form name='form1' target='result' onsubmit='return validate();'>
+<p>
+<input class='textfield' name='search' type='text' style='width:110px'>
+<img src="../img/add.png" title="keywords" onclick="window.open('mod_SelectKeyword.php','SelectKeyword','width=600,height=400,status=no');">
+<input type='submit' name='send' value='ok'>
+</p>
+</form>
+<div id='resultDivTag' class='result'></div>
+</body>
+</html>
Modified: branches/kmq_dev/http/php/mod_gazetteerMetadata_search.php
--- branches/kmq_dev/http/php/mod_gazetteerMetadata_search.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_gazetteerMetadata_search.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,125 +1,125 @@
-<?php
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$json = new Mapbender_JSON();
-$query = stripslashes($_REQUEST["search"]);
-$srs = stripslashes($_REQUEST["srs"]);
-if (!preg_match("/^[a-zA-Z_\- ]+$/", $query)) {
-	echo "[]"; die;
-if (!preg_match("/^[a-zA-Z_\-:0-9 ]+$/", $srs)) {
-	echo "[]"; die;
-$n = new administration();
-$myguis = $n->getGuisByPermission($user_id, true);
-$mywms = $n->getWmsByOwnGuis($myguis);
-if($mywms == false){
-	$mywms = array();
-$mylayer = array();
-for($i = 0; $i < count($mywms); $i++){
-	$mylayer = array_merge($mylayer,$n->getLayerByWms($mywms[$i]));
-$res_container_wms = array();
-$res_container_layer = array();
-$obj = array();
-if(preg_match("/\*/",$_REQUEST["search"])){
-	$search = trim(preg_replace("/\*/i","", $_REQUEST["search"]));
-if (count($mywms) > 0) {
-	$v = array();
-	$t = array();
-	$sql_wms = "SELECT DISTINCT layer.layer_id, wms.wms_title, " .
-		"wms.wms_getcapabilities, wms.wms_version, " .
-		"e.minx, e.miny, e.maxx, e.maxy " .
-		"FROM wms LEFT JOIN layer ON wms.wms_id = layer.fkey_wms_id " .
-		"LEFT JOIN layer_epsg e ON layer.layer_id = e.fkey_layer_id " .
-		"AND e.epsg = '$srs' " .
-		"WHERE layer.layer_pos = 0 AND wms.wms_id IN (";
-	for($i=0; $i<count($mywms); $i++){
-		if ($i > 0) {$sql_wms .= ",";}
-		$sql_wms .= "$".($i+1);
-		array_push($v, $mywms[$i]);
-		array_push($t, 'i');
-	$sql_wms .= ") AND (wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%') ORDER BY wms_title";
-	$res_wms = db_prep_query($sql_wms,$v,$t);
-	while ($row = db_fetch_array($res_wms)) {
-		array_push($obj, array(
-			'wms_getcapabilities' => $row['wms_getcapabilities'],
-			'wms_version' => $row['wms_version'],
-			'layer_id' => $row['layer_id'],
-			'title' => $row['wms_title'],
-			'extent' => array(
-				$row['minx'],
-				$row['miny'],
-				$row['maxx'],
-				$row['maxy']
-if (count($mylayer) > 0) {
-	$v = array();
-	$t = array();
-	$sql_layer = "SELECT DISTINCT l.layer_id, l.fkey_wms_id, l.layer_title, " .
-		"l.layer_name, w.wms_getcapabilities, w.wms_version, " .
-		"FROM layer l LEFT JOIN layer_keyword lkw " .
-		"LEFT JOIN keyword kw ON kw.keyword_id = lkw.fkey_keyword_id " .
-		"ON l.layer_id = lkw.fkey_layer_id " .
-		"LEFT JOIN wms w ON l.fkey_wms_id = w.wms_id " .
-		"LEFT JOIN layer_epsg e ON l.layer_id = e.fkey_layer_id " .
-		"WHERE l.layer_id IN (";
-	for($i = 0; $i < count($mylayer); $i++){
-		if ($i > 0) {$sql_layer .= ",";}
-		$sql_layer .= "$".($i+1);
-		array_push($v, $mylayer[$i]);
-	$sql_layer .= ") AND (" .
-		"layer_title ILIKE '%".$query."%' OR " .
-		"layer_name ILIKE '%".$query."%' OR " .
-		"layer_abstract ILIKE '%".$query."%' OR " .
-		"kw.keyword ILIKE '%".$query."%') ";
-	$sql_layer .= "ORDER BY l.layer_title;";
-	$res_layer = db_prep_query($sql_layer,$v,$t);
-	while ($row = db_fetch_array($res_layer)) {
-			'layer_name' => $row['layer_name'],
-			'title' => $row['layer_title'],
-				$row['minx'],
-				$row['miny'],
-				$row['maxx'],
-				$row['maxy']
-$output = $json->encode($obj);
-echo $output;
+<?php
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$json = new Mapbender_JSON();
+$query = stripslashes($_REQUEST["search"]);
+$srs = stripslashes($_REQUEST["srs"]);
+if (!preg_match("/^[a-zA-Z_\- ]+$/", $query)) {
+	echo "[]"; die;
+if (!preg_match("/^[a-zA-Z_\-:0-9 ]+$/", $srs)) {
+	echo "[]"; die;
+$n = new administration();
+$myguis = $n->getGuisByPermission($user_id, true);
+$mywms = $n->getWmsByOwnGuis($myguis);
+if($mywms == false){
+	$mywms = array();
+$mylayer = array();
+for($i = 0; $i < count($mywms); $i++){
+	$mylayer = array_merge($mylayer,$n->getLayerByWms($mywms[$i]));
+$res_container_wms = array();
+$res_container_layer = array();
+$obj = array();
+if(preg_match("/\*/",$_REQUEST["search"])){
+	$search = trim(preg_replace("/\*/i","", $_REQUEST["search"]));
+if (count($mywms) > 0) {
+	$v = array();
+	$t = array();
+	$sql_wms = "SELECT DISTINCT layer.layer_id, wms.wms_title, " .
+		"wms.wms_getcapabilities, wms.wms_version, " .
+		"e.minx, e.miny, e.maxx, e.maxy " .
+		"FROM wms LEFT JOIN layer ON wms.wms_id = layer.fkey_wms_id " .
+		"LEFT JOIN layer_epsg e ON layer.layer_id = e.fkey_layer_id " .
+		"AND e.epsg = '$srs' " .
+		"WHERE layer.layer_pos = 0 AND wms.wms_id IN (";
+	for($i=0; $i<count($mywms); $i++){
+		if ($i > 0) {$sql_wms .= ",";}
+		$sql_wms .= "$".($i+1);
+		array_push($v, $mywms[$i]);
+		array_push($t, 'i');
+	$sql_wms .= ") AND (wms_title ILIKE '%".$query."%' OR wms_abstract ILIKE '%".$query."%') ORDER BY wms_title";
+	$res_wms = db_prep_query($sql_wms,$v,$t);
+	while ($row = db_fetch_array($res_wms)) {
+		array_push($obj, array(
+			'wms_getcapabilities' => $row['wms_getcapabilities'],
+			'wms_version' => $row['wms_version'],
+			'layer_id' => $row['layer_id'],
+			'title' => $row['wms_title'],
+			'extent' => array(
+				$row['minx'],
+				$row['miny'],
+				$row['maxx'],
+				$row['maxy']
+if (count($mylayer) > 0) {
+	$v = array();
+	$t = array();
+	$sql_layer = "SELECT DISTINCT l.layer_id, l.fkey_wms_id, l.layer_title, " .
+		"l.layer_name, w.wms_getcapabilities, w.wms_version, " .
+		"FROM layer l LEFT JOIN layer_keyword lkw " .
+		"LEFT JOIN keyword kw ON kw.keyword_id = lkw.fkey_keyword_id " .
+		"ON l.layer_id = lkw.fkey_layer_id " .
+		"LEFT JOIN wms w ON l.fkey_wms_id = w.wms_id " .
+		"LEFT JOIN layer_epsg e ON l.layer_id = e.fkey_layer_id " .
+		"WHERE l.layer_id IN (";
+	for($i = 0; $i < count($mylayer); $i++){
+		if ($i > 0) {$sql_layer .= ",";}
+		$sql_layer .= "$".($i+1);
+		array_push($v, $mylayer[$i]);
+	$sql_layer .= ") AND (" .
+		"layer_title ILIKE '%".$query."%' OR " .
+		"layer_name ILIKE '%".$query."%' OR " .
+		"layer_abstract ILIKE '%".$query."%' OR " .
+		"kw.keyword ILIKE '%".$query."%') ";
+	$sql_layer .= "ORDER BY l.layer_title;";
+	$res_layer = db_prep_query($sql_layer,$v,$t);
+	while ($row = db_fetch_array($res_layer)) {
+			'layer_name' => $row['layer_name'],
+			'title' => $row['layer_title'],
+				$row['minx'],
+				$row['miny'],
+				$row['maxx'],
+				$row['maxy']
+$output = $json->encode($obj);
+echo $output;
Modified: branches/kmq_dev/http/php/mod_group_filteredGui.php
--- branches/kmq_dev/http/php/mod_group_filteredGui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_group_filteredGui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -71,8 +71,8 @@
 $exists = false;
 /*handle remove, update and insert**************************************************************************************/
Modified: branches/kmq_dev/http/php/mod_group_filteredUser.php
--- branches/kmq_dev/http/php/mod_group_filteredUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_group_filteredUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -120,8 +120,8 @@
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_gui_filteredGroup.php
--- branches/kmq_dev/http/php/mod_gui_filteredGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_gui_filteredGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -70,8 +70,8 @@
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_gui_filteredUser.php
--- branches/kmq_dev/http/php/mod_gui_filteredUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_gui_filteredUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -123,8 +123,8 @@
 $exists = false;
 if($insert){
Modified: branches/kmq_dev/http/php/mod_gui_owner.php
--- branches/kmq_dev/http/php/mod_gui_owner.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_gui_owner.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -164,7 +164,7 @@
 /*get own guis  ********************************************************************************************/
 $admin = new administration();
 if (count($ownguis)>0){
 	$v = array();
 	$t = array();
Modified: branches/kmq_dev/http/php/mod_loadCapabilities.php
--- branches/kmq_dev/http/php/mod_loadCapabilities.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_loadCapabilities.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -86,7 +86,7 @@
 echo "<table cellpadding='0' cellspacing='0' border='0'>";
@@ -114,7 +114,7 @@
 		echo ">".$row["gui_name"]."</option>";
-	$arrayGUIs=$_SESSION["mb_user_guis"];
+	$arrayGUIs = Mapbender::session()->get("mb_user_id");
 	echo count($arrayGUIs);
 	echo "</select><br><br>";
 	echo "</td>";
Modified: branches/kmq_dev/http/php/mod_loadCapabilitiesList.php
--- branches/kmq_dev/http/php/mod_loadCapabilitiesList.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_loadCapabilitiesList.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,307 +1,306 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-import_request_variables("PG");
-require(dirname(__FILE__)."/../php/mb_validatePermission.php");
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Load WMS from Catalog</title>
-<?php
-include '../include/dyn_css.php';
-  	body{
-      background-color: #ffffff;
-  		font-family: Arial, Helvetica, sans-serif;
-  		font-size : 12px;
-  		color: #808080
-  	.list_guis{
-  		font-size : 12px;
-  		color: #808080;
-.text1{
-   font-size : 15px;
-   position:absolute;
-   top:190px;
-.select1{
-   top:210px;
-   width:270px;
-.text2{
-   font-size : 15px;
-   top:190px;
-   left:300px;
-.select2{
-   top:210px;
-   left:300px;
-.getcapabilities{
-   font-size : 15px;
-   top:570px;
-</style>
-<script language="JavaScript">
-function validate(wert){
-   if(wert == 'guiList'){
-      var listIndex = document.form1.guiList.selectedIndex;
-      if(listIndex<0){
-		   alert("Please select a GUI.");
-			return false;
-      else{
-         var gui_id=document.form1.guiList.options[listIndex].value;
-			document.form1.action='../php/mod_loadwms.php<?php echo SID;?>';
-			document.form1.submit();
-function load(){
-      if(document.form1.guiList.selectedIndex<0){
-			return false;
-      var gui_ind = document.form1.guiList.selectedIndex;
-      var ind = document.form1.wmsID.selectedIndex;
-      var ind2 = document.form1.guiID_.selectedIndex;
-			var indexWMSList = document.form1.wmsID.selectedIndex;
-			var permission = true;
-			var selectedWmsId = document.form1.wmsID.options[document.form1.wmsID.selectedIndex].value;
-			for (i = 0; i < document.form1.wmsList.length; i++) {
-						if (document.form1.wmsList.options[i].value == selectedWmsId){
-							 permission = false;
-							 alert ('The WMS (' + selectedWmsId + ') is already loaded in this application.');
-							 break;
-  			if (permission) { // only check if permission is not false
-        	var loadConfirmed = confirm("Load " + document.form1.wmsID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
-          if(loadConfirmed){
-          else{
-             document.form1.guiID_.selectedIndex = -1;
-</script>
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-###INSERT
-if(isset($wmsID) && isset($guiID_)){
-	$sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
-	$v = array($guiList);
-	$t = array('s');
-	$res_pos = db_prep_query($sql_pos,$v,$t);
-	if(db_result($res_pos,0,"my_gui_wms_position") > -1){
-		$gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
-	else{
-		$gui_wms_position = 0;
-	$sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-	$v = array($guiID_,$wmsID);
-	$t = array('s','i');
-	$res = db_prep_query($sql,$v,$t);
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		$sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
-		$sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl) ";
-		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
-		$v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
-		$row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"],$row["gui_wms_opacity"],$row["gui_wms_sldurl"]);
-		$t = array('s','i','i','s','s','s','s','i','i','s');
-		db_prep_query($sql_ins,$v,$t);
-		$cnt++;
-	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
-	$v = array($guiID_, $wmsID);
-	$res = db_prep_query($sql, $v, $t);
-	$cnt = 0;
-		$sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
-		$sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype) ";
-		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13)";
-		$v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
-		$row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
-		$row["gui_layer_maxscale"],$row["gui_layer_priority"],$row["gui_layer_style"],$row["gui_layer_wfs_featuretype"]);
-		$t = array('s','i','i','i','i','i','i','i','i','i','i','s','s');
-		$cnt++;
-echo "<form name='form1' action='" . $self."' method='post'>";
-echo "<table cellpadding='0' cellspacing='0' border='0'>";
-echo "<tr>";
-echo "<td>";
-if (count($ownguis)>0){
-	echo"GUI";
-	echo"<br>";
-	$sql = "SELECT * FROM gui WHERE gui_id IN (";
-	$v = $ownguis;
-	$t = array();
-	for ($i = 1; $i <= count($ownguis); $i++){
-		if ($i > 1) {
-			$sql .= ",";
-		$sql .= "$".$i;
-	$sql .= ") ORDER BY gui_name";
-	$count=0;
-	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
-		$gui_name[$count]=$row["gui_name"];
-		$gui_description[$count]=$row["gui_description"];
-		$count++;
-		echo "<option value='".$row["gui_id"]."' ";
-		if($guiList && $guiList == $row["gui_name"]){
-			echo "selected";
-		echo ">".$row["gui_name"]."</option>";
-	echo count($arrayGUIs);
-	echo "</select><br><br>";
-	echo "</td>";
-	echo "<td>";
-	echo"WMS";
-	echo"<br>";
-	if(isset($guiList) && $guiList!=""){
-		$sql = "SELECT DISTINCT wms_id, wms.wms_title, gui_wms_position FROM gui_wms ";
-		$sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
-		$sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
-		$t = array('s');
-		$count=0;
-		echo"<select size='8' name='wmsList' style='width:200px'>";
-			if ($row["wms_title"]!=""){
-				echo "<option value='".$row["wms_id"]."' ";
-				echo ">".$row["wms_title"]."</option>";
-			$count++;
-	}else{
-		echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
-	echo "</td>";
-	echo "<tr></table><br>";
-	echo"<div class='text1'>Load WMS</div>";
-	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
-	$sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
-	$v = $arrayGUIs;
-	$t = array();
-	for ($i = 1; $i <= count($arrayGUIs); $i++){
-		if ($i > 1) {
-			$sql .= ",";
-		$sql .= "$" . $i;
-		array_push($t, "s");
-	$sql .= ") ORDER BY wms.wms_title";
-	echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
-	$cnt = 0;
-		if($row["wms_owner"] == $_SESSION["mb_user_id"]){
-			echo "style='color:green' ";
-		else{
-			echo "style='color:red' ";
-		if(isset($wmsID) && $wmsID == $row["wms_id"]){
-			echo "selected";
-			$wms_getcapabilities = $row["wms_getcapabilities"];
-		$cnt++;
-	echo "</select>";
-	if(isset($wmsID)){
-		echo "<div class='text2'>FROM:</div>";
-		$sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
-		$v = array($wmsID);
-		$t = array("s");
-		echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
-		$cnt = 0;
-			echo "<option value='".$row["fkey_gui_id"]."' ";
-			echo ">".$row["fkey_gui_id"]."</option>";
-			$cnt++;
-	echo "</select>";
-echo "</form>";
-}else{
-	echo "There are no guis available for this user. Please create a gui first.";
-echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
-</body>
-</html>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+import_request_variables("PG");
+require(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Load WMS from Catalog</title>
+<?php
+include '../include/dyn_css.php';
+  	body{
+      background-color: #ffffff;
+  		font-family: Arial, Helvetica, sans-serif;
+  		font-size : 12px;
+  		color: #808080
+  	.list_guis{
+  		font-size : 12px;
+  		color: #808080;
+.text1{
+   font-size : 15px;
+   position:absolute;
+   top:190px;
+.select1{
+   top:210px;
+   width:270px;
+.text2{
+   font-size : 15px;
+   top:190px;
+   left:300px;
+.select2{
+   top:210px;
+   left:300px;
+.getcapabilities{
+   font-size : 15px;
+   top:570px;
+</style>
+<script language="JavaScript">
+function validate(wert){
+   if(wert == 'guiList'){
+      var listIndex = document.form1.guiList.selectedIndex;
+      if(listIndex<0){
+		   alert("Please select a GUI.");
+			return false;
+      else{
+         var gui_id=document.form1.guiList.options[listIndex].value;
+			document.form1.action='../php/mod_loadwms.php<?php echo SID;?>';
+			document.form1.submit();
+function load(){
+      if(document.form1.guiList.selectedIndex<0){
+			return false;
+      var gui_ind = document.form1.guiList.selectedIndex;
+      var ind = document.form1.wmsID.selectedIndex;
+      var ind2 = document.form1.guiID_.selectedIndex;
+			var indexWMSList = document.form1.wmsID.selectedIndex;
+			var permission = true;
+			var selectedWmsId = document.form1.wmsID.options[document.form1.wmsID.selectedIndex].value;
+			for (i = 0; i < document.form1.wmsList.length; i++) {
+						if (document.form1.wmsList.options[i].value == selectedWmsId){
+							 permission = false;
+							 alert ('The WMS (' + selectedWmsId + ') is already loaded in this application.');
+							 break;
+  			if (permission) { // only check if permission is not false
+        	var loadConfirmed = confirm("Load " + document.form1.wmsID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
+          if(loadConfirmed){
+          else{
+             document.form1.guiID_.selectedIndex = -1;
+</script>
+</head>
+<body>
+<?php
+$admin = new administration();
+###INSERT
+if(isset($wmsID) && isset($guiID_)){
+	$sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
+	$v = array($guiList);
+	$t = array('s');
+	$res_pos = db_prep_query($sql_pos,$v,$t);
+	if(db_result($res_pos,0,"my_gui_wms_position") > -1){
+		$gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
+	else{
+		$gui_wms_position = 0;
+	$sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+	$v = array($guiID_,$wmsID);
+	$t = array('s','i');
+	$res = db_prep_query($sql,$v,$t);
+	$cnt = 0;
+	while($row = db_fetch_array($res)){
+		$sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
+		$sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
+		$v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
+		$row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"],$row["gui_wms_opacity"],$row["gui_wms_sldurl"]);
+		$t = array('s','i','i','s','s','s','s','i','i','s');
+		db_prep_query($sql_ins,$v,$t);
+		$cnt++;
+	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
+	$v = array($guiID_, $wmsID);
+	$res = db_prep_query($sql, $v, $t);
+	$cnt = 0;
+		$sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
+		$sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13)";
+		$v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
+		$row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
+		$row["gui_layer_maxscale"],$row["gui_layer_priority"],$row["gui_layer_style"],$row["gui_layer_wfs_featuretype"]);
+		$t = array('s','i','i','i','i','i','i','i','i','i','i','s','s');
+		$cnt++;
+echo "<form name='form1' action='" . $self."' method='post'>";
+echo "<table cellpadding='0' cellspacing='0' border='0'>";
+echo "<tr>";
+echo "<td>";
+if (count($ownguis)>0){
+	echo"GUI";
+	echo"<br>";
+	$sql = "SELECT * FROM gui WHERE gui_id IN (";
+	$v = $ownguis;
+	$t = array();
+	for ($i = 1; $i <= count($ownguis); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$".$i;
+	$sql .= ") ORDER BY gui_name";
+	$count=0;
+	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
+		$gui_name[$count]=$row["gui_name"];
+		$gui_description[$count]=$row["gui_description"];
+		$count++;
+		echo "<option value='".$row["gui_id"]."' ";
+		if($guiList && $guiList == $row["gui_name"]){
+			echo "selected";
+		echo ">".$row["gui_name"]."</option>";
+	echo count($arrayGUIs);
+	echo "</select><br><br>";
+	echo "</td>";
+	echo "<td>";
+	echo"WMS";
+	echo"<br>";
+	if(isset($guiList) && $guiList!=""){
+		$sql = "SELECT DISTINCT wms_id, wms.wms_title, gui_wms_position FROM gui_wms ";
+		$sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
+		$sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
+		$t = array('s');
+		$count=0;
+		echo"<select size='8' name='wmsList' style='width:200px'>";
+			if ($row["wms_title"]!=""){
+				echo "<option value='".$row["wms_id"]."' ";
+				echo ">".$row["wms_title"]."</option>";
+			$count++;
+	}else{
+		echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
+	echo "</td>";
+	echo "<tr></table><br>";
+	echo"<div class='text1'>Load WMS</div>";
+	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
+	$sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
+	$v = $arrayGUIs;
+	$t = array();
+	for ($i = 1; $i <= count($arrayGUIs); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$" . $i;
+	$sql .= ") ORDER BY wms.wms_title";
+	echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
+	$cnt = 0;
+		if($row["wms_owner"] == Mapbender::session()->get("mb_user_id")){
+			echo "style='color:green' ";
+		else{
+			echo "style='color:red' ";
+		if(isset($wmsID) && $wmsID == $row["wms_id"]){
+			echo "selected";
+			$wms_getcapabilities = $row["wms_getcapabilities"];
+		$cnt++;
+	echo "</select>";
+	if(isset($wmsID)){
+		echo "<div class='text2'>FROM:</div>";
+		$sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
+		$v = array($wmsID);
+		$t = array("s");
+		echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
+		$cnt = 0;
+			echo "<option value='".$row["fkey_gui_id"]."' ";
+			echo ">".$row["fkey_gui_id"]."</option>";
+			$cnt++;
+	echo "</select>";
+echo "</form>";
+}else{
+	echo "There are no guis available for this user. Please create a gui first.";
+echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
+</body>
+</html>
Modified: branches/kmq_dev/http/php/mod_loadWFSCapabilities.php
--- branches/kmq_dev/http/php/mod_loadWFSCapabilities.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_loadWFSCapabilities.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -85,7 +85,7 @@
 <?php
 echo count($ownguis)."<br>";
 echo "<form name='form1' action='" . $self ."' method='post'>";
Modified: branches/kmq_dev/http/php/mod_loadwmc_server.php
--- branches/kmq_dev/http/php/mod_loadwmc_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_loadwmc_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,180 +1,180 @@
-<?php
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_user.php");
-require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
-require_once(dirname(__FILE__) . "/../classes/class_json.php");
-require_once(dirname(__FILE__) . "/../classes/class_administration.php");
- * encodes and delivers the data
- * @param object the un-encoded object
-function sendOutput($out){
-	global $json;
-	$output = $json->encode($out);
-	if (CHARSET == "ISO-8859-1") {
-		$output = utf8_decode($output);
-	header("Content-Type: text/x-json");
-	echo $output;
- * Get all available WMC documents from the database
- * @return mixed[] an array of wmcs
- * 					(wmc = assoc. array of "id", "title", "timestamp")
-function getWmc(){
-	global $con;
-	global $userId;
-	$wmcArray = array();
-	// get WMC ids
-	$currentUser = new User($userId);
-	$wmcIdArray = $currentUser->getWmcByOwner();
-	// get WMC data
-	$v = array();
-	$t = array();
-	$wmcIdList = "";
-	for ($i = 0; $i < count($wmcIdArray); $i++) {
-		if ($i > 0) {
-			$wmcIdList .= ",";
-		$wmcIdList .= "$".($i+1);
-		array_push($v, $wmcIdArray[$i]);
-		array_push($t, 's');
-	if ($wmcIdList !== "") {
-		$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
-		$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
-		$sql .=	"ORDER BY wmc_timestamp DESC";
-			$currentResult = array();
-			$currentResult["id"] = $row["wmc_id"];
-			$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
-			$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
-			array_push($wmcArray, $currentResult);
-	return $wmcArray;
-$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
-$resultObj = array();
-$e = new mb_exception("command: " . $queryObj->command);
-$wmc = new wmc();
-$userId = $_SESSION[mb_user_id];
-switch($queryObj->command){
-	// gets available WMCs
-	case 'getWmc':
-		$resultObj["wmc"] = getWmc();
-	break;
-	// gets XML document of a WMC
-	case 'getWmcDocument':
-		$wmcId = $queryObj->parameters->id;
-		$doc = $wmc->getDocument($wmcId);
-		if (!$doc) {
-			$resultObj["error"] = "The WMC document could not be found.";
-		else {
-			$resultObj["wmc"] = array("document" => $doc);
-	break;
-	// deletes a WMC
-	case 'deleteWmc':
-		if ($wmc->delete($wmcId)) {
-			$resultObj["success"] = "WMC has been deleted from the database.";
-		else {
-			$resultObj["error"] = "WMC could not be deleted.";
-	break;
-	// loads a WMC (returns array of JS code)
-	case 'loadWmc':
-		$wmc->createFromDb($wmcId);
-		$jsArray = $wmc->toJavaScript();
-		if ($jsArray) {
-			$resultObj["javascript"] = $jsArray;
-		else {
-			$resultObj["error"] = "WMC could not be loaded.";
-	break;
-	// merges data with WMC and loads it (returns array of JS code)
-	case 'mergeWmc':
-		$params = $queryObj->parameters;
-		// generate a WMC for the current client state
-		$currentWmc = new wmc();
-		$currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
-		// get the desired WMC from the database
-		$wmcXml = wmc::getDocument($wmcId);
-		// merge the two WMCs
-		$currentWmc->merge($wmcXml);
-		// load the merged WMC
-		$jsArray = $currentWmc->toJavaScript();
-		if (is_array($jsArray) && count($jsArray) > 0) {
-		else {
-	break;
-	// appends a WMC (returns JS code)
-	case 'appendWmc':
-		$currentWmc->append($wmcXml);
-		else {
-			$resultObj["error"] = "WMC could not be appended.";
-	break;
-	// Invalid command
-	default:
-		$resultObj["error"] = "no action specified...";
-sendOutput($resultObj);
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	if (CHARSET == "ISO-8859-1") {
+		$output = utf8_decode($output);
+	header("Content-Type: text/x-json");
+	echo $output;
+ * Get all available WMC documents from the database
+ * @return mixed[] an array of wmcs
+ * 					(wmc = assoc. array of "id", "title", "timestamp")
+function getWmc(){
+	global $con;
+	global $userId;
+	$wmcArray = array();
+	// get WMC ids
+	$currentUser = new User($userId);
+	$wmcIdArray = $currentUser->getWmcByOwner();
+	// get WMC data
+	$v = array();
+	$t = array();
+	$wmcIdList = "";
+	for ($i = 0; $i < count($wmcIdArray); $i++) {
+		if ($i > 0) {
+			$wmcIdList .= ",";
+		$wmcIdList .= "$".($i+1);
+		array_push($v, $wmcIdArray[$i]);
+		array_push($t, 's');
+	if ($wmcIdList !== "") {
+		$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp FROM mb_user_wmc ";
+		$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
+		$sql .=	"ORDER BY wmc_timestamp DESC";
+			$currentResult = array();
+			$currentResult["id"] = $row["wmc_id"];
+			$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
+			$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+			array_push($wmcArray, $currentResult);
+	return $wmcArray;
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$wmc = new wmc();
+$userId = Mapbender::session()->get("mb_user_id");
+switch($queryObj->command){
+	// gets available WMCs
+	case 'getWmc':
+		$resultObj["wmc"] = getWmc();
+	break;
+	// gets XML document of a WMC
+	case 'getWmcDocument':
+		$wmcId = $queryObj->parameters->id;
+		$doc = $wmc->getDocument($wmcId);
+		if (!$doc) {
+			$resultObj["error"] = "The WMC document could not be found.";
+		else {
+			$resultObj["wmc"] = array("document" => $doc);
+	break;
+	// deletes a WMC
+	case 'deleteWmc':
+		if ($wmc->delete($wmcId)) {
+			$resultObj["success"] = "WMC has been deleted from the database.";
+		else {
+			$resultObj["error"] = "WMC could not be deleted.";
+	break;
+	// loads a WMC (returns array of JS code)
+	case 'loadWmc':
+		$wmc->createFromDb($wmcId);
+		$jsArray = $wmc->toJavaScript();
+		if ($jsArray) {
+			$resultObj["javascript"] = $jsArray;
+		else {
+			$resultObj["error"] = "WMC could not be loaded.";
+	break;
+	// merges data with WMC and loads it (returns array of JS code)
+	case 'mergeWmc':
+		$params = $queryObj->parameters;
+		// generate a WMC for the current client state
+		$currentWmc = new wmc();
+		$currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
+		// get the desired WMC from the database
+		$wmcXml = wmc::getDocument($wmcId);
+		// merge the two WMCs
+		$currentWmc->merge($wmcXml);
+		// load the merged WMC
+		$jsArray = $currentWmc->toJavaScript();
+		if (is_array($jsArray) && count($jsArray) > 0) {
+		else {
+	break;
+	// appends a WMC (returns JS code)
+	case 'appendWmc':
+		$currentWmc->append($wmcXml);
+		else {
+			$resultObj["error"] = "WMC could not be appended.";
+	break;
+	// Invalid command
+	default:
+		$resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
Modified: branches/kmq_dev/http/php/mod_log.php
--- branches/kmq_dev/http/php/mod_log.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_log.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -17,7 +17,8 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$ajaxResponse = new AjaxResponse($_REQUEST);
 require(dirname(__FILE__)."/../include/dyn_php.php");
 if($_REQUEST['req']){
Modified: branches/kmq_dev/http/php/mod_map1.php
--- branches/kmq_dev/http/php/mod_map1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_map1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -32,7 +32,7 @@
 <title>mod_map1</title>
 <?php
 $sql = "SELECT e_width, e_height FROM gui_element WHERE e_id = 'mapframe1' AND fkey_gui_id = $1";
-$v = array($_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_user_id"));
 $t = array("s");
 $cnt = 0;
Modified: branches/kmq_dev/http/php/mod_mapOV.php
--- branches/kmq_dev/http/php/mod_mapOV.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_mapOV.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -41,7 +41,7 @@
 <?php
-$gui_id = $_SESSION["mb_user_gui"];
+$gui_id = Mapbender::session()->get("mb_user_gui");
 $sql = "SELECT e_width,e_height, e_target FROM gui_element WHERE e_id = 'overview' AND fkey_gui_id = $1";
 $v = array($gui_id);
 $t = array("s");
@@ -85,7 +85,7 @@
 function mod_ov_showMapExtent(){
 	for(var i=0; i<parent.mb_mapObj.length; i++){
 		if(parent.mb_mapObj[i].frameName == mod_overview_target){
-			var arrayBBox = parent.mb_mapObj[i].extent.split(",");
+			var arrayBBox = parent.mb_mapObj[i].extent.toString().split(",");
 			var minX = parseFloat(arrayBBox[0]);
 			var minY = parseFloat(arrayBBox[1]);
 			var maxX = parseFloat(arrayBBox[2]);
Modified: branches/kmq_dev/http/php/mod_meetingPoint.php
--- branches/kmq_dev/http/php/mod_meetingPoint.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_meetingPoint.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,350 +1,350 @@
-<?PHP
-# $Id$
-# http://www.mapbender.org/index.php/MeetingPoint
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>meetingPoint</title>
-<?php
-<script language='JavaScript'>
-<?php
-include('../include/dyn_js.php');
-echo "var mod_meetingPoint_target = '" . $_REQUEST["e_target"] . "';";
-echo "var meetingPoint_write_to = 'meetingPoint';";
-try{
-	if (meetingPoint_export_subject){}
-catch(e){
-	meetingPoint_export_subject = 'Your meeting point. Follow the link!';
-try{
-	if (meetingPoint_export_format){}
-catch(e){
-	meetingPoint_export_format = 'prompt';
-try{
-	if (meetingPoint_max_characters){}
-catch(e){
-	meetingPoint_max_characters = 100;
-try{
-	if (meetingPoint_image){}
-catch(e){
-	meetingPoint_image = "../img/button_digitize/point_off.png";
-try{
-	if (meetingPoint_icon){}
-catch(e){
-	meetingPoint_icon = '../img/redball.gif';
-try{
-	if (meetingPoint_width){}
-catch(e){
-	meetingPoint_width = 14;
-try{
-	if (meetingPoint_height){}
-catch(e){
-	meetingPoint_height = 14;
-try{
-	if (meetingPoint_style){}
-catch(e){
-	meetingPoint_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
-try{
-	if (meetingPoint_please_click){}
-catch(e){
-	meetingPoint_please_click = 'Please click for the meeting point position!';
-var mod_meetingPointRealPoint = null;
-//parent.mb_registerSubFunctions("window.frames['meetingPoint'].mod_meetingPoint_draw()");
-parent.eventAfterMapRequest.register(function () {
-	mod_meetingPoint_draw();
-var ie = document.all?1:0;
-var mod_meetingPoint_win = null;
-var mod_meetingPoint_elName = "meetingPoint";
-var mod_meetingPoint_frameName = "meetingPoint";
-var mod_meetingPoint_button = "my_getCoords";
-var mod_meetingPoint_img_on = new Image(); mod_meetingPoint_img_on.src = meetingPoint_image.replace(/_off/,"_on") ;
-var mod_meetingPoint_img_off = new Image(); mod_meetingPoint_img_off.src = meetingPoint_image;
-var mod_meetingPoint_img_over = new Image(); mod_meetingPoint_img_over.src = meetingPoint_image.replace(/_off/,"_over") ;
-var mod_meetingPoint_fix = "";
-function init_mod_meetingPoint(ind){
-	parent.mb_button[ind] = window.document.getElementById(mod_meetingPoint_button);
-	parent.mb_button[ind].img_over = mod_meetingPoint_img_over.src;
-	parent.mb_button[ind].img_on = mod_meetingPoint_img_on.src;
-	parent.mb_button[ind].img_off = mod_meetingPoint_img_off.src;
-	parent.mb_button[ind].status = 0;
-	parent.mb_button[ind].elName = mod_meetingPoint_button;
-	parent.mb_button[ind].go = new Function ("mod_meetingPoint_run()");
-	parent.mb_button[ind].stop = new Function ("mod_meetingPoint_disable()");
-function mod_meetingPoint_run(){
-	var mapObject = parent.getMapObjByName(mod_meetingPoint_target);
-	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = function (e) {
-			var clickPos = mapObject.getMousePosition(e);
-			mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
-			mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
-			parent.mb_disableThisButton(mod_meetingPoint_button);
-function mod_meetingPoint_disable(){
-	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = null;
-function mod_meetingPoint_click(e){
-	if(ie){
-		clickX = parent.frames[mod_meetingPoint_target].event.clientX;
-		clickY = parent.frames[mod_meetingPoint_target].event.clientY;
-	else{
-		clickX = e.pageX;
-		clickY = e.pageY;
-	var pos = parent.makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
-	mod_meetingPoint_write(pos[0],pos[1]);
-function mod_meetingPoint_write(x,y){
-   document.forms[0].x.value =x;
-   document.forms[0].y.value =y;
-function mod_meetingPoint_hide(){
-	//var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
-	//parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'hidden';
-	parent.$("#" + mapObject.elementName + "_permanent").css({
-		visibility:"hidden"
-function mod_meetingPoint_draw(){
-	if (mapObject) {
-		if (mod_meetingPointRealPoint !== null) {
-			//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " );
-			var meetingPointClickPos = mapObject.convertRealToPixel(mod_meetingPointRealPoint);
-			var tagSource = "";
-			tagSource += "<div style='z-index:13;position:absolute;left:"+(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
-			tagSource += "<img src='"+meetingPoint_icon+"'>";
-			tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"<span>";
-			tagSource += "</div>";
-			var map_el = mapObject.getDomElement();
-			if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
-				//create Box Elements
-				var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
-				$div.css({
-					position: "absolute",
-					top: "0px",
-					left: "0px",
-					zIndex: 13
-				map_el.appendChild($div.get(0));
-			parent.$("#" + mapObject.elementName + "_permanent").html(tagSource);
-	var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
-	if (document.forms[0].x.value!='' && document.forms[0].y.value != ''){
-		//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " + parent.mb_mapObj[ind].width +" iii: "+ ind);
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.width = parent.mb_mapObj[ind].width;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.height = parent.mb_mapObj[ind].height;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.top = 0;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.left = 0;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'visible';
-		var pos = parent.makeRealWorld2mapPos(mod_meetingPoint_target,document.forms[0].x.value, document.forms[0].y.value);
-		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos[0]- Math.round(0.5*meetingPoint_width))+"px;top:"+(pos[1]-Math.round(0.5*meetingPoint_height))+"px'>";
-		//prompt("meetingPoint",tagSource);
-	    parent.writeTag(mod_meetingPoint_target, "permanent", tagSource);
-</script>
-<?php
-echo "var used_charset = '".CHARSET ."';";
-	var mycheck = true;
-	var checkObj= document.forms[0].mytext.value;
-	if(checkObj == '') {
-    	alert ("Bitte geben Sie einen Text an!");
-    	checkObj.focus();
-        mycheck=false;
-    var checkObj= document.forms[0].x.value;
-    	alert (meetingPoint_please_click);
-        mycheck = false;
-    if(mycheck == true){
-    	my_meetingPoint = document.forms[0].myurl.value + "?";
-    	my_meetingPoint += "name=" + encodeURIComponent(document.forms[0].myuser.value);
-    	my_meetingPoint += "&password=" + encodeURIComponent(document.forms[0].mypw.value);
-    	my_meetingPoint += "&mb_user_myGui=" + encodeURIComponent(document.forms[0].mygui.value);
-    	var coord = parent.mb_mapObj[ind].extent.split(",");
-    	my_meetingPoint += "&mb_myBBOX=" + parseFloat(coord[0]) + ",";
-		my_meetingPoint +=  parseFloat(coord[1]) + ",";
-		my_meetingPoint +=  parseFloat(coord[2]) + ",";
-		my_meetingPoint +=  parseFloat(coord[3]) ;
-    	my_meetingPoint += "&mb_myPOI=";
-    	var splitext  = document.forms[0].mytext.value;
-    	document.forms[0].mytext.value = splitext.substring(0, meetingPoint_max_characters);
-    	my_meetingPoint += encodeURIComponent(document.forms[0].mytext.value);
-    	my_meetingPoint += "|" + document.forms[0].x.value + "|";
-    	my_meetingPoint += document.forms[0].y.value;
-    	if(meetingPoint_export_format == 'email'){
-    		createEmail(my_meetingPoint,meetingPoint_export_subject);
-		}else{
-			prompt(meetingPoint_export_subject,my_meetingPoint);
-function emptyfields(){
-	document.forms[0].mytext.value ='';
-	document.forms[0].x.value ='';
-	document.forms[0].y.value =  '';
-	 mod_meetingPoint_hide();
-function createEmail (url,subject) {
-  var email = "mailto:"
-  email  += "";
-  email  += "?subject=";
-  email  += subject;
-  email  += "&body=";
-  email  += escape(url);
-  var win = window.open(email, 'email', 'top=120,left=120');
-  win.close();
-function goBack(where){
-    document.location.href=where;
-function init(){
-	parent.mb_regButton_frame("init_mod_meetingPoint","meetingPoint",null);
-</script>
-</head>
-<body>
-<form action="" >
-<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
-<br>
-<input class='strinput' type="hidden" name='myurl' value='<?php  echo LOGIN;  ?>'>
-<input class='strinput' type="hidden" name='mygui' value='<?php  echo $_SESSION["mb_user_gui"];  ?>'>
-<input class='strinput' type="hidden" name='myuser' value='<?php  echo $_SESSION["mb_user_name"];  ?>'>
-<input class='strinput' type="hidden" name='mypw' value='<?php  echo $_SESSION["mb_user_password"];  ?>'>
-<br>
-<!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
-<textarea class='strinput' rows="3" name='mytext' title='maximal 70 Zeichen'></textarea>
-<br>
-<input class="okbutton" name="Send"   type="button" value="ok" onclick="validate();">
-<input class="ibutton" type="button" value="cancel" onClick="emptyfields();">
-<br>
-<input class="coord" type="hidden" name='x' value='' readonly>
-<input class="coord" type="hidden" name='y' value='' readonly>
-<br>
-</form>
-</body>
+<?PHP
+# $Id$
+# http://www.mapbender.org/index.php/MeetingPoint
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+<html>
+<head>
+<title>meetingPoint</title>
+<?php
+<script language='JavaScript'>
+<?php
+include('../include/dyn_js.php');
+echo "var mod_meetingPoint_target = '" . $_REQUEST["e_target"] . "';";
+echo "var meetingPoint_write_to = 'meetingPoint';";
+try{
+	if (meetingPoint_export_subject){}
+catch(e){
+	meetingPoint_export_subject = 'Your meeting point. Follow the link!';
+try{
+	if (meetingPoint_export_format){}
+catch(e){
+	meetingPoint_export_format = 'prompt';
+try{
+	if (meetingPoint_max_characters){}
+catch(e){
+	meetingPoint_max_characters = 100;
+try{
+	if (meetingPoint_image){}
+catch(e){
+	meetingPoint_image = "../img/button_digitize/point_off.png";
+try{
+	if (meetingPoint_icon){}
+catch(e){
+	meetingPoint_icon = '../img/redball.gif';
+try{
+	if (meetingPoint_width){}
+catch(e){
+	meetingPoint_width = 14;
+try{
+	if (meetingPoint_height){}
+catch(e){
+	meetingPoint_height = 14;
+try{
+	if (meetingPoint_style){}
+catch(e){
+	meetingPoint_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
+try{
+	if (meetingPoint_please_click){}
+catch(e){
+	meetingPoint_please_click = 'Please click for the meeting point position!';
+var mod_meetingPointRealPoint = null;
+//parent.mb_registerSubFunctions("window.frames['meetingPoint'].mod_meetingPoint_draw()");
+parent.eventAfterMapRequest.register(function () {
+	mod_meetingPoint_draw();
+var ie = document.all?1:0;
+var mod_meetingPoint_win = null;
+var mod_meetingPoint_elName = "meetingPoint";
+var mod_meetingPoint_frameName = "meetingPoint";
+var mod_meetingPoint_button = "my_getCoords";
+var mod_meetingPoint_img_on = new Image(); mod_meetingPoint_img_on.src = meetingPoint_image.replace(/_off/,"_on") ;
+var mod_meetingPoint_img_off = new Image(); mod_meetingPoint_img_off.src = meetingPoint_image;
+var mod_meetingPoint_img_over = new Image(); mod_meetingPoint_img_over.src = meetingPoint_image.replace(/_off/,"_over") ;
+var mod_meetingPoint_fix = "";
+function init_mod_meetingPoint(ind){
+	parent.mb_button[ind] = window.document.getElementById(mod_meetingPoint_button);
+	parent.mb_button[ind].img_over = mod_meetingPoint_img_over.src;
+	parent.mb_button[ind].img_on = mod_meetingPoint_img_on.src;
+	parent.mb_button[ind].img_off = mod_meetingPoint_img_off.src;
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = mod_meetingPoint_button;
+	parent.mb_button[ind].go = new Function ("mod_meetingPoint_run()");
+	parent.mb_button[ind].stop = new Function ("mod_meetingPoint_disable()");
+function mod_meetingPoint_run(){
+	var mapObject = parent.getMapObjByName(mod_meetingPoint_target);
+	if (mapObject) {
+		mapObject.getDomElement().ownerDocument.onclick = function (e) {
+			var clickPos = mapObject.getMousePosition(e);
+			mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
+			mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
+			parent.mb_disableThisButton(mod_meetingPoint_button);
+function mod_meetingPoint_disable(){
+	if (mapObject) {
+		mapObject.getDomElement().ownerDocument.onclick = null;
+function mod_meetingPoint_click(e){
+	if(ie){
+		clickX = parent.frames[mod_meetingPoint_target].event.clientX;
+		clickY = parent.frames[mod_meetingPoint_target].event.clientY;
+	else{
+		clickX = e.pageX;
+		clickY = e.pageY;
+	var pos = parent.makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
+	mod_meetingPoint_write(pos[0],pos[1]);
+function mod_meetingPoint_write(x,y){
+   document.forms[0].x.value =x;
+   document.forms[0].y.value =y;
+function mod_meetingPoint_hide(){
+	//var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
+	//parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'hidden';
+	parent.$("#" + mapObject.elementName + "_permanent").css({
+		visibility:"hidden"
+function mod_meetingPoint_draw(){
+	if (mapObject) {
+		if (mod_meetingPointRealPoint !== null) {
+			//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " );
+			var meetingPointClickPos = mapObject.convertRealToPixel(mod_meetingPointRealPoint);
+			var tagSource = "";
+			tagSource += "<div style='z-index:13;position:absolute;left:"+(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
+			tagSource += "<img src='"+meetingPoint_icon+"'>";
+			tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"<span>";
+			tagSource += "</div>";
+			var map_el = mapObject.getDomElement();
+			if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
+				//create Box Elements
+				var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
+				$div.css({
+					position: "absolute",
+					top: "0px",
+					left: "0px",
+					zIndex: 13
+				map_el.appendChild($div.get(0));
+			parent.$("#" + mapObject.elementName + "_permanent").html(tagSource);
+	var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
+	if (document.forms[0].x.value!='' && document.forms[0].y.value != ''){
+		//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " + parent.mb_mapObj[ind].width +" iii: "+ ind);
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.width = parent.mb_mapObj[ind].width;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.height = parent.mb_mapObj[ind].height;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.top = 0;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.left = 0;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'visible';
+		var pos = parent.makeRealWorld2mapPos(mod_meetingPoint_target,document.forms[0].x.value, document.forms[0].y.value);
+		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos[0]- Math.round(0.5*meetingPoint_width))+"px;top:"+(pos[1]-Math.round(0.5*meetingPoint_height))+"px'>";
+		//prompt("meetingPoint",tagSource);
+	    parent.writeTag(mod_meetingPoint_target, "permanent", tagSource);
+</script>
+<?php
+echo "var used_charset = '".CHARSET ."';";
+	var mycheck = true;
+	var checkObj= document.forms[0].mytext.value;
+	if(checkObj == '') {
+    	alert ("Bitte geben Sie einen Text an!");
+    	checkObj.focus();
+        mycheck=false;
+    var checkObj= document.forms[0].x.value;
+    	alert (meetingPoint_please_click);
+        mycheck = false;
+    if(mycheck == true){
+    	my_meetingPoint = document.forms[0].myurl.value + "?";
+    	my_meetingPoint += "name=" + encodeURIComponent(document.forms[0].myuser.value);
+    	my_meetingPoint += "&password=" + encodeURIComponent(document.forms[0].mypw.value);
+    	my_meetingPoint += "&mb_user_myGui=" + encodeURIComponent(document.forms[0].mygui.value);
+    	var coord = parent.mb_mapObj[ind].extent.toString().split(",");
+    	my_meetingPoint += "&mb_myBBOX=" + parseFloat(coord[0]) + ",";
+		my_meetingPoint +=  parseFloat(coord[1]) + ",";
+		my_meetingPoint +=  parseFloat(coord[2]) + ",";
+		my_meetingPoint +=  parseFloat(coord[3]) ;
+    	my_meetingPoint += "&mb_myPOI=";
+    	var splitext  = document.forms[0].mytext.value;
+    	document.forms[0].mytext.value = splitext.substring(0, meetingPoint_max_characters);
+    	my_meetingPoint += encodeURIComponent(document.forms[0].mytext.value);
+    	my_meetingPoint += "|" + document.forms[0].x.value + "|";
+    	my_meetingPoint += document.forms[0].y.value;
+    	if(meetingPoint_export_format == 'email'){
+    		createEmail(my_meetingPoint,meetingPoint_export_subject);
+		}else{
+			prompt(meetingPoint_export_subject,my_meetingPoint);
+function emptyfields(){
+	document.forms[0].mytext.value ='';
+	document.forms[0].x.value ='';
+	document.forms[0].y.value =  '';
+	 mod_meetingPoint_hide();
+function createEmail (url,subject) {
+  var email = "mailto:"
+  email  += "";
+  email  += "?subject=";
+  email  += subject;
+  email  += "&body=";
+  email  += escape(url);
+  var win = window.open(email, 'email', 'top=120,left=120');
+  win.close();
+function goBack(where){
+    document.location.href=where;
+function init(){
+	parent.mb_regButton_frame("init_mod_meetingPoint","meetingPoint",null);
+</script>
+</head>
+<body>
+<form action="" >
+<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
+<br>
+<input class='strinput' type="hidden" name='myurl' value='<?php  echo LOGIN;  ?>'>
+<input class='strinput' type="hidden" name='mygui' value='<?php  echo Mapbender::session()->get("mb_user_gui");  ?>'>
+<input class='strinput' type="hidden" name='myuser' value='<?php  echo Mapbender::session()->get("mb_user_name");  ?>'>
+<input class='strinput' type="hidden" name='mypw' value='<?php  echo Mapbender::session()->get("mb_user_password");  ?>'>
+<br>
+<!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
+<textarea class='strinput' rows="3" name='mytext' title='maximal 70 Zeichen'></textarea>
+<br>
+<input class="okbutton" name="Send"   type="button" value="ok" onclick="validate();">
+<input class="ibutton" type="button" value="cancel" onClick="emptyfields();">
+<br>
+<input class="coord" type="hidden" name='x' value='' readonly>
+<input class="coord" type="hidden" name='y' value='' readonly>
+<br>
+</form>
+</body>
 </html>
\ No newline at end of file
Modified: branches/kmq_dev/http/php/mod_newGui.php
--- branches/kmq_dev/http/php/mod_newGui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_newGui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -51,12 +51,12 @@
 	$sql = "INSERT INTO gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) ";
 	$sql .= "VALUES($1, $2, $3)";
-	$v = array($newGui,$_SESSION["mb_user_id"], 'owner');
+	$v = array($newGui,Mapbender::session()->get("mb_user_id"), 'owner');
 	$t = array('s','i','s');
 	require_once(dirname(__FILE__)."/mb_getGUIs.php");
-	$arrayGUIs = mb_getGUIs( $_SESSION["mb_user_id"]);
-	$_SESSION["mb_user_guis"] = $arrayGUIs;
+	$arrayGUIs = mb_getGUIs( Mapbender::session()->get("mb_user_id"));
+	Mapbender::session()->set("mb_user_guis",$arrayGUIs);
 	$guiCreated=true;
Modified: branches/kmq_dev/http/php/mod_owsproxy_conf.php
--- branches/kmq_dev/http/php/mod_owsproxy_conf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_owsproxy_conf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,66 +1,66 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_owsproxy_conf.php
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-$ownwms = $admin->getWmsByOwner($_SESSION["mb_user_id"]);
-if(isset($_REQUEST["wms_id"]) && isset($_REQUEST["status"])){
-	$admin->setWMSOWSstring(intval($_REQUEST["wms_id"]),$_REQUEST["status"]);
-<html>
-<head>
-<?php
-<title>OWS Security Proxy</title>
-<style type="text/css">
-body{
-</style>
-<script language="JavaScript" type="text/javascript">
-function set(wms_id, status){
-	document.location.href = "<?php echo $self; ?>&wms_id="+wms_id+"&status="+status;
-</script>
-</head>
-<body>
-<form>
-<table>
-<?php
-for($i=0; $i<count($ownwms); $i++){
-	echo "<tr>";
-	echo "<td>";
-	echo "<input type='checkbox' onclick='if(this.checked){set(\"".$ownwms[$i]."\",\"on\")}else{set(\"".$ownwms[$i]."\",\"off\")}' ";
-	if($admin->getWMSOWSstring($ownwms[$i]) != false){ echo "checked";  }
-	echo ">";
-	echo "</td>";
-	echo "<td>".$ownwms[$i]."</td>";
-	echo "<td>".$admin->getWmsTitleByWmsId($ownwms[$i])."</td>";
-	echo "</tr>";
-</table>
-</form>
-</body>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_owsproxy_conf.php
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$ownwms = $admin->getWmsByOwner(Mapbender::session()->get("mb_user_id"));
+if(isset($_REQUEST["wms_id"]) && isset($_REQUEST["status"])){
+	$admin->setWMSOWSstring(intval($_REQUEST["wms_id"]),$_REQUEST["status"]);
+<html>
+<head>
+<?php
+<title>OWS Security Proxy</title>
+<style type="text/css">
+body{
+</style>
+<script language="JavaScript" type="text/javascript">
+function set(wms_id, status){
+	document.location.href = "<?php echo $self; ?>&wms_id="+wms_id+"&status="+status;
+</script>
+</head>
+<body>
+<form>
+<table>
+<?php
+for($i=0; $i<count($ownwms); $i++){
+	echo "<tr>";
+	echo "<td>";
+	echo "<input type='checkbox' onclick='if(this.checked){set(\"".$ownwms[$i]."\",\"on\")}else{set(\"".$ownwms[$i]."\",\"off\")}' ";
+	if($admin->getWMSOWSstring($ownwms[$i]) != false){ echo "checked";  }
+	echo ">";
+	echo "</td>";
+	echo "<td>".$ownwms[$i]."</td>";
+	echo "<td>".$admin->getWmsTitleByWmsId($ownwms[$i])."</td>";
+	echo "</tr>";
+</table>
+</form>
+</body>
 </html>
Modified: branches/kmq_dev/http/php/mod_printView1.php
--- branches/kmq_dev/http/php/mod_printView1.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_printView1.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -20,8 +20,9 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 include(dirname(__FILE__)."/../../conf/print.conf");
-$_SESSION["mb_print_url"] = $map_url;
-$_SESSION["mb_print_resolution"] = $quality;
+Mapbender::session()->set("mb_print_url",$map_url);
+Mapbender::session()->set("mb_print_resolution",$quality);
Modified: branches/kmq_dev/http/php/mod_renameGUI.php
--- branches/kmq_dev/http/php/mod_renameGUI.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_renameGUI.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -169,7 +169,7 @@
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
 if(count($ownguis)>0){
Modified: branches/kmq_dev/http/php/mod_savewmc_server.php
--- branches/kmq_dev/http/php/mod_savewmc_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_savewmc_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -26,7 +26,7 @@
 // get data from POST and SESSION
 $mapObject = $json->decode(stripslashes($_POST["mapObject"]));
-$userId = $_SESSION["mb_user_id"];
 $saveInSession = intval($_POST["saveInSession"]);
 $generalTitle = $_POST["generalTitle"];
 $extensionData = $json->decode(stripslashes($_POST["extensionData"]));
@@ -39,9 +39,10 @@
 if ($saveInSession === 1) {
 	// store XML in session
-	$_SESSION["mb_wmc"] = $wmc->xml;
-	$_SESSION["epsg"] = $mapObject->epsg;
-	$_SESSION["previous_gui"] = $_SESSION["mb_user_gui"];
+	Mapbender::session()->set("mb_wmc",$wmc->xml);
+	Mapbender::session()->set("epsg",$mapObject->epsg);
+	Mapbender::session()->set("previous_gui", Mapbender::session()->get("mb_user_gui"));
 	$e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
 else {
Modified: branches/kmq_dev/http/php/mod_setLocale.php
--- branches/kmq_dev/http/php/mod_setLocale.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_setLocale.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -20,8 +20,9 @@
 require_once(dirname(__FILE__) . "/../classes/class_locale.php");
-$_SESSION["mb_lang"] = $_REQUEST["lang"];
-$localeObj = new Mb_locale($_SESSION["mb_lang"]);
+Mapbender::session()->set("mb_lang", Mapbender::session()->get("lang"));
+$localeObj = new Mb_locale(Mapbender::session()->get("mb_lang"));
 session_write_close();
 header("Content-type='text/plain';Charset=utf-8");
Modified: branches/kmq_dev/http/php/mod_showLoggedUser.php
--- branches/kmq_dev/http/php/mod_showLoggedUser.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_showLoggedUser.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -33,8 +33,9 @@
 </head>
 <body leftmargin="5" topmargin="0">
 <?php
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
+$logged_user_name = Mapbender::session()->get("mb_user_name");
+$logged_user_id = Mapbender::session()->get("mb_user_id");
 echo "<div class='text4'>Logged User: ".$logged_user_name."</div>";
 </body>
Modified: branches/kmq_dev/http/php/mod_tab_messages.php
--- branches/kmq_dev/http/php/mod_tab_messages.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_tab_messages.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -31,7 +31,7 @@
 		"AS gui_element_temp WHERE gui_element_temp.current_e_id = e_id ".
 		"AND fkey_gui_id = $3";
-$v = array($_SESSION["mb_lang"], $_SESSION["mb_user_gui"], $_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_lang"), Mapbender::session()->get("mb_user_gui"), Mapbender::session()->get("mb_user_gui"));
 $t = array("s", "s", "s");
 while ($row = db_fetch_array($res)) {
Modified: branches/kmq_dev/http/php/mod_updateWMS.php
--- branches/kmq_dev/http/php/mod_updateWMS.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_updateWMS.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -57,8 +57,8 @@
-$permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"],true);
+$permguis = $admin->getGuisByPermission(Mapbender::session()->get("mb_user_id"),true);
 $wms_id_own = $admin->getWmsByOwnGuis($ownguis);
 if (count($wms_id_own)>0 AND count($ownguis)>0 AND count($permguis)>0){
@@ -122,7 +122,7 @@
-			$replyto = $admin->getEmailByUserId($_SESSION["mb_user_id"]);
+			$replyto = $admin->getEmailByUserId(Mapbender::session()->get("mb_user_id"));
 			$from = $replyto;
 			$pathArray = explode("http/php/", $_SERVER["PATH_TRANSLATED"]);
 			$path = $pathArray[0];
Modified: branches/kmq_dev/http/php/mod_usemap.php
--- branches/kmq_dev/http/php/mod_usemap.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_usemap.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -3,7 +3,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/UseMap
@@ -21,7 +21,7 @@
 require_once(dirname(__FILE__)."/../classes/class_gml2.php");
 <title>image map generator</title>
 </head>
@@ -45,9 +45,9 @@
 function init(){
-	parent.mod_usemap_set(um_title,um_x,um_y)
-</script>
+	parent.mod_usemap_set(um_title,um_x,um_y);
+</script>
 <body onload='init()'>
 </body>
 </html>
Modified: branches/kmq_dev/http/php/mod_user_filteredGroup.php
--- branches/kmq_dev/http/php/mod_user_filteredGroup.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_user_filteredGroup.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -121,8 +121,8 @@
 $cnt_group_user = 0;
 $cnt_group_group = 0;
 $exists = false;
 /*handle remove, update and insert*****************************************************************/
 if($insert){
Modified: branches/kmq_dev/http/php/mod_user_filteredGui.php
--- branches/kmq_dev/http/php/mod_user_filteredGui.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_user_filteredGui.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -129,8 +129,8 @@
 $gui_id_array = array();
Modified: branches/kmq_dev/http/php/mod_wfs.php
--- branches/kmq_dev/http/php/mod_wfs.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -66,6 +66,11 @@
 var iamready = false;
 </script>
 <?php
+function myNl2br ($str) {
+	return preg_replace('#\r?\n#', '\\n', $str);
 echo "<script language='JavaScript' type='text/javascript'>";
 if(isset($_REQUEST['id']) && $_REQUEST['id']!=""){
 	$wfs = mb_split(",",$_REQUEST['id']);
@@ -154,18 +159,21 @@
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_label'] = '".htmlentities($row["f_label"], ENT_QUOTES, "UTF-8")."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_label_id'] = '".$row["f_label_id"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_show'] = '".$row["f_show"]."';";
-			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_show_detail'] = '".$row["f_show_detail"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_respos'] = '".$row["f_respos"]."';";
+			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_show_detail'] = '".$row["f_show_detail"]."';";
+			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_detailpos'] = '".$row["f_detailpos"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['element_name'] = '".htmlentities($row["element_name"], ENT_QUOTES, "UTF-8")."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['element_type'] = '".htmlentities($row["element_type"], ENT_QUOTES, "UTF-8")."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_geom'] = '".$row["f_geom"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_gid'] = '".$row["f_gid"]."';";
-			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"".(preg_replace("/\n/", "", preg_replace("/\r/", "", htmlentities($row["f_form_element_html"], ENT_QUOTES, "UTF-8"))))."\";";
+			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"".(preg_replace("/\n/", "", preg_replace("/\r/", "", $row["f_form_element_html"])))."\";";
 //			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"\";";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_edit'] = '".$row["f_edit"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_mandatory'] = '".$row["f_mandatory"]."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_auth_varname'] = '".htmlentities($row["f_auth_varname"], ENT_QUOTES, "UTF-8")."';";
 			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_operator'] = '".$row["f_operator"]."';";
+			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_helptext'] = '".myNl2br(htmlentities($row["f_helptext"], ENT_QUOTES, "UTF-8"))."';";
+			echo "wfs_conf[".$i."]['element'][".$cnt."]['f_category_name'] = '".htmlentities($row["f_category_name"], ENT_QUOTES, "UTF-8")."';";
 			$cnt++;
 		if($cnt == 0){die("wfs_conf data not available");}
Modified: branches/kmq_dev/http/php/mod_wfsSpatialRequest_messages.php
--- branches/kmq_dev/http/php/mod_wfsSpatialRequest_messages.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfsSpatialRequest_messages.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,42 +1,42 @@
-<?php
-#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
-setlocale(LC_ALL, $_SESSION["mb_locale"]);
-// Messages
-$msg_obj = array();
-$msg_obj["buttonLabelRectangle"] = _mb("select by rectangle");
-$msg_obj["buttonLabelPolygon"] = _mb("select by polygon");
-$msg_obj["buttonLabelPoint"] = _mb("select by point");
-$msg_obj["buttonLabelExtent"] = _mb("select by extent");
-$msg_obj["buttonLabelDialogue"] = _mb("open dialogue form");
-$msg_obj["errorMessageInvalidExtent"] = _mb("Invalid box!");
-$json = new Mapbender_JSON();
-$output = $json->encode($msg_obj);
-header("Content-type:application/x-json; charset=utf-8");
-echo $output;
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$e = new mb_notice("locale: " . Mapbender::session()->get("mb_locale") . "; lang: " . Mapbender::session()->get("mb_lang"));
+setlocale(LC_ALL, Mapbender::session()->get("mb_locale"));
+// Messages
+$msg_obj = array();
+$msg_obj["buttonLabelRectangle"] = _mb("select by rectangle");
+$msg_obj["buttonLabelPolygon"] = _mb("select by polygon");
+$msg_obj["buttonLabelPoint"] = _mb("select by point");
+$msg_obj["buttonLabelExtent"] = _mb("select by extent");
+$msg_obj["buttonLabelDialogue"] = _mb("open dialogue form");
+$msg_obj["errorMessageInvalidExtent"] = _mb("Invalid box!");
+$json = new Mapbender_JSON();
+$output = $json->encode($msg_obj);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
Modified: branches/kmq_dev/http/php/mod_wfs_conf.php
--- branches/kmq_dev/http/php/mod_wfs_conf.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_conf.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -110,7 +110,7 @@
 Select WFS:&nbsp;
 <?php
 $aWFS = new wfs_conf();
-$aWFS->getallwfs($_SESSION['mb_user_id']);
+$aWFS->getallwfs(Mapbender::session()->get("mb_user_id"));
 function toImage($text) {
Modified: branches/kmq_dev/http/php/mod_wfs_conf_featuretype_elements.html
--- branches/kmq_dev/http/php/mod_wfs_conf_featuretype_elements.html	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_conf_featuretype_elements.html	2009-07-01 14:40:19 UTC (rev 4271)
@@ -46,18 +46,19 @@
 			<th class='wfs_conf_geom'>geom</th>
 			<th class='wfs_conf_search'>search</th>
 			<th class='wfs_conf_pos'>pos</th>
-			<th class='wfs_conf_mininput'>minimum_input</th>
-			<th class='wfs_conf_styleid'>style_id</th>
-			<th class='wfs_conf_toupper'>upper</th>
+			<th class='wfs_conf_minInput'>minimum_input</th>
+			<th class='wfs_conf_styleId'>style_id</th>
+			<th class='wfs_conf_toUpper'>upper</th>
 			<th class='wfs_conf_label'>label</th>
-			<th class='wfs_conf_labelid'>label_id</th>
+			<th class='wfs_conf_labelId'>label_id</th>
 			<th class='wfs_conf_show'>show</th>
-			<th class='wfs_conf_showdetail'>show_detail</th>
 			<th class='wfs_conf_respos'>position</th>
+			<th class='wfs_conf_showDetail'>show_detail</th>
+			<th class='wfs_conf_detailPos'>detail_position</th>
 			<th class='wfs_conf_mandatory'>mandatory</th>
 			<th class='wfs_conf_edit'>edit</th>
-			<th class='wfs_conf_formelementhtml'>html</th>
-			<th class='wfs_conf_authvarname'>auth</th>
+			<th class='wfs_conf_formElementHtml'>html</th>
+			<th class='wfs_conf_authVarname'>auth</th>
 			<th class='wfs_conf_operator'>operator</th>
 			<th class='wfs_conf_helptext'>helptext</th>
 			<th class='wfs_conf_category'>category</th>
Modified: branches/kmq_dev/http/php/mod_wfs_conf_interface.js
--- branches/kmq_dev/http/php/mod_wfs_conf_interface.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_conf_interface.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -12,7 +12,7 @@
 			"def" : 0,
 			"size" : 1
-		"mininput" : {
+		"minInput" : {
 			"type" : "select",
 			"def" : {
 				"0" : "...",
@@ -23,19 +23,19 @@
 				"5" : "5"
-		"styleid" : {
+		"styleId" : {
 			"type" : "text",
 			"def" : 0,
 			"size" : 1
-		"toupper" : {
+		"toUpper" : {
 			"type" : "checkbox"
 		"label" : {
 			"type" : "text",
 			"size" : 2
-		"labelid" : {
+		"labelId" : {
 			"type" : "text",
 			"def" : 0,
 			"size" : 1
@@ -43,10 +43,15 @@
 		"show" : {
 			"type" : "checkbox"
-		"showdetail" : {
+		"respos" : {
+			"type" : "text",
+			"def" : 0,
+			"size" : 1
+		"showDetail" : {
 			"type" : "checkbox"
-		"respos" : {
+		"detailPos" : {
 			"type" : "text",
 			"def" : 0,
 			"size" : 1
@@ -57,10 +62,10 @@
 		"edit" : {
 			"type" : "checkbox"
-		"formelementhtml" : {
+		"formElementHtml" : {
 			"type" : "htmlTemplate"
-		"authvarname" : {
+		"authVarname" : {
 			"type" : "text",
 			"size" : 8
@@ -125,7 +130,7 @@
 			"title" : "Download",
 			"icon" : "someicon.png",
 			"columns" : [
-				"geom", "pos", "show", "showdetail", "respos", "helptext"
+				"geom", "pos", "show", "respos", "showDetail", "detailPos", "helptext"
@@ -134,9 +139,9 @@
 			"title" : "Search",
 			"columns" : [
-				"geom", "search", "pos", "mininput", "styleid", "toupper",
-				"label", "labelid", "show", "showdetail", "respos",
-				"authvarname", "operator", "helptext"
+				"geom", "search", "pos", "minInput", "styleId", "toUpper",
+				"label", "labelId", "show", "respos", "showDetail", "detailPos",
+				"authVarname", "operator", "helptext"
@@ -145,9 +150,9 @@
 			"title" : "Digitize",
 			"columns" : [
-				"geom", "pos", "styleid", "label", "labelid", "show",
-				"showdetail", "respos", "mandatory", "edit", "formelementhtml",
-				"authvarname", "helptext",	"category"
+				"geom", "pos", "styleId", "label", "labelId", "show",
+				"respos", "mandatory", "edit", "formElementHtml",
+				"authVarname", "helptext",	"category"
@@ -163,81 +168,88 @@
 	// get available WFS ("new" mode)
 	var getWfsFromDb = function (options) {
 		var req = new Mapbender.Ajax.Request({
-			"method" : "getWfs",
-			"parameters" : {}
+			method : "getWfs",
+			parameters : {},
+			url: "../php/mod_wfs_conf_server.php",
+			callback: function(result, success, message) {
+				if (result !== null) {
+					wfsArray = result;
+				if (typeof options !== "object") {
+					return;
+				if (typeof options.callback === "function") {
+					options.callback(wfsArray);
-		req.send("../php/mod_wfs_conf_server.php", function(result, success, message) {
-			if (result !== null) {
-				wfsArray = result;
-			if (typeof options !== "object") {
-				return;
-			if (typeof options.callback === "function") {
-				options.callback(wfsArray);
+		req.send();
 	// get available WFS configurations ("edit" mode)
 	var getWfsConfsFromDb = function (options) {
-			"method" : "getWfsConfs",
-			"parameters" : {}
+			method : "getWfsConfs",
+			parameters : {},
+			callback: function (result, success, message) {
+					wfsConfArray = result;
+					return;
+					options.callback(wfsConfArray);
-		req.send("../php/mod_wfs_conf_server.php", function (result, success, message) {
-				wfsConfArray = result;
-				return;
-				options.callback(wfsConfArray);
+		req.send();
 	var updateWfsConfInDb = function (wfsConf) {
-			"method" : "updateWfsConf",
-			"parameters": {
+			method : "updateWfsConf",
+			parameters: {
 				"wfsConf": wfsConf
+				isNotBusy.trigger();
+				alert(message);
 		isBusy.trigger();
-			isNotBusy.trigger();
-			alert(message);
+		req.send();
 	var insertWfsConfIntoDb = function (wfsConf) {
-			"method" : "insertWfsConf",
-			"parameters": {
+			method : "insertWfsConf",
+			parameters: {
 				"wfsConf": wfsConf
+				if (success) {
+					$("#wfs_conf_id").val(result.id);
+					// update WFS conf array (add the latest entry)
+					getWfsConfsFromDb({
+						"callback": function(wfsConfArray) {
+							alert(message);
+				else {
+					alert(message);
 		isBusy.trigger();
-			if (success) {
-				$("#wfs_conf_id").val(result.id);
-				// update WFS conf array (add the latest entry)
-				getWfsConfsFromDb({
-					"callback": function(wfsConfArray) {
-						alert(message);
-			else {
-				alert(message);
+		req.send();
 	var getWfsById = function (id) {
@@ -260,6 +272,16 @@
 		return null;
+	var getWfsConfIndex = function (id) {
+		// find WFS Conf in WFS Conf array
+		for (var i = 0; i < wfsConfArray.length; i++) {
+			if (wfsConfArray[i].id === id) {
+				return i;
+		return null;
 	// FORMS
@@ -622,18 +644,18 @@
 			return {
 				"id": wfsConfId,
 				"wfsId" : wfsId,
-				"wfsFeaturetypeId" : wfsFeaturetypeId,
+				"featuretypeId" : wfsFeaturetypeId,
 				"type" : wfsConfType,
-				"title": $('#wfs_conf_title').val(),
+				"abstr": $('#wfs_conf_title').val(),
 				"description": $('#wfs_conf_description').val(),
 				"label": $('#wfs_conf_label').val(),
-				"label_id": $('#wfs_conf_label_id').val(),
+				"labelId": $('#wfs_conf_label_id').val(),
 				"button": $('#wfs_conf_button').val(),
-				"button_id": $('#wfs_conf_button_id').val(),
+				"buttonId": $('#wfs_conf_button_id').val(),
 				"style": $('#wfs_conf_style').val(),
 				"buffer": $('#wfs_conf_buffer').val(),
-				"result_style": $('#wfs_conf_resultstyle').val(),
-				"elements": ftElements
+				"resStyle": $('#wfs_conf_resultstyle').val(),
+				"elementArray": ftElements
@@ -718,7 +740,7 @@
 					var $tr = $("#" + prefix + "wfs_conf_form_tr_" + el.id);
 					for (var attr in el) {
 						for (var column in ALL_WFS_CONF_ATTRIBUTES) {
-							if (attr.toLowerCase() === column) {
+							if (attr === column) {
 								var $td = $tr.children("TD.wfs_conf_" + column);
 								fillWfsConfFormElement(column, $td, el[attr]);
 								break;
@@ -884,6 +906,10 @@
 				var wfsConf = getWfsConfFromHtml(prefix);
 				if (wfsConf.id !== null) {
 					updateWfsConfInDb(wfsConf);
+					var index = getWfsConfIndex(wfsConf.id);
+					if (index !== null) {
+						wfsConfArray[index] = wfsConf;
 				else {
 					insertWfsConfIntoDb(wfsConf);
Modified: branches/kmq_dev/http/php/mod_wfs_conf_server.php
--- branches/kmq_dev/http/php/mod_wfs_conf_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_conf_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -28,7 +28,7 @@
 switch ($command) {
 	case "getWfsConfs" :
-		$currentUser = new User($_SESSION["mb_user_id"]);
+		$currentUser = new User(Mapbender::session()->get("mb_user_id"));
 		$wfsConfIds = $currentUser->getWfsConfByWfsOwner();
 		if ($wfsConfIds === null) {
 			$wfsConfIds = array();
@@ -47,7 +47,7 @@
 	case "getWfs" :
-		$aWFS->getallwfs($_SESSION['mb_user_id']);
+		$aWFS->getallwfs(Mapbender::session()->get("mb_user_id"));
 		$result = array();
Modified: branches/kmq_dev/http/php/mod_wfs_gazetteer_server.php
--- branches/kmq_dev/http/php/mod_wfs_gazetteer_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_gazetteer_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,139 +1,139 @@
-<?php
-# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
-# http://www.mapbender.org/index.php/Administration
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
-$command = $_REQUEST["command"];
- * checks if a variable name is valid.
- * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
- * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
-function isValidVarName ($varname) {
-	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
-		return true;
-	return false;
- * If access to the WFS conf is restricted, modify the filter.
- function checkAccessConstraint($filter, $wfs_conf_id) {
-	/* wfs_conf_element */
-	$sql = "SELECT * FROM wfs_conf_element ";
-	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql .= "ORDER BY wfs_conf_element.f_respos";
-	$v = array($wfs_conf_id);
-	$t = array('i');
-	$res = db_prep_query($sql,$v,$t);
-	while($row = db_fetch_array($res)){
-		if (!empty($row["f_auth_varname"])) {
-			$auth_varname = $row["f_auth_varname"];
-			$element_name = $row["element_name"];
-	if (!empty($auth_varname)) {
-		if (isValidVarName($auth_varname)) {
-			$user = eval("return " . $auth_varname . ";");
-			if ($user) {
-				$pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
-				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
-				$filter = mb_eregi_replace($pattern, $replacement, $filter);
-			else {
-				$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
-		else {
-			$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
-	return $filter;
-if ($command == "getWfsConf") {
-	$wfsConfIdString = $_GET["wfsConfIdString"];
-	if ($wfsConfIdString != "") {
-		//array_keys(array_flip()) produces an array with unique entries
-		$wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
-	else {
-		echo "please specify wfs conf id.";
-		die();
-	$obj = new WfsConf();
-	$obj->load($wfsConfIdArray);
-	$json = new Mapbender_JSON();
-	$output = $json->encode($obj->confArray);
-	echo $output;
-else if ($command == "getSearchResults") {
-	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
-	$backlink = $_REQUEST["backlink"];
-	$frame = $_REQUEST["frame"];
-	$filter = $_REQUEST["filter"];
-	$url = $_REQUEST["url"];
-	$typename = $_REQUEST["typename"];
-	$wfsConf = WfsConfiguration::createFromDb($wfs_conf_id);
-	if (is_null($wfsConf)) {
-		sendErrorMessage("Invalid WFS conf: " . $wfs_conf_id);
-	$admin = new administration();
-	$filter = $admin->char_decode(stripslashes($filter));
-	$wfsId = $wfsConf->wfsId;
-	$myWfsFactory = new UniversalWfsFactory();
-	$myWfs = $myWfsFactory->createFromDb($wfsId);
-	$data = $myWfs->getFeature($typename, $filter);
-	if ($data === null) die('{}');
-//	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
-	$gmlFactory = new UniversalGmlFactory();
-	$myGml = $gmlFactory->createFromXml($data, $wfsConf);
-	$geoJson = $myGml->toGeoJSON();
-	header("Content-type:application/x-json; charset=utf-8");
-	echo $geoJson;
-else {
-	echo "please enter a valid command.";
+<?php
+# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
+# http://www.mapbender.org/index.php/Administration
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
+$command = $_REQUEST["command"];
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like Mapbender::session()->get("mb_user_id")
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+		return true;
+	return false;
+ * If access to the WFS conf is restricted, modify the filter.
+ function checkAccessConstraint($filter, $wfs_conf_id) {
+	/* wfs_conf_element */
+	$sql = "SELECT * FROM wfs_conf_element ";
+	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+	$sql .= "ORDER BY wfs_conf_element.f_respos";
+	$v = array($wfs_conf_id);
+	$t = array('i');
+	$res = db_prep_query($sql,$v,$t);
+	while($row = db_fetch_array($res)){
+		if (!empty($row["f_auth_varname"])) {
+			$auth_varname = $row["f_auth_varname"];
+			$element_name = $row["element_name"];
+	if (!empty($auth_varname)) {
+		if (isValidVarName($auth_varname)) {
+			$user = eval("return " . $auth_varname . ";");
+			if ($user) {
+				$pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+				$filter = mb_eregi_replace($pattern, $replacement, $filter);
+			else {
+				$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
+		else {
+			$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
+	return $filter;
+if ($command == "getWfsConf") {
+	$wfsConfIdString = $_GET["wfsConfIdString"];
+	if ($wfsConfIdString != "") {
+		//array_keys(array_flip()) produces an array with unique entries
+		$wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
+	else {
+		echo "please specify wfs conf id.";
+		die();
+	$obj = new WfsConf();
+	$obj->load($wfsConfIdArray);
+	$json = new Mapbender_JSON();
+	$output = $json->encode($obj->confArray);
+	echo $output;
+else if ($command == "getSearchResults") {
+	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
+	$backlink = $_REQUEST["backlink"];
+	$frame = $_REQUEST["frame"];
+	$filter = $_REQUEST["filter"];
+	$url = $_REQUEST["url"];
+	$typename = $_REQUEST["typename"];
+	$wfsConf = WfsConfiguration::createFromDb($wfs_conf_id);
+	if (is_null($wfsConf)) {
+		sendErrorMessage("Invalid WFS conf: " . $wfs_conf_id);
+	$admin = new administration();
+	$filter = $admin->char_decode(stripslashes($filter));
+	$wfsId = $wfsConf->wfsId;
+	$myWfsFactory = new UniversalWfsFactory();
+	$myWfs = $myWfsFactory->createFromDb($wfsId);
+	$data = $myWfs->getFeature($typename, $filter);
+	if ($data === null) die('{}');
+//	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
+	$gmlFactory = new UniversalGmlFactory();
+	$myGml = $gmlFactory->createFromXml($data, $wfsConf);
+	$geoJson = $myGml->toGeoJSON();
+	header("Content-type:application/x-json; charset=utf-8");
+	echo $geoJson;
+else {
+	echo "please enter a valid command.";
Modified: branches/kmq_dev/http/php/mod_wfs_result.php
--- branches/kmq_dev/http/php/mod_wfs_result.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_result.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,105 +1,105 @@
-<?php
-# $Id$
-require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
-require_once(dirname(__FILE__) . "/../classes/class_connector.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs.php");
-$filter = stripslashes($_REQUEST["filter"]);
-$db_wfs_conf_id = $_REQUEST["db_wfs_conf_id"];
-$typename = $_REQUEST["typename"];
-		return true;
-	return false;
-function checkAccessConstraint($filter, $wfs_conf_id) {
-	$t = array('i');
-	$e = new mb_exception($auth_varname . " " . $element_name);
-			$filter = eregi_replace($pattern, $replacement, $filter);
-	return $filter;
-$filter = checkAccessConstraint($filter, $db_wfs_conf_id);
-$sql = "SELECT fkey_wfs_id FROM wfs_conf WHERE wfs_conf_id = $1";
-$v = array($db_wfs_conf_id);
-$t = array('i');
-$res = db_prep_query($sql, $v, $t);
-$row = db_fetch_array($res);
-$wfsId = $row["fkey_wfs_id"];
-$myWfsFactory = new UniversalWfsFactory();
-$myWfs = $myWfsFactory->createFromDb($wfsId);
-$data = $myWfs->getFeature($typename, $filter);
-if ($data === null) die('{}');
-$myWfsConf = WfsConfiguration::createFromDb($db_wfs_conf_id);
-if (is_null($myWfsConf)) {
-	die("{}");
-$gmlFactory = new UniversalGmlFactory();
-$myGml = $gmlFactory->createFromXml($data, $myWfsConf);
-$geoJson = $myGml->toGeoJSON();
-header('Content-type: text/html');
-echo $geoJson;
+<?php
+# $Id$
+require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
+require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs.php");
+$filter = stripslashes($_REQUEST["filter"]);
+$db_wfs_conf_id = $_REQUEST["db_wfs_conf_id"];
+$typename = $_REQUEST["typename"];
+		return true;
+	return false;
+function checkAccessConstraint($filter, $wfs_conf_id) {
+	$t = array('i');
+	$e = new mb_exception($auth_varname . " " . $element_name);
+			$filter = eregi_replace($pattern, $replacement, $filter);
+	return $filter;
+$filter = checkAccessConstraint($filter, $db_wfs_conf_id);
+$sql = "SELECT fkey_wfs_id FROM wfs_conf WHERE wfs_conf_id = $1";
+$v = array($db_wfs_conf_id);
+$t = array('i');
+$res = db_prep_query($sql, $v, $t);
+$row = db_fetch_array($res);
+$wfsId = $row["fkey_wfs_id"];
+$myWfsFactory = new UniversalWfsFactory();
+$myWfs = $myWfsFactory->createFromDb($wfsId);
+$data = $myWfs->getFeature($typename, $filter);
+if ($data === null) die('{}');
+$myWfsConf = WfsConfiguration::createFromDb($db_wfs_conf_id);
+if (is_null($myWfsConf)) {
+	die("{}");
+$gmlFactory = new UniversalGmlFactory();
+$myGml = $gmlFactory->createFromXml($data, $myWfsConf);
+$geoJson = $myGml->toGeoJSON();
+header('Content-type: text/html');
+echo $geoJson;
Modified: branches/kmq_dev/http/php/mod_wfs_server.php
--- branches/kmq_dev/http/php/mod_wfs_server.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/mod_wfs_server.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,326 +1,326 @@
-<?php
-require_once(dirname(__FILE__) . "/../classes/class_json.php");
-require_once(dirname(__FILE__) . "/../classes/class_universal_wfs_factory.php");
-$obj = $json->decode(stripslashes($_REQUEST['obj']));
-//workflow:
-switch($obj->action){
-	case 'getServices':
-		$obj->services = getServices($obj);
-		sendOutput($obj);
-	break;
-	case 'getWfsConfData':
-		$obj->wfsConf = getWfsConfData($obj->wfs);
-		sendOutput($obj);
-	break;
-	case 'getGuis':
-		$obj->id = getGuis($obj);
-		sendOutput($obj);
-	break;
-	case 'getAssignedConfs':
-		$obj->assignedConfs = getAssignedConfs($obj);
-		sendOutput($obj);
-	break;
-	case 'getUpdateUrl':
-		$obj->url = getUpdateUrl($obj);
-		sendOutput($obj);
-	break;
-		case 'add':
-		addConfsToGui($obj);
-		sendOutput($obj);
-	break;
-	case 'remove':
-		removeConfsFromGui($obj);
-		sendOutput($obj);
-	break;
-	case 'updateWfs':
-		updateWfs($obj);
-		sendOutput($obj);
-	break;
-	case 'deleteWfs':
-		deleteWfs($obj);
-		sendOutput($obj);
-	break;
-	case 'setOwsproxy':
-		$ows = array();
-		$ows['string'] = setOwsproxy($obj);
-		$ows['action'] = "owsproxy";
-		sendOutput($ows);
-	break;
-	case 'removeOwsproxy':
-		$ows = array();
-		$ows['string'] = removeOwsproxy($obj);
-		sendOutput($ows);
-	break;
-	case 'getOwsproxy':
-		$ows = array();
-		$ows['string'] = getOwsproxy($obj);
-		sendOutput($ows);
-	break;
-	default:
-		sendOutput("no action specified...");
- * Get all services (ids and titles) where the current user is owner
- * @return mixed[] services the ids and titles of the services
-function getServices(){
-	global $con;
-	$services = array();
-	$services['id'] = array();
-	$services['title'] = array();
-	$adm = new administration();
-	$serviceList = $adm->getWfsByOwner($_SESSION['mb_user_id']);
-	if(count($serviceList) == 0){
-		return false;
-	$sql = "SELECT * FROM wfs WHERE wfs_id IN (";
-	$v = $serviceList;
-	$t = array();
-	for ($i = 1; $i <= count($serviceList); $i++) {
-		if ($i > 1) {
-			$sql .= ", ";
-		$sql .= "$" . $i;
-		array_push($t, "i");
-	$sql .= ") ORDER BY wfs_title";
-	$res = db_prep_query($sql, $v, $t);
-		array_push($services['id'], $row['wfs_id']);
-		array_push($services['title'], $row['wfs_title']);
-	return $services;
- * Get all configurations of the selcted wfs if the current user is owner
- * @return mixed[]
-function getWfsConfData($wfsID){
-	global $con;
-	// re-check permission
-	if(in_array($wfsID, $serviceList)){
-		$wfsConf = array();
-		$wfsConf['id'] = array();
-		$wfsConf['abstract'] = array();
-		$sql = "SELECT * FROM wfs_conf WHERE fkey_wfs_id = $1 ORDER BY wfs_conf_abstract";
-		$v = array($wfsID);
-		$t = array('i');
-		$cnt = 0;
-			array_push($wfsConf['id'], $row['wfs_conf_id']);
-			array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
-			$cnt++;
-		if($cnt == 0){
-			return false;
-		else{
-			return $wfsConf;
-	else if($wfsID==="gui_confs"){
-		$wfsConf['id'] = $adm->getWfsConfByPermission($_SESSION['mb_user_id']);
-		$cnt = 0;
-		foreach($wfsConf['id'] as $wfscid){
-			$sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
-			$v = array($wfscid);
-			$t = array('i');
-			$cnt++;
-		if($cnt == 0){
-			return false;
-		else{
-			return $wfsConf;
- * Get all GUIs where the current user is owner. This are the GUIs where the user could publish his
- * wfs configurations
- * @return mixed[]
-function getGuis(){
-	$guiList = $adm->getGuisByOwner($_SESSION['mb_user_id'],1);
-	if(count($guiList) > 0){
-		return $guiList;
-	return false;
- * get all wfs_confs of the selected WFS which are assigned to the selected gui
- * @param
- * @return mixed[]
-function getAssignedConfs($obj){
-	global $con;
-	$assignedConfs = array();
-	$confs = getWfsConfData($obj->selectedWfs);
-	if($confs === false){
-		return false;
-	$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id IN (".join(",",$confs['id']).")";
-	$v = array($obj->selectedGui);
-	$t = array('s');
-	if(!$res){
-		$e = new mb_exception("Error: SQL: " . $sql . " -> Gui: " .$obj->selectedGui);
-		array_push($assignedConfs, $row['fkey_wfs_conf_id']);
-	return $assignedConfs;
-function addConfsToGui($obj){
-	global $con;
-	for($i=0; $i<count($obj->confs); $i++){
-		$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
-		$v = array($obj->gui,$obj->confs->$i);
-		$t = array('s','i');
-		if(!$row = db_fetch_array($res)){
-			$sql1 = "INSERT INTO gui_wfs_conf (fkey_gui_id,fkey_wfs_conf_id) VALUES ($1,$2)";
-			$v1 = array($obj->gui, $obj->confs->$i);
-			$t1 = array('s', 'i');
-			$res1 = db_prep_query($sql1,$v1,$t1);
-function removeConfsFromGui($obj){
-	global $con;
-		$sql = "DELETE FROM gui_wfs_conf  WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
-		$v = array($obj->gui, $obj->confs->$i);
-		$t = array('s', 'i');
- * updates an WFS
- * @param object the un-encoded object
- * @return boolean success
-function updateWfs($obj){
-	$id = $obj->wfs;
-	$url = $obj->url;
-	$wfsFactory = new UniversalWfsFactory();
-	$myWfs = $wfsFactory->createFromUrl($url);
-	$myWfs->id = $id;
-	if(is_null($myWfs) || !$myWfs->update()){
-		$obj->success = false;
-	else {
-		$obj->success = true;
-	return true;
- * deletes an WFS
-function deleteWfs($obj){
-	$id = $obj->wfs;
-	$myWfs = $wfsFactory->createFromDb($id);
-	if (is_null($myWfs) || !$myWfs->delete()) {
-	else {
-	return true;
- * gets the specified url column from db
- * @return string requested url
-function getUpdateUrl($obj){
-	global $con;
-	$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
-	$v = array($obj->wfs);
-	$t = array('i');
-		$ContentOfColumn = $row[$obj->column];
-		if($obj->column == 'wfs_getcapabilities'){
-										$n = new administration();
-										$updateUrl = $n->checkURL($ContentOfColumn)."Version=".$row['wfs_version']."&Request=getCapabilities&SERVICE=WFS";
-		}else{
-					$updateUrl = $ContentOfColumn;
-		return $updateUrl;
-	return "";
-function getOwsproxy($obj){
-	if($obj->wfs=="gui_confs")
-		return false;
-	return $n->getWfsOwsproxyString($obj->wfs);
-function setOwsproxy($obj){
-		return false;
-	return $n->setWfsOwsproxyString($obj->wfs,true);
-function removeOwsproxy($obj){
-		return false;
-	return $n->setWfsOwsproxyString($obj->wfs,false);
- * encodes and delivers the data
-function sendOutput($out){
-	global $json;
-	$output = $json->encode($out);
-	header("Content-Type: text/x-json");
-	echo $output;
+<?php
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_universal_wfs_factory.php");
+$obj = $json->decode(stripslashes($_REQUEST['obj']));
+//workflow:
+switch($obj->action){
+	case 'getServices':
+		$obj->services = getServices($obj);
+		sendOutput($obj);
+	break;
+	case 'getWfsConfData':
+		$obj->wfsConf = getWfsConfData($obj->wfs);
+		sendOutput($obj);
+	break;
+	case 'getGuis':
+		$obj->id = getGuis($obj);
+		sendOutput($obj);
+	break;
+	case 'getAssignedConfs':
+		$obj->assignedConfs = getAssignedConfs($obj);
+		sendOutput($obj);
+	break;
+	case 'getUpdateUrl':
+		$obj->url = getUpdateUrl($obj);
+		sendOutput($obj);
+	break;
+		case 'add':
+		addConfsToGui($obj);
+		sendOutput($obj);
+	break;
+	case 'remove':
+		removeConfsFromGui($obj);
+		sendOutput($obj);
+	break;
+	case 'updateWfs':
+		updateWfs($obj);
+		sendOutput($obj);
+	break;
+	case 'deleteWfs':
+		deleteWfs($obj);
+		sendOutput($obj);
+	break;
+	case 'setOwsproxy':
+		$ows = array();
+		$ows['string'] = setOwsproxy($obj);
+		$ows['action'] = "owsproxy";
+		sendOutput($ows);
+	break;
+	case 'removeOwsproxy':
+		$ows = array();
+		$ows['string'] = removeOwsproxy($obj);
+		sendOutput($ows);
+	break;
+	case 'getOwsproxy':
+		$ows = array();
+		$ows['string'] = getOwsproxy($obj);
+		sendOutput($ows);
+	break;
+	default:
+		sendOutput("no action specified...");
+ * Get all services (ids and titles) where the current user is owner
+ * @return mixed[] services the ids and titles of the services
+function getServices(){
+	global $con;
+	$services = array();
+	$services['id'] = array();
+	$services['title'] = array();
+	$adm = new administration();
+	$serviceList = $adm->getWfsByOwner(Mapbender::session()->get("mb_user_id"));
+	if(count($serviceList) == 0){
+		return false;
+	$sql = "SELECT * FROM wfs WHERE wfs_id IN (";
+	$v = $serviceList;
+	$t = array();
+	for ($i = 1; $i <= count($serviceList); $i++) {
+		if ($i > 1) {
+			$sql .= ", ";
+		$sql .= "$" . $i;
+		array_push($t, "i");
+	$sql .= ") ORDER BY wfs_title";
+	$res = db_prep_query($sql, $v, $t);
+		array_push($services['id'], $row['wfs_id']);
+		array_push($services['title'], $row['wfs_title']);
+	return $services;
+ * Get all configurations of the selcted wfs if the current user is owner
+ * @return mixed[]
+function getWfsConfData($wfsID){
+	global $con;
+	// re-check permission
+	if(in_array($wfsID, $serviceList)){
+		$wfsConf = array();
+		$wfsConf['id'] = array();
+		$wfsConf['abstract'] = array();
+		$sql = "SELECT * FROM wfs_conf WHERE fkey_wfs_id = $1 ORDER BY wfs_conf_abstract";
+		$v = array($wfsID);
+		$t = array('i');
+		$cnt = 0;
+			array_push($wfsConf['id'], $row['wfs_conf_id']);
+			array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
+			$cnt++;
+		if($cnt == 0){
+			return false;
+		else{
+			return $wfsConf;
+	else if($wfsID==="gui_confs"){
+		$wfsConf['id'] = $adm->getWfsConfByPermission(Mapbender::session()->get("mb_user_id"));
+		$cnt = 0;
+		foreach($wfsConf['id'] as $wfscid){
+			$sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
+			$v = array($wfscid);
+			$t = array('i');
+			$cnt++;
+		if($cnt == 0){
+			return false;
+		else{
+			return $wfsConf;
+ * Get all GUIs where the current user is owner. This are the GUIs where the user could publish his
+ * wfs configurations
+ * @return mixed[]
+function getGuis(){
+	$guiList = $adm->getGuisByOwner(Mapbender::session()->get("mb_user_id"),1);
+	if(count($guiList) > 0){
+		return $guiList;
+	return false;
+ * get all wfs_confs of the selected WFS which are assigned to the selected gui
+ * @param
+ * @return mixed[]
+function getAssignedConfs($obj){
+	global $con;
+	$assignedConfs = array();
+	$confs = getWfsConfData($obj->selectedWfs);
+	if($confs === false){
+		return false;
+	$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id IN (".join(",",$confs['id']).")";
+	$v = array($obj->selectedGui);
+	$t = array('s');
+	if(!$res){
+		$e = new mb_exception("Error: SQL: " . $sql . " -> Gui: " .$obj->selectedGui);
+		array_push($assignedConfs, $row['fkey_wfs_conf_id']);
+	return $assignedConfs;
+function addConfsToGui($obj){
+	global $con;
+	for($i=0; $i<count($obj->confs); $i++){
+		$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
+		$v = array($obj->gui,$obj->confs->$i);
+		$t = array('s','i');
+		if(!$row = db_fetch_array($res)){
+			$sql1 = "INSERT INTO gui_wfs_conf (fkey_gui_id,fkey_wfs_conf_id) VALUES ($1,$2)";
+			$v1 = array($obj->gui, $obj->confs->$i);
+			$t1 = array('s', 'i');
+			$res1 = db_prep_query($sql1,$v1,$t1);
+function removeConfsFromGui($obj){
+	global $con;
+		$sql = "DELETE FROM gui_wfs_conf  WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
+		$v = array($obj->gui, $obj->confs->$i);
+		$t = array('s', 'i');
+ * updates an WFS
+ * @param object the un-encoded object
+ * @return boolean success
+function updateWfs($obj){
+	$id = $obj->wfs;
+	$url = $obj->url;
+	$wfsFactory = new UniversalWfsFactory();
+	$myWfs = $wfsFactory->createFromUrl($url);
+	$myWfs->id = $id;
+	if(is_null($myWfs) || !$myWfs->update()){
+		$obj->success = false;
+	else {
+		$obj->success = true;
+	return true;
+ * deletes an WFS
+function deleteWfs($obj){
+	$id = $obj->wfs;
+	$myWfs = $wfsFactory->createFromDb($id);
+	if (is_null($myWfs) || !$myWfs->delete()) {
+	else {
+	return true;
+ * gets the specified url column from db
+ * @return string requested url
+function getUpdateUrl($obj){
+	global $con;
+	$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
+	$v = array($obj->wfs);
+	$t = array('i');
+		$ContentOfColumn = $row[$obj->column];
+		if($obj->column == 'wfs_getcapabilities'){
+										$n = new administration();
+										$updateUrl = $n->checkURL($ContentOfColumn)."Version=".$row['wfs_version']."&Request=getCapabilities&SERVICE=WFS";
+		}else{
+					$updateUrl = $ContentOfColumn;
+		return $updateUrl;
+	return "";
+function getOwsproxy($obj){
+	if($obj->wfs=="gui_confs")
+		return false;
+	return $n->getWfsOwsproxyString($obj->wfs);
+function setOwsproxy($obj){
+		return false;
+	return $n->setWfsOwsproxyString($obj->wfs,true);
+function removeOwsproxy($obj){
+		return false;
+	return $n->setWfsOwsproxyString($obj->wfs,false);
+ * encodes and delivers the data
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	header("Content-Type: text/x-json");
+	echo $output;
Modified: branches/kmq_dev/http/php/nestedSets.php
--- branches/kmq_dev/http/php/nestedSets.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/php/nestedSets.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -254,7 +254,7 @@
 <?php
 $sql = "SELECT * FROM gui WHERE gui_id IN (";
 $v = $ownguis;
Modified: branches/kmq_dev/http/print/mod_printPDF.php
--- branches/kmq_dev/http/print/mod_printPDF.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/print/mod_printPDF.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -93,7 +93,7 @@
 					var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
 					var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
 					if(layerStyle==false){
-						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"");
 					else{
 						var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
@@ -140,7 +140,7 @@
 		if(size != "false" && format != "false"){
 			var ind = pt.getMapObjIndexByName(target);
 			var map_el = pt.mb_mapObj[ind].getDomElement();
-			var coord = pt.mb_mapObj[ind].extent.split(",");
+			var coord = pt.mb_mapObj[ind].extent.toString().split(",");
 			var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
 			var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
 			if(size == "A4" && format == "portrait"){
@@ -185,7 +185,12 @@
 			var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
 			var prevscale= pt.mb_getScale(target);
-			pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," +  coord[3];
+			pt.mb_mapObj[ind].extent = new pt.Extent(
+				coord[0],
+				pos[1],
+				pos[0],
+				coord[3]
 			pt.mb_mapObj[ind].width = Math.round(map_width);
 			pt.mb_mapObj[ind].height = Math.round(map_height);
@@ -224,12 +229,17 @@
 		if(size != "" && format != ""){
+				coord[0],
+				pos[1],
+				pos[0],
+				coord[3]
Modified: branches/kmq_dev/http/sld/sld_pick_color.php
--- branches/kmq_dev/http/sld/sld_pick_color.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/http/sld/sld_pick_color.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -31,7 +31,7 @@
-session_start();
 $id = $_REQUEST["id"];
 $color= $_REQUEST["color"];
Deleted: branches/kmq_dev/index.php
--- branches/kmq_dev/index.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/index.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,3 +0,0 @@
-<?php
Modified: branches/kmq_dev/lib/ajax.js
--- branches/kmq_dev/lib/ajax.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/ajax.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -4,95 +4,68 @@
 * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
- *   AJAX wrapper functions
- * A wrapper for an AJAX request via GET
+ * Package: Ajax
- * @deprecated
- * @param {String} url the URL of a (presumably a server side) script.
- * @param {Object} param An object containing parameters, f.e. {name1:value1, name2:value2}
- * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (XML, HTML, whatever), status is a {String}, either "success" or "error".
+ * Description:
+ * An AJAX wrapper for client server interaction via JSON RPC
+ * Files:
+ *  - lib/ajax.js
+ * Help:
+ * <none>
-function mb_ajax_get(url, param, callback) {
-	try {
-//		$.ajaxSetup({async:false});
-		$.get(url, param, callback);
+Mapbender.Ajax = {
+	 * Property: requestCount
+	 * Description:
+	 * counts the number of requests that have been made
+	requestCount: 0,
+	Messages: {
+		fatalError: "A fatal error occured.",
+		idMismatchError: "The ID of the response is not equal to the ID of the request."
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_get:'+e);
- * A wrapper for an AJAX request via POST
+ * Package: Notification
+ * Description:
+ * An AJAX notification (it doesn't expect a reply from the server)
+ * Files:
+ *  - lib/ajax.js
- * @deprecated
+ * Help:
+ * <none>
-function mb_ajax_post(url, param, callback) {
-	try {
-		$.post(url, param, callback);
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_post:'+e);
- * @deprecated
- * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (a JavaScript Object, not a String!), status is a {String}, either "success" or "error".
+ * Constructor: Mapbender.Ajax.Request
+ * Parameters:
+ * options.url		- (String) The URL or the server side script
+ * options.type		- *[optional]* (String) "POST" (default) or "GET"
+ * options.log		- *[optional]* (Boolean) logs the request
+ * 						as Mapbender.Notice  (default: false)
+ * options.method	- *[optional]* (String) The name of the method that
+ * 						is called on the server side (default: "")
+ * options.parameters	- *[optional]* (Object) arguments being passed to
+ * 							the method given above
+ * <deprecated variable name>  - *[deprecated]* <type and description>
-function mb_ajax_json(url, param, callback) {
-	try {
-//		window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
-		$.getJSON(url, param, callback);
+Mapbender.Ajax.Notification = function (options) {
+	if (typeof options === "object") {
+		var url = (options.url) ? options.url : "";
+		var type = (options.type) ? options.type.toUpperCase() : "POST";
+		var log = (options.log) ? options.log : false;
+		var method = (options.method) ? options.method : "";
+		var parameters = (options.parameters) ? options.parameters : {};
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_json:'+e);
-Mapbender.Ajax = {
-	requestCount: 0,
-	Messages: {
-		"fatalError": "A fatal error occured.",
-		"idMismatchError": "The ID of the response is not equal to the ID of the request."
-Mapbender.Ajax.Notification = function () {
-	 * The method to call on the server
-	var method = "";
-	 * The parameters to pass to the above method
-	var parameters = {};
-	this.setMethod = function (aMethod) {
-		method = aMethod.toString();
-	this.setParameter = function (key, value) {
-		parameters[key] = value;
-		return true;
-	this.send = function (type, url) {
+	this.send = function () {
 		switch (type.toUpperCase()) {
 			case "POST" :
 				$.post(url, getParameters(), function () {
@@ -103,6 +76,8 @@
 				break;
 			default:
+				new Mapbender.Exception("Invalid type (" + type +
+					") in Mapbender.Ajax.Notification.");
 				return false;
 		return true;
@@ -115,64 +90,76 @@
 			"id": null
+ * Package: Request
+ * Description:
+ * An AJAX request (it expects a reply from the server)
+ * Files:
+ *  - lib/ajax.js
+ * Help:
+ * <none>
+ * Parameters:
+ * options.url			- (String) The URL to the server side script
+ * options.callback			- (Function) Will be called after the request
+ * 							is finished
+ * options.scope		- *[optional]* (Object) the callback will
+ * 							be executed within the scope of this object
 Mapbender.Ajax.Request = function (options) {
-	 * "POST" or "GET"
-	var type = (typeof(options) == "object" && options.type) ? options.type.toUpperCase() : "POST";
-	 * result of request will be logged as Mb_notice
-	var log = (typeof(options) == "object" && options.log) ? options.log : false;
-	var method = (typeof(options) == "object" && options.method) ? options.method : "";
+		var callback = (options.callback) ? options.callback : null;
+		var scope = (options.scope) ? options.scope : null;
+	else {
+		new Mapbender.Exception("No options specified in " +
+			"Mapbender.Ajax.Notification.");
+		return;
-	var parameters = (typeof(options) == "object" && options.parameters) ? options.parameters : {};
-	 * A unique identifier for this Ajax request
+	// A unique identifier for this Ajax request
 	var id = ++Mapbender.Ajax.requestCount;
-	 * The result object, coming from the server
+	// The result object, coming from the server
 	var result = {};
-	 * A message coming from the server
+	// A message coming from the server
 	var message = "";
-	 * Did the request succeed?
+	// Did the request succeed?
 	var success = false;
-	 * Did an internal error occur
+	// Did an internal error occur
 	var internalError = false;
-	 * Checks if the response is valid.
-	 * @param {String} json
-	 * @param {String} status
+	// Did the session expire
+	var sessionExpired = false;
+	// Checks if the response is valid.
 	var receive = function (json, status) {
 		if (!json) {
 			message = Mapbender.Ajax.Messages.fatalError;
-			new Mb_warning(message);
+			new Mapbender.Warning(message);
 			internalError = true;
 			return;
@@ -180,7 +167,7 @@
 		// some severe error has occured
 		if (typeof(resultObj) != "object" || status != "success") {
 			return;
@@ -195,7 +182,10 @@
 			if (resultObj.error.code == -1) {
+			else if (resultObj.error.code == -2) {
+				sessionExpired = true;
 			return;
@@ -205,7 +195,7 @@
 			if (id != resultObj.id) {
 				message = Mapbender.Ajax.Messages.idMismatchError;
 				return;
@@ -221,19 +211,36 @@
 		return;
-	this.send = function (url, callback, scope) {
+	 * Method: send
+	 * Description:
+	 * Sends the request to the server side
+		sessionExpired = false;
 		success = false;
 		var callbackWrapper = function (json, status) {
 			receive(json, status);
+			if (sessionExpired) {
+				alert(message);
+				window.location.reload();
+				return;
 			if (!internalError) {
-				new Mb_notice("REQUEST #" + id + ": " + url + "\n\n" +
+				new Mapbender.Notice("REQUEST #" + id + ": " + url + "\n\n" +
 					"RESULT: " + $.toJSON(result) + "\n\n" +
 					"SUCCESS: " + success + "\n\n" +
 					"MESSAGE: " + message);
-				if (scope !== undefined) {
+				if (typeof callback === null) {
+					new Mapbender.Warning("No callback function in " +
+						"Mapbender.Ajax.Request.");
+					return;
+				if (scope !== null) {
 					callback.apply(scope, [result, success, message]);
 				else {
Modified: branches/kmq_dev/lib/ajax.php
--- branches/kmq_dev/lib/ajax.php	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/ajax.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -18,6 +18,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__) . "/../http/classes/class_json.php");
+require_once(dirname(__FILE__) . "/class_Mapbender.php");
  * Represents an incoming JSON-RPC. It will NOT send a response to the client!
@@ -134,6 +135,16 @@
 			$this->message = _mb("Fatal error: Could not detect ID of AJAX request.");
 			$this->send();
+		if (!Mapbender::session()->get("mb_user_id") ||
+			!Mapbender::session()->get("mb_user_ip") ||
+			Mapbender::session()->get("mb_user_ip") != $_SERVER['REMOTE_ADDR']) {
+			$this->setSuccess(false);
+			$this->error = array(
+				"code" => -2,
+				"message" => _mb("The session has expired. Please log in again.")
@@ -186,10 +197,12 @@
 			$dataObject["message"] = $this->message;
 		else {
-			$this->error = array(
-				"code" => -1,
-				"message" => $this->message
+			if (is_null($this->error)) {
+					"code" => -1,
+					"message" => $this->message
 		$obj = array(
 			"result" => $dataObject,
Copied: branches/kmq_dev/lib/backwards_compatibility_to_2.6.js (from rev 4267, trunk/mapbender/lib/backwards_compatibility_to_2.6.js)
--- branches/kmq_dev/lib/backwards_compatibility_to_2.6.js	                        (rev 0)
+++ branches/kmq_dev/lib/backwards_compatibility_to_2.6.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,71 @@
+var ie = $.browser.msie;
+var n6 = document.getElementById&&!document.all?1:0;
+var n4 = document.layers?1:0;
+var mb_log = Mapbender.log;
+var mb_timestamp = Mapbender.getTimestamp;
+// Should be moved to a deprecated file
+var Mb_notice = Mapbender.Notice;
+var Mb_warning = Mapbender.Warning;
+var Mb_exception = Mapbender.Exception;
+ * A wrapper for an AJAX request via GET
+ * @deprecated
+ * @param {String} url the URL of a (presumably a server side) script.
+ * @param {Object} param An object containing parameters, f.e. {name1:value1, name2:value2}
+ * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (XML, HTML, whatever), status is a {String}, either "success" or "error".
+function mb_ajax_get(url, param, callback) {
+	try {
+//		$.ajaxSetup({async:false});
+		$.get(url, param, callback);
+	catch(e) {
+		var error = new Mb_exception('map.php: mb_ajax_get:'+e);
+ * A wrapper for an AJAX request via POST
+ * @deprecated
+function mb_ajax_post(url, param, callback) {
+	try {
+		$.post(url, param, callback);
+	catch(e) {
+		var error = new Mb_exception('map.php: mb_ajax_post:'+e);
+ * @deprecated
+ * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (a JavaScript Object, not a String!), status is a {String}, either "success" or "error".
+function mb_ajax_json(url, param, callback) {
+	try {
+//		window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
+		$.getJSON(url, param, callback);
+	catch(e) {
+		var error = new Mb_exception('map.php: mb_ajax_json:'+e);
Modified: branches/kmq_dev/lib/basic.js
--- branches/kmq_dev/lib/basic.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/basic.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,11 +1,6 @@
-var ie = document.all?1:0;
-var n6 = document.getElementById&&!document.all?1:0;
-var n4 = document.layers?1:0;
 var clickX;
 var clickY;
-var mb_log = null;
 // transparent GIF
@@ -75,11 +70,6 @@
 	return c;
-function mb_timestamp(){
-	var d = new Date();
-	var ts = Math.round(Date.parse(d)/1000);
-	return ts;
  * @deprecated
Modified: branches/kmq_dev/lib/button.js
--- branches/kmq_dev/lib/button.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/button.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -3,42 +3,62 @@
  *   button handling
+Mapbender.Button = function (options) {
+	mb_regButton(options);
 var mb_button = [];
 function mb_regButton_frame(wii, frameName, param){
 	var ind = mb_button.length;
 	mb_button[ind] = new mb_conButton(wii, ind);
-	if (frameName === null) {
-		if (param === null) {
-			if (typeof(wii) == "string") {
-				eval(wii+"("+ind+")");
-			else {
-				wii(ind);
+	if (typeof wii === "object") {
+		var options = wii;
+		mb_button[ind] = options.domElement;
+		mb_button[ind].img_over = options.over ? options.over : "";
+		mb_button[ind].img_on = options.on ? options.on : ""
+		mb_button[ind].img_off = options.off ? options.off : "";
+		mb_button[ind].status = options.status ? options.status : 0;
+		mb_button[ind].elName = options.name ? options.name : "";
+		mb_button[ind].fName = options.frameName ? options.frameName : "";
+		if (options.go && typeof options.go === "function") {
+			mb_button[ind].go = options.go;
 		else {
-				eval(wii + "(" + ind + ", " + param + ")");
-			else {
-				wii(ind, param);
+			mb_button[ind].go = function () {
+		if (options.stop && typeof options.stop === "function") {
+			mb_button[ind].stop = options.stop;
+		else {
+			mb_button[ind].stop = function () {
-	else if (param === null) {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
+	else if (typeof wii === "string") {
+		var str = "";
+		if (frameName !== null) {
+			str += "window.frames['" + frameName + "'].";
+		str += wii + "(" + ind;
+		if (param !== null) {
+			str += "," + param;
+		str += ");";
+		eval(str);
-	else {
-			eval("window.frames['" + frameName + "']."+ wii + "(" + ind + ", " + param + ")");
+	else if (typeof wii == "function") {
+		if (param === null) {
+			wii(ind);
 		else {
 			wii(ind, param);
 	mb_button[ind].prev = mb_button[ind].src;
 	mb_button[ind].src = mb_button[ind].img_off;
 	mb_button[ind].onmouseover = function () {
@@ -63,7 +83,6 @@
 function mb_conButton(wii, ind){
-   this.wii = wii;
    return true;
 function mb_button_over(ind){
@@ -156,8 +175,11 @@
 function mb_localizeButtons(){
-	var req = new Mapbender.Ajax.Request();
-	req.send("../php/mod_button_tooltips.php", updateButtonTooltips);
+	var req = new Mapbender.Ajax.Request({
+		url: "../php/mod_button_tooltips.php",
+		callback: updateButtonTooltips
+	req.send();
 eventLocalize.register(function () {
Copied: branches/kmq_dev/lib/class_Mapbender.php (from rev 4267, trunk/mapbender/lib/class_Mapbender.php)
--- branches/kmq_dev/lib/class_Mapbender.php	                        (rev 0)
+++ branches/kmq_dev/lib/class_Mapbender.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,25 @@
+<?php
+ * Created on 24.06.2009
+ * To change the template for this generated file go to
+ * Window - Preferences - PHPeclipse - PHP - Code Templates
+require_once(dirname(__FILE__)."/class_Mapbender_session.php");
+require_once(dirname(__FILE__)."/class_Singleton.php");
+ class Mapbender extends Singleton{
+ 	protected function __construct() {
+ 	public static function session(){
+ 		return Mapbender_session::singleton();
+ 	public static function singleton()
+        return parent::singleton(__CLASS__);
Copied: branches/kmq_dev/lib/class_Mapbender_session.php (from rev 4267, trunk/mapbender/lib/class_Mapbender_session.php)
--- branches/kmq_dev/lib/class_Mapbender_session.php	                        (rev 0)
+++ branches/kmq_dev/lib/class_Mapbender_session.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,99 @@
+<?php
+ * manages the session-handling and the access to session-variables
+ * @class
+ require_once(dirname(__FILE__)."/../http/classes/class_mb_exception.php");
+ require_once(dirname(__FILE__)."/class_Singleton.php");
+ class Mapbender_session extends Singleton{
+ 	private $id ;
+	 * @constructor
+ 		$id = false;
+ 		new mb_notice("session.mapbender_session.instantiated ... ");
+	 * sets the value of the session-variable
+	 * @param String name the name of the session-variable
+	 * @param Mixed value the new value of the session-variable
+ 	public function set($name, $value){
+ 		$this->start();
+ 		$_SESSION[$name] = $value;
+ 		new mb_notice("session.setSessionVariable.set: " . $name ." = ". $value);
+ 		session_write_close();
+ 	/* pushs the array of the session-variable
+ 	public function push($name, $value){
+ 		//not implemented yet
+ 		// todo
+	 * returns the value of the session-variable
+ 	public function get($name){
+ 		$this->start();
+ 		if(isset($_SESSION[$name])){
+ 			return $_SESSION[$name];
+ 		else{
+ 			new mb_exception("some want to acces the sessionVariable: ".$name." but it's not set!'");
+ 			return false;
+	 * sets a new session-id
+	 * @param String id the new id of the session
+ 	public function setId($id){
+		$this->id = $id;
+	 * starts the new session
+	private function start(){
+		if(session_id() == ''){
+			new mb_notice("session.sessionStart.noActiveId");
+		if($this->id){
+			session_id($this->id);
+			new mb_notice("session.sessionStart.changeId to: ". session_id());
+		session_start();
+		new mb_notice("session.sessionStart.id: ". session_id());
+	 * kills the current session
+	 public function kill(){
+	 	if (isset($_COOKIE[session_name()])) {
+    	setcookie(session_name(), '', time()-42000, '/');
+		if(session_id()){
+			session_destroy();
Copied: branches/kmq_dev/lib/class_Singleton.php (from rev 4267, trunk/mapbender/lib/class_Singleton.php)
--- branches/kmq_dev/lib/class_Singleton.php	                        (rev 0)
+++ branches/kmq_dev/lib/class_Singleton.php	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,23 @@
+<?php
+class Singleton
+   // Hold an instance of the class
+   private static $instance;
+   // A private constructor; prevents direct creation of object
+   private function __construct()
+       echo 'I am constructed';
+   // The singleton method
+   public static function singleton($classname)
+       if (!isset(self::$instance)) {
+           self::$instance = new $classname;
+       return self::$instance;
\ No newline at end of file
Modified: branches/kmq_dev/lib/core.js
--- branches/kmq_dev/lib/core.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/core.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,3 +1,9 @@
+ * @deprecated, use Mapbender.modules[module_id]
+var mb_mapObj = [];
 var currentWmcExtensionData = {};
 var restoredWmcExtensionData = {};
@@ -39,25 +45,25 @@
  * Triggered when Mapbender is loaded and after the map object has been initialised.
-var eventInit = new MapbenderEvent();
+var eventInit = Mapbender.events.init = new MapbenderEvent();
  * Triggered before eventInit.
-var eventBeforeInit = new MapbenderEvent();
+var eventBeforeInit = Mapbender.events.beforeInit = new MapbenderEvent();
  * Triggered after Mapbender is loaded and has been initialised.
  * Used to trigger initial map requests
-var eventAfterInit = new MapbenderEvent();
+var eventAfterInit = Mapbender.events.afterInit = new MapbenderEvent();
  * Initializes the map object. Triggered when Mapbender is loaded.
-var eventInitMap = new MapbenderEvent();
+var eventInitMap = Mapbender.events.initMaps = new MapbenderEvent();
-eventInit.register(function() {
+Mapbender.events.init.register(function() {
 	$lm = $("#loading_mapbender");
 	$cm = $("#complete_mapbender");
 	$lm.empty();
@@ -67,7 +73,7 @@
  * Switches the locale. Triggered by module switch_locale or onload(?)
-var eventLocalize = new MapbenderEvent();
+var eventLocalize = Mapbender.events.localize = new MapbenderEvent();
  * Triggered after the map object has been created.
@@ -172,16 +178,9 @@
  * Called in index.php on body onload
-function init() {
-	// creates the map objects (mapframe1, overview...)
-	eventInitMap.trigger();
-	eventBeforeInit.trigger();
-	// initialisation
-	eventInit.trigger();
-	eventAfterInit.trigger();
+function init(){
+	new Mb_notice("old body onload init");
Modified: branches/kmq_dev/lib/event.js
--- branches/kmq_dev/lib/event.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/event.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,22 +1,25 @@
- * An event. What happens, when the event occurs, depends on which functions have been
+ * Package: Event
+ * Description:
+ *  An event. What happens, when the event occurs, depends on which functions have been
  * registered with the event.
  * usage:
- * // create a new Event
- * var eventAfterMapRequest = new MapbenderEvent();
+ * > // create a new Event
+ * > var eventAfterMapRequest = new MapbenderEvent();
+ * > // register a function with that event
+ * > eventAfterMapRequest.register(function () {
+ * > // trigger the event
+ * > eventAfterMapRequest.trigger();
- * // register a function with that event
- * eventAfterMapRequest.register(function () {
- * // trigger the event
- * eventAfterMapRequest.trigger();
-var MapbenderEvent = function () {
+var MapbenderEvent = Mapbender.Event = function () {
 	// public methods
Modified: branches/kmq_dev/lib/exception.js
--- branches/kmq_dev/lib/exception.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/exception.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -4,111 +4,139 @@
- *   Javascript exception handling
- * @class An abstract class, logs JavaScript events like errors, warnings etc.
- * @constructor
-function Mb_log () {
-	var that = this;
+(function () {
-	var levelArray = global_log_levels.split(",");
-	var log_level = global_mb_log_level;
-	var log_js = global_mb_log_js;
-	var indexOfLevel = function(aLevel) {
-		for (var i = 0; i < levelArray.length; i++) {
-			if (aLevel == levelArray[i])  {
-				return i;
-		return false;
-	var isValidLevel = function(aLevel) {
-		var isNotOff = typeof(log_js) != 'undefined' && log_js != "off";
-		var levelIndex = indexOfLevel(aLevel);
-		var isAppropriate = (typeof(levelIndex)=='number' && levelIndex <= indexOfLevel(log_level));
-		return (isNotOff && isAppropriate);
-	this.throwException = function (message, level) {
-		if (isValidLevel(level)) {
-			if (log_js == "on") {
-				try {
-					mb_ajax_post('../php/mb_js_exception.php', {level:level,text:message});
+	//An abstract class, logs JavaScript events like errors, warnings etc.
+	function Mb_log () {
+		var that = this;
+		var levelArray = global_log_levels.split(",");
+		var log_level = global_mb_log_level;
+		var log_js = global_mb_log_js;
+		var indexOfLevel = function(aLevel) {
+			for (var i = 0; i < levelArray.length; i++) {
+				if (aLevel == levelArray[i]) {
+					return i;
-				catch(e) {
-					alert(e + ": " + message);
-			else if (log_js == "alert") {
-				alert(message);
-			else if (log_js == "console") {
-				if ($.browser.msie) {
+			return false;
+		var isValidLevel = function(aLevel) {
+			var isNotOff = typeof(log_js) != 'undefined' && log_js != "off";
+			var levelIndex = indexOfLevel(aLevel);
+			var isAppropriate = (typeof(levelIndex)=='number' && levelIndex <= indexOfLevel(log_level));
+			return (isNotOff && isAppropriate);
+		this.throwException = function (message, level) {
+			if (isValidLevel(level)) {
+				if (log_js == "on") {
 					try {
 					catch(e) {
-				else {
-					if (level == "warning") {
-						console.warn("%s", message);
+				else if (log_js == "alert") {
+					alert(message);
+				else if (log_js == "console") {
+					if ($.browser.msie) {
+						try {
+							mb_ajax_post('../php/mb_js_exception.php', {level:level,text:message});
+						catch(e) {
+							alert(e + ": " + message);
-					else if (level == "error") {
-						console.error("%s", message);
 					else {
-						console.log("%s", message);
+						if (level == "warning") {
+							console.warn("%s", message);
+						else if (level == "error") {
+							console.error("%s", message);
+						else {
+							console.log("%s", message);
+	 * Class: Exception
+	 * Description:
+	 * Logs an exception in the log file, in a console window or as an alert
+	 * Files:
+	 *  - lib/exception.js
+	 * Help:
+	 * <none>
+	 * Constructor: Exception
+	 * Parameters:
+	 * message	- A message that is being logged
+	Mapbender.Exception = function (message) {
+		var level = "error";
+		this.throwException(message, level);
+	Mapbender.Exception.prototype = new Mb_log();
+	 * Class: Warning
+	 * Description:
+	 * Logs an warning in the log file, in a console window or as an alert
+	 * Files:
+	 * Help:
+	 * <none>
+	 * Constructor: Warning
+	 * Parameters:
+	Mapbender.Warning = function (message) {
+		var level = "warning";
+	Mapbender.Warning.prototype = new Mb_log();
+	 * Package: Notice
+	 * Description:
+	 * Logs a notice in the log file, in a console window or as an alert
+	 * Files:
+	 * Help:
+	 * <none>
+	 * Constructor: Notice
+	 * Parameters:
+	Mapbender.Notice = function (message) {
+		var level = "notice";
+	Mapbender.Notice.prototype = new Mb_log();
- *  class for exception logging
- * @extends {@link Mb_log}
- * @param message the message that is being logged
-function Mb_exception(message) {
-	var level = "error";
-	this.throwException(message, level);
-Mb_exception.prototype = new Mb_log();
- *  class for warning logging
-function Mb_warning(message) {
-	var level = "warning";
-Mb_warning.prototype = new Mb_log();
- *  class for notice logging
-function Mb_notice(message) {
-	var level = "notice";
-Mb_notice.prototype = new Mb_log();
Modified: branches/kmq_dev/lib/point.js
--- branches/kmq_dev/lib/point.js	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/lib/point.js	2009-07-01 14:40:19 UTC (rev 4271)
@@ -162,7 +162,12 @@
 		new_min = new Point(min.x, center.y - relation_px_y * extent.x / 2);
 		new_max = new Point(max.x, center.y + relation_px_y * extent.x / 2);
-	mb_mapObj[ind].extent = new_min.x +","+ new_min.y +","+ new_max.x  +","+ new_max.y;
+	mb_mapObj[ind].extent = new Extent(
+		new_min.x,
+		new_min.y,
+		new_max.x,
+		new_max.y
  * @ignore
Modified: branches/kmq_dev/license/gpl.txt
--- branches/kmq_dev/license/gpl.txt	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/license/gpl.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,301 +1,642 @@
-		    GNU GENERAL PUBLIC LICENSE
-		       Version 2, June 1991
+                    GNU GENERAL PUBLIC LICENSE
+                       Version 3, 29 June 2007
- Copyright (C) 1989, 1991 Free Software Foundation, Inc.
-                       59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+ Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
  Everyone is permitted to copy and distribute verbatim copies
  of this license document, but changing it is not allowed.
-			    Preamble
+                            Preamble
-  The licenses for most software are designed to take away your
-freedom to share and change it.  By contrast, the GNU General Public
-License is intended to guarantee your freedom to share and change free
-software--to make sure the software is free for all its users.  This
-General Public License applies to most of the Free Software
-Foundation's software and to any other program whose authors commit to
-using it.  (Some other Free Software Foundation software is covered by
-the GNU Library General Public License instead.)  You can apply it to
+  The GNU General Public License is a free, copyleft license for
+software and other kinds of works.
+  The licenses for most software and other practical works are designed
+to take away your freedom to share and change the works.  By contrast,
+the GNU General Public License is intended to guarantee your freedom to
+share and change all versions of a program--to make sure it remains free
+software for all its users.  We, the Free Software Foundation, use the
+GNU General Public License for most of our software; it applies also to
+any other work released this way by its authors.  You can apply it to
 your programs, too.
   When we speak of free software, we are referring to freedom, not
 price.  Our General Public Licenses are designed to make sure that you
 have the freedom to distribute copies of free software (and charge for
-this service if you wish), that you receive source code or can get it
-if you want it, that you can change the software or use pieces of it
-in new free programs; and that you know you can do these things.
+them if you wish), that you receive source code or can get it if you
+want it, that you can change the software or use pieces of it in new
+free programs, and that you know you can do these things.
-  To protect your rights, we need to make restrictions that forbid
-anyone to deny you these rights or to ask you to surrender the rights.
-These restrictions translate to certain responsibilities for you if you
-distribute copies of the software, or if you modify it.
+  To protect your rights, we need to prevent others from denying you
+these rights or asking you to surrender the rights.  Therefore, you have
+certain responsibilities if you distribute copies of the software, or if
+you modify it: responsibilities to respect the freedom of others.
   For example, if you distribute copies of such a program, whether
-gratis or for a fee, you must give the recipients all the rights that
-you have.  You must make sure that they, too, receive or can get the
-source code.  And you must show them these terms so they know their
-rights.
+gratis or for a fee, you must pass on to the recipients the same
+freedoms that you received.  You must make sure that they, too, receive
+or can get the source code.  And you must show them these terms so they
+know their rights.
-  We protect your rights with two steps: (1) copyright the software, and
-(2) offer you this license which gives you legal permission to copy,
-distribute and/or modify the software.
+  Developers that use the GNU GPL protect your rights with two steps:
+(1) assert copyright on the software, and (2) offer you this License
+giving you legal permission to copy, distribute and/or modify it.
-  Also, for each author's protection and ours, we want to make certain
-that everyone understands that there is no warranty for this free
-software.  If the software is modified by someone else and passed on, we
-want its recipients to know that what they have is not the original, so
-that any problems introduced by others will not reflect on the original
-authors' reputations.
+  For the developers' and authors' protection, the GPL clearly explains
+that there is no warranty for this free software.  For both users' and
+authors' sake, the GPL requires that modified versions be marked as
+changed, so that their problems will not be attributed erroneously to
+authors of previous versions.
-  Finally, any free program is threatened constantly by software
-patents.  We wish to avoid the danger that redistributors of a free
-program will individually obtain patent licenses, in effect making the
-program proprietary.  To prevent this, we have made it clear that any
-patent must be licensed for everyone's free use or not licensed at all.
+  Some devices are designed to deny users access to install or run
+modified versions of the software inside them, although the manufacturer
+can do so.  This is fundamentally incompatible with the aim of
+protecting users' freedom to change the software.  The systematic
+pattern of such abuse occurs in the area of products for individuals to
+use, which is precisely where it is most unacceptable.  Therefore, we
+have designed this version of the GPL to prohibit the practice for those
+products.  If such problems arise substantially in other domains, we
+stand ready to extend this provision to those domains in future versions
+of the GPL, as needed to protect the freedom of users.
+  Finally, every program is threatened constantly by software patents.
+States should not allow patents to restrict development and use of
+software on general-purpose computers, but in those that do, we wish to
+avoid the special danger that patents applied to a free program could
+make it effectively proprietary.  To prevent this, the GPL assures that
+patents cannot be used to render the program non-free.
   The precise terms and conditions for copying, distribution and
 modification follow.
-   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
-  0. This License applies to any program or other work which contains
-a notice placed by the copyright holder saying it may be distributed
-under the terms of this General Public License.  The "Program", below,
-refers to any such program or work, and a "work based on the Program"
-means either the Program or any derivative work under copyright law:
-that is to say, a work containing the Program or a portion of it,
-either verbatim or with modifications and/or translated into another
-language.  (Hereinafter, translation is included without limitation in
-the term "modification".)  Each licensee is addressed as "you".
+                       TERMS AND CONDITIONS
-Activities other than copying, distribution and modification are not
-covered by this License; they are outside its scope.  The act of
-running the Program is not restricted, and the output from the Program
-is covered only if its contents constitute a work based on the
-Program (independent of having been made by running the Program).
-Whether that is true depends on what the Program does.
+  0. Definitions.
-  1. You may copy and distribute verbatim copies of the Program's
-source code as you receive it, in any medium, provided that you
-conspicuously and appropriately publish on each copy an appropriate
-copyright notice and disclaimer of warranty; keep intact all the
-notices that refer to this License and to the absence of any warranty;
-and give any other recipients of the Program a copy of this License
-along with the Program.
+  "This License" refers to version 3 of the GNU General Public License.
-You may charge a fee for the physical act of transferring a copy, and
-you may at your option offer warranty protection in exchange for a fee.
+  "Copyright" also means copyright-like laws that apply to other kinds of
+works, such as semiconductor masks.
-  2. You may modify your copy or copies of the Program or any portion
-of it, thus forming a work based on the Program, and copy and
-distribute such modifications or work under the terms of Section 1
-above, provided that you also meet all of these conditions:
+  "The Program" refers to any copyrightable work licensed under this
+License.  Each licensee is addressed as "you".  "Licensees" and
+"recipients" may be individuals or organizations.
-    a) You must cause the modified files to carry prominent notices
-    stating that you changed the files and the date of any change.
+  To "modify" a work means to copy from or adapt all or part of the work
+in a fashion requiring copyright permission, other than the making of an
+exact copy.  The resulting work is called a "modified version" of the
+earlier work or a work "based on" the earlier work.
-    b) You must cause any work that you distribute or publish, that in
-    whole or in part contains or is derived from the Program or any
-    part thereof, to be licensed as a whole at no charge to all third
-    parties under the terms of this License.
+  A "covered work" means either the unmodified Program or a work based
+on the Program.
-    c) If the modified program normally reads commands interactively
-    when run, you must cause it, when started running for such
-    interactive use in the most ordinary way, to print or display an
-    announcement including an appropriate copyright notice and a
-    notice that there is no warranty (or else, saying that you provide
-    a warranty) and that users may redistribute the program under
-    these conditions, and telling the user how to view a copy of this
-    License.  (Exception: if the Program itself is interactive but
-    does not normally print such an announcement, your work based on
-    the Program is not required to print an announcement.)
-These requirements apply to the modified work as a whole.  If
-identifiable sections of that work are not derived from the Program,
-and can be reasonably considered independent and separate works in
-themselves, then this License, and its terms, do not apply to those
-sections when you distribute them as separate works.  But when you
-distribute the same sections as part of a whole which is a work based
-on the Program, the distribution of the whole must be on the terms of
-this License, whose permissions for other licensees extend to the
-entire whole, and thus to each and every part regardless of who wrote it.
+  To "propagate" a work means to do anything with it that, without
+permission, would make you directly or secondarily liable for
+infringement under applicable copyright law, except executing it on a
+computer or modifying a private copy.  Propagation includes copying,
+distribution (with or without modification), making available to the
+public, and in some countries other activities as well.
-Thus, it is not the intent of this section to claim rights or contest
-your rights to work written entirely by you; rather, the intent is to
-exercise the right to control the distribution of derivative or
-collective works based on the Program.
+  To "convey" a work means any kind of propagation that enables other
+parties to make or receive copies.  Mere interaction with a user through
+a computer network, with no transfer of a copy, is not conveying.
-In addition, mere aggregation of another work not based on the Program
-with the Program (or with a work based on the Program) on a volume of
-a storage or distribution medium does not bring the other work under
-the scope of this License.
+  An interactive user interface displays "Appropriate Legal Notices"
+to the extent that it includes a convenient and prominently visible
+feature that (1) displays an appropriate copyright notice, and (2)
+tells the user that there is no warranty for the work (except to the
+extent that warranties are provided), that licensees may convey the
+work under this License, and how to view a copy of this License.  If
+the interface presents a list of user commands or options, such as a
+menu, a prominent item in the list meets this criterion.
-  3. You may copy and distribute the Program (or a work based on it,
-under Section 2) in object code or executable form under the terms of
-Sections 1 and 2 above provided that you also do one of the following:
+  1. Source Code.
-    a) Accompany it with the complete corresponding machine-readable
-    source code, which must be distributed under the terms of Sections
-    1 and 2 above on a medium customarily used for software interchange; or,
+  The "source code" for a work means the preferred form of the work
+for making modifications to it.  "Object code" means any non-source
+form of a work.
-    b) Accompany it with a written offer, valid for at least three
-    years, to give any third party, for a charge no more than your
-    cost of physically performing source distribution, a complete
-    machine-readable copy of the corresponding source code, to be
-    distributed under the terms of Sections 1 and 2 above on a medium
-    customarily used for software interchange; or,
+  A "Standard Interface" means an interface that either is an official
+standard defined by a recognized standards body, or, in the case of
+interfaces specified for a particular programming language, one that
+is widely used among developers working in that language.
-    c) Accompany it with the information you received as to the offer
-    to distribute corresponding source code.  (This alternative is
-    allowed only for noncommercial distribution and only if you
-    received the program in object code or executable form with such
-    an offer, in accord with Subsection b above.)
+  The "System Libraries" of an executable work include anything, other
+than the work as a whole, that (a) is included in the normal form of
+packaging a Major Component, but which is not part of that Major
+Component, and (b) serves only to enable use of the work with that
+Major Component, or to implement a Standard Interface for which an
+implementation is available to the public in source code form.  A
+"Major Component", in this context, means a major essential component
+(kernel, window system, and so on) of the specific operating system
+(if any) on which the executable work runs, or a compiler used to
+produce the work, or an object code interpreter used to run it.
-The source code for a work means the preferred form of the work for
-making modifications to it.  For an executable work, complete source
-code means all the source code for all modules it contains, plus any
-associated interface definition files, plus the scripts used to
-control compilation and installation of the executable.  However, as a
-special exception, the source code distributed need not include
-anything that is normally distributed (in either source or binary
-form) with the major components (compiler, kernel, and so on) of the
-operating system on which the executable runs, unless that component
-itself accompanies the executable.
+  The "Corresponding Source" for a work in object code form means all
+the source code needed to generate, install, and (for an executable
+work) run the object code and to modify the work, including scripts to
+control those activities.  However, it does not include the work's
+System Libraries, or general-purpose tools or generally available free
+programs which are used unmodified in performing those activities but
+which are not part of the work.  For example, Corresponding Source
+includes interface definition files associated with source files for
+the work, and the source code for shared libraries and dynamically
+linked subprograms that the work is specifically designed to require,
+such as by intimate data communication or control flow between those
+subprograms and other parts of the work.
-If distribution of executable or object code is made by offering
-access to copy from a designated place, then offering equivalent
-access to copy the source code from the same place counts as
-distribution of the source code, even though third parties are not
-compelled to copy the source along with the object code.
-  4. You may not copy, modify, sublicense, or distribute the Program
-except as expressly provided under this License.  Any attempt
-otherwise to copy, modify, sublicense or distribute the Program is
-void, and will automatically terminate your rights under this License.
-However, parties who have received copies, or rights, from you under
-this License will not have their licenses terminated so long as such
-parties remain in full compliance.
+  The Corresponding Source need not include anything that users
+can regenerate automatically from other parts of the Corresponding
+Source.
-  5. You are not required to accept this License, since you have not
-signed it.  However, nothing else grants you permission to modify or
-distribute the Program or its derivative works.  These actions are
-prohibited by law if you do not accept this License.  Therefore, by
-modifying or distributing the Program (or any work based on the
-Program), you indicate your acceptance of this License to do so, and
-all its terms and conditions for copying, distributing or modifying
-the Program or works based on it.
+  The Corresponding Source for a work in source code form is that
+same work.
-  6. Each time you redistribute the Program (or any work based on the
-Program), the recipient automatically receives a license from the
-original licensor to copy, distribute or modify the Program subject to
-these terms and conditions.  You may not impose any further
-restrictions on the recipients' exercise of the rights granted herein.
-You are not responsible for enforcing compliance by third parties to
+  2. Basic Permissions.
+  All rights granted under this License are granted for the term of
+copyright on the Program, and are irrevocable provided the stated
+conditions are met.  This License explicitly affirms your unlimited
+permission to run the unmodified Program.  The output from running a
+covered work is covered by this License only if the output, given its
+content, constitutes a covered work.  This License acknowledges your
+rights of fair use or other equivalent, as provided by copyright law.
+  You may make, run and propagate covered works that you do not
+convey, without conditions so long as your license otherwise remains
+in force.  You may convey covered works to others for the sole purpose
+of having them make modifications exclusively for you, or provide you
+with facilities for running those works, provided that you comply with
+the terms of this License in conveying all material for which you do
+not control copyright.  Those thus making or running the covered works
+for you must do so exclusively on your behalf, under your direction
+and control, on terms that prohibit them from making any copies of
+your copyrighted material outside their relationship with you.
+  Conveying under any other circumstances is permitted solely under
+the conditions stated below.  Sublicensing is not allowed; section 10
+makes it unnecessary.
+  3. Protecting Users' Legal Rights From Anti-Circumvention Law.
+  No covered work shall be deemed part of an effective technological
+measure under any applicable law fulfilling obligations under article
+11 of the WIPO copyright treaty adopted on 20 December 1996, or
+similar laws prohibiting or restricting circumvention of such
+measures.
+  When you convey a covered work, you waive any legal power to forbid
+circumvention of technological measures to the extent such circumvention
+is effected by exercising rights under this License with respect to
+the covered work, and you disclaim any intention to limit operation or
+modification of the work as a means of enforcing, against the work's
+users, your or third parties' legal rights to forbid circumvention of
+technological measures.
+  4. Conveying Verbatim Copies.
+  You may convey verbatim copies of the Program's source code as you
+receive it, in any medium, provided that you conspicuously and
+appropriately publish on each copy an appropriate copyright notice;
+keep intact all notices stating that this License and any
+non-permissive terms added in accord with section 7 apply to the code;
+keep intact all notices of the absence of any warranty; and give all
+recipients a copy of this License along with the Program.
+  You may charge any price or no price for each copy that you convey,
+and you may offer support or warranty protection for a fee.
+  5. Conveying Modified Source Versions.
+  You may convey a work based on the Program, or the modifications to
+produce it from the Program, in the form of source code under the
+terms of section 4, provided that you also meet all of these conditions:
+    a) The work must carry prominent notices stating that you modified
+    it, and giving a relevant date.
+    b) The work must carry prominent notices stating that it is
+    released under this License and any conditions added under section
+    7.  This requirement modifies the requirement in section 4 to
+    "keep intact all notices".
+    c) You must license the entire work, as a whole, under this
+    License to anyone who comes into possession of a copy.  This
+    License will therefore apply, along with any applicable section 7
+    additional terms, to the whole of the work, and all its parts,
+    regardless of how they are packaged.  This License gives no
+    permission to license the work in any other way, but it does not
+    invalidate such permission if you have separately received it.
+    d) If the work has interactive user interfaces, each must display
+    Appropriate Legal Notices; however, if the Program has interactive
+    interfaces that do not display Appropriate Legal Notices, your
+    work need not make them do so.
+  A compilation of a covered work with other separate and independent
+works, which are not by their nature extensions of the covered work,
+and which are not combined with it such as to form a larger program,
+in or on a volume of a storage or distribution medium, is called an
+"aggregate" if the compilation and its resulting copyright are not
+used to limit the access or legal rights of the compilation's users
+beyond what the individual works permit.  Inclusion of a covered work
+in an aggregate does not cause this License to apply to the other
+parts of the aggregate.
+  6. Conveying Non-Source Forms.
+  You may convey a covered work in object code form under the terms
+of sections 4 and 5, provided that you also convey the
+machine-readable Corresponding Source under the terms of this License,
+in one of these ways:
+    a) Convey the object code in, or embodied in, a physical product
+    (including a physical distribution medium), accompanied by the
+    Corresponding Source fixed on a durable physical medium
+    customarily used for software interchange.
+    b) Convey the object code in, or embodied in, a physical product
+    (including a physical distribution medium), accompanied by a
+    written offer, valid for at least three years and valid for as
+    long as you offer spare parts or customer support for that product
+    model, to give anyone who possesses the object code either (1) a
+    copy of the Corresponding Source for all the software in the
+    product that is covered by this License, on a durable physical
+    medium customarily used for software interchange, for a price no
+    more than your reasonable cost of physically performing this
+    conveying of source, or (2) access to copy the
+    Corresponding Source from a network server at no charge.
+    c) Convey individual copies of the object code with a copy of the
+    written offer to provide the Corresponding Source.  This
+    alternative is allowed only occasionally and noncommercially, and
+    only if you received the object code with such an offer, in accord
+    with subsection 6b.
+    d) Convey the object code by offering access from a designated
+    place (gratis or for a charge), and offer equivalent access to the
+    Corresponding Source in the same way through the same place at no
+    further charge.  You need not require recipients to copy the
+    Corresponding Source along with the object code.  If the place to
+    copy the object code is a network server, the Corresponding Source
+    may be on a different server (operated by you or a third party)
+    that supports equivalent copying facilities, provided you maintain
+    clear directions next to the object code saying where to find the
+    Corresponding Source.  Regardless of what server hosts the
+    Corresponding Source, you remain obligated to ensure that it is
+    available for as long as needed to satisfy these requirements.
+    e) Convey the object code using peer-to-peer transmission, provided
+    you inform other peers where the object code and Corresponding
+    Source of the work are being offered to the general public at no
+    charge under subsection 6d.
+  A separable portion of the object code, whose source code is excluded
+from the Corresponding Source as a System Library, need not be
+included in conveying the object code work.
+  A "User Product" is either (1) a "consumer product", which means any
+tangible personal property which is normally used for personal, family,
+or household purposes, or (2) anything designed or sold for incorporation
+into a dwelling.  In determining whether a product is a consumer product,
+doubtful cases shall be resolved in favor of coverage.  For a particular
+product received by a particular user, "normally used" refers to a
+typical or common use of that class of product, regardless of the status
+of the particular user or of the way in which the particular user
+actually uses, or expects or is expected to use, the product.  A product
+is a consumer product regardless of whether the product has substantial
+commercial, industrial or non-consumer uses, unless such uses represent
+the only significant mode of use of the product.
+  "Installation Information" for a User Product means any methods,
+procedures, authorization keys, or other information required to install
+and execute modified versions of a covered work in that User Product from
+a modified version of its Corresponding Source.  The information must
+suffice to ensure that the continued functioning of the modified object
+code is in no case prevented or interfered with solely because
+modification has been made.
+  If you convey an object code work under this section in, or with, or
+specifically for use in, a User Product, and the conveying occurs as
+part of a transaction in which the right of possession and use of the
+User Product is transferred to the recipient in perpetuity or for a
+fixed term (regardless of how the transaction is characterized), the
+Corresponding Source conveyed under this section must be accompanied
+by the Installation Information.  But this requirement does not apply
+if neither you nor any third party retains the ability to install
+modified object code on the User Product (for example, the work has
+been installed in ROM).
+  The requirement to provide Installation Information does not include a
+requirement to continue to provide support service, warranty, or updates
+for a work that has been modified or installed by the recipient, or for
+the User Product in which it has been modified or installed.  Access to a
+network may be denied when the modification itself materially and
+adversely affects the operation of the network or violates the rules and
+protocols for communication across the network.
+  Corresponding Source conveyed, and Installation Information provided,
+in accord with this section must be in a format that is publicly
+documented (and with an implementation available to the public in
+source code form), and must require no special password or key for
+unpacking, reading or copying.
+  7. Additional Terms.
+  "Additional permissions" are terms that supplement the terms of this
+License by making exceptions from one or more of its conditions.
+Additional permissions that are applicable to the entire Program shall
+be treated as though they were included in this License, to the extent
+that they are valid under applicable law.  If additional permissions
+apply only to part of the Program, that part may be used separately
+under those permissions, but the entire Program remains governed by
+this License without regard to the additional permissions.
+  When you convey a copy of a covered work, you may at your option
+remove any additional permissions from that copy, or from any part of
+it.  (Additional permissions may be written to require their own
+removal in certain cases when you modify the work.)  You may place
+additional permissions on material, added by you to a covered work,
+for which you have or can give appropriate copyright permission.
+  Notwithstanding any other provision of this License, for material you
+add to a covered work, you may (if authorized by the copyright holders of
+that material) supplement the terms of this License with terms:
+    a) Disclaiming warranty or limiting liability differently from the
+    terms of sections 15 and 16 of this License; or
+    b) Requiring preservation of specified reasonable legal notices or
+    author attributions in that material or in the Appropriate Legal
+    Notices displayed by works containing it; or
+    c) Prohibiting misrepresentation of the origin of that material, or
+    requiring that modified versions of such material be marked in
+    reasonable ways as different from the original version; or
+    d) Limiting the use for publicity purposes of names of licensors or
+    authors of the material; or
+    e) Declining to grant rights under trademark law for use of some
+    trade names, trademarks, or service marks; or
+    f) Requiring indemnification of licensors and authors of that
+    material by anyone who conveys the material (or modified versions of
+    it) with contractual assumptions of liability to the recipient, for
+    any liability that these contractual assumptions directly impose on
+    those licensors and authors.
+  All other non-permissive additional terms are considered "further
+restrictions" within the meaning of section 10.  If the Program as you
+received it, or any part of it, contains a notice stating that it is
+governed by this License along with a term that is a further
+restriction, you may remove that term.  If a license document contains
+a further restriction but permits relicensing or conveying under this
+License, you may add to a covered work material governed by the terms
+of that license document, provided that the further restriction does
+not survive such relicensing or conveying.
+  If you add terms to a covered work in accord with this section, you
+must place, in the relevant source files, a statement of the
+additional terms that apply to those files, or a notice indicating
+where to find the applicable terms.
+  Additional terms, permissive or non-permissive, may be stated in the
+form of a separately written license, or stated as exceptions;
+the above requirements apply either way.
+  8. Termination.
+  You may not propagate or modify a covered work except as expressly
+provided under this License.  Any attempt otherwise to propagate or
+modify it is void, and will automatically terminate your rights under
+this License (including any patent licenses granted under the third
+paragraph of section 11).
+  However, if you cease all violation of this License, then your
+license from a particular copyright holder is reinstated (a)
+provisionally, unless and until the copyright holder explicitly and
+finally terminates your license, and (b) permanently, if the copyright
+holder fails to notify you of the violation by some reasonable means
+prior to 60 days after the cessation.
+  Moreover, your license from a particular copyright holder is
+reinstated permanently if the copyright holder notifies you of the
+violation by some reasonable means, this is the first time you have
+received notice of violation of this License (for any work) from that
+copyright holder, and you cure the violation prior to 30 days after
+your receipt of the notice.
+  Termination of your rights under this section does not terminate the
+licenses of parties who have received copies or rights from you under
+this License.  If your rights have been terminated and not permanently
+reinstated, you do not qualify to receive new licenses for the same
+material under section 10.
+  9. Acceptance Not Required for Having Copies.
+  You are not required to accept this License in order to receive or
+run a copy of the Program.  Ancillary propagation of a covered work
+occurring solely as a consequence of using peer-to-peer transmission
+to receive a copy likewise does not require acceptance.  However,
+nothing other than this License grants you permission to propagate or
+modify any covered work.  These actions infringe copyright if you do
+not accept this License.  Therefore, by modifying or propagating a
+covered work, you indicate your acceptance of this License to do so.
+  10. Automatic Licensing of Downstream Recipients.
+  Each time you convey a covered work, the recipient automatically
+receives a license from the original licensors, to run, modify and
+propagate that work, subject to this License.  You are not responsible
+for enforcing compliance by third parties with this License.
+  An "entity transaction" is a transaction transferring control of an
+organization, or substantially all assets of one, or subdividing an
+organization, or merging organizations.  If propagation of a covered
+work results from an entity transaction, each party to that
+transaction who receives a copy of the work also receives whatever
+licenses to the work the party's predecessor in interest had or could
+give under the previous paragraph, plus a right to possession of the
+Corresponding Source of the work from the predecessor in interest, if
+the predecessor has it or can get it with reasonable efforts.
+  You may not impose any further restrictions on the exercise of the
+rights granted or affirmed under this License.  For example, you may
+not impose a license fee, royalty, or other charge for exercise of
+rights granted under this License, and you may not initiate litigation
+(including a cross-claim or counterclaim in a lawsuit) alleging that
+any patent claim is infringed by making, using, selling, offering for
+sale, or importing the Program or any portion of it.
+  11. Patents.
+  A "contributor" is a copyright holder who authorizes use under this
+License of the Program or a work on which the Program is based.  The
+work thus licensed is called the contributor's "contributor version".
+  A contributor's "essential patent claims" are all patent claims
+owned or controlled by the contributor, whether already acquired or
+hereafter acquired, that would be infringed by some manner, permitted
+by this License, of making, using, or selling its contributor version,
+but do not include claims that would be infringed only as a
+consequence of further modification of the contributor version.  For
+purposes of this definition, "control" includes the right to grant
+patent sublicenses in a manner consistent with the requirements of
 this License.
-  7. If, as a consequence of a court judgment or allegation of patent
-infringement or for any other reason (not limited to patent issues),
-conditions are imposed on you (whether by court order, agreement or
+  Each contributor grants you a non-exclusive, worldwide, royalty-free
+patent license under the contributor's essential patent claims, to
+make, use, sell, offer for sale, import and otherwise run, modify and
+propagate the contents of its contributor version.
+  In the following three paragraphs, a "patent license" is any express
+agreement or commitment, however denominated, not to enforce a patent
+(such as an express permission to practice a patent or covenant not to
+sue for patent infringement).  To "grant" such a patent license to a
+party means to make such an agreement or commitment not to enforce a
+patent against the party.
+  If you convey a covered work, knowingly relying on a patent license,
+and the Corresponding Source of the work is not available for anyone
+to copy, free of charge and under the terms of this License, through a
+publicly available network server or other readily accessible means,
+then you must either (1) cause the Corresponding Source to be so
+available, or (2) arrange to deprive yourself of the benefit of the
+patent license for this particular work, or (3) arrange, in a manner
+consistent with the requirements of this License, to extend the patent
+license to downstream recipients.  "Knowingly relying" means you have
+actual knowledge that, but for the patent license, your conveying the
+covered work in a country, or your recipient's use of the covered work
+in a country, would infringe one or more identifiable patents in that
+country that you have reason to believe are valid.
+  If, pursuant to or in connection with a single transaction or
+arrangement, you convey, or propagate by procuring conveyance of, a
+covered work, and grant a patent license to some of the parties
+receiving the covered work authorizing them to use, propagate, modify
+or convey a specific copy of the covered work, then the patent license
+you grant is automatically extended to all recipients of the covered
+work and works based on it.
+  A patent license is "discriminatory" if it does not include within
+the scope of its coverage, prohibits the exercise of, or is
+conditioned on the non-exercise of one or more of the rights that are
+specifically granted under this License.  You may not convey a covered
+work if you are a party to an arrangement with a third party that is
+in the business of distributing software, under which you make payment
+to the third party based on the extent of your activity of conveying
+the work, and under which the third party grants, to any of the
+parties who would receive the covered work from you, a discriminatory
+patent license (a) in connection with copies of the covered work
+conveyed by you (or copies made from those copies), or (b) primarily
+for and in connection with specific products or compilations that
+contain the covered work, unless you entered into that arrangement,
+or that patent license was granted, prior to 28 March 2007.
+  Nothing in this License shall be construed as excluding or limiting
+any implied license or other defenses to infringement that may
+otherwise be available to you under applicable patent law.
+  12. No Surrender of Others' Freedom.
+  If conditions are imposed on you (whether by court order, agreement or
 otherwise) that contradict the conditions of this License, they do not
-excuse you from the conditions of this License.  If you cannot
-distribute so as to satisfy simultaneously your obligations under this
-License and any other pertinent obligations, then as a consequence you
-may not distribute the Program at all.  For example, if a patent
-license would not permit royalty-free redistribution of the Program by
-all those who receive copies directly or indirectly through you, then
-the only way you could satisfy both it and this License would be to
-refrain entirely from distribution of the Program.
+excuse you from the conditions of this License.  If you cannot convey a
+covered work so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you may
+not convey it at all.  For example, if you agree to terms that obligate you
+to collect a royalty for further conveying from those to whom you convey
+the Program, the only way you could satisfy both those terms and this
+License would be to refrain entirely from conveying the Program.
-If any portion of this section is held invalid or unenforceable under
-any particular circumstance, the balance of the section is intended to
-apply and the section as a whole is intended to apply in other
-circumstances.
+  13. Use with the GNU Affero General Public License.
-It is not the purpose of this section to induce you to infringe any
-patents or other property right claims or to contest validity of any
-such claims; this section has the sole purpose of protecting the
-integrity of the free software distribution system, which is
-implemented by public license practices.  Many people have made
-generous contributions to the wide range of software distributed
-through that system in reliance on consistent application of that
-system; it is up to the author/donor to decide if he or she is willing
-to distribute software through any other system and a licensee cannot
-impose that choice.
+  Notwithstanding any other provision of this License, you have
+permission to link or combine any covered work with a work licensed
+under version 3 of the GNU Affero General Public License into a single
+combined work, and to convey the resulting work.  The terms of this
+License will continue to apply to the part which is the covered work,
+but the special requirements of the GNU Affero General Public License,
+section 13, concerning interaction through a network will apply to the
+combination as such.
-This section is intended to make thoroughly clear what is believed to
-be a consequence of the rest of this License.
-  8. If the distribution and/or use of the Program is restricted in
-certain countries either by patents or by copyrighted interfaces, the
-original copyright holder who places the Program under this License
-may add an explicit geographical distribution limitation excluding
-those countries, so that distribution is permitted only in or among
-countries not thus excluded.  In such case, this License incorporates
-the limitation as if written in the body of this License.
+  14. Revised Versions of this License.
-  9. The Free Software Foundation may publish revised and/or new versions
-of the General Public License from time to time.  Such new versions will
+  The Free Software Foundation may publish revised and/or new versions of
+the GNU General Public License from time to time.  Such new versions will
 be similar in spirit to the present version, but may differ in detail to
 address new problems or concerns.
-Each version is given a distinguishing version number.  If the Program
-specifies a version number of this License which applies to it and "any
-later version", you have the option of following the terms and conditions
-either of that version or of any later version published by the Free
-Software Foundation.  If the Program does not specify a version number of
-this License, you may choose any version ever published by the Free Software
-Foundation.
+  Each version is given a distinguishing version number.  If the
+Program specifies that a certain numbered version of the GNU General
+Public License "or any later version" applies to it, you have the
+option of following the terms and conditions either of that numbered
+version or of any later version published by the Free Software
+Foundation.  If the Program does not specify a version number of the
+GNU General Public License, you may choose any version ever published
+by the Free Software Foundation.
-  10. If you wish to incorporate parts of the Program into other free
-programs whose distribution conditions are different, write to the author
-to ask for permission.  For software which is copyrighted by the Free
-Software Foundation, write to the Free Software Foundation; we sometimes
-make exceptions for this.  Our decision will be guided by the two goals
-of preserving the free status of all derivatives of our free software and
-of promoting the sharing and reuse of software generally.
+  If the Program specifies that a proxy can decide which future
+versions of the GNU General Public License can be used, that proxy's
+public statement of acceptance of a version permanently authorizes you
+to choose that version for the Program.
-			    NO WARRANTY
+  Later license versions may give you additional or different
+permissions.  However, no additional obligations are imposed on any
+author or copyright holder as a result of your choosing to follow a
+later version.
-  11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY
-FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.  EXCEPT WHEN
-OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
-PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
-OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
-MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.  THE ENTIRE RISK AS
-TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU.  SHOULD THE
-PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING,
-REPAIR OR CORRECTION.
+  15. Disclaimer of Warranty.
-  12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
-WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
-REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
-INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
-OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED
-TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY
-YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
-PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
-POSSIBILITY OF SUCH DAMAGES.
+  THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY
+APPLICABLE LAW.  EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT
+HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY
+OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO,
+THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM
+IS WITH YOU.  SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF
+ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
-		     END OF TERMS AND CONDITIONS
-	    How to Apply These Terms to Your New Programs
+  16. Limitation of Liability.
+  IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
+WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MODIFIES AND/OR CONVEYS
+THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY
+GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE
+USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF
+DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD
+PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS),
+EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF
+SUCH DAMAGES.
+  17. Interpretation of Sections 15 and 16.
+  If the disclaimer of warranty and limitation of liability provided
+above cannot be given local legal effect according to their terms,
+reviewing courts shall apply local law that most closely approximates
+an absolute waiver of all civil liability in connection with the
+Program, unless a warranty or assumption of liability accompanies a
+copy of the Program in return for a fee.
+                     END OF TERMS AND CONDITIONS
+            How to Apply These Terms to Your New Programs
   If you develop a new program, and you want it to be of the greatest
 possible use to the public, the best way to achieve this is to make it
 free software which everyone can redistribute and change under these terms.
   To do so, attach the following notices to the program.  It is safest
 to attach them to the start of each source file to most effectively
-convey the exclusion of warranty; and each file should have at least
+state the exclusion of warranty; and each file should have at least
 the "copyright" line and a pointer to where the full notice is found.
     <one line to give the program's name and a brief idea of what it does.>
     Copyright (C) <year>  <name of author>
-    This program is free software; you can redistribute it and/or modify
+    This program is free software: you can redistribute it and/or modify
     it under the terms of the GNU General Public License as published by
-    the Free Software Foundation; either version 2 of the License, or
+    the Free Software Foundation, either version 3 of the License, or
     (at your option) any later version.
     This program is distributed in the hope that it will be useful,
@@ -304,37 +645,30 @@
     GNU General Public License for more details.
     You should have received a copy of the GNU General Public License
-    along with this program; if not, write to the Free Software
-    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+    along with this program.  If not, see <http://www.gnu.org/licenses/>.
 Also add information on how to contact you by electronic and paper mail.
-If the program is interactive, make it output a short notice like this
-when it starts in an interactive mode:
+  If the program does terminal interaction, make it output a short
+notice like this when it starts in an interactive mode:
-    Gnomovision version 69, Copyright (C) year name of author
-    Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
+    <program>  Copyright (C) <year>  <name of author>
+    This program comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
     This is free software, and you are welcome to redistribute it
     under certain conditions; type `show c' for details.
 The hypothetical commands `show w' and `show c' should show the appropriate
-parts of the General Public License.  Of course, the commands you use may
-be called something other than `show w' and `show c'; they could even be
-mouse-clicks or menu items--whatever suits your program.
+parts of the General Public License.  Of course, your program's commands
+might be different; for a GUI interface, you would use an "about box".
-You should also get your employer (if you work as a programmer) or your
-school, if any, to sign a "copyright disclaimer" for the program, if
-necessary.  Here is a sample; alter the names:
+  You should also get your employer (if you work as a programmer) or school,
+if any, to sign a "copyright disclaimer" for the program, if necessary.
+For more information on this, and how to apply and follow the GNU GPL, see
+<http://www.gnu.org/licenses/>.
-  Yoyodyne, Inc., hereby disclaims all copyright interest in the program
-  `Gnomovision' (which makes passes at compilers) written by James Hacker.
-  <signature of Ty Coon>, 1 April 1989
-  Ty Coon, President of Vice
-This General Public License does not permit incorporating your program into
-proprietary programs.  If your program is a subroutine library, you may
-consider it more useful to permit linking proprietary applications with the
-library.  If this is what you want to do, use the GNU Library General
-Public License instead of this License.
+  The GNU General Public License does not permit incorporating your program
+into proprietary programs.  If your program is a subroutine library, you
+may consider it more useful to permit linking proprietary applications with
+the library.  If this is what you want to do, use the GNU Lesser General
+Public License instead of this License.  But first, please read
+<http://www.gnu.org/philosophy/why-not-lgpl.html>.
Modified: branches/kmq_dev/license/gpl_short.txt
--- branches/kmq_dev/license/gpl_short.txt	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/license/gpl_short.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,15 +1,16 @@
-# Copyright (C) 2002 CCGIS
+#   Copyright 2009 Open Source Geospatial Foundation
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
+#   This file is part of Mapbender.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
+#   Mapbender is free software: you can redistribute it and/or modify
+#   it under the terms of the GNU General Public License as published by
+#   the Free Software Foundation, either version 3 of the License, or
+#   (at your option) any later version.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#   Mapbender is distributed in the hope that it will be useful,
+#   but WITHOUT ANY WARRANTY; without even the implied warranty of
+#   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#   GNU General Public License for more details.
+#   You should have received a copy of the GNU General Public License
+#   along with Mapbender.  If not, see <http://www.gnu.org/licenses/>.
Modified: branches/kmq_dev/license/licence_reference.txt
--- branches/kmq_dev/license/licence_reference.txt	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/license/licence_reference.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,6 +1,5 @@
-Licensing: See the GNU General Public License for more details.
-http://www.gnu.org/copyleft/gpl.html
-or:
-mapbender/licence/
+Copyright 2009, Open Source Geospatial Foundation. All rights reserved.
+This program is dual licensed under the GNU General Public License and Simplified BSD license:
+http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
\ No newline at end of file
Copied: branches/kmq_dev/license/license.txt (from rev 4267, trunk/mapbender/license/license.txt)
--- branches/kmq_dev/license/license.txt	                        (rev 0)
+++ branches/kmq_dev/license/license.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,45 @@
+# Copyright 2009, Open Source Geospatial Foundation. All rights reserved.
+# This program is dual licensed under the GNU General Public License:
+# http://svn.mapbender.org/trunk/mapbender/gpl.txt
+# and Simplified BSD license:
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/simplified_bsd.txt
+#######################  GNU General Public License  ########################
+#######################    Simplified BSD License    ########################
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+#    * Redistributions of source code must retain the above copyright
+#      notice, this list of conditions and the following disclaimer.
+#    * Redistributions in binary form must reproduce the above copyright
+#      notice, this list of conditions and the following disclaimer in the
+#      documentation and/or other materials provided with the
+#      distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
+# IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+# TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+# PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+# HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+# TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+# LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+# NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+# http://opensource.org/licenses/bsd-license.php
Modified: branches/kmq_dev/license/license_js.txt
--- branches/kmq_dev/license/license_js.txt	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/license/license_js.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -1,2 +1,4 @@
-/* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-*  License (>=v2). Read the file COPYING that comes with Mapbender for details. */
+/* Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
Copied: branches/kmq_dev/license/simplified_bsd.txt (from rev 4267, trunk/mapbender/license/simplified_bsd.txt)
--- branches/kmq_dev/license/simplified_bsd.txt	                        (rev 0)
+++ branches/kmq_dev/license/simplified_bsd.txt	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,25 @@
+#   All rights reserved.
+#   met:
+#        distribution.
Copied: branches/kmq_dev/resources/db/install_2.6.sh (from rev 4267, trunk/mapbender/resources/db/install_2.6.sh)
--- branches/kmq_dev/resources/db/install_2.6.sh	                        (rev 0)
+++ branches/kmq_dev/resources/db/install_2.6.sh	2009-07-01 14:40:19 UTC (rev 4271)
@@ -0,0 +1,225 @@
+#!/bin/bash
+rm log_*.txt
+# Disclaimer
+echo ""
+echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+echo "The script will create a database for you and will import the Mapbender data to the new database"
+echo "It will also compile the Mapbender.mo files"
+echo ""
+echo "To run this script you have to set the following options"
+# echo " * set the right to execute on this install script"
+# echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
+# echo " * write access to mapbender/log"
+# echo " * write access to mapbender/http/tmp"
+# echo " * write access to mapbender/resources/locale/ and subdirectories"
+echo " * provide a database user that can create a database"
+echo ""
+echo ""
+echo "If everything is prepared you can continue."
+echo ""
+echo "Continue? (y)es or (n)o"
+read disclaimer
+if test $disclaimer != "y"
+then
+	exit 1
+fi
+# ask for db version
+echo ""
+echo "Database version? (p)ostgresql or (m)ysql?"
+read dbversion
+if test $dbversion != "p" -a $dbversion != "m"
+then
+	echo ""
+	echo "Incorrect database type. Terminating the script..."
+	exit 1
+fi
+# ask for db character encoding-U $dbuser
+echo ""
+echo "Database character encoding? (i)so-8859-1 or (u)tf-8?"
+read dbenc
+if test $dbenc != "i" -a $dbenc != "u"
+then
+	echo ""
+	echo "Incorrect database character encoding. Terminating the script..."
+	exit 1
+fi
+# ask for database name
+echo ""
+echo "Name of database?"
+read dbname
+if test $dbversion = "m"
+then
+	echo "Not available!!!"
+	exit 1
+	echo ""
+	echo "Enter your MySQL password:"
+	stty -echo
+	read password
+	stty echo
+	echo ""
+	if test $dbenc = "i"
+	then
+		echo ""
+		echo "Installing Mapbender with MySQL (ISO-8859-1) in database $dbname";
+		echo ""
+		mysql -e "create database $dbname CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$password
+		mysql $dbname -p$password < mysql/mysql_schema_2.5.sql > log_schema.txt
+		mysql $dbname -p$password < mysql/ISO-8859-1/mysql_data_2.5.sql > log_data.txt
+		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql > log_update.txt
+		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql > log_update.txt
+		mysql $dbname -p$password < mysql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_mysql_ISO-8859-1.sql > log_update.txt
+	elif test $dbenc = "u"
+	then
+		echo ""
+		echo "Installing Mapbender with MySQL (UTF-8) in database $dbname";
+		echo ""
+		mysql -e "create database $dbname CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$password
+		mysql $dbname -p$password < mysql/UTF-8/mysql_data_2.5.sql > log_data.txt
+		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql > log_update.txt
+		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql > log_update.txt
+		mysql $dbname -p$password < mysql/UTF-8/update/update_2.5.1_to_2.6rc1_mysql_UTF-8.sql > log_update.txt
+	fi
+elif test $dbversion = "p" -a $dbenc = "i"
+then
+	#Creating database user with rw access
+	echo "Please specify a user for the database"
+	read mapbenderuser
+    	echo ""
+	    echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
+	    echo ""
+        # ask for database user
+        echo ""
+        echo "Name of database user?"
+        read dbuser
+        #ask for database template
+        echo ""
+        echo "Do you want to use a database template? (y)es or (n)o "
+        read dbtemplateuse
+        if test $dbtemplateuse = "y"
+        then
+           #ask for template name
+           echo ""
+           echo "Name of the template?"
+           read dbtemplate
+        fi
+        if test dbtemplate != ""
+        then
+           createdb -U $dbuser -E ISO-8859-1 $dbname -T $dbtemplate
+        else
+        fi
+	psql -U $dbuser -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
+	psql -U $dbuser -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
+	psql -U $dbuser -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
+	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+	psql -U $dbuser -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+elif test $dbversion = "p" -a $dbenc = "u"
+then
+	echo ""
+	echo "Installing Mapbender with PostgreSQL (UTF-8) in database $dbname";
+	echo ""
+        echo ""
+        read dbuser
+        echo ""
+        then
+           echo ""
+           read dbtemplate
+        fi
+    echo "The script will ask you several times for your database password. Don't be confused about this."
+        if test $dbtemplate != ""
+        then
+           createdb -U $dbuser -E UTF-8 $dbname -T $dbtemplate
+        else
+        fi
+	psql -U $dbuser -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
+	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
+	psql -U $dbuser -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+	psql -U $dbuser -f pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql $dbname > log_update.txt
+fi
+echo "The installer can set the permissions to the files"
+echo "and directory for you. If you want the installer to"
+echo "do this please enter (y)es else (n)o"
+echo "Please note, to do this you have to be"
+echo "read write access to the Mapbender directory"
+read automatic
+if test $automatic != "n"
+then
+      echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
+      read setowner
+      if test $setowner != "n"
+      then
+	    echo "Please specify the webserver user"
+	    read webservuser
+	    chown -R $webservuser:$webservuser ../../
+      fi
+      echo "setting permissions on /resources/locale/ and subdirectories"
+      chmod -R o+rw ../locale
+      echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
+      chmod -R o+rx ../../tools/i18n_update_mo.sh
+      # creating mapbender.conf
+      cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
+fi
+echo ""
+echo "Compiling .po files..."
+cd ../../tools/
+./i18n_update_mo.sh
+cd ../resources/db/
+echo "removing permissions on /resources/locale/ and subdirectories"
+chmod -R o-rw ../locale
+echo "removing execute rights on mapbender/tools/i18n_update_mo.sh"
+chmod -R o-rx ../../tools/i18n_update_mo.sh
+echo ""
+echo ""
+echo "Finished...check the log files to see if an error occured.";
Modified: branches/kmq_dev/resources/db/install_2.6rc1.sh
--- branches/kmq_dev/resources/db/install_2.6rc1.sh	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/resources/db/install_2.6rc1.sh	2009-07-01 14:40:19 UTC (rev 4271)
@@ -6,7 +6,20 @@
 # Disclaimer
 echo ""
+echo "The script will create a database for you and will import the Mapbender datat to the new database"
 echo ""
+echo " * set the right to execute on this install script"
+echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
+echo " * write access to mapbender/log"
+echo " * write access to mapbender/http/tmp"
+echo " * write access to mapbender/resources/locale/ and subdirectories"
+echo ""
+echo ""
+echo ""
 read disclaimer
@@ -27,7 +40,7 @@
 	exit 1
 fi
-# ask for db character encoding
 echo ""
 read dbenc
@@ -86,31 +99,83 @@
 	fi
 then
-	echo "Not available!!!"
-	exit 1
-	echo ""
-	echo "Installing Mapbender with PostgreSQL (ISO-8859-1) in database $dbname";
-	echo ""
-	createdb -E ISO-8859-1 $dbname
-	psql -f pgsql/pgsql_schema_2.5.sql $dbname > log_schema.txt
-	psql -f pgsql/ISO-8859-1/pgsql_data_2.5.sql $dbname > log_data.txt
-	psql -f pgsql/pgsql_serial_set_sequences_2.5.sql $dbname > log_sequences.txt
-	psql -f pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
-	psql -f pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
-	psql -f pgsql/ISO-8859-1/update/update_2.5.1_to_2.6rc1_pgsql_ISO-8859-1.sql $dbname > log_update.txt
+    	echo ""
+	    echo ""
+        echo ""
+        read dbuser
+        echo ""
+        then
+           echo ""
+           read dbtemplate
+        fi
+        then
+        else
+        fi
 then
 	echo ""
 	echo ""
-	createdb -E UTF-8 $dbname
-	psql -f pgsql/UTF-8/pgsql_data_2.5.sql $dbname > log_data.txt
-	psql -f pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql $dbname > log_update.txt
-	psql -f pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql $dbname > log_update.txt
-	psql -f pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql $dbname > log_update.txt
+        echo ""
+        read dbuser
+        echo ""
+        then
+           echo ""
+           read dbtemplate
+        fi
+        then
+        else
+        fi
 fi
 echo ""
@@ -119,4 +184,4 @@
 ./i18n_update_mo.sh
 echo ""
 echo ""
-echo "Finished...check the log files to see if an error occured.";
Modified: branches/kmq_dev/resources/db/update/update_2.7.sql
--- branches/kmq_dev/resources/db/update/update_2.7.sql	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/resources/db/update/update_2.7.sql	2009-07-01 14:40:19 UTC (rev 4271)
@@ -79,4 +79,9 @@
 ALTER TABLE wfs_conf_element ADD COLUMN
 f_category_name varchar(255) NOT NULL DEFAULT '';
+-- reload uses Mapbender API
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
+-- body uses Mapbender API
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body'
Modified: branches/kmq_dev/sql/insert_wfs_conf_element.sql
--- branches/kmq_dev/sql/insert_wfs_conf_element.sql	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/sql/insert_wfs_conf_element.sql	2009-07-01 14:40:19 UTC (rev 4271)
@@ -16,10 +16,11 @@
 	f_auth_varname,
 	f_operator,
 	f_show_detail,
+	f_detailpos,
 	f_min_input,
 	f_helptext,
 	f_category_name
 ) VALUES (
 	$1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12,
-	$13, $14, $15, $16, $17, $18, $19, $20
+	$13, $14, $15, $16, $17, $18, $19, $20, $21
Modified: branches/kmq_dev/sql/update_wfs_conf_element.sql
--- branches/kmq_dev/sql/update_wfs_conf_element.sql	2009-07-01 14:37:04 UTC (rev 4270)
+++ branches/kmq_dev/sql/update_wfs_conf_element.sql	2009-07-01 14:40:19 UTC (rev 4271)
@@ -14,7 +14,8 @@
 f_auth_varname = $13,
 f_operator = $14,
 f_show_detail = $15,
-f_min_input = $16,
-f_helptext = $17,
-f_category_name = $18
-WHERE f_id = $19
+f_detailpos = $16,
+f_min_input = $17,
+f_helptext = $18,
+f_category_name = $19
+WHERE f_id = $20 AND fkey_wfs_conf_id = $21
More information about the Mapbender_commits mailing list
