[Mapbender-commits] r4298 - branches/mifan_dev/mapbender/http/php
svn_mapbender at osgeo.org
Fri Jul 3 15:37:38 EDT 2009
Author: mifan
Date: 2009-07-03 15:37:38 -0400 (Fri, 03 Jul 2009)
New Revision: 4298
branches/mifan_dev/mapbender/http/php/mod_loadCatalogCapabilities.php
more admin func. to add catalogs
Modified: branches/mifan_dev/mapbender/http/php/mod_loadCatalogCapabilities.php
--- branches/mifan_dev/mapbender/http/php/mod_loadCatalogCapabilities.php 2009-07-03 19:31:07 UTC (rev 4297)
+++ branches/mifan_dev/mapbender/http/php/mod_loadCatalogCapabilities.php 2009-07-03 19:37:38 UTC (rev 4298)
@@ -65,3 +65,111 @@
</style>
+<script language="JavaScript">
+function validate(wert){
+ if(wert == 'guiList'){
+ var listIndex = document.form1.guiList.selectedIndex;
+ if(listIndex<0){
+ alert("Please select a GUI.");
+ return false;
+ else{
+ var gui_id=document.form1.guiList.options[listIndex].value;
+ document.form1.action = '../php/mod_loadwms.php?<?php echo $urlParameters ?>';
+ document.form1.submit();
+</script>
+</head>
+<body>
+<?php
+//Get GUIs for present user
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<table cellpadding='0' cellspacing='0' border='0'>";
+echo "<tr>";
+echo "<td>";
+if (count($ownguis)>0){
+ echo"GUI";
+ echo"<br>";
+ $v = array();
+ $t = array();
+ $sql = "SELECT * FROM gui WHERE gui_id IN (";
+ for($i=0; $i<count($ownguis); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "$".($i+1);
+ array_push($v,$ownguis[$i]);
+ array_push($t,'s');
+ $sql .= ") ORDER BY gui_name";
+ $res = db_prep_query($sql,$v,$t);
+ echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
+ while($row = db_fetch_array($res)){
+ echo "<option value='".$row["gui_id"]."' ";
+ if($guiList && $guiList == $row["gui_name"]){
+ echo "selected";
+ echo ">".$row["gui_name"]."</option>";
+ $arrayGUIs=$_SESSION["mb_user_guis"];
+ echo count($arrayGUIs);
+ echo "</select><br><br>";
+ echo "</td>";
+ echo "<td>";
+ echo"CATALOG";
+ echo"<br>";
+ //Change to catalog tables: mif
+ if(isset($guiList) && $guiList!=""){
+ $sql = "SELECT DISTINCT wms.wms_title,gui_wms_position from gui_wms JOIN ";
+ $sql .= "gui on gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id = wms.wms_id ";
+ $sql .= "and gui_wms.fkey_gui_id = gui.gui_id where gui.gui_name = $1 order by gui_wms_position";
+ $v = array($guiList);
+ $t = array('s');
+ $count=0;
+ echo"<select size='8' name='wmsList' style='width:200px'>";
+ if ($row["wms_title"]!=""){
+ echo "<option value='' ";
+ echo ">".$row["wms_title"]."</option>";
+ $count++;
+ else{
+ echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
+ echo "</td>";
+ echo "<tr></table><br>";
+ echo "Add the following REQUEST to the Online Resource URL to obtain the Capabilities document:<br>";
+ echo "<i>(Triple click to select and copy)</i><br>";
+ echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1<br>";
+ echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0<br>";
+ echo "REQUEST=capabilities&WMTVER=1.0.0<br><br>";
+ echo "Link to Catalog Capabilities URL:<br>";
+ if (isset($xml_file)){
+ echo"<input type='text' name='xml_file' size='50' value='".$xml_file."'>";
+ }else{
+ echo"<input type='text' name='xml_file' size='50' value='http://'>";
+ echo"<input type='button' name='loadCap' value='Load' onClick='validate(\"guiList\")'>";
+ echo "</form>";
+else{
+ echo "There are no guis available for this user. Please create a gui first.";
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
