[Mapbender-commits] r4309 -
branches/mifan_dev/mapbender/resources/db/pgsql
svn_mapbender at osgeo.org
Sun Jul 5 15:09:14 EDT 2009
Author: mifan
Date: 2009-07-05 15:09:14 -0400 (Sun, 05 Jul 2009)
New Revision: 4309
branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql
table to hold values of cat cap operations - getrecords in particular
Modified: branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql
--- branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql 2009-07-05 19:07:50 UTC (rev 4308)
+++ branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql 2009-07-05 19:09:14 UTC (rev 4309)
@@ -89,3 +89,23 @@
REFERENCES cat (cat_id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE CASCADE
+CREATE TABLE cat_op_conf
+ fk_cat_id integer NOT NULL,
+ param_name character varying(255) NOT NULL,
+ param_value text NOT NULL,
+ CONSTRAINT pk_cons PRIMARY KEY (fk_cat_id, param_name, param_value),
+ CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
+ REFERENCES cat (cat_id) MATCH SIMPLE
+ ON UPDATE CASCADE ON DELETE CASCADE
+WITH (OIDS=FALSE);
More information about the Mapbender_commits
