[Mapbender-commits] r4329 -
branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jul 9 09:11:58 EDT 2009
Author: mifan
Date: 2009-07-09 09:11:57 -0400 (Thu, 09 Jul 2009)
New Revision: 4329
branches/mifan_dev/mapbender/http/classes/class_csw.php
database entry
Modified: branches/mifan_dev/mapbender/http/classes/class_csw.php
--- branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-07-09 09:01:56 UTC (rev 4328)
+++ branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-07-09 13:11:57 UTC (rev 4329)
@@ -63,6 +63,9 @@
var $catowner;
var $cattimestamp;
+ var $providername;
+ var $providersite;
+ var $delivery='';
//store catalog retrieval status
var $cat_status;
@@ -106,7 +109,6 @@
//operational vars
$op_type=null; //get-capabilities, getrecords ...
$this->cat_getcapabilities_doc = $data;
$this->cat_upload_url = $url;
$this->cat_id="";//Auto-assing catalog id
@@ -131,9 +133,10 @@
foreach($value_array as $element){
//Version
echo "Print:";
- print_r($element);
+ //print_r($element);
print_r ($element);
echo "\n";
@@ -201,8 +204,6 @@
//Handle operational elements
//Open operational element
if((mb_strtoupper($element[tag]) == "OWS:OPERATION" OR mb_strtoupper($element[tag]) == "OPERATION") && $element[type] == "open"){
$op_type = $element[attributes][name];
@@ -233,9 +234,6 @@
$op_type = null;
//Success/Failure
@@ -270,55 +268,57 @@
public function setCatObjToDB($gui)
global $con;
- //db_begin();
- $sql = "INSERT INTO cat ()";
- echo "HELLO THERE";
+ $admin = new administration();//to char_encode XML
+ db_begin();
+ # INSERT INTO TABLE cat - auto insert cat_id
+ $sql = "INSERT INTO cat( ";
+ $sql .= "cat_version, cat_title, cat_abstract, cat_op_getcapabilities, ";
+ $sql .= "cat_op_describerecord, cat_op_getrecords, cat_op_getrecordbyid, ";
+ $sql .= "cat_upload_url, fees, accessconstraints, providername, providersite, ";
+ $sql .= "individualname, positionname, voice, facsimile, deliverypoint, ";
+ $sql .= "city, administrativearea, postalcode, country, electronicmailaddress, ";
+ $sql .= "cat_getcapabilities_doc, cat_owner, cat_timestamp) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25)";
+ $v = array($this->cat_version,$this->cat_title,$this->cat_abstract,$this->cat_op_getcapabilities,
+ $this->cat_op_describerecord,$this->cat_op_getrecords,$this->cat_op_getrecordbyid,
+ $this->cat_upload_url,$this->fees,$this->accessconstraints,$this->providername,$this->providersite,
+ $this->contactperson, $this->contactposition, $this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->delivery,
+ $this->city,$this->address,$this->postcode,$this->country,$this->contactelectronicmailaddress,
+ $admin->char_encode($this->cat_getcapabilities_doc),
+ $_SESSION['mb_user_id'],strtotime("now"));
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
+ echo $sql;
+ $cat_insert_id = db_insert_id($con,'cat', 'cat_id');
+ //Commit Changes
+ db_commit();
+ $this->cat_id = $cat_insert_id;
public function displayCatalog(){
- echo "<br>id: " . $this->wms_id . " <br>";
- echo "version: " . $this->cat_version . " <br>";
- echo "title: " . $this->cat_title . " <br>";
- echo "abstract: " . $this->cat_abstract . " <br>";
- echo "maprequest: " . $this->wms_getmap . " <br>";
- echo "capabilitiesrequest: " . $this->wms_getcapabilities . " <br>";
- echo "featureinforequest: " . $this->wms_getfeatureinfo . " <br>";
- echo "gui_wms_mapformat: " . $this->gui_wms_mapformat . " <br>";
- echo "gui_wms_featureinfoformat: " . $this->gui_wms_featureinfoformat . " <br>";
- echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
- echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
- echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
- echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
- echo "gui_wms_opacity: " . $this->gui_wms_opacity . " <br>";
- echo "support_sld: " . $this->wms_supportsld . " <br>";
+ echo "Catalog Details";
+ echo "<br>id: " . $this->cat_id . " <br>";
+ echo "Version: " . $this->cat_version . " <br>";
+ echo "Title: " . $this->cat_title . " <br>";
+ echo "Abstract: " . $this->cat_abstract . " <br>";
+ echo "Capabilitiesrequest: " . $this->cat_op_getcapabilities . " <br>";
+ echo "Getrecordsrequest: " . $this->cat_op_getrecords . " <br>";
+ echo "Getrecordbyidrequest: " . $this->cat_op_getrecordbyid . " <br>";
+ echo "Describerecord: " . $this->cat_op_describerecord . " <br>";
+ echo "<hr>";
- for($i=0; $i<count($this->data_type);$i++){
- echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
- for($i=0; $i<count($this->objLayer); $i++){
- echo "<hr>";
- echo "id: <b>".$this->objLayer[$i]->layer_id ."</b> parent: <b>".$this->objLayer[$i]->layer_parent."</b> name: <b>".$this->objLayer[$i]->layer_name;
- echo "</b> title: <b>".$this->objLayer[$i]->layer_title. "</b> queryable: <b>".$this->objLayer[$i]->layer_queryable."</b> minScale: <b>". $this->objLayer[$i]->layer_minscale."</b> maxScale: <b>".$this->objLayer[$i]->layer_maxscale."</b>";
- echo "<br>dataurl: <b>".$this->objLayer[$i]->layer_dataurl_href. "</b>";
- echo "<br>metadataurl: <b>".$this->objLayer[$i]->layer_metadataurl. "</b>";
- echo "<table border='1'>";
- for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
- echo "<tr><td>".$this->objLayer[$i]->layer_epsg[$j][epsg]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][minx]."</td>";
- echo "<td>".$this->objLayer[$i]->layer_epsg[$j][miny]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][maxx]."</td>";
- echo "<td>".$this->objLayer[$i]->layer_epsg[$j][maxy]."</td></tr>";
- echo "</table>";
- echo "layerstyle:";
- echo "<tr><td>name</td><td>title</td><td>legendurl</td><td>legendurlformat</td></tr>";
- for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
- echo "<tr><td>".$this->objLayer[$i]->layer_style[$j][name]."</td><td>".$this->objLayer[$i]->layer_style[$j][title]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurl]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurlformat]."</td></tr>";
- echo "</table>";
- echo "<hr>";
- echo "<hr>";
More information about the Mapbender_commits
