[Mapbender-commits] r4355 - branches/kmq_dev/http/javascripts
svn_mapbender at osgeo.org
Wed Jul 15 04:00:40 EDT 2009
Author: kmq
Date: 2009-07-15 04:00:39 -0400 (Wed, 15 Jul 2009)
New Revision: 4355
Added:
branches/kmq_dev/http/javascripts/mod_group.js
Group Editor, done slighlty different (better) than the UserEditor
Added: branches/kmq_dev/http/javascripts/mod_group.js
--- branches/kmq_dev/http/javascripts/mod_group.js (rev 0)
+++ branches/kmq_dev/http/javascripts/mod_group.js 2009-07-15 08:00:39 UTC (rev 4355)
@@ -0,0 +1,199 @@
+var ConfObject = function(options,fields) {
+ this.options = options;
+ this.fields = fields;
+ConfObject.prototype.load = function(key) {
+ var me = this;
+ var req = Mapbender.Ajax.Request({
+ url : me.options.url,
+ method : "load",
+ parameters : {
+ name : key
+ callback: function(){
+ throw("load needs a callback");
+ req.send();
+ConfObject.prototype.remove = function(){
+ var me = this;
+ method : "remove",
+ parameters : {
+ name : me.field.name
+ callback : function(){
+ throw("remove needs a callback");
+ req.send();
+ConfObject.prototype.update = function(){
+ var me = this;
+ method : "update",
+ parameters : {
+ name : me.fields.name,
+ fields : me.fields
+ throw("update needs a callback");
+ req.send();
+ConfObject.prototype.create = function(){
+ var me = this;
+ parameters : {
+ throw("create needs a callback");
+ req.send();
+ConfObject.prototype.setEditor = function(newEditor) {
+ this.editor = newEditor || null;
+var ConfEditor = function(){
+ alert("Please override the ConfEditor Constructor");
+ConfEditor.prototype.oad = function(key){
+ this.confObject = new ConfObject(this.options,this.fields);
+ if(!key)
+ //FIXME: i18n
+ this.confObject.fields.name = "New User";
+ this.clear();
+ this.display();
+ //FIXME: set something that would make "save" redirect to "create"\n\
+ //TODO: do something nicer
+ try{
+ this.confObject.load(key);
+ }catch(E){
+ alert(E);
+ConfEditor.prototype.remove = function(){
+ if(this.confObject)
+ try{
+ this.confObject.remove();
+ }catch(E){
+ alert(E);
+ }else{
+ //TODO: notify user
+ alert("can't remove: no user loaded");
+ConfEditor.prototype.save = function(){
+ if(this.confObject){
+ }else{
+ alert("cant save : no user loaded");
+ConfEditor.prototype.create = function(){
+ //see comments in display
+ for(var c = 0;c<this.fields.length;c++)
+ try{
+ this.fields[c].value = $('#' + options.id + this.fields[c].name);
+ }catch(E){
+ alert("Error trying to read fieldvalue " +E);
+ this.confObject.fields = this.fields;
+ this.confObject.create();
+ this.refresh();
+ConfEditor.prototype.refresh = function() {
+ this.confObject.load(this.confObject.name);
+ }else{
+ alert("can't refresh : no user loaded");
+ConfEditor.prototype.display = function(){
+ //form is a jQuery Object
+ //FIXME: this needs to differentiate between the different possible fieldtypes
+ try{
+ this.form.select('#' + options.id + this.fields[c].name).val(this.fields[c].defaultValue);
+ }catch(E){
+ alert("Error trying to set " +E);
+ConfEditor.prototype.reset = function(){
+ //see comments in display();
+ try{
+ }catch(E){
+ConfEditor.prototype.setList = function(newList) {
+ this.list = newList || null;
+var me = this;
+var GroupEditor = function(){
+ // chose the id to be of the form: options.id + <fieldname>
+ var form = $('<div> <h2>groupEditor</h2> <form> <input id="'+options.id + 'name" type="text" /> </div>');
+ this.fields = [];
+ this.fields.name = { name: "name", defaultValue : "", value: "", display: "Group Name", type: "text"};
+ this.fields.owner = { name: "owner", defaultValue : "", value:"", display: "Owner", type: "text"};
+ this.name = this.fields.name.value;
+ $(me).replaceWith(form);
+ me = form;
+ this.reset();
+GroupEditor.prototype = new ConfEditor();
+GroupEditor.prototype.constructor = GroupEditor;
+Mapbender.modules[options.id] = new GroupEditor();
More information about the Mapbender_commits
