[Mapbender-commits] r4386 - branches/mifan_dev/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 20 04:36:38 EDT 2009
Author: mifan
Date: 2009-07-20 04:36:38 -0400 (Mon, 20 Jul 2009)
New Revision: 4386
Added:
   branches/mifan_dev/mapbender/http/php/mod_loadCatalogToGUI.php
load a catalog to a gui
Added: branches/mifan_dev/mapbender/http/php/mod_loadCatalogToGUI.php
--- branches/mifan_dev/mapbender/http/php/mod_loadCatalogToGUI.php	                        (rev 0)
+++ branches/mifan_dev/mapbender/http/php/mod_loadCatalogToGUI.php	2009-07-20 08:36:38 UTC (rev 4386)
@@ -0,0 +1,307 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Link Catalog to GUI</title>
+<?php
+include '../include/dyn_css.php';
+<style type="text/css">
+  	body{
+      background-color: #ffffff;
+  		font-family: Arial, Helvetica, sans-serif;
+  		font-size : 12px;
+  		color: #808080
+  	.list_guis{
+  		font-size : 12px;
+  		color: #808080;
+.text1{
+   font-size : 15px;
+   position:absolute;
+   top:190px;
+.select1{
+   top:210px;
+   width:270px;
+.text2{
+   font-size : 15px;
+   top:190px;
+   left:300px;
+.select2{
+   top:210px;
+   left:300px;
+.getcapabilities{
+   font-size : 15px;
+   top:570px;
+</style>
+<script language="JavaScript">
+function validate(vals){
+   if(vals == 'guiList'){
+      var listIndex = document.form1.guiList.selectedIndex;
+      if(listIndex<0){
+		   alert("Please select a GUI.");
+			return false;
+      else{
+         var gui_id=document.form1.guiList.options[listIndex].value;
+			document.form1.action='../php/mod_loadCatalog.php<?php echo SID;?>';
+			document.form1.submit();
+function load(){
+      if(document.form1.guiList.selectedIndex<0){
+			return false;
+      var gui_ind = document.form1.guiList.selectedIndex;
+      var ind = document.form1.wmsID.selectedIndex;
+      var ind2 = document.form1.guiID_.selectedIndex;
+			var indexWMSList = document.form1.wmsID.selectedIndex;
+			var permission = true;
+			var selectedWmsId = document.form1.wmsID.options[document.form1.wmsID.selectedIndex].value;
+			for (i = 0; i < document.form1.wmsList.length; i++) {
+						if (document.form1.wmsList.options[i].value == selectedWmsId){
+							 permission = false;
+							 alert ('The WMS (' + selectedWmsId + ') is already loaded in this application.');
+							 break;
+  			if (permission) { // only check if permission is not false
+        	var loadConfirmed = confirm("Load " + document.form1.wmsID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
+          if(loadConfirmed){
+          else{
+             document.form1.guiID_.selectedIndex = -1;
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+###INSERT
+if(isset($wmsID) && isset($guiID_)){
+	$sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
+	$v = array($guiList);
+	$t = array('s');
+	$res_pos = db_prep_query($sql_pos,$v,$t);
+	if(db_result($res_pos,0,"my_gui_wms_position") > -1){
+		$gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
+	else{
+		$gui_wms_position = 0;
+	$sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+	$v = array($guiID_,$wmsID);
+	$t = array('s','i');
+	$res = db_prep_query($sql,$v,$t);
+	$cnt = 0;
+	while($row = db_fetch_array($res)){
+		$sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
+		$sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
+		$v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
+		$row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"],$row["gui_wms_opacity"],$row["gui_wms_sldurl"]);
+		$t = array('s','i','i','s','s','s','s','i','i','s');
+		db_prep_query($sql_ins,$v,$t);
+		$cnt++;
+	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
+	$v = array($guiID_, $wmsID);
+	$t = array("s", "i");
+	$res = db_prep_query($sql, $v, $t);
+	$cnt = 0;
+		$sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
+		$sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13)";
+		$v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
+		$row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
+		$row["gui_layer_maxscale"],$row["gui_layer_priority"],$row["gui_layer_style"],$row["gui_layer_wfs_featuretype"]);
+		$t = array('s','i','i','i','i','i','i','i','i','i','i','s','s');
+		$cnt++;
+echo "<form name='form1' action='" . $self."' method='post'>";
+echo "<table cellpadding='0' cellspacing='0' border='0'>";
+echo "<tr>";
+echo "<td>";
+if (count($ownguis)>0){
+	echo"GUI";
+	echo"<br>";
+	$sql = "SELECT * FROM gui WHERE gui_id IN (";
+	$v = $ownguis;
+	$t = array();
+	for ($i = 1; $i <= count($ownguis); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$".$i;
+		array_push($t, "s");
+	$sql .= ") ORDER BY gui_name";
+	$count=0;
+	echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
+		$gui_name[$count]=$row["gui_name"];
+		$gui_description[$count]=$row["gui_description"];
+		$count++;
+		echo "<option value='".$row["gui_id"]."' ";
+		if($guiList && $guiList == $row["gui_name"]){
+			echo "selected";
+		echo ">".$row["gui_name"]."</option>";
+	$arrayGUIs=$_SESSION["mb_user_guis"];
+	echo count($arrayGUIs);
+	echo "</select><br><br>";
+	echo "</td>";
+	echo "<td>";
+	echo"WMS";
+	echo"<br>";
+	if(isset($guiList) && $guiList!=""){
+		$sql = "SELECT DISTINCT wms_id, wms.wms_title, gui_wms_position FROM gui_wms ";
+		$sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
+		$sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
+		$t = array('s');
+		$count=0;
+		echo"<select size='8' name='wmsList' style='width:200px'>";
+			if ($row["wms_title"]!=""){
+				echo "<option value='".$row["wms_id"]."' ";
+				echo ">".$row["wms_title"]."</option>";
+			$count++;
+	}else{
+		echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
+	echo "</td>";
+	echo "<tr></table><br>";
+	echo"<div class='text1'>Load WMS</div>";
+	$sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
+	$sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
+	$v = $arrayGUIs;
+	$t = array();
+	for ($i = 1; $i <= count($arrayGUIs); $i++){
+		if ($i > 1) {
+			$sql .= ",";
+		$sql .= "$" . $i;
+	$sql .= ") ORDER BY wms.wms_title";
+	echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
+	$cnt = 0;
+		if($row["wms_owner"] == $_SESSION["mb_user_id"]){
+			echo "style='color:green' ";
+		else{
+			echo "style='color:red' ";
+		if(isset($wmsID) && $wmsID == $row["wms_id"]){
+			echo "selected";
+			$wms_getcapabilities = $row["wms_getcapabilities"];
+		$cnt++;
+	echo "</select>";
+	if(isset($wmsID)){
+		echo "<div class='text2'>FROM:</div>";
+		$sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
+		$v = array($wmsID);
+		$t = array("s");
+		echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
+		$cnt = 0;
+			echo "<option value='".$row["fkey_gui_id"]."' ";
+			echo ">".$row["fkey_gui_id"]."</option>";
+			$cnt++;
+	echo "</select>";
+echo "</form>";
+}else{
+	echo "There are no guis available for this user. Please create a gui first.";
+echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
+</body>
+</html>
More information about the Mapbender_commits mailing list
