[Mapbender-commits] r4388 -
branches/mifan_dev/mapbender/resources/db/pgsql
svn_mapbender at osgeo.org
Mon Jul 20 05:25:29 EDT 2009
Author: mifan
Date: 2009-07-20 05:25:29 -0400 (Mon, 20 Jul 2009)
New Revision: 4388
branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql
change to accomodate multiple cat op values
Modified: branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql
--- branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql 2009-07-20 09:22:06 UTC (rev 4387)
+++ branches/mifan_dev/mapbender/resources/db/pgsql/csw_schema_pgsql_2.8.sql 2009-07-20 09:25:29 UTC (rev 4388)
@@ -88,15 +88,14 @@
CREATE TABLE cat_op_conf
fk_cat_id integer NOT NULL,
- param_type character varying(255) NOT NULL,
param_name character varying(255) NOT NULL,
param_value text NOT NULL,
- CONSTRAINT pk_cons PRIMARY KEY (fk_cat_id, param_name, param_value),
+ param_type character varying(255) NOT NULL,
+ CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
REFERENCES cat (cat_id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE CASCADE
-WITH (OIDS=FALSE);
More information about the Mapbender_commits
